paraview_server_manager_data.h
1 // Loadable modules
2 //
3 // Generated by /builds/gitlab-kitware-sciviz-ci/build/bin/vtkProcessXML-pv5.13
4 //
5 #ifndef paraview_server_manager_data_h
6 #define paraview_server_manager_data_h
7
8 #include <cstring>
9 #include <cassert>
10 #include <algorithm>
11
12
13 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Core/Resources/core_sources.xml
15 "<ServerManagerConfiguration>\n"
16 " <ProxyGroup name=\"sources\">\n"
17 " <!-- ==================================================================== -->\n"
18 " <SourceProxy class=\"vtkTrivialProducer\"\n"
19 " name=\"TrivialProducer\">\n"
20 " </SourceProxy>\n"
21 "\n"
22 " <!-- ==================================================================== -->\n"
23 " <SourceProxy class=\"vtkPVTrivialProducer\"\n"
24 " name=\"PVTrivialProducer\">\n"
25 " <IntVectorProperty command=\"SetWholeExtent\"\n"
26 " default_values=\"0 -1 0 -1 0 -1\"\n"
27 " name=\"WholeExtent\"\n"
28 " number_of_elements=\"6\"\n"
29 " panel_visibility=\"never\" >\n"
30 " <Documentation>The values of this property specify the whole extent of\n"
31 " the topologically regular grid.</Documentation>\n"
32 " </IntVectorProperty>\n"
33 " </SourceProxy>\n"
34 "\n"
35 " <!-- ==================================================================== -->\n"
36 " <SourceProxy class=\"vtkPVTrivialProducer\" name=\"PVTrivialProducer2\">\n"
37 " </SourceProxy>\n"
38 "\n"
39 " <!-- ==================================================================== -->\n"
40 " <SourceProxy class=\"vtkDistributedTrivialProducer\"\n"
41 " name=\"DistributedTrivialProducer\">\n"
42 " <IntVectorProperty command=\"SetWholeExtent\"\n"
43 " default_values=\"0 -1 0 -1 0 -1\"\n"
44 " name=\"WholeExtent\"\n"
45 " number_of_elements=\"6\"\n"
46 " panel_visibility=\"never\" >\n"
47 " <Documentation>The values of this property specify the whole extent of\n"
48 " the topologically regular grid.</Documentation>\n"
49 " </IntVectorProperty>\n"
50 " <StringVectorProperty command=\"UpdateFromGlobal\"\n"
51 " default_values=\"\"\n"
52 " name=\"UpdateDataset\"\n"
53 " number_of_elements=\"1\"\n"
54 " panel_visibility=\"default\">\n"
55 " <Documentation>This property allow to initialize the trivial producer based\n"
56 " on a previously registered dataset.\n"
57 " </Documentation>\n"
58 " </StringVectorProperty>\n"
59 " </SourceProxy>\n"
60 " </ProxyGroup>\n"
61 "</ServerManagerConfiguration>\n"
62 "\n";
63 // Get single string
65 {
66
67  const size_t len0 = strlen(paraview_server_managercore_sourcesInterface0);
68  size_t len = ( 0
69  + len0 );
70  char* res = new char[ len + 1];
71  size_t offset = 0;
73  assert(offset == len);
74  res[offset] = 0;
75  return res;
76 }
77
78
79 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Extraction/Resources/extraction_filters.xml
81 "<ServerManagerConfiguration>\n"
82 " <ProxyGroup name=\"internal_filters\">\n"
83 " <!-- ==================================================================== -->\n"
84 " <SourceProxy class=\"vtkExtractSelectionRange\"\n"
85 " label=\"Extract Selection Range (internal)\"\n"
86 " name=\"ExtractSelectionRange\">\n"
87 " <Documentation>\n"
88 " This filter extracts the range of a given set of cells or points given\n"
89 " a selection. The selection can be obtained from a rubber-band selection\n"
90 " (either point, cell, visible or in a frustum) and passed to the filter or\n"
91 " specified by providing an ID list. This is an internal filter.\n"
92 " </Documentation>\n"
93 " <InputProperty command=\"SetInputConnection\"\n"
94 " name=\"Input\"\n"
95 " port_index=\"0\">\n"
96 " <ProxyGroupDomain name=\"groups\">\n"
97 " <Group name=\"sources\"/>\n"
98 " <Group name=\"filters\"/>\n"
99 " </ProxyGroupDomain>\n"
100 " <DataTypeDomain name=\"input_type\">\n"
101 " <DataType value=\"vtkDataObject\"/>\n"
102 " </DataTypeDomain>\n"
103 " <Documentation>\n"
104 " The input from which the selection is\n"
105 " extracted.\n"
106 " </Documentation>\n"
107 " </InputProperty>\n"
108 " <InputProperty command=\"SetInputConnection\"\n"
109 " name=\"Selection\"\n"
110 " port_index=\"1\">\n"
111 " <ProxyGroupDomain name=\"groups\">\n"
112 " <Group name=\"sources\"/>\n"
113 " <Group name=\"filters\"/>\n"
114 " </ProxyGroupDomain>\n"
115 " <DataTypeDomain name=\"input_type\">\n"
116 " <DataType value=\"vtkSelection\"/>\n"
117 " </DataTypeDomain>\n"
118 " <Documentation>\n"
119 " The input that provides the selection\n"
120 " object.\n"
121 " </Documentation>\n"
122 " </InputProperty>\n"
123 " <StringVectorProperty command=\"SetArrayName\"\n"
124 " name=\"ArrayName\"\n"
125 " number_of_elements=\"1\">\n"
126 " <Documentation>\n"
127 " This property indicates the name of the scalar array\n"
128 " used to compute the range.\n"
129 " </Documentation>\n"
130 " </StringVectorProperty>\n"
131 " <IntVectorProperty command=\"SetFieldType\"\n"
132 " default_values=\"0\"\n"
133 " is_internal=\"1\"\n"
134 " name=\"FieldType\"\n"
135 " number_of_elements=\"1\">\n"
136 " <Documentation>\n"
137 " Set the field type of the selection.\n"
138 " </Documentation>\n"
139 " </IntVectorProperty>\n"
140 " <IntVectorProperty command=\"SetComponent\"\n"
141 " default_values=\"0\"\n"
142 " is_internal=\"1\"\n"
143 " name=\"Component\"\n"
144 " number_of_elements=\"1\">\n"
145 " <Documentation>\n"
146 " Select the component of the selection.\n"
147 " </Documentation>\n"
148 " </IntVectorProperty>\n"
149 " <DoubleVectorProperty command=\"GetRange\"\n"
150 " default_values=\"0 0\"\n"
151 " information_only=\"1\"\n"
152 " name=\"Range\"\n"
153 " number_of_elements=\"2\">\n"
154 " </DoubleVectorProperty>\n"
155 " <!-- End ExtractSelectionRange -->\n"
156 " </SourceProxy>\n"
157 " <!-- ==================================================================== -->\n"
158 " <SourceProxy class=\"vtkSelectArraysExtractBlocks\" name=\"SelectArraysExtractBlocks\">\n"
159 " <Documentation long_help=\"The SelectArraysExtractBlocks filter is a meta-filter combining\n"
160 " the PassArray filter and the ExtractBlock filter.\"\n"
161 " short_help=\"Combines the PassArray and the ExtractBlock filter.\">\n"
162 " The SelectArraysExtractBlocks filter is a meta-filter combining the PassArray\n"
163 " filter and the ExtractBlock filter. It's intended to be used as a pre-processing\n"
164 " filter for MultiBlockDataSet, UniformGridAMR and PartitionedDataSetCollection\n"
165 " writers. It allows to select specific data arrays and/or blocks to write.\n"
166 " </Documentation>\n"
167 " <InputProperty command=\"SetInputConnection\" name=\"Input\">\n"
168 " <ProxyGroupDomain name=\"groups\">\n"
169 " <Group name=\"sources\" />\n"
170 " <Group name=\"filters\" />\n"
171 " </ProxyGroupDomain>\n"
172 " <DataTypeDomain name=\"input_type\">\n"
173 " <DataType value=\"vtkMultiBlockDataSet\"/>\n"
174 " <DataType value=\"vtkUniformGridAMR\"/>\n"
175 " <DataType value=\"vtkPartitionedDataSetCollection\"/>\n"
176 " </DataTypeDomain>\n"
177 " <InputArrayDomain name=\"point_arrays\" attribute_type=\"point\" optional=\"1\" />\n"
178 " <InputArrayDomain name=\"cell_arrays\" attribute_type=\"cell\" optional=\"1\" />\n"
179 " <InputArrayDomain name=\"field_arrays\" attribute_type=\"field\" optional=\"1\" />\n"
180 " <InputArrayDomain name=\"vertex_arrays\" attribute_type=\"vertex\" optional=\"1\" />\n"
181 " <InputArrayDomain name=\"edge_arrays\" attribute_type=\"edge\" optional=\"1\" />\n"
182 " <InputArrayDomain name=\"row_arrays\" attribute_type=\"row\" optional=\"1\" />\n"
183 " </InputProperty>\n"
184 "\n"
185 " <IntVectorProperty name=\"ChooseArraysToWrite\"\n"
186 " command=\"SetPassArraysEnabled\"\n"
187 " default_values=\"0\"\n"
188 " number_of_elements=\"1\">\n"
189 " <BooleanDomain name=\"bool\" />\n"
190 " <Documentation>\n"
191 " Explicitly choose which arrays to write.\n"
192 " </Documentation>\n"
193 " </IntVectorProperty>\n"
194 " <StringVectorProperty\n"
195 " name=\"PointDataArrays\"\n"
196 " command=\"GetPointDataArraySelection\"\n"
197 " number_of_elements_per_command=\"1\"\n"
198 " repeat_command=\"1\"\n"
199 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
200 " <ArrayListDomain name=\"array_list\" input_domain_name=\"point_arrays\">\n"
201 " <RequiredProperties>\n"
202 " <Property name=\"Input\" function=\"Input\" />\n"
203 " </RequiredProperties>\n"
204 " </ArrayListDomain>\n"
205 " <Documentation>\n"
206 " Select the point data arrays to pass through.\n"
207 " </Documentation>\n"
208 " <Hints>\n"
209 " <ArraySelectionWidget icon_type=\"point\"/>\n"
210 " </Hints>\n"
211 " </StringVectorProperty>\n"
212 " <StringVectorProperty\n"
213 " name=\"CellDataArrays\"\n"
214 " command=\"GetCellDataArraySelection\"\n"
215 " number_of_elements_per_command=\"1\"\n"
216 " repeat_command=\"1\"\n"
217 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
218 " <ArrayListDomain name=\"array_list\" input_domain_name=\"cell_arrays\">\n"
219 " <RequiredProperties>\n"
220 " <Property name=\"Input\" function=\"Input\" />\n"
221 " </RequiredProperties>\n"
222 " </ArrayListDomain>\n"
223 " <Documentation>\n"
224 " Select the cell data arrays to pass through.\n"
225 " </Documentation>\n"
226 " <Hints>\n"
227 " <ArraySelectionWidget icon_type=\"cell\"/>\n"
228 " </Hints>\n"
229 " </StringVectorProperty>\n"
230 " <StringVectorProperty\n"
231 " name=\"FieldDataArrays\"\n"
232 " command=\"GetFieldDataArraySelection\"\n"
233 " number_of_elements_per_command=\"1\"\n"
234 " repeat_command=\"1\"\n"
235 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
236 " <ArrayListDomain name=\"array_list\" input_domain_name=\"field_arrays\">\n"
237 " <RequiredProperties>\n"
238 " <Property name=\"Input\" function=\"Input\" />\n"
239 " </RequiredProperties>\n"
240 " </ArrayListDomain>\n"
241 " <Documentation>\n"
242 " Select the field data arrays to pass through.\n"
243 " </Documentation>\n"
244 " <Hints>\n"
245 " <ArraySelectionWidget icon_type=\"field\"/>\n"
246 " </Hints>\n"
247 " </StringVectorProperty>\n"
248 " <StringVectorProperty\n"
249 " name=\"VertexDataArrays\"\n"
250 " command=\"GetVertexDataArraySelection\"\n"
251 " number_of_elements_per_command=\"1\"\n"
252 " repeat_command=\"1\"\n"
253 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
254 " <ArrayListDomain name=\"array_list\" input_domain_name=\"vertex_arrays\">\n"
255 " <RequiredProperties>\n"
256 " <Property name=\"Input\" function=\"Input\" />\n"
257 " </RequiredProperties>\n"
258 " </ArrayListDomain>\n"
259 " <Documentation>\n"
260 " Select the vertex data arrays to pass through.\n"
261 " </Documentation>\n"
262 " <Hints>\n"
263 " <ArraySelectionWidget icon_type=\"vertex\"/>\n"
264 " </Hints>\n"
265 " </StringVectorProperty>\n"
266 " <StringVectorProperty\n"
267 " name=\"EdgeDataArrays\"\n"
268 " command=\"GetEdgeDataArraySelection\"\n"
269 " number_of_elements_per_command=\"1\"\n"
270 " repeat_command=\"1\"\n"
271 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
272 " <ArrayListDomain name=\"array_list\" input_domain_name=\"edge_arrays\">\n"
273 " <RequiredProperties>\n"
274 " <Property name=\"Input\" function=\"Input\" />\n"
275 " </RequiredProperties>\n"
276 " </ArrayListDomain>\n"
277 " <Documentation>\n"
278 " Select the edge data arrays to pass through.\n"
279 " </Documentation>\n"
280 " <Hints>\n"
281 " <ArraySelectionWidget icon_type=\"edge\"/>\n"
282 " </Hints>\n"
283 " </StringVectorProperty>\n"
284 " <StringVectorProperty\n"
285 " name=\"RowDataArrays\"\n"
286 " command=\"GetRowDataArraySelection\"\n"
287 " number_of_elements_per_command=\"1\"\n"
288 " repeat_command=\"1\"\n"
289 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
290 " <ArrayListDomain name=\"array_list\" input_domain_name=\"row_arrays\">\n"
291 " <RequiredProperties>\n"
292 " <Property name=\"Input\" function=\"Input\" />\n"
293 " </RequiredProperties>\n"
294 " </ArrayListDomain>\n"
295 " <Documentation>\n"
296 " Select the row data arrays to pass through.\n"
297 " </Documentation>\n"
298 " <Hints>\n"
299 " <ArraySelectionWidget icon_type=\"row\"/>\n"
300 " </Hints>\n"
301 " </StringVectorProperty>\n"
302 "\n"
303 " <IntVectorProperty name=\"ChooseBlocksToWrite\"\n"
304 " command=\"SetExtractBlocksEnabled\"\n"
305 " default_values=\"0\"\n"
306 " number_of_elements=\"1\">\n"
307 " <BooleanDomain name=\"bool\" />\n"
308 " <Documentation>\n"
309 " Explicitly choose which blocks to write.\n"
310 " </Documentation>\n"
311 " </IntVectorProperty>\n"
312 " <StringVectorProperty name=\"Assembly\"\n"
313 " command=\"SetAssemblyName\"\n"
314 " number_of_elements=\"1\">\n"
315 " <DataAssemblyListDomain name=\"data_assembly_list\">\n"
316 " <RequiredProperties>\n"
317 " <Property function=\"Input\" name=\"Input\"/>\n"
318 " </RequiredProperties>\n"
319 " </DataAssemblyListDomain>\n"
320 " <Documentation>\n"
321 " Select which assembly is used when specifying selectors\n"
322 " to choose blocks to extract.\n"
323 " </Documentation>\n"
324 " </StringVectorProperty>\n"
325 " <StringVectorProperty name=\"Selectors\"\n"
326 " command=\"AddSelector\"\n"
327 " clean_command=\"ClearSelectors\"\n"
328 " repeat_command=\"1\"\n"
329 " number_of_elements_per_command=\"1\">\n"
330 " <DataAssemblyDomain name=\"data_assembly\">\n"
331 " <RequiredProperties>\n"
332 " <Property function=\"Input\" name=\"Input\"/>\n"
333 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
334 " </RequiredProperties>\n"
335 " </DataAssemblyDomain>\n"
336 " <Documentation>\n"
337 " Specify the selectors for the data assembly chosen using **Assembly**\n"
338 " to choose the blocks to extract from the input dataset.\n"
339 " </Documentation>\n"
340 " </StringVectorProperty>\n"
341 "\n"
342 " <PropertyGroup label=\"Blocks\" panel_widget=\"DataAssemblyEditor\">\n"
343 " <Property name=\"Assembly\" function=\"ActiveAssembly\"/>\n"
344 " <Property name=\"Selectors\" function=\"Selectors\"/>\n"
345 " </PropertyGroup>\n"
346 " </SourceProxy>\n"
347 " <!-- End of internal_filters -->\n"
348 " </ProxyGroup>\n"
349 "\n"
350 " <ProxyGroup name=\"filters\">\n"
351 "\n"
352 " <!-- ==================================================================== -->\n"
353 " <SourceProxy class=\"vtkExtractCellsAlongLine\"\n"
354 " label=\"Extract Cells Along Line\"\n"
355 " name=\"ExtractCellsAlongLine\">\n"
356 " <Documentation short_help=\"Extract cells along input line.\">\n"
357 " This filter extract the cells intersected by a line.\n"
358 " </Documentation>\n"
359 " <InputProperty command=\"SetInputConnection\"\n"
360 " name=\"Input\">\n"
361 " <ProxyGroupDomain name=\"groups\">\n"
362 " <Group name=\"sources\"/>\n"
363 " <Group name=\"filters\"/>\n"
364 " </ProxyGroupDomain>\n"
365 " <DataTypeDomain name=\"input_type\">\n"
366 " <DataType value=\"vtkDataSet\"/>\n"
367 " <DataType value=\"vtkCompositeDataSet\"/>\n"
368 " </DataTypeDomain>\n"
369 " </InputProperty>\n"
370 " <DoubleVectorProperty animateable=\"1\"\n"
371 " command=\"SetPoint1\"\n"
372 " default_values=\"0.0 0.0 0.0\"\n"
373 " name=\"Point1\"\n"
374 " number_of_elements=\"3\">\n"
375 " <BoundsDomain default_mode=\"min\"\n"
376 " mode=\"normal\"\n"
377 " name=\"range\">\n"
378 " <RequiredProperties>\n"
379 " <Property function=\"Input\"\n"
380 " name=\"Input\"/>\n"
381 " </RequiredProperties>\n"
382 " </BoundsDomain>\n"
383 " <Documentation>\n"
384 " This property controls the coordinates of the first endpoint of the line.\n"
385 " </Documentation>\n"
386 " </DoubleVectorProperty>\n"
387 " <DoubleVectorProperty animateable=\"1\"\n"
388 " command=\"SetPoint2\"\n"
389 " default_values=\"0.0 0.0 0.0\"\n"
390 " name=\"Point2\"\n"
391 " number_of_elements=\"3\">\n"
392 " <BoundsDomain default_mode=\"max\"\n"
393 " mode=\"normal\"\n"
394 " name=\"range\">\n"
395 " <RequiredProperties>\n"
396 " <Property function=\"Input\"\n"
397 " name=\"Input\"/>\n"
398 " </RequiredProperties>\n"
399 " </BoundsDomain>\n"
400 " <Documentation>\n"
401 " This property controls the coordinates of the second endpoint of the line.\n"
402 " </Documentation>\n"
403 " </DoubleVectorProperty>\n"
404 " <PropertyGroup label=\"Line Parameters\" panel_widget=\"InteractiveLine\">\n"
405 " <Property function=\"Point1WorldPosition\" name=\"Point1\"/>\n"
406 " <Property function=\"Point2WorldPosition\" name=\"Point2\"/>\n"
407 " </PropertyGroup>\n"
408 " <!-- End ExtractCellsAlongLine -->\n"
409 " </SourceProxy>\n"
410 "\n"
411 " <!-- ==================================================================== -->\n"
412 " <SourceProxy class=\"vtkExtractCellsAlongPolyLine\"\n"
413 " label=\"Extract Cells Along Lines Custom Source\"\n"
414 " name=\"ExtractCellsAlongLineCustom\">\n"
415 " <Documentation short_help=\"Extract cells along input lines from custom source\">\n"
416 " The Extract Cells Along Lines From Custom Source filter\n"
417 " extracts cells from the input data set that intersect lines from a custom source.\n"
418 " This source can be either an Unstructured Grid or a Poly Data. Any cells other\n"
419 ;
420
421 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Extraction/Resources/extraction_filters.xml
423 " than lines or poly lines are ignored in the source.\n"
424 " </Documentation>\n"
425 " <InputProperty command=\"SetInputConnection\"\n"
426 " name=\"Input\">\n"
427 " <ProxyGroupDomain name=\"groups\">\n"
428 " <Group name=\"sources\"/>\n"
429 " <Group name=\"filters\"/>\n"
430 " </ProxyGroupDomain>\n"
431 " <DataTypeDomain name=\"input_type\">\n"
432 " <DataType value=\"vtkDataSet\"/>\n"
433 " <DataType value=\"vtkCompositeDataSet\"/>\n"
434 " </DataTypeDomain>\n"
435 " </InputProperty>\n"
436 " <InputProperty command=\"SetSourceConnection\"\n"
437 " name=\"Source\">\n"
438 " <ProxyGroupDomain name=\"groups\">\n"
439 " <Group name=\"sources\"/>\n"
440 " <Group name=\"filters\"/>\n"
441 " </ProxyGroupDomain>\n"
442 " <DataTypeDomain name=\"input_type\">\n"
443 " <DataType value=\"vtkPolyData\"/>\n"
444 " <DataType value=\"vtkUnstructuredGrid\"/>\n"
445 " </DataTypeDomain>\n"
446 " <Documentation>\n"
447 " This property specifies the dataset composed of the lines and poly lines used\n"
448 " to extract cells in the input.\n"
449 " </Documentation>\n"
450 " </InputProperty>\n"
451 " <!-- End ExtractCellsAlongLineCustom -->\n"
452 " </SourceProxy>\n"
453 "\n"
454 " <!-- ==================================================================== -->\n"
455 " <SourceProxy class=\"vtkPVExtractSelection\"\n"
456 " label=\"Extract Selection (internal)\"\n"
457 " name=\"PVExtractSelection\">\n"
458 " <Documentation>\n"
459 " This filter extracts a given set of cells or points given\n"
460 " a selection. The selection can be obtained from a rubber-band selection\n"
461 " (either point, cell, visible or in a frustum) and passed to the filter or\n"
462 " specified by providing an ID list. This is an internal filter, use\n"
463 " \"ExtractSelection\" instead.\n"
464 " </Documentation>\n"
465 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
466 " command=\"SetInputConnection\"\n"
467 " name=\"Input\">\n"
468 " <ProxyGroupDomain name=\"groups\">\n"
469 " <Group name=\"sources\"/>\n"
470 " <Group name=\"filters\"/>\n"
471 " </ProxyGroupDomain>\n"
472 " <DataTypeDomain name=\"input_type\">\n"
473 " <DataType value=\"vtkDataSet\"/>\n"
474 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
475 " </DataTypeDomain>\n"
476 " <Documentation>\n"
477 " The input from which the selection is extracted.\n"
478 " </Documentation>\n"
479 " </InputProperty>\n"
480 " <InputProperty clean_command=\"RemoveAllSelectionsInputs\"\n"
481 " command=\"SetSelectionConnection\"\n"
482 " name=\"Selection\">\n"
483 " <ProxyGroupDomain name=\"groups\">\n"
484 " <Group name=\"sources\"/>\n"
485 " <Group name=\"filters\"/>\n"
486 " </ProxyGroupDomain>\n"
487 " <DataTypeDomain name=\"input_type\">\n"
488 " <DataType value=\"vtkSelection\"/>\n"
489 " </DataTypeDomain>\n"
490 " <Documentation>\n"
491 " The input that provides the selection object.\n"
492 " </Documentation>\n"
493 " </InputProperty>\n"
494 " <IntVectorProperty name=\"HyperTreeGridToUnstructuredGrid\"\n"
495 " command=\"SetHyperTreeGridToUnstructuredGrid\"\n"
496 " default_values=\"0\"\n"
497 " number_of_elements=\"1\">\n"
498 " <BooleanDomain name=\"bool\" />\n"
499 " <Documentation>\n"
500 " Output an unstructured grid instead of a hyper tree grid for input hyper tree grids.\n"
501 " </Documentation>\n"
502 " <Hints>\n"
503 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
504 " name=\"vtkHyperTreeGrid\"\n"
505 " mode=\"visibility\"/>\n"
506 " </Hints>\n"
507 " </IntVectorProperty>\n"
508 " <!-- End ExtractSelection -->\n"
509 " </SourceProxy>\n"
510 "\n"
511 " <!-- ==================================================================== -->\n"
512 " <SourceProxy class=\"vtkPConvertSelection\"\n"
513 " name=\"ConvertSelection\">\n"
514 " <Documentation>\n"
515 " Converts a selection from one type to another.\n"
516 " </Documentation>\n"
517 " <InputProperty command=\"SetInputConnection\"\n"
518 " name=\"DataInput\"\n"
519 " port_index=\"1\">\n"
520 " <DataTypeDomain name=\"input_type\">\n"
521 " <DataType value=\"vtkDataObject\"/>\n"
522 " </DataTypeDomain>\n"
523 " <Documentation>\n"
524 " Set the vtkDataObject input used to convert the selection.\n"
525 " </Documentation>\n"
526 " </InputProperty>\n"
527 " <InputProperty command=\"SetInputConnection\"\n"
528 " name=\"Input\"\n"
529 " port_index=\"0\">\n"
530 " <DataTypeDomain name=\"input_type\">\n"
531 " <DataType value=\"vtkSelection\"/>\n"
532 " </DataTypeDomain>\n"
533 " <Documentation>\n"
534 " Set the selection to convert.\n"
535 " </Documentation>\n"
536 " </InputProperty>\n"
537 " <IntVectorProperty command=\"SetOutputType\"\n"
538 " default_values=\"5\"\n"
539 " name=\"OutputType\"\n"
540 " number_of_elements=\"1\">\n"
541 " <Documentation>\n"
542 " Set the ContentType for the output.\n"
543 " </Documentation>\n"
544 " <EnumerationDomain name=\"enum\">\n"
545 " <Entry text=\"GLOBALIDs\"\n"
546 " value=\"0\"/>\n"
547 " <Entry text=\"PEDIGREEIDS\"\n"
548 " value=\"1\"/>\n"
549 " <Entry text=\"VALUES\"\n"
550 " value=\"2\"/>\n"
551 " <Entry text=\"INDICES\"\n"
552 " value=\"3\"/>\n"
553 " <Entry text=\"FRUSTUM\"\n"
554 " value=\"4\"/>\n"
555 " <Entry text=\"LOCATIONS\"\n"
556 " value=\"5\"/>\n"
557 " <Entry text=\"THRESHOLDS\"\n"
558 " value=\"6\"/>\n"
559 " </EnumerationDomain>\n"
560 " </IntVectorProperty>\n"
561 " <StringVectorProperty clean_command=\"ClearArrayNames\"\n"
562 " command=\"AddArrayName\"\n"
563 " element_types=\"2\"\n"
564 " name=\"ArrayNames\"\n"
565 " number_of_elements_per_command=\"1\"\n"
566 " repeat_command=\"1\"/>\n"
567 " <IntVectorProperty command=\"SetMatchAnyValues\"\n"
568 " default_values=\"0\"\n"
569 " name=\"MatchAnyValues\"\n"
570 " number_of_elements=\"1\">\n"
571 " <BooleanDomain name=\"bool\"/>\n"
572 " </IntVectorProperty>\n"
573 " <IntVectorProperty command=\"SetAllowMissingArray\"\n"
574 " default_values=\"0\"\n"
575 " name=\"AllowMissingArray\"\n"
576 " number_of_elements=\"1\">\n"
577 " <BooleanDomain name=\"bool\"/>\n"
578 " </IntVectorProperty>\n"
579 " <!-- End of ConvertSelection -->\n"
580 " </SourceProxy>\n"
581 "\n"
582 " <!-- ==================================================================== -->\n"
583 " <SourceProxy class=\"vtkPVSingleOutputExtractSelection\"\n"
584 " label=\"Extract Selection\"\n"
585 " name=\"ExtractSelection\">\n"
586 " <Documentation long_help=\"Extract different type of selections.\"\n"
587 " short_help=\"Extract different type of selections.\">\n"
588 " This filter extracts a set of cells/points given a selection.\n"
589 " The selection can be obtained from a rubber-band selection\n"
590 " (either cell, visible or in a frustum) or threshold\n"
591 " selection and passed to the filter or specified by\n"
592 " providing an ID list.\n"
593 " </Documentation>\n"
594 " <InputProperty command=\"SetInputConnection\"\n"
595 " name=\"Input\">\n"
596 " <ProxyGroupDomain name=\"groups\">\n"
597 " <Group name=\"sources\"/>\n"
598 " <Group name=\"filters\"/>\n"
599 " </ProxyGroupDomain>\n"
600 " <DataTypeDomain name=\"input_type\">\n"
601 " <DataType value=\"vtkDataSet\"/>\n"
602 " <DataType value=\"vtkTable\"/>\n"
603 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
604 " </DataTypeDomain>\n"
605 " <Documentation>\n"
606 " This property specifies the input from which the selection is extracted.\n"
607 " </Documentation>\n"
608 " </InputProperty>\n"
609 " <InputProperty command=\"SetSelectionConnection\"\n"
610 " name=\"Selection\"\n"
611 " panel_visibility=\"default\">\n"
612 " <ProxyGroupDomain name=\"groups\">\n"
613 " <Group name=\"sources\"/>\n"
614 " <Group name=\"filters\"/>\n"
615 " </ProxyGroupDomain>\n"
616 " <DataTypeDomain name=\"input_type\">\n"
617 " <DataType value=\"vtkSelection\"/>\n"
618 " </DataTypeDomain>\n"
619 " <Documentation>\n"
620 " The input that provides the selection object.\n"
621 " </Documentation>\n"
622 " <Hints>\n"
623 " <!-- This tag alerts the auto-generated panels and input selection\n"
624 " that this input is a selection. It should use the special\n"
625 " selection GUI. -->\n"
626 " <SelectionInput/>\n"
627 " </Hints>\n"
628 " </InputProperty>\n"
629 " <IntVectorProperty command=\"SetPreserveTopology\"\n"
630 " default_values=\"0\"\n"
631 " name=\"PreserveTopology\"\n"
632 " number_of_elements=\"1\">\n"
633 " <BooleanDomain name=\"bool\"/>\n"
634 " <Documentation>\n"
635 " If this property is set to 1 the output preserves the topology of its input and adds\n"
636 " an insidedness array to mark which cells are inside or out. If 0 then the output is\n"
637 " an unstructured grid which contains only the subset of cells that are inside.\n"
638 " </Documentation>\n"
639 " </IntVectorProperty>\n"
640 " <IntVectorProperty name=\"HyperTreeGridToUnstructuredGrid\"\n"
641 " command=\"SetHyperTreeGridToUnstructuredGrid\"\n"
642 " default_values=\"0\"\n"
643 " number_of_elements=\"1\">\n"
644 " <BooleanDomain name=\"bool\" />\n"
645 " <Documentation>\n"
646 " Output an unstructured grid instead of a hyper tree grid (for input hyper tree grids).\n"
647 " Should not be changed after first execution.\n"
648 " </Documentation>\n"
649 " <Hints>\n"
650 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
651 " name=\"vtkHyperTreeGrid\"\n"
652 " mode=\"visibility\"/>\n"
653 " </Hints>\n"
654 " </IntVectorProperty>\n"
655 " <Hints>\n"
656 " <InitializationHelper class=\"vtkSMExtractSelectionProxyInitializationHelper\"/>\n"
657 " <WarnOnCreate>\n"
658 " <DataTypeDomain name=\"input_type\">\n"
659 " <DataType value=\"vtkImageData\" />\n"
660 " <DataType value=\"vtkRectilinearGrid\" />\n"
661 " <DataType value=\"vtkStructuredGrid\" />\n"
662 " </DataTypeDomain>\n"
663 " <MemoryUsage relative=\"20\" />\n"
664 " <Text title=\"Potentially running out of memory\">\n"
665 " **Extract Selection** filter will create an unstructured grid output\n"
666 " and you may not have enough memory to create it.\n"
667 " Do you want to continue?\n"
668 " </Text>\n"
669 " </WarnOnCreate>\n"
670 " </Hints>\n"
671 " <!-- End of ExtractSelection -->\n"
672 " </SourceProxy>\n"
673 "\n"
674 " <!-- ==================================================================== -->\n"
675 " <SourceProxy class=\"vtkPVExtractCellsByType\"\n"
676 " label=\"Extract Cells By Type\"\n"
677 " name=\"ExtractCellsByType\">\n"
678 " <Documentation short_help=\"Extract cells based on their type.\">\n"
679 " This filter extracts cells of the selected types.\n"
680 " If the data set does not contain cells of the chosen types, the output is empty.\n"
681 " </Documentation>\n"
682 "\n"
683 " <InputProperty command=\"SetInputConnection\"\n"
684 " name=\"Input\">\n"
685 " <ProxyGroupDomain name=\"groups\">\n"
686 " <Group name=\"sources\" />\n"
687 " <Group name=\"filters\" />\n"
688 " </ProxyGroupDomain>\n"
689 " <DataTypeDomain name=\"input_type\">\n"
690 " <DataType value=\"vtkDataSet\" />\n"
691 " </DataTypeDomain>\n"
692 " <Documentation>\n"
693 " This property specifies the input of the filter.\n"
694 " </Documentation>\n"
695 " </InputProperty>\n"
696 "\n"
697 " <StringVectorProperty name=\"CellTypeSelectionInfo\"\n"
698 " command=\"GetCellTypeSelection\"\n"
699 " number_of_elements_per_command=\"2\"\n"
700 " information_only=\"1\"\n"
701 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
702 "\n"
703 " <StringVectorProperty name=\"CellTypes\"\n"
704 " command=\"GetCellTypeSelection\"\n"
705 " information_property=\"CellTypeSelectionInfo\"\n"
706 " number_of_elements_per_command=\"2\"\n"
707 " element_types=\"2 0\"\n"
708 " repeat_command=\"1\"\n"
709 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
710 " <ArraySelectionDomain name=\"array_list\">\n"
711 " <RequiredProperties>\n"
712 " <Property function=\"ArrayList\" name=\"CellTypeSelectionInfo\" />\n"
713 " </RequiredProperties>\n"
714 " </ArraySelectionDomain>\n"
715 " <Documentation>\n"
716 " Select the cell types to extract.\n"
717 " </Documentation>\n"
718 " </StringVectorProperty>\n"
719 " <!-- End of ExtractCellsByType -->\n"
720 " </SourceProxy>\n"
721 "\n"
722 " <!-- ==================================================================== -->\n"
723 " <SourceProxy class=\"vtkAppendSelection\"\n"
724 " name=\"AppendSelections\"\n"
725 " processes=\"client|renderserver|dataserver\">\n"
726 " <Documentation long_help=\"Append selections\"\n"
727 " short_help=\"Append multiple selections into one selection.\">\n"
728 " Append multiple selections with one or many nodes, with the same fieldType,\n"
729 " and possibly different content type, to create a combined selection. Each\n"
730 " selection has a name and a boolean expression can be set using the selection\n"
731 " names to define the relation between the selections.\n"
732 " </Documentation>\n"
733 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
734 " command=\"AddInputConnection\"\n"
735 " multiple_input=\"1\"\n"
736 " name=\"Input\">\n"
737 " <ProxyGroupDomain name=\"groups\">\n"
738 " <Group name=\"sources\"/>\n"
739 " <Group name=\"filters\"/>\n"
740 " </ProxyGroupDomain>\n"
741 " <DataTypeDomain name=\"input_type\">\n"
742 " <DataType value=\"vtkSelection\"/>\n"
743 " </DataTypeDomain>\n"
744 " <Documentation>\n"
745 " This property indicates the inputs to the AppendSelections filter.\n"
746 " </Documentation>\n"
747 " </InputProperty>\n"
748 "\n"
749 " <IntVectorProperty name=\"AppendByUnion\"\n"
750 " command=\"SetAppendByUnion\"\n"
751 " number_of_elements=\"1\"\n"
752 " default_values=\"0\"\n"
753 " panel_visibility=\"never\">\n"
754 " <BooleanDomain name=\"bool\"/>\n"
755 " <Documentation>\n"
756 " Allows by default to not append by union, so that an expression can be used.\n"
757 " </Documentation>\n"
758 " </IntVectorProperty>\n"
759 " <StringVectorProperty name=\"Expression\"\n"
760 " animateable=\"0\"\n"
761 " command=\"SetExpression\"\n"
762 " number_of_elements=\"1\">\n"
763 " <Documentation>\n"
764 " This property specifies the expression which defines the relation between the input selections.\n"
765 ;
766
767 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Extraction/Resources/extraction_filters.xml
769 " </Documentation>\n"
770 " </StringVectorProperty>\n"
771 " <IntVectorProperty command=\"SetInverse\"\n"
772 " default_values=\"0\"\n"
773 " name=\"InsideOut\"\n"
774 " number_of_elements=\"1\">\n"
775 " <BooleanDomain name=\"bool\"/>\n"
776 " <Documentation>\n"
777 " When this property is false the selection describes everything that should be extracted.\n"
778 " When this is true the selection describes everything that should NOT be extracted.\n"
779 " </Documentation>\n"
780 " </IntVectorProperty>\n"
781 " <StringVectorProperty name=\"SelectionNames\"\n"
782 " command=\"SetInputName\"\n"
783 " number_of_elements_per_command=\"1\"\n"
784 " repeat_command=\"1\"\n"
785 " use_index=\"1\"\n"
786 " clean_command=\"RemoveAllInputNames\">\n"
787 " <Documentation>\n"
788 " Specify names to use for each input selection.\n"
789 " </Documentation>\n"
790 " <RegistrationNamesDomain name=\"names_list\" registration_group=\"sources\">\n"
791 " <RequiredProperties>\n"
792 " <Property name=\"Input\" function=\"Proxies\"/>\n"
793 " </RequiredProperties>\n"
794 " </RegistrationNamesDomain>\n"
795 " </StringVectorProperty>\n"
796 " <DoubleVectorProperty name=\"SelectionColors\"\n"
797 " command=\"SetInputColor\"\n"
798 " number_of_elements_per_command=\"3\"\n"
799 " use_index=\"1\"\n"
800 " repeat_command=\"1\"\n"
801 " clean_command=\"RemoveAllInputColors\">\n"
802 " <Documentation>\n"
803 " Specify color to use for each input selection.\n"
804 " </Documentation>\n"
805 " </DoubleVectorProperty>\n"
806 " <Hints>\n"
807 " <Visibility replace_input=\"1\"/>\n"
808 " </Hints>\n"
809 " <!-- End of AppendSelections -->\n"
810 " </SourceProxy>\n"
811 " <!-- End of filters -->\n"
812 " </ProxyGroup>\n"
813 "\n"
814 " <ProxyGroup name=\"sources\">\n"
815 " <!-- ==================================================================== -->\n"
816 " <SourceProxy class=\"vtkSelectionSource\"\n"
817 " name=\"SelectionQuerySource\">\n"
818 " <IntVectorProperty command=\"SetContentType\"\n"
819 " default_values=\"9\"\n"
820 " name=\"ContentType\"\n"
821 " number_of_elements=\"1\">\n"
822 " </IntVectorProperty>\n"
823 " <IntVectorProperty command=\"SetFieldTypeOption\"\n"
824 " default_values=\"1\"\n"
825 " name=\"FieldTypeOption\"\n"
826 " number_of_elements=\"1\">\n"
827 " </IntVectorProperty>\n"
828 " <IntVectorProperty command=\"SetElementType\"\n"
829 " default_values=\"1\"\n"
830 " name=\"ElementType\"\n"
831 " number_of_elements=\"1\">\n"
832 " <Documentation>\n"
833 " Select the type of elements to select.\n"
834 " </Documentation>\n"
835 " <FieldDataDomain name=\"enum\"/>\n"
836 " </IntVectorProperty>\n"
837 " <StringVectorProperty command=\"SetQueryString\"\n"
838 " default_values=\"\"\n"
839 " name=\"QueryString\"\n"
840 " number_of_elements=\"1\"\n"
841 " panel_visibility=\"default\">\n"
842 " </StringVectorProperty>\n"
843 " <IntVectorProperty command=\"SetHierarchicalLevel\"\n"
844 " default_values=\"-1\"\n"
845 " name=\"HierarchicalLevel\"\n"
846 " number_of_elements=\"1\">\n"
847 " </IntVectorProperty>\n"
848 " <IntVectorProperty command=\"SetHierarchicalIndex\"\n"
849 " default_values=\"-1\"\n"
850 " name=\"HierarchicalIndex\"\n"
851 " number_of_elements=\"1\">\n"
852 " </IntVectorProperty>\n"
853 " <IntVectorProperty command=\"SetProcessID\"\n"
854 " default_values=\"-1\"\n"
855 " name=\"ProcessID\"\n"
856 " number_of_elements=\"1\">\n"
857 " </IntVectorProperty>\n"
858 " <StringVectorProperty name=\"Assembly\"\n"
859 " command=\"SetAssemblyName\"\n"
860 " number_of_elements=\"1\"\n"
861 " default_values=\"Hierarchy\">\n"
862 " <Documentation>\n"
863 " Select which assembly is used when specify selectors\n"
864 " to choose blocks to show for composite datasets.\n"
865 " </Documentation>\n"
866 " </StringVectorProperty>\n"
867 " <StringVectorProperty name=\"Selectors\"\n"
868 " command=\"AddSelector\"\n"
869 " clean_command=\"RemoveAllSelectors\"\n"
870 " repeat_command=\"1\"\n"
871 " number_of_elements_per_command=\"1\">\n"
872 " <Documentation>\n"
873 " For composite datasets, specify selectors to limit the view\n"
874 " to a chosen subset of blocks.\n"
875 " </Documentation>\n"
876 " </StringVectorProperty>\n"
877 " <IntVectorProperty command=\"SetInverse\"\n"
878 " default_values=\"0\"\n"
879 " name=\"InsideOut\"\n"
880 " number_of_elements=\"1\">\n"
881 " <BooleanDomain name=\"bool\"/>\n"
882 " <Documentation>\n"
883 " When this property is false the selection describes everything that should be extracted.\n"
884 " When this is true the selection describes everything that should NOT be extracted.\n"
885 " </Documentation>\n"
886 " </IntVectorProperty>\n"
887 " <IntVectorProperty command=\"SetContainingCells\"\n"
888 " default_values=\"0\"\n"
889 " name=\"ContainingCells\"\n"
890 " number_of_elements=\"1\">\n"
891 " <Documentation>\n"
892 " When field type is POINT, this controls whether single vertex cells will be produced\n"
893 " for each selected point, or whether the cells that contain each selected point will be produced.\n"
894 " When field type is CELL this has no effect.\n"
895 " </Documentation>\n"
896 " <BooleanDomain name=\"bool\"/>\n"
897 " </IntVectorProperty>\n"
898 " <IntVectorProperty command=\"SetNumberOfLayers\"\n"
899 " default_values=\"0\"\n"
900 " name=\"NumberOfLayers\"\n"
901 " number_of_elements=\"1\">\n"
902 " <Documentation>\n"
903 " Specify the number of layers of connected elements to include in the selection.\n"
904 " </Documentation>\n"
905 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
906 " </IntVectorProperty>\n"
907 " <IntVectorProperty command=\"SetRemoveSeed\"\n"
908 " default_values=\"0\"\n"
909 " name=\"RemoveSeed\"\n"
910 " number_of_elements=\"1\">\n"
911 " <Documentation>\n"
912 " When using NumberOfLayers, this controls if the initial seed selection is remove or not.\n"
913 " Default is false.\n"
914 " </Documentation>\n"
915 " <BooleanDomain name=\"bool\"/>\n"
916 " </IntVectorProperty>\n"
917 " <IntVectorProperty command=\"SetRemoveIntermediateLayers\"\n"
918 " default_values=\"0\"\n"
919 " name=\"RemoveIntermediateLayers\"\n"
920 " number_of_elements=\"1\">\n"
921 " <Documentation>\n"
922 " When using NumberOfLayers, this controls if intermediate layers are removes or not.\n"
923 " Default is false.\n"
924 " </Documentation>\n"
925 " <BooleanDomain name=\"bool\"/>\n"
926 " </IntVectorProperty>\n"
927 " <!-- End of SelectionQuerySource -->\n"
928 " </SourceProxy>\n"
929 " <!-- ==================================================================== -->\n"
930 " <Proxy name=\"SelectionSourceBase\">\n"
931 " <Documentation>\n"
932 " Internal proxy used to define the common API for Selection Source proxies. Do not use.\n"
933 " </Documentation>\n"
934 " <IntVectorProperty command=\"SetFieldType\"\n"
935 " default_values=\"0\"\n"
936 " name=\"FieldType\"\n"
937 " number_of_elements=\"1\">\n"
938 " <Documentation>\n"
939 " The location of the array the selection came from (e.g. point, cell).\n"
940 " </Documentation>\n"
941 " <EnumerationDomain name=\"enum\">\n"
942 " <Entry text=\"CELL\"\n"
943 " value=\"0\"/>\n"
944 " <Entry text=\"POINT\"\n"
945 " value=\"1\"/>\n"
946 " <Entry text=\"FIELD\"\n"
947 " value=\"2\"/>\n"
948 " <Entry text=\"VERTEX\"\n"
949 " value=\"3\"/>\n"
950 " <Entry text=\"EDGE\"\n"
951 " value=\"4\"/>\n"
952 " <Entry text=\"ROW\"\n"
953 " value=\"5\"/>\n"
954 " </EnumerationDomain>\n"
955 " </IntVectorProperty>\n"
956 " <IntVectorProperty command=\"SetContainingCells\"\n"
957 " default_values=\"0\"\n"
958 " name=\"ContainingCells\"\n"
959 " number_of_elements=\"1\">\n"
960 " <Documentation>\n"
961 " When field type is POINT, this controls whether single vertex cells will be produced\n"
962 " for each selected point, or whether the cells that contain each selected point will be produced.\n"
963 " When field type is CELL this has no effect.\n"
964 " </Documentation>\n"
965 " <BooleanDomain name=\"bool\"/>\n"
966 " </IntVectorProperty>\n"
967 " <IntVectorProperty command=\"SetInverse\"\n"
968 " default_values=\"0\"\n"
969 " name=\"InsideOut\"\n"
970 " number_of_elements=\"1\">\n"
971 " <BooleanDomain name=\"bool\"/>\n"
972 " <Documentation>\n"
973 " When this property is false the selection describes everything that should be extracted.\n"
974 " When this is true the selection describes everything that should NOT be extracted.\n"
975 " </Documentation>\n"
976 " </IntVectorProperty>\n"
977 " <IntVectorProperty command=\"SetNumberOfLayers\"\n"
978 " default_values=\"0\"\n"
979 " name=\"NumberOfLayers\"\n"
980 " number_of_elements=\"1\">\n"
981 " <Documentation>\n"
982 " Specify the number of layers of connected elements to include in the selection.\n"
983 " </Documentation>\n"
984 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
985 " </IntVectorProperty>\n"
986 " <IntVectorProperty command=\"SetRemoveSeed\"\n"
987 " default_values=\"0\"\n"
988 " name=\"RemoveSeed\"\n"
989 " number_of_elements=\"1\">\n"
990 " <Documentation>\n"
991 " When using NumberOfLayers, this controls if the initial seed selection is remove or not.\n"
992 " Default is false.\n"
993 " </Documentation>\n"
994 " <BooleanDomain name=\"bool\"/>\n"
995 " </IntVectorProperty>\n"
996 " <IntVectorProperty command=\"SetRemoveIntermediateLayers\"\n"
997 " default_values=\"0\"\n"
998 " name=\"RemoveIntermediateLayers\"\n"
999 " number_of_elements=\"1\">\n"
1000 " <Documentation>\n"
1001 " When using NumberOfLayers, this controls if intermediate layers are removes or not.\n"
1002 " Default is false.\n"
1003 " </Documentation>\n"
1004 " <BooleanDomain name=\"bool\"/>\n"
1005 " </IntVectorProperty>\n"
1006 " </Proxy>\n"
1007 " <!-- ==================================================================== -->\n"
1008 " <SourceProxy base_proxygroup=\"sources\"\n"
1009 " base_proxyname=\"SelectionSourceBase\"\n"
1010 " class=\"vtkPVSelectionSource\"\n"
1011 " name=\"BlockSelectionSource\"\n"
1012 " processes=\"client|renderserver|dataserver\">\n"
1013 " <Documentation>\n"
1014 " BlockSelectionSource is a source producing a block-based selection used to select blocks\n"
1015 " from a composite dataset.\n"
1016 " </Documentation>\n"
1017 " <IdTypeVectorProperty clean_command=\"RemoveAllBlocks\"\n"
1018 " command=\"AddBlock\"\n"
1019 " label=\"Blocks\"\n"
1020 " name=\"Blocks\"\n"
1021 " number_of_elements=\"0\"\n"
1022 " number_of_elements_per_command=\"1\"\n"
1023 " repeat_command=\"1\">\n"
1024 " <Documentation>\n"
1025 " The list of blocks that will be added to the selection produced by the selection source.\n"
1026 " The blocks are identified using their composite index (flat index).\n"
1027 " </Documentation>\n"
1028 " </IdTypeVectorProperty>\n"
1029 " <!-- End of BlockSelectionSource -->\n"
1030 " </SourceProxy>\n"
1031 " <!-- ==================================================================== -->\n"
1032 " <SourceProxy base_proxygroup=\"sources\"\n"
1033 " base_proxyname=\"SelectionSourceBase\"\n"
1034 " class=\"vtkPVSelectionSource\"\n"
1035 " name=\"BlockSelectorsSelectionSource\"\n"
1036 " processes=\"client|renderserver|dataserver\">\n"
1037 " <Documentation>\n"
1038 " BlockSelectorsSelectionSource is a source producing a block-based selection used to select blocks\n"
1039 " from a composite dataset using selectors.\n"
1040 " </Documentation>\n"
1041 " <StringVectorProperty clean_command=\"RemoveAllBlockSelectors\"\n"
1042 " command=\"AddBlockSelector\"\n"
1043 " label=\"Block Selectors\"\n"
1044 " name=\"BlockSelectors\"\n"
1045 " number_of_elements=\"0\"\n"
1046 " number_of_elements_per_command=\"1\"\n"
1047 " repeat_command=\"1\">\n"
1048 " <Documentation>\n"
1049 " The list of blocks selectors that will be added to the selection produced by the selection source.\n"
1050 " </Documentation>\n"
1051 " </StringVectorProperty>\n"
1052 "\n"
1053 " <StringVectorProperty command=\"SetArrayName\"\n"
1054 " name=\"BlockSelectorsAssemblyName\"\n"
1055 " number_of_elements=\"1\"\n"
1056 " default_values=\"Hierarchy\"/>\n"
1057 " <!-- End of BlockSelectionSource -->\n"
1058 " </SourceProxy>\n"
1059 " <!-- ==================================================================== -->\n"
1060 " <SourceProxy base_proxygroup=\"sources\"\n"
1061 " base_proxyname=\"SelectionSourceBase\"\n"
1062 " class=\"vtkPVSelectionSource\"\n"
1063 " name=\"FrustumSelectionSource\"\n"
1064 " processes=\"client|renderserver|dataserver\">\n"
1065 " <Documentation>\n"
1066 " FrustumSelectionSource is a source producing a frustum selection.\n"
1067 " </Documentation>\n"
1068 " <DoubleVectorProperty argument_is_array=\"1\"\n"
1069 " command=\"AddFrustum\"\n"
1070 " default_values=\"0.0 0.0 1.0 0.0\n"
1071 " 0.0 0.0 0.0 0.0\n"
1072 " 0.0 1.0 1.0 0.0\n"
1073 " 0.0 1.0 0.0 0.0\n"
1074 " 1.0 0.0 1.0 0.0\n"
1075 " 1.0 0.0 0.0 0.0\n"
1076 " 1.0 1.0 1.0 0.0\n"
1077 " 1.0 1.0 0.0 0.0\"\n"
1078 " label=\"Frustum\"\n"
1079 " name=\"Frustum\"\n"
1080 " number_of_elements=\"32\">\n"
1081 " <Documentation>\n"
1082 " Vertices that define a frustum for the selection source.\n"
1083 " </Documentation>\n"
1084 " </DoubleVectorProperty>\n"
1085 " <!-- End of FrustumSelectionSource -->\n"
1086 " </SourceProxy>\n"
1087 " <!-- ==================================================================== -->\n"
1088 " <SourceProxy base_proxygroup=\"sources\"\n"
1089 " base_proxyname=\"SelectionSourceBase\"\n"
1090 " class=\"vtkPVSelectionSource\"\n"
1091 " name=\"GlobalIDSelectionSource\"\n"
1092 ;
1093
1094 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Extraction/Resources/extraction_filters.xml
1096 " processes=\"client|renderserver|dataserver\">\n"
1097 " <Documentation>\n"
1098 " GlobalIDSelectionSource is a source producing a global ID based selection.\n"
1099 " </Documentation>\n"
1100 " <IdTypeVectorProperty clean_command=\"RemoveAllGlobalIDs\"\n"
1101 " command=\"AddGlobalID\"\n"
1102 " label=\"Global IDs\"\n"
1103 " name=\"IDs\"\n"
1104 " number_of_elements=\"0\"\n"
1105 " number_of_elements_per_command=\"1\"\n"
1106 " repeat_command=\"1\">\n"
1107 " <Documentation>\n"
1108 " The list of IDs that will be added to the selection produced by the selection source.\n"
1109 " </Documentation>\n"
1110 " </IdTypeVectorProperty>\n"
1111 " <!-- End of GlobalIDSelectionSource -->\n"
1112 " </SourceProxy>\n"
1113 " <!-- ==================================================================== -->\n"
1114 " <SourceProxy base_proxygroup=\"sources\"\n"
1115 " base_proxyname=\"SelectionSourceBase\"\n"
1116 " class=\"vtkPVSelectionSource\"\n"
1117 " name=\"PedigreeIDSelectionSource\"\n"
1118 " processes=\"client|renderserver|dataserver\">\n"
1119 " <Documentation>\n"
1120 " PedigreeIDSelectionSource is a source producing a pedigree ID based selection.\n"
1121 " </Documentation>\n"
1122 " <StringVectorProperty clean_command=\"RemoveAllPedigreeIDs\"\n"
1123 " command=\"AddPedigreeID\"\n"
1124 " default_values=\"id 0\"\n"
1125 " element_types=\"2 0\"\n"
1126 " label=\"Pedigree IDs\"\n"
1127 " name=\"IDs\"\n"
1128 " number_of_elements=\"2\"\n"
1129 " number_of_elements_per_command=\"2\"\n"
1130 " repeat_command=\"1\">\n"
1131 " <Documentation>\n"
1132 " The list of integer IDs that will be added to the selection produced by the selection source,\n"
1133 " specified by the pair (domain, id).\n"
1134 " </Documentation>\n"
1135 " </StringVectorProperty>\n"
1136 " <StringVectorProperty clean_command=\"RemoveAllPedigreeStringIDs\"\n"
1137 " command=\"AddPedigreeStringID\"\n"
1138 " default_values=\"id foo\"\n"
1139 " element_types=\"2 2\"\n"
1140 " label=\"Pedigree String IDs\"\n"
1141 " name=\"StringIDs\"\n"
1142 " number_of_elements=\"2\"\n"
1143 " number_of_elements_per_command=\"2\"\n"
1144 " repeat_command=\"1\">\n"
1145 " <Documentation>\n"
1146 " The list of string IDs that will be added to the selection produced by the selection source,\n"
1147 " specified by the pair (domain, id).\n"
1148 " </Documentation>\n"
1149 " </StringVectorProperty>\n"
1150 " <!-- End of PedigreeIDSelectionSource -->\n"
1151 " </SourceProxy>\n"
1152 " <!-- ==================================================================== -->\n"
1153 " <SourceProxy base_proxygroup=\"sources\"\n"
1154 " base_proxyname=\"SelectionSourceBase\"\n"
1155 " class=\"vtkPVSelectionSource\"\n"
1156 " name=\"IDSelectionSource\"\n"
1157 " processes=\"client|renderserver|dataserver\">\n"
1158 " <Documentation>\n"
1159 " IDSelectionSource is a source producing a ID based selection.\n"
1160 " This cannot be used for selecting composite datasets.\n"
1161 " </Documentation>\n"
1162 " <IdTypeVectorProperty clean_command=\"RemoveAllIDs\"\n"
1163 " command=\"AddID\"\n"
1164 " name=\"IDs\"\n"
1165 " number_of_elements=\"0\"\n"
1166 " number_of_elements_per_command=\"2\"\n"
1167 " repeat_command=\"1\">\n"
1168 " <Documentation>\n"
1169 " The list of IDs that will be added to the selection produced by the selection source.\n"
1170 " This takes pairs of values as (process number, id).\n"
1171 " </Documentation>\n"
1172 " </IdTypeVectorProperty>\n"
1173 " <!-- End of IDSelectionSource -->\n"
1174 " </SourceProxy>\n"
1175 " <!-- ==================================================================== -->\n"
1176 " <SourceProxy base_proxygroup=\"sources\"\n"
1177 " base_proxyname=\"SelectionSourceBase\"\n"
1178 " class=\"vtkPVSelectionSource\"\n"
1179 " name=\"ValueSelectionSource\"\n"
1180 " processes=\"client|renderserver|dataserver\">\n"
1181 " <Documentation>\n"
1182 " ValueSelectionSource is a source producing a value based selection.\n"
1183 " This cannot be used for selecting composite datasets.\n"
1184 " </Documentation>\n"
1185 " <IdTypeVectorProperty clean_command=\"RemoveAllValues\"\n"
1186 " command=\"AddValue\"\n"
1187 " name=\"Values\"\n"
1188 " number_of_elements=\"0\"\n"
1189 " number_of_elements_per_command=\"2\"\n"
1190 " repeat_command=\"1\">\n"
1191 " <Documentation>\n"
1192 " The list of Values that will be added to the selection produced by the selection source.\n"
1193 " This takes pairs of values as (process number, value).\n"
1194 " </Documentation>\n"
1195 " </IdTypeVectorProperty>\n"
1196 " <StringVectorProperty command=\"SetArrayName\"\n"
1197 " name=\"ArrayName\"\n"
1198 " number_of_elements=\"1\">\n"
1199 " </StringVectorProperty>\n"
1200 " <!-- End of ValueSelectionSource -->\n"
1201 " </SourceProxy>\n"
1202 " <!-- ==================================================================== -->\n"
1203 "\n"
1204 " <SourceProxy base_proxygroup=\"sources\"\n"
1205 " base_proxyname=\"SelectionSourceBase\"\n"
1206 " class=\"vtkPVSelectionSource\"\n"
1207 " name=\"CompositeDataIDSelectionSource\"\n"
1208 " processes=\"client|renderserver|dataserver\">\n"
1209 " <Documentation>\n"
1210 " CompositeDataIDSelectionSource used to create an ID based selection for composite datasets\n"
1211 " (Multiblock or HierarchicalBox dataset).\n"
1212 " </Documentation>\n"
1213 " <IdTypeVectorProperty clean_command=\"RemoveAllCompositeIDs\"\n"
1214 " command=\"AddCompositeID\"\n"
1215 " name=\"IDs\"\n"
1216 " number_of_elements=\"0\"\n"
1217 " number_of_elements_per_command=\"3\"\n"
1218 " repeat_command=\"1\">\n"
1219 " <Documentation>\n"
1220 " The list of IDs that will be added to the selection produced by the selection source.\n"
1221 " This takes 3-tuple of values as (flat-index, process number, id).\n"
1222 " </Documentation>\n"
1223 " </IdTypeVectorProperty>\n"
1224 " <!-- End of CompositeDataIDSelectionSource -->\n"
1225 " </SourceProxy>\n"
1226 " <!-- ==================================================================== -->\n"
1227 " <SourceProxy base_proxygroup=\"sources\"\n"
1228 " base_proxyname=\"SelectionSourceBase\"\n"
1229 " class=\"vtkPVSelectionSource\"\n"
1230 " name=\"HierarchicalDataIDSelectionSource\"\n"
1231 " processes=\"client|renderserver|dataserver\">\n"
1232 " <Documentation>\n"
1233 " HierarchicalDataIDSelectionSource used to create an ID based selection for HierarchicalBox datasets.\n"
1234 " </Documentation>\n"
1235 " <IdTypeVectorProperty clean_command=\"RemoveAllHierarchicalIDs\"\n"
1236 " command=\"AddHierarhicalID\"\n"
1237 " name=\"IDs\"\n"
1238 " number_of_elements=\"0\"\n"
1239 " number_of_elements_per_command=\"3\"\n"
1240 " repeat_command=\"1\">\n"
1241 " <Documentation>\n"
1242 " The list of IDs that will be added to the selection produced by the selection source.\n"
1243 " This takes 3-tuple of values as (level, index, id).\n"
1244 " </Documentation>\n"
1245 " </IdTypeVectorProperty>\n"
1246 " <!-- End of HierarchicalDataIDSelectionSource -->\n"
1247 " </SourceProxy>\n"
1248 " <!-- ==================================================================== -->\n"
1249 " <SourceProxy base_proxygroup=\"sources\"\n"
1250 " base_proxyname=\"SelectionSourceBase\"\n"
1251 " class=\"vtkPVSelectionSource\"\n"
1252 " name=\"ThresholdSelectionSource\"\n"
1253 " processes=\"client|renderserver|dataserver\">\n"
1254 " <Documentation>\n"
1255 " ThresholdSelectionSource is used to create a threshold based selection.\n"
1256 " </Documentation>\n"
1257 " <DoubleVectorProperty clean_command=\"RemoveAllThresholds\"\n"
1258 " command=\"AddThreshold\"\n"
1259 " name=\"Thresholds\"\n"
1260 " number_of_elements=\"0\"\n"
1261 " number_of_elements_per_command=\"2\"\n"
1262 " repeat_command=\"1\">\n"
1263 " <Documentation>\n"
1264 " The list of thresholds that will be added to the selection produced by the selection source.\n"
1265 " </Documentation>\n"
1266 " </DoubleVectorProperty>\n"
1267 " <StringVectorProperty command=\"SetArrayName\"\n"
1268 " default_values=\"none\"\n"
1269 " name=\"ArrayName\"\n"
1270 " number_of_elements=\"1\">\n"
1271 " <Documentation>\n"
1272 " For threshold and value selection, this controls the name of the scalar array that will be thresholded within.\n"
1273 " </Documentation>\n"
1274 " </StringVectorProperty>\n"
1275 " <!-- End of ThresholdSelectionSource -->\n"
1276 " </SourceProxy>\n"
1277 " <!-- ==================================================================== -->\n"
1278 " <SourceProxy base_proxygroup=\"sources\"\n"
1279 " base_proxyname=\"SelectionSourceBase\"\n"
1280 " class=\"vtkPVSelectionSource\"\n"
1281 " name=\"LocationSelectionSource\"\n"
1282 " processes=\"client|renderserver|dataserver\">\n"
1283 " <Documentation>\n"
1284 " LocationSelectionSource is used to create a location based selection.\n"
1285 " </Documentation>\n"
1286 " <DoubleVectorProperty clean_command=\"RemoveAllLocations\"\n"
1287 " command=\"AddLocation\"\n"
1288 " name=\"Locations\"\n"
1289 " number_of_elements=\"0\"\n"
1290 " number_of_elements_per_command=\"3\"\n"
1291 " repeat_command=\"1\">\n"
1292 " <Documentation>\n"
1293 " The list of locations that will be added to the selection produced by the selection source.\n"
1294 " </Documentation>\n"
1295 " </DoubleVectorProperty>\n"
1296 " <!-- End of LocationSelectionSource -->\n"
1297 " </SourceProxy>\n"
1298 " <!-- End of sources -->\n"
1299 " </ProxyGroup>\n"
1300 "</ServerManagerConfiguration>\n"
1301 "\n";
1302 // Get single string
1304 {
1305
1306  const size_t len0 = strlen(paraview_server_managerextraction_filtersInterface0);
1307  const size_t len1 = strlen(paraview_server_managerextraction_filtersInterface1);
1308  const size_t len2 = strlen(paraview_server_managerextraction_filtersInterface2);
1309  const size_t len3 = strlen(paraview_server_managerextraction_filtersInterface3);
1310  size_t len = ( 0
1311  + len0
1312  + len1
1313  + len2
1314  + len3 );
1315  char* res = new char[ len + 1];
1316  size_t offset = 0;
1321  assert(offset == len);
1322  res[offset] = 0;
1323  return res;
1324 }
1325
1326
1327 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/Resources/misc_filters.xml
1329 "<ServerManagerConfiguration>\n"
1330 " <ProxyGroup name=\"filters\">\n"
1331 "\n"
1332 " <!-- ================================================================== -->\n"
1333 " <SourceProxy class=\"vtkAttributeDataToTableFilter\"\n"
1334 " label=\"Extract Attributes\"\n"
1335 " name=\"AttributeDataToTableFilter\">\n"
1336 " <Documentation long_help=\"Extract attribute data as a table.\"\n"
1337 " short_help=\"Extract attribute data as a table.\">This is a\n"
1338 " filter that produces a vtkTable from the chosen attribute\n"
1339 " in the input data object. This filter can accept composite\n"
1340 " datasets. If the input is a composite dataset, the output\n"
1341 " is a multiblock with vtkTable leaves.</Documentation>\n"
1342 " <InputProperty command=\"SetInputConnection\"\n"
1343 " name=\"Input\">\n"
1344 " <ProxyGroupDomain name=\"groups\">\n"
1345 " <Group name=\"sources\" />\n"
1346 " <Group name=\"filters\" />\n"
1347 " </ProxyGroupDomain>\n"
1348 " <DataTypeDomain name=\"input_type\">\n"
1349 " <DataType value=\"vtkDataObject\" />\n"
1350 " </DataTypeDomain>\n"
1351 " <Documentation>This property specifies the input of the\n"
1352 " filter.</Documentation>\n"
1353 " </InputProperty>\n"
1354 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
1355 " default_values=\"0\"\n"
1356 " name=\"FieldAssociation\"\n"
1357 " number_of_elements=\"1\">\n"
1358 " <Documentation>Select the attribute data to pass.</Documentation>\n"
1359 " <EnumerationDomain name=\"enum\">\n"
1360 " <Entry text=\"Points\"\n"
1361 " value=\"0\" />\n"
1362 " <Entry text=\"Cells\"\n"
1363 " value=\"1\" />\n"
1364 " <Entry text=\"Field Data\"\n"
1365 " value=\"2\" />\n"
1366 " <Entry text=\"Vertices\"\n"
1367 " value=\"4\" />\n"
1368 " <Entry text=\"Edges\"\n"
1369 " value=\"5\" />\n"
1370 " <Entry text=\"Rows\"\n"
1371 " value=\"6\" />\n"
1372 " </EnumerationDomain>\n"
1373 " </IntVectorProperty>\n"
1374 " <IntVectorProperty command=\"SetAddMetaData\"\n"
1375 " default_values=\"0\"\n"
1376 " name=\"AddMetaData\"\n"
1377 " number_of_elements=\"1\">\n"
1378 " <BooleanDomain name=\"bool\" />\n"
1379 " <Documentation>It is possible for this filter to add additional\n"
1380 " meta-data to the field data such as point coordinates (when point\n"
1381 " attributes are selected and input is pointset) or structured\n"
1382 " coordinates etc. To enable this addition of extra information, turn\n"
1383 " this flag on. Off by default.</Documentation>\n"
1384 " </IntVectorProperty>\n"
1385 " <!-- End of AttributeDataToTableFilter -->\n"
1386 " </SourceProxy>\n"
1387 "\n"
1388 " <!-- ==================================================================== -->\n"
1389 " <SourceProxy class=\"vtkMergeBlocks\"\n"
1390 " label=\"Merge Blocks\"\n"
1391 " name=\"MergeBlocks\">\n"
1392 " <Documentation short_help=\"Appends vtkCompositeDataSet leaves into a single vtkUnstructuredGrid or vtkPolyData\">\n"
1393 " Merge Blocks appends all vtkDataSet leaves of the input composite dataset to a single\n"
1394 " unstructured grid (or polydata if all leaves are polydata). The subtree to\n"
1395 " be combined can be chosen using the SubTreeCompositeIndex. If the SubTreeCompositeIndex\n"
1396 " is a leaf node, then no appending is required nor performed.</Documentation>\n"
1397 " <InputProperty command=\"SetInputConnection\"\n"
1398 " name=\"Input\">\n"
1399 " <DataTypeDomain name=\"input_type\">\n"
1400 " <DataType value=\"vtkDataObjectTree\" />\n"
1401 " </DataTypeDomain>\n"
1402 " <Documentation>Set the input composite dataset.</Documentation>\n"
1403 " </InputProperty>\n"
1404 " <IntVectorProperty command=\"SetOutputDataSetType\"\n"
1405 " default_values=\"4\"\n"
1406 " number_of_elements=\"1\"\n"
1407 " name=\"OutputDataSetType\"\n"
1408 " panel_visibility=\"advanced\">\n"
1409 " <EnumerationDomain name=\"enum\">\n"
1410 " <Entry text=\"Polygonal Mesh\"\n"
1411 " value=\"0\" />\n"
1412 " <Entry text=\"Unstructured Grid\"\n"
1413 " value=\"4\" />\n"
1414 " </EnumerationDomain>\n"
1415 " <Documentation>Determines the output type produced by this filter. Only blocks compatible\n"
1416 " with the output type will be merged in the output. For example, if the output type is\n"
1417 " \"Polygonal Mesh\", then blocks of type \"Image Data\", \"Structured Grid\", etc. will not be merged.\n"
1418 " If the output type is \"UnstructuredGrid\", then blocks of any type will be merged in the output.\n"
1419 " Defaults to \"Unstructured Grid\".\n"
1420 " </Documentation>\n"
1421 " </IntVectorProperty>\n"
1422 "\n"
1423 " <IntVectorProperty command=\"SetMergePartitionsOnly\"\n"
1424 " name=\"MergePartitionsOnly\"\n"
1425 " default_values=\"0\"\n"
1426 " number_of_elements=\"1\">\n"
1427 " <BooleanDomain name=\"bool\" />\n"
1428 " <Documentation>\n"
1429 " When set, only paritions and pieces will be merged into a dataset each,\n"
1430 " instead of merging everything into a single dataset.\n"
1431 " </Documentation>\n"
1432 " </IntVectorProperty>\n"
1433 " <IntVectorProperty command=\"SetMergePoints\"\n"
1434 " default_values=\"1\"\n"
1435 " label=\"Merge Points\"\n"
1436 " name=\"MergePoints\"\n"
1437 " number_of_elements=\"1\">\n"
1438 " <BooleanDomain name=\"bool\" />\n"
1439 " <Documentation>Merge points within a distance specified by the **Tolerance**\n"
1440 " property.</Documentation>\n"
1441 " </IntVectorProperty>\n"
1442 " <DoubleVectorProperty command=\"SetTolerance\"\n"
1443 " default_values=\"0\"\n"
1444 " label=\"Tolerance\"\n"
1445 " name=\"Tolerance\"\n"
1446 " number_of_elements=\"1\"\n"
1447 " panel_visibility=\"advanced\">\n"
1448 " <Documentation>Set the tolerance for merging points if **Merge Points** is enabled.</Documentation>\n"
1449 " <Hints>\n"
1450 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
1451 " mode=\"visibility\"\n"
1452 " property=\"MergePoints\"\n"
1453 " value=\"1\" />\n"
1454 " <!-- show this widget when MergePoints==1 and showing advanced options -->\n"
1455 " </Hints>\n"
1456 " </DoubleVectorProperty>\n"
1457 " <IntVectorProperty command=\"SetToleranceIsAbsolute\"\n"
1458 " default_values=\"0\"\n"
1459 " name=\"ToleranceIsAbsolute\"\n"
1460 " number_of_elements=\"1\"\n"
1461 " panel_visibility=\"advanced\">\n"
1462 " <BooleanDomain name=\"bool\" />\n"
1463 " <Documentation>This property determines whether to treat the **Tolerance**\n"
1464 " property as absolute (points closer than Tolerance are merged) or relative\n"
1465 " (points closer than a fraction of the input data's bounding box diagonal length)\n"
1466 " when performing point merging.</Documentation>\n"
1467 " <Hints>\n"
1468 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
1469 " mode=\"visibility\"\n"
1470 " property=\"MergePoints\"\n"
1471 " value=\"1\" />\n"
1472 " <!-- show this widget when MergePoints==1 and showing advanced options -->\n"
1473 " </Hints>\n"
1474 " </IntVectorProperty>\n"
1475 " <!-- End of MergeBlocks -->\n"
1476 " </SourceProxy>\n"
1477 " <!-- ==================================================================== -->\n"
1478 " <SourceProxy class=\"vtkEnvironmentAnnotationFilter\"\n"
1479 " label=\"Environment Annotation\"\n"
1480 " name=\"EnvironmentAnnotation\">\n"
1481 " <Documentation long_help=\"Allows annotation of user name, date/time, OS, and possibly filename.\"\n"
1482 " short_help=\"Adds annotation overlay.\">\n"
1483 " Apply to any source. Gui allows manual selection of desired annotation options.\n"
1484 " If the source is a file, can display the filename.\n"
1485 " </Documentation>\n"
1486 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
1487 " command=\"AddInputConnection\"\n"
1488 " multiple_input=\"1\"\n"
1489 " name=\"Input\">\n"
1490 " <ProxyGroupDomain name=\"groups\">\n"
1491 " <Group name=\"sources\" />\n"
1492 " <Group name=\"filters\" />\n"
1493 " </ProxyGroupDomain>\n"
1494 " <DataTypeDomain name=\"input_type\">\n"
1495 " <DataType value=\"vtkDataObject\" />\n"
1496 " </DataTypeDomain>\n"
1497 " <Documentation>Set the input of the filter.</Documentation>\n"
1498 " </InputProperty>\n"
1499 " <IntVectorProperty command=\"SetDisplayUserName\"\n"
1500 " name=\"DisplayUserName\"\n"
1501 " default_values=\"1\"\n"
1502 " number_of_elements=\"1\">\n"
1503 " <BooleanDomain name=\"bool\" />\n"
1504 " <Documentation>\n"
1505 " Toggle User Name Visibility.\n"
1506 " </Documentation>\n"
1507 " </IntVectorProperty>\n"
1508 " <IntVectorProperty command=\"SetDisplaySystemName\"\n"
1509 " name=\"DisplaySystemName\"\n"
1510 " default_values=\"1\"\n"
1511 " number_of_elements=\"1\">\n"
1512 " <BooleanDomain name=\"bool\" />\n"
1513 " <Documentation>\n"
1514 " Toggle System Name Visibility.\n"
1515 " </Documentation>\n"
1516 " </IntVectorProperty>\n"
1517 " <IntVectorProperty command=\"SetDisplayDate\"\n"
1518 " name=\"DisplayDate\"\n"
1519 " default_values=\"1\"\n"
1520 " number_of_elements=\"1\">\n"
1521 " <BooleanDomain name=\"bool\" />\n"
1522 " <Documentation>\n"
1523 " Toggle Date/Time Visibility.\n"
1524 " </Documentation>\n"
1525 " </IntVectorProperty>\n"
1526 " <IntVectorProperty command=\"SetDisplayFileName\"\n"
1527 " name=\"DisplayFileName\"\n"
1528 " default_values=\"1\"\n"
1529 " number_of_elements=\"1\">\n"
1530 " <BooleanDomain name=\"bool\" />\n"
1531 " <Documentation>\n"
1532 " Toggle File Name Visibility.\n"
1533 " </Documentation>\n"
1534 " </IntVectorProperty>\n"
1535 " <IntVectorProperty command=\"SetDisplayFilePath\"\n"
1536 " name=\"DisplayFilePath\"\n"
1537 " default_values=\"1\"\n"
1538 " number_of_elements=\"1\">\n"
1539 " <BooleanDomain name=\"bool\" />\n"
1540 " <Documentation>\n"
1541 " Toggle Show Full File Path.\n"
1542 " </Documentation>\n"
1543 " <Hints>\n"
1544 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
1545 " mode=\"visibility\"\n"
1546 " property=\"DisplayFileName\"\n"
1547 " value=\"1\" />\n"
1548 " <!-- enable this widget when DisplayFileName==1 -->\n"
1549 " </Hints>\n"
1550 " </IntVectorProperty>\n"
1551 " <StringVectorProperty command=\"SetFileName\"\n"
1552 " name=\"FileName\"\n"
1553 " default_values=\"\"\n"
1554 " number_of_elements=\"1\"\n"
1555 " panel_widget=\"filename_widget\">\n"
1556 " <Documentation>Annotation of file name.</Documentation>\n"
1557 " <InputFileNameDomain name=\"filename\">\n"
1558 " <RequiredProperties>\n"
1559 " <Property function=\"Input\" name=\"Input\" />\n"
1560 " </RequiredProperties>\n"
1561 " </InputFileNameDomain>\n"
1562 " <Hints>\n"
1563 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
1564 " mode=\"visibility\"\n"
1565 " property=\"DisplayFileName\"\n"
1566 " value=\"1\" />\n"
1567 " <!-- enable this widget when DisplayFileName==1 -->\n"
1568 " </Hints>\n"
1569 " </StringVectorProperty>\n"
1570 " <Hints>\n"
1571 " <Visibility replace_input=\"0\" />\n"
1572 " <OutputPort index=\"0\"\n"
1573 " name=\"Output-0\"\n"
1574 " type=\"text\" />\n"
1575 " </Hints>\n"
1576 " </SourceProxy>\n"
1577 "\n"
1578 " <!-- ==================================================================== -->\n"
1579 " <SourceProxy class=\"vtkMinMax\" name=\"MinMax\">\n"
1580 " <InputProperty command=\"SetInputConnection\"\n"
1581 " name=\"Input\">\n"
1582 " <ProxyGroupDomain name=\"groups\">\n"
1583 " <Group name=\"sources\" />\n"
1584 " <Group name=\"filters\" />\n"
1585 " </ProxyGroupDomain>\n"
1586 " <DataTypeDomain name=\"input_type\">\n"
1587 " <DataType value=\"vtkDataSet\" />\n"
1588 " </DataTypeDomain>\n"
1589 " <Documentation>Set the input to the Min Max filter.</Documentation>\n"
1590 " </InputProperty>\n"
1591 " <StringVectorProperty command=\"SetOperation\"\n"
1592 " default_values=\"MIN\"\n"
1593 " name=\"Operation\"\n"
1594 " number_of_elements=\"1\">\n"
1595 " <StringListDomain name=\"operation\">\n"
1596 " <String value=\"MIN\" />\n"
1597 " <String value=\"MAX\" />\n"
1598 " <String value=\"SUM\" />\n"
1599 " </StringListDomain>\n"
1600 " <Documentation>Select whether to perform a min, max, or sum operation\n"
1601 " on the data.</Documentation>\n"
1602 " </StringVectorProperty>\n"
1603 " <!-- End MinMax -->\n"
1604 " </SourceProxy>\n"
1605 "\n"
1606 " <!-- ==================================================================== -->\n"
1607 " <SourceProxy class=\"vtkPExtractHistogram\"\n"
1608 " label=\"Histogram\"\n"
1609 " name=\"ExtractHistogram\">\n"
1610 " <Documentation long_help=\"Extract a histogram from field data.\"\n"
1611 " short_help=\"Extract a histogram from field data.\">\n"
1612 " </Documentation>\n"
1613 " <InputProperty command=\"SetInputConnection\"\n"
1614 " name=\"Input\">\n"
1615 " <ProxyGroupDomain name=\"groups\">\n"
1616 " <Group name=\"sources\" />\n"
1617 " <Group name=\"filters\" />\n"
1618 " </ProxyGroupDomain>\n"
1619 " <DataTypeDomain name=\"input_type\">\n"
1620 " <DataType value=\"vtkDataObject\" />\n"
1621 " </DataTypeDomain>\n"
1622 " <InputArrayDomain name=\"input_array\">\n"
1623 " </InputArrayDomain>\n"
1624 " <Documentation>This property specifies the input to the Histogram\n"
1625 " filter.</Documentation>\n"
1626 " </InputProperty>\n"
1627 " <StringVectorProperty animateable=\"0\"\n"
1628 " command=\"SetInputArrayToProcess\"\n"
1629 " element_types=\"0 0 0 0 2\"\n"
1630 " name=\"SelectInputArray\"\n"
1631 " number_of_elements=\"5\">\n"
1632 " <ArrayListDomain attribute_type=\"Scalars\"\n"
1633 " name=\"array_list\">\n"
1634 " <RequiredProperties>\n"
1635 " <Property function=\"Input\"\n"
1636 " name=\"Input\" />\n"
1637 " </RequiredProperties>\n"
1638 " </ArrayListDomain>\n"
1639 " <Documentation>This property indicates the name of the array from which\n"
1640 " to compute the histogram.</Documentation>\n"
1641 " </StringVectorProperty>\n"
1642 " <IntVectorProperty command=\"SetBinCount\"\n"
1643 " default_values=\"10\"\n"
1644 " name=\"BinCount\"\n"
1645 " number_of_elements=\"1\">\n"
1646 " <IntRangeDomain max=\"256\"\n"
1647 " min=\"1\"\n"
1648 ;
1649
1650 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/Resources/misc_filters.xml
1652 " name=\"range\" />\n"
1653 " <Documentation>The value of this property specifies the number of bins\n"
1654 " for the histogram.</Documentation>\n"
1655 " </IntVectorProperty>\n"
1656 " <IntVectorProperty animateable=\"0\"\n"
1657 " command=\"SetComponent\"\n"
1658 " default_values=\"0\"\n"
1659 " name=\"Component\"\n"
1660 " number_of_elements=\"1\">\n"
1661 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
1662 " <RequiredProperties>\n"
1663 " <Property function=\"Input\"\n"
1664 " name=\"Input\" />\n"
1665 " <Property function=\"ArraySelection\"\n"
1666 " name=\"SelectInputArray\" />\n"
1667 " </RequiredProperties>\n"
1668 " </NumberOfComponentsDomain>\n"
1669 " <Documentation>The value of this property specifies the array component\n"
1670 " from which the histogram should be computed.</Documentation>\n"
1671 " </IntVectorProperty>\n"
1672 " <IntVectorProperty command=\"SetCalculateAverages\"\n"
1673 " default_values=\"0\"\n"
1674 " name=\"CalculateAverages\"\n"
1675 " number_of_elements=\"1\"\n"
1676 " panel_visibility=\"advanced\">\n"
1677 " <BooleanDomain name=\"bool\" />\n"
1678 " <Documentation>This option controls whether the algorithm calculates\n"
1679 " averages of variables other than the primary variable that fall into\n"
1680 " each bin.</Documentation>\n"
1681 " </IntVectorProperty>\n"
1682 " <IntVectorProperty command=\"SetNormalize\"\n"
1683 " default_values=\"0\"\n"
1684 " name=\"Normalize\"\n"
1685 " number_of_elements=\"1\"\n"
1686 " panel_visibility=\"advanced\">\n"
1687 " <BooleanDomain name=\"bool\" />\n"
1688 " <Documentation>Controls whether the values in the output are normalized,\n"
1689 " i.e., the count in each bin is divided by the sum of counts in each bin.</Documentation>\n"
1690 " </IntVectorProperty>\n"
1691 " <IntVectorProperty command=\"SetUseCustomBinRanges\"\n"
1692 " default_values=\"0\"\n"
1693 " name=\"UseCustomBinRanges\"\n"
1694 " number_of_elements=\"1\"\n"
1695 " panel_visibility=\"advanced\">\n"
1696 " <BooleanDomain name=\"bool\" />\n"
1697 " <Documentation>When set to true, CustomBinRanges will be used instead\n"
1698 " of using the full range for the selected array. By default, set to\n"
1699 " false.</Documentation>\n"
1700 " </IntVectorProperty>\n"
1701 " <IntVectorProperty command=\"SetCenterBinsAroundMinAndMax\"\n"
1702 " default_values=\"0\"\n"
1703 " name=\"CenterBinsAroundMinAndMax\"\n"
1704 " number_of_elements=\"1\"\n"
1705 " panel_visibility=\"advanced\">\n"
1706 " <BooleanDomain name=\"bool\" />\n"
1707 " <Documentation>When set to true, first and last bin will be centered\n"
1708 " around the minimum and the maximum values of the data.\n"
1709 " By default, set to false.</Documentation>\n"
1710 " <Hints>\n"
1711 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
1712 " <Property name=\"UseCustomBinRanges\" function=\"boolean_invert\" />\n"
1713 " </PropertyWidgetDecorator>\n"
1714 " </Hints>\n"
1715 " </IntVectorProperty>\n"
1716 " <DoubleVectorProperty command=\"SetCustomBinRanges\"\n"
1717 " default_values=\"0.0 100.0\"\n"
1718 " name=\"CustomBinRanges\"\n"
1719 " number_of_elements=\"2\"\n"
1720 " panel_visibility=\"advanced\">\n"
1721 " <Documentation>Set custom bin ranges to use. These are used only when\n"
1722 " UseCustomBinRanges is set to true.</Documentation>\n"
1723 " <ArrayRangeDomain name=\"scalar_range\">\n"
1724 " <RequiredProperties>\n"
1725 " <Property function=\"Input\"\n"
1726 " name=\"Input\" />\n"
1727 " <Property function=\"ArraySelection\"\n"
1728 " name=\"SelectInputArray\" />\n"
1729 " </RequiredProperties>\n"
1730 " </ArrayRangeDomain>\n"
1731 " <Hints>\n"
1732 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
1733 " <Property name=\"UseCustomBinRanges\" function=\"boolean\" />\n"
1734 " </PropertyWidgetDecorator>\n"
1735 " </Hints>\n"
1736 " </DoubleVectorProperty>\n"
1737 " <Hints>\n"
1738 " <!-- View can be used to specify the preferred view for the proxy -->\n"
1739 " <View type=\"XYBarChartView\" />\n"
1740 " <Plotable />\n"
1741 " </Hints>\n"
1742 " <!-- End ExtractHistogram -->\n"
1743 " </SourceProxy>\n"
1744 "\n"
1745 " <!-- ==================================================================== -->\n"
1746 " <SourceProxy class=\"vtkReductionFilter\"\n"
1747 " name=\"AppendReductionFilter\"\n"
1748 " label=\"Append Reduce\">\n"
1749 " <InputProperty command=\"SetInputConnection\"\n"
1750 " name=\"Input\">\n"
1751 " <ProxyGroupDomain name=\"groups\">\n"
1752 " <Group name=\"sources\" />\n"
1753 " <Group name=\"filters\" />\n"
1754 " </ProxyGroupDomain>\n"
1755 " <DataTypeDomain composite_data_supported=\"0\"\n"
1756 " name=\"input_type\">\n"
1757 " <DataType value=\"vtkDataSet\" />\n"
1758 " </DataTypeDomain>\n"
1759 " <Documentation>Set the input to the Reduction filter.</Documentation>\n"
1760 " </InputProperty>\n"
1761 " <StringVectorProperty command=\"SetPostGatherHelperName\"\n"
1762 " name=\"PostGatherHelperName\"\n"
1763 " panel_visibility=\"never\"\n"
1764 " default_values=\"vtkAppendFilter\"\n"
1765 " number_of_elements=\"1\">\n"
1766 " <Documentation>Set the algorithm that takes multiple inputs and\n"
1767 " produces a single reduced output.</Documentation>\n"
1768 " </StringVectorProperty>\n"
1769 " <IntVectorProperty command=\"SetReductionMode\"\n"
1770 " default_values=\"2\"\n"
1771 " name=\"ReductionMode\"\n"
1772 " number_of_elements=\"1\">\n"
1773 " <EnumerationDomain name=\"enum\">\n"
1774 " <Entry text=\"Reduce all data to one processor\"\n"
1775 " value=\"0\" />\n"
1776 " <Entry text=\"Move all data to one processor\"\n"
1777 " value=\"1\" />\n"
1778 " <Entry text=\"Reduce all data to all processors\"\n"
1779 " value=\"2\" />\n"
1780 " </EnumerationDomain>\n"
1781 " <Documentation>Set the reduction mode. Reducing all data to one\n"
1782 " processor means that the destination process will have all data while\n"
1783 " each other process will still have it's own data. Moving all to one processor means\n"
1784 " that the destination process will have all data while other process have no data\n"
1785 " anymore. Reduce all data to all processors is self explanatory.</Documentation>\n"
1786 " </IntVectorProperty>\n"
1787 " <IntVectorProperty command=\"SetReductionProcessId\"\n"
1788 " default_values=\"0\"\n"
1789 " name=\"ReduceTo\"\n"
1790 " number_of_elements=\"1\">\n"
1791 " <IntRangeDomain min=\"0\"\n"
1792 " name=\"range\" />\n"
1793 " <Hints>\n"
1794 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
1795 " mode=\"visibility\"\n"
1796 " property=\"ReductionMode\"\n"
1797 " value=\"2\"\n"
1798 " inverse=\"1\"/>\n"
1799 " <!-- show this widget when ReductionMode is not 2 -->\n"
1800 " </Hints>\n"
1801 " <Documentation>Set the process to reduce to.</Documentation>\n"
1802 " </IntVectorProperty>\n"
1803 " <IntVectorProperty command=\"SetPassThrough\"\n"
1804 " default_values=\"-1\"\n"
1805 " name=\"OnlyFrom\"\n"
1806 " number_of_elements=\"1\">\n"
1807 " <IntRangeDomain min=\"-1\"\n"
1808 " name=\"range\" />\n"
1809 " <Documentation>If set to a non-negative value, then produce results\n"
1810 " using only the node Id specified.</Documentation>\n"
1811 " </IntVectorProperty>\n"
1812 " <IntVectorProperty command=\"SetGenerateProcessIds\"\n"
1813 " default_values=\"0\"\n"
1814 " name=\"GenerateProcessIds\"\n"
1815 " number_of_elements=\"1\">\n"
1816 " <BooleanDomain name=\"bool\" />\n"
1817 " <Documentation>If true, the filter will generate vtkOriginalProcessIds\n"
1818 " arrays indicating the process id on which the cell/point was\n"
1819 " generated.</Documentation>\n"
1820 " </IntVectorProperty>\n"
1821 " <!-- End ReductionFilter -->\n"
1822 " </SourceProxy>\n"
1823 "\n"
1824 " <!-- ==================================================================== -->\n"
1825 " <SourceProxy class=\"vtkReductionFilter\"\n"
1826 " name=\"ReductionFilter\">\n"
1827 " <InputProperty command=\"SetInputConnection\"\n"
1828 " name=\"Input\">\n"
1829 " <ProxyGroupDomain name=\"groups\">\n"
1830 " <Group name=\"sources\" />\n"
1831 " <Group name=\"filters\" />\n"
1832 " </ProxyGroupDomain>\n"
1833 " <Documentation>Set the input to the Reduction filter.</Documentation>\n"
1834 " </InputProperty>\n"
1835 " <IntVectorProperty command=\"SetReductionMode\"\n"
1836 " default_values=\"0\"\n"
1837 " name=\"ReductionMode\"\n"
1838 " number_of_elements=\"1\">\n"
1839 " <EnumerationDomain name=\"enum\">\n"
1840 " <Entry text=\"Move all data to one processor\"\n"
1841 " value=\"0\" />\n"
1842 " <Entry text=\"Reduce all data to one processor\"\n"
1843 " value=\"1\" />\n"
1844 " <Entry text=\"Reduce all data to all processors\"\n"
1845 " value=\"2\" />\n"
1846 " </EnumerationDomain>\n"
1847 " </IntVectorProperty>\n"
1848 " <IntVectorProperty command=\"SetReductionProcessId\"\n"
1849 " default_values=\"0\"\n"
1850 " name=\"ReduceTo\"\n"
1851 " number_of_elements=\"1\">\n"
1852 " </IntVectorProperty>\n"
1853 "\n"
1854 " <StringVectorProperty command=\"SetPreGatherHelperName\"\n"
1855 " name=\"PreGatherHelperName\"\n"
1856 " number_of_elements=\"1\">\n"
1857 " <Documentation>Set the algorithm that runs on each node in\n"
1858 " parallel.</Documentation>\n"
1859 " </StringVectorProperty>\n"
1860 " <StringVectorProperty command=\"SetPostGatherHelperName\"\n"
1861 " name=\"PostGatherHelperName\"\n"
1862 " number_of_elements=\"1\">\n"
1863 " <Documentation>Set the algorithm that takes multiple inputs and\n"
1864 " produces a single reduced output.</Documentation>\n"
1865 " </StringVectorProperty>\n"
1866 " <ProxyProperty command=\"SetPostGatherHelper\"\n"
1867 " name=\"PostGatherHelper\" />\n"
1868 " <ProxyProperty command=\"SetPreGatherHelper\"\n"
1869 " name=\"PreGatherHelper\" />\n"
1870 " <IntVectorProperty command=\"SetPassThrough\"\n"
1871 " default_values=\"-1\"\n"
1872 " name=\"PassThrough\"\n"
1873 " number_of_elements=\"1\">\n"
1874 " <IntRangeDomain min=\"-1\"\n"
1875 " name=\"range\" />\n"
1876 " <Documentation>If set to a non-negative value, then produce results\n"
1877 " using only the node Id specified.</Documentation>\n"
1878 " </IntVectorProperty>\n"
1879 " <IntVectorProperty command=\"SetGenerateProcessIds\"\n"
1880 " default_values=\"0\"\n"
1881 " name=\"GenerateProcessIds\"\n"
1882 " number_of_elements=\"1\">\n"
1883 " <BooleanDomain name=\"bool\" />\n"
1884 " <Documentation>If true, the filter will generate vtkOriginalProcessIds\n"
1885 " arrays indicating the process id on which the cell/point was\n"
1886 " generated.</Documentation>\n"
1887 " </IntVectorProperty>\n"
1888 " <!-- End ReductionFilter -->\n"
1889 " </SourceProxy>\n"
1890 "\n"
1891 " <!-- ==================================================================== -->\n"
1892 " <SourceProxy class=\"vtkPVExtractHistogram2D\"\n"
1893 " label=\"Histogram 2D\"\n"
1894 " name=\"ExtractHistogram2D\">\n"
1895 " <Documentation long_help=\"Extract a 2D histogram from field data.\"\n"
1896 " short_help=\"Extract a 2D histogram from field data.\">\n"
1897 " </Documentation>\n"
1898 " <InputProperty command=\"SetInputConnection\"\n"
1899 " name=\"Input\">\n"
1900 " <ProxyGroupDomain name=\"groups\">\n"
1901 " <Group name=\"sources\" />\n"
1902 " <Group name=\"filters\" />\n"
1903 " </ProxyGroupDomain>\n"
1904 " <DataTypeDomain name=\"input_type\">\n"
1905 " <DataType value=\"vtkDataSet\" />\n"
1906 " </DataTypeDomain>\n"
1907 " <InputArrayDomain name=\"input_array\">\n"
1908 " </InputArrayDomain>\n"
1909 " <Documentation>\n"
1910 " This property specifies the input to the Histogram filter.\n"
1911 " </Documentation>\n"
1912 " </InputProperty>\n"
1913 " <StringVectorProperty animateable=\"0\"\n"
1914 " command=\"SetInputArrayToProcess\"\n"
1915 " element_types=\"0 0 0 0 2\"\n"
1916 " name=\"SelectInputArray1\"\n"
1917 " label=\"Input Array for X-Axis\"\n"
1918 " number_of_elements=\"5\">\n"
1919 " <ArrayListDomain attribute_type=\"Scalars\"\n"
1920 " name=\"array_list\">\n"
1921 " <RequiredProperties>\n"
1922 " <Property function=\"Input\"\n"
1923 " name=\"Input\" />\n"
1924 " </RequiredProperties>\n"
1925 " </ArrayListDomain>\n"
1926 " <Documentation>This property indicates the name of the array from which\n"
1927 " to compute the histogram.</Documentation>\n"
1928 " </StringVectorProperty>\n"
1929 " <IntVectorProperty animateable=\"0\"\n"
1930 " command=\"SetComponent0\"\n"
1931 " default_values=\"0\"\n"
1932 " name=\"Component0\"\n"
1933 " label=\"Component for X-Axis array\"\n"
1934 " number_of_elements=\"1\">\n"
1935 " <NumberOfComponentsDomain name=\"comp0\" enable_magnitude=\"0\">\n"
1936 " <RequiredProperties>\n"
1937 " <Property function=\"Input\"\n"
1938 " name=\"Input\" />\n"
1939 " <Property function=\"ArraySelection\"\n"
1940 " name=\"SelectInputArray1\" />\n"
1941 " </RequiredProperties>\n"
1942 " </NumberOfComponentsDomain>\n"
1943 " <Documentation>The value of this property specifies the array component\n"
1944 " from which the histogram should be computed.</Documentation>\n"
1945 " </IntVectorProperty>\n"
1946 "\n"
1947 " <StringVectorProperty animateable=\"0\"\n"
1948 " command=\"SetInputArrayToProcess\"\n"
1949 " element_types=\"0 0 0 0 2\"\n"
1950 " name=\"SelectInputArray2\"\n"
1951 " label=\"Input Array for Y-Axis\"\n"
1952 " default_values=\"1 0 0 0 0\"\n"
1953 " number_of_elements=\"5\">\n"
1954 " <ArrayListDomain attribute_type=\"Scalars\"\n"
1955 " name=\"array_list\">\n"
1956 " <RequiredProperties>\n"
1957 " <Property function=\"Input\"\n"
1958 " name=\"Input\" />\n"
1959 " </RequiredProperties>\n"
1960 " </ArrayListDomain>\n"
1961 " <Documentation>\n"
1962 " This property indicates the name of the array from which\n"
1963 " to compute the histogram.\n"
1964 " </Documentation>\n"
1965 ;
1966
1967 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/Resources/misc_filters.xml
1969 " <Hints>\n"
1970 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
1971 " <Property name=\"UseGradientForYAxis\" function=\"boolean_invert\" />\n"
1972 " </PropertyWidgetDecorator>\n"
1973 " </Hints>\n"
1974 " </StringVectorProperty>\n"
1975 " <IntVectorProperty animateable=\"0\"\n"
1976 " command=\"SetComponent1\"\n"
1977 " default_values=\"0\"\n"
1978 " name=\"Component1\"\n"
1979 " label=\"Component for Y-Axis array\"\n"
1980 " number_of_elements=\"1\">\n"
1981 " <NumberOfComponentsDomain name=\"comp1\" enable_magnitude=\"1\">\n"
1982 " <RequiredProperties>\n"
1983 " <Property function=\"Input\"\n"
1984 " name=\"Input\" />\n"
1985 " <Property function=\"ArraySelection\"\n"
1986 " name=\"SelectInputArray2\" />\n"
1987 " </RequiredProperties>\n"
1988 " </NumberOfComponentsDomain>\n"
1989 " <Documentation>\n"
1990 " The value of this property specifies the array component\n"
1991 " from which the histogram should be computed.\n"
1992 " </Documentation>\n"
1993 " <Hints>\n"
1994 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
1995 " <Property name=\"UseGradientForYAxis\" function=\"boolean_invert\" />\n"
1996 " </PropertyWidgetDecorator>\n"
1997 " </Hints>\n"
1998 " </IntVectorProperty>\n"
1999 " <IntVectorProperty animateable=\"0\"\n"
2000 " command=\"SetNumberOfBins\"\n"
2001 " default_values=\"256 256\"\n"
2002 " name=\"NumberOfBins\"\n"
2003 " label=\"Number of Bins\"\n"
2004 " number_of_elements=\"2\">\n"
2005 " </IntVectorProperty>\n"
2006 " <IntVectorProperty command=\"SetUseGradientForYAxis\"\n"
2007 " default_values=\"1\"\n"
2008 " name=\"UseGradientForYAxis\"\n"
2009 " label=\"Use Gradient as Y-Axis Array\"\n"
2010 " number_of_elements=\"1\"\n"
2011 " panel_visibility=\"advanced\">\n"
2012 " <BooleanDomain name=\"bool\"/>\n"
2013 " <Documentation>\n"
2014 " If this property is on, the gradient of the input scalar array will be used for the Y\n"
2015 " axis of the 2D histogram.\n"
2016 " </Documentation>\n"
2017 " </IntVectorProperty>\n"
2018 " <IntVectorProperty command=\"SetUseCustomBinRanges0\"\n"
2019 " default_values=\"0\"\n"
2020 " name=\"UseCustomBinRangesX\"\n"
2021 " label=\"Use Custom Bin Ranges for X-Axis\"\n"
2022 " number_of_elements=\"1\"\n"
2023 " panel_visibility=\"advanced\">\n"
2024 " <BooleanDomain name=\"bool\" />\n"
2025 " <Documentation>\n"
2026 " When set to true, custom bin ranges will be used instead of using the full range for the\n"
2027 " selected array for X axis. By default, set to false.\n"
2028 " </Documentation>\n"
2029 " </IntVectorProperty>\n"
2030 " <DoubleVectorProperty command=\"SetCustomBinRanges0\"\n"
2031 " default_values=\"0.0 100.0\"\n"
2032 " name=\"CustomBinRangesX\"\n"
2033 " number_of_elements=\"2\"\n"
2034 " label=\"Custom Bin Ranges for X-Axis\"\n"
2035 " panel_visibility=\"advanced\">\n"
2036 " <Documentation>\n"
2037 " Set custom bin ranges to use. These are used only when\n"
2038 " UseCustomBinRanges is set to true.\n"
2039 " </Documentation>\n"
2040 " <ArrayRangeDomain name=\"scalar_range\">\n"
2041 " <RequiredProperties>\n"
2042 " <Property function=\"Input\"\n"
2043 " name=\"Input\" />\n"
2044 " <Property function=\"ArraySelection\"\n"
2045 " name=\"SelectInputArray1\" />\n"
2046 " </RequiredProperties>\n"
2047 " </ArrayRangeDomain>\n"
2048 " <Hints>\n"
2049 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
2050 " <Property name=\"UseCustomBinRangesX\" function=\"boolean\" />\n"
2051 " </PropertyWidgetDecorator>\n"
2052 " </Hints>\n"
2053 " </DoubleVectorProperty>\n"
2054 " <IntVectorProperty command=\"SetUseCustomBinRanges1\"\n"
2055 " default_values=\"0\"\n"
2056 " name=\"UseCustomBinRangesY\"\n"
2057 " label=\"Use Custom Bin Ranges for Y-Axis\"\n"
2058 " number_of_elements=\"1\"\n"
2059 " panel_visibility=\"advanced\">\n"
2060 " <BooleanDomain name=\"bool\" />\n"
2061 " <Documentation>\n"
2062 " When set to true, custom bin ranges will be used instead of using the full range for the\n"
2063 " selected array for X axis. By default, set to false.\n"
2064 " </Documentation>\n"
2065 " <Hints>\n"
2066 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
2067 " <Property name=\"UseGradientForYAxis\" function=\"boolean_invert\" />\n"
2068 " </PropertyWidgetDecorator>\n"
2069 " </Hints>\n"
2070 " </IntVectorProperty>\n"
2071 " <DoubleVectorProperty command=\"SetCustomBinRanges1\"\n"
2072 " default_values=\"0.0 100.0\"\n"
2073 " name=\"CustomBinRangesY\"\n"
2074 " number_of_elements=\"2\"\n"
2075 " label=\"Custom Bin Ranges for Y-Axis\"\n"
2076 " panel_visibility=\"advanced\">\n"
2077 " <Documentation>\n"
2078 " Set custom bin ranges to use. These are used only when\n"
2079 " UseCustomBinRanges is set to true.\n"
2080 " </Documentation>\n"
2081 " <ArrayRangeDomain name=\"scalar_range\">\n"
2082 " <RequiredProperties>\n"
2083 " <Property function=\"Input\"\n"
2084 " name=\"Input\" />\n"
2085 " <Property function=\"ArraySelection\"\n"
2086 " name=\"SelectInputArray2\" />\n"
2087 " </RequiredProperties>\n"
2088 " </ArrayRangeDomain>\n"
2089 " <Hints>\n"
2090 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
2091 " <Property name=\"UseCustomBinRangesY\" function=\"boolean\" />\n"
2092 " </PropertyWidgetDecorator>\n"
2093 " </Hints>\n"
2094 " </DoubleVectorProperty>\n"
2095 " <IntVectorProperty command=\"SetUseInputRangesForOutputBounds\"\n"
2096 " default_values=\"0\"\n"
2097 " name=\"UseInputRangesForOutputBounds\"\n"
2098 " label=\"Histogram Bounds from Input\"\n"
2099 " number_of_elements=\"1\"\n"
2100 " panel_visibility=\"advanced\">\n"
2101 " <BooleanDomain name=\"bool\" />\n"
2102 " <Documentation>\n"
2103 " When set to true, the input scalar ranges will be used to compute the histogram origin and spacing. By default, set to false.\n"
2104 " </Documentation>\n"
2105 " </IntVectorProperty>\n"
2106 " <DoubleVectorProperty command=\"SetOutputOrigin\"\n"
2107 " default_values=\"0.0 0.0\"\n"
2108 " name=\"OutputOrigin\"\n"
2109 " number_of_elements=\"2\"\n"
2110 " label=\"Histogram Origin\"\n"
2111 " panel_visibility=\"advanced\">\n"
2112 " <Documentation>\n"
2113 " The origin of the output histogram image. These are used only when\n"
2114 " UseInputRangesForOutputBounds is set to false.\n"
2115 " </Documentation>\n"
2116 " <Hints>\n"
2117 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
2118 " <Property name=\"UseInputRangesForOutputBounds\" function=\"boolean_invert\" />\n"
2119 " </PropertyWidgetDecorator>\n"
2120 " </Hints>\n"
2121 " </DoubleVectorProperty>\n"
2122 " <DoubleVectorProperty command=\"SetOutputSpacing\"\n"
2123 " default_values=\"1.0 1.0\"\n"
2124 " name=\"OutputSpacing\"\n"
2125 " number_of_elements=\"2\"\n"
2126 " label=\"Histogram Spacing\"\n"
2127 " panel_visibility=\"advanced\">\n"
2128 " <Documentation>\n"
2129 " The pixel spacing of the output histogram image. These are used only when\n"
2130 " UseInputRangesForOutputBounds is set to false.\n"
2131 " </Documentation>\n"
2132 " <Hints>\n"
2133 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
2134 " <Property name=\"UseInputRangesForOutputBounds\" function=\"boolean_invert\" />\n"
2135 " </PropertyWidgetDecorator>\n"
2136 " </Hints>\n"
2137 " </DoubleVectorProperty>\n"
2138 " <!-- End ExtractHistogram2D -->\n"
2139 " </SourceProxy>\n"
2140 " </ProxyGroup>\n"
2141 "</ServerManagerConfiguration>\n"
2142 "\n";
2143 // Get single string
2145 {
2146
2147  const size_t len0 = strlen(paraview_server_managermisc_filtersInterface0);
2148  const size_t len1 = strlen(paraview_server_managermisc_filtersInterface1);
2149  const size_t len2 = strlen(paraview_server_managermisc_filtersInterface2);
2150  size_t len = ( 0
2151  + len0
2152  + len1
2153  + len2 );
2154  char* res = new char[ len + 1];
2155  size_t offset = 0;
2159  assert(offset == len);
2160  res[offset] = 0;
2161  return res;
2162 }
2163
2164
2165 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/Resources/misc_utilities.xml
2167 "<ServerManagerConfiguration>\n"
2168 " <!-- ==================================================================== -->\n"
2169 " <ProxyGroup name=\"extended_sources\">\n"
2170 " <!-- ================================================================== -->\n"
2171 " <Proxy class=\"vtkPVTransform\" name=\"Transform2\" processes=\"dataserver|renderserver|client\">\n"
2172 " <!--Transform proxy with unconventional interface, used by BoxWidget -->\n"
2173 " <DoubleVectorProperty command=\"SetAbsolutePosition\"\n"
2174 " default_values=\"0.0 0.0 0.0\"\n"
2175 " information_property=\"PositionInfo\"\n"
2176 " label=\"Translate\"\n"
2177 " name=\"Position\"\n"
2178 " number_of_elements=\"3\">\n"
2179 " <DoubleRangeDomain name=\"range\" />\n"
2180 " </DoubleVectorProperty>\n"
2181 " <DoubleVectorProperty command=\"GetPosition\"\n"
2182 " default_values=\"0.0 0.0 0.0\"\n"
2183 " information_only=\"1\"\n"
2184 " name=\"PositionInfo\"\n"
2185 " number_of_elements=\"3\">\n"
2186 " <SimpleDoubleInformationHelper />\n"
2187 " </DoubleVectorProperty>\n"
2188 " <DoubleVectorProperty command=\"SetAbsoluteRotation\"\n"
2189 " default_values=\"0.0 0.0 0.0\"\n"
2190 " information_property=\"RotationInfo\"\n"
2191 " label=\"Rotate\"\n"
2192 " name=\"Rotation\"\n"
2193 " number_of_elements=\"3\">\n"
2194 " <DoubleRangeDomain name=\"range\" />\n"
2195 " </DoubleVectorProperty>\n"
2196 " <DoubleVectorProperty command=\"GetOrientation\"\n"
2197 " default_values=\"0.0 0.0 0.0\"\n"
2198 " information_only=\"1\"\n"
2199 " name=\"RotationInfo\"\n"
2200 " number_of_elements=\"3\">\n"
2201 " <SimpleDoubleInformationHelper />\n"
2202 " </DoubleVectorProperty>\n"
2203 " <DoubleVectorProperty command=\"SetAbsoluteScale\"\n"
2204 " default_values=\"1.0 1.0 1.0\"\n"
2205 " information_property=\"ScaleInfo\"\n"
2206 " label=\"Scale\"\n"
2207 " name=\"Scale\"\n"
2208 " number_of_elements=\"3\">\n"
2209 " <DoubleRangeDomain name=\"range\" />\n"
2210 " </DoubleVectorProperty>\n"
2211 " <DoubleVectorProperty command=\"GetScale\"\n"
2212 " default_values=\"1.0 1.0 1.0\"\n"
2213 " information_only=\"1\"\n"
2214 " name=\"ScaleInfo\"\n"
2215 " number_of_elements=\"3\" />\n"
2216 " </Proxy>\n"
2217 "\n"
2218 " <!-- ================================================================== -->\n"
2219 " <Proxy class=\"vtkPVTransform\" label=\"Transform\" name=\"Transform3\" processes=\"dataserver|renderserver|client\">\n"
2220 " <DoubleVectorProperty command=\"SetAbsolutePosition\"\n"
2221 " default_values=\"0.0 0.0 0.0\"\n"
2222 " information_property=\"PositionInfo\"\n"
2223 " label=\"Translate\"\n"
2224 " name=\"Position\"\n"
2225 " number_of_elements=\"3\">\n"
2226 " <DoubleRangeDomain name=\"range\" />\n"
2227 " </DoubleVectorProperty>\n"
2228 " <DoubleVectorProperty command=\"GetAbsolutePosition\"\n"
2229 " default_values=\"0.0 0.0 0.0\"\n"
2230 " information_only=\"1\"\n"
2231 " name=\"PositionInfo\"\n"
2232 " number_of_elements=\"3\" />\n"
2233 " <DoubleVectorProperty command=\"SetAbsoluteRotation\"\n"
2234 " default_values=\"0.0 0.0 0.0\"\n"
2235 " information_property=\"RotationInfo\"\n"
2236 " label=\"Rotate\"\n"
2237 " name=\"Rotation\"\n"
2238 " number_of_elements=\"3\">\n"
2239 " <DoubleRangeDomain name=\"range\" />\n"
2240 " </DoubleVectorProperty>\n"
2241 " <DoubleVectorProperty command=\"GetAbsoluteRotation\"\n"
2242 " default_values=\"0.0 0.0 0.0\"\n"
2243 " information_only=\"1\"\n"
2244 " name=\"RotationInfo\"\n"
2245 " number_of_elements=\"3\" />\n"
2246 " <DoubleVectorProperty command=\"SetAbsoluteScale\"\n"
2247 " default_values=\"1.0 1.0 1.0\"\n"
2248 " information_property=\"ScaleInfo\"\n"
2249 " label=\"Scale\"\n"
2250 " name=\"Scale\"\n"
2251 " number_of_elements=\"3\">\n"
2252 " <DoubleRangeDomain name=\"range\" />\n"
2253 " </DoubleVectorProperty>\n"
2254 " <DoubleVectorProperty command=\"GetAbsoluteScale\"\n"
2255 " default_values=\"1.0 1.0 1.0\"\n"
2256 " information_only=\"1\"\n"
2257 " name=\"ScaleInfo\"\n"
2258 " number_of_elements=\"3\" />\n"
2259 " <InputProperty is_internal=\"1\" name=\"DummyInput\" />\n"
2260 " <PropertyGroup panel_widget=\"InteractiveBox\">\n"
2261 " <Property function=\"Position\" name=\"Position\" />\n"
2262 " <Property function=\"Rotation\" name=\"Rotation\" />\n"
2263 " <Property function=\"Scale\" name=\"Scale\" />\n"
2264 " <Property function=\"Input\" name=\"DummyInput\" />\n"
2265 " </PropertyGroup>\n"
2266 " <Hints>\n"
2267 " <ProxyList>\n"
2268 " <Link name=\"DummyInput\" with_property=\"Input\" />\n"
2269 " </ProxyList>\n"
2270 " </Hints>\n"
2271 " </Proxy>\n"
2272 "\n"
2273 " <!-- ================================================================== -->\n"
2274 " <Proxy class=\"vtkPVRotateAroundOriginTransform\" label=\"RotateAroundOriginTransform\" name=\"RotateAroundOriginTransform\"\n"
2275 " processes=\"dataserver|renderserver|client\">\n"
2276 " <DoubleVectorProperty command=\"SetOriginOfRotation\"\n"
2277 " default_values=\"0.0 0.0 0.0\"\n"
2278 " label=\"Origin of rotation\"\n"
2279 " name=\"OriginOfRotation\"\n"
2280 " number_of_elements=\"3\">\n"
2281 " <DoubleRangeDomain name=\"range\" />\n"
2282 " </DoubleVectorProperty>\n"
2283 " <DoubleVectorProperty command=\"SetAbsoluteRotation\"\n"
2284 " default_values=\"0.0 0.0 0.0\"\n"
2285 " label=\"Rotate\"\n"
2286 " information_property=\"RotationInfo\"\n"
2287 " name=\"Rotation\"\n"
2288 " number_of_elements=\"3\">\n"
2289 " <DoubleRangeDomain name=\"range\" />\n"
2290 " </DoubleVectorProperty>\n"
2291 " <DoubleVectorProperty command=\"GetAbsoluteRotation\"\n"
2292 " default_values=\"0.0 0.0 0.0\"\n"
2293 " information_only=\"1\"\n"
2294 " name=\"RotationInfo\"\n"
2295 " number_of_elements=\"3\" />\n"
2296 " <InputProperty is_internal=\"1\" name=\"DummyInput\" />\n"
2297 " <PropertyGroup label=\"Origin of rotation\" panel_widget=\"InteractiveHandle\">\n"
2298 " <Property function=\"WorldPosition\" name=\"OriginOfRotation\" />\n"
2299 " </PropertyGroup>\n"
2300 " </Proxy>\n"
2301 "\n"
2302 " <!-- ================================================================== -->\n"
2303 " </ProxyGroup>\n"
2304 "\n"
2305 " <!-- ==================================================================== -->\n"
2306 " <ProxyGroup name=\"implicit_functions\">\n"
2307 "\n"
2308 " <!-- ================================================================== -->\n"
2309 " <Proxy class=\"vtkPVPlane\" name=\"Plane\" processes=\"dataserver|renderserver|client\">\n"
2310 " <InputProperty is_internal=\"1\"\n"
2311 " name=\"Input\"></InputProperty>\n"
2312 " <DoubleVectorProperty command=\"SetOrigin\"\n"
2313 " default_values=\"0.0 0.0 0.0\"\n"
2314 " name=\"Origin\"\n"
2315 " number_of_elements=\"3\">\n"
2316 " <BoundsDomain default_mode=\"mid\"\n"
2317 " mode=\"normal\"\n"
2318 " name=\"range\">\n"
2319 " <RequiredProperties>\n"
2320 " <Property function=\"Input\"\n"
2321 " name=\"Input\" />\n"
2322 " </RequiredProperties>\n"
2323 " </BoundsDomain>\n"
2324 " <Documentation>\n"
2325 " Set the origin of the plane.\n"
2326 " </Documentation>\n"
2327 " </DoubleVectorProperty>\n"
2328 " <DoubleVectorProperty command=\"SetNormal\"\n"
2329 " default_values=\"1.0 0.0 0.0\"\n"
2330 " name=\"Normal\"\n"
2331 " number_of_elements=\"3\">\n"
2332 " <DoubleRangeDomain name=\"range\" />\n"
2333 " <Documentation>\n"
2334 " Set the normal of the plane. For many filters this also sets the side\n"
2335 " of the plane that is of interest. The normal points towards the\n"
2336 " \"outside\" of the plane.\n"
2337 " </Documentation>\n"
2338 " </DoubleVectorProperty>\n"
2339 " <DoubleVectorProperty animateable=\"1\"\n"
2340 " command=\"SetOffset\"\n"
2341 " default_values=\"0.0\"\n"
2342 " name=\"Offset\"\n"
2343 " number_of_elements=\"1\">\n"
2344 " <Documentation>\n"
2345 " Set the value to offset the origin by. The origin is translated along the normal\n"
2346 " direction by the number specified.\n"
2347 " </Documentation>\n"
2348 " </DoubleVectorProperty>\n"
2349 "\n"
2350 " <PropertyGroup label=\"Plane Parameters\" panel_widget=\"InteractivePlane\">\n"
2351 " <Property function=\"Origin\" name=\"Origin\" />\n"
2352 " <Property function=\"Normal\" name=\"Normal\" />\n"
2353 " <Property function=\"Input\" name=\"Input\" />\n"
2354 " </PropertyGroup>\n"
2355 "\n"
2356 " <Hints>\n"
2357 " <!-- Hints are metadata associated with the proxy.\n"
2358 " As far as the ServerManager is concerned, Hints have no\n"
2359 " significance. GUI is free to interpret the hints as\n"
2360 " it chooses. Hints provide a mechanism to add some GUI\n"
2361 " pertinant information to the server manager XML.\n"
2362 " -->\n"
2363 "\n"
2364 " <ProxyList>\n"
2365 " <!--\n"
2366 " ProxyList hints are used when this proxy\n"
2367 " is made a part of a proxy list domain.\n"
2368 " It provides a mechanism to link certain\n"
2369 " properties from this proxy with properties\n"
2370 " from the proxy which has the property\n"
2371 " with the proxy list domain.\n"
2372 " -->\n"
2373 " <Link name=\"Input\"\n"
2374 " with_property=\"Input\" />\n"
2375 " </ProxyList>\n"
2376 " </Hints>\n"
2377 " </Proxy>\n"
2378 "\n"
2379 " <!-- ================================================================== -->\n"
2380 " <Proxy class=\"vtkPVPlane\"\n"
2381 " name=\"Axis Aligned Plane\">\n"
2382 " <InputProperty is_internal=\"1\"\n"
2383 " name=\"Input\"></InputProperty>\n"
2384 " <DoubleVectorProperty command=\"SetOrigin\"\n"
2385 " default_values=\"0.0 0.0 0.0\"\n"
2386 " name=\"Origin\"\n"
2387 " number_of_elements=\"3\">\n"
2388 " <BoundsDomain default_mode=\"mid\"\n"
2389 " mode=\"normal\"\n"
2390 " name=\"range\">\n"
2391 " <RequiredProperties>\n"
2392 " <Property function=\"Input\"\n"
2393 " name=\"Input\" />\n"
2394 " </RequiredProperties>\n"
2395 " </BoundsDomain>\n"
2396 " <Documentation>\n"
2397 " Set the origin of the plane.\n"
2398 " </Documentation>\n"
2399 " </DoubleVectorProperty>\n"
2400 " <DoubleVectorProperty command=\"SetNormal\"\n"
2401 " default_values=\"1.0 0.0 0.0\"\n"
2402 " name=\"Normal\"\n"
2403 " number_of_elements=\"3\">\n"
2404 " <DoubleRangeDomain name=\"range\" />\n"
2405 " <Documentation>\n"
2406 " Set the normal of the plane. For many filters this also sets the side\n"
2407 " of the plane that is of interest. The normal points towards the\n"
2408 " \"outside\" of the plane.\n"
2409 " </Documentation>\n"
2410 " </DoubleVectorProperty>\n"
2411 " <DoubleVectorProperty animateable=\"1\"\n"
2412 " command=\"SetOffset\"\n"
2413 " default_values=\"0.0\"\n"
2414 " name=\"Offset\"\n"
2415 " number_of_elements=\"1\">\n"
2416 " <Documentation>\n"
2417 " Set the value to offset the origin by. The origin is translated along the normal\n"
2418 " direction by the number specified.\n"
2419 " </Documentation>\n"
2420 " </DoubleVectorProperty>\n"
2421 " <IntVectorProperty command=\"SetAxisAligned\"\n"
2422 " default_values=\"1\"\n"
2423 " name=\"AlwaysSnapToNearestAxis\"\n"
2424 " number_of_elements=\"1\">\n"
2425 " <BooleanDomain name=\"bool\" />\n"
2426 " </IntVectorProperty>\n"
2427 " <PropertyGroup label=\"Plane Parameters\" panel_widget=\"InteractivePlane\">\n"
2428 " <Property function=\"Origin\" name=\"Origin\" />\n"
2429 " <Property function=\"Normal\" name=\"Normal\" />\n"
2430 " <Property function=\"Input\" name=\"Input\" />\n"
2431 " <Property function=\"AlwaysSnapToNearestAxis\" name=\"AlwaysSnapToNearestAxis\" />\n"
2432 " </PropertyGroup>\n"
2433 "\n"
2434 " <Hints>\n"
2435 " <ProxyList>\n"
2436 " <Link name=\"Input\"\n"
2437 " with_property=\"Input\" />\n"
2438 " </ProxyList>\n"
2439 " </Hints>\n"
2440 " <!-- End of Axis Aligned Plane -->\n"
2441 " </Proxy>\n"
2442 "\n"
2443 " <!-- ================================================================== -->\n"
2444 " <Proxy class=\"vtkPVBox\" name=\"Axis Aligned Box\">\n"
2445 " <InputProperty is_internal=\"1\" name=\"Input\" />\n"
2446 " <IntVectorProperty name=\"UseReferenceBounds\"\n"
2447 " command=\"SetUseReferenceBounds\"\n"
2448 " number_of_elements=\"1\"\n"
2449 " default_values=\"0\">\n"
2450 " <BooleanDomain name=\"bool\" />\n"
2451 " </IntVectorProperty>\n"
2452 " <DoubleVectorProperty command=\"SetReferenceBounds\"\n"
2453 " default_values=\"0 1 0 1 0 1\"\n"
2454 " name=\"Bounds\"\n"
2455 " number_of_elements=\"6\">\n"
2456 " <BoundsDomain mode=\"data_bounds\" name=\"range\">\n"
2457 " <RequiredProperties>\n"
2458 " <Property function=\"Input\" name=\"Input\" />\n"
2459 " </RequiredProperties>\n"
2460 " </BoundsDomain>\n"
2461 " <Hints>\n"
2462 " <NoDefault />\n"
2463 " </Hints>\n"
2464 " </DoubleVectorProperty>\n"
2465 " <DoubleVectorProperty animateable=\"1\"\n"
2466 " command=\"SetPosition\"\n"
2467 " default_values=\"0.0 0.0 0.0\"\n"
2468 " name=\"Position\"\n"
2469 " number_of_elements=\"3\">\n"
2470 " <BoundsDomain default_mode=\"min\" mode=\"normal\" name=\"range\">\n"
2471 " <RequiredProperties>\n"
2472 " <Property function=\"Input\" name=\"Input\" />\n"
2473 " </RequiredProperties>\n"
2474 " </BoundsDomain>\n"
2475 " <Documentation>\n"
2476 " Set the position of the box.\n"
2477 " </Documentation>\n"
2478 " </DoubleVectorProperty>\n"
2479 " <DoubleVectorProperty animateable=\"1\"\n"
2480 " command=\"SetRotation\"\n"
2481 " default_values=\"0.0 0.0 0.0\"\n"
2482 " name=\"Rotation\"\n"
2483 " number_of_elements=\"3\">\n"
2484 " <DoubleRangeDomain name=\"range\" />\n"
2485 " <Documentation>\n"
2486 " Set the orientation of the box.\n"
2487 " </Documentation>\n"
2488 " </DoubleVectorProperty>\n"
2489 " <DoubleVectorProperty animateable=\"1\"\n"
2490 ;
2491
2492 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Misc/Resources/misc_utilities.xml
2494 " command=\"SetScale\"\n"
2495 " default_values=\"1.0 1.0 1.0\"\n"
2496 " name=\"Length\"\n"
2497 " number_of_elements=\"3\">\n"
2498 " <BoundsDomain default_mode=\"max\" mode=\"component_magnitude\" name=\"range\">\n"
2499 " <RequiredProperties>\n"
2500 " <Property function=\"Input\" name=\"Input\" />\n"
2501 " </RequiredProperties>\n"
2502 " </BoundsDomain>\n"
2503 " <Documentation>\n"
2504 " Set the size of the box via a scale factor.\n"
2505 " </Documentation>\n"
2506 " </DoubleVectorProperty>\n"
2507 " <PropertyGroup label=\"Box Parameters\" panel_widget=\"InteractiveBox\">\n"
2508 " <Property function=\"Position\" name=\"Position\" />\n"
2509 " <Property function=\"Scale\" name=\"Length\" />\n"
2510 " <Property function=\"Input\" name=\"Input\" />\n"
2511 " <Property function=\"UseReferenceBounds\" name=\"UseReferenceBounds\" />\n"
2512 " <Property function=\"ReferenceBounds\" name=\"Bounds\" />\n"
2513 " </PropertyGroup>\n"
2514 " <Hints>\n"
2515 " <ProxyList>\n"
2516 " <Link name=\"Input\" with_property=\"Input\" />\n"
2517 " </ProxyList>\n"
2518 " </Hints>\n"
2519 " <!-- End of Axis Aligned Box -->\n"
2520 " </Proxy>\n"
2521 "\n"
2522 " <!-- ================================================================== -->\n"
2523 " <Proxy class=\"vtkPVBox\" name=\"Box\">\n"
2524 " <InputProperty is_internal=\"1\" name=\"Input\" />\n"
2525 " <IntVectorProperty name=\"UseReferenceBounds\"\n"
2526 " command=\"SetUseReferenceBounds\"\n"
2527 " number_of_elements=\"1\"\n"
2528 " default_values=\"0\">\n"
2529 " <BooleanDomain name=\"bool\" />\n"
2530 " </IntVectorProperty>\n"
2531 " <DoubleVectorProperty command=\"SetReferenceBounds\"\n"
2532 " default_values=\"0 1 0 1 0 1\"\n"
2533 " name=\"Bounds\"\n"
2534 " number_of_elements=\"6\">\n"
2535 " <BoundsDomain mode=\"data_bounds\" name=\"range\">\n"
2536 " <RequiredProperties>\n"
2537 " <Property function=\"Input\" name=\"Input\" />\n"
2538 " </RequiredProperties>\n"
2539 " </BoundsDomain>\n"
2540 " <Hints>\n"
2541 " <NoDefault />\n"
2542 " </Hints>\n"
2543 " </DoubleVectorProperty>\n"
2544 " <DoubleVectorProperty animateable=\"1\"\n"
2545 " command=\"SetPosition\"\n"
2546 " default_values=\"0.0 0.0 0.0\"\n"
2547 " name=\"Position\"\n"
2548 " number_of_elements=\"3\">\n"
2549 " <BoundsDomain default_mode=\"min\" mode=\"normal\" name=\"range\">\n"
2550 " <RequiredProperties>\n"
2551 " <Property function=\"Input\" name=\"Input\" />\n"
2552 " </RequiredProperties>\n"
2553 " </BoundsDomain>\n"
2554 " <Documentation>\n"
2555 " Set the position of the box.\n"
2556 " </Documentation>\n"
2557 " </DoubleVectorProperty>\n"
2558 " <DoubleVectorProperty animateable=\"1\"\n"
2559 " command=\"SetRotation\"\n"
2560 " default_values=\"0.0 0.0 0.0\"\n"
2561 " name=\"Rotation\"\n"
2562 " number_of_elements=\"3\">\n"
2563 " <DoubleRangeDomain name=\"range\" />\n"
2564 " <Documentation>\n"
2565 " Set the orientation of the box.\n"
2566 " </Documentation>\n"
2567 " </DoubleVectorProperty>\n"
2568 " <DoubleVectorProperty animateable=\"1\"\n"
2569 " command=\"SetScale\"\n"
2570 " default_values=\"1.0 1.0 1.0\"\n"
2571 " name=\"Length\"\n"
2572 " number_of_elements=\"3\">\n"
2573 " <BoundsDomain default_mode=\"max\" mode=\"component_magnitude\" name=\"range\">\n"
2574 " <RequiredProperties>\n"
2575 " <Property function=\"Input\" name=\"Input\" />\n"
2576 " </RequiredProperties>\n"
2577 " </BoundsDomain>\n"
2578 " <Documentation>\n"
2579 " Set the size of the box via a scale factor.\n"
2580 " </Documentation>\n"
2581 " </DoubleVectorProperty>\n"
2582 " <PropertyGroup label=\"Box Parameters\" panel_widget=\"InteractiveBox\">\n"
2583 " <Property function=\"Position\" name=\"Position\" />\n"
2584 " <Property function=\"Rotation\" name=\"Rotation\" />\n"
2585 " <Property function=\"Scale\" name=\"Length\" />\n"
2586 " <Property function=\"Input\" name=\"Input\" />\n"
2587 " <Property function=\"UseReferenceBounds\" name=\"UseReferenceBounds\" />\n"
2588 " <Property function=\"ReferenceBounds\" name=\"Bounds\" />\n"
2589 " </PropertyGroup>\n"
2590 " <Hints>\n"
2591 " <ProxyList>\n"
2592 " <Link name=\"Input\" with_property=\"Input\" />\n"
2593 " </ProxyList>\n"
2594 " </Hints>\n"
2595 " <!-- End of Box -->\n"
2596 " </Proxy>\n"
2597 "\n"
2598 " <!-- ================================================================== -->\n"
2599 " <Proxy class=\"vtkPVCylinder\" name=\"Cylinder\">\n"
2600 " <InputProperty is_internal=\"1\" name=\"Input\" />\n"
2601 " <DoubleVectorProperty command=\"SetCenter\"\n"
2602 " default_values=\"0 0 0\"\n"
2603 " name=\"Center\"\n"
2604 " number_of_elements=\"3\">\n"
2605 " <BoundsDomain default_mode=\"mid\" mode=\"normal\" name=\"range\">\n"
2606 " <RequiredProperties>\n"
2607 " <Property function=\"Input\" name=\"Input\" />\n"
2608 " </RequiredProperties>\n"
2609 " </BoundsDomain>\n"
2610 " <Documentation>\n"
2611 " Set the center of the cylinder.\n"
2612 " </Documentation>\n"
2613 " </DoubleVectorProperty>\n"
2614 " <DoubleVectorProperty command=\"SetOrientedAxis\"\n"
2615 " default_values=\"0. 1. 0.\"\n"
2616 " name=\"Axis\"\n"
2617 " number_of_elements=\"3\">\n"
2618 " <Documentation>\n"
2619 " Set the axis of the cylinder. This is the direction from the center of one end of\n"
2620 " the cylinder to the center of the other end. The cylinder created has infinite length\n"
2621 " but this direction controls which line through the center point the cylinder is around.\n"
2622 " </Documentation>\n"
2623 " </DoubleVectorProperty>\n"
2624 " <DoubleVectorProperty command=\"SetRadius\"\n"
2625 " default_values=\"0.5\"\n"
2626 " name=\"Radius\"\n"
2627 " number_of_elements=\"1\">\n"
2628 " <BoundsDomain name=\"range\" mode=\"scaled_extent\" scale_factor=\"0.5\" default_mode=\"max\">\n"
2629 " <RequiredProperties>\n"
2630 " <Property function=\"Input\" name=\"Input\" />\n"
2631 " </RequiredProperties>\n"
2632 " </BoundsDomain>\n"
2633 " <Documentation>\n"
2634 " Set the radius of the cylinder.\n"
2635 " </Documentation>\n"
2636 " </DoubleVectorProperty>\n"
2637 " <PropertyGroup label=\"Cylinder Parameters\" panel_widget=\"InteractiveCylinder\">\n"
2638 " <Property function=\"Center\" name=\"Center\" />\n"
2639 " <Property function=\"Axis\" name=\"Axis\" />\n"
2640 " <Property function=\"Radius\" name=\"Radius\" />\n"
2641 " <Property function=\"Input\" name=\"Input\" />\n"
2642 " </PropertyGroup>\n"
2643 " <Hints>\n"
2644 " <ProxyList>\n"
2645 " <Link name=\"Input\" with_property=\"Input\" />\n"
2646 " </ProxyList>\n"
2647 " </Hints>\n"
2648 " <!-- End of Cylinder -->\n"
2649 " </Proxy>\n"
2650 "\n"
2651 " <!-- ================================================================== -->\n"
2652 " <Proxy class=\"vtkPerlinNoise\" name=\"PerlinNoise\">\n"
2653 " <InputProperty is_internal=\"1\" name=\"Input\" />\n"
2654 " <DoubleVectorProperty\n"
2655 " name=\"Frequency\"\n"
2656 " command=\"SetFrequency\"\n"
2657 " number_of_elements=\"3\"\n"
2658 " default_values=\"1 1 1\">\n"
2659 " <Documentation>\n"
2660 " Set the frequency, or physical scale, of the noise function\n"
2661 " (higher is finer scale).\n"
2662 " </Documentation>\n"
2663 " </DoubleVectorProperty>\n"
2664 " <DoubleVectorProperty\n"
2665 " name=\"Phase\"\n"
2666 " command=\"SetPhase\"\n"
2667 " number_of_elements=\"3\"\n"
2668 " default_values=\"0 0 0\">\n"
2669 " <Documentation>\n"
2670 " This parameter can be used to shift the noise function within\n"
2671 " space (perhaps to avoid a beat with a noise pattern at another\n"
2672 " scale). Phase tends to repeat about every unit, so a phase of\n"
2673 " 0.5 is a half-cycle shift.\n"
2674 " </Documentation>\n"
2675 " </DoubleVectorProperty>\n"
2676 " <DoubleVectorProperty\n"
2677 " name=\"Amplitude\"\n"
2678 " command=\"SetAmplitude\"\n"
2679 " number_of_elements=\"1\"\n"
2680 " default_values=\"1\">\n"
2681 " <Documentation>\n"
2682 " Amplitude can be negative. The noise function varies randomly\n"
2683 " between -|Amplitude| and |Amplitude|.\n"
2684 " </Documentation>\n"
2685 " </DoubleVectorProperty>\n"
2686 " <Hints>\n"
2687 " <ProxyList>\n"
2688 " <Link name=\"Input\" with_property=\"Input\" />\n"
2689 " </ProxyList>\n"
2690 " </Hints>\n"
2691 " </Proxy>\n"
2692 " <!-- ================================================================== -->\n"
2693 " <Proxy\n"
2694 " class=\"vtkCoordinateFrame\" name=\"CoordinateFrame\"\n"
2695 " processes=\"dataserver|renderserver|client\">\n"
2696 " <InputProperty is_internal=\"1\"\n"
2697 " name=\"Input\"></InputProperty>\n"
2698 " <DoubleVectorProperty command=\"SetOrigin\"\n"
2699 " default_values=\"0.0 0.0 0.0\"\n"
2700 " name=\"Origin\"\n"
2701 " number_of_elements=\"3\">\n"
2702 " <BoundsDomain default_mode=\"mid\"\n"
2703 " mode=\"normal\"\n"
2704 " name=\"range\">\n"
2705 " <RequiredProperties>\n"
2706 " <Property function=\"Input\"\n"
2707 " name=\"Input\" />\n"
2708 " </RequiredProperties>\n"
2709 " </BoundsDomain>\n"
2710 " <Documentation>\n"
2711 " Set the origin of the coordinate frame.\n"
2712 " </Documentation>\n"
2713 " </DoubleVectorProperty>\n"
2714 " <DoubleVectorProperty command=\"SetXAxis\"\n"
2715 " default_values=\"1.0 0.0 0.0\"\n"
2716 " name=\"XAxis\"\n"
2717 " number_of_elements=\"3\">\n"
2718 " <DoubleRangeDomain name=\"range\" />\n"
2719 " <Documentation>\n"
2720 " Set one axis of the coordinate frame. The axis vectors must\n"
2721 " all be of unit length, be perpendicular to one another, and\n"
2722 " form a right-handed coordinate system.\n"
2723 " </Documentation>\n"
2724 " </DoubleVectorProperty>\n"
2725 " <DoubleVectorProperty command=\"SetYAxis\"\n"
2726 " default_values=\"0.0 1.0 0.0\"\n"
2727 " name=\"YAxis\"\n"
2728 " number_of_elements=\"3\">\n"
2729 " <DoubleRangeDomain name=\"range\" />\n"
2730 " <Documentation>\n"
2731 " Set one axis of the coordinate frame. The axis vectors must\n"
2732 " all be of unit length, be perpendicular to one another, and\n"
2733 " form a right-handed coordinate system.\n"
2734 " </Documentation>\n"
2735 " </DoubleVectorProperty>\n"
2736 " <DoubleVectorProperty command=\"SetZAxis\"\n"
2737 " default_values=\"0.0 0.0 1.0\"\n"
2738 " name=\"ZAxis\"\n"
2739 " number_of_elements=\"3\">\n"
2740 " <DoubleRangeDomain name=\"range\" />\n"
2741 " <Documentation>\n"
2742 " Set one axis of the coordinate frame. The axis vectors must\n"
2743 " all be of unit length, be perpendicular to one another, and\n"
2744 " form a right-handed coordinate system.\n"
2745 " </Documentation>\n"
2746 " </DoubleVectorProperty>\n"
2747 "\n"
2748 " <PropertyGroup label=\"Frame Parameters\" panel_widget=\"InteractivePlane\">\n"
2749 " <Property function=\"Origin\" name=\"Origin\" />\n"
2750 " <Property function=\"XAxis\" name=\"XAxis\" />\n"
2751 " <Property function=\"YAxis\" name=\"YAxis\" />\n"
2752 " <Property function=\"ZAxis\" name=\"ZAxis\" />\n"
2753 " <Property function=\"Input\" name=\"Input\" />\n"
2754 " </PropertyGroup>\n"
2755 "\n"
2756 " <Hints>\n"
2757 " <!-- Hints are metadata associated with the proxy.\n"
2758 " As far as the ServerManager is concerned, Hints have no\n"
2759 " significance. GUI is free to interpret the hints as\n"
2760 " it chooses. Hints provide a mechanism to add some GUI\n"
2761 " pertinant information to the server manager XML.\n"
2762 " -->\n"
2763 "\n"
2764 " <ProxyList>\n"
2765 " <!--\n"
2766 " ProxyList hints are used when this proxy\n"
2767 " is made a part of a proxy list domain.\n"
2768 " It provides a mechanism to link certain\n"
2769 " properties from this proxy with properties\n"
2770 " from the proxy which has the property\n"
2771 " with the proxy list domain.\n"
2772 " -->\n"
2773 " <Link name=\"Input\"\n"
2774 " with_property=\"Input\" />\n"
2775 " </ProxyList>\n"
2776 " </Hints>\n"
2777 " </Proxy>\n"
2778 "\n"
2779 " </ProxyGroup>\n"
2780 " <!-- ================================================================== -->\n"
2781 " <ProxyGroup name=\"slice_implicit_functions\">\n"
2782 " <Proxy group=\"implicit_functions\"\n"
2783 " name=\"Plane\" />\n"
2784 " <Proxy group=\"implicit_functions\"\n"
2785 " name=\"Box\" />\n"
2786 " <Proxy group=\"implicit_functions\"\n"
2787 " name=\"Sphere\" />\n"
2788 " <Proxy group=\"implicit_functions\"\n"
2789 " name=\"Cylinder\" />\n"
2790 " </ProxyGroup>\n"
2791 " <ProxyGroup name=\"slice_htg_amr_implicit_functions\">\n"
2792 " <Proxy group=\"implicit_functions\"\n"
2793 " name=\"Plane\" />\n"
2794 " <Proxy group=\"implicit_functions\"\n"
2795 " name=\"Axis Aligned Plane\" />\n"
2796 " </ProxyGroup>\n"
2797 " <ProxyGroup name=\"extract_implicit_functions\">\n"
2798 " <Proxy group=\"implicit_functions\"\n"
2799 " name=\"Plane\" />\n"
2800 " <Proxy group=\"implicit_functions\"\n"
2801 " name=\"Box\" />\n"
2802 " <Proxy group=\"implicit_functions\"\n"
2803 " name=\"Sphere\" />\n"
2804 " </ProxyGroup>\n"
2805 " <ProxyGroup name=\"clip_implicit_functions\">\n"
2806 " <Proxy group=\"implicit_functions\"\n"
2807 " name=\"Plane\" />\n"
2808 " <Proxy group=\"implicit_functions\"\n"
2809 " name=\"Box\" />\n"
2810 " <Proxy group=\"implicit_functions\"\n"
2811 " name=\"Sphere\" />\n"
2812 " <Proxy group=\"implicit_functions\"\n"
2813 " name=\"Cylinder\" />\n"
2814 " <Proxy group=\"implicit_functions\"\n"
2815 " name=\"Scalar\" />\n"
2816 " </ProxyGroup>\n"
2817 " <ProxyGroup name=\"clip_htg_implicit_functions\">\n"
2818 " <Proxy group=\"implicit_functions\"\n"
2819 " name=\"Plane\" />\n"
2820 " <Proxy group=\"implicit_functions\"\n"
2821 " name=\"Axis Aligned Box\" />\n"
2822 " <Proxy group=\"implicit_functions\"\n"
2823 " name=\"Sphere\" />\n"
2824 " <Proxy group=\"implicit_functions\"\n"
2825 " name=\"Cylinder\" />\n"
2826 " <Proxy group=\"implicit_functions\"\n"
2827 " name=\"Scalar\" />\n"
2828 " </ProxyGroup>\n"
2829 "</ServerManagerConfiguration>\n"
2830 "\n";
2831 // Get single string
2833 {
2834
2835  const size_t len0 = strlen(paraview_server_managermisc_utilitiesInterface0);
2836  const size_t len1 = strlen(paraview_server_managermisc_utilitiesInterface1);
2837  size_t len = ( 0
2838  + len0
2839  + len1 );
2840  char* res = new char[ len + 1];
2841  size_t offset = 0;
2844  assert(offset == len);
2845  res[offset] = 0;
2846  return res;
2847 }
2848
2849
2850 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersRendering/Resources/rendering_sources.xml
2852 "<ServerManagerConfiguration>\n"
2853 " <ProxyGroup name=\"sources\">\n"
2854 " <!-- ==================================================================== -->\n"
2855 " <SourceProxy class=\"vtkNetworkImageSource\"\n"
2856 " name=\"NetworkImageSource\"\n"
2857 " post_push=\"UpdateImage\"\n"
2858 " processes=\"client|renderserver\">\n"
2859 " <StringVectorProperty command=\"SetFileName\"\n"
2860 " name=\"FileName\"\n"
2861 " number_of_elements=\"1\">\n"
2862 " <Documentation>Set the name of image file to load.</Documentation>\n"
2863 " <FileListDomain name=\"files\" />\n"
2864 " </StringVectorProperty>\n"
2865 " <StringVectorProperty command=\"SetTrivialProducerKey\"\n"
2866 " name=\"TrivialProducerKey\"\n"
2867 " number_of_elements=\"1\">\n"
2868 " <Documentation>\n"
2869 " Set the key used to locate the image data object on the server.\n"
2870 " </Documentation>\n"
2871 " </StringVectorProperty>\n"
2872 " <IntVectorProperty command=\"SetMode\"\n"
2873 " name=\"Mode\"\n"
2874 " number_of_elements=\"1\"\n"
2875 " default_values=\"0\">\n"
2876 " <Documentation>\n"
2877 " Set the mode in which image data is read.\n"
2878 " </Documentation>\n"
2879 " <EnumerationDomain name=\"enum\">\n"
2880 " <Entry text=\"ReadFromFile\" value=\"0\"/>\n"
2881 " <Entry text=\"ReadFromMemory\" value=\"1\"/>\n"
2882 " </EnumerationDomain>\n"
2883 " </IntVectorProperty>\n"
2884 " <!-- End of NetworkImageSource -->\n"
2885 " </SourceProxy>\n"
2886 " </ProxyGroup>\n"
2887 "</ServerManagerConfiguration>\n"
2888 "\n";
2889 // Get single string
2891 {
2892
2893  const size_t len0 = strlen(paraview_server_managerrendering_sourcesInterface0);
2894  size_t len = ( 0
2895  + len0 );
2896  char* res = new char[ len + 1];
2897  size_t offset = 0;
2899  assert(offset == len);
2900  res[offset] = 0;
2901  return res;
2902 }
2903
2904
2905 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersRendering/Resources/filters_filtersrendering.xml
2907 "<ServerManagerConfiguration>\n"
2908 " <ProxyGroup name=\"filters\">\n"
2909 " <!-- ==================================================================== -->\n"
2910 " <SourceProxy class=\"vtkClientServerMoveData\"\n"
2911 " name=\"ClientServerMoveData\"\n"
2912 " processes=\"client|dataserver\">\n"
2913 " <InputProperty command=\"SetInputConnection\"\n"
2914 " name=\"Input\">\n"
2915 " <ProxyGroupDomain name=\"groups\">\n"
2916 " <Group name=\"sources\" />\n"
2917 " <Group name=\"filters\" />\n"
2918 " </ProxyGroupDomain>\n"
2919 " <Documentation>Set the input to the Client Server Move Data\n"
2920 " filter.</Documentation>\n"
2921 " </InputProperty>\n"
2922 " <IntVectorProperty animateable=\"0\"\n"
2923 " command=\"SetOutputDataType\"\n"
2924 " default_values=\"0\"\n"
2925 " name=\"OutputDataType\"\n"
2926 " number_of_elements=\"1\"></IntVectorProperty>\n"
2927 " <IntVectorProperty command=\"SetWholeExtent\"\n"
2928 " default_values=\"0 -1 0 -1 0 -1\"\n"
2929 " name=\"WholeExtent\"\n"
2930 " number_of_elements=\"6\"></IntVectorProperty>\n"
2931 " <!-- End ClientServerMoveData -->\n"
2932 " </SourceProxy>\n"
2933 "\n"
2934 " <!-- ==================================================================== -->\n"
2935 " <SourceProxy class=\"vtkMPIMoveData\"\n"
2936 " name=\"MPIMoveData\">\n"
2937 " <InputProperty command=\"SetInputConnection\"\n"
2938 " name=\"Input\">\n"
2939 " <ProxyGroupDomain name=\"groups\">\n"
2940 " <Group name=\"sources\" />\n"
2941 " <Group name=\"filters\" />\n"
2942 " </ProxyGroupDomain>\n"
2943 " <!-- Does this have any data type domain? -->\n"
2944 " <Documentation>Set the input to the MPI Move Data\n"
2945 " filter.</Documentation>\n"
2946 " </InputProperty>\n"
2947 " <IntVectorProperty animateable=\"0\"\n"
2948 " command=\"SetMoveMode\"\n"
2949 " default_values=\"0\"\n"
2950 " name=\"MoveMode\"\n"
2951 " number_of_elements=\"1\">\n"
2952 " <EnumerationDomain name=\"enum\">\n"
2953 " <Entry text=\"PassThrough\"\n"
2954 " value=\"0\" />\n"
2955 " <Entry text=\"Collect\"\n"
2956 " value=\"1\" />\n"
2957 " <Entry text=\"Clone\"\n"
2958 " value=\"2\" />\n"
2959 " </EnumerationDomain>\n"
2960 " <Documentation>Specify how the data is to be\n"
2961 " redistributed.</Documentation>\n"
2962 " </IntVectorProperty>\n"
2963 " <IntVectorProperty animateable=\"0\"\n"
2964 " command=\"SetOutputDataType\"\n"
2965 " default_values=\"none\"\n"
2966 " name=\"OutputDataType\"\n"
2967 " number_of_elements=\"1\">\n"
2968 " <EnumerationDomain name=\"enum\">\n"
2969 " <Entry text=\"PolyData\"\n"
2970 " value=\"0\" />\n"
2971 " <Entry text=\"Unstructured Grid\"\n"
2972 " value=\"4\" />\n"
2973 " <Entry text=\"ImageData\"\n"
2974 " value=\"6\" />\n"
2975 " </EnumerationDomain>\n"
2976 " <Documentation>Specify the type of the dataset.</Documentation>\n"
2977 " </IntVectorProperty>\n"
2978 " <!-- End MPIMoveData -->\n"
2979 " </SourceProxy>\n"
2980 "\n"
2981 " <!-- ==================================================================== -->\n"
2982 " <SourceProxy class=\"vtkPVGeometryFilter\"\n"
2983 " name=\"GeometryFilter\">\n"
2984 " <InputProperty command=\"SetInputConnection\"\n"
2985 " name=\"Input\">\n"
2986 " <ProxyGroupDomain name=\"groups\">\n"
2987 " <Group name=\"sources\" />\n"
2988 " <Group name=\"filters\" />\n"
2989 " </ProxyGroupDomain>\n"
2990 " <!-- Does this have any data type domain? -->\n"
2991 " <Documentation>Set the input to the Geometry Filter.</Documentation>\n"
2992 " </InputProperty>\n"
2993 " <IntVectorProperty animateable=\"0\"\n"
2994 " command=\"SetUseOutline\"\n"
2995 " default_values=\"0\"\n"
2996 " name=\"UseOutline\"\n"
2997 " number_of_elements=\"1\">\n"
2998 " <BooleanDomain name=\"bool\" />\n"
2999 " <Documentation>Toggle whether to generate an outline or a\n"
3000 " surface.</Documentation>\n"
3001 " </IntVectorProperty>\n"
3002 " <IntVectorProperty command=\"SetNonlinearSubdivisionLevel\"\n"
3003 " default_values=\"1\"\n"
3004 " name=\"NonlinearSubdivisionLevel\"\n"
3005 " number_of_elements=\"1\">\n"
3006 " <IntRangeDomain max=\"4\"\n"
3007 " min=\"0\"\n"
3008 " name=\"range\" />\n"
3009 " <Documentation>Nonlinear faces are approximated with flat polygons.\n"
3010 " This parameter controls how many times to subdivide nonlinear surface\n"
3011 " cells. Higher subdivisions generate closer approximations but take more\n"
3012 " memory and rendering time. Subdivision is recursive, so the number of\n"
3013 " output polygons can grow exponentially with this\n"
3014 " parameter.</Documentation>\n"
3015 " </IntVectorProperty>\n"
3016 " <IntVectorProperty animateable=\"0\"\n"
3017 " command=\"SetPassThroughCellIds\"\n"
3018 " default_values=\"1\"\n"
3019 " name=\"PassThroughIds\"\n"
3020 " number_of_elements=\"1\">\n"
3021 " <BooleanDomain name=\"bool\" />\n"
3022 " <Documentation>If on, the output polygonal dataset will have a cell data\n"
3023 " array that holds the cell index of the original 3D cell that produced\n"
3024 " each output cell. This is useful for cell picking.</Documentation>\n"
3025 " </IntVectorProperty>\n"
3026 " <IntVectorProperty animateable=\"0\"\n"
3027 " command=\"SetPassThroughPointIds\"\n"
3028 " default_values=\"1\"\n"
3029 " name=\"PassThroughPointIds\"\n"
3030 " number_of_elements=\"1\">\n"
3031 " <BooleanDomain name=\"bool\" />\n"
3032 " <Documentation>If on, the output polygonal dataset will have a\n"
3033 " point data array that holds the point index of the original 3D vertex\n"
3034 " that produced each output vertex. This is useful for\n"
3035 " picking.</Documentation>\n"
3036 " </IntVectorProperty>\n"
3037 " <!-- End GeometryFilter -->\n"
3038 " </SourceProxy>\n"
3039 "\n"
3040 " <!-- ==================================================================== -->\n"
3041 " </ProxyGroup>\n"
3042 "</ServerManagerConfiguration>\n"
3043 "\n";
3044 // Get single string
3046 {
3047
3049  size_t len = ( 0
3050  + len0 );
3051  char* res = new char[ len + 1];
3052  size_t offset = 0;
3054  assert(offset == len);
3055  res[offset] = 0;
3056  return res;
3057 }
3058
3059
3060 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/2dwidgets_remotingviews.xml
3062 "<ServerManagerConfiguration>\n"
3063 " <!-- We put all 2D widget definitions in this file -->\n"
3064 " <ProxyGroup name=\"representations\">\n"
3065 " <!-- ================================================================== -->\n"
3066 " <New2DWidgetRepresentationProxy class=\"vtk2DWidgetRepresentation\"\n"
3067 " name=\"EqualizerWidgetRepresentation\">\n"
3068 " <IntVectorProperty command=\"SetEnabled\"\n"
3069 " default_values=\"0\"\n"
3070 " name=\"Enabled\"\n"
3071 " number_of_elements=\"1\">\n"
3072 " <BooleanDomain name=\"bool\" />\n"
3073 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3074 " </IntVectorProperty>\n"
3075 "\n"
3076 " <SubProxy>\n"
3077 " <Proxy name=\"ContextItem\"\n"
3078 " proxygroup=\"2d_widget_representations\"\n"
3079 " proxyname=\"EqualizerContextItem\"></Proxy>\n"
3080 " <ExposedProperties>\n"
3081 " <Property name=\"Visibility\" />\n"
3082 " <Property name=\"EqualizerPoints\" />\n"
3083 " </ExposedProperties>\n"
3084 " </SubProxy>\n"
3085 "\n"
3086 " </New2DWidgetRepresentationProxy>\n"
3087 " <!-- End of EqualizerWidgetRepresentation -->\n"
3088 " </ProxyGroup>\n"
3089 "\n"
3090 " <ProxyGroup name=\"2d_widget_representations\">\n"
3091 " <!-- ================================================================== -->\n"
3092 " <ContextItemWidgetProxy class=\"vtkEqualizerContextItem\"\n"
3093 " name=\"EqualizerContextItem\">\n"
3094 " <IntVectorProperty animateable=\"1\"\n"
3095 " command=\"SetVisible\"\n"
3096 " default_values=\"1\"\n"
3097 " name=\"Visibility\"\n"
3098 " number_of_elements=\"1\">\n"
3099 " <BooleanDomain name=\"bool\" />\n"
3100 " </IntVectorProperty>\n"
3101 " <StringVectorProperty animateable=\"1\"\n"
3102 " command=\"SetPoints\"\n"
3103 " label=\"Equalizer Points\"\n"
3104 " name=\"EqualizerPoints\"\n"
3105 " number_of_elements=\"1\"\n"
3106 " element_types=\"2\"\n"
3107 " panel_visibility=\"never\">\n"
3108 " <Documentation>This property defines the interactive points of the equalizer.</Documentation>\n"
3109 " </StringVectorProperty>\n"
3110 " </ContextItemWidgetProxy>\n"
3111 " <!-- End of EqualizerContextItem -->\n"
3112 " </ProxyGroup>\n"
3113 "</ServerManagerConfiguration>\n"
3114 "\n";
3115 // Get single string
3117 {
3118
3120  size_t len = ( 0
3121  + len0 );
3122  char* res = new char[ len + 1];
3123  size_t offset = 0;
3125  assert(offset == len);
3126  res[offset] = 0;
3127  return res;
3128 }
3129
3130
3131 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
3133 "<ServerManagerConfiguration>\n"
3134 " <!-- We put all 3D widget definitions in this file -->\n"
3135 " <ProxyGroup name=\"representations\">\n"
3136 " <!-- ================================================================== -->\n"
3137 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3138 " name=\"HandleWidgetRepresentation\">\n"
3139 " <IntVectorProperty command=\"SetEnabled\"\n"
3140 " default_values=\"0\"\n"
3141 " name=\"Enabled\"\n"
3142 " number_of_elements=\"1\">\n"
3143 " <BooleanDomain name=\"bool\" />\n"
3144 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3145 " </IntVectorProperty>\n"
3146 " <SubProxy>\n"
3147 " <Proxy name=\"Prop\"\n"
3148 " proxygroup=\"3d_widget_representations\"\n"
3149 " proxyname=\"HandleRepresentation\"></Proxy>\n"
3150 " <ExposedProperties>\n"
3151 " <Property name=\"ForegroundWidgetColor\" />\n"
3152 " <Property name=\"InteractiveWidgetColor\" />\n"
3153 " <Property name=\"Visibility\" />\n"
3154 " <Property name=\"WorldPositionInfo\" />\n"
3155 " <Property name=\"WorldPosition\" />\n"
3156 " </ExposedProperties>\n"
3157 " </SubProxy>\n"
3158 " <SubProxy>\n"
3159 " <Proxy name=\"Widget\"\n"
3160 " proxygroup=\"3d_widgets\"\n"
3161 " proxyname=\"HandleWidget\"></Proxy>\n"
3162 " </SubProxy>\n"
3163 " </NewWidgetRepresentationProxy>\n"
3164 " <!-- ================================================================== -->\n"
3165 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3166 " name=\"LightWidgetRepresentation\">\n"
3167 " <IntVectorProperty command=\"SetEnabled\"\n"
3168 " default_values=\"0\"\n"
3169 " name=\"Enabled\"\n"
3170 " number_of_elements=\"1\">\n"
3171 " <BooleanDomain name=\"bool\" />\n"
3172 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3173 " </IntVectorProperty>\n"
3174 " <SubProxy>\n"
3175 " <Proxy name=\"Prop\"\n"
3176 " proxygroup=\"3d_widget_representations\"\n"
3177 " proxyname=\"LightRepresentation\"></Proxy>\n"
3178 " <ExposedProperties>\n"
3179 " <Property name=\"Positional\" />\n"
3180 " <Property name=\"Visibility\" />\n"
3181 " <Property name=\"WorldPositionInfo\" />\n"
3182 " <Property name=\"WorldPosition\" />\n"
3183 " <Property name=\"FocalPointInfo\" />\n"
3184 " <Property name=\"FocalPoint\" />\n"
3185 " <Property name=\"ConeAngleInfo\" />\n"
3186 " <Property name=\"ConeAngle\" />\n"
3187 " <Property name=\"LightColorInfo\" />\n"
3188 " <Property name=\"LightColor\" />\n"
3189 " </ExposedProperties>\n"
3190 " </SubProxy>\n"
3191 " <SubProxy>\n"
3192 " <Proxy name=\"Widget\"\n"
3193 " proxygroup=\"3d_widgets\"\n"
3194 " proxyname=\"LightWidget\"></Proxy>\n"
3195 " </SubProxy>\n"
3196 " </NewWidgetRepresentationProxy>\n"
3197 " <!-- ================================================================== -->\n"
3198 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3199 " name=\"LineWidgetRepresentation\">\n"
3200 " <IntVectorProperty command=\"SetEnabled\"\n"
3201 " default_values=\"0\"\n"
3202 " name=\"Enabled\"\n"
3203 " number_of_elements=\"1\">\n"
3204 " <BooleanDomain name=\"bool\" />\n"
3205 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3206 " </IntVectorProperty>\n"
3207 " <SubProxy>\n"
3208 " <Proxy name=\"Prop\"\n"
3209 " proxygroup=\"3d_widget_representations\"\n"
3210 " proxyname=\"LineRepresentation\"></Proxy>\n"
3211 " <ExposedProperties>\n"
3212 " <Property name=\"Visibility\" />\n"
3213 " <Property name=\"DirectionalLine\" />\n"
3214 " <Property name=\"Point1WorldPositionInfo\" />\n"
3215 " <Property name=\"Point1WorldPosition\" />\n"
3216 " <Property name=\"Point2WorldPositionInfo\" />\n"
3217 " <Property name=\"Point2WorldPosition\" />\n"
3218 " <Property name=\"LineColor\" />\n"
3219 " <Property name=\"ForegroundWidgetColor\" />\n"
3220 " <Property name=\"InteractiveWidgetColor\" />\n"
3221 " </ExposedProperties>\n"
3222 " </SubProxy>\n"
3223 " <SubProxy>\n"
3224 " <Proxy name=\"Widget\"\n"
3225 " proxygroup=\"3d_widgets\"\n"
3226 " proxyname=\"LineWidget2\"></Proxy>\n"
3227 " <ExposedProperties>\n"
3228 " <Property name=\"ProcessEvents\" />\n"
3229 " </ExposedProperties>\n"
3230 " </SubProxy>\n"
3231 " </NewWidgetRepresentationProxy>\n"
3232 " <!-- ================================================================== -->\n"
3233 " <NewWidgetRepresentationProxy base_proxygroup=\"representations\"\n"
3234 " base_proxyname=\"LineWidgetRepresentation\"\n"
3235 " class=\"vtk3DWidgetRepresentation\"\n"
3236 " name=\"LineSourceWidgetRepresentation\">\n"
3237 " <!--\n"
3238 " This is same as LineWidgetRepresentation except that it provides\n"
3239 " dummy property for the resolution for the line source.\n"
3240 " -->\n"
3241 " <IntVectorProperty default_values=\"1\"\n"
3242 " name=\"Resolution\"\n"
3243 " number_of_elements=\"1\">\n"
3244 " <IntRangeDomain min=\"1\"\n"
3245 " name=\"range\" />\n"
3246 " </IntVectorProperty>\n"
3247 " </NewWidgetRepresentationProxy>\n"
3248 " <!-- ================================================================== -->\n"
3249 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3250 " name=\"ImplicitPlaneWidgetRepresentation\">\n"
3251 " <IntVectorProperty command=\"SetEnabled\"\n"
3252 " default_values=\"1\"\n"
3253 " name=\"Enabled\"\n"
3254 " number_of_elements=\"1\">\n"
3255 " <BooleanDomain name=\"bool\" />\n"
3256 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3257 " </IntVectorProperty>\n"
3258 " <SubProxy>\n"
3259 " <Proxy name=\"Prop\"\n"
3260 " proxygroup=\"3d_widget_representations\"\n"
3261 " proxyname=\"ImplicitPlaneRepresentation\"></Proxy>\n"
3262 " <ExposedProperties>\n"
3263 " <Property name=\"DrawPlane\" />\n"
3264 " <Property name=\"DrawOutline\" />\n"
3265 " <Property name=\"ConstrainToWidgetBounds\" />\n"
3266 " <Property name=\"OutlineTranslation\" />\n"
3267 " <Property name=\"OriginInfo\" />\n"
3268 " <Property name=\"Origin\" />\n"
3269 " <Property name=\"NormalInfo\" />\n"
3270 " <Property name=\"Normal\" />\n"
3271 " <Property name=\"WidgetBounds\" />\n"
3272 " <Property name=\"Visibility\" />\n"
3273 " <Property name=\"PlaceFactor\" />\n"
3274 " <Property name=\"Reset\" />\n"
3275 " <Property name=\"AlwaysSnapToNearestAxis\" />\n"
3276 " <Property name=\"AlwaysSnapToNearestAxisInfo\" />\n"
3277 " </ExposedProperties>\n"
3278 " </SubProxy>\n"
3279 " <SubProxy>\n"
3280 " <Proxy name=\"Widget\"\n"
3281 " proxygroup=\"3d_widgets\"\n"
3282 " proxyname=\"ImplicitPlaneWidget2\"></Proxy>\n"
3283 " </SubProxy>\n"
3284 " </NewWidgetRepresentationProxy>\n"
3285 " <!-- ================================================================== -->\n"
3286 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3287 " name=\"DisplaySizedImplicitPlaneWidgetRepresentation\">\n"
3288 " <IntVectorProperty command=\"SetEnabled\"\n"
3289 " default_values=\"1\"\n"
3290 " name=\"Enabled\"\n"
3291 " number_of_elements=\"1\">\n"
3292 " <BooleanDomain name=\"bool\" />\n"
3293 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3294 " </IntVectorProperty>\n"
3295 " <SubProxy>\n"
3296 " <Proxy name=\"Prop\"\n"
3297 " proxygroup=\"3d_widget_representations\"\n"
3298 " proxyname=\"DisplaySizedImplicitPlaneRepresentation\"></Proxy>\n"
3299 " <ExposedProperties>\n"
3300 " <Property name=\"RadiusMultiplier\" />\n"
3301 " <Property name=\"DrawPlane\" />\n"
3302 " <Property name=\"DrawOutline\" />\n"
3303 " <Property name=\"DrawIntersectionEdges\" />\n"
3304 " <Property name=\"ConstrainToWidgetBounds\" />\n"
3305 " <Property name=\"ConstrainMaximumSizeToWidgetBounds\" />\n"
3306 " <Property name=\"ForegroundWidgetColor\" />\n"
3307 " <Property name=\"InteractiveWidgetColor\" />\n"
3308 " <Property name=\"OutlineTranslation\" />\n"
3309 " <Property name=\"OriginInfo\" />\n"
3310 " <Property name=\"Origin\" />\n"
3311 " <Property name=\"NormalInfo\" />\n"
3312 " <Property name=\"Normal\" />\n"
3313 " <Property name=\"WidgetBounds\" />\n"
3314 " <Property name=\"WidgetColor\" />\n"
3315 " <Property name=\"Visibility\" />\n"
3316 " <Property name=\"PlaceFactor\" />\n"
3317 " <Property name=\"Reset\" />\n"
3318 " <Property name=\"AlwaysSnapToNearestAxis\" />\n"
3319 " <Property name=\"AlwaysSnapToNearestAxisInfo\" />\n"
3320 " </ExposedProperties>\n"
3321 " </SubProxy>\n"
3322 " <SubProxy>\n"
3323 " <Proxy name=\"Widget\"\n"
3324 " proxygroup=\"3d_widgets\"\n"
3325 " proxyname=\"DisplaySizedImplicitPlaneWidget\"></Proxy>\n"
3326 " </SubProxy>\n"
3327 " </NewWidgetRepresentationProxy>\n"
3328 " <!-- ================================================================== -->\n"
3329 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3330 " name=\"CoordinateFrameWidgetRepresentation\">\n"
3331 " <IntVectorProperty command=\"SetEnabled\"\n"
3332 " default_values=\"1\"\n"
3333 " name=\"Enabled\"\n"
3334 " number_of_elements=\"1\">\n"
3335 " <BooleanDomain name=\"bool\" />\n"
3336 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3337 " </IntVectorProperty>\n"
3338 " <SubProxy>\n"
3339 " <Proxy name=\"Prop\"\n"
3340 " proxygroup=\"3d_widget_representations\"\n"
3341 " proxyname=\"CoordinateFrameRepresentation\"></Proxy>\n"
3342 " <ExposedProperties>\n"
3343 " <Property name=\"OriginInfo\" />\n"
3344 " <Property name=\"Origin\" />\n"
3345 " <Property name=\"XAxis\" />\n"
3346 " <Property name=\"XAxisInfo\" />\n"
3347 " <Property name=\"YAxis\" />\n"
3348 " <Property name=\"YAxisInfo\" />\n"
3349 " <Property name=\"ZAxis\" />\n"
3350 " <Property name=\"ZAxisInfo\" />\n"
3351 " <Property name=\"WidgetBounds\" />\n"
3352 " <Property name=\"Visibility\" />\n"
3353 " <Property name=\"Reset\" />\n"
3354 " <Property name=\"ResetAxes\" />\n"
3355 " <Property name=\"UseCameraNormal\" />\n"
3356 " <Property name=\"Normal\" />\n"
3357 " <Property name=\"Direction\" />\n"
3358 " <Property name=\"LockedAxis\" />\n"
3359 " <Property name=\"LockedAxisInfo\" />\n"
3360 " <Property name=\"LengthFactor\" />\n"
3361 " <Property name=\"LengthFactorInfo\" />\n"
3362 " </ExposedProperties>\n"
3363 " </SubProxy>\n"
3364 " <SubProxy>\n"
3365 " <Proxy name=\"Widget\"\n"
3366 " proxygroup=\"3d_widgets\"\n"
3367 " proxyname=\"CoordinateFrameWidget\"></Proxy>\n"
3368 " </SubProxy>\n"
3369 " </NewWidgetRepresentationProxy>\n"
3370 " <!-- ================================================================== -->\n"
3371 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3372 " name=\"DistanceWidgetRepresentation\">\n"
3373 " <IntVectorProperty command=\"SetEnabled\"\n"
3374 " default_values=\"0\"\n"
3375 " name=\"Enabled\"\n"
3376 " number_of_elements=\"1\">\n"
3377 " <BooleanDomain name=\"bool\" />\n"
3378 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3379 " </IntVectorProperty>\n"
3380 " <IntVectorProperty command=\"SetUseNonCompositedRenderer\"\n"
3381 " default_values=\"1\"\n"
3382 " name=\"UseNonCompositedRenderer\"\n"
3383 " number_of_elements=\"1\"></IntVectorProperty>\n"
3384 " <SubProxy>\n"
3385 " <Proxy name=\"Prop2D\"\n"
3386 " proxygroup=\"3d_widget_representations\"\n"
3387 " proxyname=\"DistanceRepresentation2D\"></Proxy>\n"
3388 " <ExposedProperties>\n"
3389 " <Property name=\"Visibility\" />\n"
3390 " <Property name=\"Point1WorldPositionInfo\" />\n"
3391 " <Property name=\"Point1WorldPosition\" />\n"
3392 " <Property name=\"Point2WorldPositionInfo\" />\n"
3393 " <Property name=\"Point2WorldPosition\" />\n"
3394 " <Property name=\"PlaceWidget\" />\n"
3395 " </ExposedProperties>\n"
3396 " </SubProxy>\n"
3397 " <SubProxy>\n"
3398 " <Proxy name=\"Widget\"\n"
3399 " proxygroup=\"3d_widgets\"\n"
3400 " proxyname=\"DistanceWidget\"></Proxy>\n"
3401 " <ExposedProperties>\n"
3402 " <Property name=\"ProcessEvents\" />\n"
3403 " </ExposedProperties>\n"
3404 " </SubProxy>\n"
3405 " </NewWidgetRepresentationProxy>\n"
3406 " <!-- ================================================================== -->\n"
3407 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3408 " name=\"BoxWidgetRepresentation\">\n"
3409 " <Documentation>Representation proxy for the box widget. This includes\n"
3410 " the widget/representation proxies for the box 3D widget.</Documentation>\n"
3411 " <IntVectorProperty command=\"SetEnabled\"\n"
3412 " default_values=\"0\"\n"
3413 " name=\"Enabled\"\n"
3414 " number_of_elements=\"1\">\n"
3415 " <BooleanDomain name=\"bool\" />\n"
3416 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3417 " </IntVectorProperty>\n"
3418 "\n"
3419 " <DoubleVectorProperty argument_is_array=\"1\"\n"
3420 " command=\"PlaceWidget\"\n"
3421 " default_values=\"none\"\n"
3422 " name=\"PlaceWidget\"\n"
3423 " number_of_elements=\"6\">\n"
3424 " <DoubleRangeDomain name=\"range\" />\n"
3425 " </DoubleVectorProperty>\n"
3426 "\n"
3427 " <DoubleVectorProperty argument_is_array=\"1\"\n"
3428 " command=\"SetReferenceBounds\"\n"
3429 " default_values=\"none\"\n"
3430 " name=\"ReferenceBounds\"\n"
3431 " number_of_elements=\"6\">\n"
3432 " <DoubleRangeDomain name=\"range\" />\n"
3433 " </DoubleVectorProperty>\n"
3434 "\n"
3435 " <IntVectorProperty name=\"UseReferenceBounds\"\n"
3436 " command=\"SetUseReferenceBounds\"\n"
3437 " number_of_elements=\"1\"\n"
3438 " default_values=\"0\">\n"
3439 " <BooleanDomain name=\"bool\" />\n"
3440 " </IntVectorProperty>\n"
3441 "\n"
3442 " <SubProxy>\n"
3443 " <Proxy name=\"Prop\"\n"
3444 " proxygroup=\"3d_widget_representations\"\n"
3445 " proxyname=\"BoxRepresentation\"></Proxy>\n"
3446 " <ExposedProperties>\n"
3447 " <Property name=\"PlaceFactor\" />\n"
3448 " <Property name=\"Visibility\" />\n"
3449 " <Property name=\"Position\" />\n"
3450 " <Property name=\"PositionInfo\" />\n"
3451 " <Property name=\"Rotation\" />\n"
3452 " <Property name=\"RotationInfo\" />\n"
3453 " <Property name=\"Scale\" />\n"
3454 " <Property name=\"ScaleInfo\" />\n"
3455 " <Property name=\"ForegroundWidgetColor\" />\n"
3456 " <Property name=\"InteractiveWidgetColor\" />\n"
3457 " </ExposedProperties>\n"
3458 " </SubProxy>\n"
3459 " <SubProxy>\n"
3460 " <Proxy name=\"Widget\"\n"
3461 " proxygroup=\"3d_widgets\"\n"
3462 " proxyname=\"BoxWidget2\"></Proxy>\n"
3463 ;
3464
3465 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
3467 " <ExposedProperties>\n"
3468 " <Property name=\"TranslationEnabled\" />\n"
3469 " <Property name=\"ScalingEnabled\" />\n"
3470 " <Property name=\"RotationEnabled\" />\n"
3471 " <Property name=\"MoveFacesEnabled\" />\n"
3472 " </ExposedProperties>\n"
3473 " </SubProxy>\n"
3474 " <!-- End of BoxWidgetRepresentation -->\n"
3475 " </NewWidgetRepresentationProxy>\n"
3476 " <!-- ================================================================== -->\n"
3477 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3478 " name=\"SphereWidgetRepresentation\">\n"
3479 " <Documentation>Representation proxy for the sphere widget. This\n"
3480 " includes the widget/representation proxies for the sphere 3D\n"
3481 " widget.</Documentation>\n"
3482 " <IntVectorProperty command=\"SetEnabled\"\n"
3483 " default_values=\"0\"\n"
3484 " name=\"Enabled\"\n"
3485 " number_of_elements=\"1\">\n"
3486 " <BooleanDomain name=\"bool\" />\n"
3487 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3488 " </IntVectorProperty>\n"
3489 " <SubProxy>\n"
3490 " <Proxy name=\"Prop\"\n"
3491 " proxygroup=\"3d_widget_representations\"\n"
3492 " proxyname=\"SphereRepresentation\"></Proxy>\n"
3493 " <ExposedProperties>\n"
3494 " <Property name=\"PlaceWidget\" />\n"
3495 " <Property name=\"Visibility\" />\n"
3496 " <Property name=\"Representation\" />\n"
3497 " <Property name=\"Center\" />\n"
3498 " <Property name=\"CenterInfo\" />\n"
3499 " <Property name=\"Radius\" />\n"
3500 " <Property name=\"RadiusInfo\" />\n"
3501 " <Property name=\"HandleVisibility\" />\n"
3502 " <Property name=\"RadialLine\" />\n"
3503 " <Property name=\"CenterCursor\" />\n"
3504 " <Property name=\"HandleDirection\" />\n"
3505 " <Property name=\"ForegroundWidgetColor\" />\n"
3506 " <Property name=\"InteractiveWidgetColor\" />\n"
3507 " <Property name=\"WidgetColor\" />\n"
3508 " </ExposedProperties>\n"
3509 " </SubProxy>\n"
3510 " <SubProxy>\n"
3511 " <Proxy name=\"Widget\"\n"
3512 " proxygroup=\"3d_widgets\"\n"
3513 " proxyname=\"SphereWidget2\"></Proxy>\n"
3514 " </SubProxy>\n"
3515 " <!-- End of SphereWidgetRepresentation -->\n"
3516 " </NewWidgetRepresentationProxy>\n"
3517 " <!-- ================================================================== -->\n"
3518 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3519 " name=\"ImplicitCylinderWidgetRepresentation\">\n"
3520 " <Documentation>Representation proxy for the sphere widget. This\n"
3521 " includes the widget/representation proxies for the sphere 3D\n"
3522 " widget.</Documentation>\n"
3523 " <IntVectorProperty command=\"SetEnabled\"\n"
3524 " default_values=\"0\"\n"
3525 " name=\"Enabled\"\n"
3526 " number_of_elements=\"1\">\n"
3527 " <BooleanDomain name=\"bool\" />\n"
3528 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3529 " </IntVectorProperty>\n"
3530 " <SubProxy>\n"
3531 " <Proxy name=\"Prop\"\n"
3532 " proxygroup=\"3d_widget_representations\"\n"
3533 " proxyname=\"ImplicitCylinderRepresentation\"></Proxy>\n"
3534 " <ExposedProperties>\n"
3535 " <Property name=\"Visibility\" />\n"
3536 " <Property name=\"ConstrainToWidgetBounds\" />\n"
3537 " <Property name=\"WidgetBounds\" />\n"
3538 " <Property name=\"PlaceFactor\" />\n"
3539 " <Property name=\"Center\" />\n"
3540 " <Property name=\"CenterInfo\" />\n"
3541 " <Property name=\"Axis\" />\n"
3542 " <Property name=\"AxisInfo\" />\n"
3543 " <Property name=\"Radius\" />\n"
3544 " <Property name=\"RadiusInfo\" />\n"
3545 " <Property name=\"DrawCylinder\" />\n"
3546 " <Property name=\"Tubing\" />\n"
3547 " <Property name=\"OutlineTranslation\" />\n"
3548 " <Property name=\"OutsideBounds\" />\n"
3549 " <Property name=\"ScaleEnabled\" />\n"
3550 " <Property name=\"ForegroundWidgetColor\" />\n"
3551 " <Property name=\"InteractiveWidgetColor\" />\n"
3552 " <Property name=\"WidgetColor\" />\n"
3553 " </ExposedProperties>\n"
3554 " </SubProxy>\n"
3555 " <SubProxy>\n"
3556 " <Proxy name=\"Widget\"\n"
3557 " proxygroup=\"3d_widgets\"\n"
3558 " proxyname=\"ImplicitCylinderWidget\"></Proxy>\n"
3559 " </SubProxy>\n"
3560 " <!-- End of SphereWidgetRepresentation -->\n"
3561 " </NewWidgetRepresentationProxy>\n"
3562 " <!-- ================================================================== -->\n"
3563 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3564 " name=\"SliderWidgetRepresentation\">\n"
3565 " <IntVectorProperty command=\"SetEnabled\"\n"
3566 " default_values=\"0\"\n"
3567 " name=\"Enabled\"\n"
3568 " number_of_elements=\"1\">\n"
3569 " <BooleanDomain name=\"bool\" />\n"
3570 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3571 " </IntVectorProperty>\n"
3572 " <SubProxy>\n"
3573 " <Proxy name=\"Prop\"\n"
3574 " proxygroup=\"3d_widget_representations\"\n"
3575 " proxyname=\"SliderRepresentation3D\"></Proxy>\n"
3576 " <ExposedProperties>\n"
3577 " <Property name=\"Visibility\" />\n"
3578 " <Property name=\"ValueInfo\" />\n"
3579 " <Property name=\"Value\" />\n"
3580 " <Property name=\"Point1\" />\n"
3581 " <Property name=\"Point2\" />\n"
3582 " <Property name=\"MinimumValue\" />\n"
3583 " <Property name=\"MaximumValue\" />\n"
3584 " </ExposedProperties>\n"
3585 " </SubProxy>\n"
3586 " <SubProxy>\n"
3587 " <Proxy name=\"Widget\"\n"
3588 " proxygroup=\"3d_widgets\"\n"
3589 " proxyname=\"SliderWidget\"></Proxy>\n"
3590 " </SubProxy>\n"
3591 " <!--- End of SliderWidgetRepresentation -->\n"
3592 " </NewWidgetRepresentationProxy>\n"
3593 " <!-- ================================================================== -->\n"
3594 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3595 " name=\"PolyLineWidgetRepresentation\">\n"
3596 " <Documentation>Representation proxy for the poly line widget. This\n"
3597 " includes the widget/representation proxies for the sphere 3D\n"
3598 " widget.</Documentation>\n"
3599 " <IntVectorProperty command=\"SetEnabled\"\n"
3600 " default_values=\"0\"\n"
3601 " name=\"Enabled\"\n"
3602 " number_of_elements=\"1\">\n"
3603 " <BooleanDomain name=\"bool\" />\n"
3604 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3605 " </IntVectorProperty>\n"
3606 " <SubProxy>\n"
3607 " <Proxy name=\"Prop\"\n"
3608 " proxygroup=\"3d_widget_representations\"\n"
3609 " proxyname=\"PolyLineRepresentation\"></Proxy>\n"
3610 " <ExposedProperties>\n"
3611 " <Property name=\"PlaceWidget\" />\n"
3612 " <Property name=\"Visibility\" />\n"
3613 " <Property name=\"HandlePositions\" />\n"
3614 " <Property name=\"HandlePositionsInfo\" />\n"
3615 " <Property name=\"Closed\" />\n"
3616 " <Property name=\"LineColor\" />\n"
3617 " <Property name=\"ForegroundWidgetColor\" />\n"
3618 " <Property name=\"InteractiveWidgetColor\" />\n"
3619 " <Property name=\"CurrentHandleIndex\" />\n"
3620 " <Property name=\"CurrentHandleIndexInfo\" />\n"
3621 " </ExposedProperties>\n"
3622 " </SubProxy>\n"
3623 " <SubProxy>\n"
3624 " <Proxy name=\"Widget\"\n"
3625 " proxygroup=\"3d_widgets\"\n"
3626 " proxyname=\"PolyLineWidget\"></Proxy>\n"
3627 " </SubProxy>\n"
3628 " <!-- End of PolyLineWidgetRepresentation -->\n"
3629 " </NewWidgetRepresentationProxy>\n"
3630 " <!-- ================================================================== -->\n"
3631 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3632 " name=\"SplineWidgetRepresentation\">\n"
3633 " <Documentation>Representation proxy for the spline widget. This\n"
3634 " includes the widget/representation proxies for the sphere 3D\n"
3635 " widget.</Documentation>\n"
3636 " <IntVectorProperty command=\"SetEnabled\"\n"
3637 " default_values=\"0\"\n"
3638 " name=\"Enabled\"\n"
3639 " number_of_elements=\"1\">\n"
3640 " <BooleanDomain name=\"bool\" />\n"
3641 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3642 " </IntVectorProperty>\n"
3643 " <SubProxy>\n"
3644 " <Proxy name=\"Prop\"\n"
3645 " proxygroup=\"3d_widget_representations\"\n"
3646 " proxyname=\"SplineRepresentation\"></Proxy>\n"
3647 " <ExposedProperties>\n"
3648 " <Property name=\"PlaceWidget\" />\n"
3649 " <Property name=\"Visibility\" />\n"
3650 " <Property name=\"Directional\"/>\n"
3651 " <Property name=\"HandlePositions\" />\n"
3652 " <Property name=\"HandlePositionsInfo\" />\n"
3653 " <Property name=\"Closed\" />\n"
3654 " <Property name=\"LineColor\" />\n"
3655 " <Property name=\"ForegroundWidgetColor\" />\n"
3656 " <Property name=\"InteractiveWidgetColor\" />\n"
3657 " <Property name=\"CurrentHandleIndex\" />\n"
3658 " <Property name=\"CurrentHandleIndexInfo\" />\n"
3659 " </ExposedProperties>\n"
3660 " </SubProxy>\n"
3661 " <SubProxy>\n"
3662 " <Proxy name=\"Widget\"\n"
3663 " proxygroup=\"3d_widgets\"\n"
3664 " proxyname=\"SplineWidget2\"></Proxy>\n"
3665 " </SubProxy>\n"
3666 " <!-- End of SplineWidgetRepresentation -->\n"
3667 " </NewWidgetRepresentationProxy>\n"
3668 " <!-- ================================================================== -->\n"
3669 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3670 " name=\"ContourWidgetRepresentation\">\n"
3671 " <Documentation>Representation proxy for the Contour widget. This\n"
3672 " includes the widget/representation proxies for the sphere 3D\n"
3673 " widget.</Documentation>\n"
3674 " <IntVectorProperty command=\"SetEnabled\"\n"
3675 " default_values=\"0\"\n"
3676 " name=\"Enabled\"\n"
3677 " number_of_elements=\"1\">\n"
3678 " <BooleanDomain name=\"bool\" />\n"
3679 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3680 " </IntVectorProperty>\n"
3681 " <SubProxy>\n"
3682 " <Proxy name=\"Prop\"\n"
3683 " proxygroup=\"3d_widget_representations\"\n"
3684 " proxyname=\"OrientedGlyphContourRepresentation\"></Proxy>\n"
3685 " <ExposedProperties>\n"
3686 " <Property name=\"PlaceWidget\" />\n"
3687 " <Property name=\"Visibility\" />\n"
3688 " <Property name=\"PointPlacer\" />\n"
3689 " <Property name=\"LineInterpolator\" />\n"
3690 " <Property name=\"ClearAllNodes\" />\n"
3691 " <Property name=\"LineColor\" />\n"
3692 " <Property name=\"AlwaysOnTop\" />\n"
3693 " <Property name=\"NodePositions\" />\n"
3694 " <Property name=\"ShowSelectedNodes\" />\n"
3695 " <Property name=\"SelectNodes\" />\n"
3696 " <Property name=\"ClosedLoop\" />\n"
3697 " </ExposedProperties>\n"
3698 " </SubProxy>\n"
3699 " <SubProxy>\n"
3700 " <Proxy name=\"Widget\"\n"
3701 " proxygroup=\"3d_widgets\"\n"
3702 " proxyname=\"ContourWidget\"></Proxy>\n"
3703 " <ExposedProperties>\n"
3704 " <Property name=\"CloseLoop\" />\n"
3705 " <Property name=\"WidgetState\" />\n"
3706 " <Property name=\"WidgetStateInfo\" />\n"
3707 " <Property name=\"AllowNodePicking\" />\n"
3708 " <Property name=\"Initialize\" />\n"
3709 " <Property name=\"ProcessEvents\" />\n"
3710 " </ExposedProperties>\n"
3711 " </SubProxy>\n"
3712 " <!-- End of ContourWidgetRepresentation -->\n"
3713 " </NewWidgetRepresentationProxy>\n"
3714 " <!-- ================================================================== -->\n"
3715 " <ScalarBarWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3716 " name=\"ScalarBarWidgetRepresentation\">\n"
3717 " <Documentation>ScalarBarWidgetRepresentation is a representation for a\n"
3718 " scalar bar including a widget to control the position and orientation of\n"
3719 " the scalar bar.</Documentation>\n"
3720 " <IntVectorProperty command=\"SetEnabled\"\n"
3721 " default_values=\"1\"\n"
3722 " name=\"Enabled\"\n"
3723 " number_of_elements=\"1\"\n"
3724 " panel_visibility=\"never\" >\n"
3725 " <BooleanDomain name=\"bool\" />\n"
3726 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3727 " </IntVectorProperty>\n"
3728 " <IntVectorProperty command=\"SetUseNonCompositedRenderer\"\n"
3729 " default_values=\"1\"\n"
3730 " name=\"UseNonCompositedRenderer\"\n"
3731 " number_of_elements=\"1\"\n"
3732 " panel_visibility=\"never\"></IntVectorProperty>\n"
3733 " <IntVectorProperty default_values=\"0\"\n"
3734 " name=\"LockPosition\"\n"
3735 " number_of_elements=\"1\"\n"
3736 " panel_visibility=\"never\">\n"
3737 " <BooleanDomain name=\"bool\" />\n"
3738 " <Documentation>\n"
3739 " Set this to 1 if you don't want the application to change the scalar bar position\n"
3740 " when placing automatically.\n"
3741 " </Documentation>\n"
3742 " </IntVectorProperty>\n"
3743 " <IntVectorProperty name=\"StickyVisible\"\n"
3744 " default_values=\"1\"\n"
3745 " panel_visibility=\"never\">\n"
3746 " <BooleanDomain name=\"bool\" />\n"
3747 " <Documentation>\n"
3748 " If the user manually toggles the scalar bar visibility, we keep that information\n"
3749 " in the scalar bar representation, and will never / always show it until the\n"
3750 " scalar bar button is toggled again on this array.\n"
3751 " </Documentation>\n"
3752 " </IntVectorProperty>\n"
3753 " <SubProxy>\n"
3754 " <Proxy name=\"Prop2D\"\n"
3755 " proxygroup=\"3d_widget_representations\"\n"
3756 " proxyname=\"ScalarBarRepresentation\"></Proxy>\n"
3757 " <ExposedProperties>\n"
3758 " <Property name=\"Visibility\" panel_visibility=\"never\"/>\n"
3759 " <PropertyGroup label=\"Layout\">\n"
3760 " <Property name=\"AutoOrient\" />\n"
3761 " <Property name=\"AutoOrientInfo\" />\n"
3762 " <Property name=\"Orientation\" />\n"
3763 " <Property name=\"OrientationInfo\" />\n"
3764 " <Property name=\"WindowLocation\" />\n"
3765 " <Property name=\"Position\" />\n"
3766 " <Property name=\"PositionInfo\" />\n"
3767 " </PropertyGroup>\n"
3768 " </ExposedProperties>\n"
3769 " </SubProxy>\n"
3770 " <SubProxy>\n"
3771 " <Proxy name=\"Prop2DActor\"\n"
3772 " proxygroup=\"annotations\"\n"
3773 " proxyname=\"ScalarBarActor\"></Proxy>\n"
3774 "\n"
3775 " <ExposedProperties>\n"
3776 " <Property name=\"EstimatedNumberOfAnnotations\" panel_visibility=\"never\"/>\n"
3777 " <Property name=\"LookupTable\" panel_visibility=\"never\"/>\n"
3778 " <PropertyGroup label=\"Title Texts\">\n"
3779 " <Property name=\"Title\" />\n"
3780 " <Property name=\"ComponentTitle\" />\n"
3781 " <Property name=\"TitleJustification\" />\n"
3782 " <Property name=\"HorizontalTitle\" />\n"
3783 " </PropertyGroup>\n"
3784 "\n"
3785 " <!-- properties for Title -->\n"
3786 " <PropertyGroup label=\"Title Font Properties\"\n"
3787 " panel_widget=\"FontEditor\">\n"
3788 " <Property name=\"TitleColor\" function=\"Color\"/>\n"
3789 " <Property name=\"TitleOpacity\" function=\"Opacity\"/>\n"
3790 " <Property name=\"TitleFontFamily\" function=\"Family\"/>\n"
3791 " <Property name=\"TitleFontFile\" function=\"File\"/>\n"
3792 ;
3793
3794 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
3796 " <Property name=\"TitleBold\" function=\"Bold\" />\n"
3797 " <Property name=\"TitleItalic\" function=\"Italics\"/>\n"
3798 " <Property name=\"TitleShadow\" function=\"Shadow\" />\n"
3799 " <Property name=\"TitleFontSize\" function=\"Size\"\n"
3800 " number_of_elements=\"1\" default_values=\"16\" />\n"
3801 " </PropertyGroup>\n"
3802 "\n"
3803 " <!-- properties for Label -->\n"
3804 "\n"
3805 " <PropertyGroup label=\"Text/Annotation Font Properties\"\n"
3806 " panel_widget=\"FontEditor\">\n"
3807 " <Property name=\"LabelColor\" function=\"Color\"/>\n"
3808 " <Property name=\"LabelOpacity\" function=\"Opacity\" />\n"
3809 " <Property name=\"LabelFontFamily\" function=\"Family\"/>\n"
3810 " <Property name=\"LabelFontFile\" function=\"File\"/>\n"
3811 " <Property name=\"LabelBold\" function=\"Bold\" />\n"
3812 " <Property name=\"LabelItalic\" function=\"Italics\" />\n"
3813 " <Property name=\"LabelShadow\" function=\"Shadow\" />\n"
3814 " <Property name=\"LabelFontSize\" function=\"Size\"\n"
3815 " number_of_elements=\"1\" default_values=\"16\"/>\n"
3816 " </PropertyGroup>\n"
3817 "\n"
3818 " <PropertyGroup label=\"Appearance\">\n"
3819 " <Property name=\"ScalarBarThickness\" />\n"
3820 " <Property name=\"ScalarBarLength\" />\n"
3821 " <Property name=\"DrawBackground\" panel_visibility=\"advanced\" />\n"
3822 " <Property name=\"BackgroundColor\" panel_visibility=\"advanced\" />\n"
3823 " <Property name=\"BackgroundPadding\" panel_visibility=\"advanced\" />\n"
3824 " <Property name=\"DrawScalarBarOutline\" panel_visibility=\"advanced\" />\n"
3825 " <Property name=\"ScalarBarOutlineColor\" panel_visibility=\"advanced\" />\n"
3826 " <Property name=\"ScalarBarOutlineThickness\" panel_visibility=\"advanced\" />\n"
3827 " </PropertyGroup>\n"
3828 "\n"
3829 " <PropertyGroup label=\"Labels\">\n"
3830 " <Property name=\"AutomaticLabelFormat\" panel_visibility=\"advanced\" />\n"
3831 " <Property name=\"LabelFormat\" panel_visibility=\"advanced\" />\n"
3832 " <Property name=\"DrawTickMarks\" panel_visibility=\"advanced\" />\n"
3833 " <Property name=\"DrawTickLabels\" panel_visibility=\"advanced\" />\n"
3834 " <Property name=\"UseCustomLabels\" panel_visibility=\"advanced\" />\n"
3835 " <Property name=\"CustomLabels\" panel_visibility=\"advanced\" />\n"
3836 " <Property name=\"AddRangeLabels\" panel_visibility=\"advanced\" />\n"
3837 " <Property name=\"DataRangeMin\" />\n"
3838 " <Property name=\"DataRangeMax\" />\n"
3839 " <Property name=\"RangeLabelFormat\" panel_visibility=\"advanced\" />\n"
3840 " </PropertyGroup>\n"
3841 "\n"
3842 " <PropertyGroup label=\"Visible Data Range\">\n"
3843 " <Property name=\"DrawDataRange\" />\n"
3844 " <Property name=\"DataRangeLabelFormat\" />\n"
3845 " </PropertyGroup>\n"
3846 "\n"
3847 " <PropertyGroup label=\"Annotations\">\n"
3848 " <Property name=\"DrawAnnotations\" />\n"
3849 " <Property name=\"AddRangeAnnotations\" panel_visibility=\"advanced\" />\n"
3850 " <Property name=\"AutomaticAnnotations\" panel_visibility=\"advanced\" />\n"
3851 " <Property name=\"DrawNanAnnotation\" panel_visibility=\"advanced\" />\n"
3852 " <Property name=\"NanAnnotation\" panel_visibility=\"advanced\" />\n"
3853 " <Property name=\"TextPosition\" />\n"
3854 " <Property name=\"ReverseLegend\" />\n"
3855 " </PropertyGroup>\n"
3856 " </ExposedProperties>\n"
3857 " </SubProxy>\n"
3858 " <SubProxy>\n"
3859 " <Proxy name=\"Widget\"\n"
3860 " proxygroup=\"3d_widgets\"\n"
3861 " proxyname=\"ScalarBarWidget\"></Proxy>\n"
3862 " <ExposedProperties>\n"
3863 " <Property name=\"Selectable\" panel_visibility=\"never\"/>\n"
3864 " <Property name=\"Resizable\" panel_visibility=\"never\"/>\n"
3865 " <Property name=\"Repositionable\" panel_visibility=\"never\"/>\n"
3866 " </ExposedProperties>\n"
3867 " </SubProxy>\n"
3868 " </ScalarBarWidgetRepresentationProxy>\n"
3869 " <!-- ================================================================== -->\n"
3870 " <TextWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3871 " name=\"TextWidgetRepresentation\">\n"
3872 " <Documentation>TextWidgetRepresentation is a representation for text\n"
3873 " widget as well as the representation for the text shown in the\n"
3874 " widget.</Documentation>\n"
3875 " <IntVectorProperty command=\"SetEnabled\"\n"
3876 " default_values=\"1\"\n"
3877 " name=\"Enabled\"\n"
3878 " number_of_elements=\"1\">\n"
3879 " <BooleanDomain name=\"bool\" />\n"
3880 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3881 " </IntVectorProperty>\n"
3882 " <IntVectorProperty command=\"SetUseNonCompositedRenderer\"\n"
3883 " default_values=\"1\"\n"
3884 " name=\"UseNonCompositedRenderer\"\n"
3885 " number_of_elements=\"1\"></IntVectorProperty>\n"
3886 " <SubProxy>\n"
3887 " <Proxy name=\"Prop2D\"\n"
3888 " proxygroup=\"3d_widget_representations\"\n"
3889 " proxyname=\"TextRepresentation\"></Proxy>\n"
3890 " <ExposedProperties>\n"
3891 " <Property name=\"Visibility\" />\n"
3892 " <Property name=\"Text\" />\n"
3893 " <Property name=\"Position\" />\n"
3894 " <Property name=\"Position2\" />\n"
3895 " <Property name=\"PositionInfo\" />\n"
3896 " <Property name=\"Position2Info\" />\n"
3897 " <Property name=\"WindowLocation\" />\n"
3898 " <Property name=\"TextActor\" />\n"
3899 " <Property name=\"ShowBorder\" />\n"
3900 " <Property name=\"BorderColor\" />\n"
3901 " <Property name=\"BorderThickness\" />\n"
3902 " <Property name=\"CornerRadius\" />\n"
3903 " <Property name=\"CornerResolution\" />\n"
3904 " <Property name=\"BackgroundColor\"/>\n"
3905 " <Property name=\"Padding\" />\n"
3906 " </ExposedProperties>\n"
3907 " </SubProxy>\n"
3908 " <SubProxy>\n"
3909 " <Proxy name=\"Prop2DActor\"\n"
3910 " proxygroup=\"props\"\n"
3911 " proxyname=\"TextActor\"></Proxy>\n"
3912 " <ExposedProperties>\n"
3913 " <Property name=\"TextScaleMode\" />\n"
3914 " <Property name=\"TextProperty\" />\n"
3915 " </ExposedProperties>\n"
3916 " </SubProxy>\n"
3917 " <SubProxy>\n"
3918 " <Proxy name=\"Prop2DProperty\"\n"
3919 " proxygroup=\"properties\"\n"
3920 " proxyname=\"TextPropertyCentered\"></Proxy>\n"
3921 " <ExposedProperties>\n"
3922 " <Property name=\"Justification\" />\n"
3923 " <Property name=\"VerticalJustification\" />\n"
3924 " <Property name=\"LineOffset\" />\n"
3925 " <Property name=\"LineSpacing\" />\n"
3926 " <Property name=\"CellOffset\" />\n"
3927 " <Property name=\"Orientation\" />\n"
3928 " <Property name=\"Color\" />\n"
3929 " <Property name=\"Opacity\" />\n"
3930 " <Property name=\"FontFamily\" />\n"
3931 " <Property name=\"FontFile\" />\n"
3932 " <Property name=\"Bold\" />\n"
3933 " <Property name=\"Italic\" />\n"
3934 " <Property name=\"Shadow\" />\n"
3935 " <Property name=\"FontSize\" />\n"
3936 " <Property name=\"BackgroundRGBA\"/>\n"
3937 " <Property name=\"InteriorLinesWidth\" />\n"
3938 " <Property name=\"InteriorLinesColor\" />\n"
3939 " <Property name=\"InteriorLinesVisibility\" />\n"
3940 " </ExposedProperties>\n"
3941 " </SubProxy>\n"
3942 " <SubProxy>\n"
3943 " <Proxy name=\"Widget\"\n"
3944 " proxygroup=\"3d_widgets\"\n"
3945 " proxyname=\"TextWidget\"></Proxy>\n"
3946 " <ExposedProperties>\n"
3947 " <Property name=\"ProcessEvents\" />\n"
3948 " <Property name=\"Selectable\" />\n"
3949 " <Property name=\"Resizable\" />\n"
3950 " </ExposedProperties>\n"
3951 " </SubProxy>\n"
3952 " <!-- End of TextWidgetRepresentation -->\n"
3953 " </TextWidgetRepresentationProxy>\n"
3954 " <!-- ================================================================== -->\n"
3955 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
3956 " name=\"ProgressBarWidgetRepresentation\">\n"
3957 " <Documentation>ProgressBarWidgetRepresentation is a representation for progress bar\n"
3958 " widget as well as the representation for the progress bar shown in the\n"
3959 " widget.</Documentation>\n"
3960 " <IntVectorProperty command=\"SetEnabled\"\n"
3961 " default_values=\"1\"\n"
3962 " name=\"Enabled\"\n"
3963 " number_of_elements=\"1\">\n"
3964 " <BooleanDomain name=\"bool\" />\n"
3965 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
3966 " </IntVectorProperty>\n"
3967 " <IntVectorProperty command=\"SetUseNonCompositedRenderer\"\n"
3968 " default_values=\"1\"\n"
3969 " name=\"UseNonCompositedRenderer\"\n"
3970 " number_of_elements=\"1\"></IntVectorProperty>\n"
3971 " <SubProxy>\n"
3972 " <Proxy name=\"Prop2D\"\n"
3973 " proxygroup=\"3d_widget_representations\"\n"
3974 " proxyname=\"ProgressBarRepresentation\"></Proxy>\n"
3975 " <ExposedProperties>\n"
3976 " <Property name=\"Visibility\" />\n"
3977 " <Property name=\"ProgressRate\" />\n"
3978 " <Property name=\"Position\" />\n"
3979 " <Property name=\"Position2\" />\n"
3980 " <Property name=\"PositionInfo\" />\n"
3981 " <Property name=\"Position2Info\" />\n"
3982 " <Property name=\"ProgressBarColor\"/>\n"
3983 " <Property name=\"SecondaryProgressBarColor\"/>\n"
3984 " <Property name=\"DrawBackground\"/>\n"
3985 " </ExposedProperties>\n"
3986 " </SubProxy>\n"
3987 " <SubProxy>\n"
3988 " <Proxy name=\"Widget\"\n"
3989 " proxygroup=\"3d_widgets\"\n"
3990 " proxyname=\"ProgressBarWidget\"></Proxy>\n"
3991 " <ExposedProperties>\n"
3992 " <Property name=\"ProcessEvents\" />\n"
3993 " <Property name=\"Selectable\" />\n"
3994 " <Property name=\"Resizable\" />\n"
3995 " </ExposedProperties>\n"
3996 " </SubProxy>\n"
3997 " <!-- End of ProgressBarWidgetRepresentation -->\n"
3998 " </NewWidgetRepresentationProxy>\n"
3999 " <!-- ================================================================== -->\n"
4000 " <NewWidgetRepresentationProxy class=\"vtk3DWidgetRepresentation\"\n"
4001 " name=\"LogoWidgetRepresentation\">\n"
4002 " <Documentation>LogoWidgetRepresentation is a representation for a logo widget\n"
4003 " </Documentation>\n"
4004 " <IntVectorProperty command=\"SetEnabled\"\n"
4005 " default_values=\"1\"\n"
4006 " name=\"Enabled\"\n"
4007 " number_of_elements=\"1\">\n"
4008 " <BooleanDomain name=\"bool\" />\n"
4009 " <Documentation>Enable/Disable widget interaction.</Documentation>\n"
4010 " </IntVectorProperty>\n"
4011 " <IntVectorProperty command=\"SetUseNonCompositedRenderer\"\n"
4012 " default_values=\"1\"\n"
4013 " name=\"UseNonCompositedRenderer\"\n"
4014 " number_of_elements=\"1\"></IntVectorProperty>\n"
4015 " <SubProxy>\n"
4016 " <Proxy name=\"Prop2D\"\n"
4017 " proxygroup=\"3d_widget_representations\"\n"
4018 " proxyname=\"LogoRepresentation\"></Proxy>\n"
4019 " <ExposedProperties>\n"
4020 " <Property name=\"Visibility\" />\n"
4021 " <Property name=\"ShowBorder\" />\n"
4022 " <Property name=\"BorderThickness\" />\n"
4023 " <Property name=\"BorderColor\" />\n"
4024 " <Property name=\"WindowLocation\" />\n"
4025 " <Property name=\"Position\" />\n"
4026 " <Property name=\"Position2\" />\n"
4027 " <Property name=\"PositionInfo\" />\n"
4028 " <Property name=\"Position2Info\" />\n"
4029 " </ExposedProperties>\n"
4030 " </SubProxy>\n"
4031 " <SubProxy>\n"
4032 " <Proxy name=\"Widget\"\n"
4033 " proxygroup=\"3d_widgets\"\n"
4034 " proxyname=\"LogoWidget\"></Proxy>\n"
4035 " <ExposedProperties>\n"
4036 " <Property name=\"ProcessEvents\" />\n"
4037 " <Property name=\"Selectable\" />\n"
4038 " <Property name=\"Resizable\" />\n"
4039 " </ExposedProperties>\n"
4040 " </SubProxy>\n"
4041 " <!-- End of LogoWidgetRepresentation -->\n"
4042 " </NewWidgetRepresentationProxy>\n"
4043 " </ProxyGroup>\n"
4044 " <!-- ****************************************************************** -->\n"
4045 " <ProxyGroup name=\"3d_widget_representations\">\n"
4046 " <!-- ================================================================== -->\n"
4047 " <Proxy class=\"vtkOrientedGlyphContourRepresentation\"\n"
4048 " name=\"OrientedGlyphContourRepresentation\">\n"
4049 " <Documentation>Proxy for vtkOrientedGlyphContourRepresentation. Don't use\n"
4050 " directly since it's not coupled with the widget. Use\n"
4051 " \"ContourWidgetRepresentation\" instead which include this representation\n"
4052 " as well as the widget to modify the representation.</Documentation>\n"
4053 " <IntVectorProperty animateable=\"1\"\n"
4054 " command=\"SetVisibility\"\n"
4055 " default_values=\"1\"\n"
4056 " name=\"Visibility\"\n"
4057 " number_of_elements=\"1\">\n"
4058 " <BooleanDomain name=\"bool\" />\n"
4059 " </IntVectorProperty>\n"
4060 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4061 " command=\"PlaceWidget\"\n"
4062 " default_values=\"none\"\n"
4063 " name=\"PlaceWidget\"\n"
4064 " number_of_elements=\"6\">\n"
4065 " <DoubleRangeDomain name=\"range\" />\n"
4066 " </DoubleVectorProperty>\n"
4067 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4068 " default_values=\"1.0\"\n"
4069 " name=\"PlaceFactor\"\n"
4070 " number_of_elements=\"1\">\n"
4071 " <DoubleRangeDomain min=\"0.01\"\n"
4072 " name=\"range\" />\n"
4073 " </DoubleVectorProperty>\n"
4074 " <IntVectorProperty command=\"SetClosedLoop\"\n"
4075 " default_values=\"0\"\n"
4076 " name=\"ClosedLoop\"\n"
4077 " number_of_elements=\"1\">\n"
4078 " <BooleanDomain name=\"bool\" />\n"
4079 " </IntVectorProperty>\n"
4080 " <IntVectorProperty command=\"GetClosedLoop\"\n"
4081 " default_values=\"0\"\n"
4082 " information_only=\"1\"\n"
4083 " name=\"ClosedLoopInfo\"\n"
4084 " number_of_elements=\"1\">\n"
4085 " <SimpleIntInformationHelper />\n"
4086 " </IntVectorProperty>\n"
4087 " <ProxyProperty command=\"SetPointPlacer\"\n"
4088 " name=\"PointPlacer\">\n"
4089 " <ProxyGroupDomain name=\"groups\">\n"
4090 " <Group name=\"point_placers\" />\n"
4091 " </ProxyGroupDomain>\n"
4092 " </ProxyProperty>\n"
4093 " <ProxyProperty command=\"SetLineInterpolator\"\n"
4094 " name=\"LineInterpolator\">\n"
4095 " <ProxyGroupDomain name=\"groups\">\n"
4096 " <Group name=\"contour_line_interpolators\" />\n"
4097 " </ProxyGroupDomain>\n"
4098 " </ProxyProperty>\n"
4099 " <DoubleVectorProperty command=\"AddNodeAtWorldPosition\"\n"
4100 " name=\"NodePositions\"\n"
4101 " number_of_elements_per_command=\"3\"\n"
4102 " repeat_command=\"1\"></DoubleVectorProperty>\n"
4103 " <IntVectorProperty command=\"SetNthNodeSelected\"\n"
4104 " name=\"SelectNodes\"\n"
4105 " number_of_elements_per_command=\"1\"\n"
4106 " repeat_command=\"1\"></IntVectorProperty>\n"
4107 " <IntVectorProperty command=\"SetShowSelectedNodes\"\n"
4108 " default_values=\"1\"\n"
4109 ;
4110
4111 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
4113 " name=\"ShowSelectedNodes\"\n"
4114 " number_of_elements=\"1\">\n"
4115 " <BooleanDomain name=\"bool\" />\n"
4116 " </IntVectorProperty>\n"
4117 " <Property command=\"ClearAllNodes\"\n"
4118 " name=\"ClearAllNodes\" />\n"
4119 " <DoubleVectorProperty command=\"SetLineColor\"\n"
4120 " default_values=\"1.0 1.0 1.0\"\n"
4121 " name=\"LineColor\"\n"
4122 " number_of_elements=\"3\">\n"
4123 " <DoubleRangeDomain max=\"1 1 1\"\n"
4124 " min=\"0 0 0\"\n"
4125 " name=\"range\" />\n"
4126 " </DoubleVectorProperty>\n"
4127 " <IntVectorProperty command=\"SetAlwaysOnTop\"\n"
4128 " default_values=\"0\"\n"
4129 " name=\"AlwaysOnTop\"\n"
4130 " number_of_elements=\"1\">\n"
4131 " <BooleanDomain name=\"bool\" />\n"
4132 " </IntVectorProperty>\n"
4133 " <Hints>\n"
4134 " <!-- View can be used to specify the way to get the poly data for the representation -->\n"
4135 " <Output />\n"
4136 " </Hints>\n"
4137 " <!-- End of OrientedGlyphContourRepresentation -->\n"
4138 " </Proxy>\n"
4139 " <!-- ================================================================== -->\n"
4140 " <Proxy class=\"vtkSplineRepresentation\"\n"
4141 " name=\"SplineRepresentation\">\n"
4142 " <Documentation>Proxy for vtkSplineRepresentation. Don't use directly\n"
4143 " since it's not coupled with the widget. Use \"SplineWidgetRepresentation\"\n"
4144 " instead which include this representation as well as the widget to modify\n"
4145 " the representation.</Documentation>\n"
4146 " <IntVectorProperty animateable=\"1\"\n"
4147 " command=\"SetVisibility\"\n"
4148 " default_values=\"1\"\n"
4149 " name=\"Visibility\"\n"
4150 " number_of_elements=\"1\">\n"
4151 " <BooleanDomain name=\"bool\" />\n"
4152 " </IntVectorProperty>\n"
4153 " <IntVectorProperty command=\"SetDirectional\"\n"
4154 " default_values=\"1\"\n"
4155 " name=\"Directional\"\n"
4156 " number_of_elements=\"1\">\n"
4157 " <BooleanDomain name=\"bool\" />\n"
4158 " </IntVectorProperty>\n"
4159 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4160 " command=\"PlaceWidget\"\n"
4161 " default_values=\"none\"\n"
4162 " name=\"PlaceWidget\"\n"
4163 " number_of_elements=\"6\">\n"
4164 " <DoubleRangeDomain name=\"range\" />\n"
4165 " </DoubleVectorProperty>\n"
4166 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4167 " default_values=\"1.0\"\n"
4168 " name=\"PlaceFactor\"\n"
4169 " number_of_elements=\"1\">\n"
4170 " <DoubleRangeDomain min=\"0.01\"\n"
4171 " name=\"range\" />\n"
4172 " </DoubleVectorProperty>\n"
4173 " <DoubleVectorProperty command=\"SetHandlePosition\"\n"
4174 " default_values=\"0 0 0 1 0 0\"\n"
4175 " information_property=\"HandlePositionsInfo\"\n"
4176 " name=\"HandlePositions\"\n"
4177 " number_of_elements=\"6\"\n"
4178 " number_of_elements_per_command=\"3\"\n"
4179 " repeat_command=\"1\"\n"
4180 " set_number_command=\"SetNumberOfHandles\"\n"
4181 " use_index=\"1\"></DoubleVectorProperty>\n"
4182 " <DoubleVectorProperty command=\"GetHandlePositions\"\n"
4183 " information_only=\"1\"\n"
4184 " name=\"HandlePositionsInfo\">\n"
4185 " <DoubleArrayInformationHelper />\n"
4186 " </DoubleVectorProperty>\n"
4187 " <IntVectorProperty command=\"SetClosed\"\n"
4188 " default_values=\"0\"\n"
4189 " name=\"Closed\"\n"
4190 " number_of_elements=\"1\">\n"
4191 " <BooleanDomain name=\"bool\" />\n"
4192 " </IntVectorProperty>\n"
4193 " <DoubleVectorProperty command=\"SetLineColor\"\n"
4194 " default_values=\"1.0 1.0 0.0\"\n"
4195 " name=\"LineColor\"\n"
4196 " number_of_elements=\"3\">\n"
4197 " <DoubleRangeDomain max=\"1 1 1\"\n"
4198 " min=\"0 0 0\"\n"
4199 " name=\"range\" />\n"
4200 " </DoubleVectorProperty>\n"
4201 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
4202 " name=\"ForegroundWidgetColor\"\n"
4203 " command=\"SetForegroundColor\"\n"
4204 " number_of_elements=\"3\"\n"
4205 " panel_widget=\"color_selector\">\n"
4206 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4207 " <Documentation>Color used when coloring the widget</Documentation>\n"
4208 " <Hints>\n"
4209 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
4210 " unlink_if_modified=\"1\" />\n"
4211 " </Hints>\n"
4212 " </DoubleVectorProperty>\n"
4213 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
4214 " name=\"InteractiveWidgetColor\"\n"
4215 " command=\"SetInteractionColor\"\n"
4216 " number_of_elements=\"3\"\n"
4217 " panel_widget=\"color_selector\">\n"
4218 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4219 " <Documentation>Color used for interacting widget handles</Documentation>\n"
4220 " <Hints>\n"
4221 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
4222 " unlink_if_modified=\"1\" />\n"
4223 " </Hints>\n"
4224 " </DoubleVectorProperty>\n"
4225 " <IntVectorProperty name=\"CurrentHandleIndexInfo\"\n"
4226 " command=\"GetCurrentHandleIndex\"\n"
4227 " information_only=\"1\"/>\n"
4228 " <IntVectorProperty name=\"CurrentHandleIndex\"\n"
4229 " number_of_elements=\"1\"\n"
4230 " default_values=\"-1\"\n"
4231 " command=\"SetCurrentHandleIndex\"\n"
4232 " information_property=\"CurrentHandleIndexInfo\"\n"
4233 " panel_visibility=\"never\">\n"
4234 " </IntVectorProperty>\n"
4235 " <!-- End of SplineRepresentation -->\n"
4236 " </Proxy>\n"
4237 " <!-- ================================================================== -->\n"
4238 " <Proxy class=\"vtkPolyLineRepresentation\"\n"
4239 " name=\"PolyLineRepresentation\">\n"
4240 " <Documentation>Representation for poly line source.</Documentation>\n"
4241 " <IntVectorProperty animateable=\"1\"\n"
4242 " command=\"SetVisibility\"\n"
4243 " default_values=\"1\"\n"
4244 " name=\"Visibility\"\n"
4245 " number_of_elements=\"1\">\n"
4246 " <BooleanDomain name=\"bool\" />\n"
4247 " </IntVectorProperty>\n"
4248 " <IntVectorProperty command=\"SetDirectional\"\n"
4249 " default_values=\"1\"\n"
4250 " name=\"Directional\"\n"
4251 " number_of_elements=\"1\">\n"
4252 " <BooleanDomain name=\"bool\" />\n"
4253 " </IntVectorProperty>\n"
4254 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4255 " command=\"PlaceWidget\"\n"
4256 " default_values=\"none\"\n"
4257 " name=\"PlaceWidget\"\n"
4258 " number_of_elements=\"6\">\n"
4259 " <DoubleRangeDomain name=\"range\" />\n"
4260 " </DoubleVectorProperty>\n"
4261 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4262 " default_values=\"1.0\"\n"
4263 " name=\"PlaceFactor\"\n"
4264 " number_of_elements=\"1\">\n"
4265 " <DoubleRangeDomain min=\"0.01\"\n"
4266 " name=\"range\" />\n"
4267 " </DoubleVectorProperty>\n"
4268 " <DoubleVectorProperty command=\"SetHandlePosition\"\n"
4269 " default_values=\"0 0 0 1 0 0\"\n"
4270 " information_property=\"HandlePositionsInfo\"\n"
4271 " name=\"HandlePositions\"\n"
4272 " number_of_elements=\"6\"\n"
4273 " number_of_elements_per_command=\"3\"\n"
4274 " repeat_command=\"1\"\n"
4275 " set_number_command=\"SetNumberOfHandles\"\n"
4276 " use_index=\"1\"></DoubleVectorProperty>\n"
4277 " <DoubleVectorProperty command=\"GetHandlePositions\"\n"
4278 " information_only=\"1\"\n"
4279 " name=\"HandlePositionsInfo\">\n"
4280 " <DoubleArrayInformationHelper />\n"
4281 " </DoubleVectorProperty>\n"
4282 " <IntVectorProperty command=\"SetClosed\"\n"
4283 " default_values=\"0\"\n"
4284 " name=\"Closed\"\n"
4285 " number_of_elements=\"1\">\n"
4286 " <BooleanDomain name=\"bool\" />\n"
4287 " </IntVectorProperty>\n"
4288 " <DoubleVectorProperty command=\"SetLineColor\"\n"
4289 " default_values=\"1.0 1.0 0.0\"\n"
4290 " name=\"LineColor\"\n"
4291 " number_of_elements=\"3\">\n"
4292 " <DoubleRangeDomain max=\"1 1 1\"\n"
4293 " min=\"0 0 0\"\n"
4294 " name=\"range\" />\n"
4295 " </DoubleVectorProperty>\n"
4296 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
4297 " name=\"ForegroundWidgetColor\"\n"
4298 " command=\"SetForegroundColor\"\n"
4299 " number_of_elements=\"3\"\n"
4300 " panel_widget=\"color_selector\">\n"
4301 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4302 " <Documentation>Color used when coloring the widget</Documentation>\n"
4303 " <Hints>\n"
4304 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
4305 " unlink_if_modified=\"1\" />\n"
4306 " </Hints>\n"
4307 " </DoubleVectorProperty>\n"
4308 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
4309 " name=\"InteractiveWidgetColor\"\n"
4310 " command=\"SetInteractionColor\"\n"
4311 " number_of_elements=\"3\"\n"
4312 " panel_widget=\"color_selector\">\n"
4313 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4314 " <Documentation>Color used for interacting widget handles</Documentation>\n"
4315 " <Hints>\n"
4316 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
4317 " unlink_if_modified=\"1\" />\n"
4318 " </Hints>\n"
4319 " </DoubleVectorProperty>\n"
4320 " <IntVectorProperty name=\"CurrentHandleIndexInfo\"\n"
4321 " command=\"GetCurrentHandleIndex\"\n"
4322 " information_only=\"1\"/>\n"
4323 " <IntVectorProperty name=\"CurrentHandleIndex\"\n"
4324 " number_of_elements=\"1\"\n"
4325 " default_values=\"-1\"\n"
4326 " command=\"SetCurrentHandleIndex\"\n"
4327 " information_property=\"CurrentHandleIndexInfo\"\n"
4328 " panel_visibility=\"never\">\n"
4329 " </IntVectorProperty>\n"
4330 " </Proxy>\n"
4331 " <!-- ================================================================== -->\n"
4332 " <Proxy class=\"vtkSliderRepresentation3D\"\n"
4333 " name=\"SliderRepresentation3D\">\n"
4334 " <IntVectorProperty animateable=\"1\"\n"
4335 " command=\"SetVisibility\"\n"
4336 " default_values=\"1\"\n"
4337 " name=\"Visibility\"\n"
4338 " number_of_elements=\"1\">\n"
4339 " <BooleanDomain name=\"bool\" />\n"
4340 " </IntVectorProperty>\n"
4341 " <DoubleVectorProperty command=\"SetValue\"\n"
4342 " default_values=\"0\"\n"
4343 " information_property=\"ValueInfo\"\n"
4344 " name=\"Value\"\n"
4345 " number_of_elements=\"1\">\n"
4346 " <DoubleRangeDomain name=\"range\" />\n"
4347 " </DoubleVectorProperty>\n"
4348 " <DoubleVectorProperty command=\"GetValue\"\n"
4349 " information_only=\"1\"\n"
4350 " name=\"ValueInfo\">\n"
4351 " <SimpleDoubleInformationHelper />\n"
4352 " </DoubleVectorProperty>\n"
4353 " <DoubleVectorProperty command=\"SetPoint1InWorldCoordinates\"\n"
4354 " default_values=\"-1.0 0.0 0.0\"\n"
4355 " name=\"Point1\"\n"
4356 " number_of_elements=\"3\">\n"
4357 " <DoubleRangeDomain name=\"range\" />\n"
4358 " </DoubleVectorProperty>\n"
4359 " <DoubleVectorProperty command=\"SetPoint2InWorldCoordinates\"\n"
4360 " default_values=\"1.0 0.0 0.0\"\n"
4361 " name=\"Point2\"\n"
4362 " number_of_elements=\"3\">\n"
4363 " <DoubleRangeDomain name=\"range\" />\n"
4364 " </DoubleVectorProperty>\n"
4365 " <DoubleVectorProperty command=\"SetMinimumValue\"\n"
4366 " default_values=\"0\"\n"
4367 " name=\"MinimumValue\"\n"
4368 " number_of_elements=\"1\">\n"
4369 " <DoubleRangeDomain name=\"range\" />\n"
4370 " </DoubleVectorProperty>\n"
4371 " <DoubleVectorProperty command=\"SetMaximumValue\"\n"
4372 " default_values=\"1\"\n"
4373 " name=\"MaximumValue\"\n"
4374 " number_of_elements=\"1\">\n"
4375 " <DoubleRangeDomain name=\"range\" />\n"
4376 " </DoubleVectorProperty>\n"
4377 " </Proxy>\n"
4378 " <!-- ================================================================== -->\n"
4379 " <Proxy class=\"vtkSphereRepresentation\"\n"
4380 " name=\"SphereRepresentation\">\n"
4381 " <Documentation>Proxy for vtkSphereRepresentation. Don't confuse this with\n"
4382 " the vtkSMRepresentation proxy for the sphere widget (which is the\n"
4383 " SphereWidgetRepresentation).</Documentation>\n"
4384 " <IntVectorProperty animateable=\"1\"\n"
4385 " command=\"SetVisibility\"\n"
4386 " default_values=\"1\"\n"
4387 " name=\"Visibility\"\n"
4388 " number_of_elements=\"1\">\n"
4389 " <BooleanDomain name=\"bool\" />\n"
4390 " </IntVectorProperty>\n"
4391 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4392 " command=\"PlaceWidget\"\n"
4393 " default_values=\"none\"\n"
4394 " name=\"PlaceWidget\"\n"
4395 " number_of_elements=\"6\">\n"
4396 " <DoubleRangeDomain name=\"range\" />\n"
4397 " </DoubleVectorProperty>\n"
4398 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4399 " default_values=\"1.0\"\n"
4400 " name=\"PlaceFactor\"\n"
4401 " number_of_elements=\"1\">\n"
4402 " <DoubleRangeDomain min=\"0.01\"\n"
4403 " name=\"range\" />\n"
4404 " </DoubleVectorProperty>\n"
4405 " <IntVectorProperty command=\"SetRepresentation\"\n"
4406 " default_values=\"1\"\n"
4407 " name=\"Representation\"\n"
4408 " number_of_elements=\"1\">\n"
4409 " <Documentation>Set the representation (i.e., appearance) of the sphere.\n"
4410 " Different representations are useful depending on the\n"
4411 " application.</Documentation>\n"
4412 " <EnumerationDomain name=\"enum\">\n"
4413 " <Entry text=\"Off\"\n"
4414 " value=\"0\" />\n"
4415 " <Entry text=\"Wireframe\"\n"
4416 " value=\"1\" />\n"
4417 " <Entry text=\"Surface\"\n"
4418 " value=\"2\" />\n"
4419 " </EnumerationDomain>\n"
4420 " </IntVectorProperty>\n"
4421 " <DoubleVectorProperty command=\"SetCenter\"\n"
4422 ;
4423
4424 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
4426 " default_values=\"0.0 0.0 0.0\"\n"
4427 " information_property=\"CenterInfo\"\n"
4428 " name=\"Center\"\n"
4429 " number_of_elements=\"3\">\n"
4430 " <DoubleRangeDomain name=\"range\" />\n"
4431 " <Documentation>The center position of the sphere. Note that this may\n"
4432 " adjust the direction from the handle to the center, as well as the\n"
4433 " radius of the sphere.</Documentation>\n"
4434 " </DoubleVectorProperty>\n"
4435 " <DoubleVectorProperty command=\"GetCenter\"\n"
4436 " information_only=\"1\"\n"
4437 " name=\"CenterInfo\">\n"
4438 " <SimpleDoubleInformationHelper />\n"
4439 " </DoubleVectorProperty>\n"
4440 " <DoubleVectorProperty command=\"SetRadius\"\n"
4441 " default_values=\"0.5\"\n"
4442 " information_property=\"RadiusInfo\"\n"
4443 " name=\"Radius\"\n"
4444 " number_of_elements=\"1\">\n"
4445 " <DoubleRangeDomain min=\"0.0\"\n"
4446 " name=\"range\" />\n"
4447 " <Documentation>The radius of sphere. Default is 0.5. Note that this may\n"
