vtkContext2DScalarBarActor Class Reference
Custom scalar bar actor for ParaView that uses the Charts API. More...
#include <vtkContext2DScalarBarActor.h>
Inheritance diagram for vtkContext2DScalarBarActor:
Collaboration diagram for vtkContext2DScalarBarActor:
enum  { PrecedeScalarBar = 0, SucceedScalarBar }
enum  OutOfRangeType { BELOW_RANGE = 0, ABOVE_RANGE = 1 }
typedef vtkScalarBarActor Superclass
- Public Types inherited from vtkScalarBarActor
typedef vtkActor2D Superclass
- Public Types inherited from vtkActor2D
typedef vtkProp Superclass
- Public Types inherited from vtkProp
virtual void SetBackgroundColor (double, double, double, double)
 Set color of background to draw behind the color bar. More...
virtual void SetBackgroundColor (double [4])
virtual double * GetBackgroundColor ()
virtual void GetBackgroundColor (double &, double &, double &, double &)
virtual void GetBackgroundColor (double [4])
virtual void SetBackgroundPadding (double)
 Set the padding to add to the background rectangle past the contents of the color legend contents. More...
virtual double GetBackgroundPadding ()
void SetCustomLabel (vtkIdType index, double value)
 Set label for index. More...
int RenderOverlay (vtkViewport *viewport) override
 We only render in the overlay for the context scene. More...
int RenderOpaqueGeometry (vtkViewport *viewport) override
 Draw the scalar bar and annotation text to the screen. More...
void ReleaseGraphicsResources (vtkWindow *window) override
 Release any graphics resources that are being consumed by this actor. More...
virtual bool Paint (vtkContext2D *painter)
 Responsible for actually drawing the scalar bar. More...
vtkRectf GetBoundingRect ()
 Get the bounding rectangle of the scalar bar actor contents in display coordinates. More...
int GetEstimatedNumberOfAnnotations ()
 Get an estimated number of annotations emulating loosely the algorithm generating the annotations. More...
virtual int GetTitleJustification ()
 Set the title justification. More...
virtual void SetTitleJustification (int)
virtual void SetForceHorizontalTitle (bool)
 If this flag is on, the title will be drawn horizontally above the scalar bar. More...
virtual bool GetForceHorizontalTitle ()
virtual void ForceHorizontalTitleOn ()
virtual void ForceHorizontalTitleOff ()
virtual void SetScalarBarThickness (int)
 Set the scalar bar thickness. More...
virtual int GetScalarBarThickness ()
virtual void SetScalarBarLength (double)
 Set the scalar bar length. More...
virtual double GetScalarBarLength ()
virtual void SetDrawScalarBarOutline (bool)
 Enable drawing an outline around the scalar bar. More...
virtual bool GetDrawScalarBarOutline ()
virtual void DrawScalarBarOutlineOn ()
virtual void DrawScalarBarOutlineOff ()
virtual void SetScalarBarOutlineColor (double, double, double)
 Set the RGB color of the scalar bar outline. More...
virtual void SetScalarBarOutlineColor (double [3])
virtual double * GetScalarBarOutlineColor ()
virtual void GetScalarBarOutlineColor (double &, double &, double &)
virtual void GetScalarBarOutlineColor (double [3])
virtual void SetScalarBarOutlineThickness (int)
 Set the thickness of the scalar bar outline. More...
virtual int GetScalarBarOutlineThickness ()
virtual void SetReverseLegend (bool)
 Set whether the scalar bar is reversed ie from high to low instead of from low to high. More...
virtual bool GetReverseLegend ()
virtual void ReverseLegendOn ()
virtual void ReverseLegendOff ()
virtual int GetAutomaticLabelFormat ()
 If true (the default), the printf format used for the labels will be automatically generated to make the numbers best fit within the widget. More...
virtual void SetAutomaticLabelFormat (int)
virtual void AutomaticLabelFormatOn ()
virtual void AutomaticLabelFormatOff ()
virtual void SetAddRangeLabels (int)
 Set/get whether to add range labels or not. More...
