1 # TODO: Split these up and put them in the conditional which actually requires 3 ExternalData_Expand_Arguments(ParaViewData _
4 "DATA{${paraview_test_data_directory_input}/Data/,REGEX:tensors_.*\\.vti}" 5 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/,REGEX:.*}" 6 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/,REGEX:.*}" 7 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/Level_0/,REGEX:.*}" 8 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/particles/,REGEX:.*}" 9 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00000/particles/Level_0/,REGEX:.*}" 10 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/,REGEX:.*}" 11 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/Level_0/,REGEX:.*}" 12 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/particles/,REGEX:.*}" 13 "DATA{${paraview_test_data_directory_input}/Data/AMReX-MFIX/plt00005/particles/Level_0/,REGEX:.*}" 14 "DATA{${paraview_test_data_directory_input}/Data/AxisAlignedSliceBackwardCompat.pvsm}" 15 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00000.temp/,REGEX:.*}" 16 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00000.temp/Level_0/,REGEX:.*}" 17 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00010.temp/,REGEX:.*}" 18 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00010.temp/Level_0/,REGEX:.*}" 19 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00020.temp/,REGEX:.*}" 20 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00020.temp/Level_0/,REGEX:.*}" 21 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00030.temp/,REGEX:.*}" 22 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00030.temp/Level_0/,REGEX:.*}" 23 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00040.temp/,REGEX:.*}" 24 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00040.temp/Level_0/,REGEX:.*}" 25 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00050.temp/,REGEX:.*}" 26 "DATA{${paraview_test_data_directory_input}/Data/double_mach_reflection/plt00050.temp/Level_0/,REGEX:.*}" 27 "DATA{${paraview_test_data_directory_input}/Data/paraview_icon.svg}" 28 "DATA{${paraview_test_data_directory_input}/Data/3GQP.pdb}" 29 "DATA{${paraview_test_data_directory_input}/Data/bake/bake.e}" 30 "DATA{${paraview_test_data_directory_input}/Data/CameraWidgetViewLinkState.pvsm}" 31 "DATA{${paraview_test_data_directory_input}/Data/can-restarts/,REGEX:.*}" 32 "DATA{${paraview_test_data_directory_input}/Data/CellDataWithNan.vtu}" 33 "DATA{${paraview_test_data_directory_input}/Data/cloud_layers_1k.jpg}" 34 "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphInput.vtp}" 35 "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphTree/,REGEX:.*}" 36 "DATA{${paraview_test_data_directory_input}/Data/CompositeGlyphTree.vtm}" 37 "DATA{${paraview_test_data_directory_input}/Data/ConfigureCategories.xml}" 38 "DATA{${paraview_test_data_directory_input}/Data/convergecfd_post_5016_spray.h5}" 39 "DATA{${paraview_test_data_directory_input}/Data/cth.vtr}" 40 "DATA{${paraview_test_data_directory_input}/Data/cube_1ts_mod.e}" 41 "DATA{${paraview_test_data_directory_input}/Data/CubeStringArray.vtk}" 42 "DATA{${paraview_test_data_directory_input}/Data/EnSight/,REGEX:.*}" 43 "DATA{${paraview_test_data_directory_input}/Data/ExRestarts/,REGEX:.*}" 44 "DATA{${paraview_test_data_directory_input}/Data/FDS/test_core/,REGEX:.*}" 45 "DATA{${paraview_test_data_directory_input}/Data/FieldDataBlocks/,REGEX:.*}" 46 "DATA{${paraview_test_data_directory_input}/Data/FieldDataBlocks/FieldDataBlocks/,REGEX:.*}" 47 "DATA{${paraview_test_data_directory_input}/Data/FileSeries/,REGEX:.*}" 48 "DATA{${paraview_test_data_directory_input}/Data/FileListPropertyWidgetPlugin.xml}" 49 "DATA{${paraview_test_data_directory_input}/Data/GenericIOReader/,REGEX:.*}" 50 "DATA{${paraview_test_data_directory_input}/Data/HeadMRVolume.mhd}" 51 "DATA{${paraview_test_data_directory_input}/Data/HeadMRVolume.raw}" 52 "DATA{${paraview_test_data_directory_input}/Data/hdf_fpm_simulation.erfh5}" 53 "DATA{${paraview_test_data_directory_input}/Data/Iron_Xdmf/,REGEX:.*}" 54 "DATA{${paraview_test_data_directory_input}/Data/LoadState.pvsm}" 55 "DATA{${paraview_test_data_directory_input}/Data/LoadStateDialog.pvsm}" 56 "DATA{${paraview_test_data_directory_input}/Data/LoadStateTextSourceRepresentation.pvsm}" 57 "DATA{${paraview_test_data_directory_input}/Data/MinimalTensors.vtu}" 58 "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces.vtm}" 59 "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces_0_0.vtp}" 60 "DATA{${paraview_test_data_directory_input}/Data/MultiBlockWithPieces_1_0.vtp}" 61 "DATA{${paraview_test_data_directory_input}/Data/NE2_ps_bath.png}" 62 "DATA{${paraview_test_data_directory_input}/Data/OMETIFF/multi-channel-time-series.ome.tif}" 63 "DATA{${paraview_test_data_directory_input}/Data/OverridePropertyPlugin.xml}" 64 "DATA{${paraview_test_data_directory_input}/Data/PlotOverLineLegacy.pvsm}" 65 "DATA{${paraview_test_data_directory_input}/Data/PLOAD_C_xMax.bdf}" 66 "DATA{${paraview_test_data_directory_input}/Data/PNGReadersPlugin.xml}" 67 "DATA{${paraview_test_data_directory_input}/Data/PropertyLink.pvsm}" 68 "DATA{${paraview_test_data_directory_input}/Data/ReaderNamePlugin.xml}" 69 "DATA{${paraview_test_data_directory_input}/Data/RectGrid2.vtk}" 70 "DATA{${paraview_test_data_directory_input}/Data/RodPlate/,REGEX:.*}" 71 "DATA{${paraview_test_data_directory_input}/Data/SLAC/pic-example/,REGEX:.*}" 72 "DATA{${paraview_test_data_directory_input}/Data/SPCTH/,REGEX:.*}" 73 "DATA{${paraview_test_data_directory_input}/Data/SPCTH/Dave_Karelitz_Small/,REGEX:.*}" 74 "DATA{${paraview_test_data_directory_input}/Data/SPCTH/DerivedDensity/,REGEX:.*}" 75 "DATA{${paraview_test_data_directory_input}/Data/Scenario1_p1.h5}" 76 "DATA{${paraview_test_data_directory_input}/Data/Scenario1_p1.xmf}" 77 "DATA{${paraview_test_data_directory_input}/Data/Test1.h5}" 78 "DATA{${paraview_test_data_directory_input}/Data/Test1.xmf}" 79 "DATA{${paraview_test_data_directory_input}/Data/TestCompositePropertyWidgetDecoratorPlugin.xml}" 80 "DATA{${paraview_test_data_directory_input}/Data/TestMultipleNumberOfComponentsPlugin.xml}" 81 "DATA{${paraview_test_data_directory_input}/Data/VisItBridge/,REGEX:.*}" 82 "DATA{${paraview_test_data_directory_input}/Data/nek5000/eddy_uv/,REGEX:.*}" 83 "DATA{${paraview_test_data_directory_input}/Data/amr/,REGEX:.*}" 84 "DATA{${paraview_test_data_directory_input}/Data/amr/wavelet/,REGEX:.*}" 85 "DATA{${paraview_test_data_directory_input}/Data/artifact.dta}" 86 "DATA{${paraview_test_data_directory_input}/Data/amr_gaussian_pulse.vtkhdf}" 87 "DATA{${paraview_test_data_directory_input}/Data/blow.vtk}" 88 "DATA{${paraview_test_data_directory_input}/Data/blow_data.myvtk}" 89 "DATA{${paraview_test_data_directory_input}/Data/bluntfin.vts}" 90 "DATA{${paraview_test_data_directory_input}/Data/BoxWithFaceData.cgns}" 91 "DATA{${paraview_test_data_directory_input}/Data/can.ex2}" 92 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.0}" 93 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.1}" 94 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.2}" 95 "DATA{${paraview_test_data_directory_input}/Data/can.e.4/can.e.4.3}" 96 "DATA{${paraview_test_data_directory_input}/Data/cavity/,REGEX:.*}" 97 "DATA{${paraview_test_data_directory_input}/Data/cavity/system/,RECURSE:,REGEX:.*}" 98 "DATA{${paraview_test_data_directory_input}/Data/cavity/constant/,RECURSE:,REGEX:.*}" 99 "DATA{${paraview_test_data_directory_input}/Data/cavity/0/,RECURSE:,REGEX:.*}" 100 "DATA{${paraview_test_data_directory_input}/Data/cavity/0.5/,RECURSE:,REGEX:.*}" 101 "DATA{${paraview_test_data_directory_input}/Data/cavity/1/,RECURSE:,REGEX:.*}" 102 "DATA{${paraview_test_data_directory_input}/Data/cavity/1.5/,RECURSE:,REGEX:.*}" 103 "DATA{${paraview_test_data_directory_input}/Data/cavity/2/,RECURSE:,REGEX:.*}" 104 "DATA{${paraview_test_data_directory_input}/Data/cavity/2.5/,RECURSE:,REGEX:.*}" 105 "DATA{${paraview_test_data_directory_input}/Data/cgns_np01/,REGEX:.*}" 106 "DATA{${paraview_test_data_directory_input}/Data/cgns_np04/,REGEX:.*}" 107 "DATA{${paraview_test_data_directory_input}/Data/bc_struct.cgns}" 108 "DATA{${paraview_test_data_directory_input}/Data/comb.q}" 109 "DATA{${paraview_test_data_directory_input}/Data/combxyz.bin}" 110 "DATA{${paraview_test_data_directory_input}/Data/cow.vtp}" 111 "DATA{${paraview_test_data_directory_input}/Data/cth.vtr}" 112 "DATA{${paraview_test_data_directory_input}/Data/cube.off}" 113 "DATA{${paraview_test_data_directory_input}/Data/cube.vtu}" 114 "DATA{${paraview_test_data_directory_input}/Data/cylinder_run1.e}" 115 "DATA{${paraview_test_data_directory_input}/Data/cylinder_run2.e}" 116 "DATA{${paraview_test_data_directory_input}/Data/disk_out_ref.ex2}" 117 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation.clone.pvd}" 118 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation.pvd}" 119 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation/,REGEX:.*}" 120 "DATA{${paraview_test_data_directory_input}/Data/dualSphereAnimation4.pvd}" 121 "DATA{${paraview_test_data_directory_input}/Data/elements.vtu}" 122 "DATA{${paraview_test_data_directory_input}/Data/EngineSector.cgns}" 123 "DATA{${paraview_test_data_directory_input}/Data/ensemble-wavelet/,REGEX:.*}" 124 "DATA{${paraview_test_data_directory_input}/Data/Fides/cartesian-attr.bp}" 125 "DATA{${paraview_test_data_directory_input}/Data/Fides/cartesian-attr.bp.dir/,REGEX:.*}" 126 "DATA{${paraview_test_data_directory_input}/Data/Fides/tris-blocks-time-attr.bp}" 127 "DATA{${paraview_test_data_directory_input}/Data/Fides/tris-blocks-time-attr.bp.dir/,REGEX:.*}" 128 "DATA{${paraview_test_data_directory_input}/Data/field.vtk}" 129 "DATA{${paraview_test_data_directory_input}/Data/filters.xml}" 130 "DATA{${paraview_test_data_directory_input}/Data/glTF/AnimatedMorphCube/,REGEX:.*}" 131 "DATA{${paraview_test_data_directory_input}/Data/glTF/BoxAnimated/,REGEX:.*}" 132 "DATA{${paraview_test_data_directory_input}/Data/glTF/InterpolationTest/,REGEX:.*}" 133 "DATA{${paraview_test_data_directory_input}/Data/glTF/NestedRings/NestedRings.glb}" 134 "DATA{${paraview_test_data_directory_input}/Data/glTF/Triangle/Triangle.glb}" 135 "DATA{${paraview_test_data_directory_input}/Data/glTF/SimpleSkin/SimpleSkin.gltf}" 136 "DATA{${paraview_test_data_directory_input}/Data/glTF/WaterBottle/WaterBottle.glb}" 137 "DATA{${paraview_test_data_directory_input}/Data/HTG/binary_3D_333_mask.htg}" 138 "DATA{${paraview_test_data_directory_input}/Data/HTG/ghost.htg}" 139 "DATA{${paraview_test_data_directory_input}/Data/HTGMulti.vtm}" 140 "DATA{${paraview_test_data_directory_input}/Data/HTGMulti/HTGMulti_0_0.htg}" 141 "DATA{${paraview_test_data_directory_input}/Data/HTGMulti/HTGMulti_1_0.htg}" 142 "DATA{${paraview_test_data_directory_input}/Data/WaveletGradientLegacy.pvsm}" 143 "DATA{${paraview_test_data_directory_input}/Data/img1.png}" 144 "DATA{${paraview_test_data_directory_input}/Data/img1.mypng}" 145 "DATA{${paraview_test_data_directory_input}/Data/img2.png}" 146 "DATA{${paraview_test_data_directory_input}/Data/iron_protein.vtk}" 147 "DATA{${paraview_test_data_directory_input}/Data/linesPolydata.vtk}" 148 "DATA{${paraview_test_data_directory_input}/Data/LogoSource.png}" 149 "DATA{${paraview_test_data_directory_input}/Data/manyTypes.vtu}" 150 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces.vtm}" 151 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_0_0.vtu}" 152 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_0_1.vtu}" 153 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_1_0.vtu}" 154 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_1_1.vtu}" 155 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_2_0.vtu}" 156 "DATA{${paraview_test_data_directory_input}/Data/mb_with_pieces/pvi_Material_Remap2_0005_2_1.vtu}" 157 "DATA{${paraview_test_data_directory_input}/Data/mg_diff_0062.vtm}" 158 "DATA{${paraview_test_data_directory_input}/Data/mg_diff_0062/,REGEX:.*}" 159 "DATA{${paraview_test_data_directory_input}/Data/multicomb_0.vts}" 160 "DATA{${paraview_test_data_directory_input}/Data/multicomb_1.vts}" 161 "DATA{${paraview_test_data_directory_input}/Data/multicomb_2.vts}" 162 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece.vtm}" 163 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece1.vts}" 164 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece2.vts}" 165 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece3.vts}" 166 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece4.vts}" 167 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece5.vts}" 168 "DATA{${paraview_test_data_directory_input}/Data/MultiPiece/Piece6.vts}" 169 "DATA{${paraview_test_data_directory_input}/Data/non_convex_polygon.vtu}" 170 "DATA{${paraview_test_data_directory_input}/Data/office.binary.vtk}" 171 "DATA{${paraview_test_data_directory_input}/Data/OMF/test_file.omf}" 172 "DATA{${paraview_test_data_directory_input}/Data/OSPRayMaterials/materials.json}" 173 "DATA{${paraview_test_data_directory_input}/Data/pbrSpheres.vtp}" 174 "DATA{${paraview_test_data_directory_input}/Data/pbrSpheresAlbedo.jpg}" 175 "DATA{${paraview_test_data_directory_input}/Data/pbrSpheresORM.jpg}" 176 "DATA{${paraview_test_data_directory_input}/Data/pointSet.vtk}" 177 "DATA{${paraview_test_data_directory_input}/Data/ParaView_Mark.png}" 178 "DATA{${paraview_test_data_directory_input}/Data/ParaView_Logo.png}" 179 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_0_0.vtp}" 180 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_1_0.vtp}" 181 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_2_0.vtp}" 182 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_3_0.vtp}" 183 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_4_0.vtp}" 184 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_5_0.vtp}" 185 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_6_0.vtp}" 186 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_7_0.vtp}" 187 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_8_0.vtp}" 188 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_9_0.vtp}" 189 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_10_0.vtp}" 190 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_11_0.vtp}" 191 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_12_0.vtp}" 192 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_13_0.vtp}" 193 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData/PartialFieldData_14_0.vtp}" 194 "DATA{${paraview_test_data_directory_input}/Data/PartialFieldDataMultiBlock/PartialFieldData.vtm}" 195 "DATA{${paraview_test_data_directory_input}/Data/PolarAxesDeprecation.pvsm}" 196 "DATA{${paraview_test_data_directory_input}/Data/porphyrin.cml}" 197 "DATA{${paraview_test_data_directory_input}/Data/quadraticTetra01.vtu}" 198 "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells.pvtu}" 199 "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells_0.vtu}" 200 "DATA{${paraview_test_data_directory_input}/Data/quadratic_tets_with_ghost_cells_1.vtu}" 201 "DATA{${paraview_test_data_directory_input}/Data/random_torus.vtp}" 202 "DATA{${paraview_test_data_directory_input}/Data/room.cas.h5}" 203 "DATA{${paraview_test_data_directory_input}/Data/room.dat.h5}" 204 "DATA{${paraview_test_data_directory_input}/Data/sample.h5part}" 205 "DATA{${paraview_test_data_directory_input}/Data/servers-wiki.pvsc}" 206 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/coneScript.py}" 207 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/simpleScript.py}" 208 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/LinkRenderViewsCheckSize.py}" 209 "DATA{${paraview_test_data_directory_input}/Data/Udirectory/resetSession.py}" 210 "DATA{${paraview_test_data_directory_input}/Data/sineWaves.csv}" 211 "DATA{${paraview_test_data_directory_input}/Data/singleSphereAnimation.pvd}" 212 "DATA{${paraview_test_data_directory_input}/Data/singleSphereAnimation/,REGEX:.