4448 " modify the position of the handle based on the handle\n"
4449 " direction.</Documentation>\n"
4450 " </DoubleVectorProperty>\n"
4451 " <DoubleVectorProperty command=\"GetRadius\"\n"
4452 " information_only=\"1\"\n"
4453 " name=\"RadiusInfo\">\n"
4454 " <SimpleDoubleInformationHelper />\n"
4455 " </DoubleVectorProperty>\n"
4456 " <IntVectorProperty command=\"SetHandleVisibility\"\n"
4457 " default_values=\"0\"\n"
4458 " name=\"HandleVisibility\"\n"
4459 " number_of_elements=\"1\">\n"
4460 " <BooleanDomain name=\"bool\" />\n"
4461 " <Documentation>The handle sits on the surface of the sphere and may be\n"
4462 " moved around the surface by picking (left mouse) and then moving. The\n"
4463 " position of the handle can be retrieved, this is useful for positioning\n"
4464 " cameras and lights. By default, the handle is turned\n"
4465 " off.</Documentation>\n"
4466 " </IntVectorProperty>\n"
4467 " <IntVectorProperty command=\"SetHandleText\"\n"
4468 " default_values=\"0\"\n"
4469 " name=\"HandleText\"\n"
4470 " number_of_elements=\"1\">\n"
4471 " <BooleanDomain name=\"bool\" />\n"
4472 " <Documentation>Enable/disable a label that displays the location of the\n"
4473 " handle in spherical coordinates (radius,theta,phi). The two angles,\n"
4474 " theta and phi, are displayed in degrees. Note that phi is measured from\n"
4475 " the north pole down towards the equator; and theta is the angle around\n"
4476 " the north/south axis.</Documentation>\n"
4477 " </IntVectorProperty>\n"
4478 " <IntVectorProperty command=\"SetRadialLine\"\n"
4479 " default_values=\"0\"\n"
4480 " name=\"RadialLine\"\n"
4481 " number_of_elements=\"1\">\n"
4482 " <BooleanDomain name=\"bool\" />\n"
4483 " <Documentation>Enable/disable a radial line segment that joins the\n"
4484 " center of the outer sphere and the handle.</Documentation>\n"
4485 " </IntVectorProperty>\n"
4486 " <IntVectorProperty command=\"SetCenterCursor\"\n"
4487 " default_values=\"1\"\n"
4488 " name=\"CenterCursor\"\n"
4489 " number_of_elements=\"1\">\n"
4490 " <BooleanDomain name=\"bool\" />\n"
4491 " <Documentation>Enable/disable a cursor that is shown at the\n"
4492 " center of the sphere.</Documentation>\n"
4493 " </IntVectorProperty>\n"
4494 " <DoubleVectorProperty default_values=\"0 0 1\"\n"
4495 " name=\"HandleDirection\"\n"
4496 " number_of_elements=\"3\">\n"
4497 " <Documentation>Set/Get the direction vector of the handle relative to\n"
4498 " the center of the sphere. This may affect the position of the handle\n"
4499 " and the radius of the sphere.</Documentation>\n"
4500 " </DoubleVectorProperty>\n"
4501 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
4502 " name=\"ForegroundWidgetColor\"\n"
4503 " command=\"SetForegroundColor\"\n"
4504 " number_of_elements=\"3\"\n"
4505 " panel_widget=\"color_selector\">\n"
4506 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4507 " <Documentation>Color used when coloring the outline</Documentation>\n"
4508 " <Hints>\n"
4509 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
4510 " unlink_if_modified=\"1\" />\n"
4511 " </Hints>\n"
4512 " </DoubleVectorProperty>\n"
4513 " <DoubleVectorProperty default_values=\"1.0 0.0 0.0\"\n"
4514 " name=\"WidgetColor\"\n"
4515 " command=\"SetHandleColor\"\n"
4516 " number_of_elements=\"3\"\n"
4517 " panel_widget=\"color_selector\">\n"
4518 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4519 " <Documentation>Color used for widget handles</Documentation>\n"
4520 " <Hints>\n"
4521 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"WidgetColor\"\n"
4522 " unlink_if_modified=\"1\" />\n"
4523 " </Hints>\n"
4524 " </DoubleVectorProperty>\n"
4525 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
4526 " name=\"InteractiveWidgetColor\"\n"
4527 " command=\"SetInteractionColor\"\n"
4528 " number_of_elements=\"3\"\n"
4529 " panel_widget=\"color_selector\">\n"
4530 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4531 " <Documentation>Color used for interacting widget handles</Documentation>\n"
4532 " <Hints>\n"
4533 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
4534 " unlink_if_modified=\"1\" />\n"
4535 " </Hints>\n"
4536 " </DoubleVectorProperty>\n"
4537 " <!-- End of SphereRepresentation -->\n"
4538 " </Proxy>\n"
4539 " <!-- ================================================================== -->\n"
4540 " <BoxRepresentationProxy class=\"vtkBoxRepresentation\"\n"
4541 " name=\"BoxRepresentation\">\n"
4542 " <Documentation>Proxy for vtkBoxRepresentation. Don't confuse this with\n"
4543 " the vtkSMRepresentation proxy for the box widget (which is the\n"
4544 " BoxWidgetRepresentation).</Documentation>\n"
4545 " <IntVectorProperty animateable=\"1\"\n"
4546 " command=\"SetVisibility\"\n"
4547 " default_values=\"1\"\n"
4548 " name=\"Visibility\"\n"
4549 " number_of_elements=\"1\">\n"
4550 " <BooleanDomain name=\"bool\" />\n"
4551 " </IntVectorProperty>\n"
4552 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4553 " default_values=\"1.0\"\n"
4554 " name=\"PlaceFactor\"\n"
4555 " number_of_elements=\"1\">\n"
4556 " <DoubleRangeDomain min=\"0.01\"\n"
4557 " name=\"range\" />\n"
4558 " </DoubleVectorProperty>\n"
4559 " <SubProxy>\n"
4560 " <Proxy name=\"Transform\"\n"
4561 " proxygroup=\"extended_sources\"\n"
4562 " proxyname=\"Transform2\"></Proxy>\n"
4563 " <ExposedProperties>\n"
4564 " <Property name=\"Position\" />\n"
4565 " <Property name=\"PositionInfo\" />\n"
4566 " <Property name=\"Rotation\" />\n"
4567 " <Property name=\"RotationInfo\" />\n"
4568 " <Property name=\"Scale\" />\n"
4569 " <Property name=\"ScaleInfo\" />\n"
4570 " </ExposedProperties>\n"
4571 " </SubProxy>\n"
4572 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
4573 " name=\"ForegroundWidgetColor\"\n"
4574 " command=\"SetForegroundColor\"\n"
4575 " number_of_elements=\"3\"\n"
4576 " panel_widget=\"color_selector\">\n"
4577 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4578 " <Documentation>Color used when coloring the outline</Documentation>\n"
4579 " <Hints>\n"
4580 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
4581 " unlink_if_modified=\"1\" />\n"
4582 " </Hints>\n"
4583 " </DoubleVectorProperty>\n"
4584 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
4585 " name=\"InteractiveWidgetColor\"\n"
4586 " command=\"SetInteractionColor\"\n"
4587 " number_of_elements=\"3\"\n"
4588 " panel_widget=\"color_selector\">\n"
4589 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4590 " <Documentation>Color used when coloring interactive handles and outline</Documentation>\n"
4591 " <Hints>\n"
4592 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
4593 " unlink_if_modified=\"1\" />\n"
4594 " </Hints>\n"
4595 " </DoubleVectorProperty>\n"
4596 " <!-- End of BoxRepresentation -->\n"
4597 " </BoxRepresentationProxy>\n"
4598 " <!-- ================================================================== -->\n"
4599 " <Proxy class=\"vtkPVImplicitCylinderRepresentation\"\n"
4600 " name=\"ImplicitCylinderRepresentation\">\n"
4601 " <Documentation>Proxy for vtkImplicitCylinderWidget. Don't confuse this with\n"
4602 " the vtkSMRepresentation proxy for the cylinder widget (which is the\n"
4603 " ImplicitCylinderWidget).</Documentation>\n"
4604 " <IntVectorProperty animateable=\"1\"\n"
4605 " command=\"SetVisibility\"\n"
4606 " default_values=\"1\"\n"
4607 " name=\"Visibility\"\n"
4608 " number_of_elements=\"1\">\n"
4609 " <BooleanDomain name=\"bool\" />\n"
4610 " </IntVectorProperty>\n"
4611 " <IntVectorProperty command=\"SetConstrainToWidgetBounds\"\n"
4612 " default_values=\"0\"\n"
4613 " name=\"ConstrainToWidgetBounds\"\n"
4614 " number_of_elements=\"1\">\n"
4615 " <BooleanDomain name=\"bool\" />\n"
4616 " </IntVectorProperty>\n"
4617 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4618 " command=\"SetWidgetBounds\"\n"
4619 " default_values=\"none\"\n"
4620 " name=\"WidgetBounds\"\n"
4621 " number_of_elements=\"6\">\n"
4622 " <DoubleRangeDomain name=\"range\" />\n"
4623 " </DoubleVectorProperty>\n"
4624 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4625 " default_values=\"1.2\"\n"
4626 " name=\"PlaceFactor\"\n"
4627 " number_of_elements=\"1\">\n"
4628 " <DoubleRangeDomain min=\"0.01\"\n"
4629 " name=\"range\" />\n"
4630 " </DoubleVectorProperty>\n"
4631 " <DoubleVectorProperty command=\"SetCenter\"\n"
4632 " default_values=\"0.0 0.0 0.0\"\n"
4633 " information_property=\"CenterInfo\"\n"
4634 " name=\"Center\"\n"
4635 " number_of_elements=\"3\">\n"
4636 " <DoubleRangeDomain name=\"range\" />\n"
4637 " <Documentation>The center of the cylinder. The center is located along the\n"
4638 " cylinder axis.</Documentation>\n"
4639 " </DoubleVectorProperty>\n"
4640 " <DoubleVectorProperty command=\"GetCenter\"\n"
4641 " information_only=\"1\"\n"
4642 " name=\"CenterInfo\">\n"
4643 " <SimpleDoubleInformationHelper />\n"
4644 " </DoubleVectorProperty>\n"
4645 " <DoubleVectorProperty command=\"SetAxis\"\n"
4646 " default_values=\"0.0 0.0 1.0\"\n"
4647 " information_property=\"AxisInfo\"\n"
4648 " name=\"Axis\"\n"
4649 " number_of_elements=\"3\">\n"
4650 " <DoubleRangeDomain name=\"range\" />\n"
4651 " <Documentation>The axis of rotation for the cylinder. If the axis is not\n"
4652 " specified as a unit vector, it will be normalized.</Documentation>\n"
4653 " </DoubleVectorProperty>\n"
4654 " <DoubleVectorProperty command=\"GetAxis\"\n"
4655 " information_only=\"1\"\n"
4656 " name=\"AxisInfo\">\n"
4657 " <SimpleDoubleInformationHelper />\n"
4658 " </DoubleVectorProperty>\n"
4659 " <DoubleVectorProperty command=\"SetRadius\"\n"
4660 " default_values=\"0.5\"\n"
4661 " information_property=\"RadiusInfo\"\n"
4662 " name=\"Radius\"\n"
4663 " number_of_elements=\"1\">\n"
4664 " <DoubleRangeDomain min=\"0.0\"\n"
4665 " name=\"range\" />\n"
4666 " <Documentation>The radius of the cylinder. Note that if the radius is\n"
4667 " too big the cylinder will be outside of the bounding box.</Documentation>\n"
4668 " </DoubleVectorProperty>\n"
4669 " <DoubleVectorProperty command=\"GetRadius\"\n"
4670 " information_only=\"1\"\n"
4671 " name=\"RadiusInfo\">\n"
4672 " <SimpleDoubleInformationHelper />\n"
4673 " </DoubleVectorProperty>\n"
4674 " <IntVectorProperty command=\"SetDrawCylinder\"\n"
4675 " default_values=\"1\"\n"
4676 " name=\"DrawCylinder\"\n"
4677 " number_of_elements=\"1\">\n"
4678 " <BooleanDomain name=\"bool\" />\n"
4679 " <Documentation>Enable/disable the drawing of the cylinder. In some cases\n"
4680 " the cylinder interferes with the object that it is operating on (e.g.,\n"
4681 " the cylinder interferes with the cut surface it produces resulting in\n"
4682 " z-buffer artifacts.) By default it is on.</Documentation>\n"
4683 " </IntVectorProperty>\n"
4684 " <IntVectorProperty command=\"SetResolution\"\n"
4685 " default_values=\"128\"\n"
4686 " name=\"Resolution\"\n"
4687 " number_of_elements=\"1\">\n"
4688 " <IntRangeDomain min=\"8\"\n"
4689 " max=\"2048\"\n"
4690 " name=\"range\" />\n"
4691 " <Documentation>This is the number of polygonal facets used to approximate\n"
4692 " the curved cylindrical surface (for rendering purposes). An vtkCylinder\n"
4693 " is used under the hood to provide an exact surface representation.\n"
4694 " </Documentation>\n"
4695 " </IntVectorProperty>\n"
4696 " <IntVectorProperty command=\"SetTubing\"\n"
4697 " default_values=\"1\"\n"
4698 " name=\"Tubing\"\n"
4699 " number_of_elements=\"1\">\n"
4700 " <BooleanDomain name=\"bool\" />\n"
4701 " <Documentation>Enable/disable tubing of the wire outline of the cylinder\n"
4702 " intersection (against the bounding box). The tube thickens the\n"
4703 " line by wrapping with a vtkTubeFilter..</Documentation>\n"
4704 " </IntVectorProperty>\n"
4705 " <IntVectorProperty command=\"SetOutlineTranslation\"\n"
4706 " default_values=\"0\"\n"
4707 " name=\"OutlineTranslation\"\n"
4708 " number_of_elements=\"1\">\n"
4709 " <BooleanDomain name=\"bool\" />\n"
4710 " <Documentation>Enable/disable the ability to translate the bounding box by\n"
4711 " moving it with the mouse.</Documentation>\n"
4712 " </IntVectorProperty>\n"
4713 " <IntVectorProperty command=\"SetOutsideBounds\"\n"
4714 " default_values=\"1\"\n"
4715 " name=\"OutsideBounds\"\n"
4716 " number_of_elements=\"1\">\n"
4717 " <BooleanDomain name=\"bool\" />\n"
4718 " <Documentation>Enable/disable the ability to move the widget outside of\n"
4719 ;
4720
4721 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
4723 " the bounds specified in the initial PlaceWidget() invocation.\n"
4724 " </Documentation>\n"
4725 " </IntVectorProperty>\n"
4726 " <IntVectorProperty command=\"SetScaleEnabled\"\n"
4727 " default_values=\"1\"\n"
4728 " name=\"ScaleEnabled\"\n"
4729 " number_of_elements=\"1\">\n"
4730 " <BooleanDomain name=\"bool\" />\n"
4731 " <Documentation>Enable/disable the ability to scale the widget with the\n"
4732 " mouse.</Documentation>\n"
4733 " </IntVectorProperty>\n"
4734 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
4735 " name=\"ForegroundWidgetColor\"\n"
4736 " command=\"SetForegroundColor\"\n"
4737 " number_of_elements=\"3\"\n"
4738 " panel_widget=\"color_selector\">\n"
4739 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4740 " <Documentation>Color used when coloring the outline</Documentation>\n"
4741 " <Hints>\n"
4742 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
4743 " unlink_if_modified=\"1\" />\n"
4744 " </Hints>\n"
4745 " </DoubleVectorProperty>\n"
4746 " <DoubleVectorProperty default_values=\"1.0 0.0 0.0\"\n"
4747 " name=\"WidgetColor\"\n"
4748 " command=\"SetHandleColor\"\n"
4749 " number_of_elements=\"3\"\n"
4750 " panel_widget=\"color_selector\">\n"
4751 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4752 " <Documentation>Color used for widget handles</Documentation>\n"
4753 " <Hints>\n"
4754 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"WidgetColor\"\n"
4755 " unlink_if_modified=\"1\" />\n"
4756 " </Hints>\n"
4757 " </DoubleVectorProperty>\n"
4758 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
4759 " name=\"InteractiveWidgetColor\"\n"
4760 " command=\"SetInteractionColor\"\n"
4761 " number_of_elements=\"3\"\n"
4762 " panel_widget=\"color_selector\">\n"
4763 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
4764 " <Documentation>Color used for interacting widget handles</Documentation>\n"
4765 " <Hints>\n"
4766 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
4767 " unlink_if_modified=\"1\" />\n"
4768 " </Hints>\n"
4769 " </DoubleVectorProperty>\n"
4770 " <!-- End of ImplicitCylinderRepresentation -->\n"
4771 " </Proxy>\n"
4772 " <!-- ================================================================== -->\n"
4773 " <Proxy class=\"vtkDistanceRepresentation2D\"\n"
4774 " name=\"DistanceRepresentation2D\"\n"
4775 " post_creation=\"InstantiateHandleRepresentation\">\n"
4776 " <IntVectorProperty animateable=\"1\"\n"
4777 " command=\"SetVisibility\"\n"
4778 " default_values=\"1\"\n"
4779 " name=\"Visibility\"\n"
4780 " number_of_elements=\"1\">\n"
4781 " <BooleanDomain name=\"bool\" />\n"
4782 " </IntVectorProperty>\n"
4783 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4784 " command=\"SetPoint1WorldPosition\"\n"
4785 " default_values=\"0 0 0\"\n"
4786 " information_property=\"Point1WorldPositionInfo\"\n"
4787 " name=\"Point1WorldPosition\"\n"
4788 " number_of_elements=\"3\">\n"
4789 " <DoubleRangeDomain name=\"range\" />\n"
4790 " </DoubleVectorProperty>\n"
4791 " <DoubleVectorProperty command=\"GetPoint1WorldPosition\"\n"
4792 " information_only=\"1\"\n"
4793 " name=\"Point1WorldPositionInfo\">\n"
4794 " <SimpleDoubleInformationHelper />\n"
4795 " </DoubleVectorProperty>\n"
4796 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4797 " command=\"SetPoint2WorldPosition\"\n"
4798 " default_values=\"1 0 0\"\n"
4799 " information_property=\"Point2WorldPositionInfo\"\n"
4800 " name=\"Point2WorldPosition\"\n"
4801 " number_of_elements=\"3\">\n"
4802 " <DoubleRangeDomain name=\"range\" />\n"
4803 " </DoubleVectorProperty>\n"
4804 " <DoubleVectorProperty command=\"GetPoint2WorldPosition\"\n"
4805 " information_only=\"1\"\n"
4806 " name=\"Point2WorldPositionInfo\">\n"
4807 " <SimpleDoubleInformationHelper />\n"
4808 " </DoubleVectorProperty>\n"
4809 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4810 " command=\"PlaceWidget\"\n"
4811 " default_values=\"0 1 0 1 0 1\"\n"
4812 " is_internal=\"1\"\n"
4813 " name=\"PlaceWidget\"\n"
4814 " number_of_elements=\"6\">\n"
4815 " <DoubleRangeDomain name=\"range\" />\n"
4816 " </DoubleVectorProperty>\n"
4817 " <!-- End of DistanceRepresentation2D -->\n"
4818 " </Proxy>\n"
4819 " <!-- ================================================================== -->\n"
4820 " <ImplicitPlaneRepresentationProxy class=\"vtkPVImplicitPlaneRepresentation\"\n"
4821 " name=\"ImplicitPlaneRepresentation\">\n"
4822 " <IntVectorProperty animateable=\"1\"\n"
4823 " command=\"SetVisibility\"\n"
4824 " default_values=\"1\"\n"
4825 " name=\"Visibility\"\n"
4826 " number_of_elements=\"1\">\n"
4827 " <BooleanDomain name=\"bool\" />\n"
4828 " </IntVectorProperty>\n"
4829 " <IntVectorProperty animateable=\"1\"\n"
4830 " command=\"SetDrawPlane\"\n"
4831 " default_values=\"0\"\n"
4832 " name=\"DrawPlane\"\n"
4833 " number_of_elements=\"1\">\n"
4834 " <BooleanDomain name=\"bool\" />\n"
4835 " </IntVectorProperty>\n"
4836 " <IntVectorProperty command=\"SetConstrainToWidgetBounds\"\n"
4837 " default_values=\"0\"\n"
4838 " name=\"ConstrainToWidgetBounds\"\n"
4839 " number_of_elements=\"1\">\n"
4840 " <BooleanDomain name=\"bool\" />\n"
4841 " </IntVectorProperty>\n"
4842 " <IntVectorProperty animateable=\"1\"\n"
4843 " command=\"SetDrawOutline\"\n"
4844 " default_values=\"1\"\n"
4845 " name=\"DrawOutline\"\n"
4846 " number_of_elements=\"1\">\n"
4847 " <BooleanDomain name=\"bool\" />\n"
4848 " </IntVectorProperty>\n"
4849 " <IntVectorProperty command=\"SetOutlineTranslation\"\n"
4850 " default_values=\"0\"\n"
4851 " name=\"OutlineTranslation\"\n"
4852 " number_of_elements=\"1\">\n"
4853 " <BooleanDomain name=\"bool\" />\n"
4854 " </IntVectorProperty>\n"
4855 " <IntVectorProperty command=\"SetAlwaysSnapToNearestAxis\"\n"
4856 " default_values=\"0\"\n"
4857 " information_property=\"AlwaysSnapToNearestAxisInfo\"\n"
4858 " name=\"AlwaysSnapToNearestAxis\"\n"
4859 " number_of_elements=\"1\">\n"
4860 " <BooleanDomain name=\"bool\" />\n"
4861 " </IntVectorProperty>\n"
4862 " <IntVectorProperty command=\"GetAlwaysSnapToNearestAxis\"\n"
4863 " information_only=\"1\"\n"
4864 " default_values=\"0\"\n"
4865 " name=\"AlwaysSnapToNearestAxisInfo\"\n"
4866 " number_of_elements=\"1\">\n"
4867 " <SimpleIntInformationHelper />\n"
4868 " </IntVectorProperty>\n"
4869 "\n"
4870 " <Property command=\"Reset\"\n"
4871 " name=\"Reset\"></Property>\n"
4872 " <DoubleVectorProperty command=\"SetOrigin\"\n"
4873 " default_values=\"0 0 0\"\n"
4874 " information_property=\"OriginInfo\"\n"
4875 " name=\"Origin\"\n"
4876 " number_of_elements=\"3\">\n"
4877 " <DoubleRangeDomain name=\"range\" />\n"
4878 " </DoubleVectorProperty>\n"
4879 " <DoubleVectorProperty command=\"GetOrigin\"\n"
4880 " information_only=\"1\"\n"
4881 " name=\"OriginInfo\">\n"
4882 " <SimpleDoubleInformationHelper />\n"
4883 " </DoubleVectorProperty>\n"
4884 " <DoubleVectorProperty command=\"SetNormal\"\n"
4885 " default_values=\"1 0 0\"\n"
4886 " information_property=\"NormalInfo\"\n"
4887 " name=\"Normal\"\n"
4888 " number_of_elements=\"3\">\n"
4889 " <DoubleRangeDomain name=\"range\" />\n"
4890 " </DoubleVectorProperty>\n"
4891 " <DoubleVectorProperty command=\"GetNormal\"\n"
4892 " information_only=\"1\"\n"
4893 " name=\"NormalInfo\">\n"
4894 " <SimpleDoubleInformationHelper />\n"
4895 " </DoubleVectorProperty>\n"
4896 " <DoubleVectorProperty argument_is_array=\"1\"\n"
4897 " command=\"SetWidgetBounds\"\n"
4898 " default_values=\"none\"\n"
4899 " is_internal=\"1\"\n"
4900 " name=\"WidgetBounds\"\n"
4901 " number_of_elements=\"6\">\n"
4902 " <DoubleRangeDomain name=\"range\" />\n"
4903 " </DoubleVectorProperty>\n"
4904 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
4905 " default_values=\"1.2\"\n"
4906 " name=\"PlaceFactor\"\n"
4907 " number_of_elements=\"1\">\n"
4908 " <DoubleRangeDomain name=\"range\" />\n"
4909 " </DoubleVectorProperty>\n"
4910 " </ImplicitPlaneRepresentationProxy>\n"
4911 " <!-- ================================================================== -->\n"
4912 " <DisplaySizedImplicitPlaneRepresentationProxy class=\"vtkPVDisplaySizedImplicitPlaneRepresentation\"\n"
4913 " name=\"DisplaySizedImplicitPlaneRepresentation\">\n"
4914 " <IntVectorProperty animateable=\"1\"\n"
4915 " command=\"SetVisibility\"\n"
4916 " default_values=\"1\"\n"
4917 " name=\"Visibility\"\n"
4918 " number_of_elements=\"1\">\n"
4919 " <BooleanDomain name=\"bool\" />\n"
4920 " </IntVectorProperty>\n"
4921 " <DoubleVectorProperty command=\"SetRadiusMultiplier\"\n"
4922 " default_values=\"1.0\"\n"
4923 " name=\"RadiusMultiplier\"\n"
4924 " number_of_elements=\"1\">\n"
4925 " <DoubleRangeDomain name=\"range\" />\n"
4926 " </DoubleVectorProperty>\n"
4927 " <IntVectorProperty animateable=\"1\"\n"
4928 " command=\"SetDrawPlane\"\n"
4929 " default_values=\"0\"\n"
4930 " name=\"DrawPlane\"\n"
4931 " number_of_elements=\"1\">\n"
4932 " <BooleanDomain name=\"bool\" />\n"
4933 " </IntVectorProperty>\n"
4934 " <IntVectorProperty command=\"SetConstrainToWidgetBounds\"\n"
4935 " default_values=\"0\"\n"
4936 " name=\"ConstrainToWidgetBounds\"\n"
4937 " number_of_elements=\"1\">\n"
4938 " <BooleanDomain name=\"bool\" />\n"
4939 " </IntVectorProperty>\n"
4940 " <IntVectorProperty command=\"SetConstrainMaximumSizeToWidgetBounds\"\n"
4941 " default_values=\"1\"\n"
4942 " name=\"ConstrainMaximumSizeToWidgetBounds\"\n"
4943 " number_of_elements=\"1\">\n"
4944 " <BooleanDomain name=\"bool\" />\n"
4945 " </IntVectorProperty>\n"
4946 " <IntVectorProperty animateable=\"1\"\n"
4947 " command=\"SetDrawOutline\"\n"
4948 " default_values=\"1\"\n"
4949 " name=\"DrawOutline\"\n"
4950 " number_of_elements=\"1\">\n"
4951 " <BooleanDomain name=\"bool\" />\n"
4952 " </IntVectorProperty>\n"
4953 " <IntVectorProperty animateable=\"1\"\n"
4954 " command=\"SetDrawIntersectionEdges\"\n"
4955 " default_values=\"1\"\n"
4956 " name=\"DrawIntersectionEdges\"\n"
4957 " number_of_elements=\"1\">\n"
4958 " <BooleanDomain name=\"bool\" />\n"
4959 " </IntVectorProperty>\n"
4960 " <IntVectorProperty command=\"SetOutlineTranslation\"\n"
4961 " default_values=\"0\"\n"
4962 " name=\"OutlineTranslation\"\n"
4963 " number_of_elements=\"1\">\n"
4964 " <BooleanDomain name=\"bool\" />\n"
4965 " </IntVectorProperty>\n"
4966 " <IntVectorProperty command=\"SetAlwaysSnapToNearestAxis\"\n"
4967 " default_values=\"0\"\n"
4968 " information_property=\"AlwaysSnapToNearestAxisInfo\"\n"
4969 " name=\"AlwaysSnapToNearestAxis\"\n"
4970 " number_of_elements=\"1\">\n"
4971 " <BooleanDomain name=\"bool\" />\n"
4972 " </IntVectorProperty>\n"
4973 " <IntVectorProperty command=\"GetAlwaysSnapToNearestAxis\"\n"
4974 " information_only=\"1\"\n"
4975 " default_values=\"0\"\n"
4976 " name=\"AlwaysSnapToNearestAxisInfo\"\n"
4977 " number_of_elements=\"1\">\n"
4978 " <SimpleIntInformationHelper />\n"
4979 " </IntVectorProperty>\n"
4980 "\n"
4981 " <Property command=\"Reset\"\n"
4982 " name=\"Reset\"></Property>\n"
4983 " <DoubleVectorProperty command=\"SetOrigin\"\n"
4984 " default_values=\"0 0 0\"\n"
4985 " information_property=\"OriginInfo\"\n"
4986 " name=\"Origin\"\n"
4987 " number_of_elements=\"3\">\n"
4988 " <DoubleRangeDomain name=\"range\" />\n"
4989 " </DoubleVectorProperty>\n"
4990 " <DoubleVectorProperty command=\"GetOrigin\"\n"
4991 " information_only=\"1\"\n"
4992 " name=\"OriginInfo\">\n"
4993 " <SimpleDoubleInformationHelper />\n"
4994 " </DoubleVectorProperty>\n"
4995 " <DoubleVectorProperty command=\"SetNormal\"\n"
4996 " default_values=\"1 0 0\"\n"
4997 " information_property=\"NormalInfo\"\n"
4998 " name=\"Normal\"\n"
4999 " number_of_elements=\"3\">\n"
5000 " <DoubleRangeDomain name=\"range\" />\n"
5001 " </DoubleVectorProperty>\n"
5002 " <DoubleVectorProperty command=\"GetNormal\"\n"
5003 " information_only=\"1\"\n"
5004 " name=\"NormalInfo\">\n"
5005 " <SimpleDoubleInformationHelper />\n"
5006 " </DoubleVectorProperty>\n"
5007 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5008 " command=\"SetWidgetBounds\"\n"
5009 " default_values=\"none\"\n"
5010 " is_internal=\"1\"\n"
5011 " name=\"WidgetBounds\"\n"
5012 " number_of_elements=\"6\">\n"
5013 " <DoubleRangeDomain name=\"range\" />\n"
5014 " </DoubleVectorProperty>\n"
5015 " <DoubleVectorProperty command=\"SetPlaceFactor\"\n"
5016 " default_values=\"1.2\"\n"
5017 " name=\"PlaceFactor\"\n"
5018 " number_of_elements=\"1\">\n"
5019 " <DoubleRangeDomain name=\"range\" />\n"
5020 " </DoubleVectorProperty>\n"
5021 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
5022 " name=\"ForegroundWidgetColor\"\n"
5023 " command=\"SetForegroundColor\"\n"
5024 " number_of_elements=\"3\"\n"
5025 " panel_widget=\"color_selector\">\n"
5026 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5027 " <Documentation>Color used when coloring the outline</Documentation>\n"
5028 ;
5029
5030 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
5032 " <Hints>\n"
5033 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
5034 " unlink_if_modified=\"1\" />\n"
5035 " </Hints>\n"
5036 " </DoubleVectorProperty>\n"
5037 " <DoubleVectorProperty default_values=\"1.0 0.0 0.0\"\n"
5038 " name=\"WidgetColor\"\n"
5039 " command=\"SetHandleColor\"\n"
5040 " number_of_elements=\"3\"\n"
5041 " panel_widget=\"color_selector\">\n"
5042 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5043 " <Documentation>Color used for widget handles</Documentation>\n"
5044 " <Hints>\n"
5045 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"WidgetColor\"\n"
5046 " unlink_if_modified=\"1\" />\n"
5047 " </Hints>\n"
5048 " </DoubleVectorProperty>\n"
5049 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
5050 " name=\"InteractiveWidgetColor\"\n"
5051 " command=\"SetInteractionColor\"\n"
5052 " number_of_elements=\"3\"\n"
5053 " panel_widget=\"color_selector\">\n"
5054 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5055 " <Documentation>Color used for interacting widget handles</Documentation>\n"
5056 " <Hints>\n"
5057 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
5058 " unlink_if_modified=\"1\" />\n"
5059 " </Hints>\n"
5060 " </DoubleVectorProperty>\n"
5061 " </DisplaySizedImplicitPlaneRepresentationProxy>\n"
5062 " <!-- ================================================================== -->\n"
5063 " <Proxy class=\"vtkCoordinateFrameRepresentation\"\n"
5064 " name=\"CoordinateFrameRepresentation\">\n"
5065 "\n"
5066 " <IntVectorProperty animateable=\"1\"\n"
5067 " command=\"SetVisibility\"\n"
5068 " default_values=\"1\"\n"
5069 " name=\"Visibility\"\n"
5070 " number_of_elements=\"1\">\n"
5071 " <BooleanDomain name=\"bool\" />\n"
5072 " </IntVectorProperty>\n"
5073 "\n"
5074 " <IntVectorProperty animateable=\"1\"\n"
5075 " command=\"SetLockedAxis\"\n"
5076 " default_values=\"-1\"\n"
5077 " name=\"LockedAxis\"\n"
5078 " number_of_elements=\"1\">\n"
5079 " <EnumerationDomain name=\"axis\">\n"
5080 " <Entry text=\"None\" value=\"-1\" />\n"
5081 " <Entry text=\"X Axis\" value=\"0\" />\n"
5082 " <Entry text=\"Y Axis\" value=\"1\" />\n"
5083 " <Entry text=\"Z Axis\" value=\"2\" />\n"
5084 " </EnumerationDomain>\n"
5085 " </IntVectorProperty>\n"
5086 " <IntVectorProperty command=\"GetLockedAxis\"\n"
5087 " information_only=\"1\"\n"
5088 " default_values=\"-1\"\n"
5089 " name=\"LockedAxisInfo\"\n"
5090 " number_of_elements=\"1\">\n"
5091 " <SimpleIntInformationHelper />\n"
5092 " </IntVectorProperty>\n"
5093 "\n"
5094 " <Property command=\"Reset\"\n"
5095 " name=\"Reset\"></Property>\n"
5096 "\n"
5097 " <Property command=\"ResetAxes\"\n"
5098 " name=\"ResetAxes\"></Property>\n"
5099 "\n"
5100 " <Property command=\"SetNormalToCamera\"\n"
5101 " name=\"UseCameraNormal\"></Property>\n"
5102 "\n"
5103 " <DoubleVectorProperty command=\"SetOrigin\"\n"
5104 " default_values=\"0 0 0\"\n"
5105 " information_property=\"OriginInfo\"\n"
5106 " name=\"Origin\"\n"
5107 " number_of_elements=\"3\">\n"
5108 " <DoubleRangeDomain name=\"range\" />\n"
5109 " </DoubleVectorProperty>\n"
5110 " <DoubleVectorProperty command=\"GetOrigin\"\n"
5111 " information_only=\"1\"\n"
5112 " name=\"OriginInfo\">\n"
5113 " <SimpleDoubleInformationHelper />\n"
5114 " </DoubleVectorProperty>\n"
5115 "\n"
5116 " <DoubleVectorProperty command=\"SetLengthFactor\"\n"
5117 " default_values=\"0.02\"\n"
5118 " information_property=\"LengthFactorInfo\"\n"
5119 " name=\"LengthFactor\"\n"
5120 " number_of_elements=\"1\">\n"
5121 " <DoubleRangeDomain name=\"range\" />\n"
5122 " </DoubleVectorProperty>\n"
5123 " <DoubleVectorProperty command=\"GetLengthFactor\"\n"
5124 " information_only=\"1\"\n"
5125 " name=\"LengthFactorInfo\">\n"
5126 " <SimpleDoubleInformationHelper />\n"
5127 " </DoubleVectorProperty>\n"
5128 "\n"
5129 " <!-- Note the information properties use a different method.\n"
5130 " Get(X|Y|Z)VectorNormal() vs Set(X|Y|Z)AxisVector().\n"
5131 " This is because setting one vector potentially changes\n"
5132 " all three axes; the user-facing setters normalize the\n"
5133 " input vector (which may be any length except 0) and set\n"
5134 " all 3 axes.\n"
5135 " -->\n"
5136 " <DoubleVectorProperty command=\"SetXAxisVector\"\n"
5137 " default_values=\"1 0 0\"\n"
5138 " information_property=\"XAxisInfo\"\n"
5139 " name=\"XAxis\"\n"
5140 " number_of_elements=\"3\">\n"
5141 " <DoubleRangeDomain name=\"range\" />\n"
5142 " </DoubleVectorProperty>\n"
5143 " <DoubleVectorProperty command=\"GetXVectorNormal\"\n"
5144 " information_only=\"1\"\n"
5145 " name=\"XAxisInfo\">\n"
5146 " <SimpleDoubleInformationHelper />\n"
5147 " </DoubleVectorProperty>\n"
5148 "\n"
5149 " <DoubleVectorProperty command=\"SetYAxisVector\"\n"
5150 " default_values=\"0 1 0\"\n"
5151 " information_property=\"YAxisInfo\"\n"
5152 " name=\"YAxis\"\n"
5153 " number_of_elements=\"3\">\n"
5154 " <DoubleRangeDomain name=\"range\" />\n"
5155 " </DoubleVectorProperty>\n"
5156 " <DoubleVectorProperty command=\"GetYVectorNormal\"\n"
5157 " information_only=\"1\"\n"
5158 " name=\"YAxisInfo\">\n"
5159 " <SimpleDoubleInformationHelper />\n"
5160 " </DoubleVectorProperty>\n"
5161 "\n"
5162 " <DoubleVectorProperty command=\"SetZAxisVector\"\n"
5163 " default_values=\"0 0 1\"\n"
5164 " information_property=\"ZAxisInfo\"\n"
5165 " name=\"ZAxis\"\n"
5166 " number_of_elements=\"3\">\n"
5167 " <DoubleRangeDomain name=\"range\" />\n"
5168 " </DoubleVectorProperty>\n"
5169 " <DoubleVectorProperty command=\"GetZVectorNormal\"\n"
5170 " information_only=\"1\"\n"
5171 " name=\"ZAxisInfo\">\n"
5172 " <SimpleDoubleInformationHelper />\n"
5173 " </DoubleVectorProperty>\n"
5174 "\n"
5175 " <!--\n"
5176 " Special properties that set the locked or nearest axis (if none locked).\n"
5177 " Their state is ignored and no defaults are provided because the methods\n"
5178 " affect other state rather than representing a unique portion of the\n"
5179 " proxy's state.\n"
5180 " -->\n"
5181 " <DoubleVectorProperty command=\"SetNormal\"\n"
5182 " name=\"Normal\"\n"
5183 " state_ignored=\"1\"\n"
5184 " default_values=\"none\"\n"
5185 " number_of_elements=\"3\">\n"
5186 " <DoubleRangeDomain name=\"range\" />\n"
5187 " </DoubleVectorProperty>\n"
5188 " <DoubleVectorProperty command=\"SetDirection\"\n"
5189 " name=\"Direction\"\n"
5190 " state_ignored=\"1\"\n"
5191 " default_values=\"none\"\n"
5192 " number_of_elements=\"3\">\n"
5193 " <DoubleRangeDomain name=\"range\" />\n"
5194 " </DoubleVectorProperty>\n"
5195 " <!--\n"
5196 " Special property that places the base point centered in the bounds provided.\n"
5197 " -->\n"
5198 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5199 " command=\"PlaceWidget\"\n"
5200 " default_values=\"none\"\n"
5201 " is_internal=\"1\"\n"
5202 " name=\"WidgetBounds\"\n"
5203 " number_of_elements=\"6\">\n"
5204 " <DoubleRangeDomain name=\"range\" />\n"
5205 " </DoubleVectorProperty>\n"
5206 " </Proxy>\n"
5207 " <!-- ================================================================== -->\n"
5208 " <Proxy class=\"vtkLineRepresentation\"\n"
5209 " name=\"LineRepresentation\">\n"
5210 " <IntVectorProperty animateable=\"1\"\n"
5211 " command=\"SetVisibility\"\n"
5212 " default_values=\"1\"\n"
5213 " name=\"Visibility\"\n"
5214 " number_of_elements=\"1\">\n"
5215 " <BooleanDomain name=\"bool\" />\n"
5216 " </IntVectorProperty>\n"
5217 " <IntVectorProperty command=\"SetDirectionalLine\"\n"
5218 " default_values=\"1\"\n"
5219 " name=\"DirectionalLine\"\n"
5220 " number_of_elements=\"1\">\n"
5221 " <BooleanDomain name=\"bool\" />\n"
5222 " </IntVectorProperty>\n"
5223 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5224 " command=\"SetPoint1WorldPosition\"\n"
5225 " default_values=\"0 0 0\"\n"
5226 " information_property=\"Point1WorldPositionInfo\"\n"
5227 " name=\"Point1WorldPosition\"\n"
5228 " number_of_elements=\"3\">\n"
5229 " <DoubleRangeDomain name=\"range\" />\n"
5230 " </DoubleVectorProperty>\n"
5231 " <DoubleVectorProperty command=\"GetPoint1WorldPosition\"\n"
5232 " information_only=\"1\"\n"
5233 " name=\"Point1WorldPositionInfo\">\n"
5234 " <SimpleDoubleInformationHelper />\n"
5235 " </DoubleVectorProperty>\n"
5236 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5237 " command=\"SetPoint2WorldPosition\"\n"
5238 " default_values=\"0 0 0\"\n"
5239 " information_property=\"Point2WorldPositionInfo\"\n"
5240 " name=\"Point2WorldPosition\"\n"
5241 " number_of_elements=\"3\">\n"
5242 " <DoubleRangeDomain name=\"range\" />\n"
5243 " </DoubleVectorProperty>\n"
5244 " <DoubleVectorProperty command=\"GetPoint2WorldPosition\"\n"
5245 " information_only=\"1\"\n"
5246 " name=\"Point2WorldPositionInfo\">\n"
5247 " <SimpleDoubleInformationHelper />\n"
5248 " </DoubleVectorProperty>\n"
5249 " <DoubleVectorProperty command=\"SetLineColor\"\n"
5250 " default_values=\"1.0 1.0 1.0\"\n"
5251 " name=\"LineColor\"\n"
5252 " number_of_elements=\"3\">\n"
5253 " <DoubleRangeDomain max=\"1 1 1\"\n"
5254 " min=\"0 0 0\"\n"
5255 " name=\"range\" />\n"
5256 " </DoubleVectorProperty>\n"
5257 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
5258 " name=\"ForegroundWidgetColor\"\n"
5259 " command=\"SetForegroundColor\"\n"
5260 " number_of_elements=\"3\"\n"
5261 " panel_widget=\"color_selector\">\n"
5262 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5263 " <Documentation>Color used when coloring the widget</Documentation>\n"
5264 " <Hints>\n"
5265 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
5266 " unlink_if_modified=\"1\" />\n"
5267 " </Hints>\n"
5268 " </DoubleVectorProperty>\n"
5269 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
5270 " name=\"InteractiveWidgetColor\"\n"
5271 " command=\"SetInteractionColor\"\n"
5272 " number_of_elements=\"3\"\n"
5273 " panel_widget=\"color_selector\">\n"
5274 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5275 " <Documentation>Color used for interacting widget handles</Documentation>\n"
5276 " <Hints>\n"
5277 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
5278 " unlink_if_modified=\"1\" />\n"
5279 " </Hints>\n"
5280 " </DoubleVectorProperty>\n"
5281 " </Proxy>\n"
5282 " <!-- ================================================================== -->\n"
5283 " <Proxy class=\"vtkPointHandleRepresentation3D\"\n"
5284 " name=\"HandleRepresentation\">\n"
5285 " <IntVectorProperty animateable=\"1\"\n"
5286 " command=\"SetVisibility\"\n"
5287 " default_values=\"1\"\n"
5288 " name=\"Visibility\"\n"
5289 " number_of_elements=\"1\">\n"
5290 " <BooleanDomain name=\"bool\" />\n"
5291 " </IntVectorProperty>\n"
5292 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5293 " command=\"SetWorldPosition\"\n"
5294 " default_values=\"0 0 0\"\n"
5295 " information_property=\"WorldPositionInfo\"\n"
5296 " name=\"WorldPosition\"\n"
5297 " number_of_elements=\"3\">\n"
5298 " <DoubleRangeDomain name=\"range\" />\n"
5299 " </DoubleVectorProperty>\n"
5300 " <DoubleVectorProperty command=\"GetWorldPosition\"\n"
5301 " information_only=\"1\"\n"
5302 " name=\"WorldPositionInfo\">\n"
5303 " <SimpleDoubleInformationHelper />\n"
5304 " </DoubleVectorProperty>\n"
5305 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
5306 " name=\"ForegroundWidgetColor\"\n"
5307 " command=\"SetForegroundColor\"\n"
5308 " number_of_elements=\"3\"\n"
5309 " panel_widget=\"color_selector\">\n"
5310 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5311 " <Documentation>Color used when coloring the widget</Documentation>\n"
5312 " <Hints>\n"
5313 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
5314 " unlink_if_modified=\"1\" />\n"
5315 " </Hints>\n"
5316 " </DoubleVectorProperty>\n"
5317 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
5318 " name=\"InteractiveWidgetColor\"\n"
5319 " command=\"SetInteractionColor\"\n"
5320 " number_of_elements=\"3\"\n"
5321 " panel_widget=\"color_selector\">\n"
5322 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
5323 " <Documentation>Color used for interacting widget handles</Documentation>\n"
5324 " <Hints>\n"
5325 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
5326 " unlink_if_modified=\"1\" />\n"
5327 " </Hints>\n"
5328 " </DoubleVectorProperty>\n"
5329 " </Proxy>\n"
5330 " <!-- ================================================================== -->\n"
5331 " <Proxy class=\"vtkLightRepresentation\"\n"
5332 " name=\"LightRepresentation\">\n"
5333 " <IntVectorProperty animateable=\"1\"\n"
5334 " command=\"SetVisibility\"\n"
5335 " default_values=\"1\"\n"
5336 " name=\"Visibility\"\n"
5337 " number_of_elements=\"1\">\n"
5338 " <BooleanDomain name=\"bool\" />\n"
5339 " </IntVectorProperty>\n"
5340 " <IntVectorProperty animateable=\"1\"\n"
5341 " command=\"SetPositional\"\n"
5342 " default_values=\"0\"\n"
5343 " name=\"Positional\"\n"
5344 " number_of_elements=\"1\">\n"
5345 " <BooleanDomain name=\"bool\" />\n"
5346 " </IntVectorProperty>\n"
5347 ;
5348
5349 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
5351 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5352 " command=\"SetLightPosition\"\n"
5353 " default_values=\"0 0 1\"\n"
5354 " information_property=\"WorldPositionInfo\"\n"
5355 " name=\"WorldPosition\"\n"
5356 " number_of_elements=\"3\">\n"
5357 " <DoubleRangeDomain name=\"range\" />\n"
5358 " </DoubleVectorProperty>\n"
5359 " <DoubleVectorProperty command=\"GetLightPosition\"\n"
5360 " information_only=\"1\"\n"
5361 " name=\"WorldPositionInfo\">\n"
5362 " <SimpleDoubleInformationHelper />\n"
5363 " </DoubleVectorProperty>\n"
5364 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5365 " command=\"SetFocalPoint\"\n"
5366 " default_values=\"0 0 0\"\n"
5367 " information_property=\"FocalPointInfo\"\n"
5368 " name=\"FocalPoint\"\n"
5369 " number_of_elements=\"3\">\n"
5370 " <DoubleRangeDomain name=\"range\" />\n"
5371 " </DoubleVectorProperty>\n"
5372 " <DoubleVectorProperty command=\"GetFocalPoint\"\n"
5373 " information_only=\"1\"\n"
5374 " name=\"FocalPointInfo\">\n"
5375 " <SimpleDoubleInformationHelper />\n"
5376 " </DoubleVectorProperty>\n"
5377 " <DoubleVectorProperty command=\"SetConeAngle\"\n"
5378 " default_values=\"30\"\n"
5379 " information_property=\"ConeAngleInfo\"\n"
5380 " name=\"ConeAngle\"\n"
5381 " number_of_elements=\"1\">\n"
5382 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"180\"/>\n"
5383 " </DoubleVectorProperty>\n"
5384 " <DoubleVectorProperty command=\"GetConeAngle\"\n"
5385 " information_only=\"1\"\n"
5386 " name=\"ConeAngleInfo\">\n"
5387 " <SimpleDoubleInformationHelper />\n"
5388 " </DoubleVectorProperty>\n"
5389 " <DoubleVectorProperty argument_is_array=\"1\"\n"
5390 " command=\"SetLightColor\"\n"
5391 " default_values=\"1.0 1.0 1.0\"\n"
5392 " information_property=\"LightColorInfo\"\n"
5393 " name=\"LightColor\"\n"
5394 " number_of_elements=\"3\">\n"
5395 " <DoubleRangeDomain name=\"range\" />\n"
5396 " </DoubleVectorProperty>\n"
5397 " <DoubleVectorProperty command=\"GetLightColor\"\n"
5398 " information_only=\"1\"\n"
5399 " name=\"LightColorInfo\">\n"
5400 " <SimpleDoubleInformationHelper />\n"
5401 " </DoubleVectorProperty>\n"
5402 " </Proxy>\n"
5403 " <!-- ================================================================== -->\n"
5404 " <Proxy class=\"vtkPVScalarBarRepresentation\"\n"
5405 " name=\"ScalarBarRepresentation\">\n"
5406 " <IntVectorProperty animateable=\"1\"\n"
5407 " command=\"SetVisibility\"\n"
5408 " default_values=\"1\"\n"
5409 " name=\"Visibility\"\n"
5410 " number_of_elements=\"1\">\n"
5411 " <BooleanDomain name=\"bool\" />\n"
5412 " </IntVectorProperty>\n"
5413 " <DoubleVectorProperty command=\"SetPosition\"\n"
5414 " default_values=\"0.89 0.02\"\n"
5415 " information_property=\"PositionInfo\"\n"
5416 " name=\"Position\"\n"
5417 " number_of_elements=\"2\">\n"
5418 " <DoubleRangeDomain max=\"1 1\"\n"
5419 " min=\"0 0\"\n"
5420 " name=\"range\" />\n"
5421 " <Documentation>\n"
5422 " Specify the anchor position (bottom-left corner of the scalar bar) in normalized\n"
5423 " viewport coordinates in range [0, 1]. This is used only when **Window Location**\n"
5424 " is set to **AnyLocation**.\n"
5425 " </Documentation>\n"
5426 " <Hints>\n"
5427 " <!-- Enable \"Position\" widget only when WindowLocation == AnyLocation -->\n"
5428 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
5429 " mode=\"enabled_state\"\n"
5430 " property=\"WindowLocation\"\n"
5431 " value=\"0\" />\n"
5432 " </Hints>\n"
5433 " </DoubleVectorProperty>\n"
5434 " <DoubleVectorProperty command=\"GetPosition\"\n"
5435 " information_only=\"1\"\n"
5436 " name=\"PositionInfo\">\n"
5437 " <SimpleDoubleInformationHelper />\n"
5438 " </DoubleVectorProperty>\n"
5439 " <IntVectorProperty command=\"SetAutoOrient\"\n"
5440 " default_values=\"1\"\n"
5441 " name=\"AutoOrient\"\n"
5442 " number_of_elements=\"1\">\n"
5443 " <BooleanDomain name=\"bool\" />\n"
5444 " <Hints>\n"
5445 " <NoDefault />\n"
5446 " </Hints>\n"
5447 " <Documentation>Set if color legend's orientation will be updated based on its position.</Documentation>\n"
5448 " </IntVectorProperty>\n"
5449 " <IntVectorProperty command=\"GetAutoOrient\"\n"
5450 " information_only=\"1\"\n"
5451 " name=\"AutoOrientInfo\">\n"
5452 " <BooleanDomain name=\"bool\" />\n"
5453 " </IntVectorProperty>\n"
5454 " <IntVectorProperty command=\"SetOrientation\"\n"
5455 " default_values=\"1\"\n"
5456 " information_property=\"OrientationInfo\"\n"
5457 " name=\"Orientation\"\n"
5458 " number_of_elements=\"1\">\n"
5459 " <Hints>\n"
5460 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
5461 " <Property name=\"AutoOrient\" function=\"boolean_invert\" index=\"0\" />\n"
5462 " </PropertyWidgetDecorator>\n"
5463 " <NoDefault />\n"
5464 " </Hints>\n"
5465 " <EnumerationDomain name=\"enum\">\n"
5466 " <Entry text=\"Horizontal\"\n"
5467 " value=\"0\" />\n"
5468 " <Entry text=\"Vertical\"\n"
5469 " value=\"1\" />\n"
5470 " </EnumerationDomain>\n"
5471 " <Documentation>\n"
5472 " Specify orientation of the color legend. Can be used only if Auto Orient is disabled.\n"
5473 " </Documentation>\n"
5474 " </IntVectorProperty>\n"
5475 " <IntVectorProperty command=\"GetOrientation\"\n"
5476 " information_only=\"1\"\n"
5477 " name=\"OrientationInfo\">\n"
5478 " <SimpleIntInformationHelper />\n"
5479 " </IntVectorProperty>\n"
5480 " <IntVectorProperty command=\"SetWindowLocation\"\n"
5481 " default_values=\"2\"\n"
5482 " name=\"WindowLocation\"\n"
5483 " number_of_elements=\"1\">\n"
5484 " <EnumerationDomain name=\"enum\">\n"
5485 " <Entry text=\"Any Location\"\n"
5486 " value=\"0\" />\n"
5487 " <Entry text=\"Lower Left Corner\"\n"
5488 " value=\"1\" />\n"
5489 " <Entry text=\"Lower Right Corner\"\n"
5490 " value=\"2\" />\n"
5491 " <Entry text=\"Lower Center\"\n"
5492 " value=\"3\" />\n"
5493 " <Entry text=\"Upper Left Corner\"\n"
5494 " value=\"4\" />\n"
5495 " <Entry text=\"Upper Right Corner\"\n"
5496 " value=\"5\" />\n"
5497 " <Entry text=\"Upper Center\"\n"
5498 " value=\"6\" />\n"
5499 " </EnumerationDomain>\n"
5500 " <Documentation>Specify placement of the color legend.</Documentation>\n"
5501 " </IntVectorProperty>\n"
5502 " <ProxyProperty command=\"SetScalarBarActor\"\n"
5503 " name=\"ScalarBarActor\">\n"
5504 " <ProxyGroupDomain name=\"groups\">\n"
5505 " <Group name=\"annotations\" />\n"
5506 " </ProxyGroupDomain>\n"
5507 " </ProxyProperty>\n"
5508 " </Proxy>\n"
5509 " <!-- ================================================================== -->\n"
5510 " <Proxy class=\"vtkTextRepresentation\"\n"
5511 " name=\"TextRepresentation\">\n"
5512 " <IntVectorProperty animateable=\"1\"\n"
5513 " command=\"SetVisibility\"\n"
5514 " default_values=\"1\"\n"
5515 " name=\"Visibility\"\n"
5516 " number_of_elements=\"1\">\n"
5517 " <BooleanDomain name=\"bool\" />\n"
5518 " </IntVectorProperty>\n"
5519 " <DoubleVectorProperty command=\"SetPosition\"\n"
5520 " default_values=\"0.05 0.05\"\n"
5521 " information_property=\"PositionInfo\"\n"
5522 " name=\"Position\"\n"
5523 " number_of_elements=\"2\">\n"
5524 " <DoubleRangeDomain max=\"1 1\"\n"
5525 " min=\"0 0\"\n"
5526 " name=\"range\" />\n"
5527 " </DoubleVectorProperty>\n"
5528 " <DoubleVectorProperty command=\"GetPosition\"\n"
5529 " information_only=\"1\"\n"
5530 " name=\"PositionInfo\">\n"
5531 " <SimpleDoubleInformationHelper />\n"
5532 " </DoubleVectorProperty>\n"
5533 " <DoubleVectorProperty command=\"SetPosition2\"\n"
5534 " default_values=\"0.1 0.1\"\n"
5535 " information_property=\"Position2Info\"\n"
5536 " name=\"Position2\"\n"
5537 " number_of_elements=\"2\">\n"
5538 " <DoubleRangeDomain max=\"1 1\"\n"
5539 " min=\"0 0\"\n"
5540 " name=\"range\" />\n"
5541 " </DoubleVectorProperty>\n"
5542 " <DoubleVectorProperty command=\"GetPosition2\"\n"
5543 " information_only=\"1\"\n"
5544 " name=\"Position2Info\">\n"
5545 " <SimpleDoubleInformationHelper />\n"
5546 " </DoubleVectorProperty>\n"
5547 " <StringVectorProperty command=\"SetText\"\n"
5548 " default_values=\"Some Default\"\n"
5549 " immediate_update=\"1\"\n"
5550 " name=\"Text\"></StringVectorProperty>\n"
5551 " <IntVectorProperty animateable=\"0\"\n"
5552 " command=\"SetWindowLocation\"\n"
5553 " default_values=\"4\"\n"
5554 " name=\"WindowLocation\"\n"
5555 " number_of_elements=\"1\">\n"
5556 " <EnumerationDomain name=\"enum\">\n"
5557 " <Entry text=\"Any Location\"\n"
5558 " value=\"0\" />\n"
5559 " <Entry text=\"Lower Left Corner\"\n"
5560 " value=\"1\" />\n"
5561 " <Entry text=\"Lower Right Corner\"\n"
5562 " value=\"2\" />\n"
5563 " <Entry text=\"Lower Center\"\n"
5564 " value=\"3\" />\n"
5565 " <Entry text=\"Upper Left Corner\"\n"
5566 " value=\"4\" />\n"
5567 " <Entry text=\"Upper Right Corner\"\n"
5568 " value=\"5\" />\n"
5569 " <Entry text=\"Upper Center\"\n"
5570 " value=\"6\" />\n"
5571 " </EnumerationDomain>\n"
5572 " </IntVectorProperty>\n"
5573 " <ProxyProperty command=\"SetTextActor\"\n"
5574 " name=\"TextActor\">\n"
5575 " <ProxyGroupDomain name=\"groups\">\n"
5576 " <Group name=\"props\" />\n"
5577 " </ProxyGroupDomain>\n"
5578 " </ProxyProperty>\n"
5579 "\n"
5580 " <IntVectorProperty animateable=\"0\"\n"
5581 " command=\"SetShowBorder\"\n"
5582 " default_values=\"2\"\n"
5583 " name=\"ShowBorder\"\n"
5584 " number_of_elements=\"1\">\n"
5585 " <EnumerationDomain name=\"enum\">\n"
5586 " <Entry text=\"Never\"\n"
5587 " value=\"0\" />\n"
5588 " <Entry text=\"Always\"\n"
5589 " value=\"1\" />\n"
5590 " <Entry text=\"Only on hover\"\n"
5591 " value=\"2\" />\n"
5592 " </EnumerationDomain>\n"
5593 " <Documentation>\n"
5594 " Set whether the border is always drawn, only on interaction or never.\n"
5595 " </Documentation>\n"
5596 " </IntVectorProperty>\n"
5597 " <DoubleVectorProperty command=\"SetBorderColor\"\n"
5598 " default_values=\"1 1 1\"\n"
5599 " name=\"BorderColor\"\n"
5600 " number_of_elements=\"3\"\n"
5601 " panel_widget=\"color_selector_with_palette\">\n"
5602 " <DoubleRangeDomain max=\"1 1 1\"\n"
5603 " min=\"0 0 0\"\n"
5604 " name=\"range\" />\n"
5605 " <Documentation>Set the color of the border.</Documentation>\n"
5606 " <Hints>\n"
5607 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"BorderColor\" unlink_if_modified=\"1\" />\n"
5608 " </Hints>\n"
5609 " </DoubleVectorProperty>\n"
5610 "\n"
5611 " <DoubleVectorProperty command=\"SetBorderThickness\"\n"
5612 " default_values=\"0.0\"\n"
5613 " name=\"BorderThickness\"\n"
5614 " number_of_elements=\"1\">\n"
5615 " <DoubleRangeDomain max=\"10\"\n"
5616 " min=\"0\"\n"
5617 " name=\"range\" />\n"
5618 " <Documentation>Set the thickness of the border.</Documentation>\n"
5619 " </DoubleVectorProperty>\n"
5620 "\n"
5621 " <DoubleVectorProperty command=\"SetCornerRadiusStrength\"\n"
5622 " default_values=\"0.0\"\n"
5623 " name=\"CornerRadius\"\n"
5624 " number_of_elements=\"1\">\n"
5625 " <DoubleRangeDomain max=\"1\"\n"
5626 " min=\"0\"\n"
5627 " name=\"range\" />\n"
5628 " <Documentation>Set the radius of the round corners in percent of the maximum allowed.</Documentation>\n"
5629 " </DoubleVectorProperty>\n"
5630 "\n"
5631 " <IntVectorProperty command=\"SetCornerResolution\"\n"
5632 " default_values=\"20\"\n"
5633 " name=\"CornerResolution\"\n"
5634 " number_of_elements=\"1\"\n"
5635 " panel_visibility=\"advanced\">\n"
5636 " <IntRangeDomain max=\"1000\"\n"
5637 " min=\"0\"\n"
5638 " name=\"range\" />\n"
5639 " <Documentation>Set the number of points that define each round corner.</Documentation>\n"
5640 " </IntVectorProperty>\n"
5641 "\n"
5642 " <DoubleVectorProperty command=\"SetPolygonRGBA\"\n"
5643 " default_values=\"0 0 0 0\"\n"
5644 " name=\"BackgroundColor\"\n"
5645 " label=\"Background Color\"\n"
5646 " number_of_elements=\"4\"\n"
5647 " panel_widget=\"color_selector\">\n"
5648 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
5649 " min=\"0 0 0 0\"\n"
5650 " name=\"range\" />\n"
5651 " <Documentation>Set the color and opacity of the border background.</Documentation>\n"
5652 " </DoubleVectorProperty>\n"
5653 " <IntVectorProperty command=\"SetPadding\"\n"
5654 " default_values=\"0\"\n"
5655 " name=\"Padding\"\n"
5656 " number_of_elements=\"1\">\n"
5657 " <IntRangeDomain max=\"500\" min=\"0\" name=\"range\" />\n"
5658 " <Documentation>Set the padding around the text in pixels unit.</Documentation>\n"
5659 " </IntVectorProperty>\n"
5660 "\n"
5661 " </Proxy>\n"
5662 " <!-- ================================================================== -->\n"
5663 " <Proxy class=\"vtkProgressBarRepresentation\"\n"
5664 " name=\"ProgressBarRepresentation\">\n"
5665 " <IntVectorProperty animateable=\"1\"\n"
5666 " command=\"SetVisibility\"\n"
5667 " default_values=\"1\"\n"
5668 " name=\"Visibility\"\n"
5669 " number_of_elements=\"1\">\n"
5670 " <BooleanDomain name=\"bool\" />\n"
5671 " </IntVectorProperty>\n"
5672 " <DoubleVectorProperty command=\"SetPosition\"\n"
5673 " default_values=\"0.25 0.05\"\n"
5674 " information_property=\"PositionInfo\"\n"
5675 " name=\"Position\"\n"
5676 " number_of_elements=\"2\">\n"
5677 " <DoubleRangeDomain max=\"1 1\"\n"
5678 ;
5679
5680 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
5682 " min=\"0 0\"\n"
5683 " name=\"range\" />\n"
5684 " </DoubleVectorProperty>\n"
5685 " <DoubleVectorProperty command=\"GetPosition\"\n"
5686 " information_only=\"1\"\n"
5687 " name=\"PositionInfo\">\n"
5688 " <SimpleDoubleInformationHelper />\n"
5689 " </DoubleVectorProperty>\n"
5690 " <DoubleVectorProperty command=\"SetPosition2\"\n"
5691 " default_values=\"0.5 0.06\"\n"
5692 " information_property=\"Position2Info\"\n"
5693 " name=\"Position2\"\n"
5694 " number_of_elements=\"2\">\n"
5695 " <DoubleRangeDomain max=\"1 1\"\n"
5696 " min=\"0 0\"\n"
5697 " name=\"range\" />\n"
5698 " </DoubleVectorProperty>\n"
5699 " <DoubleVectorProperty command=\"GetPosition2\"\n"
5700 " information_only=\"1\"\n"
5701 " name=\"Position2Info\">\n"
5702 " <SimpleDoubleInformationHelper />\n"
5703 " </DoubleVectorProperty>\n"
5704 " <DoubleVectorProperty command=\"SetProgressRate\"\n"
5705 " default_values=\"0\"\n"
5706 " immediate_update=\"1\"\n"
5707 " name=\"ProgressRate\">\n"
5708 " </DoubleVectorProperty>\n"
5709 " <DoubleVectorProperty animateable=\"0\"\n"
5710 " argument_is_array=\"1\"\n"
5711 " command=\"SetProgressBarColor\"\n"
5712 " default_values=\"0.0 1.0 0.0\"\n"
5713 " name=\"ProgressBarColor\"\n"
5714 " panel_widget=\"color_selector_with_palette\"\n"
5715 " number_of_elements=\"3\">\n"
5716 " <DoubleRangeDomain max=\"1 1 1\"\n"
5717 " min=\"0 0 0\"\n"
5718 " name=\"range\" />\n"
5719 " <Hints>\n"
5720 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveWidgetColor\"\n"
5721 " unlink_if_modified=\"1\" />\n"
5722 " </Hints>\n"
5723 " </DoubleVectorProperty>\n"
5724 " <DoubleVectorProperty animateable=\"0\"\n"
5725 " command=\"SetBackgroundColor\"\n"
5726 " default_values=\"1 1 1\"\n"
5727 " name=\"SecondaryProgressBarColor\"\n"
5728 " panel_widget=\"color_selector_with_palette\"\n"
5729 " number_of_elements=\"3\">\n"
5730 " <DoubleRangeDomain max=\"1 1 1\"\n"
5731 " min=\"0 0 0\"\n"
5732 " name=\"range\" />\n"
5733 " <Hints>\n"
5734 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
5735 " unlink_if_modified=\"1\" />\n"
5736 " </Hints>\n"
5737 " </DoubleVectorProperty>\n"
5738 " <IntVectorProperty animateable=\"1\"\n"
5739 " command=\"SetDrawBackground\"\n"
5740 " default_values=\"0\"\n"
5741 " name=\"DrawBackground\"\n"
5742 " number_of_elements=\"1\">\n"
5743 " <BooleanDomain name=\"bool\" />\n"
5744 " </IntVectorProperty>\n"
5745 " </Proxy>\n"
5746 " <!-- ================================================================== -->\n"
5747 " <Proxy class=\"vtkLogoRepresentation\"\n"
5748 " name=\"LogoRepresentation\">\n"
5749 " <IntVectorProperty animateable=\"1\"\n"
5750 " command=\"SetVisibility\"\n"
5751 " default_values=\"1\"\n"
5752 " name=\"Visibility\"\n"
5753 " number_of_elements=\"1\">\n"
5754 " <BooleanDomain name=\"bool\" />\n"
5755 " </IntVectorProperty>\n"
5756 " <DoubleVectorProperty command=\"SetPosition\"\n"
5757 " default_values=\"0.02 0.02\"\n"
5758 " information_property=\"PositionInfo\"\n"
5759 " name=\"Position\"\n"
5760 " number_of_elements=\"2\">\n"
5761 " <DoubleRangeDomain max=\"1 1\"\n"
5762 " min=\"0 0\"\n"
5763 " name=\"range\" />\n"
5764 " </DoubleVectorProperty>\n"
5765 " <DoubleVectorProperty command=\"GetPosition\"\n"
5766 " information_only=\"1\"\n"
5767 " name=\"PositionInfo\">\n"
5768 " <SimpleDoubleInformationHelper />\n"
5769 " </DoubleVectorProperty>\n"
5770 " <DoubleVectorProperty command=\"SetPosition2\"\n"
5771 " default_values=\"0.08 0.08\"\n"
5772 " information_property=\"Position2Info\"\n"
5773 " name=\"Position2\"\n"
5774 " number_of_elements=\"2\">\n"
5775 " <DoubleRangeDomain max=\"1 1\"\n"
5776 " min=\"0 0\"\n"
5777 " name=\"range\" />\n"
5778 " </DoubleVectorProperty>\n"
5779 " <DoubleVectorProperty command=\"GetPosition2\"\n"
5780 " information_only=\"1\"\n"
5781 " name=\"Position2Info\">\n"
5782 " <SimpleDoubleInformationHelper />\n"
5783 " </DoubleVectorProperty>\n"
5784 " <IntVectorProperty animateable=\"0\"\n"
5785 " command=\"SetWindowLocation\"\n"
5786 " default_values=\"0\"\n"
5787 " name=\"WindowLocation\"\n"
5788 " number_of_elements=\"1\">\n"
5789 " <EnumerationDomain name=\"enum\">\n"
5790 " <Entry text=\"Any Location\"\n"
5791 " value=\"0\" />\n"
5792 " <Entry text=\"Lower Left Corner\"\n"
5793 " value=\"1\" />\n"
5794 " <Entry text=\"Lower Right Corner\"\n"
5795 " value=\"2\" />\n"
5796 " <Entry text=\"Lower Center\"\n"
5797 " value=\"3\" />\n"
5798 " <Entry text=\"Upper Left Corner\"\n"
5799 " value=\"4\" />\n"
5800 " <Entry text=\"Upper Right Corner\"\n"
5801 " value=\"5\" />\n"
5802 " <Entry text=\"Upper Center\"\n"
5803 " value=\"6\" />\n"
5804 " </EnumerationDomain>\n"
5805 " </IntVectorProperty>\n"
5806 " <IntVectorProperty command=\"SetShowBorder\"\n"
5807 " default_values=\"2\"\n"
5808 " name=\"ShowBorder\"\n"
5809 " number_of_elements=\"1\">\n"
5810 " <EnumerationDomain name=\"enum\">\n"
5811 " <Entry text=\"Never\"\n"
5812 " value=\"0\" />\n"
5813 " <Entry text=\"Always\"\n"
5814 " value=\"1\" />\n"
5815 " <Entry text=\"On Hover\"\n"
5816 " value=\"2\" />\n"
5817 " </EnumerationDomain>\n"
5818 " </IntVectorProperty>\n"
5819 " <DoubleVectorProperty command=\"SetBorderThickness\"\n"
5820 " default_values=\"1\"\n"
5821 " name=\"BorderThickness\"\n"
5822 " number_of_elements=\"1\">\n"
5823 " <DoubleRangeDomain min=\"1\"\n"
5824 " name=\"range\" />\n"
5825 " </DoubleVectorProperty>\n"
5826 " <DoubleVectorProperty command=\"SetBorderColor\"\n"
5827 " default_values=\"1 1 1\"\n"
5828 " name=\"BorderColor\"\n"
5829 " number_of_elements=\"3\">\n"
5830 " <DoubleRangeDomain max=\"1 1 1\"\n"
5831 " min=\"0 0 0\"\n"
5832 " name=\"range\" />\n"
5833 " </DoubleVectorProperty>\n"
5834 " </Proxy>\n"
5835 " </ProxyGroup>\n"
5836 " <!-- ****************************************************************** -->\n"
5837 " <ProxyGroup name=\"3d_widgets\">\n"
5838 " <Proxy name=\"WidgetBase\">\n"
5839 " <Documentation>Base API definition for all 3D widgets.</Documentation>\n"
5840 " <ProxyProperty command=\"SetRepresentation\"\n"
5841 " name=\"Representation\">\n"
5842 " <ProxyGroupDomain name=\"groups\">\n"
5843 " <Group name=\"props\" />\n"
5844 " </ProxyGroupDomain>\n"
5845 " </ProxyProperty>\n"
5846 " <IntVectorProperty command=\"SetEnabled\"\n"
5847 " default_values=\"0\"\n"
5848 " name=\"Enabled\"\n"
5849 " number_of_elements=\"1\">\n"
5850 " <BooleanDomain name=\"bool\" />\n"
5851 " </IntVectorProperty>\n"
5852 " <!-- End of WidgetBase -->\n"
5853 " </Proxy>\n"
5854 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5855 " base_proxyname=\"WidgetBase\"\n"
5856 " class=\"vtkSliderWidget\"\n"
5857 " name=\"SliderWidget\"></Proxy>\n"
5858 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5859 " base_proxyname=\"WidgetBase\"\n"
5860 " class=\"vtkHandleWidget\"\n"
5861 " name=\"HandleWidget\"></Proxy>\n"
5862 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5863 " base_proxyname=\"WidgetBase\"\n"
5864 " class=\"vtkLightWidget\"\n"
5865 " name=\"LightWidget\"></Proxy>\n"
5866 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5867 " base_proxyname=\"WidgetBase\"\n"
5868 " class=\"vtkLineWidget2\"\n"
5869 " name=\"LineWidget2\">\n"
5870 " <IntVectorProperty command=\"SetProcessEvents\"\n"
5871 " default_values=\"1\"\n"
5872 " name=\"ProcessEvents\"\n"
5873 " number_of_elements=\"1\">\n"
5874 " <BooleanDomain name=\"bool\" />\n"
5875 " </IntVectorProperty>\n"
5876 " </Proxy>\n"
5877 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5878 " base_proxyname=\"WidgetBase\"\n"
5879 " class=\"vtkDistanceWidget\"\n"
5880 " name=\"DistanceWidget\"\n"
5881 " post_creation=\"SetWidgetStateToManipulate\">\n"
5882 " <IntVectorProperty command=\"SetProcessEvents\"\n"
5883 " default_values=\"1\"\n"
5884 " name=\"ProcessEvents\"\n"
5885 " number_of_elements=\"1\">\n"
5886 " <BooleanDomain name=\"bool\" />\n"
5887 " </IntVectorProperty>\n"
5888 " </Proxy>\n"
5889 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5890 " base_proxyname=\"WidgetBase\"\n"
5891 " class=\"vtkImplicitPlaneWidget2\"\n"
5892 " name=\"ImplicitPlaneWidget2\"></Proxy>\n"
5893 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5894 " base_proxyname=\"WidgetBase\"\n"
5895 " class=\"vtkDisplaySizedImplicitPlaneWidget\"\n"
5896 " name=\"DisplaySizedImplicitPlaneWidget\"></Proxy>\n"
5897 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5898 " base_proxyname=\"WidgetBase\"\n"
5899 " class=\"vtkCoordinateFrameWidget\"\n"
5900 " name=\"CoordinateFrameWidget\"></Proxy>\n"
5901 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5902 " base_proxyname=\"WidgetBase\"\n"
5903 " class=\"vtkSplineWidget2\"\n"
5904 " name=\"SplineWidget2\"></Proxy>\n"
5905 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5906 " base_proxyname=\"WidgetBase\"\n"
5907 " class=\"vtkPolyLineWidget\"\n"
5908 " name=\"PolyLineWidget\"></Proxy>\n"
5909 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5910 " base_proxyname=\"WidgetBase\"\n"
5911 " class=\"vtkContourWidget\"\n"
5912 " name=\"ContourWidget\">\n"
5913 " <Property command=\"CloseLoop\"\n"
5914 " name=\"CloseLoop\" />\n"
5915 " <Property command=\"Initialize\"\n"
5916 " name=\"Initialize\" />\n"
5917 " <IntVectorProperty command=\"SetWidgetState\"\n"
5918 " default_values=\"1\"\n"
5919 " information_property=\"WidgetStateInfo\"\n"
5920 " name=\"WidgetState\"\n"
5921 " number_of_elements=\"1\"></IntVectorProperty>\n"
5922 " <IntVectorProperty command=\"GetWidgetState\"\n"
5923 " information_only=\"1\"\n"
5924 " name=\"WidgetStateInfo\"></IntVectorProperty>\n"
5925 " <IntVectorProperty command=\"SetAllowNodePicking\"\n"
5926 " default_values=\"1\"\n"
5927 " name=\"AllowNodePicking\"\n"
5928 " number_of_elements=\"1\">\n"
5929 " <BooleanDomain name=\"bool\" />\n"
5930 " </IntVectorProperty>\n"
5931 " <IntVectorProperty command=\"SetProcessEvents\"\n"
5932 " default_values=\"1\"\n"
5933 " name=\"ProcessEvents\"\n"
5934 " number_of_elements=\"1\">\n"
5935 " <BooleanDomain name=\"bool\" />\n"
5936 " </IntVectorProperty>\n"
5937 " </Proxy>\n"
5938 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5939 " base_proxyname=\"WidgetBase\"\n"
5940 " class=\"vtkScalarBarWidget\"\n"
5941 " name=\"ScalarBarWidget\">\n"
5942 " <IntVectorProperty command=\"SetSelectable\"\n"
5943 " default_values=\"0\"\n"
5944 " name=\"Selectable\"\n"
5945 " number_of_elements=\"1\">\n"
5946 " <BooleanDomain name=\"bool\" />\n"
5947 " </IntVectorProperty>\n"
5948 " <IntVectorProperty animateable=\"0\"\n"
5949 " command=\"SetResizable\"\n"
5950 " default_values=\"1\"\n"
5951 " name=\"Resizable\"\n"
5952 " number_of_elements=\"1\">\n"
5953 " <BooleanDomain name=\"bool\" />\n"
5954 " </IntVectorProperty>\n"
5955 " <IntVectorProperty animateable=\"0\"\n"
5956 " command=\"SetRepositionable\"\n"
5957 " default_values=\"1\"\n"
5958 " name=\"Repositionable\"\n"
5959 " number_of_elements=\"1\">\n"
5960 " <BooleanDomain name=\"bool\" />\n"
5961 " </IntVectorProperty>\n"
5962 " <!-- End of ScalarBarWidget -->\n"
5963 " </Proxy>\n"
5964 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5965 " base_proxyname=\"WidgetBase\"\n"
5966 " class=\"vtkTextWidget\"\n"
5967 " name=\"TextWidget\">\n"
5968 " <IntVectorProperty command=\"SetSelectable\"\n"
5969 " default_values=\"0\"\n"
5970 " name=\"Selectable\"\n"
5971 " number_of_elements=\"1\">\n"
5972 " <BooleanDomain name=\"bool\" />\n"
5973 " </IntVectorProperty>\n"
5974 " <IntVectorProperty animateable=\"0\"\n"
5975 " command=\"SetResizable\"\n"
5976 " default_values=\"0\"\n"
5977 " name=\"Resizable\"\n"
5978 " number_of_elements=\"1\">\n"
5979 " <BooleanDomain name=\"bool\" />\n"
5980 " </IntVectorProperty>\n"
5981 " <IntVectorProperty command=\"SetProcessEvents\"\n"
5982 " default_values=\"1\"\n"
5983 " name=\"ProcessEvents\"\n"
5984 " number_of_elements=\"1\">\n"
5985 " <BooleanDomain name=\"bool\" />\n"
5986 " </IntVectorProperty>\n"
5987 " <!-- End of TextWidget -->\n"
5988 " </Proxy>\n"
5989 " <Proxy base_proxygroup=\"3d_widgets\"\n"
5990 " base_proxyname=\"WidgetBase\"\n"
5991 " class=\"vtkProgressBarWidget\"\n"
5992 " name=\"ProgressBarWidget\">\n"
5993 " <IntVectorProperty command=\"SetSelectable\"\n"
5994 " default_values=\"0\"\n"
5995 " name=\"Selectable\"\n"
5996 " number_of_elements=\"1\">\n"
5997 " <BooleanDomain name=\"bool\" />\n"
5998 " </IntVectorProperty>\n"
5999 " <IntVectorProperty animateable=\"0\"\n"
6000 " command=\"SetResizable\"\n"
6001 " default_values=\"1\"\n"
6002 " name=\"Resizable\"\n"
6003 " number_of_elements=\"1\">\n"
6004 " <BooleanDomain name=\"bool\" />\n"
6005 " </IntVectorProperty>\n"
6006 " <IntVectorProperty command=\"SetProcessEvents\"\n"
6007 " default_values=\"1\"\n"
6008 " name=\"ProcessEvents\"\n"
6009 " number_of_elements=\"1\">\n"
6010 " <BooleanDomain name=\"bool\" />\n"
6011 " </IntVectorProperty>\n"
6012 " <!-- End of ProgressBarWidget -->\n"
6013 " </Proxy>\n"
6014 " <Proxy base_proxygroup=\"3d_widgets\"\n"
6015 " base_proxyname=\"WidgetBase\"\n"
6016 " class=\"vtkLogoWidget\"\n"
6017 " name=\"LogoWidget\">\n"
6018 " <IntVectorProperty command=\"SetSelectable\"\n"
6019 " default_values=\"0\"\n"
6020 " name=\"Selectable\"\n"
6021 " number_of_elements=\"1\">\n"
6022 ;
6023
6024 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/3dwidgets_remotingviews.xml
6026 " <BooleanDomain name=\"bool\" />\n"
6027 " </IntVectorProperty>\n"
6028 " <IntVectorProperty animateable=\"0\"\n"
6029 " command=\"SetResizable\"\n"
6030 " default_values=\"1\"\n"
6031 " name=\"Resizable\"\n"
6032 " number_of_elements=\"1\">\n"
6033 " <BooleanDomain name=\"bool\" />\n"
6034 " </IntVectorProperty>\n"
6035 " <IntVectorProperty command=\"SetProcessEvents\"\n"
6036 " default_values=\"1\"\n"
6037 " name=\"ProcessEvents\"\n"
6038 " number_of_elements=\"1\">\n"
6039 " <BooleanDomain name=\"bool\" />\n"
6040 " </IntVectorProperty>\n"
6041 " <!-- End of LogoWidget -->\n"
6042 " </Proxy>\n"
6043 " <Proxy base_proxygroup=\"3d_widgets\"\n"
6044 " base_proxyname=\"WidgetBase\"\n"
6045 " class=\"vtkBoxWidget2\"\n"
6046 " name=\"BoxWidget2\">\n"
6047 " <Documentation>Proxy for vtkBoxWidget2.</Documentation>\n"
6048 " <IntVectorProperty command=\"SetTranslationEnabled\"\n"
6049 " default_values=\"1\"\n"
6050 " name=\"TranslationEnabled\"\n"
6051 " number_of_elements=\"1\">\n"
6052 " <BooleanDomain name=\"bool\" />\n"
6053 " <Documentation>Set whether to allow this 3D widget to be interactively\n"
6054 " translated.</Documentation>\n"
6055 " </IntVectorProperty>\n"
6056 " <IntVectorProperty command=\"SetScalingEnabled\"\n"
6057 " default_values=\"1\"\n"
6058 " name=\"ScalingEnabled\"\n"
6059 " number_of_elements=\"1\">\n"
6060 " <BooleanDomain name=\"bool\" />\n"
6061 " <Documentation>Set whether to allow this 3D widget to be interactively\n"
6062 " sclaed.</Documentation>\n"
6063 " </IntVectorProperty>\n"
6064 " <IntVectorProperty command=\"SetRotationEnabled\"\n"
6065 " default_values=\"1\"\n"
6066 " name=\"RotationEnabled\"\n"
6067 " number_of_elements=\"1\">\n"
6068 " <BooleanDomain name=\"bool\" />\n"
6069 " <Documentation>Set whether to allow this 3D widget to be interactively\n"
6070 " rotated.</Documentation>\n"
6071 " </IntVectorProperty>\n"
6072 " <IntVectorProperty command=\"SetMoveFacesEnabled\"\n"
6073 " default_values=\"1\"\n"
6074 " name=\"MoveFacesEnabled\"\n"
6075 " number_of_elements=\"1\">\n"
6076 " <BooleanDomain name=\"bool\" />\n"
6077 " <Documentation>Set whether to allow interactive face movement to be\n"
6078 " performed on this 3D widget.</Documentation>\n"
6079 " </IntVectorProperty>\n"
6080 " </Proxy>\n"
6081 " <Proxy base_proxygroup=\"3d_widgets\"\n"
6082 " base_proxyname=\"WidgetBase\"\n"
6083 " class=\"vtkSphereWidget2\"\n"
6084 " name=\"SphereWidget2\">\n"
6085 " <Documentation>Proxy for vtkSphereWidget2.</Documentation>\n"
6086 " </Proxy>\n"
6087 " <Proxy base_proxygroup=\"3d_widgets\"\n"
6088 " base_proxyname=\"WidgetBase\"\n"
6089 " class=\"vtkImplicitCylinderWidget\"\n"
6090 " name=\"ImplicitCylinderWidget\">\n"
6091 " <Documentation>Proxy for vtkImplicitCylinderWidget.</Documentation>\n"
6092 " </Proxy>\n"
6093 "\n"
6094 " <!-- End of ProxyGroup 3d_widgets -->\n"
6095 " </ProxyGroup>\n"
6096 "</ServerManagerConfiguration>\n"
6097 "\n";
6098 // Get single string
6100 {
6101
6112  size_t len = ( 0
6113  + len0
6114  + len1
6115  + len2
6116  + len3
6117  + len4
6118  + len5
6119  + len6
6120  + len7
6121  + len8
6122  + len9 );
6123  char* res = new char[ len + 1];
6124  size_t offset = 0;
6135  assert(offset == len);
6136  res[offset] = 0;
6137  return res;
6138 }
6139
6140
6141 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/extractors_remotingviews.xml
6143 "<ServerManagerConfiguration>\n"
6144 " <ProxyGroup name=\"extract_writers\">\n"
6145 " <!-- =================================================================== -->\n"
6146 " <ImageExtractWriterProxy name=\"PNG\">\n"
6147 " <StringVectorProperty name=\"FileName\" number_of_elements=\"1\" default_values=\"{prefix}_{timestep:06d}{camera}.png\">\n"
6148 " <Documentation>\n"
6149 " Specify the filename to use.\n"
6150 " </Documentation>\n"
6151 " </StringVectorProperty>\n"
6152 "\n"
6153 " <SubProxy>\n"
6154 " <Proxy name=\"Writer\" proxygroup=\"misc\" proxyname=\"SaveScreenshot\" />\n"
6155 " <ExposedProperties>\n"
6156 " <Property name=\"View\" />\n"
6157 " <PropertyGroup label=\"Size and Scaling\">\n"
6158 " <Property name=\"ImageResolution\" />\n"
6159 " <Property name=\"FontScaling\" />\n"
6160 " </PropertyGroup>\n"
6161 " <PropertyGroup label=\"Coloring\">\n"
6162 " <Property name=\"OverrideColorPalette\" panel_visibility=\"advanced\" />\n"
6163 " <Property name=\"StereoMode\" panel_visibility=\"advanced\" />\n"
6164 " <Property name=\"TransparentBackground\" panel_visibility=\"advanced\" />\n"
6165 " </PropertyGroup>\n"
6166 " <PropertyGroup label=\"Image Options\">\n"
6167 " <Property name=\"Format\" panel_visibility=\"advanced\" />\n"
6168 " </PropertyGroup>\n"
6169 " </ExposedProperties>\n"
6170 " </SubProxy>\n"
6171 "\n"
6172 " <IntVectorProperty name=\"ResetDisplay\"\n"
6173 " number_of_elements=\"1\"\n"
6174 " default_values=\"0\">\n"
6175 " <BooleanDomain name=\"bool\" />\n"
6176 " <Documentation>\n"
6177 " When set, the camera (or viewport) will be reset to ensure all data\n"
6178 " is visible.\n"
6179 " </Documentation>\n"
6180 " </IntVectorProperty>\n"
6181 "\n"
6182 " <IntVectorProperty name=\"CameraMode\"\n"
6183 " number_of_elements=\"1\"\n"
6184 " default_values=\"0\">\n"
6185 " <Documentation>\n"
6186 " Select whether to the camera should be moved in the the scence to generate\n"
6187 " images from multiple view points. Default is **Static** which means the camera\n"
6188 " is not moved. Another option is **Phi-Theta** which results in moving the camera\n"
6189 " around the focal point over a sphere of radius equal to the focal distance.\n"
6190 " This is only applicable for views that have a camera i.e. does not apply to\n"
6191 " chart views and other 2D plotting views.\n"
6192 " </Documentation>\n"
6193 " <EnumerationDomain name=\"enum\">\n"
6194 " <Entry value=\"0\" text=\"Static\" />\n"
6195 " <Entry value=\"1\" text=\"Phi-Theta\" />\n"
6196 " </EnumerationDomain>\n"
6197 " </IntVectorProperty>\n"
6198 "\n"
6199 " <IntVectorProperty name=\"PhiResolution\"\n"
6200 " number_of_elements=\"1\"\n"
6201 " default_values=\"6\" >\n"
6202 " <IntRangeDomain name=\"range\" min=\"1\" max=\"360\" />\n"
6203 " <Documentation>\n"
6204 " Number of samples along the phi direction.\n"
6205 " </Documentation>\n"
6206 " <Hints>\n"
6207 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraMode\" value=\"1\" />\n"
6208 " </Hints>\n"
6209 " </IntVectorProperty>\n"
6210 "\n"
6211 " <IntVectorProperty name=\"ThetaResolution\"\n"
6212 " number_of_elements=\"1\"\n"
6213 " default_values=\"6\" >\n"
6214 " <IntRangeDomain name=\"range\" min=\"1\" max=\"360\" />\n"
6215 " <Documentation>\n"
6216 " Number of samples along the theta direction.\n"
6217 " </Documentation>\n"
6218 " <Hints>\n"
6219 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraMode\" value=\"1\" />\n"
6220 " </Hints>\n"
6221 " </IntVectorProperty>\n"
6222 "\n"
6223 " <PropertyGroup label=\"Miscellaneous\">\n"
6224 " <Property name=\"ResetDisplay\" />\n"
6225 " <Property name=\"CameraMode\" />\n"
6226 " <Property name=\"PhiResolution\" />\n"
6227 " <Property name=\"ThetaResolution\" />\n"
6228 " </PropertyGroup>\n"
6229 "\n"
6230 " <Hints>\n"
6231 " <ShowInMenu category=\"Image\" />\n"
6232 " </Hints>\n"
6233 " </ImageExtractWriterProxy>\n"
6234 "\n"
6235 " <!-- =================================================================== -->\n"
6236 " <ImageExtractWriterProxy name=\"JPG\">\n"
6237 " <StringVectorProperty name=\"FileName\" number_of_elements=\"1\" default_values=\"{prefix}_{timestep:06d}{camera}.jpg\">\n"
6238 " <Documentation>\n"
6239 " Specify the filename to use.\n"
6240 " </Documentation>\n"
6241 " </StringVectorProperty>\n"
6242 "\n"
6243 " <SubProxy>\n"
6244 " <Proxy name=\"Writer\" proxygroup=\"misc\" proxyname=\"SaveScreenshot\" />\n"
6245 " <ExposedProperties>\n"
6246 " <Property name=\"View\" />\n"
6247 " <PropertyGroup label=\"Size and Scaling\">\n"
6248 " <Property name=\"ImageResolution\" />\n"
6249 " <Property name=\"FontScaling\" />\n"
6250 " </PropertyGroup>\n"
6251 " <PropertyGroup label=\"Coloring\">\n"
6252 " <Property name=\"OverrideColorPalette\" panel_visibility=\"advanced\" />\n"
6253 " <Property name=\"StereoMode\" panel_visibility=\"advanced\" />\n"
6254 " <Property name=\"TransparentBackground\" panel_visibility=\"advanced\" />\n"
6255 " </PropertyGroup>\n"
6256 " <PropertyGroup label=\"Image Options\">\n"
6257 " <Property name=\"Format\" panel_visibility=\"advanced\" />\n"
6258 " </PropertyGroup>\n"
6259 " </ExposedProperties>\n"
6260 " </SubProxy>\n"
6261 "\n"
6262 " <IntVectorProperty name=\"ResetDisplay\"\n"
6263 " number_of_elements=\"1\"\n"
6264 " default_values=\"0\">\n"
6265 " <BooleanDomain name=\"bool\" />\n"
6266 " <Documentation>\n"
6267 " When set, the camera (or viewport) will be reset to ensure all data\n"
6268 " is visible.\n"
6269 " </Documentation>\n"
6270 " </IntVectorProperty>\n"
6271 "\n"
6272 " <IntVectorProperty name=\"CameraMode\"\n"
6273 " number_of_elements=\"1\"\n"
6274 " default_values=\"0\">\n"
6275 " <Documentation>\n"
6276 " Select whether to the camera should be moved in the the scence to generate\n"
6277 " images from multiple view points. Default is **Static** which means the camera\n"
6278 " is not moved. Another option is **Phi-Theta** which results in moving the camera\n"
6279 " around the focal point over a sphere of radius equal to the focal distance.\n"
6280 " This is only applicable for views that have a camera i.e. does not apply to\n"
6281 " chart views and other 2D plotting views.\n"
6282 " </Documentation>\n"
6283 " <EnumerationDomain name=\"enum\">\n"
6284 " <Entry value=\"0\" text=\"Static\" />\n"
6285 " <Entry value=\"1\" text=\"Phi-Theta\" />\n"
6286 " </EnumerationDomain>\n"
6287 " </IntVectorProperty>\n"
6288 "\n"
6289 " <IntVectorProperty name=\"PhiResolution\"\n"
6290 " number_of_elements=\"1\"\n"
6291 " default_values=\"6\" >\n"
6292 " <IntRangeDomain name=\"range\" min=\"1\" max=\"360\" />\n"
6293 " <Documentation>\n"
6294 " Number of samples along the phi direction.\n"
6295 " </Documentation>\n"
6296 " <Hints>\n"
6297 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraMode\" value=\"1\" />\n"
6298 " </Hints>\n"
6299 " </IntVectorProperty>\n"
6300 "\n"
6301 " <IntVectorProperty name=\"ThetaResolution\"\n"
6302 " number_of_elements=\"1\"\n"
6303 " default_values=\"6\" >\n"
6304 " <IntRangeDomain name=\"range\" min=\"1\" max=\"360\" />\n"
6305 " <Documentation>\n"
6306 " Number of samples along the theta direction.\n"
6307 " </Documentation>\n"
6308 " <Hints>\n"
6309 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraMode\" value=\"1\" />\n"
6310 " </Hints>\n"
6311 " </IntVectorProperty>\n"
6312 "\n"
6313 " <PropertyGroup label=\"Miscellaneous\">\n"
6314 " <Property name=\"ResetDisplay\" />\n"
6315 " <Property name=\"CameraMode\" />\n"
6316 " <Property name=\"PhiResolution\" />\n"
6317 " <Property name=\"ThetaResolution\" />\n"
6318 " </PropertyGroup>\n"
6319 "\n"
6320 " <Hints>\n"
6321 " <ShowInMenu category=\"Image\" />\n"
6322 " </Hints>\n"
6323 " </ImageExtractWriterProxy>\n"
6324 "\n"
6325 " <!-- =================================================================== -->\n"
6326 " <CinemaVolumetricImageExtractWriterProxy name=\"CinemaVolumetricPNG\"\n"
6327 " label=\"Cinema-Volumetric PNG\"\n"
6328 " base_proxygroup=\"extract_writers\"\n"
6329 " base_proxyname=\"PNG\">\n"
6330 "\n"
6331 " <IntVectorProperty name=\"OpacityLevels\"\n"
6332 " number_of_elements=\"1\"\n"
6333 " default_values=\"1\">\n"
6334 " <Documentation>\n"
6335 " Specify the number of opacity levels.\n"
6336 " </Documentation>\n"
6337 " <IntRangeDomain name=\"range\" min=\"1\" max=\"5\" />\n"
6338 " </IntVectorProperty>\n"
6339 "\n"
6340 " <IntVectorProperty name=\"Functions\"\n"
6341 " number_of_elements=\"1\"\n"
6342 " default_values=\"5\">\n"
6343 " <IntRangeDomain name=\"range\" min=\"2\" max=\"20\" />\n"
6344 " <Documentation>\n"
6345 " Number of functions.\n"
6346 " </Documentation>\n"
6347 " </IntVectorProperty>\n"
6348 "\n"
6349 " <IntVectorProperty name=\"SingleFunctionOnly\"\n"
6350 " number_of_elements=\"1\"\n"
6351 " default_values=\"0\">\n"
6352 " <BooleanDomain name=\"bool\" />\n"
6353 " <Documentation>\n"
6354 " Have only 1 function active at a time.\n"
6355 " </Documentation>\n"
6356 " </IntVectorProperty>\n"
6357 "\n"
6358 " <IntVectorProperty name=\"MaximumNumberOfFunctions\"\n"
6359 " number_of_elements=\"1\"\n"
6360 " default_values=\"4\">\n"
6361 " <Documentation>\n"
6362 " Maximum number of active functions at a time.\n"
6363 " and single function only is disabled.\n"
6364 " </Documentation>\n"
6365 " <IntRangeDomain name=\"range\" min=\"1\" max=\"64\" />\n"
6366 " <Hints>\n"
6367 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
6368 " <Expression type=\"and\">\n"
6369 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SingleFunctionOnly\" value=\"0\" />\n"
6370 " </Expression>\n"
6371 " </PropertyWidgetDecorator>\n"
6372 " </Hints>\n"
6373 " </IntVectorProperty>\n"
6374 "\n"
6375 " <DoubleVectorProperty name=\"MaximumOpacityValue\"\n"
6376 " number_of_elements=\"1\"\n"
6377 " default_values=\"1\">\n"
6378 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"1\" />\n"
6379 " <Documentation>\n"
6380 " The maximum opacity value.\n"
6381 " </Documentation>\n"
6382 " </DoubleVectorProperty>\n"
6383 "\n"
6384 " <IntVectorProperty name=\"SpecifiedRange\"\n"
6385 " number_of_elements=\"1\"\n"
6386 " default_values=\"0\">\n"
6387 " <BooleanDomain name=\"bool\" />\n"
6388 " <Documentation>\n"
6389 " Use a specified field range as the range for the LUT.\n"
6390 " </Documentation>\n"
6391 " </IntVectorProperty>\n"
6392 "\n"
6393 " <DoubleVectorProperty name=\"Range\"\n"
6394 " default_values=\"none\"\n"
6395 " number_of_elements=\"2\">\n"
6396 " <Documentation>\n"
6397 " A user defined range for the LUT. Only meaningful if volume rendering and specified range are enabled.\n"
6398 " </Documentation>\n"
6399 " <Hints>\n"
6400 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
6401 " <Expression type=\"and\">\n"
6402 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SpecifiedRange\" value=\"1\" />\n"
6403 " </Expression>\n"
6404 " </PropertyWidgetDecorator>\n"
6405 " </Hints>\n"
6406 " </DoubleVectorProperty>\n"
6407 "\n"
6408 " <IntVectorProperty name=\"ExportTransferFunctions\"\n"
6409 " number_of_elements=\"1\"\n"
6410 " default_values=\"0\">\n"
6411 " <BooleanDomain name=\"bool\" />\n"
6412 " <Documentation>\n"
6413 " Export the transfer functions to JSON files.\n"
6414 " </Documentation>\n"
6415 " </IntVectorProperty>\n"
6416 "\n"
6417 " <Hints>\n"
6418 " <ShowInMenu category=\"Experimental\" />\n"
6419 " </Hints>\n"
6420 " <!-- end of CinemaVolumetricPNG -->\n"
6421 " </CinemaVolumetricImageExtractWriterProxy>\n"
6422 "\n"
6423 " <!-- =================================================================== -->\n"
6424 " <RecolorableImageExtractWriterProxy name=\"RecolorableImage\"\n"
6425 " label=\"Recolorable Image\">\n"
6426 " <StringVectorProperty name=\"FileName\" number_of_elements=\"1\" default_values=\"{prefix}_{timestep:06d}{camera}.vtk\">\n"
6427 " <Documentation>\n"
6428 " Specify the filename to use.\n"
6429 " </Documentation>\n"
6430 " </StringVectorProperty>\n"
6431 "\n"
6432 " <SubProxy>\n"
6433 " <Proxy name=\"Writer\" proxygroup=\"misc\" proxyname=\"SaveScreenshot\" />\n"
6434 " <ExposedProperties>\n"
6435 " <Property name=\"View\" />\n"
6436 " <PropertyGroup label=\"Size and Scaling\">\n"
6437 " <Property name=\"ImageResolution\" />\n"
6438 " </PropertyGroup>\n"
6439 " <PropertyGroup label=\"Image Options\">\n"
6440 " <Property name=\"Format\" panel_visibility=\"advanced\" />\n"
6441 " </PropertyGroup>\n"
6442 " </ExposedProperties>\n"
6443 " </SubProxy>\n"
6444 "\n"
6445 " <InputProperty name=\"DataSource\"\n"
6446 " panel_widget=\"input_selector\"\n"
6447 " panel_visibility=\"default\">\n"
6448 " <ProxyGroupDomain name=\"groups\">\n"
6449 " <Group name=\"sources\" />\n"
6450 " </ProxyGroupDomain>\n"
6451 " <Documentation>\n"
6452 " Select the primary data producer data values from which are used to generate\n"
6453 " the recolorable image.\n"
6454 " </Documentation>\n"
6455 " </InputProperty>\n"
6456 "\n"
6457 " <PropertyGroup label=\"Recolorable Image Parameters\">\n"
6458 " <Property name=\"DataSource\" />\n"
6459 " </PropertyGroup>\n"
6460 "\n"
6461 " <IntVectorProperty name=\"ResetDisplay\"\n"
6462 " number_of_elements=\"1\"\n"
6463 " default_values=\"0\">\n"
6464 " <BooleanDomain name=\"bool\" />\n"
6465 " <Documentation>\n"
6466 " When set, the camera (or viewport) will be reset to ensure all data\n"
6467 " is visible.\n"
6468 " </Documentation>\n"
6469 " </IntVectorProperty>\n"
6470 "\n"
6471 " <IntVectorProperty name=\"CameraMode\"\n"
6472 " number_of_elements=\"1\"\n"
6473 " default_values=\"0\">\n"
6474 " <Documentation>\n"
6475 " Select whether to the camera should be moved in the the scence to generate\n"
6476 " images from multiple view points. Default is **Static** which means the camera\n"
6477 " is not moved. Another option is **Phi-Theta** which results in moving the camera\n"
6478 " around the focal point over a sphere of radius equal to the focal distance.\n"
6479 " This is only applicable for views that have a camera i.e. does not apply to\n"
6480 " chart views and other 2D plotting views.\n"
6481 " </Documentation>\n"
6482 " <EnumerationDomain name=\"enum\">\n"
6483 " <Entry value=\"0\" text=\"Static\" />\n"
6484 " <Entry value=\"1\" text=\"Phi-Theta\" />\n"
6485 " </EnumerationDomain>\n"
6486 " </IntVectorProperty>\n"
6487 "\n"
6488 " <IntVectorProperty name=\"PhiResolution\"\n"
6489 " number_of_elements=\"1\"\n"
6490 " default_values=\"6\" >\n"
6491 " <IntRangeDomain name=\"range\" min=\"1\" max=\"360\" />\n"
6492 " <Documentation>\n"
6493 " Number of samples along the phi direction.\n"
6494 " </Documentation>\n"
6495 " <Hints>\n"
6496 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraMode\" value=\"1\" />\n"
6497 " </Hints>\n"
6498 " </IntVectorProperty>\n"
6499 "\n"
6500 " <IntVectorProperty name=\"ThetaResolution\"\n"
6501 " number_of_elements=\"1\"\n"
6502 " default_values=\"6\" >\n"
6503 " <IntRangeDomain name=\"range\" min=\"1\" max=\"360\" />\n"
6504 ;
6505
6506 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/extractors_remotingviews.xml
6508 " <Documentation>\n"
6509 " Number of samples along the theta direction.\n"
6510 " </Documentation>\n"
6511 " <Hints>\n"
6512 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraMode\" value=\"1\" />\n"
6513 " </Hints>\n"
6514 " </IntVectorProperty>\n"
6515 "\n"
6516 " <PropertyGroup label=\"Miscellaneous\">\n"
6517 " <Property name=\"ResetDisplay\" />\n"
6518 " <Property name=\"CameraMode\" />\n"
6519 " <Property name=\"PhiResolution\" />\n"
6520 " <Property name=\"ThetaResolution\" />\n"
6521 " </PropertyGroup>\n"
6522 "\n"
6523 " <Hints>\n"
6524 " <ShowInMenu category=\"Experimental\" />\n"
6525 " </Hints>\n"
6526 "\n"
6527 " <!-- end of RecolorableImage -->\n"
6528 " </RecolorableImageExtractWriterProxy>\n"
6529 "\n"
6530 " <!-- end of 'extract_writers' -->\n"
6531 " </ProxyGroup>\n"
6532 "</ServerManagerConfiguration>\n"
6533 "\n";
6534 // Get single string
6536 {
6537
6540  size_t len = ( 0
6541  + len0
6542  + len1 );
6543  char* res = new char[ len + 1];
6544  size_t offset = 0;
6547  assert(offset == len);
6548  res[offset] = 0;
6549  return res;
6550 }
6551
6552
6553 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/extractors_json.xml
6555 "<ServerManagerConfiguration>\n"
6556 " <ProxyGroup name=\"extract_writers\">\n"
6557 " <!-- =================================================================== -->\n"
6558 " <PlotlyJsonExtractWriterProxy name=\"PlotlyJson\">\n"
6559 " <StringVectorProperty name=\"FileName\" number_of_elements=\"1\" default_values=\"{prefix}_{timestep:06d}.json\">\n"
6560 " <Documentation>\n"
6561 " Specify the filename to use.\n"
6562 " </Documentation>\n"
6563 " </StringVectorProperty>\n"
6564 " <ProxyProperty name=\"View\" panel_visibility=\"never\" />\n"
6565 " <Hints>\n"
6566 " <ShowInMenu category=\"Data\" />\n"
6567 " </Hints>\n"
6568 " </PlotlyJsonExtractWriterProxy>\n"
6569 " <!-- =================================================================== -->\n"
6570 " </ProxyGroup>\n"
6571 "</ServerManagerConfiguration>\n"
6572 "\n";
6573 // Get single string
6575 {
6576
6577  const size_t len0 = strlen(paraview_server_managerextractors_jsonInterface0);
6578  size_t len = ( 0
6579  + len0 );
6580  char* res = new char[ len + 1];
6581  size_t offset = 0;
6583  assert(offset == len);
6584  res[offset] = 0;
6585  return res;
6586 }
6587
6588
6589 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/rendering.xml
6591 "<ServerManagerConfiguration>\n"
6592 " <ProxyGroup name=\"camera\">\n"
6593 " <CameraProxy class=\"vtkCamera\"\n"
6594 " name=\"Camera\"\n"
6595 " processes=\"client\">\n"
6596 " <!-- |dataserver|renderserver -->\n"
6597 " <DoubleVectorProperty command=\"GetPosition\"\n"
6598 " default_values=\"0 0 6.69\"\n"
6599 " information_only=\"1\"\n"
6600 " name=\"CameraPositionInfo\"\n"
6601 " number_of_elements=\"3\">\n"
6602 " <SimpleDoubleInformationHelper />\n"
6603 " </DoubleVectorProperty>\n"
6604 " <DoubleVectorProperty command=\"SetPosition\"\n"
6605 " default_values=\"0 0 6.69\"\n"
6606 " ignore_synchronization=\"1\"\n"
6607 " immediate_update=\"1\"\n"
6608 " information_property=\"CameraPositionInfo\"\n"
6609 " name=\"CameraPosition\"\n"
6610 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
6611 " <DoubleVectorProperty command=\"GetFocalPoint\"\n"
6612 " default_values=\"0 0 0\"\n"
6613 " information_only=\"1\"\n"
6614 " name=\"CameraFocalPointInfo\"\n"
6615 " number_of_elements=\"3\">\n"
6616 " <SimpleDoubleInformationHelper />\n"
6617 " </DoubleVectorProperty>\n"
6618 " <DoubleVectorProperty command=\"SetFocalPoint\"\n"
6619 " default_values=\"0 0 0\"\n"
6620 " ignore_synchronization=\"1\"\n"
6621 " immediate_update=\"1\"\n"
6622 " information_property=\"CameraFocalPointInfo\"\n"
6623 " name=\"CameraFocalPoint\"\n"
6624 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
6625 " <DoubleVectorProperty command=\"GetFocalDisk\"\n"
6626 " default_values=\"1\"\n"
6627 " information_only=\"1\"\n"
6628 " name=\"CameraFocalDiskInfo\"\n"
6629 " number_of_elements=\"1\">\n"
6630 " <SimpleDoubleInformationHelper />\n"
6631 " </DoubleVectorProperty>\n"
6632 " <DoubleVectorProperty command=\"SetFocalDisk\"\n"
6633 " default_values=\"0\"\n"
6634 " ignore_synchronization=\"1\"\n"
6635 " immediate_update=\"1\"\n"
6636 " information_property=\"CameraFocalDiskInfo\"\n"
6637 " name=\"CameraFocalDisk\"\n"
6638 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
6639 " <DoubleVectorProperty command=\"GetFocalDistance\"\n"
6640 " default_values=\"0\"\n"
6641 " information_only=\"1\"\n"
6642 " name=\"CameraFocalDistanceInfo\"\n"
6643 " number_of_elements=\"1\">\n"
6644 " <SimpleDoubleInformationHelper />\n"
6645 " </DoubleVectorProperty>\n"
6646 " <DoubleVectorProperty command=\"SetFocalDistance\"\n"
6647 " default_values=\"0\"\n"
6648 " ignore_synchronization=\"1\"\n"
6649 " immediate_update=\"1\"\n"
6650 " information_property=\"CameraFocalDistanceInfo\"\n"
6651 " name=\"CameraFocalDistance\"\n"
6652 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
6653 " <DoubleVectorProperty command=\"GetViewUp\"\n"
6654 " default_values=\"0 1 0\"\n"
6655 " information_only=\"1\"\n"
6656 " name=\"CameraViewUpInfo\"\n"
6657 " number_of_elements=\"3\">\n"
6658 " <SimpleDoubleInformationHelper />\n"
6659 " </DoubleVectorProperty>\n"
6660 " <DoubleVectorProperty command=\"SetViewUp\"\n"
6661 " default_values=\"0 1 0\"\n"
6662 " ignore_synchronization=\"1\"\n"
6663 " immediate_update=\"1\"\n"
6664 " information_property=\"CameraViewUpInfo\"\n"
6665 " name=\"CameraViewUp\"\n"
6666 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
6667 " <DoubleVectorProperty command=\"GetViewAngle\"\n"
6668 " information_only=\"1\"\n"
6669 " name=\"CameraViewAngleInfo\">\n"
6670 " <SimpleDoubleInformationHelper />\n"
6671 " </DoubleVectorProperty>\n"
6672 " <DoubleVectorProperty command=\"SetViewAngle\"\n"
6673 " default_values=\"30\"\n"
6674 " ignore_synchronization=\"1\"\n"
6675 " immediate_update=\"1\"\n"
6676 " information_property=\"CameraViewAngleInfo\"\n"
6677 " name=\"CameraViewAngle\"\n"
6678 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
6679 " <DoubleVectorProperty command=\"SetParallelScale\"\n"
6680 " default_values=\"1.73\"\n"
6681 " ignore_synchronization=\"1\"\n"
6682 " information_property=\"CameraParallelScaleInfo\"\n"
6683 " name=\"CameraParallelScale\"\n"
6684 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
6685 " <DoubleVectorProperty command=\"GetParallelScale\"\n"
6686 " default_values=\"1.73\"\n"
6687 " information_only=\"1\"\n"
6688 " name=\"CameraParallelScaleInfo\"\n"
6689 " number_of_elements=\"1\">\n"
6690 " <SimpleDoubleInformationHelper />\n"
6691 " </DoubleVectorProperty>\n"
6692 " <DoubleVectorProperty command=\"SetEyeAngle\"\n"
6693 " default_values=\"2.0\"\n"
6694 " ignore_synchronization=\"1\"\n"
6695 " name=\"EyeAngle\"\n"
6696 " number_of_elements=\"1\">\n"
6697 " <DoubleRangeDomain min=\"0\"\n"
6698 " name=\"range\" />\n"
6699 " </DoubleVectorProperty>\n"
6700 " <IntVectorProperty command=\"SetUseOffAxisProjection\"\n"
6701 " default_values=\"0\"\n"
6702 " name=\"EnableTracking\"\n"
6703 " number_of_elements=\"1\"></IntVectorProperty>\n"
6704 " <DoubleVectorProperty argument_is_array=\"1\"\n"
6705 " command=\"SetEyeTransformMatrix\"\n"
6706 " default_values=\"1.0 0.0 0.0 0.0\n"
6707 " 0.0 1.0 0.0 0.0\n"
6708 " 0.0 0.0 1.0 0.0\n"
6709 " 0.0 0.0 0.0 1.0\"\n"
6710 " immediate_update=\"1\"\n"
6711 " is_internal=\"1\"\n"
6712 " name=\"EyeTransformMatrix\"\n"
6713 " number_of_elements=\"16\"></DoubleVectorProperty>\n"
6714 " <DoubleVectorProperty argument_is_array=\"1\"\n"
6715 " command=\"SetModelTransformMatrix\"\n"
6716 " default_values=\"1.0 0.0 0.0 0.0\n"
6717 " 0.0 1.0 0.0 0.0\n"
6718 " 0.0 0.0 1.0 0.0\n"
6719 " 0.0 0.0 0.0 1.0\"\n"
6720 " immediate_update=\"1\"\n"
6721 " is_internal=\"1\"\n"
6722 " name=\"ModelTransformMatrix\"\n"
6723 " number_of_elements=\"16\"></DoubleVectorProperty>\n"
6724 " </CameraProxy>\n"
6725 " <!-- end of Camera Proxy -->\n"
6726 " </ProxyGroup>\n"
6727 " <ProxyGroup name=\"mappers\">\n"
6728 " <Proxy class=\"vtkProjectedTetrahedraMapper\"\n"
6729 " name=\"ProjectedTetrahedraMapper\"\n"
6730 " processes=\"client|renderserver|dataserver\">\n"
6731 " <IntVectorProperty name=\"UseFloatingPointFrameBuffer\"\n"
6732 " command=\"SetUseFloatingPointFrameBuffer\"\n"
6733 " number_of_elements=\"1\"\n"
6734 " default_values=\"1\"\n"
6735 " panel_visibility=\"advanced\">\n"
6736 " <BooleanDomain name=\"bool\" />\n"
6737 " <Documentation>\n"
6738 " Enable use of floating point frame buffers. If not enabled,\n"
6739 " you may encounter artifacts when mixing volumes with geometry.\n"
6740 " </Documentation>\n"
6741 " </IntVectorProperty>\n"
6742 " </Proxy>\n"
6743 " <Proxy name=\"DummyVolumeMapper\">\n"
6744 " <ProxyProperty command=\"SetRayCastFunction\"\n"
6745 " name=\"RayCastFunction\">\n"
6746 " <ProxyGroupDomain name=\"groups\">\n"
6747 " <Group name=\"ugrid_raycast_functions\" />\n"
6748 " </ProxyGroupDomain>\n"
6749 " </ProxyProperty>\n"
6750 " </Proxy>\n"
6751 " <Proxy class=\"vtkUnstructuredGridVolumeRayCastMapper\"\n"
6752 " name=\"UnstructuredGridVolumeRayCastMapper\"\n"
6753 " processes=\"client|renderserver|dataserver\">\n"
6754 " <ProxyProperty command=\"SetRayCastFunction\"\n"
6755 " name=\"RayCastFunction\">\n"
6756 " <ProxyGroupDomain name=\"groups\">\n"
6757 " <Group name=\"ugrid_raycast_functions\" />\n"
6758 " </ProxyGroupDomain>\n"
6759 " </ProxyProperty>\n"
6760 " </Proxy>\n"
6761 " <Proxy class=\"vtkUnstructuredGridVolumeZSweepMapper\"\n"
6762 " name=\"UnstructuredGridVolumeZSweepMapper\"\n"
6763 " processes=\"client|renderserver|dataserver\"></Proxy>\n"
6764 " <Proxy class=\"vtkGPUVolumeRayCastMapper\"\n"
6765 " name=\"GPUVolumeRayCastMapper\"\n"
6766 " processes=\"client|renderserver|dataserver\">\n"
6767 " <Documentation>This is the proxy for GPU based volume\n"
6768 " rendering.</Documentation>\n"
6769 " <IntVectorProperty animateable=\"0\"\n"
6770 " command=\"SetBlendMode\"\n"
6771 " default_values=\"0\"\n"
6772 " name=\"BlendMode\"\n"
6773 " number_of_elements=\"1\">\n"
6774 " <Documentation>Set the current blend mode. Default is Composite.\n"
6775 " MaximumIntensity is also known as MIP rendering.</Documentation>\n"
6776 " <EnumerationDomain name=\"enum\">\n"
6777 " <Entry text=\"Composite\"\n"
6778 " value=\"0\" />\n"
6779 " <Entry text=\"MaximumIntensity\"\n"
6780 " value=\"1\" />\n"
6781 " <Entry text=\"MinimumIntensity\"\n"
6782 " value=\"2\" />\n"
6783 " </EnumerationDomain>\n"
6784 " </IntVectorProperty>\n"
6785 " <IntVectorProperty animateable=\"0\"\n"
6786 " command=\"SetAutoAdjustSampleDistances\"\n"
6787 " default_values=\"1\"\n"
6788 " name=\"AutoAdjustSampleDistances\"\n"
6789 " number_of_elements=\"1\">\n"
6790 " <Documentation>If AutoAdjustSampleDistances is on, the the\n"
6791 " ImageSampleDistance will be varied to achieve the allocated render time\n"
6792 " of this prop (controlled by the desired update rate and any culling in\n"
6793 " use).</Documentation>\n"
6794 " </IntVectorProperty>\n"
6795 " <DoubleVectorProperty animateable=\"0\"\n"
6796 " command=\"SetSampleDistance\"\n"
6797 " default_values=\"1.0\"\n"
6798 " name=\"SampleDistance\"\n"
6799 " number_of_elements=\"1\">\n"
6800 " <Documentation>Set/Get the distance between samples used for rendering\n"
6801 " when AutoAdjustSampleDistances is off, or when this mapper has more\n"
6802 " than 1 second allocated to it for rendering.</Documentation>\n"
6803 " </DoubleVectorProperty>\n"
6804 " <!-- End of GPUVolumeRayCastMapper -->\n"
6805 " </Proxy>\n"
6806 " <Proxy class=\"vtkFixedPointVolumeRayCastMapper\"\n"
6807 " name=\"FixedPointVolumeRayCastMapper\"\n"
6808 " processes=\"client|renderserver|dataserver\">\n"
6809 " <IntVectorProperty animateable=\"0\"\n"
6810 " command=\"SetBlendMode\"\n"
6811 " default_values=\"0\"\n"
6812 " name=\"BlendMode\"\n"
6813 " number_of_elements=\"1\">\n"
6814 " <Documentation>Set the current blend mode. Default is Composite.\n"
6815 " MaximumIntensity is also known as MIP rendering.</Documentation>\n"
6816 " <EnumerationDomain name=\"enum\">\n"
6817 " <Entry text=\"Composite\"\n"
6818 " value=\"0\" />\n"
6819 " <Entry text=\"MaximumIntensity\"\n"
6820 " value=\"1\" />\n"
6821 " <Entry text=\"MinimumIntensity\"\n"
6822 " value=\"2\" />\n"
6823 " </EnumerationDomain>\n"
6824 " </IntVectorProperty>\n"
6825 " <IntVectorProperty animateable=\"0\"\n"
6826 " command=\"SetLockSampleDistanceToInputSpacing\"\n"
6827 " default_values=\"1\"\n"
6828 " name=\"LockSampleDistanceToInputSpacing\"\n"
6829 " number_of_elements=\"1\">\n"
6830 " <BooleanDomain name=\"bool\" />\n"
6831 " </IntVectorProperty>\n"
6832 " <!-- End of FixedPointVolumeRayCastMapper -->\n"
6833 " </Proxy>\n"
6834 " <Proxy class=\"vtkSmartVolumeMapper\"\n"
6835 " name=\"UnstructuredGridResampleToImageMapper\"\n"
6836 " processes=\"client|renderserver|dataserver\"></Proxy>\n"
6837 " <!-- End of \"mappers\" -->\n"
6838 " </ProxyGroup>\n"
6839 " <ProxyGroup name=\"ugrid_raycast_functions\">\n"
6840 " <Proxy class=\"vtkUnstructuredGridBunykRayCastFunction\"\n"
6841 " name=\"BunykRayCastFunction\"></Proxy>\n"
6842 " </ProxyGroup>\n"
6843 " <ProxyGroup name=\"textures\">\n"
6844 " <SourceProxy class=\"vtkTexture\"\n"
6845 " name=\"Texture\">\n"
6846 " <InputProperty command=\"SetInputConnection\"\n"
6847 " name=\"Input\">\n"
6848 " <ProxyGroupDomain name=\"groups\">\n"
6849 " <Group name=\"sources\" />\n"
6850 " <Group name=\"filters\" />\n"
6851 " </ProxyGroupDomain>\n"
6852 " <DataTypeDomain name=\"input_type\">\n"
6853 " <DataType value=\"vtkImageData\" />\n"
6854 " </DataTypeDomain>\n"
6855 " </InputProperty>\n"
6856 " <!-- This property without associated command is used to store the source filename containing the texture, as we lose this information when loading the texture from a vtkTexture directly -->\n"
6857 " <StringVectorProperty animateable=\"0\"\n"
6858 " name=\"FileName\"\n"
6859 " number_of_elements=\"1\">\n"
6860 " </StringVectorProperty>\n"
6861 " </SourceProxy>\n"
6862 " <Proxy class=\"vtkTexture\"\n"
6863 " name=\"ImageTexture\"\n"
6864 " si_class=\"vtkSIImageTextureProxy\"\n"
6865 " processes=\"client|renderserver|dataserver\">\n"
6866 " <Documentation>This is a proxy for a vtkTexture which also includes an\n"
6867 " image file reader. This reader can read an image of client/data server or\n"
6868 " render server and then transmit it to the client/render server where it\n"
6869 " will be used for texturing.</Documentation>\n"
6870 " <SubProxy>\n"
6871 " <Proxy name=\"Source\"\n"
6872 " proxygroup=\"sources\"\n"
6873 " proxyname=\"NetworkImageSource\" />\n"
6874 " <ExposedProperties>\n"
6875 " <Property name=\"FileName\" />\n"
6876 " <Property name=\"TrivialProducerKey\" />\n"
6877 " <Property name=\"Mode\" />\n"
6878 " </ExposedProperties>\n"
6879 " </SubProxy>\n"
6880 " <IntVectorProperty animateable=\"1\"\n"
6881 " command=\"SetRestrictPowerOf2ImageSmaller\"\n"
6882 " default_values=\"0\"\n"
6883 " name=\"RestrictPowerOf2ImageSmaller\"\n"
6884 " number_of_elements=\"1\">\n"
6885 " <BooleanDomain name=\"bool\" />\n"
6886 " </IntVectorProperty>\n"
6887 " <IntVectorProperty animateable=\"0\"\n"
6888 " command=\"SetColorMode\"\n"
6889 " default_values=\"2\"\n"
6890 " name=\"ColorMode\"\n"
6891 " number_of_elements=\"1\">\n"
6892 " <EnumerationDomain name=\"enum\">\n"
6893 " <Entry text=\"Default\"\n"
6894 " value=\"0\" />\n"
6895 " <Entry text=\"Map Scalars\"\n"
6896 " value=\"1\" />\n"
6897 ;
6898
6899 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/rendering.xml
6901 " <Entry text=\"Direct Scalars\"\n"
6902 " value=\"2\" />\n"
6903 " </EnumerationDomain>\n"
6904 " <Documentation>When color mode is Default, 8-bits textures is equivalent to Direct Scalars,\n"
6905 " while equivalent to Map Scalars for 16-bits textures. In the case of Map Scalars, all the\n"
6906 " values are mapped to a generic color map.</Documentation>\n"
6907 " </IntVectorProperty>\n"
6908 " </Proxy>\n"
6909 " </ProxyGroup>\n"
6910 " <ProxyGroup name=\"props\">\n"
6911 " <Proxy class=\"vtkTextActor\"\n"
6912 " name=\"TextActor\">\n"
6913 " <Documentation>Proxy for a text actor. Not to be used\n"
6914 " directly.</Documentation>\n"
6915 " <StringVectorProperty animateable=\"0\"\n"
6916 " command=\"SetInput\"\n"
6917 " name=\"Text\"\n"
6918 " number_of_elements=\"1\"></StringVectorProperty>\n"
6919 " <IntVectorProperty animateable=\"1\"\n"
6920 " command=\"SetVisibility\"\n"
6921 " default_values=\"1\"\n"
6922 " name=\"Visibility\"\n"
6923 " number_of_elements=\"1\">\n"
6924 " <BooleanDomain name=\"bool\" />\n"
6925 " </IntVectorProperty>\n"
6926 " <DoubleVectorProperty animateable=\"0\"\n"
6927 " command=\"SetPosition\"\n"
6928 " default_values=\"0 0\"\n"
6929 " name=\"Position\"\n"
6930 " number_of_elements=\"2\">\n"
6931 " <DoubleRangeDomain name=\"range\" />\n"
6932 " </DoubleVectorProperty>\n"
6933 " <IntVectorProperty animateable=\"0\"\n"
6934 " command=\"SetTextScaleMode\"\n"
6935 " default_values=\"2\"\n"
6936 " name=\"TextScaleMode\"\n"
6937 " number_of_elements=\"1\">\n"
6938 " <EnumerationDomain name=\"enum\">\n"
6939 " <Entry text=\"None\"\n"
6940 " value=\"0\" />\n"
6941 " <Entry text=\"Prop\"\n"
6942 " value=\"1\" />\n"
6943 " <Entry text=\"Viewport\"\n"
6944 " value=\"2\" />\n"
6945 " </EnumerationDomain>\n"
6946 " </IntVectorProperty>\n"
6947 " <ProxyProperty command=\"SetTextProperty\"\n"
6948 " name=\"TextProperty\">\n"
6949 " <ProxyGroupDomain name=\"groups\">\n"
6950 " <Group name=\"properties\" />\n"
6951 " </ProxyGroupDomain>\n"
6952 " </ProxyProperty>\n"
6953 " <!-- End of TextActor -->\n"
6954 " </Proxy>\n"
6955 " <!-- End of group \"props\" -->\n"
6956 " </ProxyGroup>\n"
6957 " <ProxyGroup name=\"properties\">\n"
6958 " <Proxy class=\"vtkTextProperty\" name=\"TextPropertyBase\" processes=\"client|dataserver|renderserver\" >\n"
6959 " <DoubleVectorProperty command=\"SetBackgroundRGBA\"\n"
6960 " default_values=\"0.0 0.0 0.0 0.0\"\n"
6961 " name=\"BackgroundRGBA\"\n"
6962 " number_of_elements=\"4\">\n"
6963 " <DoubleRangeDomain max=\"1 1 1 1\" min=\"0 0 0 0\" name=\"range\" />\n"
6964 " </DoubleVectorProperty>\n"
6965 "\n"
6966 " <DoubleVectorProperty animateable=\"0\"\n"
6967 " command=\"SetOpacity\"\n"
6968 " default_values=\"1.0\"\n"
6969 " name=\"Opacity\"\n"
6970 " number_of_elements=\"1\">\n"
6971 " <DoubleRangeDomain max=\"1.0\"\n"
6972 " min=\"0.0\"\n"
6973 " name=\"range\" />\n"
6974 " </DoubleVectorProperty>\n"
6975 " <IntVectorProperty animateable=\"0\"\n"
6976 " command=\"SetFontFamily\"\n"
6977 " default_values=\"0\"\n"
6978 " name=\"FontFamily\"\n"
6979 " number_of_elements=\"1\">\n"
6980 " <EnumerationDomain name=\"enum\">\n"
6981 " <Entry text=\"Arial\"\n"
6982 " value=\"0\" />\n"
6983 " <Entry text=\"Courier\"\n"
6984 " value=\"1\" />\n"
6985 " <Entry text=\"Times\"\n"
6986 " value=\"2\" />\n"
6987 " <Entry text=\"File\"\n"
6988 " value=\"4\" />\n"
6989 " </EnumerationDomain>\n"
6990 " </IntVectorProperty>\n"
6991 " <StringVectorProperty command=\"SetFontFile\"\n"
6992 " label=\"Name\"\n"
6993 " name=\"FontFile\"\n"
6994 " number_of_elements=\"1\"\n"
6995 " default_values=\"\">\n"
6996 " <Hints>\n"
6997 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
6998 " mode=\"visibility\"\n"
6999 " property=\"FontFamily\"\n"
7000 " value=\"4\" />\n"
7001 " <!-- enable this widget when FontFamily==4 -->\n"
7002 " </Hints>\n"
7003 " </StringVectorProperty>\n"
7004 " <IntVectorProperty animateable=\"0\"\n"
7005 " command=\"SetBold\"\n"
7006 " default_values=\"0\"\n"
7007 " name=\"Bold\"\n"
7008 " number_of_elements=\"1\">\n"
7009 " <BooleanDomain name=\"bool\" />\n"
7010 " </IntVectorProperty>\n"
7011 " <IntVectorProperty animateable=\"0\"\n"
7012 " command=\"SetItalic\"\n"
7013 " default_values=\"0\"\n"
7014 " name=\"Italic\"\n"
7015 " number_of_elements=\"1\">\n"
7016 " <BooleanDomain name=\"bool\" />\n"
7017 " </IntVectorProperty>\n"
7018 " <IntVectorProperty animateable=\"0\"\n"
7019 " command=\"SetShadow\"\n"
7020 " default_values=\"0\"\n"
7021 " name=\"Shadow\"\n"
7022 " number_of_elements=\"1\">\n"
7023 " <BooleanDomain name=\"bool\" />\n"
7024 " </IntVectorProperty>\n"
7025 " <IntVectorProperty animateable=\"0\"\n"
7026 " command=\"SetFontSize\"\n"
7027 " default_values=\"18\"\n"
7028 " name=\"FontSize\"\n"
7029 " number_of_elements=\"1\">\n"
7030 " <IntRangeDomain min=\"0\"\n"
7031 " name=\"range\" />\n"
7032 " </IntVectorProperty>\n"
7033 " <DoubleVectorProperty animateable=\"0\"\n"
7034 " command=\"SetOrientation\"\n"
7035 " default_values=\"0\"\n"
7036 " name=\"Orientation\"\n"
7037 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
7038 "\n"
7039 " <DoubleVectorProperty command=\"SetLineSpacing\"\n"
7040 " default_values=\"1.0\"\n"
7041 " name=\"LineSpacing\"\n"
7042 " number_of_elements=\"1\"\n"
7043 " panel_visibility=\"advanced\">\n"
7044 " <DoubleRangeDomain max=\"10\"\n"
7045 " min=\"0\"\n"
7046 " name=\"range\" />\n"
7047 " <Documentation>Set the extra spacing between lines, expressed as a text height multiplication factor.</Documentation>\n"
7048 " </DoubleVectorProperty>\n"
7049 "\n"
7050 " <IntVectorProperty command=\"SetLineOffset\"\n"
7051 " default_values=\"0.0\"\n"
7052 " name=\"LineOffset\"\n"
7053 " number_of_elements=\"1\"\n"
7054 " panel_visibility=\"advanced\">\n"
7055 " <IntRangeDomain max=\"500\"\n"
7056 " min=\"0\"\n"
7057 " name=\"range\"\n"
7058 " resolution=\"2\" />\n"
7059 " <Documentation>Set the offset between two lines in pixels unit.</Documentation>\n"
7060 " </IntVectorProperty>\n"
7061 "\n"
7062 " <IntVectorProperty command=\"SetCellOffset\"\n"
7063 " default_values=\"0.0\"\n"
7064 " name=\"CellOffset\"\n"
7065 " number_of_elements=\"1\"\n"
7066 " panel_visibility=\"advanced\">\n"
7067 " <IntRangeDomain max=\"500\"\n"
7068 " min=\"0\"\n"
7069 " name=\"range\"\n"
7070 " resolution=\"2\" />\n"
7071 " <Documentation>Set the offset between two cells in pixels unit.</Documentation>\n"
7072 " </IntVectorProperty>\n"
7073 "\n"
7074 " <IntVectorProperty animateable=\"0\"\n"
7075 " command=\"SetJustification\"\n"
7076 " default_values=\"0\"\n"
7077 " name=\"Justification\"\n"
7078 " number_of_elements=\"1\">\n"
7079 " <EnumerationDomain name=\"enum\">\n"
7080 " <Entry text=\"Left\"\n"
7081 " value=\"0\" />\n"
7082 " <Entry text=\"Center\"\n"
7083 " value=\"1\" />\n"
7084 " <Entry text=\"Right\"\n"
7085 " value=\"2\" />\n"
7086 " </EnumerationDomain>\n"
7087 " </IntVectorProperty>\n"
7088 " <IntVectorProperty animateable=\"0\"\n"
7089 " command=\"SetVerticalJustification\"\n"
7090 " default_values=\"0\"\n"
7091 " name=\"VerticalJustification\"\n"
7092 " number_of_elements=\"1\">\n"
7093 " <EnumerationDomain name=\"enum\">\n"
7094 " <Entry text=\"Bottom\"\n"
7095 " value=\"0\" />\n"
7096 " <Entry text=\"Center\"\n"
7097 " value=\"1\" />\n"
7098 " <Entry text=\"Top\"\n"
7099 " value=\"2\" />\n"
7100 " </EnumerationDomain>\n"
7101 " </IntVectorProperty>\n"
7102 "\n"
7103 " <IntVectorProperty command=\"SetInteriorLinesVisibility\"\n"
7104 " name=\"InteriorLinesVisibility\"\n"
7105 " number_of_elements=\"1\"\n"
7106 " default_values=\"0\">\n"
7107 " <BooleanDomain name=\"bool\" />\n"
7108 " <Documentation>\n"
7109 " Show/hide interior lines between cells. Only valid for multi cell text.\n"
7110 " </Documentation>\n"
7111 " </IntVectorProperty>\n"
7112 "\n"
7113 " <IntVectorProperty command=\"SetInteriorLinesWidth\"\n"
7114 " name=\"InteriorLinesWidth\"\n"
7115 " number_of_elements=\"1\"\n"
7116 " default_values=\"1\">\n"
7117 " <IntRangeDomain name=\"range\" min=\"0\" max=\"10\" />\n"
7118 " <Documentation>\n"
7119 " Set the width (in pixels) of the interior lines between cells. Only valid for multi cell text.\n"
7120 " </Documentation>\n"
7121 " </IntVectorProperty>\n"
7122 "\n"
7123 " <DoubleVectorProperty command=\"SetInteriorLinesColor\"\n"
7124 " name=\"InteriorLinesColor\"\n"
7125 " default_values=\"0.0 0.0 0.0\"\n"
7126 " number_of_elements=\"3\"\n"
7127 " panel_widget=\"color_selector\">\n"
7128 " <DoubleRangeDomain name=\"range\"\n"
7129 " min=\"0.0 0.0 0.0\"\n"
7130 " max=\"1.0 1.0 1.0\" />\n"
7131 " <Documentation>\n"
7132 " Set the color of the interior lines between cells. Only valid for multi cell text.\n"
7133 " </Documentation>\n"
7134 " </DoubleVectorProperty>\n"
7135 " <!-- End of TextProperty -->\n"
7136 " </Proxy>\n"
7137 "\n"
7138 " <Proxy class=\"vtkTextProperty\" name=\"TextProperty\"\n"
7139 " base_proxygroup=\"properties\"\n"
7140 " base_proxyname=\"TextPropertyBase\"\n"
7141 " processes=\"client|dataserver|renderserver\">\n"
7142 " <DoubleVectorProperty animateable=\"0\"\n"
7143 " argument_is_array=\"1\"\n"
7144 " command=\"SetColor\"\n"
7145 " default_values=\"1.0 1.0 1.0\"\n"
7146 " name=\"Color\"\n"
7147 " number_of_elements=\"3\">\n"
7148 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
7149 " <Hints>\n"
7150 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"TextAnnotationColor\"\n"
7151 " unlink_if_modified=\"1\" />\n"
7152 " </Hints>\n"
7153 " </DoubleVectorProperty>\n"
7154 " <ExposedProperties>\n"
7155 " <Property name=\"LineSpacing\" />\n"
7156 " <Property name=\"CellOffset\" />\n"
7157 " </ExposedProperties>\n"
7158 " </Proxy>\n"
7159 "\n"
7160 " <Proxy class=\"vtkTextProperty\" name=\"ChartTextProperty\"\n"
7161 " base_proxygroup=\"properties\"\n"
7162 " base_proxyname=\"TextPropertyBase\"\n"
7163 " processes=\"client|dataserver|renderserver\">\n"
7164 " <!-- same as \"TextProperty\" except with different color that is not\n"
7165 " linked with TextAnnotationColor -->\n"
7166 " <DoubleVectorProperty animateable=\"0\"\n"
7167 " argument_is_array=\"1\"\n"
7168 " command=\"SetColor\"\n"
7169 " default_values=\"0.0 0.0 0.0\"\n"
7170 " name=\"Color\"\n"
7171 " number_of_elements=\"3\">\n"
7172 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
7173 " </DoubleVectorProperty>\n"
7174 " </Proxy>\n"
7175 "\n"
7176 " <Proxy class=\"vtkTextProperty\" name=\"TextPropertyCentered\"\n"
7177 " base_proxygroup=\"properties\"\n"
7178 " base_proxyname=\"TextProperty\"\n"
7179 " processes=\"client|dataserver|renderserver\">\n"
7180 " <!-- inherit TextProperty with a vertical justification defaulted to centered -->\n"
7181 " <IntVectorProperty animateable=\"0\"\n"
7182 " command=\"SetVerticalJustification\"\n"
7183 " default_values=\"1\"\n"
7184 " name=\"VerticalJustification\"\n"
7185 " number_of_elements=\"1\"\n"
7186 " override=\"1\">\n"
7187 " <EnumerationDomain name=\"enum\">\n"
7188 " <Entry text=\"Bottom\"\n"
7189 " value=\"0\" />\n"
7190 " <Entry text=\"Center\"\n"
7191 " value=\"1\" />\n"
7192 " <Entry text=\"Top\"\n"
7193 " value=\"2\" />\n"
7194 " </EnumerationDomain>\n"
7195 " </IntVectorProperty>\n"
7196 "\n"
7197 " </Proxy>\n"
7198 "\n"
7199 " </ProxyGroup>\n"
7200 "\n"
7201 " <ProxyGroup name=\"additional_lights\" label=\"Lights\">\n"
7202 " <LightProxy name=\"Light\"\n"
7203 " class=\"vtkPVLight\"\n"
7204 " processes=\"client|dataserver|renderserver\">\n"
7205 " <IntVectorProperty command=\"SetSwitch\"\n"
7206 " label=\"Enable\"\n"
7207 " name=\"LightSwitch\"\n"
7208 " number_of_elements=\"1\"\n"
7209 " default_values=\"1\"\n"
7210 " >\n"
7211 " <Documentation>Turn on/off this light in the active view.</Documentation>\n"
7212 " <BooleanDomain name=\"bool\" />\n"
7213 " </IntVectorProperty>\n"
7214 "\n"
7215 " <StringVectorProperty command=\"SetName\"\n"
7216 " label=\"Name\"\n"
7217 " name=\"LightName\"\n"
7218 " panel_visibility=\"never\"\n"
7219 " number_of_elements=\"1\">\n"
7220 " </StringVectorProperty>\n"
7221 "\n"
7222 " <IntVectorProperty command=\"SetLightType\"\n"
7223 " label=\"Coords\"\n"
7224 " name=\"LightType\"\n"
7225 " number_of_elements=\"1\"\n"
7226 " default_values=\"3\">\n"
7227 " <EnumerationDomain name=\"enum\">\n"
7228 " <Entry text=\"Headlight\"\n"
7229 " value=\"1\" />\n"
7230 " <Entry text=\"Camera\"\n"
7231 " value=\"2\" />\n"
7232 " <Entry text=\"Scene\"\n"
7233 " value=\"3\" />\n"
7234 " <Entry text=\"Ambient\"\n"
7235 " value=\"4\" />\n"
7236 " </EnumerationDomain>\n"
7237 " <Documentation>\n"
7238 " Specify how the light is positioned. It can be attached to the eye (**Headlight**), relative to the\n"
7239 " eye (**Camera**), fixed in world space (**Scene**), or position-less (**Ambient**).\n"
7240 " </Documentation>\n"
7241 " </IntVectorProperty>\n"
7242 "\n"
7243 " <DoubleVectorProperty command=\"SetIntensity\"\n"
7244 " label=\"Intensity\"\n"
7245 " name=\"LightIntensity\"\n"
7246 " default_values=\"1.0\"\n"
7247 " number_of_elements=\"1\">\n"
7248 ;
7249
7250 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/rendering.xml
7252 " <DoubleRangeDomain min=\"0\"\n"
7253 " name=\"range\"\n"
7254 " resolution=\"0.01\" />\n"
7255 " <Documentation>\n"
7256 " Set the light's brightness. Can be greater than 1.\n"
7257 " </Documentation>\n"
7258 " </DoubleVectorProperty>\n"
7259 "\n"
7260 " <IntVectorProperty command=\"SetPositional\"\n"
7261 " label=\"Type\"\n"
7262 " name=\"Positional\"\n"
7263 " default_values=\"0\"\n"
7264 " number_of_elements=\"1\"\n"
7265 " >\n"
7266 " <Documentation>\n"
7267 " Set the light's type.\n"
7268 " A **Positional** light's rays diverge from its position. Use **Cone Angle** to limit them.\n"
7269 " A **Directional** light's rays come from far away, and are parallel.\n"
7270 " </Documentation>\n"
7271 " <EnumerationDomain name=\"enum\">\n"
7272 " <Entry text=\"Directional\"\n"
7273 " value=\"0\" />\n"
7274 " <Entry text=\"Positional\"\n"
7275 " value=\"1\" />\n"
7276 " </EnumerationDomain>\n"
7277 " <Hints>\n"
7278 " <!-- display when light type is not Ambient -->\n"
7279 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7280 " mode=\"visibility\"\n"
7281 " property=\"LightType\"\n"
7282 " inverse=\"1\"\n"
7283 " value=\"4\" />\n"
7284 " </Hints>\n"
7285 " </IntVectorProperty>\n"
7286 "\n"
7287 " <DoubleVectorProperty command=\"GetPosition\"\n"
7288 " name=\"PositionInfo\"\n"
7289 " default_values=\"0 0 1\"\n"
7290 " information_only=\"1\"\n"
7291 " number_of_elements=\"3\">\n"
7292 " <SimpleDoubleInformationHelper />\n"
7293 " </DoubleVectorProperty>\n"
7294 " <DoubleVectorProperty command=\"SetPosition\"\n"
7295 " label=\"Position\"\n"
7296 " name=\"LightPosition\"\n"
7297 " information_property=\"PositionInfo\"\n"
7298 " default_values=\"0 0 1\"\n"
7299 " number_of_elements=\"3\">\n"
7300 " <Documentation>\n"
7301 " Relative position of the light for **Camera Coords** light, world-space position for **Scene Coords** light.\n"
7302 " </Documentation>\n"
7303 " <Hints>\n"
7304 " <!-- display when light type is Scene or Camera -->\n"
7305 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7306 " mode=\"visibility\"\n"
7307 " property=\"LightType\"\n"
7308 " values=\"2 3\" />\n"
7309 " </Hints>\n"
7310 " </DoubleVectorProperty>\n"
7311 "\n"
7312 " <DoubleVectorProperty command=\"GetFocalPoint\"\n"
7313 " name=\"FocalPointInfo\"\n"
7314 " default_values=\"0 0 0\"\n"
7315 " information_only=\"1\"\n"
7316 " number_of_elements=\"3\">\n"
7317 " <SimpleDoubleInformationHelper />\n"
7318 " </DoubleVectorProperty>\n"
7319 " <DoubleVectorProperty command=\"SetFocalPoint\"\n"
7320 " name=\"FocalPoint\"\n"
7321 " information_property=\"FocalPointInfo\"\n"
7322 " default_values=\"0 0 0\"\n"
7323 " number_of_elements=\"3\">\n"
7324 " <Documentation>\n"
7325 " Used with position to compute the light direction, this is a \"look-at\" point.\n"
7326 " </Documentation>\n"
7327 " <Hints>\n"
7328 " <!-- display when light type is Scene or Camera -->\n"
7329 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7330 " mode=\"visibility\"\n"
7331 " property=\"LightType\"\n"
7332 " values=\"2 3\" />\n"
7333 " </Hints>\n"
7334 " </DoubleVectorProperty>\n"
7335 "\n"
7336 " <DoubleVectorProperty command=\"SetColor\"\n"
7337 " default_values=\"1 1 1\"\n"
7338 " name=\"DiffuseColor\"\n"
7339 " panel_widget=\"color_selector\"\n"
7340 " number_of_elements=\"3\">\n"
7341 " <DoubleRangeDomain\n"
7342 " max=\"1 1 1\"\n"
7343 " min=\"0 0 0\"\n"
7344 " name=\"range\" />\n"
7345 " <Documentation>\n"
7346 " Color of the light.\n"
7347 " </Documentation>\n"
7348 " </DoubleVectorProperty>\n"
7349 "\n"
7350 " <DoubleVectorProperty command=\"SetConeAngle\"\n"
7351 " default_values=\"30.0\"\n"
7352 " name=\"ConeAngle\"\n"
7353 " number_of_elements=\"1\">\n"
7354 " <DoubleRangeDomain max=\"90.0\"\n"
7355 " min=\"0.0\"\n"
7356 " name=\"range\" />\n"
7357 " <Documentation>\n"
7358 " For a **Positional** light, limit the light to a cone around its direction, creating a \"spot-light\" effect.\n"
7359 " Set to 90 to light all directions. In degrees.\n"
7360 " </Documentation>\n"
7361 " <Hints>\n"
7362 " <!-- display when light type is not Ambient, and when Positional -->\n"
7363 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7364 " mode=\"visibility\"\n"
7365 " property=\"LightType\"\n"
7366 " inverse=\"1\"\n"
7367 " value=\"4\" />\n"
7368 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7369 " mode=\"visibility\"\n"
7370 " property=\"Positional\"\n"
7371 " value=\"1\" />\n"
7372 " </Hints>\n"
7373 " </DoubleVectorProperty>\n"
7374 "\n"
7375 " <DoubleVectorProperty command=\"SetRadius\"\n"
7376 " default_values=\"0.0\"\n"
7377 " name=\"Radius\"\n"
7378 " number_of_elements=\"1\">\n"
7379 " <DoubleRangeDomain min=\"0\"\n"
7380 " name=\"range\" />\n"
7381 " <Documentation>\n"
7382 " For OSPRay renderer lights, sets the apparent size of the light.\n"
7383 " In degrees for **Directional**, world space units for **Positional**. Increasing above 0 produces soft shadows.\n"
7384 " </Documentation>\n"
7385 " <Hints>\n"
7386 " <!-- display when light type is not Ambient -->\n"
7387 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7388 " mode=\"visibility\"\n"
7389 " property=\"LightType\"\n"
7390 " inverse=\"1\"\n"
7391 " value=\"4\" />\n"
7392 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
7393 " </Hints>\n"
7394 " </DoubleVectorProperty>\n"
7395 " <PropertyGroup panel_widget=\"InteractiveLight\">\n"
7396 " <Property function=\"Positional\" name=\"Positional\" />\n"
7397 " <Property function=\"WorldPosition\" name=\"LightPosition\" />\n"
7398 " <Property function=\"FocalPoint\" name=\"FocalPoint\" />\n"
7399 " <Property function=\"ConeAngle\" name=\"ConeAngle\" />\n"
7400 " <Property function=\"LightColor\" name=\"DiffuseColor\" />\n"
7401 " </PropertyGroup>\n"
7402 " </LightProxy>\n"
7403 " <!-- End of additional_lights -->\n"
7404 " </ProxyGroup>\n"
7405 "\n"
7406 " <ProxyGroup name=\"materials\">\n"
7407 " <MaterialLibraryProxy class=\"vtkPVMaterialLibrary\"\n"
7408 " name=\"MaterialLibrary\"\n"
7409 " processes=\"client|renderserver|dataserver\">\n"
7410 " <StringVectorProperty name=\"LoadMaterials\"\n"
7411 " default_values=\"\"\n"
7412 " label=\"Load Materials\"\n"
7413 " number_of_elements=\"1\"\n"
7414 " panel_visibility=\"never\">\n"
7415 " </StringVectorProperty>\n"
7416 " </MaterialLibraryProxy>\n"
7417 " </ProxyGroup>\n"
7418 "\n"
7419 "\n"
7420 "</ServerManagerConfiguration>\n"
7421 "\n";
7422 // Get single string
7424 {
7425
7426  const size_t len0 = strlen(paraview_server_managerrenderingInterface0);
7427  const size_t len1 = strlen(paraview_server_managerrenderingInterface1);
7428  const size_t len2 = strlen(paraview_server_managerrenderingInterface2);
7429  size_t len = ( 0
7430  + len0
7431  + len1
7432  + len2 );
7433  char* res = new char[ len + 1];
7434  size_t offset = 0;
7435  std::copy(paraview_server_managerrenderingInterface0, paraview_server_managerrenderingInterface0 + len0, res + offset); offset += len0;
7436  std::copy(paraview_server_managerrenderingInterface1, paraview_server_managerrenderingInterface1 + len1, res + offset); offset += len1;
7437  std::copy(paraview_server_managerrenderingInterface2, paraview_server_managerrenderingInterface2 + len2, res + offset); offset += len2;
7438  assert(offset == len);
7439  res[offset] = 0;
7440  return res;
7441 }
7442
7443
7444 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/sources_remotingviews.xml
7446 "<ServerManagerConfiguration>\n"
7447 " <ProxyGroup name=\"sources\">\n"
7448 " <!-- ==================================================================== -->\n"
7449 " <SourceProxy class=\"vtkPVLogoSource\" name=\"LogoSource\" label=\"Logo\">\n"
7450 " <ProxyProperty command=\"SetTexture\"\n"
7451 " name=\"Texture\"\n"
7452 " panel_widget=\"texture_selector\"\n"
7453 " null_on_empty=\"1\" >\n"
7454 " <ProxyGroupDomain name=\"groups\">\n"
7455 " <Group name=\"textures\" />\n"
7456 " </ProxyGroupDomain>\n"
7457 " </ProxyProperty>\n"
7458 " <Hints>\n"
7459 " <Visibility replace_input=\"0\" />\n"
7460 " <OutputPort index=\"0\"\n"
7461 " name=\"Output-0\"\n"
7462 " type=\"logo\" />\n"
7463 " <Plotable />\n"
7464 " </Hints>\n"
7465 " <!-- End of LogoSource -->\n"
7466 " </SourceProxy>\n"
7467 "\n"
7468 " </ProxyGroup>\n"
7469 "</ServerManagerConfiguration>\n"
7470 "\n";
7471 // Get single string
7473 {
7474
7475  const size_t len0 = strlen(paraview_server_managersources_remotingviewsInterface0);
7476  size_t len = ( 0
7477  + len0 );
7478  char* res = new char[ len + 1];
7479  size_t offset = 0;
7481  assert(offset == len);
7482  res[offset] = 0;
7483  return res;
7484 }
7485
7486
7487 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
7489 "\n"
7490 "<ServerManagerConfiguration>\n"
7491 " <ProxyGroup name=\"settings\">\n"
7492 " <!-- ================================================================== -->\n"
7493 " <SettingsProxy name=\"RenderViewSettings\" label=\"Render View\"\n"
7494 " processes=\"client|dataserver|renderserver\"\n"
7495 " class=\"vtkPVRenderViewSettings\">\n"
7496 " <Documentation>\n"
7497 " Application settings for render views.\n"
7498 " </Documentation>\n"
7499 "\n"
7500 " <IntVectorProperty name=\"ResolveCoincidentTopology\"\n"
7501 " command=\"SetResolveCoincidentTopology\"\n"
7502 " number_of_elements=\"1\"\n"
7503 " default_values=\"1\"\n"
7504 " panel_visibility=\"advanced\">\n"
7505 " <Documentation>\n"
7506 " Set the mode to use to overcome the OpenGL rendering issue when faces\n"
7507 " coincide with lines and points.\n"
7508 " </Documentation>\n"
7509 " <EnumerationDomain name=\"enum\">\n"
7510 " <Entry text=\"Do nothing\" value=\"0\" />\n"
7511 " <Entry text=\"Offset faces relative to lines and points\" value=\"1\" />\n"
7512 " <Entry text=\"Offset lines and points relative to faces\" value=\"2\" />\n"
7513 " <Entry text=\"Shift z-buffer when rendering lines and points\" value=\"3\" />\n"
7514 " </EnumerationDomain>\n"
7515 " <Hints>\n"
7516 " <RestartRequired />\n"
7517 " </Hints>\n"
7518 " </IntVectorProperty>\n"
7519 "\n"
7520 " <DoubleVectorProperty name=\"PolygonOffsetParameters\"\n"
7521 " command=\"SetPolygonOffsetParameters\"\n"
7522 " number_of_elements=\"2\"\n"
7523 " default_values=\"0.0 0.0\"\n"
7524 " panel_visibility=\"advanced\">\n"
7525 " <DoubleRangeDomain name=\"range\" />\n"
7526 " <Documentation>\n"
7527 " Set the polygon offset parameters to control how polygon depths are shifted\n"
7528 " in the depth buffer. Change these parameters to change how coincident lines,\n"
7529 " points, and polygons are resolved when rendering. The first parameter controls\n"
7530 " how much the angle of the polygon relative to the camera view plane contributes\n"
7531 " to the depth offset of pixels in the rendered polygon. The second parameter is\n"
7532 " a constant offset to add to the depth buffer. Refer to the OpenGL manual on\n"
7533 " glPolygonOffset for further details on these parameters.\n"
7534 " </Documentation>\n"
7535 " <Hints>\n"
7536 " <RestartRequired />\n"
7537 " </Hints>\n"
7538 " </DoubleVectorProperty>\n"
7539 "\n"
7540 " <DoubleVectorProperty name=\"LineOffsetParameters\"\n"
7541 " command=\"SetLineOffsetParameters\"\n"
7542 " number_of_elements=\"2\"\n"
7543 " default_values=\"0.0 -4\"\n"
7544 " panel_visibility=\"advanced\">\n"
7545 " <DoubleRangeDomain name=\"range\" />\n"
7546 " <Documentation>\n"
7547 " Parameters used the same way as the parameters in **Polygon Offset Parameters**,\n"
7548 " but applied when lines are rendered.\n"
7549 " </Documentation>\n"
7550 " <Hints>\n"
7551 " <RestartRequired />\n"
7552 " </Hints>\n"
7553 " </DoubleVectorProperty>\n"
7554 "\n"
7555 " <DoubleVectorProperty name=\"PointOffsetParameter\"\n"
7556 " command=\"SetPointOffsetParameter\"\n"
7557 " number_of_elements=\"1\"\n"
7558 " default_values=\"-8\"\n"
7559 " panel_visibility=\"advanced\">\n"
7560 " <DoubleRangeDomain name=\"range\" />\n"
7561 " <Documentation>\n"
7562 " Specifies a constant depth offset to apply when points are rendered.\n"
7563 " </Documentation>\n"
7564 " <Hints>\n"
7565 " <RestartRequired />\n"
7566 " </Hints>\n"
7567 " </DoubleVectorProperty>\n"
7568 "\n"
7569 " <DoubleVectorProperty name=\"ZShift\"\n"
7570 " command=\"SetZShift\"\n"
7571 " number_of_elements=\"1\"\n"
7572 " default_values=\"0.002\"\n"
7573 " panel_visibility=\"advanced\">\n"
7574 " <DoubleRangeDomain name=\"range\" />\n"
7575 " <Documentation>\n"
7576 " Set the fraction by which to shift the z-buffer range when rendering\n"
7577 " lines and points.\n"
7578 " </Documentation>\n"
7579 " <Hints>\n"
7580 " <RestartRequired />\n"
7581 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7582 " mode=\"visibility\"\n"
7583 " property=\"ResolveCoincidentTopology\"\n"
7584 " value=\"3\" />\n"
7585 " </Hints>\n"
7586 " </DoubleVectorProperty>\n"
7587 "\n"
7588 " <IntVectorProperty name=\"DepthPeeling\"\n"
7589 " default_values=\"1\"\n"
7590 " number_of_elements=\"1\"\n"
7591 " panel_visibility=\"advanced\">\n"
7592 " <BooleanDomain name=\"bool\" />\n"
7593 " <Documentation>\n"
7594 " Enable depth-peeling to correctly render translucent polygons. May slow down\n"
7595 " rendering performance.\n"
7596 " </Documentation>\n"
7597 " </IntVectorProperty>\n"
7598 "\n"
7599 " <IntVectorProperty name=\"DepthPeelingForVolumes\"\n"
7600 " default_values=\"1\"\n"
7601 " number_of_elements=\"1\"\n"
7602 " panel_visibility=\"advanced\">\n"
7603 " <BooleanDomain name=\"bool\" />\n"
7604 " <Documentation>\n"
7605 " Include volumes in the depth-peeling pass to correctly render intermixed\n"
7606 " volumes with translucent polygons. May slow down rendering performance.\n"
7607 " </Documentation>\n"
7608 " <Hints>\n"
7609 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7610 " <Property name=\"DepthPeeling\" />\n"
7611 " </PropertyWidgetDecorator>\n"
7612 " </Hints>\n"
7613 " </IntVectorProperty>\n"
7614 "\n"
7615 " <IntVectorProperty name=\"MaximumNumberOfPeels\"\n"
7616 " default_values=\"4\"\n"
7617 " number_of_elements=\"1\"\n"
7618 " panel_visibility=\"advanced\">\n"
7619 " <IntRangeDomain name=\"range\" min=\"0\" max=\"10\" />\n"
7620 " <Documentation>\n"
7621 " Set the maximum number of peels to use when depth peeling is employed.\n"
7622 " </Documentation>\n"
7623 " <Hints>\n"
7624 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7625 " <Property name=\"DepthPeeling\" />\n"
7626 " </PropertyWidgetDecorator>\n"
7627 " </Hints>\n"
7628 " </IntVectorProperty>\n"
7629 "\n"
7630 " <IntVectorProperty name=\"UseFXAA\"\n"
7631 " default_values=\"1\"\n"
7632 " number_of_elements=\"1\"\n"
7633 " panel_visibility=\"default\">\n"
7634 " <BooleanDomain name=\"bool\" />\n"
7635 " <Documentation>\n"
7636 " Enable FXAA antialiasing on 3D geometry.\n"
7637 " </Documentation>\n"
7638 " </IntVectorProperty>\n"
7639 " <DoubleVectorProperty name=\"FXAARelativeContrastThreshold\"\n"
7640 " default_values=\"0.125\"\n"
7641 " label=\"Relative Contrast Threshold\"\n"
7642 " panel_visibility=\"advanced\"\n"
7643 " number_of_elements=\"1\">\n"
7644 " <Documentation>\n"
7645 " Contrast threshold for applying FXAA to a pixel, relative to max\n"
7646 " luminance. Lower values will affect more edges. Default is 0.125.\n"
7647 " </Documentation>\n"
7648 " <DoubleRangeDomain name=\"range\" min=\"0.0625\" max=\"0.333333333\" />\n"
7649 " <Hints>\n"
7650 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7651 " <Property name=\"UseFXAA\" />\n"
7652 " </PropertyWidgetDecorator>\n"
7653 " </Hints>\n"
7654 " </DoubleVectorProperty>\n"
7655 " <!-- The hard contrast threshold is reduced to 0.045 by default. This\n"
7656 " ensures that the red arrow of the orientation axes is\n"
7657 " antialiased. -->\n"
7658 " <DoubleVectorProperty name=\"FXAAHardContrastThreshold\"\n"
7659 " default_values=\"0.045\"\n"
7660 " label=\"Hard Contrast Threshold\"\n"
7661 " panel_visibility=\"advanced\"\n"
7662 " number_of_elements=\"1\">\n"
7663 " <Documentation>\n"
7664 " Hard contrast threshold for applying FXAA to a pixel. Lower values\n"
7665 " will affect more edges. Default is 0.045.\n"
7666 " </Documentation>\n"
7667 " <DoubleRangeDomain name=\"range\" min=\"0.03125\" max=\"0.08333333\" />\n"
7668 " <Hints>\n"
7669 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7670 " <Property name=\"UseFXAA\" />\n"
7671 " </PropertyWidgetDecorator>\n"
7672 " </Hints>\n"
7673 " </DoubleVectorProperty>\n"
7674 " <DoubleVectorProperty name=\"FXAASubpixelBlendLimit\"\n"
7675 " default_values=\"0.75\"\n"
7676 " label=\"Subpixel Blend Limit\"\n"
7677 " panel_visibility=\"advanced\"\n"
7678 " number_of_elements=\"1\">\n"
7679 " <Documentation>\n"
7680 " Maximum amount of lowpass filtering to apply to the final pixel color\n"
7681 " to correct subpixel aliasing. Default value is 0.75.\n"
7682 " </Documentation>\n"
7683 " <DoubleRangeDomain name=\"range\" min=\"0.\" max=\"1.\" />\n"
7684 " <Hints>\n"
7685 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7686 " <Property name=\"UseFXAA\" />\n"
7687 " </PropertyWidgetDecorator>\n"
7688 " </Hints>\n"
7689 " </DoubleVectorProperty>\n"
7690 " <DoubleVectorProperty name=\"FXAASubpixelContrastThreshold\"\n"
7691 " default_values=\"0.25\"\n"
7692 " label=\"Subpixel Contrast Threshold\"\n"
7693 " panel_visibility=\"advanced\"\n"
7694 " number_of_elements=\"1\">\n"
7695 " <Documentation>\n"
7696 " Contrast threshold for subpixel aliasing detection. Higher values\n"
7697 " decrease sensitivity to subpixel aliasing. Default value is 0.25.\n"
7698 " </Documentation>\n"
7699 " <DoubleRangeDomain name=\"range\" min=\"0.\" max=\"0.5\" />\n"
7700 " <Hints>\n"
7701 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7702 " <Property name=\"UseFXAA\" />\n"
7703 " </PropertyWidgetDecorator>\n"
7704 " </Hints>\n"
7705 " </DoubleVectorProperty>\n"
7706 " <IntVectorProperty name=\"FXAAUseHighQualityEndpoints\"\n"
7707 " default_values=\"1\"\n"
7708 " label=\"Improve Single Pixel Lines\"\n"
7709 " panel_visibility=\"advanced\"\n"
7710 " number_of_elements=\"1\">\n"
7711 " <BooleanDomain name=\"bool\" />\n"
7712 " <Documentation>\n"
7713 " When enabled, a more sensitive endpoint detection method is used.\n"
7714 " Disabling this will improve performance, but single-pixel lines will\n"
7715 " have noticeable artifacts. Default is On.\n"
7716 " </Documentation>\n"
7717 " <Hints>\n"
7718 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7719 " <Property name=\"UseFXAA\" />\n"
7720 " </PropertyWidgetDecorator>\n"
7721 " </Hints>\n"
7722 " </IntVectorProperty>\n"
7723 " <IntVectorProperty name=\"FXAAEndpointSearchIterations\"\n"
7724 " default_values=\"12\"\n"
7725 " label=\"Endpoint Search Iterations\"\n"
7726 " panel_visibility=\"advanced\"\n"
7727 " number_of_elements=\"1\">\n"
7728 " <Documentation>\n"
7729 " Endpoint detection radius. Higher values will provide higher quality\n"
7730 " aliasing for long edges, but performance will suffer. Default is 12.\n"
7731 " </Documentation>\n"
7732 " <IntRangeDomain name=\"range\" min=\"0\" max=\"100\" />\n"
7733 " <Hints>\n"
7734 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
7735 " <Property name=\"UseFXAA\" />\n"
7736 " </PropertyWidgetDecorator>\n"
7737 " </Hints>\n"
7738 " </IntVectorProperty>\n"
7739 "\n"
7740 " <!-- Tone Mapping -->\n"
7741 " <IntVectorProperty name=\"ToneMappingType\"\n"
7742 " number_of_elements=\"1\"\n"
7743 " default_values=\"3\"\n"
7744 " panel_visibility=\"advanced\">\n"
7745 " <Documentation>\n"
7746 " Specify tone mapping type. Clamp, Reinhard and Exponential are simpler than the GenericFilmic\n"
7747 " operator which can be fully parameterized to configure the shadows as well as the highlights.\n"
7748 " </Documentation>\n"
7749 " <EnumerationDomain name=\"enum\">\n"
7750 " <Entry text=\"Clamp\" value=\"0\" />\n"
7751 " <Entry text=\"Reinhard\" value=\"1\" />\n"
7752 " <Entry text=\"Exponential\" value=\"2\" />\n"
7753 " <Entry text=\"GenericFilmic\" value=\"3\" />\n"
7754 " </EnumerationDomain>\n"
7755 " </IntVectorProperty>\n"
7756 " <IntVectorProperty name=\"GenericFilmicPresets\"\n"
7757 " number_of_elements=\"1\"\n"
7758 " default_values=\"1\"\n"
7759 " panel_visibility=\"advanced\">\n"
7760 " <Documentation>\n"
7761 " Use predefined presets for Generic Filmic. Using the default parameters it approximates the Academy Color Encoding System (ACES).\n"
7762 " To use the popular \"Uncharted 2\" filmic tone mapping curve instead, set the property to Uncharted2.\n"
7763 " Set this property to Custom to set custom parameters.\n"
7764 " </Documentation>\n"
7765 " <EnumerationDomain name=\"enum\">\n"
7766 " <Entry text=\"Custom\" value=\"0\" />\n"
7767 " <Entry text=\"DefaultPresets\" value=\"1\" />\n"
7768 " <Entry text=\"Uncharted2\" value=\"2\" />\n"
7769 " </EnumerationDomain>\n"
7770 " <Hints>\n"
7771 " <!-- Visible if Generic Filmic -->\n"
7772 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7773 " mode=\"visibility\"\n"
7774 " property=\"ToneMappingType\"\n"
7775 " value=\"3\"/>\n"
7776 " </Hints>\n"
7777 " </IntVectorProperty>\n"
7778 " <DoubleVectorProperty name=\"Contrast\"\n"
7779 " label=\"Contrast\"\n"
7780 " default_values=\"1.6773\"\n"
7781 " number_of_elements=\"1\"\n"
7782 " panel_visibility=\"advanced\">\n"
7783 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"10.0\" />\n"
7784 " <Documentation>\n"
7785 " Adjust the toe of the curve. Typically in [1-2].\n"
7786 " </Documentation>\n"
7787 " <Hints>\n"
7788 " <!-- Visible if Generic Filmic AND GenericFilmicPresets set to Custom-->\n"
7789 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
7790 " <Expression type=\"and\">\n"
7791 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7792 " mode=\"visibility\"\n"
7793 " property=\"ToneMappingType\"\n"
7794 " value=\"3\" />\n"
7795 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7796 " mode=\"visibility\"\n"
7797 " property=\"GenericFilmicPresets\"\n"
7798 " value=\"0\" />\n"
7799 " </Expression>\n"
7800 " </PropertyWidgetDecorator>\n"
7801 " </Hints>\n"
7802 " </DoubleVectorProperty>\n"
7803 " <DoubleVectorProperty name=\"Shoulder\"\n"
7804 " label=\"Shoulder\"\n"
7805 " default_values=\"0.9714\"\n"
7806 " number_of_elements=\"1\"\n"
7807 " panel_visibility=\"advanced\">\n"
7808 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"10.0\" />\n"
7809 " <Documentation>\n"
7810 " Limit the output in the shoulder region of the curve.\n"
7811 " Typically in [0.9-1].\n"
7812 " </Documentation>\n"
7813 " <Hints>\n"
7814 " <!-- Visible if Generic Filmic AND GenericFilmicPresets set to Custom-->\n"
7815 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
7816 " <Expression type=\"and\">\n"
7817 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7818 " mode=\"visibility\"\n"
7819 " property=\"ToneMappingType\"\n"
7820 ;
7821
7822 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
7824 " value=\"3\" />\n"
7825 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7826 " mode=\"visibility\"\n"
7827 " property=\"GenericFilmicPresets\"\n"
7828 " value=\"0\" />\n"
7829 " </Expression>\n"
7830 " </PropertyWidgetDecorator>\n"
7831 " </Hints>\n"
7832 " </DoubleVectorProperty>\n"
7833 " <DoubleVectorProperty name=\"MidIn\"\n"
7834 " label=\"MidIn\"\n"
7835 " default_values=\"0.18\"\n"
7836 " number_of_elements=\"1\"\n"
7837 " panel_visibility=\"advanced\">\n"
7838 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
7839 " <Documentation>\n"
7840 " Mid level anchor input in percent gray.\n"
7841 " </Documentation>\n"
7842 " <Hints>\n"
7843 " <!-- Visible if Generic Filmic AND GenericFilmicPresets set to Custom-->\n"
7844 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
7845 " <Expression type=\"and\">\n"
7846 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7847 " mode=\"visibility\"\n"
7848 " property=\"ToneMappingType\"\n"
7849 " value=\"3\" />\n"
7850 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7851 " mode=\"visibility\"\n"
7852 " property=\"GenericFilmicPresets\"\n"
7853 " value=\"0\" />\n"
7854 " </Expression>\n"
7855 " </PropertyWidgetDecorator>\n"
7856 " </Hints>\n"
7857 " </DoubleVectorProperty>\n"
7858 " <DoubleVectorProperty name=\"MidOut\"\n"
7859 " label=\"MidOut\"\n"
7860 " default_values=\"0.18\"\n"
7861 " number_of_elements=\"1\"\n"
7862 " panel_visibility=\"advanced\">\n"
7863 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
7864 " <Documentation>\n"
7865 " Mid level anchor output in percent gray.\n"
7866 " </Documentation>\n"
7867 " <Hints>\n"
7868 " <!-- Visible if Generic Filmic AND GenericFilmicPresets set to Custom-->\n"
7869 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
7870 " <Expression type=\"and\">\n"
7871 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7872 " mode=\"visibility\"\n"
7873 " property=\"ToneMappingType\"\n"
7874 " value=\"3\" />\n"
7875 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7876 " mode=\"visibility\"\n"
7877 " property=\"GenericFilmicPresets\"\n"
7878 " value=\"0\" />\n"
7879 " </Expression>\n"
7880 " </PropertyWidgetDecorator>\n"
7881 " </Hints>\n"
7882 " </DoubleVectorProperty>\n"
7883 " <DoubleVectorProperty name=\"HdrMax\"\n"
7884 " label=\"HdrMax\"\n"
7885 " default_values=\"11.0785\"\n"
7886 " number_of_elements=\"1\"\n"
7887 " panel_visibility=\"advanced\">\n"
7888 " <DoubleRangeDomain name=\"range\" min=\"1.0\" max=\"10000.0\" />\n"
7889 " <Documentation>\n"
7890 " Maximum HDR input that is not clipped.\n"
7891 " </Documentation>\n"
7892 " <Hints>\n"
7893 " <!-- Visible if Generic Filmic AND GenericFilmicPresets set to Custom-->\n"
7894 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
7895 " <Expression type=\"and\">\n"
7896 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7897 " mode=\"visibility\"\n"
7898 " property=\"ToneMappingType\"\n"
7899 " value=\"3\" />\n"
7900 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7901 " mode=\"visibility\"\n"
7902 " property=\"GenericFilmicPresets\"\n"
7903 " value=\"0\" />\n"
7904 " </Expression>\n"
7905 " </PropertyWidgetDecorator>\n"
7906 " </Hints>\n"
7907 " </DoubleVectorProperty>\n"
7908 " <IntVectorProperty name=\"UseACES\"\n"
7909 " default_values=\"1\"\n"
7910 " number_of_elements=\"1\"\n"
7911 " panel_visibility=\"advanced\">\n"
7912 " <BooleanDomain name=\"bool\" />\n"
7913 " <Documentation>\n"
7914 " Enable the Academy Color Encoding System (ACES).\n"
7915 " </Documentation>\n"
7916 " <Hints>\n"
7917 " <!-- Visible if Generic Filmic AND GenericFilmicPresets set to Custom-->\n"
7918 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
7919 " <Expression type=\"and\">\n"
7920 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7921 " mode=\"visibility\"\n"
7922 " property=\"ToneMappingType\"\n"
7923 " value=\"3\" />\n"
7924 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7925 " mode=\"visibility\"\n"
7926 " property=\"GenericFilmicPresets\"\n"
7927 " value=\"0\" />\n"
7928 " </Expression>\n"
7929 " </PropertyWidgetDecorator>\n"
7930 " </Hints>\n"
7931 " </IntVectorProperty>\n"
7932 "\n"
7933 " <!-- SSAO -->\n"
7934 " <IntVectorProperty name=\"UseSSAODefaultPresets\"\n"
7935 " label=\"Use Default Presets\"\n"
7936 " default_values=\"1\"\n"
7937 " number_of_elements=\"1\"\n"
7938 " panel_visibility=\"advanced\">\n"
7939 " <BooleanDomain name=\"bool\" />\n"
7940 " <Documentation>\n"
7941 " If enabled, the SSAO radius and bias will be calculated depending on\n"
7942 " the size of the bounding box of the geometry. Disable to manually specify the radius and bias.\n"
7943 " </Documentation>\n"
7944 " </IntVectorProperty>\n"
7945 " <DoubleVectorProperty name=\"Radius\"\n"
7946 " default_values=\"0.5\"\n"
7947 " label=\"SSAO hemisphere radius\"\n"
7948 " panel_visibility=\"advanced\"\n"
7949 " number_of_elements=\"1\">\n"
7950 " <Documentation>\n"
7951 " Set the SSAO hemisphere radius.\n"
7952 " </Documentation>\n"
7953 " <Hints>\n"
7954 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7955 " mode=\"visibility\"\n"
7956 " property=\"UseSSAODefaultPresets\"\n"
7957 " value=\"0\"/>\n"
7958 " </Hints>\n"
7959 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"5.0\" />\n"
7960 " </DoubleVectorProperty>\n"
7961 " <DoubleVectorProperty name=\"Bias\"\n"
7962 " default_values=\"0.01\"\n"
7963 " number_of_elements=\"1\"\n"
7964 " panel_visibility=\"advanced\">\n"
7965 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
7966 " <Documentation>\n"
7967 " Set the SSAO bias when comparing samples.\n"
7968 " </Documentation>\n"
7969 " <Hints>\n"
7970 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
7971 " mode=\"visibility\"\n"
7972 " property=\"UseSSAODefaultPresets\"\n"
7973 " value=\"0\"/>\n"
7974 " </Hints>\n"
7975 " </DoubleVectorProperty>\n"
7976 " <IntVectorProperty name=\"KernelSize\"\n"
7977 " default_values=\"32\"\n"
7978 " number_of_elements=\"1\"\n"
7979 " panel_visibility=\"advanced\">\n"
7980 " <IntRangeDomain name=\"range\" min=\"0\" max=\"1024\" />\n"
7981 " <Documentation>\n"
7982 " Set the SSAO number of samples.\n"
7983 " </Documentation>\n"
7984 " </IntVectorProperty>\n"
7985 " <IntVectorProperty name=\"Blur\"\n"
7986 " default_values=\"0\"\n"
7987 " number_of_elements=\"1\"\n"
7988 " panel_visibility=\"advanced\">\n"
7989 " <BooleanDomain name=\"bool\" />\n"
7990 " <Documentation>\n"
7991 " Enable or disable the blurring of the ambient occlusion.\n"
7992 " Blurring can help to improve the result if samples number is low.\n"
7993 " </Documentation>\n"
7994 " </IntVectorProperty>\n"
7995 "\n"
7996 " <DoubleVectorProperty name=\"LODThreshold\"\n"
7997 " label=\"LOD Threshold\"\n"
7998 " default_values=\"20.0\"\n"
7999 " number_of_elements=\"1\">\n"
8000 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"102400.0\" />\n"
8001 " <Documentation>\n"
8002 " Set the data size (in megabytes) beyond which to employ decimation,\n"
8003 " if possible, to speed renders when interacting. 0 implies the use of\n"
8004 " decimation for all interactive renders.\n"
8005 " </Documentation>\n"
8006 " </DoubleVectorProperty>\n"
8007 "\n"
8008 " <DoubleVectorProperty name=\"LODResolution\"\n"
8009 " label=\"LOD Resolution\"\n"
8010 " default_values=\"0.5\"\n"
8011 " number_of_elements=\"1\"\n"
8012 " panel_visibility=\"advanced\">\n"
8013 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
8014 " <Documentation>\n"
8015 " Set the factor used to compute the decimated geometry when employed.\n"
8016 " This affects the size of the grid used for\n"
8017 " quadric clustering. For example, 1.0 implies maximum resolution while 0\n"
8018 " implies minimum resolution.\n"
8019 " </Documentation>\n"
8020 " <Hints>\n"
8021 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
8022 " <Property name=\"UseOutlineForLODRendering\" function=\"boolean_invert\" />\n"
8023 " </PropertyWidgetDecorator>\n"
8024 " </Hints>\n"
8025 " </DoubleVectorProperty>\n"
8026 "\n"
8027 " <DoubleVectorProperty name=\"NonInteractiveRenderDelay\"\n"
8028 " default_values=\"0\"\n"
8029 " number_of_elements=\"1\"\n"
8030 " panel_visibility=\"advanced\">\n"
8031 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"10\" />\n"
8032 " <Documentation>\n"
8033 " If decimated geometry was used for rendering during interaction, set the delay\n"
8034 " (in seconds) before doing a full resolution render when the interaction\n"
8035 " is finished.\n"
8036 " </Documentation>\n"
8037 " </DoubleVectorProperty>\n"
8038 "\n"
8039 " <DoubleVectorProperty name=\"WindowResizeNonInteractiveRenderDelay\"\n"
8040 " default_values=\"0.3\"\n"
8041 " number_of_elements=\"1\"\n"
8042 " panel_visibility=\"advanced\">\n"
8043 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"10\" />\n"
8044 " <Documentation>\n"
8045 " Set the delay (in seconds) before doing a full resolution render\n"
8046 " after the last resize of the window.\n"
8047 " </Documentation>\n"
8048 " </DoubleVectorProperty>\n"
8049 "\n"
8050 " <IntVectorProperty name=\"UseOutlineForLODRendering\"\n"
8051 " label=\"Use Outline For LOD Rendering\"\n"
8052 " default_values=\"0\"\n"
8053 " number_of_elements=\"1\">\n"
8054 " <BooleanDomain name=\"bool\" />\n"
8055 " <Documentation>\n"
8056 " Use outline, instead of decimated geometry when interacting, if applicable.\n"
8057 " </Documentation>\n"
8058 " </IntVectorProperty>\n"
8059 "\n"
8060 " <DoubleVectorProperty name=\"RemoteRenderThreshold\"\n"
8061 " default_values=\"20.0\"\n"
8062 " number_of_elements=\"1\">\n"
8063 " <DoubleRangeDomain min=\"0\" max=\"102400\" name=\"range\" />\n"
8064 " <Documentation>\n"
8065 " Set the data size (in megabytes) beyond which to render data remotely\n"
8066 " (or in parallel) when connected to parallel rendering capable server. In that case\n"
8067 " the rendered images are delivered to the client. Otherwise, the geometry is delivered\n"
8068 " to the client and rendering happens locally.\n"
8069 " </Documentation>\n"
8070 " </DoubleVectorProperty>\n"
8071 "\n"
8072 " <IntVectorProperty name=\"StillRenderImageReductionFactor\"\n"
8073 " default_values=\"1\"\n"
8074 " number_of_elements=\"1\"\n"
8075 " panel_visibility=\"advanced\" >\n"
8076 " <IntRangeDomain max=\"20\" min=\"1\" name=\"range\" />\n"
8077 " <Documentation>\n"
8078 " Set the sub-sampling factor to use for non-interactive rendering.\n"
8079 " When rendering on large tiles (or multiple tiles),\n"
8080 " sub-sampling will help improve image compositing performance. This has no effect\n"
8081 " if remote/parallel rendering is not being used.\n"
8082 " </Documentation>\n"
8083 " </IntVectorProperty>\n"
8084 "\n"
8085 " <IntVectorProperty name=\"ImageReductionFactor\"\n"
8086 " default_values=\"2\"\n"
8087 " number_of_elements=\"1\"\n"
8088 " panel_visibility=\"advanced\">\n"
8089 " <IntRangeDomain max=\"20\" min=\"1\" name=\"range\" />\n"
8090 " <Documentation>\n"
8091 " To reduce image compositing costs during interactions, set the\n"
8092 " image sub-sampling factor. Set to 1 to not use any subsampling.\n"
8093 " </Documentation>\n"
8094 " </IntVectorProperty>\n"
8095 "\n"
8096 " <StringVectorProperty name=\"CompressorConfig\"\n"
8097 " default_values=\"vtkLZ4Compressor 0 3\"\n"
8098 " number_of_elements=\"1\"\n"
8099 " panel_visibility=\"advanced\"\n"
8100 " panel_widget=\"image_compressor_config\">\n"
8101 " <Documentation>\n"
8102 " Set the compression method used when transferring rendered images from\n"
8103 " the server to the client.\n"
8104 " </Documentation>\n"
8105 " <Hints>\n"
8106 " <SupportsLZ4/>\n"
8107 " </Hints>\n"
8108 " </StringVectorProperty>\n"
8109 "\n"
8110 " <IntVectorProperty name=\"OutlineThreshold\"\n"
8111 " default_values=\"250\"\n"
8112 " number_of_elements=\"1\"\n"
8113 " command=\"SetOutlineThreshold\">\n"
8114 " <IntRangeDomain name=\"range\" min=\"0\" max=\"500\" />\n"
8115 " <Documentation>\n"
8116 " When opening a dataset or creating a new filter that has a number of\n"
8117 " cells greater than this threshold (in millions), use the Outline\n"
8118 " representation by default.\n"
8119 " </Documentation>\n"
8120 " </IntVectorProperty>\n"
8121 "\n"
8122 " <IntVectorProperty name=\"TwoSidedLighting\"\n"
8123 " default_values=\"1\"\n"
8124 " number_of_elements=\"1\"\n"
8125 " command=\"SetTwoSidedLighting\">\n"
8126 " <BooleanDomain name=\"bool\" />\n"
8127 " <Documentation>\n"
8128 " When rendering a volume, this option simulates light coming from both its direction\n"
8129 " and its opposite for all lights in the scene.\n"
8130 " </Documentation>\n"
8131 " </IntVectorProperty>\n"
8132 "\n"
8133 " <IntVectorProperty name=\"DefaultInteractionMode\"\n"
8134 " command=\"SetDefaultInteractionMode\"\n"
8135 " number_of_elements=\"1\"\n"
8136 " default_values=\"0\"\n"
8137 " panel_visibility=\"advanced\">\n"
8138 " <Documentation>\n"
8139 " When opening a dataset, set the initial interaction mode.\n"
8140 " </Documentation>\n"
8141 " <EnumerationDomain name=\"enum\">\n"
8142 " <Entry text=\"Automatic, based on the first time step\" value=\"0\" />\n"
8143 " <Entry text=\"Always 2D\" value=\"1\" />\n"
8144 " <Entry text=\"Always 3D\" value=\"2\" />\n"
8145 " </EnumerationDomain>\n"
8146 " </IntVectorProperty>\n"
8147 "\n"
8148 " <IntVectorProperty name=\"ShowAnnotation\"\n"
8149 " default_values=\"0\"\n"
8150 " number_of_elements=\"1\"\n"
8151 " panel_visibility=\"advanced\">\n"
8152 " <BooleanDomain name=\"bool\" />\n"
8153 " <Documentation>\n"
8154 " Set whether to see annotation providing advanced debugging and performance\n"
8155 ;
8156
8157 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
8159 " information about each render.\n"
8160 " </Documentation>\n"
8161 " </IntVectorProperty>\n"
8162 "\n"
8163 " <IntVectorProperty name=\"PointPickingRadius\"\n"
8164 " command=\"SetPointPickingRadius\"\n"
8165 " default_values=\"50\"\n"
8166 " number_of_elements=\"1\"\n"
8167 " panel_visibility=\"advanced\">\n"
8168 " <IntRangeDomain name=\"range\" min=\"0\" max=\"100\" />\n"
8169 " <Documentation>\n"
8170 " Set the radius (in pixels) to include when using *Select Points On*\n"
8171 " to click-and-select a single point on the **Render View**.\n"
8172 " </Documentation>\n"
8173 " </IntVectorProperty>\n"
8174 "\n"
8175 " <IntVectorProperty name=\"DisableIceT\"\n"
8176 " label=\"Disable IceT\"\n"
8177 " command=\"SetDisableIceT\"\n"
8178 " default_values=\"0\"\n"
8179 " number_of_elements=\"1\"\n"
8180 " panel_visibility=\"advanced\">\n"
8181 " <BooleanDomain name=\"bool\" />\n"
8182 " <Documentation>\n"
8183 " Set to disable IceT (default is unchecked). This is not common and only provided\n"
8184 " for special rendering modes/mappers.\n"
8185 " </Documentation>\n"
8186 " <Hints>\n"
8187 " <RestartRequired />\n"
8188 " </Hints>\n"
8189 " </IntVectorProperty>\n"
8190 "\n"
8191 " <IntVectorProperty name=\"EnableFastPreselection\"\n"
8192 " label=\"Enable fast preselection\"\n"
8193 " command=\"SetEnableFastPreselection\"\n"
8194 " default_values=\"0\"\n"
8195 " number_of_elements=\"1\"\n"
8196 " panel_visibility=\"advanced\">\n"
8197 " <BooleanDomain name=\"bool\" />\n"
8198 " <Documentation>\n"
8199 " Enable fast preselection. When enabled, the preselection is computed using\n"
8200 " the visible geometry. This dramatically improves performance of preselection\n"
8201 " highlighting, especially for big datasets.\n"
8202 " </Documentation>\n"
8203 " </IntVectorProperty>\n"
8204 " <IntVectorProperty name=\"GrowSelectionRemoveSeed\"\n"
8205 " label=\"Remove seed on grow selection\"\n"
8206 " command=\"SetGrowSelectionRemoveSeed\"\n"
8207 " default_values=\"0\"\n"
8208 " number_of_elements=\"1\"\n"
8209 " panel_visibility=\"advanced\">\n"
8210 " <BooleanDomain name=\"bool\" />\n"
8211 " <Documentation>\n"
8212 " When enabled and growing selection, remove the initial selection seed.\n"
8213 " </Documentation>\n"
8214 " </IntVectorProperty>\n"
8215 " <IntVectorProperty name=\"GrowSelectionRemoveIntermediateLayers\"\n"
8216 " label=\"Remove intermediate layers on grow selection\"\n"
8217 " command=\"SetGrowSelectionRemoveIntermediateLayers\"\n"
8218 " default_values=\"0\"\n"
8219 " number_of_elements=\"1\"\n"
8220 " panel_visibility=\"advanced\">\n"
8221 " <BooleanDomain name=\"bool\" />\n"
8222 " <Documentation>\n"
8223 " When enabled and growing selection, remove the intermediate layers.\n"
8224 " </Documentation>\n"
8225 " </IntVectorProperty>\n"
8226 "\n"
8227 " <DoubleVectorProperty command=\"SetZoomClosestOffsetRatio\"\n"
8228 " name=\"ZoomClosestOffsetRatio\"\n"
8229 " default_values=\"0.9\"\n"
8230 " number_of_elements=\"1\"\n"
8231 " panel_visibility=\"advanced\">\n"
8232 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"1\"/>\n"
8233 " <Documentation>\n"
8234 " ZoomClosestOffsetRatio is used to control the camera's zoom level when using Reset Camera Closest and\n"
8235 " Zoom Closest To Data. If the offset is 0, the zoom level will be identical to Reset/Zoom To Data's level.\n"
8236 " If the offset is 1, the bounding box of the view/dataset will tightly fit to the boundary of the view.\n"
8237 " </Documentation>\n"
8238 " </DoubleVectorProperty>\n"
8239 "\n"
8240 " <PropertyGroup label=\"Geometry Mapper Options\">\n"
8241 " <Property name=\"ResolveCoincidentTopology\" />\n"
8242 " <Property name=\"PolygonOffsetParameters\" />\n"
8243 " <Property name=\"ZShift\" />\n"
8244 " </PropertyGroup>\n"
8245 "\n"
8246 " <PropertyGroup label=\"Translucent Rendering Options\">\n"
8247 " <Property name=\"DepthPeeling\" />\n"
8248 " <Property name=\"MaximumNumberOfPeels\" />\n"
8249 " </PropertyGroup>\n"
8250 "\n"
8251 " <PropertyGroup label=\"Antialiasing Options\">\n"
8252 " <Property name=\"UseFXAA\" />\n"
8253 " <Property name=\"FXAARelativeContrastThreshold\" />\n"
8254 " <Property name=\"FXAAHardContrastThreshold\" />\n"
8255 " <Property name=\"FXAASubpixelBlendLimit\" />\n"
8256 " <Property name=\"FXAASubpixelContrastThreshold\" />\n"
8257 " <Property name=\"FXAAUseHighQualityEndpoints\" />\n"
8258 " <Property name=\"FXAAEndpointSearchIterations\" />\n"
8259 " </PropertyGroup>\n"
8260 "\n"
8261 " <PropertyGroup label=\"Tone Mapping Options\">\n"
8262 " <Property name=\"ToneMappingType\" />\n"
8263 " <Property name=\"GenericFilmicPresets\" />\n"
8264 " <Property name=\"Contrast\" />\n"
8265 " <Property name=\"Shoulder\" />\n"
8266 " <Property name=\"MidIn\" />\n"
8267 " <Property name=\"MidOut\" />\n"
8268 " <Property name=\"HdrMax\" />\n"
8269 " <Property name=\"UseACES\" />\n"
8270 " </PropertyGroup>\n"
8271 "\n"
8272 " <PropertyGroup label=\"Ambient Occlusion Options\">\n"
8273 " <Property name=\"UseSSAODefaultPresets\" />\n"
8274 " <Property name=\"Radius\" />\n"
8275 " <Property name=\"KernelSize\" />\n"
8276 " <Property name=\"Bias\" />\n"
8277 " <Property name=\"Blur\" />\n"
8278 " </PropertyGroup>\n"
8279 "\n"
8280 " <PropertyGroup label=\"Interactive Rendering Options\">\n"
8281 " <Property name=\"LODThreshold\" />\n"
8282 " <Property name=\"LODResolution\" />\n"
8283 " <Property name=\"NonInteractiveRenderDelay\" />\n"
8284 " <Property name=\"UseOutlineForLODRendering\" />\n"
8285 " <Property name=\"WindowResizeNonInteractiveRenderDelay\" />\n"
8286 " </PropertyGroup>\n"
8287 "\n"
8288 " <PropertyGroup label=\"Remote/Parallel Rendering Options\">\n"
8289 " <Property name=\"RemoteRenderThreshold\" />\n"
8290 " <Property name=\"StillRenderImageReductionFactor\" />\n"
8291 " </PropertyGroup>\n"
8292 "\n"
8293 " <PropertyGroup label=\"Client/Server Rendering Options\">\n"
8294 " <Property name=\"ImageReductionFactor\" />\n"
8295 " <Property name=\"CompressorConfig\" />\n"
8296 " </PropertyGroup>\n"
8297 "\n"
8298 " <PropertyGroup label=\"Selection Options\">\n"
8299 " <Property name=\"EnableFastPreselection\" />\n"
8300 " <Property name=\"GrowSelectionRemoveSeed\" />\n"
8301 " <Property name=\"GrowSelectionRemoveIntermediateLayers\" />\n"
8302 " </PropertyGroup>\n"
8303 "\n"
8304 " <PropertyGroup label=\"Miscellaneous\">\n"
8305 " <Property name=\"OutlineThreshold\" />\n"
8306 " <Property name=\"TwoSidedLighting\" />\n"
8307 " <Property name=\"DefaultInteractionMode\" />\n"
8308 " <Property name=\"ShowAnnotation\" />\n"
8309 " <Property name=\"PointPickingRadius\" />\n"
8310 " <Property name=\"DisableIceT\" />\n"
8311 " <Property name=\"ZoomClosestOffsetRatio\" />\n"
8312 " </PropertyGroup>\n"
8313 " <Hints>\n"
8314 " <UseDocumentationForLabels />\n"
8315 " </Hints>\n"
8316 " </SettingsProxy>\n"
8317 "\n"
8318 " <!-- ================================================================== -->\n"
8319 " <SettingsProxy name=\"RenderViewInteractionSettings\" label=\"Camera\"\n"
8320 " processes=\"client|dataserver|renderserver\">\n"
8321 " <IntVectorProperty name=\"Camera3DManipulators\"\n"
8322 " label=\"Camera 3D Manipulators\"\n"
8323 " number_of_elements=\"9\"\n"
8324 " default_values=\"4 1 2 3 4 1 7 4 6\"\n"
8325 " panel_widget=\"camera_manipulator\">\n"
8326 " <!-- For now, we are marking this property is_internal so that it won't\n"
8327 " get saved in state files. -->\n"
8328 " <Documentation>\n"
8329 " Select how interactions are mapped to camera movements when in 3D interaction mode.\n"
8330 " </Documentation>\n"
8331 " <EnumerationDomain name=\"enum\">\n"
8332 " <Entry text=\"None\" value=\"0\" />\n"
8333 " <Entry text=\"Pan\" value=\"1\" />\n"
8334 " <Entry text=\"Zoom\" value=\"2\" />\n"
8335 " <Entry text=\"Roll\" value=\"3\" />\n"
8336 " <Entry text=\"Rotate\" value=\"4\" />\n"
8337 " <Entry text=\"Multi-Rotate\" value=\"5\" />\n"
8338 " <Entry text=\"ZoomToMouse\" value=\"6\" />\n"
8339 " <Entry text=\"SkyboxRotate\" value=\"7\" />\n"
8340 " </EnumerationDomain>\n"
8341 " </IntVectorProperty>\n"
8342 " <DoubleVectorProperty command=\"SetCamera3DMouseWheelMotionFactor\"\n"
8343 " default_values=\"1\"\n"
8344 " name=\"Camera3DMouseWheelMotionFactor\"\n"
8345 " label=\"3D Mouse Wheel Factor\"\n"
8346 " number_of_elements=\"1\">\n"
8347 " <DoubleRangeDomain max=\"10\"\n"
8348 " min=\"0\"\n"
8349 " name=\"range\"\n"
8350 " resolution=\"1000\" />\n"
8351 " <Documentation>Set the wheel motion factor for 3D interaction.</Documentation>\n"
8352 " </DoubleVectorProperty>\n"
8353 " <IntVectorProperty name=\"Camera2DManipulators\"\n"
8354 " label=\"Camera 2D Manipulators\"\n"
8355 " number_of_elements=\"9\"\n"
8356 " default_values=\"1 3 2 2 2 6 3 1 4\"\n"
8357 " panel_widget=\"camera_manipulator\">\n"
8358 " <!-- For now, we are marking this property is_internal so that it won't\n"
8359 " get saved in state files. -->\n"
8360 " <Documentation>\n"
8361 " Select how interactions are mapped to camera movements when in 2D interaction mode.\n"
8362 " </Documentation>\n"
8363 " <EnumerationDomain name=\"enum\">\n"
8364 " <Entry text=\"None\" value=\"0\" />\n"
8365 " <Entry text=\"Pan\" value=\"1\" />\n"
8366 " <Entry text=\"Zoom\" value=\"2\" />\n"
8367 " <Entry text=\"Roll\" value=\"3\" />\n"
8368 " <Entry text=\"Rotate\" value=\"4\" />\n"
8369 " <Entry text=\"ZoomToMouse\" value=\"6\" />\n"
8370 " </EnumerationDomain>\n"
8371 " </IntVectorProperty>\n"
8372 " <DoubleVectorProperty command=\"SetCamera2DMouseWheelMotionFactor\"\n"
8373 " default_values=\"1\"\n"
8374 " name=\"Camera2DMouseWheelMotionFactor\"\n"
8375 " label=\"2D Mouse Wheel Factor\"\n"
8376 " number_of_elements=\"1\">\n"
8377 " <DoubleRangeDomain max=\"10\"\n"
8378 " min=\"0\"\n"
8379 " name=\"range\"\n"
8380 " resolution=\"1000\" />\n"
8381 " <Documentation>Set the wheel motion factor for 2D interaction.</Documentation>\n"
8382 " </DoubleVectorProperty>\n"
8383 " <IntVectorProperty name=\"ReverseMouseWheelZoomDirection\"\n"
8384 " command=\"SetReverseMouseWheelZoomDirection\"\n"
8385 " default_values=\"0\"\n"
8386 " number_of_elements=\"1\"\n"
8387 " label=\"Reverse Mouse Wheel Zoom Direction\">\n"
8388 " <BooleanDomain name=\"bool\" />\n"
8389 " <Documentation>\n"
8390 " This option changes the direction of the mouse wheel for zooming in and out.\n"
8391 " </Documentation>\n"
8392 " </IntVectorProperty>\n"
8393 " <IntVectorProperty name=\"MouseWheelZoomsToCursor\"\n"
8394 " command=\"SetMouseWheelZoomsToCursor\"\n"
8395 " default_values=\"0\"\n"
8396 " number_of_elements=\"1\"\n"
8397 " label=\"Mouse Wheel Zooms To Cursor\">\n"
8398 " <BooleanDomain name=\"bool\" />\n"
8399 " <Documentation>\n"
8400 " Zooms the renderer's camera to the projected point under the cursor position.\n"
8401 " </Documentation>\n"
8402 " </IntVectorProperty>\n"
8403 " <PropertyGroup label=\"2D Interaction Options\">\n"
8404 " <Property name=\"Camera2DManipulators\" />\n"
8405 " <Property name=\"Camera2DMouseWheelMotionFactor\" />\n"
8406 " </PropertyGroup>\n"
8407 " <PropertyGroup label=\"3D Interaction Options\">\n"
8408 " <Property name=\"Camera3DManipulators\" />\n"
8409 " <Property name=\"Camera3DMouseWheelMotionFactor\" />\n"
8410 " </PropertyGroup>\n"
8411 " <PropertyGroup label=\"Mouse Wheel Options\">\n"
8412 " <Property name=\"ReverseMouseWheelZoomDirection\" />\n"
8413 " <Property name=\"MouseWheelZoomsToCursor\" />\n"
8414 " </PropertyGroup>\n"
8415 " <Hints>\n"
8416 " <UseDocumentationForLabels />\n"
8417 " </Hints>\n"
8418 " </SettingsProxy>\n"
8419 "\n"
8420 " <!-- ================================================================== -->\n"
8421 " <SettingsProxy name=\"RepresentedArrayListSettings\"\n"
8422 " label=\"Represented Attributes\"\n"
8423 " processes=\"client\"\n"
8424 " class=\"vtkPVRepresentedArrayListSettings\">\n"
8425 " <StringVectorProperty command=\"SetFilterExpression\"\n"
8426 " name=\"FilterExpressions\"\n"
8427 " label=\"Filter Expressions\"\n"
8428 " number_of_elements_per_command=\"1\"\n"
8429 " repeat_command=\"1\"\n"
8430 " set_number_command=\"SetNumberOfFilterExpressions\"\n"
8431 " use_index=\"1\">\n"
8432 " <Documentation>\n"
8433 " List of expressions used to filter out arrays you do not want to display in the color array list.\n"
8434 " </Documentation>\n"
8435 " <Hints>\n"
8436 " <ShowLabel />\n"
8437 " </Hints>\n"
8438 " </StringVectorProperty>\n"
8439 " <IntVectorProperty name=\"ComputeArrayMagnitude\"\n"
8440 " command=\"SetComputeArrayMagnitude\"\n"
8441 " number_of_elements=\"1\"\n"
8442 " default_values=\"1\"\n"
8443 " panel_visibility=\"advanced\">\n"
8444 " <BooleanDomain name=\"bool\"/>\n"
8445 " <Documentation>\n"
8446 " Controls whether or not ParaView should compute and display the magnitude for\n"
8447 " multi-components data attributes.\n"
8448 " </Documentation>\n"
8449 " </IntVectorProperty>\n"
8450 " <IntVectorProperty name=\"ArrayMagnitudeExceptions\"\n"
8451 " command=\"SetArrayMagnitudeException\"\n"
8452 " label=\"Array Magnitude Exceptions\"\n"
8453 " number_of_elements_per_command=\"1\"\n"
8454 " repeat_command=\"1\"\n"
8455 " set_number_command=\"SetNumberOfArrayMagnitudeExceptions\"\n"
8456 " use_index=\"1\"\n"
8457 " panel_visibility=\"advanced\">\n"
8458 " <Documentation>\n"
8459 " List of exceptions for the \"ComputeArrayMagnitude\" setting. If \"ComputeArrayMagnitude\" is\n"
8460 " untoggled then the list describes the number of components for which ParaView will\n"
8461 " still compute the magnitude. Else the list describes the number of components for which\n"
8462 " ParaView will not compute the magnitude.\n"
8463 " </Documentation>\n"
8464 " <Hints>\n"
8465 " <ShowComponentLabels>\n"
8466 " <ComponentLabel component=\"0\" label=\"Exceptions\"/>\n"
8467 " </ShowComponentLabels>\n"
8468 " </Hints>\n"
8469 " </IntVectorProperty>\n"
8470 "\n"
8471 " <StringVectorProperty command=\"SetChartsDefaultXAxis\"\n"
8472 " name=\"ChartsDefaultXAxis\"\n"
8473 " number_of_elements_per_command=\"1\"\n"
8474 " repeat_command=\"1\"\n"
8475 " default_values_delimiter=\";\"\n"
8476 " default_values=\"in_extents;Time;time;arc_length;XArray;x_array;Frequency\"\n"
8477 " number_of_elements=\"7\"\n"
8478 " set_number_command=\"SetNumberOfChartsDefaultXAxis\"\n"
8479 ;
8480
8481 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
8483 " use_index=\"1\">\n"
8484 " <Documentation>\n"
8485 " List of array names to use as X axis when displaying it in charts.\n"
8486 " </Documentation>\n"
8487 " <Hints>\n"
8488 " <ShowLabel />\n"
8489 " <AllowRestoreDefaults />\n"
8490 " </Hints>\n"
8491 " </StringVectorProperty>\n"
8492 "\n"
8493 " <StringVectorProperty command=\"SetChartsHiddenAttributes\"\n"
8494 " name=\"ChartsHiddenAttributes\"\n"
8495 " number_of_elements_per_command=\"1\"\n"
8496 " repeat_command=\"1\"\n"
8497 " default_values_delimiter=\";\"\n"
8498 " default_values=\"^arc_length;^bin_extents;^(GlobalElement|GlobalNode|Object|File)Id;^object_id;^Pedigree;^Points_;^Time;^vtk;^(X|Y|Z|N|ids)( .*|$);^Frequency;^Point Coordinates\"\n"
8499 " number_of_elements=\"10\"\n"
8500 " set_number_command=\"SetNumberOfChartsHiddenAttributes\"\n"
8501 " use_index=\"1\">\n"
8502 " <Documentation>\n"
8503 " List of regex that describes array to not display by default. Note that \"Component\" arrays are always hidden by default even it not listed here.\n"
8504 " </Documentation>\n"
8505 " <Hints>\n"
8506 " <ShowLabel />\n"
8507 " <AllowRestoreDefaults />\n"
8508 " </Hints>\n"
8509 " </StringVectorProperty>\n"
8510 "\n"
8511 " <Hints>\n"
8512 " <UseDocumentationForLabels />\n"
8513 " </Hints>\n"
8514 " </SettingsProxy>\n"
8515 "\n"
8516 " <SettingsProxy name=\"IOSettings\"\n"
8517 " label=\"IO\"\n"
8518 " processes=\"client\"\n"
8519 " class=\"vtkPVIOSettings\">\n"
8520 " <StringVectorProperty name=\"ReaderDetails\"\n"
8521 " label=\"Default reader details\"\n"
8522 " number_of_elements_per_command=\"3\"\n"
8523 " repeat_command=\"1\">\n"
8524 " <Documentation>\n"
8525 " List of file patterns, names and underlying filter to use by default when selecting a file with the \"Supported Files\" filter selected.\n"
8526 " </Documentation>\n"
8527 " <Hints>\n"
8528 " <ShowLabel />\n"
8529 " <ShowComponentLabels>\n"
8530 " <ComponentLabel component=\"0\" label=\"File pattern\"/>\n"
8531 " <ComponentLabel component=\"1\" label=\"Description\"/>\n"
8532 " <ComponentLabel component=\"2\" label=\"Filter\"/>\n"
8533 " </ShowComponentLabels>\n"
8534 " </Hints>\n"
8535 " </StringVectorProperty>\n"
8536 " <StringVectorProperty command=\"SetExcludedNameFilter\"\n"
8537 " name=\"ReaderSelection\"\n"
8538 " number_of_elements_per_command=\"1\"\n"
8539 " repeat_command=\"1\"\n"
8540 " set_number_command=\"SetNumberOfExcludedNameFilters\"\n"
8541 " use_index=\"1\"\n"
8542 " panel_widget=\"reader_selector\">\n"
8543 " <Documentation>\n"
8544 " List of readers to display or hide in the File .. Open dialog.\n"
8545 " </Documentation>\n"
8546 " </StringVectorProperty>\n"
8547 " <StringVectorProperty\n"
8548 " name=\"AllNameFilters\"\n"
8549 " command=\"GetAllNameFilters\"\n"
8550 " label=\"Allowed Readers\"\n"
8551 " number_of_elements_per_command=\"2\"\n"
8552 " element_types=\"2 0\"\n"
8553 " repeat_command=\"1\"\n"
8554 " panel_visibility=\"never\">\n"
8555 " <Documentation>\n"
8556 " List of all readers, with on/off values paired. Used by the custom widget above, not displayed.\n"
8557 " </Documentation>\n"
8558 " <Hints>\n"
8559 " <ShowLabel />\n"
8560 " </Hints>\n"
8561 " </StringVectorProperty>\n"
8562 " <StringVectorProperty name=\"LocationEnvironmentVariables\"\n"
8563 " label=\"File dialog 'Location' variables\"\n"
8564 " number_of_elements_per_command=\"2\"\n"
8565 " repeat_command=\"1\">\n"
8566 " <Documentation>\n"
8567 " List of labels and environment variables to add to the 'Location' list in the File dialog.\n"
8568 " The value of the environment variable is looked up on the connected server and treated as a directory path.\n"
8569 " </Documentation>\n"
8570 " <Hints>\n"
8571 " <ShowLabel />\n"
8572 " <ShowComponentLabels>\n"
8573 " <ComponentLabel component=\"0\" label=\"Label\"/>\n"
8574 " <ComponentLabel component=\"1\" label=\"Environment variable\"/>\n"
8575 " </ShowComponentLabels>\n"
8576 " </Hints>\n"
8577 " </StringVectorProperty>\n"
8578 "\n"
8579 " <Hints>\n"
8580 " <UseDocumentationForLabels />\n"
8581 " </Hints>\n"
8582 " </SettingsProxy>\n"
8583 "\n"
8584 " <!-- ================================================================== -->\n"
8585 " <SettingsProxy name=\"ColorPalette\" label=\"Color Palette\" serializable=\"1\"\n"
8586 " processes=\"client|dataserver|renderserver\"\n"
8587 " class=\"vtkPVRenderViewSettings\">\n"
8588 " <DoubleVectorProperty default_values=\"1.0 0.0 1.0\"\n"
8589 " label=\"Border\"\n"
8590 " name=\"BorderColor\"\n"
8591 " number_of_elements=\"3\"\n"
8592 " panel_widget=\"color_selector\">\n"
8593 " <DoubleRangeDomain max=\"1 1 1\"\n"
8594 " min=\"0 0 0\"\n"
8595 " name=\"range\" />\n"
8596 " <Documentation>Color used for border surrounding the text.</Documentation>\n"
8597 " </DoubleVectorProperty>\n"
8598 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
8599 " label=\"Surface\"\n"
8600 " name=\"SurfaceColor\"\n"
8601 " number_of_elements=\"3\"\n"
8602 " panel_widget=\"color_selector\">\n"
8603 " <DoubleRangeDomain max=\"1 1 1\"\n"
8604 " min=\"0 0 0\"\n"
8605 " name=\"range\" />\n"
8606 " <Documentation>Color used when solid coloring surfaces and faces.</Documentation>\n"
8607 " </DoubleVectorProperty>\n"
8608 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
8609 " label=\"Foreground\"\n"
8610 " name=\"ForegroundColor\"\n"
8611 " number_of_elements=\"3\"\n"
8612 " panel_widget=\"color_selector\">\n"
8613 " <DoubleRangeDomain max=\"1 1 1\"\n"
8614 " min=\"0 0 0\"\n"
8615 " name=\"range\" />\n"
8616 " <Documentation>Color used for rendering elements like wireframes, points.</Documentation>\n"
8617 " </DoubleVectorProperty>\n"
8618 " <DoubleVectorProperty default_values=\"0.0 0.0 0.5\"\n"
8619 " label=\"Edges\"\n"
8620 " name=\"EdgeColor\"\n"
8621 " number_of_elements=\"3\"\n"
8622 " panel_widget=\"color_selector\">\n"
8623 " <DoubleRangeDomain max=\"1 1 1\"\n"
8624 " min=\"0 0 0\"\n"
8625 " name=\"range\" />\n"
8626 " <Documentation>\n"
8627 " Color used for the edges when using 'Surface With Edges' representation.\n"
8628 " </Documentation>\n"
8629 " </DoubleVectorProperty>\n"
8630 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
8631 " label=\"Text\"\n"
8632 " name=\"TextAnnotationColor\"\n"
8633 " number_of_elements=\"3\"\n"
8634 " panel_widget=\"color_selector\">\n"
8635 " <DoubleRangeDomain max=\"1 1 1\"\n"
8636 " min=\"0 0 0\"\n"
8637 " name=\"range\" />\n"
8638 " <Documentation>Color used for text and other annotations.</Documentation>\n"
8639 " </DoubleVectorProperty>\n"
8640 " <DoubleVectorProperty default_values=\"1.0 0.0 1.0\"\n"
8641 " label=\"Selection\"\n"
8642 " name=\"SelectionColor\"\n"
8643 " number_of_elements=\"3\"\n"
8644 " panel_widget=\"color_selector\">\n"
8645 " <DoubleRangeDomain max=\"1 1 1\"\n"
8646 " min=\"0 0 0\"\n"
8647 " name=\"range\" />\n"
8648 " <Documentation>Color used for showing selected\n"
8649 " cells/points.</Documentation>\n"
8650 " </DoubleVectorProperty>\n"
8651 " <DoubleVectorProperty default_values=\"0.5 0.0 1.0\"\n"
8652 " label=\"Interactive Selection\"\n"
8653 " name=\"InteractiveSelectionColor\"\n"
8654 " number_of_elements=\"3\"\n"
8655 " panel_widget=\"color_selector\">\n"
8656 " <DoubleRangeDomain max=\"1 1 1\"\n"
8657 " min=\"0 0 0\"\n"
8658 " name=\"range\" />\n"
8659 " <Documentation>Color used for showing interactive selection.</Documentation>\n"
8660 " </DoubleVectorProperty>\n"
8661 " <DoubleVectorProperty default_values=\"0.0 1.0 0.0\"\n"
8662 " label=\"Interactive Widget\"\n"
8663 " name=\"InteractiveWidgetColor\"\n"
8664 " number_of_elements=\"3\"\n"
8665 " panel_widget=\"color_selector\">\n"
8666 " <DoubleRangeDomain max=\"1 1 1\"\n"
8667 " min=\"0 0 0\"\n"
8668 " name=\"range\" />\n"
8669 " <Documentation>Color used for showing widget handles when interacting.</Documentation>\n"
8670 " </DoubleVectorProperty>\n"
8671 " <DoubleVectorProperty default_values=\"1.0 0.0 0.0\"\n"
8672 " label=\"Widget\"\n"
8673 " name=\"WidgetColor\"\n"
8674 " number_of_elements=\"3\"\n"
8675 " panel_widget=\"color_selector\">\n"
8676 " <DoubleRangeDomain max=\"1 1 1\"\n"
8677 " min=\"0 0 0\"\n"
8678 " name=\"range\" />\n"
8679 " <Documentation>Color used for showing widget handles that are available for interaction.</Documentation>\n"
8680 " </DoubleVectorProperty>\n"
8681 " <IntVectorProperty command=\"SetBackgroundColorMode\"\n"
8682 " name=\"BackgroundColorMode\"\n"
8683 " number_of_elements=\"1\"\n"
8684 " default_values=\"0\">\n"
8685 " <EnumerationDomain name=\"enum\">\n"
8686 " <Entry text=\"Single Color\" value=\"0\" />\n"
8687 " <Entry text=\"Gradient\" value=\"1\" />\n"
8688 " </EnumerationDomain>\n"
8689 " <Documentation>\n"
8690 " Select the background color mode.\n"
8691 " </Documentation>\n"
8692 " </IntVectorProperty>\n"
8693 " <DoubleVectorProperty default_values=\"0.0 0.0 0.16\"\n"
8694 " command=\"SetBackground2Color\"\n"
8695 " label=\"Background 2\"\n"
8696 " name=\"BackgroundColor2\"\n"
8697 " number_of_elements=\"3\"\n"
8698 " panel_widget=\"color_selector\">\n"
8699 " <DoubleRangeDomain max=\"1 1 1\"\n"
8700 " min=\"0 0 0\"\n"
8701 " name=\"range\" />\n"
8702 " <Documentation>Color used for the top section for gradient backgrounds.</Documentation>\n"
8703 " <Hints>\n"
8704 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
8705 " mode=\"enabled_state\"\n"
8706 " property=\"BackgroundColorMode\"\n"
8707 " value=\"1\" />\n"
8708 " </Hints>\n"
8709 " </DoubleVectorProperty>\n"
8710 " <DoubleVectorProperty default_values=\"0.32 0.34 0.43\"\n"
8711 " label=\"Background\"\n"
8712 " command=\"SetBackgroundColor\"\n"
8713 " name=\"BackgroundColor\"\n"
8714 " number_of_elements=\"3\"\n"
8715 " panel_widget=\"color_selector\">\n"
8716 " <DoubleRangeDomain max=\"1 1 1\"\n"
8717 " min=\"0 0 0\"\n"
8718 " name=\"range\" />\n"
8719 " <Documentation>\n"
8720 " Color used as background for the view. When using gradient backgrounds,\n"
8721 " this is the color used for the lower section of the viewport.\n"
8722 " </Documentation>\n"
8723 " </DoubleVectorProperty>\n"
8724 "\n"
8725 " <PropertyGroup label=\"Selection\">\n"
8726 " <Property name=\"SelectionColor\" />\n"
8727 " <Property name=\"InteractiveSelectionColor\" />\n"
8728 " </PropertyGroup>\n"
8729 "\n"
8730 " <PropertyGroup label=\"Background\">\n"
8731 " <Property name=\"BackgroundColorMode\" />\n"
8732 " <Property name=\"BackgroundColor2\" />\n"
8733 " <Property name=\"BackgroundColor\" />\n"
8734 " </PropertyGroup>\n"
8735 "\n"
8736 " <Property name=\"LoadPalette\"\n"
8737 " panel_widget=\"color_palette_selector\">\n"
8738 " <Documentation>\n"
8739 " You can explicitly set the colors in the application's color palette\n"
8740 " above or you can load one of the predefined color palettes to\n"
8741 " initialize the active palette.\n"
8742 " </Documentation>\n"
8743 " </Property>\n"
8744 " <Hints>\n"
8745 " <UseDocumentationForLabels />\n"
8746 " </Hints>\n"
8747 " <!-- End of ColorPalette -->\n"
8748 " </SettingsProxy>\n"
8749 " <!-- end of \"settings\" -->\n"
8750 " </ProxyGroup>\n"
8751 "\n"
8752 " <!-- ==================================================================== -->\n"
8753 " <ProxyGroup name=\"lookup_tables\">\n"
8754 "\n"
8755 " <!-- ================================================================== -->\n"
8756 " <TransferFunctionProxy class=\"vtkPVDiscretizableColorTransferFunction\"\n"
8757 " name=\"PVLookupTable\"\n"
8758 " post_push=\"Build\"\n"
8759 " processes=\"dataserver|renderserver|client\">\n"
8760 " <IntVectorProperty name=\"IndexedLookup\"\n"
8761 " command=\"SetIndexedLookup\"\n"
8762 " default_values=\"0\"\n"
8763 " number_of_elements=\"1\"\n"
8764 " label=\"Interpret Values As Categories\">\n"
8765 " <BooleanDomain name=\"bool\" />\n"
8766 " <Documentation>\n"
8767 " When enabled, the color transfer function switches to indexed-lookup\n"
8768 " (categorical colors) mode.\n"
8769 " </Documentation>\n"
8770 " <Hints>\n"
8771 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
8772 " <Expression type=\"and\">\n"
8773 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
8774 " <Property name=\"Using2DTransferFunction\" function=\"boolean_invert\"/>\n"
8775 " </PropertyWidgetDecorator>\n"
8776 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
8777 " <Property name=\"UsingSeparateOpacityArray\" function=\"boolean_invert\"/>\n"
8778 " </PropertyWidgetDecorator>\n"
8779 " </Expression>\n"
8780 " </PropertyWidgetDecorator>\n"
8781 " </Hints>\n"
8782 " </IntVectorProperty>\n"
8783 "\n"
8784 " <IntVectorProperty default_values=\"0\"\n"
8785 " name=\"AnnotationsInitialized\"\n"
8786 " number_of_elements=\"1\"\n"
8787 " panel_visibility=\"never\" >\n"
8788 " <Documentation>\n"
8789 " Set to 1 to indicate that the annotations have been initialized.\n"
8790 " </Documentation>\n"
8791 " <BooleanDomain name=\"bool\" />\n"
8792 " </IntVectorProperty>\n"
8793 "\n"
8794 " <IntVectorProperty name=\"ShowIndexedColorActiveValues\"\n"
8795 " command=\"SetUseActiveValues\"\n"
8796 " default_values=\"0\"\n"
8797 " number_of_elements=\"1\"\n"
8798 " label=\"Show Categorical Colors in Data Range Only\"\n"
8799 " panel_visibility=\"advanced\">\n"
8800 " <BooleanDomain name=\"bool\" />\n"
8801 " <Hints>\n"
8802 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
8803 " <Property name=\"IndexedLookup\" />\n"
8804 " </PropertyWidgetDecorator>\n"
8805 ;
8806
8807 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
8809 " </Hints>\n"
8810 " <Documentation>\n"
8811 " When interpreting values as categories, enabling this\n"
8812 " option results in the display of only the 'active'\n"
8813 " categorical colors for values in the data range, i.e.,\n"
8814 " values that exist in the source. You may need to click the\n"
8815 " 'Rescale to Data Range' button to update the active values\n"
8816 " that are displayed.\n"
8817 " </Documentation>\n"
8818 " </IntVectorProperty>\n"
8819 "\n"
8820 " <IntVectorProperty default_values=\"0\"\n"
8821 " name=\"AutomaticRescaleRangeMode\"\n"
8822 " number_of_elements=\"1\">\n"
8823 " <EnumerationDomain name=\"enum\">\n"
8824 " <Entry value=\"-1\" text=\"Never\"/>\n"
8825 " <Entry value=\"0\" text=\"Grow and update on 'Apply'\"/>\n"
8826 " <Entry value=\"1\" text=\"Grow and update every timestep\"/>\n"
8827 " <Entry value=\"2\" text=\"Update on 'Apply'\"/>\n"
8828 " <Entry value=\"3\" text=\"Clamp and update every timestep\"/>\n"
8829 " </EnumerationDomain>\n"
8830 " <Documentation>\n"
8831 " Choose whether and how to automatically rescale the color map range.\n"
8832 " \"Never\" means the color map range will never be changed.\n"
8833 " \"Grow and update on 'Apply'\" will expand the range to contain the\n"
8834 " union of the current range and the range of the current data source.\n"
8835 " \"Grow and update every timestep\" will expand the range to contain\n"
8836 " the union of the current range and the range of the current data source\n"
8837 " when the timestep is changed. \"Clamp and update every timestep\" will\n"
8838 " update the color map range to the current source data range.\n"
8839 " </Documentation>\n"
8840 " </IntVectorProperty>\n"
8841 " <IntVectorProperty name=\"RescaleOnVisibilityChange\"\n"
8842 " default_values=\"0\"\n"
8843 " number_of_elements=\"1\">\n"
8844 " <BooleanDomain name=\"bool\"/>\n"
8845 " <Documentation>\n"
8846 " Flag indicating whether the color map data range should be\n"
8847 " updated when a representation's visibility changes.\n"
8848 " </Documentation>\n"
8849 " </IntVectorProperty>\n"
8850 "\n"
8851 " <ProxyProperty name=\"ScalarOpacityFunction\"\n"
8852 " command=\"SetScalarOpacityFunction\">\n"
8853 " <Hints>\n"
8854 " <!-- when resetting to XML defaults, we don't want this property to\n"
8855 " get reset. This is managed explicitly. So let's just skip this\n"
8856 " from the default mechanism -->\n"
8857 " <NoDefault />\n"
8858 " </Hints>\n"
8859 " </ProxyProperty>\n"
8860 "\n"
8861 " <ProxyProperty command=\"SetTransferFunction2D\"\n"
8862 " name=\"TransferFunction2D\" >\n"
8863 " <ProxyGroupDomain name=\"groups\">\n"
8864 " <Group name=\"transfer_2d_functions\" />\n"
8865 " </ProxyGroupDomain>\n"
8866 " <Documentation>\n"
8867 " Proxy property used by the ColorOpacityWidget to store a 2D transfer function (vtkImageData).\n"
8868 " </Documentation>\n"
8869 " <Hints>\n"
8870 " <!-- when resetting to XML defaults, we don't want this property to\n"
8871 " get reset. This is managed explicitly. So let's just skip this\n"
8872 " from the default mechanism -->\n"
8873 " <NoDefault />\n"
8874 " </Hints>\n"
8875 " </ProxyProperty>\n"
8876 " <IntVectorProperty default_values=\"0\"\n"
8877 " name=\"Using2DTransferFunction\"\n"
8878 " is_internal=\"1\"\n"
8879 " number_of_elements=\"1\">\n"
8880 " <BooleanDomain name=\"bool\" />\n"
8881 " <Documentation>\n"
8882 " Proxy only property used by the ColorOpacityWidget to know if a 2D transfer function is being used.\n"
8883 " </Documentation>\n"
8884 " </IntVectorProperty>\n"
8885 " <IntVectorProperty default_values=\"0\"\n"
8886 " name=\"UsingSeparateOpacityArray\"\n"
8887 " is_internal=\"1\"\n"
8888 " number_of_elements=\"1\">\n"
8889 " <BooleanDomain name=\"bool\" />\n"
8890 " <Documentation>\n"
8891 " Proxy only property used by the ColorOpacityWidget to know if a separate array is being used to\n"
8892 " map opacity in volume rendering.\n"
8893 " </Documentation>\n"
8894 " </IntVectorProperty>\n"
8895 " <DoubleVectorProperty clean_command=\"RemoveAllPoints\"\n"
8896 " command=\"AddRGBPoint\"\n"
8897 " name=\"RGBPoints\"\n"
8898 " number_of_elements_per_command=\"4\"\n"
8899 " repeat_command=\"1\"\n"
8900 " number_of_elements=\"12\"\n"
8901 " default_values=\"0 0.231373 0.298039 0.752941 0.5 0.865003 0.865003 0.865003 1 0.705882 0.0156863 0.14902\">\n"
8902 " <Documentation>\n"
8903 " Specify the control points that form the color-transfer-function. These are\n"
8904 " a list of 4-tuples of the form (x, r, g, b) where x is the data value,\n"
8905 " and r,g,b are three color components in the range [0,1].\n"
8906 " </Documentation>\n"
8907 " </DoubleVectorProperty>\n"
8908 " <IntVectorProperty command=\"SetUseLogScale\"\n"
8909 " default_values=\"0\"\n"
8910 " name=\"UseLogScale\"\n"
8911 " number_of_elements=\"1\">\n"
8912 " <BooleanDomain name=\"bool\" />\n"
8913 " </IntVectorProperty>\n"
8914 " <IntVectorProperty\n"
8915 " default_values=\"0\"\n"
8916 " name=\"UseOpacityControlPointsFreehandDrawing\"\n"
8917 " number_of_elements=\"1\">\n"
8918 " <BooleanDomain name=\"bool\" />\n"
8919 " <Documentation> Proxy only property used by the ColorOpacityWidget to know if freehand drawing should be used\n"
8920 " </Documentation>\n"
8921 " </IntVectorProperty>\n"
8922 " <IntVectorProperty default_values=\"0\"\n"
8923 " name=\"ShowDataHistogram\"\n"
8924 " number_of_elements=\"1\">\n"
8925 " <BooleanDomain name=\"bool\" />\n"
8926 " <Documentation> Proxy only property used by the ColorOpacityWidget to know if the data histogram should be shown\n"
8927 " </Documentation>\n"
8928 " </IntVectorProperty>\n"
8929 " <IntVectorProperty default_values=\"0\"\n"
8930 " name=\"AutomaticDataHistogramComputation\"\n"
8931 " number_of_elements=\"1\">\n"
8932 " <BooleanDomain name=\"bool\" />\n"
8933 " <Documentation> Proxy only property used by the ColorOpacityWidget to know if the data histogram should be automatically computed\n"
8934 " </Documentation>\n"
8935 " </IntVectorProperty>\n"
8936 " <IntVectorProperty default_values=\"10\"\n"
8937 " name=\"DataHistogramNumberOfBins\"\n"
8938 " number_of_elements=\"1\">\n"
8939 " <Documentation> Proxy only property used by the ColorOpacityWidget to know the number of bin to use to compute the data histogram\n"
8940 " </Documentation>\n"
8941 " </IntVectorProperty>\n"
8942 " <IntVectorProperty command=\"SetColorSpace\"\n"
8943 " default_values=\"3\"\n"
8944 " name=\"ColorSpace\"\n"
8945 " number_of_elements=\"1\">\n"
8946 " <EnumerationDomain name=\"enum\">\n"
8947 " <Entry text=\"RGB\" value=\"0\" />\n"
8948 " <Entry text=\"HSV\" value=\"1\" />\n"
8949 " <Entry text=\"Lab\" value=\"2\" />\n"
8950 " <Entry text=\"Diverging\" value=\"3\" />\n"
8951 " <Entry text=\"Lab/CIEDE2000\" value=\"4\" />\n"
8952 " <Entry text=\"Step\" value=\"5\" />\n"
8953 " </EnumerationDomain>\n"
8954 " <Documentation>\n"
8955 " The color space used for interpolation: RGB, HSV, Lab (CIELAB), or\n"
8956 " Diverging. In HSV mode, if HSVWrap is on, it will take the shortest\n"
8957 " path in Hue (going back through 0 if that is the shortest way around\n"
8958 " the hue circle) whereas if HSVWrap is off it will not go through 0\n"
8959 " (in order the match the current functionality of vtkLookupTable).\n"
8960 " Diverging is a special mode where colors will pass through white when\n"
8961 " interpolating between two saturated colors.\n"
8962 " In Lab/CIEDE2000 mode, it will take the shortest path in the Lab color\n"
8963 " space with respect to the CIE Delta E 2000 color distance measure.\n"
8964 " In Step mode, the color of an interval is the color of the second point\n"
8965 " of the interval.\n"
8966 " </Documentation>\n"
8967 " <Hints>\n"
8968 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
8969 " <Expression type=\"and\">\n"
8970 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
8971 " <Property name=\"IndexedLookup\" function=\"boolean_invert\"/>\n"
8972 " </PropertyWidgetDecorator>\n"
8973 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
8974 " <Property name=\"Using2DTransferFunction\" function=\"boolean_invert\"/>\n"
8975 " </PropertyWidgetDecorator>\n"
8976 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
8977 " <Property name=\"UsingSeparateOpacityArray\" function=\"boolean_invert\"/>\n"
8978 " </PropertyWidgetDecorator>\n"
8979 " </Expression>\n"
8980 " </PropertyWidgetDecorator>\n"
8981 " </Hints>\n"
8982 " </IntVectorProperty>\n"
8983 " <IntVectorProperty command=\"SetUseBelowRangeColor\"\n"
8984 " default_values=\"0\"\n"
8985 " name=\"UseBelowRangeColor\"\n"
8986 " number_of_elements=\"1\"\n"
8987 " panel_visibility=\"advanced\" >\n"
8988 " <BooleanDomain name=\"bool\" />\n"
8989 " <Documentation>\n"
8990 " Use special color to use when a data value is below the range of the color map.\n"
8991 " </Documentation>\n"
8992 " </IntVectorProperty>\n"
8993 " <DoubleVectorProperty command=\"SetBelowRangeColor\"\n"
8994 " default_values=\"0 0 0\"\n"
8995 " name=\"BelowRangeColor\"\n"
8996 " number_of_elements=\"3\"\n"
8997 " panel_widget=\"color_selector\"\n"
8998 " panel_visibility=\"advanced\" >\n"
8999 " <Documentation>\n"
9000 " Set the color to use when a data value is below the range of the color map.\n"
9001 " </Documentation>\n"
9002 " <Hints>\n"
9003 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
9004 " <Property name=\"UseBelowRangeColor\" />\n"
9005 " </PropertyWidgetDecorator>\n"
9006 " </Hints>\n"
9007 " </DoubleVectorProperty>\n"
9008 " <IntVectorProperty command=\"SetUseAboveRangeColor\"\n"
9009 " default_values=\"0\"\n"
9010 " name=\"UseAboveRangeColor\"\n"
9011 " number_of_elements=\"1\"\n"
9012 " panel_visibility=\"advanced\" >\n"
9013 " <BooleanDomain name=\"bool\" />\n"
9014 " <Documentation>\n"
