vtkFileSeriesWriter Class Reference
meta-writer for writing a file series using writers that are not time-aware. More...
#include <vtkFileSeriesWriter.h>
Inheritance diagram for vtkFileSeriesWriter:
Collaboration diagram for vtkFileSeriesWriter:
enum  DesiredOutputPrecision
vtkMTimeType GetMTime () override
 Return the MTime also considering the internal writer. More...
int Write ()
 Invoke the writer. More...
int ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
 see vtkAlgorithm for details More...
void SetInterpreter (vtkClientServerInterpreter *interp)
 Get/Set the interpreter to use to call methods on the writer. More...
virtual void SetWriter (vtkAlgorithm *)
 Set/get the internal writer. More...
virtual vtkAlgorithm * GetWriter ()
virtual void SetFileNameMethod (const char *)
 Name of the method used to set the file name of the internal writer. More...
virtual char * GetFileNameMethod ()
 Get/Set the name of the output file. More...
virtual char * GetFileName ()
virtual int GetWriteAllTimeSteps ()
 If Off, which is the default, only the current timestep is written. More...
virtual void SetWriteAllTimeSteps (int)
virtual void WriteAllTimeStepsOn ()
virtual void WriteAllTimeStepsOff ()
virtual bool GetWriteJsonMetaFile ()
 If true, write a .series json meta file when writing all time steps. More...
virtual void SetWriteJsonMetaFile (bool)
virtual void WriteJsonMetaFileOn ()
virtual void WriteJsonMetaFileOff ()
virtual char * GetFileNameSuffix ()
 Provides an option to pad the time step when writing out time series data. More...
virtual void SetFileNameSuffix (const char *)
virtual int GetMinTimeStep ()
 Sets a minimum timestep constraint on WriteAllTimeSteps. More...
virtual void SetMinTimeStep (int)
virtual int GetMaxTimeStep ()
 Sets a maximum timestep constraint on WriteAllTimeSteps. More...
virtual void SetMaxTimeStep (int)
virtual int GetTimeStepStride ()
 Sets a stride to write out time series. More...
virtual void SetTimeStepStride (int)
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkFileSeriesWriter * New ()
static vtkFileSeriesWriter * SafeDownCast (vtkObject *o)
static bool SuffixValidation (char *fileNameSuffix)
 Utility function for validating the file name suffix. More...
static vtkAlgorithm * New ()
 vtkFileSeriesWriter ()
 ~vtkFileSeriesWriter () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
 vtkDataObjectAlgorithm ()
 ~vtkDataObjectAlgorithm ()
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
vtkFileSeriesWriter is a meta-writer that enables writing a file series using writers that are not time-aware.
Definition at line 19 of file vtkFileSeriesWriter.h.
Definition at line 23 of file vtkFileSeriesWriter.h.
◆ vtkFileSeriesWriter()
vtkFileSeriesWriter::vtkFileSeriesWriter ( )
◆ ~vtkFileSeriesWriter()
vtkFileSeriesWriter::~vtkFileSeriesWriter ( )
static vtkFileSeriesWriter* vtkFileSeriesWriter::New ( )
virtual const char* vtkFileSeriesWriter::GetClassName ( )
static int vtkFileSeriesWriter::IsTypeOf ( const char *  type)
virtual int vtkFileSeriesWriter::IsA ( const char *  type)
static vtkFileSeriesWriter* vtkFileSeriesWriter::SafeDownCast ( vtkObject *  o)
void vtkFileSeriesWriter::PrintSelf ( ostream &  os,
◆ SetWriter()
virtual void vtkFileSeriesWriter::SetWriter ( vtkAlgorithm *  )
◆ GetWriter()
virtual vtkAlgorithm* vtkFileSeriesWriter::GetWriter ( )
◆ GetMTime()
vtkMTimeType vtkFileSeriesWriter::GetMTime ( )
◆ SetFileNameMethod()
virtual void vtkFileSeriesWriter::SetFileNameMethod ( const char *  )
By default, this is SetFileName.
◆ GetFileNameMethod()
virtual char* vtkFileSeriesWriter::GetFileNameMethod ( )
◆ SetFileName()
virtual void vtkFileSeriesWriter::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkFileSeriesWriter::GetFileName ( )
◆ Write()
int vtkFileSeriesWriter::Write ( )
Invoke the writer.
Returns 1 for success, 0 for failure.
◆ GetWriteAllTimeSteps()
virtual int vtkFileSeriesWriter::GetWriteAllTimeSteps ( )
If true the writer will write every timestep, or at least those within the range of min to max.
◆ SetWriteAllTimeSteps()
virtual void vtkFileSeriesWriter::SetWriteAllTimeSteps ( int  )
◆ WriteAllTimeStepsOn()
virtual void vtkFileSeriesWriter::WriteAllTimeStepsOn ( )
◆ WriteAllTimeStepsOff()
virtual void vtkFileSeriesWriter::WriteAllTimeStepsOff ( )
◆ GetWriteJsonMetaFile()
virtual bool vtkFileSeriesWriter::GetWriteJsonMetaFile ( )
Default is false.
◆ SetWriteJsonMetaFile()
virtual void vtkFileSeriesWriter::SetWriteJsonMetaFile ( bool  )
Default is false.
◆ WriteJsonMetaFileOn()
virtual void vtkFileSeriesWriter::WriteJsonMetaFileOn ( )
Default is false.
◆ WriteJsonMetaFileOff()
virtual void vtkFileSeriesWriter::WriteJsonMetaFileOff ( )
Default is false.
◆ GetFileNameSuffix()
virtual char* vtkFileSeriesWriter::GetFileNameSuffix ( )
Only allow this format: ABC%.Xd where ABC is an arbitrary string which may or may not exist and d must exist and d must be the last character '.' and X may or may not exist, X must be an integer if it exists. Default is nullptr.
◆ SetFileNameSuffix()
virtual void vtkFileSeriesWriter::SetFileNameSuffix ( const char *  )
◆ GetMinTimeStep()
virtual int vtkFileSeriesWriter::GetMinTimeStep ( )
◆ SetMinTimeStep()
virtual void vtkFileSeriesWriter::SetMinTimeStep ( int  )
◆ GetMaxTimeStep()
virtual int vtkFileSeriesWriter::GetMaxTimeStep ( )
If less than MinTimeStep, then the MaxTimeStep constraint is ignored (i.e. all time steps from MinTimeStep to the actual last time step are written out).
◆ SetMaxTimeStep()
virtual void vtkFileSeriesWriter::SetMaxTimeStep ( int  )
◆ GetTimeStepStride()
virtual int vtkFileSeriesWriter::GetTimeStepStride ( )
◆ SetTimeStepStride()
virtual void vtkFileSeriesWriter::SetTimeStepStride ( int  )
◆ ProcessRequest()
int vtkFileSeriesWriter::ProcessRequest ( vtkInformation *  ,
vtkInformationVector **  ,
◆ SetInterpreter()
void vtkFileSeriesWriter::SetInterpreter ( vtkClientServerInterpreter *  interp)
inline
Definition at line 128 of file vtkFileSeriesWriter.h.
◆ SuffixValidation()
static bool vtkFileSeriesWriter::SuffixValidation ( char *  fileNameSuffix)
◆ RequestInformation()
int vtkFileSeriesWriter::RequestInformation ( vtkInformation *  request,
overrideprotectedvirtual
◆ RequestUpdateExtent()
int vtkFileSeriesWriter::RequestUpdateExtent ( vtkInformation *  request,
◆ RequestData()
int vtkFileSeriesWriter::RequestData ( vtkInformation *  request,