*}" 213 "DATA{${paraview_test_data_directory_input}/Data/spiaggia_di_mondello_1k.hdr}" 214 "DATA{${paraview_test_data_directory_input}/Data/SliceDeprecation.pvsm}" 215 "DATA{${paraview_test_data_directory_input}/Data/SteeringDataGeneratorPlugin.xml}" 216 "DATA{${paraview_test_data_directory_input}/Data/squareBend/,REGEX:.*}" 217 "DATA{${paraview_test_data_directory_input}/Data/squareBend/system/,RECURSE:,REGEX:.*}" 218 "DATA{${paraview_test_data_directory_input}/Data/squareBend/constant/,RECURSE:,REGEX:.*}" 219 "DATA{${paraview_test_data_directory_input}/Data/squareBend/50/,RECURSE:,REGEX:.*}" 220 "DATA{${paraview_test_data_directory_input}/Data/squareBend/100/,RECURSE:,REGEX:.*}" 221 "DATA{${paraview_test_data_directory_input}/Data/tensors.pvti}" 222 "DATA{${paraview_test_data_directory_input}/Data/test_fielddata.vtk}" 223 "DATA{${paraview_test_data_directory_input}/Data/test_transient_poly_data.vtkhdf}" 224 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartdscol/,REGEX:.*}" 225 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartdscol.vtpc}" 226 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartds/,REGEX:.*}" 227 "DATA{${paraview_test_data_directory_input}/Data/testxmlpartds.vtpd}" 228 "DATA{${paraview_test_data_directory_input}/Data/time_source.pvsm}" 229 "DATA{${paraview_test_data_directory_input}/Data/timestep_0_15.vts}" 230 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/todd2_htg.pio}" 231 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/todd2_ug.pio}" 232 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/dumps/3D_nomix_diff-dmp000000}" 233 "DATA{${paraview_test_data_directory_input}/Data/todd2_small/dumps/3D_nomix_diff-dmp000010}" 234 "DATA{${paraview_test_data_directory_input}/Data/tube.exo}" 235 "DATA{${paraview_test_data_directory_input}/Data/Unbalanced3DepthOctTree3x2x3.htg}" 236 "DATA{${paraview_test_data_directory_input}/Data/vehicle_data.csv}" 237 "DATA{${paraview_test_data_directory_input}/Data/viscoplastic-ring.h5}" 238 "DATA{${paraview_test_data_directory_input}/Data/vtkHDF/pdc_multi.vtkhdf}" 239 "DATA{${paraview_test_data_directory_input}/Data/waveletElevation.vti}" 240 "DATA{${paraview_test_data_directory_input}/Data/waveletMaterial.vti}" 241 "DATA{${paraview_test_data_directory_input}/Data/WaveletThresholdLegacy.pvsm}" 242 "DATA{${paraview_test_data_directory_input}/Data/x_ray_copy_1.json}" 243 "DATA{${paraview_test_data_directory_input}/Data/x_ray_copy_2.json}" 244 "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs.vtm}" 245 "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs/youngs_0.vtu}" 246 "DATA{${paraview_test_data_directory_input}/Data/YoungsMaterialInterface/youngs/youngs_1.vtu}" 247 "DATA{${paraview_test_data_directory_input}/Data/ugrid.nc}" 248 "DATA{${paraview_test_data_directory_input}/Data/UnstructuredGridWithTwoAdjacentHexahedraOfDifferentOrder.vtu}" 249 "DATA{${paraview_test_data_directory_input}/Data/DecimatePolyline.vtp}" 252 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAXAxis.png}" 253 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAYAxis.png}" 254 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AAZAxis.png}" 255 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AnisotropyPBR.png}" 256 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid1.png}" 257 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid2.png}" 258 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid3.png}" 259 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid4.png}" 260 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid6.png}" 261 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid7.png}" 262 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid8.png}" 263 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid9.png}" 264 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/AxesGrid10.png}" 265 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BatchAxesGrid.png}" 266 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-HideOneBlock.png}" 267 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-HideTwoBlocks.png}" 268 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowAllBlocks.png}" 269 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowOneBlock.png}" 270 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-bake-ShowZeroBlock.png}" 271 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-BlockOpacity.png}" 272 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-ShowAllBlocks.png}" 273 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-ShowOnlyBlock.png}" 274 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockContextMenu-UnsetBlockOpacity.png}" 275 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-MB.png}" 276 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-MBWithPieces.png}" 277 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-PDC.png}" 278 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BlockLinkedSelection-PDC_1.png}" 279 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-Transform.png}" 280 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipDefault.png}" 281 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipCheckUseReferenceBounds.png}" 282 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/BoxWidget-ClipUncheckUseReferenceBounds.png}" 283 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CalculatorQuotedVariable1.png}" 284 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CalculatorQuotedVariable2.png}" 285 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Parallel.png}" 286 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Parallel_1.png}" 287 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Perspective.png}" 288 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CameraLink-Perspective_1.png}" 289 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterA.png}" 290 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterB.png}" 291 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterC.png}" 292 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoricalAutomaticAnnotationsInterD.png}" 293 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CategoriesWithNaN.png}" 294 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CGNSReaderCellMesh.png}" 295 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CGNSReaderFaceMesh.png}" 296 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsA.png}" 297 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsB.png}" 298 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsC.png}" 299 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsD.png}" 300 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsE.png}" 301 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsF.png}" 302 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsG.png}" 303 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartAxisRangeAndLabelsH.png}" 304 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartDefaultSettings_A.png}" 305 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartDefaultSettings_B.png}" 306 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA.png}" 307 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA_1.png}" 308 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesA_2.png}" 309 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartLoadNoVariablesB.png}" 310 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ChartsClearSelection.png}" 311 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS12-Clamped.png}" 312 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS12-Unchanged.png}" 313 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ClampAndUpdateColorMap-TS6.png}" 314 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorBy.png}" 315 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorFreehandDrawing.png}" 316 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorFreehandDrawing_A.png}" 317 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles.png}" 318 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles_A.png}" 319 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityEditorRangeHandles_B.png}" 320 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_A.png}" 321 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_B.png}" 322 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_C.png}" 323 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_D.png}" 324 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_E.png}" 325 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_F.png}" 326 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_G.png}" 327 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_M.png}" 328 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_R.png}" 329 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_T.png}" 330 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_U.png}" 331 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorOpacityTableEditorHistogram_V.png}" 332 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorLegendBackground.png}" 333 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ColorLegendScaledScreenshot.png}" 334 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-Default.png}" 335 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-SurfaceEdgesRepr.png}" 336 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ComputeNormalInRepresentation-WithAngle.png}" 337 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConnectivityCountAscending.png}" 338 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConnectivityCountDescending.png}" 339 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour1.png}" 340 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour2.png}" 341 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3.png}" 342 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3_1.png}" 343 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Contour3_2.png}" 344 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourRange_A.png}" 345 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourRange_B.png}" 346 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ContourCellData.png}" 347 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDCGNSReader.png}" 348 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderMesh.png}" 349 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderMesh_1.png}" 350 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CONVERGECFDReaderParcels.png}" 351 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ConvertToMoleculeBonds.png}" 352 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeBetweenX.png}" 353 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeBetweenZ.png}" 354 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeLowerMagnitude.png}" 355 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CriticalTimeUpperMagnitude.png}" 356 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomTCoords.png}" 357 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints.png}" 358 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints_A.png}" 359 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/CustomViewpoints_B.png}" 360 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid2X.png}" 361 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-Custom.png}" 362 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DataAxesGrid-CustomWithReset.png}" 363 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineAngle.png}" 364 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineCustomFieldHigh.png}" 365 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineCustomFieldLow.png}" 366 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DecimatePolylineDistance.png}" 367 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser0.png}" 368 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser1.png}" 369 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/DeleteSubtreePipelineBrowser2.png}" 370 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EdgeTintPBR.png}" 371 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EDLWithSubsampling.png}" 372 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource1.png}" 373 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource2.png}" 374 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EllipseSource3.png}" 375 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT0.png}" 376 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT1.png}" 377 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EnsembleT3.png}" 378 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EqualizeLayoutA.png}" 379 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EqualizeLayoutB.png}" 380 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExpandSelection_A.png}" 381 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExpandSelection_B.png}" 382 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractCellsByType.png}" 383 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractCellsByType2.png}" 384 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractCellsByType3.png}" 385 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed.png}" 386 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_1.png}" 387 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_2.png}" 388 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExtractSubsetWithSeed_3.png}" 389 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ExodusModeShapes.png}" 390 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EyeDomeLighting.png}" 391 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource1.png}" 392 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource2.png}" 393 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource3.png}" 394 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FastUniformGridSource4.png}" 395 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesFilterHTG.png}" 396 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesHTG.png}" 397 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesHTGNoMask.png}" 398 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesNonlinearCells.png}" 399 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FeatureEdgesRepresentationHTG.png}" 400 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesReader_cartesian.png}" 401 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FidesReader_blocks.png}" 402 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FileSeries1.png}" 403 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FileSeries2.png}" 404 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataTrace.png}" 405 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-is.png}" 406 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-oneof.png}" 407 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-GlobalElementId-range.png}" 408 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-ID-is.png}" 409 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Cell-ID-min-max-per-block.png}" 410 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-ge.png}" 411 