virtual int GetAddRangeLabels ()
virtual void SetAutomaticAnnotations (int)
 Set whether annotions are automatically created according the number of discrete colors. More...
virtual int GetAutomaticAnnotations ()
virtual void AutomaticAnnotationsOn ()
virtual void AutomaticAnnotationsOff ()
virtual int GetAddRangeAnnotations ()
 Set whether the scalar data range endpoints (minimum and maximum) are added as annotations. More...
virtual void SetAddRangeAnnotations (int)
virtual void AddRangeAnnotationsOn ()
virtual void AddRangeAnnotationsOff ()
virtual void SetDrawTickMarks (bool)
 Set/get whether tick marks should be drawn. More...
virtual bool GetDrawTickMarks ()
virtual void SetRangeLabelFormat (const char *)
 Printf format for range labels. More...
virtual char * GetRangeLabelFormat ()
virtual void SetDataRangeLabelFormat (const char *)
virtual char * GetDataRangeLabelFormat ()
void SetNumberOfCustomLabels (vtkIdType numLabels)
 Set number of custom labels. More...
vtkIdType GetNumberOfCustomLabels ()
virtual void SetDrawDataRange (bool)
 If true, the ranges of the arrays linked to the scalar bar are displayed in the widget. More...
virtual bool GetDrawDataRange ()
virtual void DrawDataRangeOn ()
virtual void DrawDataRangeOff ()
virtual void SetDataRangeMin (double)
 Set/Get the minimum value of arrays linked to this scalar bar actor. More...
virtual double GetDataRangeMin ()
virtual void SetDataRangeMax (double)
 Set/Get the maximum value of arrays linked to this scalar bar actor. More...
virtual double GetDataRangeMax ()
- Public Member Functions inherited from vtkScalarBarActor
vtkScalarBarActor * NewInstance () const
virtual int HasTranslucentPolygonalGeometry ()
virtual void GetScalarBarRect (int rect[4], vtkViewport *viewport)
void ShallowCopy (vtkProp *prop)
virtual int RenderTranslucentPolygonalGeometry (vtkViewport *)
virtual void SetLookupTable (vtkScalarsToColors *)
virtual vtkScalarsToColors * GetLookupTable ()
virtual void SetUseOpacity (int)
virtual int GetUseOpacity ()
virtual void UseOpacityOn ()
virtual void UseOpacityOff ()
virtual void SetMaximumNumberOfColors (int)
virtual int GetMaximumNumberOfColors ()
virtual void SetNumberOfLabels (int)
virtual int GetNumberOfLabels ()
virtual void SetOrientation (int)
virtual int GetOrientation ()
void SetOrientationToHorizontal ()
void SetOrientationToVertical ()
virtual void SetTitleTextProperty (vtkTextProperty *p)
virtual vtkTextProperty * GetTitleTextProperty ()
virtual void SetLabelTextProperty (vtkTextProperty *p)
virtual vtkTextProperty * GetLabelTextProperty ()
virtual void SetAnnotationTextProperty (vtkTextProperty *p)
virtual vtkTextProperty * GetAnnotationTextProperty ()
virtual void SetLabelFormat (const char *)
virtual char * GetLabelFormat ()
virtual void SetTitle (const char *)
virtual char * GetTitle ()
virtual void SetComponentTitle (const char *)
virtual char * GetComponentTitle ()
virtual void SetTextureGridWidth (double)
virtual double GetTextureGridWidth ()
virtual vtkTexturedActor2D * GetTextureActor ()
virtual void SetTextPosition (int)
virtual int GetTextPosition ()
virtual void SetTextPositionToPrecedeScalarBar ()
virtual void SetTextPositionToSucceedScalarBar ()
virtual void SetMaximumWidthInPixels (int)
virtual int GetMaximumWidthInPixels ()
virtual void SetMaximumHeightInPixels (int)
virtual int GetMaximumHeightInPixels ()
virtual void SetAnnotationLeaderPadding (double)
virtual double GetAnnotationLeaderPadding ()
virtual void SetDrawAnnotations (int)
virtual int GetDrawAnnotations ()
virtual void DrawAnnotationsOn ()
virtual void DrawAnnotationsOff ()
virtual void SetDrawNanAnnotation (int)
virtual int GetDrawNanAnnotation ()
virtual void DrawNanAnnotationOn ()
virtual void DrawNanAnnotationOff ()