9015 " Use special color to use when a data value is above the range of the color map.\n"
9016 " </Documentation>\n"
9017 " </IntVectorProperty>\n"
9018 " <DoubleVectorProperty command=\"SetAboveRangeColor\"\n"
9019 " default_values=\"0.5 0.5 0.5\"\n"
9020 " name=\"AboveRangeColor\"\n"
9021 " number_of_elements=\"3\"\n"
9022 " panel_widget=\"color_selector\"\n"
9023 " panel_visibility=\"advanced\" >\n"
9024 " <Documentation>\n"
9025 " Set the color to use when a data value is above the range of the color map.\n"
9026 " </Documentation>\n"
9027 " <Hints>\n"
9028 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
9029 " <Property name=\"UseAboveRangeColor\" />\n"
9030 " </PropertyWidgetDecorator>\n"
9031 " </Hints>\n"
9032 " </DoubleVectorProperty>\n"
9033 " <DoubleVectorProperty command=\"SetNanColor\"\n"
9034 " default_values=\"1 1 0\"\n"
9035 " name=\"NanColor\"\n"
9036 " number_of_elements=\"3\"\n"
9037 " panel_widget=\"color_selector\" >\n"
9038 " <Documentation>\n"
9039 " Set the color to use when NaN (not-a-number) is encountered.\n"
9040 " </Documentation>\n"
9041 " </DoubleVectorProperty>\n"
9042 "\n"
9043 " <DoubleVectorProperty command=\"SetNanOpacity\"\n"
9044 " default_values=\"1\"\n"
9045 " name=\"NanOpacity\"\n"
9046 " number_of_elements=\"1\" >\n"
9047 " <DoubleRangeDomain min=\"0\" max=\"1\" name=\"range\" />\n"
9048 " <Documentation>\n"
9049 " Set the opacity to use when NaN (not-a-number) is encountered.\n"
9050 " </Documentation>\n"
9051 " </DoubleVectorProperty>\n"
9052 "\n"
9053 " <IntVectorProperty command=\"SetDiscretize\"\n"
9054 " default_values=\"1\"\n"
9055 " name=\"Discretize\"\n"
9056 " number_of_elements=\"1\" >\n"
9057 " <BooleanDomain name=\"bool\" />\n"
9058 " <Documentation>\n"
9059 " When set, the color transfer function will comprise of discrete colors\n"
9060 " with number of discrete colors specified using NumberOfTableValues.\n"
9061 " </Documentation>\n"
9062 " </IntVectorProperty>\n"
9063 " <IntVectorProperty command=\"SetNumberOfValues\"\n"
9064 " default_values=\"256\"\n"
9065 " name=\"NumberOfTableValues\"\n"
9066 " number_of_elements=\"1\" >\n"
9067 " <IntRangeDomain min=\"1\" max=\"1024\" name=\"range\" />\n"
9068 " <Documentation>\n"
9069 " When Discretize is set, this specifies the number of discrete colors\n"
9070 " that must be present in the transfer function.\n"
9071 " </Documentation>\n"
9072 " <Hints>\n"
9073 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9074 " <Property name=\"Discretize\" function=\"boolean\" index=\"0\" />\n"
9075 " </PropertyWidgetDecorator>\n"
9076 " </Hints>\n"
9077 " </IntVectorProperty>\n"
9078 "\n"
9079 " <DoubleVectorProperty default_values=\"0\"\n"
9080 " name=\"ScalarRangeInitialized\"\n"
9081 " number_of_elements=\"1\"\n"
9082 " panel_visibility=\"never\" >\n"
9083 " <Documentation>\n"
9084 " Set to 1 to indicate that the scalar range has been initialized.\n"
9085 " </Documentation>\n"
9086 " <BooleanDomain name=\"bool\" />\n"
9087 " </DoubleVectorProperty>\n"
9088 " <IntVectorProperty command=\"SetHSVWrap\"\n"
9089 " default_values=\"0\"\n"
9090 " name=\"HSVWrap\"\n"
9091 " number_of_elements=\"1\"\n"
9092 " panel_visibility=\"never\" >\n"
9093 " <!-- FIXME: need to add \"Wrapped HSV\" as a color-space type instead -->\n"
9094 " <BooleanDomain name=\"bool\" />\n"
9095 " </IntVectorProperty>\n"
9096 " <Property command=\"Build\" name=\"Build\" panel_visibility=\"never\" />\n"
9097 " <IntVectorProperty command=\"SetVectorComponent\"\n"
9098 " default_values=\"0\"\n"
9099 " name=\"VectorComponent\"\n"
9100 " number_of_elements=\"1\"\n"
9101 " panel_visibility=\"never\" >\n"
9102 " <IntRangeDomain name=\"range\" />\n"
9103 " </IntVectorProperty>\n"
9104 " <IntVectorProperty command=\"SetVectorMode\"\n"
9105 " default_values=\"0\"\n"
9106 " name=\"VectorMode\"\n"
9107 " number_of_elements=\"1\"\n"
9108 " panel_visibility=\"never\" >\n"
9109 " <EnumerationDomain name=\"enum\">\n"
9110 " <Entry text=\"Magnitude\" value=\"0\" />\n"
9111 " <Entry text=\"Component\" value=\"1\" />\n"
9112 " </EnumerationDomain>\n"
9113 " </IntVectorProperty>\n"
9114 " <IntVectorProperty command=\"SetAllowDuplicateScalars\"\n"
9115 ;
9116
9117 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
9119 " default_values=\"1\"\n"
9120 " name=\"AllowDuplicateScalars\"\n"
9121 " number_of_elements=\"1\"\n"
9122 " panel_visibility=\"never\" >\n"
9123 " <BooleanDomain name=\"bool\" />\n"
9124 " </IntVectorProperty>\n"
9125 "\n"
9126 " <StringVectorProperty name=\"Annotations\"\n"
9127 " clean_command=\"ResetAnnotationsInFullSet\"\n"
9128 " command=\"SetAnnotationInFullSet\"\n"
9129 " element_types=\"2 2\"\n"
9130 " number_of_elements_per_command=\"2\"\n"
9131 " repeat_command=\"1\">\n"
9132 " <Documentation>\n"
9133 " Specify annotations.\n"
9134 " </Documentation>\n"
9135 " </StringVectorProperty>\n"
9136 "\n"
9137 " <StringVectorProperty name=\"ActiveAnnotatedValues\"\n"
9138 " clean_command=\"ResetActiveAnnotatedValues\"\n"
9139 " command=\"SetActiveAnnotatedValue\"\n"
9140 " element_types=\"2\"\n"
9141 " number_of_elements_per_command=\"1\"\n"
9142 " repeat_command=\"1\"\n"
9143 " panel_visibility=\"never\">\n"
9144 " <Documentation>\n"
9145 " Specify active annotations.\n"
9146 " </Documentation>\n"
9147 " </StringVectorProperty>\n"
9148 "\n"
9149 " <DoubleVectorProperty name=\"IndexedColors\"\n"
9150 " command=\"SetIndexedColorInFullSet\"\n"
9151 " number_of_elements_per_command=\"3\"\n"
9152 " repeat_command=\"1\"\n"
9153 " set_number_command=\"SetNumberOfIndexedColorsInFullSet\"\n"
9154 " use_index=\"1\"\n"
9155 " panel_visibility=\"advanced\">\n"
9156 " <Documentation>\n"
9157 " Colors used when using IndexedLookup is true.\n"
9158 " </Documentation>\n"
9159 " </DoubleVectorProperty>\n"
9160 "\n"
9161 " <DoubleVectorProperty name=\"IndexedOpacities\"\n"
9162 " command=\"SetIndexedOpacityInFullSet\"\n"
9163 " number_of_elements_per_command=\"1\"\n"
9164 " repeat_command=\"1\"\n"
9165 " set_number_command=\"SetNumberOfIndexedOpacitiesInFullSet\"\n"
9166 " use_index=\"1\"\n"
9167 " panel_visibility=\"never\">\n"
9168 " <Documentation>\n"
9169 " Opacities used when using IndexedLookup is true.\n"
9170 " </Documentation>\n"
9171 " </DoubleVectorProperty>\n"
9172 "\n"
9173 " <IntVectorProperty name=\"EnableOpacityMapping\"\n"
9174 " command=\"SetEnableOpacityMapping\"\n"
9175 " number_of_elements=\"1\"\n"
9176 " default_values=\"0\">\n"
9177 " <BooleanDomain name=\"bool\" />\n"
9178 " <Documentation>\n"
9179 " When enabled, the opacity transfer function is used for\n"
9180 " rendering, if applicable.\n"
9181 " </Documentation>\n"
9182 " </IntVectorProperty>\n"
9183 "\n"
9184 " <PropertyGroup label=\"Transfer Functions\" panel_widget=\"ColorOpacityEditor\">\n"
9185 " <Property name=\"EnableOpacityMapping\" function=\"EnableOpacityMapping\" />\n"
9186 " <Property name=\"RGBPoints\" function=\"XRGBPoints\" />\n"
9187 " <Property name=\"ScalarOpacityFunction\" function=\"ScalarOpacityFunction\" />\n"
9188 " <Property name=\"TransferFunction2D\" function=\"TransferFunction2D\" />\n"
9189 " <Property name=\"UseLogScale\" function=\"UseLogScale\" />\n"
9190 " <Property name=\"UseOpacityControlPointsFreehandDrawing\" function=\"UseOpacityControlPointsFreehandDrawing\" />\n"
9191 " <Property name=\"ShowDataHistogram\" function=\"ShowDataHistogram\" />\n"
9192 " <Property name=\"AutomaticDataHistogramComputation\" function=\"AutomaticDataHistogramComputation\" />\n"
9193 " <Property name=\"DataHistogramNumberOfBins\" function=\"DataHistogramNumberOfBins\" />\n"
9194 " <Hints>\n"
9195 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9196 " <Property name=\"IndexedLookup\" function=\"boolean_invert\"/>\n"
9197 " </PropertyWidgetDecorator>\n"
9198 " </Hints>\n"
9199 " </PropertyGroup>\n"
9200 "\n"
9201 " <PropertyGroup label=\"Mapping Parameters\">\n"
9202 " <Property name=\"ColorSpace\" />\n"
9203 " <Property name=\"NanColor\" />\n"
9204 " <Property name=\"NanOpacity\" />\n"
9205 " </PropertyGroup>\n"
9206 "\n"
9207 " <PropertyGroup label=\"Color Discretization\">\n"
9208 " <Property name=\"Discretize\" />\n"
9209 " <Property name=\"NumberOfTableValues\" />\n"
9210 " <Hints>\n"
9211 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
9212 " <Expression type=\"and\">\n"
9213 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9214 " <Property name=\"Using2DTransferFunction\" function=\"boolean_invert\"/>\n"
9215 " </PropertyWidgetDecorator>\n"
9216 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9217 " <Property name=\"IndexedLookup\" function=\"boolean_invert\"/>\n"
9218 " </PropertyWidgetDecorator>\n"
9219 " </Expression>\n"
9220 " </PropertyWidgetDecorator>\n"
9221 " </Hints>\n"
9222 " </PropertyGroup>\n"
9223 "\n"
9224 " <PropertyGroup label=\"Categories\" panel_widget=\"AnnotationsEditor\">\n"
9225 " <Property name=\"Annotations\" />\n"
9226 " <Property name=\"EnableOpacityMapping\" function=\"EnableOpacityMapping\" />\n"
9227 " <Property name=\"IndexedColors\" />\n"
9228 " <Hints>\n"
9229 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9230 " <Property name=\"Using2DTransferFunction\" function=\"boolean_invert\"/>\n"
9231 " </PropertyWidgetDecorator>\n"
9232 " </Hints>\n"
9233 " </PropertyGroup>\n"
9234 "\n"
9235 " <!-- End of PVLookupTable -->\n"
9236 " </TransferFunctionProxy>\n"
9237 "\n"
9238 " <!-- end of \"lookup_tables\" -->\n"
9239 " </ProxyGroup>\n"
9240 "\n"
9241 " <!-- ==================================================================== -->\n"
9242 " <ProxyGroup name=\"transfer_functions\">\n"
9243 "\n"
9244 " <!-- ================================================================== -->\n"
9245 " <TransferFunctionProxy class=\"vtkColorTransferFunction\"\n"
9246 " name=\"ColorTransferFunction\"\n"
9247 " processes=\"client|renderserver|dataserver\">\n"
9248 " <DoubleVectorProperty animateable=\"0\"\n"
9249 " clean_command=\"RemoveAllPoints\"\n"
9250 " command=\"AddRGBPoint\"\n"
9251 " name=\"RGBPoints\"\n"
9252 " number_of_elements_per_command=\"4\"\n"
9253 " repeat_command=\"1\"></DoubleVectorProperty>\n"
9254 " <IntVectorProperty animateable=\"0\"\n"
9255 " command=\"SetColorSpace\"\n"
9256 " default_values=\"0\"\n"
9257 " name=\"ColorSpace\"\n"
9258 " number_of_elements=\"1\">\n"
9259 " <EnumerationDomain name=\"enum\">\n"
9260 " <Entry text=\"RGB\"\n"
9261 " value=\"0\" />\n"
9262 " <Entry text=\"HSV\"\n"
9263 " value=\"1\" />\n"
9264 " <Entry text=\"Lab\"\n"
9265 " value=\"2\" />\n"
9266 " <Entry text=\"Diverging\"\n"
9267 " value=\"3\" />\n"
9268 " <Entry text=\"Lab/CIEDE2000\"\n"
9269 " value=\"4\" />\n"
9270 " <Entry text=\"Step\"\n"
9271 " value=\"5\" />\n"
9272 " </EnumerationDomain>\n"
9273 " </IntVectorProperty>\n"
9274 " <IntVectorProperty animateable=\"0\"\n"
9275 " command=\"SetHSVWrap\"\n"
9276 " default_values=\"0\"\n"
9277 " name=\"HSVWrap\"\n"
9278 " number_of_elements=\"1\">\n"
9279 " <BooleanDomain name=\"bool\" />\n"
9280 " </IntVectorProperty>\n"
9281 " </TransferFunctionProxy>\n"
9282 "\n"
9283 " <!-- end of \"transfer_functions\" -->\n"
9284 " </ProxyGroup>\n"
9285 "\n"
9286 " <!-- ==================================================================== -->\n"
9287 " <ProxyGroup name=\"transfer_2d_functions\">\n"
9288 " <!-- ================================================================== -->\n"
9289 " <TransferFunction2DProxy class=\"vtkPVTransferFunction2D\"\n"
9290 " name=\"TransferFunction2D\"\n"
9291 " post_push=\"Build\"\n"
9292 " processes=\"client|renderserver|dataserver\">\n"
9293 " <IntVectorProperty default_values=\"0\"\n"
9294 " name=\"AutomaticRescaleRangeMode\"\n"
9295 " number_of_elements=\"1\">\n"
9296 " <EnumerationDomain name=\"enum\">\n"
9297 " <Entry value=\"-1\" text=\"Never\"/>\n"
9298 " <Entry value=\"0\" text=\"Grow and update on 'Apply'\"/>\n"
9299 " <Entry value=\"1\" text=\"Grow and update every timestep\"/>\n"
9300 " <Entry value=\"2\" text=\"Update on 'Apply'\"/>\n"
9301 " <Entry value=\"3\" text=\"Clamp and update every timestep\"/>\n"
9302 " </EnumerationDomain>\n"
9303 " <Documentation>\n"
9304 " Choose whether and how to automatically rescale the color map range.\n"
9305 " \"Never\" means the color map range will never be changed.\n"
9306 " \"Grow and update on 'Apply'\" will expand the range to contain the\n"
9307 " union of the current range and the range of the current data source.\n"
9308 " \"Grow and update every timestep\" will expand the range to contain\n"
9309 " the union of the current range and the range of the current data source\n"
9310 " when the timestep is changed. \"Clamp and update every timestep\" will\n"
9311 " update the color map range to the current source data range.\n"
9312 " </Documentation>\n"
9313 " </IntVectorProperty>\n"
9314 " <DoubleVectorProperty clean_command=\"RemoveAllBoxes\"\n"
9315 " command=\"AddControlBox\"\n"
9316 " name=\"Boxes\"\n"
9317 " number_of_elements_per_command=\"8\"\n"
9318 " repeat_command=\"1\">\n"
9319 " <Documentation>\n"
9320 " Specify the box parameters for the 2D transfer function. These are\n"
9321 " a list of 8-tuples of the form (x, y, width, height, r, g, b, a) where\n"
9322 " (x, y) is the position i.e. the range-min of the box, (width, height)\n"
9323 " specify the dimensions of the box in the scalar units and (r, g, b, a)\n"
9324 " denote the color with maximum alpha of the box. The color and alpha\n"
9325 " components are in the range [0, 1].\n"
9326 " </Documentation>\n"
9327 " </DoubleVectorProperty>\n"
9328 " <IntVectorProperty default_values=\"0\"\n"
9329 " name=\"ScalarRangeInitialized\"\n"
9330 " number_of_elements=\"1\"\n"
9331 " panel_visibility=\"never\" >\n"
9332 " <Documentation>\n"
9333 " Set to 1 to indicate that the scalar range has been initialized.\n"
9334 " </Documentation>\n"
9335 " <BooleanDomain name=\"bool\" />\n"
9336 " </IntVectorProperty>\n"
9337 " <DoubleVectorProperty command=\"SetRange\"\n"
9338 " default_values=\"0.0 1.0 0.0 1.0\"\n"
9339 " name=\"Range\"\n"
9340 " number_of_elements=\"4\"\n"
9341 " panel_visibility=\"never\" >\n"
9342 " <Documentation>\n"
9343 " The range of the X and Y axes of the transfer function. This is\n"
9344 " specified as a 4-tuple of the form (xmin, xmax, ymin, ymax).\n"
9345 " </Documentation>\n"
9346 " </DoubleVectorProperty>\n"
9347 " <IntVectorProperty command=\"SetOutputDimensions\"\n"
9348 " default_values=\"10 10\"\n"
9349 " name=\"OutputDimensions\"\n"
9350 " number_of_elements=\"2\"\n"
9351 " panel_visibility=\"never\" >\n"
9352 " <Documentation>\n"
9353 " The dimensions of the image that represents this 2D transfer function.\n"
9354 " </Documentation>\n"
9355 " </IntVectorProperty>\n"
9356 " <Property command=\"Build\" name=\"Build\" panel_visibility=\"never\" />\n"
9357 " </TransferFunction2DProxy>\n"
9358 " <!-- end of \"transfer_2d_functions\" -->\n"
9359 " </ProxyGroup>\n"
9360 "\n"
9361 " <!-- ==================================================================== -->\n"
9362 " <ProxyGroup name=\"piecewise_functions\">\n"
9363 " <!-- ================================================================== -->\n"
9364 " <TransferFunctionProxy class=\"vtkPiecewiseFunction\"\n"
9365 " name=\"PiecewiseFunction\"\n"
9366 " processes=\"client|renderserver|dataserver\">\n"
9367 " <DoubleVectorProperty clean_command=\"RemoveAllPoints\"\n"
9368 " command=\"AddPoint\"\n"
9369 " default_values=\"0.0 0.0 0.5 0.0 1.0 1.0 0.5 0.0\"\n"
9370 " name=\"Points\"\n"
9371 " number_of_elements=\"8\"\n"
9372 " number_of_elements_per_command=\"4\"\n"
9373 " repeat_command=\"1\"></DoubleVectorProperty>\n"
9374 " <IntVectorProperty command=\"SetAllowDuplicateScalars\"\n"
9375 " default_values=\"1\"\n"
9376 " name=\"AllowDuplicateScalars\"\n"
9377 " number_of_elements=\"1\"\n"
9378 " panel_visibility=\"never\" >\n"
9379 " <BooleanDomain name=\"bool\" />\n"
9380 " </IntVectorProperty>\n"
9381 " <IntVectorProperty command=\"SetUseLogScale\"\n"
9382 " default_values=\"0\"\n"
9383 " name=\"UseLogScale\"\n"
9384 " number_of_elements=\"1\">\n"
9385 " <BooleanDomain name=\"bool\" />\n"
9386 " </IntVectorProperty>\n"
9387 " <IntVectorProperty default_values=\"0\"\n"
9388 " name=\"ScalarRangeInitialized\"\n"
9389 " number_of_elements=\"1\"\n"
9390 " panel_visibility=\"never\" >\n"
9391 " <Documentation>\n"
9392 " Set to 1 to indicate that the scalar range has been initialized.\n"
9393 " </Documentation>\n"
9394 " <BooleanDomain name=\"bool\" />\n"
9395 " </IntVectorProperty>\n"
9396 " </TransferFunctionProxy>\n"
9397 "\n"
9398 " <!-- end of \"piecewise_functions\" -->\n"
9399 " </ProxyGroup>\n"
9400 "\n"
9401 " <!-- ==================================================================== -->\n"
9402 " <ProxyGroup name=\"annotations\">\n"
9403 "\n"
9404 " <!-- ================================================================== -->\n"
9405 " <Proxy class=\"vtkContext2DScalarBarActor\"\n"
9406 " name=\"ScalarBarActor\" >\n"
9407 " <ProxyProperty command=\"SetLookupTable\"\n"
9408 " name=\"LookupTable\"\n"
9409 " number_of_elements=\"1\">\n"
9410 " <ProxyGroupDomain name=\"groups\">\n"
9411 " <Group name=\"lookup_tables\" />\n"
9412 " </ProxyGroupDomain>\n"
9413 " </ProxyProperty>\n"
9414 " <IntVectorProperty command=\"GetEstimatedNumberOfAnnotations\"\n"
9415 " information_only=\"1\"\n"
9416 " name=\"EstimatedNumberOfAnnotations\">\n"
9417 " <SimpleIntInformationHelper />\n"
9418 " </IntVectorProperty>\n"
9419 " <IntVectorProperty animateable=\"0\"\n"
9420 " command=\"SetVisibility\"\n"
9421 " default_values=\"1\"\n"
9422 " name=\"Visibility\"\n"
9423 " number_of_elements=\"1\">\n"
9424 " <BooleanDomain name=\"bool\" />\n"
9425 " </IntVectorProperty>\n"
9426 " <StringVectorProperty animateable=\"0\"\n"
9427 " command=\"SetTitle\"\n"
9428 " default_values=\"Name\"\n"
9429 " no_custom_default=\"1\"\n"
9430 " name=\"Title\"\n"
9431 " number_of_elements=\"1\">\n"
9432 " <Documentation>Set the title text with respect to the color legend.</Documentation>\n"
9433 " </StringVectorProperty>\n"
9434 " <DoubleVectorProperty animateable=\"0\"\n"
9435 " command=\"SetDataRangeMin\"\n"
9436 ;
9437
9438 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
9440 " default_values=\"0\"\n"
9441 " no_custom_default=\"1\"\n"
9442 " name=\"DataRangeMin\"\n"
9443 " number_of_elements=\"1\"\n"
9444 " panel_visibility=\"never\">\n"
9445 " <Documentation>Set the minimum range with respect to the displayed representations.</Documentation>\n"
9446 " </DoubleVectorProperty>\n"
9447 " <DoubleVectorProperty animateable=\"0\"\n"
9448 " command=\"SetDataRangeMax\"\n"
9449 " default_values=\"0\"\n"
9450 " no_custom_default=\"1\"\n"
9451 " name=\"DataRangeMax\"\n"
9452 " number_of_elements=\"1\"\n"
9453 " panel_visibility=\"never\">\n"
9454 " <Documentation>Set the maximum range with respect to the displayed representations.</Documentation>\n"
9455 " </DoubleVectorProperty>\n"
9456 " <IntVectorProperty command=\"SetDrawDataRange\"\n"
9457 " default_values=\"0\"\n"
9458 " name=\"DrawDataRange\"\n"
9459 " label=\"Draw Data Range Labels\"\n"
9460 " number_of_elements=\"1\">\n"
9461 " <BooleanDomain name=\"bool\" />\n"
9462 " <Hints>\n"
9463 " <NoDefault />\n"
9464 " </Hints>\n"
9465 " <Documentation>Show labels with the visible data range for the arrays this color legend represents.</Documentation>\n"
9466 " </IntVectorProperty>\n"
9467 " <StringVectorProperty animateable=\"0\"\n"
9468 " command=\"SetComponentTitle\"\n"
9469 " default_values=\"Component\"\n"
9470 " no_custom_default=\"1\"\n"
9471 " name=\"ComponentTitle\"\n"
9472 " number_of_elements=\"1\">\n"
9473 " <Documentation>Set the component title text with respect to the color legend.</Documentation>\n"
9474 " </StringVectorProperty>\n"
9475 " <IntVectorProperty animateable=\"0\"\n"
9476 " command=\"SetTitleJustification\"\n"
9477 " default_values=\"1\"\n"
9478 " name=\"TitleJustification\"\n"
9479 " number_of_elements=\"1\">\n"
9480 " <EnumerationDomain name=\"enum\">\n"
9481 " <Entry text=\"Left\"\n"
9482 " value=\"0\" />\n"
9483 " <Entry text=\"Centered\"\n"
9484 " value=\"1\" />\n"
9485 " <Entry text=\"Right\"\n"
9486 " value=\"2\" />\n"
9487 " </EnumerationDomain>\n"
9488 " <Documentation>Set the justification of the title text with respect to the color legend.</Documentation>\n"
9489 " </IntVectorProperty>\n"
9490 " <IntVectorProperty animateable=\"0\"\n"
9491 " command=\"SetForceHorizontalTitle\"\n"
9492 " default_values=\"0\"\n"
9493 " name=\"HorizontalTitle\"\n"
9494 " number_of_elements=\"1\">\n"
9495 " <BooleanDomain name=\"bool\" />\n"
9496 " <Documentation>\n"
9497 " When on, orients the title horizontally. When off (default), the title\n"
9498 " will be rotated counter-clockwise 90 degrees and lie parallel to the\n"
9499 " color bar.\n"
9500 " </Documentation>\n"
9501 " </IntVectorProperty>\n"
9502 " <IntVectorProperty animateable=\"0\"\n"
9503 " command=\"SetForceHorizontalTitle\"\n"
9504 " default_values=\"0\"\n"
9505 " name=\"HorizontalTitle2\"\n"
9506 " number_of_elements=\"1\">\n"
9507 " <BooleanDomain name=\"bool\" />\n"
9508 " <Documentation>\n"
9509 " When on, orients the title horizontally. When off (default), the title\n"
9510 " will be rotated counter-clockwise 90 degrees and lie parallel to the\n"
9511 " color bar.\n"
9512 " </Documentation>\n"
9513 " </IntVectorProperty>\n"
9514 " <IntVectorProperty command=\"SetDrawBackground\"\n"
9515 " name=\"DrawBackground\"\n"
9516 " number_of_elements=\"1\"\n"
9517 " default_values=\"0\">\n"
9518 " <BooleanDomain name=\"bool\" />\n"
9519 " <Documentation>Enable drawing a background behind the color legend.</Documentation>\n"
9520 " </IntVectorProperty>\n"
9521 " <DoubleVectorProperty animateable=\"0\"\n"
9522 " command=\"SetBackgroundColor\"\n"
9523 " default_values=\"1 1 1 0.5\"\n"
9524 " name=\"BackgroundColor\"\n"
9525 " panel_widget=\"color_selector\"\n"
9526 " number_of_elements=\"4\">\n"
9527 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
9528 " min=\"0 0 0 0\"\n"
9529 " name=\"range\" />\n"
9530 " <Documentation>Set the color and opacity of the background behind the color legend.</Documentation>\n"
9531 " <Hints>\n"
9532 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9533 " <Property name=\"DrawBackground\" function=\"boolean\" index=\"0\" />\n"
9534 " </PropertyWidgetDecorator>\n"
9535 " </Hints>\n"
9536 " </DoubleVectorProperty>\n"
9537 " <DoubleVectorProperty command=\"SetBackgroundPadding\"\n"
9538 " default_values=\"2.0\"\n"
9539 " name=\"BackgroundPadding\"\n"
9540 " number_of_elements=\"1\">\n"
9541 " <DoubleRangeDomain min=\"0\" />\n"
9542 " <Documentation>Set the amount of padding around the outermost elements of the\n"
9543 " color legend when the background is drawn.</Documentation>\n"
9544 " <Hints>\n"
9545 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9546 " <Property name=\"DrawBackground\" function=\"boolean\" index=\"0\" />\n"
9547 " </PropertyWidgetDecorator>\n"
9548 " </Hints>\n"
9549 " </DoubleVectorProperty>\n"
9550 " <IntVectorProperty command=\"SetScalarBarThickness\"\n"
9551 " default_values=\"16\"\n"
9552 " name=\"ScalarBarThickness\"\n"
9553 " label=\"Color Bar Thickness\"\n"
9554 " number_of_elements=\"1\">\n"
9555 " <Documentation>\n"
9556 " Sets the width of the scalar bar when vertically oriented\n"
9557 " and the height when horizontally oriented.\n"
9558 " </Documentation>\n"
9559 " </IntVectorProperty>\n"
9560 " <DoubleVectorProperty command=\"SetScalarBarLength\"\n"
9561 " default_values=\"0.33\"\n"
9562 " name=\"ScalarBarLength\"\n"
9563 " label=\"Color Bar Length\"\n"
9564 " number_of_elements=\"1\">\n"
9565 " <Documentation>\n"
9566 " Sets the length of the scalar bar. The length is defined as a\n"
9567 " fraction of window width or height when the color legend is\n"
9568 " horizontal or vertical, respectively.\n"
9569 " </Documentation>\n"
9570 " </DoubleVectorProperty>\n"
9571 " <IntVectorProperty command=\"SetDrawScalarBarOutline\"\n"
9572 " default_values=\"0\"\n"
9573 " name=\"DrawScalarBarOutline\"\n"
9574 " number_of_elements=\"1\">\n"
9575 " <BooleanDomain name=\"bool\" />\n"
9576 " <Documentation>\n"
9577 " Draws an outline around the scalar bar.\n"
9578 " </Documentation>\n"
9579 " </IntVectorProperty>\n"
9580 " <DoubleVectorProperty command=\"SetScalarBarOutlineColor\"\n"
9581 " default_values=\"1 1 1\"\n"
9582 " name=\"ScalarBarOutlineColor\"\n"
9583 " number_of_elements=\"3\"\n"
9584 " panel_widget=\"color_selector\">\n"
9585 " <Documentation>\n"
9586 " Color of the outline drawn around the scalar bar if it is shown.\n"
9587 " </Documentation>\n"
9588 " <Hints>\n"
9589 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9590 " <Property name=\"DrawScalarBarOutline\" function=\"boolean\" index=\"0\" />\n"
9591 " </PropertyWidgetDecorator>\n"
9592 " </Hints>\n"
9593 " </DoubleVectorProperty>\n"
9594 " <IntVectorProperty command=\"SetScalarBarOutlineThickness\"\n"
9595 " default_values=\"1\"\n"
9596 " name=\"ScalarBarOutlineThickness\"\n"
9597 " number_of_elements=\"1\">\n"
9598 " <Documentation>\n"
9599 " Set the thickness, in pixels, of the outline drawn around the scalar bar.\n"
9600 " </Documentation>\n"
9601 " <Hints>\n"
9602 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9603 " <Property name=\"DrawScalarBarOutline\" function=\"boolean\" index=\"0\" />\n"
9604 " </PropertyWidgetDecorator>\n"
9605 " </Hints>\n"
9606 " </IntVectorProperty>\n"
9607 " <IntVectorProperty animateable=\"0\"\n"
9608 " command=\"SetReverseLegend\"\n"
9609 " default_values=\"0\"\n"
9610 " name=\"ReverseLegend\"\n"
9611 " number_of_elements=\"1\">\n"
9612 " <BooleanDomain name=\"bool\" />\n"
9613 " <Documentation>\n"
9614 " When on, the color bar and all associated ticks and notations will be reversed,\n"
9615 " from high to low instead of low to high.\n"
9616 " </Documentation>\n"
9617 " </IntVectorProperty>\n"
9618 " <IntVectorProperty command=\"SetAutomaticLabelFormat\"\n"
9619 " default_values=\"1\"\n"
9620 " name=\"AutomaticLabelFormat\"\n"
9621 " number_of_elements=\"1\">\n"
9622 " <BooleanDomain name=\"bool\" />\n"
9623 " <Documentation>\n"
9624 " Set if the number format used for the labels (specified as a C-style printf format string) will be automatically generated to make\n"
9625 " the numbers best fit within the widget. When off, the Label Format property will be used.\n"
9626 " </Documentation>\n"
9627 " </IntVectorProperty>\n"
9628 " <StringVectorProperty animateable=\"0\"\n"
9629 " command=\"SetLabelFormat\"\n"
9630 " default_values=\"%-#6.3g\"\n"
9631 " name=\"LabelFormat\"\n"
9632 " number_of_elements=\"1\">\n"
9633 " <Hints>\n"
9634 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
9635 " <Property name=\"AutomaticLabelFormat\" function=\"boolean_invert\" index=\"0\" />\n"
9636 " </PropertyWidgetDecorator>\n"
9637 " </Hints>\n"
9638 " <Documentation>\n"
9639 " Set the number format (specified as a C-style printf format string) with which to print the labels on the color legend.\n"
9640 " Can be used only if Automatic Label Format is off.\n"
9641 " </Documentation>\n"
9642 " </StringVectorProperty>\n"
9643 " <IntVectorProperty animateable=\"0\"\n"
9644 " command=\"SetDrawNanAnnotation\"\n"
9645 " default_values=\"0\"\n"
9646 " name=\"DrawNanAnnotation\"\n"
9647 " number_of_elements=\"1\">\n"
9648 " <BooleanDomain name=\"bool\" />\n"
9649 " <Documentation>Set whether the NaN annotation should be rendered or not.</Documentation>\n"
9650 " </IntVectorProperty>\n"
9651 " <IntVectorProperty animateable=\"0\"\n"
9652 " command=\"SetDrawAnnotations\"\n"
9653 " default_values=\"1\"\n"
9654 " name=\"DrawAnnotations\"\n"
9655 " number_of_elements=\"1\">\n"
9656 " <BooleanDomain name=\"bool\" />\n"
9657 " <Documentation>Set whether text annotations should be rendered or not.</Documentation>\n"
9658 " </IntVectorProperty>\n"
9659 " <IntVectorProperty animateable=\"0\"\n"
9660 " command=\"SetAddRangeAnnotations\"\n"
9661 " default_values=\"0\"\n"
9662 " name=\"AddRangeAnnotations\"\n"
9663 " number_of_elements=\"1\">\n"
9664 " <BooleanDomain name=\"bool\" />\n"
9665 " <Documentation>\n"
9666 " Set whether the data range endpoints (minimum and maximum) are added as annotations.\n"
9667 " </Documentation>\n"
9668 " </IntVectorProperty>\n"
9669 " <IntVectorProperty animateable=\"0\"\n"
9670 " command=\"SetAutomaticAnnotations\"\n"
9671 " default_values=\"0\"\n"
9672 " name=\"AutomaticAnnotations\"\n"
9673 " number_of_elements=\"1\" >\n"
9674 " <BooleanDomain name=\"bool\" />\n"
9675 " <Documentation>\n"
9676 " When set, annotations are automatically created according the number\n"
9677 " of colors shown on the scalar bar.\n"
9678 " </Documentation>\n"
9679 " </IntVectorProperty>\n"
9680 " <IntVectorProperty command=\"SetAddRangeLabels\"\n"
9681 " number_of_elements=\"1\"\n"
9682 " default_values=\"1\"\n"
9683 " name=\"AddRangeLabels\"\n"
9684 " label=\"Add Range Labels\">\n"
9685 " <BooleanDomain name=\"bool\" />\n"
9686 " <Documentation>\n"
9687 " Set whether to add range labels or not. These are labels that have\n"
9688 " the minimum/maximum values of the color legend range.\n"
9689 " </Documentation>\n"
9690 " </IntVectorProperty>\n"
9691 " <StringVectorProperty animateable=\"0\"\n"
9692 " command=\"SetRangeLabelFormat\"\n"
9693 " number_of_elements=\"1\"\n"
9694 " default_values=\"%-#6.1e\"\n"
9695 " name=\"RangeLabelFormat\"\n"
9696 " label=\"Range Label Format\">\n"
9697 " <Hints>\n"
9698 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
9699 " <Property name=\"AddRangeLabels\" function=\"boolean\" index=\"0\" />\n"
9700 " </PropertyWidgetDecorator>\n"
9701 " </Hints>\n"
9702 " <Documentation>\n"
9703 " Set number format for range labels (specified as a C-style printf format string). Can be used only if Add Range Labels is enabled.\n"
9704 " </Documentation>\n"
9705 " </StringVectorProperty>\n"
9706 " <StringVectorProperty animateable=\"0\"\n"
9707 " command=\"SetDataRangeLabelFormat\"\n"
9708 " number_of_elements=\"1\"\n"
9709 " default_values=\"%-#6.1e\"\n"
9710 " name=\"DataRangeLabelFormat\"\n"
9711 " label=\"Data Range Label Format\">\n"
9712 " <Hints>\n"
9713 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
9714 " <Property name=\"DrawDataRange\" function=\"boolean\" index=\"0\" />\n"
9715 " </PropertyWidgetDecorator>\n"
9716 " </Hints>\n"
9717 " <Documentation>\n"
9718 " Set number format for range labels (specified as a C-style printf format string). Can be used only if Add Range Labels is enabled.\n"
9719 " </Documentation>\n"
9720 " </StringVectorProperty>\n"
9721 " <StringVectorProperty animateable=\"0\"\n"
9722 " command=\"SetNanAnnotation\"\n"
9723 " default_values=\"NaN\"\n"
9724 " name=\"NanAnnotation\"\n"
9725 " number_of_elements=\"1\">\n"
9726 " <Hints>\n"
9727 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
9728 " <Property name=\"DrawNanAnnotation\" function=\"boolean\" index=\"0\" />\n"
9729 " </PropertyWidgetDecorator>\n"
9730 " </Hints>\n"
9731 " <Documentation>\n"
9732 " Set the annotation text for \"NaN\" values. Can be used only if Draw Nan Annotation is enabled.\n"
9733 " </Documentation>\n"
9734 " </StringVectorProperty>\n"
9735 " <IntVectorProperty animateable=\"0\"\n"
9736 " command=\"SetDrawTickMarks\"\n"
9737 " default_values=\"1\"\n"
9738 " name=\"DrawTickMarks\"\n"
9739 " number_of_elements=\"1\">\n"
9740 " <BooleanDomain name=\"bool\" />\n"
9741 " <Documentation>Enable/disable drawing the color legend tick marks.</Documentation>\n"
9742 ;
9743
9744 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
9746 " </IntVectorProperty>\n"
9747 " <IntVectorProperty animateable=\"0\"\n"
9748 " command=\"SetDrawTickLabels\"\n"
9749 " default_values=\"1\"\n"
9750 " name=\"DrawTickLabels\"\n"
9751 " number_of_elements=\"1\">\n"
9752 " <BooleanDomain name=\"bool\" />\n"
9753 " <Documentation>Enable/disable drawing the color legend labels for tick marks.</Documentation>\n"
9754 " </IntVectorProperty>\n"
9755 " <IntVectorProperty animateable=\"0\"\n"
9756 " command=\"SetUseCustomLabels\"\n"
9757 " name=\"UseCustomLabels\"\n"
9758 " number_of_elements=\"1\"\n"
9759 " default_values=\"0\" >\n"
9760 " <BooleanDomain name=\"bool\" />\n"
9761 " <Documentation>Enable the use of custom label values.</Documentation>\n"
9762 " </IntVectorProperty>\n"
9763 " <DoubleVectorProperty command=\"SetCustomLabel\"\n"
9764 " name=\"CustomLabels\"\n"
9765 " set_number_command=\"SetNumberOfCustomLabels\"\n"
9766 " number_of_elements=\"0\"\n"
9767 " number_of_elements_per_command=\"1\"\n"
9768 " repeat_command=\"1\"\n"
9769 " use_index=\"1\" >\n"
9770 " <Hints>\n"
9771 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
9772 " <Property name=\"UseCustomLabels\" function=\"boolean\" />\n"
9773 " </PropertyWidgetDecorator>\n"
9774 " </Hints>\n"
9775 " </DoubleVectorProperty>\n"
9776 " <IntVectorProperty animateable=\"0\"\n"
9777 " command=\"SetTextPosition\"\n"
9778 " default_values=\"1\"\n"
9779 " name=\"TextPosition\"\n"
9780 " label=\"Tick and Annotation Positions\"\n"
9781 " number_of_elements=\"1\">\n"
9782 " <EnumerationDomain name=\"enum\">\n"
9783 " <Entry text=\"Ticks right/top, annotations left/bottom\"\n"
9784 " value=\"1\" />\n"
9785 " <Entry text=\"Ticks left/bottom, annotations right/top\"\n"
9786 " value=\"0\" />\n"
9787 " </EnumerationDomain>\n"
9788 " <Documentation>Determines where the tick labels are drawn.</Documentation>\n"
9789 " </IntVectorProperty>\n"
9790 "\n"
9791 " <!--label text property -->\n"
9792 " <SubProxy command=\"SetLabelTextProperty\">\n"
9793 " <Proxy name=\"LabelTextProperty\"\n"
9794 " proxygroup=\"properties\"\n"
9795 " proxyname=\"TextProperty\"></Proxy>\n"
9796 " <ExposedProperties>\n"
9797 " <Property exposed_name=\"LabelColor\"\n"
9798 " name=\"Color\" />\n"
9799 " <Property exposed_name=\"LabelOpacity\"\n"
9800 " name=\"Opacity\" />\n"
9801 " <Property exposed_name=\"LabelFontFamily\"\n"
9802 " name=\"FontFamily\" />\n"
9803 " <Property exposed_name=\"LabelFontFile\"\n"
9804 " name=\"FontFile\" />\n"
9805 " <Property exposed_name=\"LabelBold\"\n"
9806 " name=\"Bold\" />\n"
9807 " <Property exposed_name=\"LabelItalic\"\n"
9808 " name=\"Italic\" />\n"
9809 " <Property exposed_name=\"LabelShadow\"\n"
9810 " name=\"Shadow\" />\n"
9811 " <Property exposed_name=\"LabelFontSize\"\n"
9812 " name=\"FontSize\" />\n"
9813 " </ExposedProperties>\n"
9814 " </SubProxy>\n"
9815 " <!--title text property -->\n"
9816 " <SubProxy command=\"SetTitleTextProperty\">\n"
9817 " <Proxy name=\"TitleTextProperty\"\n"
9818 " proxygroup=\"properties\"\n"
9819 " proxyname=\"TextProperty\"></Proxy>\n"
9820 " <ExposedProperties>\n"
9821 " <Property exposed_name=\"TitleColor\"\n"
9822 " name=\"Color\" />\n"
9823 " <Property exposed_name=\"TitleOpacity\"\n"
9824 " name=\"Opacity\" />\n"
9825 " <Property exposed_name=\"TitleFontFamily\"\n"
9826 " name=\"FontFamily\" />\n"
9827 " <Property exposed_name=\"TitleFontFile\"\n"
9828 " name=\"FontFile\" />\n"
9829 " <Property exposed_name=\"TitleBold\"\n"
9830 " name=\"Bold\" />\n"
9831 " <Property exposed_name=\"TitleItalic\"\n"
9832 " name=\"Italic\" />\n"
9833 " <Property exposed_name=\"TitleShadow\"\n"
9834 " name=\"Shadow\" />\n"
9835 " <Property exposed_name=\"TitleFontSize\"\n"
9836 " name=\"FontSize\" />\n"
9837 " </ExposedProperties>\n"
9838 " </SubProxy>\n"
9839 " </Proxy>\n"
9840 "\n"
9841 " <!-- ================================================================== -->\n"
9842 " <Proxy class=\"vtkFlagpoleLabel\"\n"
9843 " name=\"FlagpoleLabel\"\n"
9844 " processes=\"client|dataserver|renderserver\"\n"
9845 " >\n"
9846 " <Documentation>FlagpoleLabel is a 3D representation for a text\n"
9847 " source.</Documentation>\n"
9848 "\n"
9849 " <IntVectorProperty name=\"Visibility\"\n"
9850 " command=\"SetVisibility\"\n"
9851 " number_of_elements=\"1\"\n"
9852 " default_values=\"0\"\n"
9853 " panel_visibility=\"advanced\">\n"
9854 " <BooleanDomain name=\"bool\" />\n"
9855 " <Documentation>\n"
9856 " Show/hide the flagpole lable.\n"
9857 " </Documentation>\n"
9858 " </IntVectorProperty>\n"
9859 "\n"
9860 " <DoubleVectorProperty name=\"BasePosition\"\n"
9861 " command=\"SetBasePosition\"\n"
9862 " number_of_elements=\"3\"\n"
9863 " default_values=\"0.0 0.0 0.0\"\n"
9864 " >\n"
9865 " <DoubleRangeDomain name=\"range\" />\n"
9866 " <Documentation>\n"
9867 " The world coordinate position of the base of the flagpole.\n"
9868 " </Documentation>\n"
9869 " </DoubleVectorProperty>\n"
9870 "\n"
9871 " <DoubleVectorProperty name=\"TopPosition\"\n"
9872 " command=\"SetTopPosition\"\n"
9873 " number_of_elements=\"3\"\n"
9874 " default_values=\"0.0 1.0 0.0\"\n"
9875 " >\n"
9876 " <DoubleRangeDomain name=\"range\" />\n"
9877 " <Documentation>\n"
9878 " The world coordinate position of the top of the flagpole.\n"
9879 " </Documentation>\n"
9880 " </DoubleVectorProperty>\n"
9881 "\n"
9882 " <DoubleVectorProperty name=\"FlagSize\"\n"
9883 " command=\"SetFlagSize\"\n"
9884 " number_of_elements=\"1\"\n"
9885 " default_values=\"1.0\"\n"
9886 " >\n"
9887 " <DoubleRangeDomain min=\"0.001\" name=\"range\" />\n"
9888 " <Documentation>\n"
9889 " The size of the flag. 1.0 is the default size which corresponds to\n"
9890 " a preset texels/window value. Adjust this to increase or decrease\n"
9891 " the default size.The world coordinate position of the top of the\n"
9892 " flagpole.\n"
9893 " </Documentation>\n"
9894 " </DoubleVectorProperty>\n"
9895 "\n"
9896 " <SubProxy command=\"SetTextProperty\">\n"
9897 " <Proxy name=\"TextProperty\"\n"
9898 " proxygroup=\"properties\"\n"
9899 " proxyname=\"TextProperty\"></Proxy>\n"
9900 " <ExposedProperties>\n"
9901 " <Property name=\"Color\"/>\n"
9902 " <Property name=\"Opacity\"/>\n"
9903 " <Property name=\"FontFamily\"/>\n"
9904 " <Property name=\"FontFile\"/>\n"
9905 " <Property name=\"Bold\"/>\n"
9906 " <Property name=\"Italic\"/>\n"
9907 " <Property name=\"Shadow\"/>\n"
9908 " <Property name=\"FontSize\"/>\n"
9909 " <Property name=\"Justification\"/>\n"
9910 " </ExposedProperties>\n"
9911 " </SubProxy>\n"
9912 " <!-- End of FlagpoleLabel -->\n"
9913 " </Proxy>\n"
9914 "\n"
9915 " <!-- ================================================================== -->\n"
9916 " <Proxy class=\"vtkBillboardTextActor3D\"\n"
9917 " name=\"BillboardTextActor3D\"\n"
9918 " processes=\"client|dataserver|renderserver\"\n"
9919 " >\n"
9920 " <Documentation>BillboardTextActor3D is a 3D representation for a text\n"
9921 " source.</Documentation>\n"
9922 "\n"
9923 " <IntVectorProperty name=\"Visibility\"\n"
9924 " command=\"SetVisibility\"\n"
9925 " number_of_elements=\"1\"\n"
9926 " default_values=\"0\"\n"
9927 " panel_visibility=\"advanced\">\n"
9928 " <BooleanDomain name=\"bool\" />\n"
9929 " <Documentation>\n"
9930 " Show/hide the billboard text actor.\n"
9931 " </Documentation>\n"
9932 " </IntVectorProperty>\n"
9933 "\n"
9934 " <DoubleVectorProperty name=\"BillboardPosition\"\n"
9935 " command=\"SetPosition\"\n"
9936 " number_of_elements=\"3\"\n"
9937 " default_values=\"0.0 0.0 0.0\"\n"
9938 " >\n"
9939 " <DoubleRangeDomain name=\"range\" />\n"
9940 " <Documentation>\n"
9941 " The world coordinate position of the anchor point of the text billboard.\n"
9942 " </Documentation>\n"
9943 " </DoubleVectorProperty>\n"
9944 "\n"
9945 " <IntVectorProperty name=\"DisplayOffset\"\n"
9946 " command=\"SetDisplayOffset\"\n"
9947 " number_of_elements=\"2\"\n"
9948 " default_values=\"0 0\"\n"
9949 " panel_visibility=\"advanced\">\n"
9950 " <Documentation>\n"
9951 " Fixed offset from the anchor point in display coordinated to be used.\n"
9952 " </Documentation>\n"
9953 " </IntVectorProperty>\n"
9954 "\n"
9955 " <SubProxy command=\"SetTextProperty\">\n"
9956 " <Proxy name=\"TextProperty\"\n"
9957 " proxygroup=\"properties\"\n"
9958 " proxyname=\"TextProperty\"></Proxy>\n"
9959 " <ExposedProperties>\n"
9960 " <Property name=\"Color\"/>\n"
9961 " <Property name=\"Opacity\"/>\n"
9962 " <Property name=\"FontFamily\"/>\n"
9963 " <Property name=\"FontFile\"/>\n"
9964 " <Property name=\"Bold\"/>\n"
9965 " <Property name=\"Italic\"/>\n"
9966 " <Property name=\"Shadow\"/>\n"
9967 " <Property name=\"FontSize\"/>\n"
9968 " <Property name=\"Justification\"/>\n"
9969 " </ExposedProperties>\n"
9970 " </SubProxy>\n"
9971 " <!-- End of BillboardTextActor3D -->\n"
9972 " </Proxy>\n"
9973 "\n"
9974 " <!-- ================================================================== -->\n"
9975 " <Proxy name=\"GridAxes3DActor\"\n"
9976 " label=\"Grid Axes 3D Actor\"\n"
9977 " class=\"vtkPVGridAxes3DActor\"\n"
9978 " processes=\"client|dataserver|renderserver\">\n"
9979 " <Documentation>\n"
9980 " GridAxes3DActor can be used to render a grid in a render view.\n"
9981 " </Documentation>\n"
9982 " <IntVectorProperty name=\"Visibility\"\n"
9983 " command=\"SetVisibility\"\n"
9984 " number_of_elements=\"1\"\n"
9985 " default_values=\"0\"\n"
9986 " panel_visibility=\"advanced\">\n"
9987 " <BooleanDomain name=\"bool\" />\n"
9988 " <Documentation>\n"
9989 " Show/hide the axes grid.\n"
9990 " </Documentation>\n"
9991 " </IntVectorProperty>\n"
9992 "\n"
9993 " <StringVectorProperty name=\"XTitle\"\n"
9994 " command=\"SetXTitle\"\n"
9995 " number_of_elements=\"1\"\n"
9996 " default_values=\"X Axis\">\n"
9997 " <Documentation>\n"
9998 " Set the title string for X axis.\n"
9999 " </Documentation>\n"
10000 " </StringVectorProperty>\n"
10001 "\n"
10002 " <StringVectorProperty name=\"YTitle\"\n"
10003 " command=\"SetYTitle\"\n"
10004 " number_of_elements=\"1\"\n"
10005 " default_values=\"Y Axis\">\n"
10006 " <Documentation>\n"
10007 " Set the title string for Y axis.\n"
10008 " </Documentation>\n"
10009 " </StringVectorProperty>\n"
10010 "\n"
10011 " <StringVectorProperty name=\"ZTitle\"\n"
10012 " command=\"SetZTitle\"\n"
10013 " number_of_elements=\"1\"\n"
10014 " default_values=\"Z Axis\">\n"
10015 " <Documentation>\n"
10016 " Set the title string for Z axis.\n"
10017 " </Documentation>\n"
10018 " </StringVectorProperty>\n"
10019 "\n"
10020 " <PropertyGroup label=\"Title Texts\">\n"
10021 " <Property name=\"XTitle\"/>\n"
10022 " <Property name=\"YTitle\"/>\n"
10023 " <Property name=\"ZTitle\"/>\n"
10024 " </PropertyGroup>\n"
10025 "\n"
10026 " <SubProxy command=\"SetXTitleTextProperty\">\n"
10027 " <Proxy name=\"XTitleProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10028 " <ExposedProperties>\n"
10029 " <Property exposed_name=\"XTitleColor\" name=\"Color\" />\n"
10030 " <Property exposed_name=\"XTitleOpacity\" name=\"Opacity\" />\n"
10031 " <Property exposed_name=\"XTitleFontFamily\" name=\"FontFamily\" />\n"
10032 " <Property exposed_name=\"XTitleFontFile\" name=\"FontFile\" />\n"
10033 " <Property exposed_name=\"XTitleBold\" name=\"Bold\" />\n"
10034 " <Property exposed_name=\"XTitleItalic\" name=\"Italic\" />\n"
10035 " <Property exposed_name=\"XTitleShadow\" name=\"Shadow\" />\n"
10036 " <Property exposed_name=\"XTitleFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10037 " </ExposedProperties>\n"
10038 " </SubProxy>\n"
10039 "\n"
10040 " <PropertyGroup label=\"X Title Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10041 " <Property name=\"XTitleColor\" function=\"Color\"/>\n"
10042 " <Property name=\"XTitleFontFamily\" function=\"Family\"/>\n"
10043 " <Property name=\"XTitleFontFile\" function=\"File\"/>\n"
10044 " <Property name=\"XTitleBold\" function=\"Bold\" />\n"
10045 " <Property name=\"XTitleItalic\" function=\"Italics\"/>\n"
10046 " <Property name=\"XTitleFontSize\" function=\"Size\" />\n"
10047 " <Property name=\"XTitleShadow\" function=\"Shadow\" />\n"
10048 " <Property name=\"XTitleOpacity\" function=\"Opacity\" />\n"
10049 " </PropertyGroup>\n"
10050 "\n"
10051 " <SubProxy command=\"SetYTitleTextProperty\">\n"
10052 " <Proxy name=\"YTitleProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10053 " <ExposedProperties>\n"
10054 " <Property exposed_name=\"YTitleColor\" name=\"Color\" />\n"
10055 " <Property exposed_name=\"YTitleOpacity\" name=\"Opacity\" />\n"
10056 " <Property exposed_name=\"YTitleFontFamily\" name=\"FontFamily\" />\n"
10057 " <Property exposed_name=\"YTitleFontFile\" name=\"FontFile\" />\n"
10058 " <Property exposed_name=\"YTitleBold\" name=\"Bold\" />\n"
10059 " <Property exposed_name=\"YTitleItalic\" name=\"Italic\" />\n"
10060 " <Property exposed_name=\"YTitleShadow\" name=\"Shadow\" />\n"
10061 " <Property exposed_name=\"YTitleFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10062 " </ExposedProperties>\n"
10063 " </SubProxy>\n"
10064 "\n"
10065 " <PropertyGroup label=\"Y Title Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10066 " <Property name=\"YTitleColor\" function=\"Color\"/>\n"
10067 " <Property name=\"YTitleFontFamily\" function=\"Family\"/>\n"
10068 " <Property name=\"YTitleFontFile\" function=\"File\"/>\n"
10069 " <Property name=\"YTitleBold\" function=\"Bold\" />\n"
10070 " <Property name=\"YTitleItalic\" function=\"Italics\"/>\n"
10071 " <Property name=\"YTitleFontSize\" function=\"Size\" />\n"
10072 " <Property name=\"YTitleShadow\" function=\"Shadow\" />\n"
10073 " <Property name=\"YTitleOpacity\" function=\"Opacity\" />\n"
10074 " </PropertyGroup>\n"
10075 "\n"
10076 " <SubProxy command=\"SetZTitleTextProperty\">\n"
10077 " <Proxy name=\"ZTitleProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10078 " <ExposedProperties>\n"
10079 " <Property exposed_name=\"ZTitleColor\" name=\"Color\" />\n"
10080 " <Property exposed_name=\"ZTitleOpacity\" name=\"Opacity\" />\n"
10081 " <Property exposed_name=\"ZTitleFontFamily\" name=\"FontFamily\" />\n"
10082 " <Property exposed_name=\"ZTitleFontFile\" name=\"FontFile\" />\n"
10083 " <Property exposed_name=\"ZTitleBold\" name=\"Bold\" />\n"
10084 ;
10085
10086 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
10088 " <Property exposed_name=\"ZTitleItalic\" name=\"Italic\" />\n"
10089 " <Property exposed_name=\"ZTitleShadow\" name=\"Shadow\" />\n"
10090 " <Property exposed_name=\"ZTitleFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10091 " </ExposedProperties>\n"
10092 " </SubProxy>\n"
10093 "\n"
10094 " <PropertyGroup label=\"Z Title Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10095 " <Property name=\"ZTitleColor\" function=\"Color\"/>\n"
10096 " <Property name=\"ZTitleFontFamily\" function=\"Family\"/>\n"
10097 " <Property name=\"ZTitleFontFile\" function=\"File\"/>\n"
10098 " <Property name=\"ZTitleBold\" function=\"Bold\" />\n"
10099 " <Property name=\"ZTitleItalic\" function=\"Italics\"/>\n"
10100 " <Property name=\"ZTitleFontSize\" function=\"Size\" />\n"
10101 " <Property name=\"ZTitleShadow\" function=\"Shadow\" />\n"
10102 " <Property name=\"ZTitleOpacity\" function=\"Opacity\" />\n"
10103 " </PropertyGroup>\n"
10104 "\n"
10105 " <IntVectorProperty name=\"FacesToRender\"\n"
10106 " command=\"SetFaceMask\"\n"
10107 " number_of_elements=\"1\"\n"
10108 " default_values=\"63\"\n"
10109 " panel_widget=\"int_mask\"\n"
10110 " panel_visibility=\"advanced\">\n"
10111 " <Documentation>\n"
10112 " Set the mask to select faces. The faces rendered will be a subset of the\n"
10113 " faces selected depending on the status of **CullBackface** and\n"
10114 " **CullFrontface** properties.\n"
10115 " </Documentation>\n"
10116 " <IntRangeDomain name=\"range\" min=\"0\" />\n"
10117 " <Hints>\n"
10118 " <Mask>\n"
10119 " <Item name=\"Min-YZ\" value=\"1\" />\n"
10120 " <Item name=\"Min-ZX\" value=\"2\" />\n"
10121 " <Item name=\"Min-XY\" value=\"4\" />\n"
10122 " <Item name=\"Max-YZ\" value=\"8\" />\n"
10123 " <Item name=\"Max-ZX\" value=\"16\" />\n"
10124 " <Item name=\"Max-XY\" value=\"32\" />\n"
10125 " </Mask>\n"
10126 " </Hints>\n"
10127 " </IntVectorProperty>\n"
10128 "\n"
10129 " <SubProxy command=\"SetProperty\">\n"
10130 " <Proxy name=\"Property\" class=\"vtkProperty\" processes=\"client|dataserver|renderserver\" >\n"
10131 " <IntVectorProperty name=\"CullBackface\"\n"
10132 " command=\"SetBackfaceCulling\"\n"
10133 " number_of_elements=\"1\"\n"
10134 " default_values=\"0\"\n"
10135 " panel_visibility=\"advanced\">\n"
10136 " <BooleanDomain name=\"bool\" />\n"
10137 " <Documentation>\n"
10138 " Set to true to hide faces of the grid facing away from the camera i.e. hide all\n"
10139 " back faces.\n"
10140 " </Documentation>\n"
10141 " </IntVectorProperty>\n"
10142 "\n"
10143 " <IntVectorProperty name=\"CullFrontface\"\n"
10144 " command=\"SetFrontfaceCulling\"\n"
10145 " number_of_elements=\"1\"\n"
10146 " default_values=\"1\"\n"
10147 " panel_visibility=\"advanced\">\n"
10148 " <BooleanDomain name=\"bool\" />\n"
10149 " <Documentation>\n"
10150 " Set to true to hide faces of the grid facing towards from the camera i.e. hide all\n"
10151 " front faces.\n"
10152 " </Documentation>\n"
10153 " </IntVectorProperty>\n"
10154 "\n"
10155 " <IntVectorProperty name=\"Representation\"\n"
10156 " command=\"SetRepresentation\"\n"
10157 " number_of_elements=\"1\"\n"
10158 " default_values=\"1\">\n"
10159 " </IntVectorProperty>\n"
10160 "\n"
10161 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
10162 " name=\"GridColor\"\n"
10163 " command=\"SetColor\"\n"
10164 " number_of_elements=\"3\"\n"
10165 " panel_widget=\"color_selector\">\n"
10166 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
10167 " <Documentation>Color used when coloring the grid wireframe</Documentation>\n"
10168 " <Hints>\n"
10169 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\"\n"
10170 " unlink_if_modified=\"1\" />\n"
10171 " </Hints>\n"
10172 " </DoubleVectorProperty>\n"
10173 " </Proxy>\n"
10174 " <ExposedProperties>\n"
10175 " <Property name=\"CullBackface\" panel_visibility=\"advanced\"/>\n"
10176 " <Property name=\"CullFrontface\" panel_visibility=\"advanced\"/>\n"
10177 " <Property name=\"GridColor\" />\n"
10178 " </ExposedProperties>\n"
10179 " </SubProxy>\n"
10180 "\n"
10181 " <PropertyGroup label=\"Face Properties\">\n"
10182 " <Property name=\"FacesToRender\" />\n"
10183 " <Property name=\"CullBackface\" />\n"
10184 " <Property name=\"CullFrontface\" />\n"
10185 " <Property name=\"GridColor\"/>\n"
10186 " </PropertyGroup>\n"
10187 "\n"
10188 " <IntVectorProperty name=\"ShowGrid\"\n"
10189 " command=\"SetGenerateGrid\"\n"
10190 " number_of_elements=\"1\"\n"
10191 " default_values=\"0\">\n"
10192 " <BooleanDomain name=\"bool\"/>\n"
10193 " <Documentation>\n"
10194 " Turn off to not render the plane grids.\n"
10195 " </Documentation>\n"
10196 " </IntVectorProperty>\n"
10197 "\n"
10198 " <IntVectorProperty name=\"ShowEdges\"\n"
10199 " command=\"SetGenerateEdges\"\n"
10200 " number_of_elements=\"1\"\n"
10201 " default_values=\"1\"\n"
10202 " panel_visibility=\"advanced\">\n"
10203 " <BooleanDomain name=\"bool\"/>\n"
10204 " <Documentation>\n"
10205 " Turn off to not render the plane edges.\n"
10206 " </Documentation>\n"
10207 " </IntVectorProperty>\n"
10208 "\n"
10209 " <IntVectorProperty name=\"ShowTicks\"\n"
10210 " command=\"SetGenerateTicks\"\n"
10211 " number_of_elements=\"1\"\n"
10212 " default_values=\"1\"\n"
10213 " panel_visibility=\"advanced\">\n"
10214 " <BooleanDomain name=\"bool\"/>\n"
10215 " <Documentation>\n"
10216 " Turn off to not render the tick marks.\n"
10217 " </Documentation>\n"
10218 " </IntVectorProperty>\n"
10219 "\n"
10220 " <IntVectorProperty name=\"AxesToLabel\"\n"
10221 " command=\"SetLabelMask\"\n"
10222 " number_of_elements=\"1\"\n"
10223 " default_values=\"63\"\n"
10224 " panel_widget=\"int_mask\"\n"
10225 " panel_visibility=\"advanced\">\n"
10226 " <Documentation>\n"
10227 " Set the mask to select the axes to label. The axes labelled will be a subset of the\n"
10228 " axes selected depending on which faces are also being rendered.\n"
10229 " </Documentation>\n"
10230 " <IntRangeDomain name=\"range\" min=\"0\" />\n"
10231 " <Hints>\n"
10232 " <Mask>\n"
10233 " <Item name=\"Min-X\" value=\"1\" />\n"
10234 " <Item name=\"Min-Y\" value=\"2\" />\n"
10235 " <Item name=\"Min-Z\" value=\"4\" />\n"
10236 " <Item name=\"Max-X\" value=\"8\" />\n"
10237 " <Item name=\"Max-Y\" value=\"16\" />\n"
10238 " <Item name=\"Max-Z\" value=\"32\" />\n"
10239 " </Mask>\n"
10240 " </Hints>\n"
10241 " </IntVectorProperty>\n"
10242 "\n"
10243 " <IntVectorProperty name=\"LabelUniqueEdgesOnly\"\n"
10244 " command=\"SetLabelUniqueEdgesOnly\"\n"
10245 " number_of_elements=\"1\"\n"
10246 " default_values=\"1\"\n"
10247 " panel_visibility=\"advanced\">\n"
10248 " <BooleanDomain name=\"bool\" />\n"
10249 " <Documentation>\n"
10250 " Set to true to only label edges shared with 1 face. Note that\n"
10251 " if all faces are being rendered, this will generate no labels.\n"
10252 " </Documentation>\n"
10253 " </IntVectorProperty>\n"
10254 "\n"
10255 " <PropertyGroup label=\"Label Properties\">\n"
10256 " <Property name=\"LabelUniqueEdgesOnly\" />\n"
10257 " <Property name=\"AxesToLabel\" />\n"
10258 " </PropertyGroup>\n"
10259 "\n"
10260 " <SubProxy command=\"SetXLabelTextProperty\">\n"
10261 " <Proxy name=\"XLabelProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10262 " <ExposedProperties>\n"
10263 " <Property exposed_name=\"XLabelColor\" name=\"Color\" />\n"
10264 " <Property exposed_name=\"XLabelOpacity\" name=\"Opacity\" />\n"
10265 " <Property exposed_name=\"XLabelFontFamily\" name=\"FontFamily\" />\n"
10266 " <Property exposed_name=\"XLabelFontFile\" name=\"FontFile\" />\n"
10267 " <Property exposed_name=\"XLabelBold\" name=\"Bold\" />\n"
10268 " <Property exposed_name=\"XLabelItalic\" name=\"Italic\" />\n"
10269 " <Property exposed_name=\"XLabelShadow\" name=\"Shadow\" />\n"
10270 " <Property exposed_name=\"XLabelFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10271 " </ExposedProperties>\n"
10272 " </SubProxy>\n"
10273 "\n"
10274 " <PropertyGroup label=\"X Axis Label Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10275 " <Property name=\"XLabelColor\" function=\"Color\"/>\n"
10276 " <Property name=\"XLabelFontFamily\" function=\"Family\"/>\n"
10277 " <Property name=\"XLabelFontFile\" function=\"File\"/>\n"
10278 " <Property name=\"XLabelBold\" function=\"Bold\" />\n"
10279 " <Property name=\"XLabelItalic\" function=\"Italics\"/>\n"
10280 " <Property name=\"XLabelFontSize\" function=\"Size\" />\n"
10281 " <Property name=\"XLabelShadow\" function=\"Shadow\" />\n"
10282 " <Property name=\"XLabelOpacity\" function=\"Opacity\" />\n"
10283 " </PropertyGroup>\n"
10284 "\n"
10285 " <SubProxy command=\"SetYLabelTextProperty\">\n"
10286 " <Proxy name=\"YLabelProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10287 " <ExposedProperties>\n"
10288 " <Property exposed_name=\"YLabelColor\" name=\"Color\" />\n"
10289 " <Property exposed_name=\"YLabelOpacity\" name=\"Opacity\" />\n"
10290 " <Property exposed_name=\"YLabelFontFamily\" name=\"FontFamily\" />\n"
10291 " <Property exposed_name=\"YLabelFontFile\" name=\"FontFile\" />\n"
10292 " <Property exposed_name=\"YLabelBold\" name=\"Bold\" />\n"
10293 " <Property exposed_name=\"YLabelItalic\" name=\"Italic\" />\n"
10294 " <Property exposed_name=\"YLabelShadow\" name=\"Shadow\" />\n"
10295 " <Property exposed_name=\"YLabelFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10296 " </ExposedProperties>\n"
10297 " </SubProxy>\n"
10298 "\n"
10299 " <PropertyGroup label=\"Y Axis Label Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10300 " <Property name=\"YLabelColor\" function=\"Color\"/>\n"
10301 " <Property name=\"YLabelFontFamily\" function=\"Family\"/>\n"
10302 " <Property name=\"YLabelFontFile\" function=\"File\"/>\n"
10303 " <Property name=\"YLabelBold\" function=\"Bold\" />\n"
10304 " <Property name=\"YLabelItalic\" function=\"Italics\"/>\n"
10305 " <Property name=\"YLabelFontSize\" function=\"Size\" />\n"
10306 " <Property name=\"YLabelShadow\" function=\"Shadow\" />\n"
10307 " <Property name=\"YLabelOpacity\" function=\"Opacity\" />\n"
10308 " </PropertyGroup>\n"
10309 "\n"
10310 " <SubProxy command=\"SetZLabelTextProperty\">\n"
10311 " <Proxy name=\"ZLabelProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10312 " <ExposedProperties>\n"
10313 " <Property exposed_name=\"ZLabelColor\" name=\"Color\" />\n"
10314 " <Property exposed_name=\"ZLabelOpacity\" name=\"Opacity\" />\n"
10315 " <Property exposed_name=\"ZLabelFontFamily\" name=\"FontFamily\" />\n"
10316 " <Property exposed_name=\"ZLabelFontFile\" name=\"FontFile\" />\n"
10317 " <Property exposed_name=\"ZLabelBold\" name=\"Bold\" />\n"
10318 " <Property exposed_name=\"ZLabelItalic\" name=\"Italic\" />\n"
10319 " <Property exposed_name=\"ZLabelShadow\" name=\"Shadow\" />\n"
10320 " <Property exposed_name=\"ZLabelFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10321 " </ExposedProperties>\n"
10322 " </SubProxy>\n"
10323 "\n"
10324 " <PropertyGroup label=\"Z Axis Label Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10325 " <Property name=\"ZLabelColor\" function=\"Color\"/>\n"
10326 " <Property name=\"ZLabelFontFamily\" function=\"Family\"/>\n"
10327 " <Property name=\"ZLabelFontFile\" function=\"File\"/>\n"
10328 " <Property name=\"ZLabelBold\" function=\"Bold\" />\n"
10329 " <Property name=\"ZLabelItalic\" function=\"Italics\"/>\n"
10330 " <Property name=\"ZLabelFontSize\" function=\"Size\" />\n"
10331 " <Property name=\"ZLabelShadow\" function=\"Shadow\" />\n"
10332 " <Property name=\"ZLabelOpacity\" function=\"Opacity\" />\n"
10333 " </PropertyGroup>\n"
10334 "\n"
10335 " <IntVectorProperty name=\"XAxisNotation\"\n"
10336 " command=\"SetXNotation\"\n"
10337 " default_values=\"0\"\n"
10338 " panel_visibility=\"advanced\"\n"
10339 " number_of_elements=\"1\">\n"
10340 " <Documentation>\n"
10341 " Get/set the numerical notation, standard, scientific or mixed (0, 1, 2) for X Axis.\n"
10342 " </Documentation>\n"
10343 " <EnumerationDomain name=\"enum\">\n"
10344 " <Entry text=\"Mixed\" value=\"0\" />\n"
10345 " <Entry text=\"Scientific\" value=\"1\" />\n"
10346 " <Entry text=\"Fixed\" value=\"2\" />\n"
10347 " </EnumerationDomain>\n"
10348 " </IntVectorProperty>\n"
10349 " <IntVectorProperty command=\"SetXPrecision\"\n"
10350 " default_values=\"2\"\n"
10351 " panel_visibility=\"advanced\"\n"
10352 " name=\"XAxisPrecision\"\n"
10353 " number_of_elements=\"1\">\n"
10354 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
10355 " <Documentation>\n"
10356 " Get/set the numerical precision to use for the X Axis, default is 2.\n"
10357 " </Documentation>\n"
10358 " </IntVectorProperty>\n"
10359 "\n"
10360 " <IntVectorProperty command=\"SetXUseCustomLabels\"\n"
10361 " default_values=\"0\"\n"
10362 " name=\"XAxisUseCustomLabels\"\n"
10363 " number_of_elements=\"1\">\n"
10364 " <BooleanDomain name=\"bool\" />\n"
10365 " <Documentation>\n"
10366 " Specify whether to use custom labels for the X axis. Labels\n"
10367 " specified by **XAxisLabels** are used only when\n"
10368 " this flag is set to 1.\n"
10369 " </Documentation>\n"
10370 " </IntVectorProperty>\n"
10371 " <DoubleVectorProperty name=\"XAxisLabels\"\n"
10372 " command=\"SetXLabel\"\n"
10373 " set_number_command=\"SetNumberOfXLabels\"\n"
10374 " number_of_elements=\"0\"\n"
10375 " number_of_elements_per_command=\"1\"\n"
10376 " repeat_command=\"1\"\n"
10377 " use_index=\"1\" >\n"
10378 " <!-- used to trigger the display pqScalarValueListPropertyWidget -->\n"
10379 " <ArrayRangeDomain name=\"scalar_range\"/>\n"
10380 " <Hints>\n"
10381 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
10382 " <Property name=\"XAxisUseCustomLabels\" function=\"boolean\" />\n"
10383 " </PropertyWidgetDecorator>\n"
10384 " </Hints>\n"
10385 " </DoubleVectorProperty>\n"
10386 "\n"
10387 " <PropertyGroup label=\"X Axis Label Properties\">\n"
10388 " <Property name=\"XAxisNotation\" />\n"
10389 " <Property name=\"XAxisPrecision\" />\n"
10390 " <Property name=\"XAxisUseCustomLabels\" />\n"
10391 " <Property name=\"XAxisLabels\" />\n"
10392 " </PropertyGroup>\n"
10393 "\n"
10394 " <IntVectorProperty name=\"YAxisNotation\"\n"
10395 " command=\"SetYNotation\"\n"
10396 " default_values=\"0\"\n"
10397 " panel_visibility=\"advanced\"\n"
10398 " number_of_elements=\"1\">\n"
10399 " <Documentation>\n"
10400 " Get/set the numerical notation, standard, scientific or mixed (0, 1, 2) for Y Axis.\n"
10401 " </Documentation>\n"
10402 ;
10403
10404 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
10406 " <EnumerationDomain name=\"enum\">\n"
10407 " <Entry text=\"Mixed\" value=\"0\" />\n"
10408 " <Entry text=\"Scientific\" value=\"1\" />\n"
10409 " <Entry text=\"Fixed\" value=\"2\" />\n"
10410 " </EnumerationDomain>\n"
10411 " </IntVectorProperty>\n"
10412 " <IntVectorProperty command=\"SetYPrecision\"\n"
10413 " default_values=\"2\"\n"
10414 " panel_visibility=\"advanced\"\n"
10415 " name=\"YAxisPrecision\"\n"
10416 " number_of_elements=\"1\">\n"
10417 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
10418 " <Documentation>\n"
10419 " Get/set the numerical precision to use for the Y Axis, default is 2.\n"
10420 " </Documentation>\n"
10421 " </IntVectorProperty>\n"
10422 "\n"
10423 " <IntVectorProperty command=\"SetYUseCustomLabels\"\n"
10424 " default_values=\"0\"\n"
10425 " name=\"YAxisUseCustomLabels\"\n"
10426 " number_of_elements=\"1\">\n"
10427 " <BooleanDomain name=\"bool\" />\n"
10428 " <Documentation>\n"
10429 " Specify whether to use custom labels for the Y axis. Labels\n"
10430 " specified by **YAxisLabels** are used only when\n"
10431 " this flag is set to 1.\n"
10432 " </Documentation>\n"
10433 " </IntVectorProperty>\n"
10434 " <DoubleVectorProperty command=\"SetYLabel\"\n"
10435 " set_number_command=\"SetNumberOfYLabels\"\n"
10436 " name=\"YAxisLabels\"\n"
10437 " number_of_elements=\"0\"\n"
10438 " number_of_elements_per_command=\"1\"\n"
10439 " repeat_command=\"1\"\n"
10440 " use_index=\"1\">\n"
10441 " <!-- used to trigger the display pqScalarValueListPropertyWidget -->\n"
10442 " <ArrayRangeDomain name=\"scalar_range\"/>\n"
10443 " <Hints>\n"
10444 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
10445 " <Property name=\"YAxisUseCustomLabels\" function=\"boolean\" />\n"
10446 " </PropertyWidgetDecorator>\n"
10447 " </Hints>\n"
10448 " </DoubleVectorProperty>\n"
10449 "\n"
10450 " <PropertyGroup label=\"Y Axis Label Properties\">\n"
10451 " <Property name=\"YAxisNotation\" />\n"
10452 " <Property name=\"YAxisPrecision\" />\n"
10453 " <Property name=\"YAxisUseCustomLabels\" />\n"
10454 " <Property name=\"YAxisLabels\" />\n"
10455 " </PropertyGroup>\n"
10456 "\n"
10457 " <IntVectorProperty name=\"ZAxisNotation\"\n"
10458 " command=\"SetZNotation\"\n"
10459 " default_values=\"0\"\n"
10460 " panel_visibility=\"advanced\"\n"
10461 " number_of_elements=\"1\">\n"
10462 " <Documentation>\n"
10463 " Get/set the numerical notation, standard, scientific or mixed (0, 1, 2) for Z Axis.\n"
10464 " </Documentation>\n"
10465 " <EnumerationDomain name=\"enum\">\n"
10466 " <Entry text=\"Mixed\" value=\"0\" />\n"
10467 " <Entry text=\"Scientific\" value=\"1\" />\n"
10468 " <Entry text=\"Fixed\" value=\"2\" />\n"
10469 " </EnumerationDomain>\n"
10470 " </IntVectorProperty>\n"
10471 " <IntVectorProperty command=\"SetZPrecision\"\n"
10472 " default_values=\"2\"\n"
10473 " panel_visibility=\"advanced\"\n"
10474 " name=\"ZAxisPrecision\"\n"
10475 " number_of_elements=\"1\">\n"
10476 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
10477 " <Documentation>\n"
10478 " Get/set the numerical precision to use for the Z Axis, default is 2.\n"
10479 " </Documentation>\n"
10480 " </IntVectorProperty>\n"
10481 "\n"
10482 " <IntVectorProperty command=\"SetZUseCustomLabels\"\n"
10483 " default_values=\"0\"\n"
10484 " name=\"ZAxisUseCustomLabels\"\n"
10485 " number_of_elements=\"1\">\n"
10486 " <BooleanDomain name=\"bool\" />\n"
10487 " <Documentation>\n"
10488 " Specify whether to use custom labels for the Z axis. Labels\n"
10489 " specified by **ZAxisLabels** are used only when\n"
10490 " this flag is set to 1.\n"
10491 " </Documentation>\n"
10492 " </IntVectorProperty>\n"
10493 " <DoubleVectorProperty command=\"SetZLabel\"\n"
10494 " set_number_command=\"SetNumberOfZLabels\"\n"
10495 " name=\"ZAxisLabels\"\n"
10496 " number_of_elements=\"0\"\n"
10497 " number_of_elements_per_command=\"1\"\n"
10498 " repeat_command=\"1\"\n"
10499 " use_index=\"1\" >\n"
10500 " <!-- used to trigger the display pqScalarValueListPropertyWidget -->\n"
10501 " <ArrayRangeDomain name=\"scalar_range\"/>\n"
10502 " <Hints>\n"
10503 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
10504 " <Property name=\"ZAxisUseCustomLabels\" function=\"boolean\" />\n"
10505 " </PropertyWidgetDecorator>\n"
10506 " </Hints>\n"
10507 " </DoubleVectorProperty>\n"
10508 "\n"
10509 " <PropertyGroup label=\"Z Axis Label Properties\">\n"
10510 " <Property name=\"ZAxisNotation\" />\n"
10511 " <Property name=\"ZAxisPrecision\" />\n"
10512 " <Property name=\"ZAxisUseCustomLabels\" />\n"
10513 " <Property name=\"ZAxisLabels\" />\n"
10514 " </PropertyGroup>\n"
10515 "\n"
10516 " <IntVectorProperty name=\"UseCustomBounds\"\n"
10517 " command=\"SetUseCustomTransformedBounds\"\n"
10518 " number_of_elements=\"1\"\n"
10519 " default_values=\"0\">\n"
10520 " <BooleanDomain name=\"bool\" />\n"
10521 " <Documentation>\n"
10522 " If set, the axes will use explicitly specified bounds rather than using the bounds\n"
10523 " computed from datasets currently visible in the view.\n"
10524 " </Documentation>\n"
10525 " </IntVectorProperty>\n"
10526 "\n"
10527 " <DoubleVectorProperty name=\"CustomBounds\"\n"
10528 " command=\"SetCustomTransformedBounds\"\n"
10529 " number_of_elements=\"6\"\n"
10530 " default_values=\"0 1 0 1 0 1 0 1\">\n"
10531 " <DoubleRangeDomain name=\"range\" />\n"
10532 " <Documentation>\n"
10533 " Specify the explicit bounds to use when **UseCustomBounds** is checked.\n"
10534 " </Documentation>\n"
10535 " <Hints>\n"
10536 " <!-- show only when UseCustomBounds is true -->\n"
10537 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
10538 " mode=\"visibility\"\n"
10539 " property=\"UseCustomBounds\"\n"
10540 " value=\"1\"/>\n"
10541 " <DoubleVectorPropertyWidget>\n"
10542 " <!-- add buttons to reset using active bounds -->\n"
10543 " <Button type=\"use_active_source_bounds\" />\n"
10544 " </DoubleVectorPropertyWidget>\n"
10545 " </Hints>\n"
10546 " </DoubleVectorProperty>\n"
10547 "\n"
10548 " <DoubleVectorProperty name=\"DataScale\"\n"
10549 " command=\"SetDataScale\"\n"
10550 " number_of_elements=\"3\"\n"
10551 " default_values=\"1 1 1\"\n"
10552 " panel_visibility=\"advanced\">\n"
10553 " <DoubleRangeDomain name=\"range\" />\n"
10554 " <Documentation>\n"
10555 " If data is being scaled, you can show the original data bounds for the axes\n"
10556 " instead of the scaled bounds by setting the DataScale to match the scaling applied\n"
10557 " to the dataset.\n"
10558 " </Documentation>\n"
10559 " <Hints>\n"
10560 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
10561 " mode=\"enabled_state\"\n"
10562 " property=\"UseModelTransform\"\n"
10563 " value=\"0\"/>\n"
10564 " <!-- disable this when UseModelTransform is true -->\n"
10565 " </Hints>\n"
10566 " </DoubleVectorProperty>\n"
10567 "\n"
10568 " <DoubleVectorProperty name=\"DataPosition\"\n"
10569 " command=\"SetDataPosition\"\n"
10570 " number_of_elements=\"3\"\n"
10571 " default_values=\"0 0 0\"\n"
10572 " panel_visibility=\"advanced\">\n"
10573 " <DoubleRangeDomain name=\"range\" />\n"
10574 " <Documentation>\n"
10575 " If data is being translated, you can show the original data bounds for the axes\n"
10576 " instead of the translated bounds by setting the DataPosition to match the\n"
10577 " translation applied to the dataset.\n"
10578 " </Documentation>\n"
10579 " <Hints>\n"
10580 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
10581 " mode=\"enabled_state\"\n"
10582 " property=\"UseModelTransform\"\n"
10583 " value=\"0\"/>\n"
10584 " <!-- disable this when UseModelTransform is true -->\n"
10585 " </Hints>\n"
10586 " </DoubleVectorProperty>\n"
10587 "\n"
10588 " <DoubleVectorProperty name=\"DataBoundsScaleFactor\"\n"
10589 " command=\"SetDataBoundsScaleFactor\"\n"
10590 " number_of_elements=\"1\"\n"
10591 " default_values=\"1.0008\"\n"
10592 " panel_visibility=\"advanced\">\n"
10593 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"2\"/>\n"
10594 " <Documentation>\n"
10595 " After the data bounds have been computed, this property enables to scale the\n"
10596 " bounds used to generate the axes grid, so it will be slightly larger than the\n"
10597 " data bounds.\n"
10598 " Data bounds are not modified, only the aspect of the AxesGrid is modified.\n"
10599 " The default value (1.0008) ensures that there is no concident lines drawn when\n"
10600 " zooming close enough to the model.\n"
10601 " </Documentation>\n"
10602 " <Hints>\n"
10603 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
10604 " mode=\"enabled_state\"\n"
10605 " property=\"UseModelTransform\"\n"
10606 " value=\"0\"/>\n"
10607 " <!-- disable this when UseModelTransform is true -->\n"
10608 " </Hints>\n"
10609 " </DoubleVectorProperty>\n"
10610 "\n"
10611 " <PropertyGroup label=\"Bounds\">\n"
10612 " <Property name=\"UseCustomBounds\" />\n"
10613 " <Property name=\"CustomBounds\" />\n"
10614 " </PropertyGroup>\n"
10615 "\n"
10616 " <PropertyGroup label=\"Data Transform\">\n"
10617 " <Property name=\"DataScale\" />\n"
10618 " <Property name=\"DataPosition\" />\n"
10619 " <Property name=\"DataBoundsScaleFactor\" />\n"
10620 " </PropertyGroup>\n"
10621 "\n"
10622 " <DoubleVectorProperty name=\"ModelTransformMatrix\"\n"
10623 " command=\"SetModelTransformMatrix\"\n"
10624 " number_of_elements=\"16\"\n"
10625 " default_values=\"1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1\"\n"
10626 " argument_is_array=\"1\"\n"
10627 " panel_visibility=\"never\">\n"
10628 " </DoubleVectorProperty>\n"
10629 " <DoubleVectorProperty name=\"ModelBounds\"\n"
10630 " command=\"SetModelBounds\"\n"
10631 " number_of_elements=\"6\"\n"
10632 " default_values=\"0 1 0 1 0 1\"\n"
10633 " panel_visibility=\"never\">\n"
10634 " </DoubleVectorProperty>\n"
10635 " <IntVectorProperty name=\"UseModelTransform\"\n"
10636 " command=\"SetUseModelTransform\"\n"
10637 " number_of_elements=\"1\"\n"
10638 " default_values=\"0\"\n"
10639 " panel_visibility=\"never\">\n"
10640 " <BooleanDomain name=\"range\" />\n"
10641 " </IntVectorProperty>\n"
10642 " <!-- End of 'GridAxes3DActor' -->\n"
10643 " </Proxy>\n"
10644 "\n"
10645 " <!-- ================================================================== -->\n"
10646 " <Proxy name=\"PolarGridActor\"\n"
10647 " label=\"Polar Grid Actor\"\n"
10648 " class=\"vtkPolarAxesActor2D\"\n"
10649 " processes=\"client|dataserver|renderserver\">\n"
10650 " <Documentation short_help=\"Polar coordinates grid for render view.\">\n"
10651 " PolarGridActor is a polar coordinates grid that can be displayed in overlay of a render view.\n"
10652 " </Documentation>\n"
10653 " <IntVectorProperty name=\"Visibility\"\n"
10654 " command=\"SetVisibility\"\n"
10655 " number_of_elements=\"1\"\n"
10656 " default_values=\"0\"\n"
10657 " panel_visibility=\"default\">\n"
10658 " <BooleanDomain name=\"bool\" />\n"
10659 " <Documentation>\n"
10660 " Show/hide the polar grid.\n"
10661 " </Documentation>\n"
10662 " </IntVectorProperty>\n"
10663 "\n"
10664 " <DoubleVectorProperty name=\"Origin\"\n"
10665 " command=\"SetOrigin\"\n"
10666 " number_of_elements=\"2\"\n"
10667 " default_values=\"0.5 0.5\"\n"
10668 " panel_visibility=\"default\">\n"
10669 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"1\" />\n"
10670 " <Documentation>\n"
10671 " The origin of the axes (in normalized coordinates). Default is at center [0.5, 0.5].\n"
10672 " </Documentation>\n"
10673 " </DoubleVectorProperty>\n"
10674 "\n"
10675 " <DoubleVectorProperty name=\"StartAngle\"\n"
10676 " command=\"SetStartAngle\"\n"
10677 " number_of_elements=\"1\"\n"
10678 " default_values=\"0\"\n"
10679 " panel_visibility=\"default\">\n"
10680 " <DoubleRangeDomain name=\"range\" />\n"
10681 " <Documentation>\n"
10682 " This is the orientation of the first axis (in degrees). It starts from a left-to-right axis\n"
10683 " and is measured counter-clockwise.\n"
10684 " </Documentation>\n"
10685 " </DoubleVectorProperty>\n"
10686 "\n"
10687 " <DoubleVectorProperty name=\"EndAngle\"\n"
10688 " command=\"SetEndAngle\"\n"
10689 " number_of_elements=\"1\"\n"
10690 " default_values=\"180\"\n"
10691 " panel_visibility=\"default\">\n"
10692 " <DoubleRangeDomain name=\"range\" />\n"
10693 " <Documentation>\n"
10694 " This is the orientation of the last axis (in degrees). It starts from a left-to-right axis\n"
10695 " and is measured counter-clockwise.\n"
10696 " </Documentation>\n"
10697 " </DoubleVectorProperty>\n"
10698 "\n"
10699 " <DoubleVectorProperty name=\"AxesLength\"\n"
10700 " command=\"SetAxesLength\"\n"
10701 " number_of_elements=\"1\"\n"
10702 " default_values=\"100\"\n"
10703 " panel_visibility=\"default\">\n"
10704 " <Documentation>\n"
10705 " The length of each radial axis in Viewport coordinates (in pixels).\n"
10706 " </Documentation>\n"
10707 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
10708 " </DoubleVectorProperty>\n"
10709 "\n"
10710 " <IntVectorProperty name=\"NumberOfAxes\"\n"
10711 " command=\"SetNumberOfAxes\"\n"
10712 " number_of_elements=\"1\"\n"
10713 " default_values=\"6\"\n"
10714 " panel_visibility=\"advanced\">\n"
10715 " <Documentation>\n"
10716 " The number of axes to display. Axes are evenly oriented around Origin\n"
10717 " and starting at StartAngle.\n"
10718 " </Documentation>\n"
10719 " <IntRangeDomain name=\"range\" min=\"2\" />\n"
10720 " </IntVectorProperty>\n"
10721 "\n"
10722 " <IntVectorProperty name=\"NumberOfTicks\"\n"
10723 " command=\"SetNumberOfAxesTicks\"\n"
10724 " number_of_elements=\"1\"\n"
10725 " default_values=\"6\"\n"
10726 " panel_visibility=\"advanced\">\n"
10727 " <Documentation>\n"
10728 " The number of ticks to display on each axis.\n"
10729 " </Documentation>\n"
10730 " <IntRangeDomain name=\"range\" min=\"2\" />\n"
10731 " </IntVectorProperty>\n"
10732 "\n"
10733 " <SubProxy command=\"SetProperty\">\n"
10734 " <Proxy name=\"2DProperty\" class=\"vtkProperty2D\" >\n"
10735 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
10736 " name=\"GridColor\"\n"
10737 " command=\"SetColor\"\n"
10738 " number_of_elements=\"3\"\n"
10739 " panel_visibility=\"advanced\"\n"
10740 " panel_widget=\"color_selector\">\n"
10741 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
10742 ;
10743
10744 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
10746 " <Documentation>Color for the axes and the arcs.</Documentation>\n"
10747 " </DoubleVectorProperty>\n"
10748 " </Proxy>\n"
10749 " <ExposedProperties>\n"
10750 " <Property name=\"GridColor\" />\n"
10751 " </ExposedProperties>\n"
10752 " </SubProxy>\n"
10753 "\n"
10754 " <PropertyGroup label=\" \" panel_visibility=\"advanced\">\n"
10755 " <Property name=\"NumberOfAxes\" />\n"
10756 " <Property name=\"NumberOfTicks\" />\n"
10757 " <Property name=\"GridColor\" />\n"
10758 " </PropertyGroup>\n"
10759 "\n"
10760 " <SubProxy command=\"SetAxesTextProperty\">\n"
10761 " <Proxy name=\"AxesTextProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10762 " <ExposedProperties>\n"
10763 " <Property exposed_name=\"AxesLabelColor\" name=\"Color\" />\n"
10764 " <Property exposed_name=\"AxesLabelFontFamily\" name=\"FontFamily\" />\n"
10765 " <Property exposed_name=\"AxesLabelBold\" name=\"Bold\" />\n"
10766 " <Property exposed_name=\"AxesLabelItalic\" name=\"Italic\" />\n"
10767 " <Property exposed_name=\"AxesLabelShadow\" name=\"Shadow\" />\n"
10768 " <Property exposed_name=\"AxesLabelFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10769 " </ExposedProperties>\n"
10770 " </SubProxy>\n"
10771 "\n"
10772 " <PropertyGroup label=\"Axes Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
10773 " <Property name=\"AxesLabelColor\" function=\"Color\"/>\n"
10774 " <Property name=\"AxesLabelFontFamily\" function=\"Family\"/>\n"
10775 " <Property name=\"AxesLabelBold\" function=\"Bold\" />\n"
10776 " <Property name=\"AxesLabelItalic\" function=\"Italics\"/>\n"
10777 " <Property name=\"AxesLabelFontSize\" function=\"Size\" />\n"
10778 " <Property name=\"AxesLabelShadow\" function=\"Shadow\" />\n"
10779 " </PropertyGroup>\n"
10780 "\n"
10781 " </Proxy>\n"
10782 "\n"
10783 " <!-- ================================================================== -->\n"
10784 " <Proxy name=\"LegendGridActor\"\n"
10785 " label=\"Legend Grid Actor\"\n"
10786 " class=\"vtkLegendScaleActor\"\n"
10787 " processes=\"client|dataserver|renderserver\">\n"
10788 " <Documentation>\n"
10789 " LegendGridActor can be used to render an axes grid in a render view.\n"
10790 " </Documentation>\n"
10791 " <IntVectorProperty name=\"Visibility\"\n"
10792 " command=\"SetVisibility\"\n"
10793 " number_of_elements=\"1\"\n"
10794 " default_values=\"0\"\n"
10795 " panel_visibility=\"advanced\">\n"
10796 " <BooleanDomain name=\"bool\" />\n"
10797 " <Documentation>\n"
10798 " Show/hide the axes grid.\n"
10799 " </Documentation>\n"
10800 " </IntVectorProperty>\n"
10801 "\n"
10802 " <SubProxy command=\"SetAxesProperty\">\n"
10803 " <Proxy name=\"2DProperty\" class=\"vtkProperty2D\" processes=\"client|dataserver|renderserver\" >\n"
10804 " <DoubleVectorProperty default_values=\"1.0 1.0 1.0\"\n"
10805 " name=\"GridColor\"\n"
10806 " command=\"SetColor\"\n"
10807 " number_of_elements=\"3\"\n"
10808 " panel_widget=\"color_selector\">\n"
10809 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
10810 " <Documentation>Color used when coloring the axes and grid</Documentation>\n"
10811 " </DoubleVectorProperty>\n"
10812 " </Proxy>\n"
10813 " <ExposedProperties>\n"
10814 " <Property name=\"GridColor\" />\n"
10815 " </ExposedProperties>\n"
10816 " </SubProxy>\n"
10817 "\n"
10818 " <IntVectorProperty command=\"SetGridVisibility\"\n"
10819 " default_values=\"0\"\n"
10820 " name=\"GridVisibility\"\n"
10821 " number_of_elements=\"1\">\n"
10822 " <BooleanDomain name=\"bool\" />\n"
10823 " <Documentation>\n"
10824 " When turned on, show the full axis grid\n"
10825 " </Documentation>\n"
10826 " </IntVectorProperty>\n"
10827 "\n"
10828 " <PropertyGroup label=\"Axis appearance\">\n"
10829 " <Property name=\"GridColor\" />\n"
10830 " <Property name=\"GridVisibility\" />\n"
10831 " </PropertyGroup>\n"
10832 "\n"
10833 " <IntVectorProperty name=\"RightBorderOffset\"\n"
10834 " command=\"SetRightBorderOffset\"\n"
10835 " number_of_elements=\"1\"\n"
10836 " default_values=\"50\"\n"
10837 " panel_visibility=\"advanced\">\n"
10838 " <IntRangeDomain name=\"range\" min=\"5\" max=\"100\" />\n"
10839 " <Documentation>\n"
10840 " Set the offset of right axis from the border. This number is expressed in\n"
10841 " pixels, and represents the approximate distance of the axes from the sides\n"
10842 " of the renderer.\n"
10843 " </Documentation>\n"
10844 " </IntVectorProperty>\n"
10845 "\n"
10846 " <IntVectorProperty name=\"TopBorderOffset\"\n"
10847 " command=\"SetTopBorderOffset\"\n"
10848 " number_of_elements=\"1\"\n"
10849 " default_values=\"30\"\n"
10850 " panel_visibility=\"advanced\">\n"
10851 " <IntRangeDomain name=\"range\" min=\"5\" max=\"100\" />\n"
10852 " <Documentation>\n"
10853 " Set the offset of top axis from the border. This number is expressed in\n"
10854 " pixels, and represents the approximate distance of the axes from the sides\n"
10855 " of the renderer.\n"
10856 " </Documentation>\n"
10857 " </IntVectorProperty>\n"
10858 "\n"
10859 " <IntVectorProperty name=\"LeftBorderOffset\"\n"
10860 " command=\"SetLeftBorderOffset\"\n"
10861 " number_of_elements=\"1\"\n"
10862 " default_values=\"50\"\n"
10863 " panel_visibility=\"advanced\">\n"
10864 " <IntRangeDomain name=\"range\" min=\"5\" max=\"100\" />\n"
10865 " <Documentation>\n"
10866 " Set the offset of left axis from the border. This number is expressed in\n"
10867 " pixels, and represents the approximate distance of the axes from the sides\n"
10868 " of the renderer.\n"
10869 " </Documentation>\n"
10870 " </IntVectorProperty>\n"
10871 "\n"
10872 " <IntVectorProperty name=\"BottomBorderOffset\"\n"
10873 " command=\"SetBottomBorderOffset\"\n"
10874 " number_of_elements=\"1\"\n"
10875 " default_values=\"30\"\n"
10876 " panel_visibility=\"advanced\">\n"
10877 " <IntRangeDomain name=\"range\" min=\"5\" max=\"100\" />\n"
10878 " <Documentation>\n"
10879 " Set the offset of bottom axis from the border. This number is expressed in\n"
10880 " pixels, and represents the approximate distance of the axes from the sides\n"
10881 " of the renderer.\n"
10882 " </Documentation>\n"
10883 " </IntVectorProperty>\n"
10884 "\n"
10885 " <PropertyGroup label=\"Axis positions\" panel_visibility=\"advanced\">\n"
10886 " <Property name=\"RightBorderOffset\" />\n"
10887 " <Property name=\"LeftBorderOffset\" />\n"
10888 " <Property name=\"TopBorderOffset\" />\n"
10889 " <Property name=\"BottomBorderOffset\" />\n"
10890 " </PropertyGroup>\n"
10891 "\n"
10892 " <SubProxy command=\"SetAxesTextProperty\">\n"
10893 " <Proxy name=\"AxesTextProperties\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
10894 " <ExposedProperties>\n"
10895 " <Property exposed_name=\"LegendLabelColor\" name=\"Color\" />\n"
10896 " <Property exposed_name=\"LegendLabelOpacity\" name=\"Opacity\" />\n"
10897 " <Property exposed_name=\"LegendLabelFontFamily\" name=\"FontFamily\" />\n"
10898 " <Property exposed_name=\"LegendLabelFontFile\" name=\"FontFile\" />\n"
10899 " <Property exposed_name=\"LegendLabelBold\" name=\"Bold\" />\n"
10900 " <Property exposed_name=\"LegendLabelItalic\" name=\"Italic\" />\n"
10901 " <Property exposed_name=\"LegendLabelShadow\" name=\"Shadow\" />\n"
10902 " <Property exposed_name=\"LegendLabelFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
10903 " </ExposedProperties>\n"
10904 " </SubProxy>\n"
10905 "\n"
10906 " <PropertyGroup label=\"Axis Label Font Properties\" panel_widget=\"FontEditor\">\n"
10907 " <Property name=\"LegendLabelColor\" function=\"Color\"/>\n"
10908 " <Property name=\"LegendLabelFontFamily\" function=\"Family\"/>\n"
10909 " <Property name=\"LegendLabelFontFile\" function=\"File\"/>\n"
10910 " <Property name=\"LegendLabelBold\" function=\"Bold\" />\n"
10911 " <Property name=\"LegendLabelItalic\" function=\"Italics\"/>\n"
10912 " <Property name=\"LegendLabelFontSize\" function=\"Size\" />\n"
10913 " <Property name=\"LegendLabelShadow\" function=\"Shadow\" />\n"
10914 " <Property name=\"LegendLabelOpacity\" function=\"Opacity\" />\n"
10915 " </PropertyGroup>\n"
10916 "\n"
10917 " <IntVectorProperty name=\"AxisNotation\"\n"
10918 " command=\"SetNotation\"\n"
10919 " default_values=\"0\"\n"
10920 " number_of_elements=\"1\">\n"
10921 " <Documentation>\n"
10922 " Set the numerical notation for axis labels: standard, scientific or mixed.\n"
10923 " </Documentation>\n"
10924 " <EnumerationDomain name=\"enum\">\n"
10925 " <Entry text=\"Default\" value=\"0\" />\n"
10926 " <Entry text=\"Scientific\" value=\"1\" />\n"
10927 " <Entry text=\"Fixed\" value=\"2\" />\n"
10928 " </EnumerationDomain>\n"
10929 " </IntVectorProperty>\n"
10930 "\n"
10931 " <IntVectorProperty command=\"SetPrecision\"\n"
10932 " default_values=\"2\"\n"
10933 " name=\"AxisPrecision\"\n"
10934 " number_of_elements=\"1\">\n"
10935 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
10936 " <Documentation>\n"
10937 " Set the numerical precision to use for the axis (only for scientific and fixed-point notation).\n"
10938 " </Documentation>\n"
10939 " <Hints>\n"
10940 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
10941 " <Expression type=\"or\">\n"
10942 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AxisNotation\" value=\"1\"/>\n"
10943 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AxisNotation\" value=\"2\"/>\n"
10944 " </Expression>\n"
10945 " </PropertyWidgetDecorator>\n"
10946 " </Hints>\n"
10947 " </IntVectorProperty>\n"
10948 "\n"
10949 " <PropertyGroup label=\"Axis Label notation\">\n"
10950 " <Property name=\"AxisNotation\"/>\n"
10951 " <Property name=\"AxisPrecision\"/>\n"
10952 " </PropertyGroup>\n"
10953 "\n"
10954 " <IntVectorProperty command=\"SetNumberOfHorizontalLabels\"\n"
10955 " default_values=\"5\"\n"
10956 " panel_visibility=\"advanced\"\n"
10957 " name=\"HorizontalLabelNumber\"\n"
10958 " number_of_elements=\"1\">\n"
10959 " <IntRangeDomain name=\"range\" min=\"0\" max=\"24\"/>\n"
10960 " <Documentation>\n"
10961 " Set the number of ticks and labels for the horizontal axis.\n"
10962 " </Documentation>\n"
10963 " </IntVectorProperty>\n"
10964 "\n"
10965 " <IntVectorProperty command=\"SetNumberOfVerticalLabels\"\n"
10966 " default_values=\"5\"\n"
10967 " panel_visibility=\"advanced\"\n"
10968 " name=\"VerticalLabelNumber\"\n"
10969 " number_of_elements=\"1\">\n"
10970 " <IntRangeDomain name=\"range\" min=\"0\" max=\"24\"/>\n"
10971 " <Documentation>\n"
10972 " Set the number of ticks and labels for the vertical axis.\n"
10973 " </Documentation>\n"
10974 " </IntVectorProperty>\n"
10975 "\n"
10976 " <DoubleVectorProperty name=\"Origin\"\n"
10977 " command=\"SetOrigin\"\n"
10978 " panel_visibility=\"advanced\"\n"
10979 " number_of_elements=\"3\"\n"
10980 " default_values=\"0 0 0\">\n"
10981 " <Documentation>\n"
10982 " The origin of the measure.\n"
10983 " </Documentation>\n"
10984 " </DoubleVectorProperty>\n"
10985 "\n"
10986 "\n"
10987 " <PropertyGroup label=\"Tick configuration\" panel_visibility=\"advanced\">\n"
10988 " <Property name=\"HorizontalLabelNumber\" />\n"
10989 " <Property name=\"VerticalLabelNumber\" />\n"
10990 " <Property name=\"Origin\" />\n"
10991 " </PropertyGroup>\n"
10992 "\n"
10993 " </Proxy>\n"
10994 "\n"
10995 " <!-- ================================================================== -->\n"
10996 " <!-- End of ProxyGroup annotations -->\n"
10997 " </ProxyGroup>\n"
10998 "\n"
10999 " <!-- ==================================================================== -->\n"
11000 " <ProxyGroup name=\"misc\">\n"
11001 " <!-- ================================================================== -->\n"
11002 " <ViewLayoutProxy name=\"ViewLayout\"\n"
11003 " class=\"vtkViewLayout\"\n"
11004 " processes=\"client|renderserver\">\n"
11005 " <Documentation>Proxy used to manage layout for multiple views.</Documentation>\n"
11006 " <IntVectorProperty name=\"PreviewMode\"\n"
11007 " number_of_elements=\"2\"\n"
11008 " default_values=\"0 0\">\n"
11009 " <Documentation>\n"
11010 " Set the target resolution for the preview mode to display,\n"
11011 " [0, 0] is interpreted as exiting preview.\n"
11012 " </Documentation>\n"
11013 " </IntVectorProperty>\n"
11014 " <IntVectorProperty name=\"SeparatorWidth\"\n"
11015 " command=\"SetSeparatorWidth\"\n"
11016 " number_of_elements=\"1\"\n"
11017 " default_values=\"1\">\n"
11018 " <IntRangeDomain name=\"range\" min=\"0\" max=\"10\" />\n"
11019 " <Documentation>\n"
11020 " The width of the separator (in pixels) to be displayed in preview mode.\n"
11021 " </Documentation>\n"
11022 " </IntVectorProperty>\n"
11023 " <DoubleVectorProperty name=\"SeparatorColor\"\n"
11024 " command=\"SetSeparatorColor\"\n"
11025 " number_of_elements=\"3\"\n"
11026 " default_values=\"0.937 0.922 0.906\">\n"
11027 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" max=\"1 1 1\" />\n"
11028 " <Documentation>\n"
11029 " The color of the separator to be displayed in preview mode.\n"
11030 " </Documentation>\n"
11031 " </DoubleVectorProperty>\n"
11032 " </ViewLayoutProxy>\n"
11033 "\n"
11034 " <!-- ================================================================== -->\n"
11035 " <Proxy class=\"vtkPVRayCastPickingHelper\"\n"
11036 " name=\"PickingHelper\"\n"
11037 " processes=\"dataserver\">\n"
11038 " <Documentation>Proxy used to pick a point of a surface\n"
11039 " mesh.</Documentation>\n"
11040 " <DoubleVectorProperty command=\"SetPointA\"\n"
11041 " default_values=\"0.0 0.0 0.0\"\n"
11042 " name=\"PointA\"\n"
11043 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
11044 " <DoubleVectorProperty command=\"SetPointB\"\n"
11045 " default_values=\"0.0 0.0 1.0\"\n"
11046 " name=\"PointB\"\n"
11047 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
11048 " <IntVectorProperty command=\"SetSnapOnMeshPoint\"\n"
11049 " default_values=\"0\"\n"
11050 " name=\"SnapOnMeshPoint\"\n"
11051 " number_of_elements=\"1\">\n"
11052 " <BooleanDomain name=\"bool\" />\n"
11053 " </IntVectorProperty>\n"
11054 " <DoubleVectorProperty command=\"GetIntersection\"\n"
11055 " default_values=\"0.0 0.0 0.0\"\n"
11056 " information_only=\"1\"\n"
11057 " name=\"Intersection\"\n"
11058 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
11059 " <DoubleVectorProperty command=\"GetIntersectionNormal\"\n"
11060 " default_values=\"0.0 0.0 0.0\"\n"
11061 " information_only=\"1\"\n"
11062 " name=\"IntersectionNormal\"\n"
11063 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
11064 " <Property command=\"ComputeIntersection\"\n"
11065 " name=\"Update\"></Property>\n"
11066 " <ProxyProperty command=\"SetInput\"\n"
11067 " name=\"Input\">\n"
11068 " <Documentation>The input from which the selection is\n"
11069 " extracted.</Documentation>\n"
11070 " </ProxyProperty>\n"
11071 " <ProxyProperty command=\"SetSelection\"\n"
11072 ;
11073
11074 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
11076 " name=\"Selection\">\n"
11077 " <Documentation>The selection that is used to reduced the\n"
11078 " input.</Documentation>\n"
11079 " </ProxyProperty>\n"
11080 " </Proxy>\n"
11081 "\n"
11082 " <!-- ================================================================== -->\n"
11083 " <SaveScreenshotProxy name=\"SaveScreenshotBase\" processes=\"client\">\n"
11084 " <Documentation>\n"
11085 " Proxy used to save screenshots from view(s) or layouts.\n"
11086 " </Documentation>\n"
11087 " <ProxyProperty name=\"Layout\" panel_visibility=\"never\" />\n"
11088 " <ProxyProperty name=\"View\" panel_visibility=\"never\" />\n"
11089 "\n"
11090 " <IntVectorProperty name=\"SaveAllViews\"\n"
11091 " number_of_elements=\"1\"\n"
11092 " default_values=\"0\">\n"
11093 " <BooleanDomain name=\"bool\" />\n"
11094 " <Documentation>\n"
11095 " When checked, all views in the active layout will be saved in the image.\n"
11096 " Otherwise only the active view will be saved.\n"
11097 " </Documentation>\n"
11098 " </IntVectorProperty>\n"
11099 "\n"
11100 " <IntVectorProperty name=\"ImageResolution\"\n"
11101 " number_of_elements=\"2\"\n"
11102 " default_values=\"none\"\n"
11103 " panel_widget=\"view_resolution\" >\n"
11104 " <ViewResolutionDomain name=\"range\" default_mode=\"max\">\n"
11105 " <RequiredProperties>\n"
11106 " <Property name=\"SaveAllViews\" function=\"UseLayout\" />\n"
11107 " <Property name=\"Layout\" function=\"Layout\" />\n"
11108 " <Property name=\"View\" function=\"View\" />\n"
11109 " </RequiredProperties>\n"
11110 " </ViewResolutionDomain>\n"
11111 " <Documentation>\n"
11112 " Choose the image resolution in pixels.\n"
11113 " </Documentation>\n"
11114 " </IntVectorProperty>\n"
11115 "\n"
11116 " <IntVectorProperty name=\"FontScaling\"\n"
11117 " number_of_elements=\"1\"\n"
11118 " default_values=\"0\"\n"
11119 " panel_visibility=\"advanced\">\n"
11120 " <EnumerationDomain name=\"enum\">\n"
11121 " <Entry value=\"0\" text=\"Scale fonts proportionally\" />\n"
11122 " <Entry value=\"1\" text=\"Do not scale fonts\" />\n"
11123 " </EnumerationDomain>\n"
11124 " <Documentation>\n"
11125 " Select how fonts are to be scaled when saving images at different\n"
11126 " resolution than the current size.\n"
11127 " </Documentation>\n"
11128 " </IntVectorProperty>\n"
11129 "\n"
11130 " <IntVectorProperty name=\"SeparatorWidth\"\n"
11131 " number_of_elements=\"1\"\n"
11132 " default_values=\"1\"\n"
11133 " panel_visibility=\"advanced\">\n"
11134 " <IntRangeDomain name=\"range\" min=\"0\" max=\"10\" />\n"
11135 " <Documentation>\n"
11136 " Specify the width of border (in pixels) to use around views when\n"
11137 " **Save All Views** is checked.\n"
11138 " </Documentation>\n"
11139 " <Hints>\n"
11140 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
11141 " mode=\"enabled_state\"\n"
11142 " property=\"SaveAllViews\"\n"
11143 " value=\"1\" />\n"
11144 " </Hints>\n"
11145 " </IntVectorProperty>\n"
11146 "\n"
11147 " <DoubleVectorProperty name=\"SeparatorColor\"\n"
11148 " number_of_elements=\"3\"\n"
11149 " default_values=\"0.937 0.922 0.906\"\n"
11150 " panel_widget=\"color_selector_with_palette\"\n"
11151 " panel_visibility=\"advanced\">\n"
11152 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" max=\"1 1 1\" />\n"
11153 " <Documentation>\n"
11154 " Select the separator color.\n"
11155 " </Documentation>\n"
11156 " <Hints>\n"
11157 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
11158 " mode=\"enabled_state\"\n"
11159 " property=\"SaveAllViews\"\n"
11160 " value=\"1\" />\n"
11161 " </Hints>\n"
11162 " </DoubleVectorProperty>\n"
11163 "\n"
11164 " <StringVectorProperty name=\"OverrideColorPalette\"\n"
11165 " number_of_elements=\"1\"\n"
11166 " default_values=\"\"\n"
11167 " panel_widget=\"color_palette_selector\" >\n"
11168 " <StringListDomain name=\"list\" />\n"
11169 " <Documentation>\n"
11170 " Choose the color palette to load before saving the image.\n"
11171 " </Documentation>\n"
11172 " </StringVectorProperty>\n"
11173 "\n"
11174 " <IntVectorProperty name=\"StereoMode\"\n"
11175 " number_of_elements=\"1\"\n"
11176 " default_values=\"-1\"\n"
11177 " panel_visibility=\"advanced\">\n"
11178 " <Documentation>\n"
11179 " Select a stereo mode, as needed.\n"
11180 " </Documentation>\n"
11181 " <EnumerationDomain name=\"enum\">\n"
11182 " <Entry text=\"No change\" value=\"-1\" />\n"
11183 " <Entry text=\"No stereo\" value=\"0\" />\n"
11184 " <Entry text=\"Red-Blue\" value=\"2\" />\n"
11185 " <Entry text=\"Interlaced\" value=\"3\" />\n"
11186 " <Entry text=\"Left Eye Only\" value=\"4\" />\n"
11187 " <Entry text=\"Right Eye Only\" value=\"5\" />\n"
11188 " <Entry text=\"Both Eyes\" value=\"11\" />\n"
11189 " <Entry text=\"Dresden\" value=\"6\" />\n"
11190 " <Entry text=\"Anaglyph\" value=\"7\" />\n"
11191 " <Entry text=\"Checkerboard\" value=\"8\" />\n"
11192 " <Entry text=\"Side-by-Side Horizontal\" value=\"9\" />\n"
11193 " </EnumerationDomain>\n"
11194 " </IntVectorProperty>\n"
11195 "\n"
11196 " <IntVectorProperty name=\"TransparentBackground\"\n"
11197 " number_of_elements=\"1\"\n"
11198 " default_values=\"0\">\n"
11199 " <BooleanDomain name=\"bool\" />\n"
11200 " <Documentation>\n"
11201 " Set whether to use a transparent background.\n"
11202 " </Documentation>\n"
11203 " </IntVectorProperty>\n"
11204 " </SaveScreenshotProxy>\n"
11205 "\n"
11206 " <!-- ================================================================== -->\n"
11207 " <SaveScreenshotProxy name=\"SaveScreenshot\" processes=\"client\"\n"
11208 " label=\"Save Screenshot\"\n"
11209 " base_proxygroup=\"misc\"\n"
11210 " base_proxyname=\"SaveScreenshotBase\">\n"
11211 " <Documentation>\n"
11212 " Proxy used to save screenshots from view(s) or layouts.\n"
11213 " </Documentation>\n"
11214 " <ProxyProperty name=\"Format\">\n"
11215 " <ProxyListDomain name=\"proxy_list\">\n"
11216 " <Group name=\"screenshot_writers\" />\n"
11217 " </ProxyListDomain>\n"
11218 " <Hints>\n"
11219 " <ProxySelectionWidget enabled=\"0\" />\n"
11220 " </Hints>\n"
11221 " </ProxyProperty>\n"
11222 "\n"
11223 " <IntVectorProperty name=\"SaveInBackground\"\n"
11224 " command=\"SetSaveInBackground\"\n"
11225 " number_of_elements=\"1\"\n"
11226 " default_values=\"0\">\n"
11227 " <BooleanDomain name=\"bool\"/>\n"
11228 " <Documentation>\n"
11229 " If turned ON, screenshots are saved in a pool of threads running in the background\n"
11230 " instead of running serially.\n"
11231 " </Documentation>\n"
11232 " </IntVectorProperty>\n"
11233 "\n"
11234 " <IntVectorProperty name=\"EmbedParaViewState\"\n"
11235 " label=\"Embed ParaView State\"\n"
11236 " number_of_elements=\"1\"\n"
11237 " default_values=\"0\">\n"
11238 " <BooleanDomain name=\"bool\"/>\n"
11239 " <Documentation>\n"
11240 " Set whether to embed the ParaView state in the image as metadata.\n"
11241 " This option is only available for PNG.\n"
11242 " </Documentation>\n"
11243 " <Hints>\n"
11244 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
11245 " mode=\"visibility\"\n"
11246 " property=\"Format\"\n"
11247 " value=\"PNG\">\n"
11248 " </PropertyWidgetDecorator>\n"
11249 " </Hints>\n"
11250 " </IntVectorProperty>\n"
11251 "\n"
11252 " <PropertyGroup label=\"Size and Scaling\">\n"
11253 " <Property name=\"SaveAllViews\" />\n"
11254 " <Property name=\"ImageResolution\" />\n"
11255 " <Property name=\"FontScaling\" />\n"
11256 " </PropertyGroup>\n"
11257 "\n"
11258 " <PropertyGroup label=\"Separator Options\" >\n"
11259 " <Property name=\"SeparatorWidth\" />\n"
11260 " <Property name=\"SeparatorColor\" />\n"
11261 " </PropertyGroup>\n"
11262 "\n"
11263 " <PropertyGroup label=\"Coloring\">\n"
11264 " <Property name=\"OverrideColorPalette\" />\n"
11265 " <Property name=\"StereoMode\" />\n"
11266 " <Property name=\"TransparentBackground\" />\n"
11267 " </PropertyGroup>\n"
11268 "\n"
11269 " <PropertyGroup label=\"Image Options\">\n"
11270 " <Property name=\"Format\" />\n"
11271 " </PropertyGroup>\n"
11272 "\n"
11273 " <PropertyGroup label=\"Metadata\">\n"
11274 " <Property name=\"EmbedParaViewState\" />\n"
11275 " </PropertyGroup>\n"
11276 " </SaveScreenshotProxy>\n"
11277 "\n"
11278 " <!-- end of \"misc\" -->\n"
11279 " </ProxyGroup>\n"
11280 "\n"
11281 " <!-- ==================================================================== -->\n"
11282 " <ProxyGroup name=\"screenshot_writers\">\n"
11283 " <Documentation>\n"
11284 " This group includes all writers which can be used to write screenshots in ParaView.\n"
11285 " </Documentation>\n"
11286 "\n"
11287 " <!-- ================================================================== -->\n"
11288 " <Proxy name=\"PNG\" class=\"vtkPNGWriter\" processes=\"client|dataserver\">\n"
11289 " <Documentation>\n"
11290 " Writer for saving screenshots as PNG files.\n"
11291 " </Documentation>\n"
11292 "\n"
11293 " <StringVectorProperty name=\"FileName\" command=\"SetFileName\"\n"
11294 " number_of_elements=\"1\"\n"
11295 " default_values=\"\"\n"
11296 " panel_visibility=\"never\">\n"
11297 " </StringVectorProperty>\n"
11298 "\n"
11299 " <IntVectorProperty name=\"CompressionLevel\"\n"
11300 " command=\"SetCompressionLevel\"\n"
11301 " number_of_elements=\"1\"\n"
11302 " default_values=\"5\">\n"
11303 " <Documentation>\n"
11304 " Specify the *zlib* compression level. **0** is no compression, while **9** is\n"
11305 " maximum compression.\n"
11306 " </Documentation>\n"
11307 " <EnumerationDomain name=\"enum\">\n"
11308 " <Entry text=\"0\" value=\"0\" info=\"no compression\" />\n"
11309 " <Entry text=\"1\" value=\"1\" />\n"
11310 " <Entry text=\"2\" value=\"2\" />\n"
11311 " <Entry text=\"3\" value=\"3\" />\n"
11312 " <Entry text=\"4\" value=\"4\" />\n"
11313 " <Entry text=\"5\" value=\"5\" />\n"
11314 " <Entry text=\"6\" value=\"6\" />\n"
11315 " <Entry text=\"7\" value=\"7\" />\n"
11316 " <Entry text=\"8\" value=\"8\" />\n"
11317 " <Entry text=\"9\" value=\"9\" info=\"Maximum compression\" />\n"
11318 " </EnumerationDomain>\n"
11319 " </IntVectorProperty>\n"
11320 " <StringVectorProperty\n"
11321 " name=\"MetaData\"\n"
11322 " command=\"AddText\"\n"
11323 " number_of_elements_per_command=\"2\"\n"
11324 " element_types=\"2 2\"\n"
11325 " repeat_command=\"1\"\n"
11326 " clean_command=\"ClearText\"\n"
11327 " default_values_delimiter=\";\"\n"
11328 " default_values=\"Application;ParaView\"\n"
11329 " number_of_elements=\"2\"\n"
11330 " panel_visibility=\"advanced\">\n"
11331 " <Documentation>\n"
11332 " This property enables adding meta data as text chunks to the output\n"
11333 " PNG file in the form of text key/value pairs.\n"
11334 " </Documentation>\n"
11335 " </StringVectorProperty>\n"
11336 " <Hints>\n"
11337 " <FormatOptions extensions=\"png\"\n"
11338 " file_description=\"PNG images\" />\n"
11339 " </Hints>\n"
11340 " </Proxy>\n"
11341 "\n"
11342 " <!-- ================================================================== -->\n"
11343 " <Proxy name=\"JPEG\" class=\"vtkJPEGWriter\" processes=\"client|dataserver\">\n"
11344 " <Documentation>\n"
11345 " Writer for saving screenshots as JPEG files.\n"
11346 " </Documentation>\n"
11347 "\n"
11348 " <StringVectorProperty name=\"FileName\" command=\"SetFileName\"\n"
11349 " number_of_elements=\"1\"\n"
11350 " default_values=\"\"\n"
11351 " panel_visibility=\"never\">\n"
11352 " </StringVectorProperty>\n"
11353 "\n"
11354 " <IntVectorProperty name=\"Quality\"\n"
11355 " command=\"SetQuality\"\n"
11356 " number_of_elements=\"1\"\n"
11357 " default_values=\"95\">\n"
11358 " <Documentation>\n"
11359 " Specify the JPEG compression quality. **O** is low quality (maximum compression)\n"
11360 " and **100** is high quality (least compression).\n"
11361 " </Documentation>\n"
11362 " <IntRangeDomain name=\"range\" min=\"0\" max=\"100\" />\n"
11363 " </IntVectorProperty>\n"
11364 " <IntVectorProperty name=\"Progressive\"\n"
11365 " command=\"SetProgressive\"\n"
11366 " number_of_elements=\"1\"\n"
11367 " default_values=\"1\">\n"
11368 " <BooleanDomain name=\"bool\" />\n"
11369 " <Documentation>\n"
11370 " Save progressive JPEG.\n"
11371 " </Documentation>\n"
11372 " </IntVectorProperty>\n"
11373 " <Hints>\n"
11374 " <FormatOptions extensions=\"jpeg jpg\"\n"
11375 " file_description=\"JPEG images\" />\n"
11376 " </Hints>\n"
11377 " </Proxy>\n"
11378 "\n"
11379 " <!-- ================================================================== -->\n"
11380 " <Proxy name=\"TIFF\" class=\"vtkTIFFWriter\" processes=\"client|dataserver\">\n"
11381 " <Documentation>\n"
11382 " Writer for saving screenshots as TIFF files.\n"
11383 " </Documentation>\n"
11384 "\n"
11385 " <StringVectorProperty name=\"FileName\" command=\"SetFileName\"\n"
11386 " number_of_elements=\"1\"\n"
11387 " default_values=\"\"\n"
11388 " panel_visibility=\"never\">\n"
11389 " </StringVectorProperty>\n"
11390 "\n"
11391 " <IntVectorProperty name=\"Compression\"\n"
11392 " command=\"SetCompression\"\n"
11393 " number_of_elements=\"1\"\n"
11394 " default_values=\"1\">\n"
11395 " <Documentation>\n"
11396 " Specify compression type.\n"
11397 " </Documentation>\n"
11398 " <EnumerationDomain name=\"enum\">\n"
11399 " <Entry text=\"None\" value=\"0\" />\n"
11400 " <Entry text=\"PackBits\" value=\"1\" />\n"
11401 " <Entry text=\"Deflate\" value=\"3\" />\n"
11402 " <!--\n"
11403 " JPEG is disabled since it raised errors about color space when\n"
11404 " using it.\n"
11405 "\n"
11406 " LZW is disabled since its not available (as per docs in vtkTIFFWriter\n"
11407 " -->\n"
11408 " </EnumerationDomain>\n"
11409 " </IntVectorProperty>\n"
11410 " <Hints>\n"
11411 " <FormatOptions extensions=\"tiff tif\"\n"
11412 " file_description=\"TIFF images\" />\n"
11413 " </Hints>\n"
11414 " </Proxy>\n"
11415 "\n"
11416 " <!-- ================================================================== -->\n"
11417 " <Proxy name=\"BMP\" class=\"vtkBMPWriter\" processes=\"client|dataserver\">\n"
11418 " <Documentation>\n"
11419 " Writer for saving screenshots as BMP files.\n"
11420 " </Documentation>\n"
11421 "\n"
11422 " <StringVectorProperty name=\"FileName\" command=\"SetFileName\"\n"
11423 " number_of_elements=\"1\"\n"
11424 " default_values=\"\"\n"
11425 " panel_visibility=\"never\">\n"
11426 " </StringVectorProperty>\n"
11427 "\n"
11428 " <Hints>\n"
11429 " <FormatOptions extensions=\"bmp\"\n"
11430 " file_description=\"Bitmap images\" />\n"
11431 " </Hints>\n"
11432 " </Proxy>\n"
11433 "\n"
11434 " <!-- ================================================================== -->\n"
11435 " <Proxy name=\"VTK\" class=\"vtkGenericDataObjectWriter\" processes=\"client|dataserver\">\n"
11436 " <Documentation>\n"
11437 " Writer for saving screenshots as VTK files.\n"
11438 " </Documentation>\n"
11439 "\n"
11440 " <StringVectorProperty name=\"FileName\" command=\"SetFileName\"\n"
11441 " number_of_elements=\"1\"\n"
11442 " default_values=\"\"\n"
11443 " panel_visibility=\"never\">\n"
11444 " </StringVectorProperty>\n"
11445 "\n"
11446 " <IntVectorProperty name=\"FileType\"\n"
11447 " command=\"SetFileType\"\n"
11448 " number_of_elements=\"1\"\n"
11449 " default_values=\"2\">\n"
11450 " <Documentation>\n"
11451 " Specify the file type (ASCII or Binary).\n"
11452 " </Documentation>\n"
11453 " <EnumerationDomain name=\"enum\">\n"
11454 " <Entry text=\"ASCII\" value=\"1\" />\n"
11455 " <Entry text=\"Binary\" value=\"2\" />\n"
11456 " </EnumerationDomain>\n"
11457 " </IntVectorProperty>\n"
11458 "\n"
11459 " <Hints>\n"
11460 " <FormatOptions extensions=\"vtk\"\n"
11461 " file_description=\"VTK images\" />\n"
11462 " </Hints>\n"
11463 "\n"
11464 " </Proxy>\n"
11465 "\n"
11466 " <!-- end of \"screenshot_writers\" -->\n"
11467 " </ProxyGroup>\n"
11468 "\n"
11469 " <!-- ==================================================================== -->\n"
11470 ;
11471
11472 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/utilities_remotingviews.xml
11474 " <ProxyGroup name=\"HardwareSelectors\">\n"
11475 " <Proxy name=\"PVHardwareSelector\"\n"
11476 " class=\"vtkPVHardwareSelector\">\n"
11477 " </Proxy>\n"
11478 " </ProxyGroup>\n"
11479 "\n"
11480 "</ServerManagerConfiguration>\n"
11481 "\n";
11482 // Get single string
11484 {
11485
11496  const size_t len10 = strlen(paraview_server_managerutilities_remotingviewsInterface10);
11497  const size_t len11 = strlen(paraview_server_managerutilities_remotingviewsInterface11);
11498  const size_t len12 = strlen(paraview_server_managerutilities_remotingviewsInterface12);
11499  size_t len = ( 0
11500  + len0
11501  + len1
11502  + len2
11503  + len3
11504  + len4
11505  + len5
11506  + len6
11507  + len7
11508  + len8
11509  + len9
11510  + len10
11511  + len11
11512  + len12 );
11513  char* res = new char[ len + 1];
11514  size_t offset = 0;
11528  assert(offset == len);
11529  res[offset] = 0;
11530  return res;
11531 }
11532
11533
11534 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
11536 "<ServerManagerConfiguration>\n"
11537 " <!-- ******************************************************************** -->\n"
11538 " <ProxyGroup name=\"delivery_managers\">\n"
11539 " <DataDeliveryManagerProxy name=\"RenderViewDeliveryManager\" class=\"vtkPVRenderViewDataDeliveryManager\">\n"
11540 " </DataDeliveryManagerProxy>\n"
11541 " <DataDeliveryManagerProxy name=\"ContextViewDeliveryManager\" class=\"vtkPVContextViewDataDeliveryManager\">\n"
11542 " </DataDeliveryManagerProxy>\n"
11543 " </ProxyGroup>\n"
11544 "\n"
11545 " <ProxyGroup name=\"internal_views\">\n"
11546 " <!-- ================================================================== -->\n"
11547 "\n"
11548 " <Proxy name=\"ViewBase\"\n"
11549 " processes=\"client|renderserver|dataserver\">\n"
11550 " <DoubleVectorProperty command=\"SetViewTime\"\n"
11551 " default_values=\"none\"\n"
11552 " name=\"ViewTime\"\n"
11553 " number_of_elements=\"1\"\n"
11554 " panel_visibility=\"never\"\n"
11555 " state_ignored=\"1\">\n"
11556 " <DoubleRangeDomain name=\"range\" />\n"
11557 " <Documentation>The pipeline update time for this view. This gets passed\n"
11558 " to all representations added to this view.</Documentation>\n"
11559 " </DoubleVectorProperty>\n"
11560 " <DoubleVectorProperty command=\"SetCacheKey\"\n"
11561 " default_values=\"none\"\n"
11562 " name=\"CacheKey\"\n"
11563 " number_of_elements=\"1\"\n"
11564 " panel_visibility=\"never\"\n"
11565 " state_ignored=\"1\">\n"
11566 " <DoubleRangeDomain name=\"range\" />\n"
11567 " <Documentation>This is the cache key used to identify which cache\n"
11568 " entry to use for rendering when caching is enabled.</Documentation>\n"
11569 " </DoubleVectorProperty>\n"
11570 " <IntVectorProperty command=\"SetUseCache\"\n"
11571 " default_values=\"0\"\n"
11572 " name=\"UseCache\"\n"
11573 " panel_visibility=\"never\"\n"
11574 " number_of_elements=\"1\"\n"
11575 " state_ignored=\"1\">\n"
11576 " <BooleanDomain name=\"bool\" />\n"
11577 " <Documentation>Indicates whether to use cache for subsequent\n"
11578 " renderings.</Documentation>\n"
11579 " </IntVectorProperty>\n"
11580 " <IntVectorProperty command=\"SetPosition\"\n"
11581 " default_values=\"0 0\"\n"
11582 " name=\"ViewPosition\"\n"
11583 " panel_visibility=\"never\"\n"
11584 " number_of_elements=\"2\"\n"
11585 " is_internal=\"1\">\n"
11586 " <!-- ViewPosition is \"internal\" since vtkSMViewLayoutProxy typically\n"
11587 " sets it up. -->\n"
11588 " <Documentation>Set the position on this view in the multiview\n"
11589 " configuration.</Documentation>\n"
11590 " <Hints>\n"
11591 " <NoDefault />\n"
11592 " </Hints>\n"
11593 " </IntVectorProperty>\n"
11594 " <IntVectorProperty command=\"SetSize\"\n"
11595 " default_values=\"400 400\"\n"
11596 " ignore_synchronization=\"1\"\n"
11597 " name=\"ViewSize\"\n"
11598 " number_of_elements=\"2\"\n"
11599 " panel_visibility=\"never\"\n"
11600 " state_ignored=\"1\"\n"
11601 " no_custom_default=\"1\">\n"
11602 " <Hints>\n"
11603 " <NoDefault />\n"
11604 " </Hints>\n"
11605 " <Documentation>Set the size of this view in the multiview\n"
11606 " configuration.</Documentation>\n"
11607 " </IntVectorProperty>\n"
11608 " <ProxyProperty command=\"AddRepresentation\"\n"
11609 " name=\"Representations\"\n"
11610 " remove_command=\"RemoveRepresentation\"\n"
11611 " repeatable=\"1\">\n"
11612 " <Documentation>Representations in this view.</Documentation>\n"
11613 " </ProxyProperty>\n"
11614 " <IntVectorProperty command=\"SetPPI\"\n"
11615 " default_values=\"72\"\n"
11616 " name=\"PPI\"\n"
11617 " number_of_elements=\"1\"\n"
11618 " panel_visibility=\"never\">\n"
11619 " <Documentation>Set the screen ppi (pixels per inch). This is used\n"
11620 " when mapping font sizes in points to screen pixels.\n"
11621 " </Documentation>\n"
11622 " <Hints>\n"
11623 " <PropertyLink group=\"settings\"\n"
11624 " proxy=\"GeneralSettings\"\n"
11625 " property=\"ScreenPixelsPerInch\"/>\n"
11626 " </Hints>\n"
11627 " </IntVectorProperty>\n"
11628 " </Proxy>\n"
11629 "\n"
11630 " <!-- ================================================================== -->\n"
11631 " <Proxy base_proxygroup=\"internal_views\"\n"
11632 " base_proxyname=\"ViewBase\"\n"
11633 " class=\"vtkPVXYChartView\"\n"
11634 " name=\"XYChartViewTitle\"\n"
11635 " processes=\"client|renderserver|dataserver\">\n"
11636 " <Documentation>This is the base proxy for XY chart views.</Documentation>\n"
11637 "\n"
11638 " <SubProxy command=\"SetDeliveryManager\">\n"
11639 " <Proxy name=\"DeliveryManager\"\n"
11640 " proxygroup=\"delivery_managers\"\n"
11641 " proxyname=\"ContextViewDeliveryManager\"/>\n"
11642 " </SubProxy>\n"
11643 "\n"
11644 " <StringVectorProperty command=\"SetTitle\"\n"
11645 " name=\"ChartTitle\"\n"
11646 " number_of_elements=\"1\"\n"
11647 " default_values=\"\">\n"
11648 " <Documentation>\n"
11649 " Set the title to use for the chart. Use {time} to display the current time.\n"
11650 " </Documentation>\n"
11651 " <Hints>\n"
11652 " <PlaceholderText>Use {time} to display current time</PlaceholderText>\n"
11653 " </Hints>\n"
11654 " </StringVectorProperty>\n"
11655 " <IntVectorProperty command=\"SetTitleAlignment\"\n"
11656 " default_values=\"1\"\n"
11657 " name=\"ChartTitleAlignment\"\n"
11658 " number_of_elements=\"1\">\n"
11659 " <EnumerationDomain name=\"enum\">\n"
11660 " <Entry text=\"Left\"\n"
11661 " value=\"0\" />\n"
11662 " <Entry text=\"Center\"\n"
11663 " value=\"1\" />\n"
11664 " <Entry text=\"Right\"\n"
11665 " value=\"2\" />\n"
11666 " </EnumerationDomain>\n"
11667 " </IntVectorProperty>\n"
11668 " <StringVectorProperty command=\"SetTitleFontFamily\"\n"
11669 " default_values=\"Arial\"\n"
11670 " name=\"ChartTitleFontFamily\"\n"
11671 " number_of_elements=\"1\">\n"
11672 " <Documentation>Set the chart title font family.</Documentation>\n"
11673 " <StringListDomain name=\"list\">\n"
11674 " <String value=\"Arial\" />\n"
11675 " <String value=\"Courier\" />\n"
11676 " <String value=\"Times\" />\n"
11677 " <String value=\"File\" />\n"
11678 " </StringListDomain>\n"
11679 " </StringVectorProperty>\n"
11680 " <StringVectorProperty command=\"SetTitleFontFile\"\n"
11681 " name=\"ChartTitleFontFile\"\n"
11682 " number_of_elements=\"1\"\n"
11683 " default_values=\"\">\n"
11684 " <Documentation>Set the chart title font file.</Documentation>\n"
11685 " </StringVectorProperty>\n"
11686 " <IntVectorProperty command=\"SetTitleFontSize\"\n"
11687 " default_values=\"18\"\n"
11688 " name=\"ChartTitleFontSize\"\n"
11689 " number_of_elements=\"1\">\n"
11690 " <Documentation>Set the chart title font size.</Documentation>\n"
11691 " </IntVectorProperty>\n"
11692 " <IntVectorProperty command=\"SetTitleBold\"\n"
11693 " default_values=\"0\"\n"
11694 " name=\"ChartTitleBold\"\n"
11695 " number_of_elements=\"1\">\n"
11696 " <Documentation>Set the chart title bold.</Documentation>\n"
11697 " <BooleanDomain name=\"bool\" />\n"
11698 " </IntVectorProperty>\n"
11699 " <IntVectorProperty command=\"SetTitleItalic\"\n"
11700 " default_values=\"0\"\n"
11701 " name=\"ChartTitleItalic\"\n"
11702 " number_of_elements=\"1\">\n"
11703 " <Documentation>Set the chart title bold.</Documentation>\n"
11704 " <BooleanDomain name=\"bool\" />\n"
11705 " </IntVectorProperty>\n"
11706 " <DoubleVectorProperty command=\"SetTitleColor\"\n"
11707 " default_values=\"0 0 0\"\n"
11708 " name=\"ChartTitleColor\"\n"
11709 " number_of_elements=\"3\">\n"
11710 " <DoubleRangeDomain max=\"1\"\n"
11711 " min=\"0\"\n"
11712 " name=\"range\" />\n"
11713 " </DoubleVectorProperty>\n"
11714 " <PropertyGroup label=\"Title\">\n"
11715 " <Property name=\"ChartTitle\"/>\n"
11716 " </PropertyGroup>\n"
11717 " <PropertyGroup label=\"Chart Title Properties\"\n"
11718 " panel_widget=\"FontEditor\"\n"
11719 " panel_visibility=\"advanced\">\n"
11720 " <Property name=\"ChartTitleColor\" function=\"Color\"/>\n"
11721 " <Property name=\"ChartTitleFontFamily\" function=\"Family\"/>\n"
11722 " <Property name=\"ChartTitleFontFile\" function=\"File\"/>\n"
11723 " <Property name=\"ChartTitleBold\" function=\"Bold\" />\n"
11724 " <Property name=\"ChartTitleItalic\" function=\"Italics\"/>\n"
11725 " <Property name=\"ChartTitleFontSize\" function=\"Size\" />\n"
11726 " <Property name=\"ChartTitleAlignment\" function=\"Justification\" />\n"
11727 " </PropertyGroup>\n"
11728 " </Proxy>\n"
11729 " <!-- ================================================================== -->\n"
11730 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
11731 " base_proxyname=\"XYChartViewTitle\"\n"
11732 " name=\"XYChartViewBase\"\n"
11733 " processes=\"client|renderserver|dataserver\">\n"
11734 " <Documentation>This is the base proxy for XY chart views.</Documentation>\n"
11735 " <IntVectorProperty command=\"SetLegendVisibility\"\n"
11736 " default_values=\"1\"\n"
11737 " name=\"ShowLegend\"\n"
11738 " number_of_elements=\"1\">\n"
11739 " <BooleanDomain name=\"bool\" />\n"
11740 " </IntVectorProperty>\n"
11741 " <IntVectorProperty command=\"SetLegendLocation\"\n"
11742 " default_values=\"1\"\n"
11743 " name=\"LegendLocation\"\n"
11744 " number_of_elements=\"1\"\n"
11745 " panel_visibility=\"advanced\">\n"
11746 " <EnumerationDomain name=\"enum\">\n"
11747 " <Entry text=\"TopLeft\"\n"
11748 " value=\"0\" />\n"
11749 " <Entry text=\"TopRight\"\n"
11750 " value=\"1\" />\n"
11751 " <Entry text=\"BottomRight\"\n"
11752 " value=\"2\" />\n"
11753 " <Entry text=\"BottomLeft\"\n"
11754 " value=\"3\" />\n"
11755 " <Entry text=\"Left\"\n"
11756 " value=\"4\" />\n"
11757 " <Entry text=\"Top\"\n"
11758 " value=\"5\" />\n"
11759 " <Entry text=\"Right\"\n"
11760 " value=\"6\" />\n"
11761 " <Entry text=\"Bottom\"\n"
11762 " value=\"7\" />\n"
11763 " <Entry text=\"Custom\"\n"
11764 " value=\"8\" />\n"
11765 " </EnumerationDomain>\n"
11766 " </IntVectorProperty>\n"
11767 " <IntVectorProperty command=\"SetLegendSymbolWidth\"\n"
11768 " default_values=\"25\"\n"
11769 " name=\"LegendSymbolWidth\"\n"
11770 " number_of_elements=\"1\"\n"
11771 " panel_visibility=\"advanced\">\n"
11772 " <Documentation>Set the legend symbol width.</Documentation>\n"
11773 " </IntVectorProperty>\n"
11774 " <IntVectorProperty command=\"SetSortByXAxis\"\n"
11775 " default_values=\"0\"\n"
11776 " name=\"SortByXAxis\"\n"
11777 " label=\"Sort By X-Axis\"\n"
11778 " number_of_elements=\"1\">\n"
11779 " <BooleanDomain name=\"bool\" />\n"
11780 " <Documentation>Sort the chart data by the x-axis before deciding line plot connectivity.</Documentation>\n"
11781 " </IntVectorProperty>\n"
11782 " <IntVectorProperty command=\"SetLegendPosition\"\n"
11783 " default_values=\"0 0\"\n"
11784 " name=\"LegendPosition\"\n"
11785 " panel_visibility=\"default\"\n"
11786 " number_of_elements=\"2\">\n"
11787 " <Documentation>Set the legend position in the view for\n"
11788 " custom location.</Documentation>\n"
11789 " <Hints>\n"
11790 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
11791 " mode=\"visibility\"\n"
11792 " property=\"LegendLocation\"\n"
11793 " value=\"8\" />\n"
11794 " <!-- show this widget when LegendLocation==8 (ie.Custom) -->\n"
11795 " </Hints>\n"
11796 " </IntVectorProperty>\n"
11797 " <StringVectorProperty command=\"SetLegendFontFamily\"\n"
11798 " default_values=\"Arial\"\n"
11799 " name=\"LegendFontFamily\"\n"
11800 " number_of_elements=\"1\">\n"
11801 " <StringListDomain name=\"list\">\n"
11802 " <String value=\"Arial\" />\n"
11803 " <String value=\"Courier\" />\n"
11804 " <String value=\"Times\" />\n"
11805 " <String value=\"File\" />\n"
11806 " </StringListDomain>\n"
11807 " <Documentation>Set the legend font familyname.</Documentation>\n"
11808 " </StringVectorProperty>\n"
11809 " <StringVectorProperty command=\"SetLegendFontFile\"\n"
11810 " default_values=\"\"\n"
11811 " name=\"LegendFontFile\"\n"
11812 " number_of_elements=\"1\">\n"
11813 " <Documentation>Set the legend font file.</Documentation>\n"
11814 " </StringVectorProperty>\n"
11815 " <IntVectorProperty command=\"SetLegendFontSize\"\n"
11816 " default_values=\"12\"\n"
11817 " name=\"LegendFontSize\"\n"
11818 " number_of_elements=\"1\">\n"
11819 " <Documentation>Set the legend font size.</Documentation>\n"
11820 " </IntVectorProperty>\n"
11821 " <IntVectorProperty command=\"SetLegendBold\"\n"
11822 " default_values=\"0\"\n"
11823 " name=\"LegendBold\"\n"
11824 " number_of_elements=\"1\">\n"
11825 " <BooleanDomain name=\"bool\" />\n"
11826 " <Documentation>Set the legend font bold.</Documentation>\n"
11827 " </IntVectorProperty>\n"
11828 " <IntVectorProperty command=\"SetLegendItalic\"\n"
11829 " default_values=\"0\"\n"
11830 " name=\"LegendItalic\"\n"
11831 " number_of_elements=\"1\">\n"
11832 " <BooleanDomain name=\"bool\" />\n"
11833 " <Documentation>Set the legend font italic.</Documentation>\n"
11834 " </IntVectorProperty>\n"
11835 " <StringVectorProperty command=\"SetTooltipLabelFormat\"\n"
11836 " default_values=\"\"\n"
11837 " name=\"TooltipLabelFormat\"\n"
11838 " number_of_elements=\"1\"\n"
11839 " panel_visibility=\"advanced\">\n"
11840 " <Documentation>\n"
11841 " Set a printf-style string to build custom tooltip labels from.\n"
11842 " An empty string generates the default tooltip labels.\n"
11843 " The following case-sensitive format tags (without quotes) are recognized:\n"
11844 " '%x' The X value of the plot element\n"
11845 " '%y' The Y value of the plot element\n"
11846 " Other characters may be supported depending on plot type. Other characters or\n"
11847 " unrecognized format tags are printed in the tooltip label verbatim.\n"
11848 " </Documentation>\n"
11849 " </StringVectorProperty>\n"
11850 " <IntVectorProperty command=\"SetTooltipNotation\"\n"
11851 " default_values=\"0\"\n"
11852 " name=\"TooltipNotation\"\n"
11853 " number_of_elements=\"1\"\n"
11854 ;
11855
11856 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
11858 " panel_visibility=\"advanced\">\n"
11859 " <EnumerationDomain name=\"enum\">\n"
11860 " <Entry text=\"Mixed\"\n"
11861 " value=\"0\" />\n"
11862 " <Entry text=\"Scientific\"\n"
11863 " value=\"1\" />\n"
11864 " <Entry text=\"Fixed\"\n"
11865 " value=\"2\" />\n"
11866 " </EnumerationDomain>\n"
11867 " </IntVectorProperty>\n"
11868 " <IntVectorProperty command=\"SetTooltipPrecision\"\n"
11869 " default_values=\"6\"\n"
11870 " name=\"TooltipPrecision\"\n"
11871 " number_of_elements=\"1\"\n"
11872 " panel_visibility=\"advanced\">\n"
11873 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
11874 " </IntVectorProperty>\n"
11875 " <IntVectorProperty name=\"HideTimeMarker\"\n"
11876 " command=\"SetHideTimeMarker\"\n"
11877 " number_of_elements=\"1\"\n"
11878 " default_values=\"0\"\n"
11879 " panel_visibility=\"advanced\">\n"
11880 " <Documentation>\n"
11881 " Hide the marker that is used to mark the current time, when one of the axes is\n"
11882 " plotting time.\n"
11883 " </Documentation>\n"
11884 " <BooleanDomain name=\"bool\" />\n"
11885 " </IntVectorProperty>\n"
11886 "\n"
11887 " <PropertyGroup label=\"Legend Properties\"\n"
11888 " panel_widget=\"FontEditor\"\n"
11889 " panel_visibility=\"advanced\">\n"
11890 " <Property name=\"LegendFontFamily\" function=\"Family\"/>\n"
11891 " <Property name=\"LegendFontFile\" function=\"File\"/>\n"
11892 " <Property name=\"LegendBold\" function=\"Bold\" />\n"
11893 " <Property name=\"LegendItalic\" function=\"Italics\"/>\n"
11894 " <Property name=\"LegendFontSize\" function=\"Size\" />\n"
11895 " <!-- next properties are not available -->\n"
11896 " <!-- <Property name=\"LegendColor\" function=\"Color\"/> -->\n"
11897 " <!-- <Property name=\"LegendOpacity\" function=\"Opacity\"/> -->\n"
11898 " <!-- <Property name=\"LegendShadow\" function=\"Shadow\" /> -->\n"
11899 " </PropertyGroup>\n"
11900 "\n"
11901 " <PropertyGroup label=\"Annotation\">\n"
11902 " <Property name=\"ShowLegend\"/>\n"
11903 " <Property name=\"LegendLocation\"/>\n"
11904 " <Property name=\"LegendPosition\"/>\n"
11905 " <Property name=\"HideTimeMarker\"/>\n"
11906 " <Property name=\"LegendSymbolWidth\"/>\n"
11907 " </PropertyGroup>\n"
11908 " <PropertyGroup label=\"Tooltip\"\n"
11909 " panel_visibility=\"advanced\">\n"
11910 " <Property name=\"TooltipLabelFormat\"/>\n"
11911 " <Property name=\"TooltipNotation\"/>\n"
11912 " <Property name=\"TooltipPrecision\"/>\n"
11913 " </PropertyGroup>\n"
11914 "\n"
11915 " <!-- left axis -->\n"
11916 " <!-- title -->\n"
11917 " <StringVectorProperty command=\"SetLeftAxisTitle\"\n"
11918 " name=\"LeftAxisTitle\"\n"
11919 " number_of_elements=\"1\"\n"
11920 " default_values=\"\"/>\n"
11921 " <IntVectorProperty command=\"SetLeftGridVisibility\"\n"
11922 " default_values=\"1\"\n"
11923 " panel_visibility=\"advanced\"\n"
11924 " name=\"ShowLeftAxisGrid\"\n"
11925 " number_of_elements=\"1\">\n"
11926 " <BooleanDomain name=\"bool\" />\n"
11927 " </IntVectorProperty>\n"
11928 " <DoubleVectorProperty command=\"SetLeftGridColor\"\n"
11929 " default_values=\"0.95 0.95 0.95\"\n"
11930 " name=\"LeftAxisGridColor\"\n"
11931 " panel_visibility=\"advanced\"\n"
11932 " panel_widget=\"color_selector\"\n"
11933 " number_of_elements=\"3\">\n"
11934 " <DoubleRangeDomain max=\"1\"\n"
11935 " min=\"0\"\n"
11936 " name=\"range\" />\n"
11937 " </DoubleVectorProperty>\n"
11938 " <DoubleVectorProperty command=\"SetLeftAxisColor\"\n"
11939 " default_values=\"0 0 0\"\n"
11940 " name=\"LeftAxisColor\"\n"
11941 " panel_visibility=\"advanced\"\n"
11942 " panel_widget=\"color_selector\"\n"
11943 " number_of_elements=\"3\">\n"
11944 " <DoubleRangeDomain max=\"1\"\n"
11945 " min=\"0\"\n"
11946 " name=\"range\" />\n"
11947 " </DoubleVectorProperty>\n"
11948 " <StringVectorProperty command=\"SetLeftAxisTitleFontFamily\"\n"
11949 " default_values=\"Arial\"\n"
11950 " name=\"LeftAxisTitleFontFamily\"\n"
11951 " number_of_elements=\"1\">\n"
11952 " <StringListDomain name=\"list\">\n"
11953 " <String value=\"Arial\" />\n"
11954 " <String value=\"Courier\" />\n"
11955 " <String value=\"Times\" />\n"
11956 " <String value=\"File\" />\n"
11957 " </StringListDomain>\n"
11958 " <Documentation>Set the axis title font familyname.</Documentation>\n"
11959 " </StringVectorProperty>\n"
11960 " <StringVectorProperty command=\"SetLeftAxisTitleFontFile\"\n"
11961 " name=\"LeftAxisTitleFontFile\"\n"
11962 " number_of_elements=\"1\"\n"
11963 " default_values=\"\">\n"
11964 " <Documentation>Set the axis title font file.</Documentation>\n"
11965 " </StringVectorProperty>\n"
11966 " <IntVectorProperty command=\"SetLeftAxisTitleFontSize\"\n"
11967 " default_values=\"18\"\n"
11968 " name=\"LeftAxisTitleFontSize\"\n"
11969 " number_of_elements=\"1\">\n"
11970 " <Documentation>Set the axis title font size.</Documentation>\n"
11971 " </IntVectorProperty>\n"
11972 " <IntVectorProperty command=\"SetLeftAxisTitleBold\"\n"
11973 " default_values=\"1\"\n"
11974 " name=\"LeftAxisTitleBold\"\n"
11975 " number_of_elements=\"1\">\n"
11976 " <BooleanDomain name=\"bool\" />\n"
11977 " <Documentation>Set the axis title font bold.</Documentation>\n"
11978 " </IntVectorProperty>\n"
11979 " <IntVectorProperty command=\"SetLeftAxisTitleItalic\"\n"
11980 " default_values=\"0\"\n"
11981 " name=\"LeftAxisTitleItalic\"\n"
11982 " number_of_elements=\"1\">\n"
11983 " <BooleanDomain name=\"bool\" />\n"
11984 " <Documentation>Set the axis title font italic.</Documentation>\n"
11985 " </IntVectorProperty>\n"
11986 " <DoubleVectorProperty command=\"SetLeftAxisTitleColor\"\n"
11987 " default_values=\"0 0 0\"\n"
11988 " name=\"LeftAxisTitleColor\"\n"
11989 " number_of_elements=\"3\">\n"
11990 " <DoubleRangeDomain max=\"1\"\n"
11991 " min=\"0\"\n"
11992 " name=\"range\" />\n"
11993 " </DoubleVectorProperty>\n"
11994 "\n"
11995 " <!-- range -->\n"
11996 " <IntVectorProperty command=\"SetLeftAxisLogScale\"\n"
11997 " default_values=\"0\"\n"
11998 " name=\"LeftAxisLogScale\"\n"
11999 " number_of_elements=\"1\">\n"
12000 " <BooleanDomain name=\"bool\" />\n"
12001 " </IntVectorProperty>\n"
12002 " <IntVectorProperty command=\"SetLeftAxisUseCustomRange\"\n"
12003 " default_values=\"0\"\n"
12004 " name=\"LeftAxisUseCustomRange\"\n"
12005 " number_of_elements=\"1\">\n"
12006 " <BooleanDomain name=\"bool\" />\n"
12007 " <Documentation>\n"
12008 " Specify whether to use the axis range specified or whether the view\n"
12009 " should compute the ranges automatically based on the data being shown.\n"
12010 " The ranges specified by ...AxisRange are only respected when the\n"
12011 " corresponding flag in this property is set to 1.\n"
12012 " </Documentation>\n"
12013 " </IntVectorProperty>\n"
12014 " <DoubleVectorProperty command=\"SetLeftAxisRangeMinimum\"\n"
12015 " default_values=\"0\"\n"
12016 " name=\"LeftAxisRangeMinimum\"\n"
12017 " number_of_elements=\"1\">\n"
12018 " <Documentation>Set the axis range minimum for the Left axis.\n"
12019 " </Documentation>\n"
12020 " <Hints>\n"
12021 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12022 " <Property name=\"LeftAxisUseCustomRange\"\n"
12023 " function=\"boolean\" />\n"
12024 " </PropertyWidgetDecorator>\n"
12025 " </Hints>\n"
12026 " </DoubleVectorProperty>\n"
12027 " <DoubleVectorProperty command=\"SetLeftAxisRangeMaximum\"\n"
12028 " default_values=\"1\"\n"
12029 " name=\"LeftAxisRangeMaximum\"\n"
12030 " number_of_elements=\"1\">\n"
12031 " <Documentation>Set the axis range maximum for the Left axis.\n"
12032 " </Documentation>\n"
12033 " <Hints>\n"
12034 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12035 " <Property name=\"LeftAxisUseCustomRange\"\n"
12036 " function=\"boolean\" />\n"
12037 " </PropertyWidgetDecorator>\n"
12038 " </Hints>\n"
12039 " </DoubleVectorProperty>\n"
12040 "\n"
12041 " <!-- labels -->\n"
12042 " <IntVectorProperty command=\"SetLeftAxisLabelVisibility\"\n"
12043 " default_values=\"1\"\n"
12044 " name=\"ShowLeftAxisLabels\"\n"
12045 " panel_visibility=\"advanced\"\n"
12046 " number_of_elements=\"1\">\n"
12047 " <BooleanDomain name=\"bool\" />\n"
12048 " </IntVectorProperty>\n"
12049 " <IntVectorProperty command=\"SetLeftAxisLabelNotation\"\n"
12050 " default_values=\"0\"\n"
12051 " panel_visibility=\"advanced\"\n"
12052 " name=\"LeftAxisLabelNotation\"\n"
12053 " number_of_elements=\"1\">\n"
12054 " <EnumerationDomain name=\"enum\">\n"
12055 " <Entry text=\"Mixed\"\n"
12056 " value=\"0\" />\n"
12057 " <Entry text=\"Scientific\"\n"
12058 " value=\"1\" />\n"
12059 " <Entry text=\"Fixed\"\n"
12060 " value=\"2\" />\n"
12061 " </EnumerationDomain>\n"
12062 " </IntVectorProperty>\n"
12063 " <IntVectorProperty command=\"SetLeftAxisLabelPrecision\"\n"
12064 " default_values=\"2\"\n"
12065 " panel_visibility=\"advanced\"\n"
12066 " name=\"LeftAxisLabelPrecision\"\n"
12067 " number_of_elements=\"1\">\n"
12068 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
12069 " </IntVectorProperty>\n"
12070 " <IntVectorProperty command=\"SetLeftAxisUseCustomLabels\"\n"
12071 " default_values=\"0\"\n"
12072 " panel_visibility=\"advanced\"\n"
12073 " name=\"LeftAxisUseCustomLabels\"\n"
12074 " number_of_elements=\"1\">\n"
12075 " <BooleanDomain name=\"bool\" />\n"
12076 " <Documentation>\n"
12077 " Specify whether to use custom labels for each of the axis. Labels\n"
12078 " specified by ...AxisLabels etc. are used only when\n"
12079 " the corresponding AxisUseCustomLabels flag is set to 1.\n"
12080 " </Documentation>\n"
12081 " </IntVectorProperty>\n"
12082 "\n"
12083 " <StringVectorProperty name=\"LeftAxisLabels\"\n"
12084 " command=\"SetLeftAxisLabels\"\n"
12085 " panel_visibility=\"advanced\"\n"
12086 " animateable=\"1\"\n"
12087 " number_of_elements=\"0\"\n"
12088 " number_of_elements_per_command=\"2\"\n"
12089 " repeat_command=\"1\"\n"
12090 " use_index=\"1\"\n"
12091 " set_number_command=\"SetLeftAxisLabelsNumber\">\n"
12092 " <Hints>\n"
12093 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12094 " <Property name=\"LeftAxisUseCustomLabels\"\n"
12095 " function=\"boolean\" />\n"
12096 " </PropertyWidgetDecorator>\n"
12097 " </Hints>\n"
12098 " <Documentation>\n"
12099 " Specify list of ticks and the associated labels to display. If the label is empty,\n"
12100 " the value of the tick will be used for display.\n"
12101 " </Documentation>\n"
12102 " </StringVectorProperty>\n"
12103 "\n"
12104 " <StringVectorProperty command=\"SetLeftAxisLabelFontFamily\"\n"
12105 " default_values=\"Arial\"\n"
12106 " name=\"LeftAxisLabelFontFamily\"\n"
12107 " number_of_elements=\"1\">\n"
12108 " <StringListDomain name=\"list\">\n"
12109 " <String value=\"Arial\" />\n"
12110 " <String value=\"Courier\" />\n"
12111 " <String value=\"Times\" />\n"
12112 " <String value=\"File\" />\n"
12113 " </StringListDomain>\n"
12114 " <Documentation>Set the axis title font familyname.</Documentation>\n"
12115 " </StringVectorProperty>\n"
12116 " <StringVectorProperty command=\"SetLeftAxisLabelFontFile\"\n"
12117 " name=\"LeftAxisLabelFontFile\"\n"
12118 " number_of_elements=\"1\"\n"
12119 " default_values=\"\">\n"
12120 " <Documentation>Set the axis title font file.</Documentation>\n"
12121 " </StringVectorProperty>\n"
12122 " <IntVectorProperty command=\"SetLeftAxisLabelFontSize\"\n"
12123 " default_values=\"12\"\n"
12124 " name=\"LeftAxisLabelFontSize\"\n"
12125 " number_of_elements=\"1\">\n"
12126 " <Documentation>Set the axis title font size.</Documentation>\n"
12127 " </IntVectorProperty>\n"
12128 " <IntVectorProperty command=\"SetLeftAxisLabelBold\"\n"
12129 " default_values=\"0\"\n"
12130 " name=\"LeftAxisLabelBold\"\n"
12131 " number_of_elements=\"1\">\n"
12132 " <BooleanDomain name=\"bool\" />\n"
12133 " <Documentation>Set the axis title bold.</Documentation>\n"
12134 " </IntVectorProperty>\n"
12135 " <IntVectorProperty command=\"SetLeftAxisLabelItalic\"\n"
12136 " default_values=\"0\"\n"
12137 " name=\"LeftAxisLabelItalic\"\n"
12138 " number_of_elements=\"1\">\n"
12139 " <BooleanDomain name=\"bool\" />\n"
12140 " <Documentation>Set the axis title italic.</Documentation>\n"
12141 " </IntVectorProperty>\n"
12142 " <DoubleVectorProperty command=\"SetLeftAxisLabelColor\"\n"
12143 " default_values=\"0 0 0\"\n"
12144 " name=\"LeftAxisLabelColor\"\n"
12145 " number_of_elements=\"3\">\n"
12146 " <DoubleRangeDomain max=\"1\"\n"
12147 " min=\"0\"\n"
12148 " name=\"range\" />\n"
12149 " </DoubleVectorProperty>\n"
12150 "\n"
12151 " <PropertyGroup label=\"Left Axis\">\n"
12152 " <Property name=\"LeftAxisTitle\"/>\n"
12153 " <Property name=\"ShowLeftAxisGrid\"/>\n"
12154 " <Property name=\"LeftAxisGridColor\"/>\n"
12155 " <Property name=\"LeftAxisColor\"/>\n"
12156 " </PropertyGroup>\n"
12157 "\n"
12158 " <PropertyGroup label=\"Left Axis Title Properties\"\n"
12159 " panel_widget=\"FontEditor\"\n"
12160 " panel_visibility=\"advanced\">\n"
12161 " <Property name=\"LeftAxisTitleColor\" function=\"Color\"/>\n"
12162 " <Property name=\"LeftAxisTitleFontFamily\" function=\"Family\"/>\n"
12163 " <Property name=\"LeftAxisTitleFontFile\" function=\"File\"/>\n"
12164 " <Property name=\"LeftAxisTitleBold\" function=\"Bold\" />\n"
12165 " <Property name=\"LeftAxisTitleItalic\" function=\"Italics\"/>\n"
12166 " <Property name=\"LeftAxisTitleFontSize\" function=\"Size\" />\n"
12167 " <!-- next properties are not available -->\n"
12168 " <!-- <Property name=\"LeftAxisTitleOpacity\" function=\"Opacity\"/> -->\n"
12169 " <!-- <Property name=\"LeftAxisTitleShadow\" function=\"Shadow\" /> -->\n"
12170 " </PropertyGroup>\n"
12171 "\n"
12172 " <PropertyGroup label=\"Left Axis Range\">\n"
12173 " <Property name=\"LeftAxisLogScale\"/>\n"
12174 " <Property name=\"LeftAxisUseCustomRange\"/>\n"
12175 " <Property name=\"LeftAxisRangeMinimum\"/>\n"
12176 ;
12177
12178 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
12180 " <Property name=\"LeftAxisRangeMaximum\"/>\n"
12181 " </PropertyGroup>\n"
12182 "\n"
12183 " <PropertyGroup label=\"Left Axis Labels\">\n"
12184 " <Property name=\"ShowLeftAxisLabels\"/>\n"
12185 " <Property name=\"LeftAxisLabelNotation\"/>\n"
12186 " <Property name=\"LeftAxisLabelPrecision\"/>\n"
12187 " <Property name=\"LeftAxisUseCustomLabels\"/>\n"
12188 " <Property name=\"LeftAxisLabels\"/>\n"
12189 " </PropertyGroup>\n"
12190 "\n"
12191 " <PropertyGroup label=\"Left Axis Label Properties\"\n"
12192 " panel_widget=\"FontEditor\"\n"
12193 " panel_visibility=\"advanced\">\n"
12194 " <Property name=\"LeftAxisLabelColor\" function=\"Color\"/>\n"
12195 " <Property name=\"LeftAxisLabelFontFamily\" function=\"Family\"/>\n"
12196 " <Property name=\"LeftAxisLabelFontFile\" function=\"File\"/>\n"
12197 " <Property name=\"LeftAxisLabelBold\" function=\"Bold\" />\n"
12198 " <Property name=\"LeftAxisLabelItalic\" function=\"Italics\"/>\n"
12199 " <Property name=\"LeftAxisLabelFontSize\" function=\"Size\" />\n"
12200 " <!-- next properties are not available -->\n"
12201 " <!-- <Property name=\"LeftAxisLabelOpacity\" function=\"Opacity\"/> -->\n"
12202 " <!-- <Property name=\"LeftAxisLabelShadow\" function=\"Shadow\" /> -->\n"
12203 " </PropertyGroup>\n"
12204 " <!-- end left axis -->\n"
12205 "\n"
12206 " <!-- bottom axis -->\n"
12207 " <!-- title -->\n"
12208 " <StringVectorProperty command=\"SetBottomAxisTitle\"\n"
12209 " name=\"BottomAxisTitle\"\n"
12210 " number_of_elements=\"1\"\n"
12211 " default_values=\"\"/>\n"
12212 " <IntVectorProperty command=\"SetBottomGridVisibility\"\n"
12213 " default_values=\"1\"\n"
12214 " panel_visibility=\"advanced\"\n"
12215 " name=\"ShowBottomAxisGrid\"\n"
12216 " number_of_elements=\"1\">\n"
12217 " <BooleanDomain name=\"bool\" />\n"
12218 " </IntVectorProperty>\n"
12219 " <DoubleVectorProperty command=\"SetBottomGridColor\"\n"
12220 " default_values=\"0.95 0.95 0.95\"\n"
12221 " name=\"BottomAxisGridColor\"\n"
12222 " panel_visibility=\"advanced\"\n"
12223 " panel_widget=\"color_selector\"\n"
12224 " number_of_elements=\"3\">\n"
12225 " <DoubleRangeDomain max=\"1\"\n"
12226 " min=\"0\"\n"
12227 " name=\"range\" />\n"
12228 " </DoubleVectorProperty>\n"
12229 " <DoubleVectorProperty command=\"SetBottomAxisColor\"\n"
12230 " default_values=\"0 0 0\"\n"
12231 " name=\"BottomAxisColor\"\n"
12232 " panel_visibility=\"advanced\"\n"
12233 " panel_widget=\"color_selector\"\n"
12234 " number_of_elements=\"3\">\n"
12235 " <DoubleRangeDomain max=\"1\"\n"
12236 " min=\"0\"\n"
12237 " name=\"range\" />\n"
12238 " </DoubleVectorProperty>\n"
12239 " <StringVectorProperty command=\"SetBottomAxisTitleFontFamily\"\n"
12240 " default_values=\"Arial\"\n"
12241 " name=\"BottomAxisTitleFontFamily\"\n"
12242 " number_of_elements=\"1\">\n"
12243 " <StringListDomain name=\"list\">\n"
12244 " <String value=\"Arial\" />\n"
12245 " <String value=\"Courier\" />\n"
12246 " <String value=\"Times\" />\n"
12247 " <String value=\"File\" />\n"
12248 " </StringListDomain>\n"
12249 " <Documentation>Set the axis title font familyname.</Documentation>\n"
12250 " </StringVectorProperty>\n"
12251 " <StringVectorProperty command=\"SetBottomAxisTitleFontFile\"\n"
12252 " name=\"BottomAxisTitleFontFile\"\n"
12253 " number_of_elements=\"1\"\n"
12254 " default_values=\"\">\n"
12255 " <Documentation>Set the axis title font file.</Documentation>\n"
12256 " </StringVectorProperty>\n"
12257 " <IntVectorProperty command=\"SetBottomAxisTitleFontSize\"\n"
12258 " default_values=\"18\"\n"
12259 " name=\"BottomAxisTitleFontSize\"\n"
12260 " number_of_elements=\"1\">\n"
12261 " <Documentation>Set the axis title font size.</Documentation>\n"
12262 " </IntVectorProperty>\n"
12263 " <IntVectorProperty command=\"SetBottomAxisTitleBold\"\n"
12264 " default_values=\"1\"\n"
12265 " name=\"BottomAxisTitleBold\"\n"
12266 " number_of_elements=\"1\">\n"
12267 " <BooleanDomain name=\"bool\" />\n"
12268 " <Documentation>Set the axis title font bold.</Documentation>\n"
12269 " </IntVectorProperty>\n"
12270 " <IntVectorProperty command=\"SetBottomAxisTitleItalic\"\n"
12271 " default_values=\"0\"\n"
12272 " name=\"BottomAxisTitleItalic\"\n"
12273 " number_of_elements=\"1\">\n"
12274 " <BooleanDomain name=\"bool\" />\n"
12275 " <Documentation>Set the axis title font italic.</Documentation>\n"
12276 " </IntVectorProperty>\n"
12277 " <DoubleVectorProperty command=\"SetBottomAxisTitleColor\"\n"
12278 " default_values=\"0 0 0\"\n"
12279 " name=\"BottomAxisTitleColor\"\n"
12280 " number_of_elements=\"3\">\n"
12281 " <DoubleRangeDomain max=\"1\"\n"
12282 " min=\"0\"\n"
12283 " name=\"range\" />\n"
12284 " </DoubleVectorProperty>\n"
12285 "\n"
12286 " <!-- range -->\n"
12287 " <IntVectorProperty command=\"SetBottomAxisLogScale\"\n"
12288 " default_values=\"0\"\n"
12289 " name=\"BottomAxisLogScale\"\n"
12290 " number_of_elements=\"1\">\n"
12291 " <BooleanDomain name=\"bool\" />\n"
12292 " </IntVectorProperty>\n"
12293 " <IntVectorProperty command=\"SetBottomAxisUseCustomRange\"\n"
12294 " default_values=\"0\"\n"
12295 " name=\"BottomAxisUseCustomRange\"\n"
12296 " number_of_elements=\"1\">\n"
12297 " <BooleanDomain name=\"bool\" />\n"
12298 " <Documentation>\n"
12299 " Specify whether to use the axis range specified or whether the view\n"
12300 " should compute the ranges automatically based on the data being shown.\n"
12301 " The ranges specified by ...AxisRange are only respected when the\n"
12302 " corresponding flag in this property is set to 1.\n"
12303 " </Documentation>\n"
12304 " </IntVectorProperty>\n"
12305 " <DoubleVectorProperty command=\"SetBottomAxisRangeMinimum\"\n"
12306 " default_values=\"0\"\n"
12307 " name=\"BottomAxisRangeMinimum\"\n"
12308 " number_of_elements=\"1\">\n"
12309 " <Documentation>Set the axis range minimum for the Bottom axis.\n"
12310 " </Documentation>\n"
12311 " <Hints>\n"
12312 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12313 " <Property name=\"BottomAxisUseCustomRange\"\n"
12314 " function=\"boolean\" />\n"
12315 " </PropertyWidgetDecorator>\n"
12316 " </Hints>\n"
12317 " </DoubleVectorProperty>\n"
12318 " <DoubleVectorProperty command=\"SetBottomAxisRangeMaximum\"\n"
12319 " default_values=\"1\"\n"
12320 " name=\"BottomAxisRangeMaximum\"\n"
12321 " number_of_elements=\"1\">\n"
12322 " <Documentation>Set the axis range maximum for the Bottom axis.\n"
12323 " </Documentation>\n"
12324 " <Hints>\n"
12325 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12326 " <Property name=\"BottomAxisUseCustomRange\"\n"
12327 " function=\"boolean\" />\n"
12328 " </PropertyWidgetDecorator>\n"
12329 " </Hints>\n"
12330 " </DoubleVectorProperty>\n"
12331 "\n"
12332 " <!-- labels -->\n"
12333 " <IntVectorProperty command=\"SetBottomAxisLabelVisibility\"\n"
12334 " default_values=\"1\"\n"
12335 " name=\"ShowBottomAxisLabels\"\n"
12336 " panel_visibility=\"advanced\"\n"
12337 " number_of_elements=\"1\">\n"
12338 " <BooleanDomain name=\"bool\" />\n"
12339 " </IntVectorProperty>\n"
12340 " <IntVectorProperty command=\"SetBottomAxisLabelNotation\"\n"
12341 " default_values=\"0\"\n"
12342 " panel_visibility=\"advanced\"\n"
12343 " name=\"BottomAxisLabelNotation\"\n"
12344 " number_of_elements=\"1\">\n"
12345 " <EnumerationDomain name=\"enum\">\n"
12346 " <Entry text=\"Mixed\"\n"
12347 " value=\"0\" />\n"
12348 " <Entry text=\"Scientific\"\n"
12349 " value=\"1\" />\n"
12350 " <Entry text=\"Fixed\"\n"
12351 " value=\"2\" />\n"
12352 " </EnumerationDomain>\n"
12353 " </IntVectorProperty>\n"
12354 " <IntVectorProperty command=\"SetBottomAxisLabelPrecision\"\n"
12355 " default_values=\"2\"\n"
12356 " panel_visibility=\"advanced\"\n"
12357 " name=\"BottomAxisLabelPrecision\"\n"
12358 " number_of_elements=\"1\">\n"
12359 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
12360 " </IntVectorProperty>\n"
12361 " <IntVectorProperty command=\"SetBottomAxisUseCustomLabels\"\n"
12362 " default_values=\"0\"\n"
12363 " panel_visibility=\"advanced\"\n"
12364 " name=\"BottomAxisUseCustomLabels\"\n"
12365 " number_of_elements=\"1\">\n"
12366 " <BooleanDomain name=\"bool\" />\n"
12367 " <Documentation>\n"
12368 " Specify whether to use custom labels for each of the axis. Labels\n"
12369 " specified by ...AxisLabels etc. are used only when\n"
12370 " the corresponding AxisUseCustomLabels flag is set to 1.\n"
12371 " </Documentation>\n"
12372 " </IntVectorProperty>\n"
12373 " <StringVectorProperty command=\"SetBottomAxisLabels\"\n"
12374 " name=\"BottomAxisLabels\"\n"
12375 " panel_visibility=\"advanced\"\n"
12376 " animateable=\"1\"\n"
12377 " number_of_elements=\"0\"\n"
12378 " number_of_elements_per_command=\"2\"\n"
12379 " repeat_command=\"1\"\n"
12380 " use_index=\"1\"\n"
12381 " set_number_command=\"SetBottomAxisLabelsNumber\">\n"
12382 " <Hints>\n"
12383 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12384 " <Property name=\"BottomAxisUseCustomLabels\"\n"
12385 " function=\"boolean\" />\n"
12386 " </PropertyWidgetDecorator>\n"
12387 " </Hints>\n"
12388 " <Documentation>\n"
12389 " Specify list of ticks and the associated labels to display. If the label is empty,\n"
12390 " the value of the tick will be used for display.\n"
12391 " </Documentation>\n"
12392 " </StringVectorProperty>\n"
12393 " <StringVectorProperty command=\"SetBottomAxisLabelFontFamily\"\n"
12394 " default_values=\"Arial\"\n"
12395 " name=\"BottomAxisLabelFontFamily\"\n"
12396 " number_of_elements=\"1\">\n"
12397 " <StringListDomain name=\"list\">\n"
12398 " <String value=\"Arial\" />\n"
12399 " <String value=\"Courier\" />\n"
12400 " <String value=\"Times\" />\n"
12401 " <String value=\"File\" />\n"
12402 " </StringListDomain>\n"
12403 " <Documentation>Set the axis title font familyname.</Documentation>\n"
12404 " </StringVectorProperty>\n"
12405 " <StringVectorProperty command=\"SetBottomAxisLabelFontFile\"\n"
12406 " name=\"BottomAxisLabelFontFile\"\n"
12407 " number_of_elements=\"1\"\n"
12408 " default_values=\"\">\n"
12409 " <Documentation>Set the axis title font file.</Documentation>\n"
12410 " </StringVectorProperty>\n"
12411 " <IntVectorProperty command=\"SetBottomAxisLabelFontSize\"\n"
12412 " default_values=\"12\"\n"
12413 " name=\"BottomAxisLabelFontSize\"\n"
12414 " number_of_elements=\"1\">\n"
12415 " <Documentation>Set the axis title font size.</Documentation>\n"
12416 " </IntVectorProperty>\n"
12417 " <IntVectorProperty command=\"SetBottomAxisLabelBold\"\n"
12418 " default_values=\"0\"\n"
12419 " name=\"BottomAxisLabelBold\"\n"
12420 " number_of_elements=\"1\">\n"
12421 " <BooleanDomain name=\"bool\" />\n"
12422 " <Documentation>Set the axis title bold.</Documentation>\n"
12423 " </IntVectorProperty>\n"
12424 " <IntVectorProperty command=\"SetBottomAxisLabelItalic\"\n"
12425 " default_values=\"0\"\n"
12426 " name=\"BottomAxisLabelItalic\"\n"
12427 " number_of_elements=\"1\">\n"
12428 " <BooleanDomain name=\"bool\" />\n"
12429 " <Documentation>Set the axis title italic.</Documentation>\n"
12430 " </IntVectorProperty>\n"
12431 " <DoubleVectorProperty command=\"SetBottomAxisLabelColor\"\n"
12432 " default_values=\"0 0 0\"\n"
12433 " name=\"BottomAxisLabelColor\"\n"
12434 " number_of_elements=\"3\">\n"
12435 " <DoubleRangeDomain max=\"1\"\n"
12436 " min=\"0\"\n"
12437 " name=\"range\" />\n"
12438 " </DoubleVectorProperty>\n"
12439 "\n"
12440 " <PropertyGroup label=\"Bottom Axis\">\n"
12441 " <Property name=\"BottomAxisTitle\"/>\n"
12442 " <Property name=\"ShowBottomAxisGrid\"/>\n"
12443 " <Property name=\"BottomAxisGridColor\"/>\n"
12444 " <Property name=\"BottomAxisColor\"/>\n"
12445 " </PropertyGroup>\n"
12446 "\n"
12447 " <PropertyGroup label=\"Bottom Axis Title Properties\"\n"
12448 " panel_widget=\"FontEditor\"\n"
12449 " panel_visibility=\"advanced\">\n"
12450 " <Property name=\"BottomAxisTitleColor\" function=\"Color\"/>\n"
12451 " <Property name=\"BottomAxisTitleFontFamily\" function=\"Family\"/>\n"
12452 " <Property name=\"BottomAxisTitleFontFile\" function=\"File\"/>\n"
12453 " <Property name=\"BottomAxisTitleBold\" function=\"Bold\" />\n"
12454 " <Property name=\"BottomAxisTitleItalic\" function=\"Italics\"/>\n"
12455 " <Property name=\"BottomAxisTitleFontSize\" function=\"Size\" />\n"
12456 " <!-- next properties are not available -->\n"
12457 " <!-- <Property name=\"BottomAxisTitleOpacity\" function=\"Opacity\"/> -->\n"
12458 " <!-- <Property name=\"BottomAxisTitleShadow\" function=\"Shadow\" /> -->\n"
12459 " </PropertyGroup>\n"
12460 "\n"
12461 " <PropertyGroup label=\"Bottom Axis Range\">\n"
12462 " <Property name=\"BottomAxisLogScale\"/>\n"
12463 " <Property name=\"BottomAxisUseCustomRange\"/>\n"
12464 " <Property name=\"BottomAxisRangeMinimum\"/>\n"
12465 " <Property name=\"BottomAxisRangeMaximum\"/>\n"
12466 " </PropertyGroup>\n"
12467 "\n"
12468 " <PropertyGroup label=\"Bottom Axis Labels\">\n"
12469 " <Property name=\"ShowBottomAxisLabels\"/>\n"
12470 " <Property name=\"BottomAxisLabelNotation\"/>\n"
12471 " <Property name=\"BottomAxisLabelPrecision\"/>\n"
12472 " <Property name=\"BottomAxisUseCustomLabels\"/>\n"
12473 " <Property name=\"BottomAxisLabels\"/>\n"
12474 " </PropertyGroup>\n"
12475 "\n"
12476 " <PropertyGroup label=\"Bottom Axis Label Properties\"\n"
12477 " panel_widget=\"FontEditor\"\n"
12478 " panel_visibility=\"advanced\">\n"
12479 " <Property name=\"BottomAxisLabelColor\" function=\"Color\"/>\n"
12480 " <Property name=\"BottomAxisLabelFontFamily\" function=\"Family\"/>\n"
12481 " <Property name=\"BottomAxisLabelFontFile\" function=\"File\"/>\n"
12482 " <Property name=\"BottomAxisLabelBold\" function=\"Bold\" />\n"
12483 " <Property name=\"BottomAxisLabelItalic\" function=\"Italics\"/>\n"
12484 " <Property name=\"BottomAxisLabelFontSize\" function=\"Size\" />\n"
12485 " <!-- next properties are not available -->\n"
12486 " <!-- <Property name=\"BottomAxisLabelOpacity\" function=\"Opacity\"/> -->\n"
12487 ;
12488
12489 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
12491 " <!-- <Property name=\"BottomAxisLabelShadow\" function=\"Shadow\" /> -->\n"
12492 " </PropertyGroup>\n"
12493 " <!-- end bottom axis -->\n"
12494 " <ProxyProperty command=\"AddRepresentation\"\n"
12495 " is_internal=\"1\"\n"
12496 " name=\"HiddenRepresentations\"\n"
12497 " remove_command=\"RemoveRepresentation\"\n"
12498 " repeatable=\"1\">\n"
12499 " <Documentation>\n"
12500 " This property is meant for adding/removing\n"
12501 " representation secretly. e.g. 2D widgets etc. This property is not\n"
12502 " saved in states nor it recorded by undo-redo.\n"
12503 " </Documentation>\n"
12504 " </ProxyProperty>\n"
12505 "\n"
12506 " </ContextViewProxy>\n"
12507 " <!-- ================================================================== -->\n"
12508 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
12509 " base_proxyname=\"XYChartViewBase\"\n"
12510 " class=\"vtkPVXYChartView\"\n"
12511 " name=\"XYChartViewBase4Axes\"\n"
12512 " processes=\"client|renderserver|dataserver\">\n"
12513 "\n"
12514 " <Documentation>This is the base proxy for XY chart views with\n"
12515 " four axis: left, bottom, right and top</Documentation>\n"
12516 "\n"
12517 " <!-- right axis -->\n"
12518 " <!-- title -->\n"
12519 " <StringVectorProperty command=\"SetRightAxisTitle\"\n"
12520 " name=\"RightAxisTitle\"\n"
12521 " number_of_elements=\"1\"\n"
12522 " default_values=\"\"\n"
12523 " panel_visibility=\"advanced\" />\n"
12524 " <IntVectorProperty command=\"SetRightGridVisibility\"\n"
12525 " default_values=\"1\"\n"
12526 " panel_visibility=\"advanced\"\n"
12527 " name=\"ShowRightAxisGrid\"\n"
12528 " number_of_elements=\"1\">\n"
12529 " <BooleanDomain name=\"bool\" />\n"
12530 " </IntVectorProperty>\n"
12531 " <DoubleVectorProperty command=\"SetRightGridColor\"\n"
12532 " default_values=\"0.95 0.95 0.95\"\n"
12533 " name=\"RightAxisGridColor\"\n"
12534 " panel_visibility=\"advanced\"\n"
12535 " panel_widget=\"color_selector\"\n"
12536 " number_of_elements=\"3\">\n"
12537 " <DoubleRangeDomain max=\"1\"\n"
12538 " min=\"0\"\n"
12539 " name=\"range\" />\n"
12540 " </DoubleVectorProperty>\n"
12541 " <DoubleVectorProperty command=\"SetRightAxisColor\"\n"
12542 " default_values=\"0 0 0\"\n"
12543 " name=\"RightAxisColor\"\n"
12544 " panel_visibility=\"advanced\"\n"
12545 " panel_widget=\"color_selector\"\n"
12546 " number_of_elements=\"3\">\n"
12547 " <DoubleRangeDomain max=\"1\"\n"
12548 " min=\"0\"\n"
12549 " name=\"range\" />\n"
12550 " </DoubleVectorProperty>\n"
12551 " <StringVectorProperty command=\"SetRightAxisTitleFontFamily\"\n"
12552 " default_values=\"Arial\"\n"
12553 " name=\"RightAxisTitleFontFamily\"\n"
12554 " number_of_elements=\"1\">\n"
12555 " <StringListDomain name=\"list\">\n"
12556 " <String value=\"Arial\" />\n"
12557 " <String value=\"Courier\" />\n"
12558 " <String value=\"Times\" />\n"
12559 " <String value=\"File\" />\n"
12560 " </StringListDomain>\n"
12561 " <Documentation>Set the axis title font familyname.</Documentation>\n"
12562 " </StringVectorProperty>\n"
12563 " <StringVectorProperty command=\"SetRightAxisTitleFontFile\"\n"
12564 " default_values=\"\"\n"
12565 " name=\"RightAxisTitleFontFile\"\n"
12566 " number_of_elements=\"1\">\n"
12567 " <Documentation>Set the axis title font file.</Documentation>\n"
12568 " </StringVectorProperty>\n"
12569 " <IntVectorProperty command=\"SetRightAxisTitleFontSize\"\n"
12570 " default_values=\"18\"\n"
12571 " name=\"RightAxisTitleFontSize\"\n"
12572 " number_of_elements=\"1\">\n"
12573 " <Documentation>Set the axis title font size.</Documentation>\n"
12574 " </IntVectorProperty>\n"
12575 " <IntVectorProperty command=\"SetRightAxisTitleBold\"\n"
12576 " default_values=\"1\"\n"
12577 " name=\"RightAxisTitleBold\"\n"
12578 " number_of_elements=\"1\">\n"
12579 " <BooleanDomain name=\"bool\" />\n"
12580 " <Documentation>Set the axis title font bold.</Documentation>\n"
12581 " </IntVectorProperty>\n"
12582 " <IntVectorProperty command=\"SetRightAxisTitleItalic\"\n"
12583 " default_values=\"0\"\n"
12584 " name=\"RightAxisTitleItalic\"\n"
12585 " number_of_elements=\"1\">\n"
12586 " <BooleanDomain name=\"bool\" />\n"
12587 " <Documentation>Set the axis title font italic.</Documentation>\n"
12588 " </IntVectorProperty>\n"
12589 " <DoubleVectorProperty command=\"SetRightAxisTitleColor\"\n"
12590 " default_values=\"0 0 0\"\n"
12591 " name=\"RightAxisTitleColor\"\n"
12592 " number_of_elements=\"3\">\n"
12593 " <DoubleRangeDomain max=\"1\"\n"
12594 " min=\"0\"\n"
12595 " name=\"range\" />\n"
12596 " </DoubleVectorProperty>\n"
12597 "\n"
12598 " <!-- range -->\n"
12599 " <IntVectorProperty command=\"SetRightAxisLogScale\"\n"
12600 " default_values=\"0\"\n"
12601 " name=\"RightAxisLogScale\"\n"
12602 " number_of_elements=\"1\"\n"
12603 " panel_visibility=\"advanced\">\n"
12604 " <BooleanDomain name=\"bool\" />\n"
12605 " </IntVectorProperty>\n"
12606 " <IntVectorProperty command=\"SetRightAxisUseCustomRange\"\n"
12607 " default_values=\"0\"\n"
12608 " name=\"RightAxisUseCustomRange\"\n"
12609 " number_of_elements=\"1\"\n"
12610 " panel_visibility=\"advanced\">\n"
12611 " <BooleanDomain name=\"bool\" />\n"
12612 " <Documentation>\n"
12613 " Specify whether to use the axis range specified or whether the view\n"
12614 " should compute the ranges automatically based on the data being shown.\n"
12615 " The ranges specified by ...AxisRange are only respected when the\n"
12616 " corresponding flag in this property is set to 1.\n"
12617 " </Documentation>\n"
12618 " </IntVectorProperty>\n"
12619 " <DoubleVectorProperty command=\"SetRightAxisRangeMinimum\"\n"
12620 " default_values=\"0\"\n"
12621 " name=\"RightAxisRangeMinimum\"\n"
12622 " number_of_elements=\"1\"\n"
12623 " panel_visibility=\"advanced\">\n"
12624 " <Documentation>Set the axis range minimum for the Right axis.\n"
12625 " </Documentation>\n"
12626 " <Hints>\n"
12627 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12628 " <Property name=\"RightAxisUseCustomRange\"\n"
12629 " function=\"boolean\" />\n"
12630 " </PropertyWidgetDecorator>\n"
12631 " </Hints>\n"
12632 " </DoubleVectorProperty>\n"
12633 " <DoubleVectorProperty command=\"SetRightAxisRangeMaximum\"\n"
12634 " default_values=\"1\"\n"
12635 " name=\"RightAxisRangeMaximum\"\n"
12636 " number_of_elements=\"1\"\n"
12637 " panel_visibility=\"advanced\">\n"
12638 " <Documentation>Set the axis range maximum for the Right axis.\n"
12639 " </Documentation>\n"
12640 " <Hints>\n"
12641 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12642 " <Property name=\"RightAxisUseCustomRange\"\n"
12643 " function=\"boolean\" />\n"
12644 " </PropertyWidgetDecorator>\n"
12645 " </Hints>\n"
12646 " </DoubleVectorProperty>\n"
12647 "\n"
12648 " <!-- labels -->\n"
12649 " <IntVectorProperty command=\"SetRightAxisLabelVisibility\"\n"
12650 " default_values=\"1\"\n"
12651 " name=\"ShowRightAxisLabels\"\n"
12652 " panel_visibility=\"advanced\"\n"
12653 " number_of_elements=\"1\">\n"
12654 " <BooleanDomain name=\"bool\" />\n"
12655 " </IntVectorProperty>\n"
12656 " <IntVectorProperty command=\"SetRightAxisLabelNotation\"\n"
12657 " default_values=\"0\"\n"
12658 " panel_visibility=\"advanced\"\n"
12659 " name=\"RightAxisLabelNotation\"\n"
12660 " number_of_elements=\"1\">\n"
12661 " <EnumerationDomain name=\"enum\">\n"
12662 " <Entry text=\"Mixed\"\n"
12663 " value=\"0\" />\n"
12664 " <Entry text=\"Scientific\"\n"
12665 " value=\"1\" />\n"
12666 " <Entry text=\"Fixed\"\n"
12667 " value=\"2\" />\n"
12668 " </EnumerationDomain>\n"
12669 " </IntVectorProperty>\n"
12670 " <IntVectorProperty command=\"SetRightAxisLabelPrecision\"\n"
12671 " default_values=\"2\"\n"
12672 " panel_visibility=\"advanced\"\n"
12673 " name=\"RightAxisLabelPrecision\"\n"
12674 " number_of_elements=\"1\">\n"
12675 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
12676 " </IntVectorProperty>\n"
12677 " <IntVectorProperty command=\"SetRightAxisUseCustomLabels\"\n"
12678 " default_values=\"0\"\n"
12679 " panel_visibility=\"advanced\"\n"
12680 " name=\"RightAxisUseCustomLabels\"\n"
12681 " number_of_elements=\"1\">\n"
12682 " <BooleanDomain name=\"bool\" />\n"
12683 " <Documentation>\n"
12684 " Specify whether to use custom labels for each of the axis. Labels\n"
12685 " specified by ...AxisLabels etc. are used only when\n"
12686 " the corresponding AxisUseCustomLabels flag is set to 1.\n"
12687 " </Documentation>\n"
12688 " </IntVectorProperty>\n"
12689 " <StringVectorProperty command=\"SetRightAxisLabels\"\n"
12690 " name=\"RightAxisLabels\"\n"
12691 " panel_visibility=\"advanced\"\n"
12692 " animateable=\"1\"\n"
12693 " number_of_elements=\"0\"\n"
12694 " number_of_elements_per_command=\"2\"\n"
12695 " repeat_command=\"1\"\n"
12696 " use_index=\"1\"\n"
12697 " set_number_command=\"SetRightAxisLabelsNumber\">\n"
12698 " <Hints>\n"
12699 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12700 " <Property name=\"RightAxisUseCustomLabels\"\n"
12701 " function=\"boolean\" />\n"
12702 " </PropertyWidgetDecorator>\n"
12703 " </Hints>\n"
12704 " <Documentation>\n"
12705 " Specify list of ticks and the associated labels to display. If the label is empty,\n"
12706 " the value of the tick will be used for display.\n"
12707 " </Documentation>\n"
12708 " </StringVectorProperty>\n"
12709 " <StringVectorProperty command=\"SetRightAxisLabelFontFamily\"\n"
12710 " default_values=\"Arial\"\n"
12711 " name=\"RightAxisLabelFontFamily\"\n"
12712 " number_of_elements=\"1\">\n"
12713 " <StringListDomain name=\"list\">\n"
12714 " <String value=\"Arial\" />\n"
12715 " <String value=\"Courier\" />\n"
12716 " <String value=\"Times\" />\n"
12717 " <String value=\"File\" />\n"
12718 " </StringListDomain>\n"
12719 " <Documentation>Set the axis title font familyname.</Documentation>\n"
12720 " </StringVectorProperty>\n"
12721 " <StringVectorProperty command=\"SetRightAxisLabelFontFile\"\n"
12722 " name=\"RightAxisLabelFontFile\"\n"
12723 " number_of_elements=\"1\"\n"
12724 " default_values=\"\">\n"
12725 " <Documentation>Set the axis title font file.</Documentation>\n"
12726 " </StringVectorProperty>\n"
12727 " <IntVectorProperty command=\"SetRightAxisLabelFontSize\"\n"
12728 " default_values=\"12\"\n"
12729 " name=\"RightAxisLabelFontSize\"\n"
12730 " number_of_elements=\"1\">\n"
12731 " <Documentation>Set the axis title font size.</Documentation>\n"
12732 " </IntVectorProperty>\n"
12733 " <IntVectorProperty command=\"SetRightAxisLabelBold\"\n"
12734 " default_values=\"0\"\n"
12735 " name=\"RightAxisLabelBold\"\n"
12736 " number_of_elements=\"1\">\n"
12737 " <BooleanDomain name=\"bool\" />\n"
12738 " <Documentation>Set the axis title bold.</Documentation>\n"
12739 " </IntVectorProperty>\n"
12740 " <IntVectorProperty command=\"SetRightAxisLabelItalic\"\n"
12741 " default_values=\"0\"\n"
12742 " name=\"RightAxisLabelItalic\"\n"
12743 " number_of_elements=\"1\">\n"
12744 " <BooleanDomain name=\"bool\" />\n"
12745 " <Documentation>Set the axis title italic.</Documentation>\n"
12746 " </IntVectorProperty>\n"
12747 " <DoubleVectorProperty command=\"SetRightAxisLabelColor\"\n"
12748 " default_values=\"0 0 0\"\n"
12749 " name=\"RightAxisLabelColor\"\n"
12750 " number_of_elements=\"3\">\n"
12751 " <DoubleRangeDomain max=\"1\"\n"
12752 " min=\"0\"\n"
12753 " name=\"range\" />\n"
12754 " </DoubleVectorProperty>\n"
12755 "\n"
12756 " <PropertyGroup label=\"Right Axis\">\n"
12757 " <Property name=\"RightAxisTitle\"/>\n"
12758 " <Property name=\"ShowRightAxisGrid\"/>\n"
12759 " <Property name=\"RightAxisGridColor\"/>\n"
12760 " <Property name=\"RightAxisColor\"/>\n"
12761 " </PropertyGroup>\n"
12762 "\n"
12763 " <PropertyGroup label=\"Right Axis Title Properties\"\n"
12764 " panel_widget=\"FontEditor\"\n"
12765 " panel_visibility=\"advanced\">\n"
12766 " <Property name=\"RightAxisTitleColor\" function=\"Color\"/>\n"
12767 " <Property name=\"RightAxisTitleFontFamily\" function=\"Family\"/>\n"
12768 " <Property name=\"RightAxisTitleFontFile\" function=\"File\"/>\n"
12769 " <Property name=\"RightAxisTitleBold\" function=\"Bold\" />\n"
12770 " <Property name=\"RightAxisTitleItalic\" function=\"Italics\"/>\n"
12771 " <Property name=\"RightAxisTitleFontSize\" function=\"Size\" />\n"
12772 " <!-- next properties are not available -->\n"
12773 " <!-- <Property name=\"RightAxisTitleOpacity\" function=\"Opacity\"/> -->\n"
12774 " <!-- <Property name=\"RightAxisTitleShadow\" function=\"Shadow\" /> -->\n"
12775 " </PropertyGroup>\n"
12776 "\n"
12777 " <PropertyGroup label=\"Right Axis Range\">\n"
12778 " <Property name=\"RightAxisLogScale\"/>\n"
12779 " <Property name=\"RightAxisUseCustomRange\"/>\n"
12780 " <Property name=\"RightAxisRangeMinimum\"/>\n"
12781 " <Property name=\"RightAxisRangeMaximum\"/>\n"
12782 " </PropertyGroup>\n"
12783 "\n"
12784 " <PropertyGroup label=\"Right Axis Labels\">\n"
12785 " <Property name=\"ShowRightAxisLabels\"/>\n"
12786 " <Property name=\"RightAxisLabelNotation\"/>\n"
12787 " <Property name=\"RightAxisLabelPrecision\"/>\n"
12788 " <Property name=\"RightAxisUseCustomLabels\"/>\n"
12789 " <Property name=\"RightAxisLabels\"/>\n"
12790 " </PropertyGroup>\n"
12791 "\n"
12792 " <PropertyGroup label=\"Right Axis Label Properties\"\n"
12793 " panel_widget=\"FontEditor\"\n"
12794 " panel_visibility=\"advanced\">\n"
12795 " <Property name=\"RightAxisLabelColor\" function=\"Color\"/>\n"
12796 " <Property name=\"RightAxisLabelFontFamily\" function=\"Family\"/>\n"
12797 " <Property name=\"RightAxisLabelFontFile\" function=\"File\"/>\n"
12798 " <Property name=\"RightAxisLabelBold\" function=\"Bold\" />\n"
12799 " <Property name=\"RightAxisLabelItalic\" function=\"Italics\"/>\n"
12800 " <Property name=\"RightAxisLabelFontSize\" function=\"Size\" />\n"
12801 ;
12802
12803 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
12805 " <!-- next properties are not available -->\n"
12806 " <!-- <Property name=\"RightAxisLabelOpacity\" function=\"Opacity\"/> -->\n"
12807 " <!-- <Property name=\"RightAxisLabelShadow\" function=\"Shadow\" /> -->\n"
12808 " </PropertyGroup>\n"
12809 " <!-- end right axis -->\n"
12810 "\n"
12811 " <!-- top axis -->\n"
12812 " <!-- title -->\n"
12813 " <StringVectorProperty command=\"SetTopAxisTitle\"\n"
12814 " name=\"TopAxisTitle\"\n"
12815 " number_of_elements=\"1\"\n"
12816 " default_values=\"\"\n"
12817 " panel_visibility=\"advanced\"/>\n"
12818 " <IntVectorProperty command=\"SetTopGridVisibility\"\n"
12819 " default_values=\"1\"\n"
12820 " panel_visibility=\"advanced\"\n"
12821 " name=\"ShowTopAxisGrid\"\n"
12822 " number_of_elements=\"1\">\n"
12823 " <BooleanDomain name=\"bool\" />\n"
12824 " </IntVectorProperty>\n"
12825 " <DoubleVectorProperty command=\"SetTopGridColor\"\n"
12826 " default_values=\"0.95 0.95 0.95\"\n"
12827 " name=\"TopAxisGridColor\"\n"
12828 " panel_visibility=\"advanced\"\n"
12829 " panel_widget=\"color_selector\"\n"
12830 " number_of_elements=\"3\">\n"
12831 " <DoubleRangeDomain max=\"1\"\n"
12832 " min=\"0\"\n"
12833 " name=\"range\" />\n"
12834 " </DoubleVectorProperty>\n"
12835 " <DoubleVectorProperty command=\"SetTopAxisColor\"\n"
12836 " default_values=\"0 0 0\"\n"
12837 " name=\"TopAxisColor\"\n"
12838 " panel_visibility=\"advanced\"\n"
12839 " panel_widget=\"color_selector\"\n"
12840 " number_of_elements=\"3\">\n"
12841 " <DoubleRangeDomain max=\"1\"\n"
12842 " min=\"0\"\n"
12843 " name=\"range\" />\n"
12844 " </DoubleVectorProperty>\n"
12845 " <StringVectorProperty command=\"SetTopAxisTitleFontFamily\"\n"
12846 " default_values=\"Arial\"\n"
12847 " name=\"TopAxisTitleFontFamily\"\n"
12848 " number_of_elements=\"1\">\n"
12849 " <StringListDomain name=\"list\">\n"
12850 " <String value=\"Arial\" />\n"
12851 " <String value=\"Courier\" />\n"
12852 " <String value=\"Times\" />\n"
12853 " <String value=\"File\" />\n"
12854 " </StringListDomain>\n"
12855 " <Documentation>Set the axis title font familyname.</Documentation>\n"
12856 " </StringVectorProperty>\n"
12857 " <StringVectorProperty command=\"SetTopAxisTitleFontFile\"\n"
12858 " name=\"TopAxisTitleFontFile\"\n"
12859 " number_of_elements=\"1\"\n"
12860 " default_values=\"\">\n"
12861 " <Documentation>Set the axis title font file.</Documentation>\n"
12862 " </StringVectorProperty>\n"
12863 " <IntVectorProperty command=\"SetTopAxisTitleFontSize\"\n"
12864 " default_values=\"18\"\n"
12865 " name=\"TopAxisTitleFontSize\"\n"
12866 " number_of_elements=\"1\">\n"
12867 " <Documentation>Set the axis title font size.</Documentation>\n"
12868 " </IntVectorProperty>\n"
12869 " <IntVectorProperty command=\"SetTopAxisTitleBold\"\n"
12870 " default_values=\"1\"\n"
12871 " name=\"TopAxisTitleBold\"\n"
12872 " number_of_elements=\"1\">\n"
12873 " <BooleanDomain name=\"bool\" />\n"
12874 " <Documentation>Set the axis title font bold.</Documentation>\n"
12875 " </IntVectorProperty>\n"
12876 " <IntVectorProperty command=\"SetTopAxisTitleItalic\"\n"
12877 " default_values=\"0\"\n"
12878 " name=\"TopAxisTitleItalic\"\n"
12879 " number_of_elements=\"1\">\n"
12880 " <BooleanDomain name=\"bool\" />\n"
12881 " <Documentation>Set the axis title font italic.</Documentation>\n"
12882 " </IntVectorProperty>\n"
12883 " <DoubleVectorProperty command=\"SetTopAxisTitleColor\"\n"
12884 " default_values=\"0 0 0\"\n"
12885 " name=\"TopAxisTitleColor\"\n"
12886 " number_of_elements=\"3\">\n"
12887 " <DoubleRangeDomain max=\"1\"\n"
12888 " min=\"0\"\n"
12889 " name=\"range\" />\n"
12890 " </DoubleVectorProperty>\n"
12891 "\n"
12892 " <!-- range -->\n"
12893 " <IntVectorProperty command=\"SetTopAxisLogScale\"\n"
12894 " default_values=\"0\"\n"
12895 " name=\"TopAxisLogScale\"\n"
12896 " number_of_elements=\"1\"\n"
12897 " panel_visibility=\"advanced\">\n"
12898 " <BooleanDomain name=\"bool\" />\n"
12899 " </IntVectorProperty>\n"
12900 " <IntVectorProperty command=\"SetTopAxisUseCustomRange\"\n"
12901 " default_values=\"0\"\n"
12902 " name=\"TopAxisUseCustomRange\"\n"
12903 " number_of_elements=\"1\"\n"
12904 " panel_visibility=\"advanced\">\n"
12905 " <BooleanDomain name=\"bool\" />\n"
12906 " <Documentation>\n"
12907 " Specify whether to use the axis range specified or whether the view\n"
12908 " should compute the ranges automatically based on the data being shown.\n"
12909 " The ranges specified by ...AxisRange, are only respected when the\n"
12910 " corresponding flag in this property is set to 1.\n"
12911 " </Documentation>\n"
12912 " </IntVectorProperty>\n"
12913 " <DoubleVectorProperty command=\"SetTopAxisRangeMinimum\"\n"
12914 " default_values=\"0\"\n"
12915 " name=\"TopAxisRangeMinimum\"\n"
12916 " number_of_elements=\"1\"\n"
12917 " panel_visibility=\"advanced\">\n"
12918 " <Documentation>Set the axis range minimum for the Top axis.\n"
12919 " </Documentation>\n"
12920 " <Hints>\n"
12921 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12922 " <Property name=\"TopAxisUseCustomRange\"\n"
12923 " function=\"boolean\" />\n"
12924 " </PropertyWidgetDecorator>\n"
12925 " </Hints>\n"
12926 " </DoubleVectorProperty>\n"
12927 " <DoubleVectorProperty command=\"SetTopAxisRangeMaximum\"\n"
12928 " default_values=\"1\"\n"
12929 " name=\"TopAxisRangeMaximum\"\n"
12930 " number_of_elements=\"1\"\n"
12931 " panel_visibility=\"advanced\">\n"
12932 " <Documentation>Set the axis range maximum for the Top axis.\n"
12933 " </Documentation>\n"
12934 " <Hints>\n"
12935 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12936 " <Property name=\"TopAxisUseCustomRange\"\n"
12937 " function=\"boolean\" />\n"
12938 " </PropertyWidgetDecorator>\n"
12939 " </Hints>\n"
12940 " </DoubleVectorProperty>\n"
12941 "\n"
12942 " <!-- labels -->\n"
12943 " <IntVectorProperty command=\"SetTopAxisLabelVisibility\"\n"
12944 " default_values=\"1\"\n"
12945 " name=\"ShowTopAxisLabels\"\n"
12946 " panel_visibility=\"advanced\"\n"
12947 " number_of_elements=\"1\">\n"
12948 " <BooleanDomain name=\"bool\" />\n"
12949 " </IntVectorProperty>\n"
12950 " <IntVectorProperty command=\"SetTopAxisLabelNotation\"\n"
12951 " default_values=\"0\"\n"
12952 " panel_visibility=\"advanced\"\n"
12953 " name=\"TopAxisLabelNotation\"\n"
12954 " number_of_elements=\"1\">\n"
12955 " <EnumerationDomain name=\"enum\">\n"
12956 " <Entry text=\"Mixed\"\n"
12957 " value=\"0\" />\n"
12958 " <Entry text=\"Scientific\"\n"
12959 " value=\"1\" />\n"
12960 " <Entry text=\"Fixed\"\n"
12961 " value=\"2\" />\n"
12962 " </EnumerationDomain>\n"
12963 " </IntVectorProperty>\n"
12964 " <IntVectorProperty command=\"SetTopAxisLabelPrecision\"\n"
12965 " default_values=\"2\"\n"
12966 " panel_visibility=\"advanced\"\n"
12967 " name=\"TopAxisLabelPrecision\"\n"
12968 " number_of_elements=\"1\">\n"
12969 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
12970 " </IntVectorProperty>\n"
12971 " <IntVectorProperty command=\"SetTopAxisUseCustomLabels\"\n"
12972 " default_values=\"0\"\n"
12973 " panel_visibility=\"advanced\"\n"
12974 " name=\"TopAxisUseCustomLabels\"\n"
12975 " number_of_elements=\"1\">\n"
12976 " <BooleanDomain name=\"bool\" />\n"
12977 " <Documentation>\n"
12978 " Specify whether to use custom labels for each of the axis. Labels\n"
12979 " specified by ...AxisLabels are used only when\n"
12980 " the corresponding AxisUseCustomLabels flag is set to 1.\n"
12981 " </Documentation>\n"
12982 " </IntVectorProperty>\n"
12983 " <StringVectorProperty command=\"SetTopAxisLabels\"\n"
12984 " name=\"TopAxisLabels\"\n"
12985 " panel_visibility=\"advanced\"\n"
12986 " animateable=\"1\"\n"
12987 " number_of_elements=\"0\"\n"
12988 " number_of_elements_per_command=\"2\"\n"
12989 " repeat_command=\"1\"\n"
12990 " use_index=\"1\"\n"
12991 " set_number_command=\"SetTopAxisLabelsNumber\">\n"
12992 " <Hints>\n"
12993 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
12994 " <Property name=\"TopAxisUseCustomLabels\"\n"
12995 " function=\"boolean\" />\n"
12996 " </PropertyWidgetDecorator>\n"
12997 " </Hints>\n"
12998 " <Documentation>\n"
12999 " Specify list of ticks and the associated labels to display. If the label is empty,\n"
13000 " the value of the tick will be used for display.\n"
13001 " </Documentation>\n"
13002 " </StringVectorProperty>\n"
13003 " <StringVectorProperty command=\"SetTopAxisLabelFontFamily\"\n"
13004 " default_values=\"Arial\"\n"
13005 " name=\"TopAxisLabelFontFamily\"\n"
13006 " number_of_elements=\"1\">\n"
13007 " <StringListDomain name=\"list\">\n"
13008 " <String value=\"Arial\" />\n"
13009 " <String value=\"Courier\" />\n"
13010 " <String value=\"Times\" />\n"
13011 " <String value=\"File\" />\n"
13012 " </StringListDomain>\n"
13013 " <Documentation>Set the axis title font familyname.</Documentation>\n"
13014 " </StringVectorProperty>\n"
13015 " <StringVectorProperty command=\"SetTopAxisLabelFontFile\"\n"
13016 " name=\"TopAxisLabelFontFile\"\n"
13017 " number_of_elements=\"1\"\n"
13018 " default_values=\"\">\n"
13019 " <Documentation>Set the axis title font file.</Documentation>\n"
13020 " </StringVectorProperty>\n"
13021 " <IntVectorProperty command=\"SetTopAxisLabelFontSize\"\n"
13022 " default_values=\"12\"\n"
13023 " name=\"TopAxisLabelFontSize\"\n"
13024 " number_of_elements=\"1\">\n"
13025 " <Documentation>Set the axis title font size.</Documentation>\n"
13026 " </IntVectorProperty>\n"
13027 " <IntVectorProperty command=\"SetTopAxisLabelBold\"\n"
13028 " default_values=\"0\"\n"
13029 " name=\"TopAxisLabelBold\"\n"
13030 " number_of_elements=\"1\">\n"
13031 " <BooleanDomain name=\"bool\" />\n"
13032 " <Documentation>Set the axis title bold.</Documentation>\n"
13033 " </IntVectorProperty>\n"
13034 " <IntVectorProperty command=\"SetTopAxisLabelItalic\"\n"
13035 " default_values=\"0\"\n"
13036 " name=\"TopAxisLabelItalic\"\n"
13037 " number_of_elements=\"1\">\n"
13038 " <BooleanDomain name=\"bool\" />\n"
13039 " <Documentation>Set the axis title italic.</Documentation>\n"
13040 " </IntVectorProperty>\n"
13041 " <DoubleVectorProperty command=\"SetTopAxisLabelColor\"\n"
13042 " default_values=\"0 0 0\"\n"
13043 " name=\"TopAxisLabelColor\"\n"
13044 " number_of_elements=\"3\">\n"
13045 " <DoubleRangeDomain max=\"1\"\n"
13046 " min=\"0\"\n"
13047 " name=\"range\" />\n"
13048 " </DoubleVectorProperty>\n"
13049 "\n"
13050 " <PropertyGroup label=\"Top Axis\">\n"
13051 " <Property name=\"TopAxisTitle\"/>\n"
13052 " <Property name=\"ShowTopAxisGrid\"/>\n"
13053 " <Property name=\"TopAxisGridColor\"/>\n"
13054 " <Property name=\"TopAxisColor\"/>\n"
13055 " </PropertyGroup>\n"
13056 "\n"
13057 " <PropertyGroup label=\"Top Axis Title Properties\"\n"
13058 " panel_widget=\"FontEditor\"\n"
13059 " panel_visibility=\"advanced\">\n"
13060 " <Property name=\"TopAxisTitleColor\" function=\"Color\"/>\n"
13061 " <Property name=\"TopAxisTitleFontFamily\" function=\"Family\"/>\n"
13062 " <Property name=\"TopAxisTitleFontFile\" function=\"File\"/>\n"
13063 " <Property name=\"TopAxisTitleBold\" function=\"Bold\" />\n"
13064 " <Property name=\"TopAxisTitleItalic\" function=\"Italics\"/>\n"
13065 " <Property name=\"TopAxisTitleFontSize\" function=\"Size\" />\n"
13066 " <!-- next properties are not available -->\n"
13067 " <!-- <Property name=\"TopAxisTitleOpacity\" function=\"Opacity\"/> -->\n"
13068 " <!-- <Property name=\"TopAxisTitleShadow\" function=\"Shadow\" /> -->\n"
13069 " </PropertyGroup>\n"
13070 "\n"
13071 " <PropertyGroup label=\"Top Axis Range\">\n"
13072 " <Property name=\"TopAxisLogScale\"/>\n"
13073 " <Property name=\"TopAxisUseCustomRange\"/>\n"
13074 " <Property name=\"TopAxisRangeMinimum\"/>\n"
13075 " <Property name=\"TopAxisRangeMaximum\"/>\n"
13076 " </PropertyGroup>\n"
13077 "\n"
13078 " <PropertyGroup label=\"Top Axis Labels\">\n"
13079 " <Property name=\"ShowTopAxisLabels\"/>\n"
13080 " <Property name=\"TopAxisLabelNotation\"/>\n"
13081 " <Property name=\"TopAxisLabelPrecision\"/>\n"
13082 " <Property name=\"TopAxisUseCustomLabels\"/>\n"
13083 " <Property name=\"TopAxisLabels\"/>\n"
13084 " </PropertyGroup>\n"
13085 "\n"
13086 " <PropertyGroup label=\"Top Axis Label Properties\"\n"
13087 " panel_widget=\"FontEditor\"\n"
13088 " panel_visibility=\"advanced\">\n"
13089 " <Property name=\"TopAxisLabelColor\" function=\"Color\"/>\n"
13090 " <Property name=\"TopAxisLabelFontFamily\" function=\"Family\"/>\n"
13091 " <Property name=\"TopAxisLabelFontFile\" function=\"File\"/>\n"
13092 " <Property name=\"TopAxisLabelBold\" function=\"Bold\" />\n"
13093 " <Property name=\"TopAxisLabelItalic\" function=\"Italics\"/>\n"
13094 " <Property name=\"TopAxisLabelFontSize\" function=\"Size\" />\n"
13095 " <!-- next properties are not available -->\n"
13096 " <!-- <Property name=\"TopAxisLabelOpacity\" function=\"Opacity\"/> -->\n"
13097 " <!-- <Property name=\"TopAxisLabelShadow\" function=\"Shadow\" /> -->\n"
13098 " </PropertyGroup>\n"
13099 " <!-- end top axis -->\n"
13100 " </ContextViewProxy>\n"
13101 "\n"
13102 " <!-- ================================================================== -->\n"
13103 " <Proxy name=\"ComparativeViewBase\">\n"
13104 " <DoubleVectorProperty command=\"SetViewTime\"\n"
13105 " default_values=\"none\"\n"
13106 " name=\"ViewTime\"\n"
13107 " number_of_elements=\"1\"\n"
13108 " panel_visibility=\"never\"\n"
13109 " state_ignored=\"1\">\n"
13110 " <DoubleRangeDomain name=\"range\" />\n"
13111 " <Documentation>The pipeline update time for this view. This gets passed\n"
13112 " to all representations added to this view.</Documentation>\n"
13113 " </DoubleVectorProperty>\n"
13114 " <DoubleVectorProperty default_values=\"none\"\n"
13115 " name=\"CacheKey\"\n"
13116 ;
13117
13118 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
13120 " number_of_elements=\"1\"\n"
13121 " panel_visibility=\"never\"\n"
13122 " state_ignored=\"1\"\n"
13123 " is_internal=\"1\">\n"
13124 " <DoubleRangeDomain name=\"range\" />\n"
13125 " <Documentation>This is the cache key used to identify which cache\n"
13126 " entry to use for rendering when caching is enabled.</Documentation>\n"
13127 " </DoubleVectorProperty>\n"
13128 " <IntVectorProperty default_values=\"0\"\n"
13129 " name=\"UseCache\"\n"
13130 " number_of_elements=\"1\"\n"
13131 " panel_visibility=\"never\"\n"
13132 " state_ignored=\"1\"\n"
13133 " is_internal=\"1\">\n"
13134 " <BooleanDomain name=\"bool\" />\n"
13135 " <Documentation>Indicates whether to use cache for subsequent\n"
13136 " renderings.</Documentation>\n"
13137 " </IntVectorProperty>\n"
13138 " <IntVectorProperty command=\"SetViewPosition\"\n"
13139 " default_values=\"0 0\"\n"
13140 " name=\"ViewPosition\"\n"
13141 " panel_visibility=\"never\"\n"
13142 " number_of_elements=\"2\">\n"
13143 " <Hints>\n"
13144 " <NoDefault />\n"
13145 " </Hints>\n"
13146 " <Documentation>Set the position on this view in the multiview\n"
13147 " configuration.</Documentation>\n"
13148 " </IntVectorProperty>\n"
13149 " <IntVectorProperty command=\"SetViewSize\"\n"
13150 " default_values=\"400 400\"\n"
13151 " ignore_synchronization=\"1\"\n"
13152 " name=\"ViewSize\"\n"
13153 " number_of_elements=\"2\"\n"
13154 " panel_visibility=\"never\"\n"
13155 " state_ignored=\"1\">\n"
13156 " <Hints>\n"
13157 " <NoDefault />\n"
13158 " </Hints>\n"
13159 " <Documentation>Set the size of this view in the multiview\n"
13160 " configuration.</Documentation>\n"
13161 " </IntVectorProperty>\n"
13162 " <IntVectorProperty command=\"Build\"\n"
13163 " default_values=\"2 2\"\n"
13164 " name=\"Dimensions\"\n"
13165 " panel_visibility=\"never\"\n"
13166 " number_of_elements=\"2\">\n"
13167 " <IntRangeDomain max=\"10 10\"\n"
13168 " min=\"1 1\"\n"
13169 " name=\"range\" />\n"
13170 " </IntVectorProperty>\n"
13171 " <IntVectorProperty command=\"SetOverlayAllComparisons\"\n"
13172 " default_values=\"0\"\n"
13173 " name=\"OverlayAllComparisons\"\n"
13174 " panel_visibility=\"never\"\n"
13175 " number_of_elements=\"1\">\n"
13176 " <BooleanDomain name=\"bool\" />\n"
13177 " </IntVectorProperty>\n"
13178 " <IntVectorProperty command=\"SetSpacing\"\n"
13179 " default_values=\"1 1\"\n"
13180 " name=\"Spacing\"\n"
13181 " panel_visibility=\"never\"\n"
13182 " number_of_elements=\"2\">\n"
13183 " <IntRangeDomain max=\"10 10\"\n"
13184 " min=\"0 0\"\n"
13185 " name=\"range\" />\n"
13186 " </IntVectorProperty>\n"
13187 " <ProxyProperty argument_type=\"SMProxy\"\n"
13188 " command=\"AddRepresentation\"\n"
13189 " name=\"Representations\"\n"
13190 " remove_command=\"RemoveRepresentation\"\n"
13191 " repeatable=\"1\">\n"
13192 " <Documentation>Representations in this view.</Documentation>\n"
13193 " </ProxyProperty>\n"
13194 " <ProxyProperty argument_type=\"SMProxy\"\n"
13195 " command=\"AddCue\"\n"
13196 " name=\"Cues\"\n"
13197 " remove_command=\"RemoveCue\">\n"
13198 " <Documentation>Animation cues for changing parameters.</Documentation>\n"
13199 " </ProxyProperty>\n"
13200 " </Proxy>\n"
13201 " </ProxyGroup>\n"
13202 "\n"
13203 " <!-- ******************************************************************** -->\n"
13204 " <ProxyGroup name=\"views\">\n"
13205 " <!-- ================================================================== -->\n"
13206 " <RenderViewProxy base_proxygroup=\"internal_views\"\n"
13207 " base_proxyname=\"ViewBase\"\n"
13208 " class=\"vtkPVRenderView\"\n"
13209 " name=\"RenderView\"\n"
13210 " label=\"Render View\"\n"
13211 " processes=\"client|renderserver|dataserver\">\n"
13212 " <Documentation>View proxy for a 3D interactive render\n"
13213 " view.</Documentation>\n"
13214 " <IntVectorProperty command=\"SetShowAnnotation\"\n"
13215 " default_values=\"0\"\n"
13216 " number_of_elements=\"1\"\n"
13217 " name=\"ShowAnnotation\"\n"
13218 " panel_visibility=\"never\">\n"
13219 " <BooleanDomain name=\"bool\" />\n"
13220 " <Documentation>\n"
13221 " Set whether to see annotation providing advanced debugging and performance\n"
13222 " information about each render.\n"
13223 " </Documentation>\n"
13224 " <Hints>\n"
13225 " <PropertyLink group=\"settings\"\n"
13226 " proxy=\"RenderViewSettings\"\n"
13227 " property=\"ShowAnnotation\"/>\n"
13228 " </Hints>\n"
13229 " </IntVectorProperty>\n"
13230 " <DoubleVectorProperty command=\"SetAnnotationColor\"\n"
13231 " default_values=\"1 1 1\"\n"
13232 " name=\"AnnotationColor\"\n"
13233 " panel_widget=\"color_selector_with_palette\"\n"
13234 " panel_visibility=\"never\"\n"
13235 " number_of_elements=\"3\">\n"
13236 " <Hints>\n"
13237 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"TextAnnotationColor\" unlink_if_modified=\"1\" />\n"
13238 " </Hints>\n"
13239 " </DoubleVectorProperty>\n"
13240 " <IntVectorProperty command=\"SetUseInteractiveRenderingForScreenshots\"\n"
13241 " default_values=\"0\"\n"
13242 " name=\"UseInteractiveRenderingForScreenshots\"\n"
13243 " panel_visibility=\"never\"\n"
13244 " number_of_elements=\"1\">\n"
13245 " <BooleanDomain name=\"bool\" />\n"
13246 " <Documentation>Set whether InteractiveRender() should be used during\n"
13247 " CaptureWindow calls. Default is to use StillRender().</Documentation>\n"
13248 " </IntVectorProperty>\n"
13249 " <IntVectorProperty command=\"SetInteractionMode\"\n"
13250 " default_values=\"0\"\n"
13251 " name=\"InteractionMode\"\n"
13252 " number_of_elements=\"1\"\n"
13253 " panel_visibility=\"never\"\n"
13254 " state_ignored=\"1\">\n"
13255 " <EnumerationDomain name=\"enum\">\n"
13256 " <Entry text=\"3D\"\n"
13257 " value=\"0\" />\n"
13258 " <Entry text=\"2D\"\n"
13259 " value=\"1\" />\n"
13260 " <Entry text=\"Selection\"\n"
13261 " value=\"2\" />\n"
13262 " </EnumerationDomain>\n"
13263 " </IntVectorProperty>\n"
13264 " <IntVectorProperty command=\"SetStillRenderImageReductionFactor\"\n"
13265 " default_values=\"1\"\n"
13266 " name=\"StillRenderImageReductionFactor\"\n"
13267 " panel_visibility=\"never\"\n"
13268 " number_of_elements=\"1\">\n"
13269 " <IntRangeDomain max=\"20\"\n"
13270 " min=\"1\"\n"
13271 " name=\"range\" />\n"
13272 " <Documentation>Get/Set the reduction-factor to use when for\n"
13273 " StillRender(). This is typically set to 1, but in some cases with\n"
13274 " terrible connectivity or really large displays, one may want to use a\n"
13275 " sub-sampled image even for StillRender(). This is set it number of\n"
13276 " pixels to be sub-sampled by. Note that image reduction factors have no\n"
13277 " effect when in built-in mode.</Documentation>\n"
13278 " <Hints>\n"
13279 " <PropertyLink group=\"settings\"\n"
13280 " proxy=\"RenderViewSettings\"\n"
13281 " property=\"StillRenderImageReductionFactor\"/>\n"
13282 " </Hints>\n"
13283 " </IntVectorProperty>\n"
13284 " <DoubleVectorProperty default_values=\"100.0\"\n"
13285 " name=\"CollectGeometryThreshold\"\n"
13286 " panel_visibility=\"never\"\n"
13287 " number_of_elements=\"1\">\n"
13288 " <Documentation>DEPRECATED: Simply set UseOutlineForLODRendering flag to\n"
13289 " true, and whenever LOD rendering is employed, we rendering outlines, is\n"
13290 " possible.</Documentation>\n"
13291 " </DoubleVectorProperty>\n"
13292 " <IntVectorProperty command=\"SetInteractiveRenderImageReductionFactor\"\n"
13293 " default_values=\"2\"\n"
13294 " name=\"ImageReductionFactor\"\n"
13295 " panel_visibility=\"never\"\n"
13296 " number_of_elements=\"1\">\n"
13297 " <IntRangeDomain max=\"20\"\n"
13298 " min=\"1\"\n"
13299 " name=\"range\" />\n"
13300 " <Documentation>Get/Set the reduction-factor to use when for\n"
13301 " InteractiveRender(). This is set it number of pixels to be sub-sampled\n"
13302 " by. Note that image reduction factors have no effect when in built-in\n"
13303 " mode.</Documentation>\n"
13304 " <Hints>\n"
13305 " <PropertyLink group=\"settings\"\n"
13306 " proxy=\"RenderViewSettings\"\n"
13307 " property=\"ImageReductionFactor\"/>\n"
13308 " </Hints>\n"
13309 " </IntVectorProperty>\n"
13310 " <IntVectorProperty command=\"SetSuppressRendering\"\n"
13311 " default_values=\"0\"\n"
13312 " name=\"SuppressRendering\"\n"
13313 " panel_visibility=\"never\"\n"
13314 " number_of_elements=\"1\">\n"
13315 " <BooleanDomain name=\"bool\" />\n"
13316 " <Documentation>When set to true, this will suppress rendering\n"
13317 " into a window yet still perform all the updates that normally\n"
13318 " happen as a part of rendering.</Documentation>\n"
13319 " </IntVectorProperty>\n"
13320 " <DoubleVectorProperty command=\"SetRemoteRenderingThreshold\"\n"
13321 " default_values=\"20.0\"\n"
13322 " ignore_synchronization=\"1\"\n"
13323 " name=\"RemoteRenderThreshold\"\n"
13324 " panel_visibility=\"never\"\n"
13325 " number_of_elements=\"1\">\n"
13326 " <DoubleRangeDomain min=\"0\"\n"
13327 " name=\"range\" />\n"
13328 " <Documentation>The threshold used to determine if the compositing\n"
13329 " should be used for rendering. The value is rendering-geometry size in\n"
13330 " MBs.</Documentation>\n"
13331 " <Hints>\n"
13332 " <PropertyLink group=\"settings\"\n"
13333 " proxy=\"RenderViewSettings\"\n"
13334 " property=\"RemoteRenderThreshold\"/>\n"
13335 " </Hints>\n"
13336 " </DoubleVectorProperty>\n"
13337 " <DoubleVectorProperty command=\"SetLODRenderingThreshold\"\n"
13338 " default_values=\"5\"\n"
13339 " name=\"LODThreshold\"\n"
13340 " panel_visibility=\"never\"\n"
13341 " number_of_elements=\"1\">\n"
13342 " <Documentation>Set the memory size threshold above which LOD will be\n"
13343 " used while rendering interactively. The value is rendering-geometry\n"
13344 " size in MBs.</Documentation>\n"
13345 " <DoubleRangeDomain min=\"0\"\n"
13346 " name=\"range\" />\n"
13347 " <Hints>\n"
13348 " <PropertyLink group=\"settings\"\n"
13349 " proxy=\"RenderViewSettings\"\n"
13350 " property=\"LODThreshold\"/>\n"
13351 " </Hints>\n"
13352 " </DoubleVectorProperty>\n"
13353 " <DoubleVectorProperty command=\"SetLODResolution\"\n"
13354 " default_values=\"0.5\"\n"
13355 " name=\"LODResolution\"\n"
13356 " panel_visibility=\"never\"\n"
13357 " number_of_elements=\"1\">\n"
13358 " <DoubleRangeDomain max=\"1.0\"\n"
13359 " min=\"0\"\n"
13360 " name=\"range\" />\n"
