| #define | VTK_REPORT_OPENGL_ERRORS |
| #define | vtkOpenGLClearErrorMacro() vtkClearOpenGLErrors(16); |
| #define | vtkOpenGLCheckErrorMacroImpl(ostr, message) |
| #define | vtkOpenGLCheckErrorMacro(message) vtkOpenGLCheckErrorMacroImpl(vtkErrorMacro, message) |
| #define | vtkOpenGLStaticCheckErrorMacro(message) vtkOpenGLCheckErrorMacroImpl(vtkGenericWarningMacro, message) |
| #define | vtkOpenGLDebugClearErrorMacro() vtkOpenGLClearErrorMacro() |
| #define | vtkOpenGLDebugCheckErrorMacro(message) vtkOpenGLStaticCheckErrorMacro(message) |
| VTK_ABI_NAMESPACE_BEGIN const char * | vtkOpenGLStrError (unsigned int code) |
| The following functions can be used to detect and report, and/or silently clear OpenGL error flags. More... | |
| int | vtkGetOpenGLErrors (int maxNum, unsigned int *errCode, const char **errDesc) |
| Check for OpenGL errors. More... | |
| void | vtkPrintOpenGLErrors (ostream &os, int maxErrors, int numErrors, unsigned int *errCode, const char **errDesc) |
| Send a set of errors collected by GetOpenGLErrors to the give stream. More... | |
| bool | vtkOpenGLCheckErrors (const char *headerMessage="") |
| Errors are queried and reported via vtkGenericWarningMacro. More... | |
| void | vtkClearOpenGLErrors (const unsigned int maxErrors=16) |
| Clear OpenGL's error flags. More... | |
| #define VTK_REPORT_OPENGL_ERRORS |
Definition at line 12 of file vtkOpenGLError.h.
| #define vtkOpenGLClearErrorMacro | ( | ) | vtkClearOpenGLErrors(16); |
Definition at line 239 of file vtkOpenGLError.h.
| #define vtkOpenGLCheckErrorMacroImpl | ( | ostr, | |
| message | |||
Definition at line 241 of file vtkOpenGLError.h.
| #define vtkOpenGLCheckErrorMacro | ( | message | ) | vtkOpenGLCheckErrorMacroImpl(vtkErrorMacro, message) |
Definition at line 267 of file vtkOpenGLError.h.
| #define vtkOpenGLStaticCheckErrorMacro | ( | message | ) | vtkOpenGLCheckErrorMacroImpl(vtkGenericWarningMacro, message) |
Definition at line 269 of file vtkOpenGLError.h.
| #define vtkOpenGLDebugClearErrorMacro | ( | ) | vtkOpenGLClearErrorMacro() |
Definition at line 279 of file vtkOpenGLError.h.
| #define vtkOpenGLDebugCheckErrorMacro | ( | message | ) | vtkOpenGLStaticCheckErrorMacro(message) |
Definition at line 281 of file vtkOpenGLError.h.
These are not intended to be used directly, instead use the following macros.
vtkOpenGLClearErrorMacro() – Silently clear OpenGL error flags.
vtkOpenGLCheckErrorMacro(message) – Check and clear OpenGL's error flags. Report errors detected via vtkErrorMacro.
vtkOpenGLStaticCheckErrorMacro(message) – Check and clear OpenGL's error flags. Report errors detected via vtkGenericWarningMacro. This may be used in static methods and outside of vtkObjects.
The intended usage pattern is to 1) call vtkOpenGLClearErrorMacro at the top of, and 2) vtkOpenGLCheckErrorMacro at the bottom of methods that make OpenGL calls.
By calling vtkOpenGLClearErrorMacro at the top of a method that makes OpenGL calls, you isolate the code and prevent it from detecting any preceding errors. By calling vtkOpenGLCheckErrorMacro at the bottom of the method you clear the error flags and report any errors that have occurred in the method where they occurred.
The macros maybe completely disabled via the CMakeLists variable VTK_REPORT_OPENGL_ERRORS. Note that in that case error flags are never cleared so that if an error occurs the flags will remain dirty making it impossible for anyone else to use them reliably. Please don't disable them with out a good reason. Convert an OpenGL error code into a descriptive string.
Definition at line 58 of file vtkOpenGLError.h.
Error status is querried until OpenGL reports no errors. The list of errors and their descriptions are returned in the user supplied arrays. User passes the size of the arrays as the first argument. Error flags will still be cleared if the user arrays are less than the number of errors.
Definition at line 96 of file vtkOpenGLError.h.
The number of errors is obtained in the return value of GetOpenGLErrors, while the max errors gives the size of the error arrays.
Definition at line 142 of file vtkOpenGLError.h.
An optional header message can be appended to the stream. Returns true if no errors were reported.
Definition at line 186 of file vtkOpenGLError.h.
Definition at line 215 of file vtkOpenGLError.h.