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-ge-mean.png}" 412 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-le.png}" 413 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-le-mean.png}" 414 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-max.png}" 415 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-mean.png}" 416 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-Temp-min.png}" 417 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataQueries-Point-MultipleQueries.png}" 418 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataSelectLocation.png}" 419 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataSelectLocationMultiblock.png}" 420 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FindDataDialogNaN.png}" 421 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/FreezeQueryMultiblock.png}" 422 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ForceTimeDiamond.png}" 423 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFImporterNestedRings.png}" 424 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFImporterWaterBottle.png}" 425 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderTriangle.png}" 426 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderAnimatedMorphing.png}" 427 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderAnimatedMorphing_IsLoaded.png}" 428 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes_IsLoaded.png}" 429 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes_SceneOne.png}" 430 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleScenes.png}" 431 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations_IsLoaded.png}" 432 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations_ThreeAnimations.png}" 433 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderMultipleAnimations.png}" 434 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation_IsLoaded.png}" 435 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation_IsSkinned.png}" 436 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/glTFReaderToggleDeformation.png}" 437 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsGeneratorImageDistributed.png}" 438 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostCellsGeneratorImageSerial.png}" 439 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe1.png}" 440 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe2.png}" 441 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe3.png}" 442 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe4.png}" 443 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe5.png}" 444 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe6.png}" 445 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe7.png}" 446 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe8.png}" 447 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe9.png}" 448 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GhostFeatureEdgesAndWireframe10.png}" 449 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Glyph3DRepresentation_Cylinder.png}" 450 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Glyph3DRepresentation_Cylinder_1.png}" 451 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_A.png}" 452 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_B.png}" 453 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/GlyphWithEmptyCells_C.png}" 454 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection1.png}" 455 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection1_1.png}" 456 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection2.png}" 457 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection2_1.png}" 458 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection3.png}" 459 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection4.png}" 460 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HistogramSelection4_1.png}" 461 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip1-Plane.png}" 462 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip2-RevPlane.png}" 463 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisClip3-Box.png}" 464 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisCut.png}" 465 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridAxisReflection.png}" 466 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridCellCenters.png}" 467 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContour.png}" 468 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContour_1.png}" 469 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyA.png}" 470 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyA_1.png}" 471 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridContourStrategyB.png}" 472 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridDepthLimiter.png}" 473 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridEvaluateCoarse.png}" 474 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridExtractGhostCells.png}" 475 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridGeometry.png}" 476 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridGradient.png}" 477 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridMultiBlock.png}" 478 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridMultipleClip.png}" 479 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridObliquePlaneCutter.png}" 480 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridPlaneCutter.png}" 481 #
"DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold.png}" 482 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold-DepthOne.png}" 483 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/HyperTreeGridThreshold-DepthTwo.png}" 484 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/IndexedLookupInitialization.png}" 485 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/IndexedLookupInitialization_1.png}" 486 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightAddRemove1.png}" 487 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightAddRemove2.png}" 488 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightWidget.png}" 489 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LightToolbar.png}" 490 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection1.png}" 491 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection1_1.png}" 492 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection2.png}" 493 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection2_1.png}" 494 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection4.png}" 495 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LineChartSelection4_1.png}" 496 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView.png}" 497 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_1.png}" 498 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkCameraFromView_2.png}" 499 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LinkViewsLinked.png}" 500 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LoadStateMultiView.png}" 501 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap1.png}" 502 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap2.png}" 503 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap3.png}" 504 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap4.png}" 505 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap5.png}" 506 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap6.png}" 507 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMap7.png}" 508 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMapToggle1.png}" 509 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogColorMapToggle2.png}" 510 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSource.png}" 511 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSourceDefault.png}" 512 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/LogoSourcesInChartViews.png}" 513 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MatchBoundariesIgnoringCellOrder.png}" 514 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorCreateMaterials1.png}" 515 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorCreateMaterials2.png}" 516 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorLoadMaterials1.png}" 517 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorLoadMaterials2.png}" 518 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials1.png}" 519 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials2.png}" 520 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorSaveMaterials3.png}" 521 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene1.png}" 522 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene2.png}" 523 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MaterialEditorShaderBallScene3.png}" 524 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MathTextColumn.png}" 525 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MergePointBlocks.png}" 526 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MergeVectorComponents.png}" 527 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-BallStick.png}" 528 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-Custom.png}" 529 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Molecule-Liquorice.png}" 530 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockChartSelectionPlotView.png}" 531 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockChartSelectionRenderView.png}" 532 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties.png}" 533 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_A.png}" 534 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_B.png}" 535 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_C.png}" 536 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_D.png}" 537 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_E.png}" 538 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_F.png}" 539 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_G.png}" 540 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_H.png}" 541 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_I.png}" 542 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_J.png}" 543 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorProperties_K.png}" 544 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-SelectBlock2.png}" 545 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-SelectElementBlocks.png}" 546 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorSelection-HideBlock1.png}" 547 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultiBlockInspectorWithoutSelectOnClickSetting.png}" 548 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/MultipleColorOnSelectionA.png}" 549 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NestedViews.png}" 550 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NestedViews_1.png}" 551 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NetCDFUGRID.png}" 552 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision0Display.png}" 553 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision0Display_1.png}" 554 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision1Display.png}" 555 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision1Display_1.png}" 556 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision2Display.png}" 557 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision2Display_1.png}" 558 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision3Display.png}" 559 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision3Display_1.png}" 560 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision4Display.png}" 561 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/NonlinearSubdivision4Display_1.png}" 562 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/EmptyInitialCompositeReader.png}" 563 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMajorAxis.png}" 564 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMediumAxis.png}" 565 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OBBMinorAxis.png}" 566 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OffsetSliceWithPlane.png}" 567 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OMFReader.png}" 568 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/OpacityWidgetRange.png}" 569 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ParallelCoordinatesView.png}" 570 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ParallelCoordinatesView_1.png}" 571 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Slice.png}" 572 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSet_Surface.png}" 573 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Slice.png}" 574 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PartitionedDataSetCollection_Surface.png}" 575 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PBRSpheres.png}" 576 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PLYWriter.png}" 577 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteBlackBackground.png}" 578 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteBlueGrayBackground.png}" 579 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteGradientBackground.png}" 580 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteLightGrayBackground.png}" 581 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteNeutralGrayBackground.png}" 582 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteWarmGrayBackground.png}" 583 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteDarkGrayBackground.png}" 584 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PaletteWhiteBackground.png}" 585 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Boundary.png}" 586 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Center.png}" 587 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PlotOverLine_Uniform.png}" 588 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointGaussianScaleOpacityArrayA.png}" 589 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PointGaussianScaleOpacityArrayA.png}" 590 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes1.png}" 591 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes2.png}" 592 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PolarAxes3.png}" 593 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Preview-SingleView.png}" 594 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Preview-AllViews.png}" 595 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonAlgorithmPlugin.png}" 596 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonAlgorithmReadersAndWriters.png}" 597 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PythonShellRunScript.png}" 598 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PropertyContextMenu1.png}" 599 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/PropertyContextMenu2.png}" 600 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotArea.png}" 601 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotArea_1.png}" 602 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/QuartilePlotLines.png}" 603 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomAttributesHTGScalars.png}" 604 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RandomAttributesHTGVectors.png}" 605 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_BCOnly.png}" 606 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_BCOnlyBlockColors.png}" 607 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_CellData.png}" 608 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_LoadPatches.png}" 609 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadPartitionedCGNS_PointData.png}" 610 