13361 " <Documentation>Set the LOD resolution. 0 implies lowest level or\n"
13362 " detail, while 1 implies maximum level of detail.</Documentation>\n"
13363 " <Hints>\n"
13364 " <PropertyLink group=\"settings\"\n"
13365 " proxy=\"RenderViewSettings\"\n"
13366 " property=\"LODResolution\"/>\n"
13367 " </Hints>\n"
13368 " </DoubleVectorProperty>\n"
13369 " <IntVectorProperty command=\"SetUseOutlineForLODRendering\"\n"
13370 " default_values=\"0\"\n"
13371 " name=\"UseOutlineForLODRendering\"\n"
13372 " panel_visibility=\"never\"\n"
13373 " number_of_elements=\"1\">\n"
13374 " <BooleanDomain name=\"bool\" />\n"
13375 " <Documentation>When set to true, this overrides the LODResolution. In\n"
13376 " that case, when using LOD for rendering, if possible, the data is\n"
13377 " rendered as outlines.</Documentation>\n"
13378 " <Hints>\n"
13379 " <PropertyLink group=\"settings\"\n"
13380 " proxy=\"RenderViewSettings\"\n"
13381 " property=\"UseOutlineForLODRendering\"/>\n"
13382 " </Hints>\n"
13383 " </IntVectorProperty>\n"
13384 " <StringVectorProperty command=\"ConfigureCompressor\"\n"
13385 " default_values=\"vtkLZ4Compressor 0 3\"\n"
13386 " name=\"CompressorConfig\"\n"
13387 " panel_visibility=\"never\"\n"
13388 " number_of_elements=\"1\">\n"
13389 " <Documentation>Used to configure the image compression used for\n"
13390 " client-server image transfer when doing interactive\n"
13391 " renders.</Documentation>\n"
13392 " <Hints>\n"
13393 " <PropertyLink group=\"settings\"\n"
13394 " proxy=\"RenderViewSettings\"\n"
13395 " property=\"CompressorConfig\"/>\n"
13396 " </Hints>\n"
13397 " </StringVectorProperty>\n"
13398 "\n"
13399 " <ProxyProperty name=\"AxesGrid\"\n"
13400 " command=\"SetGridAxes3DActor\"\n"
13401 " panel_widget=\"proxy_editor\">\n"
13402 " <ProxyListDomain name=\"proxy_list\">\n"
13403 " <Proxy group=\"annotations\" name=\"GridAxes3DActor\" />\n"
13404 " </ProxyListDomain>\n"
13405 " <Hints>\n"
13406 " <ProxyEditorPropertyWidget property=\"Visibility\">\n"
13407 " <!-- tell pqProxyEditorPropertyWidget that use the \"Visibility\"\n"
13408 " property on the GridAxes3DActor proxy for a checkbox\n"
13409 " on the UI -->\n"
13410 " </ProxyEditorPropertyWidget>\n"
13411 " </Hints>\n"
13412 " </ProxyProperty>\n"
13413 "\n"
13414 " <!-- Camera Orientation Widget -->\n"
13415 " <IntVectorProperty command=\"SetCameraOrientationWidgetVisibility\"\n"
13416 " name=\"CameraOrientationWidgetVisibility\"\n"
13417 " label=\"Visible\"\n"
13418 " default_values=\"0\"\n"
13419 " number_of_elements=\"1\">\n"
13420 " <BooleanDomain name=\"bool\" />\n"
13421 " <Documentation>Visibility of the camera orientation widget.</Documentation>\n"
13422 " </IntVectorProperty>\n"
13423 " <IntVectorProperty command=\"SetCameraOrientationWidgetSize\"\n"
13424 " name=\"CameraOrientationWidgetSize\"\n"
13425 " label=\"Size\"\n"
13426 " default_values=\"100\"\n"
13427 " number_of_elements=\"1\"\n"
13428 " panel_visibility=\"advanced\">\n"
13429 " <IntRangeDomain min=\"10\" max=\"512\" name=\"range\" resolution=\"10\" />\n"
13430 " <Documentation>Size of the camera orientation widget.</Documentation>\n"
13431 " <Hints>\n"
13432 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraOrientationWidgetVisibility\" value=\"1\" />\n"
13433 ;
13434
13435 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
13437 " </Hints>\n"
13438 " </IntVectorProperty>\n"
13439 " <IntVectorProperty command=\"SetCameraOrientationWidgetAnchor\"\n"
13440 " name=\"CameraOrientationWidgetAnchor\"\n"
13441 " label=\"Location\"\n"
13442 " default_values=\"3\"\n"
13443 " number_of_elements=\"1\"\n"
13444 " panel_visibility=\"advanced\">\n"
13445 " <EnumerationDomain name=\"enum\">\n"
13446 " <Entry text=\"Top Left\" value=\"1\" />\n"
13447 " <Entry text=\"Top Right\" value=\"3\" />\n"
13448 " <Entry text=\"Bottom Left\" value=\"0\" />\n"
13449 " <Entry text=\"Bottom Right\" value=\"2\" />\n"
13450 " </EnumerationDomain>\n"
13451 " <Documentation>Location of the camera orientation widget.</Documentation>\n"
13452 " <Hints>\n"
13453 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"CameraOrientationWidgetVisibility\" value=\"1\" />\n"
13454 " </Hints>\n"
13455 " </IntVectorProperty>\n"
13456 "\n"
13457 " <!-- Center and Orientation Axes -->\n"
13458 " <IntVectorProperty command=\"SetCenterAxesVisibility\"\n"
13459 " default_values=\"0\"\n"
13460 " name=\"CenterAxesVisibility\"\n"
13461 " number_of_elements=\"1\">\n"
13462 " <BooleanDomain name=\"bool\" />\n"
13463 " <Documentation>Toggle the visibility of the axes showing the center of\n"
13464 " rotation in the scene.</Documentation>\n"
13465 " </IntVectorProperty>\n"
13466 " <IntVectorProperty command=\"SetOrientationAxesVisibility\"\n"
13467 " default_values=\"1\"\n"
13468 " name=\"OrientationAxesVisibility\"\n"
13469 " number_of_elements=\"1\">\n"
13470 " <BooleanDomain name=\"bool\" />\n"
13471 " <Documentation>Toggle the visibility of the axes showing the\n"
13472 " viewing direction.</Documentation>\n"
13473 " </IntVectorProperty>\n"
13474 " <IntVectorProperty command=\"SetOrientationAxesInteractivity\"\n"
13475 " default_values=\"0\"\n"
13476 " panel_visibility=\"advanced\"\n"
13477 " name=\"OrientationAxesInteractivity\"\n"
13478 " number_of_elements=\"1\">\n"
13479 " <BooleanDomain name=\"bool\" />\n"
13480 " <Documentation>Allows repositioning of the orientation\n"
13481 " axes.</Documentation>\n"
13482 " </IntVectorProperty>\n"
13483 " <DoubleVectorProperty command=\"SetOrientationAxesLabelColor\"\n"
13484 " default_values=\"1 1 1\"\n"
13485 " name=\"OrientationAxesLabelColor\"\n"
13486 " panel_widget=\"color_selector_with_palette\"\n"
13487 " panel_visibility=\"advanced\"\n"
13488 " number_of_elements=\"3\">\n"
13489 " <Hints>\n"
13490 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"TextAnnotationColor\" unlink_if_modified=\"1\" />\n"
13491 " </Hints>\n"
13492 " </DoubleVectorProperty>\n"
13493 " <DoubleVectorProperty command=\"SetOrientationAxesOutlineColor\"\n"
13494 " default_values=\"1 1 1\"\n"
13495 " name=\"OrientationAxesOutlineColor\"\n"
13496 " panel_widget=\"color_selector_with_palette\"\n"
13497 " panel_visibility=\"advanced\"\n"
13498 " number_of_elements=\"3\">\n"
13499 " <Hints>\n"
13500 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\" unlink_if_modified=\"1\" />\n"
13501 " </Hints>\n"
13502 " </DoubleVectorProperty>\n"
13503 " <IntVectorProperty name=\"OrientationAxesXVisibility\"\n"
13504 " number_of_elements=\"1\"\n"
13505 " default_values=\"1\"\n"
13506 " command=\"SetOrientationAxesXVisibility\"\n"
13507 " panel_visibility=\"advanced\">\n"
13508 " <BooleanDomain name=\"bool\" />\n"
13509 " <Hints>\n"
13510 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\"/>\n"
13511 " </Hints>\n"
13512 " </IntVectorProperty>\n"
13513 " <IntVectorProperty name=\"OrientationAxesYVisibility\"\n"
13514 " number_of_elements=\"1\"\n"
13515 " default_values=\"1\"\n"
13516 " command=\"SetOrientationAxesYVisibility\"\n"
13517 " panel_visibility=\"advanced\">\n"
13518 " <BooleanDomain name=\"bool\" />\n"
13519 " <Hints>\n"
13520 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\"/>\n"
13521 " </Hints>\n"
13522 " </IntVectorProperty>\n"
13523 " <IntVectorProperty name=\"OrientationAxesZVisibility\"\n"
13524 " number_of_elements=\"1\"\n"
13525 " default_values=\"1\"\n"
13526 " command=\"SetOrientationAxesZVisibility\"\n"
13527 " panel_visibility=\"advanced\">\n"
13528 " <BooleanDomain name=\"bool\" />\n"
13529 " <Hints>\n"
13530 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\"/>\n"
13531 " </Hints>\n"
13532 " </IntVectorProperty>\n"
13533 " <DoubleVectorProperty name=\"OrientationAxesXColor\"\n"
13534 " number_of_elements=\"3\"\n"
13535 " default_values=\"1 0 0\"\n"
13536 " command=\"SetOrientationAxesXColor\"\n"
13537 " panel_widget=\"color_selector_with_palette\"\n"
13538 " panel_visibility=\"advanced\">\n"
13539 " <Hints>\n"
13540 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
13541 " <Expression type=\"and\">\n"
13542 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\" />\n"
13543 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesXVisibility\" value=\"1\" />\n"
13544 " </Expression>\n"
13545 " </PropertyWidgetDecorator>\n"
13546 " </Hints>\n"
13547 " </DoubleVectorProperty>\n"
13548 " <DoubleVectorProperty name=\"OrientationAxesYColor\"\n"
13549 " number_of_elements=\"3\"\n"
13550 " default_values=\"1 1 0\"\n"
13551 " command=\"SetOrientationAxesYColor\"\n"
13552 " panel_widget=\"color_selector_with_palette\"\n"
13553 " panel_visibility=\"advanced\">\n"
13554 " <Hints>\n"
13555 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
13556 " <Expression type=\"and\">\n"
13557 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\" />\n"
13558 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesYVisibility\" value=\"1\" />\n"
13559 " </Expression>\n"
13560 " </PropertyWidgetDecorator>\n"
13561 " </Hints>\n"
13562 " </DoubleVectorProperty>\n"
13563 " <DoubleVectorProperty name=\"OrientationAxesZColor\"\n"
13564 " number_of_elements=\"3\"\n"
13565 " default_values=\"0 1 0\"\n"
13566 " command=\"SetOrientationAxesZColor\"\n"
13567 " panel_widget=\"color_selector_with_palette\"\n"
13568 " panel_visibility=\"advanced\">\n"
13569 " <Hints>\n"
13570 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
13571 " <Expression type=\"and\">\n"
13572 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\" />\n"
13573 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesZVisibility\" value=\"1\" />\n"
13574 " </Expression>\n"
13575 " </PropertyWidgetDecorator> </Hints>\n"
13576 " </DoubleVectorProperty>\n"
13577 " <StringVectorProperty name=\"OrientationAxesXLabelText\"\n"
13578 " number_of_elements=\"1\"\n"
13579 " default_values=\"X\"\n"
13580 " command=\"SetOrientationAxesXLabelText\"\n"
13581 " panel_visibility=\"advanced\">\n"
13582 " <Hints>\n"
13583 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
13584 " <Expression type=\"and\">\n"
13585 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\" />\n"
13586 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesXVisibility\" value=\"1\" />\n"
13587 " </Expression>\n"
13588 " </PropertyWidgetDecorator> </Hints>\n"
13589 " </StringVectorProperty>\n"
13590 " <StringVectorProperty name=\"OrientationAxesYLabelText\"\n"
13591 " number_of_elements=\"1\"\n"
13592 " default_values=\"Y\"\n"
13593 " command=\"SetOrientationAxesYLabelText\"\n"
13594 " panel_visibility=\"advanced\">\n"
13595 " <Hints>\n"
13596 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
13597 " <Expression type=\"and\">\n"
13598 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\" />\n"
13599 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesYVisibility\" value=\"1\" />\n"
13600 " </Expression>\n"
13601 " </PropertyWidgetDecorator> </Hints>\n"
13602 " </StringVectorProperty>\n"
13603 " <StringVectorProperty name=\"OrientationAxesZLabelText\"\n"
13604 " number_of_elements=\"1\"\n"
13605 " default_values=\"Z\"\n"
13606 " command=\"SetOrientationAxesZLabelText\"\n"
13607 " panel_visibility=\"advanced\">\n"
13608 " <Hints>\n"
13609 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
13610 " <Expression type=\"and\">\n"
13611 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesVisibility\" value=\"1\" />\n"
13612 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"OrientationAxesZVisibility\" value=\"1\" />\n"
13613 " </Expression>\n"
13614 " </PropertyWidgetDecorator> </Hints>\n"
13615 " </StringVectorProperty>\n"
13616 "\n"
13617 " <DoubleVectorProperty command=\"SetCenterOfRotation\"\n"
13618 " default_values=\"0 0 0\"\n"
13619 " name=\"CenterOfRotation\"\n"
13620 " panel_visibility=\"never\"\n"
13621 " number_of_elements=\"3\">\n"
13622 " <Documentation>Center of rotation for the interactor.</Documentation>\n"
13623 " </DoubleVectorProperty>\n"
13624 " <DoubleVectorProperty command=\"SetRotationFactor\"\n"
13625 " default_values=\"1\"\n"
13626 " name=\"RotationFactor\"\n"
13627 " panel_visibility=\"never\"\n"
13628 " number_of_elements=\"1\">\n"
13629 " <Documentation>Rotation speed factor for the interactor. This default\n"
13630 " rotation speed is multipied by this factor. Default value is 1.\n"
13631 " </Documentation>\n"
13632 " </DoubleVectorProperty>\n"
13633 " <DoubleVectorProperty default_values=\"0\"\n"
13634 " name=\"NonInteractiveRenderDelay\"\n"
13635 " panel_visibility=\"never\"\n"
13636 " number_of_elements=\"1\">\n"
13637 " <Documentation>Set the delay (in seconds) after an interactive render\n"
13638 " before switching to a full-res render.</Documentation>\n"
13639 " <Hints>\n"
13640 " <PropertyLink group=\"settings\"\n"
13641 " proxy=\"RenderViewSettings\"\n"
13642 " property=\"NonInteractiveRenderDelay\"/>\n"
13643 " </Hints>\n"
13644 " </DoubleVectorProperty>\n"
13645 " <IntVectorProperty name=\"EnableRenderOnInteraction\"\n"
13646 " default_values=\"1\"\n"
13647 " panel_visibility=\"never\"\n"
13648 " number_of_elements=\"1\">\n"
13649 " <BooleanDomain name=\"bool\" />\n"
13650 " <Documentation>\n"
13651 " Set whether the view must render automatically on interaction. If application\n"
13652 " wants to manage renders explicitly, set this to 0 (Off). 1 (On) by default.\n"
13653 " </Documentation>\n"
13654 " </IntVectorProperty>\n"
13655 " <DoubleVectorProperty default_values=\"0.3\"\n"
13656 " name=\"WindowResizeNonInteractiveRenderDelay\"\n"
13657 " panel_visibility=\"never\"\n"
13658 " number_of_elements=\"1\">\n"
13659 " <Documentation>Set the delay (in seconds) before doing a full resolution render after the last resize of the window.</Documentation>\n"
13660 " <Hints>\n"
13661 " <PropertyLink group=\"settings\"\n"
13662 " proxy=\"RenderViewSettings\"\n"
13663 " property=\"WindowResizeNonInteractiveRenderDelay\"/>\n"
13664 " </Hints>\n"
13665 " </DoubleVectorProperty>\n"
13666 " <IntVectorProperty name=\"Camera3DManipulators\"\n"
13667 " command=\"SetCamera3DManipulators\"\n"
13668 " argument_is_array=\"1\"\n"
13669 " number_of_elements=\"9\"\n"
13670 " default_values=\"4 1 2 3 4 7 2 4 6\"\n"
13671 " panel_visibility=\"never\">\n"
13672 " <Documentation>\n"
13673 " Set the interactions mode for 3D interaction. The values are specified\n"
13674 " in order as (left button, middle button, right button), and repeated for\n"
13675 " shift key and control key modifiers.\n"
13676 " </Documentation>\n"
13677 " <Hints>\n"
13678 " <PropertyLink group=\"settings\"\n"
13679 " proxy=\"RenderViewInteractionSettings\"\n"
13680 " property=\"Camera3DManipulators\"/>\n"
13681 " </Hints>\n"
13682 " <EnumerationDomain name=\"enum\">\n"
13683 " <Entry text=\"None\" value=\"0\" />\n"
13684 " <Entry text=\"Pan\" value=\"1\" />\n"
13685 " <Entry text=\"Zoom\" value=\"2\" />\n"
13686 " <Entry text=\"Roll\" value=\"3\" />\n"
13687 " <Entry text=\"Rotate\" value=\"4\" />\n"
13688 " <Entry text=\"Multi-Rotate\" value=\"5\" />\n"
13689 " <Entry text=\"ZoomToMouse\" value=\"6\" />\n"
13690 " <Entry text=\"SkyboxRotate\" value=\"7\" />\n"
13691 " </EnumerationDomain>\n"
13692 " </IntVectorProperty>\n"
13693 "\n"
13694 " <IntVectorProperty name=\"Camera2DManipulators\"\n"
13695 " command=\"SetCamera2DManipulators\"\n"
13696 " argument_is_array=\"1\"\n"
13697 " number_of_elements=\"9\"\n"
13698 " default_values=\"1 3 2 2 2 6 3 1 4\"\n"
13699 " panel_visibility=\"never\">\n"
13700 " <Documentation>\n"
13701 " Set the interactions mode for 2D interaction. The values are specified\n"
13702 " in order as (left button, middle button, right button), and repeated for\n"
13703 " shift key and control key modifiers.\n"
13704 " </Documentation>\n"
13705 " <Hints>\n"
13706 " <PropertyLink group=\"settings\"\n"
13707 " proxy=\"RenderViewInteractionSettings\"\n"
13708 " property=\"Camera2DManipulators\"/>\n"
13709 " </Hints>\n"
13710 " <EnumerationDomain name=\"enum\">\n"
13711 " <Entry text=\"None\" value=\"0\" />\n"
13712 " <Entry text=\"Pan\" value=\"1\" />\n"
13713 " <Entry text=\"Zoom\" value=\"2\" />\n"
13714 " <Entry text=\"Roll\" value=\"3\" />\n"
13715 " <Entry text=\"Rotate\" value=\"4\" />\n"
13716 " <Entry text=\"ZoomToMouse\" value=\"6\" />\n"
13717 " </EnumerationDomain>\n"
13718 " </IntVectorProperty>\n"
13719 " <DoubleVectorProperty command=\"SetCamera2DMouseWheelMotionFactor\"\n"
13720 " default_values=\"1\"\n"
13721 ;
13722
13723 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
13725 " name=\"Camera2DMouseWheelMotionFactor\"\n"
13726 " number_of_elements=\"1\"\n"
13727 " panel_visibility=\"never\">\n"
13728 " <DoubleRangeDomain max=\"10\"\n"
13729 " min=\"0\"\n"
13730 " name=\"range\"\n"
13731 " resolution=\"0.01\" />\n"
13732 " <Hints>\n"
13733 " <PropertyLink group=\"settings\"\n"
13734 " proxy=\"RenderViewInteractionSettings\"\n"
13735 " property=\"Camera2DMouseWheelMotionFactor\"/>\n"
13736 " </Hints>\n"
13737 " <Documentation>Set the wheel motion factor for 2D interaction.</Documentation>\n"
13738 " </DoubleVectorProperty>\n"
13739 " <DoubleVectorProperty command=\"SetCamera3DMouseWheelMotionFactor\"\n"
13740 " default_values=\"1\"\n"
13741 " name=\"Camera3DMouseWheelMotionFactor\"\n"
13742 " number_of_elements=\"1\"\n"
13743 " panel_visibility=\"never\">\n"
13744 " <DoubleRangeDomain max=\"10\"\n"
13745 " min=\"0\"\n"
13746 " name=\"range\"\n"
13747 " resolution=\"0.01\" />\n"
13748 " <Hints>\n"
13749 " <PropertyLink group=\"settings\"\n"
13750 " proxy=\"RenderViewInteractionSettings\"\n"
13751 " property=\"Camera3DMouseWheelMotionFactor\"/>\n"
13752 " </Hints>\n"
13753 " <Documentation>Set the wheel motion factor for 3D interaction.</Documentation>\n"
13754 " </DoubleVectorProperty>\n"
13755 " <IntVectorProperty name=\"ReverseMouseWheelZoomDirection\"\n"
13756 " command=\"SetReverseMouseWheelZoomDirection\"\n"
13757 " default_values=\"0\"\n"
13758 " number_of_elements=\"1\"\n"
13759 " label=\"Reverse Mouse Wheel Zoom Direction\"\n"
13760 " panel_visibility=\"never\">\n"
13761 " <BooleanDomain name=\"bool\" />\n"
13762 " <Hints>\n"
13763 " <PropertyLink group=\"settings\"\n"
13764 " proxy=\"RenderViewInteractionSettings\"\n"
13765 " property=\"ReverseMouseWheelZoomDirection\"/>\n"
13766 " </Hints>\n"
13767 " <Documentation>\n"
13768 " This option changes the direction of the mouse wheel for zooming in and out.\n"
13769 " </Documentation>\n"
13770 " </IntVectorProperty>\n"
13771 " <IntVectorProperty name=\"MouseWheelZoomsToCursor\"\n"
13772 " command=\"SetMouseWheelZoomsToCursor\"\n"
13773 " default_values=\"0\"\n"
13774 " number_of_elements=\"1\"\n"
13775 " label=\"Mouse Wheel Zooms To Cursor\"\n"
13776 " panel_visibility=\"never\">\n"
13777 " <BooleanDomain name=\"bool\" />\n"
13778 " <Hints>\n"
13779 " <PropertyLink group=\"settings\"\n"
13780 " proxy=\"RenderViewInteractionSettings\"\n"
13781 " property=\"MouseWheelZoomsToCursor\"/>\n"
13782 " </Hints>\n"
13783 " <Documentation>\n"
13784 " Zooms the renderer's camera to the projected point under the cursor position.\n"
13785 " </Documentation>\n"
13786 " </IntVectorProperty>\n"
13787 " <IntVectorProperty command=\"SetUseLightKit\"\n"
13788 " default_values=\"1\"\n"
13789 " name=\"UseLight\"\n"
13790 " number_of_elements=\"1\">\n"
13791 " <Documentation>Enable/Disable the LightKit.</Documentation>\n"
13792 " <BooleanDomain name=\"bool\" />\n"
13793 " </IntVectorProperty>\n"
13794 " <!-- Key Light -->\n"
13795 " <DoubleVectorProperty command=\"SetKeyLightWarmth\"\n"
13796 " default_values=\"0.60\"\n"
13797 " name=\"KeyLightWarmth\"\n"
13798 " number_of_elements=\"1\">\n"
13799 " <DoubleRangeDomain max=\"1\"\n"
13800 " min=\"0\"\n"
13801 " name=\"range\"\n"
13802 " resolution=\"0.01\" />\n"
13803 " </DoubleVectorProperty>\n"
13804 " <DoubleVectorProperty command=\"SetKeyLightIntensity\"\n"
13805 " default_values=\"0.75\"\n"
13806 " name=\"KeyLightIntensity\"\n"
13807 " number_of_elements=\"1\">\n"
13808 " <DoubleRangeDomain max=\"1\"\n"
13809 " min=\"0\"\n"
13810 " name=\"range\"\n"
13811 " resolution=\"0.05\" />\n"
13812 " </DoubleVectorProperty>\n"
13813 " <DoubleVectorProperty command=\"SetKeyLightElevation\"\n"
13814 " default_values=\"50.0\"\n"
13815 " name=\"KeyLightElevation\"\n"
13816 " number_of_elements=\"1\">\n"
13817 " <DoubleRangeDomain max=\"90\"\n"
13818 " min=\"0\"\n"
13819 " name=\"range\"\n"
13820 " resolution=\"1\" />\n"
13821 " </DoubleVectorProperty>\n"
13822 " <DoubleVectorProperty command=\"SetKeyLightAzimuth\"\n"
13823 " default_values=\"10.0\"\n"
13824 " name=\"KeyLightAzimuth\"\n"
13825 " number_of_elements=\"1\">\n"
13826 " <DoubleRangeDomain max=\"90\"\n"
13827 " min=\"-90\"\n"
13828 " name=\"range\"\n"
13829 " resolution=\"1\" />\n"
13830 " </DoubleVectorProperty>\n"
13831 " <!-- Fill Light -->\n"
13832 " <DoubleVectorProperty command=\"SetFillLightWarmth\"\n"
13833 " default_values=\"0.40\"\n"
13834 " name=\"FillLightWarmth\"\n"
13835 " number_of_elements=\"1\">\n"
13836 " <DoubleRangeDomain max=\"1\"\n"
13837 " min=\"0\"\n"
13838 " name=\"range\"\n"
13839 " resolution=\"0.01\" />\n"
13840 " </DoubleVectorProperty>\n"
13841 " <DoubleVectorProperty command=\"SetKeyToFillRatio\"\n"
13842 " default_values=\"3.0\"\n"
13843 " name=\"FillLightK:F Ratio\"\n"
13844 " number_of_elements=\"1\">\n"
13845 " <DoubleRangeDomain max=\"15\"\n"
13846 " min=\"1\"\n"
13847 " name=\"range\"\n"
13848 " resolution=\"0.1\" />\n"
13849 " </DoubleVectorProperty>\n"
13850 " <DoubleVectorProperty command=\"SetFillLightElevation\"\n"
13851 " default_values=\"-75.0\"\n"
13852 " name=\"FillLightElevation\"\n"
13853 " number_of_elements=\"1\">\n"
13854 " <DoubleRangeDomain max=\"10\"\n"
13855 " min=\"-90\"\n"
13856 " name=\"range\"\n"
13857 " resolution=\"1\" />\n"
13858 " </DoubleVectorProperty>\n"
13859 " <DoubleVectorProperty command=\"SetFillLightAzimuth\"\n"
13860 " default_values=\"-10.0\"\n"
13861 " name=\"FillLightAzimuth\"\n"
13862 " number_of_elements=\"1\">\n"
13863 " <DoubleRangeDomain max=\"90\"\n"
13864 " min=\"-90\"\n"
13865 " name=\"range\"\n"
13866 " resolution=\"1\" />\n"
13867 " </DoubleVectorProperty>\n"
13868 " <!-- Back Light -->\n"
13869 " <DoubleVectorProperty command=\"SetBackLightWarmth\"\n"
13870 " default_values=\"0.50\"\n"
13871 " name=\"BackLightWarmth\"\n"
13872 " number_of_elements=\"1\">\n"
13873 " <DoubleRangeDomain max=\"1\"\n"
13874 " min=\"0\"\n"
13875 " name=\"range\"\n"
13876 " resolution=\"0.01\" />\n"
13877 " </DoubleVectorProperty>\n"
13878 " <DoubleVectorProperty command=\"SetKeyToBackRatio\"\n"
13879 " default_values=\"3.5\"\n"
13880 " name=\"BackLightK:B Ratio\"\n"
13881 " number_of_elements=\"1\">\n"
13882 " <DoubleRangeDomain max=\"15\"\n"
13883 " min=\"1\"\n"
13884 " name=\"range\"\n"
13885 " resolution=\"0.1\" />\n"
13886 " </DoubleVectorProperty>\n"
13887 " <DoubleVectorProperty command=\"SetBackLightElevation\"\n"
13888 " default_values=\"0.0\"\n"
13889 " name=\"BackLightElevation\"\n"
13890 " number_of_elements=\"1\">\n"
13891 " <DoubleRangeDomain max=\"45\"\n"
13892 " min=\"-45\"\n"
13893 " name=\"range\"\n"
13894 " resolution=\"1\" />\n"
13895 " </DoubleVectorProperty>\n"
13896 " <DoubleVectorProperty command=\"SetBackLightAzimuth\"\n"
13897 " default_values=\"110.0\"\n"
13898 " name=\"BackLightAzimuth\"\n"
13899 " number_of_elements=\"1\">\n"
13900 " <DoubleRangeDomain max=\"170\"\n"
13901 " min=\"60\"\n"
13902 " name=\"range\"\n"
13903 " resolution=\"1\" />\n"
13904 " </DoubleVectorProperty>\n"
13905 " <!-- Head Light -->\n"
13906 " <DoubleVectorProperty command=\"SetHeadLightWarmth\"\n"
13907 " default_values=\"0.50\"\n"
13908 " name=\"HeadLightWarmth\"\n"
13909 " number_of_elements=\"1\">\n"
13910 " <DoubleRangeDomain max=\"1\"\n"
13911 " min=\"0\"\n"
13912 " name=\"range\"\n"
13913 " resolution=\"0.01\" />\n"
13914 " </DoubleVectorProperty>\n"
13915 " <DoubleVectorProperty command=\"SetKeyToHeadRatio\"\n"
13916 " default_values=\"3.0\"\n"
13917 " name=\"HeadLightK:H Ratio\"\n"
13918 " number_of_elements=\"1\">\n"
13919 " <DoubleRangeDomain max=\"15\"\n"
13920 " min=\"1\"\n"
13921 " name=\"range\"\n"
13922 " resolution=\"0.1\" />\n"
13923 " </DoubleVectorProperty>\n"
13924 " <!-- Maintain Luminance -->\n"
13925 " <IntVectorProperty command=\"SetMaintainLuminance\"\n"
13926 " default_values=\"0\"\n"
13927 " name=\"MaintainLuminance\"\n"
13928 " number_of_elements=\"1\">\n"
13929 " <BooleanDomain name=\"bool\" />\n"
13930 " </IntVectorProperty>\n"
13931 "\n"
13932 " <IntVectorProperty command=\"SetUseHiddenLineRemoval\"\n"
13933 " default_values=\"0\"\n"
13934 " name=\"HiddenLineRemoval\"\n"
13935 " number_of_elements=\"1\">\n"
13936 " <BooleanDomain name=\"bool\" />\n"
13937 " <Documentation>\n"
13938 " Use a hidden line removal technique to hide wireframe surfaces that\n"
13939 " are occluded by other wireframe surfaces. Note that this is disabled\n"
13940 " when rendering distributed geometry in parallel.\n"
13941 " </Documentation>\n"
13942 " </IntVectorProperty>\n"
13943 "\n"
13944 " <IntVectorProperty command=\"SetUseDepthPeeling\"\n"
13945 " default_values=\"1\"\n"
13946 " name=\"DepthPeeling\"\n"
13947 " panel_visibility=\"never\"\n"
13948 " number_of_elements=\"1\">\n"
13949 " <BooleanDomain name=\"bool\" />\n"
13950 " <Hints>\n"
13951 " <PropertyLink group=\"settings\"\n"
13952 " proxy=\"RenderViewSettings\"\n"
13953 " property=\"DepthPeeling\"/>\n"
13954 " </Hints>\n"
13955 " </IntVectorProperty>\n"
13956 "\n"
13957 " <IntVectorProperty command=\"SetUseDepthPeelingForVolumes\"\n"
13958 " default_values=\"1\"\n"
13959 " name=\"DepthPeelingForVolumes\"\n"
13960 " panel_visibility=\"never\"\n"
13961 " number_of_elements=\"1\">\n"
13962 " <BooleanDomain name=\"bool\" />\n"
13963 " <Hints>\n"
13964 " <PropertyLink group=\"settings\"\n"
13965 " proxy=\"RenderViewSettings\"\n"
13966 " property=\"DepthPeelingForVolumes\"/>\n"
13967 " </Hints>\n"
13968 " </IntVectorProperty>\n"
13969 "\n"
13970 " <IntVectorProperty command=\"SetMaximumNumberOfPeels\"\n"
13971 " default_values=\"4\"\n"
13972 " name=\"MaximumNumberOfPeels\"\n"
13973 " panel_visibility=\"never\"\n"
13974 " number_of_elements=\"1\">\n"
13975 " <Documentation>In case of depth peeling, define the maximum number of\n"
13976 " peeling layers. Initial value is 4. A special value of 0 means no\n"
13977 " maximum limit. It has to be a positive value.</Documentation>\n"
13978 " <IntRangeDomain min=\"0\"\n"
13979 " name=\"range\" />\n"
13980 " <Hints>\n"
13981 " <PropertyLink group=\"settings\"\n"
13982 " proxy=\"RenderViewSettings\"\n"
13983 " property=\"MaximumNumberOfPeels\"/>\n"
13984 " </Hints>\n"
13985 " </IntVectorProperty>\n"
13986 "\n"
13987 " <IntVectorProperty command=\"SetUseFXAA\"\n"
13988 " default_values=\"0\"\n"
13989 " name=\"UseFXAA\"\n"
13990 " panel_visibility=\"never\"\n"
13991 " number_of_elements=\"1\">\n"
13992 " <BooleanDomain name=\"bool\" />\n"
13993 " <Hints>\n"
13994 " <PropertyLink group=\"settings\"\n"
13995 " proxy=\"RenderViewSettings\"\n"
13996 " property=\"UseFXAA\"/>\n"
13997 " </Hints>\n"
13998 " </IntVectorProperty>\n"
13999 " <DoubleVectorProperty command=\"SetFXAARelativeContrastThreshold\"\n"
14000 " default_values=\"0.125\"\n"
14001 " name=\"FXAARelativeContrastThreshold\"\n"
14002 " panel_visibility=\"never\"\n"
14003 " number_of_elements=\"1\">\n"
14004 " <Hints>\n"
14005 " <PropertyLink group=\"settings\"\n"
14006 " proxy=\"RenderViewSettings\"\n"
14007 " property=\"FXAARelativeContrastThreshold\" />\n"
14008 " </Hints>\n"
14009 " </DoubleVectorProperty>\n"
14010 " <DoubleVectorProperty command=\"SetFXAAHardContrastThreshold\"\n"
14011 " default_values=\"0.0625\"\n"
14012 " name=\"FXAAHardContrastThreshold\"\n"
14013 " panel_visibility=\"never\"\n"
14014 " number_of_elements=\"1\">\n"
14015 " <Hints>\n"
14016 " <PropertyLink group=\"settings\"\n"
14017 " proxy=\"RenderViewSettings\"\n"
14018 " property=\"FXAAHardContrastThreshold\" />\n"
14019 " </Hints>\n"
14020 " </DoubleVectorProperty>\n"
14021 " <DoubleVectorProperty command=\"SetFXAASubpixelBlendLimit\"\n"
14022 " default_values=\"0.75\"\n"
14023 " name=\"FXAASubpixelBlendLimit\"\n"
14024 " panel_visibility=\"never\"\n"
14025 " number_of_elements=\"1\">\n"
14026 " <Hints>\n"
14027 " <PropertyLink group=\"settings\"\n"
14028 " proxy=\"RenderViewSettings\"\n"
14029 " property=\"FXAASubpixelBlendLimit\" />\n"
14030 " </Hints>\n"
14031 " </DoubleVectorProperty>\n"
14032 " <DoubleVectorProperty command=\"SetFXAASubpixelContrastThreshold\"\n"
14033 " default_values=\"0.25\"\n"
14034 " name=\"FXAASubpixelContrastThreshold\"\n"
14035 " panel_visibility=\"never\"\n"
14036 " number_of_elements=\"1\">\n"
14037 " <Hints>\n"
14038 " <PropertyLink group=\"settings\"\n"
14039 " proxy=\"RenderViewSettings\"\n"
14040 " property=\"FXAASubpixelContrastThreshold\" />\n"
14041 " </Hints>\n"
14042 " </DoubleVectorProperty>\n"
14043 " <IntVectorProperty command=\"SetFXAAUseHighQualityEndpoints\"\n"
14044 " default_values=\"1\"\n"
14045 " name=\"FXAAUseHighQualityEndpoints\"\n"
14046 " panel_visibility=\"never\"\n"
14047 " number_of_elements=\"1\">\n"
14048 ;
14049
14050 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
14052 " <BooleanDomain name=\"bool\" />\n"
14053 " <Hints>\n"
14054 " <PropertyLink group=\"settings\"\n"
14055 " proxy=\"RenderViewSettings\"\n"
14056 " property=\"FXAAUseHighQualityEndpoints\" />\n"
14057 " </Hints>\n"
14058 " </IntVectorProperty>\n"
14059 " <IntVectorProperty command=\"SetFXAAEndpointSearchIterations\"\n"
14060 " default_values=\"12\"\n"
14061 " name=\"FXAAEndpointSearchIterations\"\n"
14062 " panel_visibility=\"never\"\n"
14063 " number_of_elements=\"1\">\n"
14064 " <Hints>\n"
14065 " <PropertyLink group=\"settings\"\n"
14066 " proxy=\"RenderViewSettings\"\n"
14067 " property=\"FXAAEndpointSearchIterations\" />\n"
14068 " </Hints>\n"
14069 " </IntVectorProperty>\n"
14070 "\n"
14071 " <IntVectorProperty name=\"UseToneMapping\"\n"
14072 " command=\"SetUseToneMapping\"\n"
14073 " default_values=\"0\"\n"
14074 " panel_visibility=\"advanced\"\n"
14075 " number_of_elements=\"1\">\n"
14076 " <BooleanDomain name=\"bool\" />\n"
14077 " <Documentation>\n"
14078 " Enable / Disable tone mapping. Tone mapping is a technique to preserve the colors when the scene is too dark or too bright.\n"
14079 " Refer to the settings for more configuration.\n"
14080 " </Documentation>\n"
14081 " </IntVectorProperty>\n"
14082 " <DoubleVectorProperty name=\"Exposure\"\n"
14083 " command=\"SetExposure\"\n"
14084 " default_values=\"1.0\"\n"
14085 " number_of_elements=\"1\"\n"
14086 " panel_visibility=\"advanced\">\n"
14087 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"10.0\" />\n"
14088 " <Documentation>\n"
14089 " Set the exposure coefficient.\n"
14090 " </Documentation>\n"
14091 " <Hints>\n"
14092 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14093 " <Expression type=\"and\">\n"
14094 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"UseToneMapping\"\n"
14095 " value=\"1\" />\n"
14096 " <Expression type=\"or\">\n"
14097 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14098 " mode=\"visibility\"\n"
14099 " property=\"ToneMappingType\"\n"
14100 " value=\"2\" />\n"
14101 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14102 " mode=\"visibility\"\n"
14103 " property=\"ToneMappingType\"\n"
14104 " value=\"3\" />\n"
14105 " </Expression>\n"
14106 " </Expression>\n"
14107 " </PropertyWidgetDecorator>\n"
14108 " </Hints>\n"
14109 " </DoubleVectorProperty>\n"
14110 " <IntVectorProperty name=\"ToneMappingType\"\n"
14111 " command=\"SetToneMappingType\"\n"
14112 " number_of_elements=\"1\"\n"
14113 " default_values=\"3\"\n"
14114 " panel_visibility=\"never\">\n"
14115 " <Hints>\n"
14116 " <PropertyLink group=\"settings\"\n"
14117 " proxy=\"RenderViewSettings\"\n"
14118 " property=\"ToneMappingType\"/>\n"
14119 " </Hints>\n"
14120 " </IntVectorProperty>\n"
14121 " <DoubleVectorProperty name=\"Contrast\"\n"
14122 " command=\"SetContrast\"\n"
14123 " default_values=\"1.6773\"\n"
14124 " number_of_elements=\"1\"\n"
14125 " panel_visibility=\"never\">\n"
14126 " <Hints>\n"
14127 " <PropertyLink group=\"settings\"\n"
14128 " proxy=\"RenderViewSettings\"\n"
14129 " property=\"Contrast\"/>\n"
14130 " </Hints>\n"
14131 " </DoubleVectorProperty>\n"
14132 " <DoubleVectorProperty name=\"Shoulder\"\n"
14133 " command=\"SetShoulder\"\n"
14134 " default_values=\"0.9714\"\n"
14135 " number_of_elements=\"1\"\n"
14136 " panel_visibility=\"never\">\n"
14137 " <Hints>\n"
14138 " <PropertyLink group=\"settings\"\n"
14139 " proxy=\"RenderViewSettings\"\n"
14140 " property=\"Shoulder\"/>\n"
14141 " </Hints>\n"
14142 " </DoubleVectorProperty>\n"
14143 " <DoubleVectorProperty name=\"MidIn\"\n"
14144 " command=\"SetMidIn\"\n"
14145 " default_values=\"0.18\"\n"
14146 " number_of_elements=\"1\"\n"
14147 " panel_visibility=\"never\">\n"
14148 " <Hints>\n"
14149 " <PropertyLink group=\"settings\"\n"
14150 " proxy=\"RenderViewSettings\"\n"
14151 " property=\"MidIn\"/>\n"
14152 " </Hints>\n"
14153 " </DoubleVectorProperty>\n"
14154 " <DoubleVectorProperty name=\"MidOut\"\n"
14155 " command=\"SetMidOut\"\n"
14156 " default_values=\"0.18\"\n"
14157 " number_of_elements=\"1\"\n"
14158 " panel_visibility=\"never\">\n"
14159 " <Hints>\n"
14160 " <PropertyLink group=\"settings\"\n"
14161 " proxy=\"RenderViewSettings\"\n"
14162 " property=\"MidOut\"/>\n"
14163 " </Hints>\n"
14164 " </DoubleVectorProperty>\n"
14165 " <DoubleVectorProperty name=\"HdrMax\"\n"
14166 " command=\"SetHdrMax\"\n"
14167 " default_values=\"11.0785\"\n"
14168 " number_of_elements=\"1\"\n"
14169 " panel_visibility=\"never\">\n"
14170 " <Hints>\n"
14171 " <PropertyLink group=\"settings\"\n"
14172 " proxy=\"RenderViewSettings\"\n"
14173 " property=\"HdrMax\"/>\n"
14174 " </Hints>\n"
14175 " </DoubleVectorProperty>\n"
14176 " <IntVectorProperty name=\"UseACES\"\n"
14177 " command=\"SetUseACES\"\n"
14178 " default_values=\"1\"\n"
14179 " number_of_elements=\"1\"\n"
14180 " panel_visibility=\"never\">\n"
14181 " <BooleanDomain name=\"bool\" />\n"
14182 " <Hints>\n"
14183 " <PropertyLink group=\"settings\"\n"
14184 " proxy=\"RenderViewSettings\"\n"
14185 " property=\"UseACES\"/>\n"
14186 " </Hints>\n"
14187 " </IntVectorProperty>\n"
14188 " <IntVectorProperty name=\"GenericFilmicPresets\"\n"
14189 " command=\"SetGenericFilmicPresets\"\n"
14190 " number_of_elements=\"1\"\n"
14191 " default_values=\"1\"\n"
14192 " panel_visibility=\"never\">\n"
14193 " <Hints>\n"
14194 " <PropertyLink group=\"settings\"\n"
14195 " proxy=\"RenderViewSettings\"\n"
14196 " property=\"GenericFilmicPresets\"/>\n"
14197 " </Hints>\n"
14198 " </IntVectorProperty>\n"
14199 "\n"
14200 " <IntVectorProperty name=\"UseSSAO\"\n"
14201 " command=\"SetUseSSAO\"\n"
14202 " label=\"Use Ambient Occlusion\"\n"
14203 " default_values=\"0\"\n"
14204 " panel_visibility=\"advanced\"\n"
14205 " number_of_elements=\"1\">\n"
14206 " <BooleanDomain name=\"bool\" />\n"
14207 " <Documentation>\n"
14208 " Enable / Disable screen space ambient occlusion.\n"
14209 " </Documentation>\n"
14210 " </IntVectorProperty>\n"
14211 " <IntVectorProperty name=\"UseSSAODefaultPresets\"\n"
14212 " command=\"SetUseSSAODefaultPresets\"\n"
14213 " default_values=\"1\"\n"
14214 " number_of_elements=\"1\"\n"
14215 " panel_visibility=\"never\">\n"
14216 " <BooleanDomain name=\"bool\" />\n"
14217 " <Hints>\n"
14218 " <PropertyLink group=\"settings\"\n"
14219 " proxy=\"RenderViewSettings\"\n"
14220 " property=\"UseSSAODefaultPresets\"/>\n"
14221 " </Hints>\n"
14222 " </IntVectorProperty>\n"
14223 " <DoubleVectorProperty name=\"Radius\"\n"
14224 " command=\"SetRadius\"\n"
14225 " default_values=\"0.5\"\n"
14226 " number_of_elements=\"1\"\n"
14227 " panel_visibility=\"never\">\n"
14228 " <Hints>\n"
14229 " <PropertyLink group=\"settings\"\n"
14230 " proxy=\"RenderViewSettings\"\n"
14231 " property=\"Radius\"/>\n"
14232 " </Hints>\n"
14233 " </DoubleVectorProperty>\n"
14234 " <DoubleVectorProperty name=\"Bias\"\n"
14235 " command=\"SetBias\"\n"
14236 " default_values=\"0.01\"\n"
14237 " number_of_elements=\"1\"\n"
14238 " panel_visibility=\"never\">\n"
14239 " <Hints>\n"
14240 " <PropertyLink group=\"settings\"\n"
14241 " proxy=\"RenderViewSettings\"\n"
14242 " property=\"Bias\"/>\n"
14243 " </Hints>\n"
14244 " </DoubleVectorProperty>\n"
14245 " <IntVectorProperty name=\"KernelSize\"\n"
14246 " command=\"SetKernelSize\"\n"
14247 " default_values=\"32\"\n"
14248 " number_of_elements=\"1\"\n"
14249 " panel_visibility=\"never\">\n"
14250 " <Hints>\n"
14251 " <PropertyLink group=\"settings\"\n"
14252 " proxy=\"RenderViewSettings\"\n"
14253 " property=\"KernelSize\"/>\n"
14254 " </Hints>\n"
14255 " </IntVectorProperty>\n"
14256 " <IntVectorProperty name=\"Blur\"\n"
14257 " command=\"SetBlur\"\n"
14258 " default_values=\"0\"\n"
14259 " number_of_elements=\"1\"\n"
14260 " panel_visibility=\"never\">\n"
14261 " <BooleanDomain name=\"bool\" />\n"
14262 " <Hints>\n"
14263 " <PropertyLink group=\"settings\"\n"
14264 " proxy=\"RenderViewSettings\"\n"
14265 " property=\"Blur\"/>\n"
14266 " </Hints>\n"
14267 " </IntVectorProperty>\n"
14268 "\n"
14269 " <IntVectorProperty command=\"SetStereoCapableWindow\"\n"
14270 " default_values=\"none\"\n"
14271 " name=\"StereoCapableWindow\"\n"
14272 " number_of_elements=\"1\"\n"
14273 " is_internal=\"1\">\n"
14274 " <BooleanDomain name=\"bool\" />\n"
14275 " </IntVectorProperty>\n"
14276 " <IntVectorProperty command=\"SetStereoRender\"\n"
14277 " default_values=\"0\"\n"
14278 " name=\"StereoRender\"\n"
14279 " number_of_elements=\"1\"\n"
14280 " panel_visibility=\"never\">\n"
14281 " <BooleanDomain name=\"bool\" />\n"
14282 " </IntVectorProperty>\n"
14283 " <IntVectorProperty command=\"SetStereoType\"\n"
14284 " default_values=\"none\"\n"
14285 " name=\"StereoType\"\n"
14286 " number_of_elements=\"1\">\n"
14287 " <Documentation>\n"
14288 " Set the stereo rendering mode to use. In client-server configurations,\n"
14289 " you may also want to set the ServerStereoType.\n"
14290 " </Documentation>\n"
14291 " <EnumerationDomain name=\"enum\">\n"
14292 " <Entry text=\"Crystal Eyes\"\n"
14293 " value=\"1\" />\n"
14294 " <Entry text=\"Red-Blue\"\n"
14295 " value=\"2\" />\n"
14296 " <Entry text=\"Interlaced\"\n"
14297 " value=\"3\" />\n"
14298 " <Entry text=\"Left\"\n"
14299 " value=\"4\" />\n"
14300 " <Entry text=\"Right\"\n"
14301 " value=\"5\" />\n"
14302 " <Entry text=\"Dresden\"\n"
14303 " value=\"6\" />\n"
14304 " <Entry text=\"Anaglyph\"\n"
14305 " value=\"7\" />\n"
14306 " <Entry text=\"Checkerboard\"\n"
14307 " value=\"8\" />\n"
14308 " <Entry text=\"SplitViewportHorizontal\"\n"
14309 " value=\"9\" />\n"
14310 " <Entry text=\"None\"\n"
14311 " value=\"10\" />\n"
14312 " </EnumerationDomain>\n"
14313 " <Hints>\n"
14314 " <NoDefault />\n"
14315 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
14316 " <Property name=\"StereoRender\" />\n"
14317 " </PropertyWidgetDecorator>\n"
14318 " </Hints>\n"
14319 " </IntVectorProperty>\n"
14320 " <IntVectorProperty command=\"SetServerStereoType\"\n"
14321 " default_values=\"0\"\n"
14322 " name=\"ServerStereoType\"\n"
14323 " number_of_elements=\"1\">\n"
14324 " <Documentation>\n"
14325 " This property allows you to set a different stereo mode for the server processes.\n"
14326 " Note that the stereo type selected on the client and server must be *compatible*, i.e.\n"
14327 " if the stereo type on the client side needs 2 renders each frame, the stereo type on the\n"
14328 " server must do exactly the same, otherwise deadlocks may ensue.\n"
14329 " </Documentation>\n"
14330 " <EnumerationDomain name=\"enum\">\n"
14331 " <Entry text=\"Same As Client\" value=\"0\" />\n"
14332 " <Entry text=\"Crystal Eyes\" value=\"1\" />\n"
14333 " <Entry text=\"Red-Blue\" value=\"2\" />\n"
14334 " <Entry text=\"Interlaced\" value=\"3\" />\n"
14335 " <Entry text=\"Left\" value=\"4\" />\n"
14336 " <Entry text=\"Right\" value=\"5\" />\n"
14337 " <Entry text=\"Dresden\" value=\"6\" />\n"
14338 " <Entry text=\"Anaglyph\" value=\"7\" />\n"
14339 " <Entry text=\"Checkerboard\" value=\"8\" />\n"
14340 " <Entry text=\"SplitViewportHorizontal\" value=\"9\" />\n"
14341 " <Entry text=\"None\" value=\"10\" />\n"
14342 " </EnumerationDomain>\n"
14343 " <Hints>\n"
14344 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
14345 " <Property name=\"StereoRender\" />\n"
14346 " </PropertyWidgetDecorator>\n"
14347 " </Hints>\n"
14348 " </IntVectorProperty>\n"
14349 " <IntVectorProperty command=\"SetMultiSamples\"\n"
14350 " default_values=\"0\"\n"
14351 " name=\"MultiSamples\"\n"
14352 " panel_visibility=\"never\"\n"
14353 " number_of_elements=\"1\">\n"
14354 " </IntVectorProperty>\n"
14355 " <IntVectorProperty command=\"SetAlphaBitPlanes\"\n"
14356 " default_values=\"1\"\n"
14357 " name=\"AlphaBitPlanes\"\n"
14358 " panel_visibility=\"never\"\n"
14359 " number_of_elements=\"1\">\n"
14360 " <BooleanDomain name=\"bool\" />\n"
14361 " </IntVectorProperty>\n"
14362 " <IntVectorProperty command=\"SetStencilCapable\"\n"
14363 " default_values=\"1\"\n"
14364 " name=\"StencilCapable\"\n"
14365 " panel_visibility=\"never\"\n"
14366 " number_of_elements=\"1\">\n"
14367 " <BooleanDomain name=\"bool\" />\n"
14368 " </IntVectorProperty>\n"
14369 " <ProxyProperty command=\"AddRepresentation\"\n"
14370 " is_internal=\"1\"\n"
14371 " name=\"HiddenRepresentations\"\n"
14372 " remove_command=\"RemoveRepresentation\"\n"
14373 " repeatable=\"1\">\n"
14374 " <Documentation>This property is meant for adding/removing\n"
14375 " representation secretly. e.g. 3D widgets etc. This property is not\n"
14376 " saved in states nor it recorded by undo-redo.</Documentation>\n"
14377 " </ProxyProperty>\n"
14378 " <ProxyProperty command=\"AddPropToRenderer\"\n"
14379 " is_internal=\"1\"\n"
14380 " name=\"HiddenProps\"\n"
14381 " remove_command=\"RemovePropFromRenderer\"\n"
14382 " repeatable=\"1\">\n"
14383 " <Documentation>This property is meant for adding/removing props\n"
14384 " secretly. e.g. 3D widgets etc. This property is not saved in states nor\n"
14385 " it recorded by undo-redo.</Documentation>\n"
14386 " </ProxyProperty>\n"
14387 " <SubProxy>\n"
14388 ;
14389
14390 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
14392 " <Proxy name=\"ActiveCamera\"\n"
14393 " proxygroup=\"camera\"\n"
14394 " proxyname=\"Camera\"></Proxy>\n"
14395 " <ExposedProperties>\n"
14396 " <Property name=\"CameraPositionInfo\" panel_visibility=\"never\"/>\n"
14397 " <Property name=\"CameraPosition\" panel_visibility=\"never\"/>\n"
14398 " <Property name=\"CameraFocalPointInfo\" panel_visibility=\"never\"/>\n"
14399 " <Property name=\"CameraFocalPoint\" panel_visibility=\"never\"/>\n"
14400 " <Property name=\"CameraViewUpInfo\" panel_visibility=\"never\"/>\n"
14401 " <Property name=\"CameraViewUp\" panel_visibility=\"never\"/>\n"
14402 " <Property name=\"CameraViewAngleInfo\" panel_visibility=\"never\"/>\n"
14403 " <Property name=\"CameraViewAngle\" panel_visibility=\"never\"/>\n"
14404 " <Property name=\"CameraFocalDiskInfo\" panel_visibility=\"never\"/>\n"
14405 " <Property name=\"CameraFocalDisk\" panel_visibility=\"never\"/>\n"
14406 " <Property name=\"CameraFocalDistanceInfo\" panel_visibility=\"never\"/>\n"
14407 " <Property name=\"CameraFocalDistance\" panel_visibility=\"never\"/>\n"
14408 " <Property name=\"CameraParallelScale\" panel_visibility=\"never\"/>\n"
14409 " <Property name=\"CameraParallelScaleInfo\" panel_visibility=\"never\"/>\n"
14410 " <Property name=\"EyeAngle\" panel_visibility=\"never\"/>\n"
14411 " <Property name=\"EyeTransformMatrix\" />\n"
14412 " <Property name=\"ModelTransformMatrix\" />\n"
14413 " </ExposedProperties>\n"
14414 " </SubProxy>\n"
14415 " <IntVectorProperty command=\"SetParallelProjection\"\n"
14416 " default_values=\"0\"\n"
14417 " ignore_synchronization=\"1\"\n"
14418 " name=\"CameraParallelProjection\"\n"
14419 " number_of_elements=\"1\"\n"
14420 " panel_visibility=\"default\">\n"
14421 " <BooleanDomain name=\"bool\" />\n"
14422 " <Documentation>\n"
14423 " Enable/disable parallel projection mode.\n"
14424 " </Documentation>\n"
14425 " </IntVectorProperty>\n"
14426 " <ProxyProperty name=\"LegendGrid\"\n"
14427 " command=\"SetLegendGridActor\"\n"
14428 " panel_widget=\"proxy_editor\">\n"
14429 " <ProxyListDomain name=\"proxy_list\">\n"
14430 " <Proxy group=\"annotations\" name=\"LegendGridActor\" />\n"
14431 " </ProxyListDomain>\n"
14432 " <Hints>\n"
14433 " <ProxyEditorPropertyWidget property=\"Visibility\">\n"
14434 " <!-- UI hint: pqProxyEditorPropertyWidget will display a checkbox\n"
14435 " for the \"Visibility\" property next to the \"Edit\" button -->\n"
14436 " </ProxyEditorPropertyWidget>\n"
14437 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14438 " property=\"CameraParallelProjection\" value=\"1\" />\n"
14439 " </Hints>\n"
14440 " </ProxyProperty>\n"
14441 "\n"
14442 " <ProxyProperty name=\"PolarGrid\"\n"
14443 " command=\"SetPolarGridActor\"\n"
14444 " panel_widget=\"proxy_editor\">\n"
14445 " <ProxyListDomain name=\"proxy_list\">\n"
14446 " <Proxy group=\"annotations\" name=\"PolarGridActor\" />\n"
14447 " </ProxyListDomain>\n"
14448 " <Hints>\n"
14449 " <ProxyEditorPropertyWidget property=\"Visibility\">\n"
14450 " <!-- UI hint: pqProxyEditorPropertyWidget will display a checkbox\n"
14451 " for the \"Visibility\" property next to the \"Edit\" button -->\n"
14452 " </ProxyEditorPropertyWidget>\n"
14453 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14454 " property=\"CameraParallelProjection\" value=\"1\" />\n"
14455 " </Hints>\n"
14456 " </ProxyProperty>\n"
14457 "\n"
14458 " <IntVectorProperty command=\"SetUseRenderViewSettingsForBackground\"\n"
14459 " name=\"UseColorPaletteForBackground\"\n"
14460 " number_of_elements=\"1\"\n"
14461 " default_values=\"1\">\n"
14462 " <BooleanDomain name=\"bool\" />\n"
14463 " <Documentation>\n"
14464 " When set, the view uses the background color settings as specified in\n"
14465 " global color palette.\n"
14466 " </Documentation>\n"
14467 " </IntVectorProperty>\n"
14468 " <IntVectorProperty command=\"SetBackgroundColorMode\"\n"
14469 " name=\"BackgroundColorMode\"\n"
14470 " number_of_elements=\"1\"\n"
14471 " default_values=\"0\">\n"
14472 " <EnumerationDomain name=\"enum\">\n"
14473 " <Entry text=\"Single Color\" value=\"0\" />\n"
14474 " <Entry text=\"Gradient\" value=\"1\" />\n"
14475 " <Entry text=\"Texture\" value=\"2\" />\n"
14476 " <Entry text=\"Skybox\" value=\"3\" />\n"
14477 " <Entry text=\"Stereo Skybox\" value=\"4\" />\n"
14478 " </EnumerationDomain>\n"
14479 " <Documentation>\n"
14480 " Select the background for the view.\n"
14481 " </Documentation>\n"
14482 " <Hints>\n"
14483 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14484 " property=\"UseColorPaletteForBackground\" values=\"0\" />\n"
14485 " </Hints>\n"
14486 " </IntVectorProperty>\n"
14487 " <ProxyProperty command=\"SetBackgroundTexture\"\n"
14488 " name=\"BackgroundTexture\" panel_widget=\"texture_selector\">\n"
14489 " <ProxyGroupDomain name=\"groups\">\n"
14490 " <Group name=\"textures\" />\n"
14491 " </ProxyGroupDomain>\n"
14492 " <Hints>\n"
14493 " <!-- hide widget unless mode is \"Texture\" or \"Skybox\" -->\n"
14494 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\"\n"
14495 " property=\"BackgroundColorMode\" values=\"2 3 4\" />\n"
14496 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14497 " property=\"UseColorPaletteForBackground\" values=\"0\" />\n"
14498 " </Hints>\n"
14499 " </ProxyProperty>\n"
14500 " <DoubleVectorProperty command=\"SetBackground2\"\n"
14501 " default_values=\"0 0 0.165\"\n"
14502 " name=\"Background2\"\n"
14503 " label=\"Background 2\"\n"
14504 " panel_widget=\"color_selector\"\n"
14505 " number_of_elements=\"3\">\n"
14506 " <DoubleRangeDomain max=\"1 1 1\" min=\"0 0 0\" name=\"range\" />\n"
14507 " <Hints>\n"
14508 " <!-- hide widget unless mode is \"Gradient\" -->\n"
14509 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\"\n"
14510 " property=\"BackgroundColorMode\" value=\"1\" />\n"
14511 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14512 " property=\"UseColorPaletteForBackground\" values=\"0\" />\n"
14513 " </Hints>\n"
14514 " <Documentation>\n"
14515 " Specify the color to use for the upper half of the viewport when using **Gradient**\n"
14516 " background color mode.\n"
14517 " </Documentation>\n"
14518 " </DoubleVectorProperty>\n"
14519 " <DoubleVectorProperty command=\"SetBackground\"\n"
14520 " default_values=\"0.329 0.349 0.427\"\n"
14521 " name=\"Background\"\n"
14522 " panel_widget=\"color_selector\"\n"
14523 " number_of_elements=\"3\">\n"
14524 " <DoubleRangeDomain max=\"1 1 1\"\n"
14525 " min=\"0 0 0\"\n"
14526 " name=\"range\" />\n"
14527 " <Hints>\n"
14528 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14529 " property=\"UseColorPaletteForBackground\" values=\"0\" />\n"
14530 " </Hints>\n"
14531 " </DoubleVectorProperty>\n"
14532 " <IntVectorProperty command=\"SetUseEnvironmentLighting\"\n"
14533 " default_values=\"0\"\n"
14534 " name=\"UseEnvironmentLighting\"\n"
14535 " number_of_elements=\"1\">\n"
14536 " <Documentation>\n"
14537 " Enable skybox light contribution. This feature is only compatible with PBR interpolation.\n"
14538 " </Documentation>\n"
14539 " <BooleanDomain name=\"bool\" />\n"
14540 " <Hints>\n"
14541 " <!-- hide widget unless mode is \"Skybox\" -->\n"
14542 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\"\n"
14543 " property=\"BackgroundColorMode\" value=\"3\" />\n"
14544 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\"\n"
14545 " property=\"UseColorPaletteForBackground\" values=\"0\" />\n"
14546 " </Hints>\n"
14547 " </IntVectorProperty>\n"
14548 " <Property\n"
14549 " name=\"CaptureZBuffer\"\n"
14550 " command=\"CaptureZBuffer\"\n"
14551 " >\n"
14552 " <Documentation>A helper function to get the Z buffer from\n"
14553 " a RenderView.</Documentation>\n"
14554 " </Property>\n"
14555 " <DoubleVectorProperty\n"
14556 " command=\"SetMaxClipBounds\"\n"
14557 " default_values=\"0.0 -1.0 0.0 -1.0 0.0 -1.0\"\n"
14558 " name=\"MaxClipBounds\"\n"
14559 " number_of_elements=\"6\"\n"
14560 " argument_is_array=\"1\"\n"
14561 " animateable=\"0\"\n"
14562 " >\n"
14563 " <DoubleRangeDomain name=\"range\" />\n"
14564 " <Documentation>Set the most conservative clipping range.</Documentation>\n"
14565 " </DoubleVectorProperty>\n"
14566 " <IntVectorProperty\n"
14567 " name=\"LockBounds\"\n"
14568 " command=\"SetLockBounds\"\n"
14569 " default_values=\"0\"\n"
14570 " animateable=\"0\"\n"
14571 " number_of_elements=\"1\"\n"
14572 " >\n"
14573 " <BooleanDomain name=\"bool\" />\n"
14574 " <Documentation>A helper function to force consistent Z buffer\n"
14575 " captures from a RenderView.</Documentation>\n"
14576 " </IntVectorProperty>\n"
14577 " <IntVectorProperty name=\"EnableOSPRay\"\n"
14578 " label=\"Enable Ray Tracing\"\n"
14579 " command=\"SetEnableOSPRay\"\n"
14580 " default_values=\"0\"\n"
14581 " animateable=\"0\"\n"
14582 " number_of_elements=\"1\">\n"
14583 " <BooleanDomain name=\"bool\" />\n"
14584 " <Documentation>Switches between rasterization and ray tracing.</Documentation>\n"
14585 " <Hints>\n"
14586 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14587 " </Hints>\n"
14588 " </IntVectorProperty>\n"
14589 " <StringVectorProperty name=\"OSPRayRendererType\"\n"
14590 " command=\"SetOSPRayRendererType\"\n"
14591 " label=\"Back End\"\n"
14592 " default_values=\"scivis\"\n"
14593 " number_of_elements=\"1\">\n"
14594 " <RendererDomain name=\"list\">\n"
14595 " </RendererDomain>\n"
14596 " <Documentation>Selects a specific ray traced rendering engine.</Documentation>\n"
14597 " <Hints>\n"
14598 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14599 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14600 " mode=\"visibility\"\n"
14601 " property=\"EnableOSPRay\"\n"
14602 " values=\"1\" />\n"
14603 " <WarnOnPropertyChange onlyonce=\"true\">\n"
14604 " <Text title=\"Warning: Potentially slow operation\">\n"
14605 "OSPRay pathtracer may need to transfer default materials from client to server. This operation can take a few seconds in client-server mode.\n"
14606 " </Text>\n"
14607 " </WarnOnPropertyChange>\n"
14608 " </Hints>\n"
14609 " </StringVectorProperty>\n"
14610 " <IntVectorProperty\n"
14611 " name=\"Shadows\"\n"
14612 " command=\"SetShadows\"\n"
14613 " default_values=\"0\"\n"
14614 " animateable=\"0\"\n"
14615 " number_of_elements=\"1\">\n"
14616 " <BooleanDomain name=\"bool\" />\n"
14617 " <Documentation>Controls whether OSPRay raycaster back end casts shadow rays\n"
14618 " or not.</Documentation>\n"
14619 " <Hints>\n"
14620 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14621 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14622 " <Expression type=\"and\">\n"
14623 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14624 " mode=\"visibility\"\n"
14625 " property=\"EnableOSPRay\"\n"
14626 " values=\"1\" />\n"
14627 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14628 " <Property name=\"OSPRayRendererType\" function=\"equals\" value=\"OSPRay raycaster\"/>\n"
14629 " </PropertyWidgetDecorator>\n"
14630 " </Expression>\n"
14631 " </PropertyWidgetDecorator>\n"
14632 " </Hints>\n"
14633 " </IntVectorProperty>\n"
14634 " <IntVectorProperty\n"
14635 " name=\"AmbientSamples\"\n"
14636 " command=\"SetAmbientOcclusionSamples\"\n"
14637 " default_values=\"0\"\n"
14638 " animateable=\"0\"\n"
14639 " number_of_elements=\"1\">\n"
14640 " <IntRangeDomain\n"
14641 " min=\"0\"\n"
14642 " name=\"range\"/>\n"
14643 " <Documentation>Sets the number of occlusion query rays that\n"
14644 " OSPRay raycaster sends at each intersection.</Documentation>\n"
14645 " <Hints>\n"
14646 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14647 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14648 " <Expression type=\"and\">\n"
14649 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14650 " mode=\"visibility\"\n"
14651 " property=\"EnableOSPRay\"\n"
14652 " values=\"1\" />\n"
14653 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14654 " <Property name=\"OSPRayRendererType\" function=\"equals\" value=\"OSPRay raycaster\"/>\n"
14655 " </PropertyWidgetDecorator>\n"
14656 " </Expression>\n"
14657 " </PropertyWidgetDecorator>\n"
14658 " </Hints>\n"
14659 " </IntVectorProperty>\n"
14660 " <IntVectorProperty\n"
14661 " name=\"SamplesPerPixel\"\n"
14662 " command=\"SetSamplesPerPixel\"\n"
14663 " default_values=\"1\"\n"
14664 " animateable=\"0\"\n"
14665 " number_of_elements=\"1\">\n"
14666 " <IntRangeDomain\n"
14667 " min=\"1\"\n"
14668 " name=\"range\"/>\n"
14669 " <Documentation>Set the number of primary rays that ray tracers\n"
14670 " shoot per pixel.</Documentation>\n"
14671 " <Hints>\n"
14672 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14673 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14674 " mode=\"visibility\"\n"
14675 " property=\"EnableOSPRay\"\n"
14676 " values=\"1\" />\n"
14677 " </Hints>\n"
14678 " </IntVectorProperty>\n"
14679 " <IntVectorProperty\n"
14680 " name=\"MaxFrames\"\n"
14681 " label=\"Progressive Passes\"\n"
14682 " command=\"SetMaxFrames\"\n"
14683 " default_values=\"1\"\n"
14684 " animateable=\"0\"\n"
14685 " number_of_elements=\"1\">\n"
14686 " <IntRangeDomain\n"
14687 " min=\"1\"\n"
14688 " name=\"range\"/>\n"
14689 " <Documentation>Set the number of render passes ray tracers take to\n"
14690 " improve image quality. Note, this requires turning on the\n"
14691 " 'Enable Streaming' setting in Edit->Preferences/Settings.</Documentation>\n"
14692 " <Hints>\n"
14693 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14694 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14695 " mode=\"visibility\"\n"
14696 " property=\"EnableOSPRay\"\n"
14697 " values=\"1\" />\n"
14698 " </Hints>\n"
14699 " </IntVectorProperty>\n"
14700 " <IntVectorProperty\n"
14701 " name=\"RouletteDepth\"\n"
14702 " command=\"SetRouletteDepth\"\n"
14703 " default_values=\"5\"\n"
14704 " animateable=\"0\"\n"
14705 " number_of_elements=\"1\">\n"
14706 " <IntRangeDomain\n"
14707 " min=\"0\"\n"
14708 " name=\"range\"/>\n"
14709 " <Documentation>Set the path traced recursion depth at which to start Russian roulette termination.</Documentation>\n"
14710 " <Hints>\n"
14711 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14712 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14713 ;
14714
14715 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
14717 " <Expression type=\"and\">\n"
14718 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14719 " mode=\"visibility\"\n"
14720 " property=\"EnableOSPRay\"\n"
14721 " values=\"1\" />\n"
14722 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14723 " <Property name=\"OSPRayRendererType\" function=\"equals\" value=\"OSPRay pathtracer\"/>\n"
14724 " </PropertyWidgetDecorator>\n"
14725 " </Expression>\n"
14726 " </PropertyWidgetDecorator>\n"
14727 " </Hints>\n"
14728 " </IntVectorProperty>\n"
14729 " <DoubleVectorProperty\n"
14730 " name=\"VolumeAnisotropy\"\n"
14731 " default_values=\"0.0\"\n"
14732 " panel_visibility=\"never\"\n"
14733 " animateable=\"0\"\n"
14734 " number_of_elements=\"1\">\n"
14735 " <Documentation>DEPRECATED_IN_5.11 (Use SetAnisotropy of vtkImageVolumeRepresentation instead):\n"
14736 " Set the tendency for light to scatter back towards (negative) or away from (positive) the light source within path traced volumes.</Documentation>\n"
14737 " </DoubleVectorProperty>\n"
14738 " <IntVectorProperty\n"
14739 " name=\"Denoise\"\n"
14740 " command=\"SetDenoise\"\n"
14741 " default_values=\"1\"\n"
14742 " animateable=\"0\"\n"
14743 " number_of_elements=\"1\">\n"
14744 " <BooleanDomain name=\"bool\" />\n"
14745 " <Documentation>Controls whether to denoise images. This option will have no effect without a denoiser library and until progressive passes or samples per pixel exceeds four.</Documentation>\n"
14746 " <Hints>\n"
14747 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14748 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14749 " mode=\"visibility\"\n"
14750 " property=\"EnableOSPRay\"\n"
14751 " values=\"1\" />\n"
14752 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14753 " <Expression type=\"or\">\n"
14754 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14755 " <Property name=\"MaxFrames\" function=\"greaterthan\" value=\"3\"/>\n"
14756 " </PropertyWidgetDecorator>\n"
14757 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14758 " <Property name=\"SamplesPerPixel\" function=\"greaterthan\" value=\"3\" />\n"
14759 " </PropertyWidgetDecorator>\n"
14760 " </Expression>\n"
14761 " </PropertyWidgetDecorator>\n"
14762 " </Hints>\n"
14763 " </IntVectorProperty>\n"
14764 " <DoubleVectorProperty\n"
14765 " name=\"LightScale\"\n"
14766 " command=\"SetLightScale\"\n"
14767 " default_values=\"1.0\"\n"
14768 " animateable=\"0\"\n"
14769 " number_of_elements=\"1\">\n"
14770 " <DoubleRangeDomain\n"
14771 " min=\"0.0\"\n"
14772 " name=\"range\"/>\n"
14773 " <Documentation>Diminish or amplify all lights in the scene.</Documentation>\n"
14774 " <Hints>\n"
14775 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14776 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14777 " mode=\"visibility\"\n"
14778 " property=\"EnableOSPRay\"\n"
14779 " values=\"1\" />\n"
14780 " </Hints>\n"
14781 " </DoubleVectorProperty>\n"
14782 " <IntVectorProperty\n"
14783 " name=\"OSPRayTemporalCacheSize\"\n"
14784 " label=\"Temporal Cache Size\"\n"
14785 " command=\"SetTimeCacheSize\"\n"
14786 " default_values=\"0\"\n"
14787 " animateable=\"0\"\n"
14788 " number_of_elements=\"1\">\n"
14789 " <IntRangeDomain\n"
14790 " min=\"0\"\n"
14791 " name=\"range\"/>\n"
14792 " <Documentation>Set the size of the timestep cache that speeds up flip book animation in ray tracers.</Documentation>\n"
14793 " <Hints>\n"
14794 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14795 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14796 " mode=\"visibility\"\n"
14797 " property=\"EnableOSPRay\"\n"
14798 " values=\"1\" />\n"
14799 " </Hints>\n"
14800 " </IntVectorProperty>\n"
14801 " <IntVectorProperty command=\"SetBackgroundMode\"\n"
14802 " label=\"Background mode\"\n"
14803 " default_values=\"2\"\n"
14804 " name=\"BackgroundMode\"\n"
14805 " number_of_elements=\"1\">\n"
14806 " <EnumerationDomain name=\"enum\">\n"
14807 " <!--<Entry text=\"None\"\n"
14808 " value=\"0\" /> Disabled since needs more work. -->\n"
14809 " <Entry text=\"Backplate\"\n"
14810 " value=\"1\" />\n"
14811 " <Entry text=\"Environment\"\n"
14812 " value=\"2\" />\n"
14813 " <Entry text=\"Both\"\n"
14814 " value=\"3\" />\n"
14815 " </EnumerationDomain>\n"
14816 " <Documentation>\n"
14817 " Background behavior for path tracers. Backplate does not move or affect materials. Environment does.\n"
14818 " </Documentation>\n"
14819 " <Hints>\n"
14820 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14821 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14822 " <Expression type=\"and\">\n"
14823 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14824 " mode=\"visibility\"\n"
14825 " property=\"EnableOSPRay\"\n"
14826 " values=\"1\" />\n"
14827 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14828 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14829 " </PropertyWidgetDecorator>\n"
14830 " </Expression>\n"
14831 " </PropertyWidgetDecorator>\n"
14832 " </Hints>\n"
14833 " </IntVectorProperty>\n"
14834 " <DoubleVectorProperty\n"
14835 " name=\"BackgroundNorth\"\n"
14836 " label=\"Environment North\"\n"
14837 " command=\"SetBackgroundNorth\"\n"
14838 " default_values=\"0.0 1.0 0.0\"\n"
14839 " animateable=\"0\"\n"
14840 " number_of_elements=\"3\">\n"
14841 " <Documentation>Sets north pole for gradient and image environmental background in path tracers.</Documentation>\n"
14842 " <Hints>\n"
14843 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14844 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14845 " <Expression type=\"and\">\n"
14846 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14847 " mode=\"visibility\"\n"
14848 " property=\"EnableOSPRay\"\n"
14849 " values=\"1\" />\n"
14850 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14851 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14852 " </PropertyWidgetDecorator>\n"
14853 " </Expression>\n"
14854 " </PropertyWidgetDecorator>\n"
14855 " </Hints>\n"
14856 " </DoubleVectorProperty>\n"
14857 " <DoubleVectorProperty\n"
14858 " name=\"BackgroundEast\"\n"
14859 " command=\"SetBackgroundEast\"\n"
14860 " label=\"Environment East\"\n"
14861 " default_values=\"1.0 0.0 0.0\"\n"
14862 " animateable=\"0\"\n"
14863 " number_of_elements=\"3\">\n"
14864 " <Documentation>Sets east direction for image environmental background in path tracers.</Documentation>\n"
14865 " <Hints>\n"
14866 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14867 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14868 " <Expression type=\"and\">\n"
14869 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14870 " mode=\"visibility\"\n"
14871 " property=\"EnableOSPRay\"\n"
14872 " values=\"1\" />\n"
14873 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14874 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14875 " </PropertyWidgetDecorator>\n"
14876 " </Expression>\n"
14877 " </PropertyWidgetDecorator>\n"
14878 " </Hints>\n"
14879 " </DoubleVectorProperty>\n"
14880 " <DoubleVectorProperty command=\"SetEnvironmentalBG\"\n"
14881 " default_values=\"0.329 0.349 0.427\"\n"
14882 " name=\"EnvironmentalBG\"\n"
14883 " panel_widget=\"color_selector_with_palette\"\n"
14884 " number_of_elements=\"3\">\n"
14885 " <DoubleRangeDomain max=\"1 1 1\"\n"
14886 " min=\"0 0 0\"\n"
14887 " name=\"range\" />\n"
14888 " <Hints>\n"
14889 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14890 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14891 " <Expression type=\"and\">\n"
14892 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14893 " mode=\"visibility\"\n"
14894 " property=\"EnableOSPRay\"\n"
14895 " values=\"1\" />\n"
14896 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14897 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14898 " </PropertyWidgetDecorator>\n"
14899 " </Expression>\n"
14900 " </PropertyWidgetDecorator>\n"
14901 " </Hints>\n"
14902 " </DoubleVectorProperty>\n"
14903 " <DoubleVectorProperty command=\"SetEnvironmentalBG2\"\n"
14904 " default_values=\"0 0 0.165\"\n"
14905 " name=\"EnvironmentalBG2\"\n"
14906 " panel_widget=\"color_selector\"\n"
14907 " number_of_elements=\"3\">\n"
14908 " <DoubleRangeDomain max=\"1 1 1\"\n"
14909 " min=\"0 0 0\"\n"
14910 " name=\"range\" />\n"
14911 " <Hints>\n"
14912 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14913 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14914 " <Expression type=\"and\">\n"
14915 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14916 " mode=\"visibility\"\n"
14917 " property=\"EnableOSPRay\"\n"
14918 " values=\"1\" />\n"
14919 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14920 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14921 " </PropertyWidgetDecorator>\n"
14922 " </Expression>\n"
14923 " </PropertyWidgetDecorator>\n"
14924 " </Hints>\n"
14925 " </DoubleVectorProperty>\n"
14926 " <IntVectorProperty command=\"SetGradientEnvironmentalBG\"\n"
14927 " default_values=\"0\"\n"
14928 " name=\"UseGradientEnvironmentalBG\"\n"
14929 " number_of_elements=\"1\">\n"
14930 " <BooleanDomain name=\"bool\" />\n"
14931 " <Hints>\n"
14932 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14933 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14934 " <Expression type=\"and\">\n"
14935 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14936 " mode=\"visibility\"\n"
14937 " property=\"EnableOSPRay\"\n"
14938 " values=\"1\" />\n"
14939 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14940 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14941 " </PropertyWidgetDecorator>\n"
14942 " </Expression>\n"
14943 " </PropertyWidgetDecorator>\n"
14944 " </Hints>\n"
14945 " </IntVectorProperty>\n"
14946 " <IntVectorProperty command=\"SetTexturedEnvironmentalBG\"\n"
14947 " default_values=\"0\"\n"
14948 " name=\"UseTexturedEnvironmentalBG\"\n"
14949 " number_of_elements=\"1\">\n"
14950 " <BooleanDomain name=\"bool\" />\n"
14951 " <Hints>\n"
14952 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14953 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14954 " <Expression type=\"and\">\n"
14955 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14956 " mode=\"visibility\"\n"
14957 " property=\"EnableOSPRay\"\n"
14958 " values=\"1\" />\n"
14959 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14960 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14961 " </PropertyWidgetDecorator>\n"
14962 " </Expression>\n"
14963 " </PropertyWidgetDecorator>\n"
14964 " </Hints>\n"
14965 " </IntVectorProperty>\n"
14966 " <ProxyProperty command=\"SetEnvironmentalBGTexture\"\n"
14967 " name=\"EnvironmentalBGTexture\"\n"
14968 " panel_widget=\"texture_selector\">\n"
14969 " <ProxyGroupDomain name=\"groups\">\n"
14970 " <Group name=\"textures\" />\n"
14971 " </ProxyGroupDomain>\n"
14972 " <Hints>\n"
14973 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
14974 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
14975 " <Expression type=\"and\">\n"
14976 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
14977 " mode=\"visibility\"\n"
14978 " property=\"EnableOSPRay\"\n"
14979 " values=\"1\" />\n"
14980 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
14981 " <Property name=\"OSPRayRendererType\" function=\"contains\" value=\"pathtracer\"/>\n"
14982 " </PropertyWidgetDecorator>\n"
14983 " </Expression>\n"
14984 " </PropertyWidgetDecorator>\n"
14985 " </Hints>\n"
14986 " </ProxyProperty>\n"
14987 " <ProxyProperty\n"
14988 " name=\"AdditionalLights\"\n"
14989 " command=\"AddLight\"\n"
14990 " remove_command=\"RemoveLight\"\n"
14991 " repeatable=\"1\">\n"
14992 " </ProxyProperty>\n"
14993 " <ProxyProperty command=\"SetMaterialLibrary\"\n"
14994 " name=\"OSPRayMaterialLibrary\"\n"
14995 " label=\"OSPRay Material Library\"\n"
14996 " number_of_elements=\"1\"\n"
14997 " panel_visibility=\"never\"\n"
14998 " default_values=\"None\">\n"
14999 " <Documentation>Container for a set of material specifications.</Documentation>\n"
15000 " </ProxyProperty>\n"
15001 " <ProxyProperty command=\"SetHardwareSelector\"\n"
15002 " name=\"SetHardwareSelector\">\n"
15003 " <ProxyGroupDomain name=\"groups\">\n"
15004 " <Group name=\"HardwareSelectors\" />\n"
15005 " </ProxyGroupDomain>\n"
15006 " <Documentation>Set the hardware selector hold by the view.</Documentation>\n"
15007 " </ProxyProperty>\n"
15008 " <PropertyGroup label=\"Orientation Axes\">\n"
15009 " <Property name=\"OrientationAxesVisibility\"/>\n"
15010 " <Property name=\"OrientationAxesInteractivity\"/>\n"
15011 " <Property name=\"OrientationAxesLabelColor\"/>\n"
15012 " <Property name=\"OrientationAxesOutlineColor\"/>\n"
15013 " </PropertyGroup>\n"
15014 " <PropertyGroup label=\"Camera Orientation Widget\">\n"
15015 " <Property name=\"CameraOrientationWidgetVisibility\"/>\n"
15016 " <Property name=\"CameraOrientationWidgetSize\"/>\n"
15017 " <Property name=\"CameraOrientationWidgetAnchor\"/>\n"
15018 " </PropertyGroup>\n"
15019 " <PropertyGroup label=\"Render Passes\">\n"
15020 " <Property name=\"UseToneMapping\"/>\n"
15021 " <Property name=\"Exposure\"/>\n"
15022 " <Property name=\"UseSSAO\"/>\n"
15023 " </PropertyGroup>\n"
15024 " <PropertyGroup name=\"Lights\"\n"
15025 ;
15026
15027 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
15029 " label=\"Lights\"\n"
15030 " panel_visibility=\"never\">\n"
15031 " <!-- Light Kit -->\n"
15032 " <Property name=\"UseLight\"/>\n"
15033 " <!-- Key Light -->\n"
15034 " <Property name=\"KeyLightWarmth\"/>\n"
15035 " <Property name=\"KeyLightIntensity\"/>\n"
15036 " <Property name=\"KeyLightElevation\"/>\n"
15037 " <Property name=\"KeyLightAzimuth\"/>\n"
15038 " <!-- Fill Light -->\n"
15039 " <Property name=\"FillLightWarmth\"/>\n"
15040 " <Property name=\"FillLightK:F Ratio\"/>\n"
15041 " <Property name=\"FillLightElevation\"/>\n"
15042 " <Property name=\"FillLightAzimuth\"/>\n"
15043 " <!-- Back Light -->\n"
15044 " <Property name=\"BackLightWarmth\"/>\n"
15045 " <Property name=\"BackLightK:B Ratio\"/>\n"
15046 " <Property name=\"BackLightElevation\"/>\n"
15047 " <Property name=\"BackLightAzimuth\"/>\n"
15048 " <!-- Head Light -->\n"
15049 " <Property name=\"HeadLightWarmth\"/>\n"
15050 " <Property name=\"HeadLightK:H Ratio\"/>\n"
15051 " <Property name=\"MaintainLuminance\"/>\n"
15052 " </PropertyGroup>\n"
15053 " <PropertyGroup label=\"Background\" >\n"
15054 " <Property name=\"UseColorPaletteForBackground\" />\n"
15055 " <Property name=\"BackgroundColorMode\" />\n"
15056 " <Property name=\"Background2\"/>\n"
15057 " <Property name=\"Background\"/>\n"
15058 " <Property name=\"BackgroundTexture\"/>\n"
15059 " <Property name=\"UseEnvironmentLighting\"/>\n"
15060 " </PropertyGroup>\n"
15061 " <PropertyGroup label=\"Stereo\">\n"
15062 " <Property name=\"StereoCapableWindow\" />\n"
15063 " <Property name=\"StereoRender\" />\n"
15064 " <Property name=\"StereoType\" />\n"
15065 " <Property name=\"ServerStereoType\" />\n"
15066 " </PropertyGroup>\n"
15067 " <PropertyGroup label=\"Cinema Export\"\n"
15068 " panel_visibility=\"never\">\n"
15069 " <Property name=\"CaptureZBuffer\"/>\n"
15070 " <Property name=\"MaxClipBounds\"/>\n"
15071 " <Property name=\"LockBounds\"/>\n"
15072 " </PropertyGroup>\n"
15073 " <PropertyGroup label=\"Ray Traced Rendering\"\n"
15074 " panel_visibility=\"advanced\">\n"
15075 " <Property name=\"EnableOSPRay\"/>\n"
15076 " <Property name=\"Shadows\"/>\n"
15077 " <Property name=\"OSPRayRendererType\"/>\n"
15078 " <Property name=\"AmbientSamples\"/>\n"
15079 " <Property name=\"SamplesPerPixel\"/>\n"
15080 " <Property name=\"RouletteDepth\"/>\n"
15081 " <Property name=\"MaxFrames\"/>\n"
15082 " <Property name=\"Denoise\"/>\n"
15083 " <Property name=\"LightScale\"/>\n"
15084 " <Property name=\"OSPRayTemporalCacheSize\"/>\n"
15085 " <Property name=\"BackgroundNorth\"/>\n"
15086 " <Property name=\"BackgroundEast\"/>\n"
15087 " <Property name=\"BackgroundMode\"/>\n"
15088 " </PropertyGroup>\n"
15089 " <PropertyGroup label=\"Path Traced Environment\" panel_widget=\"EnvironmentalBGEditor\" panel_visibility=\"default\">\n"
15090 " <Property name=\"EnvironmentalBG\"/>\n"
15091 " <Property name=\"EnvironmentalBG2\"/>\n"
15092 " <Property name=\"UseGradientEnvironmentalBG\"/>\n"
15093 " <Property name=\"UseTexturedEnvironmentalBG\"/>\n"
15094 " <Property name=\"EnvironmentalBGTexture\"/>\n"
15095 " <Hints>\n"
15096 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
15097 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
15098 " <Expression type=\"and\">\n"
15099 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
15100 " mode=\"visibility\"\n"
15101 " property=\"EnableOSPRay\"\n"
15102 " values=\"1\" />\n"
15103 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
15104 " <Property name=\"OSPRayRendererType\" function=\"equals\" value=\"OSPRay pathtracer\"/>\n"
15105 " </PropertyWidgetDecorator>\n"
15106 " </Expression>\n"
15107 " </PropertyWidgetDecorator>\n"
15108 " </Hints>\n"
15109 " </PropertyGroup>\n"
15110 "\n"
15111 " <SubProxy command=\"SetDeliveryManager\">\n"
15112 " <Proxy name=\"DeliveryManager\"\n"
15113 " proxygroup=\"delivery_managers\"\n"
15114 " proxyname=\"RenderViewDeliveryManager\"/>\n"
15115 " </SubProxy>\n"
15116 " </RenderViewProxy>\n"
15117 "\n"
15118 " <!-- ================================================================== -->\n"
15119 " <OrthographicSliceViewProxy base_proxygroup=\"views\"\n"
15120 " base_proxyname=\"RenderView\"\n"
15121 " class=\"vtkPVOrthographicSliceView\"\n"
15122 " processes=\"client|renderserver|dataserver\"\n"
15123 " label=\"Orthographic Slice View\"\n"
15124 " name=\"OrthographicSliceView\">\n"
15125 " <DoubleVectorProperty name=\"SlicePosition\"\n"
15126 " command=\"SetSlicePosition\"\n"
15127 " number_of_elements=\"3\"\n"
15128 " default_values=\"0 0 0\">\n"
15129 " <Documentation>\n"
15130 " Set the slice position.\n"
15131 " </Documentation>\n"
15132 " <DoubleRangeDomain name=\"range\" />\n"
15133 " </DoubleVectorProperty>\n"
15134 "\n"
15135 " <DoubleVectorProperty name=\"SliceIncrements\"\n"
15136 " command=\"SetSliceIncrements\"\n"
15137 " number_of_elements=\"3\"\n"
15138 " default_values=\"1 1 1\">\n"
15139 " <DoubleRangeDomain name=\"range\" />\n"
15140 " <Documentation>\n"
15141 " When interacting using the thumb wheel, set the increments to use\n"
15142 " to change the slice position.\n"
15143 " </Documentation>\n"
15144 " </DoubleVectorProperty>\n"
15145 "\n"
15146 " <IntVectorProperty name=\"ShowSliceAnnotations\"\n"
15147 " command=\"SetSliceAnnotationsVisibility\"\n"
15148 " number_of_elements=\"1\"\n"
15149 " default_values=\"1\">\n"
15150 " <BooleanDomain name=\"bool\" />\n"
15151 " </IntVectorProperty>\n"
15152 "\n"
15153 " </OrthographicSliceViewProxy>\n"
15154 "\n"
15155 " <!-- ================================================================== -->\n"
15156 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15157 " base_proxyname=\"XYChartViewBase4Axes\"\n"
15158 " class=\"vtkPVXYChartView\"\n"
15159 " name=\"XYChartView\"\n"
15160 " label=\"Line Chart View\"\n"
15161 " processes=\"client|renderserver|dataserver\"\n"
15162 " representation_name=\"XYChartRepresentation\"\n"
15163 " post_creation=\"SetChartTypeToLine\" >\n"
15164 " <Documentation>This is the proxy for the XY line chart\n"
15165 " view.</Documentation>\n"
15166 " </ContextViewProxy>\n"
15167 " <!-- ================================================================== -->\n"
15168 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15169 " base_proxyname=\"XYChartViewBase4Axes\"\n"
15170 " class=\"vtkPVXYChartView\"\n"
15171 " name=\"XYPointChartView\"\n"
15172 " label=\"Point Chart View\"\n"
15173 " processes=\"client|renderserver|dataserver\"\n"
15174 " representation_name=\"XYPointChartRepresentation\"\n"
15175 " post_creation=\"SetChartTypeToPoint\" >\n"
15176 " <Documentation>This is the proxy for the XY point chart\n"
15177 " view.</Documentation>\n"
15178 " </ContextViewProxy>\n"
15179 " <!-- ================================================================== -->\n"
15180 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15181 " base_proxyname=\"XYChartViewBase4Axes\"\n"
15182 " class=\"vtkPVXYChartView\"\n"
15183 " name=\"QuartileChartView\"\n"
15184 " label=\"Quartile Chart View\"\n"
15185 " processes=\"client|renderserver|dataserver\"\n"
15186 " representation_name=\"QuartileChartRepresentation\"\n"
15187 " post_creation=\"SetChartTypeToArea\" >\n"
15188 " <Documentation>This is the proxy for the Quartile chart view.</Documentation>\n"
15189 " </ContextViewProxy>\n"
15190 " <!-- ================================================================== -->\n"
15191 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15192 " base_proxyname=\"XYChartViewBase4Axes\"\n"
15193 " class=\"vtkPVXYChartView\"\n"
15194 " name=\"XYBarChartView\"\n"
15195 " label=\"Bar Chart View\"\n"
15196 " processes=\"client|renderserver|dataserver\"\n"
15197 " representation_name=\"XYBarChartRepresentation\"\n"
15198 " post_creation=\"SetChartTypeToBar\" >\n"
15199 " <Documentation>This is the proxy for bar chart view.</Documentation>\n"
15200 " </ContextViewProxy>\n"
15201 " <!-- ================================================================== -->\n"
15202 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15203 " base_proxyname=\"XYChartViewBase4Axes\"\n"
15204 " class=\"vtkPVXYChartView\"\n"
15205 " name=\"XYHistogramChartView\"\n"
15206 " label=\"Histogram View\"\n"
15207 " processes=\"client|renderserver|dataserver\"\n"
15208 " post_creation=\"SetChartTypeToBar\"\n"
15209 " representation_name=\"HistogramChartRepresentation\"\n"
15210 " skip_plotable_check=\"1\">\n"
15211 " <Documentation>This is the proxy for the histogram chart view.</Documentation>\n"
15212 " <Hints>\n"
15213 " <ShowOneRepresentationAtATime type=\"HistogramChartRepresentation\" />\n"
15214 " <!-- When present, vtkSMParaViewPipelineController::Show() will\n"
15215 " result in hiding other representations that are currently visible\n"
15216 " -->\n"
15217 " </Hints>\n"
15218 " </ContextViewProxy>\n"
15219 " <!-- ================================================================== -->\n"
15220 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15221 " base_proxyname=\"XYChartViewTitle\"\n"
15222 " class=\"vtkPVXYChartView\"\n"
15223 " name=\"BoxChartView\"\n"
15224 " label=\"Box Chart View\"\n"
15225 " processes=\"client|renderserver|dataserver\"\n"
15226 " representation_name=\"BoxChartRepresentation\"\n"
15227 " post_creation=\"SetChartTypeToBox\" >\n"
15228 " <Documentation>This is the proxy for box chart view.</Documentation>\n"
15229 " <IntVectorProperty command=\"SetLegendVisibility\"\n"
15230 " default_values=\"1\"\n"
15231 " panel_visibility=\"never\"\n"
15232 " name=\"ShowLegend\"\n"
15233 " number_of_elements=\"1\">\n"
15234 " <BooleanDomain name=\"bool\" />\n"
15235 " </IntVectorProperty>\n"
15236 " <IntVectorProperty command=\"SetLegendSymbolWidth\"\n"
15237 " default_values=\"25\"\n"
15238 " name=\"LegendSymbolWidth\"\n"
15239 " number_of_elements=\"1\"\n"
15240 " panel_visibility=\"never\">\n"
15241 " </IntVectorProperty>\n"
15242 " </ContextViewProxy>\n"
15243 " <!-- ================================================================== -->\n"
15244 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15245 " base_proxyname=\"ViewBase\"\n"
15246 " class=\"vtkPVXYChartView\"\n"
15247 " name=\"ParallelCoordinatesChartView\"\n"
15248 " label=\"Parallel Coordinates View\"\n"
15249 " processes=\"client|renderserver|dataserver\"\n"
15250 " representation_name=\"ParallelCoordinatesRepresentation\"\n"
15251 " post_creation=\"SetChartTypeToParallelCoordinates\"\n"
15252 " skip_plotable_check=\"1\">\n"
15253 " <Documentation>\n"
15254 " This is the proxy for parallel coordinates chart view.\n"
15255 " </Documentation>\n"
15256 " <SubProxy command=\"SetDeliveryManager\">\n"
15257 " <Proxy name=\"DeliveryManager\"\n"
15258 " proxygroup=\"delivery_managers\"\n"
15259 " proxyname=\"ContextViewDeliveryManager\"/>\n"
15260 " </SubProxy>\n"
15261 " <Hints>\n"
15262 " <ShowOneRepresentationAtATime type=\"ParallelCoordinatesRepresentation\" />\n"
15263 " <!-- When present, vtkSMParaViewPipelineController::Show() will\n"
15264 " result in hiding other representations that are currently visible\n"
15265 " -->\n"
15266 " </Hints>\n"
15267 " </ContextViewProxy>\n"
15268 " <!-- ================================================================== -->\n"
15269 " <ContextViewProxy base_proxygroup=\"internal_views\"\n"
15270 " base_proxyname=\"XYChartViewBase\"\n"
15271 " class=\"vtkPVXYChartView\"\n"
15272 " name=\"ImageChartView\"\n"
15273 " processes=\"client|renderserver|dataserver\"\n"
15274 " representation_name=\"ImageChartRepresentation\"\n"
15275 " post_creation=\"SetChartTypeToImage\"\n"
15276 " skip_plotable_check=\"1\">\n"
15277 " <Documentation>This is the proxy for image chart view.</Documentation>\n"
15278 " <Hints>\n"
15279 " <ShowOneRepresentationAtATime type=\"ImageChartRepresentation\" />\n"
15280 " <!-- When present, vtkSMParaViewPipelineController::Show() will\n"
15281 " result in hiding other representations that are currently visible\n"
15282 " -->\n"
15283 " </Hints>\n"
15284 " </ContextViewProxy>\n"
15285 " <!-- ================================================================== -->\n"
15286 " <PlotMatrixViewProxy base_proxygroup=\"internal_views\"\n"
15287 " base_proxyname=\"XYChartViewTitle\"\n"
15288 " class=\"vtkPVPlotMatrixView\"\n"
15289 " name=\"PlotMatrixView\"\n"
15290 " label=\"Plot Matrix View\"\n"
15291 " processes=\"client|renderserver|dataserver\"\n"
15292 " representation_name=\"PlotMatrixRepresentation\"\n"
15293 " skip_plotable_check=\"1\">\n"
15294 " <Documentation>This is the proxy for the plot matrix\n"
15295 " view.</Documentation>\n"
15296 " <IntVectorProperty command=\"SetBorderLeft\"\n"
15297 " default_values=\"50\"\n"
15298 " name=\"BorderLeft\"\n"
15299 " number_of_elements=\"1\"\n"
15300 " panel_visibility=\"advanced\">\n"
15301 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15302 " </IntVectorProperty>\n"
15303 " <IntVectorProperty command=\"SetBorderBottom\"\n"
15304 " default_values=\"40\"\n"
15305 " name=\"BorderBottom\"\n"
15306 " number_of_elements=\"1\"\n"
15307 " panel_visibility=\"advanced\">\n"
15308 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15309 " </IntVectorProperty>\n"
15310 " <IntVectorProperty command=\"SetBorderRight\"\n"
15311 " default_values=\"50\"\n"
15312 " name=\"BorderRight\"\n"
15313 " number_of_elements=\"1\"\n"
15314 " panel_visibility=\"advanced\">\n"
15315 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15316 " </IntVectorProperty>\n"
15317 " <IntVectorProperty command=\"SetBorderTop\"\n"
15318 " default_values=\"40\"\n"
15319 " name=\"BorderTop\"\n"
15320 " number_of_elements=\"1\"\n"
15321 " panel_visibility=\"advanced\">\n"
15322 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15323 " </IntVectorProperty>\n"
15324 " <IntVectorProperty command=\"SetGutterX\"\n"
15325 " default_values=\"15\"\n"
15326 " name=\"GutterX\"\n"
15327 " number_of_elements=\"1\"\n"
15328 " panel_visibility=\"advanced\">\n"
15329 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15330 " </IntVectorProperty>\n"
15331 " <IntVectorProperty command=\"SetGutterY\"\n"
15332 " default_values=\"15\"\n"
15333 " name=\"GutterY\"\n"
15334 " number_of_elements=\"1\"\n"
15335 " panel_visibility=\"advanced\">\n"
15336 ;
15337
15338 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
15340 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15341 " </IntVectorProperty>\n"
15342 " <DoubleVectorProperty command=\"SetPadding\"\n"
15343 " default_values=\"0.05\"\n"
15344 " name=\"Padding\"\n"
15345 " number_of_elements=\"1\"\n"
15346 " panel_visibility=\"advanced\">\n"
15347 " <DoubleRangeDomain min=\"0.0\" max=\"0.25\" name=\"range\" />\n"
15348 " </DoubleVectorProperty>\n"
15349 " <IntVectorProperty command=\"SetNumberOfAnimationFrames\"\n"
15350 " default_values=\"25\"\n"
15351 " name=\"NumberOfAnimationFrames\"\n"
15352 " number_of_elements=\"1\"\n"
15353 " panel_visibility=\"advanced\">\n"
15354 " <IntRangeDomain min=\"0\" name=\"range\" />\n"
15355 " </IntVectorProperty>\n"
15356 "\n"
15357 " <PropertyGroup label=\"Border\">\n"
15358 " <Property name=\"BorderLeft\"/>\n"
15359 " <Property name=\"BorderBottom\"/>\n"
15360 " <Property name=\"BorderRight\"/>\n"
15361 " <Property name=\"BorderTop\"/>\n"
15362 " </PropertyGroup>\n"
15363 "\n"
15364 " <PropertyGroup label=\"Spacing (Gutter)\">\n"
15365 " <Property name=\"GutterX\"/>\n"
15366 " <Property name=\"GutterY\"/>\n"
15367 " <Property name=\"Padding\"/>\n"
15368 " </PropertyGroup>\n"
15369 "\n"
15370 " <DoubleVectorProperty command=\"SetScatterPlotSelectedRowColumnColor\"\n"
15371 " default_values=\"0.8 0 0 0.4\"\n"
15372 " name=\"ScatterPlotSelectedRowColumnColor\"\n"
15373 " number_of_elements=\"4\"\n"
15374 " panel_widget=\"color_selector\"\n"
15375 " panel_visibility=\"advanced\">\n"
15376 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
15377 " min=\"0 0 0 0\"\n"
15378 " name=\"range\" />\n"
15379 " </DoubleVectorProperty>\n"
15380 "\n"
15381 " <DoubleVectorProperty command=\"SetScatterPlotSelectedActiveColor\"\n"
15382 " default_values=\"0 0.8 0 0.4\"\n"
15383 " name=\"ScatterPlotSelectedActiveColor\"\n"
15384 " number_of_elements=\"4\"\n"
15385 " panel_widget=\"color_selector\"\n"
15386 " panel_visibility=\"advanced\">\n"
15387 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
15388 " min=\"0 0 0 0\"\n"
15389 " name=\"range\" />\n"
15390 " </DoubleVectorProperty>\n"
15391 "\n"
15392 " <!-- activeplot -->\n"
15393 " <DoubleVectorProperty command=\"SetActivePlotBackgroundColor\"\n"
15394 " default_values=\"1 1 1 0\"\n"
15395 " name=\"ActivePlotBackgroundColor\"\n"
15396 " number_of_elements=\"4\"\n"
15397 " panel_widget=\"color_selector\"\n"
15398 " panel_visibility=\"advanced\">\n"
15399 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
15400 " min=\"0 0 0 0\"\n"
15401 " name=\"range\" />\n"
15402 " </DoubleVectorProperty>\n"
15403 " <DoubleVectorProperty command=\"SetActivePlotAxisColor\"\n"
15404 " default_values=\"0 0 0\"\n"
15405 " name=\"ActivePlotAxisColor\"\n"
15406 " panel_widget=\"color_selector\"\n"
15407 " number_of_elements=\"3\"\n"
15408 " panel_visibility=\"advanced\">\n"
15409 " <DoubleRangeDomain max=\"1 1 1\"\n"
15410 " min=\"0 0 0\"\n"
15411 " name=\"range\" />\n"
15412 " </DoubleVectorProperty>\n"
15413 " <DoubleVectorProperty command=\"SetActivePlotGridColor\"\n"
15414 " default_values=\"0.95 0.95 0.95\"\n"
15415 " name=\"ActivePlotGridColor\"\n"
15416 " panel_widget=\"color_selector\"\n"
15417 " number_of_elements=\"3\"\n"
15418 " panel_visibility=\"advanced\">\n"
15419 " <DoubleRangeDomain max=\"1 1 1\"\n"
15420 " min=\"0 0 0\"\n"
15421 " name=\"range\" />\n"
15422 " </DoubleVectorProperty>\n"
15423 " <IntVectorProperty command=\"SetActivePlotGridVisibility\"\n"
15424 " default_values=\"1\"\n"
15425 " name=\"ActivePlotGridVisibility\"\n"
15426 " number_of_elements=\"1\"\n"
15427 " panel_visibility=\"advanced\">\n"
15428 " <BooleanDomain name=\"bool\" />\n"
15429 " </IntVectorProperty>\n"
15430 " <IntVectorProperty command=\"SetActivePlotAxisLabelVisibility\"\n"
15431 " default_values=\"1\"\n"
15432 " name=\"ActivePlotAxisLabelVisibility\"\n"
15433 " number_of_elements=\"1\"\n"
15434 " panel_visibility=\"advanced\">\n"
15435 " <BooleanDomain name=\"bool\" />\n"
15436 " </IntVectorProperty>\n"
15437 " <IntVectorProperty command=\"SetActivePlotAxisLabelNotation\"\n"
15438 " default_values=\"0\"\n"
15439 " panel_visibility=\"advanced\"\n"
15440 " name=\"ActivePlotAxisLabelNotation\"\n"
15441 " number_of_elements=\"1\">\n"
15442 " <EnumerationDomain name=\"enum\">\n"
15443 " <Entry text=\"Mixed\"\n"
15444 " value=\"0\" />\n"
15445 " <Entry text=\"Scientific\"\n"
15446 " value=\"1\" />\n"
15447 " <Entry text=\"Fixed\"\n"
15448 " value=\"2\" />\n"
15449 " </EnumerationDomain>\n"
15450 " </IntVectorProperty>\n"
15451 " <IntVectorProperty command=\"SetActivePlotAxisLabelPrecision\"\n"
15452 " default_values=\"2\"\n"
15453 " panel_visibility=\"advanced\"\n"
15454 " name=\"ActivePlotAxisLabelPrecision\"\n"
15455 " number_of_elements=\"1\">\n"
15456 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
15457 " </IntVectorProperty>\n"
15458 " <StringVectorProperty command=\"SetActivePlotAxisLabelFontFamily\"\n"
15459 " default_values=\"Arial\"\n"
15460 " name=\"ActivePlotAxisLabelFontFamily\"\n"
15461 " number_of_elements=\"1\">\n"
15462 " <StringListDomain name=\"list\">\n"
15463 " <String value=\"Arial\" />\n"
15464 " <String value=\"Courier\" />\n"
15465 " <String value=\"Times\" />\n"
15466 " <String value=\"File\" />\n"
15467 " </StringListDomain>\n"
15468 " <Documentation>Set the font familyname.</Documentation>\n"
15469 " </StringVectorProperty>\n"
15470 " <StringVectorProperty command=\"SetActivePlotAxisLabelFontFile\"\n"
15471 " name=\"ActivePlotAxisLabelFontFile\"\n"
15472 " number_of_elements=\"1\"\n"
15473 " default_values=\"\">\n"
15474 " <Documentation>Set the font file.</Documentation>\n"
15475 " </StringVectorProperty>\n"
15476 " <IntVectorProperty command=\"SetActivePlotAxisLabelFontSize\"\n"
15477 " default_values=\"12\"\n"
15478 " name=\"ActivePlotAxisLabelFontSize\"\n"
15479 " number_of_elements=\"1\">\n"
15480 " <Documentation>Set the axis title font size.</Documentation>\n"
15481 " </IntVectorProperty>\n"
15482 " <IntVectorProperty command=\"SetActivePlotAxisLabelBold\"\n"
15483 " default_values=\"0\"\n"
15484 " name=\"ActivePlotAxisLabelBold\"\n"
15485 " number_of_elements=\"1\">\n"
15486 " <BooleanDomain name=\"bool\" />\n"
15487 " <Documentation>Set the axis title bold.</Documentation>\n"
15488 " </IntVectorProperty>\n"
15489 " <IntVectorProperty command=\"SetActivePlotAxisLabelItalic\"\n"
15490 " default_values=\"0\"\n"
15491 " name=\"ActivePlotAxisLabelItalic\"\n"
15492 " number_of_elements=\"1\">\n"
15493 " <BooleanDomain name=\"bool\" />\n"
15494 " <Documentation>Set the axis title italic.</Documentation>\n"
15495 " </IntVectorProperty>\n"
15496 " <DoubleVectorProperty command=\"SetActivePlotAxisLabelColor\"\n"
15497 " default_values=\"0 0 0\"\n"
15498 " name=\"ActivePlotAxisLabelColor\"\n"
15499 " number_of_elements=\"3\">\n"
15500 " <DoubleRangeDomain max=\"1\"\n"
15501 " min=\"0\"\n"
15502 " name=\"range\" />\n"
15503 " </DoubleVectorProperty>\n"
15504 "\n"
15505 " <PropertyGroup label=\"ActivePlot\"\n"
15506 " panel_visibility=\"advanced\">\n"
15507 " <Property name=\"ActivePlotBackgroundColor\"/>\n"
15508 " <Property name=\"ActivePlotAxisColor\"/>\n"
15509 " <Property name=\"ActivePlotGridColor\"/>\n"
15510 " <Property name=\"ActivePlotGridVisibility\"/>\n"
15511 " <Property name=\"ActivePlotAxisLabelVisibility\"/>\n"
15512 " <Property name=\"ActivePlotAxisLabelNotation\"/>\n"
15513 " <Property name=\"ActivePlotAxisLabelPrecision\"/>\n"
15514 " </PropertyGroup>\n"
15515 " <PropertyGroup label=\"ActivePlot Axis Label Properties\"\n"
15516 " panel_widget=\"FontEditor\"\n"
15517 " panel_visibility=\"advanced\">\n"
15518 " <Property name=\"ActivePlotAxisLabelColor\" function=\"Color\"/>\n"
15519 " <Property name=\"ActivePlotAxisLabelFontFamily\" function=\"Family\"/>\n"
15520 " <Property name=\"ActivePlotAxisLabelFontFile\" function=\"File\"/>\n"
15521 " <Property name=\"ActivePlotAxisLabelBold\" function=\"Bold\" />\n"
15522 " <Property name=\"ActivePlotAxisLabelItalic\" function=\"Italics\"/>\n"
15523 " <Property name=\"ActivePlotAxisLabelFontSize\" function=\"Size\" />\n"
15524 " </PropertyGroup>\n"
15525 "\n"
15526 " <!-- scatterplot -->\n"
15527 " <DoubleVectorProperty command=\"SetScatterPlotBackgroundColor\"\n"
15528 " default_values=\"1 1 1 0\"\n"
15529 " name=\"ScatterPlotBackgroundColor\"\n"
15530 " number_of_elements=\"4\"\n"
15531 " panel_widget=\"color_selector\"\n"
15532 " panel_visibility=\"advanced\">\n"
15533 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
15534 " min=\"0 0 0 0\"\n"
15535 " name=\"range\" />\n"
15536 " </DoubleVectorProperty>\n"
15537 " <DoubleVectorProperty command=\"SetScatterPlotAxisColor\"\n"
15538 " default_values=\"0 0 0\"\n"
15539 " name=\"ScatterPlotAxisColor\"\n"
15540 " panel_widget=\"color_selector\"\n"
15541 " number_of_elements=\"3\"\n"
15542 " panel_visibility=\"advanced\">\n"
15543 " <DoubleRangeDomain max=\"1 1 1\"\n"
15544 " min=\"0 0 0\"\n"
15545 " name=\"range\" />\n"
15546 " </DoubleVectorProperty>\n"
15547 " <DoubleVectorProperty command=\"SetScatterPlotGridColor\"\n"
15548 " default_values=\"0.95 0.95 0.95\"\n"
15549 " name=\"ScatterPlotGridColor\"\n"
15550 " panel_widget=\"color_selector\"\n"
15551 " number_of_elements=\"3\"\n"
15552 " panel_visibility=\"advanced\">\n"
15553 " <DoubleRangeDomain max=\"1 1 1\"\n"
15554 " min=\"0 0 0\"\n"
15555 " name=\"range\" />\n"
15556 " </DoubleVectorProperty>\n"
15557 " <IntVectorProperty command=\"SetScatterPlotGridVisibility\"\n"
15558 " default_values=\"1\"\n"
15559 " name=\"ScatterPlotGridVisibility\"\n"
15560 " number_of_elements=\"1\"\n"
15561 " panel_visibility=\"advanced\">\n"
15562 " <BooleanDomain name=\"bool\" />\n"
15563 " </IntVectorProperty>\n"
15564 " <IntVectorProperty command=\"SetScatterPlotAxisLabelVisibility\"\n"
15565 " default_values=\"1\"\n"
15566 " name=\"ScatterPlotAxisLabelVisibility\"\n"
15567 " number_of_elements=\"1\"\n"
15568 " panel_visibility=\"advanced\">\n"
15569 " <BooleanDomain name=\"bool\" />\n"
15570 " </IntVectorProperty>\n"
15571 " <IntVectorProperty command=\"SetScatterPlotAxisLabelNotation\"\n"
15572 " default_values=\"0\"\n"
15573 " panel_visibility=\"advanced\"\n"
15574 " name=\"ScatterPlotAxisLabelNotation\"\n"
15575 " number_of_elements=\"1\">\n"
15576 " <EnumerationDomain name=\"enum\">\n"
15577 " <Entry text=\"Mixed\"\n"
15578 " value=\"0\" />\n"
15579 " <Entry text=\"Scientific\"\n"
15580 " value=\"1\" />\n"
15581 " <Entry text=\"Fixed\"\n"
15582 " value=\"2\" />\n"
15583 " </EnumerationDomain>\n"
15584 " </IntVectorProperty>\n"
15585 " <IntVectorProperty command=\"SetScatterPlotAxisLabelPrecision\"\n"
15586 " default_values=\"2\"\n"
15587 " panel_visibility=\"advanced\"\n"
15588 " name=\"ScatterPlotAxisLabelPrecision\"\n"
15589 " number_of_elements=\"1\">\n"
15590 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
15591 " </IntVectorProperty>\n"
15592 " <StringVectorProperty command=\"SetScatterPlotAxisLabelFontFamily\"\n"
15593 " default_values=\"Arial\"\n"
15594 " name=\"ScatterPlotAxisLabelFontFamily\"\n"
15595 " number_of_elements=\"1\">\n"
15596 " <StringListDomain name=\"list\">\n"
15597 " <String value=\"Arial\" />\n"
15598 " <String value=\"Courier\" />\n"
15599 " <String value=\"Times\" />\n"
15600 " <String value=\"File\" />\n"
15601 " </StringListDomain>\n"
15602 " <Documentation>Set the font familyname.</Documentation>\n"
15603 " </StringVectorProperty>\n"
15604 " <StringVectorProperty command=\"SetScatterPlotAxisLabelFontFile\"\n"
15605 " name=\"ScatterPlotAxisLabelFontFile\"\n"
15606 " number_of_elements=\"1\"\n"
15607 " default_values=\"\">\n"
15608 " <Documentation>Set the font file.</Documentation>\n"
15609 " </StringVectorProperty>\n"
15610 " <IntVectorProperty command=\"SetScatterPlotAxisLabelFontSize\"\n"
15611 " default_values=\"12\"\n"
15612 " name=\"ScatterPlotAxisLabelFontSize\"\n"
15613 " number_of_elements=\"1\">\n"
15614 " <Documentation>Set the axis title font size.</Documentation>\n"
15615 " </IntVectorProperty>\n"
15616 " <IntVectorProperty command=\"SetScatterPlotAxisLabelBold\"\n"
15617 " default_values=\"0\"\n"
15618 " name=\"ScatterPlotAxisLabelBold\"\n"
15619 " number_of_elements=\"1\">\n"
15620 " <BooleanDomain name=\"bool\" />\n"
15621 " <Documentation>Set the axis title bold.</Documentation>\n"
15622 " </IntVectorProperty>\n"
15623 " <IntVectorProperty command=\"SetScatterPlotAxisLabelItalic\"\n"
15624 " default_values=\"0\"\n"
15625 " name=\"ScatterPlotAxisLabelItalic\"\n"
15626 " number_of_elements=\"1\">\n"
15627 " <BooleanDomain name=\"bool\" />\n"
15628 " <Documentation>Set the axis title italic.</Documentation>\n"
15629 " </IntVectorProperty>\n"
15630 " <DoubleVectorProperty command=\"SetScatterPlotAxisLabelColor\"\n"
15631 " default_values=\"0 0 0\"\n"
15632 " name=\"ScatterPlotAxisLabelColor\"\n"
15633 " number_of_elements=\"3\">\n"
15634 " <DoubleRangeDomain max=\"1\"\n"
15635 " min=\"0\"\n"
15636 " name=\"range\" />\n"
15637 " </DoubleVectorProperty>\n"
15638 "\n"
15639 " <PropertyGroup label=\"ScatterPlot\"\n"
15640 " panel_visibility=\"advanced\">\n"
15641 " <Property name=\"ScatterPlotBackgroundColor\"/>\n"
15642 " <Property name=\"ScatterPlotAxisColor\"/>\n"
15643 " <Property name=\"ScatterPlotGridColor\"/>\n"
15644 " <Property name=\"ScatterPlotGridVisibility\"/>\n"
15645 ;
15646
15647 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
15649 " <Property name=\"ScatterPlotAxisLabelVisibility\"/>\n"
15650 " <Property name=\"ScatterPlotAxisLabelNotation\"/>\n"
15651 " <Property name=\"ScatterPlotAxisLabelPrecision\"/>\n"
15652 " </PropertyGroup>\n"
15653 " <PropertyGroup label=\"ScatterPlot Axis Label Properties\"\n"
15654 " panel_widget=\"FontEditor\"\n"
15655 " panel_visibility=\"advanced\">\n"
15656 " <Property name=\"ScatterPlotAxisLabelColor\" function=\"Color\"/>\n"
15657 " <Property name=\"ScatterPlotAxisLabelFontFamily\" function=\"Family\"/>\n"
15658 " <Property name=\"ScatterPlotAxisLabelFontFile\" function=\"File\"/>\n"
15659 " <Property name=\"ScatterPlotAxisLabelBold\" function=\"Bold\" />\n"
15660 " <Property name=\"ScatterPlotAxisLabelItalic\" function=\"Italics\"/>\n"
15661 " <Property name=\"ScatterPlotAxisLabelFontSize\" function=\"Size\" />\n"
15662 " </PropertyGroup>\n"
15663 "\n"
15664 " <!-- histogram -->\n"
15665 " <DoubleVectorProperty command=\"SetHistogramBackgroundColor\"\n"
15666 " default_values=\"0.5 0.5 0.5 0.4\"\n"
15667 " name=\"HistogramBackgroundColor\"\n"
15668 " number_of_elements=\"4\"\n"
15669 " panel_widget=\"color_selector\"\n"
15670 " panel_visibility=\"advanced\">\n"
15671 " <DoubleRangeDomain max=\"1 1 1 1\"\n"
15672 " min=\"0 0 0 0\"\n"
15673 " name=\"range\" />\n"
15674 " </DoubleVectorProperty>\n"
15675 " <DoubleVectorProperty command=\"SetHistogramAxisColor\"\n"
15676 " default_values=\"0 0 0\"\n"
15677 " name=\"HistogramAxisColor\"\n"
15678 " panel_widget=\"color_selector\"\n"
15679 " number_of_elements=\"3\"\n"
15680 " panel_visibility=\"advanced\">\n"
15681 " <DoubleRangeDomain max=\"1 1 1\"\n"
15682 " min=\"0 0 0\"\n"
15683 " name=\"range\" />\n"
15684 " </DoubleVectorProperty>\n"
15685 " <DoubleVectorProperty command=\"SetHistogramGridColor\"\n"
15686 " default_values=\"0.95 0.95 0.95\"\n"
15687 " name=\"HistogramGridColor\"\n"
15688 " panel_widget=\"color_selector\"\n"
15689 " number_of_elements=\"3\"\n"
15690 " panel_visibility=\"advanced\">\n"
15691 " <DoubleRangeDomain max=\"1 1 1\"\n"
15692 " min=\"0 0 0\"\n"
15693 " name=\"range\" />\n"
15694 " </DoubleVectorProperty>\n"
15695 " <IntVectorProperty command=\"SetHistogramGridVisibility\"\n"
15696 " default_values=\"1\"\n"
15697 " name=\"HistogramGridVisibility\"\n"
15698 " number_of_elements=\"1\"\n"
15699 " panel_visibility=\"advanced\">\n"
15700 " <BooleanDomain name=\"bool\" />\n"
15701 " </IntVectorProperty>\n"
15702 " <IntVectorProperty command=\"SetHistogramAxisLabelVisibility\"\n"
15703 " default_values=\"1\"\n"
15704 " name=\"HistogramAxisLabelVisibility\"\n"
15705 " number_of_elements=\"1\"\n"
15706 " panel_visibility=\"advanced\">\n"
15707 " <BooleanDomain name=\"bool\" />\n"
15708 " </IntVectorProperty>\n"
15709 " <IntVectorProperty command=\"SetHistogramAxisLabelNotation\"\n"
15710 " default_values=\"0\"\n"
15711 " panel_visibility=\"advanced\"\n"
15712 " name=\"HistogramAxisLabelNotation\"\n"
15713 " number_of_elements=\"1\">\n"
15714 " <EnumerationDomain name=\"enum\">\n"
15715 " <Entry text=\"Mixed\"\n"
15716 " value=\"0\" />\n"
15717 " <Entry text=\"Scientific\"\n"
15718 " value=\"1\" />\n"
15719 " <Entry text=\"Fixed\"\n"
15720 " value=\"2\" />\n"
15721 " </EnumerationDomain>\n"
15722 " </IntVectorProperty>\n"
15723 " <IntVectorProperty command=\"SetHistogramAxisLabelPrecision\"\n"
15724 " default_values=\"2\"\n"
15725 " panel_visibility=\"advanced\"\n"
15726 " name=\"HistogramAxisLabelPrecision\"\n"
15727 " number_of_elements=\"1\">\n"
15728 " <IntRangeDomain name=\"range\" min=\"0\"/>\n"
15729 " </IntVectorProperty>\n"
15730 " <StringVectorProperty command=\"SetHistogramAxisLabelFontFamily\"\n"
15731 " default_values=\"Arial\"\n"
15732 " name=\"HistogramAxisLabelFontFamily\"\n"
15733 " number_of_elements=\"1\">\n"
15734 " <StringListDomain name=\"list\">\n"
15735 " <String value=\"Arial\" />\n"
15736 " <String value=\"Courier\" />\n"
15737 " <String value=\"Times\" />\n"
15738 " <String value=\"File\" />\n"
15739 " </StringListDomain>\n"
15740 " <Documentation>Set the font familyname.</Documentation>\n"
15741 " </StringVectorProperty>\n"
15742 " <StringVectorProperty command=\"SetHistogramAxisLabelFontFile\"\n"
15743 " name=\"HistogramAxisLabelFontFile\"\n"
15744 " number_of_elements=\"1\"\n"
15745 " default_values=\"\">\n"
15746 " <Documentation>Set the font file.</Documentation>\n"
15747 " </StringVectorProperty>\n"
15748 " <IntVectorProperty command=\"SetHistogramAxisLabelFontSize\"\n"
15749 " default_values=\"12\"\n"
15750 " name=\"HistogramAxisLabelFontSize\"\n"
15751 " number_of_elements=\"1\">\n"
15752 " <Documentation>Set the axis title font size.</Documentation>\n"
15753 " </IntVectorProperty>\n"
15754 " <IntVectorProperty command=\"SetHistogramAxisLabelBold\"\n"
15755 " default_values=\"0\"\n"
15756 " name=\"HistogramAxisLabelBold\"\n"
15757 " number_of_elements=\"1\">\n"
15758 " <BooleanDomain name=\"bool\" />\n"
15759 " <Documentation>Set the axis title bold.</Documentation>\n"
15760 " </IntVectorProperty>\n"
15761 " <IntVectorProperty command=\"SetHistogramAxisLabelItalic\"\n"
15762 " default_values=\"0\"\n"
15763 " name=\"HistogramAxisLabelItalic\"\n"
15764 " number_of_elements=\"1\">\n"
15765 " <BooleanDomain name=\"bool\" />\n"
15766 " <Documentation>Set the axis title italic.</Documentation>\n"
15767 " </IntVectorProperty>\n"
15768 " <DoubleVectorProperty command=\"SetHistogramAxisLabelColor\"\n"
15769 " default_values=\"0 0 0\"\n"
15770 " name=\"HistogramAxisLabelColor\"\n"
15771 " number_of_elements=\"3\">\n"
15772 " <DoubleRangeDomain max=\"1\"\n"
15773 " min=\"0\"\n"
15774 " name=\"range\" />\n"
15775 " </DoubleVectorProperty>\n"
15776 "\n"
15777 " <PropertyGroup label=\"Histogram\"\n"
15778 " panel_visibility=\"advanced\">\n"
15779 " <Property name=\"HistogramBackgroundColor\"/>\n"
15780 " <Property name=\"HistogramAxisColor\"/>\n"
15781 " <Property name=\"HistogramGridColor\"/>\n"
15782 " <Property name=\"HistogramGridVisibility\"/>\n"
15783 " <Property name=\"HistogramAxisLabelVisibility\"/>\n"
15784 " <Property name=\"HistogramAxisLabelNotation\"/>\n"
15785 " <Property name=\"HistogramAxisLabelPrecision\"/>\n"
15786 " </PropertyGroup>\n"
15787 " <PropertyGroup label=\"Histogram Axis Label Properties\"\n"
15788 " panel_widget=\"FontEditor\"\n"
15789 " panel_visibility=\"advanced\">\n"
15790 " <Property name=\"HistogramAxisLabelColor\" function=\"Color\"/>\n"
15791 " <Property name=\"HistogramAxisLabelFontFamily\" function=\"Family\"/>\n"
15792 " <Property name=\"HistogramAxisLabelFontFile\" function=\"File\"/>\n"
15793 " <Property name=\"HistogramAxisLabelBold\" function=\"Bold\" />\n"
15794 " <Property name=\"HistogramAxisLabelItalic\" function=\"Italics\"/>\n"
15795 " <Property name=\"HistogramAxisLabelFontSize\" function=\"Size\" />\n"
15796 " </PropertyGroup>\n"
15797 "\n"
15798 " <Hints>\n"
15799 " <ShowOneRepresentationAtATime type=\"PlotMatrixRepresentation\" />\n"
15800 " <!-- When present, vtkSMParaViewPipelineController::Show() will\n"
15801 " result in hiding other representations that are currently visible\n"
15802 " -->\n"
15803 " </Hints>\n"
15804 "\n"
15805 " <!-- end of PlotMatrixViewProxy -->\n"
15806 " </PlotMatrixViewProxy>\n"
15807 " <!-- ================================================================== -->\n"
15808 " <SpreadSheetViewProxy base_proxygroup=\"internal_views\"\n"
15809 " base_proxyname=\"ViewBase\"\n"
15810 " class=\"vtkSpreadSheetView\"\n"
15811 " name=\"SpreadSheetView\"\n"
15812 " label=\"SpreadSheet View\"\n"
15813 " processes=\"client|dataserver|renderserver\"\n"
15814 " representation_name=\"SpreadSheetRepresentation\">\n"
15815 " <IntVectorProperty name=\"CellFontSize\"\n"
15816 " default_values=\"9\"\n"
15817 " number_of_elements=\"1\">\n"
15818 " <IntRangeDomain min=\"1\" max=\"48\" name=\"range\" />\n"
15819 " <Documentation>Sets the font size for cells in the\n"
15820 " spreadsheet.</Documentation>\n"
15821 " </IntVectorProperty>\n"
15822 " <IntVectorProperty name=\"HeaderFontSize\"\n"
15823 " default_values=\"9\"\n"
15824 " number_of_elements=\"1\">\n"
15825 " <IntRangeDomain min=\"1\" max=\"48\" name=\"range\" />\n"
15826 " <Documentation>Sets the font size for row and column headers\n"
15827 " in the spreadsheet.</Documentation>\n"
15828 " </IntVectorProperty>\n"
15829 " <IntVectorProperty command=\"SetShowExtractedSelection\"\n"
15830 " default_values=\"0\"\n"
15831 " name=\"SelectionOnly\"\n"
15832 " number_of_elements=\"1\"\n"
15833 " panel_visibility=\"never\">\n"
15834 " <Documentation>When set to 1, this representations shows only the\n"
15835 " selected cells (or points). The change will effect only after calling\n"
15836 " Update(). Note that changing this will clean all cache.</Documentation>\n"
15837 " <BooleanDomain name=\"bool\" />\n"
15838 " </IntVectorProperty>\n"
15839 " <IntVectorProperty command=\"SetGenerateCellConnectivity\"\n"
15840 " default_values=\"0\"\n"
15841 " name=\"GenerateCellConnectivity\"\n"
15842 " number_of_elements=\"1\"\n"
15843 " panel_visibility=\"never\">\n"
15844 " <BooleanDomain name=\"bool\" />\n"
15845 " <Documentation>Generation of the cell connectivity.</Documentation>\n"
15846 " </IntVectorProperty>\n"
15847 " <IntVectorProperty command=\"SetShowFieldData\"\n"
15848 " default_values=\"0\"\n"
15849 " name=\"ShowFieldData\"\n"
15850 " number_of_elements=\"1\"\n"
15851 " panel_visibility=\"never\">\n"
15852 " <BooleanDomain name=\"bool\" />\n"
15853 " <Documentation>Show the field data associated to the points / cells.</Documentation>\n"
15854 " </IntVectorProperty>\n"
15855 " <StringVectorProperty command=\"SetColumnNameToSort\"\n"
15856 " name=\"ColumnToSort\"\n"
15857 " number_of_elements=\"1\"\n"
15858 " panel_visibility=\"never\">\n"
15859 " </StringVectorProperty>\n"
15860 " <IntVectorProperty command=\"SetInvertSortOrder\"\n"
15861 " default_values=\"0\"\n"
15862 " name=\"InvertOrder\"\n"
15863 " number_of_elements=\"1\"\n"
15864 " panel_visibility=\"never\">\n"
15865 " <BooleanDomain name=\"bool\" />\n"
15866 " </IntVectorProperty>\n"
15867 " <IdTypeVectorProperty command=\"SetBlockSize\"\n"
15868 " default_values=\"1024\"\n"
15869 " name=\"BlockSize\"\n"
15870 " number_of_elements=\"1\"\n"
15871 " panel_visibility=\"never\">\n"
15872 " <Documentation>Get/Set the number of rows that fit within one block.\n"
15873 " The output of this filter will have at most BlockSize\n"
15874 " rows.</Documentation>\n"
15875 " </IdTypeVectorProperty>\n"
15876 " <StringVectorProperty command=\"HideColumnByLabel\"\n"
15877 " clean_command=\"ClearHiddenColumnsByLabel\"\n"
15878 " name=\"HiddenColumnLabels\"\n"
15879 " number_of_elements_per_command=\"1\"\n"
15880 " panel_visibility=\"never\"\n"
15881 " default_values_delimiter=\";\"\n"
15882 " default_values=\"Block Number\"\n"
15883 " number_of_elements=\"1\"\n"
15884 " repeat_command=\"1\">\n"
15885 " <Documentation>This is list of labels for columns that will be hidden\n"
15886 " in the view i.e. these columns won't be show in the GUI or exported\n"
15887 " when exporting the view.\n"
15888 " </Documentation>\n"
15889 " </StringVectorProperty>\n"
15890 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
15891 " default_values=\"0\"\n"
15892 " name=\"FieldAssociation\"\n"
15893 " number_of_elements=\"1\"\n"
15894 " panel_visibility=\"never\">\n"
15895 " <Documentation>Select the attribute data to pass.</Documentation>\n"
15896 " <FieldDataDomain enable_field_data=\"1\"\n"
15897 " name=\"enum\">\n"
15898 " </FieldDataDomain>\n"
15899 " </IntVectorProperty>\n"
15900 "\n"
15901 " <Hints>\n"
15902 " <ShowOneRepresentationAtATime />\n"
15903 " <!-- When present, vtkSMParaViewPipelineController::Show() will\n"
15904 " result in hiding other representations that are currently visible\n"
15905 " -->\n"
15906 " </Hints>\n"
15907 "\n"
15908 " <!-- End of SpreadSheetView -->\n"
15909 " </SpreadSheetViewProxy>\n"
15910 "\n"
15911 " <!-- ================================================================== -->\n"
15912 " <RenderViewProxy name=\"RenderViewWithEDL\" class=\"vtkPVRenderViewWithEDL\"\n"
15913 " label=\"Eye Dome Lighting\"\n"
15914 " processes=\"client|renderserver|dataserver\"\n"
15915 " base_proxygroup=\"views\"\n"
15916 " base_proxyname=\"RenderView\">\n"
15917 " <!-- End of EyeDomeLighting View -->\n"
15918 " </RenderViewProxy>\n"
15919 "\n"
15920 " </ProxyGroup>\n"
15921 "\n"
15922 " <!-- ==================================================================== -->\n"
15923 " <ProxyGroup name=\"internal_representations\">\n"
15924 " <PVRepresentationProxy class=\"vtkPVCompositeRepresentation\"\n"
15925 " name=\"PVRepresentationBase\"\n"
15926 " processes=\"client|renderserver|dataserver\">\n"
15927 " <Documentation>ParaView's default representation for showing any type of\n"
15928 " dataset in the render view.</Documentation>\n"
15929 " <InputProperty command=\"SetSelectionConnection\"\n"
15930 " name=\"Selection\">\n"
15931 " <DataTypeDomain name=\"input_type\">\n"
15932 " <DataType value=\"vtkSelection\" />\n"
15933 " </DataTypeDomain>\n"
15934 " <Documentation>Set the selection.</Documentation>\n"
15935 " </InputProperty>\n"
15936 " <IntVectorProperty command=\"SetVisibility\"\n"
15937 " default_values=\"1\"\n"
15938 " name=\"Visibility\"\n"
15939 " number_of_elements=\"1\"\n"
15940 " panel_visibility=\"never\">\n"
15941 " <BooleanDomain name=\"bool\" />\n"
15942 " <Documentation>Set the visibility for this\n"
15943 " representation.</Documentation>\n"
15944 " </IntVectorProperty>\n"
15945 " <IntVectorProperty command=\"SetForceUseCache\"\n"
15946 " default_values=\"0\"\n"
15947 " is_internal=\"1\"\n"
15948 " name=\"ForceUseCache\"\n"
15949 " number_of_elements=\"1\">\n"
15950 " <BooleanDomain name=\"bool\" />\n"
15951 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
15952 ;
15953
15954 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
15956 " and representations cache based on what the view tells it. However in\n"
15957 " some cases we may want to force a representation to cache irrespective\n"
15958 " of the view (e.g. comparative views). In which case these ivars can up\n"
15959 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
15960 " Instead, ForcedCacheKey is used.</Documentation>\n"
15961 " </IntVectorProperty>\n"
15962 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
15963 " default_values=\"none\"\n"
15964 " is_internal=\"1\"\n"
15965 " name=\"ForcedCacheKey\"\n"
15966 " number_of_elements=\"1\">\n"
15967 " <DoubleRangeDomain name=\"range\" />\n"
15968 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
15969 " and representations cache based on what the view tells it. However in\n"
15970 " some cases we may want to force a representation to cache irrespective\n"
15971 " of the view (e.g. comparative views). In which case these ivars can up\n"
15972 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
15973 " Instead, ForcedCacheKey is used.</Documentation>\n"
15974 " </DoubleVectorProperty>\n"
15975 " <IntVectorProperty command=\"SetSelectionVisibility\"\n"
15976 " default_values=\"1\"\n"
15977 " name=\"SelectionVisibility\"\n"
15978 " number_of_elements=\"1\"\n"
15979 " panel_visibility=\"never\">\n"
15980 " <BooleanDomain name=\"bool\" />\n"
15981 " <Documentation>Set the visibility for the selection, if\n"
15982 " any.</Documentation>\n"
15983 " </IntVectorProperty>\n"
15984 " <RepresentationType subproxy=\"OutlineRepresentation\"\n"
15985 " text=\"Outline\" />\n"
15986 " <RepresentationType subproxy=\"FeatureEdgesRepresentation\"\n"
15987 " text=\"Feature Edges\" />\n"
15988 " <RepresentationType subproxy=\"SurfaceRepresentation\"\n"
15989 " subtype=\"Points\"\n"
15990 " text=\"Points\" />\n"
15991 " <RepresentationType subproxy=\"SurfaceRepresentation\"\n"
15992 " subtype=\"Wireframe\"\n"
15993 " text=\"Wireframe\" />\n"
15994 " <RepresentationType subproxy=\"SurfaceRepresentation\"\n"
15995 " subtype=\"Surface\"\n"
15996 " text=\"Surface\" />\n"
15997 " <RepresentationType subproxy=\"SurfaceRepresentation\"\n"
15998 " subtype=\"Surface With Edges\"\n"
15999 " text=\"Surface With Edges\" />\n"
16000 " <RepresentationType subproxy=\"Glyph3DRepresentation\"\n"
16001 " subtype=\"Surface\"\n"
16002 " text=\"3D Glyphs\" />\n"
16003 " <RepresentationType subproxy=\"PointGaussianRepresentation\"\n"
16004 " text=\"Point Gaussian\" />\n"
16005 " <StringVectorProperty command=\"GetRepresentationTypes\"\n"
16006 " information_only=\"1\"\n"
16007 " name=\"RepresentationTypesInfo\"\n"
16008 " si_class=\"vtkSIDataArrayProperty\">\n"
16009 " <Documentation>Property that lists the available representation types.\n"
16010 " This is used by the domain for \"Representation\" to setup the list of\n"
16011 " types available correctly.</Documentation>\n"
16012 " </StringVectorProperty>\n"
16013 " <StringVectorProperty command=\"SetActiveRepresentation\"\n"
16014 " default_values=\"Surface\"\n"
16015 " name=\"Representation\"\n"
16016 " number_of_elements=\"1\"\n"
16017 " panel_visibility=\"default\"\n"
16018 " panel_widget=\"display_representation_selector\" >\n"
16019 " <Documentation>Choose the type for the representation.</Documentation>\n"
16020 " <RepresentationTypeDomain name=\"list\">\n"
16021 " <RequiredProperties>\n"
16022 " <Property function=\"StringList\"\n"
16023 " name=\"RepresentationTypesInfo\" />\n"
16024 " <Property function=\"Input\"\n"
16025 " name=\"Input\" />\n"
16026 " </RequiredProperties>\n"
16027 " </RepresentationTypeDomain>\n"
16028 " </StringVectorProperty>\n"
16029 " <StringVectorProperty command=\"SetCellFieldDataArrayName\"\n"
16030 " default_values=\"vtkOriginalCellIds\"\n"
16031 " name=\"SelectionCellFieldDataArrayName\"\n"
16032 " number_of_elements=\"1\"\n"
16033 " panel_visibility=\"never\">\n"
16034 " <ArrayListDomain input_domain_name=\"input_array_cell\"\n"
16035 " name=\"array_list\">\n"
16036 " <RequiredProperties>\n"
16037 " <Property function=\"Input\" name=\"Input\" />\n"
16038 " </RequiredProperties>\n"
16039 " </ArrayListDomain>\n"
16040 " </StringVectorProperty>\n"
16041 " <StringVectorProperty command=\"SetPointFieldDataArrayName\"\n"
16042 " default_values=\"vtkOriginalPointIds\"\n"
16043 " name=\"SelectionPointFieldDataArrayName\"\n"
16044 " number_of_elements=\"1\"\n"
16045 " panel_visibility=\"never\">\n"
16046 " <ArrayListDomain input_domain_name=\"input_array_point\"\n"
16047 " name=\"array_list\">\n"
16048 " <RequiredProperties>\n"
16049 " <Property function=\"Input\" name=\"Input\" />\n"
16050 " </RequiredProperties>\n"
16051 " </ArrayListDomain>\n"
16052 " </StringVectorProperty>\n"
16053 " <SubProxy>\n"
16054 " <Proxy name=\"SurfaceRepresentation\"\n"
16055 " proxygroup=\"representations\"\n"
16056 " proxyname=\"SurfaceRepresentation\"></Proxy>\n"
16057 " <ExposedProperties>\n"
16058 " <PropertyGroup panel_visibility=\"default\"\n"
16059 " panel_widget=\"ColorEditor\"\n"
16060 " label=\"Coloring\" >\n"
16061 " <Property name=\"AmbientColor\" />\n"
16062 " <Property name=\"ColorArrayName\" />\n"
16063 " <Property name=\"DiffuseColor\" />\n"
16064 " <Property name=\"LookupTable\" />\n"
16065 " <Property name=\"UseSeparateColorMap\" />\n"
16066 " </PropertyGroup>\n"
16067 "\n"
16068 " <PropertyGroup label=\"Scalar Coloring\">\n"
16069 " <Property name=\"MapScalars\"\n"
16070 " panel_visibility=\"advanced\" />\n"
16071 " <Property name=\"MultiComponentsMapping\"\n"
16072 " panel_visibility=\"advanced\" />\n"
16073 " <Property name=\"InterpolateScalarsBeforeMapping\"\n"
16074 " panel_visibility=\"advanced\" />\n"
16075 " <Property name=\"UseNanColorForMissingArrays\"\n"
16076 " panel_visibility=\"advanced\" />\n"
16077 " </PropertyGroup>\n"
16078 "\n"
16079 " <PropertyGroup label=\"Styling\">\n"
16080 " <Property name=\"Opacity\"\n"
16081 " panel_visibility=\"default\" />\n"
16082 " <Property name=\"PointSize\"\n"
16083 " panel_visibility=\"advanced\"\n"
16084 " panel_visibility_default_for_representation=\"points\" />\n"
16085 " <Property name=\"LineWidth\"\n"
16086 " panel_visibility=\"advanced\"\n"
16087 " panel_visibility_default_for_representation=\"wireframe\" />\n"
16088 " <Property name=\"RenderLinesAsTubes\"\n"
16089 " panel_visibility=\"advanced\"\n"
16090 " panel_visibility_default_for_representation=\"wireframe\"/>\n"
16091 " <Property name=\"RenderPointsAsSpheres\"\n"
16092 " panel_visibility=\"advanced\"\n"
16093 " panel_visibility_default_for_representation=\"points\"/>\n"
16094 " <Hints>\n"
16095 " <!--Hide for volume representation-->\n"
16096 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16097 " mode=\"visibility\"\n"
16098 " property=\"Representation\"\n"
16099 " value=\"Volume\"\n"
16100 " inverse=\"1\" />\n"
16101 " </Hints>\n"
16102 " </PropertyGroup>\n"
16103 " <PropertyGroup name=\"Lighting\">\n"
16104 " <Property name=\"DisableLighting\"\n"
16105 " panel_visibility=\"advanced\" />\n"
16106 " <Property name=\"Diffuse\"\n"
16107 " panel_visibility=\"advanced\" />\n"
16108 " </PropertyGroup>\n"
16109 " <PropertyGroup name=\"Lighting\">\n"
16110 " <Property name=\"Interpolation\"\n"
16111 " panel_visibility=\"advanced\" />\n"
16112 " <Property name=\"Specular\"\n"
16113 " panel_visibility=\"default\" />\n"
16114 " <Property name=\"SpecularColor\"\n"
16115 " panel_widget=\"color_selector\"\n"
16116 " panel_visibility=\"advanced\" />\n"
16117 " <Property name=\"InteractiveSelectionColor\"\n"
16118 " panel_visibility=\"never\" />\n"
16119 " <Property name=\"SpecularPower\"\n"
16120 " panel_visibility=\"advanced\" />\n"
16121 " <Property name=\"Luminosity\"\n"
16122 " panel_visibility=\"advanced\" />\n"
16123 " <Property name=\"Ambient\" panel_visibility=\"advanced\"/>\n"
16124 " <Property name=\"Roughness\" panel_visibility=\"advanced\"/>\n"
16125 " <Property name=\"Metallic\" panel_visibility=\"advanced\"/>\n"
16126 " <Property name=\"EdgeTint\"\n"
16127 " panel_widget=\"color_selector\"\n"
16128 " panel_visibility=\"advanced\"/>\n"
16129 " <Property name=\"Anisotropy\" panel_visibility=\"advanced\"/>\n"
16130 " <Property name=\"AnisotropyRotation\" panel_visibility=\"advanced\"/>\n"
16131 " <Property name=\"BaseIOR\" panel_visibility=\"advanced\"/>\n"
16132 " <Property name=\"CoatStrength\" panel_visibility=\"advanced\"/>\n"
16133 " <Property name=\"CoatIOR\" panel_visibility=\"advanced\"/>\n"
16134 " <Property name=\"CoatRoughness\" panel_visibility=\"advanced\"/>\n"
16135 " <Property name=\"CoatColor\"\n"
16136 " panel_widget=\"color_selector\"\n"
16137 " panel_visibility=\"advanced\" />\n"
16138 " <Property name=\"SelectNormalArray\" panel_visibility=\"advanced\"/>\n"
16139 " <Property name=\"SelectTangentArray\" panel_visibility=\"advanced\"/>\n"
16140 " <Hints>\n"
16141 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
16142 " <Expression type=\"and\">\n"
16143 " <!-- Hide when DisableLighting selected -->\n"
16144 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16145 " mode=\"visibility\"\n"
16146 " property=\"DisableLighting\"\n"
16147 " value=\"0\" />\n"
16148 " <!-- Hide for volume representation -->\n"
16149 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16150 " mode=\"visibility\"\n"
16151 " property=\"Representation\"\n"
16152 " value=\"Volume\"\n"
16153 " inverse=\"1\" />\n"
16154 " </Expression>\n"
16155 " </PropertyWidgetDecorator>\n"
16156 " </Hints>\n"
16157 " </PropertyGroup>\n"
16158 " <PropertyGroup name=\"Surface Normals\">\n"
16159 " <Property name=\"ComputePointNormals\"\n"
16160 " panel_visibility=\"default\"/>\n"
16161 " <Property name=\"Splitting\"\n"
16162 " panel_visibility=\"default\"/>\n"
16163 " <Property name=\"FeatureAngle\"\n"
16164 " panel_visibility=\"default\"/>\n"
16165 " <Hints>\n"
16166 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
16167 " <Expression type=\"or\">\n"
16168 " <!-- Show for Surface representation -->\n"
16169 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16170 " mode=\"visibility\"\n"
16171 " property=\"Representation\"\n"
16172 " value=\"Surface\"/>\n"
16173 " <!-- Show for Surface With Edges representation -->\n"
16174 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16175 " mode=\"visibility\"\n"
16176 " property=\"Representation\"\n"
16177 " value=\"Surface With Edges\"/>\n"
16178 " <!-- Show for Surface LIC representation -->\n"
16179 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16180 " mode=\"visibility\"\n"
16181 " property=\"Representation\"\n"
16182 " value=\"Surface LIC\"/>\n"
16183 " </Expression>\n"
16184 " </PropertyWidgetDecorator>\n"
16185 " </Hints>\n"
16186 " </PropertyGroup>\n"
16187 " <PropertyGroup label=\"Texturing\">\n"
16188 " <Property name=\"SelectTCoordArray\" panel_visibility=\"advanced\"/>\n"
16189 " <Property name=\"Texture\" panel_visibility=\"advanced\"/>\n"
16190 " <Property name=\"RepeatTextures\" panel_visibility=\"advanced\"/>\n"
16191 " <Property name=\"InterpolateTextures\" panel_visibility=\"advanced\"/>\n"
16192 " <Property name=\"SeamlessU\" panel_visibility=\"advanced\"/>\n"
16193 " <Property name=\"SeamlessV\" panel_visibility=\"advanced\"/>\n"
16194 " <Property name=\"UseMipmapTextures\" panel_visibility=\"advanced\"/>\n"
16195 " <Property name=\"ShowTexturesOnBackface\" panel_visibility=\"advanced\"/>\n"
16196 " <Property name=\"BaseColorTexture\" panel_visibility=\"advanced\"/>\n"
16197 " <Property name=\"NormalTexture\" panel_visibility=\"advanced\"/>\n"
16198 " <Property name=\"NormalScale\" panel_visibility=\"advanced\"/>\n"
16199 " <Property name=\"CoatNormalTexture\" panel_visibility=\"advanced\"/>\n"
16200 " <Property name=\"CoatNormalScale\" panel_visibility=\"advanced\"/>\n"
16201 " <Property name=\"MaterialTexture\" panel_visibility=\"advanced\"/>\n"
16202 " <Property name=\"OcclusionStrength\" panel_visibility=\"advanced\"/>\n"
16203 " <Property name=\"AnisotropyTexture\" panel_visibility=\"advanced\"/>\n"
16204 " <Property name=\"EmissiveTexture\" panel_visibility=\"advanced\"/>\n"
16205 " <Property name=\"EmissiveFactor\" panel_visibility=\"advanced\"/>\n"
16206 " <Property name=\"TextureTransform\" panel_visibility=\"advanced\"/>\n"
16207 " <Hints>\n"
16208 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
16209 " <Expression type=\"and\">\n"
16210 " <!-- Hide when DisableLighting selected -->\n"
16211 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16212 " mode=\"visibility\"\n"
16213 " property=\"DisableLighting\"\n"
16214 " value=\"0\" />\n"
16215 " <!-- Hide for volume representation -->\n"
16216 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16217 " mode=\"visibility\"\n"
16218 " property=\"Representation\"\n"
16219 " value=\"Volume\"\n"
16220 " inverse=\"1\" />\n"
16221 " </Expression>\n"
16222 " </PropertyWidgetDecorator>\n"
16223 " </Hints>\n"
16224 " </PropertyGroup>\n"
16225 "\n"
16226 " <PropertyGroup label=\"Edge Styling\">\n"
16227 " <Property name=\"EdgeColor\"\n"
16228 " panel_widget=\"color_selector_with_palette\"\n"
16229 ;
16230
16231 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
16233 " panel_visibility=\"advanced\"\n"
16234 " panel_visibility_default_for_representation=\"Surface With Edges\" />\n"
16235 " <Property name=\"EdgeOpacity\"\n"
16236 " panel_visibility=\"advanced\"\n"
16237 " panel_visibility_default_for_representation=\"Surface With Edges\" />\n"
16238 " </PropertyGroup>\n"
16239 "\n"
16240 " <PropertyGroup label=\"Backface Styling\">\n"
16241 " <Property name=\"BackfaceRepresentation\"\n"
16242 " panel_visibility=\"advanced\" />\n"
16243 " <Property name=\"BackfaceAmbientColor\"\n"
16244 " panel_widget=\"color_selector\"\n"
16245 " panel_visibility=\"advanced\" />\n"
16246 " <Property name=\"BackfaceDiffuseColor\"\n"
16247 " panel_widget=\"color_selector\"\n"
16248 " panel_visibility=\"advanced\" />\n"
16249 " <Property name=\"BackfaceOpacity\"\n"
16250 " panel_visibility=\"advanced\" />\n"
16251 " </PropertyGroup>\n"
16252 "\n"
16253 " <PropertyGroup label=\"Transforming\">\n"
16254 " <Property name=\"Position\"\n"
16255 " exposed_name=\"Translation\"\n"
16256 " panel_visibility=\"advanced\" />\n"
16257 " <Property name=\"Scale\"\n"
16258 " panel_visibility=\"advanced\" />\n"
16259 " <Property name=\"Orientation\"\n"
16260 " panel_visibility=\"advanced\" />\n"
16261 " <Property name=\"Origin\"\n"
16262 " panel_visibility=\"advanced\" />\n"
16263 " <Property name=\"CoordinateShiftScaleMethod\"\n"
16264 " panel_visibility=\"advanced\"/>\n"
16265 " </PropertyGroup>\n"
16266 "\n"
16267 " <PropertyGroup label=\"Miscellaneous\">\n"
16268 " <Property name=\"Pickable\"\n"
16269 " panel_visibility=\"advanced\" />\n"
16270 " <Property name=\"StaticMode\"\n"
16271 " panel_visibility=\"never\" />\n"
16272 " <Property name=\"SuppressLOD\"\n"
16273 " panel_visibility=\"never\" />\n"
16274 " <Property name=\"UserTransform\"\n"
16275 " panel_visibility=\"never\" />\n"
16276 " <Property name=\"Triangulate\"\n"
16277 " panel_visibility=\"advanced\" />\n"
16278 " <Property name=\"UseShaderReplacements\"\n"
16279 " panel_visibility=\"advanced\" />\n"
16280 " <Property name=\"ShaderReplacements\"\n"
16281 " panel_visibility=\"advanced\" />\n"
16282 " <Property name=\"NonlinearSubdivisionLevel\"\n"
16283 " panel_visibility=\"advanced\" />\n"
16284 " <Property name=\"MatchBoundariesIgnoringCellOrder\"\n"
16285 " panel_visibility=\"advanced\" />\n"
16286 " <Property name=\"BlockColorsDistinctValues\"\n"
16287 " panel_visibility=\"advanced\" />\n"
16288 " <Property name=\"UseDataPartitions\"\n"
16289 " panel_visibility=\"advanced\" />\n"
16290 " </PropertyGroup>\n"
16291 "\n"
16292 " <PropertyGroup panel_visibility=\"advanced\"\n"
16293 " label=\"Ray Tracing\" >\n"
16294 " <Property name=\"OSPRayUseScaleArray\" />\n"
16295 " <Property name=\"OSPRayScaleArray\" />\n"
16296 " <Property name=\"OSPRayScaleFunction\" />\n"
16297 " <Property name=\"OSPRayMaterial\" />\n"
16298 " </PropertyGroup>\n"
16299 "\n"
16300 " <PropertyGroup label=\"Blocks\"\n"
16301 " panel_widget=\"DataAssemblyEditor\"\n"
16302 " panel_visibility=\"multiblock_inspector\">\n"
16303 " <Property name=\"Assembly\" function=\"ActiveAssembly\" />\n"
16304 " <Property name=\"SelectedBlockSelectors\" function=\"SelectedSelectors\" />\n"
16305 " <Property name=\"BlockSelectors\" function=\"Selectors\" />\n"
16306 " <Hints>\n"
16307 " <DataAssemblyPropertyWidget use_inputname_as_header=\"1\" link_active_selection=\"1\"/>\n"
16308 " </Hints>\n"
16309 " </PropertyGroup>\n"
16310 "\n"
16311 " <PropertyGroup label=\"Block Coloring\"\n"
16312 " panel_visibility=\"multiblock_inspector\"\n"
16313 " panel_widget=\"BlockColorEditor\">\n"
16314 " <Property name=\"BlockColors\"/>\n"
16315 " <Property name=\"BlockColorArrayNames\"/>\n"
16316 " <Property name=\"BlockLookupTables\"/>\n"
16317 " <Property name=\"BlockUseSeparateColorMaps\"/>\n"
16318 " </PropertyGroup>\n"
16319 "\n"
16320 " <PropertyGroup label=\"Block Scalar Coloring\"\n"
16321 " panel_visibility=\"multiblock_inspector\"\n"
16322 " panel_widget=\"BlockPropertiesEditor\">\n"
16323 " <Property name=\"BlockMapScalars\" function=\"MapScalars\"/>\n"
16324 " <Property name=\"BlockInterpolateScalarsBeforeMappings\" function=\"InterpolateScalarsBeforeMappings\"/>\n"
16325 " <Property name=\"BlockOpacities\" function=\"Opacities\"/>\n"
16326 " <!-- The following properties are used to create a GUI which edits the above properties -->\n"
16327 " <Property name=\"BlockMapScalarsGUI\" function=\"MapScalarsGUI\"/>\n"
16328 " <Property name=\"BlockInterpolateScalarsBeforeMappingsGUI\" function=\"InterpolateScalarsBeforeMappingsGUI\"/>\n"
16329 " <Property name=\"BlockOpacitiesGUI\" function=\"OpacitiesGUI\"/>\n"
16330 " </PropertyGroup>\n"
16331 " </ExposedProperties>\n"
16332 " </SubProxy>\n"
16333 " <SubProxy>\n"
16334 " <Proxy name=\"OutlineRepresentation\"\n"
16335 " proxygroup=\"representations\"\n"
16336 " proxyname=\"OutlineRepresentation\"></Proxy>\n"
16337 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
16338 " <Exception name=\"Input\" />\n"
16339 " <Exception name=\"Visibility\" />\n"
16340 " </ShareProperties>\n"
16341 " </SubProxy>\n"
16342 " <SubProxy>\n"
16343 " <Proxy name=\"FeatureEdgesRepresentation\"\n"
16344 " proxygroup=\"representations\"\n"
16345 " proxyname=\"FeatureEdgesRepresentation\"></Proxy>\n"
16346 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
16347 " <Exception name=\"Input\" />\n"
16348 " <Exception name=\"Visibility\" />\n"
16349 " </ShareProperties>\n"
16350 " </SubProxy>\n"
16351 " <SubProxy>\n"
16352 " <Proxy name=\"Glyph3DRepresentation\"\n"
16353 " proxygroup=\"representations\"\n"
16354 " proxyname=\"Glyph3DRepresentation\"></Proxy>\n"
16355 " <ExposedProperties>\n"
16356 " <PropertyGroup label=\"Glyph Parameters\"\n"
16357 " panel_visibility=\"advanced\">\n"
16358 " <Property name=\"Masking\"\n"
16359 " panel_visibility=\"never\" />\n"
16360 " <Property name=\"MeshVisibility\"\n"
16361 " panel_visibility=\"never\" />\n"
16362 " <Property name=\"Orient\"\n"
16363 " panel_visibility=\"advanced\" />\n"
16364 " <Property name=\"OrientationMode\"\n"
16365 " panel_visibility=\"advanced\" />\n"
16366 " <Property name=\"SelectOrientationVectors\"\n"
16367 " panel_visibility=\"advanced\" />\n"
16368 " <Property name=\"Scaling\"\n"
16369 " panel_visibility=\"advanced\" />\n"
16370 " <Property name=\"ScaleMode\"\n"
16371 " panel_visibility=\"advanced\" />\n"
16372 " <Property name=\"ScaleFactor\"\n"
16373 " panel_visibility=\"advanced\" />\n"
16374 " <Property name=\"SelectMaskArray\"\n"
16375 " panel_visibility=\"never\" />\n"
16376 " <Property name=\"SelectScaleArray\"\n"
16377 " panel_visibility=\"advanced\" />\n"
16378 " <Property name=\"GlyphType\"\n"
16379 " panel_visibility=\"advanced\"\n"
16380 " panel_visibility_default_for_representation=\"3d glyphs\"/>\n"
16381 " <Property name=\"UseGlyphTable\"\n"
16382 " panel_visibility=\"advanced\"/>\n"
16383 " <Property name=\"GlyphTableIndexArray\"\n"
16384 " panel_visibility=\"advanced\"/>\n"
16385 " <Property name=\"UseCompositeGlyphTable\"\n"
16386 " panel_visibility=\"advanced\"/>\n"
16387 " <Property name=\"UseGlyphCullingAndLOD\"\n"
16388 " panel_visibility=\"advanced\"/>\n"
16389 " <Property name=\"LODValues\"\n"
16390 " panel_visibility=\"advanced\"/>\n"
16391 " <Property name=\"ColorByLODIndex\"\n"
16392 " panel_visibility=\"advanced\"/>\n"
16393 " <Hints>\n"
16394 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16395 " mode=\"visibility\"\n"
16396 " property=\"Representation\"\n"
16397 " value=\"3D Glyphs\" />\n"
16398 " </Hints>\n"
16399 " </PropertyGroup>\n"
16400 " </ExposedProperties>\n"
16401 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
16402 " <Exception name=\"Input\" />\n"
16403 " <Exception name=\"Visibility\" />\n"
16404 " </ShareProperties>\n"
16405 " </SubProxy>\n"
16406 " <SubProxy>\n"
16407 " <Proxy name=\"PointGaussianRepresentation\"\n"
16408 " proxygroup=\"representations\" proxyname=\"PointGaussianRepresentation\">\n"
16409 " </Proxy>\n"
16410 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
16411 " <Exception name=\"Input\" />\n"
16412 " <Exception name=\"Visibility\" />\n"
16413 " </ShareProperties>\n"
16414 " <ExposedProperties>\n"
16415 " <PropertyGroup label=\"Point Gaussian\">\n"
16416 " <Property name=\"GaussianRadius\" />\n"
16417 " <Property name=\"ShaderPreset\" />\n"
16418 " <Property name=\"CustomTriangleScale\" />\n"
16419 " <Property name=\"CustomShader\" />\n"
16420 " <Property name=\"Emissive\" />\n"
16421 " <Property name=\"ScaleByArray\" />\n"
16422 " <Property name=\"SetScaleArray\" />\n"
16423 " <Property name=\"ScaleArrayComponent\" />\n"
16424 " <Property name=\"UseScaleFunction\" />\n"
16425 " <Property name=\"ScaleTransferFunction\" />\n"
16426 " <Property name=\"OpacityByArray\" />\n"
16427 " <Property name=\"OpacityArray\" />\n"
16428 " <Property name=\"OpacityArrayComponent\" />\n"
16429 " <Property name=\"OpacityTransferFunction\" />\n"
16430 " <Hints>\n"
16431 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16432 " mode=\"visibility\"\n"
16433 " property=\"Representation\"\n"
16434 " value=\"Point Gaussian\" />\n"
16435 " </Hints>\n"
16436 " </PropertyGroup>\n"
16437 " </ExposedProperties>\n"
16438 " </SubProxy>\n"
16439 " <ProxyProperty name=\"DataAxesGrid\"\n"
16440 " command=\"SetGridAxesRepresentation\"\n"
16441 " panel_widget=\"proxy_editor\" >\n"
16442 " <ProxyListDomain name=\"proxy_list\">\n"
16443 " <Proxy group=\"representations\" name=\"GridAxesRepresentation\" />\n"
16444 " </ProxyListDomain>\n"
16445 " <Hints>\n"
16446 " <!-- tell pqProxyEditorPropertyWidget that use the \"GridAxesVisibility\"\n"
16447 " property on the GridAxes3DRepr for a checkbox on the UI -->\n"
16448 " <ProxyEditorPropertyWidget property=\"GridAxesVisibility\" />\n"
16449 " </Hints>\n"
16450 " </ProxyProperty>\n"
16451 " <SubProxy command=\"SetSelectionRepresentation\">\n"
16452 " <Proxy name=\"SelectionRepresentation\"\n"
16453 " proxygroup=\"representations\"\n"
16454 " proxyname=\"SelectionRepresentation\" />\n"
16455 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
16456 " <Exception name=\"Input\" />\n"
16457 " <Exception name=\"Visibility\" />\n"
16458 " <Exception name=\"Representation\" />\n"
16459 " <Exception name=\"Color\" />\n"
16460 " <Exception name=\"LineWidth\" />\n"
16461 " <Exception name=\"Opacity\" />\n"
16462 " <Exception name=\"PointSize\" />\n"
16463 " </ShareProperties>\n"
16464 " <ExposedProperties>\n"
16465 " <Property exposed_name=\"SelectionColor\" name=\"Color\" panel_visibility=\"never\" />\n"
16466 " <Property exposed_name=\"SelectionOpacity\" name=\"Opacity\" panel_visibility=\"never\" />\n"
16467 " <Property exposed_name=\"SelectionUseOutline\" name=\"UseOutline\" panel_visibility=\"never\" />\n"
16468 " <Property exposed_name=\"SelectionRepresentation\" name=\"Representation\" panel_visibility=\"never\" />\n"
16469 " <Property exposed_name=\"SelectionPointSize\" name=\"PointSize\" panel_visibility=\"never\" />\n"
16470 " <Property exposed_name=\"SelectionLineWidth\" name=\"LineWidth\" panel_visibility=\"never\" />\n"
16471 " <Property exposed_name=\"SelectionCellLabelVisibility\" name=\"CellLabelVisibility\" panel_visibility=\"never\"/>\n"
16472 " <PropertyGroup label=\"Cell Label Font\" panel_visibility=\"never\" panel_widget=\"FontEditor\">\n"
16473 " <Property exposed_name=\"SelectionCellLabelBold\" name=\"CellLabelBold\" function=\"Bold\"/>\n"
16474 " <Property exposed_name=\"SelectionCellLabelColor\" name=\"CellLabelColor\" function=\"Color\"/>\n"
16475 " <Property exposed_name=\"SelectionCellLabelFontFamily\" name=\"CellLabelFontFamily\" function=\"Family\"/>\n"
16476 " <Property exposed_name=\"SelectionCellLabelFontFile\" name=\"CellLabelFontFile\" function=\"File\"/>\n"
16477 " <Property exposed_name=\"SelectionCellLabelFontSize\" name=\"CellLabelFontSize\" function=\"Size\"/>\n"
16478 " <Property exposed_name=\"SelectionCellLabelItalic\" name=\"CellLabelItalic\" function=\"Italics\"/>\n"
16479 " <Property exposed_name=\"SelectionCellLabelJustification\" name=\"CellLabelJustification\" function=\"Justification\"/>\n"
16480 " <Property exposed_name=\"SelectionCellLabelOpacity\" name=\"CellLabelOpacity\" function=\"Opacity\"/>\n"
16481 " <Property exposed_name=\"SelectionCellLabelShadow\" name=\"CellLabelShadow\" function=\"Shadow\"/>\n"
16482 " </PropertyGroup>\n"
16483 " <Property exposed_name=\"SelectionCellLabelFormat\" name=\"CellLabelFormat\" panel_visibility=\"never\"/>\n"
16484 " <Property exposed_name=\"SelectionPointLabelVisibility\" name=\"PointLabelVisibility\" panel_visibility=\"never\"/>\n"
16485 " <Property exposed_name=\"SelectionMaximumNumberOfLabels\" name=\"MaximumNumberOfLabels\" panel_visibility=\"never\"/>\n"
16486 " <PropertyGroup label=\"Point Label Font\" panel_visibility=\"never\" panel_widget=\"FontEditor\">\n"
16487 " <Property exposed_name=\"SelectionPointLabelBold\" name=\"PointLabelBold\" function=\"Bold\"/>\n"
16488 " <Property exposed_name=\"SelectionPointLabelColor\" name=\"PointLabelColor\" function=\"Color\"/>\n"
16489 " <Property exposed_name=\"SelectionPointLabelFontFamily\" name=\"PointLabelFontFamily\" function=\"Family\"/>\n"
16490 " <Property exposed_name=\"SelectionPointLabelFontFile\" name=\"PointLabelFontFile\" function=\"File\"/>\n"
16491 " <Property exposed_name=\"SelectionPointLabelFontSize\" name=\"PointLabelFontSize\" function=\"Size\"/>\n"
16492 " <Property exposed_name=\"SelectionPointLabelItalic\" name=\"PointLabelItalic\" function=\"Italics\"/>\n"
16493 " <Property exposed_name=\"SelectionPointLabelJustification\" name=\"PointLabelJustification\" function=\"Justification\"/>\n"
16494 " <Property exposed_name=\"SelectionPointLabelOpacity\" name=\"PointLabelOpacity\" function=\"Opacity\"/>\n"
16495 " <Property exposed_name=\"SelectionPointLabelShadow\" name=\"PointLabelShadow\" function=\"Shadow\"/>\n"
16496 " </PropertyGroup>\n"
16497 " <Property exposed_name=\"SelectionPointLabelFormat\" name=\"PointLabelFormat\" panel_visibility=\"never\"/>\n"
16498 " </ExposedProperties>\n"
16499 " </SubProxy>\n"
16500 " <ProxyProperty name=\"PolarAxes\"\n"
16501 " command=\"SetPolarAxesRepresentation\"\n"
16502 " panel_visibility=\"advanced\"\n"
16503 " panel_widget=\"proxy_editor\">\n"
16504 ;
16505
16506 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
16508 " <ProxyListDomain name=\"proxy_list\">\n"
16509 " <Proxy group=\"representations\" name=\"PolarAxesRepresentation\" />\n"
16510 " </ProxyListDomain>\n"
16511 " <Hints>\n"
16512 " <ProxyEditorPropertyWidget property=\"Visibility\"/>\n"
16513 " <!-- tell pqProxyEditorPropertyWidget that use the \"Visibility\"\n"
16514 " property on the PolarAxesActor proxy for a checkbox\n"
16515 " on the UI -->\n"
16516 " </Hints>\n"
16517 " </ProxyProperty>\n"
16518 " <PropertyGroup label=\"Annotations\">\n"
16519 " <Property name=\"PolarAxes\"\n"
16520 " panel_visibility=\"advanced\" />\n"
16521 " </PropertyGroup>\n"
16522 " </PVRepresentationProxy>\n"
16523 "\n"
16524 " <!-- A proxy for composite datasets holding cell grids -->\n"
16525 " <PVRepresentationProxy class=\"vtkPVCompositeRepresentation\"\n"
16526 " name=\"PVCellGridRepresentationBase\"\n"
16527 " processes=\"client|renderserver|dataserver\">\n"
16528 " <Documentation>ParaView's default representation for showing any type of\n"
16529 " dataset in the render view.</Documentation>\n"
16530 " <InputProperty command=\"SetSelectionConnection\"\n"
16531 " name=\"Selection\">\n"
16532 " <DataTypeDomain name=\"input_type\">\n"
16533 " <DataType value=\"vtkSelection\" />\n"
16534 " </DataTypeDomain>\n"
16535 " <Documentation>Set the selection.</Documentation>\n"
16536 " </InputProperty>\n"
16537 " <IntVectorProperty command=\"SetVisibility\"\n"
16538 " default_values=\"1\"\n"
16539 " name=\"Visibility\"\n"
16540 " number_of_elements=\"1\"\n"
16541 " panel_visibility=\"never\">\n"
16542 " <BooleanDomain name=\"bool\" />\n"
16543 " <Documentation>Set the visibility for this\n"
16544 " representation.</Documentation>\n"
16545 " </IntVectorProperty>\n"
16546 " <IntVectorProperty command=\"SetForceUseCache\"\n"
16547 " default_values=\"0\"\n"
16548 " is_internal=\"1\"\n"
16549 " name=\"ForceUseCache\"\n"
16550 " number_of_elements=\"1\">\n"
16551 " <BooleanDomain name=\"bool\" />\n"
16552 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
16553 " and representations cache based on what the view tells it. However in\n"
16554 " some cases we may want to force a representation to cache irrespective\n"
16555 " of the view (e.g. comparative views). In which case these ivars can up\n"
16556 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
16557 " Instead, ForcedCacheKey is used.</Documentation>\n"
16558 " </IntVectorProperty>\n"
16559 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
16560 " default_values=\"none\"\n"
16561 " is_internal=\"1\"\n"
16562 " name=\"ForcedCacheKey\"\n"
16563 " number_of_elements=\"1\">\n"
16564 " <DoubleRangeDomain name=\"range\" />\n"
16565 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
16566 " and representations cache based on what the view tells it. However in\n"
16567 " some cases we may want to force a representation to cache irrespective\n"
16568 " of the view (e.g. comparative views). In which case these ivars can up\n"
16569 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
16570 " Instead, ForcedCacheKey is used.</Documentation>\n"
16571 " </DoubleVectorProperty>\n"
16572 " <IntVectorProperty command=\"SetSelectionVisibility\"\n"
16573 " default_values=\"1\"\n"
16574 " name=\"SelectionVisibility\"\n"
16575 " number_of_elements=\"1\"\n"
16576 " panel_visibility=\"never\">\n"
16577 " <BooleanDomain name=\"bool\" />\n"
16578 " <Documentation>Set the visibility for the selection, if\n"
16579 " any.</Documentation>\n"
16580 " </IntVectorProperty>\n"
16581 " <RepresentationType subproxy=\"OutlineRepresentation\"\n"
16582 " text=\"Outline\" />\n"
16583 " <RepresentationType subproxy=\"CellGridSurfaceRepresentation\"\n"
16584 " subtype=\"Surface\"\n"
16585 " text=\"Surface\" />\n"
16586 " <StringVectorProperty command=\"GetRepresentationTypes\"\n"
16587 " information_only=\"1\"\n"
16588 " name=\"RepresentationTypesInfo\"\n"
16589 " si_class=\"vtkSIDataArrayProperty\">\n"
16590 " <Documentation>Property that lists the available representation types.\n"
16591 " This is used by the domain for \"Representation\" to setup the list of\n"
16592 " types available correctly.</Documentation>\n"
16593 " </StringVectorProperty>\n"
16594 " <StringVectorProperty command=\"SetActiveRepresentation\"\n"
16595 " default_values=\"Surface\"\n"
16596 " name=\"Representation\"\n"
16597 " number_of_elements=\"1\"\n"
16598 " panel_visibility=\"default\"\n"
16599 " panel_widget=\"display_representation_selector\" >\n"
16600 " <Documentation>Choose the type for the representation.</Documentation>\n"
16601 " <RepresentationTypeDomain name=\"list\">\n"
16602 " <RequiredProperties>\n"
16603 " <Property function=\"StringList\"\n"
16604 " name=\"RepresentationTypesInfo\" />\n"
16605 " <Property function=\"Input\"\n"
16606 " name=\"Input\" />\n"
16607 " </RequiredProperties>\n"
16608 " </RepresentationTypeDomain>\n"
16609 " </StringVectorProperty>\n"
16610 " <StringVectorProperty command=\"SetCellFieldDataArrayName\"\n"
16611 " default_values=\"vtkOriginalCellIds\"\n"
16612 " name=\"SelectionCellFieldDataArrayName\"\n"
16613 " number_of_elements=\"1\"\n"
16614 " panel_visibility=\"never\">\n"
16615 " <ArrayListDomain input_domain_name=\"input_array_cell\"\n"
16616 " name=\"array_list\">\n"
16617 " <RequiredProperties>\n"
16618 " <Property function=\"Input\" name=\"Input\" />\n"
16619 " </RequiredProperties>\n"
16620 " </ArrayListDomain>\n"
16621 " </StringVectorProperty>\n"
16622 " <StringVectorProperty command=\"SetPointFieldDataArrayName\"\n"
16623 " default_values=\"vtkOriginalPointIds\"\n"
16624 " name=\"SelectionPointFieldDataArrayName\"\n"
16625 " number_of_elements=\"1\"\n"
16626 " panel_visibility=\"never\">\n"
16627 " <ArrayListDomain input_domain_name=\"input_array_point\"\n"
16628 " name=\"array_list\">\n"
16629 " <RequiredProperties>\n"
16630 " <Property function=\"Input\" name=\"Input\" />\n"
16631 " </RequiredProperties>\n"
16632 " </ArrayListDomain>\n"
16633 " </StringVectorProperty>\n"
16634 " <SubProxy>\n"
16635 " <Proxy name=\"CellGridSurfaceRepresentation\"\n"
16636 " proxygroup=\"representations\"\n"
16637 " proxyname=\"CellGridSurfaceRepresentation\"></Proxy>\n"
16638 " <ExposedProperties>\n"
16639 " <PropertyGroup panel_visibility=\"default\"\n"
16640 " label=\"Style\" >\n"
16641 " <Property name=\"SidesToShow\" />\n"
16642 " <Property name=\"PreserveRenderableInputs\" />\n"
16643 " <Property name=\"OmitSidesForRenderableInputs\" />\n"
16644 " </PropertyGroup>\n"
16645 "\n"
16646 " <PropertyGroup panel_visibility=\"default\"\n"
16647 " panel_widget=\"ColorEditor\"\n"
16648 " label=\"Coloring\" >\n"
16649 " <Property name=\"AmbientColor\" />\n"
16650 " <Property name=\"ColorArrayName\" />\n"
16651 " <Property name=\"DiffuseColor\" />\n"
16652 " <Property name=\"LookupTable\" />\n"
16653 " <Property name=\"UseSeparateColorMap\" />\n"
16654 " </PropertyGroup>\n"
16655 "\n"
16656 " <PropertyGroup label=\"Scalar Coloring\">\n"
16657 " <Property name=\"MapScalars\"\n"
16658 " panel_visibility=\"advanced\" />\n"
16659 " <Property name=\"MultiComponentsMapping\"\n"
16660 " panel_visibility=\"advanced\" />\n"
16661 " <Property name=\"InterpolateScalarsBeforeMapping\"\n"
16662 " panel_visibility=\"advanced\" />\n"
16663 " </PropertyGroup>\n"
16664 "\n"
16665 " <PropertyGroup label=\"Styling\">\n"
16666 " <Property name=\"Opacity\"\n"
16667 " panel_visibility=\"default\" />\n"
16668 " <Property name=\"PointSize\"\n"
16669 " panel_visibility=\"advanced\"\n"
16670 " panel_visibility_default_for_representation=\"points\" />\n"
16671 " <Property name=\"LineWidth\"\n"
16672 " panel_visibility=\"advanced\"\n"
16673 " panel_visibility_default_for_representation=\"wireframe\" />\n"
16674 " <Property name=\"RenderLinesAsTubes\"\n"
16675 " panel_visibility=\"advanced\"\n"
16676 " panel_visibility_default_for_representation=\"wireframe\"/>\n"
16677 " <Property name=\"RenderPointsAsSpheres\"\n"
16678 " panel_visibility=\"advanced\"\n"
16679 " panel_visibility_default_for_representation=\"points\"/>\n"
16680 " </PropertyGroup>\n"
16681 " <PropertyGroup name=\"Lighting\">\n"
16682 " <Property name=\"Interpolation\"\n"
16683 " panel_visibility=\"advanced\" />\n"
16684 " <Property name=\"Diffuse\" panel_visibility=\"advanced\"/>\n"
16685 " <Property name=\"Specular\"\n"
16686 " panel_visibility=\"default\" />\n"
16687 " <Property name=\"SpecularColor\"\n"
16688 " panel_widget=\"color_selector\"\n"
16689 " panel_visibility=\"advanced\" />\n"
16690 " <Property name=\"InteractiveSelectionColor\"\n"
16691 " panel_visibility=\"never\" />\n"
16692 " <Property name=\"SpecularPower\"\n"
16693 " panel_visibility=\"advanced\" />\n"
16694 " <Property name=\"Luminosity\"\n"
16695 " panel_visibility=\"advanced\" />\n"
16696 " <Property name=\"Ambient\" panel_visibility=\"advanced\"/>\n"
16697 " </PropertyGroup>\n"
16698 "\n"
16699 " <PropertyGroup label=\"Edge Styling\">\n"
16700 " <Property name=\"EdgeColor\"\n"
16701 " panel_widget=\"color_selector_with_palette\"\n"
16702 " panel_visibility=\"advanced\"\n"
16703 " panel_visibility_default_for_representation=\"Surface With Edges\" />\n"
16704 " </PropertyGroup>\n"
16705 "\n"
16706 " <PropertyGroup label=\"Transforming\">\n"
16707 " <Property name=\"Position\"\n"
16708 " exposed_name=\"Translation\"\n"
16709 " panel_visibility=\"advanced\" />\n"
16710 " <Property name=\"Scale\"\n"
16711 " panel_visibility=\"advanced\" />\n"
16712 " <Property name=\"Orientation\"\n"
16713 " panel_visibility=\"advanced\" />\n"
16714 " <Property name=\"Origin\"\n"
16715 " panel_visibility=\"advanced\" />\n"
16716 " </PropertyGroup>\n"
16717 "\n"
16718 " <PropertyGroup label=\"Miscellaneous\">\n"
16719 " <Property name=\"Pickable\"\n"
16720 " panel_visibility=\"advanced\" />\n"
16721 " <Property name=\"StaticMode\"\n"
16722 " panel_visibility=\"never\" />\n"
16723 " <Property name=\"SuppressLOD\"\n"
16724 " panel_visibility=\"never\" />\n"
16725 " <Property name=\"UserTransform\"\n"
16726 " panel_visibility=\"never\" />\n"
16727 " <Property name=\"BlockColorsDistinctValues\"\n"
16728 " panel_visibility=\"advanced\" />\n"
16729 " <Property name=\"UseDataPartitions\"\n"
16730 " panel_visibility=\"advanced\" />\n"
16731 " </PropertyGroup>\n"
16732 "\n"
16733 " <PropertyGroup label=\"Blocks\"\n"
16734 " panel_widget=\"DataAssemblyEditor\"\n"
16735 " panel_visibility=\"multiblock_inspector\">\n"
16736 " <Property name=\"Assembly\" function=\"ActiveAssembly\"/>\n"
16737 " <Property name=\"SelectedBlockSelectors\" function=\"SelectedSelectors\"/>\n"
16738 " <Property name=\"BlockSelectors\" function=\"Selectors\"/>\n"
16739 " <Hints>\n"
16740 " <DataAssemblyPropertyWidget use_inputname_as_header=\"1\" link_active_selection=\"1\"/>\n"
16741 " </Hints>\n"
16742 " </PropertyGroup>\n"
16743 "\n"
16744 " <PropertyGroup label=\"Block Coloring\"\n"
16745 " panel_visibility=\"multiblock_inspector\"\n"
16746 " panel_widget=\"BlockColorEditor\">\n"
16747 " <Property name=\"BlockColors\"/>\n"
16748 " <Property name=\"BlockColorArrayNames\"/>\n"
16749 " <Property name=\"BlockLookupTables\"/>\n"
16750 " <Property name=\"BlockUseSeparateColorMaps\"/>\n"
16751 " </PropertyGroup>\n"
16752 "\n"
16753 " <PropertyGroup label=\"Block Scalar Coloring\"\n"
16754 " panel_visibility=\"multiblock_inspector\"\n"
16755 " panel_widget=\"BlockPropertiesEditor\">\n"
16756 " <Property name=\"BlockMapScalars\" function=\"MapScalars\"/>\n"
16757 " <Property name=\"BlockInterpolateScalarsBeforeMappings\" function=\"InterpolateScalarsBeforeMappings\"/>\n"
16758 " <Property name=\"BlockOpacities\" function=\"Opacities\"/>\n"
16759 " <!-- The following properties are used to create a GUI which edits the above properties -->\n"
16760 " <Property name=\"BlockMapScalarsGUI\" function=\"MapScalarsGUI\"/>\n"
16761 " <Property name=\"BlockInterpolateScalarsBeforeMappingsGUI\" function=\"InterpolateScalarsBeforeMappingsGUI\"/>\n"
16762 " <Property name=\"BlockOpacitiesGUI\" function=\"OpacitiesGUI\"/>\n"
16763 " </PropertyGroup>\n"
16764 "\n"
16765 " </ExposedProperties>\n"
16766 " </SubProxy>\n"
16767 " <SubProxy>\n"
16768 " <Proxy name=\"OutlineRepresentation\"\n"
16769 " proxygroup=\"representations\"\n"
16770 " proxyname=\"OutlineRepresentation\"></Proxy>\n"
16771 " <ShareProperties subproxy=\"CellGridSurfaceRepresentation\">\n"
16772 " <Exception name=\"Input\" />\n"
16773 " <Exception name=\"Visibility\" />\n"
16774 " </ShareProperties>\n"
16775 " </SubProxy>\n"
16776 " <ProxyProperty name=\"DataAxesGrid\"\n"
16777 " command=\"SetGridAxesRepresentation\"\n"
16778 " panel_widget=\"proxy_editor\" >\n"
16779 " <ProxyListDomain name=\"proxy_list\">\n"
16780 " <Proxy group=\"representations\" name=\"GridAxesRepresentation\" />\n"
16781 " </ProxyListDomain>\n"
16782 " <Hints>\n"
16783 " <!-- tell pqProxyEditorPropertyWidget that use the \"GridAxesVisibility\"\n"
16784 " property on the GridAxes3DRepr for a checkbox on the UI -->\n"
16785 " <ProxyEditorPropertyWidget property=\"GridAxesVisibility\" />\n"
16786 " </Hints>\n"
16787 " </ProxyProperty>\n"
16788 " <SubProxy command=\"SetSelectionRepresentation\">\n"
16789 " <Proxy name=\"SelectionRepresentation\"\n"
16790 " proxygroup=\"representations\"\n"
16791 " proxyname=\"SelectionRepresentation\" />\n"
16792 " <ShareProperties subproxy=\"CellGridSurfaceRepresentation\">\n"
16793 " <Exception name=\"Input\" />\n"
16794 " <Exception name=\"Visibility\" />\n"
16795 " <Exception name=\"Representation\" />\n"
16796 " <Exception name=\"Color\" />\n"
16797 " <Exception name=\"LineWidth\" />\n"
16798 " <Exception name=\"Opacity\" />\n"
16799 " <Exception name=\"PointSize\" />\n"
16800 " </ShareProperties>\n"
16801 " <ExposedProperties>\n"
16802 " <Property exposed_name=\"SelectionColor\" name=\"Color\" panel_visibility=\"never\" />\n"
16803 " <Property exposed_name=\"SelectionOpacity\" name=\"Opacity\" panel_visibility=\"never\" />\n"
16804 " <Property exposed_name=\"SelectionUseOutline\" name=\"UseOutline\" panel_visibility=\"never\" />\n"
16805 ;
16806
16807 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
16809 " <Property exposed_name=\"SelectionRepresentation\" name=\"Representation\" panel_visibility=\"never\" />\n"
16810 " <Property exposed_name=\"SelectionPointSize\" name=\"PointSize\" panel_visibility=\"never\" />\n"
16811 " <Property exposed_name=\"SelectionLineWidth\" name=\"LineWidth\" panel_visibility=\"never\" />\n"
16812 " <Property exposed_name=\"SelectionCellLabelVisibility\" name=\"CellLabelVisibility\" panel_visibility=\"never\"/>\n"
16813 " <PropertyGroup label=\"Cell Label Font\" panel_visibility=\"never\" panel_widget=\"FontEditor\">\n"
16814 " <Property exposed_name=\"SelectionCellLabelBold\" name=\"CellLabelBold\" function=\"Bold\"/>\n"
16815 " <Property exposed_name=\"SelectionCellLabelColor\" name=\"CellLabelColor\" function=\"Color\"/>\n"
16816 " <Property exposed_name=\"SelectionCellLabelFontFamily\" name=\"CellLabelFontFamily\" function=\"Family\"/>\n"
16817 " <Property exposed_name=\"SelectionCellLabelFontFile\" name=\"CellLabelFontFile\" function=\"File\"/>\n"
16818 " <Property exposed_name=\"SelectionCellLabelFontSize\" name=\"CellLabelFontSize\" function=\"Size\"/>\n"
16819 " <Property exposed_name=\"SelectionCellLabelItalic\" name=\"CellLabelItalic\" function=\"Italics\"/>\n"
16820 " <Property exposed_name=\"SelectionCellLabelJustification\" name=\"CellLabelJustification\" function=\"Justification\"/>\n"
16821 " <Property exposed_name=\"SelectionCellLabelOpacity\" name=\"CellLabelOpacity\" function=\"Opacity\"/>\n"
16822 " <Property exposed_name=\"SelectionCellLabelShadow\" name=\"CellLabelShadow\" function=\"Shadow\"/>\n"
16823 " </PropertyGroup>\n"
16824 " <Property exposed_name=\"SelectionCellLabelFormat\" name=\"CellLabelFormat\" panel_visibility=\"never\"/>\n"
16825 " <Property exposed_name=\"SelectionPointLabelVisibility\" name=\"PointLabelVisibility\" panel_visibility=\"never\"/>\n"
16826 " <Property exposed_name=\"SelectionMaximumNumberOfLabels\" name=\"MaximumNumberOfLabels\" panel_visibility=\"never\"/>\n"
16827 " <PropertyGroup label=\"Point Label Font\" panel_visibility=\"never\" panel_widget=\"FontEditor\">\n"
16828 " <Property exposed_name=\"SelectionPointLabelBold\" name=\"PointLabelBold\" function=\"Bold\"/>\n"
16829 " <Property exposed_name=\"SelectionPointLabelColor\" name=\"PointLabelColor\" function=\"Color\"/>\n"
16830 " <Property exposed_name=\"SelectionPointLabelFontFamily\" name=\"PointLabelFontFamily\" function=\"Family\"/>\n"
16831 " <Property exposed_name=\"SelectionPointLabelFontFile\" name=\"PointLabelFontFile\" function=\"File\"/>\n"
16832 " <Property exposed_name=\"SelectionPointLabelFontSize\" name=\"PointLabelFontSize\" function=\"Size\"/>\n"
16833 " <Property exposed_name=\"SelectionPointLabelItalic\" name=\"PointLabelItalic\" function=\"Italics\"/>\n"
16834 " <Property exposed_name=\"SelectionPointLabelJustification\" name=\"PointLabelJustification\" function=\"Justification\"/>\n"
16835 " <Property exposed_name=\"SelectionPointLabelOpacity\" name=\"PointLabelOpacity\" function=\"Opacity\"/>\n"
16836 " <Property exposed_name=\"SelectionPointLabelShadow\" name=\"PointLabelShadow\" function=\"Shadow\"/>\n"
16837 " </PropertyGroup>\n"
16838 " <Property exposed_name=\"SelectionPointLabelFormat\" name=\"PointLabelFormat\" panel_visibility=\"never\"/>\n"
16839 " </ExposedProperties>\n"
16840 " </SubProxy>\n"
16841 " <!-- End of PVCellGridRepresentationBase -->\n"
16842 " </PVRepresentationProxy>\n"
16843 " </ProxyGroup>\n"
16844 "\n"
16845 " <!-- ==================================================================== -->\n"
16846 " <ProxyGroup name=\"representations\">\n"
16847 " <!-- ================================================================== -->\n"
16848 " <PVRepresentationProxy base_proxygroup=\"internal_representations\"\n"
16849 " base_proxyname=\"PVRepresentationBase\"\n"
16850 " class=\"vtkPVCompositeRepresentation\"\n"
16851 " name=\"GeometryRepresentation\"\n"
16852 " processes=\"client|renderserver|dataserver\">\n"
16853 " <Documentation>ParaView's default representation for showing any type of\n"
16854 " dataset in the render view.</Documentation>\n"
16855 " <InputProperty command=\"SetInputConnection\"\n"
16856 " name=\"Input\">\n"
16857 " <DataTypeDomain composite_data_supported=\"1\"\n"
16858 " name=\"input_type\">\n"
16859 " <DataType value=\"vtkDataSet\" />\n"
16860 " <DataType value=\"vtkGenericDataSet\" />\n"
16861 "\n"
16862 " <!-- for MB, we want to match if any of the leaf nodes is of the following type -->\n"
16863 " <DataType value=\"vtkDataObjectTree\" child_match=\"any\">\n"
16864 " <DataType value=\"vtkDataSet\" />\n"
16865 " <DataType value=\"vtkGenericDataSet\" />\n"
16866 " </DataType>\n"
16867 "\n"
16868 " </DataTypeDomain>\n"
16869 " <InputArrayDomain attribute_type=\"cell\"\n"
16870 " name=\"input_array_cell\"\n"
16871 " optional=\"1\"></InputArrayDomain>\n"
16872 " <InputArrayDomain attribute_type=\"point\"\n"
16873 " name=\"input_array_point\"\n"
16874 " optional=\"1\"></InputArrayDomain>\n"
16875 " <Documentation>Set the input to the representation.</Documentation>\n"
16876 " </InputProperty>\n"
16877 " <!-- End of GeometryRepresentation -->\n"
16878 " </PVRepresentationProxy>\n"
16879 "\n"
16880 " <!-- ================================================================== -->\n"
16881 " <PVRepresentationProxy base_proxygroup=\"internal_representations\"\n"
16882 " base_proxyname=\"PVRepresentationBase\"\n"
16883 " class=\"vtkPVCompositeRepresentation\"\n"
16884 " name=\"UnstructuredGridRepresentation\"\n"
16885 " processes=\"client|renderserver|dataserver\">\n"
16886 " <Documentation>This representation is used to show unstructured grid as\n"
16887 " Surface/Outline/Points/Wireframe/Volume</Documentation>\n"
16888 " <!-- this adds to what is already defined in PVRepresentationBase -->\n"
16889 " <RepresentationType subproxy=\"VolumeRepresentation\"\n"
16890 " text=\"Volume\" />\n"
16891 " <InputProperty command=\"SetInputConnection\"\n"
16892 " name=\"Input\">\n"
16893 " <DataTypeDomain composite_data_supported=\"1\"\n"
16894 " name=\"input_type\">\n"
16895 " <DataType value=\"vtkUnstructuredGrid\" />\n"
16896 " <DataType value=\"vtkUnstructuredGridBase\" />\n"
16897 " </DataTypeDomain>\n"
16898 " <InputArrayDomain attribute_type=\"cell\"\n"
16899 " name=\"input_array_cell\"\n"
16900 " optional=\"1\"></InputArrayDomain>\n"
16901 " <InputArrayDomain attribute_type=\"point\"\n"
16902 " name=\"input_array_point\"\n"
16903 " optional=\"1\"></InputArrayDomain>\n"
16904 " <Documentation>Set the input to the representation.</Documentation>\n"
16905 " </InputProperty>\n"
16906 " <SubProxy>\n"
16907 " <Proxy name=\"VolumeRepresentation\"\n"
16908 " proxygroup=\"representations\"\n"
16909 " proxyname=\"UnstructuredGridVolumeRepresentation\" />\n"
16910 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
16911 " <Exception name=\"Input\" />\n"
16912 " <Exception name=\"Visibility\" />\n"
16913 " </ShareProperties>\n"
16914 " <ExposedProperties>\n"
16915 " <PropertyGroup label=\"Volume Rendering\">\n"
16916 " <Property name=\"ScalarOpacityFunction\" />\n"
16917 " <Property name=\"ScalarOpacityUnitDistance\"\n"
16918 " panel_visibility=\"advanced\" />\n"
16919 " <Property name=\"UseSeparateOpacityArray\"\n"
16920 " panel_visibility=\"advanced\" />\n"
16921 " <Property name=\"OpacityArrayName\"\n"
16922 " panel_visibility=\"advanced\" />\n"
16923 " <Property name=\"OpacityComponent\"\n"
16924 " panel_visibility=\"advanced\" />\n"
16925 " <Property name=\"SelectMapper\"\n"
16926 " panel_visibility=\"advanced\"\n"
16927 " panel_visibility_default_for_representation=\"volume\" />\n"
16928 " <Property name=\"SamplingDimensions\"\n"
16929 " panel_visibility=\"advanced\"\n"
16930 " panel_visibility_default_for_representation=\"volume\"/>\n"
16931 " <Property name=\"UseFloatingPointFrameBuffer\" />\n"
16932 " <Hints>\n"
16933 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
16934 " <Expression type=\"or\">\n"
16935 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16936 " mode=\"visibility\"\n"
16937 " property=\"Representation\"\n"
16938 " value=\"Volume\" />\n"
16939 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
16940 " mode=\"visibility\"\n"
16941 " property=\"Representation\"\n"
16942 " value=\"NVIDIA IndeX\" />\n"
16943 " </Expression>\n"
16944 " </PropertyWidgetDecorator>\n"
16945 " </Hints>\n"
16946 " </PropertyGroup>\n"
16947 " </ExposedProperties>\n"
16948 " </SubProxy>\n"
16949 " <Hints>\n"
16950 " <!-- pqDisplayRepresentationWidget respects this hint to put out\n"
16951 " a warning for the user before switching to this type of Representation.\n"
16952 " The user can then accept or reject the change.\n"
16953 " BUG #15117\n"
16954 " -->\n"
16955 " <WarnOnRepresentationChange value=\"Volume\" />\n"
16956 " <!-- pqDisplayColorWidget disables \"Solid Color\" for this representation type -->\n"
16957 " <NoSolidColor representation=\"Volume\" />\n"
16958 " </Hints>\n"
16959 " <!-- End of UnstructuredGridRepresentation -->\n"
16960 " </PVRepresentationProxy>\n"
16961 "\n"
16962 " <!-- ================================================================== -->\n"
16963 " <PVRepresentationProxy base_proxygroup=\"internal_representations\"\n"
16964 " base_proxyname=\"PVCellGridRepresentationBase\"\n"
16965 " class=\"vtkPVCompositeRepresentation\"\n"
16966 " name=\"CellGridRepresentation\"\n"
16967 " processes=\"client|renderserver|dataserver\">\n"
16968 " <Documentation>This representation is used to show cell grids as\n"
16969 " Surface/Surface+Edges/Wireframe</Documentation>\n"
16970 " <InputProperty command=\"SetInputConnection\"\n"
16971 " name=\"Input\">\n"
16972 " <DataTypeDomain composite_data_supported=\"1\"\n"
16973 " name=\"input_type\">\n"
16974 " <DataType value=\"vtkCellGrid\" />\n"
16975 "\n"
16976 " <!-- for MB, we want to match if any of the leaf nodes is of the following type -->\n"
16977 " <DataType value=\"vtkDataObjectTree\" child_match=\"all\">\n"
16978 " <DataType value=\"vtkCellGrid\" />\n"
16979 " </DataType>\n"
16980 "\n"
16981 " </DataTypeDomain>\n"
16982 " <InputArrayDomain attribute_type=\"cell\"\n"
16983 " name=\"input_array_cell\"\n"
16984 " optional=\"1\"></InputArrayDomain>\n"
16985 " <InputArrayDomain attribute_type=\"point\"\n"
16986 " name=\"input_array_point\"\n"
16987 " optional=\"1\"></InputArrayDomain>\n"
16988 " <Documentation>Set the input to the representation.</Documentation>\n"
16989 " </InputProperty>\n"
16990 " <!-- End of CellGridRepresentation -->\n"
16991 " </PVRepresentationProxy>\n"
16992 "\n"
16993 " <!-- ================================================================== -->\n"
16994 " <PVRepresentationProxy base_proxygroup=\"internal_representations\"\n"
16995 " base_proxyname=\"PVRepresentationBase\"\n"
16996 " class=\"vtkPVCompositeRepresentation\"\n"
16997 " name=\"StructuredGridRepresentation\"\n"
16998 " processes=\"client|renderserver|dataserver\">\n"
16999 " <Documentation>This representation is used to show structured grid as\n"
17000 " Surface/Outline/Points/Wireframe/Volume</Documentation>\n"
17001 " <!-- this adds to what is already defined in PVRepresentationBase -->\n"
17002 " <RepresentationType subproxy=\"VolumeRepresentation\"\n"
17003 " text=\"Volume\" />\n"
17004 " <InputProperty command=\"SetInputConnection\"\n"
17005 " name=\"Input\">\n"
17006 " <DataTypeDomain composite_data_supported=\"1\"\n"
17007 " name=\"input_type\">\n"
17008 " <DataType value=\"vtkStructuredGrid\" />\n"
17009 " </DataTypeDomain>\n"
17010 " <InputArrayDomain attribute_type=\"point\"\n"
17011 " name=\"input_array_point\"\n"
17012 " optional=\"1\"></InputArrayDomain>\n"
17013 " <Documentation>Set the input to the representation.</Documentation>\n"
17014 " </InputProperty>\n"
17015 " <SubProxy>\n"
17016 " <Proxy name=\"VolumeRepresentation\"\n"
17017 " proxygroup=\"representations\"\n"
17018 " proxyname=\"StructuredGridVolumeRepresentation\" />\n"
17019 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
17020 " <Exception name=\"Input\" />\n"
17021 " <Exception name=\"Visibility\" />\n"
17022 " </ShareProperties>\n"
17023 " <ExposedProperties>\n"
17024 " <PropertyGroup label=\"Volume Rendering\">\n"
17025 " <Property name=\"ScalarOpacityFunction\" />\n"
17026 " <Property name=\"ScalarOpacityUnitDistance\"\n"
17027 " panel_visibility=\"advanced\" />\n"
17028 " <Property name=\"SelectMapper\"\n"
17029 " panel_visibility=\"advanced\"\n"
17030 " panel_visibility_default_for_representation=\"volume\" />\n"
17031 " <Property name=\"SamplingDimensions\"\n"
17032 " panel_visibility=\"advanced\"\n"
17033 " panel_visibility_default_for_representation=\"volume\"/>\n"
17034 " <Hints>\n"
17035 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17036 " mode=\"visibility\"\n"
17037 " property=\"Representation\"\n"
17038 " value=\"Volume\" />\n"
17039 " </Hints>\n"
17040 " </PropertyGroup>\n"
17041 " </ExposedProperties>\n"
17042 " </SubProxy>\n"
17043 " <Hints>\n"
17044 " <!-- pqDisplayRepresentationWidget respects this hint to put out\n"
17045 " a warning for the user before switching to this type of Representation.\n"
17046 " The user can then accept or reject the change.\n"
17047 " BUG #15117\n"
17048 " -->\n"
17049 " <WarnOnRepresentationChange value=\"Volume\" />\n"
17050 " <!-- pqDisplayColorWidget disables \"Solid Color\" for this representation type -->\n"
17051 " <NoSolidColor representation=\"Volume\" />\n"
17052 " </Hints>\n"
17053 " <!-- End of StructuredGridRepresentation -->\n"
17054 " </PVRepresentationProxy>\n"
17055 "\n"
17056 " <!-- ================================================================== -->\n"
17057 " <PVRepresentationProxy base_proxygroup=\"internal_representations\"\n"
17058 " base_proxyname=\"PVRepresentationBase\"\n"
17059 " class=\"vtkPVCompositeRepresentation\"\n"
17060 " name=\"UniformGridRepresentation\"\n"
17061 " processes=\"client|renderserver|dataserver\">\n"
17062 " <Documentation>This representation is used to show image data as\n"
17063 " Surface/Outline/Points/Wireframe/Volume/Slice.</Documentation>\n"
17064 " <!-- this adds to the types already defined in PVRepresentationBase -->\n"
17065 " <RepresentationType subproxy=\"VolumeRepresentation\"\n"
17066 " text=\"Volume\" />\n"
17067 " <RepresentationType subproxy=\"SliceRepresentation\"\n"
17068 " text=\"Slice\" />\n"
17069 " <InputProperty command=\"SetInputConnection\"\n"
17070 ;
17071
17072 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
17074 " name=\"Input\">\n"
17075 " <DataTypeDomain composite_data_supported=\"1\"\n"
17076 " name=\"input_type\">\n"
17077 " <DataType value=\"vtkImageData\" />\n"
17078 " <DataType value=\"vtkRectilinearGrid\" />\n"
17079 " </DataTypeDomain>\n"
17080 " <InputArrayDomain attribute_type=\"cell\"\n"
17081 " name=\"input_array_cell\"\n"
17082 " optional=\"1\"></InputArrayDomain>\n"
17083 " <InputArrayDomain attribute_type=\"point\"\n"
17084 " name=\"input_array_point\"\n"
17085 " optional=\"1\"></InputArrayDomain>\n"
17086 " <Documentation>Set the input to the representation.</Documentation>\n"
17087 " </InputProperty>\n"
17088 " <SubProxy>\n"
17089 " <Proxy name=\"VolumeRepresentation\"\n"
17090 " proxygroup=\"representations\"\n"
17091 " proxyname=\"UniformGridVolumeRepresentation\" />\n"
17092 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
17093 " <Exception name=\"Input\" />\n"
17094 " <Exception name=\"Visibility\" />\n"
17095 " </ShareProperties>\n"
17096 " <ExposedProperties>\n"
17097 " <PropertyGroup label=\"Volume Rendering\">\n"
17098 " <Property name=\"ScalarOpacityUnitDistance\"\n"
17099 " panel_visibility=\"advanced\" />\n"
17100 " <Property name=\"ScalarOpacityFunction\" />\n"
17101 " <Property name=\"TransferFunction2D\" />\n"
17102 " <Property name=\"UseSeparateOpacityArray\"\n"
17103 " panel_visibility=\"advanced\" />\n"
17104 " <Property name=\"OpacityArrayName\"\n"
17105 " panel_visibility=\"advanced\" />\n"
17106 " <Property name=\"OpacityComponent\"\n"
17107 " panel_visibility=\"advanced\" />\n"
17108 " <Property name=\"UseTransfer2D\"\n"
17109 " panel_visibility=\"advanced\" />\n"
17110 " <Property name=\"UseGradientForTransfer2D\"\n"
17111 " panel_visibility=\"advanced\" />\n"
17112 " <Property name=\"ColorArray2Name\"\n"
17113 " panel_visibility=\"advanced\" />\n"
17114 " <Property name=\"ColorArray2Component\"\n"
17115 " panel_visibility=\"advanced\" />\n"
17116 " <Property name=\"VolumeRenderingMode\"\n"
17117 " panel_visibility=\"advanced\"\n"
17118 " panel_visibility_default_for_representation=\"volume\" />\n"
17119 " <Property name=\"Shade\"\n"
17120 " panel_visibility=\"advanced\"\n"
17121 " panel_visibility_default_for_representation=\"volume\" />\n"
17122 " <Property name=\"GlobalIlluminationReach\"\n"
17123 " panel_visibility=\"advanced\"\n"
17124 " panel_visibility_default_for_representation=\"volume\" />\n"
17125 " <Property name=\"VolumetricScatteringBlending\"\n"
17126 " panel_visibility=\"advanced\"\n"
17127 " panel_visibility_default_for_representation=\"volume\" />\n"
17128 " <Property name=\"VolumeAnisotropy\"\n"
17129 " panel_visibility=\"advanced\"/>\n"
17130 " <Property name=\"InterpolationType\"\n"
17131 " panel_visibility=\"never\" />\n"
17132 " <Property name=\"BlendMode\" />\n"
17133 " <Property name=\"IsosurfaceValues\" />\n"
17134 " <Property name=\"SliceFunction\" />\n"
17135 " <Property name=\"UseCropping\" />\n"
17136 " <Hints>\n"
17137 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
17138 " <Expression type=\"or\">\n"
17139 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17140 " mode=\"visibility\"\n"
17141 " property=\"Representation\"\n"
17142 " value=\"Volume\" />\n"
17143 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17144 " mode=\"visibility\"\n"
17145 " property=\"Representation\"\n"
17146 " value=\"NVIDIA IndeX\" />\n"
17147 " </Expression>\n"
17148 " </PropertyWidgetDecorator>\n"
17149 " </Hints>\n"
17150 " </PropertyGroup>\n"
17151 " <PropertyGroup label=\"Cropping Parameters\" panel_widget=\"InteractiveBox\">\n"
17152 " <Property function=\"Position\" name=\"CroppingOrigin\" />\n"
17153 " <Property function=\"Scale\" name=\"CroppingScale\" />\n"
17154 " <Property function=\"Input\" name=\"DummyInput\" />\n"
17155 " <Hints>\n"
17156 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
17157 " <Expression type=\"and\">\n"
17158 " <Expression type=\"or\">\n"
17159 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17160 " mode=\"visibility\"\n"
17161 " property=\"Representation\"\n"
17162 " value=\"Volume\" />\n"
17163 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17164 " mode=\"visibility\"\n"
17165 " property=\"Representation\"\n"
17166 " value=\"NVIDIA IndeX\" />\n"
17167 " </Expression>\n"
17168 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17169 " mode=\"visibility\"\n"
17170 " property=\"UseCropping\"\n"
17171 " value=\"1\" />\n"
17172 " </Expression>\n"
17173 " </PropertyWidgetDecorator>\n"
17174 " </Hints>\n"
17175 " </PropertyGroup>\n"
17176 " </ExposedProperties>\n"
17177 " <LinkProperties>\n"
17178 " <Property name=\"DummyInput\" with_property=\"Input\" />\n"
17179 " </LinkProperties>\n"
17180 " </SubProxy>\n"
17181 " <SubProxy>\n"
17182 " <Proxy name=\"SliceRepresentation\"\n"
17183 " proxygroup=\"representations\"\n"
17184 " proxyname=\"ImageSliceRepresentation\" />\n"
17185 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
17186 " <Exception name=\"Input\" />\n"
17187 " <Exception name=\"Visibility\" />\n"
17188 " </ShareProperties>\n"
17189 " <ExposedProperties>\n"
17190 " <PropertyGroup label=\"Slicing\">\n"
17191 " <Property name=\"SliceMode\"\n"
17192 " panel_visibility=\"advanced\"\n"
17193 " panel_visibility_default_for_representation=\"slice\" />\n"
17194 " <Property name=\"Slice\"\n"
17195 " panel_visibility=\"advanced\"\n"
17196 " panel_visibility_default_for_representation=\"slice\" />\n"
17197 " <Hints>\n"
17198 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17199 " mode=\"visibility\"\n"
17200 " property=\"Representation\"\n"
17201 " value=\"Slice\" />\n"
17202 " </Hints>\n"
17203 " </PropertyGroup>\n"
17204 " </ExposedProperties>\n"
17205 " </SubProxy>\n"
17206 " <Hints>\n"
17207 " <!-- pqDisplayRepresentationWidget respects this hint to put out\n"
17208 " a warning for the user before switching to this type of Representation.\n"
17209 " The user can then accept or reject the change.\n"
17210 " BUG #15117\n"
17211 " -->\n"
17212 " <WarnOnRepresentationChange value=\"Volume\" />\n"
17213 " <!-- pqDisplayColorWidget disables \"Solid Color\" for this representation type -->\n"
17214 " <NoSolidColor representation=\"Slice\" />\n"
17215 " <NoSolidColor representation=\"Volume\" />\n"
17216 " </Hints>\n"
17217 " <!-- End of UniformGridRepresentation -->\n"
17218 " </PVRepresentationProxy>\n"
17219 "\n"
17220 " <!-- ================================================================== -->\n"
17221 " <PVRepresentationProxy base_proxygroup=\"internal_representations\"\n"
17222 " base_proxyname=\"PVRepresentationBase\"\n"
17223 " class=\"vtkPVCompositeRepresentation\"\n"
17224 " name=\"AMRRepresentation\"\n"
17225 " processes=\"client|renderserver|dataserver\">\n"
17226 " <Documentation>This representation is used to show AMR data as\n"
17227 " Surface/Outline/Points/Wireframe/Volume.</Documentation>\n"
17228 " <!-- this adds to the types already defined in PVRepresentationBase -->\n"
17229 " <RepresentationType subproxy=\"VolumeRepresentation\"\n"
17230 " text=\"Volume\" />\n"
17231 " <RepresentationType subproxy=\"AMROutlineRepresentation\"\n"
17232 " text=\"AMR Blocks\" />\n"
17233 " <InputProperty command=\"SetInputConnection\"\n"
17234 " name=\"Input\">\n"
17235 " <DataTypeDomain name=\"input_type\">\n"
17236 " <DataType value=\"vtkOverlappingAMR\" />\n"
17237 " </DataTypeDomain>\n"
17238 " <InputArrayDomain attribute_type=\"cell\"\n"
17239 " name=\"input_array_cell\"\n"
17240 " optional=\"1\"></InputArrayDomain>\n"
17241 " <InputArrayDomain attribute_type=\"point\"\n"
17242 " name=\"input_array_point\"\n"
17243 " optional=\"1\"></InputArrayDomain>\n"
17244 " <Documentation>Set the input to the representation.</Documentation>\n"
17245 " </InputProperty>\n"
17246 "\n"
17247 " <SubProxy>\n"
17248 " <Proxy name=\"VolumeRepresentation\"\n"
17249 " proxygroup=\"internal_representations\"\n"
17250 " proxyname=\"AMRVolumeRepresentation\" />\n"
17251 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
17252 " <Exception name=\"Input\" />\n"
17253 " </ShareProperties>\n"
17254 " <ExposedProperties>\n"
17255 " <PropertyGroup label=\"Volume Rendering\">\n"
17256 " <Property name=\"ScalarOpacityUnitDistance\"\n"
17257 " panel_visibility=\"advanced\" />\n"
17258 " <Property name=\"ScalarOpacityFunction\" />\n"
17259 " <Property name=\"VolumeRenderingMode\" />\n"
17260 " <Property name=\"ResamplingMode\" />\n"
17261 " <Property name=\"StreamingRequestSize\" />\n"
17262 " <Property name=\"NumberOfSamples\" />\n"
17263 " <Property name=\"Shade\" />\n"
17264 " <Hints>\n"
17265 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17266 " mode=\"visibility\"\n"
17267 " property=\"Representation\"\n"
17268 " value=\"Volume\" />\n"
17269 " </Hints>\n"
17270 " </PropertyGroup>\n"
17271 " </ExposedProperties>\n"
17272 " </SubProxy>\n"
17273 "\n"
17274 " <SubProxy>\n"
17275 " <Proxy name=\"AMROutlineRepresentation\"\n"
17276 " proxygroup=\"internal_representations\"\n"
17277 " proxyname=\"AMROutlineRepresentation\" />\n"
17278 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
17279 " <Exception name=\"Input\" />\n"
17280 " </ShareProperties>\n"
17281 " </SubProxy>\n"
17282 "\n"
17283 " <Hints>\n"
17284 " <!-- pqDisplayRepresentationWidget respects this hint to put out\n"
17285 " a warning for the user before switching to this type of Representation.\n"
17286 " The user can then accept or reject the change.\n"
17287 " BUG #15117\n"
17288 " -->\n"
17289 " <WarnOnRepresentationChange value=\"Volume\" />\n"
17290 " <!-- pqDisplayColorWidget disables \"Solid Color\" for this representation type -->\n"
17291 " <NoSolidColor representation=\"Volume\" />\n"
17292 " </Hints>\n"
17293 "\n"
17294 " <!-- End of AMRRepresentation -->\n"
17295 " </PVRepresentationProxy>\n"
17296 "\n"
17297 " <!-- ================================================================== -->\n"
17298 " <PVRepresentationProxy class=\"vtkPVCompositeRepresentation\"\n"
17299 " name=\"HyperTreeGridRepresentation\"\n"
17300 " base_proxygroup=\"internal_representations\"\n"
17301 " base_proxyname=\"PVRepresentationBase\"\n"
17302 " processes=\"client|renderserver|dataserver\">\n"
17303 " <Documentation>Representation to show Hyper Tree Grids in the render view\n"
17304 " based on the Composite Representation.</Documentation>\n"
17305 "\n"
17306 " <InputProperty command=\"SetInputConnection\"\n"
17307 " name=\"Input\">\n"
17308 " <DataTypeDomain composite_data_supported=\"1\"\n"
17309 " name=\"input_type\">\n"
17310 " <DataType value=\"vtkHyperTreeGrid\" />\n"
17311 " <DataType value=\"vtkDataObjectTree\" child_match=\"all\">\n"
17312 " <DataType value=\"vtkHyperTreeGrid\" />\n"
17313 " </DataType>\n"
17314 " </DataTypeDomain>\n"
17315 " <Documentation>Set the input to the representation.</Documentation>\n"
17316 " </InputProperty>\n"
17317 "\n"
17318 " </PVRepresentationProxy>\n"
17319 "\n"
17320 " <PVRepresentationProxy class=\"vtkHyperTreeGridRepresentation\"\n"
17321 " name=\"FastHyperTreeGridRepresentation\"\n"
17322 " processes=\"client|renderserver|dataserver\"\n"
17323 " si_class=\"vtkSIProxy\">\n"
17324 " <Documentation>Dedicated representation to show 2D Hyper Tree Grid.\n"
17325 " Use an adaptive decimation mechanism for improved performances.\n"
17326 " </Documentation>\n"
17327 "\n"
17328 " <InputProperty command=\"SetInputConnection\"\n"
17329 " name=\"Input\">\n"
17330 " <DataTypeDomain composite_data_supported=\"0\"\n"
17331 " name=\"input_type\">\n"
17332 " <DataType value=\"vtkHyperTreeGrid\" />\n"
17333 " </DataTypeDomain>\n"
17334 " <InputArrayDomain attribute_type=\"cell\"\n"
17335 " name=\"input_array_cell\"\n"
17336 " optional=\"1\">\n"
17337 " </InputArrayDomain>\n"
17338 " <Documentation>Set the input to the representation.</Documentation>\n"
17339 " </InputProperty>\n"
17340 "\n"
17341 " <IntVectorProperty command=\"SetAdaptiveDecimation\"\n"
17342 " default_values=\"1\"\n"
17343 " name=\"AdaptiveDecimation\"\n"
17344 " number_of_elements=\"1\">\n"
17345 " <BooleanDomain name=\"bool\" />\n"
17346 " <Documentation>\n"
17347 " Enable the use of the Adaptive decimation to only map the part\n"
17348 " of the HTG inside the camera frustum. Only support 2D HTG with\n"
17349 " parallel prokjection.\n"
17350 " </Documentation>\n"
17351 " <Hints>\n"
17352 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
17353 " <Expression type=\"or\">\n"
17354 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17355 " mode=\"visibility\"\n"
17356 " property=\"Representation\"\n"
17357 " value=\"HTG Surface\" />\n"
17358 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17359 " mode=\"visibility\"\n"
17360 " property=\"Representation\"\n"
17361 " value=\"HTG Surface With Edges\" />\n"
17362 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17363 " mode=\"visibility\"\n"
17364 " property=\"Representation\"\n"
17365 " value=\"HTG Wireframe\" />\n"
17366 " </Expression>\n"
17367 " </PropertyWidgetDecorator>\n"
17368 " </Hints>\n"
17369 " </IntVectorProperty>\n"
17370 "\n"
17371 " <IntVectorProperty command=\"SetRepresentation\"\n"
17372 " default_values=\"1\"\n"
17373 " name=\"Representation\"\n"
17374 " panel_widget=\"display_representation_selector\"\n"
17375 " number_of_elements=\"1\">\n"
17376 " <EnumerationDomain name=\"enum\">\n"
17377 " <Entry text=\"Wireframe\"\n"
17378 " value=\"1\" />\n"
17379 " <Entry text=\"Surface\"\n"
17380 " value=\"2\" />\n"
17381 ;
17382
17383 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
17385 " <Entry text=\"Surface With Edges\"\n"
17386 " value=\"3\" />\n"
17387 " </EnumerationDomain>\n"
17388 " </IntVectorProperty>\n"
17389 "\n"
17390 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
17391 " element_types=\"0 0 0 0 2\"\n"
17392 " name=\"ColorArrayName\"\n"
17393 " no_custom_default=\"1\"\n"
17394 " number_of_elements=\"5\">\n"
17395 " <Documentation>\n"
17396 " Set the array to color with. One must specify the field association and\n"
17397 " the array name of the array. If the array is missing, scalar coloring will\n"
17398 " automatically be disabled.\n"
17399 " </Documentation>\n"
17400 " <RepresentedArrayListDomain name=\"array_list\"\n"
17401 " input_domain_name=\"input_array_any\">\n"
17402 " <RequiredProperties>\n"
17403 " <Property function=\"Input\" name=\"Input\" />\n"
17404 " </RequiredProperties>\n"
17405 " </RepresentedArrayListDomain>\n"
17406 " </StringVectorProperty>\n"
17407 "\n"
17408 " <!-- Coloring -->\n"
17409 "\n"
17410 " <IntVectorProperty command=\"SetMapScalars\"\n"
17411 " default_values=\"1\"\n"
17412 " name=\"MapScalars\"\n"
17413 " number_of_elements=\"1\">\n"
17414 " <BooleanDomain name=\"bool\" />\n"
17415 " <Documentation>When set to True, LookupTable will always be\n"
17416 " used for scalar mapping. Otherwise, when up to 4 component\n"
17417 " scalars are present, the components are clamped to a valid\n"
17418 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
17419 " floating point type) and then directly used as\n"
17420 " color.</Documentation>\n"
17421 " </IntVectorProperty>\n"
17422 " <ProxyProperty command=\"SetLookupTable\"\n"
17423 " name=\"LookupTable\" >\n"
17424 " <Documentation>Set the lookup-table to use to map data array to colors.\n"
17425 " Lookuptable is only used with MapScalars to ON.</Documentation>\n"
17426 " <ProxyGroupDomain name=\"groups\">\n"
17427 " <Group name=\"lookup_tables\" />\n"
17428 " </ProxyGroupDomain>\n"
17429 " </ProxyProperty>\n"
17430 " <IntVectorProperty default_values=\"0\"\n"
17431 " name=\"UseSeparateColorMap\"\n"
17432 " number_of_elements=\"1\"\n"
17433 " panel_visibility=\"never\">\n"
17434 " <BooleanDomain name=\"bool\" />\n"
17435 " <Documentation>By default, ParaView shares a single color map among all datasets colored\n"
17436 " by arrays that have the same name. When this option is enabled, the active dataset will\n"
17437 " be assigned a separate color map not shared by other datasets.</Documentation>\n"
17438 " </IntVectorProperty>\n"
17439 " <DoubleVectorProperty command=\"SetDiffuseColor\"\n"
17440 " default_values=\"1.0 1.0 1.0\"\n"
17441 " name=\"DiffuseColor\"\n"
17442 " number_of_elements=\"3\">\n"
17443 " <DoubleRangeDomain max=\"1 1 1\"\n"
17444 " min=\"0 0 0\"\n"
17445 " name=\"range\" />\n"
17446 " <Hints>\n"
17447 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SurfaceColor\" unlink_if_modified=\"1\" />\n"
17448 " </Hints>\n"
17449 " <Documentation>\n"
17450 " The solid color of the model.\n"
17451 " </Documentation>\n"
17452 " </DoubleVectorProperty>\n"
17453 "\n"
17454 " <!-- Edges parameters -->\n"
17455 "\n"
17456 " <DoubleVectorProperty command=\"SetEdgeColor\"\n"
17457 " default_values=\"0 0 0.5\"\n"
17458 " name=\"EdgeColor\"\n"
17459 " panel_widget=\"color_selector_with_palette\"\n"
17460 " number_of_elements=\"3\">\n"
17461 " <Documentation>Set the edge color. This color is used to draw the edge\n"
17462 " for the hyper tree grid data when EdgeVisibility is on.</Documentation>\n"
17463 " <DoubleRangeDomain max=\"1 1 1\"\n"
17464 " min=\"0 0 0\"\n"
17465 " name=\"range\" />\n"
17466 " <Hints>\n"
17467 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"EdgeColor\" unlink_if_modified=\"1\" />\n"
17468 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17469 " mode=\"visibility\"\n"
17470 " property=\"Representation\"\n"
17471 " value=\"3\" />\n"
17472 " </Hints>\n"
17473 " </DoubleVectorProperty>\n"
17474 "\n"
17475 " <!-- Position -->\n"
17476 "\n"
17477 " <DoubleVectorProperty command=\"SetPosition\"\n"
17478 " default_values=\"0 0 0\"\n"
17479 " label=\"Translation\"\n"
17480 " name=\"Position\"\n"
17481 " panel_visibility=\"advanced\"\n"
17482 " number_of_elements=\"3\">\n"
17483 " <DoubleRangeDomain name=\"range\" />\n"
17484 " </DoubleVectorProperty>\n"
17485 " <DoubleVectorProperty command=\"SetScale\"\n"
17486 " default_values=\"1 1 1\"\n"
17487 " name=\"Scale\"\n"
17488 " panel_visibility=\"advanced\"\n"
17489 " number_of_elements=\"3\">\n"
17490 " <DoubleRangeDomain name=\"range\" />\n"
17491 " </DoubleVectorProperty>\n"
17492 " <DoubleVectorProperty command=\"SetOrientation\"\n"
17493 " default_values=\"0 0 0\"\n"
17494 " name=\"Orientation\"\n"
17495 " panel_visibility=\"advanced\"\n"
17496 " number_of_elements=\"3\">\n"
