Core
pqContextView.h
1
// SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
// SPDX-FileCopyrightText: Copyright (c) Sandia Corporation
3
// SPDX-License-Identifier: BSD-3-Clause
4
#ifndef pqContextView_h
5
#define pqContextView_h
6
7
pqView.h
vtkType.h
9
10
vtkSMContextViewProxy
11
vtkContextView
12
vtkObject
13
vtkSelection
14
PQCORE_EXPORT
pqContextView
public
pqView
20
21
Q_OBJECT
22
typedef
pqView
Superclass
23
24
public
25
pqContextView
override
26
31
vtkContextView
* getVTKContextView()
const
32
36
* getContextViewProxy()
const
37
41
bool
supportsSelection()
const
42
48
bool
supportsCapture
const override
return
true
49
54
// Default is vtkChart::SELECT_RECTANGLE
55
void
setSelectionAction(
int
selAction);
56
int
selectionAction();
57
61
void
resetDisplay
bool
closest =
false
override
62
63
Q_SLOTS:
65
70
void
startInteraction();
71
void
endInteraction();
73
74
// NOLINT(readability-redundant-access-specifiers)
84
pqContextView
const
QString&
type
const
QString& group,
const
QString&
name
85
vtkSMViewProxy
* view,
pqServer
* server, QObject* parent =
nullptr
86
91
QWidget*
createWidget
override
92
96
void
selectionChanged();
97
101
void
setSelection(
vtkSelection
102
command;
103
command*
Command
104
105
private
106
Q_DISABLE_COPY(
pqContextView
107
108
pqInternal;
109
pqInternal* Internal;
110
111
112
#endif
vtkObject
type
type
pqContextView
pqContextView is an abstract base class for all charting views based on the VTK context charting libr...
Definition:
pqContextView.h:19
vtkSMViewProxy
Superclass for all view proxies.
Definition:
vtkSMViewProxy.h:42
vtkSelection
pqView
This is a PQ abstraction of a generic view module.
Definition:
pqView.h:26
name
name
PQCORE_EXPORT
#define PQCORE_EXPORT
Definition:
pqCoreModule.h:15
abstract base class for all Chart Views.
Definition:
vtkSMContextViewProxy.h:26
pqContextView::Command
command * Command
Definition:
pqContextView.h:102
vtkType.h
pqView::resetDisplay
virtual void resetDisplay(bool closest=false)
Called to reset the view's display.
Definition:
pqView.h:116
pqView.h
pqView::createWidget
virtual QWidget * createWidget()=0
Subclasses must override this method to create a widget for the view.
vtkContextView
pqServer
pqServer (should be renamed to pqSession) is a pqServerManagerModelItem subclass that represents a vt...
Definition:
pqServer.h:35
pqContextView::supportsCapture
bool supportsCapture() const override
Returns if this view module can support image capture.
Definition:
pqContextView.h:48