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadCGNSBCDataset.png}" 611 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries0.png}" 612 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries1.png}" 613 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFFileSeries2.png}" 614 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache0.png}" 615 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache1.png}" 616 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadIOHDFWithCache2.png}" 617 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReadFLUENTCFFFormat.png}" 618 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RectilinearVolumeRendering.png}" 619 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadAMReXGrid-AfterReload.png}" 620 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadAMReXGrid-BeforeReload.png}" 621 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadExodusFile-AfterReload.png}" 622 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReloadExodusFile-BeforeReload.png}" 623 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface.png}" 624 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface_1.png}" 625 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingSurface_2.png}" 626 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RemoteRenderingVolume.png}" 627 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanDefaultColor.png}" 628 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanGUIColor.png}" 629 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderNanPresetColor.png}" 630 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderViewContextMenuArrayColoring.png}" 631 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RenderViewContextMenuSolidColoring.png}" 632 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGridBranching_3.png}" 633 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DX.png}" 634 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DY.png}" 635 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToHyperTreeGrid2DZ.png}" 636 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleToLine.png}" 637 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_A.png}" 638 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_B.png}" 639 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResampleWithDataset_C.png}" 640 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetSession.png}" 641 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeA.png}" 642 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeA_1.png}" 643 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeB.png}" 644 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC.png}" 645 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC_1.png}" 646 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeC_2.png}" 647 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeD.png}" 648 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ResetToVisibleRangeE.png}" 649 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionA.png}" 650 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionB.png}" 651 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionC.png}" 652 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreArrayDefaultTransferFunctionC_1.png}" 653 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionA.png}" 654 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionB.png}" 655 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RestoreDefaultTransferFunctionC.png}" 656 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReverseLegend_A.png}" 657 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ReverseLegend_B.png}" 658 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RotateAroundOriginTransform.png}" 659 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerA.png}" 660 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerA_1.png}" 661 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerB.png}" 662 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerB_1.png}" 663 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerC.png}" 664 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerC_1.png}" 665 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerD.png}" 666 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/RulerD_1.png}" 667 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveLargeScreenshot.png}" 668 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveLargeScreenshot_1.png}" 669 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveSmallScreenshot.png}" 670 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SaveSmallScreenshot_1.png}" 671 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar1.png}" 672 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar2.png}" 673 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar3.png}" 674 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar4.png}" 675 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar5.png}" 676 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar6.png}" 677 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar7.png}" 678 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ScalarBar8.png}" 679 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsFrustumTrace.png}" 680 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsFrustumTrace_1.png}" 681 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsInteractiveTrace.png}" 682 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace.png}" 683 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace_1.png}" 684 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectCellsTrace_2.png}" 685 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectColorMapFromComboBox_A.png}" 686 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionByArray.png}" 687 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionEditor.png}" 688 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkParallelCoordinatesView.png}" 689 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkScriptingA.png}" 690 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectionLinkScriptingB.png}" 691 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsFrustumTrace.png}" 692 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsInteractiveTrace.png}" 693 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SelectPointsTrace.png}" 694 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparatedColorMapA.png}" 695 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparatedColorMapB.png}" 696 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_X.png}" 697 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Y.png}" 698 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Z.png}" 699 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeparateOpacityArray_Magnitude.png}" 700 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPreset.png}" 701 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexpNoRegexp.png}" 702 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexpYD.png}" 703 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SeriesPresetRegexp.png}" 704 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ShowMultiPieceFieldData.png}" 705 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Slice.png}" 706 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceDirectDoubleColoring.png}" 707 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceRepresentation.png}" 708 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlaneCellData.png}" 709 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlaneMultiBlock.png}" 710 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SliceWithPlane.png}" 711 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SpherePointSource_InterA.png}" 712 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SpherePointSource_InterB.png}" 713 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SplitViewTraceScreenshot.png}" 714 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SSAO.png}" 715 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorA.png}" 716 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorB.png}" 717 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/SteeringDataGeneratorC.png}" 718 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StepColorSpaceA.png}" 719 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StructuredGridCellBlanking.png}" 720 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/StructuredGridVolumeRendering.png}" 721 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TableFFT1.png}" 722 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TableFFT2.png}" 723 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TemporalSmoothingHalfWidthSmall.png}" 724 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TemporalSmoothingHalfWidthLarge.png}" 725 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestAnnotateSelectionFilter.png}" 726 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE-tile0.png}" 727 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVE-tile1.png}" 728 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVEVolRen-tile0.png}" 729 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCAVEVolRen-tile1.png}" 730 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_0.png}" 731 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_1.png}" 732 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCleanGridPointDataStrategies_2.png}" 733 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestColorMapModificationRendersAllViews.png}" 734 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestClipCylinder.png}" 735 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestColorHistogram.png}" 736 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestCompositedGeometryCulling.png}" 737 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestGeometryBoundsClobber.png}" 738 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestERFReader.png}" 739 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_boundaries_cc.png}" 740 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_boundaries.png}" 741 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_slice_cc.png}" 742 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t0_slice.png}" 743 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_boundaries_cc.png}" 744 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_boundaries.png}" 745 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_slice_cc.png}" 746 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestFDSReader_t8_slice.png}" 747 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_A.png}" 748 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_B.png}" 749 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_C.png}" 750 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGSelection_D.png}" 751 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGThreshold.png}" 752 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestHTGThreshold_1.png}" 753 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume1.png}" 754 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume2.png}" 755 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume3.png}" 756 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume4.png}" 757 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestIsoVolume5.png}" 758 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestLineChartLabelPrefix.png}" 759 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer1.png}" 760 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer2.png}" 761 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer3.png}" 762 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestMultiServer4.png}" 763 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestOFFReader.png}" 764 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPreviewTextScale.png}" 765 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPreviewTextScale_1.png}" 766 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonView.png}" 767 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonView_1.png}" 768 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestPythonViewScript.png}" 769 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TestResampleHyperTreeGridWithSphere.png}" 770 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourceBorder.png}" 771 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourceInteriorLines.png}" 772 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews.png}" 773 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews2.png}" 774 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TextSourcesInChartViews3.png}" 775 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/Threshold.png}" 776 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdAllComponents.png}" 777 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdAnyComponent.png}" 778 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdInvert.png}" 779 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentX.png}" 780 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentY.png}" 781 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedComponentZ.png}" 782 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ThresholdSelectedMagnitude.png}" 783 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-1x1-tile0.png}" 784 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x1-tile0.png}" 785 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x1-tile1.png}" 786 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile0.png}" 787 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile1.png}" 788 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile2.png}" 789 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-2x2-tile3.png}" 790 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile0.png}" 791 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile1.png}" 792 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TileDisplaySplitView-3x1-tile2.png}" 793 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TimeStepProgressBar_Inter.png}" 794 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ToneMapping.png}" 795 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceExodus.png}" 796 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceMultiViews.png}" 797 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceMultiViews_1.png}" 798 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TraceTimeControls.png}" 799 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_AllBlocks.png}" 800 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_OneBlock.png}" 801 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunctionResetOnVisibilityChange_TwoBlocks.png}" 802 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DEditor.png}" 803 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars.png}" 804 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_1.png}" 805 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalars_2.png}" 806 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditor.png}" 807 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorA.png}" 808 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TransferFunction2DYScalarsEditorB.png}" 809 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/TriangleStrips.png}" 810 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_A.png}" 811 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_B.png}" 812 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UniformInverseTransformSamplingGlyph_C.png}" 