17497 " <DoubleRangeDomain name=\"range\" />\n"
17498 " </DoubleVectorProperty>\n"
17499 "\n"
17500 " <!-- UI -->\n"
17501 "\n"
17502 " </PVRepresentationProxy>\n"
17503 "\n"
17504 " <Extension name=\"HyperTreeGridRepresentation\">\n"
17505 " <Documentation>\n"
17506 " Extends standard HTG Representation by adding\n"
17507 " Fast2DHyperTreeGridRepresentation as a new type of representation.\n"
17508 " </Documentation>\n"
17509 "\n"
17510 " <RepresentationType subproxy=\"FastHyperTreeGridRepresentation\"\n"
17511 " text=\"HTG Surface\" subtype=\"Surface\"/>\n"
17512 " <RepresentationType subproxy=\"FastHyperTreeGridRepresentation\"\n"
17513 " text=\"HTG Surface With Edges\" subtype=\"Surface With Edges\"/>\n"
17514 " <RepresentationType subproxy=\"FastHyperTreeGridRepresentation\"\n"
17515 " text=\"HTG Wireframe\" subtype=\"Wireframe\"/>\n"
17516 "\n"
17517 " <SubProxy>\n"
17518 " <Proxy name=\"FastHyperTreeGridRepresentation\"\n"
17519 " proxygroup=\"representations\"\n"
17520 " proxyname=\"FastHyperTreeGridRepresentation\">\n"
17521 " </Proxy>\n"
17522 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
17523 " <Exception name=\"Input\" />\n"
17524 " </ShareProperties>\n"
17525 " <ExposedProperties>\n"
17526 " <PropertyGroup panel_visibility=\"default\"\n"
17527 " label=\"HTG Rendering\" >\n"
17528 " <Property name=\"AdaptiveDecimation\" />\n"
17529 " </PropertyGroup>\n"
17530 " </ExposedProperties>\n"
17531 " </SubProxy>\n"
17532 " </Extension>\n"
17533 "\n"
17534 " <!-- ================================================================== -->\n"
17535 " <RepresentationProxy class=\"vtkStructuredGridVolumeRepresentation\"\n"
17536 " name=\"StructuredGridVolumeRepresentation\"\n"
17537 " processes=\"client|renderserver|dataserver\"\n"
17538 " si_class=\"vtkSIUnstructuredGridVolumeRepresentationProxy\"\n"
17539 " base_proxygroup=\"representations\"\n"
17540 " base_proxyname=\"UnstructuredGridVolumeRepresentation\">\n"
17541 " </RepresentationProxy>\n"
17542 "\n"
17543 " <!-- ================================================================== -->\n"
17544 " <RepresentationProxy class=\"vtkImageVolumeRepresentation\"\n"
17545 " name=\"UniformGridVolumeRepresentation\"\n"
17546 " processes=\"client|renderserver|dataserver\"\n"
17547 " si_class=\"vtkSIProxy\">\n"
17548 " <Documentation>Representation for rendering a vtkImageData as\n"
17549 " volume.</Documentation>\n"
17550 " <InputProperty command=\"SetInputConnection\"\n"
17551 " name=\"Input\">\n"
17552 " <DataTypeDomain composite_data_supported=\"0\"\n"
17553 " name=\"input_type\">\n"
17554 " <DataType value=\"vtkImageData\" />\n"
17555 " </DataTypeDomain>\n"
17556 " <InputArrayDomain attribute_type=\"any\"\n"
17557 " name=\"input_array_any\">\n"
17558 " </InputArrayDomain>\n"
17559 " <Documentation>Set the input to the representation.</Documentation>\n"
17560 " </InputProperty>\n"
17561 " <IntVectorProperty command=\"SetVisibility\"\n"
17562 " default_values=\"1\"\n"
17563 " name=\"Visibility\"\n"
17564 " number_of_elements=\"1\">\n"
17565 " <BooleanDomain name=\"bool\" />\n"
17566 " <Documentation>Set the visibility for this\n"
17567 " representation.</Documentation>\n"
17568 " </IntVectorProperty>\n"
17569 " <IntVectorProperty command=\"SetForceUseCache\"\n"
17570 " default_values=\"0\"\n"
17571 " is_internal=\"1\"\n"
17572 " name=\"ForceUseCache\"\n"
17573 " number_of_elements=\"1\">\n"
17574 " <BooleanDomain name=\"bool\" />\n"
17575 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
17576 " and representations cache based on what the view tells it. However in\n"
17577 " some cases we may want to force a representation to cache irrespective\n"
17578 " of the view (e.g. comparative views). In which case these ivars can up\n"
17579 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
17580 " Instead, ForcedCacheKey is used.</Documentation>\n"
17581 " </IntVectorProperty>\n"
17582 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
17583 " default_values=\"none\"\n"
17584 " is_internal=\"1\"\n"
17585 " name=\"ForcedCacheKey\"\n"
17586 " number_of_elements=\"1\">\n"
17587 " <DoubleRangeDomain name=\"range\" />\n"
17588 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
17589 " and representations cache based on what the view tells it. However in\n"
17590 " some cases we may want to force a representation to cache irrespective\n"
17591 " of the view (e.g. comparative views). In which case these ivars can up\n"
17592 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
17593 " Instead, ForcedCacheKey is used.</Documentation>\n"
17594 " </DoubleVectorProperty>\n"
17595 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
17596 " element_types=\"0 0 0 0 2\"\n"
17597 " name=\"ColorArrayName\"\n"
17598 " no_custom_default=\"1\"\n"
17599 " number_of_elements=\"5\">\n"
17600 " <Documentation>\n"
17601 " Set the array to color with. One must specify the field association and\n"
17602 " the array name of the array. If the array is missing, scalar coloring will\n"
17603 " automatically be disabled.\n"
17604 " </Documentation>\n"
17605 " <RepresentedArrayListDomain name=\"array_list\"\n"
17606 " input_domain_name=\"input_array_any\">\n"
17607 " <RequiredProperties>\n"
17608 " <Property function=\"Input\" name=\"Input\" />\n"
17609 " </RequiredProperties>\n"
17610 " </RepresentedArrayListDomain>\n"
17611 " </StringVectorProperty>\n"
17612 " <IntVectorProperty command=\"SetUseTransfer2D\"\n"
17613 " default_values=\"0\"\n"
17614 " name=\"UseTransfer2D\"\n"
17615 " label=\"Use 2D Transfer Function\"\n"
17616 " number_of_elements=\"1\"\n"
17617 " panel_visibility=\"advanced\">\n"
17618 " <BooleanDomain name=\"bool\"/>\n"
17619 " <Documentation>\n"
17620 " If this property is on, a 2D transfer function will be used for volume rendering instead\n"
17621 " of two 1D piecewise functions.\n"
17622 " </Documentation>\n"
17623 " </IntVectorProperty>\n"
17624 " <IntVectorProperty command=\"SetUseGradientForTransfer2D\"\n"
17625 " default_values=\"1\"\n"
17626 " name=\"UseGradientForTransfer2D\"\n"
17627 " label=\"Use Gradient as Y-Axis Array\"\n"
17628 " number_of_elements=\"1\"\n"
17629 " panel_visibility=\"advanced\">\n"
17630 " <BooleanDomain name=\"bool\"/>\n"
17631 " <Documentation>\n"
17632 " If this property is on, the gradient of the input scalar array will be used for the Y\n"
17633 " axis of the 2D transfer function.\n"
17634 " </Documentation>\n"
17635 " <Hints>\n"
17636 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17637 " <Property name=\"UseTransfer2D\" function=\"boolean\" />\n"
17638 " </PropertyWidgetDecorator>\n"
17639 " </Hints>\n"
17640 " </IntVectorProperty>\n"
17641 " <StringVectorProperty name=\"ColorArray2Name\"\n"
17642 " command=\"SelectColorArray2\"\n"
17643 " number_of_elements=\"5\"\n"
17644 " element_types=\"0 0 0 0 2\"\n"
17645 " label=\"2D Transfer Function Y-Axis Array\"\n"
17646 " panel_visibility=\"advanced\">\n"
17647 " <ArrayListDomain name=\"array_list\"\n"
17648 " input_domain_name=\"input_point_array\">\n"
17649 " <RequiredProperties>\n"
17650 " <Property name=\"Input\" function=\"Input\"/>\n"
17651 " </RequiredProperties>\n"
17652 " </ArrayListDomain>\n"
17653 " <Documentation>\n"
17654 " Set the second array to color with. This would be used when a 2D transfer function is\n"
17655 " enabled and if the use_gradient property is set to false.\n"
17656 " </Documentation>\n"
17657 " <Hints>\n"
17658 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17659 " <Property name=\"UseTransfer2D\" function=\"boolean\" />\n"
17660 " </PropertyWidgetDecorator>\n"
17661 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17662 " <Property name=\"UseGradientForTransfer2D\" function=\"boolean_invert\" />\n"
17663 " </PropertyWidgetDecorator>\n"
17664 " </Hints>\n"
17665 " </StringVectorProperty>\n"
17666 " <IntVectorProperty animateable=\"0\"\n"
17667 " command=\"SelectColorArray2Component\"\n"
17668 " default_values=\"0\"\n"
17669 " name=\"ColorArray2Component\"\n"
17670 " label=\"2D Transfer Function Y-Axis Array Component\"\n"
17671 " number_of_elements=\"1\">\n"
17672 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"0\">\n"
17673 " <RequiredProperties>\n"
17674 " <Property function=\"Input\"\n"
17675 " name=\"Input\" />\n"
17676 " <Property function=\"ArraySelection\"\n"
17677 " name=\"ColorArray2Name\" />\n"
17678 " </RequiredProperties>\n"
17679 " </NumberOfComponentsDomain>\n"
17680 " <Documentation>\n"
17681 " This property indicates the component of the array to be used for Y-axis of the volume 2D\n"
17682 " transfer function.\n"
17683 " </Documentation>\n"
17684 " <Hints>\n"
17685 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17686 " <Property name=\"UseTransfer2D\" function=\"boolean\" />\n"
17687 " </PropertyWidgetDecorator>\n"
17688 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17689 " <Property name=\"UseGradientForTransfer2D\" function=\"boolean_invert\" />\n"
17690 " </PropertyWidgetDecorator>\n"
17691 " </Hints>\n"
17692 " </IntVectorProperty>\n"
17693 " <IntVectorProperty command=\"SetUseSeparateOpacityArray\"\n"
17694 " default_values=\"0\"\n"
17695 " name=\"UseSeparateOpacityArray\"\n"
17696 ;
17697
17698 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
17700 " number_of_elements=\"1\"\n"
17701 " panel_visibility=\"advanced\">\n"
17702 " <BooleanDomain name=\"bool\"/>\n"
17703 " <Documentation>\n"
17704 " If this property is on, the Opacity Array will be used to determine the\n"
17705 " point gaussian sprites.\n"
17706 " </Documentation>\n"
17707 " <Hints>\n"
17708 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17709 " <Property name=\"UseTransfer2D\" function=\"boolean_invert\" />\n"
17710 " </PropertyWidgetDecorator>\n"
17711 " </Hints>\n"
17712 " </IntVectorProperty>\n"
17713 " <StringVectorProperty name=\"OpacityArrayName\"\n"
17714 " command=\"SelectOpacityArray\"\n"
17715 " number_of_elements=\"5\"\n"
17716 " element_types=\"0 0 0 0 2\"\n"
17717 " label=\"Volume Opacity Array\"\n"
17718 " panel_visibility=\"advanced\">\n"
17719 " <ArrayListDomain name=\"array_list\"\n"
17720 " input_domain_name=\"input_point_array\">\n"
17721 " <RequiredProperties>\n"
17722 " <Property name=\"Input\" function=\"Input\"/>\n"
17723 " </RequiredProperties>\n"
17724 " </ArrayListDomain>\n"
17725 " <Documentation>\n"
17726 " This property specifies the name of the input array to map to opacity.\n"
17727 " </Documentation>\n"
17728 " <Hints>\n"
17729 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17730 " <Property name=\"UseSeparateOpacityArray\" function=\"boolean\" />\n"
17731 " </PropertyWidgetDecorator>\n"
17732 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17733 " <Property name=\"UseTransfer2D\" function=\"boolean_invert\" />\n"
17734 " </PropertyWidgetDecorator>\n"
17735 " </Hints>\n"
17736 " </StringVectorProperty>\n"
17737 " <IntVectorProperty animateable=\"0\"\n"
17738 " command=\"SelectOpacityArrayComponent\"\n"
17739 " default_values=\"0\"\n"
17740 " name=\"OpacityComponent\"\n"
17741 " number_of_elements=\"1\">\n"
17742 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
17743 " <RequiredProperties>\n"
17744 " <Property function=\"Input\"\n"
17745 " name=\"Input\" />\n"
17746 " <Property function=\"ArraySelection\"\n"
17747 " name=\"OpacityArrayName\" />\n"
17748 " </RequiredProperties>\n"
17749 " </NumberOfComponentsDomain>\n"
17750 " <Documentation>\n"
17751 " This property indicates the component of the array to be used for opacity.\n"
17752 " </Documentation>\n"
17753 " <Hints>\n"
17754 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17755 " <Property name=\"UseSeparateOpacityArray\" function=\"boolean\" />\n"
17756 " </PropertyWidgetDecorator>\n"
17757 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
17758 " <Property name=\"UseTransfer2D\" function=\"boolean_invert\" />\n"
17759 " </PropertyWidgetDecorator>\n"
17760 " </Hints>\n"
17761 " </IntVectorProperty>\n"
17762 " <DoubleVectorProperty command=\"SetPosition\"\n"
17763 " default_values=\"0 0 0\"\n"
17764 " name=\"Position\"\n"
17765 " number_of_elements=\"3\">\n"
17766 " <DoubleRangeDomain name=\"range\" />\n"
17767 " </DoubleVectorProperty>\n"
17768 " <DoubleVectorProperty command=\"SetScale\"\n"
17769 " default_values=\"1 1 1\"\n"
17770 " name=\"Scale\"\n"
17771 " number_of_elements=\"3\">\n"
17772 " <DoubleRangeDomain name=\"range\" />\n"
17773 " </DoubleVectorProperty>\n"
17774 " <DoubleVectorProperty command=\"SetOrientation\"\n"
17775 " default_values=\"0 0 0\"\n"
17776 " name=\"Orientation\"\n"
17777 " number_of_elements=\"3\">\n"
17778 " <DoubleRangeDomain name=\"range\" />\n"
17779 " </DoubleVectorProperty>\n"
17780 " <DoubleVectorProperty command=\"SetOrigin\"\n"
17781 " default_values=\"0 0 0\"\n"
17782 " name=\"Origin\"\n"
17783 " number_of_elements=\"3\">\n"
17784 " <DoubleRangeDomain name=\"range\" />\n"
17785 " </DoubleVectorProperty>\n"
17786 " <IntVectorProperty command=\"SetPickable\"\n"
17787 " default_values=\"1\"\n"
17788 " name=\"Pickable\"\n"
17789 " number_of_elements=\"1\">\n"
17790 " <Hints>\n"
17791 " <NoDefault />\n"
17792 " </Hints>\n"
17793 " <BooleanDomain name=\"bool\" />\n"
17794 " </IntVectorProperty>\n"
17795 " <IntVectorProperty command=\"SetInterpolationType\"\n"
17796 " default_values=\"2\"\n"
17797 " name=\"InterpolationType\"\n"
17798 " number_of_elements=\"1\">\n"
17799 " <EnumerationDomain name=\"enum\">\n"
17800 " <Entry text=\"Nearest\"\n"
17801 " value=\"0\" />\n"
17802 " <Entry text=\"Linear\"\n"
17803 " value=\"1\" />\n"
17804 " <Entry text=\"Cubic\"\n"
17805 " value=\"2\" />\n"
17806 " </EnumerationDomain>\n"
17807 " </IntVectorProperty>\n"
17808 " <ProxyProperty command=\"SetColor\"\n"
17809 " name=\"LookupTable\" >\n"
17810 " <ProxyGroupDomain name=\"groups\">\n"
17811 " <Group name=\"transfer_functions\" />\n"
17812 " </ProxyGroupDomain>\n"
17813 " </ProxyProperty>\n"
17814 " <DoubleVectorProperty command=\"SetAmbient\"\n"
17815 " default_values=\"0.0\"\n"
17816 " name=\"Ambient\"\n"
17817 " number_of_elements=\"1\">\n"
17818 " <DoubleRangeDomain max=\"1\"\n"
17819 " min=\"0\"\n"
17820 " name=\"range\" />\n"
17821 " </DoubleVectorProperty>\n"
17822 " <DoubleVectorProperty command=\"SetDiffuse\"\n"
17823 " default_values=\"1.0\"\n"
17824 " name=\"Diffuse\"\n"
17825 " number_of_elements=\"1\">\n"
17826 " <DoubleRangeDomain max=\"1\"\n"
17827 " min=\"0\"\n"
17828 " name=\"range\" />\n"
17829 " </DoubleVectorProperty>\n"
17830 " <DoubleVectorProperty command=\"SetSpecular\"\n"
17831 " default_values=\"0.0\"\n"
17832 " name=\"Specular\"\n"
17833 " number_of_elements=\"1\">\n"
17834 " <DoubleRangeDomain max=\"1\"\n"
17835 " min=\"0\"\n"
17836 " name=\"range\" />\n"
17837 " </DoubleVectorProperty>\n"
17838 " <DoubleVectorProperty command=\"SetSpecularPower\"\n"
17839 " default_values=\"100.0\"\n"
17840 " name=\"SpecularPower\"\n"
17841 " number_of_elements=\"1\">\n"
17842 " <DoubleRangeDomain max=\"100\"\n"
17843 " min=\"0\"\n"
17844 " name=\"range\" />\n"
17845 " </DoubleVectorProperty>\n"
17846 " <IntVectorProperty command=\"SetShade\"\n"
17847 " default_values=\"0\"\n"
17848 " name=\"Shade\"\n"
17849 " number_of_elements=\"1\">\n"
17850 " <BooleanDomain name=\"bool\" />\n"
17851 " <Documentation>Enable/Disable shading.</Documentation>\n"
17852 " </IntVectorProperty>\n"
17853 " <DoubleVectorProperty command=\"SetGlobalIlluminationReach\"\n"
17854 " default_values=\"0.0\"\n"
17855 " name=\"GlobalIlluminationReach\"\n"
17856 " number_of_elements=\"1\">\n"
17857 " <DoubleRangeDomain max=\"1.0\"\n"
17858 " min=\"0.0\"\n"
17859 " name=\"range\" />\n"
17860 " <Documentation>\n"
17861 " This parameter acts as a balance between localness and globalness of shadows.\n"
17862 " A higher value results in more accurate, but also slower renders.\n"
17863 " A slower value results in faster renders, but only produces ambiant occlusion.\n"
17864 " </Documentation>\n"
17865 " <Hints>\n"
17866 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17867 " mode=\"visibility\"\n"
17868 " property=\"Shade\"\n"
17869 " value=\"1\"\n"
17870 " inverse=\"0\" />\n"
17871 " </Hints>\n"
17872 " </DoubleVectorProperty>\n"
17873 " <DoubleVectorProperty command=\"SetVolumetricScatteringBlending\"\n"
17874 " default_values=\"0.0\"\n"
17875 " name=\"VolumetricScatteringBlending\"\n"
17876 " number_of_elements=\"1\">\n"
17877 " <DoubleRangeDomain max=\"2.0\"\n"
17878 " min=\"0.0\"\n"
17879 " name=\"range\" />\n"
17880 " <Documentation>\n"
17881 " This parameter controls the blending between surfacic approximation\n"
17882 " and volumetric multi-scattering.\n"
17883 " A value of 0.0 means that no scattered rays will be cast, no volumetric shadows.\n"
17884 " A value of 1.0 means that the shader will smartly blend between the two models.\n"
17885 " A value of 2.0 means that the shader only uses the volumetric scattering model.\n"
17886 " </Documentation>\n"
17887 " <Hints>\n"
17888 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17889 " mode=\"visibility\"\n"
17890 " property=\"Shade\"\n"
17891 " value=\"1\"\n"
17892 " inverse=\"0\" />\n"
17893 " </Hints>\n"
17894 " </DoubleVectorProperty>\n"
17895 " <DoubleVectorProperty command=\"SetAnisotropy\"\n"
17896 " default_values=\"0.0\"\n"
17897 " name=\"VolumeAnisotropy\"\n"
17898 " number_of_elements=\"1\"\n"
17899 " panel_visibility=\"advanced\">\n"
17900 " <DoubleRangeDomain max=\"1.0\"\n"
17901 " min=\"-1.0\"\n"
17902 " name=\"range\" />\n"
17903 " <Documentation>\n"
17904 " Set the volume's anisotropy, according to the Henyey-Greenstein model.\n"
17905 " Describes whether the model is rather backwards-scattering (-1.0) or forwards-scattering (1.0).\n"
17906 " An isotropic volume has a null anisotropy.\n"
17907 " </Documentation>\n"
17908 " </DoubleVectorProperty>\n"
17909 " <IntVectorProperty command=\"SetMapScalars\"\n"
17910 " default_values=\"1\"\n"
17911 " name=\"MapScalars\"\n"
17912 " number_of_elements=\"1\">\n"
17913 " <BooleanDomain name=\"bool\" />\n"
17914 " <Documentation>When enabled, LookupTable will always be\n"
17915 " used for scalar mapping. Otherwise, when up to 4 component\n"
17916 " scalars are present, the components are clamped to a valid\n"
17917 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
17918 " floating point type) and then directly used as\n"
17919 " color.</Documentation>\n"
17920 " </IntVectorProperty>\n"
17921 " <IntVectorProperty command=\"SetMultiComponentsMapping\"\n"
17922 " default_values=\"0\"\n"
17923 " name=\"MultiComponentsMapping\"\n"
17924 " number_of_elements=\"1\">\n"
17925 " <BooleanDomain name=\"bool\" />\n"
17926 " <Hints>\n"
17927 " <PropertyWidgetDecorator type=\"MultiComponentsDecorator\"\n"
17928 " components=\"2 4\" />\n"
17929 " </Hints>\n"
17930 " </IntVectorProperty>\n"
17931 " <ProxyProperty command=\"SetScalarOpacity\"\n"
17932 " name=\"ScalarOpacityFunction\">\n"
17933 " <ProxyGroupDomain name=\"groups\">\n"
17934 " <Group name=\"piecewise_functions\" />\n"
17935 " </ProxyGroupDomain>\n"
17936 " </ProxyProperty>\n"
17937 " <ProxyProperty command=\"SetTransferFunction2D\"\n"
17938 " name=\"TransferFunction2D\" >\n"
17939 " <ProxyGroupDomain name=\"groups\">\n"
17940 " <Group name=\"transfer_2d_functions\" />\n"
17941 " </ProxyGroupDomain>\n"
17942 " </ProxyProperty>\n"
17943 " <IntVectorProperty command=\"SetRequestedRenderMode\"\n"
17944 " default_values=\"0\"\n"
17945 " name=\"VolumeRenderingMode\"\n"
17946 " number_of_elements=\"1\">\n"
17947 " <EnumerationDomain name=\"enum\">\n"
17948 " <Entry text=\"Smart\" value=\"0\" />\n"
17949 " <Entry text=\"Ray Cast Only\" value=\"1\" />\n"
17950 " <Entry text=\"GPU Based\" value=\"2\" />\n"
17951 " <Entry text=\"OSPRay Based\" value=\"3\" />\n"
17952 " </EnumerationDomain>\n"
17953 " </IntVectorProperty>\n"
17954 " <DoubleVectorProperty command=\"SetScalarOpacityUnitDistance\"\n"
17955 " default_values=\"1\"\n"
17956 " name=\"ScalarOpacityUnitDistance\"\n"
17957 " number_of_elements=\"1\">\n"
17958 " <BoundsDomain mode=\"approximate_cell_length\"\n"
17959 " name=\"bounds\" >\n"
17960 " <RequiredProperties>\n"
17961 " <Property function=\"Input\"\n"
17962 " name=\"Input\" />\n"
17963 " </RequiredProperties>\n"
17964 " </BoundsDomain>\n"
17965 " <Hints>\n"
17966 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
17967 " mode=\"visibility\"\n"
17968 " property=\"BlendMode\"\n"
17969 " value=\"6\"\n"
17970 " inverse=\"1\" />\n"
17971 " </Hints>\n"
17972 " </DoubleVectorProperty>\n"
17973 " <IntVectorProperty command=\"SetBlendMode\"\n"
17974 " default_values=\"0\"\n"
17975 " name=\"BlendMode\"\n"
17976 " number_of_elements=\"1\">\n"
17977 " <EnumerationDomain name=\"enum\">\n"
17978 " <!-- See vtkVolumeMapper::BlendModes -->\n"
17979 " <Entry text=\"Composite\"\n"
17980 " value=\"0\" />\n"
17981 " <Entry text=\"Isosurface\"\n"
17982 " value=\"5\" />\n"
17983 " <Entry text=\"Slice\"\n"
17984 " value=\"6\" />\n"
17985 " </EnumerationDomain>\n"
17986 " <Documentation>This property specifies how the samples should be blended</Documentation>\n"
17987 " </IntVectorProperty>\n"
17988 " <DoubleVectorProperty animateable=\"1\"\n"
17989 " command=\"SetIsosurfaceValue\"\n"
17990 " label=\"Isosurfaces\"\n"
17991 " name=\"IsosurfaceValues\"\n"
17992 " number_of_elements=\"0\"\n"
17993 " number_of_elements_per_command=\"1\"\n"
17994 " repeat_command=\"1\"\n"
17995 " set_number_command=\"SetNumberOfIsosurfaces\"\n"
17996 " use_index=\"1\">\n"
17997 " <ArrayRangeDomain name=\"scalar_range\">\n"
17998 " <RequiredProperties>\n"
17999 " <Property function=\"Input\"\n"
18000 " name=\"Input\" />\n"
18001 " <Property function=\"ArraySelection\"\n"
18002 " name=\"ColorArrayName\" />\n"
18003 " </RequiredProperties>\n"
18004 " </ArrayRangeDomain>\n"
18005 " <Documentation>This property specifies the values at which to display\n"
18006 " isosurfaces and also the number of such values.</Documentation>\n"
18007 " <Hints>\n"
18008 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18009 " mode=\"visibility\"\n"
18010 " property=\"BlendMode\"\n"
18011 " value=\"5\" />\n"
18012 " <!-- enable this widget when BlendMode==Isosurface -->\n"
18013 " </Hints>\n"
18014 " </DoubleVectorProperty>\n"
18015 " <ProxyProperty command=\"SetSliceFunction\"\n"
18016 " label=\"Slice Type\"\n"
18017 " name=\"SliceFunction\">\n"
18018 " <ProxyGroupDomain name=\"groups\">\n"
18019 " <Group name=\"implicit_functions\" />\n"
18020 " </ProxyGroupDomain>\n"
18021 " <ProxyListDomain name=\"proxy_list\">\n"
18022 " <Proxy group=\"implicit_functions\"\n"
18023 " name=\"Plane\" />\n"
18024 " </ProxyListDomain>\n"
18025 " <Documentation>This property sets the parameters of the slice\n"
18026 " function.</Documentation>\n"
18027 " <Hints>\n"
18028 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18029 " mode=\"visibility\"\n"
18030 ;
18031
18032 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
18034 " property=\"BlendMode\"\n"
18035 " value=\"6\" />\n"
18036 " <!-- enable this widget when BlendMode==Slice -->\n"
18037 " </Hints>\n"
18038 " </ProxyProperty>\n"
18039 " <IntVectorProperty command=\"SetCropping\"\n"
18040 " default_values=\"0\"\n"
18041 " name=\"UseCropping\"\n"
18042 " number_of_elements=\"1\">\n"
18043 " <BooleanDomain name=\"bool\"/>\n"
18044 " <Documentation>This property specifies if the cropping is enabled.</Documentation>\n"
18045 " </IntVectorProperty>\n"
18046 " <DoubleVectorProperty animateable=\"1\"\n"
18047 " command=\"SetCroppingOrigin\"\n"
18048 " name=\"CroppingOrigin\"\n"
18049 " number_of_elements=\"3\"\n"
18050 " argument_is_array=\"1\"\n"
18051 " default_values=\"0 0 0\">\n"
18052 " <Documentation>This property specifies the cropping origin.</Documentation>\n"
18053 " </DoubleVectorProperty>\n"
18054 " <DoubleVectorProperty animateable=\"1\"\n"
18055 " command=\"SetCroppingScale\"\n"
18056 " name=\"CroppingScale\"\n"
18057 " number_of_elements=\"3\"\n"
18058 " argument_is_array=\"1\"\n"
18059 " default_values=\"1 1 1\">\n"
18060 " <Documentation>This property specifies the cropping scale.</Documentation>\n"
18061 " </DoubleVectorProperty>\n"
18062 " <InputProperty is_internal=\"1\" name=\"DummyInput\" />\n"
18063 " <Hints>\n"
18064 " <ProxyList>\n"
18065 " <Link name=\"DummyInput\"\n"
18066 " with_property=\"Input\" />\n"
18067 " </ProxyList>\n"
18068 " </Hints>\n"
18069 "\n"
18070 " <!-- end of UniformGridVolumeRepresentation -->\n"
18071 " </RepresentationProxy>\n"
18072 "\n"
18073 " <!--======================================================================-->\n"
18074 " <RepresentationProxy name=\"SurfaceLICRepresentation\"\n"
18075 " class=\"vtkSurfaceLICRepresentation\"\n"
18076 " processes=\"client|dataserver|renderserver\"\n"
18077 " base_proxygroup=\"representations\"\n"
18078 " base_proxyname=\"SurfaceRepresentation\">\n"
18079 " <Documentation>\n"
18080 " Representation proxy for Surface LIC.\n"
18081 " </Documentation>\n"
18082 "\n"
18083 " <StringVectorProperty name=\"SelectInputVectors\"\n"
18084 " command=\"SelectInputVectors\"\n"
18085 " number_of_elements=\"5\"\n"
18086 " element_types=\"0 0 0 0 2\"\n"
18087 " label=\"Vectors\">\n"
18088 " <ArrayListDomain name=\"array_list\" attribute_type=\"Vectors\"\n"
18089 " input_domain_name=\"input_array_point_3\">\n"
18090 " <RequiredProperties>\n"
18091 " <Property name=\"Input\" function=\"Input\"/>\n"
18092 " </RequiredProperties>\n"
18093 " </ArrayListDomain>\n"
18094 " <Documentation>\n"
18095 " This property specifies the name of the input vector array to process.\n"
18096 " </Documentation>\n"
18097 " </StringVectorProperty>\n"
18098 "\n"
18099 " <!--\n"
18100 " Integrator controls\n"
18101 " -->\n"
18102 " <IntVectorProperty name=\"NumberOfSteps\"\n"
18103 " command=\"SetNumberOfSteps\"\n"
18104 " number_of_elements=\"1\"\n"
18105 " default_values=\"40\">\n"
18106 " <IntRangeDomain name=\"range\" min=\"1\" />\n"
18107 " </IntVectorProperty>\n"
18108 "\n"
18109 " <DoubleVectorProperty name=\"StepSize\"\n"
18110 " command=\"SetStepSize\"\n"
18111 " number_of_elements=\"1\"\n"
18112 " default_values=\"0.25\">\n"
18113 " <DoubleRangeDomain name=\"range\" min=\"0.0\"/>\n"
18114 " </DoubleVectorProperty>\n"
18115 "\n"
18116 " <IntVectorProperty name=\"NormalizeVectors\"\n"
18117 " command=\"SetNormalizeVectors\"\n"
18118 " number_of_elements=\"1\"\n"
18119 " default_values=\"1\">\n"
18120 " <BooleanDomain name=\"bool\" />\n"
18121 " </IntVectorProperty>\n"
18122 "\n"
18123 " <IntVectorProperty name=\"EnhancedLIC\"\n"
18124 " command=\"SetEnhancedLIC\"\n"
18125 " label=\"Enhanced/2-Pass Image LIC\"\n"
18126 " number_of_elements=\"1\"\n"
18127 " default_values=\"1\"\n"
18128 " >\n"
18129 " <BooleanDomain name=\"bool\" />\n"
18130 " </IntVectorProperty>\n"
18131 "\n"
18132 " <!--\n"
18133 " Coloring controls\n"
18134 " -->\n"
18135 " <IntVectorProperty name=\"ColorMode\"\n"
18136 " command=\"SetColorMode\"\n"
18137 " number_of_elements=\"1\"\n"
18138 " default_values=\"0\"\n"
18139 " >\n"
18140 " <EnumerationDomain name=\"enum\">\n"
18141 " <Entry text=\"Blend\" value=\"0\" />\n"
18142 " <Entry text=\"Multiply\" value=\"1\" />\n"
18143 " </EnumerationDomain>\n"
18144 " </IntVectorProperty>\n"
18145 "\n"
18146 " <DoubleVectorProperty name=\"MapModeBias\"\n"
18147 " command=\"SetMapModeBias\"\n"
18148 " number_of_elements=\"1\"\n"
18149 " default_values=\"0.0\"\n"
18150 " panel_visibility=\"advanced\"\n"
18151 " >\n"
18152 " <DoubleRangeDomain name=\"range\" min=\"-0.25\" max=\"0.25\" />\n"
18153 " </DoubleVectorProperty>\n"
18154 "\n"
18155 " <DoubleVectorProperty name=\"LICIntensity\"\n"
18156 " label=\"LIC Intensity\"\n"
18157 " command=\"SetLICIntensity\"\n"
18158 " number_of_elements=\"1\"\n"
18159 " default_values=\"0.8\"\n"
18160 " panel_visibility=\"advanced\"\n"
18161 " >\n"
18162 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
18163 " </DoubleVectorProperty>\n"
18164 "\n"
18165 " <IntVectorProperty name=\"EnhanceContrast\"\n"
18166 " command=\"SetEnhanceContrast\"\n"
18167 " number_of_elements=\"1\"\n"
18168 " default_values=\"0\"\n"
18169 " >\n"
18170 " <EnumerationDomain name=\"enum\">\n"
18171 " <Entry text=\"Off\" value=\"0\" />\n"
18172 " <Entry text=\"LIC Only\" value=\"1\" />\n"
18173 " <Entry text=\"LIC and Color\" value=\"4\" />\n"
18174 " <Entry text=\"Color Only\" value=\"3\" />\n"
18175 " </EnumerationDomain>\n"
18176 " </IntVectorProperty>\n"
18177 "\n"
18178 " <DoubleVectorProperty name=\"LowLICContrastEnhancementFactor\"\n"
18179 " command=\"SetLowLICContrastEnhancementFactor\"\n"
18180 " number_of_elements=\"1\"\n"
18181 " default_values=\"0.0\"\n"
18182 " panel_visibility=\"advanced\"\n"
18183 " >\n"
18184 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"0.5\" />\n"
18185 " </DoubleVectorProperty>\n"
18186 "\n"
18187 " <DoubleVectorProperty name=\"HighLICContrastEnhancementFactor\"\n"
18188 " command=\"SetHighLICContrastEnhancementFactor\"\n"
18189 " number_of_elements=\"1\"\n"
18190 " default_values=\"0.0\"\n"
18191 " panel_visibility=\"advanced\"\n"
18192 " >\n"
18193 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"0.5\" />\n"
18194 " </DoubleVectorProperty>\n"
18195 "\n"
18196 " <DoubleVectorProperty name=\"LowColorContrastEnhancementFactor\"\n"
18197 " command=\"SetLowColorContrastEnhancementFactor\"\n"
18198 " number_of_elements=\"1\"\n"
18199 " default_values=\"0.0\"\n"
18200 " panel_visibility=\"advanced\"\n"
18201 " >\n"
18202 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"0.5\" />\n"
18203 " </DoubleVectorProperty>\n"
18204 "\n"
18205 " <DoubleVectorProperty name=\"HighColorContrastEnhancementFactor\"\n"
18206 " command=\"SetHighColorContrastEnhancementFactor\"\n"
18207 " number_of_elements=\"1\"\n"
18208 " default_values=\"0.0\"\n"
18209 " panel_visibility=\"advanced\"\n"
18210 " >\n"
18211 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"0.5\" />\n"
18212 " </DoubleVectorProperty>\n"
18213 "\n"
18214 " <IntVectorProperty name=\"AntiAlias\"\n"
18215 " command=\"SetAntiAlias\"\n"
18216 " number_of_elements=\"1\"\n"
18217 " default_values=\"0\"\n"
18218 " panel_visibility=\"advanced\"\n"
18219 " >\n"
18220 " <IntRangeDomain name=\"range\" min=\"0\" max=\"5\" />\n"
18221 " </IntVectorProperty>\n"
18222 "\n"
18223 " <!--\n"
18224 " Fragment masking Control\n"
18225 " -->\n"
18226 " <IntVectorProperty name=\"MaskOnSurface\"\n"
18227 " command=\"SetMaskOnSurface\"\n"
18228 " number_of_elements=\"1\"\n"
18229 " default_values=\"1\"\n"
18230 " panel_visibility=\"advanced\"\n"
18231 " >\n"
18232 " <BooleanDomain name=\"bool\" />\n"
18233 " </IntVectorProperty>\n"
18234 "\n"
18235 " <DoubleVectorProperty name=\"MaskThreshold\"\n"
18236 " command=\"SetMaskThreshold\"\n"
18237 " number_of_elements=\"1\"\n"
18238 " default_values=\"0.0\"\n"
18239 " panel_visibility=\"advanced\"\n"
18240 " >\n"
18241 " <DoubleRangeDomain name=\"range\" />\n"
18242 " </DoubleVectorProperty>\n"
18243 "\n"
18244 " <DoubleVectorProperty name=\"MaskColor\"\n"
18245 " command=\"SetMaskColor\"\n"
18246 " number_of_elements=\"3\"\n"
18247 " default_values=\"0.5 0.5 0.5\"\n"
18248 " panel_visibility=\"advanced\"\n"
18249 " >\n"
18250 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" max=\"1 1 1\"/>\n"
18251 " </DoubleVectorProperty>\n"
18252 "\n"
18253 " <DoubleVectorProperty name=\"MaskIntensity\"\n"
18254 " command=\"SetMaskIntensity\"\n"
18255 " number_of_elements=\"1\"\n"
18256 " default_values=\"0.0\"\n"
18257 " panel_visibility=\"advanced\"\n"
18258 " >\n"
18259 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\"/>\n"
18260 " </DoubleVectorProperty>\n"
18261 "\n"
18262 " <!--\n"
18263 " Noise Texture Generator Controls\n"
18264 " -->\n"
18265 " <IntVectorProperty name=\"GenerateNoiseTexture\"\n"
18266 " command=\"SetGenerateNoiseTexture\"\n"
18267 " number_of_elements=\"1\"\n"
18268 " default_values=\"0\"\n"
18269 " panel_visibility=\"advanced\"\n"
18270 " >\n"
18271 " <BooleanDomain name=\"bool\" />\n"
18272 " </IntVectorProperty>\n"
18273 "\n"
18274 " <IntVectorProperty name=\"NoiseType\"\n"
18275 " command=\"SetNoiseType\"\n"
18276 " number_of_elements=\"1\"\n"
18277 " default_values=\"1\"\n"
18278 " panel_visibility=\"advanced\"\n"
18279 " >\n"
18280 " <EnumerationDomain name=\"enum\">\n"
18281 " <Entry text=\"uniform\" value=\"0\" />\n"
18282 " <Entry text=\"Gaussian\" value=\"1\" />\n"
18283 " <Entry text=\"Perlin\" value=\"2\" />\n"
18284 " </EnumerationDomain>\n"
18285 " </IntVectorProperty>\n"
18286 "\n"
18287 " <IntVectorProperty name=\"NoiseTextureSize\"\n"
18288 " command=\"SetNoiseTextureSize\"\n"
18289 " number_of_elements=\"1\"\n"
18290 " default_values=\"128\"\n"
18291 " panel_visibility=\"advanced\"\n"
18292 " >\n"
18293 " <IntRangeDomain name=\"range\" min=\"2\" max=\"4096\" />\n"
18294 " </IntVectorProperty>\n"
18295 "\n"
18296 " <IntVectorProperty name=\"NoiseGrainSize\"\n"
18297 " command=\"SetNoiseGrainSize\"\n"
18298 " number_of_elements=\"1\"\n"
18299 " default_values=\"2\"\n"
18300 " panel_visibility=\"advanced\"\n"
18301 " >\n"
18302 " <IntRangeDomain name=\"range\" min=\"1\" max=\"4096\" />\n"
18303 " </IntVectorProperty>\n"
18304 "\n"
18305 " <DoubleVectorProperty name=\"MinNoiseValue\"\n"
18306 " command=\"SetMinNoiseValue\"\n"
18307 " number_of_elements=\"1\"\n"
18308 " default_values=\"0.0\"\n"
18309 " panel_visibility=\"advanced\"\n"
18310 " >\n"
18311 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\"/>\n"
18312 " </DoubleVectorProperty>\n"
18313 "\n"
18314 " <DoubleVectorProperty name=\"MaxNoiseValue\"\n"
18315 " command=\"SetMaxNoiseValue\"\n"
18316 " number_of_elements=\"1\"\n"
18317 " default_values=\"0.8\"\n"
18318 " panel_visibility=\"advanced\"\n"
18319 " >\n"
18320 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\"/>\n"
18321 " </DoubleVectorProperty>\n"
18322 "\n"
18323 " <IntVectorProperty name=\"NumberOfNoiseLevels\"\n"
18324 " command=\"SetNumberOfNoiseLevels\"\n"
18325 " number_of_elements=\"1\"\n"
18326 " default_values=\"1024\"\n"
18327 " panel_visibility=\"advanced\"\n"
18328 " >\n"
18329 " <IntRangeDomain name=\"range\" min=\"1\" max=\"1024\" />\n"
18330 " </IntVectorProperty>\n"
18331 "\n"
18332 " <DoubleVectorProperty name=\"ImpulseNoiseProbability\"\n"
18333 " label=\"Impulse Probability\"\n"
18334 " command=\"SetImpulseNoiseProbability\"\n"
18335 " number_of_elements=\"1\"\n"
18336 " default_values=\"1.0\"\n"
18337 " panel_visibility=\"advanced\"\n"
18338 " >\n"
18339 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
18340 " </DoubleVectorProperty>\n"
18341 "\n"
18342 " <DoubleVectorProperty name=\"ImpulseNoiseBackgroundValue\"\n"
18343 " label=\"Impulse BackgroundValue\"\n"
18344 " command=\"SetImpulseNoiseBackgroundValue\"\n"
18345 " number_of_elements=\"1\"\n"
18346 " default_values=\"0.0\"\n"
18347 " panel_visibility=\"advanced\"\n"
18348 " >\n"
18349 " <DoubleRangeDomain name=\"range\" min=\"0.0\" max=\"1.0\" />\n"
18350 " </DoubleVectorProperty>\n"
18351 "\n"
18352 " <IntVectorProperty name=\"NoiseGeneratorSeed\"\n"
18353 " label=\"RNG Seed\"\n"
18354 " command=\"SetNoiseGeneratorSeed\"\n"
18355 " number_of_elements=\"1\"\n"
18356 " default_values=\"1\"\n"
18357 " panel_visibility=\"advanced\"\n"
18358 " >\n"
18359 " <IntRangeDomain name=\"range\" min=\"1\" max=\"1073741823\" />\n"
18360 " </IntVectorProperty>\n"
18361 "\n"
18362 " <!--\n"
18363 " Parallel performance\n"
18364 " -->\n"
18365 " <IntVectorProperty name=\"CompositeStrategy\"\n"
18366 " command=\"SetCompositeStrategy\"\n"
18367 " number_of_elements=\"1\"\n"
18368 " default_values=\"3\"\n"
18369 " panel_visibility=\"advanced\"\n"
18370 " >\n"
18371 " <EnumerationDomain name=\"enum\">\n"
18372 " <Entry text=\"INPLACE\" value=\"0\" />\n"
18373 " <Entry text=\"INPLACE DISJOINT\" value=\"1\" />\n"
18374 " <Entry text=\"BALANCED\" value=\"2\" />\n"
18375 " <Entry text=\"AUTO\" value=\"3\" />\n"
18376 " </EnumerationDomain>\n"
18377 " </IntVectorProperty>\n"
18378 "\n"
18379 " <!--\n"
18380 " Interactive performance.\n"
18381 " -->\n"
18382 " <IntVectorProperty name=\"UseLICForLOD\"\n"
18383 " label=\"Use LIC for LOD\"\n"
18384 " command=\"SetUseLICForLOD\"\n"
18385 " number_of_elements=\"1\"\n"
18386 " default_values=\"0\"\n"
18387 " panel_visibility=\"advanced\"\n"
18388 " >\n"
18389 " <BooleanDomain name=\"bool\" />\n"
18390 " </IntVectorProperty>\n"
18391 "\n"
18392 " <!--\n"
18393 " for benchmarking\n"
18394 " setting the file name will trigger the write.\n"
18395 " -->\n"
18396 " <StringVectorProperty name=\"WriteLog\"\n"
18397 " command=\"WriteTimerLog\"\n"
18398 " number_of_elements=\"1\"\n"
18399 " label=\"Log File\"\n"
18400 " panel_visibility=\"advanced\">\n"
18401 " <Documentation>\n"
18402 " when compiled for benchmarking\n"
18403 " setting the file name will trigger\n"
18404 " a write of the parallel timer log\n"
18405 " </Documentation>\n"
18406 " </StringVectorProperty>\n"
18407 " <!-- end of SurfaceLICRepresentation -->\n"
18408 " </RepresentationProxy>\n"
18409 "\n"
18410 " <!--======================================================================-->\n"
18411 " <Extension name=\"GeometryRepresentation\">\n"
18412 " <RepresentationType subproxy=\"SurfaceLICRepresentation\"\n"
18413 " subtype=\"Surface\" text=\"Surface LIC\" />\n"
18414 "\n"
18415 " <SubProxy>\n"
18416 " <Proxy name=\"SurfaceLICRepresentation\"\n"
18417 " proxygroup=\"representations\" proxyname=\"SurfaceLICRepresentation\" />\n"
18418 "\n"
18419 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
18420 " <Exception name=\"Input\" />\n"
18421 " <Exception name=\"Visibility\" />\n"
18422 " </ShareProperties>\n"
18423 "\n"
18424 " <ExposedProperties>\n"
18425 " <!--<PropertyGroup label=\"Surface LIC Parameters\">-->\n"
18426 " <!-- Integrator -->\n"
18427 " <PropertyGroup label=\"SurfaceLIC: Integrator\">\n"
18428 " <Property name=\"SelectInputVectors\"/>\n"
18429 " <Property name=\"NumberOfSteps\"/>\n"
18430 " <Property name=\"StepSize\" />\n"
18431 " <Property name=\"NormalizeVectors\" />\n"
18432 " <Property name=\"EnhancedLIC\" />\n"
18433 " <Hints>\n"
18434 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18435 " mode=\"visibility\"\n"
18436 " property=\"Representation\"\n"
18437 " value=\"Surface LIC\" />\n"
18438 " </Hints>\n"
18439 " </PropertyGroup>\n"
18440 "\n"
18441 " <!-- Rendering controls -->\n"
18442 " <PropertyGroup label=\"SurfaceLIC: Rendering\">\n"
18443 " <Property name=\"ColorMode\" />\n"
18444 " <Property name=\"LICIntensity\" />\n"
18445 ;
18446
18447 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
18449 " <Property name=\"MapModeBias\" />\n"
18450 "\n"
18451 " <Property name=\"EnhanceContrast\" />\n"
18452 " <Property name=\"LowLICContrastEnhancementFactor\" />\n"
18453 " <Property name=\"HighLICContrastEnhancementFactor\" />\n"
18454 " <Property name=\"LowColorContrastEnhancementFactor\" />\n"
18455 " <Property name=\"HighColorContrastEnhancementFactor\" />\n"
18456 "\n"
18457 " <Property name=\"AntiAlias\" />\n"
18458 " <Hints>\n"
18459 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18460 " mode=\"visibility\"\n"
18461 " property=\"Representation\"\n"
18462 " value=\"Surface LIC\" />\n"
18463 " </Hints>\n"
18464 " </PropertyGroup>\n"
18465 "\n"
18466 " <!-- Fragment Masking -->\n"
18467 " <PropertyGroup label=\"SurfaceLIC: Fragment masking\">\n"
18468 " <Property name=\"MaskOnSurface\" />\n"
18469 " <Property name=\"MaskThreshold\" />\n"
18470 " <Property name=\"MaskIntensity\" />\n"
18471 " <Property name=\"MaskColor\" />\n"
18472 " <Hints>\n"
18473 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18474 " mode=\"visibility\"\n"
18475 " property=\"Representation\"\n"
18476 " value=\"Surface LIC\" />\n"
18477 " </Hints>\n"
18478 " </PropertyGroup>\n"
18479 "\n"
18480 " <!-- Noise texture controls -->\n"
18481 " <PropertyGroup label=\"SurfaceLIC: Noise texture generator\">\n"
18482 " <Property name=\"GenerateNoiseTexture\" />\n"
18483 " <Property name=\"NoiseType\" />\n"
18484 " <Property name=\"NoiseTextureSize\" />\n"
18485 " <Property name=\"NoiseGrainSize\" />\n"
18486 " <Property name=\"MinNoiseValue\" />\n"
18487 " <Property name=\"MaxNoiseValue\" />\n"
18488 " <Property name=\"NumberOfNoiseLevels\" />\n"
18489 " <Property name=\"ImpulseNoiseProbability\" />\n"
18490 " <Property name=\"ImpulseNoiseBackgroundValue\" />\n"
18491 " <Property name=\"NoiseGeneratorSeed\" />\n"
18492 " <Hints>\n"
18493 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18494 " mode=\"visibility\"\n"
18495 " property=\"Representation\"\n"
18496 " value=\"Surface LIC\" />\n"
18497 " </Hints>\n"
18498 " </PropertyGroup>\n"
18499 "\n"
18500 " <!-- Parallel controls -->\n"
18501 " <PropertyGroup label=\"SurfaceLIC: Parallelization\">\n"
18502 " <Property name=\"CompositeStrategy\" />\n"
18503 " <Hints>\n"
18504 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18505 " mode=\"visibility\"\n"
18506 " property=\"Representation\"\n"
18507 " value=\"Surface LIC\" />\n"
18508 " </Hints>\n"
18509 " </PropertyGroup>\n"
18510 "\n"
18511 " <!-- Interactivity controls -->\n"
18512 " <PropertyGroup label=\"SurfaceLIC: Interactivity\">\n"
18513 " <Property name=\"UseLICForLOD\" />\n"
18514 " <Hints>\n"
18515 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18516 " mode=\"visibility\"\n"
18517 " property=\"Representation\"\n"
18518 " value=\"Surface LIC\" />\n"
18519 " </Hints>\n"
18520 " </PropertyGroup>\n"
18521 "\n"
18522 " <!-- benchmarking -->\n"
18523 " <PropertyGroup label=\"SurfaceLIC: Benchmark\">\n"
18524 " <Property name=\"WriteLog\" />\n"
18525 " <Hints>\n"
18526 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18527 " mode=\"visibility\"\n"
18528 " property=\"Representation\"\n"
18529 " value=\"Surface LIC\" />\n"
18530 " </Hints>\n"
18531 " </PropertyGroup>\n"
18532 " <!-- </PropertyGroup> -->\n"
18533 " </ExposedProperties>\n"
18534 "\n"
18535 " </SubProxy>\n"
18536 " </Extension>\n"
18537 "\n"
18538 " <!--======================================================================-->\n"
18539 " <Extension name=\"UnstructuredGridRepresentation\">\n"
18540 " <RepresentationType subproxy=\"SurfaceLICRepresentation\"\n"
18541 " subtype=\"Surface\" text=\"Surface LIC\" />\n"
18542 "\n"
18543 " <SubProxy>\n"
18544 " <Proxy name=\"SurfaceLICRepresentation\"\n"
18545 " proxygroup=\"representations\" proxyname=\"SurfaceLICRepresentation\" />\n"
18546 "\n"
18547 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
18548 " <Exception name=\"Input\" />\n"
18549 " <Exception name=\"Visibility\" />\n"
18550 " </ShareProperties>\n"
18551 "\n"
18552 " <ExposedProperties>\n"
18553 " <!--<PropertyGroup label=\"Surface LIC Parameters\">-->\n"
18554 " <!-- Integrator -->\n"
18555 " <PropertyGroup label=\"SurfaceLIC: Integrator\">\n"
18556 " <Property name=\"SelectInputVectors\"/>\n"
18557 " <Property name=\"NumberOfSteps\"/>\n"
18558 " <Property name=\"StepSize\" />\n"
18559 " <Property name=\"NormalizeVectors\" />\n"
18560 " <Property name=\"EnhancedLIC\" />\n"
18561 " <Hints>\n"
18562 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18563 " mode=\"visibility\"\n"
18564 " property=\"Representation\"\n"
18565 " value=\"Surface LIC\" />\n"
18566 " </Hints>\n"
18567 " </PropertyGroup>\n"
18568 "\n"
18569 " <!-- Rendering controls -->\n"
18570 " <PropertyGroup label=\"SurfaceLIC: Rendering\">\n"
18571 " <Property name=\"ColorMode\" />\n"
18572 " <Property name=\"LICIntensity\" />\n"
18573 " <Property name=\"MapModeBias\" />\n"
18574 "\n"
18575 " <Property name=\"EnhanceContrast\" />\n"
18576 " <Property name=\"LowLICContrastEnhancementFactor\" />\n"
18577 " <Property name=\"HighLICContrastEnhancementFactor\" />\n"
18578 " <Property name=\"LowColorContrastEnhancementFactor\" />\n"
18579 " <Property name=\"HighColorContrastEnhancementFactor\" />\n"
18580 "\n"
18581 " <Property name=\"AntiAlias\" />\n"
18582 " <Hints>\n"
18583 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18584 " mode=\"visibility\"\n"
18585 " property=\"Representation\"\n"
18586 " value=\"Surface LIC\" />\n"
18587 " </Hints>\n"
18588 " </PropertyGroup>\n"
18589 "\n"
18590 " <!-- Fragment Masking -->\n"
18591 " <PropertyGroup label=\"SurfaceLIC: Fragment masking\">\n"
18592 " <Property name=\"MaskOnSurface\" />\n"
18593 " <Property name=\"MaskThreshold\" />\n"
18594 " <Property name=\"MaskIntensity\" />\n"
18595 " <Property name=\"MaskColor\" />\n"
18596 " <Hints>\n"
18597 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18598 " mode=\"visibility\"\n"
18599 " property=\"Representation\"\n"
18600 " value=\"Surface LIC\" />\n"
18601 " </Hints>\n"
18602 " </PropertyGroup>\n"
18603 "\n"
18604 " <!-- Noise texture controls -->\n"
18605 " <PropertyGroup label=\"SurfaceLIC: Noise texture generator\">\n"
18606 " <Property name=\"GenerateNoiseTexture\" />\n"
18607 " <Property name=\"NoiseType\" />\n"
18608 " <Property name=\"NoiseTextureSize\" />\n"
18609 " <Property name=\"NoiseGrainSize\" />\n"
18610 " <Property name=\"MinNoiseValue\" />\n"
18611 " <Property name=\"MaxNoiseValue\" />\n"
18612 " <Property name=\"NumberOfNoiseLevels\" />\n"
18613 " <Property name=\"ImpulseNoiseProbability\" />\n"
18614 " <Property name=\"ImpulseNoiseBackgroundValue\" />\n"
18615 " <Property name=\"NoiseGeneratorSeed\" />\n"
18616 " <Hints>\n"
18617 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18618 " mode=\"visibility\"\n"
18619 " property=\"Representation\"\n"
18620 " value=\"Surface LIC\" />\n"
18621 " </Hints>\n"
18622 " </PropertyGroup>\n"
18623 "\n"
18624 " <!-- Parallel controls -->\n"
18625 " <PropertyGroup label=\"SurfaceLIC: Parallelization\">\n"
18626 " <Property name=\"CompositeStrategy\" />\n"
18627 " <Hints>\n"
18628 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18629 " mode=\"visibility\"\n"
18630 " property=\"Representation\"\n"
18631 " value=\"Surface LIC\" />\n"
18632 " </Hints>\n"
18633 " </PropertyGroup>\n"
18634 "\n"
18635 " <!-- Interactivity controls -->\n"
18636 " <PropertyGroup label=\"SurfaceLIC: Interactivity\">\n"
18637 " <Property name=\"UseLICForLOD\" />\n"
18638 " <Hints>\n"
18639 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18640 " mode=\"visibility\"\n"
18641 " property=\"Representation\"\n"
18642 " value=\"Surface LIC\" />\n"
18643 " </Hints>\n"
18644 " </PropertyGroup>\n"
18645 "\n"
18646 " <!-- benchmarking -->\n"
18647 " <PropertyGroup label=\"SurfaceLIC: Benchmark\">\n"
18648 " <Property name=\"WriteLog\" />\n"
18649 " <Hints>\n"
18650 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18651 " mode=\"visibility\"\n"
18652 " property=\"Representation\"\n"
18653 " value=\"Surface LIC\" />\n"
18654 " </Hints>\n"
18655 " </PropertyGroup>\n"
18656 " <!-- </PropertyGroup> -->\n"
18657 " </ExposedProperties>\n"
18658 "\n"
18659 " </SubProxy>\n"
18660 " </Extension>\n"
18661 "\n"
18662 " <!--======================================================================-->\n"
18663 " <Extension name=\"UniformGridRepresentation\">\n"
18664 " <RepresentationType subproxy=\"SurfaceLICRepresentation\"\n"
18665 " subtype=\"Surface\" text=\"Surface LIC\" />\n"
18666 " <SubProxy>\n"
18667 " <Proxy name=\"SurfaceLICRepresentation\"\n"
18668 " proxygroup=\"representations\" proxyname=\"SurfaceLICRepresentation\" />\n"
18669 "\n"
18670 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
18671 " <Exception name=\"Input\" />\n"
18672 " <Exception name=\"Visibility\" />\n"
18673 " </ShareProperties>\n"
18674 "\n"
18675 " <ExposedProperties>\n"
18676 " <!--<PropertyGroup label=\"Surface LIC Parameters\">-->\n"
18677 " <!-- Integrator -->\n"
18678 " <PropertyGroup label=\"SurfaceLIC: Integrator\">\n"
18679 " <Property name=\"SelectInputVectors\"/>\n"
18680 " <Property name=\"NumberOfSteps\"/>\n"
18681 " <Property name=\"StepSize\" />\n"
18682 " <Property name=\"NormalizeVectors\" />\n"
18683 " <Property name=\"EnhancedLIC\" />\n"
18684 " <Hints>\n"
18685 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18686 " mode=\"visibility\"\n"
18687 " property=\"Representation\"\n"
18688 " value=\"Surface LIC\" />\n"
18689 " </Hints>\n"
18690 " </PropertyGroup>\n"
18691 "\n"
18692 " <!-- Rendering controls -->\n"
18693 " <PropertyGroup label=\"SurfaceLIC: Rendering\">\n"
18694 " <Property name=\"ColorMode\" />\n"
18695 " <Property name=\"LICIntensity\" />\n"
18696 " <Property name=\"MapModeBias\" />\n"
18697 "\n"
18698 " <Property name=\"EnhanceContrast\" />\n"
18699 " <Property name=\"LowLICContrastEnhancementFactor\" />\n"
18700 " <Property name=\"HighLICContrastEnhancementFactor\" />\n"
18701 " <Property name=\"LowColorContrastEnhancementFactor\" />\n"
18702 " <Property name=\"HighColorContrastEnhancementFactor\" />\n"
18703 "\n"
18704 " <Property name=\"AntiAlias\" />\n"
18705 " <Hints>\n"
18706 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18707 " mode=\"visibility\"\n"
18708 " property=\"Representation\"\n"
18709 " value=\"Surface LIC\" />\n"
18710 " </Hints>\n"
18711 " </PropertyGroup>\n"
18712 "\n"
18713 " <!-- Fragment Masking -->\n"
18714 " <PropertyGroup label=\"SurfaceLIC: Fragment masking\">\n"
18715 " <Property name=\"MaskOnSurface\" />\n"
18716 " <Property name=\"MaskThreshold\" />\n"
18717 " <Property name=\"MaskIntensity\" />\n"
18718 " <Property name=\"MaskColor\" />\n"
18719 " <Hints>\n"
18720 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18721 " mode=\"visibility\"\n"
18722 " property=\"Representation\"\n"
18723 " value=\"Surface LIC\" />\n"
18724 " </Hints>\n"
18725 " </PropertyGroup>\n"
18726 "\n"
18727 " <!-- Noise texture controls -->\n"
18728 " <PropertyGroup label=\"SurfaceLIC: Noise texture generator\">\n"
18729 " <Property name=\"GenerateNoiseTexture\" />\n"
18730 " <Property name=\"NoiseType\" />\n"
18731 " <Property name=\"NoiseTextureSize\" />\n"
18732 " <Property name=\"NoiseGrainSize\" />\n"
18733 " <Property name=\"MinNoiseValue\" />\n"
18734 " <Property name=\"MaxNoiseValue\" />\n"
18735 " <Property name=\"NumberOfNoiseLevels\" />\n"
18736 " <Property name=\"ImpulseNoiseProbability\" />\n"
18737 " <Property name=\"ImpulseNoiseBackgroundValue\" />\n"
18738 " <Property name=\"NoiseGeneratorSeed\" />\n"
18739 " <Hints>\n"
18740 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18741 " mode=\"visibility\"\n"
18742 " property=\"Representation\"\n"
18743 " value=\"Surface LIC\" />\n"
18744 " </Hints>\n"
18745 " </PropertyGroup>\n"
18746 "\n"
18747 " <!-- Parallel controls -->\n"
18748 " <PropertyGroup label=\"SurfaceLIC: Parallelization\">\n"
18749 " <Property name=\"CompositeStrategy\" />\n"
18750 " <Hints>\n"
18751 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18752 " mode=\"visibility\"\n"
18753 " property=\"Representation\"\n"
18754 " value=\"Surface LIC\" />\n"
18755 " </Hints>\n"
18756 " </PropertyGroup>\n"
18757 "\n"
18758 " <!-- Interactivity controls -->\n"
18759 " <PropertyGroup label=\"SurfaceLIC: Interactivity\">\n"
18760 " <Property name=\"UseLICForLOD\" />\n"
18761 " <Hints>\n"
18762 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18763 " mode=\"visibility\"\n"
18764 " property=\"Representation\"\n"
18765 " value=\"Surface LIC\" />\n"
18766 " </Hints>\n"
18767 " </PropertyGroup>\n"
18768 "\n"
18769 " <!-- benchmarking -->\n"
18770 " <PropertyGroup label=\"SurfaceLIC: Benchmark\">\n"
18771 " <Property name=\"WriteLog\" />\n"
18772 " <Hints>\n"
18773 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18774 " mode=\"visibility\"\n"
18775 " property=\"Representation\"\n"
18776 " value=\"Surface LIC\" />\n"
18777 " </Hints>\n"
18778 " </PropertyGroup>\n"
18779 " <!-- </PropertyGroup> -->\n"
18780 " </ExposedProperties>\n"
18781 "\n"
18782 " </SubProxy>\n"
18783 " </Extension>\n"
18784 "\n"
18785 " <!--======================================================================-->\n"
18786 " <Extension name=\"StructuredGridRepresentation\">\n"
18787 " <RepresentationType subproxy=\"SurfaceLICRepresentation\"\n"
18788 " subtype=\"Surface\" text=\"Surface LIC\" />\n"
18789 " <SubProxy>\n"
18790 " <Proxy name=\"SurfaceLICRepresentation\"\n"
18791 " proxygroup=\"representations\" proxyname=\"SurfaceLICRepresentation\" />\n"
18792 "\n"
18793 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
18794 ;
18795
18796 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
18798 " <Exception name=\"Input\" />\n"
18799 " <Exception name=\"Visibility\" />\n"
18800 " </ShareProperties>\n"
18801 "\n"
18802 " <ExposedProperties>\n"
18803 " <!--<PropertyGroup label=\"Surface LIC Parameters\">-->\n"
18804 " <!-- Integrator -->\n"
18805 " <PropertyGroup label=\"SurfaceLIC: Integrator\">\n"
18806 " <Property name=\"SelectInputVectors\"/>\n"
18807 " <Property name=\"NumberOfSteps\"/>\n"
18808 " <Property name=\"StepSize\" />\n"
18809 " <Property name=\"NormalizeVectors\" />\n"
18810 " <Property name=\"EnhancedLIC\" />\n"
18811 " <Hints>\n"
18812 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18813 " mode=\"visibility\"\n"
18814 " property=\"Representation\"\n"
18815 " value=\"Surface LIC\" />\n"
18816 " </Hints>\n"
18817 " </PropertyGroup>\n"
18818 "\n"
18819 " <!-- Rendering controls -->\n"
18820 " <PropertyGroup label=\"SurfaceLIC: Rendering\">\n"
18821 " <Property name=\"ColorMode\" />\n"
18822 " <Property name=\"LICIntensity\" />\n"
18823 " <Property name=\"MapModeBias\" />\n"
18824 "\n"
18825 " <Property name=\"EnhanceContrast\" />\n"
18826 " <Property name=\"LowLICContrastEnhancementFactor\" />\n"
18827 " <Property name=\"HighLICContrastEnhancementFactor\" />\n"
18828 " <Property name=\"LowColorContrastEnhancementFactor\" />\n"
18829 " <Property name=\"HighColorContrastEnhancementFactor\" />\n"
18830 "\n"
18831 " <Property name=\"AntiAlias\" />\n"
18832 " <Hints>\n"
18833 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18834 " mode=\"visibility\"\n"
18835 " property=\"Representation\"\n"
18836 " value=\"Surface LIC\" />\n"
18837 " </Hints>\n"
18838 " </PropertyGroup>\n"
18839 "\n"
18840 " <!-- Fragment Masking -->\n"
18841 " <PropertyGroup label=\"SurfaceLIC: Fragment masking\">\n"
18842 " <Property name=\"MaskOnSurface\" />\n"
18843 " <Property name=\"MaskThreshold\" />\n"
18844 " <Property name=\"MaskIntensity\" />\n"
18845 " <Property name=\"MaskColor\" />\n"
18846 " <Hints>\n"
18847 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18848 " mode=\"visibility\"\n"
18849 " property=\"Representation\"\n"
18850 " value=\"Surface LIC\" />\n"
18851 " </Hints>\n"
18852 " </PropertyGroup>\n"
18853 "\n"
18854 " <!-- Noise texture controls -->\n"
18855 " <PropertyGroup label=\"SurfaceLIC: Noise texture generator\">\n"
18856 " <Property name=\"GenerateNoiseTexture\" />\n"
18857 " <Property name=\"NoiseType\" />\n"
18858 " <Property name=\"NoiseTextureSize\" />\n"
18859 " <Property name=\"NoiseGrainSize\" />\n"
18860 " <Property name=\"MinNoiseValue\" />\n"
18861 " <Property name=\"MaxNoiseValue\" />\n"
18862 " <Property name=\"NumberOfNoiseLevels\" />\n"
18863 " <Property name=\"ImpulseNoiseProbability\" />\n"
18864 " <Property name=\"ImpulseNoiseBackgroundValue\" />\n"
18865 " <Property name=\"NoiseGeneratorSeed\" />\n"
18866 " <Hints>\n"
18867 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18868 " mode=\"visibility\"\n"
18869 " property=\"Representation\"\n"
18870 " value=\"Surface LIC\" />\n"
18871 " </Hints>\n"
18872 " </PropertyGroup>\n"
18873 "\n"
18874 " <!-- Parallel controls -->\n"
18875 " <PropertyGroup label=\"SurfaceLIC: Parallelization\">\n"
18876 " <Property name=\"CompositeStrategy\" />\n"
18877 " <Hints>\n"
18878 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18879 " mode=\"visibility\"\n"
18880 " property=\"Representation\"\n"
18881 " value=\"Surface LIC\" />\n"
18882 " </Hints>\n"
18883 " </PropertyGroup>\n"
18884 "\n"
18885 " <!-- Interactivity controls -->\n"
18886 " <PropertyGroup label=\"SurfaceLIC: Interactivity\">\n"
18887 " <Property name=\"UseLICForLOD\" />\n"
18888 " <Hints>\n"
18889 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18890 " mode=\"visibility\"\n"
18891 " property=\"Representation\"\n"
18892 " value=\"Surface LIC\" />\n"
18893 " </Hints>\n"
18894 " </PropertyGroup>\n"
18895 "\n"
18896 " <!-- benchmarking -->\n"
18897 " <PropertyGroup label=\"SurfaceLIC: Benchmark\">\n"
18898 " <Property name=\"WriteLog\" />\n"
18899 " <Hints>\n"
18900 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
18901 " mode=\"visibility\"\n"
18902 " property=\"Representation\"\n"
18903 " value=\"Surface LIC\" />\n"
18904 " </Hints>\n"
18905 " </PropertyGroup>\n"
18906 " <!-- </PropertyGroup> -->\n"
18907 " </ExposedProperties>\n"
18908 "\n"
18909 " </SubProxy>\n"
18910 " </Extension>\n"
18911 "\n"
18912 "\n"
18913 "\n"
18914 " <!-- ================================================================== -->\n"
18915 " <RepresentationProxy class=\"vtkOutlineRepresentation\"\n"
18916 " name=\"OutlineRepresentation\"\n"
18917 " processes=\"client|renderserver|dataserver\"\n"
18918 " base_proxygroup=\"representations\"\n"
18919 " base_proxyname=\"SurfaceRepresentation\" >\n"
18920 " <Documentation>\n"
18921 " Representation for showing an outline for any dataset.\n"
18922 " </Documentation>\n"
18923 " <!-- end of OutlineRepresentation -->\n"
18924 " </RepresentationProxy>\n"
18925 "\n"
18926 " <!-- ================================================================== -->\n"
18927 " <RepresentationProxy class=\"vtkFeatureEdgesRepresentation\"\n"
18928 " name=\"FeatureEdgesRepresentation\"\n"
18929 " processes=\"client|renderserver|dataserver\"\n"
18930 " base_proxygroup=\"representations\"\n"
18931 " base_proxyname=\"SurfaceRepresentation\" >\n"
18932 " <Documentation>\n"
18933 " Representation for showing feature edges for any dataset.\n"
18934 " </Documentation>\n"
18935 " <!-- end of OutlineRepresentation -->\n"
18936 " </RepresentationProxy>\n"
18937 "\n"
18938 " <!-- ================================================================== -->\n"
18939 " <RepresentationProxy base_proxyname=\"PVRepresentationBase\"\n"
18940 " name=\"PointGaussianRepresentation\"\n"
18941 " class=\"vtkPointGaussianRepresentation\"\n"
18942 " processes=\"client|renderserver|dataserver\">\n"
18943 " <Documentation>\n"
18944 " </Documentation>\n"
18945 " <InputProperty command=\"SetInputConnection\"\n"
18946 " name=\"Input\">\n"
18947 " <DataTypeDomain composite_data_supported=\"0\"\n"
18948 " name=\"input_type\">\n"
18949 " <DataType value=\"vtkDataSet\"/>\n"
18950 " </DataTypeDomain>\n"
18951 " <InputArrayDomain attribute_type=\"point\"\n"
18952 " name=\"input_point_array\"\n"
18953 " optional=\"1\">\n"
18954 " </InputArrayDomain>\n"
18955 " </InputProperty>\n"
18956 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
18957 " element_types=\"0 0 0 0 2\"\n"
18958 " name=\"ColorArrayName\"\n"
18959 " number_of_elements=\"5\">\n"
18960 " <Documentation>\n"
18961 " Set the array to color with. One must specify the field association and\n"
18962 " the array name of the array. If the array is missing, scalar coloring will\n"
18963 " automatically be disabled.\n"
18964 " </Documentation>\n"
18965 " <RepresentedArrayListDomain name=\"array_list\"\n"
18966 " input_domain_name=\"input_array_any\">\n"
18967 " <RequiredProperties>\n"
18968 " <Property function=\"Input\" name=\"Input\" />\n"
18969 " </RequiredProperties>\n"
18970 " </RepresentedArrayListDomain>\n"
18971 " </StringVectorProperty>\n"
18972 " <IntVectorProperty command=\"SetMapScalars\"\n"
18973 " default_values=\"1\"\n"
18974 " name=\"MapScalars\"\n"
18975 " number_of_elements=\"1\">\n"
18976 " <BooleanDomain name=\"bool\" />\n"
18977 " <Documentation>When set to True, LookupTable will always be\n"
18978 " used for scalar mapping. Otherwise, when up to 4 component\n"
18979 " scalars are present, the components are clamped to a valid\n"
18980 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
18981 " floating point type) and then directly used as\n"
18982 " color.</Documentation>\n"
18983 " </IntVectorProperty>\n"
18984 " <ProxyProperty command=\"SetLookupTable\"\n"
18985 " name=\"LookupTable\" >\n"
18986 " <Documentation>Set the lookup-table to use to map data array to colors.\n"
18987 " Lookuptable is only used with MapScalars to ON.</Documentation>\n"
18988 " <ProxyGroupDomain name=\"groups\">\n"
18989 " <Group name=\"lookup_tables\" />\n"
18990 " </ProxyGroupDomain>\n"
18991 " </ProxyProperty>\n"
18992 " <DoubleVectorProperty command=\"SetSplatSize\"\n"
18993 " default_values=\"0.0\"\n"
18994 " name=\"GaussianRadius\"\n"
18995 " label=\"Gaussian Radius\"\n"
18996 " number_of_elements=\"1\">\n"
18997 " <BoundsDomain name=\"range\" mode=\"scaled_extent\" scale_factor=\"0.005\">\n"
18998 " <RequiredProperties>\n"
18999 " <Property function=\"Input\" name=\"Input\" />\n"
19000 " </RequiredProperties>\n"
19001 " </BoundsDomain>\n"
19002 " <Documentation>\n"
19003 " The radius of the gaussian blur for each point.\n"
19004 " </Documentation>\n"
19005 " </DoubleVectorProperty>\n"
19006 " <IntVectorProperty command=\"SelectShaderPreset\"\n"
19007 " default_values=\"1\"\n"
19008 " name=\"ShaderPreset\"\n"
19009 " number_of_elements=\"1\">\n"
19010 " <EnumerationDomain name=\"enum\">\n"
19011 " <Entry text=\"Gaussian Blur\"\n"
19012 " value=\"0\" />\n"
19013 " <Entry text=\"Sphere\"\n"
19014 " value=\"1\" />\n"
19015 " <Entry text=\"Black-edged circle\"\n"
19016 " value=\"2\" />\n"
19017 " <Entry text=\"Plain circle\"\n"
19018 " value=\"3\" />\n"
19019 " <Entry text=\"Triangle\"\n"
19020 " value=\"4\" />\n"
19021 " <Entry text=\"Square Outline\"\n"
19022 " value=\"5\" />\n"
19023 " <Entry text=\"Custom\"\n"
19024 " value=\"6\" />\n"
19025 " </EnumerationDomain>\n"
19026 " </IntVectorProperty>\n"
19027 " <IntVectorProperty animateable=\"0\"\n"
19028 " command=\"SetCustomTriangleScale\"\n"
19029 " default_values=\"3\"\n"
19030 " name=\"CustomTriangleScale\"\n"
19031 " number_of_elements=\"1\"\n"
19032 " panel_visibility=\"advanced\">\n"
19033 " <Documentation>\n"
19034 " Sets the scale of the triangle geometry drawn, automatically\n"
19035 " set when using preset but needed with custom shader code\n"
19036 " </Documentation>\n"
19037 " <Hints>\n"
19038 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
19039 " mode=\"visibility\"\n"
19040 " property=\"ShaderPreset\"\n"
19041 " value=\"6\" />\n"
19042 " <!-- show this widget when using CustomShader -->\n"
19043 " </Hints>\n"
19044 " </IntVectorProperty>\n"
19045 " <StringVectorProperty command=\"SetCustomShader\"\n"
19046 " default_values=\"\n"
19047 "// This custom shader code define a gaussian blur&#xa;\n"
19048 "// Please take a look into vtkSMPointGaussianRepresentation.cxx&#xa;\n"
19049 "// for other custom shader examples&#xa;\n"
19050 "//VTK::Color::Impl&#xa;\n"
19051 " float dist2 = dot(offsetVCVSOutput.xy,offsetVCVSOutput.xy);&#xa;\n"
19052 " float gaussian = exp(-0.5*dist2);&#xa;\n"
19053 " opacity = opacity*gaussian;&#xa;\"\n"
19054 " label=\"Custom Shader Code\"\n"
19055 " name=\"CustomShader\"\n"
19056 " number_of_elements=\"1\"\n"
19057 " panel_visibility=\"advanced\">\n"
19058 " <Documentation>\n"
19059 " Sets the custom shader code\n"
19060 " </Documentation>\n"
19061 " <Hints>\n"
19062 " <Widget type=\"multi_line\" />\n"
19063 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
19064 " mode=\"visibility\"\n"
19065 " property=\"ShaderPreset\"\n"
19066 " value=\"6\" />\n"
19067 " <!-- show this widget when using CustomShader -->\n"
19068 " </Hints>\n"
19069 " </StringVectorProperty>\n"
19070 " <IntVectorProperty command=\"SetEmissive\"\n"
19071 " default_values=\"0\"\n"
19072 " name=\"Emissive\"\n"
19073 " number_of_elements=\"1\"\n"
19074 " panel_visibility=\"advanced\">\n"
19075 " <BooleanDomain name=\"bool\" />\n"
19076 " <Documentation>\n"
19077 " Should the splat be emissive like a light source or not. For cosmology emissive should be on. For scanned point clouds typically it would be off.\n"
19078 " </Documentation>\n"
19079 " </IntVectorProperty>\n"
19080 " <IntVectorProperty command=\"SetScaleByArray\"\n"
19081 " default_values=\"0\"\n"
19082 " name=\"ScaleByArray\"\n"
19083 " number_of_elements=\"1\"\n"
19084 " label=\"Use Scale Array\"\n"
19085 " panel_visibility=\"advanced\">\n"
19086 " <BooleanDomain name=\"bool\"/>\n"
19087 " <Documentation>\n"
19088 " If this property is on, the Scale Array will be used to determine that radii\n"
19089 " of the gaussians. Otherwise the Default Radius will be used.\n"
19090 " </Documentation>\n"
19091 " </IntVectorProperty>\n"
19092 " <StringVectorProperty name=\"SetScaleArray\"\n"
19093 " command=\"SelectScaleArray\"\n"
19094 " number_of_elements=\"5\"\n"
19095 " element_types=\"0 0 0 0 2\"\n"
19096 " label=\"Gaussian Scale Array\"\n"
19097 " panel_visibility=\"advanced\">\n"
19098 " <ArrayListDomain name=\"array_list\"\n"
19099 " input_domain_name=\"input_point_array\">\n"
19100 " <RequiredProperties>\n"
19101 " <Property name=\"Input\" function=\"Input\"/>\n"
19102 " </RequiredProperties>\n"
19103 " </ArrayListDomain>\n"
19104 " <Documentation>\n"
19105 " This property specifies the name of the input array to scale the splats by.\n"
19106 " </Documentation>\n"
19107 " <Hints>\n"
19108 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19109 " <Property name=\"ScaleByArray\" function=\"boolean\" />\n"
19110 " </PropertyWidgetDecorator>\n"
19111 " </Hints>\n"
19112 " </StringVectorProperty>\n"
19113 " <IntVectorProperty animateable=\"0\"\n"
19114 " command=\"SelectScaleArrayComponent\"\n"
19115 " default_values=\"0\"\n"
19116 " name=\"ScaleArrayComponent\"\n"
19117 " number_of_elements=\"1\">\n"
19118 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
19119 " <RequiredProperties>\n"
19120 " <Property function=\"Input\"\n"
19121 " name=\"Input\" />\n"
19122 " <Property function=\"ArraySelection\"\n"
19123 " name=\"SetScaleArray\" />\n"
19124 " </RequiredProperties>\n"
19125 " </NumberOfComponentsDomain>\n"
19126 " <Documentation>\n"
19127 " This property indicates the component of the array to be used for scaling.\n"
19128 ;
19129
19130 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
19132 " </Documentation>\n"
19133 " <Hints>\n"
19134 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19135 " <Property name=\"ScaleByArray\" function=\"boolean\" />\n"
19136 " </PropertyWidgetDecorator>\n"
19137 " </Hints>\n"
19138 " </IntVectorProperty>\n"
19139 " <IntVectorProperty command=\"SetUseScaleFunction\"\n"
19140 " default_values=\"1\"\n"
19141 " name=\"UseScaleFunction\"\n"
19142 " number_of_elements=\"1\"\n"
19143 " label=\"Use Scale Transfer Function\"\n"
19144 " panel_visibility=\"advanced\">\n"
19145 " <BooleanDomain name=\"bool\"/>\n"
19146 " <Documentation>\n"
19147 " If this property is enabled, the Scale Transfer Function is used to map\n"
19148 " the scale values of the Scale Array. Otherwise, the scale values are used as-is.\n"
19149 " </Documentation>\n"
19150 " <Hints>\n"
19151 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19152 " <Property name=\"ScaleByArray\" function=\"boolean\" />\n"
19153 " </PropertyWidgetDecorator>\n"
19154 " </Hints>\n"
19155 " </IntVectorProperty>\n"
19156 " <ProxyProperty command=\"SetScaleTransferFunction\"\n"
19157 " name=\"ScaleTransferFunction\"\n"
19158 " panel_visibility=\"advanced\"\n"
19159 " panel_widget=\"transfer_function_editor\" >\n"
19160 " <Documentation>Set the piecewise function used to map data array to sprite size.\n"
19161 " ScaleTransferFunction is only used if ScaleByArray is set.</Documentation>\n"
19162 " <RangedTransferFunctionDomain name=\"proxy_list\">\n"
19163 " <RequiredProperties>\n"
19164 " <Property function=\"Input\" name=\"Input\" />\n"
19165 " <Property function=\"ArraySelection\" name=\"SetScaleArray\" />\n"
19166 " <Property function=\"ComponentSelection\" name=\"ScaleArrayComponent\" />\n"
19167 " </RequiredProperties>\n"
19168 " </RangedTransferFunctionDomain>\n"
19169 " <Hints>\n"
19170 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
19171 " <Expression type=\"and\">\n"
19172 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19173 " <Property name=\"ScaleByArray\" function=\"boolean\" />\n"
19174 " </PropertyWidgetDecorator>\n"
19175 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19176 " <Property name=\"UseScaleFunction\" function=\"boolean\" />\n"
19177 " </PropertyWidgetDecorator>\n"
19178 " </Expression>\n"
19179 " </PropertyWidgetDecorator>\n"
19180 " </Hints>\n"
19181 " </ProxyProperty>\n"
19182 " <IntVectorProperty command=\"SetOpacityByArray\"\n"
19183 " default_values=\"0\"\n"
19184 " name=\"OpacityByArray\"\n"
19185 " number_of_elements=\"1\"\n"
19186 " label=\"Use Opacity Array\"\n"
19187 " panel_visibility=\"advanced\">\n"
19188 " <BooleanDomain name=\"bool\"/>\n"
19189 " <Documentation>\n"
19190 " If this property is on, the Opacity Array will be used to determine the\n"
19191 " point gaussian sprites.\n"
19192 " </Documentation>\n"
19193 " </IntVectorProperty>\n"
19194 " <StringVectorProperty name=\"OpacityArray\"\n"
19195 " command=\"SelectOpacityArray\"\n"
19196 " number_of_elements=\"5\"\n"
19197 " element_types=\"0 0 0 0 2\"\n"
19198 " label=\"Gaussian Opacity Array\"\n"
19199 " panel_visibility=\"advanced\">\n"
19200 " <ArrayListDomain name=\"array_list\"\n"
19201 " input_domain_name=\"input_point_array\">\n"
19202 " <RequiredProperties>\n"
19203 " <Property name=\"Input\" function=\"Input\"/>\n"
19204 " </RequiredProperties>\n"
19205 " </ArrayListDomain>\n"
19206 " <Documentation>\n"
19207 " This property specifies the name of the input array to map to point opacity.\n"
19208 " </Documentation>\n"
19209 " <Hints>\n"
19210 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19211 " <Property name=\"OpacityByArray\" function=\"boolean\" />\n"
19212 " </PropertyWidgetDecorator>\n"
19213 " </Hints>\n"
19214 " </StringVectorProperty>\n"
19215 " <IntVectorProperty animateable=\"0\"\n"
19216 " command=\"SelectOpacityArrayComponent\"\n"
19217 " default_values=\"0\"\n"
19218 " name=\"OpacityArrayComponent\"\n"
19219 " number_of_elements=\"1\">\n"
19220 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
19221 " <RequiredProperties>\n"
19222 " <Property function=\"Input\"\n"
19223 " name=\"Input\" />\n"
19224 " <Property function=\"ArraySelection\"\n"
19225 " name=\"OpacityArray\" />\n"
19226 " </RequiredProperties>\n"
19227 " </NumberOfComponentsDomain>\n"
19228 " <Documentation>\n"
19229 " This property indicates the component of the array to be used for opacity.\n"
19230 " </Documentation>\n"
19231 " <Hints>\n"
19232 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19233 " <Property name=\"OpacityByArray\" function=\"boolean\" />\n"
19234 " </PropertyWidgetDecorator>\n"
19235 " </Hints>\n"
19236 " </IntVectorProperty>\n"
19237 " <ProxyProperty command=\"SetOpacityTransferFunction\"\n"
19238 " name=\"OpacityTransferFunction\"\n"
19239 " panel_visibility=\"advanced\"\n"
19240 " panel_widget=\"transfer_function_editor\">\n"
19241 " <Documentation>Set the piecewise function used to map data array to sprite opacity.\n"
19242 " OpacityTransferFunction is only used if ScaleByArray is set and OpacityArray is\n"
19243 " also given.</Documentation>\n"
19244 " <RangedTransferFunctionDomain name=\"proxy_list\">\n"
19245 " <RequiredProperties>\n"
19246 " <Property function=\"Input\" name=\"Input\" />\n"
19247 " <Property function=\"ArraySelection\" name=\"OpacityArray\" />\n"
19248 " <Property function=\"ComponentSelection\" name=\"OpacityArrayComponent\" />\n"
19249 " </RequiredProperties>\n"
19250 " </RangedTransferFunctionDomain>\n"
19251 " <Hints>\n"
19252 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19253 " <Property name=\"OpacityByArray\" function=\"boolean\" />\n"
19254 " </PropertyWidgetDecorator>\n"
19255 " </Hints>\n"
19256 " </ProxyProperty>\n"
19257 " <DoubleVectorProperty command=\"SetOpacity\"\n"
19258 " default_values=\"1.0\"\n"
19259 " name=\"Opacity\"\n"
19260 " number_of_elements=\"1\">\n"
19261 " <DoubleRangeDomain max=\"1\" min=\"0\" name=\"range\" />\n"
19262 " <Documentation>\n"
19263 " The opacity to use when rendering the model.\n"
19264 " </Documentation>\n"
19265 " </DoubleVectorProperty>\n"
19266 " <DoubleVectorProperty command=\"SetEdgeColor\"\n"
19267 " default_values=\"0 0 0.5\"\n"
19268 " name=\"EdgeColor\"\n"
19269 " number_of_elements=\"3\">\n"
19270 " <Documentation>Set the edge color. This color is used to draw the edge\n"
19271 " for the polygonal data when EdgeVisibility is on.</Documentation>\n"
19272 " <DoubleRangeDomain max=\"1 1 1\"\n"
19273 " min=\"0 0 0\"\n"
19274 " name=\"range\" />\n"
19275 " <Hints>\n"
19276 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"EdgeColor\" unlink_if_modified=\"1\" />\n"
19277 " </Hints>\n"
19278 " </DoubleVectorProperty>\n"
19279 " <DoubleVectorProperty command=\"SetAmbientColor\"\n"
19280 " default_values=\"1.0 1.0 1.0\"\n"
19281 " name=\"AmbientColor\"\n"
19282 " number_of_elements=\"3\">\n"
19283 " <DoubleRangeDomain max=\"1 1 1\"\n"
19284 " min=\"0 0 0\"\n"
19285 " name=\"range\" />\n"
19286 " <Hints>\n"
19287 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\" unlink_if_modified=\"1\" />\n"
19288 " </Hints>\n"
19289 " </DoubleVectorProperty>\n"
19290 " <DoubleVectorProperty command=\"SetDiffuseColor\"\n"
19291 " default_values=\"1.0 1.0 1.0\"\n"
19292 " name=\"DiffuseColor\"\n"
19293 " number_of_elements=\"3\">\n"
19294 " <DoubleRangeDomain max=\"1 1 1\"\n"
19295 " min=\"0 0 0\"\n"
19296 " name=\"range\" />\n"
19297 " <Hints>\n"
19298 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SurfaceColor\" unlink_if_modified=\"1\" />\n"
19299 " </Hints>\n"
19300 " <Documentation>\n"
19301 " The diffuse color of the model\n"
19302 " </Documentation>\n"
19303 " </DoubleVectorProperty>\n"
19304 " <DoubleVectorProperty command=\"SetSpecularColor\"\n"
19305 " default_values=\"1.0 1.0 1.0\"\n"
19306 " name=\"SpecularColor\"\n"
19307 " number_of_elements=\"3\">\n"
19308 " <DoubleRangeDomain max=\"1 1 1\"\n"
19309 " min=\"0 0 0\"\n"
19310 " name=\"range\" />\n"
19311 " <Documentation>\n"
19312 " The specular color of the model\n"
19313 " </Documentation>\n"
19314 " </DoubleVectorProperty>\n"
19315 " <DoubleVectorProperty command=\"SetPointSize\"\n"
19316 " default_values=\"2.0\"\n"
19317 " name=\"PointSize\"\n"
19318 " number_of_elements=\"1\">\n"
19319 " <DoubleRangeDomain min=\"0\"\n"
19320 " name=\"range\" />\n"
19321 " </DoubleVectorProperty>\n"
19322 " <DoubleVectorProperty command=\"SetPosition\"\n"
19323 " default_values=\"0 0 0\"\n"
19324 " label=\"Translation\"\n"
19325 " name=\"Position\"\n"
19326 " number_of_elements=\"3\">\n"
19327 " <DoubleRangeDomain name=\"range\" />\n"
19328 " </DoubleVectorProperty>\n"
19329 " <DoubleVectorProperty command=\"SetScale\"\n"
19330 " default_values=\"1 1 1\"\n"
19331 " name=\"Scale\"\n"
19332 " number_of_elements=\"3\">\n"
19333 " <DoubleRangeDomain name=\"range\" />\n"
19334 " </DoubleVectorProperty>\n"
19335 " <DoubleVectorProperty command=\"SetOrientation\"\n"
19336 " default_values=\"0 0 0\"\n"
19337 " name=\"Orientation\"\n"
19338 " number_of_elements=\"3\">\n"
19339 " <DoubleRangeDomain name=\"range\" />\n"
19340 " </DoubleVectorProperty>\n"
19341 " <DoubleVectorProperty command=\"SetOrigin\"\n"
19342 " default_values=\"0 0 0\"\n"
19343 " name=\"Origin\"\n"
19344 " number_of_elements=\"3\">\n"
19345 " <DoubleRangeDomain name=\"range\" />\n"
19346 " </DoubleVectorProperty>\n"
19347 " <IntVectorProperty command=\"SetPickable\"\n"
19348 " default_values=\"1\"\n"
19349 " name=\"Pickable\"\n"
19350 " number_of_elements=\"1\">\n"
19351 " <Hints>\n"
19352 " <NoDefault />\n"
19353 " </Hints>\n"
19354 " <BooleanDomain name=\"bool\" />\n"
19355 " </IntVectorProperty>\n"
19356 " <!-- End of PointGaussianRepresentation -->\n"
19357 " </RepresentationProxy>\n"
19358 "\n"
19359 " <!-- ================================================================== -->\n"
19360 " <RepresentationProxy class=\"vtkUnstructuredGridVolumeRepresentation\"\n"
19361 " name=\"UnstructuredGridVolumeRepresentation\"\n"
19362 " processes=\"client|renderserver|dataserver\"\n"
19363 " si_class=\"vtkSIUnstructuredGridVolumeRepresentationProxy\">\n"
19364 " <Documentation>Representation for rendering a vtkImageData as\n"
19365 " volume.</Documentation>\n"
19366 " <InputProperty command=\"SetInputConnection\"\n"
19367 " name=\"Input\">\n"
19368 " <DataTypeDomain composite_data_supported=\"1\"\n"
19369 " name=\"input_type\">\n"
19370 " <DataType value=\"vtkUnstructuredGridBase\" />\n"
19371 " </DataTypeDomain>\n"
19372 " <InputArrayDomain name=\"input_array_any\">\n"
19373 " </InputArrayDomain>\n"
19374 " <Documentation>Set the input to the representation.</Documentation>\n"
19375 " </InputProperty>\n"
19376 " <IntVectorProperty command=\"SetVisibility\"\n"
19377 " default_values=\"1\"\n"
19378 " name=\"Visibility\"\n"
19379 " number_of_elements=\"1\">\n"
19380 " <BooleanDomain name=\"bool\" />\n"
19381 " <Documentation>Set the visibility for this\n"
19382 " representation.</Documentation>\n"
19383 " </IntVectorProperty>\n"
19384 " <IntVectorProperty command=\"SetForceUseCache\"\n"
19385 " default_values=\"0\"\n"
19386 " is_internal=\"1\"\n"
19387 " name=\"ForceUseCache\"\n"
19388 " number_of_elements=\"1\">\n"
19389 " <BooleanDomain name=\"bool\" />\n"
19390 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
19391 " and representations cache based on what the view tells it. However in\n"
19392 " some cases we may want to force a representation to cache irrespective\n"
19393 " of the view (e.g. comparative views). In which case these ivars can up\n"
19394 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
19395 " Instead, ForcedCacheKey is used.</Documentation>\n"
19396 " </IntVectorProperty>\n"
19397 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
19398 " default_values=\"none\"\n"
19399 " is_internal=\"1\"\n"
19400 " name=\"ForcedCacheKey\"\n"
19401 " number_of_elements=\"1\">\n"
19402 " <DoubleRangeDomain name=\"range\" />\n"
19403 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
19404 " and representations cache based on what the view tells it. However in\n"
19405 " some cases we may want to force a representation to cache irrespective\n"
19406 " of the view (e.g. comparative views). In which case these ivars can up\n"
19407 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
19408 " Instead, ForcedCacheKey is used.</Documentation>\n"
19409 " </DoubleVectorProperty>\n"
19410 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
19411 " element_types=\"0 0 0 0 2\"\n"
19412 " name=\"ColorArrayName\"\n"
19413 " no_custom_default=\"1\"\n"
19414 " number_of_elements=\"5\" >\n"
19415 " <Documentation>\n"
19416 " Set the array to color with. One must specify the field association and\n"
19417 " the array name of the array. If the array is missing, scalar coloring will\n"
19418 " automatically be disabled.\n"
19419 " </Documentation>\n"
19420 " <RepresentedArrayListDomain name=\"array_list\"\n"
19421 " input_domain_name=\"input_array_any\">\n"
19422 " <RequiredProperties>\n"
19423 " <Property function=\"Input\" name=\"Input\" />\n"
19424 " </RequiredProperties>\n"
19425 " </RepresentedArrayListDomain>\n"
19426 " </StringVectorProperty>\n"
19427 " <IntVectorProperty command=\"SetUseSeparateOpacityArray\"\n"
19428 " default_values=\"0\"\n"
19429 " name=\"UseSeparateOpacityArray\"\n"
19430 " number_of_elements=\"1\"\n"
19431 " panel_visibility=\"advanced\">\n"
19432 " <BooleanDomain name=\"bool\"/>\n"
19433 " <Documentation>\n"
19434 " If this property is on, the Opacity Array will be used to determine the\n"
19435 " point gaussian sprites.\n"
19436 " </Documentation>\n"
19437 " </IntVectorProperty>\n"
19438 " <StringVectorProperty name=\"OpacityArrayName\"\n"
19439 " command=\"SelectOpacityArray\"\n"
19440 ;
19441
19442 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
19444 " number_of_elements=\"5\"\n"
19445 " element_types=\"0 0 0 0 2\"\n"
19446 " label=\"Volume Opacity Array\"\n"
19447 " panel_visibility=\"advanced\">\n"
19448 " <ArrayListDomain name=\"array_list\"\n"
19449 " input_domain_name=\"input_point_array\">\n"
19450 " <RequiredProperties>\n"
19451 " <Property name=\"Input\" function=\"Input\"/>\n"
19452 " </RequiredProperties>\n"
19453 " </ArrayListDomain>\n"
19454 " <Documentation>\n"
19455 " This property specifies the name of the input array to map to opacity.\n"
19456 " </Documentation>\n"
19457 " <Hints>\n"
19458 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19459 " <Property name=\"UseSeparateOpacityArray\" function=\"boolean\" />\n"
19460 " </PropertyWidgetDecorator>\n"
19461 " </Hints>\n"
19462 " </StringVectorProperty>\n"
19463 " <IntVectorProperty animateable=\"0\"\n"
19464 " command=\"SelectOpacityArrayComponent\"\n"
19465 " default_values=\"0\"\n"
19466 " name=\"OpacityComponent\"\n"
19467 " number_of_elements=\"1\">\n"
19468 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
19469 " <RequiredProperties>\n"
19470 " <Property function=\"Input\"\n"
19471 " name=\"Input\" />\n"
19472 " <Property function=\"ArraySelection\"\n"
19473 " name=\"OpacityArrayName\" />\n"
19474 " </RequiredProperties>\n"
19475 " </NumberOfComponentsDomain>\n"
19476 " <Documentation>\n"
19477 " This property indicates the component of the array to be used for opacity.\n"
19478 " </Documentation>\n"
19479 " <Hints>\n"
19480 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
19481 " <Property name=\"UseSeparateOpacityArray\" function=\"boolean\" />\n"
19482 " </PropertyWidgetDecorator>\n"
19483 " </Hints>\n"
19484 " </IntVectorProperty>\n"
19485 "\n"
19486 " <StringVectorProperty name=\"Assembly\"\n"
19487 " command=\"SetActiveAssembly\"\n"
19488 " number_of_elements=\"1\"\n"
19489 " panel_visibility=\"multiblock_inspector\">\n"
19490 " <DataAssemblyListDomain name=\"data_assembly\">\n"
19491 " <RequiredProperties>\n"
19492 " <Property function=\"Input\" name=\"Input\" />\n"
19493 " </RequiredProperties>\n"
19494 " </DataAssemblyListDomain>\n"
19495 " <Documentation>\n"
19496 " Select which assembly is used when specify selectors\n"
19497 " to choose block visibilities, block colors, etc. for composite datasets.\n"
19498 " </Documentation>\n"
19499 " </StringVectorProperty>\n"
19500 "\n"
19501 " <StringVectorProperty name=\"BlockSelectors\"\n"
19502 " command=\"AddBlockSelector\"\n"
19503 " clean_command=\"RemoveAllBlockSelectors\"\n"
19504 " repeat_command=\"1\"\n"
19505 " number_of_elements_per_command=\"1\"\n"
19506 " panel_visibility=\"multiblock_inspector\"\n"
19507 " number_of_elements=\"1\"\n"
19508 " default_values=\"/\">\n"
19509 " <DataAssemblyDomain name=\"data_assembly\">\n"
19510 " <RequiredProperties>\n"
19511 " <Property function=\"Input\" name=\"Input\" />\n"
19512 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
19513 " </RequiredProperties>\n"
19514 " </DataAssemblyDomain>\n"
19515 " <Documentation>\n"
19516 " For composite datasets, specify selectors to limit the view\n"
19517 " to a chosen subset of blocks.\n"
19518 " </Documentation>\n"
19519 " </StringVectorProperty>\n"
19520 "\n"
19521 " <DoubleVectorProperty command=\"SetPosition\"\n"
19522 " default_values=\"0 0 0\"\n"
19523 " name=\"Position\"\n"
19524 " number_of_elements=\"3\">\n"
19525 " <DoubleRangeDomain name=\"range\" />\n"
19526 " </DoubleVectorProperty>\n"
19527 " <DoubleVectorProperty command=\"SetScale\"\n"
19528 " default_values=\"1 1 1\"\n"
19529 " name=\"Scale\"\n"
19530 " number_of_elements=\"3\">\n"
19531 " <DoubleRangeDomain name=\"range\" />\n"
19532 " </DoubleVectorProperty>\n"
19533 " <DoubleVectorProperty command=\"SetOrientation\"\n"
19534 " default_values=\"0 0 0\"\n"
19535 " name=\"Orientation\"\n"
19536 " number_of_elements=\"3\">\n"
19537 " <DoubleRangeDomain name=\"range\" />\n"
19538 " </DoubleVectorProperty>\n"
19539 " <DoubleVectorProperty command=\"SetOrigin\"\n"
19540 " default_values=\"0 0 0\"\n"
19541 " name=\"Origin\"\n"
19542 " number_of_elements=\"3\">\n"
19543 " <DoubleRangeDomain name=\"range\" />\n"
19544 " </DoubleVectorProperty>\n"
19545 " <IntVectorProperty command=\"SetPickable\"\n"
19546 " default_values=\"1\"\n"
19547 " name=\"Pickable\"\n"
19548 " number_of_elements=\"1\">\n"
19549 " <Hints>\n"
19550 " <NoDefault />\n"
19551 " </Hints>\n"
19552 " <BooleanDomain name=\"bool\" />\n"
19553 " </IntVectorProperty>\n"
19554 " <IntVectorProperty command=\"SetInterpolationType\"\n"
19555 " default_values=\"1\"\n"
19556 " name=\"InterpolationType\"\n"
19557 " number_of_elements=\"1\">\n"
19558 " <EnumerationDomain name=\"enum\">\n"
19559 " <Entry text=\"Nearest\"\n"
19560 " value=\"0\" />\n"
19561 " <Entry text=\"Linear\"\n"
19562 " value=\"1\" />\n"
19563 " </EnumerationDomain>\n"
19564 " </IntVectorProperty>\n"
19565 " <ProxyProperty command=\"SetColor\"\n"
19566 " name=\"LookupTable\" >\n"
19567 " <ProxyGroupDomain name=\"groups\">\n"
19568 " <Group name=\"transfer_functions\" />\n"
19569 " </ProxyGroupDomain>\n"
19570 " </ProxyProperty>\n"
19571 " <IntVectorProperty command=\"SetMapScalars\"\n"
19572 " default_values=\"1\"\n"
19573 " name=\"MapScalars\"\n"
19574 " number_of_elements=\"1\">\n"
19575 " <BooleanDomain name=\"bool\" />\n"
19576 " <Documentation>When enabled, LookupTable will always be\n"
19577 " used for scalar mapping. Otherwise, when up to 4 component\n"
19578 " scalars are present, the components are clamped to a valid\n"
19579 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
19580 " floating point type) and then directly used as\n"
19581 " color.</Documentation>\n"
19582 " </IntVectorProperty>\n"
19583 " <IntVectorProperty command=\"SetMultiComponentsMapping\"\n"
19584 " default_values=\"0\"\n"
19585 " name=\"MultiComponentsMapping\"\n"
19586 " number_of_elements=\"1\">\n"
19587 " <BooleanDomain name=\"bool\" />\n"
19588 " <Hints>\n"
19589 " <PropertyWidgetDecorator type=\"MultiComponentsDecorator\"\n"
19590 " components=\"2 4\" />\n"
19591 " </Hints>\n"
19592 " </IntVectorProperty>\n"
19593 " <ProxyProperty command=\"SetScalarOpacity\"\n"
19594 " name=\"ScalarOpacityFunction\" >\n"
19595 " <ProxyGroupDomain name=\"groups\">\n"
19596 " <Group name=\"piecewise_functions\" />\n"
19597 " </ProxyGroupDomain>\n"
19598 " </ProxyProperty>\n"
19599 " <StringVectorProperty command=\"SetActiveVolumeMapper\"\n"
19600 " default_values=\"Projected tetra\"\n"
19601 " name=\"SelectMapper\"\n"
19602 " number_of_elements=\"1\">\n"
19603 " <Documentation>Select the volume mapper to use for Volume\n"
19604 " rendering.</Documentation>\n"
19605 " <StringListDomain name=\"list\">\n"
19606 " <String value=\"Projected tetra\" />\n"
19607 " <String value=\"Z sweep\" />\n"
19608 " <String value=\"Bunyk ray cast\" />\n"
19609 " <String value=\"Resample To Image\" />\n"
19610 " </StringListDomain>\n"
19611 " </StringVectorProperty>\n"
19612 " <IntVectorProperty command=\"SetSamplingDimensions\"\n"
19613 " default_values=\"128 128 128\"\n"
19614 " name=\"SamplingDimensions\"\n"
19615 " number_of_elements=\"3\">\n"
19616 " <IntRangeDomain name=\"range\" min=\"1 1 1\"/>\n"
19617 " <Documentation>\n"
19618 " How many linear samples we want along each axis\n"
19619 " </Documentation>\n"
19620 " <Hints>\n"
19621 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
19622 " mode=\"visibility\"\n"
19623 " property=\"SelectMapper\"\n"
19624 " value=\"Resample To Image\" />\n"
19625 " </Hints>\n"
19626 " </IntVectorProperty>\n"
19627 " <DoubleVectorProperty command=\"SetScalarOpacityUnitDistance\"\n"
19628 " default_values=\"1\"\n"
19629 " name=\"ScalarOpacityUnitDistance\"\n"
19630 " number_of_elements=\"1\">\n"
19631 " <BoundsDomain mode=\"approximate_cell_length\"\n"
19632 " name=\"bounds\" >\n"
19633 " <RequiredProperties>\n"
19634 " <Property function=\"Input\"\n"
19635 " name=\"Input\" />\n"
19636 " </RequiredProperties>\n"
19637 " </BoundsDomain>\n"
19638 " </DoubleVectorProperty>\n"
19639 " <IntVectorProperty command=\"SetUseDataPartitions\"\n"
19640 " default_values=\"0\"\n"
19641 " name=\"UseDataPartitions\"\n"
19642 " number_of_elements=\"1\">\n"
19643 " <BooleanDomain name=\"bool\" />\n"
19644 " <Documentation>Specify whether or not to redistribute the data when actor is translucent.\n"
19645 " Default is false.</Documentation>\n"
19646 " </IntVectorProperty>\n"
19647 " <SubProxy>\n"
19648 " <Proxy name=\"VolumeDummyMapper\"\n"
19649 " proxygroup=\"mappers\"\n"
19650 " proxyname=\"DummyVolumeMapper\"></Proxy>\n"
19651 " <ExposedProperties>\n"
19652 " <Property name=\"RayCastFunction\" />\n"
19653 " </ExposedProperties>\n"
19654 " </SubProxy>\n"
19655 " <SubProxy>\n"
19656 " <Proxy name=\"VolumeBunykMapper\"\n"
19657 " proxygroup=\"mappers\"\n"
19658 " proxyname=\"UnstructuredGridVolumeRayCastMapper\"></Proxy>\n"
19659 " <ShareProperties subproxy=\"VolumeDummyMapper\"></ShareProperties>\n"
19660 " </SubProxy>\n"
19661 " <SubProxy>\n"
19662 " <Proxy name=\"VolumeZSweepMapper\"\n"
19663 " proxygroup=\"mappers\"\n"
19664 " proxyname=\"UnstructuredGridVolumeZSweepMapper\"></Proxy>\n"
19665 " <ShareProperties subproxy=\"VolumeDummyMapper\"></ShareProperties>\n"
19666 " </SubProxy>\n"
19667 " <SubProxy>\n"
19668 " <Proxy name=\"VolumePTMapper\"\n"
19669 " proxygroup=\"mappers\"\n"
19670 " proxyname=\"ProjectedTetrahedraMapper\"></Proxy>\n"
19671 " <ShareProperties subproxy=\"VolumeDummyMapper\"></ShareProperties>\n"
19672 " <ExposedProperties>\n"
19673 " <Property name=\"UseFloatingPointFrameBuffer\" />\n"
19674 " </ExposedProperties>\n"
19675 " </SubProxy>\n"
19676 " <SubProxy>\n"
19677 " <Proxy name=\"VolumeResampleToImageMapper\"\n"
19678 " proxygroup=\"mappers\"\n"
19679 " proxyname=\"UnstructuredGridResampleToImageMapper\"></Proxy>\n"
19680 " </SubProxy>\n"
19681 " <!-- end of UnstructuredGridVolumeRepresentation -->\n"
19682 " </RepresentationProxy>\n"
19683 "\n"
19684 " <!-- ================================================================== -->\n"
19685 " <RepresentationProxy class=\"vtkImageSliceRepresentation\"\n"
19686 " name=\"ImageSliceRepresentation\"\n"
19687 " processes=\"client|renderserver|dataserver\">\n"
19688 " <Documentation>Representation to show 2D images. If the input image has\n"
19689 " 3D extents, then this representation shows a single Z\n"
19690 " slice.</Documentation>\n"
19691 " <InputProperty command=\"SetInputConnection\"\n"
19692 " name=\"Input\">\n"
19693 " <Documentation>Set the input to the representation. Must be a\n"
19694 " vtkImageData producer.</Documentation>\n"
19695 " <DataTypeDomain composite_data_supported=\"0\"\n"
19696 " name=\"input_type\">\n"
19697 " <DataType value=\"vtkImageData\" />\n"
19698 " </DataTypeDomain>\n"
19699 " <InputArrayDomain attribute_type=\"any\"\n"
19700 " name=\"input_array_any\"></InputArrayDomain>\n"
19701 " </InputProperty>\n"
19702 " <IntVectorProperty command=\"SetVisibility\"\n"
19703 " default_values=\"1\"\n"
19704 " name=\"Visibility\"\n"
19705 " number_of_elements=\"1\">\n"
19706 " <BooleanDomain name=\"bool\" />\n"
19707 " <Documentation>Set the visibility for this\n"
19708 " representation.</Documentation>\n"
19709 " </IntVectorProperty>\n"
19710 " <IntVectorProperty command=\"SetForceUseCache\"\n"
19711 " default_values=\"0\"\n"
19712 " is_internal=\"1\"\n"
19713 " name=\"ForceUseCache\"\n"
19714 " number_of_elements=\"1\">\n"
19715 " <BooleanDomain name=\"bool\" />\n"
19716 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
19717 " and representations cache based on what the view tells it. However in\n"
19718 " some cases we may want to force a representation to cache irrespective\n"
19719 " of the view (e.g. comparative views). In which case these ivars can up\n"
19720 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
19721 " Instead, ForcedCacheKey is used.</Documentation>\n"
19722 " </IntVectorProperty>\n"
19723 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
19724 " default_values=\"none\"\n"
19725 " is_internal=\"1\"\n"
19726 " name=\"ForcedCacheKey\"\n"
19727 " number_of_elements=\"1\">\n"
19728 " <DoubleRangeDomain name=\"range\" />\n"
19729 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
19730 " and representations cache based on what the view tells it. However in\n"
19731 " some cases we may want to force a representation to cache irrespective\n"
19732 " of the view (e.g. comparative views). In which case these ivars can up\n"
19733 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
19734 " Instead, ForcedCacheKey is used.</Documentation>\n"
19735 " </DoubleVectorProperty>\n"
19736 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
19737 " element_types=\"0 0 0 0 2\"\n"
19738 " name=\"ColorArrayName\"\n"
19739 " no_custom_default=\"1\"\n"
19740 " number_of_elements=\"5\">\n"
19741 " <Documentation>\n"
19742 " Set the array to color with. One must specify the field association and\n"
19743 " the array name of the array. If the array is missing, scalar coloring will\n"
19744 " automatically be disabled.\n"
19745 " </Documentation>\n"
19746 " <RepresentedArrayListDomain name=\"array_list\"\n"
19747 " input_domain_name=\"input_array_any\">\n"
19748 " <RequiredProperties>\n"
19749 " <Property function=\"Input\" name=\"Input\" />\n"
19750 " </RequiredProperties>\n"
19751 " </RepresentedArrayListDomain>\n"
19752 " </StringVectorProperty>\n"
19753 " <IntVectorProperty command=\"SetSlice\"\n"
19754 " default_values=\"0\"\n"
19755 " name=\"Slice\"\n"
19756 " number_of_elements=\"1\">\n"
19757 " <Documentation>Set the current slice number. Slice number is used to\n"
19758 " load a 2D slice from a 3D input image. If the input image is 2D, then\n"
19759 " the slice number if ignored. The direction of the slice is determined\n"
19760 " by SliceMode.</Documentation>\n"
19761 " <DimensionsDomain name=\"dims\">\n"
19762 " <RequiredProperties>\n"
19763 " <Property function=\"Input\"\n"
19764 " name=\"Input\" />\n"
19765 ;
19766
19767 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
19769 " <Property function=\"Direction\"\n"
19770 " name=\"SliceMode\" />\n"
19771 " </RequiredProperties>\n"
19772 " </DimensionsDomain>\n"
19773 " </IntVectorProperty>\n"
19774 " <IntVectorProperty command=\"SetSliceMode\"\n"
19775 " default_values=\"5\"\n"
19776 " label=\"Slice Direction\"\n"
19777 " name=\"SliceMode\"\n"
19778 " number_of_elements=\"1\">\n"
19779 " <Documentation>Determines the direction of slicing to obtain a 2D slice\n"
19780 " from a 3D image.</Documentation>\n"
19781 " <EnumerationDomain name=\"enum\">\n"
19782 " <Entry text=\"XY Plane\"\n"
19783 " value=\"5\" />\n"
19784 " <Entry text=\"YZ Plane\"\n"
19785 " value=\"6\" />\n"
19786 " <Entry text=\"XZ Plane\"\n"
19787 " value=\"7\" />\n"
19788 " </EnumerationDomain>\n"
19789 " </IntVectorProperty>\n"
19790 " <IntVectorProperty command=\"SetMapScalars\"\n"
19791 " default_values=\"1\"\n"
19792 " name=\"MapScalars\"\n"
19793 " number_of_elements=\"1\">\n"
19794 " <BooleanDomain name=\"bool\" />\n"
19795 " <Documentation>When set to True, LookupTable will always be\n"
19796 " used for scalar mapping. Otherwise, when up to 4 component\n"
19797 " scalars are present, the components are clamped to a valid\n"
19798 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
19799 " floating point type) and then directly used as\n"
19800 " color.</Documentation>\n"
19801 " </IntVectorProperty>\n"
19802 "\n"
19803 " <ProxyProperty command=\"SetLookupTable\"\n"
19804 " name=\"LookupTable\" >\n"
19805 " <Documentation>Set the lookup table to use for scalar\n"
19806 " mapping.</Documentation>\n"
19807 " <ProxyGroupDomain name=\"groups\">\n"
19808 " <Group name=\"lookup_tables\" />\n"
19809 " </ProxyGroupDomain>\n"
19810 " </ProxyProperty>\n"
19811 " <IntVectorProperty command=\"SetUseXYPlane\"\n"
19812 " default_values=\"0\"\n"
19813 " name=\"UseXYPlane\"\n"
19814 " number_of_elements=\"1\">\n"
19815 " <BooleanDomain name=\"bool\" />\n"
19816 " <Documentation>When set, the image slice is always rendered in the XY\n"
19817 " plane (Z==0) irrespective of the image bounds. Default if\n"
19818 " Off.</Documentation>\n"
19819 " </IntVectorProperty>\n"
19820 " <DoubleVectorProperty command=\"SetPosition\"\n"
19821 " default_values=\"0 0 0\"\n"
19822 " name=\"Position\"\n"
19823 " number_of_elements=\"3\">\n"
19824 " <DoubleRangeDomain name=\"range\" />\n"
19825 " </DoubleVectorProperty>\n"
19826 " <DoubleVectorProperty command=\"SetScale\"\n"
19827 " default_values=\"1 1 1\"\n"
19828 " name=\"Scale\"\n"
19829 " number_of_elements=\"3\">\n"
19830 " <DoubleRangeDomain name=\"range\" />\n"
19831 " </DoubleVectorProperty>\n"
19832 " <DoubleVectorProperty command=\"SetOrientation\"\n"
19833 " default_values=\"0 0 0\"\n"
19834 " name=\"Orientation\"\n"
19835 " number_of_elements=\"3\">\n"
19836 " <DoubleRangeDomain name=\"range\" />\n"
19837 " </DoubleVectorProperty>\n"
19838 " <DoubleVectorProperty command=\"SetOrigin\"\n"
19839 " default_values=\"0 0 0\"\n"
19840 " name=\"Origin\"\n"
19841 " number_of_elements=\"3\">\n"
19842 " <DoubleRangeDomain name=\"range\" />\n"
19843 " </DoubleVectorProperty>\n"
19844 " <IntVectorProperty command=\"SetPickable\"\n"
19845 " default_values=\"1\"\n"
19846 " name=\"Pickable\"\n"
19847 " number_of_elements=\"1\">\n"
19848 " <Hints>\n"
19849 " <NoDefault />\n"
19850 " </Hints>\n"
19851 " <BooleanDomain name=\"bool\" />\n"
19852 " </IntVectorProperty>\n"
19853 " <DoubleVectorProperty command=\"SetOpacity\"\n"
19854 " default_values=\"1.0\"\n"
19855 " name=\"Opacity\"\n"
19856 " number_of_elements=\"1\">\n"
19857 " <DoubleRangeDomain max=\"1\"\n"
19858 " min=\"0\"\n"
19859 " name=\"range\" />\n"
19860 " </DoubleVectorProperty>\n"
19861 " <!-- End of ImageSliceRepresentation -->\n"
19862 " </RepresentationProxy>\n"
19863 "\n"
19864 " <!-- ================================================================== -->\n"
19865 " <RepresentationProxy class=\"vtkCellGridRepresentation\"\n"
19866 " name=\"CellGridSurfaceRepresentation\"\n"
19867 " processes=\"client|renderserver|dataserver\">\n"
19868 " <Documentation>Representation to show a cell-grid in a 3D render view.</Documentation>\n"
19869 " <InputProperty command=\"SetInputConnection\"\n"
19870 " name=\"Input\">\n"
19871 " <DataTypeDomain name=\"input_type\">\n"
19872 " <DataType value=\"vtkCellGrid\" />\n"
19873 " </DataTypeDomain>\n"
19874 " <InputArrayDomain attribute_type=\"any\"\n"
19875 " name=\"input_array_any\" />\n"
19876 " <InputArrayDomain attribute_type=\"cell\"\n"
19877 " name=\"input_array_cell\"\n"
19878 " optional=\"1\" />\n"
19879 " <InputArrayDomain attribute_type=\"point\"\n"
19880 " name=\"input_array_point\"\n"
19881 " optional=\"1\" />\n"
19882 " <InputArrayDomain attribute_type=\"cell\"\n"
19883 " name=\"input_array_cell_1\"\n"
19884 " number_of_components=\"1\"\n"
19885 " optional=\"1\" />\n"
19886 " <InputArrayDomain attribute_type=\"point\"\n"
19887 " name=\"input_array_point_1\"\n"
19888 " number_of_components=\"1\"\n"
19889 " optional=\"1\" />\n"
19890 " <InputArrayDomain attribute_type=\"point\"\n"
19891 " name=\"input_array_point_2\"\n"
19892 " number_of_components=\"2\"\n"
19893 " optional=\"1\" />\n"
19894 " <InputArrayDomain attribute_type=\"cell\"\n"
19895 " name=\"input_array_cell_3\"\n"
19896 " number_of_components=\"3\"\n"
19897 " optional=\"1\" />\n"
19898 " <InputArrayDomain attribute_type=\"point\"\n"
19899 " name=\"input_array_point_3\"\n"
19900 " number_of_components=\"3\"\n"
19901 " optional=\"1\" />\n"
19902 " <Documentation>Set the input to the representation.</Documentation>\n"
19903 " </InputProperty>\n"
19904 " <IntVectorProperty command=\"SetVisibility\"\n"
19905 " default_values=\"1\"\n"
19906 " name=\"Visibility\"\n"
19907 " number_of_elements=\"1\">\n"
19908 " <BooleanDomain name=\"bool\" />\n"
19909 " <Documentation>Get/Set the visibility of the\n"
19910 " representation.</Documentation>\n"
19911 " </IntVectorProperty>\n"
19912 " <IntVectorProperty command=\"SetForceUseCache\"\n"
19913 " default_values=\"0\"\n"
19914 " is_internal=\"1\"\n"
19915 " name=\"ForceUseCache\"\n"
19916 " number_of_elements=\"1\">\n"
19917 " <BooleanDomain name=\"bool\" />\n"
19918 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
19919 " and representations cache based on what the view tells it. However in\n"
19920 " some cases we may want to force a representation to cache irrespective\n"
19921 " of the view (e.g. comparative views). In which case these ivars can up\n"
19922 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
19923 " Instead, ForcedCacheKey is used.</Documentation>\n"
19924 " </IntVectorProperty>\n"
19925 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
19926 " default_values=\"none\"\n"
19927 " is_internal=\"1\"\n"
19928 " name=\"ForcedCacheKey\"\n"
19929 " number_of_elements=\"1\">\n"
19930 " <DoubleRangeDomain name=\"range\" />\n"
19931 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
19932 " and representations cache based on what the view tells it. However in\n"
19933 " some cases we may want to force a representation to cache irrespective\n"
19934 " of the view (e.g. comparative views). In which case these ivars can up\n"
19935 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
19936 " Instead, ForcedCacheKey is used.</Documentation>\n"
19937 " </DoubleVectorProperty>\n"
19938 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
19939 " element_types=\"0 0 0 0 2\"\n"
19940 " name=\"ColorArrayName\"\n"
19941 " no_custom_default=\"1\"\n"
19942 " number_of_elements=\"5\">\n"
19943 " <Documentation>\n"
19944 " Set the array to color with. One must specify the field association and\n"
19945 " the array name of the array. If the array is missing, scalar coloring will\n"
19946 " automatically be disabled.\n"
19947 " </Documentation>\n"
19948 " <RepresentedArrayListDomain name=\"array_list\"\n"
19949 " input_domain_name=\"input_array_any\">\n"
19950 " <RequiredProperties>\n"
19951 " <Property function=\"Input\" name=\"Input\" />\n"
19952 " </RequiredProperties>\n"
19953 " </RepresentedArrayListDomain>\n"
19954 " </StringVectorProperty>\n"
19955 " <StringVectorProperty command=\"SetRepresentation\"\n"
19956 " default_values=\"Surface\"\n"
19957 " name=\"Representation\"\n"
19958 " panel_widget=\"display_representation_selector\"\n"
19959 " number_of_elements=\"1\">\n"
19960 " <StringListDomain name=\"string_list\">\n"
19961 " <String value=\"Points\" />\n"
19962 " <String value=\"Wireframe\" />\n"
19963 " <String value=\"Surface\" />\n"
19964 " <String value=\"Surface With Edges\" />\n"
19965 " <String value=\"Outline\" />\n"
19966 " </StringListDomain>\n"
19967 " </StringVectorProperty>\n"
19968 " <IntVectorProperty name=\"SidesToShow\"\n"
19969 " number_of_elements=\"1\"\n"
19970 " default_values=\"37\"\n"
19971 " command=\"SetSidesToShow\">\n"
19972 " <EnumerationDomain name=\"enum\">\n"
19973 " <!--\n"
19974 " <Entry text=\"Vertices of Edges\" value=\"1\"/>\n"
19975 " <Entry text=\"Vertices of Surfaces\" value=\"2\"/>\n"
19976 " <Entry text=\"Edges of Surfaces\" value=\"4\"/>\n"
19977 " <Entry text=\"Vertices of Volumes\" value=\"8\"/>\n"
19978 " <Entry text=\"Edges of Volumes\" value=\"16\"/>\n"
19979 " <Entry text=\"Surfaces of Volumes\" value=\"32\"/>\n"
19980 " -->\n"
19981 " <Entry text=\"Surfaces of Inputs\" value=\"32\"/>\n"
19982 " <Entry text=\"Edges of Inputs\" value=\"20\"/>\n"
19983 " <Entry text=\"Vertices of Inputs\" value=\"11\"/>\n"
19984 " <Entry text=\"All Sides\" value=\"63\"/>\n"
19985 " <Entry text=\"Next Lowest Dimension\" value=\"37\"/>\n"
19986 " </EnumerationDomain>\n"
19987 " <Documentation>Choose how to render the input.</Documentation>\n"
19988 " </IntVectorProperty>\n"
19989 " <IntVectorProperty name=\"PreserveRenderableInputs\"\n"
19990 " number_of_elements=\"1\"\n"
19991 " default_values=\"1\"\n"
19992 " command=\"SetPreserveRenderableInputs\">\n"
19993 " <BooleanDomain name=\"bool\" />\n"
19994 " <Documentation>Set whether to preserve renderable inputs or only show their boundaries.</Documentation>\n"
19995 " </IntVectorProperty>\n"
19996 " <IntVectorProperty name=\"OmitSidesForRenderableInputs\"\n"
19997 " number_of_elements=\"1\"\n"
19998 " default_values=\"1\"\n"
19999 " command=\"SetOmitSidesForRenderableInputs\">\n"
20000 " <BooleanDomain name=\"bool\" />\n"
20001 " <Documentation>Set whether to compute sides for renderable inputs or only for volumetric cells.</Documentation>\n"
20002 " </IntVectorProperty>\n"
20003 " <DoubleVectorProperty command=\"SetAmbient\"\n"
20004 " default_values=\"0.0\"\n"
20005 " name=\"Ambient\"\n"
20006 " number_of_elements=\"1\">\n"
20007 " <DoubleRangeDomain max=\"1\"\n"
20008 " min=\"0\"\n"
20009 " name=\"range\" />\n"
20010 " <Hints>\n"
20011 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20012 " mode=\"visibility\"\n"
20013 " property=\"Interpolation\"\n"
20014 " value=\"3\"\n"
20015 " inverse=\"1\" />\n"
20016 " </Hints>\n"
20017 " </DoubleVectorProperty>\n"
20018 " <DoubleVectorProperty command=\"SetDiffuse\"\n"
20019 " default_values=\"1.0\"\n"
20020 " name=\"Diffuse\"\n"
20021 " number_of_elements=\"1\">\n"
20022 " <DoubleRangeDomain max=\"1\"\n"
20023 " min=\"0\"\n"
20024 " name=\"range\" />\n"
20025 " </DoubleVectorProperty>\n"
20026 " <DoubleVectorProperty command=\"SetSpecular\"\n"
20027 " default_values=\"0.0\"\n"
20028 " name=\"Specular\"\n"
20029 " number_of_elements=\"1\">\n"
20030 " <DoubleRangeDomain max=\"1\"\n"
20031 " min=\"0\"\n"
20032 " name=\"range\" />\n"
20033 " <Hints>\n"
20034 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20035 " mode=\"visibility\"\n"
20036 " property=\"Interpolation\"\n"
20037 " value=\"3\"\n"
20038 " inverse=\"1\" />\n"
20039 " </Hints>\n"
20040 " </DoubleVectorProperty>\n"
20041 " <IntVectorProperty command=\"SetSuppressLOD\"\n"
20042 " default_values=\"0\"\n"
20043 " name=\"SuppressLOD\"\n"
20044 " number_of_elements=\"1\">\n"
20045 " <BooleanDomain name=\"bool\" />\n"
20046 " </IntVectorProperty>\n"
20047 " <DoubleVectorProperty command=\"SetAmbientColor\"\n"
20048 " default_values=\"1.0 1.0 1.0\"\n"
20049 " name=\"AmbientColor\"\n"
20050 " number_of_elements=\"3\">\n"
20051 " <DoubleRangeDomain max=\"1 1 1\"\n"
20052 " min=\"0 0 0\"\n"
20053 " name=\"range\" />\n"
20054 " <Hints>\n"
20055 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\" unlink_if_modified=\"1\" />\n"
20056 " </Hints>\n"
20057 " </DoubleVectorProperty>\n"
20058 " <DoubleVectorProperty command=\"SetDiffuseColor\"\n"
20059 " default_values=\"1.0 1.0 1.0\"\n"
20060 " name=\"DiffuseColor\"\n"
20061 " number_of_elements=\"3\"\n"
20062 " panel_widget=\"color_selector_with_palette\">\n"
20063 " <DoubleRangeDomain max=\"1 1 1\"\n"
20064 " min=\"0 0 0\"\n"
20065 " name=\"range\" />\n"
20066 " <Hints>\n"
20067 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SurfaceColor\" unlink_if_modified=\"1\" />\n"
20068 " </Hints>\n"
20069 " </DoubleVectorProperty>\n"
20070 " <DoubleVectorProperty command=\"SetSpecularColor\"\n"
20071 " default_values=\"1.0 1.0 1.0\"\n"
20072 " name=\"SpecularColor\"\n"
20073 " number_of_elements=\"3\">\n"
20074 " <DoubleRangeDomain max=\"1 1 1\"\n"
20075 " min=\"0 0 0\"\n"
20076 " name=\"range\" />\n"
20077 " <Hints>\n"
20078 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20079 " mode=\"visibility\"\n"
20080 ;
20081
20082 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
20084 " property=\"Interpolation\"\n"
20085 " value=\"3\"\n"
20086 " inverse=\"1\" />\n"
20087 " </Hints>\n"
20088 " </DoubleVectorProperty>\n"
20089 " <DoubleVectorProperty command=\"SetLineWidth\"\n"
20090 " default_values=\"1.0\"\n"
20091 " name=\"LineWidth\"\n"
20092 " number_of_elements=\"1\">\n"
20093 " <DoubleRangeDomain min=\"0\"\n"
20094 " name=\"range\" />\n"
20095 " </DoubleVectorProperty>\n"
20096 " <DoubleVectorProperty command=\"SetPointSize\"\n"
20097 " default_values=\"2.0\"\n"
20098 " name=\"PointSize\"\n"
20099 " number_of_elements=\"1\">\n"
20100 " <DoubleRangeDomain min=\"0\"\n"
20101 " name=\"range\" />\n"
20102 " </DoubleVectorProperty>\n"
20103 " <IntVectorProperty command=\"SetRenderLinesAsTubes\"\n"
20104 " default_values=\"0\"\n"
20105 " name=\"RenderLinesAsTubes\"\n"
20106 " number_of_elements=\"1\"\n"
20107 " panel_visibility=\"never\">\n"
20108 " <BooleanDomain name=\"bool\" />\n"
20109 " <Documentation>\n"
20110 " When set, all lines are rendered as 3D tubes, if supported by OpenGL driver.\n"
20111 " </Documentation>\n"
20112 " </IntVectorProperty>\n"
20113 " <IntVectorProperty command=\"SetRenderPointsAsSpheres\"\n"
20114 " default_values=\"0\"\n"
20115 " name=\"RenderPointsAsSpheres\"\n"
20116 " number_of_elements=\"1\"\n"
20117 " panel_visibility=\"never\">\n"
20118 " <BooleanDomain name=\"bool\" />\n"
20119 " <Documentation>\n"
20120 " When set, all points are rendered as 3D spheres, if supported by OpenGL driver.\n"
20121 " </Documentation>\n"
20122 " </IntVectorProperty>\n"
20123 " <IntVectorProperty command=\"SetInterpolation\"\n"
20124 " default_values=\"1\"\n"
20125 " name=\"Interpolation\"\n"
20126 " number_of_elements=\"1\">\n"
20127 " <EnumerationDomain name=\"enum\">\n"
20128 " <Entry text=\"Flat\"\n"
20129 " value=\"0\" />\n"
20130 " <Entry text=\"Gouraud\"\n"
20131 " value=\"1\" />\n"
20132 " <Entry text=\"PBR\"\n"
20133 " value=\"3\" />\n"
20134 " </EnumerationDomain>\n"
20135 " </IntVectorProperty>\n"
20136 " <DoubleVectorProperty command=\"SetOpacity\"\n"
20137 " default_values=\"1.0\"\n"
20138 " name=\"Opacity\"\n"
20139 " number_of_elements=\"1\">\n"
20140 " <DoubleRangeDomain max=\"1\"\n"
20141 " min=\"0\"\n"
20142 " name=\"range\" />\n"
20143 " </DoubleVectorProperty>\n"
20144 " <DoubleVectorProperty command=\"SetSpecularPower\"\n"
20145 " default_values=\"100.0\"\n"
20146 " name=\"SpecularPower\"\n"
20147 " number_of_elements=\"1\">\n"
20148 " <DoubleRangeDomain max=\"100\"\n"
20149 " min=\"0\"\n"
20150 " name=\"range\" />\n"
20151 " <Hints>\n"
20152 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20153 " mode=\"visibility\"\n"
20154 " property=\"Interpolation\"\n"
20155 " value=\"3\"\n"
20156 " inverse=\"1\" />\n"
20157 " </Hints>\n"
20158 " </DoubleVectorProperty>\n"
20159 " <DoubleVectorProperty command=\"SetLuminosity\"\n"
20160 " default_values=\"0.0\"\n"
20161 " name=\"Luminosity\"\n"
20162 " number_of_elements=\"1\">\n"
20163 " <DoubleRangeDomain max=\"100.0\"\n"
20164 " min=\"0\"\n"
20165 " name=\"range\" />\n"
20166 " <Documentation>Makes the object emit light.\n"
20167 " Only takes effect with OSPRay's path traced renderer.\n"
20168 " </Documentation>\n"
20169 " <Hints>\n"
20170 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
20171 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20172 " mode=\"visibility\"\n"
20173 " property=\"EnableOSPRay\"\n"
20174 " values=\"1\" />\n"
20175 " </Hints>\n"
20176 " </DoubleVectorProperty>\n"
20177 " <DoubleVectorProperty command=\"SetEdgeColor\"\n"
20178 " default_values=\"0 0 0.5\"\n"
20179 " name=\"EdgeColor\"\n"
20180 " number_of_elements=\"3\">\n"
20181 " <Documentation>Set the edge color. This color is used to draw the edge\n"
20182 " for the polygonal data when EdgeVisibility is on.</Documentation>\n"
20183 " <DoubleRangeDomain max=\"1 1 1\"\n"
20184 " min=\"0 0 0\"\n"
20185 " name=\"range\" />\n"
20186 " <Hints>\n"
20187 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"EdgeColor\" unlink_if_modified=\"1\" />\n"
20188 " </Hints>\n"
20189 " </DoubleVectorProperty>\n"
20190 " <DoubleVectorProperty command=\"SetInteractiveSelectionColor\"\n"
20191 " default_values=\"0.5 0.0 1.0\"\n"
20192 " name=\"InteractiveSelectionColor\"\n"
20193 " number_of_elements=\"3\">\n"
20194 " <Documentation>Set the preselection color. This color is used to draw the edge\n"
20195 " of the current preselection.</Documentation>\n"
20196 " <DoubleRangeDomain max=\"1 1 1\"\n"
20197 " min=\"0 0 0\"\n"
20198 " name=\"range\" />\n"
20199 " <Hints>\n"
20200 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveSelectionColor\" unlink_if_modified=\"1\" />\n"
20201 " </Hints>\n"
20202 " </DoubleVectorProperty>\n"
20203 " <DoubleVectorProperty command=\"SetPosition\"\n"
20204 " default_values=\"0 0 0\"\n"
20205 " label=\"Translation\"\n"
20206 " name=\"Position\"\n"
20207 " number_of_elements=\"3\">\n"
20208 " <DoubleRangeDomain name=\"range\" />\n"
20209 " </DoubleVectorProperty>\n"
20210 " <DoubleVectorProperty command=\"SetScale\"\n"
20211 " default_values=\"1 1 1\"\n"
20212 " name=\"Scale\"\n"
20213 " number_of_elements=\"3\">\n"
20214 " <DoubleRangeDomain name=\"range\" />\n"
20215 " </DoubleVectorProperty>\n"
20216 " <DoubleVectorProperty command=\"SetOrientation\"\n"
20217 " default_values=\"0 0 0\"\n"
20218 " name=\"Orientation\"\n"
20219 " number_of_elements=\"3\">\n"
20220 " <DoubleRangeDomain name=\"range\" />\n"
20221 " </DoubleVectorProperty>\n"
20222 " <DoubleVectorProperty command=\"SetOrigin\"\n"
20223 " default_values=\"0 0 0\"\n"
20224 " name=\"Origin\"\n"
20225 " number_of_elements=\"3\">\n"
20226 " <DoubleRangeDomain name=\"range\" />\n"
20227 " </DoubleVectorProperty>\n"
20228 "\n"
20229 " <DoubleVectorProperty argument_is_array=\"1\"\n"
20230 " command=\"SetUserTransform\"\n"
20231 " default_values=\"1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1\"\n"
20232 " name=\"UserTransform\"\n"
20233 " number_of_elements=\"16\">\n"
20234 " <Documentation>\n"
20235 " In addition to the instance variables such as position and\n"
20236 " orientation, you can add an additional transformation for your own\n"
20237 " use. This transformation is concatenated with the actor's internal\n"
20238 " transformation, which you implicitly create through the use of\n"
20239 " Position, Origin, Orientation. The value is 4x4 matrix for the linear\n"
20240 " transform to use.\n"
20241 " </Documentation>\n"
20242 " </DoubleVectorProperty>\n"
20243 "\n"
20244 " <IntVectorProperty command=\"SetPickable\"\n"
20245 " default_values=\"1\"\n"
20246 " name=\"Pickable\"\n"
20247 " number_of_elements=\"1\">\n"
20248 " <Hints>\n"
20249 " <NoDefault />\n"
20250 " </Hints>\n"
20251 " <BooleanDomain name=\"bool\" />\n"
20252 " </IntVectorProperty>\n"
20253 " <ProxyProperty command=\"SetLookupTable\"\n"
20254 " name=\"LookupTable\" >\n"
20255 " <Documentation>Set the lookup-table to use to map data array to colors.\n"
20256 " Lookuptable is only used with MapScalars to ON.</Documentation>\n"
20257 " <ProxyGroupDomain name=\"groups\">\n"
20258 " <Group name=\"lookup_tables\" />\n"
20259 " </ProxyGroupDomain>\n"
20260 " </ProxyProperty>\n"
20261 " <IntVectorProperty default_values=\"0\"\n"
20262 " name=\"UseSeparateColorMap\"\n"
20263 " number_of_elements=\"1\"\n"
20264 " panel_visibility=\"never\">\n"
20265 " <BooleanDomain name=\"bool\" />\n"
20266 " <Documentation>By default, ParaView shares a single color map among all datasets colored\n"
20267 " by arrays that have the same name. When this option is enabled, the active dataset will\n"
20268 " be assigned a separate color map not shared by other datasets.</Documentation>\n"
20269 " </IntVectorProperty>\n"
20270 " <IntVectorProperty command=\"SetMapScalars\"\n"
20271 " default_values=\"1\"\n"
20272 " name=\"MapScalars\"\n"
20273 " number_of_elements=\"1\">\n"
20274 " <BooleanDomain name=\"bool\" />\n"
20275 " <Documentation>When enabled, LookupTable will always be\n"
20276 " used for scalar mapping. Otherwise, when up to 4 component\n"
20277 " scalars are present, the components are clamped to a valid\n"
20278 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
20279 " floating point type) and then directly used as\n"
20280 " color.</Documentation>\n"
20281 " </IntVectorProperty>\n"
20282 " <IntVectorProperty default_values=\"0\"\n"
20283 " name=\"MultiComponentsMapping\"\n"
20284 " number_of_elements=\"1\">\n"
20285 " <BooleanDomain name=\"bool\" />\n"
20286 " <Documentation>Enable multi components mapping. For a two-components array,\n"
20287 " the first component is mapped to the color, the second component is mapped to the\n"
20288 " opacity. For a four-components array, the first, second and third components are used as\n"
20289 " RGB values and the fourth component is mapped to the opacity. Only available\n"
20290 " when MapScalars is ON. This feature forces \"Separate Color Map\" and scales the color and\n"
20291 " the opacity range with the correct component.</Documentation>\n"
20292 " <Hints>\n"
20293 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20294 " mode=\"visibility\"\n"
20295 " property=\"Representation\"\n"
20296 " value=\"Volume\" />\n"
20297 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20298 " mode=\"visibility\"\n"
20299 " property=\"MapScalars\"\n"
20300 " value=\"1\" />\n"
20301 " <PropertyWidgetDecorator type=\"MultiComponentsDecorator\"\n"
20302 " components=\"2 4\" />\n"
20303 " </Hints>\n"
20304 " </IntVectorProperty>\n"
20305 " <IntVectorProperty command=\"SetInterpolateScalarsBeforeMapping\"\n"
20306 " default_values=\"1\"\n"
20307 " name=\"InterpolateScalarsBeforeMapping\"\n"
20308 " number_of_elements=\"1\">\n"
20309 " <BooleanDomain name=\"bool\" />\n"
20310 " <Documentation>When set to true (default), texture coordinates\n"
20311 " are sent to and interpolated by the graphics card. This is\n"
20312 " equivalent with interpolating scalars and then mapping them to\n"
20313 " obtain colors between points. Otherwise, colors are sent to\n"
20314 " and interpolated by the graphics card.\n"
20315 " </Documentation>\n"
20316 " </IntVectorProperty>\n"
20317 " <IntVectorProperty command=\"SetStatic\"\n"
20318 " default_values=\"0\"\n"
20319 " name=\"StaticMode\"\n"
20320 " number_of_elements=\"1\">\n"
20321 " <BooleanDomain name=\"bool\" />\n"
20322 " </IntVectorProperty>\n"
20323 "\n"
20324 " <StringVectorProperty name=\"Assembly\"\n"
20325 " command=\"SetActiveAssembly\"\n"
20326 " number_of_elements=\"1\"\n"
20327 " panel_visibility=\"multiblock_inspector\">\n"
20328 " <DataAssemblyListDomain name=\"data_assembly\">\n"
20329 " <RequiredProperties>\n"
20330 " <Property function=\"Input\" name=\"Input\" />\n"
20331 " </RequiredProperties>\n"
20332 " </DataAssemblyListDomain>\n"
20333 " <Documentation>\n"
20334 " Select which assembly is used when specify selectors\n"
20335 " to choose block visibilities, block colors, etc. for composite datasets.\n"
20336 " </Documentation>\n"
20337 " </StringVectorProperty>\n"
20338 "\n"
20339 " <StringVectorProperty name=\"SelectedBlockSelectors\"\n"
20340 " repeat_command=\"1\"\n"
20341 " number_of_elements_per_command=\"1\"\n"
20342 " number_of_elements=\"1\"\n"
20343 " panel_visibility=\"multiblock_inspector\">\n"
20344 " <DataAssemblyDomain name=\"data_assembly\">\n"
20345 " <RequiredProperties>\n"
20346 " <Property function=\"Input\" name=\"Input\"/>\n"
20347 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
20348 " </RequiredProperties>\n"
20349 " </DataAssemblyDomain>\n"
20350 " <Hints>\n"
20351 " <NoDefault/>\n"
20352 " </Hints>\n"
20353 " <Documentation>\n"
20354 " Used by the multiblock inspector to track the selected block selectors.\n"
20355 " </Documentation>\n"
20356 " </StringVectorProperty>\n"
20357 "\n"
20358 " <StringVectorProperty name=\"BlockSelectors\"\n"
20359 " command=\"AddBlockSelector\"\n"
20360 " clean_command=\"RemoveAllBlockSelectors\"\n"
20361 " repeat_command=\"1\"\n"
20362 " number_of_elements_per_command=\"1\"\n"
20363 " panel_visibility=\"multiblock_inspector\"\n"
20364 " number_of_elements=\"1\"\n"
20365 " default_values=\"/\">\n"
20366 " <DataAssemblyDomain name=\"data_assembly\">\n"
20367 " <RequiredProperties>\n"
20368 " <Property function=\"Input\" name=\"Input\" />\n"
20369 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
20370 " </RequiredProperties>\n"
20371 " </DataAssemblyDomain>\n"
20372 " <Documentation>\n"
20373 " For composite datasets, specify selectors to limit the view\n"
20374 " to a chosen subset of blocks.\n"
20375 " </Documentation>\n"
20376 " </StringVectorProperty>\n"
20377 "\n"
20378 " <StringVectorProperty name=\"BlockColors\"\n"
20379 " command=\"SetBlockColor\"\n"
20380 " clean_command=\"RemoveAllBlockColors\"\n"
20381 " element_types=\"2 1 1 1\"\n"
20382 " number_of_elements_per_command=\"4\"\n"
20383 " repeat_command=\"1\"\n"
20384 " panel_visibility=\"multiblock_inspector\">\n"
20385 " <DataAssemblyDomain name=\"data_assembly\">\n"
20386 " <RequiredProperties>\n"
20387 " <Property function=\"Input\" name=\"Input\" />\n"
20388 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
20389 " </RequiredProperties>\n"
20390 " </DataAssemblyDomain>\n"
20391 " <Hints>\n"
20392 " <NoDefault/>\n"
20393 " </Hints>\n"
20394 " <Documentation>\n"
20395 " For composite datasets, specify colors associated with selectors\n"
20396 " on the assembly chosen using **Assembly**.\n"
20397 ;
20398
20399 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
20401 " </Documentation>\n"
20402 " </StringVectorProperty>\n"
20403 "\n"
20404 " <StringVectorProperty name=\"BlockColorArrayNames\"\n"
20405 " command=\"SetBlockArrayName\"\n"
20406 " clean_command=\"RemoveAllBlockArrayNames\"\n"
20407 " element_types=\"2 0 2\"\n"
20408 " number_of_elements_per_command=\"3\"\n"
20409 " repeat_command=\"1\"\n"
20410 " panel_visibility=\"multiblock_inspector\">\n"
20411 " <RepresentedArrayListDomain name=\"array_list\" input_domain_name=\"input_array_any\">\n"
20412 " <RequiredProperties>\n"
20413 " <Property function=\"Input\" name=\"Input\"/>\n"
20414 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
20415 " <Property function=\"Selectors\" name=\"SelectedBlockSelectors\"/>\n"
20416 " </RequiredProperties>\n"
20417 " </RepresentedArrayListDomain>\n"
20418 " <Documentation>\n"
20419 " For composite datasets, specify the color array name associated with selectors\n"
20420 " on the assembly chosen using **Assembly**.\n"
20421 " </Documentation>\n"
20422 " <Hints>\n"
20423 " <NoDefault/>\n"
20424 " </Hints>\n"
20425 " </StringVectorProperty>\n"
20426 "\n"
20427 " <ProxyProperty command=\"SetBlockLookupTable\"\n"
20428 " name=\"BlockLookupTables\"\n"
20429 " clean_command=\"RemoveAllBlockLookupTables\"\n"
20430 " repeat_command=\"1\"\n"
20431 " panel_visibility=\"multiblock_inspector\">\n"
20432 " <ProxyGroupDomain name=\"groups\">\n"
20433 " <Group name=\"lookup_tables\"/>\n"
20434 " </ProxyGroupDomain>\n"
20435 " <Hints>\n"
20436 " <NoDefault/>\n"
20437 " </Hints>\n"
20438 " <Documentation>\n"
20439 " Set the block lookup-table to use to map data array to colors.\n"
20440 " Lookup table is only used with MapScalars to ON or BlockMapScalars to ON.\n"
20441 " </Documentation>\n"
20442 " </ProxyProperty>\n"
20443 "\n"
20444 " <StringVectorProperty name=\"BlockUseSeparateColorMaps\"\n"
20445 " element_types=\"2 0\"\n"
20446 " number_of_elements_per_command=\"2\"\n"
20447 " repeat_command=\"1\"\n"
20448 " panel_visibility=\"multiblock_inspector\">\n"
20449 " <DataAssemblyDomain name=\"data_assembly\">\n"
20450 " <RequiredProperties>\n"
20451 " <Property function=\"Input\" name=\"Input\"/>\n"
20452 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
20453 " </RequiredProperties>\n"
20454 " </DataAssemblyDomain>\n"
20455 " <Hints>\n"
20456 " <NoDefault/>\n"
20457 " </Hints>\n"
20458 " <Documentation>\n"
20459 " By default, ParaView shares a single color map among all datasets colored\n"
20460 " by arrays that have the same name. When this option is enabled, the block of the active dataset will\n"
20461 " be assigned a separate color map not shared by other blocks or datasets.\n"
20462 " </Documentation>\n"
20463 " </StringVectorProperty>\n"
20464 "\n"
20465 " <StringVectorProperty name=\"BlockMapScalars\"\n"
20466 " command=\"SetBlockMapScalars\"\n"
20467 " clean_command=\"RemoveAllBlockMapScalars\"\n"
20468 " element_types=\"2 0\"\n"
20469 " number_of_elements_per_command=\"2\"\n"
20470 " repeat_command=\"1\"\n"
20471 " panel_visibility=\"multiblock_inspector\">\n"
20472 " <DataAssemblyDomain name=\"data_assembly\">\n"
20473 " <RequiredProperties>\n"
20474 " <Property function=\"Input\" name=\"Input\"/>\n"
20475 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
20476 " </RequiredProperties>\n"
20477 " </DataAssemblyDomain>\n"
20478 " <Hints>\n"
20479 " <NoDefault/>\n"
20480 " </Hints>\n"
20481 " <Documentation>\n"
20482 " For composite datasets, specify if to map scalars associated with selectors\n"
20483 " on the assembly chosen using **Assembly**.\n"
20484 " </Documentation>\n"
20485 " </StringVectorProperty>\n"
20486 "\n"
20487 " <StringVectorProperty name=\"BlockInterpolateScalarsBeforeMappings\"\n"
20488 " command=\"SetBlockInterpolateScalarsBeforeMapping\"\n"
20489 " clean_command=\"RemoveAllBlockInterpolateScalarsBeforeMappings\"\n"
20490 " element_types=\"2 0\"\n"
20491 " number_of_elements_per_command=\"2\"\n"
20492 " repeat_command=\"1\"\n"
20493 " panel_visibility=\"multiblock_inspector\">\n"
20494 " <DataAssemblyDomain name=\"data_assembly\">\n"
20495 " <RequiredProperties>\n"
20496 " <Property function=\"Input\" name=\"Input\"/>\n"
20497 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
20498 " </RequiredProperties>\n"
20499 " </DataAssemblyDomain>\n"
20500 " <Hints>\n"
20501 " <NoDefault/>\n"
20502 " </Hints>\n"
20503 " <Documentation>\n"
20504 " For composite datasets, specify if to interpolate scalars before mapping associated with selectors\n"
20505 " on the assembly chosen using **Assembly**.\n"
20506 " </Documentation>\n"
20507 " </StringVectorProperty>\n"
20508 "\n"
20509 " <StringVectorProperty name=\"BlockOpacities\"\n"
20510 " command=\"SetBlockOpacity\"\n"
20511 " clean_command=\"RemoveAllBlockOpacities\"\n"
20512 " element_types=\"2 1\"\n"
20513 " number_of_elements_per_command=\"2\"\n"
20514 " repeat_command=\"1\"\n"
20515 " panel_visibility=\"multiblock_inspector\">\n"
20516 " <DataAssemblyDomain name=\"data_assembly\">\n"
20517 " <RequiredProperties>\n"
20518 " <Property function=\"Input\" name=\"Input\" />\n"
20519 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
20520 " </RequiredProperties>\n"
20521 " </DataAssemblyDomain>\n"
20522 " <Hints>\n"
20523 " <NoDefault/>\n"
20524 " </Hints>\n"
20525 " <Documentation>\n"
20526 " For composite datasets, specify opacities associated with selectors\n"
20527 " on the assembly chosen using **Assembly**.\n"
20528 " </Documentation>\n"
20529 " </StringVectorProperty>\n"
20530 "\n"
20531 " <IntVectorProperty default_values=\"1\"\n"
20532 " label=\"Map Scalars\"\n"
20533 " name=\"BlockMapScalarsGUI\"\n"
20534 " number_of_elements=\"1\"\n"
20535 " panel_visibility=\"multiblock_properties\">\n"
20536 " <BooleanDomain name=\"bool\"/>\n"
20537 " <Documentation>\n"
20538 " For composite datasets, specify if to map scalars associated with selectors\n"
20539 " on the assembly chosen using **Assembly**.\n"
20540 " </Documentation>\n"
20541 " </IntVectorProperty>\n"
20542 "\n"
20543 " <IntVectorProperty default_values=\"1\"\n"
20544 " label=\"Interpolate Scalars Before Mapping\"\n"
20545 " name=\"BlockInterpolateScalarsBeforeMappingsGUI\"\n"
20546 " number_of_elements=\"1\"\n"
20547 " panel_visibility=\"multiblock_properties\">\n"
20548 " <BooleanDomain name=\"bool\"/>\n"
20549 " <Documentation>\n"
20550 " For composite datasets, specify if to interpolate scalars before mapping associated with selectors\n"
20551 " on the assembly chosen using **Assembly**.\n"
20552 " </Documentation>\n"
20553 " </IntVectorProperty>\n"
20554 "\n"
20555 " <DoubleVectorProperty default_values=\"1.0\"\n"
20556 " label=\"Opacity\"\n"
20557 " name=\"BlockOpacitiesGUI\"\n"
20558 " number_of_elements=\"1\"\n"
20559 " panel_visibility=\"multiblock_properties\">\n"
20560 " <DoubleRangeDomain max=\"1\"\n"
20561 " min=\"0\"\n"
20562 " name=\"range\"/>\n"
20563 " <Documentation>\n"
20564 " For composite datasets, specify opacities associated with selectors\n"
20565 " on the assembly chosen using **Assembly**.\n"
20566 " </Documentation>\n"
20567 " </DoubleVectorProperty>\n"
20568 "\n"
20569 " <IntVectorProperty command=\"SetBlockColorsDistinctValues\"\n"
20570 " default_values=\"7\"\n"
20571 " name=\"BlockColorsDistinctValues\"\n"
20572 " number_of_elements=\"1\"\n"
20573 " panel_visibility=\"never\">\n"
20574 " <Documentation>\n"
20575 " Determines the number of distinct values in\n"
20576 " vtkBlockColors. This array is added to each block if\n"
20577 " the dataset is a composite dataset. The array has one value\n"
20578 " set to (blockIndex % BlockColorsDistinctValues)\n"
20579 " </Documentation>\n"
20580 " <IntRangeDomain min=\"2\" name=\"range\" />\n"
20581 " <Hints>\n"
20582 " <PropertyLink group=\"settings\"\n"
20583 " proxy=\"GeneralSettings\"\n"
20584 " property=\"BlockColorsDistinctValues\"/>\n"
20585 " </Hints>\n"
20586 " </IntVectorProperty>\n"
20587 " <IntVectorProperty command=\"SetUseDataPartitions\"\n"
20588 " default_values=\"0\"\n"
20589 " name=\"UseDataPartitions\"\n"
20590 " number_of_elements=\"1\">\n"
20591 " <BooleanDomain name=\"bool\" />\n"
20592 " <Documentation>Specify whether or not to redistribute the data when actor is translucent.\n"
20593 " Default is false.</Documentation>\n"
20594 " </IntVectorProperty>\n"
20595 " <!-- End of CellGridSurfaceRepresentation -->\n"
20596 " </RepresentationProxy>\n"
20597 "\n"
20598 " <!-- ================================================================== -->\n"
20599 " <RepresentationProxy base_proxygroup=\"internal_representations\"\n"
20600 " base_proxyname=\"SurfaceRepresentationBase\"\n"
20601 " class=\"vtkGeometryRepresentationWithFaces\"\n"
20602 " name=\"SurfaceRepresentation\"\n"
20603 " processes=\"client|renderserver|dataserver\">\n"
20604 " <Documentation>Representation to show any dataset in a 3D render\n"
20605 " view.</Documentation>\n"
20606 " <InputProperty command=\"SetInputConnection\"\n"
20607 " name=\"Input\">\n"
20608 " <DataTypeDomain name=\"input_type\">\n"
20609 " <DataType value=\"vtkDataSet\" />\n"
20610 " </DataTypeDomain>\n"
20611 " <InputArrayDomain attribute_type=\"any\"\n"
20612 " name=\"input_array_any\" />\n"
20613 " <InputArrayDomain attribute_type=\"cell\"\n"
20614 " name=\"input_array_cell\"\n"
20615 " optional=\"1\" />\n"
20616 " <InputArrayDomain attribute_type=\"point\"\n"
20617 " name=\"input_array_point\"\n"
20618 " optional=\"1\" />\n"
20619 " <InputArrayDomain attribute_type=\"cell\"\n"
20620 " name=\"input_array_cell_1\"\n"
20621 " number_of_components=\"1\"\n"
20622 " optional=\"1\" />\n"
20623 " <InputArrayDomain attribute_type=\"point\"\n"
20624 " name=\"input_array_point_1\"\n"
20625 " number_of_components=\"1\"\n"
20626 " optional=\"1\" />\n"
20627 " <InputArrayDomain attribute_type=\"point\"\n"
20628 " name=\"input_array_point_2\"\n"
20629 " number_of_components=\"2\"\n"
20630 " optional=\"1\" />\n"
20631 " <InputArrayDomain attribute_type=\"cell\"\n"
20632 " name=\"input_array_cell_3\"\n"
20633 " number_of_components=\"3\"\n"
20634 " optional=\"1\" />\n"
20635 " <InputArrayDomain attribute_type=\"point\"\n"
20636 " name=\"input_array_point_3\"\n"
20637 " number_of_components=\"3\"\n"
20638 " optional=\"1\" />\n"
20639 " <Documentation>Set the input to the representation.</Documentation>\n"
20640 " </InputProperty>\n"
20641 " <IntVectorProperty command=\"SetBackfaceRepresentation\"\n"
20642 " default_values=\"400\"\n"
20643 " name=\"BackfaceRepresentation\"\n"
20644 " number_of_elements=\"1\">\n"
20645 " <Documentation>Choose the representation type for the\n"
20646 " backface.</Documentation>\n"
20647 " <EnumerationDomain name=\"enum\">\n"
20648 " <Entry text=\"Follow Frontface\"\n"
20649 " value=\"400\" />\n"
20650 " <Entry text=\"Cull Backface\"\n"
20651 " value=\"401\" />\n"
20652 " <Entry text=\"Cull Frontface\"\n"
20653 " value=\"402\" />\n"
20654 " <Entry text=\"Points\"\n"
20655 " value=\"0\" />\n"
20656 " <Entry text=\"Wireframe\"\n"
20657 " value=\"1\" />\n"
20658 " <Entry text=\"Surface\"\n"
20659 " value=\"2\" />\n"
20660 " <Entry text=\"Surface With Edges\"\n"
20661 " value=\"3\" />\n"
20662 " </EnumerationDomain>\n"
20663 " </IntVectorProperty>\n"
20664 " <DoubleVectorProperty command=\"SetBackfaceOpacity\"\n"
20665 " default_values=\"1.0\"\n"
20666 " name=\"BackfaceOpacity\"\n"
20667 " number_of_elements=\"1\">\n"
20668 " <DoubleRangeDomain max=\"1\"\n"
20669 " min=\"0\"\n"
20670 " name=\"range\" />\n"
20671 " </DoubleVectorProperty>\n"
20672 " <DoubleVectorProperty command=\"SetBackfaceAmbientColor\"\n"
20673 " default_values=\"1.0 1.0 1.0\"\n"
20674 " name=\"BackfaceAmbientColor\"\n"
20675 " number_of_elements=\"3\">\n"
20676 " <DoubleRangeDomain max=\"1 1 1\"\n"
20677 " min=\"0 0 0\"\n"
20678 " name=\"range\" />\n"
20679 " </DoubleVectorProperty>\n"
20680 " <DoubleVectorProperty command=\"SetBackfaceDiffuseColor\"\n"
20681 " default_values=\"1.0 1.0 1.0\"\n"
20682 " name=\"BackfaceDiffuseColor\"\n"
20683 " number_of_elements=\"3\">\n"
20684 " <DoubleRangeDomain max=\"1 1 1\"\n"
20685 " min=\"0 0 0\"\n"
20686 " name=\"range\" />\n"
20687 " <Hints>\n"
20688 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SurfaceColor\" unlink_if_modified=\"1\" />\n"
20689 " </Hints>\n"
20690 " </DoubleVectorProperty>\n"
20691 " </RepresentationProxy>\n"
20692 " <!-- ================================================================== -->\n"
20693 " <RepresentationProxy base_proxygroup=\"internal_representations\"\n"
20694 " base_proxyname=\"SurfaceRepresentationBase\"\n"
20695 " class=\"vtkGlyph3DRepresentation\"\n"
20696 " name=\"Glyph3DRepresentation\"\n"
20697 " processes=\"client|renderserver|dataserver\">\n"
20698 " <Documentation>Representation to show any dataset in a 3D render\n"
20699 " view.</Documentation>\n"
20700 " <InputProperty command=\"SetInputConnection\"\n"
20701 " name=\"Input\">\n"
20702 " <DataTypeDomain name=\"input_type\">\n"
20703 " <DataType value=\"vtkDataSet\" />\n"
20704 " </DataTypeDomain>\n"
20705 " <InputArrayDomain name=\"scale_array\"\n"
20706 " number_of_components=\"1,3\"\n"
20707 " optional=\"1\" />\n"
20708 " <InputArrayDomain name=\"vector_array\"\n"
20709 " number_of_components=\"3,4\"\n"
20710 " optional=\"1\" />\n"
20711 " <Documentation>Set the input to the representation.</Documentation>\n"
20712 " </InputProperty>\n"
20713 " <InputProperty command=\"SetInputConnection\"\n"
20714 " label=\"Glyph Type\"\n"
20715 " name=\"GlyphType\"\n"
20716 " panel_visibility=\"advanced\"\n"
20717 " port_index=\"1\">\n"
20718 " <Documentation>Specify the source objects.</Documentation>\n"
20719 " <DataTypeDomain name=\"input_type\">\n"
20720 ;
20721
20722 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
20724 " <DataType value=\"vtkPolyData\" />\n"
20725 " <DataType value=\"vtkDataObjectTree\" />\n"
20726 " </DataTypeDomain>\n"
20727 " <ProxyListDomain name=\"proxy_list\">\n"
20728 " <Proxy group=\"sources\" name=\"ArrowSource\" />\n"
20729 " <Proxy group=\"sources\" name=\"ConeSource\" />\n"
20730 " <Proxy group=\"sources\" name=\"CubeSource\" />\n"
20731 " <Proxy group=\"sources\" name=\"CylinderSource\" />\n"
20732 " <Proxy group=\"sources\" name=\"LineSource\" />\n"
20733 " <Proxy group=\"sources\" name=\"SphereSource\" />\n"
20734 " <Proxy group=\"sources\" name=\"GlyphSource2D\" />\n"
20735 " <Proxy group=\"internal_filters\" name=\"PipelineConnection\" />\n"
20736 " </ProxyListDomain>\n"
20737 " <Hints>\n"
20738 " <ProxyPropertyWidget selected_proxy_panel_visibility=\"advanced\" />\n"
20739 " <!-- show the selected proxy's panel, only in advanced mode. -->\n"
20740 " </Hints>\n"
20741 " </InputProperty>\n"
20742 " <IntVectorProperty command=\"SetMeshVisibility\"\n"
20743 " default_values=\"0\"\n"
20744 " name=\"MeshVisibility\"\n"
20745 " number_of_elements=\"1\">\n"
20746 " <BooleanDomain name=\"bool\" />\n"
20747 " <Documentation>Get/Set the visibility of the original\n"
20748 " mesh.</Documentation>\n"
20749 " </IntVectorProperty>\n"
20750 " <StringVectorProperty command=\"SetMaskArray\"\n"
20751 " default_values=\"\"\n"
20752 " label=\"Mask Array\"\n"
20753 " name=\"SelectMaskArray\"\n"
20754 " number_of_elements=\"1\"></StringVectorProperty>\n"
20755 " <StringVectorProperty command=\"SetScaleArray\"\n"
20756 " default_values=\"\"\n"
20757 " label=\"Scale Array\"\n"
20758 " name=\"SelectScaleArray\"\n"
20759 " number_of_elements=\"1\">\n"
20760 " <ArrayListDomain attribute_type=\"Scalars\"\n"
20761 " input_domain_name=\"scale_array\"\n"
20762 " name=\"array_list\"\n"
20763 " none_string=\"None\">\n"
20764 " <RequiredProperties>\n"
20765 " <Property function=\"Input\"\n"
20766 " name=\"Input\" />\n"
20767 " </RequiredProperties>\n"
20768 " </ArrayListDomain>\n"
20769 " </StringVectorProperty>\n"
20770 " <IntVectorProperty command=\"SetScaling\"\n"
20771 " default_values=\"0\"\n"
20772 " name=\"Scaling\"\n"
20773 " number_of_elements=\"1\">\n"
20774 " <BooleanDomain name=\"bool\" />\n"
20775 " <Documentation>Enable/Disable scaling of source\n"
20776 " geometry.</Documentation>\n"
20777 " </IntVectorProperty>\n"
20778 " <IntVectorProperty command=\"SetScaleMode\"\n"
20779 " default_values=\"0\"\n"
20780 " name=\"ScaleMode\"\n"
20781 " number_of_elements=\"1\">\n"
20782 " <EnumerationDomain name=\"enum\">\n"
20783 " <Entry text=\"No Data Scaling Off\"\n"
20784 " value=\"0\" />\n"
20785 " <Entry text=\"Magnitude\"\n"
20786 " value=\"1\" />\n"
20787 " <Entry text=\"Vector Components\"\n"
20788 " value=\"2\" />\n"
20789 " </EnumerationDomain>\n"
20790 " </IntVectorProperty>\n"
20791 " <StringVectorProperty command=\"SetOrientationArray\"\n"
20792 " default_values=\"\"\n"
20793 " label=\"Orientation Vectors\"\n"
20794 " name=\"SelectOrientationVectors\"\n"
20795 " number_of_elements=\"1\">\n"
20796 " <ArrayListDomain attribute_type=\"Vectors\"\n"
20797 " input_domain_name=\"vector_array\"\n"
20798 " name=\"array_list\"\n"
20799 " none_string=\"None\">\n"
20800 " <RequiredProperties>\n"
20801 " <Property function=\"Input\"\n"
20802 " name=\"Input\" />\n"
20803 " </RequiredProperties>\n"
20804 " </ArrayListDomain>\n"
20805 " </StringVectorProperty>\n"
20806 " <DoubleVectorProperty command=\"SetScaleFactor\"\n"
20807 " default_values=\"1.0\"\n"
20808 " name=\"ScaleFactor\"\n"
20809 " number_of_elements=\"1\">\n"
20810 " <BoundsDomain mode=\"scaled_extent\"\n"
20811 " name=\"bounds\"\n"
20812 " scale_factor=\"0.1\">\n"
20813 " <RequiredProperties>\n"
20814 " <Property function=\"Input\"\n"
20815 " name=\"Input\" />\n"
20816 " </RequiredProperties>\n"
20817 " </BoundsDomain>\n"
20818 " <ArrayRangeDomain name=\"scalar_range\">\n"
20819 " <RequiredProperties>\n"
20820 " <Property function=\"Input\"\n"
20821 " name=\"Input\" />\n"
20822 " <Property function=\"ArraySelection\"\n"
20823 " name=\"SelectScaleArray\" />\n"
20824 " </RequiredProperties>\n"
20825 " </ArrayRangeDomain>\n"
20826 " <ArrayRangeDomain name=\"vector_range\">\n"
20827 " <RequiredProperties>\n"
20828 " <Property function=\"Input\"\n"
20829 " name=\"Input\" />\n"
20830 " <Property function=\"ArraySelection\"\n"
20831 " name=\"SelectOrientationVectors\" />\n"
20832 " </RequiredProperties>\n"
20833 " </ArrayRangeDomain>\n"
20834 " <Documentation>The value of this property will be used as a multiplier\n"
20835 " for scaling the glyphs before adding them to the\n"
20836 " output.</Documentation>\n"
20837 " </DoubleVectorProperty>\n"
20838 " <IntVectorProperty command=\"SetOrient\"\n"
20839 " default_values=\"0\"\n"
20840 " name=\"Orient\"\n"
20841 " number_of_elements=\"1\">\n"
20842 " <BooleanDomain name=\"bool\" />\n"
20843 " <Documentation>If this property is set to 1, the glyphs will be\n"
20844 " oriented based on the selected orientation vector\n"
20845 " array.</Documentation>\n"
20846 " </IntVectorProperty>\n"
20847 " <IntVectorProperty command=\"SetOrientationMode\"\n"
20848 " default_values=\"0\"\n"
20849 " name=\"OrientationMode\"\n"
20850 " number_of_elements=\"1\">\n"
20851 " <EnumerationDomain name=\"enum\">\n"
20852 " <Entry text=\"Direction\"\n"
20853 " value=\"0\" />\n"
20854 " <Entry text=\"Rotation\"\n"
20855 " value=\"1\" />\n"
20856 " <Entry text=\"Quaternion\"\n"
20857 " value=\"2\" />\n"
20858 " </EnumerationDomain>\n"
20859 " <Documentation>Orientation mode indicates if the OrientationArray\n"
20860 " provides the direction vector for the orientation, the rotations\n"
20861 " around each axes or the quaternion in WXYZ format. Default is DIRECTION.</Documentation>\n"
20862 " </IntVectorProperty>\n"
20863 " <IntVectorProperty command=\"SetMasking\"\n"
20864 " default_values=\"0\"\n"
20865 " name=\"Masking\"\n"
20866 " number_of_elements=\"1\">\n"
20867 " <BooleanDomain name=\"bool\" />\n"
20868 " <Documentation>Tells the mapper to skip glyphing input points that\n"
20869 " haves false values in the mask array. If there is no mask array (id\n"
20870 " access mode is set and there is no such id, or array name access mode\n"
20871 " is set and the there is no such name), masking is silently ignored. A\n"
20872 " mask array is a vtkBitArray with only one component.</Documentation>\n"
20873 " </IntVectorProperty>\n"
20874 " <IntVectorProperty command=\"SetSourceIndexing\"\n"
20875 " default_values=\"0\"\n"
20876 " name=\"UseGlyphTable\"\n"
20877 " number_of_elements=\"1\">\n"
20878 " <BooleanDomain name=\"bool\" />\n"
20879 " <Documentation>When enabled, the source index array would be used to select the\n"
20880 " glyph source. If not, only the first source input will be used to generate\n"
20881 " the glyph. It's a prerequisite to enable UseCompositeGlyphTable.</Documentation>\n"
20882 " </IntVectorProperty>\n"
20883 " <StringVectorProperty command=\"SetSourceIndexArray\"\n"
20884 " default_values=\"\"\n"
20885 " name=\"GlyphTableIndexArray\"\n"
20886 " number_of_elements=\"1\">\n"
20887 " <ArrayListDomain attribute_type=\"Scalars\"\n"
20888 " input_domain_name=\"input_array_point\"\n"
20889 " name=\"array_list\"\n"
20890 " none_string=\"None\">\n"
20891 " <RequiredProperties>\n"
20892 " <Property function=\"Input\"\n"
20893 " name=\"Input\" />\n"
20894 " </RequiredProperties>\n"
20895 " </ArrayListDomain>\n"
20896 " </StringVectorProperty>\n"
20897 " <IntVectorProperty command=\"SetUseSourceTableTree\"\n"
20898 " default_values=\"0\"\n"
20899 " name=\"UseCompositeGlyphTable\"\n"
20900 " number_of_elements=\"1\">\n"
20901 " <BooleanDomain name=\"bool\" />\n"
20902 " <Documentation>When true, the glyph data is expected to be a multiblock\n"
20903 " dataset, where each top-level node contains a separate glyph which may\n"
20904 " be selected by a point data array on the input dataset. UseGlyphTable\n"
20905 " must be enabled as a prerequisite.</Documentation>\n"
20906 " <Hints>\n"
20907 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20908 " mode=\"visibility\"\n"
20909 " property=\"UseGlyphTable\"\n"
20910 " value=\"1\" />\n"
20911 " <!-- enable this widget when UseGlyphTable==1 -->\n"
20912 " </Hints>\n"
20913 " </IntVectorProperty>\n"
20914 " <IntVectorProperty command=\"SetUseCullingAndLOD\"\n"
20915 " default_values=\"0\"\n"
20916 " name=\"UseGlyphCullingAndLOD\"\n"
20917 " number_of_elements=\"1\">\n"
20918 " <BooleanDomain name=\"bool\" />\n"
20919 " <Documentation>When true, culling pass and level of details are enabled.\n"
20920 " The culling pass detects points outside the frustum view and LOD displays\n"
20921 " decimated geometry based on the distance between the camera and the instance.\n"
20922 " This allows to render a higher number of glyphs at interactive rate.\n"
20923 " This feature works only with OpenGL driver >= 4.0.\n"
20924 " </Documentation>\n"
20925 " </IntVectorProperty>\n"
20926 " <DoubleVectorProperty animateable=\"1\"\n"
20927 " command=\"SetLODDistanceAndTargetReduction\"\n"
20928 " label=\"LOD Values\"\n"
20929 " name=\"LODValues\"\n"
20930 " number_of_elements=\"0\"\n"
20931 " number_of_elements_per_command=\"2\"\n"
20932 " repeat_command=\"1\"\n"
20933 " set_number_command=\"SetNumberOfLOD\"\n"
20934 " use_index=\"1\">\n"
20935 " <ArrayRangeDomain name=\"scalar_range\">\n"
20936 " <RequiredProperties>\n"
20937 " <Property function=\"Input\"\n"
20938 " name=\"Input\" />\n"
20939 " <Property function=\"Input\"\n"
20940 " name=\"UseGlyphCullingAndLOD\" />\n"
20941 " </RequiredProperties>\n"
20942 " </ArrayRangeDomain>\n"
20943 " <Documentation>\n"
20944 " Configure LODs. The first value is the distance after which it is enabled.\n"
20945 " The second value is the decimation parameter (0 displays full geometry,\n"
20946 " 1 displays only a point)\n"
20947 " The maximum number of LODs depends on the GPU capacity.\n"
20948 " </Documentation>\n"
20949 " <Hints>\n"
20950 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20951 " mode=\"visibility\"\n"
20952 " property=\"UseGlyphCullingAndLOD\"\n"
20953 " value=\"1\" />\n"
20954 " <!-- enable this widget when UseGlyphCullingAndLOD==1 -->+\n"
20955 " <ShowComponentLabels>\n"
20956 " <ComponentLabel component=\"0\" label=\"Distance\"/>\n"
20957 " <ComponentLabel component=\"1\" label=\"Decimation\"/>\n"
20958 " </ShowComponentLabels>\n"
20959 " </Hints>\n"
20960 " </DoubleVectorProperty>\n"
20961 " <IntVectorProperty command=\"SetColorByLODIndex\"\n"
20962 " default_values=\"0\"\n"
20963 " label = \"Color By LOD Index\"\n"
20964 " name=\"ColorByLODIndex\"\n"
20965 " number_of_elements=\"1\">\n"
20966 " <BooleanDomain name=\"bool\" />\n"
20967 " <Documentation>When true, each level of detail has its own color based on its index.\n"
20968 " It can be useful to correctly configure the levels of details.</Documentation>\n"
20969 " <Hints>\n"
20970 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
20971 " mode=\"visibility\"\n"
20972 " property=\"UseGlyphCullingAndLOD\"\n"
20973 " value=\"1\" />\n"
20974 " </Hints>\n"
20975 " </IntVectorProperty>\n"
20976 " <!-- end of Glyph3DRepresentation -->\n"
20977 " </RepresentationProxy>\n"
20978 " <!-- ================================================================== -->\n"
20979 " <RepresentationProxy class=\"vtkDataLabelRepresentation\"\n"
20980 " name=\"DataLabelRepresentation\"\n"
20981 " processes=\"client|renderserver|dataserver\">\n"
20982 " <Documentation>Representation used to add labels to points/cells of any\n"
20983 " dataset.</Documentation>\n"
20984 " <InputProperty command=\"SetInputConnection\"\n"
20985 " name=\"Input\">\n"
20986 " <InputArrayDomain name=\"input_array_any\"></InputArrayDomain>\n"
20987 " </InputProperty>\n"
20988 " <IntVectorProperty command=\"SetVisibility\"\n"
20989 " default_values=\"1\"\n"
20990 " name=\"Visibility\"\n"
20991 " number_of_elements=\"1\"\n"
20992 " panel_visibility=\"never\">\n"
20993 " <BooleanDomain name=\"bool\" />\n"
20994 " <Documentation>Set the visibility for this\n"
20995 " representation.</Documentation>\n"
20996 " </IntVectorProperty>\n"
20997 " <DoubleVectorProperty command=\"SetPointLabelColor\"\n"
20998 " default_values=\"1 1 0\"\n"
20999 " name=\"PointLabelColor\"\n"
21000 " number_of_elements=\"3\">\n"
21001 " <DoubleRangeDomain max=\"1 1 1\"\n"
21002 " min=\"0 0 0\"\n"
21003 " name=\"range\" />\n"
21004 " </DoubleVectorProperty>\n"
21005 " <DoubleVectorProperty command=\"SetPointLabelOpacity\"\n"
21006 " default_values=\"1.0\"\n"
21007 " name=\"PointLabelOpacity\"\n"
21008 " number_of_elements=\"1\">\n"
21009 " <DoubleRangeDomain max=\"1.0\"\n"
21010 " min=\"0.0\"\n"
21011 " name=\"range\" />\n"
21012 " </DoubleVectorProperty>\n"
21013 " <IntVectorProperty command=\"SetPointLabelFontFamily\"\n"
21014 " default_values=\"0\"\n"
21015 " name=\"PointLabelFontFamily\"\n"
21016 " number_of_elements=\"1\">\n"
21017 " <EnumerationDomain name=\"enum\">\n"
21018 " <Entry text=\"Arial\"\n"
21019 " value=\"0\" />\n"
21020 " <Entry text=\"Courier\"\n"
21021 " value=\"1\" />\n"
21022 " <Entry text=\"Times\"\n"
21023 " value=\"2\" />\n"
21024 " <Entry text=\"File\"\n"
21025 " value=\"4\" />\n"
21026 " </EnumerationDomain>\n"
21027 " </IntVectorProperty>\n"
21028 " <StringVectorProperty command=\"SetPointLabelFontFile\"\n"
21029 " name=\"PointLabelFontFile\"\n"
21030 " number_of_elements=\"1\"\n"
21031 " default_values=\"\">\n"
21032 " </StringVectorProperty>\n"
21033 " <IntVectorProperty command=\"SetMaximumNumberOfLabels\"\n"
21034 ;
21035
21036 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
21038 " default_values=\"100\"\n"
21039 " name=\"MaximumNumberOfLabels\"\n"
21040 " number_of_elements=\"1\">\n"
21041 " <IntRangeDomain min=\"1\"\n"
21042 " name=\"range\" />\n"
21043 " <Documentation>The maximum number of point labels shown. If the dataset\n"
21044 " contains more points that this number, a random subset of this size is\n"
21045 " chosen and labeled.</Documentation>\n"
21046 " <Hints>\n"
21047 " <PropertyLink group=\"settings\"\n"
21048 " proxy=\"GeneralSettings\"\n"
21049 " property=\"MaximumNumberOfDataRepresentationLabels\"/>\n"
21050 " </Hints>\n"
21051 " </IntVectorProperty>\n"
21052 " <IntVectorProperty command=\"SetPointLabelBold\"\n"
21053 " default_values=\"0\"\n"
21054 " name=\"PointLabelBold\"\n"
21055 " number_of_elements=\"1\">\n"
21056 " <BooleanDomain name=\"bool\" />\n"
21057 " </IntVectorProperty>\n"
21058 " <IntVectorProperty command=\"SetPointLabelItalic\"\n"
21059 " default_values=\"0\"\n"
21060 " name=\"PointLabelItalic\"\n"
21061 " number_of_elements=\"1\">\n"
21062 " <BooleanDomain name=\"bool\" />\n"
21063 " </IntVectorProperty>\n"
21064 " <IntVectorProperty command=\"SetPointLabelShadow\"\n"
21065 " default_values=\"0\"\n"
21066 " name=\"PointLabelShadow\"\n"
21067 " number_of_elements=\"1\">\n"
21068 " <BooleanDomain name=\"bool\" />\n"
21069 " </IntVectorProperty>\n"
21070 " <IntVectorProperty command=\"SetPointLabelFontSize\"\n"
21071 " default_values=\"18\"\n"
21072 " name=\"PointLabelFontSize\"\n"
21073 " number_of_elements=\"1\">\n"
21074 " <IntRangeDomain min=\"0\"\n"
21075 " name=\"range\" />\n"
21076 " </IntVectorProperty>\n"
21077 " <StringVectorProperty command=\"SetPointLabelFormat\"\n"
21078 " default_values=\"\"\n"
21079 " name=\"PointLabelFormat\"\n"
21080 " number_of_elements=\"1\">\n"
21081 " <Documentation>\n"
21082 " This should be a printf-style format string. By default,\n"
21083 " the mapper will try to print each component of the tuple\n"
21084 " using a sane format: d for integers, f for floats, g for\n"
21085 " doubles, ld for longs, et cetera. If you need a different\n"
21086 " format, set it here. You can do things like limit the number\n"
21087 " of significant digits, add prefixes/suffixes, basically\n"
21088 " anything that printf can do. Leave empty to auto select an\n"
21089 " appropriate format.\n"
21090 " </Documentation>\n"
21091 " </StringVectorProperty>\n"
21092 " <IntVectorProperty command=\"SetPointLabelJustification\"\n"
21093 " default_values=\"0\"\n"
21094 " name=\"PointLabelJustification\"\n"
21095 " number_of_elements=\"1\">\n"
21096 " <EnumerationDomain name=\"enum\">\n"
21097 " <Entry text=\"Left\"\n"
21098 " value=\"0\" />\n"
21099 " <Entry text=\"Center\"\n"
21100 " value=\"1\" />\n"
21101 " <Entry text=\"Right\"\n"
21102 " value=\"2\" />\n"
21103 " </EnumerationDomain>\n"
21104 " </IntVectorProperty>\n"
21105 " <IntVectorProperty command=\"SetPointLabelVisibility\"\n"
21106 " default_values=\"0\"\n"
21107 " name=\"PointLabelVisibility\"\n"
21108 " number_of_elements=\"1\">\n"
21109 " <BooleanDomain name=\"bool\" />\n"
21110 " </IntVectorProperty>\n"
21111 " <IntVectorProperty command=\"SetPointLabelMode\"\n"
21112 " default_values=\"6\"\n"
21113 " name=\"PointLabelMode\"\n"
21114 " number_of_elements=\"1\">\n"
21115 " <EnumerationDomain name=\"enum\">\n"
21116 " <Entry text=\"IDs\"\n"
21117 " value=\"0\" />\n"
21118 " <Entry text=\"Scalars\"\n"
21119 " value=\"1\" />\n"
21120 " <Entry text=\"Vectors\"\n"
21121 " value=\"2\" />\n"
21122 " <Entry text=\"Normals\"\n"
21123 " value=\"3\" />\n"
21124 " <Entry text=\"TCoords\"\n"
21125 " value=\"4\" />\n"
21126 " <Entry text=\"Tensors\"\n"
21127 " value=\"5\" />\n"
21128 " <Entry text=\"FieldData\"\n"
21129 " value=\"6\" />\n"
21130 " </EnumerationDomain>\n"
21131 " </IntVectorProperty>\n"
21132 " <StringVectorProperty command=\"SetPointFieldDataArrayName\"\n"
21133 " name=\"PointFieldDataArrayName\"\n"
21134 " number_of_elements=\"1\">\n"
21135 " <ArrayListDomain input_domain_name=\"input_array\"\n"
21136 " name=\"array_list\">\n"
21137 " <RequiredProperties>\n"
21138 " <Property function=\"Input\"\n"
21139 " name=\"Input\" />\n"
21140 " </RequiredProperties>\n"
21141 " </ArrayListDomain>\n"
21142 " </StringVectorProperty>\n"
21143 " <DoubleVectorProperty command=\"SetCellLabelColor\"\n"
21144 " default_values=\"0.0 1.0 0.0\"\n"
21145 " name=\"CellLabelColor\"\n"
21146 " number_of_elements=\"3\">\n"
21147 " <DoubleRangeDomain max=\"1 1 1\"\n"
21148 " min=\"0 0 0\"\n"
21149 " name=\"range\" />\n"
21150 " </DoubleVectorProperty>\n"
21151 " <DoubleVectorProperty command=\"SetCellLabelOpacity\"\n"
21152 " default_values=\"1.0\"\n"
21153 " name=\"CellLabelOpacity\"\n"
21154 " number_of_elements=\"1\">\n"
21155 " <DoubleRangeDomain max=\"1.0\"\n"
21156 " min=\"0.0\"\n"
21157 " name=\"range\" />\n"
21158 " </DoubleVectorProperty>\n"
21159 " <IntVectorProperty command=\"SetCellLabelFontFamily\"\n"
21160 " default_values=\"0\"\n"
21161 " name=\"CellLabelFontFamily\"\n"
21162 " number_of_elements=\"1\">\n"
21163 " <EnumerationDomain name=\"enum\">\n"
21164 " <Entry text=\"Arial\"\n"
21165 " value=\"0\" />\n"
21166 " <Entry text=\"Courier\"\n"
21167 " value=\"1\" />\n"
21168 " <Entry text=\"Times\"\n"
21169 " value=\"2\" />\n"
21170 " <Entry text=\"File\"\n"
21171 " value=\"4\" />\n"
21172 " </EnumerationDomain>\n"
21173 " </IntVectorProperty>\n"
21174 " <StringVectorProperty command=\"SetCellLabelFontFile\"\n"
21175 " name=\"CellLabelFontFile\"\n"
21176 " number_of_elements=\"1\"\n"
21177 " default_values=\"\">\n"
21178 " </StringVectorProperty>\n"
21179 " <IntVectorProperty command=\"SetCellLabelBold\"\n"
21180 " default_values=\"0\"\n"
21181 " name=\"CellLabelBold\"\n"
21182 " number_of_elements=\"1\">\n"
21183 " <BooleanDomain name=\"bool\" />\n"
21184 " </IntVectorProperty>\n"
21185 " <IntVectorProperty command=\"SetCellLabelItalic\"\n"
21186 " default_values=\"0\"\n"
21187 " name=\"CellLabelItalic\"\n"
21188 " number_of_elements=\"1\">\n"
21189 " <BooleanDomain name=\"bool\" />\n"
21190 " </IntVectorProperty>\n"
21191 " <IntVectorProperty command=\"SetCellLabelShadow\"\n"
21192 " default_values=\"0\"\n"
21193 " name=\"CellLabelShadow\"\n"
21194 " number_of_elements=\"1\">\n"
21195 " <BooleanDomain name=\"bool\" />\n"
21196 " </IntVectorProperty>\n"
21197 " <IntVectorProperty command=\"SetCellLabelFontSize\"\n"
21198 " default_values=\"18\"\n"
21199 " name=\"CellLabelFontSize\"\n"
21200 " number_of_elements=\"1\">\n"
21201 " <IntRangeDomain min=\"0\"\n"
21202 " name=\"range\" />\n"
21203 " </IntVectorProperty>\n"
21204 " <StringVectorProperty command=\"SetCellLabelFormat\"\n"
21205 " default_values=\"\"\n"
21206 " name=\"CellLabelFormat\"\n"
21207 " number_of_elements=\"1\">\n"
21208 " <Documentation>\n"
21209 " This should be a printf-style format string. By default,\n"
21210 " the mapper will try to print each component of the tuple\n"
21211 " using a sane format: d for integers, f for floats, g for\n"
21212 " doubles, ld for longs, et cetera. If you need a different\n"
21213 " format, set it here. You can do things like limit the number\n"
21214 " of significant digits, add prefixes/suffixes, basically\n"
21215 " anything that printf can do. Leave empty to auto select an\n"
21216 " appropriate format.\n"
21217 " </Documentation>\n"
21218 " </StringVectorProperty>\n"
21219 " <IntVectorProperty command=\"SetCellLabelJustification\"\n"
21220 " default_values=\"0\"\n"
21221 " name=\"CellLabelJustification\"\n"
21222 " number_of_elements=\"1\">\n"
21223 " <EnumerationDomain name=\"enum\">\n"
21224 " <Entry text=\"Left\"\n"
21225 " value=\"0\" />\n"
21226 " <Entry text=\"Center\"\n"
21227 " value=\"1\" />\n"
21228 " <Entry text=\"Right\"\n"
21229 " value=\"2\" />\n"
21230 " </EnumerationDomain>\n"
21231 " </IntVectorProperty>\n"
21232 " <IntVectorProperty command=\"SetCellLabelVisibility\"\n"
21233 " default_values=\"0\"\n"
21234 " name=\"CellLabelVisibility\"\n"
21235 " number_of_elements=\"1\">\n"
21236 " <BooleanDomain name=\"bool\" />\n"
21237 " </IntVectorProperty>\n"
21238 " <IntVectorProperty command=\"SetCellLabelMode\"\n"
21239 " default_values=\"6\"\n"
21240 " name=\"CellLabelMode\"\n"
21241 " number_of_elements=\"1\">\n"
21242 " <EnumerationDomain name=\"enum\">\n"
21243 " <Entry text=\"IDs\"\n"
21244 " value=\"0\" />\n"
21245 " <Entry text=\"Scalars\"\n"
21246 " value=\"1\" />\n"
21247 " <Entry text=\"Vectors\"\n"
21248 " value=\"2\" />\n"
21249 " <Entry text=\"Normals\"\n"
21250 " value=\"3\" />\n"
21251 " <Entry text=\"TCoords\"\n"
21252 " value=\"4\" />\n"
21253 " <Entry text=\"Tensors\"\n"
21254 " value=\"5\" />\n"
21255 " <Entry text=\"FieldData\"\n"
21256 " value=\"6\" />\n"
21257 " </EnumerationDomain>\n"
21258 " </IntVectorProperty>\n"
21259 " <StringVectorProperty command=\"SetCellFieldDataArrayName\"\n"
21260 " name=\"CellFieldDataArrayName\"\n"
21261 " number_of_elements=\"1\">\n"
21262 " <ArrayListDomain input_domain_name=\"input_array\"\n"
21263 " name=\"array_list\">\n"
21264 " <RequiredProperties>\n"
21265 " <Property function=\"Input\"\n"
21266 " name=\"Input\" />\n"
21267 " </RequiredProperties>\n"
21268 " </ArrayListDomain>\n"
21269 " </StringVectorProperty>\n"
21270 " <!-- End of DataLabelRepresentation -->\n"
21271 " </RepresentationProxy>\n"
21272 " <!-- ================================================================== -->\n"
21273 " <RepresentationProxy class=\"vtkSelectionRepresentation\"\n"
21274 " name=\"SelectionRepresentation\"\n"
21275 " processes=\"client|renderserver|dataserver\"\n"
21276 " si_class=\"vtkSIProxy\">\n"
21277 " <Documentation>Proxy to show a selection as geometry.</Documentation>\n"
21278 " <InputProperty command=\"SetInputConnection\"\n"
21279 " name=\"Input\">\n"
21280 " <InputArrayDomain name=\"input_array_any\"></InputArrayDomain>\n"
21281 " </InputProperty>\n"
21282 " <IntVectorProperty command=\"SetVisibility\"\n"
21283 " default_values=\"1\"\n"
21284 " name=\"Visibility\"\n"
21285 " number_of_elements=\"1\">\n"
21286 " <BooleanDomain name=\"bool\" />\n"
21287 " <Documentation>Get/Set the visibility of the\n"
21288 " representation.</Documentation>\n"
21289 " </IntVectorProperty>\n"
21290 " <IntVectorProperty command=\"SetForceUseCache\"\n"
21291 " default_values=\"0\"\n"
21292 " is_internal=\"1\"\n"
21293 " name=\"ForceUseCache\"\n"
21294 " number_of_elements=\"1\">\n"
21295 " <BooleanDomain name=\"bool\" />\n"
21296 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21297 " and representations cache based on what the view tells it. However in\n"
21298 " some cases we may want to force a representation to cache irrespective\n"
21299 " of the view (e.g. comparative views). In which case these ivars can up\n"
21300 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21301 " Instead, ForcedCacheKey is used.</Documentation>\n"
21302 " </IntVectorProperty>\n"
21303 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
21304 " default_values=\"none\"\n"
21305 " is_internal=\"1\"\n"
21306 " name=\"ForcedCacheKey\"\n"
21307 " number_of_elements=\"1\">\n"
21308 " <DoubleRangeDomain name=\"range\" />\n"
21309 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21310 " and representations cache based on what the view tells it. However in\n"
21311 " some cases we may want to force a representation to cache irrespective\n"
21312 " of the view (e.g. comparative views). In which case these ivars can up\n"
21313 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21314 " Instead, ForcedCacheKey is used.</Documentation>\n"
21315 " </DoubleVectorProperty>\n"
21316 " <DoubleVectorProperty command=\"SetColor\"\n"
21317 " default_values=\"1.0 0.0 1.0\"\n"
21318 " name=\"Color\"\n"
21319 " number_of_elements=\"3\">\n"
21320 " <DoubleRangeDomain max=\"1 1 1\"\n"
21321 " min=\"0 0 0\"\n"
21322 " name=\"range\" />\n"
21323 " <Hints>\n"
21324 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SelectionColor\" unlink_if_modified=\"1\" />\n"
21325 " </Hints>\n"
21326 " </DoubleVectorProperty>\n"
21327 " <DoubleVectorProperty command=\"SetLineWidth\"\n"
21328 " default_values=\"2.0\"\n"
21329 " name=\"LineWidth\"\n"
21330 " number_of_elements=\"1\">\n"
21331 " <DoubleRangeDomain min=\"0\"\n"
21332 " name=\"range\" />\n"
21333 " </DoubleVectorProperty>\n"
21334 " <DoubleVectorProperty command=\"SetOpacity\"\n"
21335 " default_values=\"1\"\n"
21336 " name=\"Opacity\"\n"
21337 " number_of_elements=\"1\">\n"
21338 " <DoubleRangeDomain max=\"1\"\n"
21339 " min=\"0\"\n"
21340 " name=\"range\" />\n"
21341 " </DoubleVectorProperty>\n"
21342 " <DoubleVectorProperty command=\"SetPointSize\"\n"
21343 " default_values=\"5.0\"\n"
21344 " name=\"PointSize\"\n"
21345 " number_of_elements=\"1\">\n"
21346 " <DoubleRangeDomain min=\"0\"\n"
21347 " name=\"range\" />\n"
21348 " </DoubleVectorProperty>\n"
21349 " <IntVectorProperty command=\"SetRenderLinesAsTubes\"\n"
21350 " default_values=\"0\"\n"
21351 " name=\"RenderLinesAsTubes\"\n"
21352 " number_of_elements=\"1\">\n"
21353 " <BooleanDomain name=\"bool\" />\n"
21354 " <Documentation>\n"
21355 " When set, all lines are rendered as 3D tubes, if supported by OpenGL driver.\n"
21356 " </Documentation>\n"
21357 " </IntVectorProperty>\n"
21358 " <IntVectorProperty command=\"SetRenderPointsAsSpheres\"\n"
21359 " default_values=\"0\"\n"
21360 " name=\"RenderPointsAsSpheres\"\n"
21361 ;
21362
21363 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
21365 " number_of_elements=\"1\">\n"
21366 " <BooleanDomain name=\"bool\" />\n"
21367 " <Documentation>\n"
21368 " When set, all points are rendered as 3D spheres, if supported by OpenGL driver.\n"
21369 " </Documentation>\n"
21370 " </IntVectorProperty>\n"
21371 " <IntVectorProperty command=\"SetRepresentation\"\n"
21372 " default_values=\"1\"\n"
21373 " name=\"Representation\"\n"
21374 " panel_widget=\"display_representation_selector\"\n"
21375 " number_of_elements=\"1\">\n"
21376 " <EnumerationDomain name=\"enum\">\n"
21377 " <Entry text=\"Points\"\n"
21378 " value=\"0\" />\n"
21379 " <Entry text=\"Wireframe\"\n"
21380 " value=\"1\" />\n"
21381 " <Entry text=\"Surface\"\n"
21382 " value=\"2\" />\n"
21383 " </EnumerationDomain>\n"
21384 " </IntVectorProperty>\n"
21385 " <IntVectorProperty command=\"SetUseOutline\"\n"
21386 " default_values=\"0\"\n"
21387 " name=\"UseOutline\"\n"
21388 " number_of_elements=\"1\">\n"
21389 " <BooleanDomain name=\"bool\" />\n"
21390 " </IntVectorProperty>\n"
21391 " <DoubleVectorProperty command=\"SetPosition\"\n"
21392 " default_values=\"0 0 0\"\n"
21393 " name=\"Position\"\n"
21394 " number_of_elements=\"3\">\n"
21395 " <DoubleRangeDomain name=\"range\" />\n"
21396 " </DoubleVectorProperty>\n"
21397 " <DoubleVectorProperty command=\"SetScale\"\n"
21398 " default_values=\"1 1 1\"\n"
21399 " name=\"Scale\"\n"
21400 " number_of_elements=\"3\">\n"
21401 " <DoubleRangeDomain name=\"range\" />\n"
21402 " </DoubleVectorProperty>\n"
21403 " <DoubleVectorProperty command=\"SetOrientation\"\n"
21404 " default_values=\"0 0 0\"\n"
21405 " name=\"Orientation\"\n"
21406 " number_of_elements=\"3\">\n"
21407 " <DoubleRangeDomain name=\"range\" />\n"
21408 " </DoubleVectorProperty>\n"
21409 " <DoubleVectorProperty command=\"SetOrigin\"\n"
21410 " default_values=\"0 0 0\"\n"
21411 " name=\"Origin\"\n"
21412 " number_of_elements=\"3\">\n"
21413 " <DoubleRangeDomain name=\"range\" />\n"
21414 " </DoubleVectorProperty>\n"
21415 "\n"
21416 " <DoubleVectorProperty argument_is_array=\"1\"\n"
21417 " command=\"SetUserTransform\"\n"
21418 " default_values=\"1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1\"\n"
21419 " name=\"UserTransform\"\n"
21420 " number_of_elements=\"16\">\n"
21421 " <Documentation>\n"
21422 " In addition to the instance variables such as position and\n"
21423 " orientation, you can add an additional transformation for your own\n"
21424 " use. This transformation is concatenated with the actor's internal\n"
21425 " transformation, which you implicitly create through the use of\n"
21426 " Position, Origin, Orientation. The value is 4x4 matrix for the linear\n"
21427 " transform to use.\n"
21428 " </Documentation>\n"
21429 " </DoubleVectorProperty>\n"
21430 "\n"
21431 " <SubProxy command=\"SetLabelRepresentation\">\n"
21432 " <Proxy name=\"LabelRepresentation\"\n"
21433 " proxygroup=\"representations\"\n"
21434 " proxyname=\"DataLabelRepresentation\" />\n"
21435 " <ExposedProperties>\n"
21436 " <Property name=\"CellFieldDataArrayName\" />\n"
21437 " <Property name=\"CellLabelBold\" />\n"
21438 " <Property name=\"CellLabelColor\" />\n"
21439 " <Property name=\"CellLabelFontFamily\" />\n"
21440 " <Property name=\"CellLabelFontFile\" />\n"
21441 " <Property name=\"CellLabelFontSize\" />\n"
21442 " <Property name=\"CellLabelFormat\" />\n"
21443 " <Property name=\"CellLabelItalic\" />\n"
21444 " <Property name=\"CellLabelJustification\" />\n"
21445 " <Property name=\"CellLabelOpacity\" />\n"
21446 " <Property name=\"CellLabelShadow\" />\n"
21447 " <Property name=\"CellLabelVisibility\" />\n"
21448 " <Property name=\"PointFieldDataArrayName\" />\n"
21449 " <Property name=\"PointLabelBold\" />\n"
21450 " <Property name=\"PointLabelColor\" />\n"
21451 " <Property name=\"PointLabelFontFamily\" />\n"
21452 " <Property name=\"PointLabelFontFile\" />\n"
21453 " <Property name=\"PointLabelFontSize\" />\n"
21454 " <Property name=\"PointLabelFormat\" />\n"
21455 " <Property name=\"PointLabelItalic\" />\n"
21456 " <Property name=\"PointLabelJustification\" />\n"
21457 " <Property name=\"PointLabelOpacity\" />\n"
21458 " <Property name=\"PointLabelShadow\" />\n"
21459 " <Property name=\"PointLabelVisibility\" />\n"
21460 " <Property name=\"MaximumNumberOfLabels\" />\n"
21461 " </ExposedProperties>\n"
21462 " </SubProxy>\n"
21463 "\n"
21464 " <PropertyGroup label=\"Cell Label Font\" panel_visibility=\"never\" panel_widget=\"FontEditor\">\n"
21465 " <Property name=\"CellLabelBold\" function=\"Bold\"/>\n"
21466 " <Property name=\"CellLabelColor\" function=\"Color\"/>\n"
21467 " <Property name=\"CellLabelFontFamily\" function=\"Family\"/>\n"
21468 " <Property name=\"CellLabelFontFile\" function=\"File\"/>\n"
21469 " <Property name=\"CellLabelFontSize\" function=\"Size\"/>\n"
21470 " <Property name=\"CellLabelItalic\" function=\"Italics\"/>\n"
21471 " <Property name=\"CellLabelJustification\" function=\"Justification\"/>\n"
21472 " <Property name=\"CellLabelOpacity\" function=\"Opacity\"/>\n"
21473 " <Property name=\"CellLabelShadow\" function=\"Shadow\"/>\n"
21474 " </PropertyGroup>\n"
21475 "\n"
21476 " <PropertyGroup label=\"Point Label Font\" panel_visibility=\"never\" panel_widget=\"FontEditor\">\n"
21477 " <Property name=\"PointLabelBold\" function=\"Bold\"/>\n"
21478 " <Property name=\"PointLabelColor\" function=\"Color\"/>\n"
21479 " <Property name=\"PointLabelFontFamily\" function=\"Family\"/>\n"
21480 " <Property name=\"PointLabelFontFile\" function=\"File\"/>\n"
21481 " <Property name=\"PointLabelFontSize\" function=\"Size\"/>\n"
21482 " <Property name=\"PointLabelItalic\" function=\"Italics\"/>\n"
21483 " <Property name=\"PointLabelJustification\" function=\"Justification\"/>\n"
21484 " <Property name=\"PointLabelOpacity\" function=\"Opacity\"/>\n"
21485 " <Property name=\"PointLabelShadow\" function=\"Shadow\"/>\n"
21486 " </PropertyGroup>\n"
21487 " <!-- End of SelectionRepresentation -->\n"
21488 " </RepresentationProxy>\n"
21489 " <!-- ================================================================== -->\n"
21490 " <RepresentationProxy class=\"vtkPVGridAxes3DRepresentation\"\n"
21491 " name=\"GridAxesRepresentation\"\n"
21492 " processes=\"client|renderserver|dataserver\"\n"
21493 " si_class=\"vtkSIProxy\">\n"
21494 " <Documentation>Proxy to show a selection as geometry.</Documentation>\n"
21495 " <InputProperty command=\"SetInputConnection\"\n"
21496 " name=\"Input\">\n"
21497 " <InputArrayDomain name=\"input_array_any\"></InputArrayDomain>\n"
21498 " </InputProperty>\n"
21499 " <IntVectorProperty command=\"SetForceUseCache\"\n"
21500 " default_values=\"0\"\n"
21501 " is_internal=\"1\"\n"
21502 " name=\"ForceUseCache\"\n"
21503 " number_of_elements=\"1\">\n"
21504 " <BooleanDomain name=\"bool\" />\n"
21505 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21506 " and representations cache based on what the view tells it. However in\n"
21507 " some cases we may want to force a representation to cache irrespective\n"
21508 " of the view (e.g. comparative views). In which case these ivars can up\n"
21509 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21510 " Instead, ForcedCacheKey is used.</Documentation>\n"
21511 " </IntVectorProperty>\n"
21512 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
21513 " default_values=\"none\"\n"
21514 " is_internal=\"1\"\n"
21515 " name=\"ForcedCacheKey\"\n"
21516 " number_of_elements=\"1\">\n"
21517 " <DoubleRangeDomain name=\"range\" />\n"
21518 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21519 " and representations cache based on what the view tells it. However in\n"
21520 " some cases we may want to force a representation to cache irrespective\n"
21521 " of the view (e.g. comparative views). In which case these ivars can up\n"
21522 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21523 " Instead, ForcedCacheKey is used.</Documentation>\n"
21524 " </DoubleVectorProperty>\n"
21525 " <IntVectorProperty command=\"SetGridAxesVisibility\"\n"
21526 " name=\"GridAxesVisibility\"\n"
21527 " default_values=\"0\"\n"
21528 " panel_visibility=\"never\"\n"
21529 " number_of_elements=\"1\">\n"
21530 " <BooleanDomain name=\"bool\" />\n"
21531 " <Documentation>Show/hide an Axes Grid around the selected data.</Documentation>\n"
21532 " </IntVectorProperty>\n"
21533 " <DoubleVectorProperty command=\"SetPosition\"\n"
21534 " default_values=\"0 0 0\"\n"
21535 " name=\"Position\"\n"
21536 " panel_visibility=\"never\"\n"
21537 " number_of_elements=\"3\">\n"
21538 " <DoubleRangeDomain name=\"range\" />\n"
21539 " <Documentation>Keeps axes synced with actor transforms.</Documentation>\n"
21540 " </DoubleVectorProperty>\n"
21541 " <DoubleVectorProperty command=\"SetScale\"\n"
21542 " default_values=\"1 1 1\"\n"
21543 " name=\"Scale\"\n"
21544 " panel_visibility=\"never\"\n"
21545 " number_of_elements=\"3\">\n"
21546 " <DoubleRangeDomain name=\"range\" />\n"
21547 " <Documentation>Keeps axes synced with actor transforms.</Documentation>\n"
21548 " </DoubleVectorProperty>\n"
21549 " <Hints>\n"
21550 " <ProxyList>\n"
21551 " <Link name=\"Scale\" with_property=\"Scale\" />\n"
21552 " <Link name=\"Position\" with_property=\"Position\" />\n"
21553 " </ProxyList>\n"
21554 " </Hints>\n"
21555 "\n"
21556 " <SubProxy command=\"SetGridAxes\">\n"
21557 " <Proxy name=\"GridAxes\"\n"
21558 " proxygroup=\"annotations\"\n"
21559 " proxyname=\"GridAxes3DActor\" />\n"
21560 " <ExposedProperties>\n"
21561 " <PropertyGroup label=\"Title Texts\">\n"
21562 " <Property name=\"XTitle\"/>\n"
21563 " <Property name=\"YTitle\"/>\n"
21564 " <Property name=\"ZTitle\"/>\n"
21565 " </PropertyGroup>\n"
21566 " <PropertyGroup label=\"X Title Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
21567 " <Property name=\"XTitleColor\" function=\"Color\"/>\n"
21568 " <Property name=\"XTitleFontFamily\" function=\"Family\"/>\n"
21569 " <Property name=\"XTitleFontFile\" function=\"File\"/>\n"
21570 " <Property name=\"XTitleBold\" function=\"Bold\" />\n"
21571 " <Property name=\"XTitleItalic\" function=\"Italics\"/>\n"
21572 " <Property name=\"XTitleFontSize\" function=\"Size\" />\n"
21573 " <Property name=\"XTitleShadow\" function=\"Shadow\" />\n"
21574 " <Property name=\"XTitleOpacity\" function=\"Opacity\" />\n"
21575 " </PropertyGroup>\n"
21576 " <PropertyGroup label=\"Y Title Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
21577 " <Property name=\"YTitleColor\" function=\"Color\"/>\n"
21578 " <Property name=\"YTitleFontFamily\" function=\"Family\"/>\n"
21579 " <Property name=\"YTitleFontFile\" function=\"File\"/>\n"
21580 " <Property name=\"YTitleBold\" function=\"Bold\" />\n"
21581 " <Property name=\"YTitleItalic\" function=\"Italics\"/>\n"
21582 " <Property name=\"YTitleFontSize\" function=\"Size\" />\n"
21583 " <Property name=\"YTitleShadow\" function=\"Shadow\" />\n"
21584 " <Property name=\"YTitleOpacity\" function=\"Opacity\" />\n"
21585 " </PropertyGroup>\n"
21586 " <PropertyGroup label=\"Z Title Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
21587 " <Property name=\"ZTitleColor\" function=\"Color\"/>\n"
21588 " <Property name=\"ZTitleFontFamily\" function=\"Family\"/>\n"
21589 " <Property name=\"ZTitleFontFile\" function=\"File\"/>\n"
21590 " <Property name=\"ZTitleBold\" function=\"Bold\" />\n"
21591 " <Property name=\"ZTitleItalic\" function=\"Italics\"/>\n"
21592 " <Property name=\"ZTitleFontSize\" function=\"Size\" />\n"
21593 " <Property name=\"ZTitleShadow\" function=\"Shadow\" />\n"
21594 " <Property name=\"ZTitleOpacity\" function=\"Opacity\" />\n"
21595 " </PropertyGroup>\n"
21596 " <PropertyGroup label=\"Face Properties\">\n"
21597 " <Property name=\"FacesToRender\" />\n"
21598 " <Property name=\"CullBackface\" />\n"
21599 " <Property name=\"CullFrontface\" />\n"
21600 " <Property name=\"GridColor\"/>\n"
21601 " </PropertyGroup>\n"
21602 " <Property name=\"ShowGrid\"/>\n"
21603 " <Property name=\"ShowEdges\"/>\n"
21604 " <Property name=\"ShowTicks\"/>\n"
21605 " <PropertyGroup label=\"Label Properties\">\n"
21606 " <Property name=\"LabelUniqueEdgesOnly\" />\n"
21607 " <Property name=\"AxesToLabel\" />\n"
21608 " </PropertyGroup>\n"
21609 " <PropertyGroup label=\"X Axis Label Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
21610 " <Property name=\"XLabelColor\" function=\"Color\"/>\n"
21611 " <Property name=\"XLabelFontFamily\" function=\"Family\"/>\n"
21612 " <Property name=\"XLabelFontFile\" function=\"File\"/>\n"
21613 " <Property name=\"XLabelBold\" function=\"Bold\" />\n"
21614 " <Property name=\"XLabelItalic\" function=\"Italics\"/>\n"
21615 " <Property name=\"XLabelFontSize\" function=\"Size\" />\n"
21616 " <Property name=\"XLabelShadow\" function=\"Shadow\" />\n"
21617 " <Property name=\"XLabelOpacity\" function=\"Opacity\" />\n"
21618 " </PropertyGroup>\n"
21619 " <PropertyGroup label=\"Y Axis Label Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
21620 " <Property name=\"YLabelColor\" function=\"Color\"/>\n"
21621 " <Property name=\"YLabelFontFamily\" function=\"Family\"/>\n"
21622 " <Property name=\"YLabelFontFile\" function=\"File\"/>\n"
21623 " <Property name=\"YLabelBold\" function=\"Bold\" />\n"
21624 " <Property name=\"YLabelItalic\" function=\"Italics\"/>\n"
21625 " <Property name=\"YLabelFontSize\" function=\"Size\" />\n"
21626 " <Property name=\"YLabelShadow\" function=\"Shadow\" />\n"
21627 " <Property name=\"YLabelOpacity\" function=\"Opacity\" />\n"
21628 " </PropertyGroup>\n"
21629 " <PropertyGroup label=\"Z Axis Label Font Properties\" panel_widget=\"FontEditor\" panel_visibility=\"advanced\">\n"
21630 " <Property name=\"ZLabelColor\" function=\"Color\"/>\n"
21631 " <Property name=\"ZLabelFontFamily\" function=\"Family\"/>\n"
21632 " <Property name=\"ZLabelFontFile\" function=\"File\"/>\n"
21633 " <Property name=\"ZLabelBold\" function=\"Bold\" />\n"
21634 " <Property name=\"ZLabelItalic\" function=\"Italics\"/>\n"
21635 " <Property name=\"ZLabelFontSize\" function=\"Size\" />\n"
21636 " <Property name=\"ZLabelShadow\" function=\"Shadow\" />\n"
21637 " <Property name=\"ZLabelOpacity\" function=\"Opacity\" />\n"
21638 " </PropertyGroup>\n"
21639 " <PropertyGroup label=\"X Axis Label Properties\">\n"
21640 " <Property name=\"XAxisNotation\" />\n"
21641 " <Property name=\"XAxisPrecision\" />\n"
21642 " <Property name=\"XAxisUseCustomLabels\" />\n"
21643 " <Property name=\"XAxisLabels\" />\n"
21644 ;
21645
21646 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
21648 " </PropertyGroup>\n"
21649 " <PropertyGroup label=\"Y Axis Label Properties\">\n"
21650 " <Property name=\"YAxisNotation\" />\n"
21651 " <Property name=\"YAxisPrecision\" />\n"
21652 " <Property name=\"YAxisUseCustomLabels\" />\n"
21653 " <Property name=\"YAxisLabels\" />\n"
21654 " </PropertyGroup>\n"
21655 " <PropertyGroup label=\"Z Axis Label Properties\">\n"
21656 " <Property name=\"ZAxisNotation\" />\n"
21657 " <Property name=\"ZAxisPrecision\" />\n"
21658 " <Property name=\"ZAxisUseCustomLabels\" />\n"
21659 " <Property name=\"ZAxisLabels\" />\n"
21660 " </PropertyGroup>\n"
21661 " <PropertyGroup label=\"Bounds\">\n"
21662 " <Property name=\"UseCustomBounds\" />\n"
21663 " <Property name=\"CustomBounds\" />\n"
21664 " </PropertyGroup>\n"
21665 " </ExposedProperties>\n"
21666 " </SubProxy>\n"
21667 " <!-- End of GridAxesRepresentation -->\n"
21668 " </RepresentationProxy>\n"
21669 " <!-- ================================================================== -->\n"
21670 " <RepresentationProxy class=\"vtkMoleculeRepresentation\"\n"
21671 " name=\"MoleculeRepresentation\"\n"
21672 " processes=\"client|renderserver|dataserver\">\n"
21673 " <Documentation>Representation for a vtkMolecule.</Documentation>\n"
21674 " <InputProperty command=\"SetInputConnection\"\n"
21675 " name=\"Input\">\n"
21676 " <DataTypeDomain name=\"input_type\">\n"
21677 " <DataType value=\"vtkMolecule\" />\n"
21678 " </DataTypeDomain>\n"
21679 " <Documentation>Set the input molecule for the\n"
21680 " representation.</Documentation>\n"
21681 " <InputArrayDomain attribute_type=\"vertex\"\n"
21682 " name=\"input_array\"\n"
21683 " optional=\"1\" />\n"
21684 " </InputProperty>\n"
21685 " <IntVectorProperty command=\"SetVisibility\"\n"
21686 " default_values=\"1\"\n"
21687 " name=\"Visibility\"\n"
21688 " number_of_elements=\"1\"\n"
21689 " panel_visibility=\"never\">\n"
21690 " <BooleanDomain name=\"bool\" />\n"
21691 " <Documentation>Set the visibility for this\n"
21692 " representation.</Documentation>\n"
21693 " </IntVectorProperty>\n"
21694 " <DoubleVectorProperty command=\"SetOpacity\"\n"
21695 " default_values=\"1.0\"\n"
21696 " name=\"Opacity\"\n"
21697 " number_of_elements=\"1\">\n"
21698 " <DoubleRangeDomain max=\"1\" min=\"0\" name=\"range\" />\n"
21699 " <Documentation>\n"
21700 " The opacity to use when rendering the model.\n"
21701 " </Documentation>\n"
21702 " </DoubleVectorProperty>\n"
21703 " <DoubleVectorProperty command=\"SetSpecular\"\n"
21704 " default_values=\"0.0\"\n"
21705 " name=\"Specular\"\n"
21706 " number_of_elements=\"1\">\n"
21707 " <DoubleRangeDomain max=\"1\" min=\"0\" name=\"range\" />\n"
21708 " <Documentation>\n"
21709 " The specularity to use when rendering the model.\n"
21710 " </Documentation>\n"
21711 " </DoubleVectorProperty>\n"
21712 " <DoubleVectorProperty command=\"SetSpecularPower\"\n"
21713 " default_values=\"100.0\"\n"
21714 " name=\"SpecularPower\"\n"
21715 " number_of_elements=\"1\">\n"
21716 " <DoubleRangeDomain max=\"100\" min=\"0\" name=\"range\" />\n"
21717 " <Documentation>\n"
21718 " The specularity to use when rendering the model.\n"
21719 " </Documentation>\n"
21720 " </DoubleVectorProperty>\n"
21721 " <IntVectorProperty command=\"SetMapScalars\"\n"
21722 " default_values=\"1\"\n"
21723 " name=\"MapScalars\"\n"
21724 " number_of_elements=\"1\">\n"
21725 " <BooleanDomain name=\"bool\" />\n"
21726 " <Documentation>When enabled, LookupTable will always be\n"
21727 " used for scalar mapping. Otherwise, when up to 4 component\n"
21728 " scalars are present, the components are clamped to a valid\n"
21729 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
21730 " floating point type) and then directly used as\n"
21731 " color.</Documentation>\n"
21732 " </IntVectorProperty>\n"
21733 " <IntVectorProperty command=\"SetRenderAtoms\"\n"
21734 " default_values=\"1\"\n"
21735 " name=\"RenderAtoms\"\n"
21736 " number_of_elements=\"1\">\n"
21737 " <BooleanDomain name=\"bool\" />\n"
21738 " <Documentation>Set the visibility for the atoms.</Documentation>\n"
21739 " </IntVectorProperty>\n"
21740 " <DoubleVectorProperty command=\"SetAtomicRadiusScaleFactor\"\n"
21741 " default_values=\"0.3\"\n"
21742 " name=\"AtomicRadiusFactor\"\n"
21743 " number_of_elements=\"1\">\n"
21744 " <DoubleRangeDomain max=\"3\" min=\"0\" name=\"range\" />\n"
21745 " <Documentation>The scale factor to apply on atom radius. Radius is expected to be in Angstrom. </Documentation>\n"
21746 " </DoubleVectorProperty>\n"
21747 " <IntVectorProperty command=\"SetAtomicRadiusType\"\n"
21748 " default_values=\"1\"\n"
21749 " label=\"Atomic Radius Type\"\n"
21750 " name=\"AtomicRadiusType\"\n"
21751 " number_of_elements=\"1\"\n"
21752 " panel_visibility=\"advanced\">\n"
21753 " <EnumerationDomain name=\"enum\">\n"
21754 " <Entry text=\"Covalent\"\n"
21755 " value=\"0\" />\n"
21756 " <Entry text=\"Van Der Waals\"\n"
21757 " value=\"1\" />\n"
21758 " <Entry text=\"Unit\"\n"
21759 " value=\"2\" />\n"
21760 " <Entry text=\"Input Array\"\n"
21761 " value=\"3\" />\n"
21762 " </EnumerationDomain>\n"
21763 " <Documentation>The radius type to use.</Documentation>\n"
21764 " </IntVectorProperty>\n"
21765 " <StringVectorProperty name=\"AtomicRadiusArrayName\"\n"
21766 " command=\"SetAtomicRadiusArray\"\n"
21767 " number_of_elements=\"1\"\n"
21768 " label=\"Atomic Radii Array\"\n"
21769 " panel_visibility=\"advanced\">\n"
21770 " <ArrayListDomain input_domain_name=\"input_array\"\n"
21771 " attribute_type=\"Scalars\"\n"
21772 " name=\"array_list\">\n"
21773 " <RequiredProperties>\n"
21774 " <Property name=\"Input\" function=\"Input\"/>\n"
21775 " </RequiredProperties>\n"
21776 " </ArrayListDomain>\n"
21777 " <Documentation>This property specifies the name of the input array to use for atom radii. Values are expected to be in Angstrom.\n"
21778 " </Documentation>\n"
21779 " </StringVectorProperty>\n"
21780 " <IntVectorProperty command=\"SetRenderBonds\"\n"
21781 " default_values=\"1\"\n"
21782 " name=\"RenderBonds\"\n"
21783 " number_of_elements=\"1\">\n"
21784 " <BooleanDomain name=\"bool\" />\n"
21785 " <Documentation>Set the visibility for the bonds.</Documentation>\n"
21786 " </IntVectorProperty>\n"
21787 " <DoubleVectorProperty command=\"SetBondRadius\"\n"
21788 " default_values=\"0.075\"\n"
21789 " name=\"BondRadius\"\n"
21790 " number_of_elements=\"1\">\n"
21791 " <DoubleRangeDomain max=\"0.5\" min=\"0\" name=\"range\" />\n"
21792 " <Documentation>The bond radius, in Angstrom. </Documentation>\n"
21793 " </DoubleVectorProperty>\n"
21794 " <IntVectorProperty command=\"SetUseMultiCylindersForBonds\"\n"
21795 " default_values=\"1\"\n"
21796 " name=\"MultiCylindersForBonds\"\n"
21797 " number_of_elements=\"1\">\n"
21798 " <BooleanDomain name=\"bool\" />\n"
21799 " <Documentation>Display multiple cylinders for high bond order.</Documentation>\n"
21800 " </IntVectorProperty>\n"
21801 " <IntVectorProperty command=\"SetBondColorMode\"\n"
21802 " default_values=\"1\"\n"
21803 " name=\"BondColorMode\"\n"
21804 " number_of_elements=\"1\">\n"
21805 " <BooleanDomain name=\"bool\" />\n"
21806 " <Documentation>Use atom color for bonds. If disabled, use the custom bond color.</Documentation>\n"
21807 " </IntVectorProperty>\n"
21808 " <DoubleVectorProperty command=\"SetBondColor\"\n"
21809 " default_values=\"1 1 1\"\n"
21810 " name=\"BondColor\"\n"
21811 " number_of_elements=\"3\"\n"
21812 " panel_widget=\"color_selector\"\n"
21813 " panel_visibility=\"default\">\n"
21814 " <Documentation>Sets the color for the bonds.</Documentation>\n"
21815 " </DoubleVectorProperty>\n"
21816 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
21817 " element_types=\"0 0 0 0 2\"\n"
21818 " name=\"ColorArrayName\"\n"
21819 " no_custom_default=\"1\"\n"
21820 " default_values_delimiter=\";\"\n"
21821 " default_values=\"0;0;0;4;Atomic Numbers\"\n"
21822 " panel_visibility=\"never\"\n"
21823 " number_of_elements=\"5\">\n"
21824 " <Documentation>\n"
21825 " Set the array to color with. One must specify the field association and\n"
21826 " the array name of the array. If the array is missing, scalar coloring will\n"
21827 " automatically be disabled.\n"
21828 " </Documentation>\n"
21829 " <RepresentedArrayListDomain name=\"array_list\">\n"
21830 " <RequiredProperties>\n"
21831 " <Property function=\"Input\" name=\"Input\" />\n"
21832 " </RequiredProperties>\n"
21833 " </RepresentedArrayListDomain>\n"
21834 " </StringVectorProperty>\n"
21835 " <ProxyProperty command=\"SetLookupTable\"\n"
21836 " name=\"LookupTable\" >\n"
21837 " <Documentation>Set the lookup-table to use to map data array to colors.\n"
21838 " Lookuptable is only used with MapScalars to ON.</Documentation>\n"
21839 " <ProxyGroupDomain name=\"groups\">\n"
21840 " <Group name=\"lookup_tables\" />\n"
21841 " </ProxyGroupDomain>\n"
21842 " </ProxyProperty>\n"
21843 " <!-- End of MoleculeRepresentation -->\n"
21844 " </RepresentationProxy>\n"
21845 " <PVMoleculeRepresentationProxy class=\"vtkPVCompositeRepresentation\"\n"
21846 " name=\"PVMoleculeRepresentation\"\n"
21847 " processes=\"client|renderserver|dataserver\">\n"
21848 " <Documentation>PVRepresentationProxy for vtkMolecule.</Documentation>\n"
21849 " <IntVectorProperty command=\"SetVisibility\"\n"
21850 " default_values=\"1\"\n"
21851 " name=\"Visibility\"\n"