virtual void SetDrawBelowRangeSwatch (bool)
virtual bool GetDrawBelowRangeSwatch ()
virtual void DrawBelowRangeSwatchOn ()
virtual void DrawBelowRangeSwatchOff ()
virtual void SetBelowRangeAnnotation (const char *)
virtual char * GetBelowRangeAnnotation ()
virtual void SetDrawAboveRangeSwatch (bool)
virtual bool GetDrawAboveRangeSwatch ()
virtual void DrawAboveRangeSwatchOn ()
virtual void DrawAboveRangeSwatchOff ()
virtual void SetAboveRangeAnnotation (const char *)
virtual char * GetAboveRangeAnnotation ()
virtual void SetFixedAnnotationLeaderLineColor (int)
virtual int GetFixedAnnotationLeaderLineColor ()
virtual void FixedAnnotationLeaderLineColorOn ()
virtual void FixedAnnotationLeaderLineColorOff ()
virtual void SetNanAnnotation (const char *)
virtual char * GetNanAnnotation ()
virtual void SetAnnotationTextScaling (int)
virtual int GetAnnotationTextScaling ()
virtual void AnnotationTextScalingOn ()
virtual void AnnotationTextScalingOff ()
virtual void SetDrawBackground (int)
virtual int GetDrawBackground ()
virtual void DrawBackgroundOn ()
virtual void DrawBackgroundOff ()
virtual void SetDrawFrame (int)
virtual int GetDrawFrame ()
virtual void DrawFrameOn ()
virtual void DrawFrameOff ()
virtual void SetDrawColorBar (int)
virtual int GetDrawColorBar ()
virtual void DrawColorBarOn ()
virtual void DrawColorBarOff ()
virtual void SetDrawTickLabels (int)
virtual int GetDrawTickLabels ()
virtual void DrawTickLabelsOn ()
virtual void DrawTickLabelsOff ()
virtual void SetBackgroundProperty (vtkProperty2D *p)
virtual vtkProperty2D * GetBackgroundProperty ()
virtual void SetFrameProperty (vtkProperty2D *p)
virtual vtkProperty2D * GetFrameProperty ()
virtual int GetTextPad ()
virtual void SetTextPad (int)
virtual int GetVerticalTitleSeparation ()
virtual void SetVerticalTitleSeparation (int)
virtual double GetBarRatio ()
virtual void SetBarRatio (double)
virtual double GetTitleRatio ()
virtual void SetTitleRatio (double)
virtual void SetUnconstrainedFontSize (bool)
virtual bool GetUnconstrainedFontSize ()
virtual void UnconstrainedFontSizeOn ()
virtual void UnconstrainedFontSizeOff ()
- Public Member Functions inherited from vtkActor2D
vtkActor2D * NewInstance () const
vtkProperty2D * GetProperty ()
virtual void SetProperty (vtkProperty2D *)
void SetDisplayPosition (int, int)
virtual void GetActors2D (vtkPropCollection *pc)
virtual void SetMapper (vtkMapper2D *mapper)
virtual vtkMapper2D * GetMapper ()
virtual void SetLayerNumber (int)
virtual int GetLayerNumber ()
virtual vtkCoordinate * GetPositionCoordinate ()
virtual void SetPosition (float x[2])
virtual void SetPosition (float x, float y)
virtual float * GetPosition ()
virtual vtkCoordinate * GetPosition2Coordinate ()
virtual void SetPosition2 (float x[2])
virtual void SetPosition2 (float x, float y)
virtual float * GetPosition2 ()
void SetWidth (double w)
double GetWidth ()
void SetHeight (double h)
double GetHeight ()
virtual vtkCoordinate * GetActualPositionCoordinate (void)
virtual vtkCoordinate * GetActualPosition2Coordinate (void)
double GetWidth ()
double GetHeight ()
- Public Member Functions inherited from vtkProp
vtkProp * NewInstance () const
virtual void Pick ()
virtual bool HasKeys (vtkInformation *requiredKeys)
virtual void BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path)
virtual void GetActors (vtkPropCollection *)
virtual void GetVolumes (vtkPropCollection *)
virtual void SetVisibility (int)
virtual int GetVisibility ()
virtual void VisibilityOn ()
virtual void VisibilityOff ()
virtual void SetPickable (int)
virtual int GetPickable ()
virtual void PickableOn ()
virtual void PickableOff ()
virtual void SetDragable (int)
virtual int GetDragable ()
virtual void DragableOn ()
