vtkCameraManipulator Class Reference
Abstraction of style away from button. More...
#include <vtkCameraManipulator.h>
Inheritance diagram for vtkCameraManipulator:
Collaboration diagram for vtkCameraManipulator:
virtual void OnMouseMove (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren)
virtual void OnButtonDown (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren)
virtual void OnButtonUp (int x, int y, vtkRenderer *ren, vtkRenderWindowInteractor *iren)
virtual void OnKeyUp (vtkRenderWindowInteractor *iren)
virtual void OnKeyDown (vtkRenderWindowInteractor *iren)
virtual void SetButton (int)
virtual int GetButton ()
virtual void SetShift (int)
virtual int GetShift ()
virtual void ShiftOn ()
virtual void ShiftOff ()
virtual void SetControl (int)
virtual int GetControl ()
virtual void ControlOn ()
virtual void ControlOff ()
virtual void SetCenter (double [3])
virtual double * GetCenter ()
virtual void GetCenter (double [3])
static vtkCameraManipulator * New ()
static vtkCameraManipulator * SafeDownCast (vtkObject *o)
char * ManipulatorName
int Button
int Shift
int Control
double Center [3]
double RotationFactor
double DisplayCenter [2]
 vtkCameraManipulator ()
 ~vtkCameraManipulator () override
vtkCameraManipulator is a superclass foractions inside an interactor style and associated with a single button. An example might be rubber-band bounding-box zoom. This abstraction allows a camera manipulator to be assigned to any button. This super class might become a subclass of vtkInteractorObserver in the future.
Definition at line 24 of file vtkCameraManipulator.h.
Definition at line 28 of file vtkCameraManipulator.h.
◆ vtkCameraManipulator()
vtkCameraManipulator::vtkCameraManipulator ( )
Get/Set the GUI helper.
◆ ~vtkCameraManipulator()
vtkCameraManipulator::~vtkCameraManipulator ( )
static vtkCameraManipulator* vtkCameraManipulator::New ( )
virtual const char* vtkCameraManipulator::GetClassName ( )
static int vtkCameraManipulator::IsTypeOf ( const char *  type)
virtual int vtkCameraManipulator::IsA ( const char *  type)
static vtkCameraManipulator* vtkCameraManipulator::SafeDownCast ( vtkObject *  o)
void vtkCameraManipulator::PrintSelf ( ostream &  os,
◆ StartInteraction()
virtual void vtkCameraManipulator::StartInteraction ( )
◆ EndInteraction()
virtual void vtkCameraManipulator::EndInteraction ( )
◆ OnMouseMove()
virtual void vtkCameraManipulator::OnMouseMove ( int  x,
int  y,
vtkRenderer *  ren,
vtkRenderWindowInteractor *  iren
◆ OnButtonDown()
virtual void vtkCameraManipulator::OnButtonDown ( int  x,
int  y,
vtkRenderer *  ren,
◆ OnButtonUp()
virtual void vtkCameraManipulator::OnButtonUp ( int  x,
int  y,
vtkRenderer *  ren,
◆ OnKeyUp()
virtual void vtkCameraManipulator::OnKeyUp ( vtkRenderWindowInteractor *  iren)
These methods are called on all registered manipulators, not just the active one.
Hence, these should just be used to record state and not perform any interactions.
Reimplemented in vtkPVTrackballRotate, and vtkTrackballPan.
◆ OnKeyDown()
virtual void vtkCameraManipulator::OnKeyDown ( vtkRenderWindowInteractor *  iren)
◆ SetButton()
virtual void vtkCameraManipulator::SetButton ( int  )
These settings determine which button and modifiers the manipulator responds to.
Button can be either 1 (left), 2 (middle), and 3 right.
◆ GetButton()
virtual int vtkCameraManipulator::GetButton ( )
◆ SetShift()
virtual void vtkCameraManipulator::SetShift ( int  )
◆ GetShift()
virtual int vtkCameraManipulator::GetShift ( )
◆ ShiftOn()
virtual void vtkCameraManipulator::ShiftOn ( )
◆ ShiftOff()
virtual void vtkCameraManipulator::ShiftOff ( )
◆ SetControl()
virtual void vtkCameraManipulator::SetControl ( int  )
◆ GetControl()
virtual int vtkCameraManipulator::GetControl ( )
◆ ControlOn()
virtual void vtkCameraManipulator::ControlOn ( )
◆ ControlOff()
virtual void vtkCameraManipulator::ControlOff ( )
◆ SetCenter() [1/2]
virtual void vtkCameraManipulator::SetCenter ( double  ,
double  ,
double
For setting the center of rotation.
◆ SetCenter() [2/2]
virtual void vtkCameraManipulator::SetCenter ( double  [3])
◆ GetCenter() [1/3]
virtual double* vtkCameraManipulator::GetCenter ( )
◆ GetCenter() [2/3]
virtual void vtkCameraManipulator::GetCenter ( double &  ,
double &  ,
double &
◆ GetCenter() [3/3]
virtual void vtkCameraManipulator::GetCenter ( double  [3])
◆ SetRotationFactor()
virtual void vtkCameraManipulator::SetRotationFactor ( double  )
Set and get the rotation factor.
◆ GetRotationFactor()
virtual double vtkCameraManipulator::GetRotationFactor ( )
◆ SetManipulatorName()
virtual void vtkCameraManipulator::SetManipulatorName ( const char *  )
Set and get the manipulator name.
◆ GetManipulatorName()
virtual char* vtkCameraManipulator::GetManipulatorName ( )
◆ SetGUIHelper()
void vtkCameraManipulator::SetGUIHelper ( vtkCameraManipulatorGUIHelper *  )
◆ GetGUIHelper()
virtual vtkCameraManipulatorGUIHelper* vtkCameraManipulator::GetGUIHelper ( )
◆ ComputeDisplayCenter()
void vtkCameraManipulator::ComputeDisplayCenter ( vtkRenderer *  ren)
◆ ManipulatorName
char* vtkCameraManipulator::ManipulatorName
Definition at line 106 of file vtkCameraManipulator.h.
◆ Button
int vtkCameraManipulator::Button
Definition at line 108 of file vtkCameraManipulator.h.
◆ Shift
int vtkCameraManipulator::Shift
Definition at line 109 of file vtkCameraManipulator.h.
◆ Control
int vtkCameraManipulator::Control
Definition at line 110 of file vtkCameraManipulator.h.
◆ Center
double vtkCameraManipulator::Center[3]
Definition at line 112 of file vtkCameraManipulator.h.
◆ RotationFactor
double vtkCameraManipulator::RotationFactor
Definition at line 113 of file vtkCameraManipulator.h.
◆ DisplayCenter
double vtkCameraManipulator::DisplayCenter[2]
Definition at line 114 of file vtkCameraManipulator.h.
◆ GUIHelper
vtkCameraManipulatorGUIHelper* vtkCameraManipulator::GUIHelper
Definition at line 117 of file vtkCameraManipulator.h.