21852 " number_of_elements=\"1\"\n"
21853 " panel_visibility=\"never\">\n"
21854 " <BooleanDomain name=\"bool\" />\n"
21855 " <Documentation>Set the visibility for this\n"
21856 " representation.</Documentation>\n"
21857 " </IntVectorProperty>\n"
21858 " <IntVectorProperty command=\"SetForceUseCache\"\n"
21859 " default_values=\"0\"\n"
21860 " is_internal=\"1\"\n"
21861 " name=\"ForceUseCache\"\n"
21862 " number_of_elements=\"1\">\n"
21863 " <BooleanDomain name=\"bool\" />\n"
21864 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21865 " and representations cache based on what the view tells it. However in\n"
21866 " some cases we may want to force a representation to cache irrespective\n"
21867 " of the view (e.g. comparative views). In which case these ivars can up\n"
21868 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21869 " Instead, ForcedCacheKey is used.</Documentation>\n"
21870 " </IntVectorProperty>\n"
21871 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
21872 " default_values=\"none\"\n"
21873 " is_internal=\"1\"\n"
21874 " name=\"ForcedCacheKey\"\n"
21875 " number_of_elements=\"1\">\n"
21876 " <DoubleRangeDomain name=\"range\" />\n"
21877 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21878 " and representations cache based on what the view tells it. However in\n"
21879 " some cases we may want to force a representation to cache irrespective\n"
21880 " of the view (e.g. comparative views). In which case these ivars can up\n"
21881 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21882 " Instead, ForcedCacheKey is used.</Documentation>\n"
21883 " </DoubleVectorProperty>\n"
21884 " <RepresentationType subproxy=\"MoleculeRepresentation\"\n"
21885 " subtype=\"Molecule\"\n"
21886 " text=\"Molecule\" />\n"
21887 " <StringVectorProperty command=\"GetRepresentationTypes\"\n"
21888 " information_only=\"1\"\n"
21889 " name=\"RepresentationTypesInfo\"\n"
21890 " si_class=\"vtkSIDataArrayProperty\">\n"
21891 " <Documentation>Property that lists the available representation types.\n"
21892 " This is used by the domain for \"Representation\" to setup the list of\n"
21893 " types available correctly.</Documentation>\n"
21894 " </StringVectorProperty>\n"
21895 " <StringVectorProperty command=\"SetActiveRepresentation\"\n"
21896 " default_values=\"Molecule\"\n"
21897 " name=\"Representation\"\n"
21898 " number_of_elements=\"1\"\n"
21899 " panel_visibility=\"default\"\n"
21900 " panel_widget=\"display_representation_selector\" >\n"
21901 " <Documentation>Choose the type for the representation.</Documentation>\n"
21902 " <RepresentationTypeDomain name=\"list\">\n"
21903 " <RequiredProperties>\n"
21904 " <Property function=\"StringList\"\n"
21905 " name=\"RepresentationTypesInfo\" />\n"
21906 " <Property function=\"Input\"\n"
21907 " name=\"Input\" />\n"
21908 " </RequiredProperties>\n"
21909 " </RepresentationTypeDomain>\n"
21910 " </StringVectorProperty>\n"
21911 " <InputProperty command=\"SetInputConnection\"\n"
21912 " name=\"Input\">\n"
21913 " <DataTypeDomain name=\"input_type\">\n"
21914 " <DataType value=\"vtkMolecule\" />\n"
21915 " </DataTypeDomain>\n"
21916 " <Documentation>Set the input to the representation.</Documentation>\n"
21917 " </InputProperty>\n"
21918 " <SubProxy>\n"
21919 " <Proxy name=\"MoleculeRepresentation\"\n"
21920 " proxygroup=\"representations\"\n"
21921 " proxyname=\"MoleculeRepresentation\" />\n"
21922 " <ExposedProperties>\n"
21923 " <PropertyGroup label=\"Coloring\">\n"
21924 " <Property name=\"Opacity\"\n"
21925 " panel_visibility=\"default\" />\n"
21926 " <Property name=\"Specular\"\n"
21927 " panel_visibility=\"default\" />\n"
21928 " <Property name=\"SpecularPower\"\n"
21929 " panel_visibility=\"default\" />\n"
21930 " <Property name=\"MapScalars\"\n"
21931 " panel_visibility=\"default\" />\n"
21932 " <Property name=\"ColorArrayName\"\n"
21933 " panel_visibility=\"default\" />\n"
21934 " <Property name=\"LookupTable\"\n"
21935 " panel_visibility=\"never\" />\n"
21936 " </PropertyGroup>\n"
21937 " <PropertyGroup label=\"Styling\"\n"
21938 " panel_widget=\"MoleculeParameters\">\n"
21939 " <Property name=\"RenderAtoms\"\n"
21940 " function=\"RenderAtoms\" />\n"
21941 " <Property name=\"AtomicRadiusFactor\"\n"
21942 " function=\"AtomicRadiusFactor\" />\n"
21943 " <Property name=\"AtomicRadiusType\"\n"
21944 " function=\"AtomicRadiusType\"/>\n"
21945 " <Proprety name=\"AtomicRadiusArrayName\"\n"
21946 ;
21947
21948 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
21950 " function=\"AtomicRadiusArrayName\"/>\n"
21951 " <Property name=\"RenderBonds\"\n"
21952 " function=\"RenderBonds\" />\n"
21953 " <Property name=\"BondRadius\"\n"
21954 " function=\"BondRadius\" />\n"
21955 " <Property name=\"MultiCylindersForBonds\"\n"
21956 " function=\"UseMultiCylindersForBonds\"/>\n"
21957 " <Property name=\"BondColorMode\"\n"
21958 " function=\"BondColorMode\"/>\n"
21959 " <Property name=\"BondColor\"\n"
21960 " function=\"BondColor\"/>\n"
21961 " </PropertyGroup>\n"
21962 " </ExposedProperties>\n"
21963 " </SubProxy>\n"
21964 " </PVMoleculeRepresentationProxy>\n"
21965 "\n"
21966 " <!-- =================================================================== -->\n"
21967 " <ChartRepresentationProxy class=\"vtkChartTextRepresentation\"\n"
21968 " name=\"ChartTextRepresentation\"\n"
21969 " processes=\"client|dataserver|renderserver\">\n"
21970 " <Documentation>Representation to show text in Chart views</Documentation>\n"
21971 " <InputProperty command=\"SetInputConnection\"\n"
21972 " name=\"Input\">\n"
21973 " <Documentation>Data input for the representation.</Documentation>\n"
21974 " <DataTypeDomain name=\"input_type\">\n"
21975 " <DataType value=\"vtkDataObject\" />\n"
21976 " </DataTypeDomain>\n"
21977 " </InputProperty>\n"
21978 " <IntVectorProperty command=\"SetVisibility\"\n"
21979 " default_values=\"1\"\n"
21980 " name=\"Visibility\"\n"
21981 " number_of_elements=\"1\"\n"
21982 " panel_visibility=\"never\">\n"
21983 " <BooleanDomain name=\"bool\" />\n"
21984 " <Documentation>Visibility of the representation.</Documentation>\n"
21985 " </IntVectorProperty>\n"
21986 " <IntVectorProperty command=\"SetForceUseCache\"\n"
21987 " default_values=\"0\"\n"
21988 " is_internal=\"1\"\n"
21989 " name=\"ForceUseCache\"\n"
21990 " number_of_elements=\"1\">\n"
21991 " <BooleanDomain name=\"bool\" />\n"
21992 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
21993 " and representations cache based on what the view tells it. However in\n"
21994 " some cases we may want to force a representation to cache irrespective\n"
21995 " of the view (e.g. comparative views). In which case these ivars can up\n"
21996 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
21997 " Instead, ForcedCacheKey is used.</Documentation>\n"
21998 " </IntVectorProperty>\n"
21999 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22000 " default_values=\"none\"\n"
22001 " is_internal=\"1\"\n"
22002 " name=\"ForcedCacheKey\"\n"
22003 " number_of_elements=\"1\">\n"
22004 " <DoubleRangeDomain name=\"range\" />\n"
22005 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22006 " and representations cache based on what the view tells it. However in\n"
22007 " some cases we may want to force a representation to cache irrespective\n"
22008 " of the view (e.g. comparative views). In which case these ivars can up\n"
22009 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22010 " Instead, ForcedCacheKey is used.</Documentation>\n"
22011 " </DoubleVectorProperty>\n"
22012 " <IntVectorProperty command=\"SetInteractivity\"\n"
22013 " default_values=\"0\"\n"
22014 " name=\"Interactivity\"\n"
22015 " number_of_elements=\"1\"\n"
22016 " panel_visibility=\"never\">\n"
22017 " <BooleanDomain name=\"bool\" />\n"
22018 " <Documentation>\n"
22019 " Set whether user should be able to interactively place the text in the view.\n"
22020 " </Documentation>\n"
22021 " <!-- for now, we hide this property since we don't users interact with\n"
22022 " the text right now -->\n"
22023 " </IntVectorProperty>\n"
22024 "\n"
22025 " <IntVectorProperty command=\"SetLabelLocation\"\n"
22026 " default_values=\"4\"\n"
22027 " name=\"LabelLocation\"\n"
22028 " number_of_elements=\"1\">\n"
22029 " <EnumerationDomain name=\"enum\">\n"
22030 " <Entry text=\"Any Location\" value=\"0\" />\n"
22031 " <Entry text=\"Lower Left Corner\" value=\"1\" />\n"
22032 " <Entry text=\"Lower Right Corner\" value=\"2\" />\n"
22033 " <Entry text=\"Lower Center\" value=\"3\" />\n"
22034 " <Entry text=\"Upper Left Corner\" value=\"4\" />\n"
22035 " <Entry text=\"Upper Right Corner\" value=\"5\" />\n"
22036 " <Entry text=\"Upper Center\" value=\"6\" />\n"
22037 " </EnumerationDomain>\n"
22038 " <Documentation>\n"
22039 " Placement of the text inside of the window.\n"
22040 " </Documentation>\n"
22041 " </IntVectorProperty>\n"
22042 "\n"
22043 " <DoubleVectorProperty command=\"SetPosition\"\n"
22044 " name=\"Position\"\n"
22045 " default_values=\"0.05 0.05\"\n"
22046 " number_of_elements=\"2\"\n"
22047 " information_property=\"PositionInfo\">\n"
22048 " <DoubleRangeDomain min=\"0 0\"\n"
22049 " max=\"1 1\"\n"
22050 " name=\"range\" />\n"
22051 " <Documentation>\n"
22052 " Normalized position of the bottom left corner of the text box in pixels.\n"
22053 " </Documentation>\n"
22054 " </DoubleVectorProperty>\n"
22055 "\n"
22056 " <PropertyGroup label=\"Text Position\" panel_widget=\"TextLocationEditor\">\n"
22057 " <Property name=\"LabelLocation\" function=\"WindowLocation\" />\n"
22058 " <Property name=\"Position\" />\n"
22059 " </PropertyGroup>\n"
22060 "\n"
22061 " <SubProxy command=\"SetTextProperty\">\n"
22062 " <Proxy name=\"Prop2DProperty\" proxygroup=\"properties\" proxyname=\"ChartTextProperty\" />\n"
22063 " <ExposedProperties>\n"
22064 " <PropertyGroup label=\"Font Properties\" panel_widget=\"FontEditor\">\n"
22065 " <Property name=\"Color\" function=\"Color\" />\n"
22066 " <Property name=\"Opacity\" function=\"Opacity\"/>\n"
22067 " <Property name=\"FontFamily\" function=\"Family\"/>\n"
22068 " <Property name=\"FontFile\" function=\"File\"/>\n"
22069 " <Property name=\"Bold\" function=\"Bold\"/>\n"
22070 " <Property name=\"Italic\" function=\"Italics\" />\n"
22071 " <Property name=\"Shadow\" function=\"Shadow\"/>\n"
22072 " <Property name=\"FontSize\" function=\"Size\"/>\n"
22073 " <Property name=\"Justification\" function=\"Justification\"/>\n"
22074 " <Property name=\"VerticalJustification\" default_values=\"1\" />\n"
22075 " </PropertyGroup>\n"
22076 "\n"
22077 " <PropertyGroup label=\"Multi Cell Properties\">\n"
22078 " <Property name=\"LineSpacing\" panel_visibility=\"advanced\" />\n"
22079 " <Property name=\"CellOffset\" panel_visibility=\"advanced\" />\n"
22080 " <Property name=\"InteriorLinesWidth\" panel_visibility=\"advanced\" />\n"
22081 " <Property name=\"InteriorLinesColor\" panel_visibility=\"advanced\" />\n"
22082 " <Property name=\"InteriorLinesVisibility\" panel_visibility=\"advanced\" />\n"
22083 " </PropertyGroup>\n"
22084 " </ExposedProperties>\n"
22085 " </SubProxy>\n"
22086 "\n"
22087 " </ChartRepresentationProxy>\n"
22088 "\n"
22089 " <!-- =================================================================== -->\n"
22090 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
22091 " class=\"vtkPVImageChartRepresentation\"\n"
22092 " name=\"ImageChartRepresentation\"\n"
22093 " processes=\"client|dataserver|renderserver\" >\n"
22094 " <Documentation>Representation used by ImageChartView.</Documentation>\n"
22095 "\n"
22096 " <InputProperty command=\"SetInputConnection\"\n"
22097 " name=\"Input\">\n"
22098 " <Documentation>Data input for the representation.</Documentation>\n"
22099 " <ProxyGroupDomain name=\"groups\">\n"
22100 " <Group name=\"sources\" />\n"
22101 " <Group name=\"filters\" />\n"
22102 " </ProxyGroupDomain>\n"
22103 " <DataTypeDomain composite_data_supported=\"1\"\n"
22104 " name=\"input_type\">\n"
22105 " <DataType value=\"vtkImageData\" />\n"
22106 " </DataTypeDomain>\n"
22107 " </InputProperty>\n"
22108 " <IntVectorProperty command=\"SetVisibility\"\n"
22109 " default_values=\"1\"\n"
22110 " name=\"Visibility\"\n"
22111 " number_of_elements=\"1\"\n"
22112 " panel_visibility=\"never\">\n"
22113 " <BooleanDomain name=\"bool\" />\n"
22114 " <Documentation>Visibility of the representation.</Documentation>\n"
22115 " </IntVectorProperty>\n"
22116 " <IntVectorProperty command=\"SetForceUseCache\"\n"
22117 " default_values=\"0\"\n"
22118 " is_internal=\"1\"\n"
22119 " name=\"ForceUseCache\"\n"
22120 " number_of_elements=\"1\">\n"
22121 " <BooleanDomain name=\"bool\" />\n"
22122 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22123 " and representations cache based on what the view tells it. However in\n"
22124 " some cases we may want to force a representation to cache irrespective\n"
22125 " of the view (e.g. comparative views). In which case these ivars can up\n"
22126 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22127 " Instead, ForcedCacheKey is used.</Documentation>\n"
22128 " </IntVectorProperty>\n"
22129 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22130 " default_values=\"none\"\n"
22131 " is_internal=\"1\"\n"
22132 " name=\"ForcedCacheKey\"\n"
22133 " number_of_elements=\"1\">\n"
22134 " <DoubleRangeDomain name=\"range\" />\n"
22135 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22136 " and representations cache based on what the view tells it. However in\n"
22137 " some cases we may want to force a representation to cache irrespective\n"
22138 " of the view (e.g. comparative views). In which case these ivars can up\n"
22139 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22140 " Instead, ForcedCacheKey is used.</Documentation>\n"
22141 " </DoubleVectorProperty>\n"
22142 " <IntVectorProperty clean_command=\"ResetCompositeDataSetIndices\"\n"
22143 " command=\"AddCompositeDataSetIndex\"\n"
22144 " default_values=\"0\"\n"
22145 " number_of_elements=\"1\"\n"
22146 " name=\"CompositeDataSetIndex\"\n"
22147 " number_of_elements_per_command=\"1\"\n"
22148 " panel_visibility=\"default\"\n"
22149 " repeat_command=\"1\">\n"
22150 " <CompositeTreeDomain mode=\"leaves\" name=\"tree\">\n"
22151 " <RequiredProperties>\n"
22152 " <Property function=\"Input\" name=\"Input\" />\n"
22153 " </RequiredProperties>\n"
22154 " </CompositeTreeDomain>\n"
22155 " <Documentation>\n"
22156 " This property lists the ids of the blocks to extract\n"
22157 " from the input multiblock dataset.\n"
22158 " </Documentation>\n"
22159 " <Hints>\n"
22160 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
22161 " mode=\"visibility\" name=\"vtkMultiBlockDataSet\" />\n"
22162 " </Hints>\n"
22163 " </IntVectorProperty>\n"
22164 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
22165 " element_types=\"0 0 0 0 2\"\n"
22166 " name=\"ColorArrayName\"\n"
22167 " no_custom_default=\"1\"\n"
22168 " number_of_elements=\"5\">\n"
22169 " <ArrayListDomain name=\"array_list\">\n"
22170 " <RequiredProperties>\n"
22171 " <Property function=\"Input\"\n"
22172 " name=\"Input\" />\n"
22173 " </RequiredProperties>\n"
22174 " </ArrayListDomain>\n"
22175 " <Documentation>This property specifies the name of the scalar array\n"
22176 " from which we will color by.</Documentation>\n"
22177 " </StringVectorProperty>\n"
22178 " <ProxyProperty command=\"SetLookupTable\"\n"
22179 " name=\"LookupTable\" >\n"
22180 " <Documentation>Set the lookup-table to use to map data array to colors.</Documentation>\n"
22181 " <ProxyGroupDomain name=\"groups\">\n"
22182 " <Group name=\"lookup_tables\" />\n"
22183 " </ProxyGroupDomain>\n"
22184 " </ProxyProperty>\n"
22185 " <IntVectorProperty default_values=\"0\"\n"
22186 " name=\"UseSeparateColorMap\"\n"
22187 " number_of_elements=\"1\"\n"
22188 " panel_visibility=\"never\">\n"
22189 " <BooleanDomain name=\"bool\" />\n"
22190 " <Documentation>By default, ParaView shares a single color map among all datasets colored\n"
22191 " by arrays that have the same name. When this option is enabled, the active dataset will\n"
22192 " be assigned a separate color map not shared by other datasets.</Documentation>\n"
22193 " </IntVectorProperty>\n"
22194 " <PropertyGroup panel_visibility=\"default\"\n"
22195 " panel_widget=\"ColorEditor\"\n"
22196 " label=\"Coloring\" >\n"
22197 " <Property name=\"ColorArrayName\" />\n"
22198 " <Property name=\"LookupTable\" />\n"
22199 " <Property name=\"UseSeparateColorMap\" />\n"
22200 " </PropertyGroup>\n"
22201 " <SubProxy command=\"SetSelectionRepresentation\">\n"
22202 "\n"
22203 " SelectionRepresentation proxy is used to convey the selection to view.\n"
22204 " We keep this separate as subproxy so that when the selection is\n"
22205 " modified, we don't have to update the representation as well, we can\n"
22206 " only update the SelectionRepresentation.\n"
22207 "\n"
22208 " <RepresentationProxy name=\"SelectionRepresentation\"\n"
22209 " class=\"vtkChartSelectionRepresentation\"\n"
22210 " processes=\"client|dataserver|renderserver\">\n"
22211 " <InputProperty command=\"SetInputConnection\"\n"
22212 " name=\"OriginalSelectionInput\"/>\n"
22213 " </RepresentationProxy>\n"
22214 " </SubProxy>\n"
22215 " </ChartRepresentationProxy>\n"
22216 "\n"
22217 "<!-- =================================================================== -->\n"
22218 " <ChartRepresentationProxy class=\"vtkChartLogoRepresentation\"\n"
22219 " name=\"ChartLogoRepresentation\"\n"
22220 " processes=\"client|dataserver|renderserver\">\n"
22221 " <Documentation>Representation to show logo in Chart views</Documentation>\n"
22222 " <InputProperty command=\"SetInputConnection\"\n"
22223 " name=\"Input\">\n"
22224 " <Documentation>Data input for the representation.</Documentation>\n"
22225 " <DataTypeDomain name=\"input_type\">\n"
22226 " <DataType value=\"vtkDataObject\" />\n"
22227 " </DataTypeDomain>\n"
22228 " </InputProperty>\n"
22229 " <IntVectorProperty command=\"SetVisibility\"\n"
22230 " default_values=\"1\"\n"
22231 " name=\"Visibility\"\n"
22232 " number_of_elements=\"1\"\n"
22233 " panel_visibility=\"never\">\n"
22234 " <BooleanDomain name=\"bool\" />\n"
22235 " <Documentation>Visibility of the representation.</Documentation>\n"
22236 " </IntVectorProperty>\n"
22237 " <IntVectorProperty command=\"SetForceUseCache\"\n"
22238 " default_values=\"0\"\n"
22239 " is_internal=\"1\"\n"
22240 " name=\"ForceUseCache\"\n"
22241 " number_of_elements=\"1\">\n"
22242 " <BooleanDomain name=\"bool\" />\n"
22243 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22244 " and representations cache based on what the view tells it. However in\n"
22245 " some cases we may want to force a representation to cache irrespective\n"
22246 ;
22247
22248 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
22250 " of the view (e.g. comparative views). In which case these ivars can up\n"
22251 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22252 " Instead, ForcedCacheKey is used.</Documentation>\n"
22253 " </IntVectorProperty>\n"
22254 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22255 " default_values=\"none\"\n"
22256 " is_internal=\"1\"\n"
22257 " name=\"ForcedCacheKey\"\n"
22258 " number_of_elements=\"1\">\n"
22259 " <DoubleRangeDomain name=\"range\" />\n"
22260 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22261 " and representations cache based on what the view tells it. However in\n"
22262 " some cases we may want to force a representation to cache irrespective\n"
22263 " of the view (e.g. comparative views). In which case these ivars can up\n"
22264 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22265 " Instead, ForcedCacheKey is used.</Documentation>\n"
22266 " </DoubleVectorProperty>\n"
22267 " <IntVectorProperty command=\"SetLogoLocation\"\n"
22268 " default_values=\"5\"\n"
22269 " name=\"LogoLocation\"\n"
22270 " number_of_elements=\"1\">\n"
22271 " <EnumerationDomain name=\"enum\">\n"
22272 " <Entry text=\"Any Location\" value=\"0\" />\n"
22273 " <Entry text=\"Lower Left Corner\" value=\"1\" />\n"
22274 " <Entry text=\"Lower Right Corner\" value=\"2\" />\n"
22275 " <Entry text=\"Lower Center\" value=\"3\" />\n"
22276 " <Entry text=\"Upper Left Corner\" value=\"4\" />\n"
22277 " <Entry text=\"Upper Right Corner\" value=\"5\" />\n"
22278 " <Entry text=\"Upper Center\" value=\"6\" />\n"
22279 " </EnumerationDomain>\n"
22280 " <Documentation>Specify placement of the logo actor.</Documentation>\n"
22281 " </IntVectorProperty>\n"
22282 " <DoubleVectorProperty command=\"SetPosition\"\n"
22283 " name=\"Position\"\n"
22284 " default_values=\"0.05 0.05\"\n"
22285 " number_of_elements=\"2\"\n"
22286 " information_property=\"PositionInfo\">\n"
22287 " <DoubleRangeDomain min=\"0 0\"\n"
22288 " max=\"1 1\"\n"
22289 " name=\"range\" />\n"
22290 " <Documentation>\n"
22291 " Normalized position of the bottom left corner of the text box in pixels.\n"
22292 " </Documentation>\n"
22293 " </DoubleVectorProperty>\n"
22294 " <DoubleVectorProperty command=\"GetPosition\"\n"
22295 " information_only=\"1\"\n"
22296 " name=\"PositionInfo\">\n"
22297 " <SimpleDoubleInformationHelper />\n"
22298 " </DoubleVectorProperty>\n"
22299 "\n"
22300 " <PropertyGroup label=\"Logo Position\" panel_widget=\"TextLocationEditor\">\n"
22301 " <Property name=\"LogoLocation\" function=\"WindowLocation\" />\n"
22302 " <Property name=\"Position\"/>\n"
22303 " </PropertyGroup>\n"
22304 "\n"
22305 " </ChartRepresentationProxy>\n"
22306 "\n"
22307 " <!-- =================================================================== -->\n"
22308 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
22309 " class=\"vtkXYChartRepresentation\"\n"
22310 " name=\"XYChartRepresentationBase\"\n"
22311 " processes=\"client|dataserver|renderserver\">\n"
22312 " <Documentation>API for representations used by XYChartView and XYBarChartView.\n"
22313 " </Documentation>\n"
22314 " <InputProperty command=\"SetInputConnection\"\n"
22315 " name=\"Input\">\n"
22316 " <Documentation>Data input for the representation.</Documentation>\n"
22317 " <DataTypeDomain name=\"input_type\">\n"
22318 " <DataType value=\"vtkDataObject\" />\n"
22319 " </DataTypeDomain>\n"
22320 " </InputProperty>\n"
22321 " <IntVectorProperty command=\"SetVisibility\"\n"
22322 " default_values=\"1\"\n"
22323 " name=\"Visibility\"\n"
22324 " number_of_elements=\"1\"\n"
22325 " panel_visibility=\"never\">\n"
22326 " <BooleanDomain name=\"bool\" />\n"
22327 " <Documentation>Visibility of the representation.</Documentation>\n"
22328 " </IntVectorProperty>\n"
22329 " <IntVectorProperty command=\"SetForceUseCache\"\n"
22330 " default_values=\"0\"\n"
22331 " is_internal=\"1\"\n"
22332 " name=\"ForceUseCache\"\n"
22333 " number_of_elements=\"1\">\n"
22334 " <BooleanDomain name=\"bool\" />\n"
22335 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22336 " and representations cache based on what the view tells it. However in\n"
22337 " some cases we may want to force a representation to cache irrespective\n"
22338 " of the view (e.g. comparative views). In which case these ivars can up\n"
22339 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22340 " Instead, ForcedCacheKey is used.</Documentation>\n"
22341 " </IntVectorProperty>\n"
22342 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22343 " default_values=\"none\"\n"
22344 " is_internal=\"1\"\n"
22345 " name=\"ForcedCacheKey\"\n"
22346 " number_of_elements=\"1\">\n"
22347 " <DoubleRangeDomain name=\"range\" />\n"
22348 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22349 " and representations cache based on what the view tells it. However in\n"
22350 " some cases we may want to force a representation to cache irrespective\n"
22351 " of the view (e.g. comparative views). In which case these ivars can up\n"
22352 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22353 " Instead, ForcedCacheKey is used.</Documentation>\n"
22354 " </DoubleVectorProperty>\n"
22355 " <IntVectorProperty clean_command=\"ResetCompositeDataSetIndices\"\n"
22356 " command=\"AddCompositeDataSetIndex\"\n"
22357 " default_values=\"1\"\n"
22358 " number_of_elements=\"1\"\n"
22359 " name=\"CompositeDataSetIndex\"\n"
22360 " number_of_elements_per_command=\"1\"\n"
22361 " panel_visibility=\"default\"\n"
22362 " repeat_command=\"1\">\n"
22363 " <CompositeTreeDomain mode=\"leaves\" name=\"tree\">\n"
22364 " <RequiredProperties>\n"
22365 " <Property function=\"Input\" name=\"Input\" />\n"
22366 " </RequiredProperties>\n"
22367 " </CompositeTreeDomain>\n"
22368 " <Documentation>This property lists the ids of the blocks to extract\n"
22369 " from the input multiblock dataset.</Documentation>\n"
22370 " <Hints>\n"
22371 " <!-- we don't want to show this property, except for MBs. -->\n"
22372 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
22373 " mode=\"visibility\" name=\"vtkMultiBlockDataSet\" />\n"
22374 " </Hints>\n"
22375 " </IntVectorProperty>\n"
22376 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
22377 " default_values=\"0\"\n"
22378 " name=\"AttributeType\"\n"
22379 " number_of_elements=\"1\">\n"
22380 " <Documentation>Select the attribute data to render.</Documentation>\n"
22381 " <FieldDataDomain enable_field_data=\"1\"\n"
22382 " name=\"enum\">\n"
22383 " <RequiredProperties>\n"
22384 " <Property function=\"Input\" name=\"Input\" />\n"
22385 " </RequiredProperties>\n"
22386 " </FieldDataDomain>\n"
22387 " </IntVectorProperty>\n"
22388 " <IntVectorProperty command=\"SetUseIndexForXAxis\"\n"
22389 " default_values=\"1\"\n"
22390 " name=\"UseIndexForXAxis\"\n"
22391 " number_of_elements=\"1\">\n"
22392 " <ChartUseIndexForAxisDomain name=\"bool\">\n"
22393 " <RequiredProperties>\n"
22394 " <Property function=\"ArraySelection\" name=\"XArrayName\" />\n"
22395 " </RequiredProperties>\n"
22396 " </ChartUseIndexForAxisDomain>\n"
22397 " <Documentation>When set, the array index will be used for X axis,\n"
22398 " otherwise the array identified by XArrayName will be\n"
22399 " used.</Documentation>\n"
22400 " </IntVectorProperty>\n"
22401 " <StringVectorProperty command=\"SetXAxisSeriesName\"\n"
22402 " default_values=\"\"\n"
22403 " name=\"XArrayName\"\n"
22404 " number_of_elements=\"1\">\n"
22405 " <Documentation>Set the array to use on X axis. This is used only when\n"
22406 " UseIndexForXAxis is set to 0.</Documentation>\n"
22407 " <ChartSeriesListDomain name=\"array_list\"\n"
22408 " hide_partial_arrays=\"1\">\n"
22409 " <RequiredProperties>\n"
22410 " <Property function=\"Input\" name=\"Input\" />\n"
22411 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
22412 " </RequiredProperties>\n"
22413 " </ChartSeriesListDomain>\n"
22414 " <Hints>\n"
22415 " <!-- the widget for this property is only enabled, when\n"
22416 " UseIndexForXAxis is unchecked. -->\n"
22417 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
22418 " <Property name=\"UseIndexForXAxis\" function=\"boolean_invert\" />\n"
22419 " </PropertyWidgetDecorator>\n"
22420 " </Hints>\n"
22421 " </StringVectorProperty>\n"
22422 " <PropertyGroup label=\"X Axis Parameters\">\n"
22423 " <Property name=\"UseIndexForXAxis\" />\n"
22424 " <Property name=\"XArrayName\" />\n"
22425 " </PropertyGroup>\n"
22426 " <StringVectorProperty command=\"SetSeriesVisibility\"\n"
22427 " element_types=\"2 0\"\n"
22428 " name=\"SeriesVisibility\"\n"
22429 " number_of_elements_per_command=\"2\"\n"
22430 " repeat_command=\"1\"\n"
22431 " clean_command=\"ClearSeriesVisibilities\">\n"
22432 " <Documentation>Set the series visibility.</Documentation>\n"
22433 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
22434 " hide_partial_arrays=\"0\"\n"
22435 " default_mode=\"visibility\">\n"
22436 " <RequiredProperties>\n"
22437 " <Property function=\"Input\" name=\"Input\" />\n"
22438 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
22439 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
22440 " </RequiredProperties>\n"
22441 " </ChartSeriesSelectionDomain>\n"
22442 " <Hints>\n"
22443 " <!-- when present, the SeriesEditor widget will allow user to\n"
22444 " re-order the series which will affect the rendered plot -->\n"
22445 " <SeriesEditor supports_reordering=\"1\" />\n"
22446 " </Hints>\n"
22447 " </StringVectorProperty>\n"
22448 " <StringVectorProperty command=\"SetLabel\"\n"
22449 " clean_command=\"ClearLabels\"\n"
22450 " element_types=\"2 2\"\n"
22451 " name=\"SeriesLabel\"\n"
22452 " number_of_elements_per_command=\"2\"\n"
22453 " repeat_command=\"1\">\n"
22454 " <Documentation>Set the series labels.</Documentation>\n"
22455 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
22456 " hide_partial_arrays=\"0\"\n"
22457 " default_mode=\"label\">\n"
22458 " <RequiredProperties>\n"
22459 " <Property function=\"Input\" name=\"Input\" />\n"
22460 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
22461 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
22462 " </RequiredProperties>\n"
22463 " </ChartSeriesSelectionDomain>\n"
22464 " </StringVectorProperty>\n"
22465 " <StringVectorProperty command=\"SetColor\"\n"
22466 " clean_command=\"ClearColors\"\n"
22467 " element_types=\"2 1 1 1\"\n"
22468 " name=\"SeriesColor\"\n"
22469 " number_of_elements_per_command=\"4\"\n"
22470 " repeat_command=\"1\">\n"
22471 " <Documentation>Set the series line/bar color.</Documentation>\n"
22472 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
22473 " hide_partial_arrays=\"0\"\n"
22474 " default_mode=\"color\">\n"
22475 " <RequiredProperties>\n"
22476 " <Property function=\"Input\" name=\"Input\" />\n"
22477 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
22478 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
22479 " </RequiredProperties>\n"
22480 " </ChartSeriesSelectionDomain>\n"
22481 " </StringVectorProperty>\n"
22482 " <StringVectorProperty command=\"SetOpacity\"\n"
22483 " clean_command=\"ClearOpacities\"\n"
22484 " element_types=\"2 1\"\n"
22485 " name=\"SeriesOpacity\"\n"
22486 " number_of_elements_per_command=\"2\"\n"
22487 " repeat_command=\"1\">\n"
22488 " <Documentation>Set the series line/bar opacity.</Documentation>\n"
22489 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
22490 " hide_partial_arrays=\"0\"\n"
22491 " default_mode=\"value\"\n"
22492 " default_value=\"1.0\">\n"
22493 " <RequiredProperties>\n"
22494 " <Property function=\"Input\" name=\"Input\" />\n"
22495 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
22496 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
22497 " </RequiredProperties>\n"
22498 " </ChartSeriesSelectionDomain>\n"
22499 " </StringVectorProperty>\n"
22500 " <StringVectorProperty command=\"SetAxisCorner\"\n"
22501 " clean_command=\"ClearAxisCorners\"\n"
22502 " element_types=\"2 0\"\n"
22503 " name=\"SeriesPlotCorner\"\n"
22504 " number_of_elements_per_command=\"2\"\n"
22505 " repeat_command=\"1\">\n"
22506 " <Documentation>Set the series axis corner.</Documentation>\n"
22507 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
22508 " hide_partial_arrays=\"0\"\n"
22509 " default_mode=\"value\"\n"
22510 " default_value=\"0\">\n"
22511 " <RequiredProperties>\n"
22512 " <Property function=\"Input\" name=\"Input\" />\n"
22513 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
22514 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
22515 " </RequiredProperties>\n"
22516 " </ChartSeriesSelectionDomain>\n"
22517 " </StringVectorProperty>\n"
22518 " <!--\n"
22519 " Set the palette SelectionColor color to all the plots in the chart.\n"
22520 " -->\n"
22521 " <DoubleVectorProperty command=\"SetSelectionColor\"\n"
22522 " default_values=\"1.0 0.0 1.0\"\n"
22523 " name=\"Color\"\n"
22524 " number_of_elements=\"3\"\n"
22525 " panel_visibility=\"never\">\n"
22526 " <DoubleRangeDomain max=\"1 1 1\"\n"
22527 " min=\"0 0 0\"\n"
22528 " name=\"range\" />\n"
22529 " <Hints>\n"
22530 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SelectionColor\" unlink_if_modified=\"1\" />\n"
22531 " </Hints>\n"
22532 " </DoubleVectorProperty>\n"
22533 " <SubProxy command=\"SetSelectionRepresentation\">\n"
22534 " <!--\n"
22535 " SelectionRepresentation proxy is used to convey the selection to view.\n"
22536 " We keep this separate as subproxy so that when the selection is\n"
22537 ;
22538
22539 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
22541 " modified, we don't have to update the representation as well, we can\n"
22542 " only update the SelectionRepresentation.\n"
22543 " -->\n"
22544 " <RepresentationProxy name=\"SelectionRepresentation\"\n"
22545 " class=\"vtkChartSelectionRepresentation\"\n"
22546 " processes=\"client|dataserver|renderserver\">\n"
22547 " <InputProperty command=\"SetInputConnection\"\n"
22548 " name=\"SelectionInput\"/>\n"
22549 " </RepresentationProxy>\n"
22550 " </SubProxy>\n"
22551 "\n"
22552 " <StringVectorProperty command=\"SetSeriesLabelPrefix\"\n"
22553 " name=\"SeriesLabelPrefix\"\n"
22554 " number_of_elements=\"1\"\n"
22555 " default_value=\"\"\n"
22556 " panel_visibility=\"advanced\">\n"
22557 " <Documentation>\n"
22558 " Specify a string to prefix to the **SeriesLabel** (**Legend Name**) for each\n"
22559 " of series being plotted. This will get prefixed to the labels (legend names) specified\n"
22560 " for each of the series individually via the **Series Parameters**.\n"
22561 " </Documentation>\n"
22562 " </StringVectorProperty>\n"
22563 "\n"
22564 " <StringVectorProperty name=\"LastPresetName\"\n"
22565 " number_of_elements=\"1\"\n"
22566 " default_values=\"Spectrum\"\n"
22567 " panel_visibility=\"never\">\n"
22568 " <Documentation>Dummy property containing last color preset name.\n"
22569 " The property widget can set it when a preset is applied, and the domain can read it when a default color is requested.</Documentation>\n"
22570 " </StringVectorProperty>\n"
22571 " <!-- End of XYChartRepresentationBase -->\n"
22572 " </ChartRepresentationProxy>\n"
22573 "\n"
22574 " <!-- =================================================================== -->\n"
22575 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
22576 " class=\"vtkPVHistogramChartRepresentation\"\n"
22577 " name=\"HistogramChartRepresentation\"\n"
22578 " processes=\"client|dataserver|renderserver\">\n"
22579 " <Documentation>Representation used by XYHistogramChartView.</Documentation>\n"
22580 " <InputProperty command=\"SetInputConnection\"\n"
22581 " name=\"Input\">\n"
22582 " <Documentation>Data input for the representation.</Documentation>\n"
22583 " <DataTypeDomain name=\"input_type\">\n"
22584 " <DataType value=\"vtkDataObject\" />\n"
22585 " </DataTypeDomain>\n"
22586 " <InputArrayDomain attribute_type=\"any\" name=\"input_array\" />\n"
22587 " </InputProperty>\n"
22588 " <StringVectorProperty animateable=\"0\"\n"
22589 " command=\"SetInputArrayToProcess\"\n"
22590 " element_types=\"0 0 0 0 2\"\n"
22591 " name=\"SelectInputArray\"\n"
22592 " number_of_elements=\"5\">\n"
22593 " <ArrayListDomain attribute_type=\"Scalars\"\n"
22594 " name=\"array_list\">\n"
22595 " <RequiredProperties>\n"
22596 " <Property function=\"Input\"\n"
22597 " name=\"Input\" />\n"
22598 " </RequiredProperties>\n"
22599 " </ArrayListDomain>\n"
22600 " <Documentation>This property indicates the name of the array from which\n"
22601 " to compute the histogram.</Documentation>\n"
22602 " </StringVectorProperty>\n"
22603 " <IntVectorProperty command=\"SetVisibility\"\n"
22604 " default_values=\"1\"\n"
22605 " name=\"Visibility\"\n"
22606 " number_of_elements=\"1\"\n"
22607 " panel_visibility=\"never\">\n"
22608 " <BooleanDomain name=\"bool\" />\n"
22609 " <Documentation>Visibility of the representation.</Documentation>\n"
22610 " </IntVectorProperty>\n"
22611 " <IntVectorProperty command=\"SetForceUseCache\"\n"
22612 " default_values=\"0\"\n"
22613 " is_internal=\"1\"\n"
22614 " name=\"ForceUseCache\"\n"
22615 " number_of_elements=\"1\">\n"
22616 " <BooleanDomain name=\"bool\" />\n"
22617 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22618 " and representations cache based on what the view tells it. However in\n"
22619 " some cases we may want to force a representation to cache irrespective\n"
22620 " of the view (e.g. comparative views). In which case these ivars can up\n"
22621 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22622 " Instead, ForcedCacheKey is used.</Documentation>\n"
22623 " </IntVectorProperty>\n"
22624 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22625 " default_values=\"none\"\n"
22626 " is_internal=\"1\"\n"
22627 " name=\"ForcedCacheKey\"\n"
22628 " number_of_elements=\"1\">\n"
22629 " <DoubleRangeDomain name=\"range\" />\n"
22630 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22631 " and representations cache based on what the view tells it. However in\n"
22632 " some cases we may want to force a representation to cache irrespective\n"
22633 " of the view (e.g. comparative views). In which case these ivars can up\n"
22634 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22635 " Instead, ForcedCacheKey is used.</Documentation>\n"
22636 " </DoubleVectorProperty>\n"
22637 " <IntVectorProperty command=\"SetUseColorMapping\"\n"
22638 " number_of_elements=\"1\"\n"
22639 " default_values=\"0\"\n"
22640 " name=\"UseColorMapping\"\n"
22641 " panel_visibility=\"never\">\n"
22642 " <BooleanDomain name=\"bool\" />\n"
22643 " <Documentation>\n"
22644 " Use color mapping for the histogram.\n"
22645 " </Documentation>\n"
22646 " </IntVectorProperty>\n"
22647 " <DoubleVectorProperty command=\"SetHistogramColor\"\n"
22648 " default_values=\"0 0 1\"\n"
22649 " name=\"HistogramColor\"\n"
22650 " number_of_elements=\"3\"\n"
22651 " panel_widget=\"color_selector\"\n"
22652 " panel_visibility=\"default\">\n"
22653 " <Hints>\n"
22654 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
22655 " <Property name=\"UseColorMapping\" function=\"boolean_invert\" />\n"
22656 " </PropertyWidgetDecorator>\n"
22657 " </Hints>\n"
22658 " <Documentation>Sets the color for the histograms.</Documentation>\n"
22659 " </DoubleVectorProperty>\n"
22660 " <ProxyProperty command=\"SetLookupTable\"\n"
22661 " name=\"LookupTable\"\n"
22662 " panel_visibility=\"never\" >\n"
22663 " <Documentation>Sets the lookup table to use for scalar\n"
22664 " mapping.</Documentation>\n"
22665 " <ProxyGroupDomain name=\"groups\">\n"
22666 " <Group name=\"lookup_tables\" />\n"
22667 " </ProxyGroupDomain>\n"
22668 " </ProxyProperty>\n"
22669 " <SubProxy command=\"SetSelectionRepresentation\">\n"
22670 " <!--\n"
22671 " SelectionRepresentation proxy is used to convey the selection to view.\n"
22672 " We keep this separate as subproxy so that when the selection is\n"
22673 " modified, we don't have to update the representation as well, we can\n"
22674 " only update the SelectionRepresentation.\n"
22675 " -->\n"
22676 " <RepresentationProxy name=\"SelectionRepresentation\"\n"
22677 " class=\"vtkChartSelectionRepresentation\"\n"
22678 " processes=\"client|dataserver|renderserver\">\n"
22679 " <!-- See vtkSMChartRepresentationProxy::SetPropertyModifiedFlag()\n"
22680 " for the details on naming this property -->\n"
22681 " <InputProperty command=\"SetInputConnection\"\n"
22682 " name=\"OriginalSelectionInput\"/>\n"
22683 " </RepresentationProxy>\n"
22684 " </SubProxy>\n"
22685 "\n"
22686 " <IntVectorProperty command=\"SetBinCount\"\n"
22687 " default_values=\"256\"\n"
22688 " name=\"BinCount\"\n"
22689 " number_of_elements=\"1\">\n"
22690 " <IntRangeDomain max=\"1000\"\n"
22691 " min=\"1\"\n"
22692 " name=\"range\" />\n"
22693 " <Documentation>The value of this property specifies the number of bins\n"
22694 " for the histogram.</Documentation>\n"
22695 " </IntVectorProperty>\n"
22696 " <IntVectorProperty animateable=\"0\"\n"
22697 " command=\"SetComponent\"\n"
22698 " default_values=\"0\"\n"
22699 " name=\"Component\"\n"
22700 " number_of_elements=\"1\">\n"
22701 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
22702 " <RequiredProperties>\n"
22703 " <Property function=\"Input\"\n"
22704 " name=\"Input\" />\n"
22705 " <Property function=\"ArraySelection\"\n"
22706 " name=\"SelectInputArray\" />\n"
22707 " </RequiredProperties>\n"
22708 " </NumberOfComponentsDomain>\n"
22709 " <Documentation>The value of this property specifies the array component\n"
22710 " from which the histogram should be computed.</Documentation>\n"
22711 " </IntVectorProperty>\n"
22712 " <IntVectorProperty command=\"SetCenterBinsAroundMinAndMax\"\n"
22713 " default_values=\"0\"\n"
22714 " name=\"CenterBinsAroundMinAndMax\"\n"
22715 " number_of_elements=\"1\"\n"
22716 " panel_visibility=\"advanced\">\n"
22717 " <BooleanDomain name=\"bool\" />\n"
22718 " <Documentation>When set to true, first and last bin will be centered\n"
22719 " around the minimum and the maximum values of the data.\n"
22720 " By default, set to false.</Documentation>\n"
22721 " <Hints>\n"
22722 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
22723 " mode=\"visibility\"\n"
22724 " property=\"UseCustomBinRanges\"\n"
22725 " value=\"0\" />\n"
22726 " <!-- show this widget when UseCustomBinRanges==0 -->\n"
22727 " </Hints>\n"
22728 " </IntVectorProperty>\n"
22729 " <IntVectorProperty command=\"SetUseCustomBinRanges\"\n"
22730 " default_values=\"0\"\n"
22731 " name=\"UseCustomBinRanges\"\n"
22732 " number_of_elements=\"1\"\n"
22733 " panel_visibility=\"advanced\">\n"
22734 " <BooleanDomain name=\"bool\" />\n"
22735 " <Documentation>When set to true, CustomBinRanges will be used instead\n"
22736 " of using the full range for the selected array. By default, set to\n"
22737 " false.</Documentation>\n"
22738 " </IntVectorProperty>\n"
22739 " <DoubleVectorProperty command=\"SetCustomBinRanges\"\n"
22740 " default_values=\"0.0 100.0\"\n"
22741 " name=\"CustomBinRanges\"\n"
22742 " number_of_elements=\"2\"\n"
22743 " panel_visibility=\"advanced\">\n"
22744 " <Documentation>Set custom bin ranges to use. These are used only when\n"
22745 " UseCustomBinRanges is set to true.</Documentation>\n"
22746 " <ArrayRangeDomain name=\"scalar_range\">\n"
22747 " <RequiredProperties>\n"
22748 " <Property function=\"Input\"\n"
22749 " name=\"Input\" />\n"
22750 " <Property function=\"ArraySelection\"\n"
22751 " name=\"SelectInputArray\" />\n"
22752 " </RequiredProperties>\n"
22753 " </ArrayRangeDomain>\n"
22754 " <Hints>\n"
22755 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
22756 " <Property name=\"UseCustomBinRanges\" function=\"boolean\" />\n"
22757 " </PropertyWidgetDecorator>\n"
22758 " </Hints>\n"
22759 " </DoubleVectorProperty>\n"
22760 " <IntVectorProperty command=\"SetHistogramLineStyle\"\n"
22761 " name=\"HistogramLineStyle\"\n"
22762 " number_of_elements=\"1\"\n"
22763 " default_values=\"0\"\n"
22764 " panel_visibility=\"advanced\">\n"
22765 " <Documentation>Set the line style to use for drawing a border around the histogram bins.\n"
22766 " </Documentation>\n"
22767 " <EnumerationDomain name=\"enum\">\n"
22768 " <Entry text=\"None\" value=\"0\" />\n"
22769 " <Entry text=\"Solid\" value=\"1\" />\n"
22770 " <Entry text=\"Dash\" value=\"2\" />\n"
22771 " <Entry text=\"Dot\" value=\"3\" />\n"
22772 " <Entry text=\"Dash Dot\" value=\"4\" />\n"
22773 " <Entry text=\"Dash Dot Dot\" value=\"5\" />\n"
22774 " </EnumerationDomain>\n"
22775 " </IntVectorProperty>\n"
22776 " <Hints>\n"
22777 " <InitializationHelper class=\"vtkSMXYChartRepresentationInitializationHelper\" />\n"
22778 " </Hints>\n"
22779 " </ChartRepresentationProxy>\n"
22780 "\n"
22781 " <!-- =================================================================== -->\n"
22782 " <ChartRepresentationProxy class=\"vtkPVParallelCoordinatesRepresentation\"\n"
22783 " name=\"ParallelCoordinatesRepresentation\"\n"
22784 " processes=\"client|dataserver|renderserver\">\n"
22785 " <Documentation>Representation used by\n"
22786 " ParallelCoordinatesChartView.</Documentation>\n"
22787 " <InputProperty command=\"SetInputConnection\"\n"
22788 " name=\"Input\">\n"
22789 " <Documentation>Data input for the representation.</Documentation>\n"
22790 " <DataTypeDomain name=\"input_type\">\n"
22791 " <DataType value=\"vtkDataObject\" />\n"
22792 " </DataTypeDomain>\n"
22793 " </InputProperty>\n"
22794 " <IntVectorProperty command=\"SetVisibility\"\n"
22795 " default_values=\"1\"\n"
22796 " name=\"Visibility\"\n"
22797 " number_of_elements=\"1\"\n"
22798 " panel_visibility=\"never\">\n"
22799 " <BooleanDomain name=\"bool\" />\n"
22800 " <Documentation>Visibility of the representation.</Documentation>\n"
22801 " </IntVectorProperty>\n"
22802 " <IntVectorProperty command=\"SetForceUseCache\"\n"
22803 " default_values=\"0\"\n"
22804 " is_internal=\"1\"\n"
22805 " name=\"ForceUseCache\"\n"
22806 " number_of_elements=\"1\">\n"
22807 " <BooleanDomain name=\"bool\" />\n"
22808 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22809 " and representations cache based on what the view tells it. However in\n"
22810 " some cases we may want to force a representation to cache irrespective\n"
22811 " of the view (e.g. comparative views). In which case these ivars can up\n"
22812 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22813 " Instead, ForcedCacheKey is used.</Documentation>\n"
22814 " </IntVectorProperty>\n"
22815 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22816 " default_values=\"none\"\n"
22817 " is_internal=\"1\"\n"
22818 " name=\"ForcedCacheKey\"\n"
22819 " number_of_elements=\"1\">\n"
22820 " <DoubleRangeDomain name=\"range\" />\n"
22821 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22822 " and representations cache based on what the view tells it. However in\n"
22823 " some cases we may want to force a representation to cache irrespective\n"
22824 " of the view (e.g. comparative views). In which case these ivars can up\n"
22825 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22826 " Instead, ForcedCacheKey is used.</Documentation>\n"
22827 " </DoubleVectorProperty>\n"
22828 " <IntVectorProperty command=\"SetCompositeDataSetIndex\"\n"
22829 " default_values=\"1\"\n"
22830 " name=\"CompositeDataSetIndex\"\n"
22831 " number_of_elements=\"1\">\n"
22832 " <Documentation>In case of Composite datasets, set the flat index of the\n"
22833 " dataset to pass. The flat index must point to a non-empty,\n"
22834 ;
22835
22836 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
22838 " non-composite dataset for anything to be passed through. If the input\n"
22839 " is not a composite dataset, then this index is ignored.</Documentation>\n"
22840 " <CompositeTreeDomain mode=\"leaves\"\n"
22841 " name=\"tree\">\n"
22842 " <RequiredProperties>\n"
22843 " <Property function=\"Input\"\n"
22844 " name=\"Input\" />\n"
22845 " </RequiredProperties>\n"
22846 " </CompositeTreeDomain>\n"
22847 " </IntVectorProperty>\n"
22848 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
22849 " default_values=\"0\"\n"
22850 " name=\"FieldAssociation\"\n"
22851 " number_of_elements=\"1\">\n"
22852 " <Documentation>Select the attribute data to pass.</Documentation>\n"
22853 " <FieldDataDomain enable_field_data=\"1\"\n"
22854 " name=\"enum\">\n"
22855 " <RequiredProperties>\n"
22856 " <Property function=\"Input\"\n"
22857 " name=\"Input\" />\n"
22858 " </RequiredProperties>\n"
22859 " </FieldDataDomain>\n"
22860 " </IntVectorProperty>\n"
22861 "\n"
22862 " <StringVectorProperty command=\"SetSeriesVisibility\"\n"
22863 " element_types=\"2 0\"\n"
22864 " name=\"SeriesVisibility\"\n"
22865 " number_of_elements_per_command=\"2\"\n"
22866 " repeat_command=\"1\"\n"
22867 " clean_command=\"ClearSeriesVisibilities\">\n"
22868 " <Documentation>Set the series visibility.</Documentation>\n"
22869 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
22870 " hide_partial_arrays=\"0\"\n"
22871 " default_mode=\"visibility\">\n"
22872 " <RequiredProperties>\n"
22873 " <Property function=\"Input\" name=\"Input\" />\n"
22874 " <Property function=\"FieldDataSelection\" name=\"FieldAssociation\" />\n"
22875 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
22876 " </RequiredProperties>\n"
22877 " </ChartSeriesSelectionDomain>\n"
22878 " <Hints>\n"
22879 " <!-- when present, the SeriesEditor widget will allow user to\n"
22880 " re-order the series which will affect the rendered plot -->\n"
22881 " <SeriesEditor supports_reordering=\"1\" />\n"
22882 " </Hints>\n"
22883 " </StringVectorProperty>\n"
22884 "\n"
22885 " <DoubleVectorProperty command=\"SetColor\"\n"
22886 " name=\"Color\"\n"
22887 " number_of_elements=\"3\"\n"
22888 " default_values=\"0.0 0.0 0.0\"\n"
22889 " panel_widget=\"color_selector\"\n"
22890 " panel_visibility=\"advanced\">\n"
22891 " <Documentation>Set the series line color.</Documentation>\n"
22892 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" max=\"1 1 1\" />\n"
22893 " </DoubleVectorProperty>\n"
22894 " <DoubleVectorProperty command=\"SetOpacity\"\n"
22895 " name=\"Opacity\"\n"
22896 " number_of_elements=\"1\"\n"
22897 " default_values=\"0.1\"\n"
22898 " panel_visibility=\"advanced\">\n"
22899 " <Documentation>Set the opacity of the lines.</Documentation>\n"
22900 " <DoubleRangeDomain name=\"range\" min=\"0\" max=\"1\" />\n"
22901 " </DoubleVectorProperty>\n"
22902 " <IntVectorProperty command=\"SetLineThickness\"\n"
22903 " name=\"LineThickness\"\n"
22904 " number_of_elements=\"1\"\n"
22905 " default_values=\"2\"\n"
22906 " panel_visibility=\"advanced\">\n"
22907 " <Documentation>Set the series line thickness.</Documentation>\n"
22908 " <IntRangeDomain name=\"range\" min=\"1\" max=\"10\" />\n"
22909 " </IntVectorProperty>\n"
22910 " <IntVectorProperty command=\"SetLineStyle\"\n"
22911 " name=\"LineStyle\"\n"
22912 " number_of_elements=\"1\"\n"
22913 " default_values=\"1\"\n"
22914 " panel_visibility=\"advanced\">\n"
22915 " <Documentation>Set the series line style.</Documentation>\n"
22916 " <EnumerationDomain name=\"enum\">\n"
22917 " <Entry text=\"None\" value=\"0\" />\n"
22918 " <Entry text=\"Solid\" value=\"1\" />\n"
22919 " <Entry text=\"Dash\" value=\"2\" />\n"
22920 " <Entry text=\"Dot\" value=\"3\" />\n"
22921 " <Entry text=\"Dash Dot\" value=\"4\" />\n"
22922 " <Entry text=\"Dash Dot Dot\" value=\"5\" />\n"
22923 " </EnumerationDomain>\n"
22924 " </IntVectorProperty>\n"
22925 "\n"
22926 " <PropertyGroup label=\"Series Parameters\"\n"
22927 " panel_widget=\"SeriesEditor\" >\n"
22928 " <Property name=\"SeriesVisibility\" function=\"SeriesVisibility\" />\n"
22929 " </PropertyGroup>\n"
22930 "\n"
22931 " <PropertyGroup label=\"Styling\">\n"
22932 " <Property name=\"Color\" />\n"
22933 " <Property name=\"Opacity\" />\n"
22934 " <Property name=\"LineThickness\" />\n"
22935 " <Property name=\"LineStyle\" />\n"
22936 " </PropertyGroup>\n"
22937 "\n"
22938 " <SubProxy command=\"SetSelectionRepresentation\">\n"
22939 " <!--\n"
22940 " SelectionRepresentation proxy is used to convey the selection to view.\n"
22941 " We keep this separate as subproxy so that when the selection is\n"
22942 " modified, we don't have to update the representation as well, we can\n"
22943 " only update the SelectionRepresentation.\n"
22944 " -->\n"
22945 " <RepresentationProxy name=\"SelectionRepresentation\"\n"
22946 " class=\"vtkChartSelectionRepresentation\"\n"
22947 " processes=\"client|dataserver|renderserver\">\n"
22948 " <InputProperty command=\"SetInputConnection\"\n"
22949 " name=\"SelectionInput\"/>\n"
22950 " </RepresentationProxy>\n"
22951 " </SubProxy>\n"
22952 " </ChartRepresentationProxy>\n"
22953 "\n"
22954 " <!-- =================================================================== -->\n"
22955 " <ChartRepresentationProxy class=\"vtkPVBoxChartRepresentation\"\n"
22956 " name=\"BoxChartRepresentation\"\n"
22957 " processes=\"client|dataserver|renderserver\">\n"
22958 " <Documentation>Representation used by BoxChartView.</Documentation>\n"
22959 " <InputProperty command=\"SetInputConnection\"\n"
22960 " name=\"Input\">\n"
22961 " <Documentation>Data input for the representation.</Documentation>\n"
22962 " <DataTypeDomain name=\"input_type\">\n"
22963 " <DataType value=\"vtkDataObject\" />\n"
22964 " </DataTypeDomain>\n"
22965 " </InputProperty>\n"
22966 " <IntVectorProperty command=\"SetVisibility\"\n"
22967 " default_values=\"1\"\n"
22968 " name=\"Visibility\"\n"
22969 " number_of_elements=\"1\"\n"
22970 " panel_visibility=\"never\">\n"
22971 " <BooleanDomain name=\"bool\" />\n"
22972 " <Documentation>Visibility of the representation.</Documentation>\n"
22973 " </IntVectorProperty>\n"
22974 " <IntVectorProperty command=\"SetForceUseCache\"\n"
22975 " default_values=\"0\"\n"
22976 " is_internal=\"1\"\n"
22977 " name=\"ForceUseCache\"\n"
22978 " number_of_elements=\"1\">\n"
22979 " <BooleanDomain name=\"bool\" />\n"
22980 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22981 " and representations cache based on what the view tells it. However in\n"
22982 " some cases we may want to force a representation to cache irrespective\n"
22983 " of the view (e.g. comparative views). In which case these ivars can up\n"
22984 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22985 " Instead, ForcedCacheKey is used.</Documentation>\n"
22986 " </IntVectorProperty>\n"
22987 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
22988 " default_values=\"none\"\n"
22989 " is_internal=\"1\"\n"
22990 " name=\"ForcedCacheKey\"\n"
22991 " number_of_elements=\"1\">\n"
22992 " <DoubleRangeDomain name=\"range\" />\n"
22993 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
22994 " and representations cache based on what the view tells it. However in\n"
22995 " some cases we may want to force a representation to cache irrespective\n"
22996 " of the view (e.g. comparative views). In which case these ivars can up\n"
22997 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
22998 " Instead, ForcedCacheKey is used.</Documentation>\n"
22999 " </DoubleVectorProperty>\n"
23000 " <IntVectorProperty command=\"SetCompositeDataSetIndex\"\n"
23001 " default_values=\"1\"\n"
23002 " name=\"CompositeDataSetIndex\"\n"
23003 " number_of_elements=\"1\">\n"
23004 " <Documentation>In case of Composite datasets, set the flat index of the\n"
23005 " dataset to pass. The flat index must point to a non-empty,\n"
23006 " non-composite dataset for anything to be passed through. If the input\n"
23007 " is not a composite dataset, then this index is ignored.</Documentation>\n"
23008 " <CompositeTreeDomain mode=\"leaves\"\n"
23009 " name=\"tree\">\n"
23010 " <RequiredProperties>\n"
23011 " <Property function=\"Input\"\n"
23012 " name=\"Input\" />\n"
23013 " </RequiredProperties>\n"
23014 " </CompositeTreeDomain>\n"
23015 " <Hints>\n"
23016 " <!-- we don't want to show this property, except for MBs. -->\n"
23017 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
23018 " mode=\"visibility\" name=\"vtkMultiBlockDataSet\" />\n"
23019 " </Hints>\n"
23020 " </IntVectorProperty>\n"
23021 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
23022 " default_values=\"0\"\n"
23023 " name=\"FieldAssociation\"\n"
23024 " number_of_elements=\"1\">\n"
23025 " <Documentation>Select the attribute data to pass.</Documentation>\n"
23026 " <FieldDataDomain enable_field_data=\"1\"\n"
23027 " name=\"enum\">\n"
23028 " <RequiredProperties>\n"
23029 " <Property function=\"Input\"\n"
23030 " name=\"Input\" />\n"
23031 " </RequiredProperties>\n"
23032 " </FieldDataDomain>\n"
23033 " </IntVectorProperty>\n"
23034 "\n"
23035 " <StringVectorProperty command=\"SetSeriesVisibility\"\n"
23036 " element_types=\"2 0\"\n"
23037 " name=\"SeriesVisibility\"\n"
23038 " number_of_elements_per_command=\"2\"\n"
23039 " repeat_command=\"1\"\n"
23040 " clean_command=\"ClearSeriesVisibilities\">\n"
23041 " <Documentation>Set the series visibility.</Documentation>\n"
23042 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23043 " hide_partial_arrays=\"0\"\n"
23044 " default_mode=\"visibility\">\n"
23045 " <RequiredProperties>\n"
23046 " <Property function=\"Input\" name=\"Input\" />\n"
23047 " <Property function=\"FieldDataSelection\" name=\"FieldAssociation\" />\n"
23048 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23049 " </RequiredProperties>\n"
23050 " </ChartSeriesSelectionDomain>\n"
23051 " <Hints>\n"
23052 " <!-- when present, the SeriesEditor widget will allow user to\n"
23053 " re-order the series which will affect the rendered plot -->\n"
23054 " <SeriesEditor supports_reordering=\"1\" />\n"
23055 " </Hints>\n"
23056 " </StringVectorProperty>\n"
23057 " <StringVectorProperty command=\"SetSeriesColor\"\n"
23058 " element_types=\"2 1 1 1\"\n"
23059 " name=\"SeriesColor\"\n"
23060 " number_of_elements_per_command=\"4\"\n"
23061 " repeat_command=\"1\"\n"
23062 " clean_command=\"ClearSeriesColors\">\n"
23063 " <Documentation>Set the series box plot color.</Documentation>\n"
23064 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23065 " hide_partial_arrays=\"0\"\n"
23066 " default_mode=\"color\">\n"
23067 " <RequiredProperties>\n"
23068 " <Property function=\"Input\" name=\"Input\" />\n"
23069 " <Property function=\"FieldDataSelection\" name=\"FieldAssociation\" />\n"
23070 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23071 " </RequiredProperties>\n"
23072 " </ChartSeriesSelectionDomain>\n"
23073 " </StringVectorProperty>\n"
23074 "\n"
23075 " <DoubleVectorProperty command=\"SetColor\"\n"
23076 " name=\"Color\"\n"
23077 " number_of_elements=\"3\"\n"
23078 " default_values=\"0.0 0.0 0.0\"\n"
23079 " panel_widget=\"color_selector\"\n"
23080 " panel_visibility=\"advanced\">\n"
23081 " <Documentation>Set the series line color.</Documentation>\n"
23082 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" max=\"1 1 1\" />\n"
23083 " </DoubleVectorProperty>\n"
23084 " <IntVectorProperty command=\"SetLineThickness\"\n"
23085 " name=\"LineThickness\"\n"
23086 " number_of_elements=\"1\"\n"
23087 " default_values=\"2\"\n"
23088 " panel_visibility=\"advanced\">\n"
23089 " <Documentation>Set the series line thickness.</Documentation>\n"
23090 " <IntRangeDomain name=\"range\" min=\"1\" max=\"10\" />\n"
23091 " </IntVectorProperty>\n"
23092 " <IntVectorProperty command=\"SetLineStyle\"\n"
23093 " name=\"LineStyle\"\n"
23094 " number_of_elements=\"1\"\n"
23095 " default_values=\"1\"\n"
23096 " panel_visibility=\"advanced\">\n"
23097 " <Documentation>Set the series line style.</Documentation>\n"
23098 " <EnumerationDomain name=\"enum\">\n"
23099 " <Entry text=\"None\" value=\"0\" />\n"
23100 " <Entry text=\"Solid\" value=\"1\" />\n"
23101 " <Entry text=\"Dash\" value=\"2\" />\n"
23102 " <Entry text=\"Dot\" value=\"3\" />\n"
23103 " <Entry text=\"Dash Dot\" value=\"4\" />\n"
23104 " <Entry text=\"Dash Dot Dot\" value=\"5\" />\n"
23105 " </EnumerationDomain>\n"
23106 " </IntVectorProperty>\n"
23107 " <IntVectorProperty command=\"SetLegend\"\n"
23108 " default_values=\"1\"\n"
23109 " name=\"Legend\"\n"
23110 " number_of_elements=\"1\"\n"
23111 " panel_visibility=\"advanced\">\n"
23112 " <BooleanDomain name=\"bool\" />\n"
23113 " <Documentation>Visibility of the legend.</Documentation>\n"
23114 " </IntVectorProperty>\n"
23115 "\n"
23116 " <PropertyGroup label=\"Series Parameters\"\n"
23117 " panel_widget=\"SeriesEditor\" >\n"
23118 " <Property name=\"SeriesVisibility\"\n"
23119 " function=\"SeriesVisibility\" />\n"
23120 " <Property name=\"SeriesColor\"\n"
23121 " function=\"SeriesColor\" />\n"
23122 " </PropertyGroup>\n"
23123 "\n"
23124 " <PropertyGroup label=\"Box Styling\">\n"
23125 " <Property name=\"Color\" />\n"
23126 " <Property name=\"LineThickness\" />\n"
23127 " <Property name=\"LineStyle\" />\n"
23128 " <Property name=\"Legend\" />\n"
23129 " </PropertyGroup>\n"
23130 "\n"
23131 " <SubProxy command=\"SetSelectionRepresentation\">\n"
23132 " <!--\n"
23133 " SelectionRepresentation proxy is used to convey the selection to view.\n"
23134 " We keep this separate as subproxy so that when the selection is\n"
23135 " modified, we don't have to update the representation as well, we can\n"
23136 " only update the SelectionRepresentation.\n"
23137 " -->\n"
23138 " <RepresentationProxy name=\"SelectionRepresentation\"\n"
23139 " class=\"vtkChartSelectionRepresentation\"\n"
23140 " processes=\"client|dataserver|renderserver\">\n"
23141 ;
23142
23143 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
23145 " <InputProperty command=\"SetInputConnection\"\n"
23146 " name=\"SelectionInput\"/>\n"
23147 " </RepresentationProxy>\n"
23148 " </SubProxy>\n"
23149 " </ChartRepresentationProxy>\n"
23150 "\n"
23151 " <!-- =================================================================== -->\n"
23152 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
23153 " class=\"vtkPVPlotMatrixRepresentation\"\n"
23154 " name=\"PlotMatrixRepresentation\"\n"
23155 " processes=\"client|dataserver|renderserver\">\n"
23156 " <Documentation>Representation used by PlotMatrixView.</Documentation>\n"
23157 " <InputProperty command=\"SetInputConnection\"\n"
23158 " name=\"Input\">\n"
23159 " <Documentation>Data input for the representation.</Documentation>\n"
23160 " <DataTypeDomain name=\"input_type\">\n"
23161 " <DataType value=\"vtkDataObject\" />\n"
23162 " </DataTypeDomain>\n"
23163 " </InputProperty>\n"
23164 " <IntVectorProperty command=\"SetVisibility\"\n"
23165 " default_values=\"1\"\n"
23166 " name=\"Visibility\"\n"
23167 " number_of_elements=\"1\"\n"
23168 " panel_visibility=\"never\">\n"
23169 " <BooleanDomain name=\"bool\" />\n"
23170 " <Documentation>Visibility of the representation.</Documentation>\n"
23171 " </IntVectorProperty>\n"
23172 " <IntVectorProperty command=\"SetForceUseCache\"\n"
23173 " default_values=\"0\"\n"
23174 " is_internal=\"1\"\n"
23175 " name=\"ForceUseCache\"\n"
23176 " number_of_elements=\"1\">\n"
23177 " <BooleanDomain name=\"bool\" />\n"
23178 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
23179 " and representations cache based on what the view tells it. However in\n"
23180 " some cases we may want to force a representation to cache irrespective\n"
23181 " of the view (e.g. comparative views). In which case these ivars can up\n"
23182 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
23183 " Instead, ForcedCacheKey is used.</Documentation>\n"
23184 " </IntVectorProperty>\n"
23185 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
23186 " default_values=\"none\"\n"
23187 " is_internal=\"1\"\n"
23188 " name=\"ForcedCacheKey\"\n"
23189 " number_of_elements=\"1\">\n"
23190 " <DoubleRangeDomain name=\"range\" />\n"
23191 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
23192 " and representations cache based on what the view tells it. However in\n"
23193 " some cases we may want to force a representation to cache irrespective\n"
23194 " of the view (e.g. comparative views). In which case these ivars can up\n"
23195 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
23196 " Instead, ForcedCacheKey is used.</Documentation>\n"
23197 " </DoubleVectorProperty>\n"
23198 " <IntVectorProperty command=\"SetCompositeDataSetIndex\"\n"
23199 " default_values=\"1\"\n"
23200 " name=\"CompositeDataSetIndex\"\n"
23201 " number_of_elements=\"1\">\n"
23202 " <Documentation>In case of Composite datasets, set the flat index of the\n"
23203 " dataset to pass. The flat index must point to a non-empty,\n"
23204 " non-composite dataset for anything to be passed through. If the input\n"
23205 " is not a composite dataset, then this index is ignored.</Documentation>\n"
23206 " <CompositeTreeDomain mode=\"leaves\"\n"
23207 " name=\"tree\">\n"
23208 " <RequiredProperties>\n"
23209 " <Property function=\"Input\"\n"
23210 " name=\"Input\" />\n"
23211 " </RequiredProperties>\n"
23212 " <Hints>\n"
23213 " <!-- we don't want to show this property, except for MBs. -->\n"
23214 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
23215 " mode=\"visibility\" name=\"vtkMultiBlockDataSet\" />\n"
23216 " </Hints>\n"
23217 " </CompositeTreeDomain>\n"
23218 " </IntVectorProperty>\n"
23219 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
23220 " default_values=\"0\"\n"
23221 " name=\"FieldAssociation\"\n"
23222 " number_of_elements=\"1\">\n"
23223 " <Documentation>Select the attribute data to pass.</Documentation>\n"
23224 " <FieldDataDomain enable_field_data=\"1\"\n"
23225 " name=\"enum\">\n"
23226 " <RequiredProperties>\n"
23227 " <Property function=\"Input\"\n"
23228 " name=\"Input\" />\n"
23229 " </RequiredProperties>\n"
23230 " </FieldDataDomain>\n"
23231 " </IntVectorProperty>\n"
23232 "\n"
23233 " <StringVectorProperty command=\"SetSeriesVisibility\"\n"
23234 " element_types=\"2 0\"\n"
23235 " name=\"SeriesVisibility\"\n"
23236 " number_of_elements_per_command=\"2\"\n"
23237 " repeat_command=\"1\"\n"
23238 " clean_command=\"ClearSeriesVisibilities\">\n"
23239 " <Documentation>Set the series visibility.</Documentation>\n"
23240 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23241 " hide_partial_arrays=\"0\"\n"
23242 " default_mode=\"visibility\">\n"
23243 " <RequiredProperties>\n"
23244 " <Property function=\"Input\" name=\"Input\" />\n"
23245 " <Property function=\"FieldDataSelection\" name=\"FieldAssociation\" />\n"
23246 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23247 " </RequiredProperties>\n"
23248 " </ChartSeriesSelectionDomain>\n"
23249 " <Hints>\n"
23250 " <!-- when present, the SeriesEditor widget will allow user to\n"
23251 " re-order the series which will affect the rendered plot -->\n"
23252 " <SeriesEditor supports_reordering=\"1\" />\n"
23253 " </Hints>\n"
23254 " </StringVectorProperty>\n"
23255 "\n"
23256 " <PropertyGroup label=\"Series Parameters\"\n"
23257 " panel_widget=\"SeriesEditor\" >\n"
23258 " <Property name=\"SeriesVisibility\" function=\"SeriesVisibility\" />\n"
23259 " </PropertyGroup>\n"
23260 "\n"
23261 " <DoubleVectorProperty command=\"SetColor\"\n"
23262 " default_values=\"0 0 0\"\n"
23263 " name=\"ScatterPlotsColor\"\n"
23264 " number_of_elements=\"3\"\n"
23265 " panel_widget=\"color_selector\"\n"
23266 " panel_visibility=\"advanced\">\n"
23267 " <Documentation>Sets the color.</Documentation>\n"
23268 " </DoubleVectorProperty>\n"
23269 " <DoubleVectorProperty command=\"SetHistogramColor\"\n"
23270 " default_values=\"0 0 0\"\n"
23271 " name=\"HistogramColor\"\n"
23272 " number_of_elements=\"3\"\n"
23273 " panel_widget=\"color_selector\"\n"
23274 " panel_visibility=\"advanced\">\n"
23275 " <Documentation>Sets the color for the histograms.</Documentation>\n"
23276 " </DoubleVectorProperty>\n"
23277 " <IntVectorProperty command=\"SetMarkerStyle\"\n"
23278 " default_values=\"4\"\n"
23279 " name=\"ScatterPlotMarkerStyle\"\n"
23280 " number_of_elements=\"1\"\n"
23281 " panel_visibility=\"advanced\">\n"
23282 " <Documentation>Property which sets the marker style for the scatter\n"
23283 " plots.</Documentation>\n"
23284 " <EnumerationDomain name=\"enum\">\n"
23285 " <Entry text=\"None\" value=\"0\"/>\n"
23286 " <Entry text=\"Cross\" value=\"1\"/>\n"
23287 " <Entry text=\"Plus\" value=\"2\"/>\n"
23288 " <Entry text=\"Square\" value=\"3\"/>\n"
23289 " <Entry text=\"Circle\" value=\"4\"/>\n"
23290 " <Entry text=\"Diamond\" value=\"5\"/>\n"
23291 " </EnumerationDomain>\n"
23292 " </IntVectorProperty>\n"
23293 " <DoubleVectorProperty command=\"SetMarkerSize\"\n"
23294 " default_values=\"3\"\n"
23295 " name=\"ScatterPlotMarkerSize\"\n"
23296 " number_of_elements=\"1\"\n"
23297 " panel_visibility=\"advanced\">\n"
23298 " <Documentation>Property which sets the marker size for the scatter\n"
23299 " plots.</Documentation>\n"
23300 " <DoubleRangeDomain name=\"range\" min=\"1\" max=\"20\" />\n"
23301 " </DoubleVectorProperty>\n"
23302 "\n"
23303 " <DoubleVectorProperty command=\"SetActivePlotColor\"\n"
23304 " default_values=\"0 0 0\"\n"
23305 " name=\"ActivePlotColor\"\n"
23306 " number_of_elements=\"3\"\n"
23307 " panel_widget=\"color_selector\"\n"
23308 " panel_visibility=\"advanced\">\n"
23309 " <Documentation>Sets the color for the active plot.</Documentation>\n"
23310 " </DoubleVectorProperty>\n"
23311 " <IntVectorProperty command=\"SetActivePlotMarkerStyle\"\n"
23312 " default_values=\"4\"\n"
23313 " name=\"ActivePlotMarkerStyle\"\n"
23314 " number_of_elements=\"1\"\n"
23315 " panel_visibility=\"advanced\">\n"
23316 " <Documentation>Property which sets the marker style for the active\n"
23317 " plot.</Documentation>\n"
23318 " <EnumerationDomain name=\"enum\">\n"
23319 " <Entry text=\"None\" value=\"0\"/>\n"
23320 " <Entry text=\"Cross\" value=\"1\"/>\n"
23321 " <Entry text=\"Plus\" value=\"2\"/>\n"
23322 " <Entry text=\"Square\" value=\"3\"/>\n"
23323 " <Entry text=\"Circle\" value=\"4\"/>\n"
23324 " <Entry text=\"Diamond\" value=\"5\"/>\n"
23325 " </EnumerationDomain>\n"
23326 " </IntVectorProperty>\n"
23327 " <DoubleVectorProperty command=\"SetActivePlotMarkerSize\"\n"
23328 " default_values=\"5\"\n"
23329 " name=\"ActivePlotMarkerSize\"\n"
23330 " number_of_elements=\"1\"\n"
23331 " panel_visibility=\"advanced\">\n"
23332 " <Documentation>Property which sets the marker size for the active\n"
23333 " plots.</Documentation>\n"
23334 " <DoubleRangeDomain name=\"range\" min=\"1\" max=\"20\" />\n"
23335 " </DoubleVectorProperty>\n"
23336 "\n"
23337 " <SubProxy command=\"SetSelectionRepresentation\">\n"
23338 " <!--\n"
23339 " SelectionRepresentation proxy is used to convey the selection to view.\n"
23340 " We keep this separate as subproxy so that when the selection is\n"
23341 " modified, we don't have to update the representation as well, we can\n"
23342 " only update the SelectionRepresentation.\n"
23343 " -->\n"
23344 " <RepresentationProxy name=\"SelectionRepresentation\"\n"
23345 " class=\"vtkChartSelectionRepresentation\"\n"
23346 " processes=\"client|dataserver|renderserver\">\n"
23347 " <InputProperty command=\"SetInputConnection\"\n"
23348 " name=\"SelectionInput\"/>\n"
23349 " </RepresentationProxy>\n"
23350 " </SubProxy>\n"
23351 "\n"
23352 " <PropertyGroup label=\"Styling\">\n"
23353 " <Property name=\"ScatterPlotsColor\" />\n"
23354 " <Property name=\"HistogramColor\" />\n"
23355 " <Property name=\"ScatterPlotMarkerStyle\" />\n"
23356 " <Property name=\"ScatterPlotMarkerSize\" />\n"
23357 " </PropertyGroup>\n"
23358 "\n"
23359 " <PropertyGroup label=\"Styling (Active Plot)\">\n"
23360 " <Property name=\"ActivePlotColor\" />\n"
23361 " <Property name=\"ActivePlotMarkerStyle\" />\n"
23362 " <Property name=\"ActivePlotMarkerSize\" />\n"
23363 " </PropertyGroup>\n"
23364 " <!-- End of PlotMatrixRepresentation -->\n"
23365 " </ChartRepresentationProxy>\n"
23366 "\n"
23367 " <!-- =================================================================== -->\n"
23368 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
23369 " base_proxyname=\"XYChartRepresentationBase\"\n"
23370 " class=\"vtkXYChartRepresentation\"\n"
23371 " name=\"XYChartRepresentation\"\n"
23372 " processes=\"client|dataserver|renderserver\"\n"
23373 " post_creation=\"SetChartTypeToLine\">\n"
23374 " <Documentation>Representation used by XYChartView.</Documentation>\n"
23375 " <StringVectorProperty command=\"SetLineStyle\"\n"
23376 " clean_command=\"ClearLineStyles\"\n"
23377 " element_types=\"2 0\"\n"
23378 " name=\"SeriesLineStyle\"\n"
23379 " number_of_elements_per_command=\"2\"\n"
23380 " repeat_command=\"1\">\n"
23381 " <Documentation>Set the series line style.</Documentation>\n"
23382 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23383 " hide_partial_arrays=\"0\"\n"
23384 " default_mode=\"value\"\n"
23385 " default_value=\"1\">\n"
23386 " <RequiredProperties>\n"
23387 " <Property function=\"Input\" name=\"Input\" />\n"
23388 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23389 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23390 " </RequiredProperties>\n"
23391 " </ChartSeriesSelectionDomain>\n"
23392 " </StringVectorProperty>\n"
23393 " <StringVectorProperty command=\"SetLineThickness\"\n"
23394 " clean_command=\"ClearLineThicknesses\"\n"
23395 " element_types=\"str int\"\n"
23396 " name=\"SeriesLineThickness\"\n"
23397 " number_of_elements_per_command=\"2\"\n"
23398 " repeat_command=\"1\">\n"
23399 " <Documentation>Set the series line thickness.</Documentation>\n"
23400 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23401 " hide_partial_arrays=\"0\"\n"
23402 " default_mode=\"value\"\n"
23403 " default_value=\"2\">\n"
23404 " <RequiredProperties>\n"
23405 " <Property function=\"Input\" name=\"Input\" />\n"
23406 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23407 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23408 " </RequiredProperties>\n"
23409 " </ChartSeriesSelectionDomain>\n"
23410 " </StringVectorProperty>\n"
23411 " <StringVectorProperty command=\"SetMarkerStyle\"\n"
23412 " clean_command=\"ClearMarkerStyles\"\n"
23413 " element_types=\"2 0\"\n"
23414 " name=\"SeriesMarkerStyle\"\n"
23415 " number_of_elements_per_command=\"2\"\n"
23416 " repeat_command=\"1\">\n"
23417 " <Documentation>Set the series marker style.</Documentation>\n"
23418 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23419 " hide_partial_arrays=\"0\"\n"
23420 " default_mode=\"value\"\n"
23421 " default_value=\"0\">\n"
23422 " <RequiredProperties>\n"
23423 " <Property function=\"Input\" name=\"Input\" />\n"
23424 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23425 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23426 " </RequiredProperties>\n"
23427 " </ChartSeriesSelectionDomain>\n"
23428 " </StringVectorProperty>\n"
23429 " <StringVectorProperty command=\"SetMarkerSize\"\n"
23430 " clean_command=\"ClearMarkerSizes\"\n"
23431 " element_types=\"str double\"\n"
23432 " name=\"SeriesMarkerSize\"\n"
23433 " number_of_elements_per_command=\"2\"\n"
23434 " repeat_command=\"1\">\n"
23435 " <Documentation>Set the series marker size.</Documentation>\n"
23436 ;
23437
23438 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
23440 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23441 " hide_partial_arrays=\"0\"\n"
23442 " default_mode=\"value\"\n"
23443 " default_value=\"4\">\n"
23444 " <RequiredProperties>\n"
23445 " <Property function=\"Input\" name=\"Input\" />\n"
23446 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23447 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23448 " </RequiredProperties>\n"
23449 " </ChartSeriesSelectionDomain>\n"
23450 " </StringVectorProperty>\n"
23451 "\n"
23452 " <PropertyGroup label=\"Series Parameters\"\n"
23453 " panel_widget=\"SeriesEditor\"\n"
23454 " panel_visibility=\"default\" >\n"
23455 " <Property name=\"SeriesVisibility\"\n"
23456 " function=\"SeriesVisibility\" />\n"
23457 " <Property name=\"SeriesColor\"\n"
23458 " function=\"SeriesColor\" />\n"
23459 " <Property name=\"SeriesOpacity\"\n"
23460 " function=\"SeriesOpacity\" />\n"
23461 " <Property name=\"SeriesLineThickness\"\n"
23462 " function=\"SeriesLineThickness\" />\n"
23463 " <Property name=\"SeriesLineStyle\"\n"
23464 " function=\"SeriesLineStyle\" />\n"
23465 " <Property name=\"SeriesLabel\"\n"
23466 " function=\"SeriesLabel\" />\n"
23467 " <Property name=\"SeriesMarkerSize\"\n"
23468 " function=\"SeriesMarkerSize\" />\n"
23469 " <Property name=\"SeriesMarkerStyle\"\n"
23470 " function=\"SeriesMarkerStyle\" />\n"
23471 " <Property name=\"SeriesPlotCorner\"\n"
23472 " function=\"SeriesPlotCorner\"/>\n"
23473 " <Property name=\"LastPresetName\"\n"
23474 " function=\"LastPresetName\"/>\n"
23475 " </PropertyGroup>\n"
23476 "\n"
23477 " <Hints>\n"
23478 " <InitializationHelper class=\"vtkSMXYChartRepresentationInitializationHelper\" />\n"
23479 " </Hints>\n"
23480 " </ChartRepresentationProxy>\n"
23481 "\n"
23482 " <!-- =================================================================== -->\n"
23483 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
23484 " base_proxyname=\"XYChartRepresentationBase\"\n"
23485 " class=\"vtkXYChartRepresentation\"\n"
23486 " name=\"XYPointChartRepresentation\"\n"
23487 " processes=\"client|dataserver|renderserver\"\n"
23488 " post_creation=\"SetChartTypeToPoints\">\n"
23489 " <Documentation>Representation used by XYChartView.</Documentation>\n"
23490 " <StringVectorProperty command=\"SetLineStyle\"\n"
23491 " clean_command=\"ClearLineStyles\"\n"
23492 " element_types=\"2 0\"\n"
23493 " name=\"SeriesLineStyle\"\n"
23494 " number_of_elements_per_command=\"2\"\n"
23495 " repeat_command=\"1\">\n"
23496 " <Documentation>Set the series line style.</Documentation>\n"
23497 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23498 " default_mode=\"value\"\n"
23499 " default_value=\"0\">\n"
23500 " <RequiredProperties>\n"
23501 " <Property function=\"Input\" name=\"Input\" />\n"
23502 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23503 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23504 " </RequiredProperties>\n"
23505 " </ChartSeriesSelectionDomain>\n"
23506 " </StringVectorProperty>\n"
23507 " <StringVectorProperty command=\"SetLineThickness\"\n"
23508 " clean_command=\"ClearLineThicknesses\"\n"
23509 " element_types=\"str double\"\n"
23510 " name=\"SeriesLineThickness\"\n"
23511 " number_of_elements_per_command=\"2\"\n"
23512 " repeat_command=\"1\">\n"
23513 " <Documentation>Set the series line thickness.</Documentation>\n"
23514 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23515 " default_mode=\"value\"\n"
23516 " default_value=\"1\">\n"
23517 " <RequiredProperties>\n"
23518 " <Property function=\"Input\" name=\"Input\" />\n"
23519 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23520 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23521 " </RequiredProperties>\n"
23522 " </ChartSeriesSelectionDomain>\n"
23523 " </StringVectorProperty>\n"
23524 " <StringVectorProperty command=\"SetMarkerStyle\"\n"
23525 " clean_command=\"ClearMarkerStyles\"\n"
23526 " element_types=\"2 0\"\n"
23527 " name=\"SeriesMarkerStyle\"\n"
23528 " number_of_elements_per_command=\"2\"\n"
23529 " repeat_command=\"1\">\n"
23530 " <Documentation>Set the series marker style.</Documentation>\n"
23531 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23532 " default_mode=\"value\"\n"
23533 " default_value=\"2\">\n"
23534 " <RequiredProperties>\n"
23535 " <Property function=\"Input\" name=\"Input\" />\n"
23536 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23537 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23538 " </RequiredProperties>\n"
23539 " </ChartSeriesSelectionDomain>\n"
23540 " </StringVectorProperty>\n"
23541 " <StringVectorProperty command=\"SetMarkerSize\"\n"
23542 " clean_command=\"ClearMarkerSizes\"\n"
23543 " element_types=\"str double\"\n"
23544 " name=\"SeriesMarkerSize\"\n"
23545 " number_of_elements_per_command=\"2\"\n"
23546 " repeat_command=\"1\">\n"
23547 " <Documentation>Set the series marker size.</Documentation>\n"
23548 " <ChartSeriesSelectionDomain name=\"array_list\"\n"
23549 " default_mode=\"value\"\n"
23550 " default_value=\"4\">\n"
23551 " <RequiredProperties>\n"
23552 " <Property function=\"Input\" name=\"Input\" />\n"
23553 " <Property function=\"FieldDataSelection\" name=\"AttributeType\" />\n"
23554 " <Property function=\"CompositeIndexSelection\" name=\"CompositeDataSetIndex\" />\n"
23555 " </RequiredProperties>\n"
23556 " </ChartSeriesSelectionDomain>\n"
23557 " </StringVectorProperty>\n"
23558 "\n"
23559 " <PropertyGroup label=\"Series Parameters\"\n"
23560 " panel_widget=\"SeriesEditor\"\n"
23561 " panel_visibility=\"default\" >\n"
23562 " <Property name=\"SeriesVisibility\"\n"
23563 " function=\"SeriesVisibility\" />\n"
23564 " <Property name=\"SeriesColor\"\n"
23565 " function=\"SeriesColor\" />\n"
23566 " <Property name=\"SeriesOpacity\"\n"
23567 " function=\"SeriesOpacity\" />\n"
23568 " <Property name=\"SeriesLineThickness\"\n"
23569 " function=\"SeriesLineThickness\" />\n"
23570 " <Property name=\"SeriesLineStyle\"\n"
23571 " function=\"SeriesLineStyle\" />\n"
23572 " <Property name=\"SeriesLabel\"\n"
23573 " function=\"SeriesLabel\" />\n"
23574 " <Property name=\"SeriesMarkerStyle\"\n"
23575 " function=\"SeriesMarkerStyle\" />\n"
23576 " <Property name=\"SeriesMarkerSize\"\n"
23577 " function=\"SeriesMarkerSize\" />\n"
23578 " <Property name=\"SeriesPlotCorner\"\n"
23579 " function=\"SeriesPlotCorner\"/>\n"
23580 " </PropertyGroup>\n"
23581 " <Hints>\n"
23582 " <InitializationHelper class=\"vtkSMXYChartRepresentationInitializationHelper\" />\n"
23583 " </Hints>\n"
23584 " </ChartRepresentationProxy>\n"
23585 "\n"
23586 " <!-- =================================================================== -->\n"
23587 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
23588 " base_proxyname=\"XYChartRepresentation\"\n"
23589 " class=\"vtkQuartileChartRepresentation\"\n"
23590 " name=\"QuartileChartRepresentation\"\n"
23591 " processes=\"client|dataserver|renderserver\"\n"
23592 " post_creation=\"SetChartTypeToArea\">\n"
23593 " <Documentation>Representation used by Quartile Chart View.</Documentation>\n"
23594 " <IntVectorProperty name=\"ShowQuartiles\"\n"
23595 " command=\"SetQuartileVisibility\"\n"
23596 " number_of_elements=\"1\"\n"
23597 " default_values=\"1\">\n"
23598 " <BooleanDomain name=\"bool\" />\n"
23599 " <Documentation>\n"
23600 " Set whether to render the area for the q1/q3 quartiles, if available.\n"
23601 " </Documentation>\n"
23602 " </IntVectorProperty>\n"
23603 " <IntVectorProperty name=\"ShowRanges\"\n"
23604 " command=\"SetRangeVisibility\"\n"
23605 " number_of_elements=\"1\"\n"
23606 " default_values=\"1\">\n"
23607 " <BooleanDomain name=\"bool\" />\n"
23608 " <Documentation>\n"
23609 " Set whether to render the area for the min/max range, if available.\n"
23610 " </Documentation>\n"
23611 " </IntVectorProperty>\n"
23612 " <IntVectorProperty name=\"ShowAverage\"\n"
23613 " command=\"SetAverageVisibility\"\n"
23614 " number_of_elements=\"1\"\n"
23615 " default_values=\"1\">\n"
23616 " <BooleanDomain name=\"bool\" />\n"
23617 " <Documentation>\n"
23618 " Set whether to render the line for the average value, if available.\n"
23619 " </Documentation>\n"
23620 " </IntVectorProperty>\n"
23621 " <IntVectorProperty name=\"ShowMedian\"\n"
23622 " command=\"SetMedianVisibility\"\n"
23623 " number_of_elements=\"1\"\n"
23624 " default_values=\"0\">\n"
23625 " <BooleanDomain name=\"bool\" />\n"
23626 " <Documentation>\n"
23627 " Set whether to render the line for the median value, if available.\n"
23628 " </Documentation>\n"
23629 " </IntVectorProperty>\n"
23630 " <IntVectorProperty name=\"ShowMinimum\"\n"
23631 " command=\"SetMinVisibility\"\n"
23632 " number_of_elements=\"1\"\n"
23633 " default_values=\"0\">\n"
23634 " <BooleanDomain name=\"bool\" />\n"
23635 " <Documentation>\n"
23636 " Set whether to render the line for the minimum value, if available.\n"
23637 " </Documentation>\n"
23638 " </IntVectorProperty>\n"
23639 " <IntVectorProperty name=\"ShowMaximum\"\n"
23640 " command=\"SetMaxVisibility\"\n"
23641 " number_of_elements=\"1\"\n"
23642 " default_values=\"0\">\n"
23643 " <BooleanDomain name=\"bool\" />\n"
23644 " <Documentation>\n"
23645 " Set whether to render the line for the maximum value, if available.\n"
23646 " </Documentation>\n"
23647 " </IntVectorProperty>\n"
23648 " <IntVectorProperty name=\"ShowSum\"\n"
23649 " command=\"SetSumVisibility\"\n"
23650 " number_of_elements=\"1\"\n"
23651 " default_values=\"0\">\n"
23652 " <BooleanDomain name=\"bool\" />\n"
23653 " <Documentation>\n"
23654 " Set whether to render the line for the sum, if available.\n"
23655 " </Documentation>\n"
23656 " </IntVectorProperty>\n"
23657 " </ChartRepresentationProxy>\n"
23658 "\n"
23659 " <!-- =================================================================== -->\n"
23660 " <ChartRepresentationProxy base_proxygroup=\"representations\"\n"
23661 " base_proxyname=\"XYChartRepresentationBase\"\n"
23662 " class=\"vtkXYChartRepresentation\"\n"
23663 " name=\"XYBarChartRepresentation\"\n"
23664 " processes=\"client|dataserver|renderserver\"\n"
23665 " post_creation=\"SetChartTypeToBar\">\n"
23666 " <Documentation>Representation used by XYBarChartView.</Documentation>\n"
23667 " <PropertyGroup label=\"Series Parameters\"\n"
23668 " panel_widget=\"SeriesEditor\"\n"
23669 " panel_visibility=\"default\" >\n"
23670 " <Property name=\"SeriesVisibility\"\n"
23671 " function=\"SeriesVisibility\" />\n"
23672 " <Property name=\"SeriesColor\"\n"
23673 " function=\"SeriesColor\" />\n"
23674 " <Property name=\"SeriesOpacity\"\n"
23675 " function=\"SeriesOpacity\" />\n"
23676 " <Property name=\"SeriesLabel\"\n"
23677 " function=\"SeriesLabel\" />\n"
23678 " <Property name=\"SeriesPlotCorner\"\n"
23679 " function=\"SeriesPlotCorner\"/>\n"
23680 " </PropertyGroup>\n"
23681 " </ChartRepresentationProxy>\n"
23682 "\n"
23683 " <!-- =================================================================== -->\n"
23684 " <SpreadSheetRepresentationProxy class=\"vtkSpreadSheetRepresentation\"\n"
23685 " name=\"SpreadSheetRepresentation\"\n"
23686 " processes=\"client|dataserver|renderserver\">\n"
23687 " <InputProperty command=\"SetInputConnection\"\n"
23688 " name=\"Input\">\n"
23689 " <Documentation>Data input for the representation.</Documentation>\n"
23690 " <DataTypeDomain name=\"input_type\">\n"
23691 " <DataType value=\"vtkDataObject\" />\n"
23692 " </DataTypeDomain>\n"
23693 " </InputProperty>\n"
23694 " <IntVectorProperty command=\"SetVisibility\"\n"
23695 " default_values=\"1\"\n"
23696 " name=\"Visibility\"\n"
23697 " number_of_elements=\"1\"\n"
23698 " panel_visibility=\"never\">\n"
23699 " <BooleanDomain name=\"bool\" />\n"
23700 " <Documentation>Visibility of the representation.</Documentation>\n"
23701 " </IntVectorProperty>\n"
23702 " <IntVectorProperty command=\"SetForceUseCache\"\n"
23703 " default_values=\"0\"\n"
23704 " is_internal=\"1\"\n"
23705 " name=\"ForceUseCache\"\n"
23706 " number_of_elements=\"1\">\n"
23707 " <BooleanDomain name=\"bool\" />\n"
23708 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
23709 " and representations cache based on what the view tells it. However in\n"
23710 " some cases we may want to force a representation to cache irrespective\n"
23711 " of the view (e.g. comparative views). In which case these ivars can up\n"
23712 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
23713 " Instead, ForcedCacheKey is used.</Documentation>\n"
23714 " </IntVectorProperty>\n"
23715 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
23716 " default_values=\"none\"\n"
23717 " is_internal=\"1\"\n"
23718 " name=\"ForcedCacheKey\"\n"
23719 " number_of_elements=\"1\">\n"
23720 " <DoubleRangeDomain name=\"range\" />\n"
23721 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
23722 " and representations cache based on what the view tells it. However in\n"
23723 " some cases we may want to force a representation to cache irrespective\n"
23724 " of the view (e.g. comparative views). In which case these ivars can up\n"
23725 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
23726 " Instead, ForcedCacheKey is used.</Documentation>\n"
23727 " </DoubleVectorProperty>\n"
23728 "\n"
23729 " <StringVectorProperty name=\"Assembly\"\n"
23730 " command=\"SetActiveAssemblyForSelectors\"\n"
23731 " number_of_elements=\"1\"\n"
23732 " panel_visibility=\"multiblock_inspector\">\n"
23733 " <DataAssemblyListDomain name=\"data_assembly\">\n"
23734 " <RequiredProperties>\n"
23735 " <Property function=\"Input\" name=\"Input\" />\n"
23736 " </RequiredProperties>\n"
23737 ;
23738
23739 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
23741 " </DataAssemblyListDomain>\n"
23742 " <Documentation>\n"
23743 " Select which assembly is used when specify selectors\n"
23744 " to choose blocks to show for composite datasets.\n"
23745 " </Documentation>\n"
23746 " </StringVectorProperty>\n"
23747 "\n"
23748 " <StringVectorProperty name=\"BlockVisibilities\"\n"
23749 " command=\"AddSelector\"\n"
23750 " clean_command=\"ClearSelectors\"\n"
23751 " repeat_command=\"1\"\n"
23752 " number_of_elements_per_command=\"1\"\n"
23753 " panel_visibility=\"multiblock_inspector\"\n"
23754 " default_values=\"/\">\n"
23755 " <DataAssemblyDomain name=\"data_assembly\">\n"
23756 " <RequiredProperties>\n"
23757 " <Property function=\"Input\" name=\"Input\" />\n"
23758 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
23759 " </RequiredProperties>\n"
23760 " </DataAssemblyDomain>\n"
23761 " <Documentation>\n"
23762 " For composite datasets, specify selectors to limit the view\n"
23763 " to a chosen subset of blocks.\n"
23764 " </Documentation>\n"
23765 " </StringVectorProperty>\n"
23766 "\n"
23767 " <PropertyGroup label=\"Blocks\" panel_widget=\"DataAssemblyEditor\"\n"
23768 " panel_visibility=\"multiblock_inspector\">\n"
23769 " <Property name=\"Assembly\" function=\"ActiveAssembly\" />\n"
23770 " <Property name=\"BlockVisibilities\" function=\"Selectors\" />\n"
23771 " <Hints>\n"
23772 " <DataAssemblyPropertyWidget use_inputname_as_header=\"1\" link_active_selection=\"1\"/>\n"
23773 " </Hints>\n"
23774 " </PropertyGroup>\n"
23775 "\n"
23776 " <InputProperty command=\"SetInputConnection\"\n"
23777 " is_internal=\"1\"\n"
23778 " name=\"InternalInput1\"\n"
23779 " port_index=\"1\">\n"
23780 " <Documentation>Internal property. Please don't touch\n"
23781 " this.</Documentation>\n"
23782 " </InputProperty>\n"
23783 " <!-- end of SpreadSheetRepresentation -->\n"
23784 " </SpreadSheetRepresentationProxy>\n"
23785 " <!-- =================================================================== -->\n"
23786 " <RepresentationProxy class=\"vtkTextSourceRepresentation\"\n"
23787 " name=\"TextSourceRepresentation\"\n"
23788 " processes=\"client|dataserver|renderserver\"\n"
23789 " si_class=\"vtkSIProxy\">\n"
23790 " <Documentation>Representation proxy used to show text.</Documentation>\n"
23791 " <InputProperty command=\"SetInputConnection\"\n"
23792 " name=\"Input\">\n"
23793 " <Documentation>Data input for the representation.</Documentation>\n"
23794 " <DataTypeDomain composite_data_supported=\"0\"\n"
23795 " name=\"input_type\">\n"
23796 " <DataType value=\"vtkTable\" />\n"
23797 " </DataTypeDomain>\n"
23798 " </InputProperty>\n"
23799 "\n"
23800 " <IntVectorProperty command=\"SetTextPropMode\"\n"
23801 " default_values=\"0\"\n"
23802 " name=\"TextPropMode\"\n"
23803 " number_of_elements=\"1\">\n"
23804 " <EnumerationDomain name=\"enum\">\n"
23805 " <Entry text=\"2D Text Widget\" value=\"0\" />\n"
23806 " <Entry text=\"Flagpole Actor\" value=\"1\" />\n"
23807 " <Entry text=\"Billboard 3D Text\" value=\"2\" />\n"
23808 " </EnumerationDomain>\n"
23809 " <Documentation>\n"
23810 " Select how you want the text to be represented in the view.\n"
23811 " </Documentation>\n"
23812 " </IntVectorProperty>\n"
23813 "\n"
23814 " <IntVectorProperty command=\"SetVisibility\"\n"
23815 " default_values=\"1\"\n"
23816 " name=\"Visibility\"\n"
23817 " number_of_elements=\"1\"\n"
23818 " panel_visibility=\"never\">\n"
23819 " <BooleanDomain name=\"bool\" />\n"
23820 " </IntVectorProperty>\n"
23821 " <IntVectorProperty command=\"SetForceUseCache\"\n"
23822 " default_values=\"0\"\n"
23823 " is_internal=\"1\"\n"
23824 " name=\"ForceUseCache\"\n"
23825 " number_of_elements=\"1\">\n"
23826 " <BooleanDomain name=\"bool\" />\n"
23827 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
23828 " and representations cache based on what the view tells it. However in\n"
23829 " some cases we may want to force a representation to cache irrespective\n"
23830 " of the view (e.g. comparative views). In which case these ivars can up\n"
23831 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
23832 " Instead, ForcedCacheKey is used.</Documentation>\n"
23833 " </IntVectorProperty>\n"
23834 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
23835 " default_values=\"none\"\n"
23836 " is_internal=\"1\"\n"
23837 " name=\"ForcedCacheKey\"\n"
23838 " number_of_elements=\"1\">\n"
23839 " <DoubleRangeDomain name=\"range\" />\n"
23840 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
23841 " and representations cache based on what the view tells it. However in\n"
23842 " some cases we may want to force a representation to cache irrespective\n"
23843 " of the view (e.g. comparative views). In which case these ivars can up\n"
23844 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
23845 " Instead, ForcedCacheKey is used.</Documentation>\n"
23846 " </DoubleVectorProperty>\n"
23847 " <IntVectorProperty command=\"SetInteractivity\"\n"
23848 " default_values=\"1\"\n"
23849 " name=\"Interactivity\"\n"
23850 " number_of_elements=\"1\">\n"
23851 " <BooleanDomain name=\"bool\" />\n"
23852 " <Documentation>\n"
23853 " Set whether user should be able to interactively place the text in the view.\n"
23854 " </Documentation>\n"
23855 " <Hints>\n"
23856 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23857 " mode=\"visibility\"\n"
23858 " property=\"TextPropMode\"\n"
23859 " value=\"0\" />\n"
23860 "\n"
23861 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23862 " mode=\"enabled_state\"\n"
23863 " property=\"WindowLocation\"\n"
23864 " value=\"0\" />\n"
23865 " </Hints>\n"
23866 " </IntVectorProperty>\n"
23867 "\n"
23868 " <SubProxy command=\"SetTextWidgetRepresentation\">\n"
23869 " <Proxy name=\"TextWidgetRepresentation\"\n"
23870 " proxygroup=\"representations\"\n"
23871 " proxyname=\"TextWidgetRepresentation\"></Proxy>\n"
23872 " <ExposedProperties>\n"
23873 " <!-- properties for Text Position-->\n"
23874 " <PropertyGroup name=\"TextPosition\" label=\"Text Position\" panel_widget=\"TextLocationEditor\">\n"
23875 " <Property name=\"WindowLocation\" />\n"
23876 " <Property name=\"Position\" />\n"
23877 " <Property name=\"Position2\" panel_visibility=\"never\"/>\n"
23878 " <Property name=\"PositionInfo\" />\n"
23879 " <Property name=\"Position2Info\" />\n"
23880 " <Hints>\n"
23881 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23882 " mode=\"visibility\"\n"
23883 " property=\"TextPropMode\"\n"
23884 " value=\"0\" />\n"
23885 " </Hints>\n"
23886 " </PropertyGroup>\n"
23887 " <Property name=\"TextScaleMode\" panel_visibility=\"never\" default_values=\"0\"/>\n"
23888 " <Property name=\"Resizable\" panel_visibility=\"never\"/>\n"
23889 "\n"
23890 " <!-- properties for Text -->\n"
23891 " <Property name=\"Orientation\" panel_visibility=\"never\"/>\n"
23892 " <PropertyGroup label=\"Font Properties\" panel_widget=\"FontEditor\">\n"
23893 " <Property name=\"Color\" function=\"Color\"/>\n"
23894 " <Property name=\"Opacity\" function=\"Opacity\"/>\n"
23895 " <Property name=\"FontFamily\" function=\"Family\"/>\n"
23896 " <Property name=\"FontFile\" function=\"File\"/>\n"
23897 " <Property name=\"Bold\" function=\"Bold\"/>\n"
23898 " <Property name=\"Italic\" function=\"Italics\" />\n"
23899 " <Property name=\"Shadow\" function=\"Shadow\"/>\n"
23900 " <Property name=\"FontSize\" function=\"Size\"/>\n"
23901 " <Property name=\"Justification\" function=\"Justification\" default_values=\"1\" />\n"
23902 " <Property name=\"VerticalJustification\" function=\"VerticalJustification\"/>\n"
23903 " </PropertyGroup>\n"
23904 "\n"
23905 " <Property name=\"ShowBorder\" label=\"Show Background\" />\n"
23906 " <PropertyGroup label=\"Background Properties\">\n"
23907 " <Property name=\"BackgroundColor\" default_values=\"1 1 1 0.2\"/>\n"
23908 " <Property name=\"BorderColor\" panel_visibility=\"advanced\"/>\n"
23909 " <Property name=\"BorderThickness\" panel_visibility=\"advanced\"/>\n"
23910 " <Property name=\"CornerRadius\" panel_visibility=\"advanced\"/>\n"
23911 " <Property name=\"Padding\" panel_visibility=\"advanced\" default_values=\"1\" />\n"
23912 "\n"
23913 " <Hints>\n"
23914 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23915 " mode=\"visibility\"\n"
23916 " property=\"TextPropMode\"\n"
23917 " value=\"0\" />\n"
23918 "\n"
23919 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
23920 " <Expression type=\"or\">\n"
23921 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23922 " mode=\"visibility\"\n"
23923 " property=\"ShowBorder\"\n"
23924 " value=\"1\" />\n"
23925 "\n"
23926 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23927 " mode=\"visibility\"\n"
23928 " property=\"ShowBorder\"\n"
23929 " value=\"2\" />\n"
23930 " </Expression>\n"
23931 " </PropertyWidgetDecorator>\n"
23932 " </Hints>\n"
23933 "\n"
23934 " </PropertyGroup>\n"
23935 "\n"
23936 " <PropertyGroup label=\"Multi Cell Properties\">\n"
23937 " <Property name=\"LineSpacing\" panel_visibility=\"advanced\" />\n"
23938 " <Property name=\"CellOffset\" panel_visibility=\"advanced\" />\n"
23939 " <Property name=\"InteriorLinesWidth\" panel_visibility=\"advanced\" />\n"
23940 " <Property name=\"InteriorLinesColor\" panel_visibility=\"advanced\" />\n"
23941 " <Property name=\"InteriorLinesVisibility\" panel_visibility=\"advanced\" />\n"
23942 " </PropertyGroup>\n"
23943 " </ExposedProperties>\n"
23944 " </SubProxy>\n"
23945 "\n"
23946 " <SubProxy command=\"SetFlagpoleLabel\">\n"
23947 " <Proxy name=\"FlagpoleLabel\"\n"
23948 " proxygroup=\"annotations\"\n"
23949 " proxyname=\"FlagpoleLabel\"></Proxy>\n"
23950 " <ShareProperties subproxy=\"TextWidgetRepresentation\">\n"
23951 " <Exception name=\"Orientation\" />\n"
23952 " <Exception name=\"WindowLocation\" />\n"
23953 " <Exception name=\"Position\" />\n"
23954 " <Exception name=\"Position2\" />\n"
23955 " <Exception name=\"PositionInfo\" />\n"
23956 " <Exception name=\"Position2Info\" />\n"
23957 " <Exception name=\"TextScaleMode\" />\n"
23958 " <Exception name=\"Resizable\" />\n"
23959 " </ShareProperties>\n"
23960 " <ExposedProperties>\n"
23961 " <!-- properties for Text -->\n"
23962 " <PropertyGroup label=\"Flagpole Properties\">\n"
23963 " <Property name=\"BasePosition\" />\n"
23964 " <Property name=\"TopPosition\" />\n"
23965 " <Property name=\"FlagSize\" />\n"
23966 " <Hints>\n"
23967 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23968 " mode=\"visibility\"\n"
23969 " property=\"TextPropMode\"\n"
23970 " value=\"1\" />\n"
23971 " </Hints>\n"
23972 " </PropertyGroup>\n"
23973 " </ExposedProperties>\n"
23974 " </SubProxy>\n"
23975 "\n"
23976 " <SubProxy command=\"SetBillboardTextActor\">\n"
23977 " <Proxy name=\"BillboardTextActor3D\"\n"
23978 " proxygroup=\"annotations\"\n"
23979 " proxyname=\"BillboardTextActor3D\"></Proxy>\n"
23980 " <ShareProperties subproxy=\"TextWidgetRepresentation\">\n"
23981 " <Exception name=\"Orientation\" />\n"
23982 " <Exception name=\"WindowLocation\" />\n"
23983 " <Exception name=\"Position\" />\n"
23984 " <Exception name=\"Position2\" />\n"
23985 " <Exception name=\"PositionInfo\" />\n"
23986 " <Exception name=\"Position2Info\" />\n"
23987 " <Exception name=\"TextScaleMode\" />\n"
23988 " <Exception name=\"Resizable\" />\n"
23989 " </ShareProperties>\n"
23990 " <ExposedProperties>\n"
23991 " <!-- properties for Text -->\n"
23992 " <PropertyGroup label=\"Billboard Position\" panel_widget=\"InteractiveHandle\">\n"
23993 " <Property function=\"WorldPosition\" name=\"BillboardPosition\" />\n"
23994 " <Hints>\n"
23995 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
23996 " mode=\"visibility\"\n"
23997 " property=\"TextPropMode\"\n"
23998 " value=\"2\" />\n"
23999 " </Hints>\n"
24000 " </PropertyGroup>\n"
24001 " <PropertyGroup label=\"Billboard Properties\">\n"
24002 " <Property name=\"DisplayOffset\" />\n"
24003 " <Hints>\n"
24004 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
24005 " mode=\"visibility\"\n"
24006 " property=\"TextPropMode\"\n"
24007 " value=\"2\" />\n"
24008 " </Hints>\n"
24009 " </PropertyGroup>\n"
24010 " </ExposedProperties>\n"
24011 " </SubProxy>\n"
24012 " <!-- End of TextSourceRepresentation -->\n"
24013 " </RepresentationProxy>\n"
24014 " <!-- =================================================================== -->\n"
24015 " <RepresentationProxy class=\"vtkRulerSourceRepresentation\"\n"
24016 " name=\"RulerSourceRepresentation\"\n"
24017 " processes=\"client|dataserver|renderserver\"\n"
24018 " si_class=\"vtkSIProxy\">\n"
24019 " <Documentation>Representation proxy used to show a ruler.</Documentation>\n"
24020 " <InputProperty command=\"SetInputConnection\"\n"
24021 " name=\"Input\">\n"
24022 " <Documentation>Data input for the representation.</Documentation>\n"
24023 " <DataTypeDomain composite_data_supported=\"0\"\n"
24024 " name=\"input_type\">\n"
24025 " <DataType value=\"vtkPolyData\" />\n"
24026 " </DataTypeDomain>\n"
24027 " </InputProperty>\n"
24028 " <IntVectorProperty command=\"SetVisibility\"\n"
24029 " default_values=\"1\"\n"
24030 " name=\"Visibility\"\n"
24031 " number_of_elements=\"1\"\n"
24032 " panel_visibility=\"advanced\">\n"
24033 " <BooleanDomain name=\"bool\" />\n"
24034 " </IntVectorProperty>\n"
24035 "\n"
24036 " <StringVectorProperty command=\"SetLabelFormat\"\n"
24037 " default_values=\"%6.3g\"\n"
24038 " name=\"LabelFormat\"\n"
24039 " number_of_elements=\"1\">\n"
24040 " <Documentation>\n"
24041 " This should be a printf-style format string. You can do things\n"
24042 " like limit the number of significant digits, add prefixes/suffixes,\n"
24043 " basically anything that printf can do. An empty string or a string\n"
24044 " without the % symbol results in no label.\n"
24045 " </Documentation>\n"
24046 " </StringVectorProperty>\n"
24047 "\n"
24048 " <DoubleVectorProperty name=\"Scale\"\n"
24049 " command=\"SetScale\"\n"
24050 " number_of_elements=\"1\"\n"
24051 " default_values=\"1.\">\n"
24052 " <Documentation>\n"
24053 " Scale factor applied to the global coordinate distance. Used to convert between the units used in the data set global coordinate distance to desired units. Example: convert from inches to centimeters by setting this value to 0.3937.\n"
24054 ;
24055
24056 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
24058 " </Documentation>\n"
24059 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
24060 " </DoubleVectorProperty>\n"
24061 "\n"
24062 " <IntVectorProperty name=\"RulerMode\"\n"
24063 " command=\"SetRulerMode\"\n"
24064 " number_of_elements=\"1\"\n"
24065 " default_values=\"0\">\n"
24066 " <Documentation>\n"
24067 " Check to enable \"ruler mode\", where ticks are placed at increments\n"
24068 " defined by the Graduation property.\n"
24069 " </Documentation>\n"
24070 " <BooleanDomain name=\"bool\" />\n"
24071 " </IntVectorProperty>\n"
24072 "\n"
24073 " <IntVectorProperty name=\"NumberOfTicks\"\n"
24074 " command=\"SetNumberOfRulerTicks\"\n"
24075 " number_of_elements=\"1\"\n"
24076 " default_values=\"5\">\n"
24077 " <Documentation>\n"
24078 " Specify the number of major ruler ticks. Note: the number of ticks is the number between the two handle endpoints.\n"
24079 " </Documentation>\n"
24080 " <IntRangeDomain name=\"range\" min=\"1\" />\n"
24081 " <Hints>\n"
24082 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
24083 " mode=\"visibility\"\n"
24084 " property=\"RulerMode\"\n"
24085 " value=\"0\" />\n"
24086 " </Hints>\n"
24087 " </IntVectorProperty>\n"
24088 "\n"
24089 " <DoubleVectorProperty name=\"Graduation\"\n"
24090 " command=\"SetRulerDistance\"\n"
24091 " number_of_elements=\"1\"\n"
24092 " default_values=\"1.\">\n"
24093 " <Documentation>\n"
24094 " Specify the graduation, or the spacing of the ruler tick marks. Spacing is defined in the scaled global coordinate distance (see the Scale property). For example, if data is defined in terms of inches and the Scale property is set to display distances in centimeters, this property defines the spacing of tick marks in terms of centimeters.\n"
24095 " </Documentation>\n"
24096 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
24097 " <Hints>\n"
24098 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
24099 " mode=\"visibility\"\n"
24100 " property=\"RulerMode\"\n"
24101 " value=\"1\" />\n"
24102 " </Hints>\n"
24103 " </DoubleVectorProperty>\n"
24104 "\n"
24105 " <PropertyGroup label=\"Label Properties\">\n"
24106 " <Property name=\"RulerMode\" />\n"
24107 " <Property name=\"LabelFormat\" />\n"
24108 " <Property name=\"NumberOfTicks\" />\n"
24109 " <Property name=\"Graduation\" />\n"
24110 " <Property name=\"Scale\" />\n"
24111 " </PropertyGroup>\n"
24112 "\n"
24113 " <DoubleVectorProperty command=\"SetAxisColor\"\n"
24114 " default_values=\"0 1 0\"\n"
24115 " name=\"AxisColor\"\n"
24116 " number_of_elements=\"3\"\n"
24117 " panel_widget=\"color_selector_with_palette\">\n"
24118 " <DoubleRangeDomain max=\"1 1 1\"\n"
24119 " min=\"0 0 0\"\n"
24120 " name=\"range\" />\n"
24121 " <Documentation>Set the color of the ruler.</Documentation>\n"
24122 " </DoubleVectorProperty>\n"
24123 "\n"
24124 " <DoubleVectorProperty command=\"SetAxisLineWidth\"\n"
24125 " default_values=\"2\"\n"
24126 " name=\"AxisLineWidth\"\n"
24127 " number_of_elements=\"1\">\n"
24128 " <DoubleRangeDomain min=\"0\" name=\"range\" />\n"
24129 " <Documentation>Set the line width of the ruler in screen units.</Documentation>\n"
24130 " </DoubleVectorProperty>\n"
24131 "\n"
24132 " <PropertyGroup label=\"Axis Display Properties\">\n"
24133 " <Property name=\"AxisColor\" />\n"
24134 " <Property name=\"AxisLineWidth\" />\n"
24135 " </PropertyGroup>\n"
24136 "\n"
24137 " <SubProxy command=\"SetTextProperty\">\n"
24138 " <Proxy name=\"TextProperty\"\n"
24139 " proxygroup=\"properties\"\n"
24140 " proxyname=\"TextProperty\"></Proxy>\n"
24141 " <ExposedProperties>\n"
24142 " <PropertyGroup label=\"Font Properties\" panel_widget=\"FontEditor\">\n"
24143 " <Property name=\"Color\" function=\"Color\"/>\n"
24144 " <Property name=\"Opacity\" function=\"Opacity\"/>\n"
24145 " <Property name=\"FontFamily\" function=\"Family\"/>\n"
24146 " <Property name=\"FontFile\" function=\"File\"/>\n"
24147 " <Property name=\"Bold\" function=\"Bold\"/>\n"
24148 " <Property name=\"Italic\" function=\"Italics\" />\n"
24149 " <Property name=\"Shadow\" function=\"Shadow\"/>\n"
24150 " <Property name=\"FontSize\" function=\"Size\"/>\n"
24151 " <Property name=\"Justification\" function=\"Justification\"/>\n"
24152 " </PropertyGroup>\n"
24153 " </ExposedProperties>\n"
24154 " </SubProxy>\n"
24155 "\n"
24156 " <!-- End of RulerSourceRepresentation -->\n"
24157 " </RepresentationProxy>\n"
24158 " <!-- =================================================================== -->\n"
24159 " <RepresentationProxy class=\"vtkProtractorRepresentation\"\n"
24160 " name=\"ProtractorRepresentation\"\n"
24161 " processes=\"client|dataserver|renderserver\"\n"
24162 " si_class=\"vtkSIProxy\">\n"
24163 " <Documentation>\n"
24164 " Representation proxy used to show an angle.\n"
24165 " The angle is defined by 3 points and the representation shows 2 lines\n"
24166 " as well as the angle value formed by these 2 lines as a label.\n"
24167 " </Documentation>\n"
24168 " <InputProperty command=\"SetInputConnection\"\n"
24169 " name=\"Input\">\n"
24170 " <Documentation>Data input for the representation.</Documentation>\n"
24171 " <DataTypeDomain composite_data_supported=\"0\"\n"
24172 " name=\"input_type\">\n"
24173 " <DataType value=\"vtkPolyData\" />\n"
24174 " </DataTypeDomain>\n"
24175 " </InputProperty>\n"
24176 "\n"
24177 " <IntVectorProperty command=\"SetVisibility\"\n"
24178 " default_values=\"1\"\n"
24179 " name=\"Visibility\"\n"
24180 " number_of_elements=\"1\">\n"
24181 " <BooleanDomain name=\"bool\" />\n"
24182 " </IntVectorProperty>\n"
24183 "\n"
24184 " <DoubleVectorProperty command=\"SetLineColor\"\n"
24185 " default_values=\"0 1 0\"\n"
24186 " name=\"LineColor\"\n"
24187 " number_of_elements=\"3\"\n"
24188 " panel_widget=\"color_selector_with_palette\">\n"
24189 " <DoubleRangeDomain max=\"1 1 1\"\n"
24190 " min=\"0 0 0\"\n"
24191 " name=\"range\" />\n"
24192 " <Documentation>Set the color of the ruler.</Documentation>\n"
24193 " </DoubleVectorProperty>\n"
24194 "\n"
24195 " <DoubleVectorProperty command=\"SetLineThickness\"\n"
24196 " default_values=\"2\"\n"
24197 " name=\"LineThickness\"\n"
24198 " number_of_elements=\"1\" >\n"
24199 " <DoubleRangeDomain max=\"10\" min=\"1\" name=\"range\" />\n"
24200 " <Documentation>Set the thickness of all lines.</Documentation>\n"
24201 " </DoubleVectorProperty>\n"
24202 "\n"
24203 " <IntVectorProperty command=\"SetArrowStyle\"\n"
24204 " default_values=\"0\"\n"
24205 " name=\"ArrowStyle\"\n"
24206 " panel_visibility=\"advanced\"\n"
24207 " number_of_elements=\"1\">\n"
24208 " <Documentation>Set the style of the tip of each axes.</Documentation>\n"
24209 " <EnumerationDomain name=\"enum\">\n"
24210 " <Entry text=\"Filled\" value=\"0\" />\n"
24211 " <Entry text=\"Empty\" value=\"1\" />\n"
24212 " <Entry text=\"Hollow\" value=\"2\" />\n"
24213 " </EnumerationDomain>\n"
24214 " </IntVectorProperty>\n"
24215 "\n"
24216 " <SubProxy command=\"SetTextProperty\">\n"
24217 " <Proxy name=\"TextProperty\"\n"
24218 " proxygroup=\"properties\"\n"
24219 " proxyname=\"TextProperty\"></Proxy>\n"
24220 " <ExposedProperties>\n"
24221 " <PropertyGroup label=\"Font Properties\" panel_widget=\"FontEditor\">\n"
24222 " <Property name=\"FontSize\" function=\"Size\" />\n"
24223 " <Property name=\"Color\" function=\"Color\"/>\n"
24224 " <Property name=\"Opacity\" function=\"Opacity\"/>\n"
24225 " <Property name=\"FontFamily\" function=\"Family\"/>\n"
24226 " <Property name=\"FontFile\" function=\"File\"/>\n"
24227 " <Property name=\"Bold\" function=\"Bold\"/>\n"
24228 " <Property name=\"Italic\" function=\"Italics\" />\n"
24229 " <Property name=\"Shadow\" function=\"Shadow\"/>\n"
24230 " <Property name=\"Justification\" function=\"Justification\" default_values=\"1\"/>\n"
24231 " </PropertyGroup>\n"
24232 " </ExposedProperties>\n"
24233 " </SubProxy>\n"
24234 "\n"
24235 " <StringVectorProperty command=\"SetLabelFormat\"\n"
24236 " default_values=\"%6.3g\"\n"
24237 " name=\"LabelFormat\"\n"
24238 " panel_visibility=\"advanced\"\n"
24239 " number_of_elements=\"1\">\n"
24240 " <Documentation>\n"
24241 " This should be a printf-style format string. You can do things\n"
24242 " like limit the number of significant digits, add prefixes/suffixes,\n"
24243 " basically anything that printf can do. An empty string or a string\n"
24244 " without the % symbol results in no label.\n"
24245 " </Documentation>\n"
24246 " </StringVectorProperty>\n"
24247 "\n"
24248 " <DoubleVectorProperty command=\"SetAngleScale\"\n"
24249 " default_values=\"1\"\n"
24250 " name=\"AngleScale\"\n"
24251 " panel_visibility=\"advanced\"\n"
24252 " number_of_elements=\"1\">\n"
24253 " <Documentation>\n"
24254 " Set the scale factor from degrees. The label will be defined in terms of the scaled space. For\n"
24255 " example, to use radians in the label set the scale factor to pi/180.\n"
24256 " </Documentation>\n"
24257 " </DoubleVectorProperty>\n"
24258 "\n"
24259 " <!-- End of ProtractorRepresentation -->\n"
24260 " </RepresentationProxy>\n"
24261 " <!-- =================================================================== -->\n"
24262 " <RepresentationProxy class=\"vtkProgressBarSourceRepresentation\"\n"
24263 " name=\"ProgressBarSourceRepresentation\"\n"
24264 " processes=\"client|dataserver|renderserver\"\n"
24265 " si_class=\"vtkSIProxy\">\n"
24266 " <Documentation>Representation proxy used to show ProgressBar.</Documentation>\n"
24267 " <InputProperty command=\"SetInputConnection\"\n"
24268 " name=\"Input\">\n"
24269 " <Documentation>Data input for the representation.</Documentation>\n"
24270 " <DataTypeDomain composite_data_supported=\"0\"\n"
24271 " name=\"input_type\">\n"
24272 " <DataType value=\"vtkTable\" />\n"
24273 " </DataTypeDomain>\n"
24274 " </InputProperty>\n"
24275 " <IntVectorProperty command=\"SetVisibility\"\n"
24276 " default_values=\"1\"\n"
24277 " name=\"Visibility\"\n"
24278 " number_of_elements=\"1\"\n"
24279 " panel_visibility=\"never\">\n"
24280 " <BooleanDomain name=\"bool\" />\n"
24281 " </IntVectorProperty>\n"
24282 " <IntVectorProperty command=\"SetForceUseCache\"\n"
24283 " default_values=\"0\"\n"
24284 " is_internal=\"1\"\n"
24285 " name=\"ForceUseCache\"\n"
24286 " number_of_elements=\"1\">\n"
24287 " <BooleanDomain name=\"bool\" />\n"
24288 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
24289 " and representations cache based on what the view tells it. However in\n"
24290 " some cases we may want to force a representation to cache irrespective\n"
24291 " of the view (e.g. comparative views). In which case these ivars can up\n"
24292 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
24293 " Instead, ForcedCacheKey is used.</Documentation>\n"
24294 " </IntVectorProperty>\n"
24295 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
24296 " default_values=\"none\"\n"
24297 " is_internal=\"1\"\n"
24298 " name=\"ForcedCacheKey\"\n"
24299 " number_of_elements=\"1\">\n"
24300 " <DoubleRangeDomain name=\"range\" />\n"
24301 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
24302 " and representations cache based on what the view tells it. However in\n"
24303 " some cases we may want to force a representation to cache irrespective\n"
24304 " of the view (e.g. comparative views). In which case these ivars can up\n"
24305 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
24306 " Instead, ForcedCacheKey is used.</Documentation>\n"
24307 " </DoubleVectorProperty>\n"
24308 " <IntVectorProperty command=\"SetInteractivity\"\n"
24309 " default_values=\"1\"\n"
24310 " name=\"Interactivity\"\n"
24311 " number_of_elements=\"1\">\n"
24312 " <BooleanDomain name=\"bool\" />\n"
24313 " <Documentation>\n"
24314 " Set whether user should be able to interactively place the progressBar in the view.\n"
24315 " </Documentation>\n"
24316 " </IntVectorProperty>\n"
24317 " <SubProxy command=\"SetProgressBarWidgetRepresentation\">\n"
24318 " <Proxy name=\"ProgressBarWidgetRepresentation\"\n"
24319 " proxygroup=\"representations\"\n"
24320 " proxyname=\"ProgressBarWidgetRepresentation\"></Proxy>\n"
24321 " <ExposedProperties>\n"
24322 " <Property name=\"Position\" />\n"
24323 " <Property name=\"Position2\" panel_visibility=\"never\"/>\n"
24324 " <Property name=\"PositionInfo\" />\n"
24325 " <Property name=\"Position2Info\" />\n"
24326 " <Property name=\"ProgressBarColor\"/>\n"
24327 " <Property name=\"SecondaryProgressBarColor\"/>\n"
24328 " <Property name=\"DrawBackground\"/>\n"
24329 " </ExposedProperties>\n"
24330 " </SubProxy>\n"
24331 " <!-- End of ProgressBarSourceRepresentation -->\n"
24332 " </RepresentationProxy>\n"
24333 " <!-- =================================================================== -->\n"
24334 " <RepresentationProxy class=\"vtkLogoSourceRepresentation\"\n"
24335 " name=\"LogoSourceRepresentation\"\n"
24336 " processes=\"client|dataserver|renderserver\"\n"
24337 " si_class=\"vtkSIProxy\">\n"
24338 " <Documentation>Representation proxy used to show a Logo.</Documentation>\n"
24339 " <InputProperty command=\"SetInputConnection\"\n"
24340 " name=\"Input\">\n"
24341 " <DataTypeDomain name=\"input_type\">\n"
24342 " <DataType value=\"vtkImageData\" />\n"
24343 " </DataTypeDomain>\n"
24344 " <Documentation>ImageData input for the representation.</Documentation>\n"
24345 " </InputProperty>\n"
24346 " <IntVectorProperty command=\"SetVisibility\"\n"
24347 " default_values=\"1\"\n"
24348 " name=\"Visibility\"\n"
24349 " number_of_elements=\"1\"\n"
24350 " panel_visibility=\"never\">\n"
24351 " <BooleanDomain name=\"bool\" />\n"
24352 " </IntVectorProperty>\n"
24353 " <IntVectorProperty command=\"SetInteractivity\"\n"
24354 " default_values=\"1\"\n"
24355 " name=\"Interactivity\"\n"
24356 " number_of_elements=\"1\">\n"
24357 " <BooleanDomain name=\"bool\" />\n"
24358 " <Documentation>\n"
24359 " Set whether user should be able to interactively place the Logo in the view.\n"
24360 " </Documentation>\n"
24361 " </IntVectorProperty>\n"
24362 " <IntVectorProperty command=\"SetInteractiveScaling\"\n"
24363 " default_values=\"1\"\n"
24364 " name=\"InteractiveScaling\"\n"
24365 " number_of_elements=\"1\">\n"
24366 " <BooleanDomain name=\"bool\" />\n"
24367 " <Documentation>\n"
24368 " Set whether user should be able to interactively scale the Logo in the view (when checked)\n"
24369 " or choose the scaling in the properties panel (when unchecked).\n"
24370 ;
24371
24372 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
24374 " </Documentation>\n"
24375 " </IntVectorProperty>\n"
24376 " <DoubleVectorProperty command=\"SetImageScale\"\n"
24377 " default_values=\"0.08\"\n"
24378 " name=\"ImageScale\"\n"
24379 " number_of_elements=\"1\">\n"
24380 " <DoubleRangeDomain max=\"2\"\n"
24381 " min=\"0.01\"\n"
24382 " name=\"range\" />\n"
24383 " <Hints>\n"
24384 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24385 " <Property name=\"InteractiveScaling\"\n"
24386 " function=\"boolean_invert\" />\n"
24387 " </PropertyWidgetDecorator>\n"
24388 " </Hints>\n"
24389 " <Documentation>\n"
24390 " Scale of the logo, relative to render view height. Ratio is preserved.\n"
24391 " </Documentation>\n"
24392 " </DoubleVectorProperty>\n"
24393 " <DoubleVectorProperty command=\"SetOpacity\"\n"
24394 " default_values=\"1.0\"\n"
24395 " name=\"Opacity\"\n"
24396 " number_of_elements=\"1\">\n"
24397 " <DoubleRangeDomain max=\"1\"\n"
24398 " min=\"0\"\n"
24399 " name=\"range\" />\n"
24400 " </DoubleVectorProperty>\n"
24401 "\n"
24402 " <SubProxy command=\"SetLogoWidgetRepresentation\">\n"
24403 " <Proxy name=\"LogoWidgetRepresentation\"\n"
24404 " proxygroup=\"representations\"\n"
24405 " proxyname=\"LogoWidgetRepresentation\"></Proxy>\n"
24406 " <ExposedProperties>\n"
24407 " <Property name=\"ShowBorder\" />\n"
24408 " <Property name=\"BorderThickness\" />\n"
24409 " <Property name=\"BorderColor\" />\n"
24410 " <PropertyGroup name=\"LogoPosition\" label=\"Logo Position\" panel_widget=\"TextLocationEditor\">\n"
24411 " <Property name=\"WindowLocation\" />\n"
24412 " <Property name=\"Position\" />\n"
24413 " <Property name=\"Position2\" panel_visibility=\"never\"/>\n"
24414 " <Property name=\"PositionInfo\" />\n"
24415 " <Property name=\"Position2Info\" />\n"
24416 " </PropertyGroup>\n"
24417 " </ExposedProperties>\n"
24418 " </SubProxy>\n"
24419 " <!-- End of LogoSourceRepresentation -->\n"
24420 " </RepresentationProxy>\n"
24421 " <!-- =================================================================== -->\n"
24422 " <Proxy class=\"vtkPVFrustumActor\"\n"
24423 " name=\"FrustumWidget\"\n"
24424 " processes=\"client|dataserver|renderserver\">\n"
24425 " <Documentation>Representation for a frustum</Documentation>\n"
24426 " <DoubleVectorProperty argument_is_array=\"1\"\n"
24427 " command=\"SetFrustum\"\n"
24428 " default_values=\"0 0 0 1 0 0 0 1 0 1 1 0 0 0 1 1 0 1 0 1 1 1 1 1\"\n"
24429 " name=\"Frustum\"\n"
24430 " number_of_elements=\"24\">\n"
24431 " <Documentation>Specify the corners of the outline when in Oriented\n"
24432 " mode, the values are supplied as 8*3 double values.</Documentation>\n"
24433 " </DoubleVectorProperty>\n"
24434 " <IntVectorProperty command=\"SetVisibility\"\n"
24435 " default_values=\"1\"\n"
24436 " name=\"Visibility\"\n"
24437 " number_of_elements=\"1\">\n"
24438 " <BooleanDomain name=\"bool\" />\n"
24439 " </IntVectorProperty>\n"
24440 " <DoubleVectorProperty command=\"SetColor\"\n"
24441 " default_values=\"0.5 0.5 0.5\"\n"
24442 " name=\"Color\"\n"
24443 " number_of_elements=\"3\">\n"
24444 " <DoubleRangeDomain max=\"1 1 1\"\n"
24445 " min=\"0 0 0\"\n"
24446 " name=\"range\" />\n"
24447 " <Hints>\n"
24448 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"TextAnnotationColor\" unlink_if_modified=\"1\" />\n"
24449 " </Hints>\n"
24450 " </DoubleVectorProperty>\n"
24451 " <DoubleVectorProperty command=\"SetLineWidth\"\n"
24452 " default_values=\"3.0\"\n"
24453 " name=\"LineWidth\"\n"
24454 " number_of_elements=\"1\">\n"
24455 " <DoubleRangeDomain min=\"0\"\n"
24456 " name=\"range\" />\n"
24457 " </DoubleVectorProperty>\n"
24458 " <!-- End of FrustumWidget -->\n"
24459 " </Proxy>\n"
24460 "\n"
24461 " <!-- ================================================================== -->\n"
24462 " <RepresentationProxy name=\"GeometrySliceRepresentation\"\n"
24463 " base_proxygroup=\"internal_representations\"\n"
24464 " base_proxyname=\"SurfaceRepresentationBase\"\n"
24465 " class=\"vtkGeometrySliceRepresentation\"\n"
24466 " processes=\"client|renderserver|dataserver\">\n"
24467 " <Documentation>\n"
24468 " GeometrySliceRepresentation add support to show multiple slices in the view.\n"
24469 " This is used by CompositeMultiSliceRepresentation.\n"
24470 " </Documentation>\n"
24471 " <InputProperty command=\"SetInputConnection\"\n"
24472 " name=\"Input\">\n"
24473 " <DataTypeDomain name=\"input_type\">\n"
24474 " <DataType value=\"vtkDataSet\" />\n"
24475 " </DataTypeDomain>\n"
24476 " <Documentation>Set the input to the representation.</Documentation>\n"
24477 " </InputProperty>\n"
24478 "\n"
24479 " <IntVectorProperty name=\"ShowOutline\"\n"
24480 " command=\"SetShowOutline\"\n"
24481 " number_of_elements=\"1\"\n"
24482 " default_values=\"0\">\n"
24483 " <Documentation>\n"
24484 " Check to show data outline when showing \"Slices\".\n"
24485 " </Documentation>\n"
24486 " <BooleanDomain name=\"bool\" />\n"
24487 " </IntVectorProperty>\n"
24488 " </RepresentationProxy>\n"
24489 "\n"
24490 " <!-- ================================================================ -->\n"
24491 " <PVRepresentationProxy name=\"CompositeMultiSliceRepresentation\"\n"
24492 " base_proxygroup=\"representations\"\n"
24493 " base_proxyname=\"GeometryRepresentation\"\n"
24494 " class=\"vtkPVCompositeRepresentation\"\n"
24495 " processes=\"client|renderserver|dataserver\" >\n"
24496 " <RepresentationType subproxy=\"GeometrySliceRepresentation\"\n"
24497 " text=\"Slices\" subtype=\"Surface\"/>\n"
24498 " <SubProxy>\n"
24499 " <Proxy name=\"GeometrySliceRepresentation\"\n"
24500 " proxygroup=\"representations\"\n"
24501 " proxyname=\"GeometrySliceRepresentation\">\n"
24502 " </Proxy>\n"
24503 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
24504 " <Exception name=\"Input\" />\n"
24505 " <Exception name=\"Visibility\" />\n"
24506 " </ShareProperties>\n"
24507 " <ExposedProperties>\n"
24508 " <PropertyGroup label=\"Slices Parameters\">\n"
24509 " <Property name=\"ShowOutline\"\n"
24510 " panel_visibility=\"advanced\"\n"
24511 " panel_visibility_default_for_representation=\"slices\" />\n"
24512 " </PropertyGroup>\n"
24513 " </ExposedProperties>\n"
24514 " </SubProxy>\n"
24515 " </PVRepresentationProxy>\n"
24516 "\n"
24517 " <!-- ================================================================ -->\n"
24518 " <PVRepresentationProxy name=\"CompositeOrthographicSliceRepresentation\"\n"
24519 " base_proxygroup=\"representations\"\n"
24520 " base_proxyname=\"CompositeMultiSliceRepresentation\"\n"
24521 " class=\"vtkPVCompositeOrthographicSliceRepresentation\"\n"
24522 " processes=\"client|renderserver|dataserver\">\n"
24523 " <SubProxy command=\"SetSliceRepresentation0\">\n"
24524 " <Proxy name=\"GeometrySliceRepresentationX\"\n"
24525 " proxygroup=\"representations\"\n"
24526 " proxyname=\"GeometrySliceRepresentation\">\n"
24527 " </Proxy>\n"
24528 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
24529 " <Exception name=\"Input\" />\n"
24530 " <Exception name=\"Visibility\" />\n"
24531 " </ShareProperties>\n"
24532 " </SubProxy>\n"
24533 " <SubProxy command=\"SetSliceRepresentation1\">\n"
24534 " <Proxy name=\"GeometrySliceRepresentationY\"\n"
24535 " proxygroup=\"representations\"\n"
24536 " proxyname=\"GeometrySliceRepresentation\">\n"
24537 " </Proxy>\n"
24538 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
24539 " <Exception name=\"Input\" />\n"
24540 " <Exception name=\"Visibility\" />\n"
24541 " </ShareProperties>\n"
24542 " </SubProxy>\n"
24543 " <SubProxy command=\"SetSliceRepresentation2\">\n"
24544 " <Proxy name=\"GeometrySliceRepresentationZ\"\n"
24545 " proxygroup=\"representations\"\n"
24546 " proxyname=\"GeometrySliceRepresentation\">\n"
24547 " </Proxy>\n"
24548 " <ShareProperties subproxy=\"SurfaceRepresentation\">\n"
24549 " <Exception name=\"Input\" />\n"
24550 " <Exception name=\"Visibility\" />\n"
24551 " </ShareProperties>\n"
24552 " </SubProxy>\n"
24553 " </PVRepresentationProxy>\n"
24554 " <!-- ================================================================== -->\n"
24555 " <RepresentationProxy class=\"vtkPolarAxesRepresentation\"\n"
24556 " name=\"PolarAxesRepresentation\"\n"
24557 " processes=\"client|renderserver|dataserver\">\n"
24558 " <Documentation>PolarAxesRepresentation is a representation of Polar\n"
24559 " axes on any kind of dataset.</Documentation>\n"
24560 " <InputProperty command=\"SetInputConnection\"\n"
24561 " name=\"Input\">\n"
24562 " <DataTypeDomain name=\"input_type\">\n"
24563 " <DataType value=\"vtkDataSet\" />\n"
24564 " <DataType value=\"vtkHyperTreeGrid\" />\n"
24565 " </DataTypeDomain>\n"
24566 " <Documentation>Set the input to the representation.</Documentation>\n"
24567 " </InputProperty>\n"
24568 " <Hints>\n"
24569 " <ProxyList>\n"
24570 " <Link name=\"Input\" with_property=\"Input\"/>\n"
24571 " <ShareProperties parent_subproxy=\"SurfaceRepresentation\">\n"
24572 " <Exception name=\"Input\" />\n"
24573 " <Exception name=\"Visibility\" />\n"
24574 " </ShareProperties>\n"
24575 " </ProxyList>\n"
24576 " </Hints>\n"
24577 " <IntVectorProperty command=\"SetVisibility\"\n"
24578 " default_values=\"0\"\n"
24579 " name=\"Visibility\"\n"
24580 " number_of_elements=\"1\"\n"
24581 " animateable=\"0\">\n"
24582 " <BooleanDomain name=\"bool\" />\n"
24583 " <Documentation>Set the visibility of the representation.</Documentation>\n"
24584 " </IntVectorProperty>\n"
24585 "\n"
24586 " <DoubleVectorProperty command=\"SetPosition\"\n"
24587 " default_values=\"0 0 0\"\n"
24588 " label=\"Translation\"\n"
24589 " name=\"Position\"\n"
24590 " number_of_elements=\"3\">\n"
24591 " <DoubleRangeDomain name=\"range\" />\n"
24592 " <Documentation>Set the polar axes origin position.</Documentation>\n"
24593 " </DoubleVectorProperty>\n"
24594 " <DoubleVectorProperty command=\"SetScale\"\n"
24595 " default_values=\"1 1 1\"\n"
24596 " name=\"Scale\"\n"
24597 " number_of_elements=\"3\">\n"
24598 " <DoubleRangeDomain name=\"range\" />\n"
24599 " <Documentation>Set the polar axes bounds transform scale.</Documentation>\n"
24600 " </DoubleVectorProperty>\n"
24601 " <DoubleVectorProperty command=\"SetOrientation\"\n"
24602 " default_values=\"0 0 0\"\n"
24603 " name=\"Orientation\"\n"
24604 " number_of_elements=\"3\">\n"
24605 " <DoubleRangeDomain name=\"range\" />\n"
24606 " <Documentation>Set the polar axes bounds transform orientation.</Documentation>\n"
24607 " </DoubleVectorProperty>\n"
24608 " <PropertyGroup label=\"Transform\">\n"
24609 " <Property name=\"Position\"/>\n"
24610 " <Property name=\"Scale\"/>\n"
24611 " <Property name=\"Orientation\"/>\n"
24612 " </PropertyGroup>\n"
24613 "\n"
24614 " <DoubleVectorProperty command=\"GetDataBounds\"\n"
24615 " default_values=\"0 1 0 1 0 1\"\n"
24616 " information_only=\"1\"\n"
24617 " name=\"DataBounds\"\n"
24618 " number_of_elements=\"6\">\n"
24619 " <SimpleDoubleInformationHelper />\n"
24620 " <Documentation>Get the polar axes transformed bounds.</Documentation>\n"
24621 " </DoubleVectorProperty>\n"
24622 " <IntVectorProperty command=\"SetEnableCustomBounds\"\n"
24623 " default_values=\"0 0 0\"\n"
24624 " name=\"EnableCustomBounds\"\n"
24625 " panel_visibility=\"advanced\"\n"
24626 " number_of_elements=\"3\">\n"
24627 " <Documentation>Activate the use of polar axes custom bounds.</Documentation>\n"
24628 " </IntVectorProperty>\n"
24629 " <DoubleVectorProperty command=\"SetCustomBounds\"\n"
24630 " default_values=\"0 1 0 1 0 1\"\n"
24631 " name=\"CustomBounds\"\n"
24632 " panel_visibility=\"advanced\"\n"
24633 " number_of_elements=\"6\">\n"
24634 " <Documentation>Set the polar axes custom bounds.</Documentation>\n"
24635 " </DoubleVectorProperty>\n"
24636 " <IntVectorProperty command=\"SetEnableCustomRange\"\n"
24637 " default_values=\"0\"\n"
24638 " name=\"EnableCustomRange\"\n"
24639 " number_of_elements=\"1\">\n"
24640 " <BooleanDomain name=\"bool\" />\n"
24641 " <Documentation>Activate the use of polar axes custom range.</Documentation>\n"
24642 " </IntVectorProperty>\n"
24643 " <DoubleVectorProperty command=\"SetCustomRange\"\n"
24644 " default_values=\"0 1\"\n"
24645 " name=\"CustomRange\"\n"
24646 " number_of_elements=\"2\">\n"
24647 " <Hints>\n"
24648 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24649 " <Property name=\"EnableCustomRange\"\n"
24650 " function=\"boolean\" />\n"
24651 " </PropertyWidgetDecorator>\n"
24652 " </Hints>\n"
24653 " <Documentation>Set the polar axes custom range.</Documentation>\n"
24654 " </DoubleVectorProperty>\n"
24655 " <IntVectorProperty command=\"SetEnableAutoPole\"\n"
24656 " default_values=\"1\"\n"
24657 " name=\"AutoPole\"\n"
24658 " number_of_elements=\"1\">\n"
24659 " <BooleanDomain name=\"bool\" />\n"
24660 " <Documentation>Activate the automatic placement of the pole (origin of the axes) at the center of the bounding box.\n"
24661 " </Documentation>\n"
24662 " </IntVectorProperty>\n"
24663 " <PropertyGroup label=\"Custom Bounds and Range\">\n"
24664 " <Property name=\"EnableCustomBounds\"/>\n"
24665 " <Property name=\"CustomBounds\"/>\n"
24666 " <Property name=\"EnableCustomRange\"/>\n"
24667 " <Property name=\"CustomRange\"/>\n"
24668 " <Property name=\"AutoPole\"/>\n"
24669 " </PropertyGroup>\n"
24670 "\n"
24671 " <IntVectorProperty command=\"SetPolarAxisVisibility\"\n"
24672 " default_values=\"1\"\n"
24673 " name=\"PolarAxisVisibility\"\n"
24674 " number_of_elements=\"1\">\n"
24675 " <BooleanDomain name=\"bool\" />\n"
24676 " <Documentation>Set the visibility of polar axis.</Documentation>\n"
24677 " </IntVectorProperty>\n"
24678 " <IntVectorProperty command=\"SetRadialAxesVisibility\"\n"
24679 " default_values=\"1\"\n"
24680 " name=\"RadialAxesVisibility\"\n"
24681 " number_of_elements=\"1\">\n"
24682 " <BooleanDomain name=\"bool\" />\n"
24683 " <Documentation>Set all radial axes visibility.</Documentation>\n"
24684 " </IntVectorProperty>\n"
24685 " <IntVectorProperty command=\"SetDrawRadialGridlines\"\n"
24686 " default_values=\"1\"\n"
24687 " name=\"DrawRadialGridlines\"\n"
24688 " panel_visibility=\"advanced\"\n"
24689 " number_of_elements=\"1\">\n"
24690 " <BooleanDomain name=\"bool\" />\n"
24691 " <Hints>\n"
24692 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24693 ;
24694
24695 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
24697 " <Property name=\"RadialAxesVisibility\"\n"
24698 " function=\"boolean\" />\n"
24699 " </PropertyWidgetDecorator>\n"
24700 " </Hints>\n"
24701 " <Documentation>Set the visibility of radial grid lines.</Documentation>\n"
24702 " </IntVectorProperty>\n"
24703 " <IntVectorProperty command=\"SetPolarArcsVisibility\"\n"
24704 " default_values=\"1\"\n"
24705 " name=\"PolarArcsVisibility\"\n"
24706 " number_of_elements=\"1\">\n"
24707 " <BooleanDomain name=\"bool\" />\n"
24708 " <Documentation>Set all polar arcs visibility.</Documentation>\n"
24709 " </IntVectorProperty>\n"
24710 " <IntVectorProperty command=\"SetDrawPolarArcsGridlines\"\n"
24711 " default_values=\"1\"\n"
24712 " name=\"DrawPolarArcsGridlines\"\n"
24713 " panel_visibility=\"advanced\"\n"
24714 " number_of_elements=\"1\">\n"
24715 " <BooleanDomain name=\"bool\" />\n"
24716 " <Hints>\n"
24717 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24718 " <Property name=\"PolarArcsVisibility\"\n"
24719 " function=\"boolean\" />\n"
24720 " </PropertyWidgetDecorator>\n"
24721 " </Hints>\n"
24722 " <Documentation>Set the visibility of polar arcs grid lines.</Documentation>\n"
24723 " </IntVectorProperty>\n"
24724 " <PropertyGroup label=\"Visibility Control\">\n"
24725 " <Property name=\"PolarAxisVisibility\" />\n"
24726 " <Property name=\"RadialAxesVisibility\" />\n"
24727 " <Property name=\"DrawRadialGridlines\" />\n"
24728 " <Property name=\"PolarArcsVisibility\" />\n"
24729 " <Property name=\"DrawPolarArcsGridlines\" />\n"
24730 " </PropertyGroup>\n"
24731 "\n"
24732 " <IntVectorProperty command=\"SetNumberOfRadialAxes\"\n"
24733 " default_values=\"0\"\n"
24734 " name=\"NumberOfRadialAxes\"\n"
24735 " number_of_elements=\"1\">\n"
24736 " <IntRangeDomain min=\"0\"\n"
24737 " max=\"100\"\n"
24738 " name=\"range\" />\n"
24739 " <Documentation>Set the number of radial axes,\n"
24740 " If value is 0 (the default), the number of radial axes is automatically calculated.\n"
24741 " Depends on the Delta Angle Radial Axes for automatic computation.\n"
24742 " </Documentation>\n"
24743 " </IntVectorProperty>\n"
24744 " <DoubleVectorProperty command=\"SetDeltaAngleRadialAxes\"\n"
24745 " default_values=\"45\"\n"
24746 " name=\"DeltaAngleRadialAxes\"\n"
24747 " number_of_elements=\"1\">\n"
24748 " <DoubleRangeDomain min=\"0\"\n"
24749 " max=\"360\"\n"
24750 " name=\"range\" />\n"
24751 " <Documentation>Set the angle (in degrees) between radial axes,\n"
24752 " If value is 0, the angle between radial axes is automatically calculated.\n"
24753 " Depends on the Number Of Radial Axes for automatic computation.\n"
24754 " </Documentation>\n"
24755 " </DoubleVectorProperty>\n"
24756 " <IntVectorProperty command=\"SetNumberOfPolarAxes\"\n"
24757 " default_values=\"5\"\n"
24758 " name=\"NumberOfPolarAxes\"\n"
24759 " number_of_elements=\"1\">\n"
24760 " <IntRangeDomain min=\"0\"\n"
24761 " max=\"100\"\n"
24762 " name=\"range\" />\n"
24763 " <Documentation>Set the number of polar axes,\n"
24764 " If value is 0, the number of polar axes is automatically calculated.\n"
24765 " Depends on the Delta Range Polar Axes for automatic computation.\n"
24766 " </Documentation>\n"
24767 " </IntVectorProperty>\n"
24768 " <DoubleVectorProperty command=\"SetDeltaRangePolarAxes\"\n"
24769 " name=\"DeltaRangePolarAxes\"\n"
24770 " number_of_elements=\"1\"\n"
24771 " default_values=\"0\">\n"
24772 " <DoubleRangeDomain name=\"range\" />\n"
24773 " <Documentation>Set the range between polar axes,\n"
24774 " If value is 0 (the default), the range between polar axes is automatically calculated.\n"
24775 " Depends on the Number Of Polar Axes for automatic computation.\n"
24776 " </Documentation>\n"
24777 " </DoubleVectorProperty>\n"
24778 " <IntVectorProperty command=\"SetEnableCustomMinRadius\"\n"
24779 " default_values=\"1\"\n"
24780 " name=\"CustomMinRadius\"\n"
24781 " number_of_elements=\"1\">\n"
24782 " <BooleanDomain name=\"bool\" />\n"
24783 " <Documentation>Activate the use of custom minimum radius.\n"
24784 " If off, Minimum Radius is computed relatively to pole position.\n"
24785 " </Documentation>\n"
24786 " </IntVectorProperty>\n"
24787 " <DoubleVectorProperty command=\"SetMinRadius\"\n"
24788 " default_values=\"0\"\n"
24789 " name=\"MinimumRadius\"\n"
24790 " number_of_elements=\"1\">\n"
24791 " <DoubleRangeDomain min=\"0\"\n"
24792 " max=\"100\"\n"
24793 " name=\"range\" />\n"
24794 " <Hints>\n"
24795 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24796 " <Property name=\"CustomMinRadius\"\n"
24797 " function=\"boolean\" />\n"
24798 " </PropertyWidgetDecorator>\n"
24799 " </Hints>\n"
24800 " <Documentation>Set the minimum radius.</Documentation>\n"
24801 " </DoubleVectorProperty>\n"
24802 " <IntVectorProperty command=\"SetEnableCustomMaxRadius\"\n"
24803 " default_values=\"0\"\n"
24804 " name=\"CustomMaxRadius\"\n"
24805 " number_of_elements=\"1\">\n"
24806 " <BooleanDomain name=\"bool\" />\n"
24807 " <Documentation>Activate the use of custom maximum radius.\n"
24808 " If off, Maximum Radius is computed relatively to pole position.</Documentation>\n"
24809 " </IntVectorProperty>\n"
24810 " <DoubleVectorProperty command=\"SetMaxRadius\"\n"
24811 " default_values=\"1\"\n"
24812 " name=\"MaximumRadius\"\n"
24813 " number_of_elements=\"1\">\n"
24814 " <DoubleRangeDomain min=\"0\"\n"
24815 " max=\"100\"\n"
24816 " name=\"range\" />\n"
24817 " <Hints>\n"
24818 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24819 " <Property name=\"CustomMaxRadius\"\n"
24820 " function=\"boolean\" />\n"
24821 " </PropertyWidgetDecorator>\n"
24822 " </Hints>\n"
24823 " <Documentation>Set the maximum radius.</Documentation>\n"
24824 " </DoubleVectorProperty>\n"
24825 " <IntVectorProperty command=\"SetEnableCustomAngle\"\n"
24826 " default_values=\"1\"\n"
24827 " name=\"CustomAngles\"\n"
24828 " number_of_elements=\"1\">\n"
24829 " <BooleanDomain name=\"bool\" />\n"
24830 " <Documentation>Activate the use of custom min/max angle.\n"
24831 " If off, Minimum/Maximum Angle are computed relatively to pole position.</Documentation>\n"
24832 " </IntVectorProperty>\n"
24833 " <DoubleVectorProperty command=\"SetMinAngle\"\n"
24834 " default_values=\"0\"\n"
24835 " name=\"MinimumAngle\"\n"
24836 " number_of_elements=\"1\">\n"
24837 " <DoubleRangeDomain min=\"-180\"\n"
24838 " max=\"180\"\n"
24839 " name=\"range\" />\n"
24840 " <Hints>\n"
24841 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24842 " <Property name=\"CustomAngles\"\n"
24843 " function=\"boolean\" />\n"
24844 " </PropertyWidgetDecorator>\n"
24845 " </Hints>\n"
24846 " <Documentation>Set the minimum angle (in degrees).</Documentation>\n"
24847 " </DoubleVectorProperty>\n"
24848 " <DoubleVectorProperty command=\"SetMaxAngle\"\n"
24849 " default_values=\"90\"\n"
24850 " name=\"MaximumAngle\"\n"
24851 " number_of_elements=\"1\">\n"
24852 " <DoubleRangeDomain min=\"-180\"\n"
24853 " max=\"180\"\n"
24854 " name=\"range\" />\n"
24855 " <Hints>\n"
24856 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24857 " <Property name=\"CustomAngles\"\n"
24858 " function=\"boolean\" />\n"
24859 " </PropertyWidgetDecorator>\n"
24860 " </Hints>\n"
24861 " <Documentation>Set the maximum angle (in degrees).</Documentation>\n"
24862 " </DoubleVectorProperty>\n"
24863 " <IntVectorProperty command=\"SetRadialAxesOriginToPolarAxis\"\n"
24864 " default_values=\"1\"\n"
24865 " name=\"RadialAxesOriginToPolarAxis\"\n"
24866 " panel_visibility=\"advanced\"\n"
24867 " number_of_elements=\"1\">\n"
24868 " <BooleanDomain name=\"bool\" />\n"
24869 " <Documentation>If On, the radial axes are drawn from the angle of the polar Axis\n"
24870 " (i.e. MinimumAngle) and continue counterclockwise with the step DeltaAngleRadialAxes.\n"
24871 " if Off, the start angle is 0.0.</Documentation>\n"
24872 " </IntVectorProperty>\n"
24873 " <DoubleVectorProperty command=\"SetPolarArcResolutionPerDegree\"\n"
24874 " default_values=\"0.2\"\n"
24875 " name=\"PolarArcResolutionPerDegree\"\n"
24876 " panel_visibility=\"advanced\"\n"
24877 " number_of_elements=\"1\">\n"
24878 " <DoubleRangeDomain max=\"10.0\"\n"
24879 " min=\"0.05\"\n"
24880 " name=\"range\" />\n"
24881 " <Documentation>Set the number of line drawn per degree.</Documentation>\n"
24882 " </DoubleVectorProperty>\n"
24883 " <DoubleVectorProperty command=\"SetRatio\"\n"
24884 " default_values=\"1\"\n"
24885 " name=\"Ratio\"\n"
24886 " number_of_elements=\"1\">\n"
24887 " <DoubleRangeDomain max=\"100.0\"\n"
24888 " min=\"0.001\"\n"
24889 " name=\"range\" />\n"
24890 " <Documentation>Set the polar ellipse ratio.</Documentation>\n"
24891 " </DoubleVectorProperty>\n"
24892 " <PropertyGroup label=\"Aspect Control\">\n"
24893 " <Property name=\"NumberOfRadialAxes\" />\n"
24894 " <Property name=\"DeltaAngleRadialAxes\" />\n"
24895 " <Property name=\"NumberOfPolarAxes\" />\n"
24896 " <Property name=\"DeltaRangePolarAxes\" />\n"
24897 " <Property name=\"CustomMinRadius\" />\n"
24898 " <Property name=\"MinimumRadius\" />\n"
24899 " <Property name=\"CustomMaxRadius\" />\n"
24900 " <Property name=\"MaximumRadius\" />\n"
24901 " <Property name=\"CustomAngles\" />\n"
24902 " <Property name=\"MinimumAngle\" />\n"
24903 " <Property name=\"MaximumAngle\" />\n"
24904 " <Property name=\"RadialAxesOriginToPolarAxis\" />\n"
24905 " <Property name=\"PolarArcResolutionPerDegree\" />\n"
24906 " <Property name=\"Ratio\" />\n"
24907 " </PropertyGroup>\n"
24908 "\n"
24909 " <IntVectorProperty command=\"SetEnableOverallColor\"\n"
24910 " default_values=\"1\"\n"
24911 " name=\"EnableOverallColor\"\n"
24912 " number_of_elements=\"1\">\n"
24913 " <BooleanDomain name=\"bool\" />\n"
24914 " <Documentation>If On, the whole polar axes is unicolor.\n"
24915 " If Off, you can specify a color for each feature.</Documentation>\n"
24916 " </IntVectorProperty>\n"
24917 " <DoubleVectorProperty command=\"SetOverallColor\"\n"
24918 " default_values=\"1 1 1\"\n"
24919 " name=\"OverallColor\"\n"
24920 " panel_widget=\"color_selector\"\n"
24921 " number_of_elements=\"3\">\n"
24922 " <DoubleRangeDomain max=\"1 1 1\"\n"
24923 " min=\"0 0 0\"\n"
24924 " name=\"range\" />\n"
24925 " <Hints>\n"
24926 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24927 " <Property name=\"EnableOverallColor\"\n"
24928 " function=\"boolean\" />\n"
24929 " </PropertyWidgetDecorator>\n"
24930 " </Hints>\n"
24931 " <Documentation>Set the overall color.</Documentation>\n"
24932 " </DoubleVectorProperty>\n"
24933 " <DoubleVectorProperty command=\"SetPolarAxisColor\"\n"
24934 " default_values=\"1 1 1\"\n"
24935 " name=\"PolarAxisColor\"\n"
24936 " panel_widget=\"color_selector\"\n"
24937 " number_of_elements=\"3\">\n"
24938 " <DoubleRangeDomain max=\"1 1 1\"\n"
24939 " min=\"0 0 0\"\n"
24940 " name=\"range\" />\n"
24941 " <Hints>\n"
24942 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24943 " <Property name=\"EnableOverallColor\"\n"
24944 " function=\"boolean_invert\" />\n"
24945 " </PropertyWidgetDecorator>\n"
24946 " </Hints>\n"
24947 " <Documentation>Set the Polar Axis color.</Documentation>\n"
24948 " </DoubleVectorProperty>\n"
24949 " <DoubleVectorProperty command=\"SetPolarArcsColor\"\n"
24950 " default_values=\"1 1 1\"\n"
24951 " name=\"PolarArcsColor\"\n"
24952 " panel_widget=\"color_selector\"\n"
24953 " number_of_elements=\"3\">\n"
24954 " <DoubleRangeDomain max=\"1 1 1\"\n"
24955 " min=\"0 0 0\"\n"
24956 " name=\"range\" />\n"
24957 " <Hints>\n"
24958 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24959 " <Property name=\"EnableOverallColor\"\n"
24960 " function=\"boolean_invert\" />\n"
24961 " </PropertyWidgetDecorator>\n"
24962 " </Hints>\n"
24963 " <Documentation>Set the Polar Arcs color.</Documentation>\n"
24964 " </DoubleVectorProperty>\n"
24965 " <DoubleVectorProperty command=\"SetLastRadialAxisColor\"\n"
24966 " default_values=\"1 1 1\"\n"
24967 " name=\"LastRadialAxisColor\"\n"
24968 " panel_widget=\"color_selector\"\n"
24969 " number_of_elements=\"3\">\n"
24970 " <DoubleRangeDomain max=\"1 1 1\"\n"
24971 " min=\"0 0 0\"\n"
24972 " name=\"range\" />\n"
24973 " <Hints>\n"
24974 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24975 " <Property name=\"EnableOverallColor\"\n"
24976 " function=\"boolean_invert\" />\n"
24977 " </PropertyWidgetDecorator>\n"
24978 " </Hints>\n"
24979 " <Documentation>Set the Last Radial Axis color.</Documentation>\n"
24980 " </DoubleVectorProperty>\n"
24981 " <DoubleVectorProperty command=\"SetSecondaryPolarArcsColor\"\n"
24982 " default_values=\"1 1 1\"\n"
24983 " name=\"SecondaryPolarArcsColor\"\n"
24984 " panel_widget=\"color_selector\"\n"
24985 " number_of_elements=\"3\">\n"
24986 " <DoubleRangeDomain max=\"1 1 1\"\n"
24987 " min=\"0 0 0\"\n"
24988 " name=\"range\" />\n"
24989 " <Hints>\n"
24990 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
24991 " <Property name=\"EnableOverallColor\"\n"
24992 " function=\"boolean_invert\" />\n"
24993 " </PropertyWidgetDecorator>\n"
24994 " </Hints>\n"
24995 " <Documentation>Set the Secondary Polar Arcs color.</Documentation>\n"
24996 " </DoubleVectorProperty>\n"
24997 " <DoubleVectorProperty command=\"SetSecondaryRadialAxesColor\"\n"
24998 " default_values=\"1 1 1\"\n"
24999 " name=\"SecondaryRadialAxesColor\"\n"
25000 " panel_widget=\"color_selector\"\n"
25001 " number_of_elements=\"3\">\n"
25002 " <DoubleRangeDomain max=\"1 1 1\"\n"
25003 " min=\"0 0 0\"\n"
25004 " name=\"range\" />\n"
25005 " <Hints>\n"
25006 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25007 " <Property name=\"EnableOverallColor\"\n"
25008 ;
25009
25010 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
25012 " function=\"boolean_invert\" />\n"
25013 " </PropertyWidgetDecorator>\n"
25014 " </Hints>\n"
25015 " <Documentation>Set the Secondary Radial Axes color.</Documentation>\n"
25016 " </DoubleVectorProperty>\n"
25017 " <PropertyGroup label=\"Colors\">\n"
25018 " <Property name=\"EnableOverallColor\"/>\n"
25019 " <Property name=\"OverallColor\"/>\n"
25020 " <Property name=\"PolarAxisColor\"/>\n"
25021 " <Property name=\"PolarArcsColor\"/>\n"
25022 " <Property name=\"LastRadialAxisColor\"/>\n"
25023 " <Property name=\"SecondaryPolarArcsColor\"/>\n"
25024 " <Property name=\"SecondaryRadialAxesColor\"/>\n"
25025 " </PropertyGroup>\n"
25026 "\n"
25027 " <IntVectorProperty command=\"SetPolarTitleVisibility\"\n"
25028 " default_values=\"1\"\n"
25029 " name=\"PolarAxisTitleVisibility\"\n"
25030 " number_of_elements=\"1\">\n"
25031 " <BooleanDomain name=\"bool\" />\n"
25032 " <Documentation>Set the visibility of polar axis title.</Documentation>\n"
25033 " </IntVectorProperty>\n"
25034 " <StringVectorProperty command=\"SetPolarAxisTitle\"\n"
25035 " name=\"PolarAxisTitle\"\n"
25036 " default_values=\"Radial Distance\"\n"
25037 " number_of_elements=\"1\">\n"
25038 " <Hints>\n"
25039 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25040 " <Property name=\"PolarAxisTitleVisibility\"\n"
25041 " function=\"boolean\" />\n"
25042 " </PropertyWidgetDecorator>\n"
25043 " </Hints>\n"
25044 " <Documentation>Set the polar axis title.</Documentation>\n"
25045 " </StringVectorProperty>\n"
25046 " <IntVectorProperty command=\"SetPolarAxisTitleLocation\"\n"
25047 " default_values=\"0\"\n"
25048 " name=\"PolarAxisTitleLocation\"\n"
25049 " panel_visibility=\"advanced\"\n"
25050 " number_of_elements=\"1\">\n"
25051 " <EnumerationDomain name=\"enum\">\n"
25052 " <Entry text=\"Bottom\"\n"
25053 " value=\"0\" />\n"
25054 " <Entry text=\"Extern\"\n"
25055 " value=\"1\" />\n"
25056 " </EnumerationDomain>\n"
25057 " <Hints>\n"
25058 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25059 " <Property name=\"PolarAxisTitleVisibility\"\n"
25060 " function=\"boolean\" />\n"
25061 " </PropertyWidgetDecorator>\n"
25062 " </Hints>\n"
25063 " <Documentation>Set the location of polar axis title.</Documentation>\n"
25064 " </IntVectorProperty>\n"
25065 " <DoubleVectorProperty command=\"SetPolarTitleOffset\"\n"
25066 " default_values=\"20 20\"\n"
25067 " name=\"PolarTitleOffset\"\n"
25068 " number_of_elements=\"2\">\n"
25069 " <DoubleRangeDomain name=\"range\" />\n"
25070 " <Hints>\n"
25071 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25072 " <Property name=\"PolarAxisTitleVisibility\"\n"
25073 " function=\"boolean\" />\n"
25074 " </PropertyWidgetDecorator>\n"
25075 " </Hints>\n"
25076 " <Documentation>Set the 2D text offset (in pixels) for polar title.\n"
25077 " The X offset is not applied if the text should be centered.</Documentation>\n"
25078 " </DoubleVectorProperty>\n"
25079 " <IntVectorProperty command=\"SetPolarLabelVisibility\"\n"
25080 " default_values=\"1\"\n"
25081 " name=\"PolarLabelVisibility\"\n"
25082 " number_of_elements=\"1\">\n"
25083 " <BooleanDomain name=\"bool\" />\n"
25084 " <Documentation>Set the visibility of polar axis label.</Documentation>\n"
25085 " </IntVectorProperty>\n"
25086 " <StringVectorProperty command=\"SetPolarLabelFormat\"\n"
25087 " name=\"PolarLabelFormat\"\n"
25088 " default_values=\"%-#6.3g\"\n"
25089 " panel_visibility=\"advanced\"\n"
25090 " number_of_elements=\"1\">\n"
25091 " <Hints>\n"
25092 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25093 " <Property name=\"PolarLabelVisibility\"\n"
25094 " function=\"boolean\" />\n"
25095 " </PropertyWidgetDecorator>\n"
25096 " </Hints>\n"
25097 " <Documentation>Set the polar axis label format.</Documentation>\n"
25098 " </StringVectorProperty>\n"
25099 " <IntVectorProperty command=\"SetExponentLocation\"\n"
25100 " default_values=\"2\"\n"
25101 " name=\"PolarLabelExponentLocation\"\n"
25102 " panel_visibility=\"advanced\"\n"
25103 " number_of_elements=\"1\">\n"
25104 " <EnumerationDomain name=\"enum\">\n"
25105 " <Entry text=\"Bottom\"\n"
25106 " value=\"0\" />\n"
25107 " <Entry text=\"Extern\"\n"
25108 " value=\"1\" />\n"
25109 " <Entry text=\"Labels\"\n"
25110 " value=\"2\" />\n"
25111 " </EnumerationDomain>\n"
25112 " <Hints>\n"
25113 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25114 " <Property name=\"PolarLabelVisibility\"\n"
25115 " function=\"boolean\" />\n"
25116 " </PropertyWidgetDecorator>\n"
25117 " </Hints>\n"
25118 " <Documentation>Set the location of exponent.</Documentation>\n"
25119 " </IntVectorProperty>\n"
25120 " <DoubleVectorProperty command=\"SetPolarLabelOffset\"\n"
25121 " default_values=\"10\"\n"
25122 " name=\"PolarLabelOffset\"\n"
25123 " number_of_elements=\"1\">\n"
25124 " <DoubleRangeDomain name=\"range\" />\n"
25125 " <Hints>\n"
25126 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25127 " <Property name=\"PolarLabelVisibility\"\n"
25128 " function=\"boolean\" />\n"
25129 " </PropertyWidgetDecorator>\n"
25130 " </Hints>\n"
25131 " <Documentation>Set the Y text offset (in pixels) for polar labels.</Documentation>\n"
25132 " </DoubleVectorProperty>\n"
25133 " <DoubleVectorProperty command=\"SetPolarExponentOffset\"\n"
25134 " default_values=\"5\"\n"
25135 " name=\"PolarExponentOffset\"\n"
25136 " number_of_elements=\"1\">\n"
25137 " <DoubleRangeDomain name=\"range\" />\n"
25138 " <Hints>\n"
25139 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25140 " <Property name=\"PolarLabelVisibility\"\n"
25141 " function=\"boolean\" />\n"
25142 " </PropertyWidgetDecorator>\n"
25143 " </Hints>\n"
25144 " <Documentation>Set the Y text offset (in pixels) for polar exponent.</Documentation>\n"
25145 " </DoubleVectorProperty>\n"
25146 " <IntVectorProperty command=\"SetRadialTitleVisibility\"\n"
25147 " default_values=\"1\"\n"
25148 " name=\"RadialTitleVisibility\"\n"
25149 " number_of_elements=\"1\">\n"
25150 " <BooleanDomain name=\"bool\" />\n"
25151 " <Documentation>Set radial title visibility.</Documentation>\n"
25152 " </IntVectorProperty>\n"
25153 " <StringVectorProperty command=\"SetRadialAngleFormat\"\n"
25154 " default_values=\"%-#3.1f\"\n"
25155 " name=\"RadialTitleFormat\"\n"
25156 " panel_visibility=\"advanced\"\n"
25157 " number_of_elements=\"1\">\n"
25158 " <Hints>\n"
25159 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25160 " <Property name=\"RadialTitleVisibility\"\n"
25161 " function=\"boolean\" />\n"
25162 " </PropertyWidgetDecorator>\n"
25163 " </Hints>\n"
25164 " <Documentation>Set the polar radial label format.</Documentation>\n"
25165 " </StringVectorProperty>\n"
25166 " <IntVectorProperty command=\"SetRadialAxisTitleLocation\"\n"
25167 " default_values=\"0\"\n"
25168 " name=\"RadialTitleLocation\"\n"
25169 " panel_visibility=\"advanced\"\n"
25170 " number_of_elements=\"1\">\n"
25171 " <EnumerationDomain name=\"enum\">\n"
25172 " <Entry text=\"Bottom\"\n"
25173 " value=\"0\" />\n"
25174 " <Entry text=\"Extern\"\n"
25175 " value=\"1\" />\n"
25176 " </EnumerationDomain>\n"
25177 " <Hints>\n"
25178 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25179 " <Property name=\"RadialTitleVisibility\"\n"
25180 " function=\"boolean\" />\n"
25181 " </PropertyWidgetDecorator>\n"
25182 " </Hints>\n"
25183 " <Documentation>Set the location of radial title.</Documentation>\n"
25184 " </IntVectorProperty>\n"
25185 " <DoubleVectorProperty command=\"SetRadialTitleOffset\"\n"
25186 " default_values=\"20 0\"\n"
25187 " name=\"RadialTitleOffset\"\n"
25188 " number_of_elements=\"2\">\n"
25189 " <DoubleRangeDomain name=\"range\" />\n"
25190 " <Hints>\n"
25191 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25192 " <Property name=\"RadialTitleVisibility\"\n"
25193 " function=\"boolean\" />\n"
25194 " </PropertyWidgetDecorator>\n"
25195 " </Hints>\n"
25196 " <Documentation>Set the 2D text offset (in pixels) for radial titles.\n"
25197 " The X offset is not applied if the text should be centered.</Documentation>\n"
25198 " </DoubleVectorProperty>\n"
25199 " <IntVectorProperty command=\"SetRadialUnits\"\n"
25200 " default_values=\"1\"\n"
25201 " name=\"RadialUnitsVisibility\"\n"
25202 " panel_visibility=\"advanced\"\n"
25203 " number_of_elements=\"1\">\n"
25204 " <BooleanDomain name=\"bool\" />\n"
25205 " <Documentation>Show radial units in labels (degrees).</Documentation>\n"
25206 " </IntVectorProperty>\n"
25207 " <DoubleVectorProperty command=\"SetScreenSize\"\n"
25208 " default_values=\"10\"\n"
25209 " name=\"ScreenSize\"\n"
25210 " panel_visibility=\"advanced\"\n"
25211 " number_of_elements=\"1\">\n"
25212 " <DoubleRangeDomain name=\"range\"\n"
25213 " min=\"0\"\n"
25214 " max=\"100\"/>\n"
25215 " <Documentation>Set the screen size to use, which impact label and title\n"
25216 " relative location to the axes.</Documentation>\n"
25217 " </DoubleVectorProperty>\n"
25218 " <PropertyGroup label=\"Title and Labels Control\">\n"
25219 " <Property name=\"PolarAxisTitle\" />\n"
25220 " <Property name=\"PolarAxisTitleVisibility\" />\n"
25221 " <Property name=\"PolarAxisTitleLocation\" />\n"
25222 " <Property name=\"PolarTitleOffset\" />\n"
25223 " <Property name=\"PolarLabelVisibility\" />\n"
25224 " <Property name=\"PolarLabelFormat\" />\n"
25225 " <Property name=\"PolarLabelExponentLocation\" />\n"
25226 " <Property name=\"PolarLabelOffset\" />\n"
25227 " <Property name=\"PolarExponentOffset\" />\n"
25228 " <Property name=\"RadialTitleVisibility\" />\n"
25229 " <Property name=\"RadialTitleFormat\" />\n"
25230 " <Property name=\"RadialTitleLocation\" />\n"
25231 " <Property name=\"RadialTitleOffset\" />\n"
25232 " <Property name=\"RadialUnitsVisibility\" />\n"
25233 " <Property name=\"ScreenSize\" />\n"
25234 " </PropertyGroup>\n"
25235 "\n"
25236 " <SubProxy command=\"SetPolarAxisTitleTextProperty\">\n"
25237 " <Proxy name=\"PolarAxisTitleProperty\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
25238 " <ExposedProperties>\n"
25239 " <Property exposed_name=\"PolarAxisTitleColor\" name=\"Color\" />\n"
25240 " <Property exposed_name=\"PolarAxisTitleOpacity\" name=\"Opacity\" />\n"
25241 " <Property exposed_name=\"PolarAxisTitleFontFamily\" name=\"FontFamily\" />\n"
25242 " <Property exposed_name=\"PolarAxisTitleFontFile\" name=\"FontFile\" />\n"
25243 " <Property exposed_name=\"PolarAxisTitleBold\" name=\"Bold\" />\n"
25244 " <Property exposed_name=\"PolarAxisTitleItalic\" name=\"Italic\" />\n"
25245 " <Property exposed_name=\"PolarAxisTitleShadow\" name=\"Shadow\" />\n"
25246 " <Property exposed_name=\"PolarAxisTitleFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
25247 " </ExposedProperties>\n"
25248 " </SubProxy>\n"
25249 " <PropertyGroup label=\"Polar Axis Title Font Properties\" panel_widget=\"FontEditor\">\n"
25250 " <Property name=\"PolarAxisTitleColor\" function=\"Color\"/>\n"
25251 " <Property name=\"PolarAxisTitleFontFamily\" function=\"Family\"/>\n"
25252 " <Property name=\"PolarAxisTitleFontFile\" function=\"File\"/>\n"
25253 " <Property name=\"PolarAxisTitleBold\" function=\"Bold\" />\n"
25254 " <Property name=\"PolarAxisTitleItalic\" function=\"Italics\"/>\n"
25255 " <Property name=\"PolarAxisTitleFontSize\" function=\"Size\" />\n"
25256 " <Property name=\"PolarAxisTitleShadow\" function=\"Shadow\" />\n"
25257 " <Property name=\"PolarAxisTitleOpacity\" function=\"Opacity\" />\n"
25258 " </PropertyGroup>\n"
25259 "\n"
25260 " <SubProxy command=\"SetPolarAxisLabelTextProperty\">\n"
25261 " <Proxy name=\"PolarAxisLabelProperty\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
25262 " <ExposedProperties>\n"
25263 " <Property exposed_name=\"PolarAxisLabelColor\" name=\"Color\" />\n"
25264 " <Property exposed_name=\"PolarAxisLabelOpacity\" name=\"Opacity\" />\n"
25265 " <Property exposed_name=\"PolarAxisLabelFontFamily\" name=\"FontFamily\" />\n"
25266 " <Property exposed_name=\"PolarAxisLabelFontFile\" name=\"FontFile\" />\n"
25267 " <Property exposed_name=\"PolarAxisLabelBold\" name=\"Bold\" />\n"
25268 " <Property exposed_name=\"PolarAxisLabelItalic\" name=\"Italic\" />\n"
25269 " <Property exposed_name=\"PolarAxisLabelShadow\" name=\"Shadow\" />\n"
25270 " <Property exposed_name=\"PolarAxisLabelFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
25271 " </ExposedProperties>\n"
25272 " </SubProxy>\n"
25273 " <PropertyGroup label=\"Polar Axis Label Font Properties\" panel_widget=\"FontEditor\">\n"
25274 " <Property name=\"PolarAxisLabelColor\" function=\"Color\"/>\n"
25275 " <Property name=\"PolarAxisLabelFontFamily\" function=\"Family\"/>\n"
25276 " <Property name=\"PolarAxisLabelFontFile\" function=\"File\"/>\n"
25277 " <Property name=\"PolarAxisLabelBold\" function=\"Bold\" />\n"
25278 " <Property name=\"PolarAxisLabelItalic\" function=\"Italics\"/>\n"
25279 " <Property name=\"PolarAxisLabelFontSize\" function=\"Size\" />\n"
25280 " <Property name=\"PolarAxisLabelShadow\" function=\"Shadow\" />\n"
25281 " <Property name=\"PolarAxisLabelOpacity\" function=\"Opacity\" />\n"
25282 " </PropertyGroup>\n"
25283 "\n"
25284 " <SubProxy command=\"SetLastRadialAxisTextProperty\">\n"
25285 " <Proxy name=\"LastRadialAxisTextProperty\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
25286 " <ExposedProperties>\n"
25287 " <Property exposed_name=\"LastRadialAxisTextColor\" name=\"Color\" />\n"
25288 " <Property exposed_name=\"LastRadialAxisTextOpacity\" name=\"Opacity\" />\n"
25289 " <Property exposed_name=\"LastRadialAxisTextFontFamily\" name=\"FontFamily\" />\n"
25290 " <Property exposed_name=\"LastRadialAxisTextFontFile\" name=\"FontFile\" />\n"
25291 " <Property exposed_name=\"LastRadialAxisTextBold\" name=\"Bold\" />\n"
25292 " <Property exposed_name=\"LastRadialAxisTextItalic\" name=\"Italic\" />\n"
25293 " <Property exposed_name=\"LastRadialAxisTextShadow\" name=\"Shadow\" />\n"
25294 " <Property exposed_name=\"LastRadialAxisTextFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
25295 " </ExposedProperties>\n"
25296 " </SubProxy>\n"
25297 " <PropertyGroup label=\"Last Radial Axis Text Font Properties\" panel_widget=\"FontEditor\">\n"
25298 " <Property name=\"LastRadialAxisTextColor\" function=\"Color\"/>\n"
25299 " <Property name=\"LastRadialAxisTextFontFamily\" function=\"Family\"/>\n"
25300 " <Property name=\"LastRadialAxisTextFontFile\" function=\"File\"/>\n"
25301 " <Property name=\"LastRadialAxisTextBold\" function=\"Bold\" />\n"
25302 " <Property name=\"LastRadialAxisTextItalic\" function=\"Italics\"/>\n"
25303 ;
25304
25305 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
25307 " <Property name=\"LastRadialAxisTextFontSize\" function=\"Size\" />\n"
25308 " <Property name=\"LastRadialAxisTextShadow\" function=\"Shadow\" />\n"
25309 " <Property name=\"LastRadialAxisTextOpacity\" function=\"Opacity\" />\n"
25310 " </PropertyGroup>\n"
25311 "\n"
25312 " <SubProxy command=\"SetSecondaryRadialAxesTextProperty\">\n"
25313 " <Proxy name=\"SecondaryRadialAxesTextProperty\" proxygroup=\"properties\" proxyname=\"TextProperty\" />\n"
25314 " <ExposedProperties>\n"
25315 " <Property exposed_name=\"SecondaryRadialAxesTextColor\" name=\"Color\" />\n"
25316 " <Property exposed_name=\"SecondaryRadialAxesTextOpacity\" name=\"Opacity\" />\n"
25317 " <Property exposed_name=\"SecondaryRadialAxesTextFontFamily\" name=\"FontFamily\" />\n"
25318 " <Property exposed_name=\"SecondaryRadialAxesTextFontFile\" name=\"FontFile\" />\n"
25319 " <Property exposed_name=\"SecondaryRadialAxesTextBold\" name=\"Bold\" />\n"
25320 " <Property exposed_name=\"SecondaryRadialAxesTextItalic\" name=\"Italic\" />\n"
25321 " <Property exposed_name=\"SecondaryRadialAxesTextShadow\" name=\"Shadow\" />\n"
25322 " <Property exposed_name=\"SecondaryRadialAxesTextFontSize\" name=\"FontSize\" default_values=\"12\"/>\n"
25323 " </ExposedProperties>\n"
25324 " </SubProxy>\n"
25325 " <PropertyGroup label=\"Secondary Radial Axes Text Font Properties\" panel_widget=\"FontEditor\">\n"
25326 " <Property name=\"SecondaryRadialAxesTextColor\" function=\"Color\"/>\n"
25327 " <Property name=\"SecondaryRadialAxesTextFontFamily\" function=\"Family\"/>\n"
25328 " <Property name=\"SecondaryRadialAxesTextFontFile\" function=\"File\"/>\n"
25329 " <Property name=\"SecondaryRadialAxesTextBold\" function=\"Bold\" />\n"
25330 " <Property name=\"SecondaryRadialAxesTextItalic\" function=\"Italics\"/>\n"
25331 " <Property name=\"SecondaryRadialAxesTextFontSize\" function=\"Size\" />\n"
25332 " <Property name=\"SecondaryRadialAxesTextShadow\" function=\"Shadow\" />\n"
25333 " <Property name=\"SecondaryRadialAxesTextOpacity\" function=\"Opacity\" />\n"
25334 " </PropertyGroup>\n"
25335 "\n"
25336 " <IntVectorProperty command=\"SetEnableDistanceLOD\"\n"
25337 " default_values=\"1\"\n"
25338 " name=\"EnableDistanceLOD\"\n"
25339 " number_of_elements=\"1\">\n"
25340 " <BooleanDomain name=\"bool\" />\n"
25341 " <Documentation>Set the use of LOD based on distance.</Documentation>\n"
25342 " </IntVectorProperty>\n"
25343 " <DoubleVectorProperty command=\"SetDistanceLODThreshold\"\n"
25344 " default_values=\"0.7\"\n"
25345 " name=\"DistanceLODThreshold\"\n"
25346 " panel_visibility=\"advanced\"\n"
25347 " number_of_elements=\"1\">\n"
25348 " <DoubleRangeDomain name=\"range\"\n"
25349 " min=\"0\"\n"
25350 " max=\"100\"/>\n"
25351 " <Hints>\n"
25352 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25353 " <Property name=\"EnableDistanceLOD\"\n"
25354 " function=\"boolean\" />\n"
25355 " </PropertyWidgetDecorator>\n"
25356 " </Hints>\n"
25357 " <Documentation>Set the LOD distance threshold to use.</Documentation>\n"
25358 " </DoubleVectorProperty>\n"
25359 " <IntVectorProperty command=\"SetEnableViewAngleLOD\"\n"
25360 " default_values=\"1\"\n"
25361 " name=\"EnableViewAngleLOD\"\n"
25362 " number_of_elements=\"1\">\n"
25363 " <BooleanDomain name=\"bool\" />\n"
25364 " <Documentation>Set the use of LOD based on the View Angle.</Documentation>\n"
25365 " </IntVectorProperty>\n"
25366 " <DoubleVectorProperty command=\"SetViewAngleLODThreshold\"\n"
25367 " default_values=\"0.7\"\n"
25368 " name=\"ViewAngleLODThreshold\"\n"
25369 " panel_visibility=\"advanced\"\n"
25370 " number_of_elements=\"1\">\n"
25371 " <DoubleRangeDomain name=\"range\"\n"
25372 " min=\"0\"\n"
25373 " max=\"360\"/>\n"
25374 " <Hints>\n"
25375 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25376 " <Property name=\"EnableViewAngleLOD\"\n"
25377 " function=\"boolean\" />\n"
25378 " </PropertyWidgetDecorator>\n"
25379 " </Hints>\n"
25380 " <Documentation>Set the LOD View Angle threshold to use.</Documentation>\n"
25381 " </DoubleVectorProperty>\n"
25382 " <DoubleVectorProperty command=\"SetSmallestVisiblePolarAngle\"\n"
25383 " default_values=\"0.5\"\n"
25384 " name=\"SmallestVisiblePolarAngle\"\n"
25385 " panel_visibility=\"advanced\"\n"
25386 " number_of_elements=\"1\">\n"
25387 " <DoubleRangeDomain max=\"2\"\n"
25388 " min=\"0\"\n"
25389 " name=\"range\" />\n"
25390 " <Documentation>Set the smallest radial angle distinguishable from polar axis.</Documentation>\n"
25391 " </DoubleVectorProperty>\n"
25392 " <PropertyGroup label=\"LOD and Details control\">\n"
25393 " <Property name=\"EnableDistanceLOD\" />\n"
25394 " <Property name=\"DistanceLODThreshold\" />\n"
25395 " <Property name=\"EnableViewAngleLOD\" />\n"
25396 " <Property name=\"ViewAngleLODThreshold\" />\n"
25397 " <Property name=\"SmallestVisiblePolarAngle\" />\n"
25398 " </PropertyGroup>\n"
25399 "\n"
25400 " <IntVectorProperty command=\"SetPolarTickVisibility\"\n"
25401 " default_values=\"1\"\n"
25402 " name=\"PolarTicksVisibility\"\n"
25403 " number_of_elements=\"1\">\n"
25404 " <BooleanDomain name=\"bool\" />\n"
25405 " <Documentation>Set all ticks visibility.</Documentation>\n"
25406 " </IntVectorProperty>\n"
25407 " <IntVectorProperty command=\"SetArcTicksOriginToPolarAxis\"\n"
25408 " default_values=\"1\"\n"
25409 " panel_visibility=\"advanced\"\n"
25410 " name=\"ArcTicksOriginToPolarAxis\"\n"
25411 " number_of_elements=\"1\">\n"
25412 " <BooleanDomain name=\"bool\" />\n"
25413 " <Hints>\n"
25414 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25415 " <Property name=\"PolarTicksVisibility\"\n"
25416 " function=\"boolean\" />\n"
25417 " </PropertyWidgetDecorator>\n"
25418 " </Hints>\n"
25419 " <Documentation>If On, the ticks are drawn from the angle of the polar Axis\n"
25420 " (MinimumAngle) and continue counterclockwise with the step Delta Angle Major/Minor.\n"
25421 " If Off, the start angle is 0.0</Documentation>\n"
25422 " </IntVectorProperty>\n"
25423 " <IntVectorProperty command=\"SetTickLocation\"\n"
25424 " default_values=\"2\"\n"
25425 " name=\"TickLocation\"\n"
25426 " panel_visibility=\"advanced\"\n"
25427 " number_of_elements=\"1\">\n"
25428 " <EnumerationDomain name=\"enum\">\n"
25429 " <Entry text=\"Inside\"\n"
25430 " value=\"0\" />\n"
25431 " <Entry text=\"Outside\"\n"
25432 " value=\"1\" />\n"
25433 " <Entry text=\"Both\"\n"
25434 " value=\"2\" />\n"
25435 " </EnumerationDomain>\n"
25436 " <Hints>\n"
25437 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25438 " <Property name=\"PolarTicksVisibility\"\n"
25439 " function=\"boolean\" />\n"
25440 " </PropertyWidgetDecorator>\n"
25441 " </Hints>\n"
25442 " <Documentation>Set the location of ticks.</Documentation>\n"
25443 " </IntVectorProperty>\n"
25444 " <IntVectorProperty command=\"SetAxisTickVisibility\"\n"
25445 " default_values=\"1\"\n"
25446 " name=\"AxisTickVisibility\"\n"
25447 " number_of_elements=\"1\">\n"
25448 " <BooleanDomain name=\"bool\" />\n"
25449 " <Hints>\n"
25450 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25451 " <Property name=\"PolarTicksVisibility\"\n"
25452 " function=\"boolean\" />\n"
25453 " </PropertyWidgetDecorator>\n"
25454 " </Hints>\n"
25455 " <Documentation>Set polar axis and last radial axis tick visibility.</Documentation>\n"
25456 " </IntVectorProperty>\n"
25457 " <IntVectorProperty command=\"SetAxisMinorTickVisibility\"\n"
25458 " default_values=\"0\"\n"
25459 " name=\"AxisMinorTickVisibility\"\n"
25460 " number_of_elements=\"1\">\n"
25461 " <BooleanDomain name=\"bool\" />\n"
25462 " <Hints>\n"
25463 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25464 " <Property name=\"PolarTicksVisibility\"\n"
25465 " function=\"boolean\" />\n"
25466 " </PropertyWidgetDecorator>\n"
25467 " </Hints>\n"
25468 " <Documentation>Set polar axis and last radial axis minor tick visibility.</Documentation>\n"
25469 " </IntVectorProperty>\n"
25470 " <IntVectorProperty command=\"SetAxisTickMatchesPolarAxes\"\n"
25471 " default_values=\"1\"\n"
25472 " name=\"AxisTickMatchesPolarAxes\"\n"
25473 " panel_visibility=\"advanced\"\n"
25474 " number_of_elements=\"1\">\n"
25475 " <BooleanDomain name=\"bool\" />\n"
25476 " <Documentation>If On, major axes ticks matches polar axes.\n"
25477 " Minor axes ticks are half of major ticks.\n"
25478 " If Off, ticks use Delta Range Major/Minor.</Documentation>\n"
25479 " </IntVectorProperty>\n"
25480 " <DoubleVectorProperty command=\"SetDeltaRangeMajor\"\n"
25481 " name=\"DeltaRangeMajor\"\n"
25482 " number_of_elements=\"1\"\n"
25483 " panel_visibility=\"advanced\"\n"
25484 " default_values=\"1\">\n"
25485 " <DoubleRangeDomain name=\"range\" />\n"
25486 " <Hints>\n"
25487 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
25488 " <Expression type=\"and\">\n"
25489 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AxisTickVisibility\" value=\"1\" />\n"
25490 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AxisTickMatchesPolarAxes\" value=\"0\" />\n"
25491 " </Expression>\n"
25492 " </PropertyWidgetDecorator>\n"
25493 " </Hints>\n"
25494 " <Documentation>Set the range between major axes ticks.</Documentation>\n"
25495 " </DoubleVectorProperty>\n"
25496 " <DoubleVectorProperty command=\"SetDeltaRangeMinor\"\n"
25497 " name=\"DeltaRangeMinor\"\n"
25498 " number_of_elements=\"1\"\n"
25499 " panel_visibility=\"advanced\"\n"
25500 " default_values=\"0.5\">\n"
25501 " <DoubleRangeDomain name=\"range\" />\n"
25502 " <Hints>\n"
25503 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
25504 " <Expression type=\"and\">\n"
25505 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AxisTickVisibility\" value=\"1\" />\n"
25506 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AxisTickMatchesPolarAxes\" value=\"0\" />\n"
25507 " </Expression>\n"
25508 " </PropertyWidgetDecorator>\n"
25509 " </Hints>\n"
25510 " <Documentation>Set the range between minor axes ticks.</Documentation>\n"
25511 " </DoubleVectorProperty>\n"
25512 " <IntVectorProperty command=\"SetArcTickVisibility\"\n"
25513 " default_values=\"1\"\n"
25514 " name=\"ArcTickVisibility\"\n"
25515 " number_of_elements=\"1\">\n"
25516 " <BooleanDomain name=\"bool\" />\n"
25517 " <Hints>\n"
25518 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25519 " <Property name=\"PolarTicksVisibility\"\n"
25520 " function=\"boolean\" />\n"
25521 " </PropertyWidgetDecorator>\n"
25522 " </Hints>\n"
25523 " <Documentation>Set polar arc tick visibility.</Documentation>\n"
25524 " </IntVectorProperty>\n"
25525 " <IntVectorProperty command=\"SetArcMinorTickVisibility\"\n"
25526 " default_values=\"0\"\n"
25527 " name=\"ArcMinorTickVisibility\"\n"
25528 " number_of_elements=\"1\">\n"
25529 " <BooleanDomain name=\"bool\" />\n"
25530 " <Hints>\n"
25531 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25532 " <Property name=\"PolarTicksVisibility\"\n"
25533 " function=\"boolean\" />\n"
25534 " </PropertyWidgetDecorator>\n"
25535 " </Hints>\n"
25536 " <Documentation>Set polar arc minor tick visibility.</Documentation>\n"
25537 " </IntVectorProperty>\n"
25538 " <IntVectorProperty command=\"SetArcTickMatchesRadialAxes\"\n"
25539 " default_values=\"1\"\n"
25540 " name=\"ArcTickMatchesRadialAxes\"\n"
25541 " panel_visibility=\"advanced\"\n"
25542 " number_of_elements=\"1\">\n"
25543 " <BooleanDomain name=\"bool\" />\n"
25544 " <Documentation>If On, major radial ticks matches radial axes.\n"
25545 " Minor radial ticks are half of major ticks.\n"
25546 " If Off, ticks use Delta Angle Major/Minor.</Documentation>\n"
25547 " </IntVectorProperty>\n"
25548 " <DoubleVectorProperty command=\"SetDeltaAngleMajor\"\n"
25549 " default_values=\"10\"\n"
25550 " name=\"DeltaAngleMajor\"\n"
25551 " panel_visibility=\"advanced\"\n"
25552 " number_of_elements=\"1\">\n"
25553 " <DoubleRangeDomain name=\"range\"\n"
25554 " min=\"1\"\n"
25555 " max=\"359\"/>\n"
25556 " <Hints>\n"
25557 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
25558 " <Expression type=\"and\">\n"
25559 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"PolarTicksVisibility\" value=\"1\" />\n"
25560 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ArcTickMatchesRadialAxes\" value=\"0\" />\n"
25561 " </Expression>\n"
25562 " </PropertyWidgetDecorator>\n"
25563 " </Hints>\n"
25564 " <Documentation>Set the angle (in degrees) between major ticks on last arc.</Documentation>\n"
25565 " </DoubleVectorProperty>\n"
25566 " <DoubleVectorProperty command=\"SetDeltaAngleMinor\"\n"
25567 " default_values=\"5\"\n"
25568 " name=\"DeltaAngleMinor\"\n"
25569 " panel_visibility=\"advanced\"\n"
25570 " number_of_elements=\"1\">\n"
25571 " <DoubleRangeDomain name=\"range\"\n"
25572 " min=\"1\"\n"
25573 " max=\"359\"/>\n"
25574 " <Hints>\n"
25575 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
25576 " <Expression type=\"and\">\n"
25577 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"PolarTicksVisibility\" value=\"1\" />\n"
25578 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ArcTickMatchesRadialAxes\" value=\"0\" />\n"
25579 " </Expression>\n"
25580 " </PropertyWidgetDecorator>\n"
25581 " </Hints>\n"
25582 " <Documentation>Set the angle (in degrees) between minor ticks on last arc.</Documentation>\n"
25583 " </DoubleVectorProperty>\n"
25584 " <DoubleVectorProperty command=\"SetTickRatioRadiusSize\"\n"
25585 " default_values=\"0.02\"\n"
25586 " name=\"TickRatioRadiusSize\"\n"
25587 " panel_visibility=\"advanced\"\n"
25588 " number_of_elements=\"1\">\n"
25589 " <DoubleRangeDomain name=\"range\"\n"
25590 " min=\"0.01\"\n"
25591 " max=\"0.1\"/>\n"
25592 " <Hints>\n"
25593 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25594 " <Property name=\"PolarTicksVisibility\"\n"
25595 " function=\"boolean\" />\n"
25596 ;
25597
25598 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
25600 " </PropertyWidgetDecorator>\n"
25601 " </Hints>\n"
25602 " <Documentation>Set the maximum radius / tick size ratio.\n"
25603 " Not used if a specific tick size was set.\n"
25604 " </Documentation>\n"
25605 " </DoubleVectorProperty>\n"
25606 " <DoubleVectorProperty command=\"SetPolarAxisMajorTickSize\"\n"
25607 " default_values=\"0\"\n"
25608 " name=\"PolarAxisMajorTickSize\"\n"
25609 " panel_visibility=\"advanced\"\n"
25610 " number_of_elements=\"1\">\n"
25611 " <DoubleRangeDomain name=\"range\"\n"
25612 " min=\"0\"\n"
25613 " max=\"1\"/>\n"
25614 " <Hints>\n"
25615 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25616 " <Property name=\"PolarTicksVisibility\"\n"
25617 " function=\"boolean\" />\n"
25618 " </PropertyWidgetDecorator>\n"
25619 " </Hints>\n"
25620 " <Documentation>Set the polar axis major tick size,\n"
25621 " If value is 0 (the default), tick size is automatically calculated.\n"
25622 " </Documentation>\n"
25623 " </DoubleVectorProperty>\n"
25624 " <DoubleVectorProperty command=\"SetPolarAxisTickRatioSize\"\n"
25625 " default_values=\"0.3\"\n"
25626 " name=\"PolarAxisTickRatioSize\"\n"
25627 " panel_visibility=\"advanced\"\n"
25628 " number_of_elements=\"1\">\n"
25629 " <DoubleRangeDomain name=\"range\"\n"
25630 " min=\"0\"\n"
25631 " max=\"1\"/>\n"
25632 " <Hints>\n"
25633 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25634 " <Property name=\"PolarTicksVisibility\"\n"
25635 " function=\"boolean\" />\n"
25636 " </PropertyWidgetDecorator>\n"
25637 " </Hints>\n"
25638 " <Documentation>Set the polar axis size ratio between major and minor ticks.</Documentation>\n"
25639 " </DoubleVectorProperty>\n"
25640 " <DoubleVectorProperty command=\"SetPolarAxisMajorTickThickness\"\n"
25641 " default_values=\"1.0\"\n"
25642 " name=\"PolarAxisMajorTickThickness\"\n"
25643 " panel_visibility=\"advanced\"\n"
25644 " number_of_elements=\"1\">\n"
25645 " <DoubleRangeDomain name=\"range\"\n"
25646 " min=\"0\"\n"
25647 " max=\"100\"/>\n"
25648 " <Hints>\n"
25649 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25650 " <Property name=\"PolarTicksVisibility\"\n"
25651 " function=\"boolean\" />\n"
25652 " </PropertyWidgetDecorator>\n"
25653 " </Hints>\n"
25654 " <Documentation>Set the thickness of polar axis major ticks.</Documentation>\n"
25655 " </DoubleVectorProperty>\n"
25656 " <DoubleVectorProperty command=\"SetPolarAxisTickRatioThickness\"\n"
25657 " default_values=\"0.5\"\n"
25658 " name=\"PolarAxisTickRatioThickness\"\n"
25659 " panel_visibility=\"advanced\"\n"
25660 " number_of_elements=\"1\">\n"
25661 " <DoubleRangeDomain name=\"range\"\n"
25662 " min=\"0\"\n"
25663 " max=\"1\"/>\n"
25664 " <Hints>\n"
25665 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25666 " <Property name=\"PolarTicksVisibility\"\n"
25667 " function=\"boolean\" />\n"
25668 " </PropertyWidgetDecorator>\n"
25669 " </Hints>\n"
25670 " <Documentation>Set the thickness ratio between major and minor ticks of polar axis.\n"
25671 " </Documentation>\n"
25672 " </DoubleVectorProperty>\n"
25673 " <DoubleVectorProperty command=\"SetLastRadialAxisMajorTickSize\"\n"
25674 " default_values=\"0\"\n"
25675 " name=\"LastRadialAxisMajorTickSize\"\n"
25676 " panel_visibility=\"advanced\"\n"
25677 " number_of_elements=\"1\">\n"
25678 " <DoubleRangeDomain name=\"range\"\n"
25679 " min=\"0\"\n"
25680 " max=\"1\"/>\n"
25681 " <Hints>\n"
25682 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25683 " <Property name=\"PolarTicksVisibility\"\n"
25684 " function=\"boolean\" />\n"
25685 " </PropertyWidgetDecorator>\n"
25686 " </Hints>\n"
25687 " <Documentation>Set the last radial axis major tick size,\n"
25688 " If value is 0 (the default), tick size is automatically calculated.\n"
25689 " </Documentation>\n"
25690 " </DoubleVectorProperty>\n"
25691 " <DoubleVectorProperty command=\"SetLastAxisTickRatioSize\"\n"
25692 " default_values=\"0.3\"\n"
25693 " name=\"LastRadialAxisTickRatioSize\"\n"
25694 " panel_visibility=\"advanced\"\n"
25695 " number_of_elements=\"1\">\n"
25696 " <DoubleRangeDomain name=\"range\"\n"
25697 " min=\"0\"\n"
25698 " max=\"1\"/>\n"
25699 " <Hints>\n"
25700 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25701 " <Property name=\"PolarTicksVisibility\"\n"
25702 " function=\"boolean\" />\n"
25703 " </PropertyWidgetDecorator>\n"
25704 " </Hints>\n"
25705 " <Documentation>Set the last radial axis size ratio between major and minor ticks.</Documentation>\n"
25706 " </DoubleVectorProperty>\n"
25707 " <DoubleVectorProperty command=\"SetLastRadialAxisMajorTickThickness\"\n"
25708 " default_values=\"1.0\"\n"
25709 " name=\"LastRadialAxisMajorTickThickness\"\n"
25710 " panel_visibility=\"advanced\"\n"
25711 " number_of_elements=\"1\">\n"
25712 " <DoubleRangeDomain name=\"range\"\n"
25713 " min=\"0\"\n"
25714 " max=\"100\"/>\n"
25715 " <Hints>\n"
25716 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25717 " <Property name=\"PolarTicksVisibility\"\n"
25718 " function=\"boolean\" />\n"
25719 " </PropertyWidgetDecorator>\n"
25720 " </Hints>\n"
25721 " <Documentation>Set the thickness of last radial axis major ticks.</Documentation>\n"
25722 " </DoubleVectorProperty>\n"
25723 " <DoubleVectorProperty command=\"SetLastAxisTickRatioThickness\"\n"
25724 " default_values=\"0.5\"\n"
25725 " name=\"LastRadialAxisTickRatioThickness\"\n"
25726 " panel_visibility=\"advanced\"\n"
25727 " number_of_elements=\"1\">\n"
25728 " <DoubleRangeDomain name=\"range\"\n"
25729 " min=\"0\"\n"
25730 " max=\"1\"/>\n"
25731 " <Hints>\n"
25732 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25733 " <Property name=\"PolarTicksVisibility\"\n"
25734 " function=\"boolean\" />\n"
25735 " </PropertyWidgetDecorator>\n"
25736 " </Hints>\n"
25737 " <Documentation>Set the thickness ratio between major and minor ticks of last radial axis.</Documentation>\n"
25738 " </DoubleVectorProperty>\n"
25739 " <DoubleVectorProperty command=\"SetArcMajorTickSize\"\n"
25740 " default_values=\"0\"\n"
25741 " name=\"ArcMajorTickSize\"\n"
25742 " panel_visibility=\"advanced\"\n"
25743 " number_of_elements=\"1\">\n"
25744 " <DoubleRangeDomain name=\"range\"\n"
25745 " min=\"0\"\n"
25746 " max=\"1\"/>\n"
25747 " <Hints>\n"
25748 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25749 " <Property name=\"PolarTicksVisibility\"\n"
25750 " function=\"boolean\" />\n"
25751 " </PropertyWidgetDecorator>\n"
25752 " </Hints>\n"
25753 " <Documentation>Set the arc major tick size,\n"
25754 " If value is 0 (the default), tick size is automatically calculated.\n"
25755 " </Documentation>\n"
25756 " </DoubleVectorProperty>\n"
25757 " <DoubleVectorProperty command=\"SetArcTickRatioSize\"\n"
25758 " default_values=\"0.3\"\n"
25759 " name=\"ArcTickRatioSize\"\n"
25760 " panel_visibility=\"advanced\"\n"
25761 " number_of_elements=\"1\">\n"
25762 " <DoubleRangeDomain name=\"range\"\n"
25763 " min=\"0\"\n"
25764 " max=\"1\"/>\n"
25765 " <Hints>\n"
25766 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25767 " <Property name=\"PolarTicksVisibility\"\n"
25768 " function=\"boolean\" />\n"
25769 " </PropertyWidgetDecorator>\n"
25770 " </Hints>\n"
25771 " <Documentation>Set the arc size ratio between major and minor ticks.</Documentation>\n"
25772 " </DoubleVectorProperty>\n"
25773 " <DoubleVectorProperty command=\"SetArcMajorTickThickness\"\n"
25774 " default_values=\"1.0\"\n"
25775 " name=\"ArcMajorTickThickness\"\n"
25776 " panel_visibility=\"advanced\"\n"
25777 " number_of_elements=\"1\">\n"
25778 " <DoubleRangeDomain name=\"range\"\n"
25779 " min=\"0\"\n"
25780 " max=\"100\"/>\n"
25781 " <Hints>\n"
25782 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25783 " <Property name=\"PolarTicksVisibility\"\n"
25784 " function=\"boolean\" />\n"
25785 " </PropertyWidgetDecorator>\n"
25786 " </Hints>\n"
25787 " <Documentation>Set the thickness of arc major ticks.</Documentation>\n"
25788 " </DoubleVectorProperty>\n"
25789 " <DoubleVectorProperty command=\"SetArcTickRatioThickness\"\n"
25790 " default_values=\"0.5\"\n"
25791 " name=\"ArcTickRatioThickness\"\n"
25792 " panel_visibility=\"advanced\"\n"
25793 " number_of_elements=\"1\">\n"
25794 " <DoubleRangeDomain name=\"range\"\n"
25795 " min=\"0\"\n"
25796 " max=\"1\"/>\n"
25797 " <Hints>\n"
25798 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
25799 " <Property name=\"PolarTicksVisibility\"\n"
25800 " function=\"boolean\" />\n"
25801 " </PropertyWidgetDecorator>\n"
25802 " </Hints>\n"
25803 " <Documentation>Set the thickness ratio between major and minor ticks of arc.</Documentation>\n"
25804 " </DoubleVectorProperty>\n"
25805 " <PropertyGroup label=\"Ticks Control\">\n"
25806 " <Property name=\"PolarTicksVisibility\" />\n"
25807 " <Property name=\"ArcTicksOriginToPolarAxis\" />\n"
25808 " <Property name=\"TickLocation\" />\n"
25809 " <Property name=\"AxisTickVisibility\" />\n"
25810 " <Property name=\"AxisMinorTickVisibility\" />\n"
25811 " <Property name=\"AxisTickMatchesPolarAxes\" />\n"
25812 " <Property name=\"DeltaRangeMajor\" />\n"
25813 " <Property name=\"DeltaRangeMinor\" />\n"
25814 " <Property name=\"ArcTickVisibility\" />\n"
25815 " <Property name=\"ArcMinorTickVisibility\" />\n"
25816 " <Property name=\"ArcTickMatchesRadialAxes\" />\n"
25817 " <Property name=\"DeltaAngleMajor\" />\n"
25818 " <Property name=\"DeltaAngleMinor\" />\n"
25819 " <Property name=\"TickRatioRadiusSize\" />\n"
25820 " <Property name=\"PolarAxisMajorTickSize\" />\n"
25821 " <Property name=\"PolarAxisTickRatioSize\" />\n"
25822 " <Property name=\"PolarAxisMajorTickThickness\" />\n"
25823 " <Property name=\"PolarAxisTickRatioThickness\" />\n"
25824 " <Property name=\"LastRadialAxisMajorTickSize\" />\n"
25825 " <Property name=\"LastRadialAxisTickRatioSize\" />\n"
25826 " <Property name=\"LastRadialAxisMajorTickThickness\" />\n"
25827 " <Property name=\"LastRadialAxisTickRatioThickness\" />\n"
25828 " <Property name=\"ArcMajorTickSize\" />\n"
25829 " <Property name=\"ArcTickRatioSize\" />\n"
25830 " <Property name=\"ArcMajorTickThickness\" />\n"
25831 " <Property name=\"ArcTickRatioThickness\" />\n"
25832 " </PropertyGroup>\n"
25833 "\n"
25834 " <IntVectorProperty command=\"SetUse2DMode\"\n"
25835 " default_values=\"0\"\n"
25836 " name=\"Use2DMode\"\n"
25837 " label=\"Use 2D Mode\"\n"
25838 " number_of_elements=\"1\">\n"
25839 " <BooleanDomain name=\"bool\" />\n"
25840 " <Documentation>Set the use of 2D Mode for all axes.</Documentation>\n"
25841 " </IntVectorProperty>\n"
25842 " <IntVectorProperty command=\"SetLog\"\n"
25843 " default_values=\"0\"\n"
25844 " name=\"UseLogAxis\"\n"
25845 " number_of_elements=\"1\">\n"
25846 " <BooleanDomain name=\"bool\" />\n"
25847 " <Documentation>Set the use of Log axis.</Documentation>\n"
25848 " </IntVectorProperty>\n"
25849 "\n"
25850 " <PropertyGroup label=\"Miscellaneous\">\n"
25851 " <Property name=\"Use2DMode\" />\n"
25852 " <Property name=\"UseLogAxis\" />\n"
25853 " </PropertyGroup>\n"
25854 " <!-- End of PolarAxesRepresentation -->\n"
25855 " </RepresentationProxy>\n"
25856 " <!-- End of RepresentationProxy -->\n"
25857 " </ProxyGroup>\n"
25858 "\n"
25859 " <ProxyGroup name=\"views\">\n"
25860 " <!-- ================================================================== -->\n"
25861 " <ComparativeViewProxy base_proxygroup=\"internal_views\"\n"
25862 " base_proxyname=\"ComparativeViewBase\"\n"
25863 " class=\"vtkPVComparativeView\"\n"
25864 " name=\"ComparativeRenderView\"\n"
25865 " label=\"Render View (Comparative)\">\n"
25866 " <Documentation>The is comparative view comprising of individual\n"
25867 " \"RenderView\" proxies for each panel in the comparative view\n"
25868 " grid.</Documentation>\n"
25869 " <SubProxy>\n"
25870 " <Proxy name=\"RootView\"\n"
25871 " proxygroup=\"views\"\n"
25872 " proxyname=\"RenderView\"></Proxy>\n"
25873 " <ExposedProperties>\n"
25874 " <Property name=\"HiddenRepresentations\" />\n"
25875 " <Property name=\"HiddenProps\" />\n"
25876 " <Property name=\"LODThreshold\" />\n"
25877 " <Property name=\"LODResolution\" />\n"
25878 " <Property name=\"AxesGrid\" />\n"
25879 " <Property name=\"PPI\" />\n"
25880 "\n"
25881 " <Property name=\"CenterAxesVisibility\" />\n"
25882 " <PropertyGroup label=\"Orientation Axes\">\n"
25883 " <Property name=\"OrientationAxesVisibility\" />\n"
25884 " <Property name=\"OrientationAxesInteractivity\"\n"
25885 " panel_visibility=\"advanced\"/>\n"
25886 " <Property name=\"OrientationAxesLabelColor\"\n"
25887 " panel_visibility=\"advanced\"/>\n"
25888 " <Property name=\"OrientationAxesOutlineColor\"\n"
25889 " panel_visibility=\"advanced\"/>\n"
25890 " </PropertyGroup>\n"
25891 " <PropertyGroup label=\"Camera Orientation Widget\">\n"
25892 " <Property name=\"CameraOrientationWidgetVisibility\"/>\n"
25893 " <Property name=\"CameraOrientationWidgetSize\" panel_visibility=\"advanced\"/>\n"
25894 " <Property name=\"CameraOrientationWidgetAnchor\" panel_visibility=\"advanced\"/>\n"
25895 " </PropertyGroup>\n"
25896 " <PropertyGroup label=\"Lights\" panel_visibility=\"never\">\n"
25897 " <!-- Light Kit -->\n"
25898 " <Property name=\"UseLight\"/>\n"
25899 " <!-- Key Light -->\n"