virtual void DragableOff ()
virtual vtkMTimeType GetRedrawMTime ()
virtual void SetUseBounds (bool)
virtual bool GetUseBounds ()
virtual void UseBoundsOn ()
virtual void UseBoundsOff ()
virtual double * GetBounds ()
virtual void InitPathTraversal ()
virtual vtkAssemblyPath * GetNextPath ()
virtual int GetNumberOfPaths ()
virtual void PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix))
virtual vtkMatrix4x4 * GetMatrix ()
virtual vtkInformation * GetPropertyKeys ()
virtual void SetPropertyKeys (vtkInformation *keys)
virtual int RenderVolumetricGeometry (vtkViewport *)
virtual bool RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys)
virtual bool RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys)
virtual double GetEstimatedRenderTime (vtkViewport *)
virtual double GetEstimatedRenderTime ()
virtual void SetEstimatedRenderTime (double t)
virtual void RestoreEstimatedRenderTime ()
virtual void AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp))
virtual void SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v))
virtual double GetAllocatedRenderTime ()
void SetRenderTimeMultiplier (double t)
virtual double GetRenderTimeMultiplier ()
virtual bool GetSupportsSelection ()
virtual int GetNumberOfConsumers ()
void AddConsumer (vtkObject *c)
void RemoveConsumer (vtkObject *c)
vtkObject * GetConsumer (int i)
int IsConsumer (vtkObject *c)
static vtkContext2DScalarBarActor * SafeDownCast (vtkObject *o)
static vtkContext2DScalarBarActor * New ()
- Static Public Member Functions inherited from vtkScalarBarActor
static vtkScalarBarActor * SafeDownCast (vtkObjectBase *o)
static vtkScalarBarActor * New ()
- Static Public Member Functions inherited from vtkActor2D
static vtkActor2D * SafeDownCast (vtkObjectBase *o)
static vtkActor2D * New ()
- Static Public Member Functions inherited from vtkProp
static vtkProp * SafeDownCast (vtkObjectBase *o)
static vtkInformationIntegerKey * GeneralTextureUnit ()
static vtkInformationDoubleVectorKey * GeneralTextureTransform ()
 vtkContext2DScalarBarActor ()
 ~vtkContext2DScalarBarActor () override
- Protected Member Functions inherited from vtkScalarBarActor
 vtkScalarBarActor ()
 ~vtkScalarBarActor ()
virtual void RebuildLayout (vtkViewport *viewport)
virtual int RebuildLayoutIfNeeded (vtkViewport *viewport)
virtual void FreeLayoutStorage ()
virtual void ComputeFrame ()
virtual void ComputeScalarBarThickness ()
virtual void ComputeSwatchPad ()
virtual void LayoutNanSwatch ()
virtual void LayoutBelowRangeSwatch ()
virtual void LayoutAboveRangeSwatch ()
virtual void LayoutAboveRangeSwatchPosn ()
virtual void PrepareTitleText ()
virtual void LayoutTitle ()
virtual void LayoutForUnconstrainedFont ()
virtual void ComputeScalarBarLength ()
virtual void LayoutTicks ()
virtual void LayoutAnnotations ()
virtual void ConfigureAnnotations ()
virtual void ConfigureFrame ()
virtual void DrawBoxes ()
virtual void ConfigureScalarBar ()
virtual void ConfigureTitle ()
virtual void ConfigureTicks ()
virtual void ConfigureNanSwatch ()
virtual void ConfigureAboveBelowRangeSwatch (bool above)
virtual void EditAnnotations ()
virtual void SizeTitle (double *titleSize, int *size, vtkViewport *viewport)
int MapAnnotationLabels (vtkScalarsToColors *lkup, double start, double delta, const double *range)
int PlaceAnnotationsVertically (double barX, double barY, double barWidth, double barHeight, double delta, double pad)
int PlaceAnnotationsHorizontally (double barX, double barY, double barWidth, double barHeight, double delta, double pad)
- Protected Member Functions inherited from vtkActor2D
 vtkActor2D ()
 ~vtkActor2D ()
- Protected Member Functions inherited from vtkProp
 vtkProp ()
 ~vtkProp ()
bool DrawDataRange
 Flag to show the range on the scalar bar. More...
