#include "vtkPVAdaptorsCamModule.h"
| void VTKPVADAPTORSCAM_EXPORT | se_coprocessorinitializewithpython_ (const char *pythonScriptName) |
| Initializes the Catalyst Coprocessor. More... | |
| void VTKPVADAPTORSCAM_EXPORT | se_create_grid_ (int *ne, int *np, int *nlon, double *lonRad, int *nlat, double *latRad, int *nlev, double *lev, int *nCells2d, int *maxNcols, int *mpiRank) |
| Creates grids for 2d and 3d cubed-spheres. More... | |
| void VTKPVADAPTORSCAM_EXPORT | se_add_chunk_ (int *nstep, int *chunkSize, double *lonRad, double *latRad, double *psScalar, double *tScalar, double *uScalar, double *vScalar) |
| for timestep 0: creates the points and cells for the grids. More... | |
| int VTKPVADAPTORSCAM_EXPORT | se_requestdatadescription_ (int *timeStep, double *time) |
| Checks if Catalyst needs to coprocess data. More... | |
| int VTKPVADAPTORSCAM_EXPORT | se_needtocreategrid_ () |
| Checks if the grids need to be created. More... | |
| void VTKPVADAPTORSCAM_EXPORT | se_coprocess_ () |
| calls the coprocessor More... | |
| void VTKPVADAPTORSCAM_EXPORT | se_catalyst_finalize_ () |
| void VTKPVADAPTORSCAM_EXPORT se_coprocessorinitializewithpython_ | ( | const char * | pythonScriptName | ) |
| void VTKPVADAPTORSCAM_EXPORT se_create_grid_ | ( | int * | ne, |
| int * | np, | ||
| int * | nlon, | ||
| double * | lonRad, | ||
| int * | nlat, | ||
| double * | latRad, | ||
| int * | nlev, | ||
| double * | lev, | ||
| int * | nCells2d, | ||
| int * | maxNcols, | ||
| int * | mpiRank | ||
| void VTKPVADAPTORSCAM_EXPORT se_add_chunk_ | ( | int * | nstep, |
| int * | chunkSize, | ||
| double * | psScalar, | ||
| double * | tScalar, | ||
| double * | uScalar, | ||
| double * | vScalar | ||
for all timesteps: copies data from the simulation to Catalyst.
| int VTKPVADAPTORSCAM_EXPORT se_requestdatadescription_ | ( | int * | timeStep, |
| double * | time | ||
| int VTKPVADAPTORSCAM_EXPORT se_needtocreategrid_ | ( | ) |
| void VTKPVADAPTORSCAM_EXPORT se_coprocess_ | ( | ) |
| void VTKPVADAPTORSCAM_EXPORT se_catalyst_finalize_ | ( | ) |