25900 " <Property name=\"KeyLightWarmth\"/>\n"
25901 " <Property name=\"KeyLightIntensity\"/>\n"
25902 " <Property name=\"KeyLightElevation\"/>\n"
25903 " <Property name=\"KeyLightAzimuth\"/>\n"
25904 " <!-- Fill Light -->\n"
25905 " <Property name=\"FillLightWarmth\"/>\n"
25906 " <Property name=\"FillLightK:F Ratio\"/>\n"
25907 " <Property name=\"FillLightElevation\"/>\n"
25908 " <Property name=\"FillLightAzimuth\"/>\n"
25909 " <!-- Back Light -->\n"
25910 " <Property name=\"BackLightWarmth\"/>\n"
25911 " <Property name=\"BackLightK:B Ratio\"/>\n"
25912 " <Property name=\"BackLightElevation\"/>\n"
25913 " <Property name=\"BackLightAzimuth\"/>\n"
25914 ;
25915
25916 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
25918 " <!-- Head Light -->\n"
25919 " <Property name=\"HeadLightWarmth\"/>\n"
25920 " <Property name=\"HeadLightK:H Ratio\"/>\n"
25921 " <Property name=\"MaintainLuminance\"/>\n"
25922 " </PropertyGroup>\n"
25923 "\n"
25924 " <!-- ActiveCamera -->\n"
25925 " <Property name=\"CameraPositionInfo\" panel_visibility=\"never\"/>\n"
25926 " <Property name=\"CameraPosition\" panel_visibility=\"never\"/>\n"
25927 " <Property name=\"CameraFocalPointInfo\" panel_visibility=\"never\"/>\n"
25928 " <Property name=\"CameraFocalPoint\" panel_visibility=\"never\"/>\n"
25929 " <Property name=\"CameraViewUpInfo\" panel_visibility=\"never\"/>\n"
25930 " <Property name=\"CameraViewUp\" panel_visibility=\"never\"/>\n"
25931 " <Property name=\"CameraViewAngle\" panel_visibility=\"never\"/>\n"
25932 " <Property name=\"CameraFocalDiskInfo\" panel_visibility=\"never\"/>\n"
25933 " <Property name=\"CameraFocalDisk\" panel_visibility=\"never\"/>\n"
25934 " <Property name=\"CameraFocalDistanceInfo\" panel_visibility=\"never\"/>\n"
25935 " <Property name=\"CameraFocalDistance\" panel_visibility=\"never\"/>\n"
25936 " <Property name=\"CameraParallelScale\" panel_visibility=\"never\"/>\n"
25937 " <Property name=\"CameraParallelScaleInfo\" panel_visibility=\"never\"/>\n"
25938 " <Property name=\"CameraParallelProjection\"\n"
25939 " panel_visibility=\"advanced\"/>\n"
25940 " <Property name=\"EyeAngle\" panel_visibility=\"never\"/>\n"
25941 "\n"
25942 " <PropertyGroup label=\"Background\">\n"
25943 " <Property name=\"UseColorPaletteForBackground\" />\n"
25944 " <Property name=\"BackgroundColorMode\" />\n"
25945 " <Property name=\"Background2\"/>\n"
25946 " <Property name=\"Background\"/>\n"
25947 " <Property name=\"BackgroundTexture\"/>\n"
25948 " <Property name=\"UseEnvironmentLighting\"/>\n"
25949 " </PropertyGroup>\n"
25950 "\n"
25951 " <PropertyGroup label=\"Render Passes\">\n"
25952 " <Property name=\"UseToneMapping\"/>\n"
25953 " <Property name=\"Exposure\"/>\n"
25954 " <Property name=\"UseSSAO\"/>\n"
25955 " <Property name=\"UseSSAODefaultPresets\"/>\n"
25956 " <Property name=\"Radius\"/>\n"
25957 " <Property name=\"Bias\"/>\n"
25958 " <Property name=\"KernelSize\"/>\n"
25959 " <Property name=\"Blur\"/>\n"
25960 " <Property name=\"GenericFilmicPresets\"/>\n"
25961 " <Property name=\"ToneMappingType\"/>\n"
25962 " <Property name=\"Contrast\"/>\n"
25963 " <Property name=\"Shoulder\"/>\n"
25964 " <Property name=\"MidIn\"/>\n"
25965 " <Property name=\"MidOut\"/>\n"
25966 " <Property name=\"HdrMax\"/>\n"
25967 " <Property name=\"UseACES\"/>\n"
25968 " </PropertyGroup>\n"
25969 "\n"
25970 " <!-- Interactor -->\n"
25971 " <Property name=\"InteractionMode\" panel_visibility=\"never\"/>\n"
25972 " <Property name=\"Camera3DManipulators\" panel_visibility=\"never\"/>\n"
25973 " <Property name=\"Camera2DManipulators\" panel_visibility=\"never\"/>\n"
25974 " <Property name=\"CenterOfRotation\" panel_visibility=\"never\"/>\n"
25975 " <Property name=\"RotationFactor\" panel_visibility=\"never\"/>\n"
25976 " <Property name=\"NonInteractiveRenderDelay\" panel_visibility=\"never\"/>\n"
25977 " <Property name=\"EnableRenderOnInteraction\" panel_visibility=\"never\"/>\n"
25978 " <Property name=\"WindowResizeNonInteractiveRenderDelay\" panel_visibility=\"never\"/>\n"
25979 " <!-- Renderer -->\n"
25980 " <PropertyGroup label=\"Stereo\">\n"
25981 " <Property name=\"StereoRender\"/>\n"
25982 " <Property name=\"StereoType\"/>\n"
25983 " <Property name=\"ServerStereoType\"/>\n"
25984 " </PropertyGroup>\n"
25985 " </ExposedProperties>\n"
25986 " <!-- End of \"RootView\" subproxy -->\n"
25987 " </SubProxy>\n"
25988 " <!-- End of ComparativeRenderView -->\n"
25989 " </ComparativeViewProxy>\n"
25990 " <!-- ================================================================== -->\n"
25991 " <ComparativeViewProxy base_proxygroup=\"internal_views\"\n"
25992 " base_proxyname=\"ComparativeViewBase\"\n"
25993 " class=\"vtkPVComparativeView\"\n"
25994 " name=\"ComparativeXYChartView\"\n"
25995 " label=\"Line Chart View (Comparative)\">\n"
25996 " <Documentation>The is comparative view comprising of individual\n"
25997 " \"XYChartView\" proxies for each panel in the comparative view\n"
25998 " grid.</Documentation>\n"
25999 " <SubProxy>\n"
26000 " <Proxy name=\"RootView\"\n"
26001 " proxygroup=\"views\"\n"
26002 " proxyname=\"XYChartView\"></Proxy>\n"
26003 " <ExposedProperties>\n"
26004 " <Property name=\"PPI\" />\n"
26005 " <PropertyGroup label=\"Title\">\n"
26006 " <Property name=\"ChartTitle\"/>\n"
26007 " <Property name=\"ChartTitleAlignment\"/>\n"
26008 " </PropertyGroup>\n"
26009 " <PropertyGroup label=\"Chart Title Properties\"\n"
26010 " panel_widget=\"FontEditor\"\n"
26011 " panel_visibility=\"advanced\">\n"
26012 " <Property name=\"ChartTitleColor\" function=\"Color\"/>\n"
26013 " <Property name=\"ChartTitleFontFamily\" function=\"Family\"/>\n"
26014 " <Property name=\"ChartTitleFontFile\" function=\"File\"/>\n"
26015 " <Property name=\"ChartTitleBold\" function=\"Bold\" />\n"
26016 " <Property name=\"ChartTitleItalic\" function=\"Italics\"/>\n"
26017 " <Property name=\"ChartTitleFontSize\" function=\"Size\" />\n"
26018 " </PropertyGroup>\n"
26019 " <PropertyGroup label=\"Legend\">\n"
26020 " <Property name=\"ShowLegend\"/>\n"
26021 " <Property name=\"LegendLocation\"/>\n"
26022 " <Property name=\"LegendPosition\"/>\n"
26023 " <Property name=\"LegendSymbolWidth\"/>\n"
26024 " </PropertyGroup>\n"
26025 " <PropertyGroup label=\"Legend Properties\"\n"
26026 " panel_widget=\"FontEditor\"\n"
26027 " panel_visibility=\"advanced\">\n"
26028 " <Property name=\"LegendFontFamily\" function=\"Family\"/>\n"
26029 " <Property name=\"LegendFontFile\" function=\"File\"/>\n"
26030 " <Property name=\"LegendBold\" function=\"Bold\"/>\n"
26031 " <Property name=\"LegendItalic\" function=\"Italics\"/>\n"
26032 " <Property name=\"LegendFontSize\" function=\"Size\"/>\n"
26033 " </PropertyGroup>\n"
26034 " <PropertyGroup label=\"Tooltip\"\n"
26035 " panel_visibility=\"advanced\">\n"
26036 " <Property name=\"TooltipNotation\"/>\n"
26037 " <Property name=\"TooltipPrecision\"/>\n"
26038 " </PropertyGroup>\n"
26039 "\n"
26040 " <!-- left axis -->\n"
26041 " <PropertyGroup label=\"Left Axis\">\n"
26042 " <Property name=\"LeftAxisTitle\"/>\n"
26043 " <Property name=\"ShowLeftAxisGrid\"/>\n"
26044 " <Property name=\"LeftAxisGridColor\"/>\n"
26045 " <Property name=\"LeftAxisColor\"/>\n"
26046 " </PropertyGroup>\n"
26047 "\n"
26048 " <PropertyGroup label=\"Left Axis Title Properties\"\n"
26049 " panel_widget=\"FontEditor\"\n"
26050 " panel_visibility=\"advanced\">\n"
26051 " <Property name=\"LeftAxisTitleColor\" function=\"Color\"/>\n"
26052 " <Property name=\"LeftAxisTitleFontFamily\" function=\"Family\"/>\n"
26053 " <Property name=\"LeftAxisTitleFontFile\" function=\"File\"/>\n"
26054 " <Property name=\"LeftAxisTitleBold\" function=\"Bold\" />\n"
26055 " <Property name=\"LeftAxisTitleItalic\" function=\"Italics\"/>\n"
26056 " <Property name=\"LeftAxisTitleFontSize\" function=\"Size\" />\n"
26057 " </PropertyGroup>\n"
26058 "\n"
26059 " <PropertyGroup label=\"Left Axis Range\">\n"
26060 " <Property name=\"LeftAxisLogScale\"/>\n"
26061 " <Property name=\"LeftAxisUseCustomRange\"/>\n"
26062 " <Property name=\"LeftAxisRangeMinimum\"/>\n"
26063 " <Property name=\"LeftAxisRangeMaximum\"/>\n"
26064 " </PropertyGroup>\n"
26065 "\n"
26066 " <PropertyGroup label=\"Left Axis Labels\">\n"
26067 " <Property name=\"ShowLeftAxisLabels\"/>\n"
26068 " <Property name=\"LeftAxisLabelNotation\"/>\n"
26069 " <Property name=\"LeftAxisLabelPrecision\"/>\n"
26070 " <Property name=\"LeftAxisUseCustomLabels\"/>\n"
26071 " <Property name=\"LeftAxisLabels\"/>\n"
26072 " </PropertyGroup>\n"
26073 "\n"
26074 " <PropertyGroup label=\"Left Axis Label Properties\"\n"
26075 " panel_widget=\"FontEditor\"\n"
26076 " panel_visibility=\"advanced\">\n"
26077 " <Property name=\"LeftAxisLabelColor\" function=\"Color\"/>\n"
26078 " <Property name=\"LeftAxisLabelFontFamily\" function=\"Family\"/>\n"
26079 " <Property name=\"LeftAxisLabelFontFile\" function=\"File\"/>\n"
26080 " <Property name=\"LeftAxisLabelBold\" function=\"Bold\" />\n"
26081 " <Property name=\"LeftAxisLabelItalic\" function=\"Italics\"/>\n"
26082 " <Property name=\"LeftAxisLabelFontSize\" function=\"Size\" />\n"
26083 " </PropertyGroup>\n"
26084 " <!-- bottom axis -->\n"
26085 " <PropertyGroup label=\"Bottom Axis\">\n"
26086 " <Property name=\"BottomAxisTitle\"/>\n"
26087 " <Property name=\"ShowBottomAxisGrid\"/>\n"
26088 " <Property name=\"BottomAxisGridColor\"/>\n"
26089 " <Property name=\"BottomAxisColor\"/>\n"
26090 " </PropertyGroup>\n"
26091 " <PropertyGroup label=\"Bottom Axis Title Properties\"\n"
26092 " panel_widget=\"FontEditor\"\n"
26093 " panel_visibility=\"advanced\">\n"
26094 " <Property name=\"BottomAxisTitleColor\" function=\"Color\"/>\n"
26095 " <Property name=\"BottomAxisTitleFontFamily\" function=\"Family\"/>\n"
26096 " <Property name=\"BottomAxisTitleFontFile\" function=\"File\"/>\n"
26097 " <Property name=\"BottomAxisTitleBold\" function=\"Bold\" />\n"
26098 " <Property name=\"BottomAxisTitleItalic\" function=\"Italics\"/>\n"
26099 " <Property name=\"BottomAxisTitleFontSize\" function=\"Size\" />\n"
26100 " </PropertyGroup>\n"
26101 " <PropertyGroup label=\"Bottom Axis Range\">\n"
26102 " <Property name=\"BottomAxisLogScale\"/>\n"
26103 " <Property name=\"BottomAxisUseCustomRange\"/>\n"
26104 " <Property name=\"BottomAxisRangeMinimum\"/>\n"
26105 " <Property name=\"BottomAxisRangeMaximum\"/>\n"
26106 " </PropertyGroup>\n"
26107 " <PropertyGroup label=\"Bottom Axis Labels\">\n"
26108 " <Property name=\"ShowBottomAxisLabels\"/>\n"
26109 " <Property name=\"BottomAxisLabelNotation\"/>\n"
26110 " <Property name=\"BottomAxisLabelPrecision\"/>\n"
26111 " <Property name=\"BottomAxisUseCustomLabels\"/>\n"
26112 " <Property name=\"BottomAxisLabels\"/>\n"
26113 " </PropertyGroup>\n"
26114 " <PropertyGroup label=\"Bottom Axis Label Properties\"\n"
26115 " panel_widget=\"FontEditor\"\n"
26116 " panel_visibility=\"advanced\">\n"
26117 " <Property name=\"BottomAxisLabelColor\" function=\"Color\"/>\n"
26118 " <Property name=\"BottomAxisLabelFontFamily\" function=\"Family\"/>\n"
26119 " <Property name=\"BottomAxisLabelFontFile\" function=\"File\"/>\n"
26120 " <Property name=\"BottomAxisLabelBold\" function=\"Bold\" />\n"
26121 " <Property name=\"BottomAxisLabelItalic\" function=\"Italics\"/>\n"
26122 " <Property name=\"BottomAxisLabelFontSize\" function=\"Size\" />\n"
26123 " </PropertyGroup>\n"
26124 " <!-- right axis -->\n"
26125 " <PropertyGroup label=\"Right Axis\">\n"
26126 " <Property name=\"RightAxisTitle\"/>\n"
26127 " <Property name=\"ShowRightAxisGrid\"/>\n"
26128 " <Property name=\"RightAxisGridColor\"/>\n"
26129 " <Property name=\"RightAxisColor\"/>\n"
26130 " </PropertyGroup>\n"
26131 " <PropertyGroup label=\"Right Axis Title Properties\"\n"
26132 " panel_widget=\"FontEditor\"\n"
26133 " panel_visibility=\"advanced\">\n"
26134 " <Property name=\"RightAxisTitleColor\" function=\"Color\"/>\n"
26135 " <Property name=\"RightAxisTitleFontFamily\" function=\"Family\"/>\n"
26136 " <Property name=\"RightAxisTitleFontFile\" function=\"File\"/>\n"
26137 " <Property name=\"RightAxisTitleBold\" function=\"Bold\" />\n"
26138 " <Property name=\"RightAxisTitleItalic\" function=\"Italics\"/>\n"
26139 " <Property name=\"RightAxisTitleFontSize\" function=\"Size\" />\n"
26140 " </PropertyGroup>\n"
26141 " <PropertyGroup label=\"Right Axis Range\">\n"
26142 " <Property name=\"RightAxisLogScale\"/>\n"
26143 " <Property name=\"RightAxisUseCustomRange\"/>\n"
26144 " <Property name=\"RightAxisRangeMinimum\"/>\n"
26145 " <Property name=\"RightAxisRangeMaximum\"/>\n"
26146 " </PropertyGroup>\n"
26147 " <PropertyGroup label=\"Right Axis Labels\">\n"
26148 " <Property name=\"ShowRightAxisLabels\"/>\n"
26149 " <Property name=\"RightAxisLabelNotation\"/>\n"
26150 " <Property name=\"RightAxisLabelPrecision\"/>\n"
26151 " <Property name=\"RightAxisUseCustomLabels\"/>\n"
26152 " <Property name=\"RightAxisLabels\"/>\n"
26153 " </PropertyGroup>\n"
26154 " <PropertyGroup label=\"Right Axis Label Properties\"\n"
26155 " panel_widget=\"FontEditor\"\n"
26156 " panel_visibility=\"advanced\">\n"
26157 " <Property name=\"RightAxisLabelColor\" function=\"Color\"/>\n"
26158 " <Property name=\"RightAxisLabelFontFamily\" function=\"Family\"/>\n"
26159 " <Property name=\"RightAxisLabelFontFile\" function=\"File\"/>\n"
26160 " <Property name=\"RightAxisLabelBold\" function=\"Bold\" />\n"
26161 " <Property name=\"RightAxisLabelItalic\" function=\"Italics\"/>\n"
26162 " <Property name=\"RightAxisLabelFontSize\" function=\"Size\" />\n"
26163 " </PropertyGroup>\n"
26164 " <!-- top axis -->\n"
26165 " <PropertyGroup label=\"Top Axis\">\n"
26166 " <Property name=\"TopAxisTitle\"/>\n"
26167 " <Property name=\"ShowTopAxisGrid\"/>\n"
26168 " <Property name=\"TopAxisGridColor\"/>\n"
26169 " <Property name=\"TopAxisColor\"/>\n"
26170 " </PropertyGroup>\n"
26171 " <PropertyGroup label=\"Top Axis Title Properties\"\n"
26172 " panel_widget=\"FontEditor\"\n"
26173 " panel_visibility=\"advanced\">\n"
26174 " <Property name=\"TopAxisTitleColor\" function=\"Color\"/>\n"
26175 " <Property name=\"TopAxisTitleFontFamily\" function=\"Family\"/>\n"
26176 " <Property name=\"TopAxisTitleFontFile\" function=\"File\"/>\n"
26177 " <Property name=\"TopAxisTitleBold\" function=\"Bold\" />\n"
26178 " <Property name=\"TopAxisTitleItalic\" function=\"Italics\"/>\n"
26179 " <Property name=\"TopAxisTitleFontSize\" function=\"Size\" />\n"
26180 " </PropertyGroup>\n"
26181 " <PropertyGroup label=\"Top Axis Range\">\n"
26182 " <Property name=\"TopAxisLogScale\"/>\n"
26183 " <Property name=\"TopAxisUseCustomRange\"/>\n"
26184 " <Property name=\"TopAxisRangeMinimum\"/>\n"
26185 " <Property name=\"TopAxisRangeMaximum\"/>\n"
26186 " </PropertyGroup>\n"
26187 " <PropertyGroup label=\"Top Axis Labels\">\n"
26188 " <Property name=\"ShowTopAxisLabels\"/>\n"
26189 " <Property name=\"TopAxisLabelNotation\"/>\n"
26190 " <Property name=\"TopAxisLabelPrecision\"/>\n"
26191 " <Property name=\"TopAxisUseCustomLabels\"/>\n"
26192 " <Property name=\"TopAxisLabels\"/>\n"
26193 " </PropertyGroup>\n"
26194 " <PropertyGroup label=\"Top Axis Label Properties\"\n"
26195 " panel_widget=\"FontEditor\"\n"
26196 " panel_visibility=\"advanced\">\n"
26197 " <Property name=\"TopAxisLabelColor\" function=\"Color\"/>\n"
26198 " <Property name=\"TopAxisLabelFontFamily\" function=\"Family\"/>\n"
26199 " <Property name=\"TopAxisLabelFontFile\" function=\"File\"/>\n"
26200 " <Property name=\"TopAxisLabelBold\" function=\"Bold\" />\n"
26201 ;
26202
26203 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
26205 " <Property name=\"TopAxisLabelItalic\" function=\"Italics\"/>\n"
26206 " <Property name=\"TopAxisLabelFontSize\" function=\"Size\" />\n"
26207 " </PropertyGroup>\n"
26208 " </ExposedProperties>\n"
26209 " <!-- End of \"RootView\" subproxy -->\n"
26210 " </SubProxy>\n"
26211 " <!-- End of ComparativeXYChartView -->\n"
26212 " </ComparativeViewProxy>\n"
26213 " <!-- ================================================================== -->\n"
26214 " <ComparativeViewProxy base_proxygroup=\"internal_views\"\n"
26215 " base_proxyname=\"ComparativeViewBase\"\n"
26216 " class=\"vtkPVComparativeView\"\n"
26217 " name=\"ComparativeXYBarChartView\"\n"
26218 " label=\"Bar Chart View (Comparative)\">\n"
26219 " <Documentation>The is comparative view comprising of individual\n"
26220 " \"XYBarChartView\" proxies for each panel in the comparative view\n"
26221 " grid.</Documentation>\n"
26222 "\n"
26223 " <SubProxy>\n"
26224 " <Proxy name=\"RootView\"\n"
26225 " proxygroup=\"views\"\n"
26226 " proxyname=\"XYBarChartView\"></Proxy>\n"
26227 " <ExposedProperties>\n"
26228 " <Property name=\"PPI\" />\n"
26229 " <PropertyGroup label=\"Title\">\n"
26230 " <Property name=\"ChartTitle\"/>\n"
26231 " <Property name=\"ChartTitleAlignment\"/>\n"
26232 " </PropertyGroup>\n"
26233 " <PropertyGroup label=\"Chart Title Properties\"\n"
26234 " panel_widget=\"FontEditor\"\n"
26235 " panel_visibility=\"advanced\">\n"
26236 " <Property name=\"ChartTitleColor\" function=\"Color\"/>\n"
26237 " <Property name=\"ChartTitleFontFamily\" function=\"Family\"/>\n"
26238 " <Property name=\"ChartTitleFontFile\" function=\"File\"/>\n"
26239 " <Property name=\"ChartTitleBold\" function=\"Bold\" />\n"
26240 " <Property name=\"ChartTitleItalic\" function=\"Italics\"/>\n"
26241 " <Property name=\"ChartTitleFontSize\" function=\"Size\" />\n"
26242 " </PropertyGroup>\n"
26243 " <PropertyGroup label=\"Legend\">\n"
26244 " <Property name=\"ShowLegend\"/>\n"
26245 " <Property name=\"LegendLocation\"/>\n"
26246 " <Property name=\"LegendPosition\"/>\n"
26247 " <Property name=\"LegendSymbolWidth\"/>\n"
26248 " </PropertyGroup>\n"
26249 " <PropertyGroup label=\"Legend Properties\"\n"
26250 " panel_widget=\"FontEditor\"\n"
26251 " panel_visibility=\"advanced\">\n"
26252 " <Property name=\"LegendFontFamily\" function=\"Family\"/>\n"
26253 " <Property name=\"LegendFontFile\" function=\"File\"/>\n"
26254 " <Property name=\"LegendBold\" function=\"Bold\"/>\n"
26255 " <Property name=\"LegendItalic\" function=\"Italics\"/>\n"
26256 " <Property name=\"LegendFontSize\" function=\"Size\"/>\n"
26257 " </PropertyGroup>\n"
26258 " <PropertyGroup label=\"Tooltip\"\n"
26259 " panel_visibility=\"advanced\">\n"
26260 " <Property name=\"TooltipNotation\"/>\n"
26261 " <Property name=\"TooltipPrecision\"/>\n"
26262 " </PropertyGroup>\n"
26263 "\n"
26264 " <!-- left axis -->\n"
26265 " <PropertyGroup label=\"Left Axis\">\n"
26266 " <Property name=\"LeftAxisTitle\"/>\n"
26267 " <Property name=\"ShowLeftAxisGrid\"/>\n"
26268 " <Property name=\"LeftAxisGridColor\"/>\n"
26269 " <Property name=\"LeftAxisColor\"/>\n"
26270 " </PropertyGroup>\n"
26271 "\n"
26272 " <PropertyGroup label=\"Left Axis Title Properties\"\n"
26273 " panel_widget=\"FontEditor\"\n"
26274 " panel_visibility=\"advanced\">\n"
26275 " <Property name=\"LeftAxisTitleColor\" function=\"Color\"/>\n"
26276 " <Property name=\"LeftAxisTitleFontFamily\" function=\"Family\"/>\n"
26277 " <Property name=\"LeftAxisTitleFontFile\" function=\"File\"/>\n"
26278 " <Property name=\"LeftAxisTitleBold\" function=\"Bold\" />\n"
26279 " <Property name=\"LeftAxisTitleItalic\" function=\"Italics\"/>\n"
26280 " <Property name=\"LeftAxisTitleFontSize\" function=\"Size\" />\n"
26281 " </PropertyGroup>\n"
26282 "\n"
26283 " <PropertyGroup label=\"Left Axis Range\">\n"
26284 " <Property name=\"LeftAxisLogScale\"/>\n"
26285 " <Property name=\"LeftAxisUseCustomRange\"/>\n"
26286 " <Property name=\"LeftAxisRangeMinimum\"/>\n"
26287 " <Property name=\"LeftAxisRangeMaximum\"/>\n"
26288 " </PropertyGroup>\n"
26289 "\n"
26290 " <PropertyGroup label=\"Left Axis Labels\">\n"
26291 " <Property name=\"ShowLeftAxisLabels\"/>\n"
26292 " <Property name=\"LeftAxisLabelNotation\"/>\n"
26293 " <Property name=\"LeftAxisLabelPrecision\"/>\n"
26294 " <Property name=\"LeftAxisUseCustomLabels\"/>\n"
26295 " <Property name=\"LeftAxisLabels\"/>\n"
26296 " </PropertyGroup>\n"
26297 "\n"
26298 " <PropertyGroup label=\"Left Axis Label Properties\"\n"
26299 " panel_widget=\"FontEditor\"\n"
26300 " panel_visibility=\"advanced\">\n"
26301 " <Property name=\"LeftAxisLabelColor\" function=\"Color\"/>\n"
26302 " <Property name=\"LeftAxisLabelFontFamily\" function=\"Family\"/>\n"
26303 " <Property name=\"LeftAxisLabelFontFile\" function=\"File\"/>\n"
26304 " <Property name=\"LeftAxisLabelBold\" function=\"Bold\" />\n"
26305 " <Property name=\"LeftAxisLabelItalic\" function=\"Italics\"/>\n"
26306 " <Property name=\"LeftAxisLabelFontSize\" function=\"Size\" />\n"
26307 " </PropertyGroup>\n"
26308 " <!-- bottom axis -->\n"
26309 " <PropertyGroup label=\"Bottom Axis\">\n"
26310 " <Property name=\"BottomAxisTitle\"/>\n"
26311 " <Property name=\"ShowBottomAxisGrid\"/>\n"
26312 " <Property name=\"BottomAxisGridColor\"/>\n"
26313 " <Property name=\"BottomAxisColor\"/>\n"
26314 " </PropertyGroup>\n"
26315 "\n"
26316 " <PropertyGroup label=\"Bottom Axis Title Properties\"\n"
26317 " panel_widget=\"FontEditor\"\n"
26318 " panel_visibility=\"advanced\">\n"
26319 " <Property name=\"BottomAxisTitleColor\" function=\"Color\"/>\n"
26320 " <Property name=\"BottomAxisTitleFontFamily\" function=\"Family\"/>\n"
26321 " <Property name=\"BottomAxisTitleFontFile\" function=\"File\"/>\n"
26322 " <Property name=\"BottomAxisTitleBold\" function=\"Bold\" />\n"
26323 " <Property name=\"BottomAxisTitleItalic\" function=\"Italics\"/>\n"
26324 " <Property name=\"BottomAxisTitleFontSize\" function=\"Size\" />\n"
26325 " </PropertyGroup>\n"
26326 "\n"
26327 " <PropertyGroup label=\"Bottom Axis Range\">\n"
26328 " <Property name=\"BottomAxisLogScale\"/>\n"
26329 " <Property name=\"BottomAxisUseCustomRange\"/>\n"
26330 " <Property name=\"BottomAxisRangeMinimum\"/>\n"
26331 " <Property name=\"BottomAxisRangeMaximum\"/>\n"
26332 " </PropertyGroup>\n"
26333 "\n"
26334 " <PropertyGroup label=\"Bottom Axis Labels\">\n"
26335 " <Property name=\"ShowBottomAxisLabels\"/>\n"
26336 " <Property name=\"BottomAxisLabelNotation\"/>\n"
26337 " <Property name=\"BottomAxisLabelPrecision\"/>\n"
26338 " <Property name=\"BottomAxisUseCustomLabels\"/>\n"
26339 " <Property name=\"BottomAxisLabels\"/>\n"
26340 " </PropertyGroup>\n"
26341 "\n"
26342 " <PropertyGroup label=\"Bottom Axis Label Properties\"\n"
26343 " panel_widget=\"FontEditor\"\n"
26344 " panel_visibility=\"advanced\">\n"
26345 " <Property name=\"BottomAxisLabelColor\" function=\"Color\"/>\n"
26346 " <Property name=\"BottomAxisLabelFontFamily\" function=\"Family\"/>\n"
26347 " <Property name=\"BottomAxisLabelFontFile\" function=\"File\"/>\n"
26348 " <Property name=\"BottomAxisLabelBold\" function=\"Bold\" />\n"
26349 " <Property name=\"BottomAxisLabelItalic\" function=\"Italics\"/>\n"
26350 " <Property name=\"BottomAxisLabelFontSize\" function=\"Size\" />\n"
26351 " </PropertyGroup>\n"
26352 " </ExposedProperties>\n"
26353 " </SubProxy>\n"
26354 "\n"
26355 " <!-- End of ComparativeXYBarChartView -->\n"
26356 " </ComparativeViewProxy>\n"
26357 " <!-- ================================================================== -->\n"
26358 " <MultiSliceViewProxy name=\"MultiSlice\" class=\"vtkPVMultiSliceView\"\n"
26359 " processes=\"client|renderserver|dataserver\"\n"
26360 " base_proxygroup=\"views\" base_proxyname=\"RenderView\"\n"
26361 " label=\"Slice View\">\n"
26362 " <DoubleVectorProperty name=\"XSlicesValues\"\n"
26363 " set_number_command=\"SetNumberOfXSlices\"\n"
26364 " command=\"SetXSlices\"\n"
26365 " argument_is_array=\"1\"\n"
26366 " panel_visibility=\"never\">\n"
26367 " </DoubleVectorProperty>\n"
26368 " <DoubleVectorProperty name=\"YSlicesValues\"\n"
26369 " set_number_command=\"SetNumberOfYSlices\"\n"
26370 " command=\"SetYSlices\"\n"
26371 " argument_is_array=\"1\"\n"
26372 " panel_visibility=\"never\">\n"
26373 " </DoubleVectorProperty>\n"
26374 " <DoubleVectorProperty name=\"ZSlicesValues\"\n"
26375 " set_number_command=\"SetNumberOfZSlices\"\n"
26376 " command=\"SetZSlices\"\n"
26377 " argument_is_array=\"1\"\n"
26378 " panel_visibility=\"never\">\n"
26379 " </DoubleVectorProperty>\n"
26380 " <StringVectorProperty name=\"XTitle\"\n"
26381 " number_of_elements=\"1\"\n"
26382 " default_values=\"X\"\n"
26383 " panel_visibility=\"never\" />\n"
26384 " <StringVectorProperty name=\"YTitle\"\n"
26385 " number_of_elements=\"1\"\n"
26386 " default_values=\"Y\"\n"
26387 " panel_visibility=\"never\" />\n"
26388 " <StringVectorProperty name=\"ZTitle\"\n"
26389 " number_of_elements=\"1\"\n"
26390 " default_values=\"Z\"\n"
26391 " panel_visibility=\"never\" />\n"
26392 " </MultiSliceViewProxy>\n"
26393 "\n"
26394 " <!-- ================================================================== -->\n"
26395 " </ProxyGroup>\n"
26396 "\n"
26397 " <!-- ==================================================================== -->\n"
26398 " <ProxyGroup name=\"internal_representations\">\n"
26399 " <!-- group for representations not meant to be used directly, but that\n"
26400 " should be created in a vtkPVCompositeRepresentation. Helps us keep the\n"
26401 " properties manageable, since we don't need to expose too many properties\n"
26402 " from these. Only public API properties need to be defined for these proxies\n"
26403 " (along with \"Input\" and \"Representation\", if applicable).\n"
26404 " -->\n"
26405 "\n"
26406 " <!-- ================================================================== -->\n"
26407 " <RepresentationProxy class=\"vtkAMROutlineRepresentation\"\n"
26408 " name=\"AMROutlineRepresentation\"\n"
26409 " processes=\"client|renderserver|dataserver\">\n"
26410 " <Documentation>Representation for showing an outline for AMR\n"
26411 " dataset that is streaming capable.</Documentation>\n"
26412 "\n"
26413 " <InputProperty command=\"SetInputConnection\"\n"
26414 " name=\"Input\">\n"
26415 " <DataTypeDomain name=\"input_type\">\n"
26416 " <DataType value=\"vtkOverlappingAMR\" />\n"
26417 " </DataTypeDomain>\n"
26418 " <Documentation>Set the input to the representation.</Documentation>\n"
26419 " </InputProperty>\n"
26420 "\n"
26421 " <DoubleVectorProperty command=\"SetPosition\"\n"
26422 " default_values=\"0 0 0\"\n"
26423 " name=\"Position\"\n"
26424 " number_of_elements=\"3\">\n"
26425 " <DoubleRangeDomain name=\"range\" />\n"
26426 " </DoubleVectorProperty>\n"
26427 " <DoubleVectorProperty command=\"SetScale\"\n"
26428 " default_values=\"1 1 1\"\n"
26429 " name=\"Scale\"\n"
26430 " number_of_elements=\"3\">\n"
26431 " <DoubleRangeDomain name=\"range\" />\n"
26432 " </DoubleVectorProperty>\n"
26433 " <DoubleVectorProperty command=\"SetOrientation\"\n"
26434 " default_values=\"0 0 0\"\n"
26435 " name=\"Orientation\"\n"
26436 " number_of_elements=\"3\">\n"
26437 " <DoubleRangeDomain name=\"range\" />\n"
26438 " </DoubleVectorProperty>\n"
26439 " <DoubleVectorProperty command=\"SetOrigin\"\n"
26440 " default_values=\"0 0 0\"\n"
26441 " name=\"Origin\"\n"
26442 " number_of_elements=\"3\">\n"
26443 " <DoubleRangeDomain name=\"range\" />\n"
26444 " </DoubleVectorProperty>\n"
26445 " <IntVectorProperty command=\"SetPickable\"\n"
26446 " default_values=\"1\"\n"
26447 " name=\"Pickable\"\n"
26448 " number_of_elements=\"1\">\n"
26449 " <BooleanDomain name=\"bool\" />\n"
26450 " </IntVectorProperty>\n"
26451 " <DoubleVectorProperty argument_is_array=\"1\"\n"
26452 " command=\"SetUserTransform\"\n"
26453 " default_values=\"1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1\"\n"
26454 " name=\"UserTransform\"\n"
26455 " number_of_elements=\"16\">\n"
26456 " <Documentation>\n"
26457 " In addition to the instance variables such as position and\n"
26458 " orientation, you can add an additional transformation for your own\n"
26459 " use. This transformation is concatenated with the actor's internal\n"
26460 " transformation, which you implicitly create through the use of\n"
26461 " Position, Origin, Orientation. The value is 4x4 matrix for the linear\n"
26462 " transform to use.\n"
26463 " </Documentation>\n"
26464 " </DoubleVectorProperty>\n"
26465 " <DoubleVectorProperty command=\"SetAmbient\"\n"
26466 " default_values=\"0.0\"\n"
26467 " name=\"Ambient\"\n"
26468 " number_of_elements=\"1\">\n"
26469 " <DoubleRangeDomain max=\"1\"\n"
26470 " min=\"0\"\n"
26471 " name=\"range\" />\n"
26472 " </DoubleVectorProperty>\n"
26473 " <DoubleVectorProperty command=\"SetDiffuse\"\n"
26474 " default_values=\"1.0\"\n"
26475 " name=\"Diffuse\"\n"
26476 " number_of_elements=\"1\">\n"
26477 " <DoubleRangeDomain max=\"1\"\n"
26478 " min=\"0\"\n"
26479 " name=\"range\" />\n"
26480 " </DoubleVectorProperty>\n"
26481 " <DoubleVectorProperty command=\"SetSpecular\"\n"
26482 " default_values=\"0.0\"\n"
26483 " name=\"Specular\"\n"
26484 " number_of_elements=\"1\">\n"
26485 " <DoubleRangeDomain max=\"1\"\n"
26486 " min=\"0\"\n"
26487 " name=\"range\" />\n"
26488 " </DoubleVectorProperty>\n"
26489 " <DoubleVectorProperty command=\"SetSpecularPower\"\n"
26490 " default_values=\"100.0\"\n"
26491 " name=\"SpecularPower\"\n"
26492 " number_of_elements=\"1\">\n"
26493 " <DoubleRangeDomain max=\"100\"\n"
26494 " min=\"0\"\n"
26495 " name=\"range\" />\n"
26496 " </DoubleVectorProperty>\n"
26497 " <DoubleVectorProperty command=\"SetAmbientColor\"\n"
26498 " default_values=\"1.0 1.0 1.0\"\n"
26499 " name=\"AmbientColor\"\n"
26500 " number_of_elements=\"3\">\n"
26501 " <DoubleRangeDomain max=\"1 1 1\"\n"
26502 " min=\"0 0 0\"\n"
26503 " name=\"range\" />\n"
26504 " <Hints>\n"
26505 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\" unlink_if_modified=\"1\" />\n"
26506 " </Hints>\n"
26507 " </DoubleVectorProperty>\n"
26508 " <DoubleVectorProperty command=\"SetDiffuseColor\"\n"
26509 " default_values=\"1.0 1.0 1.0\"\n"
26510 " name=\"DiffuseColor\"\n"
26511 " number_of_elements=\"3\"\n"
26512 " panel_widget=\"color_selector_with_palette\">\n"
26513 " <DoubleRangeDomain max=\"1 1 1\"\n"
26514 ;
26515
26516 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
26518 " min=\"0 0 0\"\n"
26519 " name=\"range\" />\n"
26520 " <Hints>\n"
26521 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SurfaceColor\" unlink_if_modified=\"1\" />\n"
26522 " </Hints>\n"
26523 " </DoubleVectorProperty>\n"
26524 " <DoubleVectorProperty command=\"SetSpecularColor\"\n"
26525 " default_values=\"1.0 1.0 1.0\"\n"
26526 " name=\"SpecularColor\"\n"
26527 " number_of_elements=\"3\">\n"
26528 " <DoubleRangeDomain max=\"1 1 1\"\n"
26529 " min=\"0 0 0\"\n"
26530 " name=\"range\" />\n"
26531 " </DoubleVectorProperty>\n"
26532 " <DoubleVectorProperty command=\"SetLineWidth\"\n"
26533 " default_values=\"1.0\"\n"
26534 " name=\"LineWidth\"\n"
26535 " number_of_elements=\"1\">\n"
26536 " <DoubleRangeDomain min=\"0\"\n"
26537 " name=\"range\" />\n"
26538 " </DoubleVectorProperty>\n"
26539 " <DoubleVectorProperty command=\"SetOpacity\"\n"
26540 " default_values=\"1.0\"\n"
26541 " name=\"Opacity\"\n"
26542 " number_of_elements=\"1\">\n"
26543 " <DoubleRangeDomain max=\"1\"\n"
26544 " min=\"0\"\n"
26545 " name=\"range\" />\n"
26546 " </DoubleVectorProperty>\n"
26547 " <DoubleVectorProperty command=\"SetLuminosity\"\n"
26548 " default_values=\"0.0\"\n"
26549 " name=\"Luminosity\"\n"
26550 " number_of_elements=\"1\">\n"
26551 " <DoubleRangeDomain max=\"100.0\"\n"
26552 " min=\"0\"\n"
26553 " name=\"range\" />\n"
26554 " <Documentation>Makes the object emit light.\n"
26555 " Only takes effect with OSPRay's path traced renderer.\n"
26556 " </Documentation>\n"
26557 " <Hints>\n"
26558 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
26559 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
26560 " mode=\"visibility\"\n"
26561 " property=\"EnableOSPRay\"\n"
26562 " values=\"1\" />\n"
26563 " </Hints>\n"
26564 " </DoubleVectorProperty>\n"
26565 " <IntVectorProperty command=\"SetRenderLinesAsTubes\"\n"
26566 " default_values=\"0\"\n"
26567 " name=\"RenderLinesAsTubes\"\n"
26568 " number_of_elements=\"1\">\n"
26569 " <BooleanDomain name=\"bool\" />\n"
26570 " <Documentation>\n"
26571 " When set, all lines are rendered as 3D tubes, if supported by OpenGL driver.\n"
26572 " </Documentation>\n"
26573 " </IntVectorProperty>\n"
26574 " <!-- end of AMROutlineRepresentation -->\n"
26575 " </RepresentationProxy>\n"
26576 "\n"
26577 " <!-- ================================================================== -->\n"
26578 " <RepresentationProxy class=\"vtkAMRStreamingVolumeRepresentation\"\n"
26579 " name=\"AMRVolumeRepresentation\"\n"
26580 " processes=\"client|renderserver|dataserver\">\n"
26581 " <Documentation>\n"
26582 " Representation for rendering Overlapping AMR as volume.\n"
26583 " </Documentation>\n"
26584 " <InputProperty command=\"SetInputConnection\"\n"
26585 " name=\"Input\">\n"
26586 " <DataTypeDomain name=\"input_type\">\n"
26587 " <DataType value=\"vtkOverlappingAMR\" />\n"
26588 " </DataTypeDomain>\n"
26589 " <InputArrayDomain attribute_type=\"any\"\n"
26590 " name=\"input_array_any\">\n"
26591 " </InputArrayDomain>\n"
26592 " <Documentation>Set the input to the representation.</Documentation>\n"
26593 " </InputProperty>\n"
26594 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
26595 " element_types=\"0 0 0 0 2\"\n"
26596 " name=\"ColorArrayName\"\n"
26597 " no_custom_default=\"1\"\n"
26598 " number_of_elements=\"5\">\n"
26599 " <Documentation>\n"
26600 " Set the array to color with. One must specify the field association and\n"
26601 " the array name of the array. If the array is missing, scalar coloring will\n"
26602 " automatically be disabled.\n"
26603 " </Documentation>\n"
26604 " <RepresentedArrayListDomain name=\"array_list\"\n"
26605 " input_domain_name=\"input_array_any\">\n"
26606 " <RequiredProperties>\n"
26607 " <Property function=\"Input\" name=\"Input\" />\n"
26608 " </RequiredProperties>\n"
26609 " </RepresentedArrayListDomain>\n"
26610 " </StringVectorProperty>\n"
26611 " <DoubleVectorProperty command=\"SetPosition\"\n"
26612 " default_values=\"0 0 0\"\n"
26613 " name=\"Position\"\n"
26614 " number_of_elements=\"3\">\n"
26615 " <DoubleRangeDomain name=\"range\" />\n"
26616 " </DoubleVectorProperty>\n"
26617 " <DoubleVectorProperty command=\"SetScale\"\n"
26618 " default_values=\"1 1 1\"\n"
26619 " name=\"Scale\"\n"
26620 " number_of_elements=\"3\">\n"
26621 " <DoubleRangeDomain name=\"range\" />\n"
26622 " </DoubleVectorProperty>\n"
26623 " <DoubleVectorProperty command=\"SetOrientation\"\n"
26624 " default_values=\"0 0 0\"\n"
26625 " name=\"Orientation\"\n"
26626 " number_of_elements=\"3\">\n"
26627 " <DoubleRangeDomain name=\"range\" />\n"
26628 " </DoubleVectorProperty>\n"
26629 " <DoubleVectorProperty command=\"SetOrigin\"\n"
26630 " default_values=\"0 0 0\"\n"
26631 " name=\"Origin\"\n"
26632 " number_of_elements=\"3\">\n"
26633 " <DoubleRangeDomain name=\"range\" />\n"
26634 " </DoubleVectorProperty>\n"
26635 " <IntVectorProperty command=\"SetPickable\"\n"
26636 " default_values=\"1\"\n"
26637 " name=\"Pickable\"\n"
26638 " number_of_elements=\"1\">\n"
26639 " <BooleanDomain name=\"bool\" />\n"
26640 " </IntVectorProperty>\n"
26641 " <IntVectorProperty command=\"SetInterpolationType\"\n"
26642 " default_values=\"2\"\n"
26643 " name=\"InterpolationType\"\n"
26644 " number_of_elements=\"1\">\n"
26645 " <EnumerationDomain name=\"enum\">\n"
26646 " <Entry text=\"Nearest\"\n"
26647 " value=\"0\" />\n"
26648 " <Entry text=\"Linear\"\n"
26649 " value=\"1\" />\n"
26650 " <Entry text=\"Cubic\"\n"
26651 " value=\"2\" />\n"
26652 " </EnumerationDomain>\n"
26653 " </IntVectorProperty>\n"
26654 " <ProxyProperty command=\"SetColor\"\n"
26655 " name=\"LookupTable\" >\n"
26656 " <ProxyGroupDomain name=\"groups\">\n"
26657 " <Group name=\"transfer_functions\" />\n"
26658 " </ProxyGroupDomain>\n"
26659 " </ProxyProperty>\n"
26660 " <DoubleVectorProperty command=\"SetAmbient\"\n"
26661 " default_values=\"0.0\"\n"
26662 " name=\"Ambient\"\n"
26663 " number_of_elements=\"1\">\n"
26664 " <DoubleRangeDomain max=\"1\"\n"
26665 " min=\"0\"\n"
26666 " name=\"range\" />\n"
26667 " </DoubleVectorProperty>\n"
26668 " <DoubleVectorProperty command=\"SetDiffuse\"\n"
26669 " default_values=\"1.0\"\n"
26670 " name=\"Diffuse\"\n"
26671 " number_of_elements=\"1\">\n"
26672 " <DoubleRangeDomain max=\"1\"\n"
26673 " min=\"0\"\n"
26674 " name=\"range\" />\n"
26675 " </DoubleVectorProperty>\n"
26676 " <DoubleVectorProperty command=\"SetSpecular\"\n"
26677 " default_values=\"0.0\"\n"
26678 " name=\"Specular\"\n"
26679 " number_of_elements=\"1\">\n"
26680 " <DoubleRangeDomain max=\"1\"\n"
26681 " min=\"0\"\n"
26682 " name=\"range\" />\n"
26683 " </DoubleVectorProperty>\n"
26684 " <DoubleVectorProperty command=\"SetSpecularPower\"\n"
26685 " default_values=\"100.0\"\n"
26686 " name=\"SpecularPower\"\n"
26687 " number_of_elements=\"1\">\n"
26688 " <DoubleRangeDomain max=\"100\"\n"
26689 " min=\"0\"\n"
26690 " name=\"range\" />\n"
26691 " </DoubleVectorProperty>\n"
26692 " <IntVectorProperty command=\"SetShade\"\n"
26693 " default_values=\"0\"\n"
26694 " name=\"Shade\"\n"
26695 " number_of_elements=\"1\">\n"
26696 " <BooleanDomain name=\"bool\" />\n"
26697 " <Documentation>Enable/Disable shading.</Documentation>\n"
26698 " </IntVectorProperty>\n"
26699 " <IntVectorProperty command=\"SetNumberOfSamples\"\n"
26700 " default_values=\"64 128 64\"\n"
26701 " name=\"NumberOfSamples\"\n"
26702 " number_of_elements=\"3\">\n"
26703 " <Documentation>\n"
26704 " Set the number of samples used to create an uniform grid\n"
26705 " from the AMR.\n"
26706 " </Documentation>\n"
26707 " <IntRangeDomain name=\"range\" />\n"
26708 " </IntVectorProperty>\n"
26709 " <ProxyProperty command=\"SetScalarOpacity\"\n"
26710 " name=\"ScalarOpacityFunction\" >\n"
26711 " <ProxyGroupDomain name=\"groups\">\n"
26712 " <Group name=\"piecewise_functions\" />\n"
26713 " </ProxyGroupDomain>\n"
26714 " </ProxyProperty>\n"
26715 " <IntVectorProperty command=\"SetRequestedRenderMode\"\n"
26716 " default_values=\"0\"\n"
26717 " name=\"VolumeRenderingMode\"\n"
26718 " number_of_elements=\"1\">\n"
26719 " <EnumerationDomain name=\"enum\">\n"
26720 " <Entry text=\"Smart\"\n"
26721 " value=\"0\" />\n"
26722 " <Entry text=\"Ray Cast Only\"\n"
26723 " value=\"2\" />\n"
26724 " <Entry text=\"GPU Based\"\n"
26725 " value=\"4\" />\n"
26726 " </EnumerationDomain>\n"
26727 " </IntVectorProperty>\n"
26728 "\n"
26729 " <IntVectorProperty command=\"SetResamplingMode\"\n"
26730 " default_values=\"0\"\n"
26731 " name=\"ResamplingMode\"\n"
26732 " number_of_elements=\"1\"\n"
26733 " panel_visibility=\"default\" >\n"
26734 " <EnumerationDomain name=\"enum\">\n"
26735 " <Entry text=\"Over Data Bounds\" value=\"0\" />\n"
26736 " <Entry text=\"Using View Frustum\" value=\"1\" />\n"
26737 " </EnumerationDomain>\n"
26738 " </IntVectorProperty>\n"
26739 "\n"
26740 " <IntVectorProperty command=\"SetStreamingRequestSize\"\n"
26741 " default_values=\"10\"\n"
26742 " name=\"StreamingRequestSize\"\n"
26743 " number_of_elements=\"1\"\n"
26744 " panel_visibility=\"default\">\n"
26745 " <IntRangeDomain name=\"range\" min=\"1\" max=\"10000\" />\n"
26746 " <Documentation>\n"
26747 " Set the number of blocks to request at a given time on a single\n"
26748 " process when streaming.\n"
26749 " </Documentation>\n"
26750 " </IntVectorProperty>\n"
26751 "\n"
26752 " <DoubleVectorProperty command=\"SetScalarOpacityUnitDistance\"\n"
26753 " default_values=\"1\"\n"
26754 " name=\"ScalarOpacityUnitDistance\"\n"
26755 " number_of_elements=\"1\">\n"
26756 " <BoundsDomain mode=\"approximate_cell_length\"\n"
26757 " name=\"bounds\" >\n"
26758 " <RequiredProperties>\n"
26759 " <Property function=\"Input\"\n"
26760 " name=\"Input\" />\n"
26761 " </RequiredProperties>\n"
26762 " </BoundsDomain>\n"
26763 " </DoubleVectorProperty>\n"
26764 " <!-- end of AMRVolumeRepresentation -->\n"
26765 " </RepresentationProxy>\n"
26766 "\n"
26767 " <!-- ================================================================== -->\n"
26768 " <RepresentationProxy class=\"vtkGeometryRepresentation\"\n"
26769 " name=\"SurfaceRepresentationBase\"\n"
26770 " processes=\"client|renderserver|dataserver\">\n"
26771 " <Documentation>Representation to show any dataset in a 3D render\n"
26772 " view.</Documentation>\n"
26773 "\n"
26774 " <IntVectorProperty command=\"SetPlaceHolderDataType\"\n"
26775 " default_values=\"38\"\n"
26776 " name=\"PlaceHolderDataType\"\n"
26777 " panel_visibility=\"never\"\n"
26778 " number_of_elements=\"1\">\n"
26779 " <DataTypeQueryDomain name=\"data_type_query\">\n"
26780 " <RequiredProperties>\n"
26781 " <Property function=\"Input\"\n"
26782 " name=\"Input\"/>\n"
26783 " </RequiredProperties>\n"
26784 " </DataTypeQueryDomain>\n"
26785 " <Documentation>\n"
26786 " Property to set the placeholder data type.\n"
26787 " </Documentation>\n"
26788 " </IntVectorProperty>\n"
26789 "\n"
26790 " <IntVectorProperty command=\"SetVisibility\"\n"
26791 " default_values=\"1\"\n"
26792 " name=\"Visibility\"\n"
26793 " number_of_elements=\"1\">\n"
26794 " <BooleanDomain name=\"bool\" />\n"
26795 " <Documentation>Get/Set the visibility of the\n"
26796 " representation.</Documentation>\n"
26797 " </IntVectorProperty>\n"
26798 " <IntVectorProperty command=\"SetForceUseCache\"\n"
26799 " default_values=\"0\"\n"
26800 " is_internal=\"1\"\n"
26801 " name=\"ForceUseCache\"\n"
26802 " number_of_elements=\"1\">\n"
26803 " <BooleanDomain name=\"bool\" />\n"
26804 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
26805 " and representations cache based on what the view tells it. However in\n"
26806 " some cases we may want to force a representation to cache irrespective\n"
26807 " of the view (e.g. comparative views). In which case these ivars can up\n"
26808 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
26809 " Instead, ForcedCacheKey is used.</Documentation>\n"
26810 " </IntVectorProperty>\n"
26811 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
26812 " default_values=\"none\"\n"
26813 " is_internal=\"1\"\n"
26814 " name=\"ForcedCacheKey\"\n"
26815 " number_of_elements=\"1\">\n"
26816 " <DoubleRangeDomain name=\"range\" />\n"
26817 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
26818 " and representations cache based on what the view tells it. However in\n"
26819 " some cases we may want to force a representation to cache irrespective\n"
26820 " of the view (e.g. comparative views). In which case these ivars can up\n"
26821 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
26822 " Instead, ForcedCacheKey is used.</Documentation>\n"
26823 " </DoubleVectorProperty>\n"
26824 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
26825 " element_types=\"0 0 0 0 2\"\n"
26826 " name=\"ColorArrayName\"\n"
26827 " no_custom_default=\"1\"\n"
26828 " number_of_elements=\"5\">\n"
26829 " <Documentation>\n"
26830 " Set the array to color with. One must specify the field association and\n"
26831 " the array name of the array. If the array is missing, scalar coloring will\n"
26832 " automatically be disabled.\n"
26833 " </Documentation>\n"
26834 " <RepresentedArrayListDomain name=\"array_list\"\n"
26835 " input_domain_name=\"input_array_any\">\n"
26836 " <RequiredProperties>\n"
26837 " <Property function=\"Input\" name=\"Input\" />\n"
26838 " </RequiredProperties>\n"
26839 " </RepresentedArrayListDomain>\n"
26840 " </StringVectorProperty>\n"
26841 " <IntVectorProperty command=\"SetColorMissingArraysWithNanColor\"\n"
26842 ;
26843
26844 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
26846 " default_values=\"0\"\n"
26847 " name=\"UseNanColorForMissingArrays\"\n"
26848 " number_of_elements=\"1\">\n"
26849 " <BooleanDomain name=\"bool\" />\n"
26850 " <Documentation>If any leaves of a composite dataset are missing the\n"
26851 " color array (that is, the composite dataset has a partial array),\n"
26852 " the datasets with missing data will be colored using the NaN value\n"
26853 " set in the color table. Otherwise, the specified Ambient and\n"
26854 " Diffuse colors will be used.\n"
26855 " </Documentation>\n"
26856 " </IntVectorProperty>\n"
26857 " <StringVectorProperty command=\"SetRepresentation\"\n"
26858 " default_values=\"Surface\"\n"
26859 " name=\"Representation\"\n"
26860 " panel_widget=\"display_representation_selector\"\n"
26861 " number_of_elements=\"1\">\n"
26862 " <StringListDomain name=\"string_list\">\n"
26863 " <String value=\"Points\" />\n"
26864 " <String value=\"Wireframe\" />\n"
26865 " <String value=\"Surface\" />\n"
26866 " <String value=\"Surface With Edges\" />\n"
26867 " </StringListDomain>\n"
26868 " </StringVectorProperty>\n"
26869 " <IntVectorProperty command=\"SetCoordinateShiftScaleMethod\"\n"
26870 " default_values=\"2\"\n"
26871 " name=\"CoordinateShiftScaleMethod\"\n"
26872 " number_of_elements=\"1\">\n"
26873 " <Documentation>Options for normalizing the point coordinates.\n"
26874 " The points are sent to the GPU as float data which can result in resolution issues\n"
26875 " due to the limited precision of float. VTK includes a variety of methods to normalize\n"
26876 " the point coordinates prior to sending them to the GPU. Auto shift scale is a good\n"
26877 " setting that should work for most datasets. Focal point shift scale works based\n"
26878 " on the current camera viewpoint which makes it the most robust setting but it\n"
26879 " will renormalize the data occasionally as the camera's settings change which\n"
26880 " requires reuploading the data to the GPU so there may be a performance cost.\n"
26881 " </Documentation>\n"
26882 " <EnumerationDomain name=\"enum\">\n"
26883 " <Entry text=\"Disable\"\n"
26884 " value=\"0\" />\n"
26885 " <Entry text=\"Auto Shift Scale\"\n"
26886 " value=\"1\" />\n"
26887 " <Entry text=\"Always Auto Shift Scale\"\n"
26888 " value=\"2\" />\n"
26889 " <Entry text=\"Auto Shift Only\"\n"
26890 " value=\"4\" />\n"
26891 " <Entry text=\"Near Focal Plane Shift Scale\"\n"
26892 " value=\"5\" />\n"
26893 " <Entry text=\"Focal Point Shift Scale\"\n"
26894 " value=\"6\" />\n"
26895 " </EnumerationDomain>\n"
26896 " </IntVectorProperty>\n"
26897 " <StringVectorProperty command=\"SetTCoordArray\"\n"
26898 " default_values=\"\"\n"
26899 " label=\"Texture Coordinates\"\n"
26900 " name=\"SelectTCoordArray\"\n"
26901 " number_of_elements=\"1\">\n"
26902 " <Documentation>\n"
26903 " Set the texture coordinates array used for texture mapping.\n"
26904 " </Documentation>\n"
26905 " <RepresentedArrayListDomain attribute_type=\"TCoords\"\n"
26906 " input_domain_name=\"input_array_point_2\"\n"
26907 " data_type=\"VTK_FLOAT VTK_DOUBLE\"\n"
26908 " name=\"array_list\"\n"
26909 " none_string=\"None\">\n"
26910 " <RequiredProperties>\n"
26911 " <Property function=\"Input\"\n"
26912 " name=\"Input\" />\n"
26913 " </RequiredProperties>\n"
26914 " </RepresentedArrayListDomain>\n"
26915 " </StringVectorProperty>\n"
26916 " <StringVectorProperty command=\"SetNormalArray\"\n"
26917 " default_values=\"\"\n"
26918 " label=\"Normal Array\"\n"
26919 " name=\"SelectNormalArray\"\n"
26920 " number_of_elements=\"1\">\n"
26921 " <Documentation>\n"
26922 " Set the normal array used for smooth shading.\n"
26923 " </Documentation>\n"
26924 " <RepresentedArrayListDomain attribute_type=\"Normals\"\n"
26925 " input_domain_name=\"input_array_point_3\"\n"
26926 " data_type=\"VTK_FLOAT VTK_DOUBLE\"\n"
26927 " name=\"array_list\"\n"
26928 " none_string=\"None\">\n"
26929 " <RequiredProperties>\n"
26930 " <Property function=\"Input\"\n"
26931 " name=\"Input\" />\n"
26932 " </RequiredProperties>\n"
26933 " </RepresentedArrayListDomain>\n"
26934 " </StringVectorProperty>\n"
26935 " <StringVectorProperty command=\"SetTangentArray\"\n"
26936 " default_values=\"\"\n"
26937 " label=\"Tangent Array\"\n"
26938 " name=\"SelectTangentArray\"\n"
26939 " number_of_elements=\"1\">\n"
26940 " <Documentation>\n"
26941 " Set the tangent coordinates array used for normal mapping.\n"
26942 " </Documentation>\n"
26943 " <RepresentedArrayListDomain attribute_type=\"Tangents\"\n"
26944 " input_domain_name=\"input_array_point_3\"\n"
26945 " data_type=\"VTK_FLOAT VTK_DOUBLE\"\n"
26946 " name=\"array_list\"\n"
26947 " none_string=\"None\">\n"
26948 " <RequiredProperties>\n"
26949 " <Property function=\"Input\"\n"
26950 " name=\"Input\" />\n"
26951 " </RequiredProperties>\n"
26952 " </RepresentedArrayListDomain>\n"
26953 " </StringVectorProperty>\n"
26954 " <IntVectorProperty command=\"SetDisableLighting\"\n"
26955 " default_values=\"0\"\n"
26956 " name=\"DisableLighting\"\n"
26957 " number_of_elements=\"1\">\n"
26958 " <Documentation>\n"
26959 " Disables the render view lighting interactions on this object.\n"
26960 " It only shows the diffuse lighting component of the object.\n"
26961 " </Documentation>\n"
26962 " <BooleanDomain name=\"bool\" />\n"
26963 " </IntVectorProperty>\n"
26964 " <DoubleVectorProperty command=\"SetAmbient\"\n"
26965 " default_values=\"0.0\"\n"
26966 " name=\"Ambient\"\n"
26967 " number_of_elements=\"1\">\n"
26968 " <DoubleRangeDomain max=\"1\"\n"
26969 " min=\"0\"\n"
26970 " name=\"range\" />\n"
26971 " <Hints>\n"
26972 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
26973 " mode=\"visibility\"\n"
26974 " property=\"Interpolation\"\n"
26975 " value=\"3\"\n"
26976 " inverse=\"1\" />\n"
26977 " </Hints>\n"
26978 " </DoubleVectorProperty>\n"
26979 " <DoubleVectorProperty command=\"SetDiffuse\"\n"
26980 " default_values=\"1.0\"\n"
26981 " name=\"Diffuse\"\n"
26982 " number_of_elements=\"1\">\n"
26983 " <DoubleRangeDomain max=\"1\"\n"
26984 " min=\"0\"\n"
26985 " name=\"range\" />\n"
26986 " </DoubleVectorProperty>\n"
26987 " <DoubleVectorProperty command=\"SetSpecular\"\n"
26988 " default_values=\"0.0\"\n"
26989 " name=\"Specular\"\n"
26990 " number_of_elements=\"1\">\n"
26991 " <DoubleRangeDomain max=\"1\"\n"
26992 " min=\"0\"\n"
26993 " name=\"range\" />\n"
26994 " <Hints>\n"
26995 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
26996 " mode=\"visibility\"\n"
26997 " property=\"Interpolation\"\n"
26998 " value=\"3\"\n"
26999 " inverse=\"1\" />\n"
27000 " </Hints>\n"
27001 " </DoubleVectorProperty>\n"
27002 " <DoubleVectorProperty command=\"SetRoughness\"\n"
27003 " default_values=\"0.3\"\n"
27004 " name=\"Roughness\"\n"
27005 " number_of_elements=\"1\">\n"
27006 " <Documentation>\n"
27007 " Set how rough is the surface.\n"
27008 " </Documentation>\n"
27009 " <DoubleRangeDomain max=\"1\"\n"
27010 " min=\"0\"\n"
27011 " name=\"range\" />\n"
27012 " <Hints>\n"
27013 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27014 " mode=\"visibility\"\n"
27015 " property=\"Interpolation\"\n"
27016 " value=\"3\" />\n"
27017 " </Hints>\n"
27018 " </DoubleVectorProperty>\n"
27019 " <DoubleVectorProperty command=\"SetMetallic\"\n"
27020 " default_values=\"0.0\"\n"
27021 " name=\"Metallic\"\n"
27022 " number_of_elements=\"1\">\n"
27023 " <Documentation>\n"
27024 " Set metalness of the surface. It is usually either 0 or 1 but any value is valid.\n"
27025 " </Documentation>\n"
27026 " <DoubleRangeDomain max=\"1\"\n"
27027 " min=\"0\"\n"
27028 " name=\"range\" />\n"
27029 " <Hints>\n"
27030 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27031 " mode=\"visibility\"\n"
27032 " property=\"Interpolation\"\n"
27033 " value=\"3\" />\n"
27034 " </Hints>\n"
27035 " </DoubleVectorProperty>\n"
27036 " <DoubleVectorProperty command=\"SetEdgeTint\"\n"
27037 " default_values=\"1.0 1.0 1.0\"\n"
27038 " name=\"EdgeTint\"\n"
27039 " number_of_elements=\"3\">\n"
27040 " <Documentation>\n"
27041 " For metals only. Set the tint at grazing angles.\n"
27042 " </Documentation>\n"
27043 " <DoubleRangeDomain max=\"1 1 1\"\n"
27044 " min=\"0 0 0\"\n"
27045 " name=\"range\" />\n"
27046 " <Hints>\n"
27047 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27048 " mode=\"visibility\"\n"
27049 " property=\"Interpolation\"\n"
27050 " value=\"3\" />\n"
27051 " </Hints>\n"
27052 " </DoubleVectorProperty>\n"
27053 " <DoubleVectorProperty command=\"SetBaseIOR\"\n"
27054 " default_values=\"1.5\"\n"
27055 " name=\"BaseIOR\"\n"
27056 " number_of_elements=\"1\">\n"
27057 " <Documentation>\n"
27058 " Set the index of refraction of the base layer.\n"
27059 " </Documentation>\n"
27060 " <DoubleRangeDomain max=\"4\"\n"
27061 " min=\"1\"\n"
27062 " name=\"range\" />\n"
27063 " <Hints>\n"
27064 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27065 " mode=\"visibility\"\n"
27066 " property=\"Interpolation\"\n"
27067 " value=\"3\" />\n"
27068 " </Hints>\n"
27069 " </DoubleVectorProperty>\n"
27070 " <DoubleVectorProperty command=\"SetCoatIOR\"\n"
27071 " default_values=\"2.0\"\n"
27072 " name=\"CoatIOR\"\n"
27073 " number_of_elements=\"1\">\n"
27074 " <Documentation>\n"
27075 " Set the index of refraction of the coat layer.\n"
27076 " </Documentation>\n"
27077 " <DoubleRangeDomain max=\"4\"\n"
27078 " min=\"1\"\n"
27079 " name=\"range\" />\n"
27080 " <Hints>\n"
27081 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27082 " mode=\"visibility\"\n"
27083 " property=\"Interpolation\"\n"
27084 " value=\"3\" />\n"
27085 " </Hints>\n"
27086 " </DoubleVectorProperty>\n"
27087 " <DoubleVectorProperty command=\"SetCoatStrength\"\n"
27088 " default_values=\"0.0\"\n"
27089 " name=\"CoatStrength\"\n"
27090 " number_of_elements=\"1\">\n"
27091 " <Documentation>\n"
27092 " Set the strength of the coat layer.\n"
27093 " </Documentation>\n"
27094 " <DoubleRangeDomain max=\"1\"\n"
27095 " min=\"0\"\n"
27096 " name=\"range\" />\n"
27097 " <Hints>\n"
27098 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27099 " mode=\"visibility\"\n"
27100 " property=\"Interpolation\"\n"
27101 " value=\"3\" />\n"
27102 " </Hints>\n"
27103 " </DoubleVectorProperty>\n"
27104 " <DoubleVectorProperty command=\"SetCoatRoughness\"\n"
27105 " default_values=\"0.0\"\n"
27106 " name=\"CoatRoughness\"\n"
27107 " number_of_elements=\"1\">\n"
27108 " <Documentation>\n"
27109 " Set the roughness of the coat layer.\n"
27110 " </Documentation>\n"
27111 " <DoubleRangeDomain max=\"1\"\n"
27112 " min=\"0\"\n"
27113 " name=\"range\" />\n"
27114 " <Hints>\n"
27115 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27116 " mode=\"visibility\"\n"
27117 " property=\"Interpolation\"\n"
27118 " value=\"3\" />\n"
27119 " </Hints>\n"
27120 " </DoubleVectorProperty>\n"
27121 "\n"
27122 " <DoubleVectorProperty command=\"SetCoatColor\"\n"
27123 " default_values=\"1.0 1.0 1.0\"\n"
27124 " name=\"CoatColor\"\n"
27125 " number_of_elements=\"3\">\n"
27126 " <DoubleRangeDomain max=\"1 1 1\"\n"
27127 " min=\"0 0 0\"\n"
27128 " name=\"range\" />\n"
27129 " <Hints>\n"
27130 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27131 " mode=\"visibility\"\n"
27132 " property=\"Interpolation\"\n"
27133 " value=\"3\" />\n"
27134 " </Hints>\n"
27135 " </DoubleVectorProperty>\n"
27136 " <DoubleVectorProperty command=\"SetAnisotropy\"\n"
27137 " default_values=\"0.0\"\n"
27138 " name=\"Anisotropy\"\n"
27139 " number_of_elements=\"1\">\n"
27140 " <Documentation>\n"
27141 " Set the anisotropy coefficient of the surface.\n"
27142 " </Documentation>\n"
27143 " <DoubleRangeDomain max=\"1\"\n"
27144 " min=\"0\"\n"
27145 " name=\"range\" />\n"
27146 " <Hints>\n"
27147 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27148 " mode=\"visibility\"\n"
27149 " property=\"Interpolation\"\n"
27150 " value=\"3\" />\n"
27151 " <!-- Enable widget only if normals and tangents are here -->\n"
27152 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SelectNormalArray\" value=\"None\" inverse=\"1\"/>\n"
27153 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SelectTangentArray\" value=\"None\" inverse=\"1\"/>\n"
27154 " </Hints>\n"
27155 " </DoubleVectorProperty>\n"
27156 " <DoubleVectorProperty command=\"SetAnisotropyRotation\"\n"
27157 " default_values=\"0.0\"\n"
27158 " name=\"AnisotropyRotation\"\n"
27159 " number_of_elements=\"1\">\n"
27160 " <Documentation>\n"
27161 " Set the anisotropy rotation coefficient of the surface.\n"
27162 " </Documentation>\n"
27163 " <DoubleRangeDomain max=\"1\"\n"
27164 " min=\"0\"\n"
27165 " name=\"range\" />\n"
27166 " <Hints>\n"
27167 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27168 ;
27169
27170 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
27172 " mode=\"visibility\"\n"
27173 " property=\"Interpolation\"\n"
27174 " value=\"3\" />\n"
27175 " <!-- Enable widget only if normals and tangents are here -->\n"
27176 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SelectNormalArray\" value=\"None\" inverse=\"1\"/>\n"
27177 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SelectTangentArray\" value=\"None\" inverse=\"1\"/>\n"
27178 " </Hints>\n"
27179 " </DoubleVectorProperty>\n"
27180 " <ProxyProperty command=\"SetTexture\"\n"
27181 " name=\"Texture\"\n"
27182 " panel_widget=\"texture_selector\"\n"
27183 " null_on_empty=\"1\" >\n"
27184 " <Documentation>\n"
27185 " Set the diffuse color texture.\n"
27186 " </Documentation>\n"
27187 " <ProxyGroupDomain name=\"groups\">\n"
27188 " <Group name=\"textures\" />\n"
27189 " </ProxyGroupDomain>\n"
27190 " <Hints>\n"
27191 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27192 " mode=\"visibility\"\n"
27193 " property=\"Interpolation\"\n"
27194 " value=\"3\"\n"
27195 " inverse=\"1\" />\n"
27196 " <TextureSelectorWidget check_tcoords=\"1\" />\n"
27197 " <!-- enable the texture selector only when tcoords is available. -->\n"
27198 " </Hints>\n"
27199 " <Documentation>\n"
27200 " This property allows you to specify the texture to apply to the surface.\n"
27201 " </Documentation>\n"
27202 " </ProxyProperty>\n"
27203 " <IntVectorProperty command=\"SetRepeatTextures\"\n"
27204 " default_values=\"1\"\n"
27205 " name=\"RepeatTextures\"\n"
27206 " number_of_elements=\"1\">\n"
27207 " <BooleanDomain name=\"bool\" />\n"
27208 " <Documentation>\n"
27209 " Should textures be clamped or repeated when texture coordinates go\n"
27210 " outside the range of 0 to 1.\n"
27211 " </Documentation>\n"
27212 " </IntVectorProperty>\n"
27213 " <IntVectorProperty command=\"SetInterpolateTextures\"\n"
27214 " default_values=\"0\"\n"
27215 " name=\"InterpolateTextures\"\n"
27216 " number_of_elements=\"1\">\n"
27217 " <BooleanDomain name=\"bool\" />\n"
27218 " <Documentation>\n"
27219 " When sampling a texture should linear interpolations be used. If false\n"
27220 " then nearest neighbor sampling will be used.\n"
27221 " </Documentation>\n"
27222 " </IntVectorProperty>\n"
27223 " <IntVectorProperty command=\"SetUseMipmapTextures\"\n"
27224 " default_values=\"0\"\n"
27225 " name=\"UseMipmapTextures\"\n"
27226 " number_of_elements=\"1\">\n"
27227 " <BooleanDomain name=\"bool\" />\n"
27228 " <Documentation>\n"
27229 " Should mipmaps be used for textures. Mipmaps are espcially useful when\n"
27230 " working with large detailed textures or situations where you might be\n"
27231 " viewing a texture map from far away.\n"
27232 " </Documentation>\n"
27233 " <Hints>\n"
27234 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27235 " mode=\"visibility\"\n"
27236 " property=\"InterpolateTextures\"\n"
27237 " value=\"1\" />\n"
27238 " </Hints>\n"
27239 " </IntVectorProperty>\n"
27240 " <IntVectorProperty command=\"SetShowTexturesOnBackface\"\n"
27241 " default_values=\"1\"\n"
27242 " name=\"ShowTexturesOnBackface\"\n"
27243 " number_of_elements=\"1\">\n"
27244 " <BooleanDomain name=\"bool\" />\n"
27245 " <Documentation>\n"
27246 " Should textures be applied to the backface of a surface.\n"
27247 " </Documentation>\n"
27248 " </IntVectorProperty>\n"
27249 " <ProxyProperty command=\"SetBaseColorTexture\"\n"
27250 " name=\"BaseColorTexture\"\n"
27251 " panel_widget=\"texture_selector\"\n"
27252 " null_on_empty=\"1\" >\n"
27253 " <Documentation>\n"
27254 " Set the base color (also called albedo) texture. It will define the diffuse color for a\n"
27255 " non metallic surface or the specular color for a metallic surface.\n"
27256 " </Documentation>\n"
27257 " <ProxyGroupDomain name=\"groups\">\n"
27258 " <Group name=\"textures\" />\n"
27259 " </ProxyGroupDomain>\n"
27260 " <Hints>\n"
27261 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27262 " mode=\"visibility\"\n"
27263 " property=\"Interpolation\"\n"
27264 " value=\"3\" />\n"
27265 " <TextureSelectorWidget check_tcoords=\"1\" />\n"
27266 " <!-- enable the texture selector only when tcoords is available. -->\n"
27267 " </Hints>\n"
27268 " </ProxyProperty>\n"
27269 " <ProxyProperty command=\"SetMaterialTexture\"\n"
27270 " name=\"MaterialTexture\"\n"
27271 " panel_widget=\"texture_selector\"\n"
27272 " null_on_empty=\"1\" >\n"
27273 " <Documentation>\n"
27274 " Set the material texture. This texture encodes occlusion, roughness and metalness\n"
27275 " on the red, green, blue channel respectively.\n"
27276 " </Documentation>\n"
27277 " <ProxyGroupDomain name=\"groups\">\n"
27278 " <Group name=\"textures\" />\n"
27279 " </ProxyGroupDomain>\n"
27280 " <Hints>\n"
27281 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27282 " mode=\"visibility\"\n"
27283 " property=\"Interpolation\"\n"
27284 " value=\"3\" />\n"
27285 " <TextureSelectorWidget check_tcoords=\"1\" />\n"
27286 " <!-- enable the texture selector only when tcoords is available. -->\n"
27287 " </Hints>\n"
27288 " </ProxyProperty>\n"
27289 " <ProxyProperty command=\"SetAnisotropyTexture\"\n"
27290 " name=\"AnisotropyTexture\"\n"
27291 " panel_widget=\"texture_selector\"\n"
27292 " null_on_empty=\"1\" >\n"
27293 " <Documentation>\n"
27294 " Set the anisotropy texture. This texture encodes anisotropy strength on the red and anisotropy rotation\n"
27295 " on the green channel.\n"
27296 " </Documentation>\n"
27297 " <ProxyGroupDomain name=\"groups\">\n"
27298 " <Group name=\"textures\" />\n"
27299 " </ProxyGroupDomain>\n"
27300 " <Hints>\n"
27301 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27302 " mode=\"visibility\"\n"
27303 " property=\"Interpolation\"\n"
27304 " value=\"3\" />\n"
27305 " <TextureSelectorWidget check_tcoords=\"1\" check_tangents=\"1\" />\n"
27306 " <!-- enable the texture selector only when tcoords and tangents are available. -->\n"
27307 " </Hints>\n"
27308 " </ProxyProperty>\n"
27309 " <DoubleVectorProperty command=\"SetOcclusionStrength\"\n"
27310 " default_values=\"1.0\"\n"
27311 " name=\"OcclusionStrength\"\n"
27312 " number_of_elements=\"1\">\n"
27313 " <Documentation>\n"
27314 " Set the ambient occlusion strength of the material texture.\n"
27315 " </Documentation>\n"
27316 " <DoubleRangeDomain max=\"5\"\n"
27317 " min=\"0\"\n"
27318 " name=\"range\" />\n"
27319 " <Hints>\n"
27320 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27321 " mode=\"visibility\"\n"
27322 " property=\"MaterialTexture\"\n"
27323 " value=\"null\"\n"
27324 " inverse=\"1\" />\n"
27325 " </Hints>\n"
27326 " </DoubleVectorProperty>\n"
27327 " <ProxyProperty command=\"SetNormalTexture\"\n"
27328 " name=\"NormalTexture\"\n"
27329 " panel_widget=\"texture_selector\"\n"
27330 " null_on_empty=\"1\" >\n"
27331 " <Documentation>\n"
27332 " Set the normal mapping texture.\n"
27333 " </Documentation>\n"
27334 " <ProxyGroupDomain name=\"groups\">\n"
27335 " <Group name=\"textures\" />\n"
27336 " </ProxyGroupDomain>\n"
27337 " <Hints>\n"
27338 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27339 " mode=\"visibility\"\n"
27340 " property=\"Interpolation\"\n"
27341 " value=\"0\"\n"
27342 " inverse=\"1\" />\n"
27343 " <TextureSelectorWidget check_tcoords=\"1\" check_tangents=\"1\" />\n"
27344 " <!-- enable the texture selector only when tcoords is available. -->\n"
27345 " </Hints>\n"
27346 " </ProxyProperty>\n"
27347 " <DoubleVectorProperty command=\"SetNormalScale\"\n"
27348 " default_values=\"1.0\"\n"
27349 " name=\"NormalScale\"\n"
27350 " number_of_elements=\"1\">\n"
27351 " <Documentation>\n"
27352 " Set the scale of normal mapping deviation.\n"
27353 " </Documentation>\n"
27354 " <DoubleRangeDomain max=\"5\"\n"
27355 " min=\"0\"\n"
27356 " name=\"range\" />\n"
27357 " <Hints>\n"
27358 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27359 " mode=\"visibility\"\n"
27360 " property=\"NormalTexture\"\n"
27361 " value=\"null\"\n"
27362 " inverse=\"1\" />\n"
27363 " </Hints>\n"
27364 " </DoubleVectorProperty>\n"
27365 " <ProxyProperty command=\"SetCoatNormalTexture\"\n"
27366 " name=\"CoatNormalTexture\"\n"
27367 " panel_widget=\"texture_selector\"\n"
27368 " null_on_empty=\"1\" >\n"
27369 " <Documentation>\n"
27370 " Set the coat normal mapping texture.\n"
27371 " </Documentation>\n"
27372 " <ProxyGroupDomain name=\"groups\">\n"
27373 " <Group name=\"textures\" />\n"
27374 " </ProxyGroupDomain>\n"
27375 " <Hints>\n"
27376 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27377 " mode=\"visibility\"\n"
27378 " property=\"Interpolation\"\n"
27379 " value=\"0\"\n"
27380 " inverse=\"1\" />\n"
27381 " <TextureSelectorWidget check_tcoords=\"1\" check_tangents=\"1\" />\n"
27382 " <!-- enable the texture selector only when tcoords is available. -->\n"
27383 " </Hints>\n"
27384 " </ProxyProperty>\n"
27385 " <DoubleVectorProperty command=\"SetCoatNormalScale\"\n"
27386 " default_values=\"1.0\"\n"
27387 " name=\"CoatNormalScale\"\n"
27388 " number_of_elements=\"1\">\n"
27389 " <Documentation>\n"
27390 " Set the scale of coat normal mapping deviation.\n"
27391 " </Documentation>\n"
27392 " <DoubleRangeDomain max=\"5\"\n"
27393 " min=\"0\"\n"
27394 " name=\"range\" />\n"
27395 " <Hints>\n"
27396 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27397 " mode=\"visibility\"\n"
27398 " property=\"CoatNormalTexture\"\n"
27399 " value=\"null\"\n"
27400 " inverse=\"1\" />\n"
27401 " </Hints>\n"
27402 " </DoubleVectorProperty>\n"
27403 " <ProxyProperty command=\"SetEmissiveTexture\"\n"
27404 " name=\"EmissiveTexture\"\n"
27405 " panel_widget=\"texture_selector\"\n"
27406 " null_on_empty=\"1\" >\n"
27407 " <Documentation>\n"
27408 " Set the emissive texture.\n"
27409 " </Documentation>\n"
27410 " <ProxyGroupDomain name=\"groups\">\n"
27411 " <Group name=\"textures\" />\n"
27412 " </ProxyGroupDomain>\n"
27413 " <Hints>\n"
27414 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27415 " mode=\"visibility\"\n"
27416 " property=\"Interpolation\"\n"
27417 " value=\"3\" />\n"
27418 " <TextureSelectorWidget check_tcoords=\"1\" />\n"
27419 " <!-- enable the texture selector only when tcoords is available. -->\n"
27420 " </Hints>\n"
27421 " </ProxyProperty>\n"
27422 " <DoubleVectorProperty command=\"SetEmissiveFactor\"\n"
27423 " default_values=\"1.0 1.0 1.0\"\n"
27424 " name=\"EmissiveFactor\"\n"
27425 " number_of_elements=\"3\">\n"
27426 " <Documentation>\n"
27427 " Set the factor of the red, green, blue channels of the emissive texture.\n"
27428 " </Documentation>\n"
27429 " <DoubleRangeDomain max=\"10\"\n"
27430 " min=\"0\"\n"
27431 " name=\"range\" />\n"
27432 " <Hints>\n"
27433 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27434 " mode=\"visibility\"\n"
27435 " property=\"EmissiveTexture\"\n"
27436 " value=\"null\"\n"
27437 " inverse=\"1\" />\n"
27438 " </Hints>\n"
27439 " </DoubleVectorProperty>\n"
27440 " <ProxyProperty command=\"SetTextureTransform\"\n"
27441 " name=\"TextureTransform\"\n"
27442 " null_on_empty=\"1\">\n"
27443 " <ProxyGroupDomain name=\"groups\">\n"
27444 " <Group name=\"transforms\"/>\n"
27445 " </ProxyGroupDomain>\n"
27446 " <ProxyListDomain name=\"proxy_list\">\n"
27447 " <Proxy group=\"extended_sources\"\n"
27448 " name=\"Transform2\"/>\n"
27449 " </ProxyListDomain>\n"
27450 " <Hints>\n"
27451 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
27452 " <Expression type=\"or\">\n"
27453 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27454 " mode=\"visibility\"\n"
27455 " property=\"Texture\"\n"
27456 " value=\"null\"\n"
27457 " inverse=\"1\"/>\n"
27458 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27459 " mode=\"visibility\"\n"
27460 " property=\"BaseColorTexture\"\n"
27461 " value=\"null\"\n"
27462 " inverse=\"1\"/>\n"
27463 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27464 " mode=\"visibility\"\n"
27465 " property=\"NormalTexture\"\n"
27466 " value=\"null\"\n"
27467 " inverse=\"1\"/>\n"
27468 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27469 " mode=\"visibility\"\n"
27470 " property=\"CoatNormalTexture\"\n"
27471 " value=\"null\"\n"
27472 " inverse=\"1\"/>\n"
27473 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27474 " mode=\"visibility\"\n"
27475 " property=\"MaterialTexture\"\n"
27476 " value=\"null\"\n"
27477 " inverse=\"1\"/>\n"
27478 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27479 " mode=\"visibility\"\n"
27480 " property=\"AnisotropyTexture\"\n"
27481 " value=\"null\"\n"
27482 " inverse=\"1\"/>\n"
27483 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27484 " mode=\"visibility\"\n"
27485 " property=\"EmissiveTexture\"\n"
27486 ;
27487
27488 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
27490 " value=\"null\"\n"
27491 " inverse=\"1\"/>\n"
27492 " </Expression>\n"
27493 " </PropertyWidgetDecorator>\n"
27494 " </Hints>\n"
27495 " <Documentation>\n"
27496 " Set the texture transform for the textures.\n"
27497 " </Documentation>\n"
27498 " </ProxyProperty>\n"
27499 " <IntVectorProperty command=\"SetSuppressLOD\"\n"
27500 " default_values=\"0\"\n"
27501 " name=\"SuppressLOD\"\n"
27502 " number_of_elements=\"1\">\n"
27503 " <BooleanDomain name=\"bool\" />\n"
27504 " </IntVectorProperty>\n"
27505 " <DoubleVectorProperty command=\"SetAmbientColor\"\n"
27506 " default_values=\"1.0 1.0 1.0\"\n"
27507 " name=\"AmbientColor\"\n"
27508 " number_of_elements=\"3\">\n"
27509 " <DoubleRangeDomain max=\"1 1 1\"\n"
27510 " min=\"0 0 0\"\n"
27511 " name=\"range\" />\n"
27512 " <Hints>\n"
27513 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"ForegroundColor\" unlink_if_modified=\"1\" />\n"
27514 " </Hints>\n"
27515 " </DoubleVectorProperty>\n"
27516 " <DoubleVectorProperty command=\"SetDiffuseColor\"\n"
27517 " default_values=\"1.0 1.0 1.0\"\n"
27518 " name=\"DiffuseColor\"\n"
27519 " number_of_elements=\"3\"\n"
27520 " panel_widget=\"color_selector_with_palette\">\n"
27521 " <DoubleRangeDomain max=\"1 1 1\"\n"
27522 " min=\"0 0 0\"\n"
27523 " name=\"range\" />\n"
27524 " <Hints>\n"
27525 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"SurfaceColor\" unlink_if_modified=\"1\" />\n"
27526 " </Hints>\n"
27527 " </DoubleVectorProperty>\n"
27528 " <DoubleVectorProperty command=\"SetSpecularColor\"\n"
27529 " default_values=\"1.0 1.0 1.0\"\n"
27530 " name=\"SpecularColor\"\n"
27531 " number_of_elements=\"3\">\n"
27532 " <DoubleRangeDomain max=\"1 1 1\"\n"
27533 " min=\"0 0 0\"\n"
27534 " name=\"range\" />\n"
27535 " <Hints>\n"
27536 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27537 " mode=\"visibility\"\n"
27538 " property=\"Interpolation\"\n"
27539 " value=\"3\"\n"
27540 " inverse=\"1\" />\n"
27541 " </Hints>\n"
27542 " </DoubleVectorProperty>\n"
27543 " <DoubleVectorProperty command=\"SetLineWidth\"\n"
27544 " default_values=\"1.0\"\n"
27545 " name=\"LineWidth\"\n"
27546 " number_of_elements=\"1\">\n"
27547 " <DoubleRangeDomain min=\"0\"\n"
27548 " name=\"range\" />\n"
27549 " </DoubleVectorProperty>\n"
27550 " <DoubleVectorProperty command=\"SetPointSize\"\n"
27551 " default_values=\"2.0\"\n"
27552 " name=\"PointSize\"\n"
27553 " number_of_elements=\"1\">\n"
27554 " <DoubleRangeDomain min=\"0\"\n"
27555 " name=\"range\" />\n"
27556 " </DoubleVectorProperty>\n"
27557 " <IntVectorProperty command=\"SetRenderLinesAsTubes\"\n"
27558 " default_values=\"0\"\n"
27559 " name=\"RenderLinesAsTubes\"\n"
27560 " number_of_elements=\"1\"\n"
27561 " panel_visibility=\"never\">\n"
27562 " <BooleanDomain name=\"bool\" />\n"
27563 " <Documentation>\n"
27564 " When set, all lines are rendered as 3D tubes, if supported by OpenGL driver.\n"
27565 " </Documentation>\n"
27566 " </IntVectorProperty>\n"
27567 " <IntVectorProperty command=\"SetRenderPointsAsSpheres\"\n"
27568 " default_values=\"0\"\n"
27569 " name=\"RenderPointsAsSpheres\"\n"
27570 " number_of_elements=\"1\"\n"
27571 " panel_visibility=\"never\">\n"
27572 " <BooleanDomain name=\"bool\" />\n"
27573 " <Documentation>\n"
27574 " When set, all points are rendered as 3D spheres, if supported by OpenGL driver.\n"
27575 " </Documentation>\n"
27576 " </IntVectorProperty>\n"
27577 " <IntVectorProperty command=\"SetInterpolation\"\n"
27578 " default_values=\"1\"\n"
27579 " name=\"Interpolation\"\n"
27580 " number_of_elements=\"1\">\n"
27581 " <EnumerationDomain name=\"enum\">\n"
27582 " <Entry text=\"Flat\"\n"
27583 " value=\"0\" />\n"
27584 " <Entry text=\"Gouraud\"\n"
27585 " value=\"1\" />\n"
27586 " <Entry text=\"PBR\"\n"
27587 " value=\"3\" />\n"
27588 " </EnumerationDomain>\n"
27589 " </IntVectorProperty>\n"
27590 " <IntVectorProperty command=\"SetTriangulate\"\n"
27591 " default_values=\"0\"\n"
27592 " name=\"Triangulate\"\n"
27593 " number_of_elements=\"1\">\n"
27594 " <BooleanDomain name=\"bool\" />\n"
27595 " <Documentation>Triangulate the geometry internally to avoid rendering\n"
27596 " issues of non-convex polygons. This feature has a processing and memory\n"
27597 " cost, it should be enabled only when needed.</Documentation>\n"
27598 " </IntVectorProperty>\n"
27599 " <IntVectorProperty command=\"SetUseShaderReplacements\"\n"
27600 " default_values=\"0\"\n"
27601 " name=\"UseShaderReplacements\"\n"
27602 " number_of_elements=\"1\">\n"
27603 " <BooleanDomain name=\"bool\" />\n"
27604 " <Documentation>Enable the use of shader replacements.</Documentation>\n"
27605 " </IntVectorProperty>\n"
27606 " <StringVectorProperty command=\"SetShaderReplacements\"\n"
27607 " default_values=\"\"\n"
27608 " name=\"ShaderReplacements\"\n"
27609 " number_of_elements=\"1\"\n"
27610 " panel_widget=\"shader_replacements_selector\"\n"
27611 " panel_visibility=\"advanced\">\n"
27612 " <Documentation>\n"
27613 " Specify shader replacements using a Json string.\n"
27614 " The Json string can be a single node or an array of nodes with the\n"
27615 " following properties:&#xa;\n"
27616 " \"type\": specifies the type of shader the replacement is about.\n"
27617 " It can be either \"vertex\", \"fragment\" or \"geometry\".&#xa;\n"
27618 " \"original\": specifies the original string to be replaced in the shader code.\n"
27619 " This string is generally a pattern defined by the mapper\n"
27620 " vtkOpenGLPolyDataMapper at specific locations of the shader\n"
27621 " GLSL source code.&#xa;\n"
27622 " \"replacement\": specifies the replacement string in GLSL source code.\n"
27623 " Note that the Json parser supports multiple lines entries.&#xa;\n"
27624 " Example of a simple shader replacement (draw all the fragments in full red\n"
27625 " color without any shading consideration):&#xa;\n"
27626 " {&#xa;\n"
27627 " \"type\": \"fragment\",&#xa;\n"
27628 " \"original\": \"//VTK::Light::Impl\",&#xa;\n"
27629 " \"replacement\": \"gl_FragData[0]=vec4(1.0,0.0,0.0,1.0);\"&#xa;\n"
27630 " }&#xa;\n"
27631 " </Documentation>\n"
27632 " <Hints>\n"
27633 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27634 " mode=\"visibility\"\n"
27635 " property=\"UseShaderReplacements\"\n"
27636 " value=\"1\" />\n"
27637 " <!-- show this widget when UseShaderReplacements is enabled -->\n"
27638 " </Hints>\n"
27639 " </StringVectorProperty>\n"
27640 " <IntVectorProperty command=\"SetNonlinearSubdivisionLevel\"\n"
27641 " default_values=\"1\"\n"
27642 " name=\"NonlinearSubdivisionLevel\"\n"
27643 " number_of_elements=\"1\">\n"
27644 " <IntRangeDomain max=\"4\"\n"
27645 " min=\"0\"\n"
27646 " name=\"range\" />\n"
27647 " </IntVectorProperty>\n"
27648 " <IntVectorProperty command=\"SetMatchBoundariesIgnoringCellOrder\"\n"
27649 " default_values=\"0\"\n"
27650 " name=\"MatchBoundariesIgnoringCellOrder\"\n"
27651 " number_of_elements=\"1\">\n"
27652 " <BooleanDomain name=\"bool\" />\n"
27653 " <Documentation>\n"
27654 " Only account for cell corners (topology) to detect\n"
27655 " if two adjacent cells are connected.\n"
27656 " </Documentation>\n"
27657 " </IntVectorProperty>\n"
27658 "\n"
27659 " <IntVectorProperty command=\"SetComputePointNormals\"\n"
27660 " default_values=\"0\"\n"
27661 " name=\"ComputePointNormals\"\n"
27662 " number_of_elements=\"1\">\n"
27663 " <BooleanDomain name=\"bool\"/>\n"
27664 " <Documentation>\n"
27665 " When enabled, and point normals are not present, they will be computed.\n"
27666 " </Documentation>\n"
27667 " </IntVectorProperty>\n"
27668 "\n"
27669 " <IntVectorProperty command=\"SetSplitting\"\n"
27670 " default_values=\"1\"\n"
27671 " name=\"Splitting\"\n"
27672 " number_of_elements=\"1\">\n"
27673 " <BooleanDomain name=\"bool\"/>\n"
27674 " <Documentation>\n"
27675 " This property controls the splitting of sharp edges. If\n"
27676 " sharp edges are split (property value = 1), then points are duplicated\n"
27677 " along these edges, and separate normals are computed for both sets of\n"
27678 " points to give crisp (rendered) surface definition.\n"
27679 " </Documentation>\n"
27680 " <Hints>\n"
27681 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27682 " mode=\"enabled_state\"\n"
27683 " property=\"ComputePointNormals\"\n"
27684 " value=\"1\"/>\n"
27685 " <!-- show this widget when ComputePointNormals==1 -->\n"
27686 " </Hints>\n"
27687 " </IntVectorProperty>\n"
27688 "\n"
27689 " <DoubleVectorProperty command=\"SetFeatureAngle\"\n"
27690 " default_values=\"30\"\n"
27691 " name=\"FeatureAngle\"\n"
27692 " number_of_elements=\"1\">\n"
27693 " <DoubleRangeDomain max=\"180\"\n"
27694 " min=\"0\"\n"
27695 " name=\"range\"/>\n"
27696 " <Documentation>\n"
27697 " The value of this property defines a feature edge. If\n"
27698 " the surface normal between two adjacent triangles is at least as large\n"
27699 " as this Feature Angle, a feature edge exists. If Splitting is on,\n"
27700 " points are duplicated along these feature edges. (See the Splitting property.)\n"
27701 " </Documentation>\n"
27702 " <Hints>\n"
27703 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
27704 " <Expression type=\"and\">\n"
27705 " <!-- Show when ComputePointNormals is on -->\n"
27706 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27707 " mode=\"enabled_state\"\n"
27708 " property=\"ComputePointNormals\"\n"
27709 " value=\"1\"/>\n"
27710 " <!-- Show when Splitting is on -->\n"
27711 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27712 " mode=\"enabled_state\"\n"
27713 " property=\"Splitting\"\n"
27714 " value=\"1\"/>\n"
27715 " </Expression>\n"
27716 " </PropertyWidgetDecorator>\n"
27717 " </Hints>\n"
27718 " </DoubleVectorProperty>\n"
27719 "\n"
27720 " <DoubleVectorProperty command=\"SetOpacity\"\n"
27721 " default_values=\"1.0\"\n"
27722 " name=\"Opacity\"\n"
27723 " number_of_elements=\"1\">\n"
27724 " <DoubleRangeDomain max=\"1\"\n"
27725 " min=\"0\"\n"
27726 " name=\"range\" />\n"
27727 " </DoubleVectorProperty>\n"
27728 " <DoubleVectorProperty command=\"SetSpecularPower\"\n"
27729 " default_values=\"100.0\"\n"
27730 " name=\"SpecularPower\"\n"
27731 " number_of_elements=\"1\">\n"
27732 " <DoubleRangeDomain max=\"100\"\n"
27733 " min=\"0\"\n"
27734 " name=\"range\" />\n"
27735 " <Hints>\n"
27736 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27737 " mode=\"visibility\"\n"
27738 " property=\"Interpolation\"\n"
27739 " value=\"3\"\n"
27740 " inverse=\"1\" />\n"
27741 " </Hints>\n"
27742 " </DoubleVectorProperty>\n"
27743 " <DoubleVectorProperty command=\"SetLuminosity\"\n"
27744 " default_values=\"0.0\"\n"
27745 " name=\"Luminosity\"\n"
27746 " number_of_elements=\"1\">\n"
27747 " <DoubleRangeDomain max=\"100.0\"\n"
27748 " min=\"0\"\n"
27749 " name=\"range\" />\n"
27750 " <Documentation>Makes the object emit light.\n"
27751 " Only takes effect with OSPRay's path traced renderer.\n"
27752 " </Documentation>\n"
27753 " <Hints>\n"
27754 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
27755 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27756 " mode=\"visibility\"\n"
27757 " property=\"EnableOSPRay\"\n"
27758 " values=\"1\" />\n"
27759 " </Hints>\n"
27760 " </DoubleVectorProperty>\n"
27761 " <DoubleVectorProperty command=\"SetEdgeColor\"\n"
27762 " default_values=\"0 0 0.5\"\n"
27763 " name=\"EdgeColor\"\n"
27764 " number_of_elements=\"3\">\n"
27765 " <Documentation>Set the edge color. This color is used to draw the edge\n"
27766 " for the polygonal data when EdgeVisibility is on.</Documentation>\n"
27767 " <DoubleRangeDomain max=\"1 1 1\"\n"
27768 " min=\"0 0 0\"\n"
27769 " name=\"range\" />\n"
27770 " <Hints>\n"
27771 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"EdgeColor\" unlink_if_modified=\"1\" />\n"
27772 " </Hints>\n"
27773 " </DoubleVectorProperty>\n"
27774 " <DoubleVectorProperty command=\"SetEdgeOpacity\"\n"
27775 " default_values=\"1.0\"\n"
27776 " name=\"EdgeOpacity\"\n"
27777 " number_of_elements=\"1\">\n"
27778 " <DoubleRangeDomain max=\"1\"\n"
27779 " min=\"0\"\n"
27780 " name=\"range\" />\n"
27781 " </DoubleVectorProperty>\n"
27782 " <DoubleVectorProperty command=\"SetInteractiveSelectionColor\"\n"
27783 " default_values=\"0.5 0.0 1.0\"\n"
27784 " name=\"InteractiveSelectionColor\"\n"
27785 " number_of_elements=\"3\">\n"
27786 " <Documentation>Set the preselection color. This color is used to draw the edge\n"
27787 " of the current preselection.</Documentation>\n"
27788 " <DoubleRangeDomain max=\"1 1 1\"\n"
27789 " min=\"0 0 0\"\n"
27790 " name=\"range\" />\n"
27791 " <Hints>\n"
27792 " <PropertyLink group=\"settings\" proxy=\"ColorPalette\" property=\"InteractiveSelectionColor\" unlink_if_modified=\"1\" />\n"
27793 " </Hints>\n"
27794 " </DoubleVectorProperty>\n"
27795 " <DoubleVectorProperty command=\"SetPosition\"\n"
27796 " default_values=\"0 0 0\"\n"
27797 " label=\"Translation\"\n"
27798 " name=\"Position\"\n"
27799 " number_of_elements=\"3\">\n"
27800 " <DoubleRangeDomain name=\"range\" />\n"
27801 ;
27802
27803 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
27805 " </DoubleVectorProperty>\n"
27806 " <DoubleVectorProperty command=\"SetScale\"\n"
27807 " default_values=\"1 1 1\"\n"
27808 " name=\"Scale\"\n"
27809 " number_of_elements=\"3\">\n"
27810 " <DoubleRangeDomain name=\"range\" />\n"
27811 " </DoubleVectorProperty>\n"
27812 " <DoubleVectorProperty command=\"SetOrientation\"\n"
27813 " default_values=\"0 0 0\"\n"
27814 " name=\"Orientation\"\n"
27815 " number_of_elements=\"3\">\n"
27816 " <DoubleRangeDomain name=\"range\" />\n"
27817 " </DoubleVectorProperty>\n"
27818 " <DoubleVectorProperty command=\"SetOrigin\"\n"
27819 " default_values=\"0 0 0\"\n"
27820 " name=\"Origin\"\n"
27821 " number_of_elements=\"3\">\n"
27822 " <DoubleRangeDomain name=\"range\" />\n"
27823 " </DoubleVectorProperty>\n"
27824 "\n"
27825 " <DoubleVectorProperty argument_is_array=\"1\"\n"
27826 " command=\"SetUserTransform\"\n"
27827 " default_values=\"1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1\"\n"
27828 " name=\"UserTransform\"\n"
27829 " number_of_elements=\"16\">\n"
27830 " <Documentation>\n"
27831 " In addition to the instance variables such as position and\n"
27832 " orientation, you can add an additional transformation for your own\n"
27833 " use. This transformation is concatenated with the actor's internal\n"
27834 " transformation, which you implicitly create through the use of\n"
27835 " Position, Origin, Orientation. The value is 4x4 matrix for the linear\n"
27836 " transform to use.\n"
27837 " </Documentation>\n"
27838 " </DoubleVectorProperty>\n"
27839 "\n"
27840 " <IntVectorProperty command=\"SetPickable\"\n"
27841 " default_values=\"1\"\n"
27842 " name=\"Pickable\"\n"
27843 " number_of_elements=\"1\">\n"
27844 " <Hints>\n"
27845 " <NoDefault />\n"
27846 " </Hints>\n"
27847 " <BooleanDomain name=\"bool\" />\n"
27848 " </IntVectorProperty>\n"
27849 " <ProxyProperty command=\"SetLookupTable\"\n"
27850 " name=\"LookupTable\" >\n"
27851 " <Documentation>Set the lookup-table to use to map data array to colors.\n"
27852 " Lookuptable is only used with MapScalars to ON.</Documentation>\n"
27853 " <ProxyGroupDomain name=\"groups\">\n"
27854 " <Group name=\"lookup_tables\" />\n"
27855 " </ProxyGroupDomain>\n"
27856 " </ProxyProperty>\n"
27857 " <IntVectorProperty default_values=\"0\"\n"
27858 " name=\"UseSeparateColorMap\"\n"
27859 " number_of_elements=\"1\"\n"
27860 " panel_visibility=\"never\">\n"
27861 " <BooleanDomain name=\"bool\" />\n"
27862 " <Documentation>By default, ParaView shares a single color map among all datasets colored\n"
27863 " by arrays that have the same name. When this option is enabled, the active dataset will\n"
27864 " be assigned a separate color map not shared by other datasets.</Documentation>\n"
27865 " </IntVectorProperty>\n"
27866 " <IntVectorProperty command=\"SetMapScalars\"\n"
27867 " default_values=\"1\"\n"
27868 " name=\"MapScalars\"\n"
27869 " number_of_elements=\"1\">\n"
27870 " <BooleanDomain name=\"bool\" />\n"
27871 " <Documentation>When enabled, LookupTable will always be\n"
27872 " used for scalar mapping. Otherwise, when up to 4 component\n"
27873 " scalars are present, the components are clamped to a valid\n"
27874 " color interval (0-255 for an integral type and 0.0-1.0 for a\n"
27875 " floating point type) and then directly used as\n"
27876 " color.</Documentation>\n"
27877 " </IntVectorProperty>\n"
27878 " <IntVectorProperty default_values=\"0\"\n"
27879 " name=\"MultiComponentsMapping\"\n"
27880 " number_of_elements=\"1\">\n"
27881 " <BooleanDomain name=\"bool\" />\n"
27882 " <Documentation>Enable multi components mapping. For a two-components array,\n"
27883 " the first component is mapped to the color, the second component is mapped to the\n"
27884 " opacity. For a four-components array, the first, second and third components are used as\n"
27885 " RGB values and the fourth component is mapped to the opacity. Only available\n"
27886 " when MapScalars is ON. This feature forces \"Separate Color Map\" and scales the color and\n"
27887 " the opacity range with the correct component.</Documentation>\n"
27888 " <Hints>\n"
27889 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27890 " mode=\"visibility\"\n"
27891 " property=\"Representation\"\n"
27892 " value=\"Volume\" />\n"
27893 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
27894 " mode=\"visibility\"\n"
27895 " property=\"MapScalars\"\n"
27896 " value=\"1\" />\n"
27897 " <PropertyWidgetDecorator type=\"MultiComponentsDecorator\"\n"
27898 " components=\"2 4\" />\n"
27899 " </Hints>\n"
27900 " </IntVectorProperty>\n"
27901 " <IntVectorProperty command=\"SetInterpolateScalarsBeforeMapping\"\n"
27902 " default_values=\"1\"\n"
27903 " name=\"InterpolateScalarsBeforeMapping\"\n"
27904 " number_of_elements=\"1\">\n"
27905 " <BooleanDomain name=\"bool\" />\n"
27906 " <Documentation>When set to true (default), texture coordinates\n"
27907 " are sent to and interpolated by the graphics card. This is\n"
27908 " equivalent with interpolating scalars and then mapping them to\n"
27909 " obtain colors between points. Otherwise, colors are sent to\n"
27910 " and interpolated by the graphics card.\n"
27911 " </Documentation>\n"
27912 " </IntVectorProperty>\n"
27913 " <IntVectorProperty command=\"SetSeamlessU\"\n"
27914 " default_values=\"0\"\n"
27915 " name=\"SeamlessU\"\n"
27916 " number_of_elements=\"1\">\n"
27917 " <BooleanDomain name=\"bool\" />\n"
27918 " <Documentation>This parameter prevents seams in the U direction in\n"
27919 " the parameterization space. It should be used when using a cylindrical\n"
27920 " or toroidal parameterization on the surface.\n"
27921 " </Documentation>\n"
27922 " </IntVectorProperty>\n"
27923 " <IntVectorProperty command=\"SetSeamlessV\"\n"
27924 " default_values=\"0\"\n"
27925 " name=\"SeamlessV\"\n"
27926 " number_of_elements=\"1\">\n"
27927 " <BooleanDomain name=\"bool\" />\n"
27928 " <Documentation>This parameter prevents seams in the V direction in\n"
27929 " the parameterization space. It should be used when using a cylindrical\n"
27930 " or toroidal parameterization on the surface.\n"
27931 " </Documentation>\n"
27932 " </IntVectorProperty>\n"
27933 " <IntVectorProperty command=\"SetStatic\"\n"
27934 " default_values=\"0\"\n"
27935 " name=\"StaticMode\"\n"
27936 " number_of_elements=\"1\">\n"
27937 " <BooleanDomain name=\"bool\" />\n"
27938 " </IntVectorProperty>\n"
27939 "\n"
27940 " <StringVectorProperty name=\"Assembly\"\n"
27941 " command=\"SetActiveAssembly\"\n"
27942 " number_of_elements=\"1\"\n"
27943 " panel_visibility=\"multiblock_inspector\">\n"
27944 " <DataAssemblyListDomain name=\"data_assembly\">\n"
27945 " <RequiredProperties>\n"
27946 " <Property function=\"Input\" name=\"Input\" />\n"
27947 " </RequiredProperties>\n"
27948 " </DataAssemblyListDomain>\n"
27949 " <Documentation>\n"
27950 " Select which assembly is used when specify selectors\n"
27951 " to choose block visibilities, block colors, etc. for composite datasets.\n"
27952 " </Documentation>\n"
27953 " </StringVectorProperty>\n"
27954 "\n"
27955 " <StringVectorProperty name=\"SelectedBlockSelectors\"\n"
27956 " repeat_command=\"1\"\n"
27957 " number_of_elements_per_command=\"1\"\n"
27958 " number_of_elements=\"1\"\n"
27959 " panel_visibility=\"multiblock_inspector\">\n"
27960 " <DataAssemblyDomain name=\"data_assembly\">\n"
27961 " <RequiredProperties>\n"
27962 " <Property function=\"Input\" name=\"Input\"/>\n"
27963 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
27964 " </RequiredProperties>\n"
27965 " </DataAssemblyDomain>\n"
27966 " <Hints>\n"
27967 " <NoDefault/>\n"
27968 " </Hints>\n"
27969 " <Documentation>\n"
27970 " Used by the multiblock inspector to track the selected block selectors.\n"
27971 " </Documentation>\n"
27972 " </StringVectorProperty>\n"
27973 "\n"
27974 " <StringVectorProperty name=\"BlockSelectors\"\n"
27975 " command=\"AddBlockSelector\"\n"
27976 " clean_command=\"RemoveAllBlockSelectors\"\n"
27977 " repeat_command=\"1\"\n"
27978 " number_of_elements_per_command=\"1\"\n"
27979 " panel_visibility=\"multiblock_inspector\"\n"
27980 " number_of_elements=\"1\"\n"
27981 " default_values=\"/\">\n"
27982 " <DataAssemblyDomain name=\"data_assembly\">\n"
27983 " <RequiredProperties>\n"
27984 " <Property function=\"Input\" name=\"Input\" />\n"
27985 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
27986 " </RequiredProperties>\n"
27987 " </DataAssemblyDomain>\n"
27988 " <Documentation>\n"
27989 " For composite datasets, specify selectors to limit the view\n"
27990 " to a chosen subset of blocks.\n"
27991 " </Documentation>\n"
27992 " </StringVectorProperty>\n"
27993 "\n"
27994 " <StringVectorProperty name=\"BlockColors\"\n"
27995 " command=\"SetBlockColor\"\n"
27996 " clean_command=\"RemoveAllBlockColors\"\n"
27997 " element_types=\"2 1 1 1\"\n"
27998 " number_of_elements_per_command=\"4\"\n"
27999 " repeat_command=\"1\"\n"
28000 " panel_visibility=\"multiblock_inspector\">\n"
28001 " <DataAssemblyDomain name=\"data_assembly\">\n"
28002 " <RequiredProperties>\n"
28003 " <Property function=\"Input\" name=\"Input\" />\n"
28004 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
28005 " </RequiredProperties>\n"
28006 " </DataAssemblyDomain>\n"
28007 " <Hints>\n"
28008 " <NoDefault/>\n"
28009 " </Hints>\n"
28010 " <Documentation>\n"
28011 " For composite datasets, specify colors associated with selectors\n"
28012 " on the assembly chosen using **Assembly**.\n"
28013 " </Documentation>\n"
28014 " </StringVectorProperty>\n"
28015 "\n"
28016 " <StringVectorProperty name=\"BlockColorArrayNames\"\n"
28017 " command=\"SetBlockArrayName\"\n"
28018 " clean_command=\"RemoveAllBlockArrayNames\"\n"
28019 " element_types=\"2 0 2\"\n"
28020 " number_of_elements_per_command=\"3\"\n"
28021 " repeat_command=\"1\"\n"
28022 " panel_visibility=\"multiblock_inspector\">\n"
28023 " <RepresentedArrayListDomain name=\"array_list\" input_domain_name=\"input_array_any\">\n"
28024 " <RequiredProperties>\n"
28025 " <Property function=\"Input\" name=\"Input\"/>\n"
28026 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
28027 " <Property function=\"Selectors\" name=\"SelectedBlockSelectors\"/>\n"
28028 " </RequiredProperties>\n"
28029 " </RepresentedArrayListDomain>\n"
28030 " <Documentation>\n"
28031 " For composite datasets, specify the color array name associated with selectors\n"
28032 " on the assembly chosen using **Assembly**.\n"
28033 " </Documentation>\n"
28034 " <Hints>\n"
28035 " <NoDefault/>\n"
28036 " </Hints>\n"
28037 " </StringVectorProperty>\n"
28038 "\n"
28039 " <ProxyProperty command=\"SetBlockLookupTable\"\n"
28040 " name=\"BlockLookupTables\"\n"
28041 " clean_command=\"RemoveAllBlockLookupTables\"\n"
28042 " repeat_command=\"1\"\n"
28043 " panel_visibility=\"multiblock_inspector\">\n"
28044 " <ProxyGroupDomain name=\"groups\">\n"
28045 " <Group name=\"lookup_tables\"/>\n"
28046 " </ProxyGroupDomain>\n"
28047 " <Hints>\n"
28048 " <NoDefault/>\n"
28049 " </Hints>\n"
28050 " <Documentation>\n"
28051 " Set the block lookup-table to use to map data array to colors.\n"
28052 " Lookup table is only used with MapScalars to ON or BlockMapScalars to ON.\n"
28053 " </Documentation>\n"
28054 " </ProxyProperty>\n"
28055 "\n"
28056 " <StringVectorProperty name=\"BlockUseSeparateColorMaps\"\n"
28057 " element_types=\"2 0\"\n"
28058 " number_of_elements_per_command=\"2\"\n"
28059 " repeat_command=\"1\"\n"
28060 " panel_visibility=\"multiblock_inspector\">\n"
28061 " <DataAssemblyDomain name=\"data_assembly\">\n"
28062 " <RequiredProperties>\n"
28063 " <Property function=\"Input\" name=\"Input\"/>\n"
28064 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
28065 " </RequiredProperties>\n"
28066 " </DataAssemblyDomain>\n"
28067 " <Hints>\n"
28068 " <NoDefault/>\n"
28069 " </Hints>\n"
28070 " <Documentation>\n"
28071 " By default, ParaView shares a single color map among all datasets colored\n"
28072 " by arrays that have the same name. When this option is enabled, the block of the active dataset will\n"
28073 " be assigned a separate color map not shared by other blocks or datasets.\n"
28074 " </Documentation>\n"
28075 " </StringVectorProperty>\n"
28076 "\n"
28077 " <StringVectorProperty name=\"BlockMapScalars\"\n"
28078 " command=\"SetBlockMapScalars\"\n"
28079 " clean_command=\"RemoveAllBlockMapScalars\"\n"
28080 " element_types=\"2 0\"\n"
28081 " number_of_elements_per_command=\"2\"\n"
28082 " repeat_command=\"1\"\n"
28083 " panel_visibility=\"multiblock_inspector\">\n"
28084 " <DataAssemblyDomain name=\"data_assembly\">\n"
28085 " <RequiredProperties>\n"
28086 " <Property function=\"Input\" name=\"Input\"/>\n"
28087 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
28088 " </RequiredProperties>\n"
28089 " </DataAssemblyDomain>\n"
28090 " <Hints>\n"
28091 " <NoDefault/>\n"
28092 " </Hints>\n"
28093 " <Documentation>\n"
28094 " For composite datasets, specify if to map scalars associated with selectors\n"
28095 " on the assembly chosen using **Assembly**.\n"
28096 " </Documentation>\n"
28097 " </StringVectorProperty>\n"
28098 "\n"
28099 " <StringVectorProperty name=\"BlockInterpolateScalarsBeforeMappings\"\n"
28100 " command=\"SetBlockInterpolateScalarsBeforeMapping\"\n"
28101 " clean_command=\"RemoveAllBlockInterpolateScalarsBeforeMappings\"\n"
28102 " element_types=\"2 0\"\n"
28103 " number_of_elements_per_command=\"2\"\n"
28104 " repeat_command=\"1\"\n"
28105 " panel_visibility=\"multiblock_inspector\">\n"
28106 " <DataAssemblyDomain name=\"data_assembly\">\n"
28107 " <RequiredProperties>\n"
28108 " <Property function=\"Input\" name=\"Input\"/>\n"
28109 " <Property function=\"ActiveAssembly\" name=\"Assembly\"/>\n"
28110 " </RequiredProperties>\n"
28111 " </DataAssemblyDomain>\n"
28112 " <Hints>\n"
28113 " <NoDefault/>\n"
28114 " </Hints>\n"
28115 " <Documentation>\n"
28116 " For composite datasets, specify if to interpolate scalars before mapping associated with selectors\n"
28117 " on the assembly chosen using **Assembly**.\n"
28118 ;
28119
28120 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Views/Resources/views_and_representations.xml
28122 " </Documentation>\n"
28123 " </StringVectorProperty>\n"
28124 "\n"
28125 " <StringVectorProperty name=\"BlockOpacities\"\n"
28126 " command=\"SetBlockOpacity\"\n"
28127 " clean_command=\"RemoveAllBlockOpacities\"\n"
28128 " element_types=\"2 1\"\n"
28129 " number_of_elements_per_command=\"2\"\n"
28130 " repeat_command=\"1\"\n"
28131 " panel_visibility=\"multiblock_inspector\">\n"
28132 " <DataAssemblyDomain name=\"data_assembly\">\n"
28133 " <RequiredProperties>\n"
28134 " <Property function=\"Input\" name=\"Input\" />\n"
28135 " <Property function=\"ActiveAssembly\" name=\"Assembly\" />\n"
28136 " </RequiredProperties>\n"
28137 " </DataAssemblyDomain>\n"
28138 " <Hints>\n"
28139 " <NoDefault/>\n"
28140 " </Hints>\n"
28141 " <Documentation>\n"
28142 " For composite datasets, specify opacities associated with selectors\n"
28143 " on the assembly chosen using **Assembly**.\n"
28144 " </Documentation>\n"
28145 " </StringVectorProperty>\n"
28146 "\n"
28147 " <IntVectorProperty default_values=\"1\"\n"
28148 " label=\"Map Scalars\"\n"
28149 " name=\"BlockMapScalarsGUI\"\n"
28150 " number_of_elements=\"1\"\n"
28151 " panel_visibility=\"multiblock_properties\">\n"
28152 " <BooleanDomain name=\"bool\"/>\n"
28153 " <Documentation>\n"
28154 " For composite datasets, specify if to map scalars associated with selectors\n"
28155 " on the assembly chosen using **Assembly**.\n"
28156 " </Documentation>\n"
28157 " </IntVectorProperty>\n"
28158 "\n"
28159 " <IntVectorProperty default_values=\"1\"\n"
28160 " label=\"Interpolate Scalars Before Mapping\"\n"
28161 " name=\"BlockInterpolateScalarsBeforeMappingsGUI\"\n"
28162 " number_of_elements=\"1\"\n"
28163 " panel_visibility=\"multiblock_properties\">\n"
28164 " <BooleanDomain name=\"bool\"/>\n"
28165 " <Documentation>\n"
28166 " For composite datasets, specify if to interpolate scalars before mapping associated with selectors\n"
28167 " on the assembly chosen using **Assembly**.\n"
28168 " </Documentation>\n"
28169 " </IntVectorProperty>\n"
28170 "\n"
28171 " <DoubleVectorProperty default_values=\"1.0\"\n"
28172 " label=\"Opacity\"\n"
28173 " name=\"BlockOpacitiesGUI\"\n"
28174 " number_of_elements=\"1\"\n"
28175 " panel_visibility=\"multiblock_properties\">\n"
28176 " <DoubleRangeDomain max=\"1\"\n"
28177 " min=\"0\"\n"
28178 " name=\"range\"/>\n"
28179 " <Documentation>\n"
28180 " For composite datasets, specify opacities associated with selectors\n"
28181 " on the assembly chosen using **Assembly**.\n"
28182 " </Documentation>\n"
28183 " </DoubleVectorProperty>\n"
28184 "\n"
28185 " <IntVectorProperty command=\"SetBlockColorsDistinctValues\"\n"
28186 " default_values=\"7\"\n"
28187 " name=\"BlockColorsDistinctValues\"\n"
28188 " number_of_elements=\"1\"\n"
28189 " panel_visibility=\"never\">\n"
28190 " <Documentation>\n"
28191 " Determines the number of distinct values in\n"
28192 " vtkBlockColors. This array is added to each block if\n"
28193 " the dataset is a composite dataset. The array has one value\n"
28194 " set to (blockIndex % BlockColorsDistinctValues)\n"
28195 " </Documentation>\n"
28196 " <IntRangeDomain min=\"2\" name=\"range\" />\n"
28197 " <Hints>\n"
28198 " <PropertyLink group=\"settings\"\n"
28199 " proxy=\"GeneralSettings\"\n"
28200 " property=\"BlockColorsDistinctValues\"/>\n"
28201 " </Hints>\n"
28202 " </IntVectorProperty>\n"
28203 " <IntVectorProperty command=\"SetUseDataPartitions\"\n"
28204 " default_values=\"0\"\n"
28205 " name=\"UseDataPartitions\"\n"
28206 " number_of_elements=\"1\">\n"
28207 " <BooleanDomain name=\"bool\" />\n"
28208 " <Documentation>Specify whether or not to redistribute the data when actor is translucent.\n"
28209 " Default is false.</Documentation>\n"
28210 " </IntVectorProperty>\n"
28211 " <IntVectorProperty command=\"SetEnableScaling\"\n"
28212 " default_values=\"0\"\n"
28213 " name=\"OSPRayUseScaleArray\"\n"
28214 " label=\"Scaling Mode\"\n"
28215 " number_of_elements=\"1\">\n"
28216 " <Documentation>\n"
28217 " Choose how the size of each sphere and cylinder is determined.\n"
28218 " </Documentation>\n"
28219 " <EnumerationDomain name=\"enum\">\n"
28220 " <Entry text=\"All Exact\"\n"
28221 " value=\"-1\" />\n"
28222 " <Entry text=\"All Approximate\"\n"
28223 " value=\"0\" />\n"
28224 " <Entry text=\"Each Scaled\"\n"
28225 " value=\"1\" />\n"
28226 " <Entry text=\"Each Exact\"\n"
28227 " value=\"2\" />\n"
28228 " </EnumerationDomain>\n"
28229 " <Hints>\n"
28230 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
28231 " </Hints>\n"
28232 " </IntVectorProperty>\n"
28233 " <StringVectorProperty command=\"SetScalingArrayName\"\n"
28234 " default_values=\"\"\n"
28235 " name=\"OSPRayScaleArray\"\n"
28236 " label=\"Scale Array\"\n"
28237 " number_of_elements=\"1\"\n"
28238 " panel_visibility=\"advanced\">\n"
28239 " <ArrayListDomain input_domain_name=\"input_array_point\"\n"
28240 " name=\"array_list\">\n"
28241 " <RequiredProperties>\n"
28242 " <Property function=\"Input\" name=\"Input\" />\n"
28243 " </RequiredProperties>\n"
28244 " </ArrayListDomain>\n"
28245 " <Documentation>\n"
28246 " Choice of an array for OSPRay implicit points and lines sizes.\n"
28247 " </Documentation>\n"
28248 " <Hints>\n"
28249 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
28250 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28251 " mode=\"visibility\"\n"
28252 " property=\"OSPRayUseScaleArray\"\n"
28253 " values=\"1\" />\n"
28254 " </Hints>\n"
28255 " </StringVectorProperty>\n"
28256 " <ProxyProperty command=\"SetScalingFunction\"\n"
28257 " name=\"OSPRayScaleFunction\"\n"
28258 " label=\"Scale Function\"\n"
28259 " panel_visibility=\"advanced\"\n"
28260 " panel_widget=\"transfer_function_editor\" >\n"
28261 " <Documentation>Set the piecewise function used to map data array to sprite size.\n"
28262 " ScaleTransferFunction is only used if ScaleByArray is set.</Documentation>\n"
28263 " <ProxyGroupDomain name=\"groups\">\n"
28264 " <Group name=\"piecewise_functions\" />\n"
28265 " </ProxyGroupDomain>\n"
28266 " <ProxyListDomain name=\"proxy_list\">\n"
28267 " <Proxy group=\"piecewise_functions\"\n"
28268 " name=\"PiecewiseFunction\" />\n"
28269 " </ProxyListDomain>\n"
28270 " <Hints>\n"
28271 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
28272 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28273 " mode=\"visibility\"\n"
28274 " property=\"OSPRayUseScaleArray\"\n"
28275 " values=\"1\" />\n"
28276 " </Hints>\n"
28277 " </ProxyProperty>\n"
28278 " <StringVectorProperty command=\"SetMaterial\"\n"
28279 " name=\"OSPRayMaterial\"\n"
28280 " label=\"Material\"\n"
28281 " number_of_elements=\"1\"\n"
28282 " panel_visibility=\"advanced\"\n"
28283 " default_values=\"None\">\n"
28284 " <Documentation>Set the material to paint this object with.</Documentation>\n"
28285 " <MaterialDomain name=\"string_list\">\n"
28286 " </MaterialDomain>\n"
28287 " <Hints>\n"
28288 " <PropertyWidgetDecorator type=\"OSPRayHidingDecorator\" />\n"
28289 " </Hints>\n"
28290 " </StringVectorProperty>\n"
28291 "\n"
28292 " <!-- End of SurfaceRepresentationBase -->\n"
28293 " </RepresentationProxy>\n"
28294 "\n"
28295 " </ProxyGroup>\n"
28296 "</ServerManagerConfiguration>\n"
28297 "\n";
28298 // Get single string
28300 {
28301
28356  size_t len = ( 0
28357  + len0
28358  + len1
28359  + len2
28360  + len3
28361  + len4
28362  + len5
28363  + len6
28364  + len7
28365  + len8
28366  + len9
28367  + len10
28368  + len11
28369  + len12
28370  + len13
28371  + len14
28372  + len15
28373  + len16
28374  + len17
28375  + len18
28376  + len19
28377  + len20
28378  + len21
28379  + len22
28380  + len23
28381  + len24
28382  + len25
28383  + len26
28384  + len27
28385  + len28
28386  + len29
28387  + len30
28388  + len31
28389  + len32
28390  + len33
28391  + len34
28392  + len35
28393  + len36
28394  + len37
28395  + len38
28396  + len39
28397  + len40
28398  + len41
28399  + len42
28400  + len43
28401  + len44
28402  + len45
28403  + len46
28404  + len47
28405  + len48
28406  + len49
28407  + len50
28408  + len51
28409  + len52
28410  + len53 );
28411  char* res = new char[ len + 1];
28412  size_t offset = 0;
28467  assert(offset == len);
28468  res[offset] = 0;
28469  return res;
28470 }
28471
28472
28473 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/ViewsPython/Resources/rendering_remotingpython.xml
28475 "<ServerManagerConfiguration>\n"
28476 " <ProxyGroup name=\"representations\">\n"
28477 " <!-- ================================================================== -->\n"
28478 " <RepresentationProxy name=\"PythonRepresentation\"\n"
28479 " class=\"vtkPythonRepresentation\"\n"
28480 " processes=\"client|dataserver|renderserver\">\n"
28481 " <InputProperty command=\"SetInputConnection\" name=\"Input\"/>\n"
28482 " <IntVectorProperty command=\"SetVisibility\"\n"
28483 " default_values=\"1\"\n"
28484 " name=\"Visibility\"\n"
28485 " number_of_elements=\"1\">\n"
28486 " <BooleanDomain name=\"bool\" />\n"
28487 " <Documentation>Visibility of the representation.</Documentation>\n"
28488 " </IntVectorProperty>\n"
28489 " <IntVectorProperty command=\"SetForceUseCache\"\n"
28490 " default_values=\"0\"\n"
28491 " is_internal=\"1\"\n"
28492 " name=\"ForceUseCache\"\n"
28493 " number_of_elements=\"1\">\n"
28494 " <BooleanDomain name=\"bool\" />\n"
28495 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
28496 " and representations cache based on what the view tells it. However in\n"
28497 " some cases we may want to force a representation to cache irrespective\n"
28498 " of the view (e.g. comparative views). In which case these ivars can up\n"
28499 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
28500 " Instead, ForcedCacheKey is used.</Documentation>\n"
28501 " </IntVectorProperty>\n"
28502 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
28503 " default_values=\"none\"\n"
28504 " is_internal=\"1\"\n"
28505 " name=\"ForcedCacheKey\"\n"
28506 " number_of_elements=\"1\">\n"
28507 " <DoubleRangeDomain name=\"range\" />\n"
28508 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
28509 " and representations cache based on what the view tells it. However in\n"
28510 " some cases we may want to force a representation to cache irrespective\n"
28511 " of the view (e.g. comparative views). In which case these ivars can up\n"
28512 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
28513 " Instead, ForcedCacheKey is used.</Documentation>\n"
28514 " </DoubleVectorProperty>\n"
28515 " </RepresentationProxy>\n"
28516 " </ProxyGroup>\n"
28517 "\n"
28518 " <ProxyGroup name=\"views\">\n"
28519 " <!-- ================================================================== -->\n"
28520 " <PythonViewProxy name=\"PythonView\" class=\"vtkPythonView\"\n"
28521 " label=\"Python View\"\n"
28522 " processes=\"client|dataserver|renderserver\"\n"
28523 " base_proxygroup=\"internal_views\"\n"
28524 " base_proxyname=\"ViewBase\"\n"
28525 " representation_name=\"PythonRepresentation\">\n"
28526 " <StringVectorProperty command=\"SetScript\"\n"
28527 " name=\"Script\"\n"
28528 " number_of_elements=\"1\">\n"
28529 " <Hints>\n"
28530 " <Widget type=\"multi_line\" syntax=\"python\"/>\n"
28531 " </Hints>\n"
28532 " <Documentation>This property contains the text of a Python program used\n"
28533 " to generate a plot. Use the TAB key to end editing and generate the\n"
28534 " plot.</Documentation>\n"
28535 " </StringVectorProperty>\n"
28536 " <IntVectorProperty command=\"GetNumberOfVisibleDataObjects\"\n"
28537 " name=\"NumberOfVisibleDataObjects\"\n"
28538 " number_of_elements=\"1\"\n"
28539 " default_values=\"1\"\n"
28540 " information_only=\"1\"\n"
28541 " panel_visibility=\"never\">\n"
28542 " <SimpleIntInformationHelper/>\n"
28543 " </IntVectorProperty>\n"
28544 " <IntVectorProperty command=\"SetForceUseCache\"\n"
28545 " default_values=\"0\"\n"
28546 " is_internal=\"1\"\n"
28547 " name=\"ForceUseCache\"\n"
28548 " number_of_elements=\"1\">\n"
28549 " <BooleanDomain name=\"bool\" />\n"
28550 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
28551 " and representations cache based on what the view tells it. However in\n"
28552 " some cases we may want to force a representation to cache irrespective\n"
28553 " of the view (e.g. comparative views). In which case these ivars can up\n"
28554 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
28555 " Instead, ForcedCacheKey is used.</Documentation>\n"
28556 " </IntVectorProperty>\n"
28557 " <DoubleVectorProperty command=\"SetForcedCacheKey\"\n"
28558 " default_values=\"none\"\n"
28559 " is_internal=\"1\"\n"
28560 " name=\"ForcedCacheKey\"\n"
28561 " number_of_elements=\"1\">\n"
28562 " <DoubleRangeDomain name=\"range\" />\n"
28563 " <Documentation>Typically UseCache and CacheKey are updated by the View\n"
28564 " and representations cache based on what the view tells it. However in\n"
28565 " some cases we may want to force a representation to cache irrespective\n"
28566 " of the view (e.g. comparative views). In which case these ivars can up\n"
28567 " set. If ForcedCacheKey is true, it overrides UseCache and CacheKey.\n"
28568 " Instead, ForcedCacheKey is used.</Documentation>\n"
28569 " </DoubleVectorProperty>\n"
28570 " </PythonViewProxy>\n"
28571 " </ProxyGroup>\n"
28572 "</ServerManagerConfiguration>\n"
28573 "\n";
28574 // Get single string
28576 {
28577
28579  size_t len = ( 0
28580  + len0 );
28581  char* res = new char[ len + 1];
28582  size_t offset = 0;
28584  assert(offset == len);
28585  res[offset] = 0;
28586  return res;
28587 }
28588
28589
28590 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Points/Resources/points.xml
28592 "<ServerManagerConfiguration>\n"
28593 " <!-- =================================================================== -->\n"
28594 " <ProxyGroup name=\"extended_sources\">\n"
28595 " <SourceProxy name=\"BoundedPlaneSource\" class=\"vtkBoundedPlaneSource\"\n"
28596 " label=\"Bounded Plane\">\n"
28597 " <DoubleVectorProperty command=\"SetBoundingBox\"\n"
28598 " name=\"BoundingBox\"\n"
28599 " default_values=\"0 1 0 1 0 1\"\n"
28600 " number_of_elements=\"6\">\n"
28601 " <Documentation>Set the bounding box for the domain</Documentation>\n"
28602 " <BoundsDomain mode=\"data_bounds\" name=\"range\">\n"
28603 " <RequiredProperties>\n"
28604 " <Property function=\"Input\" name=\"DummyInput\" />\n"
28605 " </RequiredProperties>\n"
28606 " </BoundsDomain>\n"
28607 " </DoubleVectorProperty>\n"
28608 "\n"
28609 " <DoubleVectorProperty command=\"SetPadding\"\n"
28610 " name=\"Padding\"\n"
28611 " default_values=\"0\"\n"
28612 " number_of_elements=\"1\">\n"
28613 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
28614 " <Documentation>\n"
28615 " Specify a padding to use to inflate the bounds in all directions\n"
28616 " before generating the plane.\n"
28617 " </Documentation>\n"
28618 " </DoubleVectorProperty>\n"
28619 "\n"
28620 " <IntVectorProperty name=\"RefinementMode\"\n"
28621 " command=\"SetRefinementMode\"\n"
28622 " number_of_elements=\"1\"\n"
28623 " default_values=\"0\">\n"
28624 " <Documentation>\n"
28625 " Specify how refinement is computed.\n"
28626 " </Documentation>\n"
28627 " <EnumerationDomain name=\"enum\">\n"
28628 " <Entry text=\"Use resolution\" value=\"0\" />\n"
28629 " <Entry text=\"Use cell-size\" value=\"1\" />\n"
28630 " </EnumerationDomain>\n"
28631 " </IntVectorProperty>\n"
28632 "\n"
28633 " <IntVectorProperty command=\"SetResolution\"\n"
28634 " default_values=\"100\"\n"
28635 " name=\"Resolution\"\n"
28636 " number_of_elements=\"1\">\n"
28637 " <IntRangeDomain min=\"1\" name=\"range\" />\n"
28638 " <Documentation>This property specifies the number of divisions along\n"
28639 " the X axis of the parallelogram.</Documentation>\n"
28640 " <Hints>\n"
28641 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28642 " mode=\"visibility\"\n"
28643 " property=\"RefinementMode\"\n"
28644 " value=\"0\" />\n"
28645 " </Hints>\n"
28646 " </IntVectorProperty>\n"
28647 "\n"
28648 " <DoubleVectorProperty name=\"CellSize\"\n"
28649 " command=\"SetCellSize\"\n"
28650 " default_values=\"1.0\"\n"
28651 " number_of_elements=\"1\">\n"
28652 " <Documentation>Specify the cell size to use to compute plane refinement.</Documentation>\n"
28653 " <DoubleRangeDomain name=\"range\" min= \"1\" />\n"
28654 " <Hints>\n"
28655 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28656 " mode=\"visibility\"\n"
28657 " property=\"RefinementMode\"\n"
28658 " value=\"1\" />\n"
28659 " </Hints>\n"
28660 " </DoubleVectorProperty>\n"
28661 "\n"
28662 " <DoubleVectorProperty name=\"Center\"\n"
28663 " command=\"SetCenter\"\n"
28664 " number_of_elements=\"3\"\n"
28665 " default_values=\"0 0 0\">\n"
28666 " <Documentation>\n"
28667 " Specify the center of the plane. Works in conjunction with the plane\n"
28668 " normal to position the plane. Don't use this method to define the plane.\n"
28669 " Instead, use it to move the plane to a new center point.\n"
28670 " </Documentation>\n"
28671 " <BoundsDomain default_mode=\"mid\" mode=\"normal\" name=\"range\">\n"
28672 " <RequiredProperties>\n"
28673 " <Property function=\"Input\" name=\"DummyInput\" />\n"
28674 " </RequiredProperties>\n"
28675 " </BoundsDomain>\n"
28676 " </DoubleVectorProperty>\n"
28677 "\n"
28678 " <DoubleVectorProperty name=\"Normal\"\n"
28679 " command=\"SetNormal\"\n"
28680 " number_of_elements=\"3\"\n"
28681 " default_values=\"0 0 1\">\n"
28682 " <Documentation>\n"
28683 " Specify the plane normal. Works in conjunction with the plane center to\n"
28684 " orient the plane. Don't use this method to define the plane. Instead, use\n"
28685 " it to rotate the plane around the current center point.\n"
28686 " </Documentation>\n"
28687 " </DoubleVectorProperty>\n"
28688 "\n"
28689 " <InputProperty is_internal=\"1\" name=\"DummyInput\">\n"
28690 " <!-- Used when this source is added to a proxy list domain. -->\n"
28691 " </InputProperty>\n"
28692 "\n"
28693 " <PropertyGroup label=\"Plane Bounds\">\n"
28694 " <Property name=\"BoundingBox\" />\n"
28695 " <Property name=\"RefinementMode\" />\n"
28696 " <Property name=\"Resolution\" />\n"
28697 " <Property name=\"CellSize\" />\n"
28698 " </PropertyGroup>\n"
28699 "\n"
28700 " <PropertyGroup label=\"Plane Parameters\" panel_widget=\"InteractivePlane\">\n"
28701 " <Property function=\"Origin\" name=\"Center\" />\n"
28702 " <Property function=\"Normal\" name=\"Normal\" />\n"
28703 " <Property function=\"Input\" name=\"DummyInput\" />\n"
28704 " </PropertyGroup>\n"
28705 " <Hints>\n"
28706 " <ProxyList>\n"
28707 " <Link name=\"DummyInput\" with_property=\"Input\" />\n"
28708 " </ProxyList>\n"
28709 " </Hints>\n"
28710 " </SourceProxy>\n"
28711 "\n"
28712 " <SourceProxy name=\"BoundedVolumeSource\" class=\"vtkBoundedVolumeSource\" label=\"Bounded Volume\">\n"
28713 " <DoubleVectorProperty name=\"Origin\"\n"
28714 " command=\"SetOrigin\"\n"
28715 " number_of_elements=\"3\"\n"
28716 " default_values=\"0 0 0\">\n"
28717 " <BoundsDomain name=\"range\" mode=\"normal\" default_mode=\"min,min,min\" >\n"
28718 " <RequiredProperties>\n"
28719 " <Property function=\"Input\" name=\"DummyInput\" />\n"
28720 " </RequiredProperties>\n"
28721 " </BoundsDomain>\n"
28722 " <Documentation>\n"
28723 " Set the origin for the volume.\n"
28724 " </Documentation>\n"
28725 " </DoubleVectorProperty>\n"
28726 "\n"
28727 " <DoubleVectorProperty name=\"Scale\"\n"
28728 " command=\"SetScale\"\n"
28729 " number_of_elements=\"3\"\n"
28730 " default_values=\"1 1 1\">\n"
28731 " <BoundsDomain name=\"range\" mode=\"extents\">\n"
28732 " <RequiredProperties>\n"
28733 " <Property function=\"Input\" name=\"DummyInput\" />\n"
28734 " </RequiredProperties>\n"
28735 " </BoundsDomain>\n"
28736 "\n"
28737 " <Documentation>\n"
28738 " Set scale factor for a unit volume.\n"
28739 " </Documentation>\n"
28740 " </DoubleVectorProperty>\n"
28741 "\n"
28742 " <DoubleVectorProperty command=\"SetPadding\"\n"
28743 " name=\"Padding\"\n"
28744 " default_values=\"0\"\n"
28745 " number_of_elements=\"1\">\n"
28746 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
28747 " <Documentation>\n"
28748 " Specify a padding to use to inflate the bounds in all directions\n"
28749 " before generating the plane.\n"
28750 " </Documentation>\n"
28751 " </DoubleVectorProperty>\n"
28752 "\n"
28753 " <IntVectorProperty name=\"RefinementMode\"\n"
28754 " command=\"SetRefinementMode\"\n"
28755 " number_of_elements=\"1\"\n"
28756 " default_values=\"0\">\n"
28757 " <Documentation>\n"
28758 " Specify how refinement is computed.\n"
28759 " </Documentation>\n"
28760 " <EnumerationDomain name=\"enum\">\n"
28761 " <Entry text=\"Use resolution\" value=\"0\" />\n"
28762 " <Entry text=\"Use cell-size\" value=\"1\" />\n"
28763 " </EnumerationDomain>\n"
28764 " </IntVectorProperty>\n"
28765 "\n"
28766 " <IntVectorProperty name=\"Resolution\"\n"
28767 " command=\"SetResolution\"\n"
28768 " number_of_elements=\"3\"\n"
28769 " default_values=\"100 100 100\">\n"
28770 " <IntRangeDomain name=\"range\" min=\"1 1 1\" />\n"
28771 " <Documentation>\n"
28772 " Set the sampling resolution for the generated volume.\n"
28773 " </Documentation>\n"
28774 " <Hints>\n"
28775 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28776 " mode=\"visibility\"\n"
28777 " property=\"RefinementMode\"\n"
28778 " value=\"0\" />\n"
28779 " </Hints>\n"
28780 " </IntVectorProperty>\n"
28781 "\n"
28782 " <DoubleVectorProperty name=\"CellSize\"\n"
28783 " command=\"SetCellSize\"\n"
28784 " default_values=\"1.0\"\n"
28785 " number_of_elements=\"1\">\n"
28786 " <Documentation>Specify the cell size to use to compute plane refinement.</Documentation>\n"
28787 " <DoubleRangeDomain name=\"range\" min= \"1\" />\n"
28788 " <Hints>\n"
28789 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28790 " mode=\"visibility\"\n"
28791 " property=\"RefinementMode\"\n"
28792 " value=\"1\" />\n"
28793 " </Hints>\n"
28794 " </DoubleVectorProperty>\n"
28795 "\n"
28796 " <InputProperty is_internal=\"1\" name=\"DummyInput\">\n"
28797 " <!-- Used when this source is added to a proxy list domain. -->\n"
28798 " </InputProperty>\n"
28799 "\n"
28800 " <PropertyGroup label=\"Volume Parameters\" panel_widget=\"InteractiveBox\">\n"
28801 " <Property function=\"Position\" name=\"Origin\" />\n"
28802 " <Property function=\"Scale\" name=\"Scale\" />\n"
28803 " </PropertyGroup>\n"
28804 "\n"
28805 " <PropertyGroup label=\"Volume Refinement\">\n"
28806 " <Property name=\"RefinementMode\" />\n"
28807 " <Property name=\"Resolution\" />\n"
28808 " <Property name=\"CellSize\" />\n"
28809 " </PropertyGroup>\n"
28810 " <Hints>\n"
28811 " <ProxyList>\n"
28812 " <Link name=\"DummyInput\" with_property=\"Input\" />\n"
28813 " </ProxyList>\n"
28814 " </Hints>\n"
28815 " </SourceProxy>\n"
28816 " </ProxyGroup>\n"
28817 "\n"
28818 " <!-- =================================================================== -->\n"
28819 " <ProxyGroup name=\"point_interpolation_kernels\">\n"
28820 " <Proxy name=\"EllipsoidalGaussianKernel\" class=\"vtkEllipsoidalGaussianKernel\">\n"
28821 " <Documentation>\n"
28822 " This is an interpolation kernel that returns the\n"
28823 " weights for all points found in the ellipsoid defined by radius R in\n"
28824 " combination with local data (normals and/or scalars).\n"
28825 " </Documentation>\n"
28826 "\n"
28827 " <IntVectorProperty name=\"UseNormals\"\n"
28828 " command=\"SetUseNormals\"\n"
28829 " number_of_elements=\"1\"\n"
28830 " default_values=\"1\">\n"
28831 " <BooleanDomain name=\"bool\" />\n"
28832 " <Documentation>\n"
28833 " Specify whether vector values should be used to affect the shape\n"
28834 " of the Gaussian distribution.\n"
28835 " </Documentation>\n"
28836 " </IntVectorProperty>\n"
28837 "\n"
28838 " <IntVectorProperty name=\"UseScalars\"\n"
28839 " command=\"SetUseScalars\"\n"
28840 " number_of_elements=\"1\"\n"
28841 " default_values=\"0\">\n"
28842 " <BooleanDomain name=\"bool\" />\n"
28843 " <Documentation>\n"
28844 " Specify whether scalar values should be used to scale the weights.\n"
28845 " </Documentation>\n"
28846 " </IntVectorProperty>\n"
28847 "\n"
28848 " <DoubleVectorProperty name=\"Radius\"\n"
28849 " command=\"SetRadius\"\n"
28850 " number_of_elements=\"1\"\n"
28851 " default_values=\"1.0\">\n"
28852 " <DoubleRangeDomain name=\"range\" min=\"0.000001\" />\n"
28853 " <Documentation>\n"
28854 " Specify the radius of the kernel. Points within this radius will be\n"
28855 " used for interpolation. If no point is found, then the closest point\n"
28856 " will be used.\n"
28857 " </Documentation>\n"
28858 " </DoubleVectorProperty>\n"
28859 "\n"
28860 " <DoubleVectorProperty name=\"Sharpness\"\n"
28861 " command=\"SetSharpness\"\n"
28862 " number_of_elements=\"1\"\n"
28863 " default_values=\"2.0\">\n"
28864 " <DoubleRangeDomain name=\"range\" min=\"1.0\" />\n"
28865 " <Documentation>\n"
28866 " Specify the sharpness (i.e., falloff) of the Gaussian. By default\n"
28867 " Sharpness=2. As the sharpness increases the effects of distant points\n"
28868 " are reduced.\n"
28869 " </Documentation>\n"
28870 " </DoubleVectorProperty>\n"
28871 "\n"
28872 " <DoubleVectorProperty name=\"Eccentricity\"\n"
28873 " command=\"SetEccentricity\"\n"
28874 " number_of_elements=\"1\"\n"
28875 " default_values=\"2.0\">\n"
28876 " <DoubleRangeDomain name=\"range\" min=\"0.000001\" />\n"
28877 " <Documentation>\n"
28878 " Specify the eccentricity of the ellipsoidal Gaussian. A value=1.0\n"
28879 " produces a spherical distribution. Values less than 1 produce a needle like\n"
28880 " distribution (in the direction of the normal); values greater than 1 produce a\n"
28881 " pancake like distribution (orthogonal to the normal).\n"
28882 " </Documentation>\n"
28883 " </DoubleVectorProperty>\n"
28884 " </Proxy>\n"
28885 "\n"
28886 " <!-- =================================================================== -->\n"
28887 " <Proxy name=\"GeneralizedKernelBase\">\n"
28888 " <IntVectorProperty name=\"KernelFootprint\"\n"
28889 " command=\"SetKernelFootprint\"\n"
28890 " number_of_elements=\"1\"\n"
28891 " default_values=\"0\">\n"
28892 " <EnumerationDomain name=\"enum\">\n"
28893 " <Entry text=\"Radius\" value=\"0\"/>\n"
28894 " <Entry text=\"N Closest\" value=\"1\"/>\n"
28895 " </EnumerationDomain>\n"
28896 " <Documentation>\n"
28897 " Specify the interpolation basis style. By default, a Radius style is\n"
28898 " used (i.e., the basis is defined from all points within a specified\n"
28899 " radius). However, it is also possible to select the N closest points\n"
28900 " (N Closest). Note that in most formulations the Radius style is assumed\n"
28901 " as it provides better mathematical properties. However, for convenience\n"
28902 " some bases are easier to use when the N closest points are taken.\n"
28903 " </Documentation>\n"
28904 " </IntVectorProperty>\n"
28905 "\n"
28906 " <DoubleVectorProperty name=\"Radius\"\n"
28907 " command=\"SetRadius\"\n"
28908 " number_of_elements=\"1\"\n"
28909 " default_values=\"1.0\">\n"
28910 " <DoubleRangeDomain name=\"range\" min=\"0.000001\" />\n"
28911 " <Documentation>\n"
28912 " If the interpolation basis style is Radius, then this method specifies\n"
28913 " the radius within which the basis points must lie.\n"
28914 " </Documentation>\n"
28915 " <Hints>\n"
28916 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28917 " mode=\"enabled_state\"\n"
28918 " property=\"KernelFootprint\"\n"
28919 " value=\"0\" />\n"
28920 " </Hints>\n"
28921 " </DoubleVectorProperty>\n"
28922 "\n"
28923 " <IntVectorProperty name=\"NumberOfPoints\"\n"
28924 " command=\"SetNumberOfPoints\"\n"
28925 " number_of_elements=\"1\"\n"
28926 " default_values=\"8\">\n"
28927 " <IntRangeDomain name=\"range\" min=\"1\" />\n"
28928 " <Documentation>\n"
28929 " If the interpolation basis style is N Closest, then this method specifies\n"
28930 " the number of the closest points used to form the interpolation basis.\n"
28931 " </Documentation>\n"
28932 " <Hints>\n"
28933 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
28934 " mode=\"enabled_state\"\n"
28935 " property=\"KernelFootprint\"\n"
28936 " value=\"1\" />\n"
28937 " </Hints>\n"
28938 " </IntVectorProperty>\n"
28939 " </Proxy>\n"
28940 "\n"
28941 " <!-- =================================================================== -->\n"
28942 " <Proxy name=\"GaussianKernel\" class=\"vtkGaussianKernel\"\n"
28943 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"GeneralizedKernelBase\">\n"
28944 " <Documentation>\n"
28945 " This is an interpolation kernel that simply returns the\n"
28946 " weights for all points found in the sphere defined by radius R. The\n"
28947 " weights are computed as: `exp(-(s*r/R)^2)` where r is the distance from the\n"
28948 " point to be interpolated to a neighboring point within R. The sharpness s\n"
28949 " simply affects the rate of fall off of the Gaussian. (A more general\n"
28950 " Gaussian kernel is available from **EllipsoidalGaussianKernel**.)\n"
28951 " </Documentation>\n"
28952 "\n"
28953 " <DoubleVectorProperty name=\"Sharpness\"\n"
28954 " command=\"SetSharpness\"\n"
28955 " number_of_elements=\"1\"\n"
28956 " default_values=\"2.0\">\n"
28957 " <DoubleRangeDomain name=\"range\" min=\"1.0\" />\n"
28958 ;
28959
28960 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Points/Resources/points.xml
28962 " <Documentation>\n"
28963 " Specify the sharpness (i.e., falloff) of the Gaussian. By default\n"
28964 " Sharpness=2. As the sharpness increases the effects of distant points\n"
28965 " are reduced.\n"
28966 " </Documentation>\n"
28967 " </DoubleVectorProperty>\n"
28968 " </Proxy>\n"
28969 "\n"
28970 " <!-- =================================================================== -->\n"
28971 " <Proxy name=\"LinearKernel\" class=\"vtkLinearKernel\"\n"
28972 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"GeneralizedKernelBase\">\n"
28973 " <Documentation>\n"
28974 " This is an interpolation kernel that averages the contributions\n"
28975 " of all points in the basis.\n"
28976 " </Documentation>\n"
28977 " </Proxy>\n"
28978 "\n"
28979 " <!-- =================================================================== -->\n"
28980 " <Proxy name=\"ProbabilisticVoronoiKernel\" class=\"vtkProbabilisticVoronoiKernel\"\n"
28981 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"GeneralizedKernelBase\">\n"
28982 " <Documentation>\n"
28983 " This is an interpolation kernel that interpolates\n"
28984 " from the closest weighted point from a neighborhood of points. The weights\n"
28985 " refer to the probabilistic weighting.\n"
28986 " </Documentation>\n"
28987 " </Proxy>\n"
28988 "\n"
28989 " <!-- =================================================================== -->\n"
28990 " <Proxy name=\"ShepardKernel\" class=\"vtkShepardKernel\"\n"
28991 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"GeneralizedKernelBase\">\n"
28992 " <Documentation>\n"
28993 " This is an interpolation kernel that uses the method of\n"
28994 " Shepard to perform interpolation. The weights are computed as 1/r^p, where\n"
28995 " r is the distance to a neighbor point within the kernel radius R; and p\n"
28996 " (the power parameter) is a positive exponent (typically p=2).\n"
28997 " </Documentation>\n"
28998 "\n"
28999 " <DoubleVectorProperty name=\"PowerParameter\"\n"
29000 " command=\"SetPowerParameter\"\n"
29001 " number_of_elements=\"1\"\n"
29002 " default_values=\"2.0\">\n"
29003 " <DoubleRangeDomain name=\"range\" min=\"0.001\" max=\"100\" />\n"
29004 " <Documentation>\n"
29005 " Specify the power parameter p. By default p=2. Values (which must be\n"
29006 " a positive, real value) != 2 may affect performance significantly.\n"
29007 " </Documentation>\n"
29008 " </DoubleVectorProperty>\n"
29009 " </Proxy>\n"
29010 "\n"
29011 " <!-- =================================================================== -->\n"
29012 " <Proxy name=\"SPHKernelBase\">\n"
29013 " <DoubleVectorProperty name=\"SpatialStep\"\n"
29014 " command=\"SetSpatialStep\"\n"
29015 " number_of_elements=\"1\"\n"
29016 " default_values=\"0.0001\">\n"
29017 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
29018 " <Documentation>\n"
29019 " Specify the initial particle spatial step.\n"
29020 " </Documentation>\n"
29021 " </DoubleVectorProperty>\n"
29022 "\n"
29023 " <IntVectorProperty name=\"Dimension\"\n"
29024 " command=\"SetDimension\"\n"
29025 " number_of_elements=\"1\"\n"
29026 " default_values=\"3\">\n"
29027 " <IntRangeDomain name=\"range\" min=\"1\" max=\"3\" />\n"
29028 " <Documentation>\n"
29029 " The domain dimension, default to 3.\n"
29030 " </Documentation>\n"
29031 " </IntVectorProperty>\n"
29032 " </Proxy>\n"
29033 "\n"
29034 " <!-- =================================================================== -->\n"
29035 " <Proxy name=\"SPHCubicKernel\" class=\"vtkSPHCubicKernel\"\n"
29036 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"SPHKernelBase\">\n"
29037 " <Documentation>\n"
29038 " This is an smooth particle hydrodynamics interpolation kernel as\n"
29039 " described by D.J. Price. This is a cubic formulation.\n"
29040 " </Documentation>\n"
29041 " </Proxy>\n"
29042 "\n"
29043 " <Proxy name=\"SPHQuarticKernel\" class=\"vtkSPHQuarticKernel\"\n"
29044 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"SPHKernelBase\">\n"
29045 " <Documentation>\n"
29046 " This is an smooth particle hydrodynamics interpolation kernel as\n"
29047 " described by D.J. Price. This is a quartic formulation.\n"
29048 " </Documentation>\n"
29049 " </Proxy>\n"
29050 "\n"
29051 " <Proxy name=\"SPHQuinticKernel\" class=\"vtkSPHQuinticKernel\"\n"
29052 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"SPHKernelBase\">\n"
29053 " <Documentation>\n"
29054 " This is an smooth particle hydrodynamics interpolation kernel as\n"
29055 " described by D.J. Price. This is a quintic formulation.\n"
29056 " </Documentation>\n"
29057 " </Proxy>\n"
29058 "\n"
29059 " <Proxy name=\"SPHWendlandQuinticKernel\" class=\"vtkWendlandQuinticKernel\"\n"
29060 " base_proxygroup=\"point_interpolation_kernels\" base_proxyname=\"SPHKernelBase\">\n"
29061 " <Documentation>\n"
29062 " This is an smooth particle hydrodynamics interpolation kernel as\n"
29063 " described by D.J. Price. This is a quintic formulation.\n"
29064 " </Documentation>\n"
29065 " </Proxy>\n"
29066 "\n"
29067 " <!-- =================================================================== -->\n"
29068 " <Proxy name=\"VoronoiKernel\" class=\"vtkVoronoiKernel\">\n"
29069 " <Documentation>\n"
29070 " This is an interpolation kernel that simply returns the\n"
29071 " closest point to a point to be interpolated. A single weight is returned\n"
29072 " with value=1.0.\n"
29073 " </Documentation>\n"
29074 " </Proxy>\n"
29075 " </ProxyGroup>\n"
29076 "\n"
29077 " <!-- =================================================================== -->\n"
29078 " <ProxyGroup name=\"generic_point_interpolation_kernels\">\n"
29079 " <Proxy group=\"point_interpolation_kernels\" name=\"EllipsoidalGaussianKernel\" />\n"
29080 " <Proxy group=\"point_interpolation_kernels\" name=\"GaussianKernel\" />\n"
29081 " <Proxy group=\"point_interpolation_kernels\" name=\"LinearKernel\" />\n"
29082 " <Proxy group=\"point_interpolation_kernels\" name=\"ProbabilisticVoronoiKernel\" />\n"
29083 " <Proxy group=\"point_interpolation_kernels\" name=\"ShepardKernel\" />\n"
29084 " <Proxy group=\"point_interpolation_kernels\" name=\"VoronoiKernel\" />\n"
29085 " </ProxyGroup>\n"
29086 " <ProxyGroup name=\"sph_point_interpolation_kernels\">\n"
29087 " <Proxy group=\"point_interpolation_kernels\" name=\"SPHQuinticKernel\" />\n"
29088 " <Proxy group=\"point_interpolation_kernels\" name=\"SPHCubicKernel\" />\n"
29089 " <Proxy group=\"point_interpolation_kernels\" name=\"SPHQuarticKernel\" />\n"
29090 " <Proxy group=\"point_interpolation_kernels\" name=\"SPHWendlandQuinticKernel\" />\n"
29091 " </ProxyGroup>\n"
29092 "\n"
29093 " <!-- =================================================================== -->\n"
29094 " <ProxyGroup name=\"filters\">\n"
29095 "\n"
29096 " <!-- ==================================================================== -->\n"
29097 " <SourceProxy name=\"ExtractEnclosedPoints\"\n"
29098 " class=\"vtkExtractEnclosedPoints\"\n"
29099 " label=\"Extract Enclosed Points\">\n"
29100 " <Documentation long_help=\"Extract points inside a closed polygonal surface\"\n"
29101 " short_help=\"Extract points inside a closed points surface\">\n"
29102 " Evaluates all points in the input dataset to determine whether they are contained within\n"
29103 " an enclosing surface, defined by the **Surface**. The filter assumes that the surface\n"
29104 " is closed and manifold. To force a check to ensure these preconditions are met\n"
29105 " set the **CheckSurface** property.\n"
29106 " </Documentation>\n"
29107 "\n"
29108 " <OutputPort index=\"0\" name=\"EnclosedPoints\" />\n"
29109 " <OutputPort index=\"1\" name=\"Outliers\" />\n"
29110 "\n"
29111 " <InputProperty command=\"SetInputConnection\" name=\"Input\">\n"
29112 " <ProxyGroupDomain name=\"groups\">\n"
29113 " <Group name=\"sources\" />\n"
29114 " <Group name=\"filters\" />\n"
29115 " </ProxyGroupDomain>\n"
29116 " <DataTypeDomain name=\"input_type\">\n"
29117 " <DataType value=\"vtkPointSet\" />\n"
29118 " </DataTypeDomain>\n"
29119 " <Documentation>This property specifies the input to extract points from.</Documentation>\n"
29120 " </InputProperty>\n"
29121 "\n"
29122 " <InputProperty command=\"SetSurfaceConnection\" name=\"Surface\">\n"
29123 " <ProxyGroupDomain name=\"groups\">\n"
29124 " <Group name=\"sources\" />\n"
29125 " <Group name=\"filters\" />\n"
29126 " </ProxyGroupDomain>\n"
29127 " <DataTypeDomain name=\"input_type\" composite_data_supported=\"0\">\n"
29128 " <DataType value=\"vtkPolyData\" />\n"
29129 " </DataTypeDomain>\n"
29130 " <Documentation>This property specifies the closed and manifold surface.</Documentation>\n"
29131 " </InputProperty>\n"
29132 "\n"
29133 " <DoubleVectorProperty name=\"Tolerance\"\n"
29134 " command=\"SetTolerance\"\n"
29135 " number_of_elements=\"1\"\n"
29136 " default_values=\"0.0001\">\n"
29137 " <DoubleRangeDomain name=\"range\" min=\"0.0\" />\n"
29138 " <Documentation>\n"
29139 " Specify the tolerance on the intersection. The tolerance is expressed as\n"
29140 " a fraction of the diagonal of the bounding box of the enclosing surface.\n"
29141 " </Documentation>\n"
29142 " </DoubleVectorProperty>\n"
29143 "\n"
29144 " <IntVectorProperty name=\"CheckSurface\"\n"
29145 " number_of_elements=\"1\"\n"
29146 " default_values=\"0\"\n"
29147 " command=\"SetCheckSurface\">\n"
29148 " <BooleanDomain name=\"bool\" />\n"
29149 " <Documentation>\n"
29150 " Specify whether to check the surface for closure. If on, then the\n"
29151 " algorithm first checks to see if the surface is closed and manifold.\n"
29152 " </Documentation>\n"
29153 " </IntVectorProperty>\n"
29154 "\n"
29155 " <IntVectorProperty name=\"GenerateOutliers\"\n"
29156 " command=\"SetGenerateOutliers\"\n"
29157 " number_of_elements=\"1\"\n"
29158 " default_values=\"0\">\n"
29159 " <Documentation>\n"
29160 " If checked, then a second output will be created\n"
29161 " that contains the outlier points.\n"
29162 " </Documentation>\n"
29163 " <BooleanDomain name=\"bool\" />\n"
29164 " </IntVectorProperty>\n"
29165 "\n"
29166 " <IntVectorProperty name=\"GenerateVertices\"\n"
29167 " command=\"SetGenerateVertices\"\n"
29168 " number_of_elements=\"1\"\n"
29169 " default_values=\"1\">\n"
29170 " <Documentation>\n"
29171 " If checked, then the outputs will contain a poly-vertex cell. This takes a\n"
29172 " lot more memory, however certain filters many requires cells to be present\n"
29173 " to function properly.\n"
29174 " </Documentation>\n"
29175 " <BooleanDomain name=\"bool\" />\n"
29176 " </IntVectorProperty>\n"
29177 " </SourceProxy>\n"
29178 "\n"
29179 " <!-- =================================================================== -->\n"
29180 " <SourceProxy name=\"SPHInterpolatorBase\" class=\"vtkSPHInterpolator\"\n"
29181 " label=\"SPH Interpolator\"\n"
29182 " multiprocess_support=\"single_process\">\n"
29183 " <Documentation>\n"
29184 " This filter uses SPH (smooth particle hydrodynamics) kernels to\n"
29185 " interpolate a data source onto an input structure. For example, while the\n"
29186 " data source is a set of particles, the data from these particles can be\n"
29187 " interpolated onto an input object such as a line, plane or volume. Then\n"
29188 " the output (which consists of the input structure plus interpolated data)\n"
29189 " can then be visualized using classical visualization techniques such as\n"
29190 " isocontouring, slicing, heat maps and so on.\n"
29191 " </Documentation>\n"
29192 "\n"
29193 " <InputProperty command=\"SetInputConnection\"\n"
29194 " name=\"Input\"\n"
29195 " port_index=\"1\">\n"
29196 " <ProxyGroupDomain name=\"groups\">\n"
29197 " <Group name=\"sources\" />\n"
29198 " <Group name=\"filters\" />\n"
29199 " </ProxyGroupDomain>\n"
29200 " <DataTypeDomain name=\"input_type\">\n"
29201 " <DataType value=\"vtkPointSet\" />\n"
29202 " </DataTypeDomain>\n"
29203 " <InputArrayDomain attribute_type=\"point\" name=\"point_scalars\" number_of_components=\"1\" />\n"
29204 " <InputArrayDomain attribute_type=\"point\" name=\"point_arrays\" />\n"
29205 " <Documentation>The data source to be interpolated onto the *Source*.</Documentation>\n"
29206 " </InputProperty>\n"
29207 "\n"
29208 " <StringVectorProperty name=\"DensityArray\"\n"
29209 " command=\"SetDensityArrayName\"\n"
29210 " number_of_elements=\"1\"\n"
29211 " default_values=\"Rho\">\n"
29212 " <Documentation>\n"
29213 " Specify the density array name. This is required in computation. If not\n"
29214 " specified the code will error out.\n"
29215 " </Documentation>\n"
29216 " <ArrayListDomain attribute_type=\"Scalars\" name=\"array_list\" input_domain_name=\"point_scalars\">\n"
29217 " <RequiredProperties>\n"
29218 " <Property function=\"Input\" name=\"Input\" />\n"
29219 " </RequiredProperties>\n"
29220 " </ArrayListDomain>\n"
29221 " </StringVectorProperty>\n"
29222 "\n"
29223 " <StringVectorProperty name=\"MassArray\"\n"
29224 " command=\"SetMassArrayName\"\n"
29225 " number_of_elements=\"1\">\n"
29226 " <Documentation>\n"
29227 " Specify the mass array name. If not specified, then the mass at each point\n"
29228 " will be computed from the density and local (spherical) volume at a each\n"
29229 " point.\n"
29230 " </Documentation>\n"
29231 " <ArrayListDomain attribute_type=\"Scalars\" name=\"array_list\" none_string=\"None\"\n"
29232 " input_domain_name=\"point_scalars\">\n"
29233 " <RequiredProperties>\n"
29234 " <Property function=\"Input\" name=\"Input\" />\n"
29235 " </RequiredProperties>\n"
29236 " </ArrayListDomain>\n"
29237 " </StringVectorProperty>\n"
29238 "\n"
29239 " <StringVectorProperty name=\"ExcludedArrays\"\n"
29240 " command=\"AddExcludedArray\"\n"
29241 " clean_command=\"ClearExcludedArrays\"\n"
29242 " number_of_elements_per_command=\"1\"\n"
29243 " repeat_command=\"1\" >\n"
29244 " <Documentation>\n"
29245 " Specify arrays which are to be excluded from the interpolation process.\n"
29246 " </Documentation>\n"
29247 " <ArrayListDomain name=\"array_list\" input_domain_name=\"point_arrays\">\n"
29248 " <RequiredProperties>\n"
29249 " <Property function=\"Input\" name=\"Input\" />\n"
29250 " </RequiredProperties>\n"
29251 " </ArrayListDomain>\n"
29252 " <Hints>\n"
29253 " <!-- This ensures that no array is selected by default -->\n"
29254 " <NoDefault />\n"
29255 " </Hints>\n"
29256 " </StringVectorProperty>\n"
29257 "\n"
29258 " <StringVectorProperty name=\"DerivativeArrays\"\n"
29259 " command=\"AddDerivativeArray\"\n"
29260 " clean_command=\"ClearDerivativeArrays\"\n"
29261 " number_of_elements_per_command=\"1\"\n"
29262 " repeat_command=\"1\">\n"
29263 " <Documentation>\n"
29264 " Specify the arrays whose derivative is to be taken. If\n"
29265 " the name of the array is \"derivArray\" this will produce an output array\n"
29266 " with the name \"derivArray_deriv\" (after filter execution).\n"
29267 " </Documentation>\n"
29268 " <ArrayListDomain name=\"array_list\" input_domain_name=\"point_arrays\">\n"
29269 " <RequiredProperties>\n"
29270 " <Property function=\"Input\" name=\"Input\" />\n"
29271 " </RequiredProperties>\n"
29272 " </ArrayListDomain>\n"
29273 " <Hints>\n"
29274 " <!-- This ensures that no array is selected by default -->\n"
29275 " <NoDefault />\n"
29276 " </Hints>\n"
29277 " </StringVectorProperty>\n"
29278 "\n"
29279 " <PropertyGroup label=\"Array Selections\">\n"
29280 " <Property name=\"DensityArray\" />\n"
29281 " <Property name=\"MassArray\" />\n"
29282 " <Property name=\"ExcludedArrays\" />\n"
29283 " <Property name=\"DerivativeArrays\" />\n"
29284 " </PropertyGroup>\n"
29285 "\n"
29286 " <ProxyProperty name=\"Kernel\" command=\"SetKernel\" >\n"
29287 " Specify an interpolation kernel. The interpolation kernel changes the basis of the\n"
29288 " interpolation.\n"
29289 " <ProxyListDomain name=\"proxy_list\">\n"
29290 " <Group name=\"sph_point_interpolation_kernels\" default=\"SPHQuinticKernel\" />\n"
29291 " </ProxyListDomain>\n"
29292 " </ProxyProperty>\n"
29293 "\n"
29294 " <IntVectorProperty name=\"NullPointsStrategy\"\n"
29295 " command=\"SetNullPointsStrategy\"\n"
29296 ;
29297
29298 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Points/Resources/points.xml
29300 " number_of_elements=\"1\"\n"
29301 " default_values=\"1\"\n"
29302 " panel_visibility=\"advanced\">\n"
29303 " <EnumerationDomain name=\"enum\">\n"
29304 " <Entry text=\"Mask Points\" value=\"0\" />\n"
29305 " <Entry text=\"Null Value\" value=\"1\" />\n"
29306 " </EnumerationDomain>\n"
29307 " <Documentation>\n"
29308 " Specify a strategy to use when encountering a \"null\" point during the\n"
29309 " interpolation process. Null points occur when the local neighborhood (of\n"
29310 " nearby points to interpolate from) is empty. If the strategy is set to\n"
29311 " MaskPoints, then an output array is created that marks points as being\n"
29312 " valid (=1) or null (invalid =0) (and the NullValue is set as well). If\n"
29313 " the strategy is set to NullValue, then the output data value(s) are set\n"
29314 " to the NullPoint value (specified in the output point data).\n"
29315 " </Documentation>\n"
29316 " </IntVectorProperty>\n"
29317 "\n"
29318 " <IntVectorProperty name=\"ComputeShepardSum\"\n"
29319 " command=\"SetComputeShepardSum\"\n"
29320 " number_of_elements=\"1\"\n"
29321 " default_values=\"1\"\n"
29322 " panel_visibility=\"advanced\">\n"
29323 " <BooleanDomain name=\"bool\" />\n"
29324 " <Documentation>\n"
29325 " Indicate whether to compute the summation of Shepard coefficients. In the\n"
29326 " interior of a SPH point cloud, the Shephard summation value should be ~1.0.\n"
29327 " Towards the boundary, the Shepard summation is less than 1.0. If ComputeShepardSum\n"
29328 " is specified, then the output will contain an array of summed Shepard weights\n"
29329 " for each output point.\n"
29330 " </Documentation>\n"
29331 " </IntVectorProperty>\n"
29332 "\n"
29333 " <StringVectorProperty name=\"ShepardSumArrayName\"\n"
29334 " command=\"SetShepardSumArrayName\"\n"
29335 " number_of_elements=\"1\"\n"
29336 " default_values=\"Shepard Summation\"\n"
29337 " panel_visibility=\"advanced\">\n"
29338 " <Documentation>\n"
29339 " If ComputeShepardSum is on, then an array is generated with name\n"
29340 " ShepardSumArrayName for each input point. This vtkFloatArray is placed\n"
29341 " into the output of the filter, and NullPoints have value =0.0. The\n"
29342 " default name is \"Shepard Summation\".\n"
29343 " </Documentation>\n"
29344 " <Hints>\n"
29345 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
29346 " mode=\"enabled_state\" property=\"ComputeShepardSum\" value=\"1\" />\n"
29347 " </Hints>\n"
29348 " </StringVectorProperty>\n"
29349 "\n"
29350 " <StringVectorProperty name=\"ValidPointsMaskArrayName\"\n"
29351 " command=\"SetValidPointsMaskArrayName\"\n"
29352 " number_of_elements=\"1\"\n"
29353 " default_values=\"vtkValidPointMask\"\n"
29354 " panel_visibility=\"advanced\">\n"
29355 " <Documentation>\n"
29356 " If the NullPointsStrategy is \"Mask Points\", then an array is generated for\n"
29357 " each input point. This vtkCharArray is placed into the output of the filter,\n"
29358 " with a non-zero value for a valid point, and zero otherwise. The name of\n"
29359 " this masking array is specified here.\n"
29360 " </Documentation>\n"
29361 " <Hints>\n"
29362 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
29363 " mode=\"enabled_state\" property=\"NullPointsStrategy\" value=\"0\" />\n"
29364 " </Hints>\n"
29365 " </StringVectorProperty>\n"
29366 "\n"
29367 " <DoubleVectorProperty name=\"NullValue\"\n"
29368 " command=\"SetNullValue\"\n"
29369 " number_of_elements=\"1\"\n"
29370 " default_values=\"0.0\"\n"
29371 " panel_visibility=\"advanced\">\n"
29372 " <DoubleRangeDomain name=\"range\" />\n"
29373 " <Documentation>\n"
29374 " Specify the null point value. When a null point is encountered then all\n"
29375 " components of each null tuple are set to this value. By default the\n"
29376 " null value is set to zero.\n"
29377 " </Documentation>\n"
29378 " </DoubleVectorProperty>\n"
29379 "\n"
29380 " <IntVectorProperty name=\"PassPointArrays\"\n"
29381 " command=\"SetPassPointArrays\"\n"
29382 " number_of_elements=\"1\"\n"
29383 " default_values=\"0\"\n"
29384 " panel_visibility=\"never\">\n"
29385 " <BooleanDomain name=\"bool\" />\n"
29386 " <Documentation>\n"
29387 " Indicate whether to shallow copy the input point data arrays to the output.\n"
29388 " </Documentation>\n"
29389 " </IntVectorProperty>\n"
29390 "\n"
29391 " <IntVectorProperty name=\"PassCellArrays\"\n"
29392 " command=\"SetPassCellArrays\"\n"
29393 " number_of_elements=\"1\"\n"
29394 " default_values=\"0\"\n"
29395 " panel_visibility=\"never\">\n"
29396 " <BooleanDomain name=\"bool\" />\n"
29397 " <Documentation>\n"
29398 " Indicate whether to shallow copy the input cell data arrays to the output.\n"
29399 " </Documentation>\n"
29400 " </IntVectorProperty>\n"
29401 "\n"
29402 " <IntVectorProperty name=\"PassFieldArrays\"\n"
29403 " command=\"SetPassFieldArrays\"\n"
29404 " number_of_elements=\"1\"\n"
29405 " default_values=\"0\"\n"
29406 " panel_visibility=\"never\">\n"
29407 " <BooleanDomain name=\"bool\" />\n"
29408 " <Documentation>\n"
29409 " Indicate whether to shallow copy the input field data arrays to the output.\n"
29410 " </Documentation>\n"
29411 " </IntVectorProperty>\n"
29412 "\n"
29413 " <ProxyProperty name=\"Locator\" command=\"SetLocator\" panel_visibility=\"advanced\">\n"
29414 " <Documentation>\n"
29415 " Specify a point locator.\n"
29416 " </Documentation>\n"
29417 " <ProxyListDomain name=\"proxy_list\">\n"
29418 " <Proxy group=\"point_locators\" name=\"StaticPointLocator\" />\n"
29419 " </ProxyListDomain>\n"
29420 " </ProxyProperty>\n"
29421 " </SourceProxy>\n"
29422 "\n"
29423 " <!-- =================================================================== -->\n"
29424 " <SourceProxy name=\"SPHLineInterpolator\" class=\"vtkSPHInterpolator\"\n"
29425 " label=\"SPH Line Interpolator\"\n"
29426 " multiprocess_support=\"single_process\"\n"
29427 " base_proxygroup=\"filters\"\n"
29428 " base_proxyname=\"SPHInterpolatorBase\">\n"
29429 " <Documentation>\n"
29430 " This filter uses SPH (smooth particle hydrodynamics) kernels to\n"
29431 " interpolate a data source onto an input structure. For example, while the\n"
29432 " data source is a set of particles, the data from these particles can be\n"
29433 " interpolated onto an input line. Then\n"
29434 " the output (which consists of the input structure plus interpolated data)\n"
29435 " can then be visualized using classical visualization techniques such as\n"
29436 " isocontouring, slicing, heat maps and so on.\n"
29437 " </Documentation>\n"
29438 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29439 " <ProxyGroupDomain name=\"groups\">\n"
29440 " <Group name=\"sources\" />\n"
29441 " <Group name=\"filters\" />\n"
29442 " </ProxyGroupDomain>\n"
29443 " <DataTypeDomain name=\"input_type\">\n"
29444 " <DataType value=\"vtkDataSet\" />\n"
29445 " </DataTypeDomain>\n"
29446 " <ProxyListDomain name=\"proxy_list\">\n"
29447 " <Proxy group=\"extended_sources\" name=\"HighResLineSource\" />\n"
29448 " </ProxyListDomain>\n"
29449 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29450 " </InputProperty>\n"
29451 " <Hints>\n"
29452 " <View type=\"XYChartView\" />\n"
29453 " <Plotable />\n"
29454 " </Hints>\n"
29455 " </SourceProxy>\n"
29456 "\n"
29457 " <!-- =================================================================== -->\n"
29458 " <SourceProxy name=\"SPHPlaneInterpolator\" class=\"vtkSPHInterpolator\"\n"
29459 " label=\"SPH Plane Interpolator\"\n"
29460 " multiprocess_support=\"single_process\"\n"
29461 " base_proxygroup=\"filters\"\n"
29462 " base_proxyname=\"SPHInterpolatorBase\">\n"
29463 " <Documentation>\n"
29464 " This filter uses SPH (smooth particle hydrodynamics) kernels to\n"
29465 " interpolate a data source onto an input structure. For example, while the\n"
29466 " data source is a set of particles, the data from these particles can be\n"
29467 " interpolated onto an input plane. Then\n"
29468 " the output (which consists of the input structure plus interpolated data)\n"
29469 " can then be visualized using classical visualization techniques such as\n"
29470 " isocontouring, slicing, heat maps and so on.\n"
29471 " </Documentation>\n"
29472 "\n"
29473 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29474 " <ProxyGroupDomain name=\"groups\">\n"
29475 " <Group name=\"sources\" />\n"
29476 " <Group name=\"filters\" />\n"
29477 " </ProxyGroupDomain>\n"
29478 " <DataTypeDomain name=\"input_type\">\n"
29479 " <DataType value=\"vtkDataSet\" />\n"
29480 " </DataTypeDomain>\n"
29481 " <ProxyListDomain name=\"proxy_list\">\n"
29482 " <Proxy group=\"extended_sources\" name=\"BoundedPlaneSource\" />\n"
29483 " </ProxyListDomain>\n"
29484 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29485 " </InputProperty>\n"
29486 " </SourceProxy>\n"
29487 "\n"
29488 " <!-- =================================================================== -->\n"
29489 " <SourceProxy name=\"SPHVolumeInterpolator\" class=\"vtkSPHInterpolator\"\n"
29490 " label=\"SPH Volume Interpolator\"\n"
29491 " multiprocess_support=\"single_process\"\n"
29492 " base_proxygroup=\"filters\"\n"
29493 " base_proxyname=\"SPHInterpolatorBase\">\n"
29494 " <Documentation>\n"
29495 " This filter uses SPH (smooth particle hydrodynamics) kernels to\n"
29496 " interpolate a data source onto an input structure. For example, while the\n"
29497 " data source is a set of particles, the data from these particles can be\n"
29498 " interpolated onto an input volume. Then\n"
29499 " the output (which consists of the input structure plus interpolated data)\n"
29500 " can then be visualized using classical visualization techniques such as\n"
29501 " isocontouring, slicing, heat maps and so on.\n"
29502 " </Documentation>\n"
29503 "\n"
29504 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29505 " <ProxyGroupDomain name=\"groups\">\n"
29506 " <Group name=\"sources\" />\n"
29507 " <Group name=\"filters\" />\n"
29508 " </ProxyGroupDomain>\n"
29509 " <DataTypeDomain name=\"input_type\">\n"
29510 " <DataType value=\"vtkDataSet\" />\n"
29511 " </DataTypeDomain>\n"
29512 " <ProxyListDomain name=\"proxy_list\">\n"
29513 " <Proxy group=\"extended_sources\" name=\"BoundedVolumeSource\" />\n"
29514 " </ProxyListDomain>\n"
29515 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29516 " </InputProperty>\n"
29517 " </SourceProxy>\n"
29518 "\n"
29519 " <!-- =================================================================== -->\n"
29520 " <SourceProxy name=\"SPHDatasetInterpolator\" class=\"vtkSPHInterpolator\"\n"
29521 " label=\"SPH Dataset Interpolator\"\n"
29522 " multiprocess_support=\"single_process\"\n"
29523 " base_proxygroup=\"filters\"\n"
29524 " base_proxyname=\"SPHInterpolatorBase\">\n"
29525 " <Documentation>\n"
29526 " This filter uses SPH (smooth particle hydrodynamics) kernels to\n"
29527 " interpolate a data source onto an input structure. For example, while the\n"
29528 " data source is a set of particles, the data from these particles can be\n"
29529 " interpolated onto an input volume. Then\n"
29530 " the output (which consists of the input structure plus interpolated data)\n"
29531 " can then be visualized using classical visualization techniques such as\n"
29532 " isocontouring, slicing, heat maps and so on.\n"
29533 " </Documentation>\n"
29534 "\n"
29535 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29536 " <ProxyGroupDomain name=\"groups\">\n"
29537 " <Group name=\"sources\" />\n"
29538 " <Group name=\"filters\" />\n"
29539 " </ProxyGroupDomain>\n"
29540 " <DataTypeDomain name=\"input_type\">\n"
29541 " <DataType value=\"vtkDataSet\" />\n"
29542 " </DataTypeDomain>\n"
29543 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29544 " </InputProperty>\n"
29545 "\n"
29546 " <StringVectorProperty name=\"CutoffArray\"\n"
29547 " command=\"SetCutoffArrayName\"\n"
29548 " number_of_elements=\"1\">\n"
29549 " <Documentation>\n"
29550 " Specify the Cutoff array name. If not specified, then the radius at each point\n"
29551 " will be computed as cutoff factor * smoothing length at a each point.\n"
29552 " </Documentation>\n"
29553 " <ArrayListDomain attribute_type=\"Scalars\" name=\"array_list\" none_string=\"None\"\n"
29554 " input_domain_name=\"point_scalars\">\n"
29555 " <RequiredProperties>\n"
29556 " <Property function=\"Input\" name=\"Source\" />\n"
29557 " </RequiredProperties>\n"
29558 " </ArrayListDomain>\n"
29559 " </StringVectorProperty>\n"
29560 " </SourceProxy>\n"
29561 "\n"
29562 " <!-- =================================================================== -->\n"
29563 " <SourceProxy name=\"PointInterpolatorBase\" class=\"vtkPointInterpolator\"\n"
29564 " label=\"Point Interpolator\"\n"
29565 " multiprocess_support=\"single_process\">\n"
29566 " <Documentation>\n"
29567 " This probes a point cloud `PC` on the *Input* with a\n"
29568 " set of points `P` (the filter *Source*), interpolating the data values from `PC`\n"
29569 " onto `P`. Note however that the descriptive phrase \"point cloud\" is a\n"
29570 " misnomer: PC can be represented by any dataset type, with the points of\n"
29571 " the dataset forming PC. Similarly, the output P can also be represented by\n"
29572 " any vtkDataSet type; and the topology/geometry structure of P is passed\n"
29573 " through to the output along with the newly interpolated arrays.\n"
29574 " </Documentation>\n"
29575 "\n"
29576 " <InputProperty command=\"SetInputConnection\"\n"
29577 " name=\"Input\"\n"
29578 " port_index=\"1\">\n"
29579 " <ProxyGroupDomain name=\"groups\">\n"
29580 " <Group name=\"sources\" />\n"
29581 " <Group name=\"filters\" />\n"
29582 " </ProxyGroupDomain>\n"
29583 " <DataTypeDomain name=\"input_type\">\n"
29584 " <DataType value=\"vtkPointSet\" />\n"
29585 " </DataTypeDomain>\n"
29586 " <InputArrayDomain attribute_type=\"point\" name=\"point_scalars\" number_of_components=\"1\" />\n"
29587 " <InputArrayDomain attribute_type=\"point\" name=\"point_arrays\" />\n"
29588 " <Documentation>The data source to be interpolated onto the *Source*.</Documentation>\n"
29589 " </InputProperty>\n"
29590 "\n"
29591 " <ProxyProperty name=\"Kernel\" command=\"SetKernel\">\n"
29592 " <Documentation>\n"
29593 " Specify an interpolation kernel. By default a vtkVoronoiKernel is used\n"
29594 " (i.e., closest point). The interpolation kernel changes the basis of the\n"
29595 " interpolation.\n"
29596 " </Documentation>\n"
29597 " <ProxyListDomain name=\"proxy_list\">\n"
29598 " <Group name=\"generic_point_interpolation_kernels\" default=\"VoronoiKernel\" />\n"
29599 " </ProxyListDomain>\n"
29600 " </ProxyProperty>\n"
29601 "\n"
29602 " <IntVectorProperty name=\"NullPointsStrategy\"\n"
29603 " command=\"SetNullPointsStrategy\"\n"
29604 " number_of_elements=\"1\"\n"
29605 " default_values=\"1\"\n"
29606 " panel_visibility=\"advanced\">\n"
29607 " <EnumerationDomain name=\"enum\">\n"
29608 " <Entry text=\"Mask Points\" value=\"0\" />\n"
29609 " <Entry text=\"Null Value\" value=\"1\" />\n"
29610 " <Entry text=\"Closest Point\" value=\"2\" />\n"
29611 " </EnumerationDomain>\n"
29612 " <Documentation>\n"
29613 " Specify a strategy to use when encountering a \"null\" point during the\n"
29614 " interpolation process. Null points occur when the local neighborhood (of\n"
29615 " nearby points to interpolate from) is empty. If the strategy is set to\n"
29616 " MaskPoints, then an output array is created that marks points as being\n"
29617 ;
29618
29619 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/Points/Resources/points.xml
29621 " valid (=1) or null (invalid =0) (and the NullValue is set as well). If\n"
29622 " the strategy is set to NullValue, then the output data value(s) are set\n"
29623 " to the NullPoint value (specified in the output point data). Finally,\n"
29624 " the default strategy ClosestPoint is to simply use the closest point to\n"
29625 " perform the interpolation.\n"
29626 " </Documentation>\n"
29627 " </IntVectorProperty>\n"
29628 "\n"
29629 " <StringVectorProperty name=\"ValidPointsMaskArrayName\"\n"
29630 " command=\"SetValidPointsMaskArrayName\"\n"
29631 " number_of_elements=\"1\"\n"
29632 " default_values=\"vtkValidPointMask\"\n"
29633 " panel_visibility=\"advanced\">\n"
29634 " <Documentation>\n"
29635 " If the NullPointsStrategy is \"Mask Points\", then an array is generated for\n"
29636 " each input point. This vtkCharArray is placed into the output of the filter,\n"
29637 " with a non-zero value for a valid point, and zero otherwise. The name of\n"
29638 " this masking array is specified here.\n"
29639 " </Documentation>\n"
29640 " <Hints>\n"
29641 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
29642 " mode=\"enabled_state\" property=\"NullPointsStrategy\" value=\"0\" />\n"
29643 " </Hints>\n"
29644 " </StringVectorProperty>\n"
29645 "\n"
29646 " <DoubleVectorProperty name=\"NullValue\"\n"
29647 " command=\"SetNullValue\"\n"
29648 " number_of_elements=\"1\"\n"
29649 " default_values=\"0.0\"\n"
29650 " panel_visibility=\"advanced\">\n"
29651 " <DoubleRangeDomain name=\"range\" />\n"
29652 " <Documentation>\n"
29653 " Specify the null point value. When a null point is encountered then all\n"
29654 " components of each null tuple are set to this value. By default the\n"
29655 " null value is set to zero.\n"
29656 " </Documentation>\n"
29657 " </DoubleVectorProperty>\n"
29658 "\n"
29659 " <IntVectorProperty name=\"PassPointArrays\"\n"
29660 " command=\"SetPassPointArrays\"\n"
29661 " number_of_elements=\"1\"\n"
29662 " default_values=\"0\"\n"
29663 " panel_visibility=\"never\">\n"
29664 " <BooleanDomain name=\"bool\" />\n"
29665 " <Documentation>\n"
29666 " Indicate whether to shallow copy the input point data arrays to the output.\n"
29667 " </Documentation>\n"
29668 " </IntVectorProperty>\n"
29669 "\n"
29670 " <IntVectorProperty name=\"PassCellArrays\"\n"
29671 " command=\"SetPassCellArrays\"\n"
29672 " number_of_elements=\"1\"\n"
29673 " default_values=\"0\"\n"
29674 " panel_visibility=\"never\">\n"
29675 " <BooleanDomain name=\"bool\" />\n"
29676 " <Documentation>\n"
29677 " Indicate whether to shallow copy the input cell data arrays to the output.\n"
29678 " </Documentation>\n"
29679 " </IntVectorProperty>\n"
29680 "\n"
29681 " <IntVectorProperty name=\"PassFieldArrays\"\n"
29682 " command=\"SetPassFieldArrays\"\n"
29683 " number_of_elements=\"1\"\n"
29684 " default_values=\"0\"\n"
29685 " panel_visibility=\"never\">\n"
29686 " <BooleanDomain name=\"bool\" />\n"
29687 " <Documentation>\n"
29688 " Indicate whether to shallow copy the input field data arrays to the output.\n"
29689 " </Documentation>\n"
29690 " </IntVectorProperty>\n"
29691 "\n"
29692 " <ProxyProperty name=\"Locator\" command=\"SetLocator\" panel_visibility=\"advanced\">\n"
29693 " <Documentation>\n"
29694 " Specify a point locator.\n"
29695 " </Documentation>\n"
29696 " <ProxyListDomain name=\"proxy_list\">\n"
29697 " <Proxy group=\"point_locators\" name=\"StaticPointLocator\" />\n"
29698 " </ProxyListDomain>\n"
29699 " </ProxyProperty>\n"
29700 " </SourceProxy>\n"
29701 "\n"
29702 " <!-- =================================================================== -->\n"
29703 " <SourceProxy name=\"PointLineInterpolator\" class=\"vtkPointInterpolator\"\n"
29704 " label=\"Point Line Interpolator\"\n"
29705 " multiprocess_support=\"single_process\"\n"
29706 " base_proxygroup=\"filters\"\n"
29707 " base_proxyname=\"PointInterpolatorBase\">\n"
29708 " <Documentation>\n"
29709 " This probes a point cloud `PC` on the *Input* with a\n"
29710 " set of points `P` (the filter *Source*), interpolating the data values from `PC`\n"
29711 " onto `P`. Note however that the descriptive phrase \"point cloud\" is a\n"
29712 " misnomer: PC can be represented by any dataset type, with the points of\n"
29713 " the dataset forming PC. Similarly, the output P can also be represented by\n"
29714 " any vtkDataSet type; and the topology/geometry structure of P is passed\n"
29715 " through to the output along with the newly interpolated arrays.\n"
29716 " </Documentation>\n"
29717 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29718 " <ProxyGroupDomain name=\"groups\">\n"
29719 " <Group name=\"sources\" />\n"
29720 " <Group name=\"filters\" />\n"
29721 " </ProxyGroupDomain>\n"
29722 " <DataTypeDomain name=\"input_type\">\n"
29723 " <DataType value=\"vtkDataSet\" />\n"
29724 " </DataTypeDomain>\n"
29725 " <ProxyListDomain name=\"proxy_list\">\n"
29726 " <Proxy group=\"extended_sources\" name=\"HighResLineSource\" />\n"
29727 " </ProxyListDomain>\n"
29728 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29729 " </InputProperty>\n"
29730 " <Hints>\n"
29731 " <View type=\"XYChartView\" />\n"
29732 " <Plotable />\n"
29733 " </Hints>\n"
29734 " </SourceProxy>\n"
29735 "\n"
29736 " <!-- =================================================================== -->\n"
29737 " <SourceProxy name=\"PointPlaneInterpolator\" class=\"vtkPointInterpolator\"\n"
29738 " label=\"Point Plane Interpolator\"\n"
29739 " multiprocess_support=\"single_process\"\n"
29740 " base_proxygroup=\"filters\"\n"
29741 " base_proxyname=\"PointInterpolatorBase\">\n"
29742 " <Documentation>\n"
29743 " This probes a point cloud `PC` on the *Input* with a\n"
29744 " set of points `P` (the filter *Source*), interpolating the data values from `PC`\n"
29745 " onto `P`. Note however that the descriptive phrase \"point cloud\" is a\n"
29746 " misnomer: PC can be represented by any dataset type, with the points of\n"
29747 " the dataset forming PC. Similarly, the output P can also be represented by\n"
29748 " any vtkDataSet type; and the topology/geometry structure of P is passed\n"
29749 " through to the output along with the newly interpolated arrays.\n"
29750 " </Documentation>\n"
29751 "\n"
29752 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29753 " <ProxyGroupDomain name=\"groups\">\n"
29754 " <Group name=\"sources\" />\n"
29755 " <Group name=\"filters\" />\n"
29756 " </ProxyGroupDomain>\n"
29757 " <DataTypeDomain name=\"input_type\">\n"
29758 " <DataType value=\"vtkDataSet\" />\n"
29759 " </DataTypeDomain>\n"
29760 " <ProxyListDomain name=\"proxy_list\">\n"
29761 " <Proxy group=\"extended_sources\" name=\"BoundedPlaneSource\" />\n"
29762 " </ProxyListDomain>\n"
29763 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29764 " </InputProperty>\n"
29765 " </SourceProxy>\n"
29766 "\n"
29767 " <!-- =================================================================== -->\n"
29768 " <SourceProxy name=\"PointVolumeInterpolator\" class=\"vtkPointInterpolator\"\n"
29769 " label=\"Point Volume Interpolator\"\n"
29770 " multiprocess_support=\"single_process\"\n"
29771 " base_proxygroup=\"filters\"\n"
29772 " base_proxyname=\"PointInterpolatorBase\">\n"
29773 " <Documentation>\n"
29774 " This probes a point cloud `PC` on the *Input* with a\n"
29775 " set of points `P` (the filter *Source*), interpolating the data values from `PC`\n"
29776 " onto `P`. Note however that the descriptive phrase \"point cloud\" is a\n"
29777 " misnomer: PC can be represented by any dataset type, with the points of\n"
29778 " the dataset forming PC. Similarly, the output P can also be represented by\n"
29779 " any vtkDataSet type; and the topology/geometry structure of P is passed\n"
29780 " through to the output along with the newly interpolated arrays.\n"
29781 " </Documentation>\n"
29782 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29783 " <ProxyGroupDomain name=\"groups\">\n"
29784 " <Group name=\"sources\" />\n"
29785 " <Group name=\"filters\" />\n"
29786 " </ProxyGroupDomain>\n"
29787 " <DataTypeDomain name=\"input_type\">\n"
29788 " <DataType value=\"vtkDataSet\" />\n"
29789 " </DataTypeDomain>\n"
29790 " <ProxyListDomain name=\"proxy_list\">\n"
29791 " <Proxy group=\"extended_sources\" name=\"BoundedVolumeSource\" />\n"
29792 " </ProxyListDomain>\n"
29793 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29794 " </InputProperty>\n"
29795 " </SourceProxy>\n"
29796 "\n"
29797 " <!-- =================================================================== -->\n"
29798 " <SourceProxy name=\"PointDatasetInterpolator\" class=\"vtkPointInterpolator\"\n"
29799 " label=\"Point Dataset Interpolator\"\n"
29800 " multiprocess_support=\"single_process\"\n"
29801 " base_proxygroup=\"filters\"\n"
29802 " base_proxyname=\"PointInterpolatorBase\">\n"
29803 " <Documentation>\n"
29804 " This probes a point cloud `PC` on the *Input* with a\n"
29805 " set of points `P` (the filter *Source*), interpolating the data values from `PC`\n"
29806 " onto `P`. Note however that the descriptive phrase \"point cloud\" is a\n"
29807 " misnomer: PC can be represented by any dataset type, with the points of\n"
29808 " the dataset forming PC. Similarly, the output P can also be represented by\n"
29809 " any vtkDataSet type; and the topology/geometry structure of P is passed\n"
29810 " through to the output along with the newly interpolated arrays.\n"
29811 " </Documentation>\n"
29812 " <InputProperty command=\"SetInputConnection\" name=\"Source\" port_index=\"0\">\n"
29813 " <ProxyGroupDomain name=\"groups\">\n"
29814 " <Group name=\"sources\" />\n"
29815 " <Group name=\"filters\" />\n"
29816 " </ProxyGroupDomain>\n"
29817 " <DataTypeDomain name=\"input_type\">\n"
29818 " <DataType value=\"vtkDataSet\" />\n"
29819 " </DataTypeDomain>\n"
29820 " <Documentation>The data source that provides the structure to be interpolated on.</Documentation>\n"
29821 " </InputProperty>\n"
29822 " </SourceProxy>\n"
29823 " </ProxyGroup>\n"
29824 "</ServerManagerConfiguration>\n"
29825 "\n";
29826 // Get single string
29828 {
29829
29830  const size_t len0 = strlen(paraview_server_managerpointsInterface0);
29831  const size_t len1 = strlen(paraview_server_managerpointsInterface1);
29832  const size_t len2 = strlen(paraview_server_managerpointsInterface2);
29833  const size_t len3 = strlen(paraview_server_managerpointsInterface3);
29834  size_t len = ( 0
29835  + len0
29836  + len1
29837  + len2
29838  + len3 );
29839  char* res = new char[ len + 1];
29840  size_t offset = 0;
29841  std::copy(paraview_server_managerpointsInterface0, paraview_server_managerpointsInterface0 + len0, res + offset); offset += len0;
29842  std::copy(paraview_server_managerpointsInterface1, paraview_server_managerpointsInterface1 + len1, res + offset); offset += len1;
29843  std::copy(paraview_server_managerpointsInterface2, paraview_server_managerpointsInterface2 + len2, res + offset); offset += len2;
29844  std::copy(paraview_server_managerpointsInterface3, paraview_server_managerpointsInterface3 + len3, res + offset); offset += len3;
29845  assert(offset == len);
29846  res[offset] = 0;
29847  return res;
29848 }
29849
29850
29851 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/Resources/filters_pv_iocore.xml
29853 "<ServerManagerConfiguration>\n"
29854 " <ProxyGroup name=\"filters\">\n"
29855 " <!-- ==================================================================== -->\n"
29856 " <SourceProxy class=\"vtkAdditionalFieldReader\"\n"
29857 " label=\"Field Arrays From File\"\n"
29858 " name=\"FieldArraysFromFile\">\n"
29859 " <Documentation long_help=\"Reads arrays from a file and adds them to the input data object.\"\n"
29860 " short_help=\"Adds arrays to a data object.\">\n"
29861 " Takes in an input data object and a filename. Opens the file\n"
29862 " and adds any arrays it sees there to the input data.\n"
29863 " </Documentation>\n"
29864 " <InputProperty command=\"SetInputConnection\"\n"
29865 " name=\"Input\">\n"
29866 " <ProxyGroupDomain name=\"groups\">\n"
29867 " <Group name=\"sources\" />\n"
29868 " <Group name=\"filters\" />\n"
29869 " </ProxyGroupDomain>\n"
29870 " <Documentation>The input.</Documentation>\n"
29871 " </InputProperty>\n"
29872 " <StringVectorProperty animateable=\"0\"\n"
29873 " command=\"SetFileName\"\n"
29874 " name=\"FileName\"\n"
29875 " number_of_elements=\"1\"\n"
29876 " panel_visibility=\"default\">\n"
29877 " <FileListDomain name=\"files\" />\n"
29878 " <Documentation>\n"
29879 " This property specifies the file to read to get arrays\n"
29880 " </Documentation>\n"
29881 " </StringVectorProperty>\n"
29882 " <Property command=\"Modified\"\n"
29883 " label=\"Reload\"\n"
29884 " name=\"Reload\"\n"
29885 " panel_widget=\"command_button\"\n"
29886 " panel_visibility=\"default\">\n"
29887 " <Documentation> A convenient way to reload the data file </Documentation>\n"
29888 " </Property>\n"
29889 " <!-- End of AdditionalFieldReader -->\n"
29890 " </SourceProxy>\n"
29891 "\n"
29892 " <SourceProxy name=\"AddFieldArrays\"\n"
29893 " class=\"vtkAdditionalFieldReader\"\n"
29894 " base_proxyname=\"FieldArraysFromFile\"\n"
29895 " base_proxygroup=\"filters\">\n"
29896 " <Deprecated deprecated_in=\"5.13\" to_remove_in=\"5.14\">\n"
29897 " This has been renamed into 'FieldArrayFromFile'. Please consider using that instead.\n"
29898 " </Deprecated>\n"
29899 " </SourceProxy>\n"
29900 " </ProxyGroup>\n"
29901 "</ServerManagerConfiguration>\n"
29902 "\n";
29903 // Get single string
29905 {
29906
29907  const size_t len0 = strlen(paraview_server_managerfilters_pv_iocoreInterface0);
29908  size_t len = ( 0
29909  + len0 );
29910  char* res = new char[ len + 1];
29911  size_t offset = 0;
29913  assert(offset == len);
29914  res[offset] = 0;
29915  return res;
29916 }
29917
29918
29919 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/Resources/readers_pv_iocore.xml
29921 "<ServerManagerConfiguration>\n"
29922 " <ProxyGroup name=\"internal_sources\">\n"
29923 " <SourceProxy class=\"vtkStringReader\"\n"
29924 " label=\"String Reader\"\n"
29925 " name=\"StringReader\">\n"
29926 " <Documentation long_help=\"Reads a string from a file.\"\n"
29927 " short_help=\"Reads a string from a file.\">\n"
29928 " This reader reads a string from a file.\n"
29929 " </Documentation>\n"
29930 " <StringVectorProperty animateable=\"0\"\n"
29931 " command=\"SetFileName\"\n"
29932 " name=\"FileName\"\n"
29933 " number_of_elements=\"1\"\n"
29934 " panel_visibility=\"never\">\n"
29935 " <FileListDomain name=\"files\"/>\n"
29936 " <Documentation>\n"
29937 " This property specifies the file name to read.\n"
29938 " </Documentation>\n"
29939 " </StringVectorProperty>\n"
29940 " <StringVectorProperty name=\"String\"\n"
29941 " command=\"GetString\"\n"
29942 " information_only=\"1\">\n"
29943 " <Documentation>\n"
29944 " This property specifies the read string.\n"
29945 " </Documentation>\n"
29946 " <SimpleStringInformationHelper/>\n"
29947 " </StringVectorProperty>\n"
29948 " <Hints>\n"
29949 " <ReaderFactory extensions=\"txt\"\n"
29950 " file_description=\"Text File\"/>\n"
29951 " </Hints>\n"
29952 " </SourceProxy>\n"
29953 " <!-- End of StringReader -->\n"
29954 " </ProxyGroup>\n"
29955 " <ProxyGroup name=\"sources\">\n"
29956 " <!-- ================================================================== -->\n"
29957 " <SourceProxy class=\"vtkPVDReader\"\n"
29958 " label=\"PVD Reader\"\n"
29959 " name=\"PVDReader\">\n"
29960 " <Documentation long_help=\"Load a dataset stored in ParaView's PVD file format.\"\n"
29961 " short_help=\"Read a PVD file.\">The PVD reader reads data\n"
29962 " stored in ParaView's PVD file format. The .pvd file is\n"
29963 " essentially a header file that collects together other\n"
29964 " data files stored in VTK's XML-based file\n"
29965 " format.</Documentation>\n"
29966 " <StringVectorProperty animateable=\"0\"\n"
29967 " command=\"SetFileName\"\n"
29968 " name=\"FileName\"\n"
29969 " number_of_elements=\"1\"\n"
29970 " panel_visibility=\"never\">\n"
29971 " <FileListDomain name=\"files\" />\n"
29972 " <Documentation>This property specifies the file name for the PVD\n"
29973 " reader.</Documentation>\n"
29974 " </StringVectorProperty>\n"
29975 " <DoubleVectorProperty information_only=\"1\"\n"
29976 " name=\"TimestepValues\"\n"
29977 " repeatable=\"1\">\n"
29978 " <TimeStepsInformationHelper />\n"
29979 " <Documentation>Available timestep values.</Documentation>\n"
29980 " </DoubleVectorProperty>\n"
29981 "\n"
29982 " <!-- Array Selection GUI Component -->\n"
29983 " <StringVectorProperty information_only=\"1\"\n"
29984 " name=\"CellArrayInfo\">\n"
29985 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
29986 " </StringVectorProperty>\n"
29987 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
29988 " element_types=\"2 0\"\n"
29989 " information_property=\"CellArrayInfo\"\n"
29990 " label=\"Cell Arrays\"\n"
29991 " name=\"CellArrayStatus\"\n"
29992 " number_of_elements=\"0\"\n"
29993 " number_of_elements_per_command=\"2\"\n"
29994 " repeat_command=\"1\">\n"
29995 " <ArraySelectionDomain name=\"array_list\">\n"
29996 " <RequiredProperties>\n"
29997 " <Property function=\"ArrayList\"\n"
29998 " name=\"CellArrayInfo\" />\n"
29999 " </RequiredProperties>\n"
30000 " </ArraySelectionDomain>\n"
30001 " <Documentation>This property lists which cell-centered arrays to\n"
30002 " read.</Documentation>\n"
30003 " </StringVectorProperty>\n"
30004 " <StringVectorProperty information_only=\"1\"\n"
30005 " name=\"PointArrayInfo\">\n"
30006 " <ArraySelectionInformationHelper attribute_name=\"Point\" />\n"
30007 " </StringVectorProperty>\n"
30008 " <StringVectorProperty command=\"SetPointArrayStatus\"\n"
30009 " element_types=\"2 0\"\n"
30010 " information_property=\"PointArrayInfo\"\n"
30011 " label=\"PointArrays\"\n"
30012 " name=\"PointArrayStatus\"\n"
30013 " number_of_elements=\"0\"\n"
30014 " number_of_elements_per_command=\"2\"\n"
30015 " repeat_command=\"1\">\n"
30016 " <ArraySelectionDomain name=\"array_list\">\n"
30017 " <RequiredProperties>\n"
30018 " <Property function=\"ArrayList\"\n"
30019 " name=\"PointArrayInfo\" />\n"
30020 " </RequiredProperties>\n"
30021 " </ArraySelectionDomain>\n"
30022 " <Documentation>This property lists which point-centered arrays to\n"
30023 " read.</Documentation>\n"
30024 " </StringVectorProperty>\n"
30025 " <StringVectorProperty information_only=\"1\"\n"
30026 " name=\"ColumnArrayInfo\">\n"
30027 " <ArraySelectionInformationHelper attribute_name=\"Column\" />\n"
30028 " </StringVectorProperty>\n"
30029 " <StringVectorProperty command=\"SetColumnArrayStatus\"\n"
30030 " element_types=\"2 0\"\n"
30031 " information_property=\"ColumnArrayInfo\"\n"
30032 " label=\"Column Arrays\"\n"
30033 " name=\"ColumnArrayStatus\"\n"
30034 " number_of_elements=\"0\"\n"
30035 " number_of_elements_per_command=\"2\"\n"
30036 " repeat_command=\"1\">\n"
30037 " <ArraySelectionDomain name=\"array_list\">\n"
30038 " <RequiredProperties>\n"
30039 " <Property function=\"ArrayList\"\n"
30040 " name=\"ColumnArrayInfo\" />\n"
30041 " </RequiredProperties>\n"
30042 " </ArraySelectionDomain>\n"
30043 " <Documentation>This property lists which columns to\n"
30044 " read.</Documentation>\n"
30045 " </StringVectorProperty>\n"
30046 " <PropertyGroup label=\"Point/Cell/Column Array Status\"\n"
30047 " name=\"ArrayStatus\"\n"
30048 " panel_visibility=\"default\"\n"
30049 " panel_widget=\"ArrayStatus\">\n"
30050 " <Property name=\"CellArrayInfo\" />\n"
30051 " <Property name=\"CellArrayStatus\" />\n"
30052 " <Property name=\"PointArrayInfo\" />\n"
30053 " <Property name=\"PointArrayStatus\" />\n"
30054 " <Property name=\"ColumnArrayInfo\" />\n"
30055 " <Property name=\"ColumnArrayStatus\" />\n"
30056 " </PropertyGroup>\n"
30057 " <Hints>\n"
30058 " <ReaderFactory extensions=\"pvd\"\n"
30059 " file_description=\"ParaView Data Files\" />\n"
30060 " </Hints>\n"
30061 " <!-- End PVDReader -->\n"
30062 " </SourceProxy>\n"
30063 "\n"
30064 "\n"
30065 " <!-- ================================================================== -->\n"
30066 "\n"
30067 " </ProxyGroup>\n"
30068 "</ServerManagerConfiguration>\n"
30069 "\n";
30070 // Get single string
30072 {
30073
30074  const size_t len0 = strlen(paraview_server_managerreaders_pv_iocoreInterface0);
30075  size_t len = ( 0
30076  + len0 );
30077  char* res = new char[ len + 1];
30078  size_t offset = 0;
30080  assert(offset == len);
30081  res[offset] = 0;
30082  return res;
30083 }
30084
30085
30086 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/Resources/writers_pv_iocore.xml
30088 "<ServerManagerConfiguration>\n"
30089 " <ProxyGroup name=\"writers\">\n"
30090 " <!-- ================================================================= -->\n"
30091 " <PWriterProxy base_proxygroup=\"internal_writers\"\n"
30092 " base_proxyname=\"ParallelWriterBase\"\n"
30093 " class=\"vtkXMLPVDWriter\"\n"
30094 " name=\"XMLPVDWriter\">\n"
30095 " <Documentation short_help=\"Write ParaView data files (pvd).\">\n"
30096 " Writer to write ParaView data files (pvd). It is used to save all pieces\n"
30097 " of a source/filter to a file with pieces spread across the server processes.\n"
30098 " </Documentation>\n"
30099 " <InputProperty command=\"SetInputConnection\"\n"
30100 " name=\"Input\">\n"
30101 " <DataTypeDomain composite_data_supported=\"0\"\n"
30102 " name=\"input_type\">\n"
30103 " <DataType value=\"vtkDataSet\"/>\n"
30104 " <DataType value=\"vtkTable\"/>\n"
30105 " </DataTypeDomain>\n"
30106 " <Documentation>\n"
30107 " The input filter/source whose output dataset is written to the files.\n"
30108 " </Documentation>\n"
30109 " </InputProperty>\n"
30110 " <IntVectorProperty command=\"SetHeaderType\"\n"
30111 " default_values=\"64\"\n"
30112 " name=\"HeaderType\"\n"
30113 " number_of_elements=\"1\">\n"
30114 " <EnumerationDomain name=\"enum\">\n"
30115 " <Entry text=\"UInt32\" value=\"32\"/>\n"
30116 " <Entry text=\"UInt64\" value=\"64\"/>\n"
30117 " </EnumerationDomain>\n"
30118 " <Documentation>\n"
30119 " Set the binary data header word type. The default is UInt32. Set to UInt64\n"
30120 " when storing arrays requiring 64-bit indexing.\n"
30121 " </Documentation>\n"
30122 " </IntVectorProperty>\n"
30123 " <IntVectorProperty command=\"SetDataMode\"\n"
30124 " default_values=\"2\"\n"
30125 " name=\"DataMode\"\n"
30126 " number_of_elements=\"1\">\n"
30127 " <EnumerationDomain name=\"enum\">\n"
30128 " <Entry text=\"Ascii\"\n"
30129 " value=\"0\"/>\n"
30130 " <Entry text=\"Binary\"\n"
30131 " value=\"1\"/>\n"
30132 " <Entry text=\"Appended\"\n"
30133 " value=\"2\"/>\n"
30134 " </EnumerationDomain>\n"
30135 " <Documentation>\n"
30136 " The mode uses for writing the file's data i.e. ascii, binary, appended binary.\n"
30137 " </Documentation>\n"
30138 " </IntVectorProperty>\n"
30139 " <IntVectorProperty command=\"SetEncodeAppendedData\"\n"
30140 " default_values=\"0\"\n"
30141 " name=\"EncodeAppendedData\"\n"
30142 " number_of_elements=\"1\">\n"
30143 " <BooleanDomain name=\"bool\"/>\n"
30144 " <Documentation>\n"
30145 " When EncodeAppendedData is turned ON, the writer uses base64 encoding\n"
30146 " when writing binary data (only if appended mode is selected).\n"
30147 " </Documentation>\n"
30148 " </IntVectorProperty>\n"
30149 " <IntVectorProperty command=\"SetCompressorType\"\n"
30150 " default_values=\"0\"\n"
30151 " name=\"CompressorType\"\n"
30152 " number_of_elements=\"1\">\n"
30153 " <EnumerationDomain name=\"enum\">\n"
30154 " <Entry text=\"None\"\n"
30155 " value=\"0\"\n"
30156 " info=\"fastest write\"/>\n"
30157 " <Entry text=\"LZ4\"\n"
30158 " value=\"2\"\n"
30159 " info=\"fastest compressed write\"/>\n"
30160 " <Entry text=\"ZLib\"\n"
30161 " value=\"1\"\n"
30162 " info=\"balanced performance\"/>\n"
30163 " <Entry text=\"LZMA\"\n"
30164 " value=\"3\"\n"
30165 " info=\"smallest filesize\"/>\n"
30166 " </EnumerationDomain>\n"
30167 " <Documentation>\n"
30168 " The compression algorithm used to compress binary data\n"
30169 " (appended mode only). None offers fastest write, LZ4 offers the fastest\n"
30170 " compressed write, ZLib offers balanced performance, LZMA offers\n"
30171 " smallest compressed filesize.\n"
30172 " </Documentation>\n"
30173 " </IntVectorProperty>\n"
30174 " <IntVectorProperty command=\"SetCompressionLevel\"\n"
30175 " default_values=\"6\"\n"
30176 " name=\"CompressionLevel\"\n"
30177 " number_of_elements=\"1\">\n"
30178 " <EnumerationDomain name=\"enum\">\n"
30179 " <Entry text=\"1\"\n"
30180 " value=\"1\"\n"
30181 " info=\"fastest write\"/>\n"
30182 " <Entry text=\"2\"\n"
30183 " value=\"2\"/>\n"
30184 " <Entry text=\"3\"\n"
30185 " value=\"3\"/>\n"
30186 " <Entry text=\"4\"\n"
30187 " value=\"4\"/>\n"
30188 " <Entry text=\"5\"\n"
30189 " value=\"5\"\n"
30190 " info=\"balanced performance\"/>\n"
30191 " <Entry text=\"6\"\n"
30192 " value=\"6\"/>\n"
30193 " <Entry text=\"7\"\n"
30194 " value=\"7\"/>\n"
30195 " <Entry text=\"8\"\n"
30196 " value=\"8\"/>\n"
30197 " <Entry text=\"9\"\n"
30198 " value=\"9\"\n"
30199 " info=\"smallest filesize\"/>\n"
30200 " </EnumerationDomain>\n"
30201 " <Documentation>\n"
30202 " A compression performance parameter from 1 (faster/larger\n"
30203 " compressed filesize) to 9 (slower/smaller compressed filesize).\n"
30204 " </Documentation>\n"
30205 " <Hints>\n"
30206 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
30207 " mode=\"enabled_state\"\n"
30208 " property=\"CompressorType\"\n"
30209 " value=\"0\"\n"
30210 " inverse=\"1\"/>\n"
30211 " </Hints>\n"
30212 " </IntVectorProperty>\n"
30213 " <IntVectorProperty command=\"SetWriteAllTimeSteps\"\n"
30214 " default_values=\"0\"\n"
30215 " name=\"WriteTimeSteps\"\n"
30216 " number_of_elements=\"1\">\n"
30217 " <BooleanDomain name=\"bool\"/>\n"
30218 " <Documentation>\n"
30219 " When WriteTimeSteps is turned ON, the writer is\n"
30220 " executed once for each timestep available from its input.\n"
30221 " </Documentation>\n"
30222 " </IntVectorProperty>\n"
30223 " <Hints>\n"
30224 " <Property name=\"Input\"\n"
30225 " show=\"0\"/>\n"
30226 " <Property name=\"FileName\"\n"
30227 " show=\"0\"/>\n"
30228 " <Property name=\"HeaderType\"\n"
30229 " show=\"0\"/>\n"
30230 " <Property name=\"UseSubdirectory\"\n"
30231 " show=\"1\"/>\n"
30232 " <Property name=\"WriteAllTimeSteps\"\n"
30233 " show=\"1\"/>\n"
30234 " <WriterFactory extensions=\"pvd\"\n"
30235 " file_description=\"ParaView Data Files\"/>\n"
30236 " </Hints>\n"
30237 " <!-- End of XMLPVDWriter -->\n"
30238 " </PWriterProxy>\n"
30239 "\n"
30240 " <!-- ================================================================= -->\n"
30241 " <PWriterProxy class=\"vtkCSVWriter\"\n"
30242 " file_name_method=\"SetFileName\"\n"
30243 " name=\"CSVWriter\">\n"
30244 " <Documentation short_help=\"Writer to write CSV files\">\n"
30245 " Writer to write comma or tab delimited files from any dataset. Set FieldAssociation to\n"
30246 " choose whether cell data/point data needs to be saved. If the file extension is tsv it\n"
30247 " uses the tab character for the delimiter. Otherwise, it uses a comma.\n"
30248 " </Documentation>\n"
30249 " <InputProperty command=\"SetInputConnection\"\n"
30250 " panel_visibility=\"never\"\n"
30251 " name=\"Input\">\n"
30252 " <DataTypeDomain name=\"input_type\">\n"
30253 " <DataType value=\"vtkCompositeDataSet\"/>\n"
30254 " <DataType value=\"vtkDataSet\"/>\n"
30255 " <DataType value=\"vtkTable\"/>\n"
30256 " </DataTypeDomain>\n"
30257 " <Documentation>\n"
30258 " The input filter/source whose output dataset is to be written to the file.\n"
30259 " </Documentation>\n"
30260 " </InputProperty>\n"
30261 " <StringVectorProperty command=\"SetFileName\"\n"
30262 " name=\"FileName\"\n"
30263 " panel_visibility=\"never\"\n"
30264 " number_of_elements=\"1\">\n"
30265 " <Documentation>\n"
30266 " The name of the file to be written.\n"
30267 " </Documentation>\n"
30268 " </StringVectorProperty>\n"
30269 " <IntVectorProperty command=\"SetWriteAllTimeSteps\"\n"
30270 " default_values=\"0\"\n"
30271 " name=\"WriteTimeSteps\"\n"
30272 " number_of_elements=\"1\">\n"
30273 " <BooleanDomain name=\"bool\"/>\n"
30274 " <Documentation>\n"
30275 " When WriteTimeSteps is turned ON, the writer is\n"
30276 " executed once for each timestep available from its input.\n"
30277 " </Documentation>\n"
30278 " </IntVectorProperty>\n"
30279 " <IntVectorProperty command=\"SetWriteAllTimeStepsSeparately\"\n"
30280 " default_values=\"0\"\n"
30281 " name=\"WriteTimeStepsSeparately\"\n"
30282 " number_of_elements=\"1\">\n"
30283 " <Documentation>\n"
30284 " When WriteTimeSteps is turned ON, the writer is\n"