int VerticalOffset = 0
 Offset applied to scalar bar when DrawDataRange is true. More...
double DataRangeMin = 0
 Range to be displayed. More...
double DataRangeMax = 0
- Protected Attributes inherited from vtkScalarBarActor
int MaximumNumberOfColors
int NumberOfLabels
int NumberOfLabelsBuilt
int Orientation
int DrawBackground
int DrawFrame
int DrawColorBar
int DrawTickLabels
int DrawAnnotations
int DrawNanAnnotation
int AnnotationTextScaling
int FixedAnnotationLeaderLineColor
vtkProperty2D * BackgroundProperty
vtkProperty2D * FrameProperty
char * Title
char * ComponentTitle
char * LabelFormat
int UseOpacity
double TextureGridWidth
int TextPosition
char * NanAnnotation
char * BelowRangeAnnotation
char * AboveRangeAnnotation
double AnnotationLeaderPadding
int MaximumWidthInPixels
int MaximumHeightInPixels
int TextPad
int VerticalTitleSeparation
double BarRatio
double TitleRatio
bool UnconstrainedFontSize
bool DrawBelowRangeSwatch
bool DrawAboveRangeSwatch
vtkTimeStamp BuildTime
int LastSize [2]
int LastOrigin [2]
vtkScalarBarActorInternal * P
vtkScalarsToColors * LookupTable
vtkTextProperty * TitleTextProperty
vtkTextProperty * LabelTextProperty
vtkTextProperty * AnnotationTextProperty
vtkTextActor * TitleActor
vtkPolyData * ScalarBar
vtkPolyDataMapper2D * ScalarBarMapper
vtkActor2D * ScalarBarActor
vtkPolyData * TexturePolyData
vtkTexture * Texture
vtkTexturedActor2D * TextureActor
vtkPolyData * Background
vtkPolyDataMapper2D * BackgroundMapper
vtkActor2D * BackgroundActor
vtkPolyData * Frame
vtkPolyDataMapper2D * FrameMapper
vtkActor2D * FrameActor
- Protected Attributes inherited from vtkActor2D
vtkMapper2D * Mapper
int LayerNumber
vtkProperty2D * Property
vtkCoordinate * PositionCoordinate
vtkCoordinate * Position2Coordinate
- Protected Attributes inherited from vtkProp
int Visibility
int Pickable
int Dragable
bool UseBounds
double AllocatedRenderTime
double EstimatedRenderTime
double SavedEstimatedRenderTime
double RenderTimeMultiplier
int NumberOfConsumers
vtkObject ** Consumers
vtkAssemblyPaths * Paths
vtkInformation * PropertyKeys
- Public Attributes inherited from vtkScalarBarActor
 PrecedeScalarBar
 SucceedScalarBar
.SECTION Description
vtkContext2DScalarBarActor is a custom scalar bar actor that uses the Charts API for drawing calls. As the scalar bar actor is inherently 2D, the Charts API offers a comparatively simpler way of implementing features in the scalar bar actor than using vtkPolyData primitives.
Definition at line 37 of file vtkContext2DScalarBarActor.h.
Definition at line 40 of file vtkContext2DScalarBarActor.h.
◆ anonymous enum
anonymous enum
Enumerator
PrecedeScalarBar
SucceedScalarBar
Definition at line 63 of file vtkContext2DScalarBarActor.h.
