Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
vtkAnimationPlayer Class Referenceabstract
Abstract superclass for an animation player. More...
#include <vtkAnimationPlayer.h>
Inheritance diagram for vtkAnimationPlayer:
Collaboration diagram for vtkAnimationPlayer:
void Play (int dir=1)
 Start playing the animation. More...
void Stop ()
 Stop playing the animation. More...
int IsInPlay ()
 Returns if the animation is currently playing. More...
virtual bool GetInPlay ()
void GoToNext ()
 Take the animation scene to next frame. More...
void GoToPrevious ()
 Take animation scene to previous frame. More...
void GoToFirst ()
 Take animation scene to first frame. More...
void GoToLast ()
 Take animation scene to last frame. More...
virtual void SetAnimationScene (vtkSMAnimationScene *)
 Set the animation scene that is to be played by this player. More...
vtkSMAnimationScene * GetAnimationScene ()
virtual void SetLoop (bool)
 Set to true to play the animation in a loop. More...
virtual bool GetLoop ()
virtual int GetStride ()
 Get/Set the stride value fot the animation player. More...
virtual void SetStride (int)
static vtkAnimationPlayer * SafeDownCast (vtkObject *o)
 vtkAnimationPlayer ()
 ~vtkAnimationPlayer () override
virtual void StartLoop (double starttime, double endtime, double curtime, double *playbackWindow)=0
 Manage loop inside playbackwindow. More...
virtual void EndLoop ()=0
virtual double GetNextTime (double currentime)=0
virtual double GetPreviousTime (double currenttime)=0
virtual double GoToNext (double start, double end, double currenttime)=0
 Return next/previous time knowing start, end and current. More...
virtual double GoToPrevious (double start, double end, double currenttime)=0
Friends
class vtkCompositeAnimationPlayer
Definition at line 17 of file vtkAnimationPlayer.h.
Definition at line 20 of file vtkAnimationPlayer.h.
◆ vtkAnimationPlayer()
vtkAnimationPlayer::vtkAnimationPlayer ( )
◆ ~vtkAnimationPlayer()
vtkAnimationPlayer::~vtkAnimationPlayer ( )
virtual const char* vtkAnimationPlayer::GetClassName ( )
static int vtkAnimationPlayer::IsTypeOf ( const char *  type)
virtual int vtkAnimationPlayer::IsA ( const char *  type)
static vtkAnimationPlayer* vtkAnimationPlayer::SafeDownCast ( vtkObject *  o)
void vtkAnimationPlayer::PrintSelf ( ostream &  os,
◆ SetAnimationScene()
virtual void vtkAnimationPlayer::SetAnimationScene ( vtkSMAnimationScene *  )
Note that the animation scene is not reference counted to avoid loops.
◆ GetAnimationScene()
vtkSMAnimationScene* vtkAnimationPlayer::GetAnimationScene ( )
◆ Play()
void vtkAnimationPlayer::Play ( int  dir = 1)
Fires StartEvent when play begins and EndEvent when play stops. If dir = 0, play the animation in reverse back to the beginning, else play it in the forward direction.
◆ Stop()
void vtkAnimationPlayer::Stop ( )
◆ IsInPlay()
int vtkAnimationPlayer::IsInPlay ( )
inline
Definition at line 48 of file vtkAnimationPlayer.h.
◆ GetInPlay()
virtual bool vtkAnimationPlayer::GetInPlay ( )
◆ SetLoop()
virtual void vtkAnimationPlayer::SetLoop ( bool  )
◆ GetLoop()
virtual bool vtkAnimationPlayer::GetLoop ( )
◆ GoToNext() [1/2]
void vtkAnimationPlayer::GoToNext ( )
◆ GoToPrevious() [1/2]
void vtkAnimationPlayer::GoToPrevious ( )
◆ GoToFirst()
void vtkAnimationPlayer::GoToFirst ( )
◆ GoToLast()
void vtkAnimationPlayer::GoToLast ( )
◆ GetStride()
virtual int vtkAnimationPlayer::GetStride ( )
This will cause the player to skip (n - 1) when GetNextTime, GoToNext and GoToPrevious are previous are called.
Stride is clamped between 1 and the number of frames of the current animation scene.
◆ SetStride()
virtual void vtkAnimationPlayer::SetStride ( int  )
Reimplemented in vtkCompositeAnimationPlayer.
◆ StartLoop()
virtual void vtkAnimationPlayer::StartLoop ( double  starttime,
double  endtime,
double  curtime,
double *  playbackWindow
protectedpure virtual
Implemented in vtkTimestepsAnimationPlayer, vtkCompositeAnimationPlayer, and vtkSequenceAnimationPlayer.
◆ EndLoop()
virtual void vtkAnimationPlayer::EndLoop ( )
◆ GetNextTime()
virtual double vtkAnimationPlayer::GetNextTime ( double  currentime)
◆ GetPreviousTime()
virtual double vtkAnimationPlayer::GetPreviousTime ( double  currenttime)
◆ GoToNext() [2/2]
virtual double vtkAnimationPlayer::GoToNext ( double  start,
double  end,
double  currenttime
◆ GoToPrevious() [2/2]
virtual double vtkAnimationPlayer::GoToPrevious ( double  start,
double  end,
double  currenttime
◆ vtkCompositeAnimationPlayer
friend class vtkCompositeAnimationPlayer
friend
Definition at line 94 of file vtkAnimationPlayer.h.