813 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Magnitude.png}" 814 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_X.png}" 815 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Y.png}" 816 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UnstructuredVolumeVectorComponent_Z.png}" 817 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges1.png}" 818 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges2.png}" 819 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges3.png}" 820 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges4.png}" 821 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges5.png}" 822 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UpdateTransferFunctionRanges6.png}" 823 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1.png}" 824 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1_1.png}" 825 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions1_2.png}" 826 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2.png}" 827 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2_1.png}" 828 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions2_2.png}" 829 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions3.png}" 830 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/UseDataPartitions4.png}" 831 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeCellSelection.png}" 832 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeCrop.png}" 833 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeOfRevolution.png}" 834 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeIsosurfaceBlendMode.png}" 835 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeNoMapScalars.png}" 836 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VolumeSliceBlendMode.png}" 837 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/VTKHDFWriter.png}" 838 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/WaveNoFontScale.png}" 839 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/WaveFontScale.png}" 840 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/YoungsMaterialInterface.png}" 841 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_ChangeParameters.png}" 842 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_Default.png}" 843 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_DisableBlocks.png}" 844 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYChart_EnableBlocks.png}" 845 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_Default.png}" 846 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_Default_1.png}" 847 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_UseIndexForX.png}" 848 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_UseIndexForX_1.png}" 849 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResult.png}" 850 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResult2.png}" 851 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResultChanged.png}" 852 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/XYHistogram_WithResultChangedNormalized.png}" 853 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestA.png}" 854 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestA_1.png}" 855 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestB.png}" 856 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestC.png}" 857 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomClosestD.png}" 858 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData.png}" 859 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData_A.png}" 860 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToData_B.png}" 861 "DATA{${CMAKE_CURRENT_SOURCE_DIR}/../Data/Baseline/ZoomToEmptyData.png}" 864 # Some tests can take a long time; increase their timeouts. 865 # Really very long (300 seconds): 866 set(SeparateOpacityArray_TIMEOUT 300)
867 set(TransferFunction2DYScalars_TIMEOUT 300)
868 set(UndoRedo1_TIMEOUT 300)
870 # Very
long (200 seconds):
871 set(EqualizeLayout_TIMEOUT 200)
873 # Somewhat
long (150 seconds):
874 set(AMReXParticlesReader_TIMEOUT 150)
875 set(Clip_TIMEOUT 150)
876 set(ColorOpacityEditorFreehandDrawing_TIMEOUT 150)
877 set(ColorOpacityTableEditorHistogram_TIMEOUT 150)
878 set(ComparativeVisPanel_TIMEOUT 150)
879 set(Ensemble_TIMEOUT 150)
880 set(HelpWindowHistory_TIMEOUT 150)
881 set(ImageVolumeRendering_TIMEOUT 150)
882 set(LagrangianIntegrationModel_TIMEOUT 150)
883 set(LagrangianParticleTrackerReseeding_TIMEOUT 150)
884 set(LagrangianParticleTracker_TIMEOUT 150)
885 set(MemoryInspectorPanel_TIMEOUT 150)
886 set(MultiBlockVolumeRendering_TIMEOUT 150)
887 set(MultiServer3_TIMEOUT 150)
888 set(PropertyContextMenu_TIMEOUT 150)
889 set(ProxyCategoriesConfiguration_TIMEOUT 150)
890 set(ProxyCategoriesDialog_TIMEOUT 150)
891 set(SaveTSV_TIMEOUT 150)
892 set(ScalarBarRange_TIMEOUT 150)
893 set(SeparatedColorMapOpacity_TIMEOUT 150)
894 set(SliceRepresentation_TIMEOUT 150)
895 set(SplitViewTrace_TIMEOUT 150)
896 set(SpreadSheet3_TIMEOUT 150)
897 set(TemporalParticleKeepDeadTrails_TIMEOUT 150)
898 set(TraceExportAndSaveData_TIMEOUT 150)
899 set(TransferFunction2D_TIMEOUT 150)
900 set(ZoomToData_TIMEOUT 150)
902 list (APPEND TESTS_WITHOUT_BASELINES
905 ArrayBoundsScaleDomain.xml
906 ArraySelectionWidget.xml
908 ComputeArrayMagnitudeSetting.xml
909 CustomOutputFormat.xml
910 DefaultReadersSetting.xml
911 DelimitedTextReader.xml
912 DynamicFieldDataDomain.xml
913 ExportFilteredColumnsSpreadsheet.xml
914 ExportSpreadsheetFormatting.xml
915 ExpressionsDialog.xml
916 ExpressionsExporter.xml
917 ExpressionsSettings.xml
918 ExtractParticlesOverTime.xml
919 FieldDataToAttribute.xml
920 FileDialogOpenInteractClose.xml
922 GradientBackwardsCompatibility.xml
923 ImportCustomPresets.xml
927 ModifyGUIWindowTitle.xml
928 OpacityWidgetRange.xml
931 PartialArrayInLineChart.xml
932 PlotOverLineLegacy.xml
933 PointCellDataConversion.xml
934 PolarAxesBackwardsCompatibility.xml
935 ProxyCategoriesConfiguration.xml
936 ProxyCategoriesDialog.xml
937 ProxyCategoriesDialogDefault.xml
938 ProxyCategoriesDialogSettings.xml
939 ProxyCategoriesFavorites.xml
940 ProxyCategoriesMenusDefault.xml
941 ProxyCategoriesToolbar.xml
942 QuickLaunchCreateProxy.xml
943 QuickLaunchNavigation.xml
944 QuickLaunchRequest.xml
945 ReadIOHDFAMRMaxLevels.xml
946 ReaderRegistrationName.xml
949 ServerConnectDialog.xml
950 SliceBackwardsCompatibility.xml
951 SpatioTemporalHarmonicsAttribute.xml
952 SpatioTemporalHarmonicsSource.xml
953 SpreadSheetFieldData.xml
954 SpreadSheetSelectedCellConnectivity.xml
955 StringInLineChartView.xml
957 TensorPrincipalInvariants.xml
958 TestCompositePropertyWidgetDecorator.xml
959 TestFileListPropertyWidget.xml
961 ThresholdBackwardsCompatibility.xml
965 TimeManagerSequence.xml
966 WriteXMLTimeValue.xml
970 if (PARAVIEW_PLUGIN_ENABLE_EULATestPlugin)
971 list(APPEND TESTS_WITHOUT_BASELINES
975 if (PARAVIEW_ENABLE_OPENVDB)
976 list (APPEND TESTS_WITHOUT_BASELINES
982 list(APPEND TESTS_WITHOUT_BASELINES
983 HelpWindowHistory.xml)
987 list(APPEND TESTS_WITHOUT_BASELINES
992 list (APPEND TESTS_WITH_INLINE_COMPARES
997 BlockLinkedSelection.xml
998 CalculatorQuotedVariable.xml
1000 CGNSReaderDataLocation.xml
1001 ChartDefaultSettings.xml
1002 ChartLoadNoVariables.xml
1003 ClampAndUpdateColorMap.xml
1004 ColorOpacityTableEditorHistogram.xml
1005 ComputeNormalsInRepresentation.xml
1011 DecimatePolyline.xml
1012 DeleteSubtreePipelineBrowser.xml
1016 ExtractSubsetWithSeed.xml
1017 FastUniformGridSource.xml
1019 FeatureEdgesHTGNoMask.xml
1021 FontScalingInScreenshots.xml
1022 HyperTreeGridAxisClip.xml
1023 HyperTreeGridAxisCut.xml
1024 HyperTreeGridAxisReflection.xml
1025 HyperTreeGridCellCenters.xml
1026 HyperTreeGridContour.xml
1027 HyperTreeGridContourStrategy.xml
1028 HyperTreeGridDepthLimiter.xml
1029 HyperTreeGridEvaluateCoarse.xml
1030 HyperTreeGridExtractGhostCells.xml
1031 HyperTreeGridGeometry.xml
1032 HyperTreeGridGradient.xml
1033 HyperTreeGridMultiBlock.xml
1034 HyperTreeGridMultipleClip.xml
1035 HyperTreeGridObliquePlaneCutter.xml
1036 HyperTreeGridPlaneCutter.xml
1037 HyperTreeGridThreshold.xml
1040 LineChartSelection.xml
1041 LoadStateMultiView.xml
1043 LogColorMapToggle.xml
1044 LogoSourcesInChartViews.xml
1045 MemoryInspectorPanel.xml
1047 MultiBlockInspectorProperties.xml
1048 MultiBlockInspectorSelection.xml
1049 MultiBlockChartSelection.xml
1050 MultipleColorOnSelection.xml
1052 NonlinearSubdivisionDisplay.xml
1053 PaletteBackgrounds.xml
1054 ParallelCoordinatesView.xml
1055 PartitionedDataSet.xml
1056 PartitionedDataSetCollection.xml
1059 PreviewFontScaling.xml
1060 PropertyContextMenu.xml
1062 ReadPartitionedCGNS.xml
1063 ReadCGNSBCDataset.xml
1064 ReadIOHDFFileSeries.xml
1065 ReadIOHDFWithCache.xml
1066 ReadFLUENTCFFFormat.xml
1067 RectilinearFractal.xml
1069 ReloadExodusFile.xml
1073 RenderViewContextMenu.xml
1074 ResetToVisibleRange.xml
1077 SaveLargeScreenshot.xml
1079 SelectColorMapFromComboBox.xml
1081 SelectionLinkParallelCoordinatesView.xml
1082 SeparateOpacityArray.xml
1083 SliceRepresentation.xml
1084 SteeringDataGenerator.xml
1085 TemporalSmoothing.xml
1086 TestCleanGridPointDataStrategies.xml
1087 TestColorMapModificationRendersAllViews.xml
1089 TestHTGSelection.xml
1090 TestHTGThreshold.xml
1092 TextSourceBorder.xml
1094 ThresholdComponentModes.xml
1095 TransferFunctionResetOnVisibilityChange.xml
1096 UnstructuredVolumeRenderingVectorComponent.xml
1097 UpdateTransferFunctionRanges.xml
1103 # Image data delivery to render server not supported. 1104 set(SeparateOpacityArray_DISABLE_CRS TRUE)
1107 # Workaround to avoid testing failures on high-res Retina displays on Macs 1108 list(APPEND TESTS_WITH_INLINE_COMPARES
1109 ColorLegendScaledScreenshot.xml
1113 list(APPEND TESTS_WITH_BASELINES
1114 AxisAlignedCutterAMR.xml
1115 AxisAlignedCutterHTG.xml
1116 AxisAlignedCutterMBHierarchy.xml
1117 AxisAlignedCutterPDCNoHierarchy.xml
1119 BoxWidgetVisibleBlock.xml
1120 CameraOrientationWidget.xml
1121 ChartsClearSelection.xml
1122 CleanToGridRemovePoints.xml
1123 ConstantShadingPerObject.xml
1124 CONVERGECFDCGNSReader.xml
1126 EmptyInitialCompositeReader.xml
# Issue #21293 1127 FeatureEdgesFilterHTG.xml
1128 FeatureEdgesRepresentationHTG.xml
1129 IOSSMergeExodusEntityBlocks.xml
1131 IntegrateVariablesPDC.xml
1133 MergeVectorComponents.xml
1134 MissingPartialArraysColoredByNaN.xml
1135 MoleculeScalarBar.xml
1138 QuadraturePointsDS.xml
1139 PartialFieldDataMultiBlock.xml
1140 ParticleTracerGlyph.xml
1144 PointAndCellIdsHTG.xml
1146 RemoveGhostInformationHTG.xml
1149 SaveLoadScreenShotWithEmbedState.xml
1150 SelectionBlocksThrough.xml
1151 SelectionByArray.xml
1153 SeriesPresetRegexp.xml
1154 ShowMultiPieceFieldData.xml
1155 TemporalParticleKeepDeadTrails.xml
1156 TestHiddenLineRemoval.xml
1157 TestOpenFOAMWeighByCell.xml
1158 TestResampleHyperTreeGridWithSphere.xml
1159 TransferFunction2D.xml
1160 TransferFunction2DYScalars.xml
1161 VolumeOfRevolution.xml
1162 ZoomClosestOffsetRatio.xml
1168 if(PARAVIEW_ENABLE_VISITBRIDGE)
1169 list(APPEND TESTS_WITH_BASELINES
1170 VisItBridgeChombo.xml
1171 VisItBridgeLAMMPSDump.xml
1172 VisItBridgeLAMMPSDump2.xml
1175 VisItBridgeMoleculeColoring.xml
1177 VisItBridgePFLOTRAN.xml
1178 # disabling
this test
for now, not sure why it fails
1179 # even with 5.7 binarie
1180 #VisItBridgePixie.xml
1181 VisItBridgeSamrai.xml
1182 TruchasReaderWithVisItBridge.xml)
1183 list(APPEND TESTS_WITH_INLINE_COMPARES
1184 CONVERGECFDReaderWithVisItBridge.xml
1187 # A number of VisIt readers support reading of .pdb and 1188 # of .h5 files, so when the VisItBridge is enabled, 1189 # the test must take extra steps to select the correct reader. 1191 # When the VisItBridge is not enabled, there is no need to select 1193 list(APPEND TESTS_WITH_BASELINES
1194 MoleculeColoring.xml
1197 list(APPEND TESTS_WITH_INLINE_COMPARES
1198 CONVERGECFDReader.xml)
1201 if(PARAVIEW_ENABLE_RAYTRACING)
1202 list(APPEND TESTS_WITH_BASELINES
1206 if(PARAVIEW_ENABLE_OPENTURNS)
1207 list(APPEND TESTS_WITH_BASELINES
1208 HistogramKernelSmoothing.xml)
1209 list(APPEND TESTS_WITH_BASELINES
1210 PlotMatrixViewDensityMaps.xml)
1213 # hits OSX bug with FileDialog so exclude test on APPLE 1215 list (APPEND TESTS_WITH_INLINE_COMPARES
1216 HistogramSelection.xml)
1219 # TODO: Port to the new API. 1221 # These tests are too complex to run in parallel. 1222 set (CATALYST_SIMULATION CatalystWaveletDriver.py)
1223 set (INSITU_SCRIPT CatalystWaveletCoprocessing)
1225 set (
"${test_name}_FORCE_SERIAL" TRUE)
1226 add_pv_test(
"pv" "_DISABLE_C" 1228 --script-ignore-output-errors --script $<TARGET_FILE:ParaView::pvbatch> --sym
1229 ${CMAKE_CURRENT_SOURCE_DIR}/${CATALYST_SIMULATION}
1230 ${INSITU_SCRIPT}
"${duration}" 1232 --client ${CLIENT_EXECUTABLE}
1234 ${command_line_connect_command}
1236 --test-directory=${PARAVIEW_TEST_DIR}
1237 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1238 TEST_SCRIPTS ${test_name}.xml
1239 EXTRA_LABELS
"catalyst")
1241 add_pv_test(pvcs
"_DISABLE_CS" 1243 --script-np 5 --script-ignore-output-errors
1244 --script $<TARGET_FILE:ParaView::pvbatch> --sym
1245 ${CMAKE_CURRENT_SOURCE_DIR}/${CATALYST_SIMULATION}
1246 ${INSITU_SCRIPT}
"${duration}" 1248 --server $<TARGET_FILE:ParaView::pvserver>
1251 --client ${CLIENT_EXECUTABLE}
1253 ${command_line_connect_command}
1255 --test-directory=${PARAVIEW_TEST_DIR}
1256 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1257 TEST_SCRIPTS ${test_name}.xml
1258 EXTRA_LABELS
"catalyst")
1262 if (PARAVIEW_ENABLE_XDMF2 AND NOT PARAVIEW_ENABLE_XDMF3)
1263 # Xdmf2 is optional. 1264 # And when both Xdmf2 and Xdmf3 are enabled, the SelectReader dialog 1265 # confuses these tests. So, we'll disable them for now. 1266 # We need a better mechanism to handle such cases in the testing framework. 1267 list(APPEND TESTS_WITH_BASELINES
1270 XdmfReadImageData.xml
1271 XdmfReadImageDataCollection.xml
1272 XdmfReadRectilinearGrid.xml
1273 XdmfReadRectilinearGridCollection.xml
1274 XdmfReadStructuredGrid.xml
1275 XdmfReadStructuredGridCollection.xml
1276 XdmfGridAttributes.xml
1281 list(APPEND TESTS_WITH_BASELINES
1282 4AxesContextView.xml
1283 AccentuatedFilename.xml
1284 AdaptiveResampleToImage.xml
1285 AMRArraySelection.xml
1288 AMReXParticlesReader.xml
1289 AxisAlignedSliceBackwardCompat.xml
1291 AnimationCameraExportImport.xml
1292 AnimationFollowPath.xml
1293 AnimationSetTimeCursor.xml
1294 AnimationUseCamera.xml
1298 ConvertToMolecule.xml
1300 CopyPasteFilters.xml
1301 CopyPasteProperties.xml
1307 CTHAMRMaterialInterfaceFilter.xml
1308 CTHDerivedDensity2DClyinder.xml
1309 AddActiveValuesFromVisibleObjects.xml
1310 AnimatePipelineTime.xml
1311 AngularPeriodicFilter.xml
1312 3DWidgetInCustomFilter.xml
1317 CameraWidgetViewLink.xml
1318 CameraWidgetViewLinkState.xml
1319 CategoriesWithNaN.xml
1321 # Disabled due to #20508
1322 # ChangeGlyphRepVisibility.xml
1323 ChangingTimestepsInStateFiles.xml
1324 ChartAxisRangeAndLabels.xml
1328 ColorAnnotationsVisibilitiesAndOpacities.xml
1329 ColorEditorControls.xml
1330 ColorEditorVolumeControls.xml
1331 ColorLegendMinMaxLabels.xml
1332 ColorLegendBackground.xml
1333 ColorOpacityTableEditing.xml
1334 ColorOpacityEditorFreehandDrawing.xml
1335 ColorOpacityEditorRangeHandles.xml
1336 CombineFrustumSelections.xml
1337 CategoricalAutomaticAnnotations.xml
1338 CategoricalColors.xml
1339 CategoricalOpacities.xml
1340 ColorByCellDataStringArray.xml
1341 ComparativeVisPanel.xml
1342 ComparativeViewOverlay.xml
1343 # disabling overlay test
for now. It has issues with Time 0.