◆ OutOfRangeType
Enumerator
BELOW_RANGE
ABOVE_RANGE
Definition at line 69 of file vtkContext2DScalarBarActor.h.
◆ vtkContext2DScalarBarActor()
vtkContext2DScalarBarActor::vtkContext2DScalarBarActor ( )
◆ ~vtkContext2DScalarBarActor()
vtkContext2DScalarBarActor::~vtkContext2DScalarBarActor ( )
virtual const char* vtkContext2DScalarBarActor::GetClassName ( )
static int vtkContext2DScalarBarActor::IsTypeOf ( const char *  type)
virtual int vtkContext2DScalarBarActor::IsA ( const char *  type)
Reimplemented from vtkScalarBarActor.
static vtkContext2DScalarBarActor* vtkContext2DScalarBarActor::SafeDownCast ( vtkObject *  o)
void vtkContext2DScalarBarActor::PrintSelf ( ostream &  os,
static vtkContext2DScalarBarActor* vtkContext2DScalarBarActor::New ( )
◆ GetTitleJustification()
virtual int vtkContext2DScalarBarActor::GetTitleJustification ( )
Valid values are VTK_TEXT_LEFT, VTK_TEXT_CENTERED, and VTK_TEXT_RIGHT.
◆ SetTitleJustification()
virtual void vtkContext2DScalarBarActor::SetTitleJustification ( int  )
◆ SetForceHorizontalTitle()
virtual void vtkContext2DScalarBarActor::SetForceHorizontalTitle ( bool  )
Off by default.
◆ GetForceHorizontalTitle()
virtual bool vtkContext2DScalarBarActor::GetForceHorizontalTitle ( )
Off by default.
◆ ForceHorizontalTitleOn()
virtual void vtkContext2DScalarBarActor::ForceHorizontalTitleOn ( )
Off by default.
◆ ForceHorizontalTitleOff()
virtual void vtkContext2DScalarBarActor::ForceHorizontalTitleOff ( )
Off by default.
◆ SetScalarBarThickness()
virtual void vtkContext2DScalarBarActor::SetScalarBarThickness ( int  )
When the orientation is VTK_ORIENT_VERTICAL, this sets the scalar bar width. When the orientation is VTK_ORIENT_HORIZONTAL, this sets the scalar bar height. Specified in points akin to font size.
◆ GetScalarBarThickness()
virtual int vtkContext2DScalarBarActor::GetScalarBarThickness ( )
◆ SetScalarBarLength()
virtual void vtkContext2DScalarBarActor::SetScalarBarLength ( double  )
When the orientation is VTK_ORIENT_VERTICAL, this sets the scalar bar height. When the orientation is VTK_ORIENT_HORIZONTAL, this sets the scalar bar width. Specified in normalized viewport coordinates, meaning the value is the fractional span of the viewport's width or height in the range [0, 1], depending on orientation.
◆ GetScalarBarLength()
virtual double vtkContext2DScalarBarActor::GetScalarBarLength ( )
◆ SetDrawScalarBarOutline()
virtual void vtkContext2DScalarBarActor::SetDrawScalarBarOutline ( bool  )
◆ GetDrawScalarBarOutline()
virtual bool vtkContext2DScalarBarActor::GetDrawScalarBarOutline ( )
◆ DrawScalarBarOutlineOn()
virtual void vtkContext2DScalarBarActor::DrawScalarBarOutlineOn ( )
◆ DrawScalarBarOutlineOff()
virtual void vtkContext2DScalarBarActor::DrawScalarBarOutlineOff ( )
◆ SetScalarBarOutlineColor() [1/2]
virtual void vtkContext2DScalarBarActor::SetScalarBarOutlineColor ( double  ,
double  ,
double
◆ SetScalarBarOutlineColor() [2/2]
virtual void vtkContext2DScalarBarActor::SetScalarBarOutlineColor ( double  [3])
◆ GetScalarBarOutlineColor() [1/3]
virtual double* vtkContext2DScalarBarActor::GetScalarBarOutlineColor ( )
◆ GetScalarBarOutlineColor() [2/3]
virtual void vtkContext2DScalarBarActor::GetScalarBarOutlineColor ( double &  ,
double &  ,
double &
◆ GetScalarBarOutlineColor() [3/3]
virtual void vtkContext2DScalarBarActor::GetScalarBarOutlineColor ( double  [3])
◆ SetScalarBarOutlineThickness()
virtual void vtkContext2DScalarBarActor::SetScalarBarOutlineThickness ( int  )
◆ GetScalarBarOutlineThickness()
virtual int vtkContext2DScalarBarActor::GetScalarBarOutlineThickness ( )
◆ SetBackgroundColor() [1/2]
virtual void vtkContext2DScalarBarActor::SetBackgroundColor ( double  ,
double  ,
double  ,
double
First three components, specify RGB color components, opacity is the fourth element.
