vtkAnnotateAttributeDataFilter Class Reference
specialization of vtkPythonAnnotationFilter to work with element data. More...
#include <vtkAnnotateAttributeDataFilter.h>
Inheritance diagram for vtkAnnotateAttributeDataFilter:
Collaboration diagram for vtkAnnotateAttributeDataFilter:
typedef vtkPythonAnnotationFilter Superclass
- Public Types inherited from vtkPythonAnnotationFilter
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetArrayName (const char *)
 Set the attribute array name to annotate with. More...
virtual char * GetArrayName ()
virtual void SetElementId (vtkIdType)
 Set the element number to annotate with. More...
virtual vtkIdType GetElementId ()
virtual void SetProcessId (int)
 Set the rank to extract the data from. More...
virtual int GetProcessId ()
virtual void SetPrefix (const char *)
 Set the text prefix to display in front of the Field value. More...
virtual char * GetPrefix ()
- Public Member Functions inherited from vtkPythonAnnotationFilter
virtual int GetNumberOfTimeSteps ()
double GetTimeStep (int index)
virtual bool GetTimeRangeValid ()
virtual double * GetTimeRange ()
virtual void GetTimeRange (double &, double &)
virtual void GetTimeRange (double [2])
virtual vtkDataObject * GetCurrentInputDataObject ()
void SetComputedAnnotationValue (const char *value)
virtual void SetExpression (const char *)
 Set the expression to evaluate. More...
virtual char * GetExpression ()
virtual void SetArrayAssociation (int)
 Set the input array association. More...
virtual int GetArrayAssociation ()
virtual char * GetComputedAnnotationValue ()
 Get the value that is going to be printed to the output. More...
virtual bool GetDataTimeValid ()
 Get methods for use in annotation.py. More...
virtual double GetDataTime ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAnnotateAttributeDataFilter * New ()
static vtkAnnotateAttributeDataFilter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPythonAnnotationFilter
static vtkPythonAnnotationFilter * New ()
static vtkPythonAnnotationFilter * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkAnnotateAttributeDataFilter ()
 ~vtkAnnotateAttributeDataFilter () override
void EvaluateExpression () override
- Protected Member Functions inherited from vtkPythonAnnotationFilter
 vtkPythonAnnotationFilter ()
 ~vtkPythonAnnotationFilter () override
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
char * ArrayName
char * Prefix
int ProcessId
vtkIdType ElementId
- Protected Attributes inherited from vtkPythonAnnotationFilter
char * Expression
char * ComputedAnnotationValue
int ArrayAssociation
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
vtkAnnotateAttributeDataFilter is a specialization of vtkPythonAnnotationFilter which makes it easier to annotate using data values from any input dataset.
Definition at line 19 of file vtkAnnotateAttributeDataFilter.h.
Definition at line 24 of file vtkAnnotateAttributeDataFilter.h.
◆ vtkAnnotateAttributeDataFilter()
vtkAnnotateAttributeDataFilter::vtkAnnotateAttributeDataFilter ( )
◆ ~vtkAnnotateAttributeDataFilter()
vtkAnnotateAttributeDataFilter::~vtkAnnotateAttributeDataFilter ( )
static vtkAnnotateAttributeDataFilter* vtkAnnotateAttributeDataFilter::New ( )
virtual const char* vtkAnnotateAttributeDataFilter::GetClassName ( )
Reimplemented from vtkPythonAnnotationFilter.
static int vtkAnnotateAttributeDataFilter::IsTypeOf ( const char *  type)
virtual int vtkAnnotateAttributeDataFilter::IsA ( const char *  type)
static vtkAnnotateAttributeDataFilter* vtkAnnotateAttributeDataFilter::SafeDownCast ( vtkObject *  o)
void vtkAnnotateAttributeDataFilter::PrintSelf ( ostream &  os,
Reimplemented from vtkTableAlgorithm.
◆ SetArrayName()
virtual void vtkAnnotateAttributeDataFilter::SetArrayName ( const char *  )
◆ GetArrayName()
virtual char* vtkAnnotateAttributeDataFilter::GetArrayName ( )
◆ SetElementId()
virtual void vtkAnnotateAttributeDataFilter::SetElementId ( vtkIdType  )
◆ GetElementId()
virtual vtkIdType vtkAnnotateAttributeDataFilter::GetElementId ( )
◆ SetProcessId()
virtual void vtkAnnotateAttributeDataFilter::SetProcessId ( int  )
Default is 0.
◆ GetProcessId()
virtual int vtkAnnotateAttributeDataFilter::GetProcessId ( )
Default is 0.
◆ SetPrefix()
virtual void vtkAnnotateAttributeDataFilter::SetPrefix ( const char *  )
◆ GetPrefix()
virtual char* vtkAnnotateAttributeDataFilter::GetPrefix ( )
◆ EvaluateExpression()
void vtkAnnotateAttributeDataFilter::EvaluateExpression ( )
overrideprotectedvirtual
◆ ArrayName
char* vtkAnnotateAttributeDataFilter::ArrayName
Definition at line 66 of file vtkAnnotateAttributeDataFilter.h.
◆ Prefix
char* vtkAnnotateAttributeDataFilter::Prefix
Definition at line 67 of file vtkAnnotateAttributeDataFilter.h.
◆ ProcessId
int vtkAnnotateAttributeDataFilter::ProcessId
Definition at line 68 of file vtkAnnotateAttributeDataFilter.h.
◆ ElementId
vtkIdType vtkAnnotateAttributeDataFilter::ElementId
Definition at line 69 of file vtkAnnotateAttributeDataFilter.h.