1344 # ComparativeOverlay.xml
1345 CompositeSurfaceSelection.xml
1346 ComputeConnectedSurfaceProperties.xml
1348 CustomSourceProbe.xml
1349 CustomViewpoints.xml
1351 DisableResetDisplayEmptyViews.xml
1352 DualSphereAnimation.xml
1356 EnSightTensorInversion.xml
1357 EnSightTensorInversionBin.xml
1358 ExodusGlobalDataWithRestarts.xml
1359 ExodusSingleTimeStep.xml
1361 ExportLinePlotToCSV.xml
1362 ExportLinePlotToTSV.xml
1363 ExportSceneSpreadSheetView2.xml
1364 ExportX3dPOVVRML.xml
1367 ExtractCellsByType.xml
1368 ExtractComponentFilter.xml
1370 ExtractTimeSteps.xml
1373 FeatureEdgesNonlinearCells.xml
1376 FileDialogOpenFile.xml
1380 FollowHiddenData.xml
1383 GenerateTimeSteps.xml
1384 GenerateTimeStepsData.xml
1385 GhostCellsGeneratorImageSerial.xml
1386 Glyph3DCullingAndLOD.xml
1387 Glyph3DRepresentation.xml
1388 GlyphUseCellCenters.xml
1389 GlyphWithEmptyCells.xml
1390 GroupDataSetOutputType.xml
1391 glTFImporterNestedRings.xml
1392 glTFImporterWaterBottle.xml
1393 glTFReaderAnimatedMorphing.xml
1394 glTFReaderMultipleAnimations.xml
1395 glTFReaderMultipleScenes.xml
1396 glTFReaderToggleDeformation.xml
1397 glTFReaderTriangle.xml
1400 HorizontalColorLegendTitle.xml
1401 HyperTreeGridGhostCellsGenerator.xml
1402 IgnoreLogAxisWarning.xml
1403 ImageDataToUniformGrid.xml
1404 ImageVolumeRendering.xml
1405 InteractiveSelection.xml
1406 InteractiveViewLinkOffscreen.xml
1407 InteractiveViewLinkOnscreen.xml
1408 InteractiveViewLinkState.xml
1411 LinearCellExtrusion.xml
1413 LinkRepresentationProperties.xml
1414 LoadPartiallyUpdatedStateFiles.xml
1415 LoadSaveStateAnimation.xml
1417 LoadStateChooseDirectory.xml
1418 LoadStateChooseFiles.xml
1419 LoadStateTextSourceRepresentation.xml
1420 LoadStateUseExisting.xml
1421 LoadSaveStateVolume.xml
1422 ManyTypesXMLWriterReader.xml
1423 MatchBoundariesIgnoringCellOrder.xml
1424 MergePointBlocks.xml
1428 # MultiBlockAttributes1.xml
1429 MultiBlockInspector.xml
1430 MultiBlockInspectorAssembly.xml
1431 MultiBlockInspectorAssemblyExtractBlocks.xml
1432 MultiBlockInspectorAssemblyWithoutSelectOnClickSetting.xml
1433 MultiBlockInspectorExtractBlocks.xml
1434 MultiBlockSingleBlock.xml
1435 MultiBlockVolumeRendering.xml
1436 MultiBlockInspectorWithoutSelectOnClickSetting.xml
1437 MultiSliceMultiBlock.xml
1438 MultiSliceWavelet.xml
1440 NumberOfComponentsDomain.xml
1441 NonConvexPolygon.xml
1442 OctreeImageFilters.xml
1443 OMETIFFChannelCalculator.xml
1445 OrderedGroupDatasets.xml
1446 OrthographicView.xml
1447 OutOfRangeColors.xml
1449 PlotDataOverTime-NonDistributed.xml
1451 # PlotEdges.xml see paraview/paraview#20659
1452 PlotGlobalVariablesOverTime.xml
1453 PlotOverTimeAutoApply.xml
1454 PolygonCellSelection.xml
1455 PolygonPointSelection.xml
1457 PointGaussianMultiBlockDataSet.xml
1458 PointGaussianNoScaleTransferFunction.xml
1459 PointGaussianScaleOpacityArray.xml
1460 PointInterpolator.xml
1461 PointVolumeInterpolator.xml
1464 PolyLineAndSplineSources.xml
1465 PropertyConversion.xml
1466 PropertyConversion1.xml
1467 PropertyConversion2.xml
1468 PropertyConversion3.xml
1469 PropertyConversion4.xml
1471 QuadraticGhostCells.xml
1472 RandomHyperTreeGridSource.xml
1474 ReadXMLPolyDataFileSeries.xml
1476 RecentFilesHardFilename.xml
1477 RectilinearVolumeRendering.xml
1478 RedistributeDataSetFilter.xml
1479 RepresentationSelector.xml
1480 ResampleWithDataset.xml
1481 RescaleToTemporal.xml
1483 RotateAroundOriginTransform.xml
1485 RotationalExtrusionFilter.xml
1486 # SaveAnimationGeometry.xml # see #20236
1490 SaveMultiBlockCSV.xml
1494 SelectedProxyPanelVisibility.xml
1496 SelectionModifiersCells.xml
1497 SelectionModifiersPoints.xml
1498 SelectionModifiersBlocks.xml
1499 SetCustomBasicPresets.xml
1500 ShaderReplacements.xml
1502 SimpleInteraction.xml
1504 SliceAlongPolyline.xml
1505 SliceAlongSpline.xml
1506 SolidColorSource.xml
1507 SpherePointSource.xml
1512 SpyPlotHistoryReader.xml
1513 SelectionLinkBasic.xml
1514 SelectionLinkConverted.xml
1515 SelectionLinkHistogram.xml
1516 SelectionLinkInitial.xml
1517 SelectionLinkMultiple.xml
1518 SelectionLinkRemove.xml
1519 SelectionLinkReaction.xml
1520 SelectionLinkReactionNonConverted.xml
1521 SeparatedColorMap.xml
1522 SeparatedColorMapOpacity.xml
1524 SliceWithPlaneMultiBlock.xml
1525 SortLineChartData.xml
1526 ScrollAreaNativeWidget.xml
1530 StreamTracerSurface.xml
1531 StreamTracerUpdates.xml
1534 TemporalInterpolator.xml
1535 TemporalShiftScale.xml
1536 TestAnnotateSelectionFilter.xml
1537 TestBoundaryMeshQuality.xml
1538 TestGroupDataFromTimeSeries.xml
1539 TestSelectionOnMultipiece.xml
1540 TimeStepProgressBar.xml
1556 UnstructuredOutline.xml
1557 UniformInverseTransformSamplingGlyph.xml
1558 VectorComponentHistogram.xml
1559 VolumeIsosurfaceBlendMode.xml
1560 VolumeRenderingWithContour.xml
1561 VolumeReprTwoIndepComp.xml
1562 VolumeSliceBlendMode.xml
1563 VariableSelector.xml
1564 VariableSelector1.xml
1565 ViewSettingsDialog.xml
1567 RandomAttributes.xml
1569 YoungsMaterialInterface.xml
1572 if (TARGET VTK::IOParallelLSDyna)
1573 list(APPEND TESTS_WITH_BASELINES
1579 if (TARGET VTK::IOFides)
1580 if (PARAVIEW_ENABLE_ADIOS2)
1581 list(APPEND TESTS_WITH_INLINE_COMPARES
1582 FidesReaderADIOS2.xml
1585 list(APPEND TESTS_WITH_INLINE_COMPARES
1591 if (TARGET VTK::IOOMF)
1592 list(APPEND TESTS_WITH_INLINE_COMPARES
1597 if(VTK_USE_LARGE_DATA)
1598 ExternalData_Expand_Arguments(ParaViewData _
1599 "DATA{${paraview_test_data_directory_input}/Data/bake/bake.e}")
1600 list(APPEND TESTS_WITH_BASELINES
1601 RestoreBlockColorDefaultTransferFunction.xml
1605 if (NOT PARAVIEW_USE_MPI)
1606 list(APPEND TESTS_WITH_BASELINES
1611 # VTKHDFWriter does not work with MPI yet 1612 # See issue https://gitlab.kitware.com/vtk/vtk/-/issues/19231 1613 if (TARGET VTK::IOHDF)
1615 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1616 TEST_SCRIPTS VTKHDFWriter.xml
1620 # The color dialog is different on MacOS X which makes this test fail. 1622 list(APPEND TESTS_WITH_BASELINES
1623 BackgroundLights.xml
1627 list(APPEND TESTS_WITH_BASELINES
1628 # This test makes use of
"Point Gaussian" representation, only available with OpenGL2
1629 BackgroundColorCheck.xml
1631 # PlotMatrixView is bugging in OpenGL1
1632 PlotMatrixViewArraySelection.xml
1634 # Composite Glyph Trees are only implemented in OpenGL2
1635 CompositeGlyphTree.xml
1638 #------------------------------------------------------------------------------ 1639 # Add streaming tests. 1640 # We need to locate smooth.flash since it's not included in the default testing 1642 find_file(smooth_flash NAMES smooth.flash
1643 DOC
"Path to smooth.flash data file." 1645 mark_as_advanced(smooth_flash)
1646 if (EXISTS
"${smooth_flash}")
1647 # we configure the file since we need to point to smooth_flash. 1648 configure_file(
"AMRStreaming.xml.in" 1649 "${CMAKE_CURRENT_BINARY_DIR}/AMRStreaming.xml" @ONLY)
1650 configure_file(
"AMRVolumeRendering.xml.in" 1651 "${CMAKE_CURRENT_BINARY_DIR}/AMRVolumeRendering.xml" @ONLY)
1653 set (streaming_tests
1654 ${CMAKE_CURRENT_BINARY_DIR}/AMRStreaming.xml)
1656 # AMRVolumeRendering is a non-streaming test.