◆ SetBackgroundColor() [2/2]
virtual void vtkContext2DScalarBarActor::SetBackgroundColor ( double  [4])
◆ GetBackgroundColor() [1/3]
virtual double* vtkContext2DScalarBarActor::GetBackgroundColor ( )
◆ GetBackgroundColor() [2/3]
virtual void vtkContext2DScalarBarActor::GetBackgroundColor ( double &  ,
double &  ,
double &  ,
double &
◆ GetBackgroundColor() [3/3]
virtual void vtkContext2DScalarBarActor::GetBackgroundColor ( double  [4])
◆ SetBackgroundPadding()
virtual void vtkContext2DScalarBarActor::SetBackgroundPadding ( double  )
◆ GetBackgroundPadding()
virtual double vtkContext2DScalarBarActor::GetBackgroundPadding ( )
◆ SetReverseLegend()
virtual void vtkContext2DScalarBarActor::SetReverseLegend ( bool  )
Default is false;
◆ GetReverseLegend()
virtual bool vtkContext2DScalarBarActor::GetReverseLegend ( )
Default is false;
◆ ReverseLegendOn()
virtual void vtkContext2DScalarBarActor::ReverseLegendOn ( )
Default is false;
◆ ReverseLegendOff()
virtual void vtkContext2DScalarBarActor::ReverseLegendOff ( )
Default is false;
◆ GetAutomaticLabelFormat()
virtual int vtkContext2DScalarBarActor::GetAutomaticLabelFormat ( )
If false, the LabelFormat ivar will be used.
◆ SetAutomaticLabelFormat()
virtual void vtkContext2DScalarBarActor::SetAutomaticLabelFormat ( int  )
◆ AutomaticLabelFormatOn()
virtual void vtkContext2DScalarBarActor::AutomaticLabelFormatOn ( )
◆ AutomaticLabelFormatOff()
virtual void vtkContext2DScalarBarActor::AutomaticLabelFormatOff ( )
◆ SetAddRangeLabels()
virtual void vtkContext2DScalarBarActor::SetAddRangeLabels ( int  )
These are labels that have the minimum/maximum values of the scalar bar range.
◆ GetAddRangeLabels()
virtual int vtkContext2DScalarBarActor::GetAddRangeLabels ( )
◆ SetAutomaticAnnotations()
virtual void vtkContext2DScalarBarActor::SetAutomaticAnnotations ( int  )
Default is FALSE;
◆ GetAutomaticAnnotations()
virtual int vtkContext2DScalarBarActor::GetAutomaticAnnotations ( )
Default is FALSE;
◆ AutomaticAnnotationsOn()
virtual void vtkContext2DScalarBarActor::AutomaticAnnotationsOn ( )
Default is FALSE;
◆ AutomaticAnnotationsOff()
virtual void vtkContext2DScalarBarActor::AutomaticAnnotationsOff ( )
Default is FALSE;
◆ GetAddRangeAnnotations()
virtual int vtkContext2DScalarBarActor::GetAddRangeAnnotations ( )
◆ SetAddRangeAnnotations()
virtual void vtkContext2DScalarBarActor::SetAddRangeAnnotations ( int  )
◆ AddRangeAnnotationsOn()
virtual void vtkContext2DScalarBarActor::AddRangeAnnotationsOn ( )
◆ AddRangeAnnotationsOff()
virtual void vtkContext2DScalarBarActor::AddRangeAnnotationsOff ( )
◆ SetDrawTickMarks()
virtual void vtkContext2DScalarBarActor::SetDrawTickMarks ( bool  )
◆ GetDrawTickMarks()
virtual bool vtkContext2DScalarBarActor::GetDrawTickMarks ( )
◆ SetRangeLabelFormat()
virtual void vtkContext2DScalarBarActor::SetRangeLabelFormat ( const char *  )
◆ GetRangeLabelFormat()
virtual char* vtkContext2DScalarBarActor::GetRangeLabelFormat ( )
◆ SetDataRangeLabelFormat()
virtual void vtkContext2DScalarBarActor::SetDataRangeLabelFormat ( const char *  )
◆ GetDataRangeLabelFormat()
virtual char* vtkContext2DScalarBarActor::GetDataRangeLabelFormat ( )
◆ SetNumberOfCustomLabels()
void vtkContext2DScalarBarActor::SetNumberOfCustomLabels ( vtkIdType  numLabels)
◆ GetNumberOfCustomLabels()
vtkIdType vtkContext2DScalarBarActor::GetNumberOfCustomLabels ( )
◆ SetCustomLabel()
void vtkContext2DScalarBarActor::SetCustomLabel ( vtkIdType  index,
double  value
◆ RenderOverlay()
int vtkContext2DScalarBarActor::RenderOverlay ( vtkViewport *  viewport)
◆ RenderOpaqueGeometry()
int vtkContext2DScalarBarActor::RenderOpaqueGeometry ( vtkViewport *  viewport)
◆ ReleaseGraphicsResources()
void vtkContext2DScalarBarActor::ReleaseGraphicsResources ( vtkWindow *  window)
The parameter window could be used to determine which graphic resources to release.
◆ Paint()
virtual bool vtkContext2DScalarBarActor::Paint ( vtkContext2D *  painter)
◆ GetBoundingRect()
vtkRectf vtkContext2DScalarBarActor::GetBoundingRect ( )
◆ GetEstimatedNumberOfAnnotations()
int vtkContext2DScalarBarActor::GetEstimatedNumberOfAnnotations ( )
The actual number of annotations can be slightly lower than the return of this method when using automatic annotations.
◆ SetDrawDataRange()
virtual void vtkContext2DScalarBarActor::SetDrawDataRange ( bool  )
By default, it is set to false.
◆ GetDrawDataRange()
virtual bool vtkContext2DScalarBarActor::GetDrawDataRange ( )
◆ DrawDataRangeOn()
virtual void vtkContext2DScalarBarActor::DrawDataRangeOn ( )
◆ DrawDataRangeOff()
virtual void vtkContext2DScalarBarActor::DrawDataRangeOff ( )
◆ SetDataRangeMin()
virtual void vtkContext2DScalarBarActor::SetDataRangeMin ( double  )
This value can be set to a minimum value that is not the same as the LUT range and is displayed in the color legend when "DrawDataRange" is set to true.
◆ GetDataRangeMin()
virtual double vtkContext2DScalarBarActor::GetDataRangeMin ( )
◆ SetDataRangeMax()
virtual void vtkContext2DScalarBarActor::SetDataRangeMax ( double  )
◆ GetDataRangeMax()
virtual double vtkContext2DScalarBarActor::GetDataRangeMax ( )
◆ DrawDataRange
bool vtkContext2DScalarBarActor::DrawDataRange
Definition at line 302 of file vtkContext2DScalarBarActor.h.
◆ DataRangeMin
double vtkContext2DScalarBarActor::DataRangeMin = 0
Definition at line 308 of file vtkContext2DScalarBarActor.h.
◆ DataRangeMax
double vtkContext2DScalarBarActor::DataRangeMax = 0
Definition at line 309 of file vtkContext2DScalarBarActor.h.
◆ VerticalOffset
int vtkContext2DScalarBarActor::VerticalOffset = 0
Definition at line 315 of file vtkContext2DScalarBarActor.h.