1657 list(APPEND TESTS_WITH_BASELINES
1658 ${CMAKE_CURRENT_BINARY_DIR}/AMRVolumeRendering.xml)
1660 foreach (tname ${streaming_tests})
1661 add_pv_test(
"pv" "_DISABLE_C" 1662 COMMAND --client ${CLIENT_EXECUTABLE}
1666 --test-directory=${PARAVIEW_TEST_DIR}
1668 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1669 TEST_SCRIPTS ${tname})
1671 add_pv_test(pvcs
"_DISABLE_CS" 1673 --server $<TARGET_FILE:ParaView::pvserver>
1676 --client ${CLIENT_EXECUTABLE}
1680 --test-directory=${PARAVIEW_TEST_DIR}
1681 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
1682 TEST_SCRIPTS ${tname})
1686 #------------------------------------------------------------------------------ 1688 # Add tests for OSPRay material editor 1689 if (paraview_use_materialeditor)
1690 list(APPEND TESTS_WITH_INLINE_COMPARES
1691 MaterialEditorCreateMaterials.xml
1692 MaterialEditorLoadMaterials.xml
1693 MaterialEditorSaveMaterials.xml
1694 MaterialEditorShaderBallScene.xml
1698 # Probe picking does not work in render server mode 1700 # Selection is not available in CRS mode 1701 set(BlockContextMenu_DISABLE_CRS TRUE)
1702 set(BlockLinkedSelection_DISABLE_CRS TRUE)
1703 set(MultipleColorOnSelection_DISABLE_CRS TRUE)
1704 set(MultiSliceWavelet_DISABLE_CRS TRUE)
1705 set(MultiSliceMultiBlock_DISABLE_CRS TRUE)
1706 set(PolygonCellSelection_DISABLE_CRS TRUE)
1707 set(PolygonPointSelection_DISABLE_CRS TRUE)
1708 set(NonlinearSubdivisionDisplay_DISABLE_CRS TRUE)
1709 set(InteractiveSelection_DISABLE_CRS TRUE)
1710 set(NonConvexPolygon_DISABLE_CRS TRUE)
1711 set(QuartilePlot_DISABLE_CRS TRUE)
1712 set(TestSelectionOnMultipiece_DISABLE_CRS TRUE)
1713 set(TestHTGSelection_DISABLE_CRS TRUE)
1714 set(SelectionBlocks_DISABLE_CRS TRUE)
1715 set(SelectionEditor_DISABLE_CRS TRUE)
1716 set(SelectionModifiersCells_DISABLE_CRS TRUE)
1717 set(SelectionModifiersBlocks_DISABLE_CRS TRUE)
1718 set(SelectionModifiersPoints_DISABLE_CRS TRUE)
1719 set(SelectionLinkBasic_DISABLE_CRS TRUE)
1720 set(SelectionLinkInitial_DISABLE_CRS TRUE)
1721 set(SelectionLinkMultiple_DISABLE_CRS TRUE)
1722 set(SelectionLinkRemove_DISABLE_CRS TRUE)
1723 set(SelectionLinkReaction_DISABLE_CRS TRUE)
1724 set(SelectionLinkScripting_DISABLE_CRS TRUE)
1725 set(TestAnnotateSelectionFilter_DISABLE_CRS TRUE)
1726 set(ExpandSelection_DISABLE_CRS TRUE)
1727 set(ExportSelectionToCSV_DISABLE_CRS TRUE)
1728 set(BlockOpacities_DISABLE_CRS TRUE)
1729 set(SaveExodus_DISABLE_CRS TRUE) # yes,
this test does a selection
1730 set(CombineFrustumSelections_DISABLE_CRS TRUE) # yes,
1731 set(RenderViewContextMenu_DISABLE_CRS TRUE)
1733 # BoxWidgetVisibleBlock and ZoomToData are not working as well in crs
1734 set(BoxWidgetVisibleBlock_DISABLE_CRS TRUE)
1735 set(ZoomToData_DISABLE_CRS TRUE)
1736 # These tests cannot be run
using ctest -j since they are affected by focus
1738 set (AnimatePipelineTime_FORCE_SERIAL TRUE)
1739 set (AnimateProperty_FORCE_SERIAL TRUE) # since
this uses popup window
1740 set (AnimationFollowPath_FORCE_SERIAL TRUE) # since
1741 set (BlockContextMenu_FORCE_SERIAL TRUE) # requires context menu
1742 set (CGNSReaderDataLocation_FORCE_SERIAL TRUE) # since
this uses popup-menu
1743 set (CTHAMRBaseline_FORCE_SERIAL TRUE) # since
1744 set (CTHAMRContour_FORCE_SERIAL TRUE) # since
1745 set (CTHAMRDualClip_FORCE_SERIAL TRUE) # since
1746 set (CTHAMRMaterialInterfaceFilter_FORCE_SERIAL TRUE) # since
1747 set (CTHDerivedDensity2DClyinder_FORCE_SERIAL TRUE) # since
1748 set (Calculator_FORCE_SERIAL TRUE) # since
1749 set (CategoricalAutomaticAnnotations_FORCE_SERIAL TRUE) # Seems to works better in serial
1750 set (CategoricalColors_FORCE_SERIAL TRUE) # Uses
inline edit popups
1751 set (CategoricalOpacities_FORCE_SERIAL TRUE) # Seems to works better in serial
1752 set (ChartAxisRangeAndLabels_FORCE_SERIAL TRUE) # Uses
inline edit popups
1753 set (ColorOpacityTableEditing_FORCE_SERIAL TRUE) # since
1754 set (ComparativeViewOverlay_FORCE_SERIAL TRUE) # Seems to works better in serial
1755 set (ComputeArrayMagnitudeSetting_FORCE_SERIAL TRUE) # Seems to works better in serial
1756 set (ConfigurableCategories_FORCE_SERIAL TRUE) # since
1757 set (Contour_FORCE_SERIAL TRUE) # since
1758 set (CustomViewpoints_FORCE_SERIAL TRUE)
1759 set (DefaultReadersSetting_FORCE_SERIAL TRUE) # since
1760 set (ExodusModeShapes_FORCE_SERIAL TRUE)
1761 set (ExportFilteredColumnsSpreadsheet_FORCE_SERIAL TRUE) # since
1762 set (ExpressionChooser_FORCE_SERIAL TRUE) # since
1763 set (ExpressionsDialog_FORCE_SERIAL TRUE) # since
1764 set (ExpressionsExporter_FORCE_SERIAL TRUE) # since
1765 set (ExpressionsSettings_FORCE_SERIAL TRUE) # since
this uses combo-box popup-menu
1766 set (LoadSaveStateAnimation_FORCE_SERIAL TRUE)
1767 set (LoadSaveStateVolume_FORCE_SERIAL TRUE)
1768 set (LogColorMapToggle_FORCE_SERIAL TRUE) # since
this pops up output window
1769 set (LogColorMap_FORCE_SERIAL TRUE) # since
1770 set (MathTextColumn_FORCE_SERIAL TRUE) # since
1771 set (PolygonCellSelection_FORCE_SERIAL TRUE)
1772 set (PolygonPointSelection_FORCE_SERIAL TRUE)
1773 set (PropertyLink_FORCE_SERIAL TRUE)
1774 set (PropertyContextMenu_FORCE_SERIAL TRUE)
1775 set (ProxyCategoriesConfiguration_FORCE_SERIAL TRUE) # since
this uses popup-line edit
1776 set (ProxyCategoriesToolbar_FORCE_SERIAL TRUE)
1777 set (QuickLaunchCreateProxy_FORCE_SERIAL TRUE)
1778 set (QuickLaunchNavigation_FORCE_SERIAL TRUE)
1779 set (QuickLaunchRequest_FORCE_SERIAL TRUE)
1780 set (ReadPartitionedCGNS_FORCE_SERIAL TRUE) # since
1781 set (RecentFiles_FORCE_SERIAL TRUE) # use
key events
1782 set (RecentFilesHardFilename_FORCE_SERIAL TRUE) # use
key events
1783 set (SPTimeseries_FORCE_SERIAL TRUE) # since
1784 set (SaveColorMap_FORCE_SERIAL TRUE) # Uses
inline edit popups
1785 set (SeriesPresetRegexp_FORCE_SERIAL TRUE) # since
1786 set (SeriesPreset_FORCE_SERIAL TRUE) # since
1787 set (ShaderReplacements_FORCE_SERIAL TRUE)
1788 set (SimpleInteraction_FORCE_SERIAL TRUE) # since
1789 set (TestHTGHoverOnCell_FORCE_SERIAL TRUE) # since
this uses QTooltip and QShortcut
1790 set (TestIsoVolume_FORCE_SERIAL TRUE) # since
1791 set (TestPythonView_FORCE_SERIAL TRUE) # Seems to work better in serial.
1792 set (TimeKeeper_FORCE_SERIAL TRUE) # since
1793 set (TooltipCopy_FORCE_SERIAL TRUE) # since
1794 set (TraceMultiViews_FORCE_SERIAL TRUE) # Seems to works better in serial
1795 set (glTFReaderAnimatedMorphing_FORCE_SERIAL TRUE) # since
1796 set (glTFReaderToggleDeformation_FORCE_SERIAL TRUE) # since
1798 # those tests load and remove macros. Serial avoid side effects 1799 set(MacroEditor_FORCE_SERIAL TRUE)
1800 set(IconBrowser_FORCE_SERIAL TRUE)
1801 set(PythonResetSessionMacro_FORCE_SERIAL TRUE)
1803 # We don
't support volume rendering of image data in data server & render server mode 1804 set(AdaptiveResampleToImage_DISABLE_CRS TRUE) 1805 set(LoadSaveStateVolume_DISABLE_CRS TRUE) 1806 set(SeparatedColorMapOpacity_DISABLE_CRS TRUE) 1807 set(VolumeReprTwoIndepComp_DISABLE_CRS TRUE) 1808 set(VolumeCrop_DISABLE_CRS TRUE) 1809 set(VolumeSliceBlendMode_DISABLE_CRS TRUE) 1810 set(VolumeIsosurfaceBlendMode_DISABLE_CRS TRUE) 1811 set(PointVolumeInterpolator_DISABLE_CRS TRUE) 1813 # Set properties for CTH tests 1814 set(CTHAMRContour_DISABLE_CS TRUE) 1815 set(CTHAMRContour_DISABLE_CRS TRUE) 1816 set(CTHAMRDualClip_DISABLE_CS TRUE) 1817 set(CTHAMRDualClip_DISABLE_CRS TRUE) 1818 set(CTHAMRClip_DISABLE_CS TRUE) 1819 set(CTHAMRClip_DISABLE_CRS TRUE) 1820 set(CTHAMRMaterialInterfaceFilter_DISABLE_CS TRUE) 1821 set(CTHAMRMaterialInterfaceFilter_DISABLE_CRS TRUE) 1823 # Add image threshold overrides for tests. 1824 # Generally all tests with wireframes need higher thresholds. 1825 SET (Flow2_THRESHOLD 15) 1826 SET (UndoRedo1_THRESHOLD 15) 1827 SET (UndoRedo4_THRESHOLD 15) 1829 # Differences between systems on whether the lines are anti-aliased or not 1830 SET (SortLineChartData_THRESHOLD 50) 1832 # Since often there are issues with fonts etc. 1833 SET (XYChart_THRESHOLD 150) 1834 SET (CheckableHeader_THRESHOLD 150) 1835 # Since the test uses surface-selection, it cannot work in render-server mode. 1836 set(XYChart_DISABLE_CRS TRUE) 1837 # this uses charts: nb of points changes in client server, so graphs differs 1838 set(LinkViews_DISABLE_CS TRUE) 1839 set(LinkViews_DISABLE_CRS TRUE) 1841 SET (XYHistogram_THRESHOLD 150) 1842 set (ChartAxisRangeAndLabels_THRESHOLD 5) 1844 # The color and opacity are often different on different machines. 1845 SET (ColorEditorControls_THRESHOLD 60) 1846 SET (ColorEditorVolumeControls_THRESHOLD 300) 1848 # PlotDataOverTime produces different block labels in parallel 1849 # This leeway helps that. 1850 set (PlotDataOverTime-NonDistributed_THRESHOLD 25) 1852 # Test needs to load a plugin, the test only records that for the 1854 set (SteeringDataGenerator_DISABLE_CS TRUE) 1855 set (SteeringDataGenerator_DISABLE_CRS TRUE) 1857 # Plot image leeway. 1858 set (SpreadSheet2_THRESHOLD 50) 1859 set (PlotOverTimeAutoApply_THRESHOLD 50) 1860 set (ExportLinePlotToCSV_THRESHOLD 30) 1861 set (ExportLinePlotToTSV_THRESHOLD 30) 1862 set (PlotOverTimeAutoApply_DISABLE_CRS TRUE) # since this uses surface selection. 1863 set (QuartilePlot_THRESHOLD 20) 1864 # The ExportLinePlotToTSV test uses the same image baseline as the ExportLinePlotToCSV test 1865 set (ExportLinePlotToTSV_BASELINE ExportLinePlotToCSV.png) 1867 # ExportSceneSpreadSheetView2 won't work in parallel CS because of ghost cells
1868 # than cannot be processed by TableToStructuredGrid.
1869 set(ExportSceneSpreadSheetView2_DISABLE_CS TRUE)
1870 set(ExportSceneSpreadSheetView2_DISABLE_CRS TRUE)
1872 # Cannot support CRS since we
do volume rendering of
image data 1874 set (RemoteRendering_DISABLE_CRS TRUE)
1875 set (RemoteRendering_THRESHOLD 50)
1876 set (VolumeRenderingWithContour_DISABLE_CRS TRUE)
1877 set (VolumeRenderingWithContour_THRESHOLD 50)
1878 set (VolumeNoMapScalars_DISABLE_CRS TRUE)
1879 set (VolumeNoMapScalars_THRESHOLD 50)
1880 set (MultiBlockVolumeRendering_DISABLE_CRS TRUE)
1881 set (ColorOpacityEditorFreehandDrawing_DISABLE_CRS TRUE)
1883 # Composite Surface Selection is currently broken in everything but builtin
1884 SET (CompositeSurfaceSelection_DISABLE_CS TRUE)
1885 SET (CompositeSurfaceSelection_DISABLE_CRS TRUE)
1887 # Clip test has object picking which is not supported in client-render-server 1889 SET (Clip_DISABLE_CRS TRUE)
1891 # Image and rectilinear grid volume rendering not supported in CRS mode. 1892 set (ImageVolumeRendering_DISABLE_CRS TRUE)
1893 set (RectilinearVolumeRendering_DISABLE_CRS TRUE)
1895 # These Xdmf tests have wireframes, hence the increased thresholds. 1896 SET (XdmfReadImageData_THRESHOLD 20)
1897 SET (XdmfReadRectilinearGrid_THRESHOLD 20)
1898 SET (XdmfReadRectilinearGridCollection_THRESHOLD 20)
1899 SET (XdmfReadStructuredGrid_THRESHOLD 20)
1900 SET (XdmfReadStructuredGridCollection_THRESHOLD 20)
1901 SET (XdmfReadImageDataCollection_THRESHOLD 20)
1903 # This test renders points and they are offsetted a bit differently on 1904 # different platforms so just increase the threshold 1905 SET (SaveCSV_THRESHOLD 40)
1906 SET (SaveTSV_THRESHOLD 40)
1907 SET (SaveTXT_THRESHOLD 40)
1908 # The SaveTXT and SaveTSV tests use the same image baseline as the SaveCSV test 1909 SET (SaveTSV_BASELINE SaveCSV.png)
1910 SET (SaveTXT_BASELINE SaveCSV.png)
1912 # Disable some testing configurations for these tests. 1914 ## Disable ClientRenderServer tests for FFTOverTime. This is done since 1915 ## selection is not supported in render server mode esp. when number of render 1916 ## server processes is not the same as the data server processes 1917 set (FFTOverTime_DISABLE_CRS TRUE)
1918 set (FFTOverTime_THRESHOLD 70) # since there
's a plot, account for minor 1919 # rendering differences. 1921 # ColorEditorVolumeControls does volume rendering of structrued data which required remote 1922 # rendering in client-serve mode. 1923 SET (ColorEditorVolumeControls_DISABLE_CS TRUE) 1924 SET (ColorEditorVolumeControls_DISABLE_CRS TRUE) 1926 # ViewSettingsDialog, TextureUsages, LogoSourcesInChartViews and LogoSource use texture which are not supported in pvcrs mode. 1927 SET (ViewSettingsDialog_DISABLE_CRS TRUE) 1928 SET (TextureUsages_DISABLE_CRS TRUE) 1929 SET (LogoSourcesInChartViews_DISABLE_CRS TRUE) 1930 SET (LogoSource_DISABLE_CRS TRUE) 1932 # MultiBlockAttributes1 requires selection which doesn't work
on pvcrs
1933 SET (MultiBlockAttributes1_DISABLE_CRS TRUE)
1935 # Due to issue #20657, the tangents are not sent in pvcrs mode 1936 # event using remote rendering 1937 # We can remove this when issue #20657 is resolved 1938 SET (AnisotropyPBR_DISABLE_CRS TRUE)
1940 ## Disable ClientRenderServer tests for TransferFunction2D. This is done since 1941 ## image data delivery is not supported in render server mode 1942 SET (TransferFunction2D_DISABLE_CRS TRUE)
1943 SET (TransferFunction2DYScalars_DISABLE_CRS TRUE)
1944 SET (TransferFunction2DYScalarsEditor_DISABLE_CRS TRUE)
1945 SET (TransferFunction2DYScalarsEditorA_DISABLE_CRS TRUE)
1946 SET (TransferFunction2DYScalarsEditorB_DISABLE_CRS TRUE)
1947 ## The 2D transfer function editor baselines are different on different machines 1948 SET (TransferFunction2D_THRESHOLD 300)
1949 SET (TransferFunction2DYScalars_THRESHOLD 500)
1950 SET (TransferFunction2DYScalarsEditor_THRESHOLD 500)
1951 SET (TransferFunction2DYScalarsEditorA_THRESHOLD 500)
1952 SET (TransferFunction2DYScalarsEditorB_THRESHOLD 500)
1954 # Plugins are only built as shared libraries. 1956 SET (NiftiReaderWriterPlugin_DISABLE_C TRUE)
1958 # There should be a client server specific version of this test. 1959 SET (NiftiReaderWriterPlugin_DISABLE_CS TRUE)
1960 SET (NiftiReaderWriterPlugin_DISABLE_CRS TRUE)
1962 # Set image threshold overrides for the tests. 1963 SET(SaveLargeScreenshot_THRESHOLD 40)
1965 # Make these tests use reverse connection. 1966 SET (CutMulti_REVERSE_CONNECT TRUE)
1968 # Since this involves charts. 1969 SET(HistogramSelection_THRESHOLD 40)
1970 SET(LineChartSelection_THRESHOLD 40)
1971 SET(MultiBlockChartSelection_THRESHOLD 40)
1973 # Increate threshold for this one since the chart axes 1974 # tends to render slightly differently. 1975 set (LoadStateMultiView_THRESHOLD 20)
1977 # Selection not supported in CRS and is needed
for this test.
1978 set (ResetToVisibleRange_DISABLE_CRS TRUE)
1980 # Molecules are not supported in client-serve modes, currently. 1981 #set (Molecule_DISABLE_CS TRUE) 1982 #set (Molecule_DISABLE_CRS TRUE) 1983 #set (MoleculeColoring_DISABLE_CS TRUE) 1984 #set (MoleculeColoring_DISABLE_CRS TRUE) 1986 # some glTF tests are not working in CS currently 1987 # https://gitlab.kitware.com/paraview/paraview/-/issues/20572 1988 set (glTFReaderToggleDeformation_DISABLE_CS TRUE)
1989 set (glTFReaderToggleDeformation_DISABLE_CRS TRUE)
1990 set (glTFReaderMultipleScenes_DISABLE_CS TRUE)
1991 set (glTFReaderMultipleScenes_DISABLE_CRS TRUE)
1992 set (glTFReaderMultipleAnimations_DISABLE_CS TRUE)
1993 set (glTFReaderMultipleAnimations_DISABLE_CRS TRUE)
1995 # pvd writer/reader has issues creating directories or filenames with punctuation 1996 # https://gitlab.kitware.com/paraview/paraview/-/issues/22361 1998 set (RecentFilesHardFilename_DISABLE_CS TRUE)
1999 set (RecentFilesHardFilename_DISABLE_CRS TRUE)
2002 # tests involve pointCount checks, so not reliable in CS modes. 2003 set (PlotOverLine_3d_DISABLE_CS TRUE)
2004 set (PlotOverLine_3d_DISABLE_CRS TRUE)
2005 set (PlotOverLine_htg_DISABLE_CS TRUE)
2006 set (PlotOverLine_htg_DISABLE_CRS TRUE)
2007 set (PlotOverLine_surface_DISABLE_CS TRUE)
2008 set (PlotOverLine_surface_DISABLE_CRS TRUE)
2010 # CGNS BC patches not supported in parallel 2011 set(ReadCGNSBCDataset_DISABLE_CS TRUE)
2012 set(ReadCGNSBCDataset_DISABLE_CRS TRUE)
2013 set(CONVERGECFDCGNSReader_DISABLE_CS TRUE)
2014 set(CONVERGECFDCGNSReader_DISABLE_CRS TRUE)
2016 set(TESTS_WITH_MULTI_SERVERS_3
2017 TestMultiServer3.xml
2020 # ResampleToHyperTreeGrid only works in client
mode 2022 TEST_SCRIPTS ResampleToHyperTreeGrid.xml
2025 # RandomAttributes generate different results depending on the data 2026 # distribution so we enable it on client mode only for now 2027 # See https://gitlab.kitware.com/paraview/paraview/-/issues/22596 2029 TEST_SCRIPTS RandomAttributesHTG.xml
2032 # FDS Reader has issues in client-server mode. 2033 # See https://gitlab.kitware.com/paraview/paraview/-/issues/22687 2035 TEST_SCRIPTS TestFDSReader.xml
2038 # TODO: remote rendering tests and reverse connect tests. 2041 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2042 TEST_SCRIPTS ${TESTS_WITH_MULTI_SERVERS_3})
2045 TEST_SCRIPTS TileDisplaySplitView.xml)
2047 TEST_SCRIPTS LinkCameraFromView.xml)
2048 if (PARAVIEW_USE_MPI)
2050 TEST_SCRIPTS TileDisplaySplitView.xml)
2052 TEST_SCRIPTS TileDisplaySplitView.xml)
2054 TEST_SCRIPTS TileDisplaySplitView.xml)
2058 TEST_SCRIPTS TestCAVE.xml TestCAVEVolumeRendering.xml)
2060 #------------------------------------------------------------------ 2061 # Add tests that test command line arguments (among other things). 2062 #------------------------------------------------------------------ 2063 if (TARGET ParaView::paraview)
2064 # The state file need to point to the correct data file. We do that by 2065 # configuring the state file. 2067 ARGS
"--state=${CMAKE_CURRENT_SOURCE_DIR}/exodusStateFile.3.14.1.pvsm" 2068 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2069 TEST_SCRIPTS LoadExodusStateFile.xml
2071 PARAVIEW_DATA_ROOT=${paraview_test_data_directory_output}
2075 ARGS
"--state=${CMAKE_CURRENT_SOURCE_DIR}/boxClip.5.6.pvsm" 2076 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2077 TEST_SCRIPTS BoxClipStateBackwardsCompatibility.xml)
2080 # Test whether or not we can load a Python state file with the --state 2081 # command line option as well as loading a Python state file that was 2082 # generated with PV 5.4.1. Loading the 5.4.1 Python state file checks 2083 # on backwards compatibility. 2084 set (Calculator54State_THRESHOLD 100)
2086 ARGS
"--state=${CMAKE_CURRENT_SOURCE_DIR}/Calculator54State.py" 2087 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2088 TEST_SCRIPTS Calculator54State.xml)
2091 #---------------------------------------------------------------------- 2092 # Add test to test stereo rendering modes. 2094 CLIENT_ARGS --stereo --stereo-
type=Interlaced
2095 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2096 TEST_SCRIPTS StereoInterlaced.xml)
2098 CLIENT_ARGS --stereo --stereo-
type=Interlaced
2099 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2100 TEST_SCRIPTS StereoInterlaced.xml)
2102 CLIENT_ARGS --stereo --stereo-
type=Interlaced
2103 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2104 TEST_SCRIPTS StereoInterlaced.xml)
2106 CLIENT_ARGS --stereo --stereo-
type=SplitViewportHorizontal
2107 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2108 TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2110 CLIENT_ARGS --stereo --stereo-
2111 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2112 TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2114 CLIENT_ARGS --stereo --stereo-
2115 BASELINE_DIR ${PARAVIEW_TEST_BASELINE_DIR}
2116 TEST_SCRIPTS StereoSplitViewportHorizontal.xml)
2119 #---------------------------------------------------------------------- 2120 # Very small texture size limits on mesa cause error messages for some tests that 2121 # include coloring by cell data. Let's skip those. 2122 set(texture_buffer_exceeding_hardware_tests
2124 CONVERGECFDReaderWithVisItBridge
2125 TestGroupDataFromTimeSeries
2129 foreach(test_name IN LISTS texture_buffer_exceeding_hardware_tests)
2130 foreach(prefix IN ITEMS pv pvcs pvcrs)
2131 if (TEST
"${prefix}.${test_name}")
2132 set_property(TEST
"${prefix}.${test_name}" APPEND PROPERTY
2133 SKIP_REGULAR_EXPRESSION
"Attempt to use a texture buffer exceeding your hardware")
2138 # Server Connection specific tests 2140 if(NOT WIN32) # On windows, QtTesting is not able to press the connection dialog buttons
2142 SMTESTING_ALLOW_ERRORS
2144 TEST_SCRIPTS ServerConnectTimeout.xml)
2148 "${CMAKE_CURRENT_SOURCE_DIR}/configuredServer.pvsc.in" 2149 "${CMAKE_CURRENT_BINARY_DIR}/configuredServer.pvsc" @ONLY)
2152 "${CMAKE_CURRENT_SOURCE_DIR}/ServerConnectConfigured.xml.in" 2153 "${CMAKE_CURRENT_BINARY_DIR}/ServerConnectConfigured.xml" @ONLY)
2157 TEST_SCRIPTS ${CMAKE_CURRENT_BINARY_DIR}/ServerConnectConfigured.xml)
2159 if (PARAVIEW_PLUGIN_ENABLE_ArrowGlyph)
2161 "${CMAKE_CURRENT_SOURCE_DIR}/ServerConnectPluginLoad.xml.in" 2162 "${CMAKE_CURRENT_BINARY_DIR}/ServerConnectPluginLoad.xml" @ONLY)
2166 TEST_SCRIPTS ${CMAKE_CURRENT_BINARY_DIR}/ServerConnectPluginLoad.xml)
macro ADD_CATALYST_LIVE_TEST(test_name, duration, command_line_connect_command)
function paraview_add_client_server_render_tests()
function paraview_add_client_server_tests()
function paraview_add_cave_tests(num_ranks, config)
function paraview_add_tile_display_tests(width, height)
#define BUILD_SHARED_LIBS
function paraview_add_multi_server_tests(count)
function paraview_add_client_tests()
#define PARAVIEW_USE_QTHELP
#define PARAVIEW_USE_PYTHON