30285 " executed once for each timestep available from its input,\n"
30286 " and the timesteps can be written to separate files, otherwise,\n"
30287 " the timesteps are written in one file.\n"
30288 " </Documentation>\n"
30289 " <BooleanDomain name=\"bool\"/>\n"
30290 " <Hints>\n"
30291 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
30292 " <Property name=\"WriteTimeSteps\" function=\"boolean\"/>\n"
30293 " </PropertyWidgetDecorator>\n"
30294 " </Hints>\n"
30295 " </IntVectorProperty>\n"
30296 " <StringVectorProperty command=\"SetFileNameSuffix\"\n"
30297 " default_values=\"_%d\"\n"
30298 " label=\"File name suffix\"\n"
30299 " name=\"FileNameSuffix\"\n"
30300 " number_of_elements=\"1\">\n"
30301 " <Documentation>\n"
30302 " The suffix to append to the file name when writing files at different timesteps.\n"
30303 " (File extensions such as .csv should be excluded.)\n"
30304 " The % format specifiers are used. For example, _%d will write files as FileName_0,\n"
30305 " FileName_1, FileName_2, etc., and _%.3d will write files as FileName_000,\n"
30306 " FileName_001, FileName_002 etc.\n"
30307 " </Documentation>\n"
30308 " <Hints>\n"
30309 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
30310 " <Expression type=\"and\">\n"
30311 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
30312 " <Property name=\"WriteTimeSteps\" function=\"boolean\"/>\n"
30313 " </PropertyWidgetDecorator>\n"
30314 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
30315 " <Property name=\"WriteTimeStepsSeparately\" function=\"boolean\"/>\n"
30316 " </PropertyWidgetDecorator>\n"
30317 " </Expression>\n"
30318 " </PropertyWidgetDecorator>\n"
30319 " </Hints>\n"
30320 " </StringVectorProperty>\n"
30321 "\n"
30322 " <SubProxy>\n"
30323 " <Proxy name=\"PassArrays\" proxygroup=\"internal_writers\" proxyname=\"PassArrays\"/>\n"
30324 " <ExposedProperties>\n"
30325 " <Property name=\"ChooseArraysToWrite\"/>\n"
30326 " <PropertyGroup label=\"Array Selection\" panel_widget=\"ArrayStatus\">\n"
30327 " <Property name=\"PointDataArrays\"/>\n"
30328 " <Property name=\"CellDataArrays\"/>\n"
30329 " <Property name=\"FieldDataArrays\"/>\n"
30330 " <Property name=\"VertexDataArrays\"/>\n"
30331 " <Property name=\"EdgeDataArrays\"/>\n"
30332 " <Property name=\"RowDataArrays\"/>\n"
30333 " <Hints>\n"
30334 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
30335 " mode=\"visibility\"\n"
30336 " property=\"ChooseArraysToWrite\"\n"
30337 " value=\"1\"/>\n"
30338 " <!-- show this widget when ChooseArraysToWrite==1 -->\n"
30339 " </Hints>\n"
30340 " </PropertyGroup>\n"
30341 " </ExposedProperties>\n"
30342 " <LinkProperties>\n"
30343 " <Property name=\"Input\" with_property=\"Input\"/>\n"
30344 " </LinkProperties>\n"
30345 " </SubProxy>\n"
30346 "\n"
30347 " <IntVectorProperty command=\"SetPrecision\"\n"
30348 " default_values=\"5\"\n"
30349 " name=\"Precision\"\n"
30350 " number_of_elements=\"1\">\n"
30351 " <IntRangeDomain min=\"0\"\n"
30352 " name=\"range\"/>\n"
30353 " </IntVectorProperty>\n"
30354 " <StringVectorProperty command=\"SetFieldDelimiter\"\n"
30355 " name=\"FieldDelimiter\"\n"
30356 " default_values=\",\"\n"
30357 " number_of_elements=\"1\"\n"
30358 " panel_visibility=\"never\">\n"
30359 " <Documentation>\n"
30360 " Used to set the delimiter character. This is hidden from the user\n"
30361 " and set automatically based on the file extension. An extension of .tsv will set\n"
30362 " the delimiter character to a tab. Otherwise a comma will be used as the delimiter.\n"
30363 " </Documentation>\n"
30364 " </StringVectorProperty>\n"
30365 " <IntVectorProperty command=\"SetUseStringDelimiter\"\n"
30366 " default_values=\"1\"\n"
30367 " name=\"UseStringDelimiter\"\n"
30368 " number_of_elements=\"1\">\n"
30369 " <BooleanDomain name=\"bool\"/>\n"
30370 " <Documentation>\n"
30371 " Used to enable StringDelimiter for string data. Enabled by default. Turn this off if you do not want\n"
30372 " quotes around the column headers.\n"
30373 " </Documentation>\n"
30374 " </IntVectorProperty>\n"
30375 " <StringVectorProperty command=\"SetStringDelimiter\"\n"
30376 " name=\"StringDelimiter\"\n"
30377 " default_values='\"'\n"
30378 " number_of_elements=\"1\"\n"
30379 " panel_visibility=\"never\">\n"
30380 " <Documentation>\n"
30381 " Used to set the delimiter used for string data, if any, eg. double quotes(\").\n"
30382 " </Documentation>\n"
30383 " <Hints>\n"
30384 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\"\n"
30385 " property=\"UseStringDelimiter\"/>\n"
30386 " <!-- enable this widget when UseStringDelimiter==1 -->\n"
30387 " </Hints>\n"
30388 " </StringVectorProperty>\n"
30389 " <IntVectorProperty command=\"SetUseScientificNotation\"\n"
30390 " default_values=\"0\"\n"
30391 " name=\"UseScientificNotation\"\n"
30392 " number_of_elements=\"1\">\n"
30393 " <BooleanDomain name=\"bool\"/>\n"
30394 " </IntVectorProperty>\n"
30395 " <IntVectorProperty command=\"SetFieldAssociation\"\n"
30396 " default_values=\"0\"\n"
30397 " name=\"FieldAssociation\"\n"
30398 " number_of_elements=\"1\">\n"
30399 " <Documentation>\n"
30400 " Select the attribute data to pass.\n"
30401 " </Documentation>\n"
30402 " <FieldDataDomain name=\"enum\" enable_field_data=\"1\">\n"
30403 " <RequiredProperties>\n"
30404 " <Property function=\"Input\" name=\"Input\"/>\n"
30405 " </RequiredProperties>\n"
30406 " </FieldDataDomain>\n"
30407 " </IntVectorProperty>\n"
30408 " <IntVectorProperty command=\"SetAddMetaData\"\n"
30409 " default_values=\"1\"\n"
30410 " name=\"AddMetaData\"\n"
30411 " number_of_elements=\"1\">\n"
30412 " <Documentation>\n"
30413 " It is possible for this filter to add additional meta-data to the field\n"
30414 " data such as point coordinates (when point attributes are selected and\n"
30415 " input is point-set) or structured coordinates etc. To enable this addition\n"
30416 " of extra information, turn this flag on.\n"
30417 " </Documentation>\n"
30418 " <BooleanDomain name=\"bool\"/>\n"
30419 ;
30420
30421 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOCore/Resources/writers_pv_iocore.xml
30423 " </IntVectorProperty>\n"
30424 " <IntVectorProperty command=\"SetAddTimeStep\"\n"
30425 " default_values=\"0\"\n"
30426 " name=\"AddTimeStep\"\n"
30427 " number_of_elements=\"1\">\n"
30428 " <Documentation>\n"
30429 " When set, the writer will add a \"TimeStep\" column to the generated\n"
30430 " file indicating the current dataset time step, if any.\n"
30431 " </Documentation>\n"
30432 " <BooleanDomain name=\"bool\"/>\n"
30433 " </IntVectorProperty>\n"
30434 " <IntVectorProperty command=\"SetAddTime\"\n"
30435 " default_values=\"0\"\n"
30436 " name=\"AddTime\"\n"
30437 " number_of_elements=\"1\">\n"
30438 " <Documentation>\n"
30439 " When set, the writer will add a \"Time\" column to the generated\n"
30440 " file indicating the current dataset time, if any.\n"
30441 " </Documentation>\n"
30442 " <BooleanDomain name=\"bool\"/>\n"
30443 " </IntVectorProperty>\n"
30444 " <PropertyGroup label=\"CSV Writer Parameters\">\n"
30445 " <Property name=\"Precision\"/>\n"
30446 " <Property name=\"FieldDelimiter\"/>\n"
30447 " <Property name=\"UseScientificNotation\"/>\n"
30448 " <Property name=\"FieldAssociation\"/>\n"
30449 " <Property name=\"AddMetaData\"/>\n"
30450 " <Property name=\"AddTimeStep\"/>\n"
30451 " <Property name=\"AddTime\"/>\n"
30452 " </PropertyGroup>\n"
30453 "\n"
30454 " <Hints>\n"
30455 " <WriterFactory extensions=\"csv txt tsv\"\n"
30456 " file_description=\"Comma or Tab Delimited Files\"/>\n"
30457 " <InitializationHelper class=\"vtkSMCSVProxiesInitializationHelper\"/>\n"
30458 " </Hints>\n"
30459 " <!-- End of CSVWriter -->\n"
30460 " </PWriterProxy>\n"
30461 "\n"
30462 " <!-- ================================================================= -->\n"
30463 " <PWriterProxy class=\"vtkCSVWriter\"\n"
30464 " file_name_method=\"SetFileName\"\n"
30465 " name=\"DataSetCSVWriter\"\n"
30466 " base_proxygroup=\"writers\"\n"
30467 " base_proxyname=\"CSVWriter\">\n"
30468 " <!-- keeping this around for old state files / traces that may be directly\n"
30469 " using the DataSetCSVWriter -->\n"
30470 " </PWriterProxy>\n"
30471 "\n"
30472 " <!-- end of \"writers\" -->\n"
30473 " </ProxyGroup>\n"
30474 "\n"
30475 " <!-- =================================================================== -->\n"
30476 " <ProxyGroup name=\"extract_writers\">\n"
30477 "\n"
30478 " <!-- ================================================================= -->\n"
30479 " <DataExtractWriterProxy name=\"CSV\">\n"
30480 " <Documentation>\n"
30481 " Extract writer to write tabular data using the CSV file format (csv).\n"
30482 " </Documentation>\n"
30483 " <StringVectorProperty name=\"FileName\"\n"
30484 " number_of_elements=\"1\"\n"
30485 " default_values=\"dataset_{timestep:06d}.csv\">\n"
30486 " <Documentation>\n"
30487 " Specify the filename to use.\n"
30488 " </Documentation>\n"
30489 " </StringVectorProperty>\n"
30490 " <SubProxy>\n"
30491 " <Proxy name=\"Writer\" proxygroup=\"writers\" proxyname=\"CSVWriter\"/>\n"
30492 " <ExposedProperties>\n"
30493 " <Property name=\"Input\"/>\n"
30494 " <Property name=\"FieldAssociation\"/>\n"
30495 " <Property name=\"Precision\" panel_visibility=\"advanced\"/>\n"
30496 " <Property name=\"UseScientificNotation\" panel_visibility=\"advanced\"/>\n"
30497 " <Property name=\"AddMetaData\" panel_visibility=\"advanced\"/>\n"
30498 " <Property name=\"AddTimeStep\" panel_visibility=\"advanced\"/>\n"
30499 " <Property name=\"AddTime\" panel_visibility=\"advanced\"/>\n"
30500 " <Property name=\"UseStringDelimiter\" panel_visibility=\"advanced\"/>\n"
30501 " <Property name=\"StringDelimiter\" panel_visibility=\"advanced\"/>\n"
30502 " </ExposedProperties>\n"
30503 " </SubProxy>\n"
30504 "\n"
30505 " <Hints>\n"
30506 " <ShowInMenu category=\"Data\"/>\n"
30507 " </Hints>\n"
30508 " </DataExtractWriterProxy>\n"
30509 "\n"
30510 " <!-- end of \"extract_writers\" -->\n"
30511 " </ProxyGroup>\n"
30512 "\n"
30513 " <ProxyGroup name=\"internal_writers\">\n"
30514 " <WriterProxy class=\"vtkStringWriter\"\n"
30515 " name=\"StringWriter\">\n"
30516 " <Documentation>\n"
30517 " This writer writes a string to a file.\n"
30518 " </Documentation>\n"
30519 " <InputProperty name=\"DummyInput\" panel_visibility=\"never\">\n"
30520 " </InputProperty>\n"
30521 " <StringVectorProperty name=\"FileName\"\n"
30522 " number_of_elements=\"1\"\n"
30523 " command=\"SetFileName\"\n"
30524 " default_values=\"\">\n"
30525 " <Documentation>\n"
30526 " The name of the file to write to.\n"
30527 " </Documentation>\n"
30528 " </StringVectorProperty>\n"
30529 "\n"
30530 " <StringVectorProperty name=\"String\"\n"
30531 " number_of_elements=\"1\"\n"
30532 " command=\"SetString\"\n"
30533 " default_values=\"\">\n"
30534 " <Documentation>\n"
30535 " The string to write to the file.\n"
30536 " </Documentation>\n"
30537 " </StringVectorProperty>\n"
30538 " <Hints>\n"
30539 " <WriterFactory extensions=\"txt\" file_description=\"Text File\"/>\n"
30540 " </Hints>\n"
30541 " </WriterProxy>\n"
30542 " <!-- End of StringWriter -->\n"
30543 " </ProxyGroup>\n"
30544 " <!-- =================================================================== -->\n"
30545 "</ServerManagerConfiguration>\n"
30546 "\n";
30547 // Get single string
30549 {
30550
30551  const size_t len0 = strlen(paraview_server_managerwriters_pv_iocoreInterface0);
30552  const size_t len1 = strlen(paraview_server_managerwriters_pv_iocoreInterface1);
30553  size_t len = ( 0
30554  + len0
30555  + len1 );
30556  char* res = new char[ len + 1];
30557  size_t offset = 0;
30560  assert(offset == len);
30561  res[offset] = 0;
30562  return res;
30563 }
30564
30565
30566 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOSPCTH/Resources/readers_pv_iospcth.xml
30568 "<ServerManagerConfiguration>\n"
30569 " <ProxyGroup name=\"internal_sources\">\n"
30570 " <!-- ================================================================== -->\n"
30571 " <!-- end of \"internal_sources\" -->\n"
30572 " </ProxyGroup>\n"
30573 "\n"
30574 " <!-- ==================================================================== -->\n"
30575 " <ProxyGroup name=\"sources\">\n"
30576 " <!-- ================================================================== -->\n"
30577 " <SourceProxy class=\"vtkSpyPlotReader\"\n"
30578 " label=\"Spy Plot Reader\"\n"
30579 " name=\"spcthreader\">\n"
30580 " <Documentation long_help=\"Reads files in the SPCTH Spy Plot file format.\"\n"
30581 " short_help=\"Read files in the Spy Plot format.\">The Spy\n"
30582 " Plot reader loads an ASCII meta-file called the \"case\"\n"
30583 " file (extension .spcth). The case file lists all the\n"
30584 " binary files containing the dataset. This reader produces\n"
30585 " hierarchical datasets. This is a distributed reader.\n"
30586 " </Documentation>\n"
30587 " <OutputPort index=\"0\"\n"
30588 " name=\"Volume Data\" />\n"
30589 " <OutputPort index=\"1\"\n"
30590 " name=\"Tracers\" />\n"
30591 " <OutputPort index=\"2\"\n"
30592 " name=\"Markers\" />\n"
30593 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
30594 " element_types=\"2 0\"\n"
30595 " information_property=\"CellArrayInfo\"\n"
30596 " label=\"Cell Arrays\"\n"
30597 " name=\"CellArrayStatus\"\n"
30598 " number_of_elements=\"0\"\n"
30599 " number_of_elements_per_command=\"2\"\n"
30600 " panel_visibility=\"default\"\n"
30601 " repeat_command=\"1\">\n"
30602 " <ArraySelectionDomain name=\"array_list\">\n"
30603 " <RequiredProperties>\n"
30604 " <Property function=\"ArrayList\"\n"
30605 " name=\"CellArrayInfo\" />\n"
30606 " </RequiredProperties>\n"
30607 " </ArraySelectionDomain>\n"
30608 " <Documentation>This property lists which cell-centered arrays to\n"
30609 " read.</Documentation>\n"
30610 " </StringVectorProperty>\n"
30611 " <StringVectorProperty animateable=\"0\"\n"
30612 " command=\"SetFileName\"\n"
30613 " name=\"FileName\"\n"
30614 " number_of_elements=\"1\"\n"
30615 " panel_visibility=\"never\"\n"
30616 " >\n"
30617 " <FileListDomain name=\"files\" />\n"
30618 " <Documentation>This property specifies the file name for the Spy Plot\n"
30619 " reader.</Documentation>\n"
30620 " </StringVectorProperty>\n"
30621 " <DoubleVectorProperty information_only=\"1\"\n"
30622 " name=\"TimestepValues\"\n"
30623 " repeatable=\"1\">\n"
30624 " <TimeStepsInformationHelper />\n"
30625 " <Documentation>Available timestep values.</Documentation>\n"
30626 " </DoubleVectorProperty>\n"
30627 " <IntVectorProperty command=\"SetDownConvertVolumeFraction\"\n"
30628 " default_values=\"1\"\n"
30629 " name=\"DownConvertVolumeFraction\"\n"
30630 " number_of_elements=\"1\">\n"
30631 " <BooleanDomain name=\"bool\" />\n"
30632 " <Documentation>If this property is set to 0, the type of the volume\n"
30633 " fraction is float; is set to 1, the type is unsigned\n"
30634 " char.</Documentation>\n"
30635 " </IntVectorProperty>\n"
30636 " <IntVectorProperty command=\"SetComputeDerivedVariables\"\n"
30637 " default_values=\"1\"\n"
30638 " name=\"ComputeDerivedVariables\"\n"
30639 " number_of_elements=\"1\">\n"
30640 " <BooleanDomain name=\"bool\" />\n"
30641 " <Documentation>If this property is set to 1, the reader will convert\n"
30642 " derived variables like material density for the materials that the user\n"
30643 " has selected. For Density the user needs to have selected Material Mass\n"
30644 " and Material Volume Fraction.</Documentation>\n"
30645 " </IntVectorProperty>\n"
30646 " <IntVectorProperty command=\"SetDistributeFiles\"\n"
30647 " default_values=\"1\"\n"
30648 " name=\"DistributeFiles\"\n"
30649 " number_of_elements=\"1\"\n"
30650 " panel_visibility=\"advanced\" >\n"
30651 " <BooleanDomain name=\"bool\" />\n"
30652 " <Documentation>In parallel mode, if this property is set to 1, the\n"
30653 " reader will distribute files or blocks.</Documentation>\n"
30654 " </IntVectorProperty>\n"
30655 " <IntVectorProperty command=\"SetGenerateLevelArray\"\n"
30656 " default_values=\"0\"\n"
30657 " name=\"GenerateLevelArray\"\n"
30658 " number_of_elements=\"1\"\n"
30659 " panel_visibility=\"advanced\" >\n"
30660 " <BooleanDomain name=\"bool\" />\n"
30661 " <Documentation>If this property is set to 1, a cell array will be\n"
30662 " generated that stores the level of each block.</Documentation>\n"
30663 " </IntVectorProperty>\n"
30664 " <IntVectorProperty command=\"SetGenerateActiveBlockArray\"\n"
30665 " default_values=\"0\"\n"
30666 " name=\"GenerateActiveBlockArray\"\n"
30667 " number_of_elements=\"1\"\n"
30668 " panel_visibility=\"advanced\" >\n"
30669 " <BooleanDomain name=\"bool\" />\n"
30670 " <Documentation>If this property is set to 1, a cell array will be\n"
30671 " generated that stores the active status of a block.</Documentation>\n"
30672 " </IntVectorProperty>\n"
30673 " <IntVectorProperty command=\"SetGenerateTracerArray\"\n"
30674 " default_values=\"1\"\n"
30675 " name=\"GenerateTracers\"\n"
30676 " number_of_elements=\"1\"\n"
30677 " panel_visibility=\"advanced\">\n"
30678 " <BooleanDomain name=\"bool\" />\n"
30679 " <Documentation>If this property is set to 1, a cell array will be\n"
30680 " generated that stores the coordinates of any tracers.</Documentation>\n"
30681 " </IntVectorProperty>\n"
30682 " <IntVectorProperty command=\"SetGenerateMarkers\"\n"
30683 " default_values=\"1\"\n"
30684 " name=\"GenerateMarkers\"\n"
30685 " number_of_elements=\"1\"\n"
30686 " panel_visibility=\"advanced\">\n"
30687 " <BooleanDomain name=\"bool\" />\n"
30688 " <Documentation>If this property is set to 1, a second output will be\n"
30689 " created using the markers data stored in the file.</Documentation>\n"
30690 " </IntVectorProperty>\n"
30691 " <IntVectorProperty command=\"SetGenerateBlockIdArray\"\n"
30692 " default_values=\"0\"\n"
30693 " name=\"GenerateBlockIdArray\"\n"
30694 " number_of_elements=\"1\"\n"
30695 " panel_visibility=\"advanced\" >\n"
30696 " <BooleanDomain name=\"bool\" />\n"
30697 " <Documentation>If this property is set to 1, a cell array will be\n"
30698 " generated that stores a unique blockId for each block.</Documentation>\n"
30699 " </IntVectorProperty>\n"
30700 " <IntVectorProperty command=\"SetMergeXYZComponents\"\n"
30701 " default_values=\"1\"\n"
30702 " name=\"MergeXYZComponents\"\n"
30703 " number_of_elements=\"1\"\n"
30704 " panel_visibility=\"advanced\">\n"
30705 " <BooleanDomain name=\"bool\" />\n"
30706 " <Documentation>If this property is set to 1, cell arrays named (for\n"
30707 " example) X velocity, Y velocity and Z velocity will be combined into a\n"
30708 " single vector array named velocity.</Documentation>\n"
30709 " </IntVectorProperty>\n"
30710 " <StringVectorProperty information_only=\"1\"\n"
30711 " name=\"CellArrayInfo\">\n"
30712 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
30713 " </StringVectorProperty>\n"
30714 " <Hints>\n"
30715 " <ReaderFactory extensions=\"spct*\"\n"
30716 " file_description=\"SpyPlot CTH dataset\"\n"
30717 " filename_patterns=\"spct*\" />\n"
30718 " </Hints>\n"
30719 " <!-- End spcthreader-->\n"
30720 " </SourceProxy>\n"
30721 "\n"
30722 " <!-- ================================================================== -->\n"
30723 " <SourceProxy class=\"vtkSpyPlotFileSeriesReader\"\n"
30724 " file_name_method=\"SetFileName\"\n"
30725 " label=\"Restarted Sim Spy Plot Reader\"\n"
30726 " name=\"SPCTHRestartReader\"\n"
30727 " si_class=\"vtkSIMetaReaderProxy\">\n"
30728 " <Documentation long_help=\"Reads collections of SPCTH files from simulations that were restarted.\"\n"
30729 " short_help=\"Read SPCTH files from simulation restarts.\">\n"
30730 " When a CTH simulation is restarted, typically you get a\n"
30731 " new set of output files. When you read them in your\n"
30732 " visualization, you often want to string these file sets\n"
30733 " together as if it was one continuous dump of files. This\n"
30734 " reader allows you to specify a metadata file that will\n"
30735 " implicitly string the files together. This is a\n"
30736 " distributed reader.\n"
30737 " </Documentation>\n"
30738 " <OutputPort index=\"0\"\n"
30739 " name=\"Volume Data\" />\n"
30740 " <OutputPort index=\"1\"\n"
30741 " name=\"Tracers\" />\n"
30742 " <OutputPort index=\"2\"\n"
30743 " name=\"Markers\" />\n"
30744 " <SubProxy>\n"
30745 " <Proxy name=\"Reader\"\n"
30746 " proxygroup=\"sources\"\n"
30747 " proxyname=\"spcthreader\" />\n"
30748 " <ExposedProperties>\n"
30749 " <Property name=\"DownConvertVolumeFraction\" />\n"
30750 " <Property name=\"DistributeFiles\" />\n"
30751 " <Property name=\"GenerateLevelArray\" />\n"
30752 " <Property name=\"GenerateActiveBlockArray\" />\n"
30753 " <Property name=\"GenerateBlockIdArray\" />\n"
30754 " <Property name=\"GenerateTracers\" />\n"
30755 " <Property name=\"GenerateMarkers\" />\n"
30756 " <Property name=\"CellArrayInfo\" />\n"
30757 " <Property name=\"CellArrayStatus\" />\n"
30758 " </ExposedProperties>\n"
30759 " </SubProxy>\n"
30760 " <StringVectorProperty animateable=\"0\"\n"
30761 " command=\"SetMetaFileName\"\n"
30762 " name=\"FileName\"\n"
30763 " number_of_elements=\"1\"\n"
30764 " panel_visibility=\"never\" >\n"
30765 " <FileListDomain name=\"files\" />\n"
30766 " <Documentation>This points to a special metadata file that lists the\n"
30767 " output files for each restart.</Documentation>\n"
30768 " </StringVectorProperty>\n"
30769 " <IntVectorProperty command=\"SetUseMetaFile\"\n"
30770 " default_values=\"1\"\n"
30771 " name=\"UseMetaFile\"\n"
30772 " number_of_elements=\"1\"\n"
30773 " panel_visibility=\"never\" >\n"
30774 " <BooleanDomain name=\"bool\" />\n"
30775 " <Documentation>This hidden property must always be set to 1 for this\n"
30776 " proxy to work.</Documentation>\n"
30777 " </IntVectorProperty>\n"
30778 " <DoubleVectorProperty information_only=\"1\"\n"
30779 " name=\"TimestepValues\"\n"
30780 " repeatable=\"1\">\n"
30781 " <TimeStepsInformationHelper />\n"
30782 " </DoubleVectorProperty>\n"
30783 " <Hints>\n"
30784 " <ReaderFactory extensions=\"spcth-timeseries\"\n"
30785 " file_description=\"Case file for restarted CTH outputs\" />\n"
30786 " </Hints>\n"
30787 " <!-- SPCTHRestartReader -->\n"
30788 " </SourceProxy>\n"
30789 "\n"
30790 " <!-- ================================================================== -->\n"
30791 " <SourceProxy class=\"vtkSpyPlotHistoryReader\"\n"
30792 " label=\"spcth history reader\"\n"
30793 " name=\"spcthhistoryreader\">\n"
30794 " <Documentation long_help=\"Reads an spcth history file where each row translates into a single time step\n"
30795 " and the columns are points, materials and properties.\"\n"
30796 " short_help=\"Read a comma-separated spctch history file.\">\n"
30797 " </Documentation>\n"
30798 " <StringVectorProperty animateable=\"0\"\n"
30799 " command=\"SetFileName\"\n"
30800 " name=\"FileName\"\n"
30801 " number_of_elements=\"1\"\n"
30802 " panel_visibility=\"never\" >\n"
30803 " <FileListDomain name=\"files\" />\n"
30804 " <Documentation>This property specifies the file name for the VRML\n"
30805 " reader.</Documentation>\n"
30806 " </StringVectorProperty>\n"
30807 " <StringVectorProperty command=\"SetCommentCharacter\"\n"
30808 " default_values=\"%\"\n"
30809 " name=\"CommentCharacter\"\n"
30810 " number_of_elements=\"1\">\n"
30811 " <Documentation>This property lists the characters that is used as the\n"
30812 " first character on comment lines</Documentation>\n"
30813 " </StringVectorProperty>\n"
30814 " <StringVectorProperty command=\"SetDelimeter\"\n"
30815 " default_values=\",\"\n"
30816 " name=\"Delimeter\"\n"
30817 " number_of_elements=\"1\">\n"
30818 " <Documentation>Character that is used as the delimiter.</Documentation>\n"
30819 " </StringVectorProperty>\n"
30820 " <DoubleVectorProperty information_only=\"1\"\n"
30821 " name=\"TimestepValues\"\n"
30822 " repeatable=\"1\">\n"
30823 " <TimeStepsInformationHelper />\n"
30824 " <Documentation>Available timestep values.</Documentation>\n"
30825 " </DoubleVectorProperty>\n"
30826 " <Hints>\n"
30827 " <ReaderFactory extensions=\"hscth\"\n"
30828 " file_description=\"Spy Plot History Files\"\n"
30829 " filename_patterns=\"*hsct*\" />\n"
30830 " </Hints>\n"
30831 " <!-- End of SPCTHHistoryReader -->\n"
30832 " </SourceProxy>\n"
30833 "\n"
30834 " <!-- ================================================================== -->\n"
30835 " <!-- end of \"sources\" -->\n"
30836 " </ProxyGroup>\n"
30837 "</ServerManagerConfiguration>\n"
30838 "\n";
30839 // Get single string
30841 {
30842
30843  const size_t len0 = strlen(paraview_server_managerreaders_pv_iospcthInterface0);
30844  size_t len = ( 0
30845  + len0 );
30846  char* res = new char[ len + 1];
30847  size_t offset = 0;
30849  assert(offset == len);
30850  res[offset] = 0;
30851  return res;
30852 }
30853
30854
30855 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOImage/Resources/readers_pv_ioimage.xml
30857 "<ServerManagerConfiguration>\n"
30858 " <ProxyGroup name=\"internal_sources\">\n"
30859 " <!-- ================================================================== -->\n"
30860 " <Proxy label=\"Image Reader Core\" name=\"ImageReaderCore\" class=\"vtkImageReader\">\n"
30861 " <Documentation long_help=\"Reads raw regular rectilinear grid data from a file. The dimensions and type of the data must be specified.\"\n"
30862 " short_help=\"Read raw regular rectilinear grid data from a file.\">\n"
30863 " The Image reader reads raw, regular, rectilinear grid\n"
30864 " (image/volume) data from a file. Because no metadata is\n"
30865 " provided, the user must specify information about the\n"
30866 " size, spacing, dimensionality, etc. about the\n"
30867 " dataset.</Documentation>\n"
30868 " <IntVectorProperty command=\"SetDataScalarType\"\n"
30869 " default_values=\"4\"\n"
30870 " name=\"DataScalarType\"\n"
30871 " number_of_elements=\"1\">\n"
30872 " <EnumerationDomain name=\"enum\">\n"
30873 " <Entry text=\"char\"\n"
30874 " value=\"2\" />\n"
30875 " <Entry text=\"unsigned char\"\n"
30876 " value=\"3\" />\n"
30877 " <Entry text=\"short\"\n"
30878 " value=\"4\" />\n"
30879 " <Entry text=\"unsigned short\"\n"
30880 " value=\"5\" />\n"
30881 " <Entry text=\"int\"\n"
30882 " value=\"6\" />\n"
30883 " <Entry text=\"unsigned int\"\n"
30884 " value=\"7\" />\n"
30885 " <Entry text=\"long\"\n"
30886 " value=\"8\" />\n"
30887 " <Entry text=\"unsigned long\"\n"
30888 " value=\"9\" />\n"
30889 " <Entry text=\"float\"\n"
30890 " value=\"10\" />\n"
30891 " <Entry text=\"double\"\n"
30892 " value=\"11\" />\n"
30893 " </EnumerationDomain>\n"
30894 " <Documentation>The value of this property indicates the scalar type of\n"
30895 " the pixels/voxels in the file(s): short, int, float ...</Documentation>\n"
30896 " </IntVectorProperty>\n"
30897 " <IntVectorProperty command=\"SetDataByteOrder\"\n"
30898 " default_values=\"0\"\n"
30899 " name=\"DataByteOrder\"\n"
30900 " number_of_elements=\"1\">\n"
30901 " <EnumerationDomain name=\"enum\">\n"
30902 " <Entry text=\"BigEndian\"\n"
30903 " value=\"0\" />\n"
30904 " <Entry text=\"LittleEndian\"\n"
30905 " value=\"1\" />\n"
30906 " </EnumerationDomain>\n"
30907 " <Documentation>This property indicates the byte order of the binary\n"
30908 " file(s).</Documentation>\n"
30909 " </IntVectorProperty>\n"
30910 " <DoubleVectorProperty command=\"SetDataOrigin\"\n"
30911 " default_values=\"0.0 0.0 0.0\"\n"
30912 " name=\"DataOrigin\"\n"
30913 " number_of_elements=\"3\">\n"
30914 " <DoubleRangeDomain name=\"range\" />\n"
30915 " <Documentation>The coordinate contained in this property specifies the\n"
30916 " position of the point with index (0,0,0).</Documentation>\n"
30917 " </DoubleVectorProperty>\n"
30918 " <DoubleVectorProperty command=\"SetDataSpacing\"\n"
30919 " default_values=\"1.0 1.0 1.0\"\n"
30920 " name=\"DataSpacing\"\n"
30921 " number_of_elements=\"3\">\n"
30922 " <DoubleRangeDomain name=\"range\" />\n"
30923 " <Documentation>This property specifies the size of a voxel in each\n"
30924 " dimension.</Documentation>\n"
30925 " </DoubleVectorProperty>\n"
30926 " <IntVectorProperty command=\"SetNumberOfScalarComponents\"\n"
30927 " default_values=\"1\"\n"
30928 " name=\"NumberOfScalarComponents\"\n"
30929 " number_of_elements=\"1\">\n"
30930 " <IntRangeDomain name=\"range\" />\n"
30931 " <Documentation>This property specifies the number of components the\n"
30932 " scalar value at each pixel or voxel has (e.g., RGB - 3 scalar\n"
30933 " components).</Documentation>\n"
30934 " </IntVectorProperty>\n"
30935 " <StringVectorProperty command=\"SetScalarArrayName\"\n"
30936 " default_values=\"ImageFile\"\n"
30937 " name=\"ScalarArrayName\"\n"
30938 " number_of_elements=\"1\">\n"
30939 " <Documentation>This property contains a text string listing a name to\n"
30940 " assign to the point-centered data array read.</Documentation>\n"
30941 " </StringVectorProperty>\n"
30942 " <IntVectorProperty command=\"SetFileLowerLeft\"\n"
30943 " default_values=\"1\"\n"
30944 " name=\"FileLowerLeft\"\n"
30945 " number_of_elements=\"1\">\n"
30946 " <BooleanDomain name=\"bool\" />\n"
30947 " <Documentation>This property determines whether the data originates in\n"
30948 " the lower left corner (on) or the upper left corner (off). Most\n"
30949 " scientific data is written with a right-handed axes that originates in\n"
30950 " the lower left corner. However, several 2D image file formats write the\n"
30951 " image from the upper left corner.</Documentation>\n"
30952 " </IntVectorProperty>\n"
30953 " <!-- End ImageReaderCore -->\n"
30954 " </Proxy>\n"
30955 "\n"
30956 " <!-- ============================================================= -->\n"
30957 " <Proxy class=\"vtkPNGReader\"\n"
30958 " label=\"PNG Reader\"\n"
30959 " name=\"PNGReader\">\n"
30960 " <Documentation long_help=\"Reads a PNG file into an image data.\"\n"
30961 " short_help=\"Read a PNG file.\">The PNG reader reads PNG\n"
30962 " (Portable Network Graphics) files, and the output is a\n"
30963 " uniform rectilinear (image/volume) dataset. The default\n"
30964 " file extension is .png.</Documentation>\n"
30965 " <StringVectorProperty animateable=\"0\"\n"
30966 " command=\"SetFileName\"\n"
30967 " name=\"FileName\"\n"
30968 " number_of_elements=\"1\"\n"
30969 " panel_visibility=\"never\">\n"
30970 " <FileListDomain name=\"files\" />\n"
30971 " <Documentation>This property specifies the file name for the PNG\n"
30972 " reader.</Documentation>\n"
30973 " </StringVectorProperty>\n"
30974 " <DoubleVectorProperty name=\"DataSpacing\"\n"
30975 " command=\"SetDataSpacing\"\n"
30976 " number_of_elements=\"3\"\n"
30977 " default_values=\"1 1 1\">\n"
30978 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" />\n"
30979 " <Documentation>\n"
30980 " Set the spacing to use for the image output by this reader.\n"
30981 " </Documentation>\n"
30982 " </DoubleVectorProperty>\n"
30983 " <StringVectorProperty command=\"GetTextKeys\"\n"
30984 " information_only=\"1\"\n"
30985 " name=\"TextKeys\">\n"
30986 " <StringArrayHelper/>\n"
30987 " <Documentation>\n"
30988 " Get the text keys from the PNG file.\n"
30989 " </Documentation>\n"
30990 " </StringVectorProperty>\n"
30991 " <StringVectorProperty command=\"GetTextValues\"\n"
30992 " information_only=\"1\"\n"
30993 " name=\"TextValues\">\n"
30994 " <StringArrayHelper/>\n"
30995 " <Documentation>\n"
30996 " Get the text values from the PNG file.\n"
30997 " </Documentation>\n"
30998 " </StringVectorProperty>\n"
30999 " <!-- End PNGReader -->\n"
31000 " </Proxy>\n"
31001 "\n"
31002 " <!-- ============================================================= -->\n"
31003 " <Proxy class=\"vtkJPEGReader\"\n"
31004 " label=\"JPEG Reader\"\n"
31005 " name=\"JPEGReader\">\n"
31006 " <Documentation long_help=\"Reads a JPEG file into an image data.\"\n"
31007 " short_help=\"Read a JPEG file.\">The JPEG reader reads JPEG\n"
31008 " files, and the output is a uniform rectilinear\n"
31009 " (image/volume) dataset. The default file extension is .jpg\n"
31010 " or .jpeg.</Documentation>\n"
31011 " <StringVectorProperty animateable=\"0\"\n"
31012 " command=\"SetFileName\"\n"
31013 " name=\"FileName\"\n"
31014 " number_of_elements=\"1\"\n"
31015 " panel_visibility=\"never\">\n"
31016 " <FileListDomain name=\"files\" />\n"
31017 " <Documentation>This property specifies the file name for the JPEG\n"
31018 " reader.</Documentation>\n"
31019 " </StringVectorProperty>\n"
31020 " <DoubleVectorProperty name=\"DataSpacing\"\n"
31021 " command=\"SetDataSpacing\"\n"
31022 " number_of_elements=\"3\"\n"
31023 " default_values=\"1 1 1\">\n"
31024 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" />\n"
31025 " <Documentation>\n"
31026 " Set the spacing to use for the image output by this reader.\n"
31027 " </Documentation>\n"
31028 " </DoubleVectorProperty>\n"
31029 " <!-- End JPEGReader -->\n"
31030 " </Proxy>\n"
31031 "\n"
31032 " <!-- ================================================================== -->\n"
31033 " <Proxy class=\"vtkMRCReader\" label=\"MRC Reader\" name=\"MRCReader\">\n"
31034 " <Documentation long_help=\"Reads a MRC file into an image data.\"\n"
31035 " short_help=\"Read a MRC file.\">The MRC reader reads MRC\n"
31036 " (Medical Research Council) image files, and the output is a\n"
31037 " uniform rectilinear (image/volume) dataset. The default\n"
31038 " file extension is .mrc but .st, .rec and .ali extensions\n"
31039 " are known to be commonly used as well.</Documentation>\n"
31040 " <StringVectorProperty animateable=\"0\"\n"
31041 " command=\"SetFileName\"\n"
31042 " name=\"FileName\"\n"
31043 " number_of_elements=\"1\"\n"
31044 " panel_visibility=\"never\">\n"
31045 " <FileListDomain name=\"files\" />\n"
31046 " <Documentation>The name of the file to load.</Documentation>\n"
31047 " </StringVectorProperty>\n"
31048 " <!-- End MRCReader -->\n"
31049 " </Proxy>\n"
31050 "\n"
31051 " <!-- ================================================================== -->\n"
31052 " <Proxy class=\"vtkTIFFReader\" label=\"TIFF Reader\" name=\"TIFFReader\">\n"
31053 " <Documentation long_help=\"Reads a TIFF file into an image data.\"\n"
31054 " short_help=\"Read a TIFF file.\">The TIFF reader reads TIFF\n"
31055 " (Tagged Image File Format) files, and the output is a\n"
31056 " uniform rectilinear (image/volume) dataset. The default\n"
31057 " file extension is .tiff.</Documentation>\n"
31058 " <StringVectorProperty animateable=\"0\"\n"
31059 " command=\"SetFileName\"\n"
31060 " name=\"FileName\"\n"
31061 " number_of_elements=\"1\"\n"
31062 " panel_visibility=\"never\">\n"
31063 " <FileListDomain name=\"files\" />\n"
31064 " <Documentation>This property specifies the file name for the TIFF\n"
31065 " reader.</Documentation>\n"
31066 " </StringVectorProperty>\n"
31067 " <IntVectorProperty name=\"UseCustomDataSpacing\"\n"
31068 " command=\"SetSpacingSpecifiedFlag\"\n"
31069 " number_of_elements=\"1\"\n"
31070 " default_values=\"0\">\n"
31071 " <BooleanDomain name=\"bool\" />\n"
31072 " <Documentation>\n"
31073 " To manually specify a custom spacing using **CustomDataSpacing**, set this property to 1 (checked).\n"
31074 " </Documentation>\n"
31075 " </IntVectorProperty>\n"
31076 " <DoubleVectorProperty name=\"CustomDataSpacing\"\n"
31077 " command=\"SetDataSpacing\"\n"
31078 " information_property=\"CustomDataSpacingInfo\"\n"
31079 " number_of_elements=\"3\"\n"
31080 " default_values=\"1 1 1\">\n"
31081 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" />\n"
31082 " <Documentation>\n"
31083 " Set the spacing to use for the image output by this reader. This is used only when\n"
31084 " **UseCustomDataSpacing** is set to true.\n"
31085 " </Documentation>\n"
31086 " <Hints>\n"
31087 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
31088 " <Property name=\"UseCustomDataSpacing\" function=\"boolean\" />\n"
31089 " </PropertyWidgetDecorator>\n"
31090 " </Hints>\n"
31091 " </DoubleVectorProperty>\n"
31092 " <DoubleVectorProperty name=\"CustomDataSpacingInfo\"\n"
31093 " command=\"GetDataSpacing\"\n"
31094 " information_only=\"1\">\n"
31095 " <SimpleDoubleInformationHelper />\n"
31096 " </DoubleVectorProperty>\n"
31097 " <!-- End TIFFReader -->\n"
31098 " </Proxy>\n"
31099 "\n"
31100 " <!-- ================================================================== -->\n"
31101 " <Proxy class=\"vtkMetaImageReader\"\n"
31102 " label=\"Meta Image reader\"\n"
31103 " name=\"MetaImageReaderCore\">\n"
31104 " <Documentation long_help=\"Reads binary UNC meta image data.\"\n"
31105 " short_help=\"Read UNC meta image data.\">The Meta Image\n"
31106 " Reader reads binary UNC meta image data, and produces\n"
31107 " uniform rectilinear (image/volume) data. The default file\n"
31108 " extensions are .mhd and .mha.</Documentation>\n"
31109 " <StringVectorProperty animateable=\"0\"\n"
31110 " command=\"SetFileName\"\n"
31111 " name=\"FileName\"\n"
31112 " number_of_elements=\"1\"\n"
31113 " panel_visibility=\"never\">\n"
31114 " <FileListDomain name=\"files\" />\n"
31115 " <Documentation>This property specifies the file name for the Meta Image\n"
31116 " reader.</Documentation>\n"
31117 " </StringVectorProperty>\n"
31118 " <!-- End Meta Image Reader -->\n"
31119 " </Proxy>\n"
31120 "\n"
31121 " <!-- ============================================================= -->\n"
31122 " <Proxy class=\"vtkHDRReader\"\n"
31123 " label=\"HDR Reader\"\n"
31124 " name=\"HDRReader\">\n"
31125 " <Documentation long_help=\"Reads a HDR file into an image data.\"\n"
31126 " short_help=\"Read a HDR file.\">The HDR reader reads HDR\n"
31127 " (High Dynamic Range) files, and the output is a\n"
31128 " uniform rectilinear (image/volume) dataset. The default\n"
31129 " file extension is .hdr.</Documentation>\n"
31130 " <StringVectorProperty animateable=\"0\"\n"
31131 " command=\"SetFileName\"\n"
31132 " name=\"FileName\"\n"
31133 " number_of_elements=\"1\"\n"
31134 " panel_visibility=\"never\">\n"
31135 " <FileListDomain name=\"files\" />\n"
31136 " <Documentation>This property specifies the file name for the HDR\n"
31137 " reader.</Documentation>\n"
31138 " </StringVectorProperty>\n"
31139 " <DoubleVectorProperty name=\"DataSpacing\"\n"
31140 " command=\"SetDataSpacing\"\n"
31141 " number_of_elements=\"3\"\n"
31142 " default_values=\"1 1 1\">\n"
31143 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" />\n"
31144 " <Documentation>\n"
31145 " Set the spacing to use for the image output by this reader.\n"
31146 " </Documentation>\n"
31147 " </DoubleVectorProperty>\n"
31148 " <!-- End HDRReader -->\n"
31149 " </Proxy>\n"
31150 "\n"
31151 " <!-- end of \"internal_sources\" -->\n"
31152 " </ProxyGroup>\n"
31153 "\n"
31154 " <!-- ==================================================================== -->\n"
31155 " <ProxyGroup name=\"sources\">\n"
31156 "\n"
31157 " <!-- ================================================================== -->\n"
31158 " <SourceProxy class=\"vtkRawImageFileSeriesReader\"\n"
31159 " file_name_method=\"SetFileName\"\n"
31160 " label=\"Image Reader\"\n"
31161 " name=\"ImageReader\"\n"
31162 ;
31163
31164 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOImage/Resources/readers_pv_ioimage.xml
31166 " si_class=\"vtkSIMetaReaderProxy\">\n"
31167 " <Documentation long_help=\"Reads a series of raw files into an time sequence of image datas.\"\n"
31168 " short_help=\"Read a series of raw files.\">The raw series\n"
31169 " reader reads raw files. The output is a time sequence of\n"
31170 " uniform rectilinear (image/volume) dataset. The default\n"
31171 " file extension is .raw.</Documentation>\n"
31172 " <StringVectorProperty animateable=\"0\"\n"
31173 " clean_command=\"RemoveAllFileNames\"\n"
31174 " command=\"AddFileName\"\n"
31175 " name=\"FileNames\"\n"
31176 " number_of_elements=\"1\"\n"
31177 " panel_visibility=\"never\"\n"
31178 " repeat_command=\"1\">\n"
31179 " <FileListDomain name=\"files\" />\n"
31180 " <Documentation>The list of files to be read by the reader. If more than\n"
31181 " one file is specified, the reader will switch to file series mode in\n"
31182 " which it will pretend that it can support time and provide one file per\n"
31183 " time step.</Documentation>\n"
31184 " </StringVectorProperty>\n"
31185 " <DoubleVectorProperty information_only=\"1\"\n"
31186 " name=\"TimestepValues\"\n"
31187 " repeatable=\"1\">\n"
31188 " <TimeStepsInformationHelper />\n"
31189 " <Documentation>Available timestep values.</Documentation>\n"
31190 " </DoubleVectorProperty>\n"
31191 " <IntVectorProperty name=\"ReadAsImageStack\"\n"
31192 " command=\"SetReadAsImageStack\"\n"
31193 " number_of_elements=\"1\"\n"
31194 " default_values=\"0\">\n"
31195 " <BooleanDomain name=\"bool\" />\n"
31196 " <Documentation>\n"
31197 " When set, the reader will read the set of files as an image stack, rather than\n"
31198 " a temporal file series.\n"
31199 " </Documentation>\n"
31200 " </IntVectorProperty>\n"
31201 " <SubProxy>\n"
31202 " <Proxy name=\"Reader\"\n"
31203 " proxygroup=\"internal_sources\"\n"
31204 " proxyname=\"ImageReaderCore\"></Proxy>\n"
31205 " <ExposedProperties>\n"
31206 " <Property name=\"DataScalarType\" />\n"
31207 " <Property name=\"DataByteOrder\" />\n"
31208 " <Property name=\"DataOrigin\" />\n"
31209 " <Property name=\"DataSpacing\" />\n"
31210 " <Property name=\"NumberOfScalarComponents\" />\n"
31211 " <Property name=\"FileLowerLeft\" />\n"
31212 " <Property name=\"ScalarArrayName\" />\n"
31213 " </ExposedProperties>\n"
31214 " </SubProxy>\n"
31215 " <IntVectorProperty command=\"SetFileDimensionality\"\n"
31216 " default_values=\"3\"\n"
31217 " name=\"FileDimensionality\"\n"
31218 " number_of_elements=\"1\">\n"
31219 " <EnumerationDomain name=\"enum\">\n"
31220 " <Entry text=\"2\"\n"
31221 " value=\"2\" />\n"
31222 " <Entry text=\"3\"\n"
31223 " value=\"3\" />\n"
31224 " </EnumerationDomain>\n"
31225 " <Documentation>This property indicates whether the file(s) in this\n"
31226 " dataset contain slices (2D) or volumes (3D).</Documentation>\n"
31227 " </IntVectorProperty>\n"
31228 " <IntVectorProperty command=\"SetDataExtent\"\n"
31229 " default_values=\"0 0 0 0 0 0\"\n"
31230 " name=\"DataExtent\"\n"
31231 " number_of_elements=\"6\">\n"
31232 " <IntRangeDomain name=\"range\" />\n"
31233 " <Documentation>This property specifies the minimum and maximum index\n"
31234 " values of the data in each dimension (xmin, xmax, ymin, ymax, zmin,\n"
31235 " zmax).</Documentation>\n"
31236 " </IntVectorProperty>\n"
31237 " <Hints>\n"
31238 " <ReaderFactory extensions=\"raw\"\n"
31239 " file_description=\"Raw (binary) Files\" />\n"
31240 " </Hints>\n"
31241 " <!-- End RAWSeriesReader -->\n"
31242 " </SourceProxy>\n"
31243 "\n"
31244 " <!-- ================================================================== -->\n"
31245 " <SourceProxy class=\"vtkOMETIFFReader\"\n"
31246 " label=\"OME TIFF Reader\"\n"
31247 " name=\"OMETIFFReader\">\n"
31248 " <Documentation long_help=\"Reads an OME-TIFF file.\"\n"
31249 " short_help=\"Reads an OME-TIFF file.\">\n"
31250 " Supports reading OME-TIFF files.\n"
31251 " </Documentation>\n"
31252 " <StringVectorProperty animateable=\"0\"\n"
31253 " command=\"SetFileName\"\n"
31254 " name=\"FileName\"\n"
31255 " number_of_elements=\"1\"\n"
31256 " panel_visibility=\"never\">\n"
31257 " <FileListDomain name=\"files\" />\n"
31258 " <Documentation>This property specifies the file name for the OME-TIFF reader.</Documentation>\n"
31259 " </StringVectorProperty>\n"
31260 " <IntVectorProperty name=\"UseCustomDataSpacing\"\n"
31261 " command=\"SetSpacingSpecifiedFlag\"\n"
31262 " number_of_elements=\"1\"\n"
31263 " default_values=\"0\">\n"
31264 " <BooleanDomain name=\"bool\" />\n"
31265 " <Documentation>\n"
31266 " To manually specify a custom spacing using **CustomDataSpacing**, set this property to 1 (checked).\n"
31267 " </Documentation>\n"
31268 " </IntVectorProperty>\n"
31269 " <DoubleVectorProperty name=\"CustomDataSpacing\"\n"
31270 " command=\"SetDataSpacing\"\n"
31271 " information_property=\"CustomDataSpacingInfo\"\n"
31272 " number_of_elements=\"3\"\n"
31273 " default_values=\"1 1 1\">\n"
31274 " <DoubleRangeDomain name=\"range\" min=\"0 0 0\" />\n"
31275 " <Documentation>\n"
31276 " Set the spacing to use for the image output by this reader. This is used only when\n"
31277 " **UseCustomDataSpacing** is set to 1.\n"
31278 " </Documentation>\n"
31279 " <Hints>\n"
31280 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
31281 " <Property name=\"UseCustomDataSpacing\" function=\"boolean\" />\n"
31282 " </PropertyWidgetDecorator>\n"
31283 " </Hints>\n"
31284 " </DoubleVectorProperty>\n"
31285 " <DoubleVectorProperty name=\"CustomDataSpacingInfo\"\n"
31286 " command=\"GetDataSpacing\"\n"
31287 " information_only=\"1\">\n"
31288 " <SimpleDoubleInformationHelper />\n"
31289 " </DoubleVectorProperty>\n"
31290 " <IntVectorProperty name=\"IgnoreColorMap\"\n"
31291 " command=\"SetIgnoreColorMap\"\n"
31292 " number_of_elements=\"1\"\n"
31293 " default_values=\"1\">\n"
31294 " <BooleanDomain name=\"bool\" />\n"
31295 " <Documentation>\n"
31296 " When checked, data values in the TIFF file will not be mapped to colors using the\n"
31297 " color map specified in the TIFF, if any. This is useful for files where the\n"
31298 " color map may be incorrectly specified.\n"
31299 " </Documentation>\n"
31300 " </IntVectorProperty>\n"
31301 " <DoubleVectorProperty information_only=\"1\"\n"
31302 " name=\"TimestepValues\"\n"
31303 " repeatable=\"1\">\n"
31304 " <TimeStepsInformationHelper />\n"
31305 " <Documentation>Available timestep values.</Documentation>\n"
31306 " </DoubleVectorProperty>\n"
31307 " <Hints>\n"
31308 " <ReaderFactory extensions=\"ome.tif ome.tiff\"\n"
31309 " file_description=\"OME TIFF Files\" />\n"
31310 " </Hints>\n"
31311 " <!-- End OMETIFFReader -->\n"
31312 " </SourceProxy>\n"
31313 "\n"
31314 " <!-- ================================================================== -->\n"
31315 " <SourceProxy class=\"vtkImageFileSeriesReader\"\n"
31316 " file_name_method=\"SetFileName\"\n"
31317 " label=\"PNG Series Reader\"\n"
31318 " name=\"PNGSeriesReader\"\n"
31319 " si_class=\"vtkSIMetaReaderProxy\">\n"
31320 " <Documentation long_help=\"Reads a PNG file into an image data.\"\n"
31321 " short_help=\"Read a PNG file.\">The PNG reader reads PNG\n"
31322 " (Portable Network Graphics) files, and the output is a\n"
31323 " uniform rectilinear (image/volume) dataset. The default\n"
31324 " file extension is .png.</Documentation>\n"
31325 " <StringVectorProperty animateable=\"0\"\n"
31326 " clean_command=\"RemoveAllFileNames\"\n"
31327 " command=\"AddFileName\"\n"
31328 " name=\"FileNames\"\n"
31329 " number_of_elements=\"1\"\n"
31330 " panel_visibility=\"never\"\n"
31331 " repeat_command=\"1\">\n"
31332 " <FileListDomain name=\"files\" />\n"
31333 " <Documentation>The list of files to be read by the reader. If more than\n"
31334 " one file is specified, the reader will switch to file series mode in\n"
31335 " which it will pretend that it can support time and provide one file per\n"
31336 " time step.</Documentation>\n"
31337 " </StringVectorProperty>\n"
31338 " <DoubleVectorProperty information_only=\"1\"\n"
31339 " name=\"TimestepValues\"\n"
31340 " repeatable=\"1\">\n"
31341 " <TimeStepsInformationHelper />\n"
31342 " <Documentation>Available timestep values.</Documentation>\n"
31343 " </DoubleVectorProperty>\n"
31344 " <IntVectorProperty name=\"ReadAsImageStack\"\n"
31345 " command=\"SetReadAsImageStack\"\n"
31346 " number_of_elements=\"1\"\n"
31347 " default_values=\"1\">\n"
31348 " <BooleanDomain name=\"bool\" />\n"
31349 " <Documentation>\n"
31350 " When set, the reader will read the set of files as an image stack, rather than\n"
31351 " a temporal file series.\n"
31352 " </Documentation>\n"
31353 " </IntVectorProperty>\n"
31354 " <SubProxy>\n"
31355 " <Proxy name=\"Reader\"\n"
31356 " proxygroup=\"internal_sources\"\n"
31357 " proxyname=\"PNGReader\"></Proxy>\n"
31358 " <ExposedProperties>\n"
31359 " <Property name=\"DataSpacing\" />\n"
31360 " <Property name=\"TextKeys\" />\n"
31361 " <Property name=\"TextValues\" />\n"
31362 " </ExposedProperties>\n"
31363 " </SubProxy>\n"
31364 " <Hints>\n"
31365 " <ReaderFactory extensions=\"png\"\n"
31366 " file_description=\"PNG Image Files\" />\n"
31367 " </Hints>\n"
31368 " <!-- End PNGSeriesReader -->\n"
31369 " </SourceProxy>\n"
31370 "\n"
31371 " <!-- ================================================================== -->\n"
31372 " <SourceProxy class=\"vtkImageFileSeriesReader\"\n"
31373 " file_name_method=\"SetFileName\"\n"
31374 " label=\"JPEG Series Reader\"\n"
31375 " name=\"JPEGSeriesReader\"\n"
31376 " si_class=\"vtkSIMetaReaderProxy\">\n"
31377 " <Documentation long_help=\"Reads a series of JPEG files into an time sequence of image datas.\"\n"
31378 " short_help=\"Read a series of JPEG files.\">The JPEG series\n"
31379 " reader reads JPEG files. The output is a time sequence of\n"
31380 " uniform rectilinear (image/volume) dataset. The default\n"
31381 " file extension is .jpg or .jpeg.</Documentation>\n"
31382 " <StringVectorProperty animateable=\"0\"\n"
31383 " clean_command=\"RemoveAllFileNames\"\n"
31384 " command=\"AddFileName\"\n"
31385 " name=\"FileNames\"\n"
31386 " number_of_elements=\"1\"\n"
31387 " panel_visibility=\"never\"\n"
31388 " repeat_command=\"1\">\n"
31389 " <FileListDomain name=\"files\" />\n"
31390 " <Documentation>The list of files to be read by the reader. If more than\n"
31391 " one file is specified, the reader will switch to file series mode in\n"
31392 " which it will pretend that it can support time and provide one file per\n"
31393 " time step.</Documentation>\n"
31394 " </StringVectorProperty>\n"
31395 " <DoubleVectorProperty information_only=\"1\"\n"
31396 " name=\"TimestepValues\"\n"
31397 " repeatable=\"1\">\n"
31398 " <TimeStepsInformationHelper />\n"
31399 " <Documentation>Available timestep values.</Documentation>\n"
31400 " </DoubleVectorProperty>\n"
31401 " <IntVectorProperty name=\"ReadAsImageStack\"\n"
31402 " command=\"SetReadAsImageStack\"\n"
31403 " number_of_elements=\"1\"\n"
31404 " default_values=\"1\">\n"
31405 " <BooleanDomain name=\"bool\" />\n"
31406 " <Documentation>\n"
31407 " When set, the reader will read the set of files as an image stack, rather than\n"
31408 " a temporal file series.\n"
31409 " </Documentation>\n"
31410 " </IntVectorProperty>\n"
31411 " <SubProxy>\n"
31412 " <Proxy name=\"Reader\"\n"
31413 " proxygroup=\"internal_sources\"\n"
31414 " proxyname=\"JPEGReader\"></Proxy>\n"
31415 " <ExposedProperties>\n"
31416 " <Property name=\"DataSpacing\" />\n"
31417 " </ExposedProperties>\n"
31418 " </SubProxy>\n"
31419 " <Hints>\n"
31420 " <ReaderFactory extensions=\"jpg jpeg\"\n"
31421 " file_description=\"JPEG Image Files\" />\n"
31422 " </Hints>\n"
31423 " <!-- End JPEGSeriesReader -->\n"
31424 " </SourceProxy>\n"
31425 "\n"
31426 " <!-- ================================================================== -->\n"
31427 " <SourceProxy class=\"vtkImageFileSeriesReader\"\n"
31428 " file_name_method=\"SetFileName\"\n"
31429 " label=\"MRC Series Reader\"\n"
31430 " name=\"MRCSeriesReader\"\n"
31431 " si_class=\"vtkSIMetaReaderProxy\">\n"
31432 " <Documentation long_help=\"Reads a series of MRC files into an time sequence of image datas.\"\n"
31433 " short_help=\"Read a series of MRC files.\">The MRC series\n"
31434 " reader reads MRC files. The output is a time sequence of\n"
31435 " uniform rectilinear (image/volume) dataset. The default\n"
31436 " file extension is .mrc but .ali, .st and .rec are also\n"
31437 " recognized.</Documentation>\n"
31438 " <StringVectorProperty animateable=\"0\"\n"
31439 " clean_command=\"RemoveAllFileNames\"\n"
31440 " command=\"AddFileName\"\n"
31441 " name=\"FileNames\"\n"
31442 " number_of_elements=\"1\"\n"
31443 " panel_visibility=\"never\"\n"
31444 " repeat_command=\"1\">\n"
31445 " <FileListDomain name=\"files\" />\n"
31446 " <Documentation>The list of files to be read by the reader. If more than\n"
31447 " one file is specified, the reader will switch to file series mode in\n"
31448 " which it will pretend that it can support time and provide one file per\n"
31449 " time step.</Documentation>\n"
31450 " </StringVectorProperty>\n"
31451 " <DoubleVectorProperty information_only=\"1\"\n"
31452 " name=\"TimestepValues\"\n"
31453 " repeatable=\"1\">\n"
31454 " <TimeStepsInformationHelper />\n"
31455 " <Documentation>Available timestep values.</Documentation>\n"
31456 " </DoubleVectorProperty>\n"
31457 " <SubProxy>\n"
31458 " <Proxy name=\"Reader\"\n"
31459 " proxygroup=\"internal_sources\"\n"
31460 " proxyname=\"MRCReader\"></Proxy>\n"
31461 " </SubProxy>\n"
31462 " <Hints>\n"
31463 " <ReaderFactory extensions=\"mrc ali st rec\"\n"
31464 " file_description=\"MRC Image Files\" />\n"
31465 " </Hints>\n"
31466 " <!-- End MRCSeriesReader -->\n"
31467 " </SourceProxy>\n"
31468 "\n"
31469 " <!-- ================================================================== -->\n"
31470 " <SourceProxy class=\"vtkImageFileSeriesReader\"\n"
31471 " file_name_method=\"SetFileName\"\n"
31472 " label=\"TIFF Series Reader\"\n"
31473 " name=\"TIFFSeriesReader\"\n"
31474 " si_class=\"vtkSIMetaReaderProxy\">\n"
31475 " <Documentation long_help=\"Reads a series of TIFF files into an time sequence of image datas.\"\n"
31476 ;
31477
31478 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOImage/Resources/readers_pv_ioimage.xml
31480 " short_help=\"Read a series of TIFF files.\">The TIFF series\n"
31481 " reader reads TIFF files. The output is a time sequence of\n"
31482 " uniform rectilinear (image/volume) dataset. The default\n"
31483 " file extension is .tif or .tiff.</Documentation>\n"
31484 " <StringVectorProperty animateable=\"0\"\n"
31485 " clean_command=\"RemoveAllFileNames\"\n"
31486 " command=\"AddFileName\"\n"
31487 " name=\"FileNames\"\n"
31488 " number_of_elements=\"1\"\n"
31489 " panel_visibility=\"never\"\n"
31490 " repeat_command=\"1\">\n"
31491 " <FileListDomain name=\"files\" />\n"
31492 " <Documentation>The list of files to be read by the reader. If more than\n"
31493 " one file is specified, the reader will switch to file series mode in\n"
31494 " which it will pretend that it can support time and provide one file per\n"
31495 " time step.</Documentation>\n"
31496 " </StringVectorProperty>\n"
31497 " <DoubleVectorProperty information_only=\"1\"\n"
31498 " name=\"TimestepValues\"\n"
31499 " repeatable=\"1\">\n"
31500 " <TimeStepsInformationHelper />\n"
31501 " <Documentation>Available timestep values.</Documentation>\n"
31502 " </DoubleVectorProperty>\n"
31503 " <IntVectorProperty name=\"ReadAsImageStack\"\n"
31504 " command=\"SetReadAsImageStack\"\n"
31505 " number_of_elements=\"1\"\n"
31506 " default_values=\"1\">\n"
31507 " <BooleanDomain name=\"bool\" />\n"
31508 " <Documentation>\n"
31509 " When set, the reader will read the set of files as an image stack, rather than\n"
31510 " a temporal file series.\n"
31511 " </Documentation>\n"
31512 " </IntVectorProperty>\n"
31513 " <SubProxy>\n"
31514 " <Proxy name=\"Reader\"\n"
31515 " proxygroup=\"internal_sources\"\n"
31516 " proxyname=\"TIFFReader\"></Proxy>\n"
31517 " <ExposedProperties>\n"
31518 " <Property name=\"UseCustomDataSpacing\" />\n"
31519 " <Property name=\"CustomDataSpacing\" />\n"
31520 " <Property name=\"CustomDataSpacingInfo\" />\n"
31521 " </ExposedProperties>\n"
31522 " </SubProxy>\n"
31523 " <Hints>\n"
31524 " <ReaderFactory extensions=\"tif tiff\"\n"
31525 " file_description=\"TIFF Image Files\" />\n"
31526 " </Hints>\n"
31527 " <!-- End TIFFSeriesReader -->\n"
31528 " </SourceProxy>\n"
31529 "\n"
31530 " <!-- ============================================================= -->\n"
31531 " <SourceProxy class=\"vtkTIFFReader\"\n"
31532 " label=\"TIFF Reader\"\n"
31533 " name=\"TIFFReader\">\n"
31534 " <Documentation long_help=\"Reads a TIFF file into an image data.\"\n"
31535 " short_help=\"Read a TIFF file.\">The TIFF reader reads TIFF\n"
31536 " (Tagged Image File Format) files, and the output is a\n"
31537 " uniform rectilinear (image/volume) dataset. The default\n"
31538 " file extension is .tiff.</Documentation>\n"
31539 " <StringVectorProperty animateable=\"0\"\n"
31540 " command=\"SetFileName\"\n"
31541 " name=\"FileName\"\n"
31542 " number_of_elements=\"1\"\n"
31543 " panel_visibility=\"never\" >\n"
31544 " <FileListDomain name=\"files\" />\n"
31545 " <Documentation>This property specifies the file name for the TIFF\n"
31546 " reader.</Documentation>\n"
31547 " </StringVectorProperty>\n"
31548 " <!-- this deliberately doesn't have ReaderFactory hints\n"
31549 " TIFFSeriesReader can actually read whatever this reader reads. This is here\n"
31550 " only for backward compatibility. -->\n"
31551 " <!-- End TIFFReader -->\n"
31552 " </SourceProxy>\n"
31553 "\n"
31554 " <!-- ============================================================= -->\n"
31555 " <SourceProxy class=\"vtkFileSeriesReader\"\n"
31556 " file_name_method=\"SetFileName\"\n"
31557 " label=\"Meta File Series Reader\"\n"
31558 " name=\"MetaImageReader\"\n"
31559 " si_class=\"vtkSIMetaReaderProxy\">\n"
31560 " <Documentation long_help=\"Reads a series of meta images.\"\n"
31561 " short_help=\"Read a series of meta images.\">Read a series\n"
31562 " of meta images. The file extension is .mhd</Documentation>\n"
31563 " <SubProxy>\n"
31564 " <Proxy name=\"Reader\"\n"
31565 " proxygroup=\"internal_sources\"\n"
31566 " proxyname=\"MetaImageReaderCore\"></Proxy>\n"
31567 " </SubProxy>\n"
31568 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
31569 " information_only=\"1\"\n"
31570 " name=\"FileNameInfo\">\n"
31571 " <SimpleStringInformationHelper />\n"
31572 " </StringVectorProperty>\n"
31573 " <StringVectorProperty animateable=\"0\"\n"
31574 " clean_command=\"RemoveAllFileNames\"\n"
31575 " command=\"AddFileName\"\n"
31576 " name=\"FileNames\"\n"
31577 " number_of_elements=\"1\"\n"
31578 " panel_visibility=\"never\"\n"
31579 " repeat_command=\"1\">\n"
31580 " <FileListDomain name=\"files\" />\n"
31581 " <Documentation>The list of files to be read by the reader. Each file is\n"
31582 " expected to be in the meta format. The standard extension is .mhd. If\n"
31583 " more than one file is specified, the reader will switch to file series\n"
31584 " mode in which it will pretend that it can support time and provide one\n"
31585 " file per time step.</Documentation>\n"
31586 " </StringVectorProperty>\n"
31587 " <DoubleVectorProperty information_only=\"1\"\n"
31588 " name=\"TimestepValues\"\n"
31589 " repeatable=\"1\">\n"
31590 " <TimeStepsInformationHelper />\n"
31591 " <Documentation>Available timestep values.</Documentation>\n"
31592 " </DoubleVectorProperty>\n"
31593 " <Hints>\n"
31594 " <ReaderFactory extensions=\"mhd mha\"\n"
31595 " file_description=\"Meta Image Files\" />\n"
31596 " </Hints>\n"
31597 " <!-- end of MetaFileSeriesReader -->\n"
31598 " </SourceProxy>\n"
31599 "\n"
31600 " <!-- ============================================================= -->\n"
31601 " <SourceProxy class=\"vtkDEMReader\"\n"
31602 " label=\"DEM Reader\"\n"
31603 " name=\"DEMReader\">\n"
31604 " <Documentation long_help=\"Reads a DEM (Digital Elevation Model) file.\"\n"
31605 " short_help=\"Read a dataset in DEM format\">The DEM reader\n"
31606 " reads Digital Elevation Model files containing elevation\n"
31607 " values derived from the U. S. Geologic Survey. The default\n"
31608 " file extension is .dem. This reader produces uniform\n"
31609 " rectilinear (image/volume) data output.</Documentation>\n"
31610 " <StringVectorProperty animateable=\"0\"\n"
31611 " command=\"SetFileName\"\n"
31612 " name=\"FileName\"\n"
31613 " number_of_elements=\"1\">\n"
31614 " <FileListDomain name=\"files\" />\n"
31615 " <Documentation>This property specifies the file name for the DEM\n"
31616 " (Digital Elevation Map) reader.</Documentation>\n"
31617 " </StringVectorProperty>\n"
31618 " <Hints>\n"
31619 " <ReaderFactory extensions=\"dem\"\n"
31620 " file_description=\"Digital Elevation Map Files\" />\n"
31621 " </Hints>\n"
31622 " <!-- End DEMReader -->\n"
31623 " </SourceProxy>\n"
31624 "\n"
31625 " <!-- ============================================================= -->\n"
31626 " <SourceProxy class=\"vtkNrrdReader\"\n"
31627 " label=\"Nrrd Reader\"\n"
31628 " name=\"NrrdReader\">\n"
31629 " <Documentation long_help=\"Reads raw image files with Nrrd meta data.\"\n"
31630 " short_help=\"Read raw image files with Nrrd meta data.\">The\n"
31631 " Nrrd reader reads raw image data much like the Raw Image\n"
31632 " Reader except that it will also read metadata information\n"
31633 " in the Nrrd format. This means that the reader will\n"
31634 " automatically set information like file dimensions. There\n"
31635 " are several limitations on what type of nrrd files we can\n"
31636 " read. This reader only supports nrrd files in raw format.\n"
31637 " Other encodings like ascii and hex will result in errors.\n"
31638 " When reading in detached headers, this only supports\n"
31639 " reading one file that is detached.</Documentation>\n"
31640 " <StringVectorProperty animateable=\"0\"\n"
31641 " command=\"SetFileName\"\n"
31642 " name=\"FileName\"\n"
31643 " number_of_elements=\"1\"\n"
31644 " panel_visibility=\"never\" >\n"
31645 " <FileListDomain name=\"files\" />\n"
31646 " <Documentation>The name of the file to read (or the meta data file that\n"
31647 " will point to the actual file).</Documentation>\n"
31648 " </StringVectorProperty>\n"
31649 " <IntVectorProperty command=\"SetDataVOI\"\n"
31650 " default_values=\"0 0 0 0 0 0\"\n"
31651 " label=\"Data VOI\"\n"
31652 " name=\"DataVOI\"\n"
31653 " number_of_elements=\"6\">\n"
31654 " <Documentation>The data volume of interest (VOI). The VOI is a\n"
31655 " sub-extent of the data that you want loaded. Setting a VOI is useful\n"
31656 " when reading from a large data set and you are only interested in a\n"
31657 " small portion of the data. If left containing all 0's, then the reader\n"
31658 " will load in the entire data set.</Documentation>\n"
31659 " </IntVectorProperty>\n"
31660 " <Hints>\n"
31661 " <ReaderFactory extensions=\"nrrd nhdr\"\n"
31662 " file_description=\"Nrrd Raw Image Files\" />\n"
31663 " </Hints>\n"
31664 " <!-- NrrdReader -->\n"
31665 " </SourceProxy>\n"
31666 "\n"
31667 " <!-- ============================================================= -->\n"
31668 " <SourceProxy label=\"DICOM Reader (Single File)\"\n"
31669 " name=\"DICOMReaderSingle\"\n"
31670 " class=\"vtkDICOMImageReader\">\n"
31671 " <Documentation long_help=\"Reads DICOM regular rectilinear grid data from a lone file.\"\n"
31672 " short_help=\"Reads DICOM file\">\n"
31673 " DICOM is a file format often used in medical imaging. This version\n"
31674 " of the reader reads a single file (as opposed to a collection of\n"
31675 " files). The DICOM reader currently only supports uncompressed\n"
31676 " files.\n"
31677 " </Documentation>\n"
31678 " <StringVectorProperty animateable=\"0\"\n"
31679 " command=\"SetFileName\"\n"
31680 " name=\"FileName\"\n"
31681 " number_of_elements=\"1\"\n"
31682 " panel_visibility=\"never\">\n"
31683 " <FileListDomain name=\"files\" />\n"
31684 " <Documentation>\n"
31685 " DICOM file to load. This version of the reader only supports\n"
31686 " loading one file at a time.\n"
31687 " </Documentation>\n"
31688 " </StringVectorProperty>\n"
31689 " <Hints>\n"
31690 " <ReaderFactory extensions=\"dcm\"\n"
31691 " file_description=\"DICOM Files (single)\" />\n"
31692 " </Hints>\n"
31693 " <!-- End DICOMReaderSingle -->\n"
31694 " </SourceProxy>\n"
31695 "\n"
31696 " <!-- ============================================================= -->\n"
31697 " <SourceProxy label=\"DICOM Reader (directory)\"\n"
31698 " name=\"DICOMReader\"\n"
31699 " class=\"vtkDICOMImageReader\">\n"
31700 " <Documentation long_help=\"Reads DICOM regular rectilinear grid data from a directory containing a file.\"\n"
31701 " short_help=\"Reads DICOM files.\">\n"
31702 " DICOM is a file format often used in medical imaging. This version\n"
31703 " of the reader will look at all files in the same directory of the\n"
31704 " selected file and load them as planes of the same data set. It is\n"
31705 " typically for 3D medical scanners to store planes as set of files\n"
31706 " in a directory.\n"
31707 " </Documentation>\n"
31708 " <Hints>\n"
31709 " <ReaderFactory extensions=\"dcm\"\n"
31710 " file_description=\"DICOM Files (directory)\" />\n"
31711 " </Hints>\n"
31712 " <StringVectorProperty animateable=\"0\"\n"
31713 " command=\"SetDirectoryName\"\n"
31714 " name=\"FileName\"\n"
31715 " number_of_elements=\"1\"\n"
31716 " panel_visibility=\"never\">\n"
31717 " <FileListDomain name=\"files\" />\n"
31718 " <Documentation>\n"
31719 " A file in the directory of files to be loaded. The DICOM reader\n"
31720 " will actually load all valid DICOM files in the same directory as\n"
31721 " this file as part of the same dataset. This is typical of how\n"
31722 " DICOM files are often stored.\n"
31723 " </Documentation>\n"
31724 " <Hints>\n"
31725 " <UseDirectoryName />\n"
31726 " </Hints>\n"
31727 " </StringVectorProperty>\n"
31728 " <!-- End DICOMReaderDirectory -->\n"
31729 " </SourceProxy>\n"
31730 "\n"
31731 " <!-- ============================================================= -->\n"
31732 " <SourceProxy name=\"SEPReader\" class=\"vtkSEPReader\" label=\"SEP Reader\">\n"
31733 " <Documentation\n"
31734 " short_help=\"Stanford Exploration Project files reader.\"\n"
31735 " long_help=\"This reader takes a .H file that points to a .H@ file and contains all the information to interpret the raw data in the .H@ file.\">\n"
31736 " </Documentation>\n"
31737 " <Hints>\n"
31738 " <ReaderFactory extensions=\"H\" file_description=\"SEP file (Plugin)\"/>\n"
31739 " </Hints>\n"
31740 "\n"
31741 " <StringVectorProperty animateable=\"0\"\n"
31742 " command=\"SetFileName\"\n"
31743 " name=\"FileName\"\n"
31744 " number_of_elements=\"1\"\n"
31745 " panel_visibility=\"never\" >\n"
31746 " <FileListDomain name=\"files\" />\n"
31747 " <Documentation>This property specifies the file name for the SEP\n"
31748 " reader.</Documentation>\n"
31749 " </StringVectorProperty>\n"
31750 "\n"
31751 " <IntVectorProperty command=\"SetOutputGridDimension\"\n"
31752 " name=\"OutputGridDimension\"\n"
31753 " number_of_elements=\"1\"\n"
31754 " default_values=\"3\"\n"
31755 " panel_visibility=\"default\" >\n"
31756 " <EnumerationDomain name=\"enum\">\n"
31757 " <Entry text=\"2D\"\n"
31758 " value=\"2\" />\n"
31759 " <Entry text=\"3D\"\n"
31760 " value=\"3\" />\n"
31761 " </EnumerationDomain>\n"
31762 " <Documentation>This property specifies the dimension of the output data set.\n"
31763 " </Documentation>\n"
31764 " </IntVectorProperty>\n"
31765 "\n"
31766 " <StringVectorProperty command=\"GetAllDimensions\"\n"
31767 " information_only=\"1\"\n"
31768 " name=\"DimensionInfo\">\n"
31769 " <StringArrayHelper />\n"
31770 " </StringVectorProperty>\n"
31771 " <StringVectorProperty animateable=\"0\"\n"
31772 " command=\"SetXDimension\"\n"
31773 " name=\"XDimension\"\n"
31774 " number_of_elements=\"1\"\n"
31775 " default_values=\"CDP\"\n"
31776 " panel_visibility=\"default\">\n"
31777 " <StringListDomain name=\"array_list\">\n"
31778 " <RequiredProperties>\n"
31779 " <Property function=\"ArrayList\"\n"
31780 " name=\"DimensionInfo\" />\n"
31781 " </RequiredProperties>\n"
31782 " </StringListDomain>\n"
31783 " </StringVectorProperty>\n"
31784 " <StringVectorProperty animateable=\"0\"\n"
31785 " command=\"SetYDimension\"\n"
31786 " name=\"YDimension\"\n"
31787 ;
31788
31789 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOImage/Resources/readers_pv_ioimage.xml
31791 " number_of_elements=\"1\"\n"
31792 " default_values=\"LINE\"\n"
31793 " panel_visibility=\"default\">\n"
31794 " <StringListDomain name=\"array_list\">\n"
31795 " <RequiredProperties>\n"
31796 " <Property function=\"ArrayList\"\n"
31797 " name=\"DimensionInfo\" />\n"
31798 " </RequiredProperties>\n"
31799 " </StringListDomain>\n"
31800 " </StringVectorProperty>\n"
31801 " <StringVectorProperty animateable=\"0\"\n"
31802 " command=\"SetZDimension\"\n"
31803 " name=\"ZDimension\"\n"
31804 " default_values=\"DEPTH\"\n"
31805 " number_of_elements=\"1\"\n"
31806 " panel_visibility=\"default\">\n"
31807 " <StringListDomain name=\"array_list\">\n"
31808 " <RequiredProperties>\n"
31809 " <Property function=\"ArrayList\"\n"
31810 " name=\"DimensionInfo\" />\n"
31811 " </RequiredProperties>\n"
31812 " </StringListDomain>\n"
31813 " <Hints>\n"
31814 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
31815 " mode=\"visibility\"\n"
31816 " property=\"OutputGridDimension\"\n"
31817 " value=\"3\">\n"
31818 " </PropertyWidgetDecorator>\n"
31819 " </Hints>\n"
31820 " </StringVectorProperty>\n"
31821 "\n"
31822 " <IntVectorProperty name=\"FixedDimensionRange\"\n"
31823 " command=\"GetFixedDimRange\"\n"
31824 " number_of_elements=\"2\"\n"
31825 " default_values=\"0 0\"\n"
31826 " information_only=\"1\">\n"
31827 " <SimpleIntInformationHelper/>\n"
31828 " </IntVectorProperty>\n"
31829 " <StringVectorProperty animateable=\"0\"\n"
31830 " command=\"SetFixedDimension1\"\n"
31831 " name=\"FixedDimension1\"\n"
31832 " label=\"Fixed Dimension 1\"\n"
31833 " default_values=\"OFFSET\"\n"
31834 " number_of_elements=\"1\"\n"
31835 " panel_visibility=\"default\">\n"
31836 " <StringListDomain name=\"array_list\">\n"
31837 " <RequiredProperties>\n"
31838 " <Property function=\"ArrayList\"\n"
31839 " name=\"DimensionInfo\" />\n"
31840 " </RequiredProperties>\n"
31841 " </StringListDomain>\n"
31842 " </StringVectorProperty>\n"
31843 " <IntVectorProperty command=\"SetFixedDimensionValue1\"\n"
31844 " name=\"FixedDimensionValue1\"\n"
31845 " label=\"Fixed Dimension 1 Value\"\n"
31846 " number_of_elements=\"1\"\n"
31847 " default_values=\"1\"\n"
31848 " panel_visibility=\"default\">\n"
31849 " <IntRangeDomain name=\"range\"\n"
31850 " default_mode=\"min\">\n"
31851 " <RequiredProperties>\n"
31852 " <Property name=\"FixedDimensionRange\"\n"
31853 " function=\"Range\"/>\n"
31854 " </RequiredProperties>\n"
31855 " </IntRangeDomain>\n"
31856 " </IntVectorProperty>\n"
31857 " <StringVectorProperty animateable=\"0\"\n"
31858 " command=\"SetFixedDimension2\"\n"
31859 " name=\"FixedDimension2\"\n"
31860 " label=\"Fixed Dimension 2\"\n"
31861 " default_values=\"DEPTH\"\n"
31862 " number_of_elements=\"1\"\n"
31863 " panel_visibility=\"default\">\n"
31864 " <StringListDomain name=\"array_list\">\n"
31865 " <RequiredProperties>\n"
31866 " <Property function=\"ArrayList\"\n"
31867 " name=\"DimensionInfo\" />\n"
31868 " </RequiredProperties>\n"
31869 " </StringListDomain>\n"
31870 " <Hints>\n"
31871 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
31872 " mode=\"visibility\"\n"
31873 " property=\"OutputGridDimension\"\n"
31874 " value=\"2\">\n"
31875 " </PropertyWidgetDecorator>\n"
31876 " </Hints>\n"
31877 " </StringVectorProperty>\n"
31878 " <IntVectorProperty command=\"SetFixedDimensionValue2\"\n"
31879 " name=\"FixedDimensionValue2\"\n"
31880 " label=\"Fixed Dimension 2 Value\"\n"
31881 " number_of_elements=\"1\"\n"
31882 " default_values=\"1\"\n"
31883 " panel_visibility=\"default\">\n"
31884 " <IntRangeDomain name=\"range\"\n"
31885 " default_mode=\"min\">\n"
31886 " <RequiredProperties>\n"
31887 " <Property name=\"FixedDimensionRange\"\n"
31888 " function=\"Range\"/>\n"
31889 " </RequiredProperties>\n"
31890 " </IntRangeDomain>\n"
31891 " <Hints>\n"
31892 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
31893 " mode=\"visibility\"\n"
31894 " property=\"OutputGridDimension\"\n"
31895 " value=\"2\">\n"
31896 " </PropertyWidgetDecorator>\n"
31897 " </Hints>\n"
31898 " </IntVectorProperty>\n"
31899 "\n"
31900 " <StringVectorProperty command=\"GetAllRanges\"\n"
31901 " information_only=\"1\"\n"
31902 " panel_visibility=\"default\"\n"
31903 " repeat_command=\"1\"\n"
31904 " number_of_elements_per_command=\"2\"\n"
31905 " name=\"RangesInformation\"\n"
31906 " si_class=\"vtkSIDataArrayProperty\">\n"
31907 " </StringVectorProperty>\n"
31908 "\n"
31909 " <IntVectorProperty command=\"SetExtentSplitMode\"\n"
31910 " name=\"ExtentSplitMode\"\n"
31911 " number_of_elements=\"1\"\n"
31912 " default_values=\"3\"\n"
31913 " panel_visibility=\"advanced\" >\n"
31914 " <EnumerationDomain name=\"enum\">\n"
31915 " <Entry text=\"XSlab\"\n"
31916 " value=\"0\" />\n"
31917 " <Entry text=\"YSlab\"\n"
31918 " value=\"1\" />\n"
31919 " <Entry text=\"ZSlab\"\n"
31920 " value=\"2\" />\n"
31921 " <Entry text=\"Block\"\n"
31922 " value=\"3\" />\n"
31923 " </EnumerationDomain>\n"
31924 " <Documentation>This property specifies the extent mode.\n"
31925 " </Documentation>\n"
31926 " </IntVectorProperty>\n"
31927 "\n"
31928 " <PropertyGroup panel_widget=\"Line\"\n"
31929 " label=\"Dimensions setup\">\n"
31930 " <Property name=\"XDimension\" />\n"
31931 " <Property name=\"YDimension\" />\n"
31932 " <Property name=\"ZDimension\" />\n"
31933 " <Property name=\"FixedDimension1\" />\n"
31934 " <Property name=\"FixedDimensionValue1\" />\n"
31935 " <Property name=\"FixedDimension2\" />\n"
31936 " <Property name=\"FixedDimensionValue2\" />\n"
31937 " </PropertyGroup>\n"
31938 " </SourceProxy>\n"
31939 "\n"
31940 " <!-- ============================================================= -->\n"
31941 " <SourceProxy name=\"HDRReader\" class=\"vtkHDRReader\" label=\"HDR Reader\">\n"
31942 " <Documentation\n"
31943 " short_help=\"Reads a file in Radiance HDR format.\"\n"
31944 " long_help=\"Reads a file in Radiance High Dynamic Range format.\">\n"
31945 " An HDR image is a high-bit–depth image (normally 32 bits per channel)\n"
31946 " that contains color and brightness information across a very wide dynamic range.\n"
31947 " </Documentation>\n"
31948 " <Hints>\n"
31949 " <ReaderFactory extensions=\"hdr\" file_description=\"Radiance HDR file\"/>\n"
31950 " </Hints>\n"
31951 " <StringVectorProperty name=\"FileName\" command=\"SetFileName\" animateable=\"0\" number_of_elements=\"1\">\n"
31952 " <FileListDomain name=\"files\"/>\n"
31953 " </StringVectorProperty>\n"
31954 " <!-- End HDRReader -->\n"
31955 " </SourceProxy>\n"
31956 "\n"
31957 " <!-- ============================================================= -->\n"
31958 "\n"
31959 " <!-- end of \"readers\" -->\n"
31960 " </ProxyGroup>\n"
31961 "\n"
31962 "</ServerManagerConfiguration>\n"
31963 "\n";
31964 // Get single string
31966 {
31967
31968  const size_t len0 = strlen(paraview_server_managerreaders_pv_ioimageInterface0);
31969  const size_t len1 = strlen(paraview_server_managerreaders_pv_ioimageInterface1);
31970  const size_t len2 = strlen(paraview_server_managerreaders_pv_ioimageInterface2);
31971  const size_t len3 = strlen(paraview_server_managerreaders_pv_ioimageInterface3);
31972  size_t len = ( 0
31973  + len0
31974  + len1
31975  + len2
31976  + len3 );
31977  char* res = new char[ len + 1];
31978  size_t offset = 0;
31983  assert(offset == len);
31984  res[offset] = 0;
31985  return res;
31986 }
31987
31988
31989 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOImage/Resources/writers_pv_ioimage.xml
31991 "<ServerManagerConfiguration>\n"
31992 " <ProxyGroup name=\"writers\">\n"
31993 "\n"
31994 " <!-- ================================================================= -->\n"
31995 " <WriterProxy class=\"vtkMetaImageWriter\"\n"
31996 " name=\"MetaImageWriter\">\n"
31997 " <Documentation short_help=\"Write a binary UNC meta image data.\">Writer to\n"
31998 " write a binary UNC meta image data. This is a fairly simple yet powerful\n"
31999 " format consisting of a text header and a binary data section. MetaImage\n"
32000 " headers are expected to have extension: \".mha\" or \".mhd\"</Documentation>\n"
32001 " <InputProperty command=\"SetInputConnection\"\n"
32002 " panel_visibility=\"never\"\n"
32003 " name=\"Input\">\n"
32004 " <DataTypeDomain composite_data_supported=\"0\"\n"
32005 " name=\"input_type\">\n"
32006 " <DataType value=\"vtkImageData\" />\n"
32007 " </DataTypeDomain>\n"
32008 " <Documentation>The input filter/source whose output dataset is to\n"
32009 " written to the file.</Documentation>\n"
32010 " </InputProperty>\n"
32011 " <StringVectorProperty command=\"SetFileName\"\n"
32012 " name=\"FileName\"\n"
32013 " panel_visibility=\"never\"\n"
32014 " number_of_elements=\"1\">\n"
32015 " <Documentation>The name of the file to be written.</Documentation>\n"
32016 " </StringVectorProperty>\n"
32017 " <Hints>\n"
32018 " <WriterFactory extensions=\"mhd\"\n"
32019 " file_description=\"Meta Image Files\" />\n"
32020 " </Hints>\n"
32021 " <!-- End of MetaImageWriter -->\n"
32022 " </WriterProxy>\n"
32023 "\n"
32024 " <!-- ================================================================= -->\n"
32025 " <WriterProxy class=\"vtkPNGWriter\"\n"
32026 " name=\"PNGWriter\">\n"
32027 " <Documentation short_help=\"Write image data as a PNG file.\">Writer to\n"
32028 " write image data as a PNG file. It supports 1 to 4 component data of\n"
32029 " unsigned char or unsigned short.\n"
32030 " This Writer can also generate a stack of images when the FileName is in\n"
32031 " the form of /path/file_%03d.png and that the input data is a 3D image\n"
32032 " data.\n"
32033 " </Documentation>\n"
32034 " <InputProperty command=\"SetInputConnection\"\n"
32035 " panel_visibility=\"never\"\n"
32036 " name=\"Input\">\n"
32037 " <DataTypeDomain composite_data_supported=\"0\"\n"
32038 " name=\"input_type\">\n"
32039 " <DataType value=\"vtkImageData\" />\n"
32040 " </DataTypeDomain>\n"
32041 " <Documentation>The input filter/source whose output dataset is to\n"
32042 " written to the file.</Documentation>\n"
32043 " </InputProperty>\n"
32044 " <StringVectorProperty command=\"SetFilePattern\"\n"
32045 " name=\"FileName\"\n"
32046 " panel_visibility=\"never\"\n"
32047 " number_of_elements=\"1\">\n"
32048 " <Documentation>The name of the file to be written.</Documentation>\n"
32049 " </StringVectorProperty>\n"
32050 " <Hints>\n"
32051 " <WriterFactory extensions=\"png\"\n"
32052 " file_description=\"PNG Image Files\" />\n"
32053 " </Hints>\n"
32054 " <!-- End of PNGWriter -->\n"
32055 " </WriterProxy>\n"
32056 "\n"
32057 " <!-- ================================================================= -->\n"
32058 " <WriterProxy class=\"vtkTIFFWriter\"\n"
32059 " name=\"TIFFWriter\">\n"
32060 " <Documentation short_help=\"Write image data as a TIFF file.\">Writer to\n"
32061 " write image data as a TIFF file.\n"
32062 " </Documentation>\n"
32063 " <InputProperty command=\"SetInputConnection\"\n"
32064 " panel_visibility=\"never\"\n"
32065 " name=\"Input\">\n"
32066 " <DataTypeDomain composite_data_supported=\"0\"\n"
32067 " name=\"input_type\">\n"
32068 " <DataType value=\"vtkImageData\" />\n"
32069 " </DataTypeDomain>\n"
32070 " <Documentation>The input filter/source whose output dataset is to be\n"
32071 " written to the file.</Documentation>\n"
32072 " </InputProperty>\n"
32073 " <StringVectorProperty command=\"SetFilePattern\"\n"
32074 " name=\"FileName\"\n"
32075 " panel_visibility=\"never\"\n"
32076 " number_of_elements=\"1\">\n"
32077 " <Documentation>The name of the file to be written.</Documentation>\n"
32078 " </StringVectorProperty>\n"
32079 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
32080 " element_types=\"0 0 0 0 2\"\n"
32081 " label=\"Scalars\"\n"
32082 " name=\"SelectInputScalars\"\n"
32083 " number_of_elements=\"5\"\n"
32084 " panel_visibility=\"default\">\n"
32085 " <ArrayListDomain attribute_type=\"Scalars\"\n"
32086 " name=\"array_list\">\n"
32087 " <RequiredProperties>\n"
32088 " <Property function=\"Input\"\n"
32089 " name=\"Input\" />\n"
32090 " </RequiredProperties>\n"
32091 " </ArrayListDomain>\n"
32092 " <Documentation>This property contains the name of the scalar array to\n"
32093 " be saved.</Documentation>\n"
32094 " </StringVectorProperty>\n"
32095 "\n"
32096 " <Hints>\n"
32097 " <WriterFactory extensions=\"tiff\"\n"
32098 " file_description=\"TIFF Image Files\" />\n"
32099 " </Hints>\n"
32100 " <!-- End of TIFFWriter -->\n"
32101 " </WriterProxy>\n"
32102 "\n"
32103 " <!-- ================================================================= -->\n"
32104 " <WriterProxy class=\"vtkJPEGWriter\"\n"
32105 " name=\"JPEGWriter\">\n"
32106 " <Documentation short_help=\"Write image data as a JPEG file.\">\n"
32107 " Writer to write image data as a JPEG file. It supports 1 to 3 component\n"
32108 " data of unsigned char or unsigned short.\n"
32109 " This Writer can also generate a stack of images when the FileName is in\n"
32110 " the form of /path/file_%03d.jpg and that the input data is a 3D image\n"
32111 " data.\n"
32112 " </Documentation>\n"
32113 " <InputProperty command=\"SetInputConnection\"\n"
32114 " panel_visibility=\"never\"\n"
32115 " name=\"Input\">\n"
32116 " <DataTypeDomain composite_data_supported=\"0\"\n"
32117 " name=\"input_type\">\n"
32118 " <DataType value=\"vtkImageData\" />\n"
32119 " </DataTypeDomain>\n"
32120 " <Documentation>The input filter/source whose output dataset is to\n"
32121 " written to the file.</Documentation>\n"
32122 " </InputProperty>\n"
32123 " <StringVectorProperty command=\"SetFilePattern\"\n"
32124 " name=\"FileName\"\n"
32125 " panel_visibility=\"never\"\n"
32126 " number_of_elements=\"1\">\n"
32127 " <Documentation>The name of the file to be written.</Documentation>\n"
32128 " </StringVectorProperty>\n"
32129 " <Hints>\n"
32130 " <WriterFactory extensions=\"jpg\"\n"
32131 " file_description=\"JPEG Image Files\" />\n"
32132 " </Hints>\n"
32133 " <!-- End of JPEGWriter -->\n"
32134 " </WriterProxy>\n"
32135 "\n"
32136 " <!-- ================================================================= -->\n"
32137 " <WriterProxy class=\"vtkJSONImageWriter\"\n"
32138 " name=\"JSONImageWriter\">\n"
32139 " <Documentation short_help=\"Write image data as a JSON file.\"/>\n"
32140 " <InputProperty command=\"SetInputConnection\"\n"
32141 " panel_visibility=\"never\"\n"
32142 " name=\"Input\">\n"
32143 " <DataTypeDomain composite_data_supported=\"0\"\n"
32144 " name=\"input_type\">\n"
32145 " <DataType value=\"vtkImageData\" />\n"
32146 " </DataTypeDomain>\n"
32147 " <Documentation>The input filter/source whose output dataset is to\n"
32148 " written to the file.</Documentation>\n"
32149 " </InputProperty>\n"
32150 " <StringVectorProperty command=\"SetFileName\"\n"
32151 " name=\"FileName\"\n"
32152 " panel_visibility=\"never\"\n"
32153 " number_of_elements=\"1\">\n"
32154 " <Documentation>The name of the file to be written.</Documentation>\n"
32155 " </StringVectorProperty>\n"
32156 " <StringVectorProperty command=\"SetArrayName\"\n"
32157 " name=\"ArrayName\"\n"
32158 " number_of_elements=\"1\">\n"
32159 " <Documentation>The name of the field to export. If Empty all fields will be saved.</Documentation>\n"
32160 " </StringVectorProperty>\n"
32161 " <IntVectorProperty command=\"SetSlice\"\n"
32162 " name=\"Slice\"\n"
32163 " default_values=\"-1\"\n"
32164 " number_of_elements=\"1\">\n"
32165 " <Documentation>Write only one slice if slice >= 0</Documentation>\n"
32166 " <IntRangeDomain min=\"-1\"\n"
32167 " name=\"range\" />\n"
32168 " </IntVectorProperty>\n"
32169 " <Hints>\n"
32170 " <WriterFactory extensions=\"json\"\n"
32171 " file_description=\"json Image Files\" />\n"
32172 " </Hints>\n"
32173 " <!-- End of vtkJSONImageWriter -->\n"
32174 " </WriterProxy>\n"
32175 "\n"
32176 " </ProxyGroup>\n"
32177 "</ServerManagerConfiguration>\n"
32178 "\n";
32179 // Get single string
32181 {
32182
32183  const size_t len0 = strlen(paraview_server_managerwriters_pv_ioimageInterface0);
32184  size_t len = ( 0
32185  + len0 );
32186  char* res = new char[ len + 1];
32187  size_t offset = 0;
32189  assert(offset == len);
32190  res[offset] = 0;
32191  return res;
32192 }
32193
32194
32195 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/Resources/readers_ioexodus.xml
32197 "<ServerManagerConfiguration>\n"
32198 " <ProxyGroup name=\"internal_sources\">\n"
32199 " <!-- ================================================================== -->\n"
32200 " <SourceProxy class=\"vtkPExodusIIReader\"\n"
32201 " name=\"ExodusIIReaderCore\">\n"
32202 " <Documentation long_help=\"Reads an Exodus II file to produce an unstructured grid.\"\n"
32203 " short_help=\"Read Exodus II files.\">The Exodus reader loads\n"
32204 " Exodus II files and produces an unstructured grid output.\n"
32205 " The default file extensions are .g, .e, .ex2, .ex2v2,\n"
32206 " .exo, .gen, .exoII, .exii, .frq, .0, .00, .000, and\n"
32207 " .0000. This is a distributed reader.\n"
32208 " </Documentation>\n"
32209 " <StringVectorProperty animateable=\"0\"\n"
32210 " command=\"SetFileName\"\n"
32211 " name=\"FileName\"\n"
32212 " number_of_elements=\"1\"\n"
32213 " panel_visibility=\"never\">\n"
32214 " <FileListDomain name=\"files\" />\n"
32215 " <Documentation>This property specifies the file name for the Exodus\n"
32216 " reader.</Documentation>\n"
32217 " </StringVectorProperty>\n"
32218 " <IntVectorProperty command=\"SetHasModeShapes\"\n"
32219 " default_values=\"0\"\n"
32220 " name=\"HasModeShapes\"\n"
32221 " number_of_elements=\"1\">\n"
32222 " <BooleanDomain name=\"bool\" />\n"
32223 " <Documentation>Some simulations overload the Exodus time steps to\n"
32224 " represent mode shapes. In this case, it does not make sense to iterate\n"
32225 " over the \"time steps\", because they are not meant to be played in\n"
32226 " order. Rather, each represents the vibration at a different \"mode.\"\n"
32227 " Setting the value of this property to 1 changes the semantics of the\n"
32228 " reader to not report the time steps to downstream\n"
32229 " filters.</Documentation>\n"
32230 " </IntVectorProperty>\n"
32231 " <IntVectorProperty animateable=\"0\"\n"
32232 " command=\"SetAnimateModeShapes\"\n"
32233 " default_values=\"1\"\n"
32234 " label=\"Animate Vibrations\"\n"
32235 " name=\"AnimateVibrations\"\n"
32236 " number_of_elements=\"1\">\n"
32237 " <BooleanDomain name=\"bool\" />\n"
32238 " <Documentation>If this flag is on and HasModeShapes is also on, then\n"
32239 " this reader will report a continuous time range [0,1] and animate the\n"
32240 " displacements in a periodic sinusoid. If this flag is off and\n"
32241 " HasModeShapes is on, this reader ignores time. This flag has no effect\n"
32242 " if HasModeShapes is off.</Documentation>\n"
32243 " </IntVectorProperty>\n"
32244 " <!-- The following two properties magically send time information -->\n"
32245 " <!-- to the animation panel. Usually you only need one (the former -->\n"
32246 " <!-- for discrete time, the latter for continuous time), but changing -->\n"
32247 " <!-- the HasModeShapes ivar switches between discrete and continuous -->\n"
32248 " <!-- time. -->\n"
32249 " <DoubleVectorProperty information_only=\"1\"\n"
32250 " name=\"TimestepValues\"\n"
32251 " repeatable=\"1\">\n"
32252 " <TimeStepsInformationHelper />\n"
32253 " </DoubleVectorProperty>\n"
32254 " <IntVectorProperty command=\"GetModeShapesRange\"\n"
32255 " information_only=\"1\"\n"
32256 " name=\"ModeShapesRangeInfo\"></IntVectorProperty>\n"
32257 " <IntVectorProperty command=\"SetModeShape\"\n"
32258 " default_values=\"1\"\n"
32259 " name=\"ModeShape\"\n"
32260 " number_of_elements=\"1\">\n"
32261 " <IntRangeDomain name=\"range\" default_mode=\"min\">\n"
32262 " <RequiredProperties>\n"
32263 " <Property function=\"Range\"\n"
32264 " name=\"ModeShapesRangeInfo\" />\n"
32265 " </RequiredProperties>\n"
32266 " </IntRangeDomain>\n"
32267 " <Documentation>Specify which mode shape to animate when HasModeShapes\n"
32268 " is on.</Documentation>\n"
32269 " </IntVectorProperty>\n"
32270 " <IntVectorProperty command=\"SetIgnoreFileTime\"\n"
32271 " animateable=\"0\"\n"
32272 " default_values=\"0\"\n"
32273 " name=\"IgnoreFileTime\"\n"
32274 " label=\"Ignore File Time\"\n"
32275 " number_of_elements=\"1\">\n"
32276 " <BooleanDomain name=\"bool\" />\n"
32277 " <Documentation>If on, the reader will ignore the time value reported at\n"
32278 " each time step, using the index of the time step as the time value. This\n"
32279 " is useful for Exodus files where different time steps are overloaded to\n"
32280 " represent different aspects of a data set rather than the data set at\n"
32281 " different time values.\n"
32282 " </Documentation>\n"
32283 " </IntVectorProperty>\n"
32284 " <StringVectorProperty information_only=\"1\"\n"
32285 " name=\"EdgeBlocksInfo\">\n"
32286 " <ArraySelectionInformationHelper attribute_name=\"EdgeBlock\" />\n"
32287 " </StringVectorProperty>\n"
32288 " <StringVectorProperty command=\"SetEdgeBlockArrayStatus\"\n"
32289 " element_types=\"2 0\"\n"
32290 " information_property=\"EdgeBlocksInfo\"\n"
32291 " name=\"EdgeBlocks\"\n"
32292 " number_of_elements_per_command=\"2\"\n"
32293 " repeat_command=\"1\">\n"
32294 " <ArraySelectionDomain name=\"array_list\">\n"
32295 " <RequiredProperties>\n"
32296 " <Property function=\"ArrayList\"\n"
32297 " name=\"EdgeBlocksInfo\" />\n"
32298 " </RequiredProperties>\n"
32299 " </ArraySelectionDomain>\n"
32300 " <Documentation>Use this property to select which blocks of edges should\n"
32301 " be loaded. All edges in the same block will have the same interpolant\n"
32302 " (linear, quadratic, etc.) and have the same variables defined over\n"
32303 " them.</Documentation>\n"
32304 " </StringVectorProperty>\n"
32305 " <StringVectorProperty information_only=\"1\"\n"
32306 " name=\"FaceBlocksInfo\">\n"
32307 " <ArraySelectionInformationHelper attribute_name=\"FaceBlock\" />\n"
32308 " </StringVectorProperty>\n"
32309 " <StringVectorProperty command=\"SetFaceBlockArrayStatus\"\n"
32310 " element_types=\"2 0\"\n"
32311 " information_property=\"FaceBlocksInfo\"\n"
32312 " name=\"FaceBlocks\"\n"
32313 " number_of_elements_per_command=\"2\"\n"
32314 " repeat_command=\"1\">\n"
32315 " <ArraySelectionDomain name=\"array_list\">\n"
32316 " <RequiredProperties>\n"
32317 " <Property function=\"ArrayList\"\n"
32318 " name=\"FaceBlocksInfo\" />\n"
32319 " </RequiredProperties>\n"
32320 " </ArraySelectionDomain>\n"
32321 " <Documentation>Use this property to select which blocks of faces should\n"
32322 " be loaded. All faces in the same block will have the same interpolant\n"
32323 " (triangular, bilinear quadrilateral, etc.) and have the same variables\n"
32324 " defined over them.</Documentation>\n"
32325 " </StringVectorProperty>\n"
32326 " <StringVectorProperty information_only=\"1\"\n"
32327 " name=\"ElementBlocksInfo\">\n"
32328 " <ArraySelectionInformationHelper attribute_name=\"ElementBlock\" />\n"
32329 " </StringVectorProperty>\n"
32330 " <StringVectorProperty command=\"SetElementBlockArrayStatus\"\n"
32331 " element_types=\"2 0\"\n"
32332 " information_property=\"ElementBlocksInfo\"\n"
32333 " name=\"ElementBlocks\"\n"
32334 " number_of_elements_per_command=\"2\"\n"
32335 " repeat_command=\"1\">\n"
32336 " <ArraySelectionDomain name=\"array_list\">\n"
32337 " <RequiredProperties>\n"
32338 " <Property function=\"ArrayList\"\n"
32339 " name=\"ElementBlocksInfo\" />\n"
32340 " </RequiredProperties>\n"
32341 " </ArraySelectionDomain>\n"
32342 " <Documentation>Use this property to select which blocks of elements\n"
32343 " (cells) should be loaded. All elements (cells) in the same block will\n"
32344 " have the same interpolant (tetrahedral, triangular, trilinear\n"
32345 " hexahedral, etc.) and have the same variables defined over\n"
32346 " them.</Documentation>\n"
32347 " </StringVectorProperty>\n"
32348 " <StringVectorProperty information_only=\"1\"\n"
32349 " name=\"GlobalVariablesInfo\">\n"
32350 " <ArraySelectionInformationHelper attribute_name=\"GlobalResult\" />\n"
32351 " </StringVectorProperty>\n"
32352 " <StringVectorProperty command=\"SetGlobalResultArrayStatus\"\n"
32353 " element_types=\"2 0\"\n"
32354 " information_property=\"GlobalVariablesInfo\"\n"
32355 " name=\"GlobalVariables\"\n"
32356 " number_of_elements_per_command=\"2\"\n"
32357 " repeat_command=\"1\">\n"
32358 " <ArraySelectionDomain name=\"array_list\">\n"
32359 " <RequiredProperties>\n"
32360 " <Property function=\"ArrayList\"\n"
32361 " name=\"GlobalVariablesInfo\" />\n"
32362 " </RequiredProperties>\n"
32363 " </ArraySelectionDomain>\n"
32364 " <Documentation>Use this property to select which global (i.e.,\n"
32365 " per-mesh) variables should be loaded. Global variables are stored as\n"
32366 " arrays in the field data of the reader's output.</Documentation>\n"
32367 " </StringVectorProperty>\n"
32368 " <StringVectorProperty information_only=\"1\"\n"
32369 " name=\"PointVariablesInfo\">\n"
32370 " <ArraySelectionInformationHelper attribute_name=\"PointResult\" />\n"
32371 " </StringVectorProperty>\n"
32372 " <StringVectorProperty command=\"SetPointResultArrayStatus\"\n"
32373 " element_types=\"2 0\"\n"
32374 " information_property=\"PointVariablesInfo\"\n"
32375 " name=\"PointVariables\"\n"
32376 " number_of_elements_per_command=\"2\"\n"
32377 " repeat_command=\"1\">\n"
32378 " <ArraySelectionDomain name=\"array_list\">\n"
32379 " <RequiredProperties>\n"
32380 " <Property function=\"ArrayList\"\n"
32381 " name=\"PointVariablesInfo\" />\n"
32382 " </RequiredProperties>\n"
32383 " </ArraySelectionDomain>\n"
32384 " <Documentation>Use this property to select which nodal (i.e.,\n"
32385 " per-point) variables should be loaded.</Documentation>\n"
32386 " </StringVectorProperty>\n"
32387 " <StringVectorProperty information_only=\"1\"\n"
32388 " name=\"EdgeVariablesInfo\">\n"
32389 " <ArraySelectionInformationHelper attribute_name=\"EdgeResult\" />\n"
32390 " </StringVectorProperty>\n"
32391 " <StringVectorProperty command=\"SetEdgeResultArrayStatus\"\n"
32392 " element_types=\"2 0\"\n"
32393 " information_property=\"EdgeVariablesInfo\"\n"
32394 " name=\"EdgeVariables\"\n"
32395 " number_of_elements_per_command=\"2\"\n"
32396 " repeat_command=\"1\">\n"
32397 " <ArraySelectionDomain name=\"array_list\">\n"
32398 " <RequiredProperties>\n"
32399 " <Property function=\"ArrayList\"\n"
32400 " name=\"EdgeVariablesInfo\" />\n"
32401 " </RequiredProperties>\n"
32402 " </ArraySelectionDomain>\n"
32403 " <Documentation>Use this property to select which variables defined over\n"
32404 " edges should be loaded. Edges are oriented boundaries of one or more\n"
32405 " higher-dimensional cells also present in the mesh. Edge variables\n"
32406 " specify a single value per entry in some edge block.</Documentation>\n"
32407 " </StringVectorProperty>\n"
32408 " <StringVectorProperty information_only=\"1\"\n"
32409 " name=\"FaceVariablesInfo\">\n"
32410 " <ArraySelectionInformationHelper attribute_name=\"FaceResult\" />\n"
32411 " </StringVectorProperty>\n"
32412 " <StringVectorProperty command=\"SetFaceResultArrayStatus\"\n"
32413 " element_types=\"2 0\"\n"
32414 " information_property=\"FaceVariablesInfo\"\n"
32415 " name=\"FaceVariables\"\n"
32416 " number_of_elements_per_command=\"2\"\n"
32417 " repeat_command=\"1\">\n"
32418 " <ArraySelectionDomain name=\"array_list\">\n"
32419 " <RequiredProperties>\n"
32420 " <Property function=\"ArrayList\"\n"
32421 " name=\"FaceVariablesInfo\" />\n"
32422 " </RequiredProperties>\n"
32423 " </ArraySelectionDomain>\n"
32424 " <Documentation>Use this property to select which variables defined over\n"
32425 " faces should be loaded. Faces are oriented boundaries of one or more\n"
32426 " higher-dimensional cells also present in the mesh. Face variables\n"
32427 " specify a single value per entry in some face block.</Documentation>\n"
32428 " </StringVectorProperty>\n"
32429 " <StringVectorProperty information_only=\"1\"\n"
32430 " name=\"ElementVariablesInfo\">\n"
32431 " <ArraySelectionInformationHelper attribute_name=\"ElementResult\" />\n"
32432 " </StringVectorProperty>\n"
32433 " <StringVectorProperty command=\"SetElementResultArrayStatus\"\n"
32434 " element_types=\"2 0\"\n"
32435 " information_property=\"ElementVariablesInfo\"\n"
32436 " name=\"ElementVariables\"\n"
32437 " number_of_elements_per_command=\"2\"\n"
32438 " repeat_command=\"1\">\n"
32439 " <ArraySelectionDomain name=\"array_list\">\n"
32440 " <RequiredProperties>\n"
32441 " <Property function=\"ArrayList\"\n"
32442 " name=\"ElementVariablesInfo\" />\n"
32443 " </RequiredProperties>\n"
32444 " </ArraySelectionDomain>\n"
32445 " <Documentation>Use this property to select which variables defined over\n"
32446 " elements (cells) should be loaded. Element variables specify a single\n"
32447 " value per entry in some element block.</Documentation>\n"
32448 " </StringVectorProperty>\n"
32449 " <StringVectorProperty information_only=\"1\"\n"
32450 " name=\"NodeMapInfo\">\n"
32451 " <ArraySelectionInformationHelper attribute_name=\"NodeMap\" />\n"
32452 " </StringVectorProperty>\n"
32453 " <StringVectorProperty command=\"SetNodeMapArrayStatus\"\n"
32454 " element_types=\"2 0\"\n"
32455 " information_property=\"NodeMapInfo\"\n"
32456 " name=\"NodeMapArrayStatus\"\n"
32457 " number_of_elements_per_command=\"2\"\n"
32458 " repeat_command=\"1\">\n"
32459 " <ArraySelectionDomain name=\"array_list\">\n"
32460 " <RequiredProperties>\n"
32461 " <Property function=\"ArrayList\"\n"
32462 " name=\"NodeMapInfo\" />\n"
32463 " </RequiredProperties>\n"
32464 " </ArraySelectionDomain>\n"
32465 " <Documentation>Specify which maps defined over nodes (points) in the\n"
32466 " mesh should be loaded. A node map is a renumbering of all the points in\n"
32467 " a file from their offset in the file to some arbitrary integers,\n"
32468 " usually specifying a unique global ID across a set of files. These are\n"
32469 " sometimes called new-style maps because they are specified differently\n"
32470 " than in older Exodus files, which only allowed a single node\n"
32471 " map.</Documentation>\n"
32472 " </StringVectorProperty>\n"
32473 " <StringVectorProperty information_only=\"1\"\n"
32474 " name=\"EdgeMapInfo\">\n"
32475 " <ArraySelectionInformationHelper attribute_name=\"EdgeMap\" />\n"
32476 ;
32477
32478 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/Resources/readers_ioexodus.xml
32480 " </StringVectorProperty>\n"
32481 " <StringVectorProperty command=\"SetEdgeMapArrayStatus\"\n"
32482 " element_types=\"2 0\"\n"
32483 " information_property=\"EdgeMapInfo\"\n"
32484 " name=\"EdgeMapArrayStatus\"\n"
32485 " number_of_elements_per_command=\"2\"\n"
32486 " repeat_command=\"1\">\n"
32487 " <ArraySelectionDomain name=\"array_list\">\n"
32488 " <RequiredProperties>\n"
32489 " <Property function=\"ArrayList\"\n"
32490 " name=\"EdgeMapInfo\" />\n"
32491 " </RequiredProperties>\n"
32492 " </ArraySelectionDomain>\n"
32493 " <Documentation>Specify which maps defined over edges in the mesh should\n"
32494 " be loaded. An edge map is a renumbering of all the edges (across all\n"
32495 " the edge blocks of a file) from their offset in the file to some\n"
32496 " arbitrary integers, usually specifying a unique global ID across a set\n"
32497 " of files.</Documentation>\n"
32498 " <Hints>\n"
32499 " <OmitFromLoadAllVariables />\n"
32500 " </Hints>\n"
32501 " </StringVectorProperty>\n"
32502 " <StringVectorProperty information_only=\"1\"\n"
32503 " name=\"FaceMapInfo\">\n"
32504 " <ArraySelectionInformationHelper attribute_name=\"FaceMap\" />\n"
32505 " </StringVectorProperty>\n"
32506 " <StringVectorProperty command=\"SetFaceMapArrayStatus\"\n"
32507 " element_types=\"2 0\"\n"
32508 " information_property=\"FaceMapInfo\"\n"
32509 " name=\"FaceMapArrayStatus\"\n"
32510 " number_of_elements_per_command=\"2\"\n"
32511 " repeat_command=\"1\">\n"
32512 " <ArraySelectionDomain name=\"array_list\">\n"
32513 " <RequiredProperties>\n"
32514 " <Property function=\"ArrayList\"\n"
32515 " name=\"FaceMapInfo\" />\n"
32516 " </RequiredProperties>\n"
32517 " </ArraySelectionDomain>\n"
32518 " <Documentation>Specify which maps defined over faces in the mesh should\n"
32519 " be loaded. A face map is a renumbering of all the faces (across all the\n"
32520 " face blocks of a file) from their offset in the file to some arbitrary\n"
32521 " integers, usually specifying a unique global ID across a set of\n"
32522 " files.</Documentation>\n"
32523 " <Hints>\n"
32524 " <OmitFromLoadAllVariables />\n"
32525 " </Hints>\n"
32526 " </StringVectorProperty>\n"
32527 " <StringVectorProperty information_only=\"1\"\n"
32528 " name=\"ElementMapInfo\">\n"
32529 " <ArraySelectionInformationHelper attribute_name=\"ElementMap\" />\n"
32530 " </StringVectorProperty>\n"
32531 " <StringVectorProperty command=\"SetElementMapArrayStatus\"\n"
32532 " element_types=\"2 0\"\n"
32533 " information_property=\"ElementMapInfo\"\n"
32534 " name=\"ElementMapArrayStatus\"\n"
32535 " number_of_elements_per_command=\"2\"\n"
32536 " repeat_command=\"1\">\n"
32537 " <ArraySelectionDomain name=\"array_list\">\n"
32538 " <RequiredProperties>\n"
32539 " <Property function=\"ArrayList\"\n"
32540 " name=\"ElementMapInfo\" />\n"
32541 " </RequiredProperties>\n"
32542 " </ArraySelectionDomain>\n"
32543 " <Documentation>Specify which maps defined over elements (cells) in the\n"
32544 " mesh should be loaded. An element map is a renumbering of all the\n"
32545 " elements (across all the element blocks of a file) from their offset in\n"
32546 " the file to some arbitrary integers, usually specifying a unique global\n"
32547 " ID across a set of files. These are sometimes called new-style maps\n"
32548 " because they are specified differently than in older Exodus files,\n"
32549 " which only allowed a single element map.</Documentation>\n"
32550 " <Hints>\n"
32551 " <OmitFromLoadAllVariables />\n"
32552 " </Hints>\n"
32553 " </StringVectorProperty>\n"
32554 " <StringVectorProperty information_only=\"1\"\n"
32555 " name=\"NodeSetInfo\">\n"
32556 " <ArraySelectionInformationHelper attribute_name=\"NodeSet\" />\n"
32557 " </StringVectorProperty>\n"
32558 " <StringVectorProperty command=\"SetNodeSetArrayStatus\"\n"
32559 " element_types=\"2 0\"\n"
32560 " information_property=\"NodeSetInfo\"\n"
32561 " name=\"NodeSetArrayStatus\"\n"
32562 " number_of_elements_per_command=\"2\"\n"
32563 " repeat_command=\"1\">\n"
32564 " <ArraySelectionDomain name=\"array_list\">\n"
32565 " <RequiredProperties>\n"
32566 " <Property function=\"ArrayList\"\n"
32567 " name=\"NodeSetInfo\" />\n"
32568 " </RequiredProperties>\n"
32569 " </ArraySelectionDomain>\n"
32570 " <Documentation>An Exodus II file may define subsets of all the nodes\n"
32571 " (points) in a file as sets in their own right. Variables, such as\n"
32572 " boundary conditions, may then be defined over these sets by specifying\n"
32573 " a single number per node. This property specifies which of those sets\n"
32574 " should be loaded. The accompanying NodeSetResultArrayStatus property\n"
32575 " specifies which variables defined over those sets should be\n"
32576 " loaded.</Documentation>\n"
32577 " <Hints>\n"
32578 " <OmitFromLoadAllVariables />\n"
32579 " </Hints>\n"
32580 " </StringVectorProperty>\n"
32581 " <StringVectorProperty information_only=\"1\"\n"
32582 " name=\"SideSetInfo\">\n"
32583 " <ArraySelectionInformationHelper attribute_name=\"SideSet\" />\n"
32584 " </StringVectorProperty>\n"
32585 " <StringVectorProperty command=\"SetSideSetArrayStatus\"\n"
32586 " element_types=\"2 0\"\n"
32587 " information_property=\"SideSetInfo\"\n"
32588 " name=\"SideSetArrayStatus\"\n"
32589 " number_of_elements_per_command=\"2\"\n"
32590 " repeat_command=\"1\">\n"
32591 " <ArraySelectionDomain name=\"array_list\">\n"
32592 " <RequiredProperties>\n"
32593 " <Property function=\"ArrayList\"\n"
32594 " name=\"SideSetInfo\" />\n"
32595 " </RequiredProperties>\n"
32596 " </ArraySelectionDomain>\n"
32597 " <Documentation>An Exodus II file may define subsets of all the\n"
32598 " <i>boundaries</i>of all the elements in a file as sets in their own\n"
32599 " right. This property specifies which of those sets should be loaded.\n"
32600 " Variables, such as boundary conditions, may then be defined over these\n"
32601 " sets by specifying a single number per side. For example, a hexahedron\n"
32602 " has 18 sides: 6 faces and 12 edges. Any of these sides may be\n"
32603 " individually called out in a set and assigned a result value. The\n"
32604 " accompanying SideSetResultArrayStatus property specifies which\n"
32605 " variables defined over those sets should be loaded.</Documentation>\n"
32606 " <Hints>\n"
32607 " <OmitFromLoadAllVariables />\n"
32608 " </Hints>\n"
32609 " </StringVectorProperty>\n"
32610 " <StringVectorProperty information_only=\"1\"\n"
32611 " name=\"FaceSetInfo\">\n"
32612 " <ArraySelectionInformationHelper attribute_name=\"FaceSet\" />\n"
32613 " </StringVectorProperty>\n"
32614 " <StringVectorProperty command=\"SetFaceSetArrayStatus\"\n"
32615 " element_types=\"2 0\"\n"
32616 " information_property=\"FaceSetInfo\"\n"
32617 " name=\"FaceSetArrayStatus\"\n"
32618 " number_of_elements_per_command=\"2\"\n"
32619 " repeat_command=\"1\">\n"
32620 " <ArraySelectionDomain name=\"array_list\">\n"
32621 " <RequiredProperties>\n"
32622 " <Property function=\"ArrayList\"\n"
32623 " name=\"FaceSetInfo\" />\n"
32624 " </RequiredProperties>\n"
32625 " </ArraySelectionDomain>\n"
32626 " <Documentation>An Exodus II file may define subsets of all the faces\n"
32627 " (across all face blocks) in a file as sets in their own right. This\n"
32628 " property specifies which of those sets should be loaded. Variables,\n"
32629 " such as boundary conditions, may then be defined over these sets by\n"
32630 " specifying a single number per face. The accompanying\n"
32631 " FaceSetResultArrayStatus property specifies which variables defined\n"
32632 " over those sets should be loaded.</Documentation>\n"
32633 " <Hints>\n"
32634 " <OmitFromLoadAllVariables />\n"
32635 " </Hints>\n"
32636 " </StringVectorProperty>\n"
32637 " <StringVectorProperty information_only=\"1\"\n"
32638 " name=\"EdgeSetInfo\">\n"
32639 " <ArraySelectionInformationHelper attribute_name=\"EdgeSet\" />\n"
32640 " </StringVectorProperty>\n"
32641 " <StringVectorProperty command=\"SetEdgeSetArrayStatus\"\n"
32642 " element_types=\"2 0\"\n"
32643 " information_property=\"EdgeSetInfo\"\n"
32644 " name=\"EdgeSetArrayStatus\"\n"
32645 " number_of_elements_per_command=\"2\"\n"
32646 " repeat_command=\"1\">\n"
32647 " <ArraySelectionDomain name=\"array_list\">\n"
32648 " <RequiredProperties>\n"
32649 " <Property function=\"ArrayList\"\n"
32650 " name=\"EdgeSetInfo\" />\n"
32651 " </RequiredProperties>\n"
32652 " </ArraySelectionDomain>\n"
32653 " <Documentation>An Exodus II file may define subsets of all the edges\n"
32654 " (across all edge blocks) in a file as sets in their own right. This\n"
32655 " property specifies which of those sets should be loaded. Variables,\n"
32656 " such as boundary conditions, may then be defined over these sets by\n"
32657 " specifying a single number per edge. The accompanying\n"
32658 " EdgeSetResultArrayStatus property specifies which variables defined\n"
32659 " over those sets should be loaded.</Documentation>\n"
32660 " <Hints>\n"
32661 " <OmitFromLoadAllVariables />\n"
32662 " </Hints>\n"
32663 " </StringVectorProperty>\n"
32664 " <StringVectorProperty information_only=\"1\"\n"
32665 " name=\"ElementSetInfo\">\n"
32666 " <ArraySelectionInformationHelper attribute_name=\"ElementSet\" />\n"
32667 " </StringVectorProperty>\n"
32668 " <StringVectorProperty command=\"SetElementSetArrayStatus\"\n"
32669 " element_types=\"2 0\"\n"
32670 " information_property=\"ElementSetInfo\"\n"
32671 " name=\"ElementSetArrayStatus\"\n"
32672 " number_of_elements_per_command=\"2\"\n"
32673 " repeat_command=\"1\">\n"
32674 " <ArraySelectionDomain name=\"array_list\">\n"
32675 " <RequiredProperties>\n"
32676 " <Property function=\"ArrayList\"\n"
32677 " name=\"ElementSetInfo\" />\n"
32678 " </RequiredProperties>\n"
32679 " </ArraySelectionDomain>\n"
32680 " <Documentation>An Exodus II file may define subsets of all the elements\n"
32681 " (across all element blocks) in a file as sets in their own right. This\n"
32682 " property specifies which of those sets should be loaded. Variables,\n"
32683 " such as feature classifiers, may then be defined over these sets by\n"
32684 " specifying a single number per element. The accompanying\n"
32685 " ElementSetResultArrayStatus property specifies which variables defined\n"
32686 " over those sets should be loaded.</Documentation>\n"
32687 " <Hints>\n"
32688 " <OmitFromLoadAllVariables />\n"
32689 " </Hints>\n"
32690 " </StringVectorProperty>\n"
32691 " <StringVectorProperty information_only=\"1\"\n"
32692 " name=\"ElementSetResultArrayInfo\">\n"
32693 " <ArraySelectionInformationHelper attribute_name=\"ElementSetResult\" />\n"
32694 " </StringVectorProperty>\n"
32695 " <StringVectorProperty command=\"SetElementSetResultArrayStatus\"\n"
32696 " element_types=\"2 0\"\n"
32697 " information_property=\"ElementSetResultArrayInfo\"\n"
32698 " name=\"ElementSetResultArrayStatus\"\n"
32699 " number_of_elements_per_command=\"2\"\n"
32700 " repeat_command=\"1\">\n"
32701 " <ArraySelectionDomain name=\"array_list\">\n"
32702 " <RequiredProperties>\n"
32703 " <Property function=\"ArrayList\"\n"
32704 " name=\"ElementSetResultArrayInfo\" />\n"
32705 " </RequiredProperties>\n"
32706 " </ArraySelectionDomain>\n"
32707 " <Documentation>An Exodus II file may define subsets of all the elements\n"
32708 " (across all element blocks) in a file as sets in their own right.\n"
32709 " Variables, such as feature classifiers, may then be defined over these\n"
32710 " sets by specifying a single number per element. This property specifies\n"
32711 " which of those variables should be loaded. The corresponding set must\n"
32712 " also be loaded using the ElementSetArrayStatus property in order for\n"
32713 " the variable to appear.</Documentation>\n"
32714 " <Hints>\n"
32715 " <OmitFromLoadAllVariables />\n"
32716 " </Hints>\n"
32717 " </StringVectorProperty>\n"
32718 " <StringVectorProperty information_only=\"1\"\n"
32719 " name=\"SideSetResultArrayInfo\">\n"
32720 " <ArraySelectionInformationHelper attribute_name=\"SideSetResult\" />\n"
32721 " </StringVectorProperty>\n"
32722 " <StringVectorProperty command=\"SetSideSetResultArrayStatus\"\n"
32723 " element_types=\"2 0\"\n"
32724 " information_property=\"SideSetResultArrayInfo\"\n"
32725 " name=\"SideSetResultArrayStatus\"\n"
32726 " number_of_elements_per_command=\"2\"\n"
32727 " repeat_command=\"1\">\n"
32728 " <ArraySelectionDomain name=\"array_list\">\n"
32729 " <RequiredProperties>\n"
32730 " <Property function=\"ArrayList\"\n"
32731 " name=\"SideSetResultArrayInfo\" />\n"
32732 " </RequiredProperties>\n"
32733 " </ArraySelectionDomain>\n"
32734 " <Documentation>An Exodus II file may define subsets of all the\n"
32735 " <i>boundaries</i>of all the elements in a file as sets in their own\n"
32736 " right. Variables, such as boundary conditions, may then be defined over\n"
32737 " these sets by specifying a single number per side. For example, a\n"
32738 " hexahedron has 18 sides: 6 faces and 12 edges. Any of these sides may\n"
32739 " be individually called out in a set and assigned a result value. This\n"
32740 " property specifies which of those variables should be loaded. The\n"
32741 " corresponding set must also be loaded using the SideSetArrayStatus\n"
32742 " property in order for the variable to appear.</Documentation>\n"
32743 " <Hints>\n"
32744 " <OmitFromLoadAllVariables />\n"
32745 " </Hints>\n"
32746 " </StringVectorProperty>\n"
32747 " <StringVectorProperty information_only=\"1\"\n"
32748 " name=\"FaceSetResultArrayInfo\">\n"
32749 " <ArraySelectionInformationHelper attribute_name=\"FaceSetResult\" />\n"
32750 " </StringVectorProperty>\n"
32751 " <StringVectorProperty command=\"SetFaceSetResultArrayStatus\"\n"
32752 " element_types=\"2 0\"\n"
32753 " information_property=\"FaceSetResultArrayInfo\"\n"
32754 " name=\"FaceSetResultArrayStatus\"\n"
32755 " number_of_elements_per_command=\"2\"\n"
32756 " repeat_command=\"1\">\n"
32757 " <ArraySelectionDomain name=\"array_list\">\n"
32758 " <RequiredProperties>\n"
32759 " <Property function=\"ArrayList\"\n"
32760 " name=\"FaceSetResultArrayInfo\" />\n"
32761 " </RequiredProperties>\n"
32762 " </ArraySelectionDomain>\n"
32763 " <Documentation>An Exodus II file may define subsets of all the faces\n"
32764 ;
32765
32766 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/Resources/readers_ioexodus.xml
32768 " (across all face blocks) in a file as sets in their own right.\n"
32769 " Variables, such as boundary conditions, may then be defined over these\n"
32770 " sets by specifying a single number per face. This property specifies\n"
32771 " which of those variables should be loaded. The corresponding set must\n"
32772 " also be loaded using the FaceSetArrayStatus property in order for the\n"
32773 " variable to appear.</Documentation>\n"
32774 " <Hints>\n"
32775 " <OmitFromLoadAllVariables />\n"
32776 " </Hints>\n"
32777 " </StringVectorProperty>\n"
32778 " <StringVectorProperty information_only=\"1\"\n"
32779 " name=\"EdgeSetResultArrayInfo\">\n"
32780 " <ArraySelectionInformationHelper attribute_name=\"EdgeSetResult\" />\n"
32781 " </StringVectorProperty>\n"
32782 " <StringVectorProperty command=\"SetEdgeSetResultArrayStatus\"\n"
32783 " element_types=\"2 0\"\n"
32784 " information_property=\"EdgeSetResultArrayInfo\"\n"
32785 " name=\"EdgeSetResultArrayStatus\"\n"
32786 " number_of_elements_per_command=\"2\"\n"
32787 " repeat_command=\"1\">\n"
32788 " <ArraySelectionDomain name=\"array_list\">\n"
32789 " <RequiredProperties>\n"
32790 " <Property function=\"ArrayList\"\n"
32791 " name=\"EdgeSetResultArrayInfo\" />\n"
32792 " </RequiredProperties>\n"
32793 " </ArraySelectionDomain>\n"
32794 " <Documentation>An Exodus II file may define subsets of all the edges\n"
32795 " (across all edge blocks) in a file as sets in their own right.\n"
32796 " Variables, such as boundary conditions, may then be defined over these\n"
32797 " sets by specifying a single number per edge. This property specifies\n"
32798 " which of those variables should be loaded. The corresponding set must\n"
32799 " also be loaded using the EdgeSetArrayStatus property in order for the\n"
32800 " variable to appear.</Documentation>\n"
32801 " <Hints>\n"
32802 " <OmitFromLoadAllVariables />\n"
32803 " </Hints>\n"
32804 " </StringVectorProperty>\n"
32805 " <StringVectorProperty information_only=\"1\"\n"
32806 " name=\"NodeSetResultArrayInfo\">\n"
32807 " <ArraySelectionInformationHelper attribute_name=\"NodeSetResult\" />\n"
32808 " </StringVectorProperty>\n"
32809 " <StringVectorProperty command=\"SetNodeSetResultArrayStatus\"\n"
32810 " element_types=\"2 0\"\n"
32811 " information_property=\"NodeSetResultArrayInfo\"\n"
32812 " name=\"NodeSetResultArrayStatus\"\n"
32813 " number_of_elements_per_command=\"2\"\n"
32814 " repeat_command=\"1\">\n"
32815 " <ArraySelectionDomain name=\"array_list\">\n"
32816 " <RequiredProperties>\n"
32817 " <Property function=\"ArrayList\"\n"
32818 " name=\"NodeSetResultArrayInfo\" />\n"
32819 " </RequiredProperties>\n"
32820 " </ArraySelectionDomain>\n"
32821 " <Documentation>An Exodus II file may define subsets of all the nodes\n"
32822 " (points) in a file as sets in their own right. Variables, such as\n"
32823 " boundary conditions, may then be defined over these sets by specifying\n"
32824 " a single number per node. This property specifies which of those\n"
32825 " variables should be loaded. The corresponding set must also be loaded\n"
32826 " using the NodeSetArrayStatus property in order for the variable to\n"
32827 " appear.</Documentation>\n"
32828 " <Hints>\n"
32829 " <OmitFromLoadAllVariables />\n"
32830 " </Hints>\n"
32831 " </StringVectorProperty>\n"
32832 " <IntVectorProperty command=\"SetApplyDisplacements\"\n"
32833 " default_values=\"1\"\n"
32834 " name=\"ApplyDisplacements\"\n"
32835 " number_of_elements=\"1\">\n"
32836 " <BooleanDomain name=\"bool\" />\n"
32837 " <Documentation>Geometric locations can include displacements. When this\n"
32838 " option is on, the nodal positions are 'displaced' by the standard\n"
32839 " exodus displacement vector. If displacements are turned 'off', the user\n"
32840 " can explicitly add them by applying a warp filter.</Documentation>\n"
32841 " </IntVectorProperty>\n"
32842 " <DoubleVectorProperty command=\"SetDisplacementMagnitude\"\n"
32843 " default_values=\"1\"\n"
32844 " name=\"DisplacementMagnitude\"\n"
32845 " number_of_elements=\"1\">\n"
32846 " <DoubleRangeDomain name=\"range\" />\n"
32847 " <Documentation>When displacements are being applied, they are scaled by\n"
32848 " this amount. Set to 1 for no scaling.</Documentation>\n"
32849 " </DoubleVectorProperty>\n"
32850 " <IntVectorProperty command=\"SetGenerateObjectIdCellArray\"\n"
32851 " default_values=\"1\"\n"
32852 " name=\"GenerateObjectIdCellArray\"\n"
32853 " number_of_elements=\"1\">\n"
32854 " <BooleanDomain name=\"bool\" />\n"
32855 " <Documentation>Specifies whether a variable named \"ObjectId\" should be\n"
32856 " created for each entry of each block and set being loaded and assigned\n"
32857 " the identifying number of the block or set, so that given a cell one\n"
32858 " can readily identify the block or set it came from. This is useful for\n"
32859 " coloring a mesh by block ID or set ID.</Documentation>\n"
32860 " </IntVectorProperty>\n"
32861 " <IntVectorProperty command=\"SetGenerateGlobalNodeIdArray\"\n"
32862 " default_values=\"1\"\n"
32863 " name=\"GenerateGlobalNodeIdArray\"\n"
32864 " number_of_elements=\"1\">\n"
32865 " <BooleanDomain name=\"bool\" />\n"
32866 " <Documentation>Should the reader retrieve the first new-style node map,\n"
32867 " or if that is not present, the solitary old-style node map (which\n"
32868 " always exists but may be procedurally generated if it is not stored\n"
32869 " with the file)?</Documentation>\n"
32870 " </IntVectorProperty>\n"
32871 " <IntVectorProperty command=\"SetGenerateGlobalElementIdArray\"\n"
32872 " default_values=\"1\"\n"
32873 " name=\"GenerateGlobalElementIdArray\"\n"
32874 " number_of_elements=\"1\">\n"
32875 " <BooleanDomain name=\"bool\" />\n"
32876 " <Documentation>Should the reader retrieve the first new-style element\n"
32877 " map, or if that is not present, the solitary old-style element map\n"
32878 " (which always exists but may be procedurally generated if it is not\n"
32879 " stored with the file)?</Documentation>\n"
32880 " </IntVectorProperty>\n"
32881 " <IntVectorProperty command=\"SetGenerateImplicitNodeIdArray\"\n"
32882 " default_values=\"0\"\n"
32883 " name=\"GenerateImplicitNodeIdArray\"\n"
32884 " number_of_elements=\"1\">\n"
32885 " <BooleanDomain name=\"bool\" />\n"
32886 " <Documentation>Should the reader retrieve the solitary old-style node\n"
32887 " map (which always exists but may be procedurally generated if it is not\n"
32888 " stored with the file)?</Documentation>\n"
32889 " </IntVectorProperty>\n"
32890 " <IntVectorProperty command=\"SetGenerateImplicitElementIdArray\"\n"
32891 " default_values=\"0\"\n"
32892 " name=\"GenerateImplicitElementIdArray\"\n"
32893 " number_of_elements=\"1\">\n"
32894 " <BooleanDomain name=\"bool\" />\n"
32895 " <Documentation>Should the reader retrieve the solitary old-style\n"
32896 " element map (which always exists but may be procedurally generated if\n"
32897 " it is not stored with the file)?</Documentation>\n"
32898 " </IntVectorProperty>\n"
32899 " <IntVectorProperty command=\"SetGenerateFileIdArray\"\n"
32900 " default_values=\"0\"\n"
32901 " name=\"GenerateFileIdArray\"\n"
32902 " number_of_elements=\"1\">\n"
32903 " <BooleanDomain name=\"bool\" />\n"
32904 " <Documentation>Should each cell in the mesh be assigned an integer\n"
32905 " identifying the file it came from? If turned on, a cell variable named\n"
32906 " \"FileId\" should be present.</Documentation>\n"
32907 " </IntVectorProperty>\n"
32908 " <StringVectorProperty animateable=\"0\"\n"
32909 " command=\"SetFilePrefix\"\n"
32910 " name=\"FilePrefix\"\n"
32911 " number_of_elements=\"1\">\n"
32912 " <FileListDomain name=\"default_value\" optional=\"1\"/>\n"
32913 " <Documentation>This property specifies the file root used with the file\n"
32914 " pattern to format a file name. (See the File Pattern\n"
32915 " property).</Documentation>\n"
32916 " </StringVectorProperty>\n"
32917 " <StringVectorProperty animateable=\"0\"\n"
32918 " command=\"SetFilePattern\"\n"
32919 " name=\"FilePattern\"\n"
32920 " number_of_elements=\"1\">\n"
32921 " <FileListDomain name=\"default_value\" optional=\"1\"/>\n"
32922 " <Documentation>This property contains a text string specifying the\n"
32923 " pattern used to load files. There are two parts to it: the prefix (%s)\n"
32924 " and the file number (%i). The format used is the same as that used for\n"
32925 " printf.</Documentation>\n"
32926 " </StringVectorProperty>\n"
32927 " <IntVectorProperty animateable=\"0\"\n"
32928 " command=\"SetFileRange\"\n"
32929 " default_values=\"-1 -1\"\n"
32930 " name=\"FileRange\"\n"
32931 " number_of_elements=\"2\">\n"
32932 " <IntRangeDomain name=\"range\" />\n"
32933 " <Documentation>This property controls the indices of the first and last\n"
32934 " files to be read.</Documentation>\n"
32935 " </IntVectorProperty>\n"
32936 " <StringVectorProperty command=\"GetXMLFileName\"\n"
32937 " information_only=\"1\"\n"
32938 " name=\"XMLFileNameInfo\">\n"
32939 " <SimpleStringInformationHelper />\n"
32940 " </StringVectorProperty>\n"
32941 " <StringVectorProperty animateable=\"0\"\n"
32942 " command=\"SetXMLFileName\"\n"
32943 " label=\"XML File Name\"\n"
32944 " name=\"XMLFileName\"\n"
32945 " number_of_elements=\"1\">\n"
32946 " <FileListDomain name=\"default_value\"\n"
32947 " optional=\"1\">\n"
32948 " <RequiredProperties>\n"
32949 " <Property function=\"XMLFileName\"\n"
32950 " name=\"XMLFileNameInfo\" />\n"
32951 " </RequiredProperties>\n"
32952 " </FileListDomain>\n"
32953 " <Documentation>This property specifies the name of an XML file\n"
32954 " containing part and material descriptions and a mapping to element\n"
32955 " blocks.</Documentation>\n"
32956 " </StringVectorProperty>\n"
32957 "\n"
32958 " <IntVectorProperty name=\"UseLegacyBlockNamesWithElementTypes\"\n"
32959 " command=\"SetUseLegacyBlockNames\"\n"
32960 " number_of_elements=\"1\"\n"
32961 " default_values=\"0\"\n"
32962 " panel_visibility=\"advanced\">\n"
32963 " <BooleanDomain name=\"bool\" />\n"
32964 " <Documentation>\n"
32965 " In previous versions, the reader added the type of elements in the block to\n"
32966 " the block name when no name was provided for the block. This has issues\n"
32967 " with consistency when naming blocks across ranks for partitioned files.\n"
32968 " Hence we no longer do that. For legacy pipelines, one can enable\n"
32969 " the old behavior by setting this flag to true.\n"
32970 " </Documentation>\n"
32971 " </IntVectorProperty>\n"
32972 "\n"
32973 " <!-- End ExodusIIReaderCore -->\n"
32974 " </SourceProxy>\n"
32975 "\n"
32976 " <!-- end of \"internal_sources\" -->\n"
32977 " </ProxyGroup>\n"
32978 "\n"
32979 " <!-- ==================================================================== -->\n"
32980 " <ProxyGroup name=\"sources\">\n"
32981 "\n"
32982 " <!-- ================================================================== -->\n"
32983 " <SourceProxy class=\"vtkExodusFileSeriesReader\"\n"
32984 " file_name_method=\"SetFileName\"\n"
32985 " name=\"ExodusIIReader\"\n"
32986 " si_class=\"vtkSIMetaReaderProxy\">\n"
32987 " <Documentation long_help=\"Reads an Exodus II file to produce an unstructured grid.\"\n"
32988 " short_help=\"Read Exodus II files.\">The Exodus reader loads\n"
32989 " Exodus II files and produces an unstructured grid output.\n"
32990 " The default file extensions are .g, .e, .ex2, .ex2v2,\n"
32991 " .exo, .gen, .exoII, .exii, .frq, .0, .00, .000, and .0000. The\n"
32992 " file format is described fully at:\n"
32993 " http://endo.sandia.gov/SEACAS/Documentation/exodusII.pdf.\n"
32994 " Each Exodus file contains a single set of points with 2-D\n"
32995 " or 3-D coordinates plus one or more blocks, sets, and\n"
32996 " maps. Block group elements (or their bounding edges or\n"
32997 " faces) of the same type together. Sets select subsets\n"
32998 " (across all the blocks in a file) of elements, sides of\n"
32999 " elements (which may be of mixed dimensionality), bounding\n"
33000 " faces of volumetric elements, or bounding edges of\n"
33001 " volumetric or areal elements. Each block or set may have\n"
33002 " multiple result variables, each of which defines a value\n"
33003 " per element, per timestep. The elements (cells), faces of\n"
33004 " elements (when enumerated in face blocks), edges of\n"
33005 " elements (when enumerated in edge blocks), and nodes\n"
33006 " (points) in a file may be assigned an arbitrary integer\n"
33007 " number by an element map, face map, edge map, or node map,\n"
33008 " respectively. Usually, only a single map of each type\n"
33009 " exists and is employed to assign a unique global ID to\n"
33010 " entities across multiple files which partition a large\n"
33011 " mesh for a distributed-memory calculation. However here\n"
33012 " may be multiply maps of each type and there are no\n"
33013 " constraints which force the integers to be unique. The\n"
33014 " connectivity of elements is constant across all of the\n"
33015 " timesteps in any single Exodus II file. However, multiple\n"
33016 " files which specify a single time-evolution of a mesh may\n"
33017 " be used to represent meshes which exhibit changes in\n"
33018 " connectivity infrequently. Field variable mode_shape[0]\n"
33019 " represents the time step (t_index) if HasModeShapes is\n"
33020 " not set or the ModeShape otherwise. This is a distributed\n"
33021 " reader.\n"
33022 " </Documentation>\n"
33023 " <SubProxy>\n"
33024 " <Proxy name=\"Reader\"\n"
33025 " proxygroup=\"internal_sources\"\n"
33026 " proxyname=\"ExodusIIReaderCore\" />\n"
33027 " <ExposedProperties>\n"
33028 " <PropertyGroup label=\"Variables\"\n"
33029 " name=\"Variables\"\n"
33030 " panel_visibility=\"default\"\n"
33031 " panel_widget=\"ArrayStatus\">\n"
33032 " <Property name=\"GenerateObjectIdCellArray\" />\n"
33033 " <Property name=\"GenerateGlobalElementIdArray\" />\n"
33034 " <Property name=\"ElementVariables\" />\n"
33035 " <Property name=\"FaceVariables\" />\n"
33036 " <Property name=\"EdgeVariables\" />\n"
33037 " <Property name=\"SideSetResultArrayStatus\" />\n"
33038 " <Property name=\"NodeSetResultArrayStatus\" />\n"
33039 " <Property name=\"FaceSetResultArrayStatus\" />\n"
33040 " <Property name=\"EdgeSetResultArrayStatus\" />\n"
33041 ;
33042
33043 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/Resources/readers_ioexodus.xml
33045 " <Property name=\"GenerateGlobalNodeIdArray\" />\n"
33046 " <Property name=\"ElementSetResultArrayStatus\" />\n"
33047 " <Property name=\"PointVariables\" />\n"
33048 " <Property name=\"GlobalVariables\" />\n"
33049 " <Hints>\n"
33050 " <WidgetHeight number_of_rows=\"20\" />\n"
33051 " </Hints>\n"
33052 " </PropertyGroup>\n"
33053 " <!-- fixme - need to group these two properties -->\n"
33054 " <Property name=\"ApplyDisplacements\" />\n"
33055 " <Property name=\"DisplacementMagnitude\" />\n"
33056 " <Property name=\"EdgeBlocks\" />\n"
33057 " <Property name=\"EdgeBlocksInfo\" />\n"
33058 " <PropertyGroup label=\"Sets\"\n"
33059 " name=\"Sets\"\n"
33060 " panel_visibility=\"advanced\"\n"
33061 " panel_widget=\"ArrayStatus\">\n"
33062 " <Property name=\"NodeSetArrayStatus\" />\n"
33063 " <Property name=\"SideSetArrayStatus\" />\n"
33064 " <Property name=\"FaceSetArrayStatus\" />\n"
33065 " <Property name=\"EdgeSetArrayStatus\" />\n"
33066 " <Property name=\"ElementSetArrayStatus\" />\n"
33067 " </PropertyGroup>\n"
33068 " <PropertyGroup label=\"Maps\"\n"
33069 " name=\"Maps\"\n"
33070 " panel_visibility=\"advanced\"\n"
33071 " panel_widget=\"ArrayStatus\">\n"
33072 " <Property name=\"NodeMapArrayStatus\" />\n"
33073 " <Property name=\"EdgeMapArrayStatus\" />\n"
33074 " <Property name=\"FaceMapArrayStatus\" />\n"
33075 " <Property name=\"ElementMapArrayStatus\" />\n"
33076 " </PropertyGroup>\n"
33077 " <Property name=\"EdgeMapInfo\" />\n"
33078 " <Property name=\"EdgeSetInfo\" />\n"
33079 " <Property name=\"EdgeSetResultArrayInfo\" />\n"
33080 " <Property name=\"EdgeVariablesInfo\" />\n"
33081 " <Property name=\"ElementBlocks\" />\n"
33082 " <Property name=\"ElementBlocksInfo\" />\n"
33083 " <Property name=\"ElementMapInfo\" />\n"
33084 " <Property name=\"ElementSetInfo\" />\n"
33085 " <Property name=\"ElementSetResultArrayInfo\" />\n"
33086 " <Property name=\"ElementVariablesInfo\" />\n"
33087 " <Property name=\"FaceBlocks\" />\n"
33088 " <Property name=\"FaceBlocksInfo\" />\n"
33089 " <Property name=\"FaceMapInfo\" />\n"
33090 " <Property name=\"FaceSetInfo\" />\n"
33091 " <Property name=\"FaceSetResultArrayInfo\" />\n"
33092 " <Property name=\"FaceVariablesInfo\" />\n"
33093 " <Property name=\"GlobalVariablesInfo\" />\n"
33094 " <Property name=\"NodeMapInfo\" />\n"
33095 " <Property name=\"NodeSetInfo\" />\n"
33096 " <Property name=\"NodeSetResultArrayInfo\" />\n"
33097 " <Property name=\"PointVariablesInfo\" />\n"
33098 " <Property name=\"SideSetInfo\" />\n"
33099 " <Property name=\"SideSetResultArrayInfo\" />\n"
33100 " <PropertyGroup label=\"Mode Shapes\">\n"
33101 " <Property name=\"HasModeShapes\" panel_visibility=\"advanced\" />\n"
33102 " <Property name=\"ModeShape\" panel_visibility=\"advanced\" />\n"
33103 " <Property name=\"AnimateVibrations\" panel_visibility=\"advanced\" />\n"
33104 " <Property name=\"ModeShapesRangeInfo\" />\n"
33105 " </PropertyGroup>\n"
33106 " <PropertyGroup label=\"Time\">\n"
33107 " <Property name=\"IgnoreFileTime\" panel_visibility=\"advanced\" />\n"
33108 " </PropertyGroup>\n"
33109 " <PropertyGroup label=\"File Pattern\">\n"
33110 " <Property name=\"FilePrefix\" panel_visibility=\"advanced\" />\n"
33111 " <Property name=\"FilePattern\" panel_visibility=\"advanced\"/>\n"
33112 " <Property name=\"FileRange\" panel_visibility=\"advanced\" />\n"
33113 " <Property name=\"XMLFileName\" panel_visibility=\"advanced\"/>\n"
33114 " <Property name=\"XMLFileNameInfo\" />\n"
33115 " </PropertyGroup>\n"
33116 " <Property name=\"GenerateFileIdArray\" />\n"
33117 " <Property name=\"UseLegacyBlockNamesWithElementTypes\" />\n"
33118 " </ExposedProperties>\n"
33119 " </SubProxy>\n"
33120 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
33121 " information_only=\"1\"\n"
33122 " name=\"FileNameInfo\">\n"
33123 " <SimpleStringInformationHelper />\n"
33124 " </StringVectorProperty>\n"
33125 " <StringVectorProperty animateable=\"0\"\n"
33126 " clean_command=\"RemoveAllFileNames\"\n"
33127 " command=\"AddFileName\"\n"
33128 " information_property=\"FileNameInfo\"\n"
33129 " name=\"FileName\"\n"
33130 " number_of_elements=\"1\"\n"
33131 " panel_visibility=\"never\"\n"
33132 " repeat_command=\"1\">\n"
33133 " <FileListDomain name=\"files\" />\n"
33134 " <Documentation>This property specifies the file name for the Exodus\n"
33135 " reader.</Documentation>\n"
33136 " </StringVectorProperty>\n"
33137 " <IntVectorProperty command=\"SetUseMetaFile\"\n"
33138 " default_values=\"0\"\n"
33139 " name=\"UseMetaFile\"\n"
33140 " number_of_elements=\"1\"\n"
33141 " panel_visibility=\"never\" >\n"
33142 " <BooleanDomain name=\"bool\" />\n"
33143 " <Documentation>This hidden property must always be set to 1 for this\n"
33144 " proxy to work.</Documentation>\n"
33145 " </IntVectorProperty>\n"
33146 " <DoubleVectorProperty information_only=\"1\"\n"
33147 " name=\"TimestepValues\"\n"
33148 " repeatable=\"1\">\n"
33149 " <TimeStepsInformationHelper />\n"
33150 " </DoubleVectorProperty>\n"
33151 " <Hints>\n"
33152 " <!--\n"
33153 " <ReaderFactory extensions=\"g e h gc ex2 ex2v2 exo gen par exoII exii frq\"\n"
33154 " file_description=\"ExodusII\"\n"
33155 " filename_patterns=\"*e-s*\" />\n"
33156 " -->\n"
33157 " </Hints>\n"
33158 " <!-- ExodusIIReader -->\n"
33159 " </SourceProxy>\n"
33160 "\n"
33161 " <!-- ================================================================== -->\n"
33162 " <SourceProxy class=\"vtkExodusFileSeriesReader\"\n"
33163 " file_name_method=\"SetFileName\"\n"
33164 " label=\"Restarted Sim Exodus Reader\"\n"
33165 " name=\"ExodusRestartReader\"\n"
33166 " si_class=\"vtkSIMetaReaderProxy\">\n"
33167 " <Documentation long_help=\"Reads collections of Exodus output files from simulations that were restarted.\"\n"
33168 " short_help=\"Read Exodus files from simulation restarts.\">\n"
33169 " When a simulation that outputs exodus files is restarted,\n"
33170 " typically you get a new set of output files. When you read\n"
33171 " them in your visualization, you often want to string these\n"
33172 " file sets together as if it was one continuous dump of\n"
33173 " files. This reader allows you to specify a metadata file\n"
33174 " that will implicitly string the files\n"
33175 " together. This is a distributed reader.\n"
33176 " </Documentation>\n"
33177 " <SubProxy>\n"
33178 " <Proxy name=\"Reader\"\n"
33179 " proxygroup=\"internal_sources\"\n"
33180 " proxyname=\"ExodusIIReaderCore\" />\n"
33181 " <ExposedProperties>\n"
33182 " <PropertyGroup label=\"Variables\"\n"
33183 " name=\"Variables\"\n"
33184 " panel_visibility=\"default\"\n"
33185 " panel_widget=\"ArrayStatus\">\n"
33186 " <Property name=\"GenerateObjectIdCellArray\" />\n"
33187 " <Property name=\"GenerateGlobalElementIdArray\" />\n"
33188 " <Property name=\"ElementVariables\" />\n"
33189 " <Property name=\"FaceVariables\" />\n"
33190 " <Property name=\"EdgeVariables\" />\n"
33191 " <Property name=\"SideSetResultArrayStatus\" />\n"
33192 " <Property name=\"NodeSetResultArrayStatus\" />\n"
33193 " <Property name=\"FaceSetResultArrayStatus\" />\n"
33194 " <Property name=\"EdgeSetResultArrayStatus\" />\n"
33195 " <Property name=\"GenerateGlobalNodeIdArray\" />\n"
33196 " <Property name=\"ElementSetResultArrayStatus\" />\n"
33197 " <Property name=\"PointVariables\" />\n"
33198 " <Property name=\"GlobalVariables\" />\n"
33199 " </PropertyGroup>\n"
33200 " <!-- fixme - need to group these two properties -->\n"
33201 " <Property name=\"ApplyDisplacements\" />\n"
33202 " <Property name=\"DisplacementMagnitude\" />\n"
33203 " <Property name=\"EdgeBlocks\" />\n"
33204 " <Property name=\"EdgeBlocksInfo\" />\n"
33205 " <PropertyGroup label=\"Sets\"\n"
33206 " name=\"Sets\"\n"
33207 " panel_visibility=\"advanced\"\n"
33208 " panel_widget=\"ArrayStatus\">\n"
33209 " <Property name=\"NodeSetArrayStatus\" />\n"
33210 " <Property name=\"SideSetArrayStatus\" />\n"
33211 " <Property name=\"FaceSetArrayStatus\" />\n"
33212 " <Property name=\"EdgeSetArrayStatus\" />\n"
33213 " <Property name=\"ElementSetArrayStatus\" />\n"
33214 " </PropertyGroup>\n"
33215 " <PropertyGroup label=\"Maps\"\n"
33216 " name=\"Maps\"\n"
33217 " panel_visibility=\"advanced\"\n"
33218 " panel_widget=\"ArrayStatus\">\n"
33219 " <Property name=\"NodeMapArrayStatus\" />\n"
33220 " <Property name=\"EdgeMapArrayStatus\" />\n"
33221 " <Property name=\"FaceMapArrayStatus\" />\n"
33222 " <Property name=\"ElementMapArrayStatus\" />\n"
33223 " </PropertyGroup>\n"
33224 " <Property name=\"EdgeMapInfo\" />\n"
33225 " <Property name=\"EdgeSetInfo\" />\n"
33226 " <Property name=\"EdgeSetResultArrayInfo\" />\n"
33227 " <Property name=\"EdgeVariablesInfo\" />\n"
33228 " <Property name=\"ElementBlocksInfo\" />\n"
33229 " <Property name=\"ElementBlocks\" />\n"
33230 " <Property name=\"ElementMapInfo\" />\n"
33231 " <Property name=\"ElementSetInfo\" />\n"
33232 " <Property name=\"ElementSetResultArrayInfo\" />\n"
33233 " <Property name=\"ElementVariablesInfo\" />\n"
33234 " <Property name=\"FaceBlocks\" />\n"
33235 " <Property name=\"FaceBlocksInfo\" />\n"
33236 " <Property name=\"FaceMapInfo\" />\n"
33237 " <Property name=\"FaceSetInfo\" />\n"
33238 " <Property name=\"FaceSetResultArrayInfo\" />\n"
33239 " <Property name=\"FaceVariablesInfo\" />\n"
33240 " <Property name=\"GlobalVariablesInfo\" />\n"
33241 " <Property name=\"NodeMapInfo\" />\n"
33242 " <Property name=\"NodeSetInfo\" />\n"
33243 " <Property name=\"NodeSetResultArrayInfo\" />\n"
33244 " <Property name=\"PointVariablesInfo\" />\n"
33245 " <Property name=\"SideSetInfo\" />\n"
33246 " <Property name=\"SideSetResultArrayInfo\" />\n"
33247 " <PropertyGroup label=\"Mode Shapes\">\n"
33248 " <Property name=\"HasModeShapes\" panel_visibility=\"advanced\" />\n"
33249 " <Property name=\"ModeShape\" panel_visibility=\"advanced\" />\n"
33250 " <Property name=\"AnimateVibrations\" panel_visibility=\"advanced\" />\n"
33251 " <Property name=\"ModeShapesRangeInfo\" />\n"
33252 " </PropertyGroup>\n"
33253 " <PropertyGroup label=\"File Pattern\">\n"
33254 " <Property name=\"FilePrefix\" panel_visibility=\"advanced\"/>\n"
33255 " <Property name=\"FilePattern\" panel_visibility=\"advanced\"/>\n"
33256 " <Property name=\"FileRange\" panel_visibility=\"advanced\"/>\n"
33257 " <Property name=\"XMLFileName\" panel_visibility=\"advanced\"/>\n"
33258 " <Property name=\"XMLFileNameInfo\" />\n"
33259 " </PropertyGroup>\n"
33260 " <Property name=\"GenerateFileIdArray\" />\n"
33261 " <Property name=\"UseLegacyBlockNamesWithElementTypes\" />\n"
33262 " </ExposedProperties>\n"
33263 " </SubProxy>\n"
33264 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
33265 " information_only=\"1\"\n"
33266 " name=\"FileNameInfo\">\n"
33267 " <SimpleStringInformationHelper />\n"
33268 " </StringVectorProperty>\n"
33269 " <StringVectorProperty animateable=\"0\"\n"
33270 " command=\"SetMetaFileName\"\n"
33271 " information_property=\"FileNameInfo\"\n"
33272 " name=\"FileName\"\n"
33273 " number_of_elements=\"1\"\n"
33274 " panel_visibility=\"never\" >\n"
33275 " <FileListDomain name=\"files\" />\n"
33276 " <Documentation>This points to a special metadata file that lists the\n"
33277 " output files for each restart.</Documentation>\n"
33278 " </StringVectorProperty>\n"
33279 " <IntVectorProperty command=\"SetUseMetaFile\"\n"
33280 " default_values=\"1\"\n"
33281 " name=\"UseMetaFile\"\n"
33282 " number_of_elements=\"1\"\n"
33283 " panel_visibility=\"never\"\n"
33284 " >\n"
33285 " <BooleanDomain name=\"bool\" />\n"
33286 " <Documentation>This hidden property must always be set to 1 for this\n"
33287 " proxy to work.</Documentation>\n"
33288 " </IntVectorProperty>\n"
33289 " <DoubleVectorProperty information_only=\"1\"\n"
33290 " name=\"TimestepValues\"\n"
33291 " repeatable=\"1\">\n"
33292 " <TimeStepsInformationHelper />\n"
33293 " </DoubleVectorProperty>\n"
33294 " <Hints>\n"
33295 " <!--\n"
33296 " <ReaderFactory extensions=\"ex-timeseries\"\n"
33297 " file_description=\"Metafile for restarted exodus outputs\" />\n"
33298 " -->\n"
33299 " </Hints>\n"
33300 " <!-- ExodusRestartReader -->\n"
33301 " </SourceProxy>\n"
33302 "\n"
33303 " <!-- ================================================================== -->\n"
33304 "\n"
33305 " <!-- end of \"sources\" -->\n"
33306 " </ProxyGroup>\n"
33307 "</ServerManagerConfiguration>\n"
33308 "\n";
33309 // Get single string
33311 {
33312
33313  const size_t len0 = strlen(paraview_server_managerreaders_ioexodusInterface0);
33314  const size_t len1 = strlen(paraview_server_managerreaders_ioexodusInterface1);
33315  const size_t len2 = strlen(paraview_server_managerreaders_ioexodusInterface2);
33316  const size_t len3 = strlen(paraview_server_managerreaders_ioexodusInterface3);
33317  size_t len = ( 0
33318  + len0
33319  + len1
33320  + len2
33321  + len3 );
33322  char* res = new char[ len + 1];
33323  size_t offset = 0;
33328  assert(offset == len);
33329  res[offset] = 0;
33330  return res;
33331 }
33332
33333
33334 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOExodus/Resources/writers_ioexodus.xml
33336 "<ServerManagerConfiguration>\n"
33337 " <ProxyGroup name=\"writers\">\n"
33338 " <!-- ================================================================= -->\n"
33339 " <PWriterProxy base_proxygroup=\"internal_writers\"\n"
33340 " base_proxyname=\"ParallelWriterBase\"\n"
33341 " class=\"vtkExodusIIWriter\"\n"
33342 " name=\"ExodusIIWriter\">\n"
33343 " <Documentation short_help=\"Write Exodus II files.\">Writer to write Exodus\n"
33344 " II files. Refere to http://endo.sandia.gov/SEACAS/ for more information\n"
33345 " about the Exodus II format.</Documentation>\n"
33346 " <InputProperty command=\"SetInputConnection\"\n"
33347 " panel_visibility=\"never\"\n"
33348 " name=\"Input\">\n"
33349 " <DataTypeDomain composite_data_supported=\"1\"\n"
33350 " name=\"input_type\">\n"
33351 " <DataType value=\"vtkCompositeDataSet\" />\n"
33352 " <DataType value=\"vtkDataSet\" />\n"
33353 " </DataTypeDomain>\n"
33354 " <Documentation>The input filter/source whose output dataset is to\n"
33355 " written to the file.</Documentation>\n"
33356 " </InputProperty>\n"
33357 " <IntVectorProperty command=\"SetWriteAllTimeSteps\"\n"
33358 " default_values=\"0\"\n"
33359 " name=\"WriteAllTimeSteps\"\n"
33360 " number_of_elements=\"1\">\n"
33361 " <BooleanDomain name=\"bool\" />\n"
33362 " <Documentation>When WriteAllTimeSteps is turned ON, the writer is\n"
33363 " executed once for each time step available from its input.</Documentation>\n"
33364 " </IntVectorProperty>\n"
33365 " <IntVectorProperty command=\"SetIgnoreMetaDataWarning\"\n"
33366 " default_values=\"0\"\n"
33367 " name=\"IgnoreMetaDataWarning\"\n"
33368 " number_of_elements=\"1\">\n"
33369 " <BooleanDomain name=\"bool\" />\n"
33370 " <Documentation>In certain cases like Catalyst we know that metadata doesn't exist and\n"
33371 " we want to ignore that warning.</Documentation>\n"
33372 " </IntVectorProperty>\n"
33373 " <Hints>\n"
33374 " <Property name=\"Input\"\n"
33375 " show=\"0\" />\n"
33376 " <Property name=\"FileName\"\n"
33377 " show=\"0\" />\n"
33378 " <Property name=\"GhostLevel\"\n"
33379 " show=\"0\" />\n"
33380 " <Property name=\"IgnoreMetaDataWarning\"\n"
33381 " show=\"0\" />\n"
33382 " <WriterFactory extensions=\"g e ex2 ex2v2 gen exoII exoii\"\n"
33383 " file_description=\"Exodus II File\" />\n"
33384 " </Hints>\n"
33385 " <!-- End of ExodusIIWriter -->\n"
33386 " </PWriterProxy>\n"
33387 " <!-- end of \"writers\" -->\n"
33388 " </ProxyGroup>\n"
33389 "\n"
33390 " <!-- =================================================================== -->\n"
33391 " <ProxyGroup name=\"extract_writers\">\n"
33392 " <DataExtractWriterProxy name=\"Exodus\">\n"
33393 " <Documentation>\n"
33394 " Extract writer to write data using the Exodus file format.\n"
33395 " </Documentation>\n"
33396 " <StringVectorProperty name=\"FileName\"\n"
33397 " number_of_elements=\"1\"\n"
33398 " default_values=\"dataset_{timestep:06d}.ex2\">\n"
33399 " <Documentation>\n"
33400 " Specify the filename to use.\n"
33401 " </Documentation>\n"
33402 " </StringVectorProperty>\n"
33403 " <SubProxy>\n"
33404 " <Proxy name=\"Writer\" proxygroup=\"writers\" proxyname=\"ExodusIIWriter\" />\n"
33405 " <ExposedProperties>\n"
33406 " <Property name=\"Input\" />\n"
33407 " </ExposedProperties>\n"
33408 " </SubProxy>\n"
33409 "\n"
33410 " <Hints>\n"
33411 " <ShowInMenu category=\"Data\" />\n"
33412 " </Hints>\n"
33413 " <!-- end of Exodus -->\n"
33414 " </DataExtractWriterProxy>\n"
33415 "\n"
33416 " <!-- end of \"extract_writers\" -->\n"
33417 " </ProxyGroup>\n"
33418 "\n"
33419 "</ServerManagerConfiguration>\n"
33420 "\n";
33421 // Get single string
33423 {
33424
33425  const size_t len0 = strlen(paraview_server_managerwriters_ioexodusInterface0);
33426  size_t len = ( 0
33427  + len0 );
33428  char* res = new char[ len + 1];
33429  size_t offset = 0;
33431  assert(offset == len);
33432  res[offset] = 0;
33433  return res;
33434 }
33435
33436
33437 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOEnSight/Resources/readers_pv_ioensight.xml
33439 "<ServerManagerConfiguration>\n"
33440 " <ProxyGroup name=\"sources\">\n"
33441 " <!-- ================================================================== -->\n"
33442 " <SourceProxy class=\"vtkPGenericEnSightReader\"\n"
33443 " label=\"EnSight Reader\"\n"
33444 " name=\"ensight\">\n"
33445 " <Documentation long_help=\"Reads EnSight 6 and Gold files.\"\n"
33446 " short_help=\"Read EnSight files.\">The EnSight reader reads\n"
33447 " files in the format produced by CEI's EnSight. EnSight 6\n"
33448 " and Gold files (both ASCII and binary) are supported. The\n"
33449 " default extension is .case. The output of this reader is a\n"
33450 " multiblock dataset. This is a distributed reader.\n"
33451 " </Documentation>\n"
33452 " <StringVectorProperty animateable=\"0\"\n"
33453 " command=\"SetCaseFileName\"\n"
33454 " name=\"CaseFileName\"\n"
33455 " number_of_elements=\"1\">\n"
33456 " <FileListDomain name=\"files\" />\n"
33457 " <Documentation>This property specifies the case file name for the\n"
33458 " EnSight reader.</Documentation>\n"
33459 " </StringVectorProperty>\n"
33460 " <DoubleVectorProperty information_only=\"1\"\n"
33461 " name=\"TimestepValues\"\n"
33462 " repeatable=\"1\">\n"
33463 " <TimeStepsInformationHelper />\n"
33464 " <Documentation>Available timestep values.</Documentation>\n"
33465 " </DoubleVectorProperty>\n"
33466 " <StringVectorProperty information_only=\"1\"\n"
33467 " name=\"CellArrayInfo\">\n"
33468 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
33469 " </StringVectorProperty>\n"
33470 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
33471 " element_types=\"2 0\"\n"
33472 " information_property=\"CellArrayInfo\"\n"
33473 " label=\"Cell Arrays\"\n"
33474 " name=\"CellArrayStatus\"\n"
33475 " number_of_elements=\"0\"\n"
33476 " number_of_elements_per_command=\"2\"\n"
33477 " repeat_command=\"1\">\n"
33478 " <ArraySelectionDomain name=\"array_list\">\n"
33479 " <RequiredProperties>\n"
33480 " <Property function=\"ArrayList\"\n"
33481 " name=\"CellArrayInfo\" />\n"
33482 " </RequiredProperties>\n"
33483 " </ArraySelectionDomain>\n"
33484 " <Documentation>This property lists which cell-centered arrays to\n"
33485 " read.</Documentation>\n"
33486 " </StringVectorProperty>\n"
33487 " <StringVectorProperty information_only=\"1\"\n"
33488 " name=\"PointArrayInfo\">\n"
33489 " <ArraySelectionInformationHelper attribute_name=\"Point\" />\n"
33490 " </StringVectorProperty>\n"
33491 " <StringVectorProperty command=\"SetPointArrayStatus\"\n"
33492 " element_types=\"2 0\"\n"
33493 " information_property=\"PointArrayInfo\"\n"
33494 " label=\"Point Arrays\"\n"
33495 " name=\"PointArrayStatus\"\n"
33496 " number_of_elements=\"0\"\n"
33497 " number_of_elements_per_command=\"2\"\n"
33498 " repeat_command=\"1\">\n"
33499 " <ArraySelectionDomain name=\"array_list\">\n"
33500 " <RequiredProperties>\n"
33501 " <Property function=\"ArrayList\"\n"
33502 " name=\"PointArrayInfo\" />\n"
33503 " </RequiredProperties>\n"
33504 " </ArraySelectionDomain>\n"
33505 " <Documentation>This property lists which point-centered arrays to\n"
33506 " read.</Documentation>\n"
33507 " </StringVectorProperty>\n"
33508 " <IntVectorProperty command=\"SetApplyTetrahedralize\"\n"
33509 " default_values=\"0\"\n"
33510 " name=\"ApplyTetrahedralize\"\n"
33511 " label=\"Apply Tetrahedralize\"\n"
33512 " panel_visibility=\"advanced\"\n"
33513 " number_of_elements=\"1\">\n"
33514 " <BooleanDomain name=\"bool\" />\n"
33515 " <Documentation>\n"
33516 " This property set if we want to tetrahedralize the output to prevent non manifold\n"
33517 " mesh later (generated by the Ensight Solver).\n"
33518 " </Documentation>\n"
33519 " </IntVectorProperty>\n"
33520 " <Hints>\n"
33521 " <ReaderFactory extensions=\"case CASE Case encas ENCAS Encas\"\n"
33522 " file_description=\"EnSight Files\" />\n"
33523 " </Hints>\n"
33524 " <!-- End ensight -->\n"
33525 " </SourceProxy>\n"
33526 "\n"
33527 " <!-- ================================================================== -->\n"
33528 " <SourceProxy class=\"vtkPVEnSightMasterServerReader2\"\n"
33529 " label=\"EnSight Master Server Reader\"\n"
33530 " name=\"ensightMS\">\n"
33531 " <Documentation long_help=\"Reads files in EnSight's Master Server format.\"\n"
33532 " short_help=\"Read parallel EnSight files.\">The EnSight\n"
33533 " Master Server reader reads EnSight's parallel files. The\n"
33534 " master file usually has a .sos extension and may point to\n"
33535 " multiple .case files. The output is a multiblock\n"
33536 " dataset. This is a distributed reader.\n"
33537 " </Documentation>\n"
33538 " <StringVectorProperty animateable=\"0\"\n"
33539 " command=\"SetCaseFileName\"\n"
33540 " name=\"CaseFileName\"\n"
33541 " number_of_elements=\"1\">\n"
33542 " <FileListDomain name=\"files\" />\n"
33543 " <Documentation>This property specifies the name of the .sos file for\n"
33544 " the EnSight Master Server reader.</Documentation>\n"
33545 " </StringVectorProperty>\n"
33546 " <IntVectorProperty command=\"SetByteOrder\"\n"
33547 " default_values=\"0\"\n"
33548 " name=\"ByteOrder\"\n"
33549 " number_of_elements=\"1\">\n"
33550 " <EnumerationDomain name=\"enum\">\n"
33551 " <Entry text=\"BigEndian\"\n"
33552 " value=\"0\" />\n"
33553 " <Entry text=\"LittleEndian\"\n"
33554 " value=\"1\" />\n"
33555 " </EnumerationDomain>\n"
33556 " <Documentation>This property indicates the byte order of the binary\n"
33557 " file(s).</Documentation>\n"
33558 " </IntVectorProperty>\n"
33559 " <DoubleVectorProperty information_only=\"1\"\n"
33560 " name=\"TimestepValues\"\n"
33561 " repeatable=\"1\">\n"
33562 " <TimeStepsInformationHelper />\n"
33563 " <Documentation>Available timestep values.</Documentation>\n"
33564 " </DoubleVectorProperty>\n"
33565 " <DoubleVectorProperty animateable=\"1\"\n"
33566 " command=\"SetTimeValue\"\n"
33567 " default_values=\"0.0\"\n"
33568 " name=\"SetTimeValue\"\n"
33569 " number_of_elements=\"1\">\n"
33570 " <DoubleRangeDomain name=\"range\" />\n"
33571 " <Documentation>This property indicates which time value to\n"
33572 " read.</Documentation>\n"
33573 " </DoubleVectorProperty>\n"
33574 " <StringVectorProperty information_only=\"1\"\n"
33575 " name=\"CellArrayInfo\">\n"
33576 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
33577 " </StringVectorProperty>\n"
33578 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
33579 " element_types=\"2 0\"\n"
33580 " information_property=\"CellArrayInfo\"\n"
33581 " label=\"Cell Arrays\"\n"
33582 " name=\"CellArrayStatus\"\n"
33583 " number_of_elements=\"0\"\n"
33584 " number_of_elements_per_command=\"2\"\n"
33585 " repeat_command=\"1\">\n"
33586 " <ArraySelectionDomain name=\"array_list\">\n"
33587 " <RequiredProperties>\n"
33588 " <Property function=\"ArrayList\"\n"
33589 " name=\"CellArrayInfo\" />\n"
33590 " </RequiredProperties>\n"
33591 " </ArraySelectionDomain>\n"
33592 " <Documentation>This property lists which cell-centered arrays to\n"
33593 " read.</Documentation>\n"
33594 " </StringVectorProperty>\n"
33595 " <StringVectorProperty information_only=\"1\"\n"
33596 " name=\"PointArrayInfo\">\n"
33597 " <ArraySelectionInformationHelper attribute_name=\"Point\" />\n"
33598 " </StringVectorProperty>\n"
33599 " <StringVectorProperty command=\"SetPointArrayStatus\"\n"
33600 " element_types=\"2 0\"\n"
33601 " information_property=\"PointArrayInfo\"\n"
33602 " label=\"Point Arrays\"\n"
33603 " name=\"PointArrayStatus\"\n"
33604 " number_of_elements=\"0\"\n"
33605 " number_of_elements_per_command=\"2\"\n"
33606 " repeat_command=\"1\">\n"
33607 " <ArraySelectionDomain name=\"array_list\">\n"
33608 " <RequiredProperties>\n"
33609 " <Property function=\"ArrayList\"\n"
33610 " name=\"PointArrayInfo\" />\n"
33611 " </RequiredProperties>\n"
33612 " </ArraySelectionDomain>\n"
33613 " <Documentation>This property lists which point-centered arrays to\n"
33614 " read.</Documentation>\n"
33615 " </StringVectorProperty>\n"
33616 " <Hints>\n"
33617 " <ReaderFactory extensions=\"sos SOS\"\n"
33618 " file_description=\"EnSight Master Server Files\" />\n"
33619 " </Hints>\n"
33620 " <!-- End ensightMS -->\n"
33621 " </SourceProxy>\n"
33622 " </ProxyGroup>\n"
33623 "</ServerManagerConfiguration>\n"
33624 "\n";
33625 // Get single string
33627 {
33628
33629  const size_t len0 = strlen(paraview_server_managerreaders_pv_ioensightInterface0);
33630  size_t len = ( 0
33631  + len0 );
33632  char* res = new char[ len + 1];
33633  size_t offset = 0;
33635  assert(offset == len);
33636  res[offset] = 0;
33637  return res;
33638 }
33639
33640
33641 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOAMR/Resources/readers_pv_ioamr.xml
33643 "<ServerManagerConfiguration>\n"
33644 " <ProxyGroup name=\"internal_sources\">\n"
33645 " <!-- ================================================================== -->\n"
33646 " <Proxy class=\"vtkAMRFlashParticlesReader\"\n"
33647 " label=\"FLASH Particles AMR Reader\"\n"
33648 " name=\"FlashParticlesReaderCore\">\n"
33649 " <Documentation long_help=\"Reads AMR particles from FLASH dataset\"\n"
33650 " short_help=\"Reads AMR particles from FLASH dataset\">The\n"
33651 " Flash particles reader loads particle simulation data\n"
33652 " stored in Flash format. The output of this reader is a\n"
33653 " MultiBlock dataset where each block is vtkPolyData that\n"
33654 " holds the particles and corresponding particle\n"
33655 " data.</Documentation>\n"
33656 " <StringVectorProperty animateable=\"0\"\n"
33657 " command=\"SetFileName\"\n"
33658 " name=\"FileName\"\n"
33659 " number_of_elements=\"1\"\n"
33660 " panel_visibility=\"never\">\n"
33661 " <FileListDomain name=\"files\" />\n"
33662 " <Documentation>This property specifies the Enzo file\n"
33663 " name</Documentation>\n"
33664 " </StringVectorProperty>\n"
33665 " <!-- Display the number of Particles -->\n"
33666 " <IntVectorProperty command=\"GetTotalNumberOfParticles\"\n"
33667 " information_only=\"1\"\n"
33668 " name=\"NumParticles\">\n"
33669 " <SimpleIntInformationHelper />\n"
33670 " </IntVectorProperty>\n"
33671 " <IntVectorProperty command=\"SetFrequency\"\n"
33672 " default_values=\"1\"\n"
33673 " name=\"Frequency\"\n"
33674 " number_of_elements=\"1\">\n"
33675 " <IntRangeDomain name=\"range\" />\n"
33676 " <Documentation>This property sets the frequency interval for loading\n"
33677 " particles.</Documentation>\n"
33678 " </IntVectorProperty>\n"
33679 " <IntVectorProperty command=\"SetFilterLocation\"\n"
33680 " default_values=\"0\"\n"
33681 " name=\"FilterLocation\"\n"
33682 " number_of_elements=\"1\">\n"
33683 " <BooleanDomain name=\"bool\" />\n"
33684 " <Documentation>Turns on filtering of particles by\n"
33685 " location</Documentation>\n"
33686 " </IntVectorProperty>\n"
33687 " <DoubleVectorProperty animateable=\"1\"\n"
33688 " command=\"SetMinLocation\"\n"
33689 " default_values=\"0.0 0.0 0.0\"\n"
33690 " name=\"MinLocation\"\n"
33691 " number_of_elements=\"3\">\n"
33692 " <DoubleRangeDomain name=\"range\" />\n"
33693 " <Documentation>This property sets the minimum 3-D coordinate location\n"
33694 " by which the particles will be filtered out.</Documentation>\n"
33695 " </DoubleVectorProperty>\n"
33696 " <DoubleVectorProperty animateable=\"1\"\n"
33697 " command=\"SetMaxLocation\"\n"
33698 " default_values=\"0.0 0.0 0.0\"\n"
33699 " name=\"MaxLocation\"\n"
33700 " number_of_elements=\"3\">\n"
33701 " <DoubleRangeDomain name=\"range\" />\n"
33702 " <Documentation>This property sets the minimum 3-D coordinate location\n"
33703 " by which the particles will be filtered out.</Documentation>\n"
33704 " </DoubleVectorProperty>\n"
33705 " <!-- Array Selection GUI Component -->\n"
33706 " <StringVectorProperty information_only=\"1\"\n"
33707 " name=\"ParticleArrayInfo\">\n"
33708 " <ArraySelectionInformationHelper attribute_name=\"Particle\" />\n"
33709 " </StringVectorProperty>\n"
33710 " <StringVectorProperty command=\"SetParticleArrayStatus\"\n"
33711 " element_types=\"2 0\"\n"
33712 " information_property=\"ParticleArrayInfo\"\n"
33713 " label=\"Particle Arrays\"\n"
33714 " name=\"ParticleArrayStatus\"\n"
33715 " number_of_elements=\"0\"\n"
33716 " number_of_elements_per_command=\"2\"\n"
33717 " repeat_command=\"1\">\n"
33718 " <ArraySelectionDomain name=\"array_list\">\n"
33719 " <RequiredProperties>\n"
33720 " <Property function=\"ArrayList\"\n"
33721 " name=\"ParticleArrayInfo\" />\n"
33722 " </RequiredProperties>\n"
33723 " </ArraySelectionDomain>\n"
33724 " <Documentation>This property lists which particle arrays to read.</Documentation>\n"
33725 " </StringVectorProperty>\n"
33726 " <!-- end of \"FlashParticlesReaderCore\" -->\n"
33727 " </Proxy>\n"
33728 "\n"
33729 " <!-- ================================================================== -->\n"
33730 " <Proxy class=\"vtkAMREnzoParticlesReader\"\n"
33731 " label=\"Enzo Particles AMR Reader\"\n"
33732 " name=\"EnzoParticlesReaderCore\">\n"
33733 " <Documentation long_help=\"Reads AMR particles from an ENZO dataset\"\n"
33734 " short_help=\"Reads AMR particles from an ENZO dataset\">The\n"
33735 " Enzo particles reader loads particle simulation data\n"
33736 " stored in Enzo HDF5 format. The output of this reader is\n"
33737 " MultiBlock dataset where each block is a vtkPolyData that\n"
33738 " holds the particles (points) and corresponding particle\n"
33739 " data.</Documentation>\n"
33740 " <StringVectorProperty animateable=\"0\"\n"
33741 " command=\"SetFileName\"\n"
33742 " name=\"FileName\"\n"
33743 " number_of_elements=\"1\"\n"
33744 " panel_visibility=\"never\">\n"
33745 " <FileListDomain name=\"files\" />\n"
33746 " <Documentation>This property specifies the Enzo file\n"
33747 " name</Documentation>\n"
33748 " </StringVectorProperty>\n"
33749 " <!-- Display the number of Particles -->\n"
33750 " <IntVectorProperty command=\"GetTotalNumberOfParticles\"\n"
33751 " information_only=\"1\"\n"
33752 " name=\"NumParticles\">\n"
33753 " <SimpleIntInformationHelper />\n"
33754 " </IntVectorProperty>\n"
33755 " <IntVectorProperty command=\"SetFrequency\"\n"
33756 " default_values=\"1\"\n"
33757 " name=\"Frequency\"\n"
33758 " number_of_elements=\"1\">\n"
33759 " <IntRangeDomain name=\"range\" />\n"
33760 " <Documentation>This property sets the frequency interval for loading\n"
33761 " particles.</Documentation>\n"
33762 " </IntVectorProperty>\n"
33763 " <IntVectorProperty command=\"SetFilterLocation\"\n"
33764 " default_values=\"0\"\n"
33765 " name=\"FilterLocation\"\n"
33766 " number_of_elements=\"1\">\n"
33767 " <BooleanDomain name=\"bool\" />\n"
33768 " <Documentation>Turns on filtering of particles by\n"
33769 " location</Documentation>\n"
33770 " </IntVectorProperty>\n"
33771 " <DoubleVectorProperty animateable=\"1\"\n"
33772 " command=\"SetMinLocation\"\n"
33773 " default_values=\"0.0 0.0 0.0\"\n"
33774 " name=\"MinLocation\"\n"
33775 " number_of_elements=\"3\">\n"
33776 " <DoubleRangeDomain name=\"range\" />\n"
33777 " <Documentation>This property sets the minimum 3-D coordinate location\n"
33778 " by which the particles will be filtered out.</Documentation>\n"
33779 " </DoubleVectorProperty>\n"
33780 " <DoubleVectorProperty animateable=\"1\"\n"
33781 " command=\"SetMaxLocation\"\n"
33782 " default_values=\"0.0 0.0 0.0\"\n"
33783 " name=\"MaxLocation\"\n"
33784 " number_of_elements=\"3\">\n"
33785 " <DoubleRangeDomain name=\"range\" />\n"
33786 " <Documentation>This property sets the minimum 3-D coordinate location\n"
33787 " by which the particles will be filtered out.</Documentation>\n"
33788 " </DoubleVectorProperty>\n"
33789 " <!-- Array Selection GUI Component -->\n"
33790 " <StringVectorProperty information_only=\"1\"\n"
33791 " name=\"ParticleArrayInfo\">\n"
33792 " <ArraySelectionInformationHelper attribute_name=\"Particle\" />\n"
33793 " </StringVectorProperty>\n"
33794 " <StringVectorProperty command=\"SetParticleArrayStatus\"\n"
33795 " element_types=\"2 0\"\n"
33796 " information_property=\"ParticleArrayInfo\"\n"
33797 " label=\"Particle Arrays\"\n"
33798 " name=\"ParticleArrayStatus\"\n"
33799 " number_of_elements=\"0\"\n"
33800 " number_of_elements_per_command=\"2\"\n"
33801 " repeat_command=\"1\">\n"
33802 " <ArraySelectionDomain name=\"array_list\">\n"
33803 " <RequiredProperties>\n"
33804 " <Property function=\"ArrayList\"\n"
33805 " name=\"ParticleArrayInfo\" />\n"
33806 " </RequiredProperties>\n"
33807 " </ArraySelectionDomain>\n"
33808 " <Documentation>This property lists which particle arrays to\n"
33809 " read.</Documentation>\n"
33810 " </StringVectorProperty>\n"
33811 " <IntVectorProperty command=\"SetParticleType\"\n"
33812 " default_values=\"0\"\n"
33813 " name=\"ParticleType\"\n"
33814 " number_of_elements=\"1\">\n"
33815 " <EnumerationDomain name=\"enum\">\n"
33816 " <Entry text=\"All Particles\"\n"
33817 " value=\"0\" />\n"
33818 " <Entry text=\"Dark Matter\"\n"
33819 " value=\"1\" />\n"
33820 " <Entry text=\"Active (Star)\"\n"
33821 " value=\"2\" />\n"
33822 " <Entry text=\"Passive (Tracer)\"\n"
33823 " value=\"3\" />\n"
33824 " </EnumerationDomain>\n"
33825 " </IntVectorProperty>\n"
33826 " <!-- end of \"EnzoParticlesReaderCore\" -->\n"
33827 " </Proxy>\n"
33828 "\n"
33829 " <!-- ================================================================== -->\n"
33830 " <Proxy class=\"vtkAMRFlashReader\"\n"
33831 " label=\"Flash AMR Reader\"\n"
33832 " name=\"FlashReaderCore\">\n"
33833 " <Documentation long_help=\"Read hierarchical box dataset from a Flash dataset.\"\n"
33834 " short_help=\"Read hierarchical box dataset from a Flash dataset.\">\n"
33835 " This Flash reader loads data stored in Flash format. The\n"
33836 " output of this reader is a hierarchical-box\n"
33837 " dataset.</Documentation>\n"
33838 " <!-- Define Flas Filename -->\n"
33839 " <StringVectorProperty animateable=\"0\"\n"
33840 " command=\"SetFileName\"\n"
33841 " name=\"FileName\"\n"
33842 " number_of_elements=\"1\"\n"
33843 " panel_visibility=\"never\">\n"
33844 " <FileListDomain name=\"files\" />\n"
33845 " <Documentation>This property specifies the Flash file\n"
33846 " name</Documentation>\n"
33847 " </StringVectorProperty>\n"
33848 " <!-- Display the number of levels -->\n"
33849 " <IntVectorProperty command=\"GetNumberOfLevels\"\n"
33850 " information_only=\"1\"\n"
33851 " name=\"NumLevels\">\n"
33852 " <SimpleIntInformationHelper />\n"
33853 " </IntVectorProperty>\n"
33854 " <!-- Display the number of blocks -->\n"
33855 " <IntVectorProperty command=\"GetNumberOfBlocks\"\n"
33856 " information_only=\"1\"\n"
33857 " name=\"NumBlocks\">\n"
33858 " <SimpleIntInformationHelper />\n"
33859 " </IntVectorProperty>\n"
33860 " <IntVectorProperty command=\"SetEnableCaching\"\n"
33861 " default_values=\"0\"\n"
33862 " name=\"EnableCaching\"\n"
33863 " number_of_elements=\"1\">\n"
33864 " <BooleanDomain name=\"bool\" />\n"
33865 " <Documentation>Turn caching on/off</Documentation>\n"
33866 " </IntVectorProperty>\n"
33867 " <!-- Define MaxLevel property -->\n"
33868 " <IntVectorProperty command=\"SetMaxLevel\"\n"
33869 " default_values=\"1\"\n"
33870 " name=\"Level\"\n"
33871 " number_of_elements=\"1\">\n"
33872 " <IntRangeDomain max=\"100\"\n"
33873 " min=\"0\"\n"
33874 " name=\"range\" />\n"
33875 " <Documentation>This property specifies the desired level of resolution\n"
33876 " that will be visible.</Documentation>\n"
33877 " </IntVectorProperty>\n"
33878 " <!-- Array Selection GUI Component -->\n"
33879 " <StringVectorProperty information_only=\"1\"\n"
33880 " name=\"CellArrayInfo\">\n"
33881 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
33882 " </StringVectorProperty>\n"
33883 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
33884 " element_types=\"2 0\"\n"
33885 " information_property=\"CellArrayInfo\"\n"
33886 " label=\"Cell Arrays\"\n"
33887 " name=\"CellArrayStatus\"\n"
33888 " number_of_elements=\"0\"\n"
33889 " number_of_elements_per_command=\"2\"\n"
33890 " repeat_command=\"1\">\n"
33891 " <ArraySelectionDomain name=\"array_list\">\n"
33892 " <RequiredProperties>\n"
33893 " <Property function=\"ArrayList\"\n"
33894 " name=\"CellArrayInfo\" />\n"
33895 " </RequiredProperties>\n"
33896 " </ArraySelectionDomain>\n"
33897 " <Documentation>This property lists which cell-centered arrays to\n"
33898 " read.</Documentation>\n"
33899 " </StringVectorProperty>\n"
33900 " <StringVectorProperty information_only=\"1\"\n"
33901 " name=\"PointArrayInfo\">\n"
33902 " <ArraySelectionInformationHelper attribute_name=\"Point\" />\n"
33903 " </StringVectorProperty>\n"
33904 " <StringVectorProperty command=\"SetPointArrayStatus\"\n"
33905 " element_types=\"2 0\"\n"
33906 " information_property=\"PointArrayInfo\"\n"
33907 " label=\"PointArrays\"\n"
33908 " name=\"PointArrayStatus\"\n"
33909 " number_of_elements=\"0\"\n"
33910 " number_of_elements_per_command=\"2\"\n"
33911 " repeat_command=\"1\">\n"
33912 " <ArraySelectionDomain name=\"array_list\">\n"
33913 " <RequiredProperties>\n"
33914 " <Property function=\"ArrayList\"\n"
33915 " name=\"PointArrayInfo\" />\n"
33916 " </RequiredProperties>\n"
33917 " </ArraySelectionDomain>\n"
33918 " <Documentation>This property lists which point-centered arrays to\n"
33919 " read.</Documentation>\n"
33920 " </StringVectorProperty>\n"
33921 " </Proxy>\n"
33922 "\n"
33923 " <!-- ================================================================== -->\n"
33924 " <Proxy class=\"vtkAMREnzoReader\"\n"
33925 " label=\"Enzo AMR Reader\"\n"
33926 " name=\"EnzoReaderCore\">\n"
33927 " <Documentation long_help=\"Read hierarchical box dataset from an Enzo file.\"\n"
33928 " short_help=\"Read hierarchical box dataset from an Enzo file.\">\n"
33929 " This Enzo reader loads data stored in Enzo format. The\n"
33930 " output of this reader is a hierarchical-box\n"
33931 " dataset.</Documentation>\n"
33932 " <!-- Define Enzo Filename -->\n"
33933 " <StringVectorProperty animateable=\"0\"\n"
33934 " command=\"SetFileName\"\n"
33935 " name=\"FileName\"\n"
33936 " number_of_elements=\"1\"\n"
33937 " panel_visibility=\"never\">\n"
33938 " <FileListDomain name=\"files\" />\n"
33939 " <Documentation>This property specifies the Enzo file\n"
33940 " name</Documentation>\n"
33941 " </StringVectorProperty>\n"
33942 " <!-- Display the number of levels -->\n"
33943 " <IntVectorProperty command=\"GetNumberOfLevels\"\n"
33944 " information_only=\"1\"\n"
33945 ;
33946
33947 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOAMR/Resources/readers_pv_ioamr.xml
33949 " name=\"NumLevels\">\n"
33950 " <SimpleIntInformationHelper />\n"
33951 " </IntVectorProperty>\n"
33952 " <!-- Display the number of blocks -->\n"
33953 " <IntVectorProperty command=\"GetNumberOfBlocks\"\n"
33954 " information_only=\"1\"\n"
33955 " name=\"NumBlocks\">\n"
33956 " <SimpleIntInformationHelper />\n"
33957 " </IntVectorProperty>\n"
33958 " <IntVectorProperty command=\"SetEnableCaching\"\n"
33959 " default_values=\"0\"\n"
33960 " name=\"EnableCaching\"\n"
33961 " number_of_elements=\"1\">\n"
33962 " <BooleanDomain name=\"bool\" />\n"
33963 " <Documentation>Turn caching on/off</Documentation>\n"
33964 " </IntVectorProperty>\n"
33965 " <!-- Define MaxLevel property -->\n"
33966 " <IntVectorProperty command=\"SetMaxLevel\"\n"
33967 " default_values=\"1\"\n"
33968 " name=\"Level\"\n"
33969 " number_of_elements=\"1\">\n"
33970 " <IntRangeDomain max=\"100\"\n"
33971 " min=\"0\"\n"
33972 " name=\"range\" />\n"
33973 " <Documentation>This property specifies the desired level of resolution\n"
33974 " that will be visible.</Documentation>\n"
33975 " </IntVectorProperty>\n"
33976 " <!-- Set Conversion to CGS -->\n"
33977 " <IntVectorProperty command=\"SetConvertToCGS\"\n"
33978 " default_values=\"0\"\n"
33979 " name=\"ConvertToCGS\"\n"
33980 " number_of_elements=\"1\">\n"
33981 " <BooleanDomain name=\"bool\" />\n"
33982 " <Documentation>This property specifies whether or not units will be\n"
33983 " converted to CGS.</Documentation>\n"
33984 " </IntVectorProperty>\n"
33985 " <!-- Array Selection GUI Component -->\n"
33986 " <StringVectorProperty information_only=\"1\"\n"
33987 " name=\"CellArrayInfo\">\n"
33988 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
33989 " </StringVectorProperty>\n"
33990 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
33991 " element_types=\"2 0\"\n"
33992 " information_property=\"CellArrayInfo\"\n"
33993 " label=\"Cell Arrays\"\n"
33994 " name=\"CellArrayStatus\"\n"
33995 " number_of_elements=\"0\"\n"
33996 " number_of_elements_per_command=\"2\"\n"
33997 " repeat_command=\"1\">\n"
33998 " <ArraySelectionDomain name=\"array_list\">\n"
33999 " <RequiredProperties>\n"
34000 " <Property function=\"ArrayList\"\n"
34001 " name=\"CellArrayInfo\" />\n"
34002 " </RequiredProperties>\n"
34003 " </ArraySelectionDomain>\n"
34004 " <Documentation>This property lists which cell-centered arrays to\n"
34005 " read.</Documentation>\n"
34006 " </StringVectorProperty>\n"
34007 " <StringVectorProperty information_only=\"1\"\n"
34008 " name=\"PointArrayInfo\">\n"
34009 " <ArraySelectionInformationHelper attribute_name=\"Point\" />\n"
34010 " </StringVectorProperty>\n"
34011 " <StringVectorProperty command=\"SetPointArrayStatus\"\n"
34012 " element_types=\"2 0\"\n"
34013 " information_property=\"PointArrayInfo\"\n"
34014 " label=\"PointArrays\"\n"
34015 " name=\"PointArrayStatus\"\n"
34016 " number_of_elements=\"0\"\n"
34017 " number_of_elements_per_command=\"2\"\n"
34018 " repeat_command=\"1\">\n"
34019 " <ArraySelectionDomain name=\"array_list\">\n"
34020 " <RequiredProperties>\n"
34021 " <Property function=\"ArrayList\"\n"
34022 " name=\"PointArrayInfo\" />\n"
34023 " </RequiredProperties>\n"
34024 " </ArraySelectionDomain>\n"
34025 " <Documentation>This property lists which point-centered arrays to\n"
34026 " read.</Documentation>\n"
34027 " </StringVectorProperty>\n"
34028 " </Proxy>\n"
34029 "\n"
34030 " <!-- ================================================================== -->\n"
34031 " <Proxy name=\"vtkAMReXGridReaderCore\" class=\"vtkAMReXGridReader\" label=\"AMReX Grid Reader\">\n"
34032 " <Documentation\n"
34033 " long_help=\"Reads AMReX plotfiles (grids) data.\"\n"
34034 " short_help=\"Reads AMReX plotfiles (grids) data.\">\n"
34035 " This AMReX reader loads data stored in AMReX's plt flie format. The\n"
34036 " output of this reader is a hierarchical-box dataset.</Documentation>\n"
34037 " <!-- Define Flas FileName -->\n"
34038 " <StringVectorProperty\n"
34039 " name=\"FileName\"\n"
34040 " animateable=\"0\"\n"
34041 " command=\"SetFileName\"\n"
34042 " number_of_elements=\"1\"\n"
34043 " panel_visibility=\"never\"\n"
34044 " >\n"
34045 " <FileListDomain name=\"files\" />\n"
34046 " </StringVectorProperty>\n"
34047 " <!-- Display the number of levels -->\n"
34048 " <IntVectorProperty command=\"GetNumberOfLevels\"\n"
34049 " information_only=\"1\"\n"
34050 " name=\"NumLevels\">\n"
34051 " <SimpleIntInformationHelper />\n"
34052 " </IntVectorProperty>\n"
34053 " <!-- Display the number of blocks -->\n"
34054 " <IntVectorProperty command=\"GetNumberOfBlocks\"\n"
34055 " information_only=\"1\"\n"
34056 " name=\"NumBlocks\">\n"
34057 " <SimpleIntInformationHelper />\n"
34058 " </IntVectorProperty>\n"
34059 " <!-- Define EnableCaching property -->\n"
34060 " <IntVectorProperty command=\"SetEnableCaching\"\n"
34061 " default_values=\"0\"\n"
34062 " name=\"EnableCaching\"\n"
34063 " number_of_elements=\"1\">\n"
34064 " <BooleanDomain name=\"bool\" />\n"
34065 " <Documentation>Turn caching on/off</Documentation>\n"
34066 " </IntVectorProperty>\n"
34067 " <!-- Define MaxLevel property -->\n"
34068 " <IntVectorProperty command=\"SetMaxLevel\"\n"
34069 " default_values=\"1\"\n"
34070 " name=\"Level\"\n"
34071 " number_of_elements=\"1\">\n"
34072 " <IntRangeDomain max=\"100\"\n"
34073 " min=\"0\"\n"
34074 " name=\"range\" />\n"
34075 " <Documentation>This property specifies the desired level of resolution\n"
34076 " that will be visible.</Documentation>\n"
34077 " </IntVectorProperty>\n"
34078 " <StringVectorProperty name=\"PointArrayInfo\"\n"
34079 " command=\"GetPointDataArraySelection\"\n"
34080 " number_of_elements_per_command=\"2\"\n"
34081 " information_only=\"1\"\n"
34082 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
34083 "\n"
34084 " <StringVectorProperty name=\"PointArrayStatus\"\n"
34085 " command=\"GetPointDataArraySelection\"\n"
34086 " information_property=\"PointArrayInfo\"\n"
34087 " number_of_elements_per_command=\"2\"\n"
34088 " element_types=\"2 0\"\n"
34089 " repeat_command=\"1\"\n"
34090 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
34091 " <ArraySelectionDomain name=\"array_list\">\n"
34092 " <RequiredProperties>\n"
34093 " <Property function=\"ArrayList\" name=\"PointArrayInfo\" />\n"
34094 " </RequiredProperties>\n"
34095 " </ArraySelectionDomain>\n"
34096 " <Documentation>Select the point arrays to read load.</Documentation>\n"
34097 " </StringVectorProperty>\n"
34098 "\n"
34099 " <StringVectorProperty name=\"CellArrayInfo\"\n"
34100 " command=\"GetCellDataArraySelection\"\n"
34101 " number_of_elements_per_command=\"2\"\n"
34102 " information_only=\"1\"\n"
34103 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
34104 "\n"
34105 " <StringVectorProperty name=\"CellArrayStatus\"\n"
34106 " command=\"GetCellDataArraySelection\"\n"
34107 " information_property=\"CellArrayInfo\"\n"
34108 " number_of_elements_per_command=\"2\"\n"
34109 " element_types=\"2 0\"\n"
34110 " repeat_command=\"1\"\n"
34111 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
34112 " <ArraySelectionDomain name=\"array_list\">\n"
34113 " <RequiredProperties>\n"
34114 " <Property function=\"ArrayList\" name=\"CellArrayInfo\" />\n"
34115 " </RequiredProperties>\n"
34116 " </ArraySelectionDomain>\n"
34117 " <Documentation>Select the cell arrays to read load.</Documentation>\n"
34118 " </StringVectorProperty>\n"
34119 " </Proxy>\n"
34120 "\n"
34121 " <!-- ================================================================== -->\n"
34122 " <Proxy class=\"vtkAMRVelodyneReader\"\n"
34123 " label=\"Velodyne AMR Reader\"\n"
34124 " name=\"VelodyneReaderCore\">\n"
34125 " <Documentation long_help=\"Read OvelappingAMR from a Velodyne AMR dataset.\"\n"
34126 " short_help=\"Read Velodyne AMR.\">\n"
34127 " This Velodyne AMR reader loads data stored in xamr format. The\n"
34128 " output of this reader is a vtkOverlappingAMR\n"
34129 " dataset.</Documentation>\n"
34130 " <!-- Define Filename -->\n"
34131 " <StringVectorProperty animateable=\"0\"\n"
34132 " command=\"SetFileName\"\n"
34133 " name=\"FileName\"\n"
34134 " number_of_elements=\"1\"\n"
34135 " panel_visibility=\"never\">\n"
34136 " <FileListDomain name=\"files\" />\n"
34137 " <Documentation>This property specifies the Vamr file\n"
34138 " name</Documentation>\n"
34139 " </StringVectorProperty>\n"
34140 " <!-- Display the number of levels -->\n"
34141 " <IntVectorProperty command=\"GetNumberOfLevels\"\n"
34142 " information_only=\"1\"\n"
34143 " name=\"NumLevels\">\n"
34144 " <SimpleIntInformationHelper />\n"
34145 " </IntVectorProperty>\n"
34146 " <!-- Display the number of blocks -->\n"
34147 " <IntVectorProperty command=\"GetNumberOfBlocks\"\n"
34148 " information_only=\"1\"\n"
34149 " name=\"NumBlocks\">\n"
34150 " <SimpleIntInformationHelper />\n"
34151 " </IntVectorProperty>\n"
34152 " <IntVectorProperty command=\"SetEnableCaching\"\n"
34153 " default_values=\"0\"\n"
34154 " name=\"EnableCaching\"\n"
34155 " number_of_elements=\"1\">\n"
34156 " <BooleanDomain name=\"bool\" />\n"
34157 " <Documentation>Turn caching on/off</Documentation>\n"
34158 " </IntVectorProperty>\n"
34159 " <!-- Define MaxLevel property -->\n"
34160 " <IntVectorProperty command=\"SetMaxLevel\"\n"
34161 " default_values=\"15\"\n"
34162 " name=\"Level\"\n"
34163 " number_of_elements=\"1\">\n"
34164 " <IntRangeDomain max=\"100\"\n"
34165 " min=\"0\"\n"
34166 " name=\"range\" />\n"
34167 " <Documentation>This property specifies the desired level of resolution\n"
34168 " that will be visible.</Documentation>\n"
34169 " </IntVectorProperty>\n"
34170 " <!-- Array Selection GUI Component -->\n"
34171 " <StringVectorProperty information_only=\"1\"\n"
34172 " name=\"CellArrayInfo\">\n"
34173 " <ArraySelectionInformationHelper attribute_name=\"Cell\" />\n"
34174 " </StringVectorProperty>\n"
34175 " <StringVectorProperty command=\"SetCellArrayStatus\"\n"
34176 " element_types=\"2 0\"\n"
34177 " information_property=\"CellArrayInfo\"\n"
34178 " label=\"Cell Arrays\"\n"
34179 " name=\"CellArrayStatus\"\n"
34180 " number_of_elements=\"0\"\n"
34181 " number_of_elements_per_command=\"2\"\n"
34182 " repeat_command=\"1\">\n"
34183 " <ArraySelectionDomain name=\"array_list\">\n"
34184 " <RequiredProperties>\n"
34185 " <Property function=\"ArrayList\"\n"
34186 " name=\"CellArrayInfo\" />\n"
34187 " </RequiredProperties>\n"
34188 " </ArraySelectionDomain>\n"
34189 " <Documentation>This property lists which cell-centered arrays to\n"
34190 " read.</Documentation>\n"
34191 " </StringVectorProperty>\n"
34192 " <StringVectorProperty information_only=\"1\"\n"
34193 " name=\"PointArrayInfo\">\n"
34194 " <ArraySelectionInformationHelper attribute_name=\"Point\" />\n"
34195 " </StringVectorProperty>\n"
34196 " <StringVectorProperty command=\"SetPointArrayStatus\"\n"
34197 " element_types=\"2 0\"\n"
34198 " information_property=\"PointArrayInfo\"\n"
34199 " label=\"PointArrays\"\n"
34200 " name=\"PointArrayStatus\"\n"
34201 " number_of_elements=\"0\"\n"
34202 " number_of_elements_per_command=\"2\"\n"
34203 " repeat_command=\"1\">\n"
34204 " <ArraySelectionDomain name=\"array_list\">\n"
34205 " <RequiredProperties>\n"
34206 " <Property function=\"ArrayList\"\n"
34207 " name=\"PointArrayInfo\" />\n"
34208 " </RequiredProperties>\n"
34209 " </ArraySelectionDomain>\n"
34210 " <Documentation>This property lists which point-centered arrays to\n"
34211 " read.</Documentation>\n"
34212 " </StringVectorProperty>\n"
34213 " </Proxy>\n"
34214 "\n"
34215 " <!-- ================================================================== -->\n"
34216 " <SourceProxy name=\"AMReXParticlesReaderCore\"\n"
34217 " class=\"vtkAMReXParticlesReader\">\n"
34218 " <Documentation short_help=\"Reader for AMReX particle data\">\n"
34219 " Internal reader proxy for AMReX particles. This is a distributed reader.\n"
34220 " </Documentation>\n"
34221 "\n"
34222 " <StringVectorProperty name=\"ParticleType\"\n"
34223 " command=\"SetParticleType\"\n"
34224 " number_of_elements=\"1\"\n"
34225 " default_values=\"particles\">\n"
34226 " <Documentation>\n"
34227 " Set the type of particles to read.\n"
34228 " </Documentation>\n"
34229 " </StringVectorProperty>\n"
34230 "\n"
34231 " <StringVectorProperty name=\"PointArrayInfo\"\n"
34232 " command=\"GetPointDataArraySelection\"\n"
34233 " number_of_elements_per_command=\"2\"\n"
34234 " information_only=\"1\"\n"
34235 " si_class=\"vtkSIDataArraySelectionProperty\" />\n"
34236 "\n"
34237 " <StringVectorProperty name=\"PointArrayStatus\"\n"
34238 " command=\"GetPointDataArraySelection\"\n"
34239 " information_property=\"PointArrayInfo\"\n"
34240 " number_of_elements_per_command=\"2\"\n"
34241 " element_types=\"2 0\"\n"
34242 " repeat_command=\"1\"\n"
34243 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
34244 " <ArraySelectionDomain name=\"array_list\">\n"
34245 " <RequiredProperties>\n"
34246 " <Property function=\"ArrayList\" name=\"PointArrayInfo\" />\n"
34247 " </RequiredProperties>\n"
34248 " </ArraySelectionDomain>\n"
34249 " <Documentation>Select the point arrays to read load.</Documentation>\n"
34250 " </StringVectorProperty>\n"
34251 " <!-- End AMReXParticlesReaderCore -->\n"
34252 " </SourceProxy>\n"
34253 "\n"
34254 " <!-- end of \"internal_sources\" -->\n"
34255 " </ProxyGroup>\n"
34256 "\n"
34257 " <!-- ==================================================================== -->\n"
34258 " <ProxyGroup name=\"sources\">\n"
34259 "\n"
34260 " <!-- ================================================================== -->\n"
34261 " <SourceProxy class=\"vtkFileSeriesReader\"\n"
34262 " file_name_method=\"SetFileName\"\n"
34263 " label=\"FLASH AMR Particles Reader\"\n"
34264 " name=\"FlashParticlesReader\"\n"
34265 " si_class=\"vtkSIMetaReaderProxy\">\n"
34266 " <Documentation long_help=\"Reads AMR particles from FLASH dataset\"\n"
34267 " short_help=\"Reads AMR particles from FLASH dataset\">The\n"
34268 " Flash particles reader loads particle simulation data\n"
34269 " stored in Flash format. The output of this reader is a\n"
34270 " MultiBlock dataset where each block is vtkPolyData that\n"
34271 " holds the particles and corresponding particle\n"
34272 " data.</Documentation>\n"
34273 " <SubProxy>\n"
34274 " <Proxy name=\"Reader\"\n"
34275 " proxygroup=\"internal_sources\"\n"
34276 ;
34277
34278 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOAMR/Resources/readers_pv_ioamr.xml
34280 " proxyname=\"FlashParticlesReaderCore\"></Proxy>\n"
34281 " <ExposedProperties>\n"
34282 " <Property name=\"NumParticles\" />\n"
34283 " <Property name=\"Frequency\" />\n"
34284 " <Property name=\"FilterLocation\" />\n"
34285 " <Property name=\"MinLocation\" />\n"
34286 " <Property name=\"MaxLocation\" />\n"
34287 " <Property name=\"ParticleArrayStatus\" />\n"
34288 " </ExposedProperties>\n"
34289 " </SubProxy>\n"
34290 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34291 " information_only=\"1\"\n"
34292 " name=\"FileNameInfo\">\n"
34293 " <SimpleStringInformationHelper />\n"
34294 " </StringVectorProperty>\n"
34295 " <StringVectorProperty animateable=\"0\"\n"
34296 " clean_command=\"RemoveAllFileNames\"\n"
34297 " command=\"AddFileName\"\n"
34298 " name=\"FileNames\"\n"
34299 " number_of_elements=\"0\"\n"
34300 " panel_visibility=\"never\"\n"
34301 " repeat_command=\"1\">\n"
34302 " <FileListDomain name=\"files\" />\n"
34303 " <Documentation>The list of files to be read by the\n"
34304 " reader.</Documentation>\n"
34305 " </StringVectorProperty>\n"
34306 " <DoubleVectorProperty information_only=\"1\"\n"
34307 " name=\"TimestepValues\"\n"
34308 " repeatable=\"1\">\n"
34309 " <TimeStepsInformationHelper />\n"
34310 " <Documentation>Available timestep values.</Documentation>\n"
34311 " </DoubleVectorProperty>\n"
34312 " <Hints>\n"
34313 " <ReaderFactory extensions=\"Flash flash\"\n"
34314 " file_description=\"FLASH AMR Particles Reader\" />\n"
34315 " </Hints>\n"
34316 " </SourceProxy>\n"
34317 "\n"
34318 " <!-- ================================================================== -->\n"
34319 " <SourceProxy class=\"vtkFileSeriesReader\"\n"
34320 " file_name_method=\"SetFileName\"\n"
34321 " label=\"ENZO AMR Particles Reader\"\n"
34322 " name=\"EnzoParticlesReader\"\n"
34323 " si_class=\"vtkSIMetaReaderProxy\">\n"
34324 " <Documentation long_help=\"Reads AMR particles from an ENZO dataset\"\n"
34325 " short_help=\"Reads AMR particles from an ENZO dataset\">The\n"
34326 " Enzo particles reader loads particle simulation data\n"
34327 " stored in Enzo HDF5 format. The output of this reader is\n"
34328 " MultiBlock dataset where each block is a vtkPolyData that\n"
34329 " holds the particles (points) and corresponding particle\n"
34330 " data.</Documentation>\n"
34331 " <SubProxy>\n"
34332 " <Proxy name=\"Reader\"\n"
34333 " proxygroup=\"internal_sources\"\n"
34334 " proxyname=\"EnzoParticlesReaderCore\"></Proxy>\n"
34335 " <ExposedProperties>\n"
34336 " <Property name=\"NumParticles\" />\n"
34337 " <Property name=\"Frequency\" />\n"
34338 " <Property name=\"FilterLocation\" />\n"
34339 " <Property name=\"MinLocation\" />\n"
34340 " <Property name=\"MaxLocation\" />\n"
34341 " <Property name=\"ParticleArrayStatus\" />\n"
34342 " <Property name=\"ParticleType\" />\n"
34343 " </ExposedProperties>\n"
34344 " </SubProxy>\n"
34345 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34346 " information_only=\"1\"\n"
34347 " name=\"FileNameInfo\">\n"
34348 " <SimpleStringInformationHelper />\n"
34349 " </StringVectorProperty>\n"
34350 " <StringVectorProperty animateable=\"0\"\n"
34351 " clean_command=\"RemoveAllFileNames\"\n"
34352 " command=\"AddFileName\"\n"
34353 " name=\"FileNames\"\n"
34354 " number_of_elements=\"0\"\n"
34355 " panel_visibility=\"never\"\n"
34356 " repeat_command=\"1\">\n"
34357 " <FileListDomain name=\"files\" />\n"
34358 " <Documentation>The list of files to be read by the\n"
34359 " reader.</Documentation>\n"
34360 " </StringVectorProperty>\n"
34361 " <DoubleVectorProperty information_only=\"1\"\n"
34362 " name=\"TimestepValues\"\n"
34363 " repeatable=\"1\">\n"
34364 " <TimeStepsInformationHelper />\n"
34365 " <Documentation>Available timestep values.</Documentation>\n"
34366 " </DoubleVectorProperty>\n"
34367 " <Hints>\n"
34368 " <ReaderFactory extensions=\"boundary hierarchy\"\n"
34369 " file_description=\"ENZO AMR Particles Reader\" />\n"
34370 " </Hints>\n"
34371 " </SourceProxy>\n"
34372 "\n"
34373 " <!-- ================================================================== -->\n"
34374 " <SourceProxy class=\"vtkFileSeriesReader\"\n"
34375 " file_name_method=\"SetFileName\"\n"
34376 " label=\"Flash Reader\"\n"
34377 " name=\"FlashReader\"\n"
34378 " si_class=\"vtkSIMetaReaderProxy\">\n"
34379 " <Documentation long_help=\"Read hierarchical box dataset from a Flash dataset.\"\n"
34380 " short_help=\"Read hierarchical box dataset from a Flash dataset.\">\n"
34381 " This Flash reader loads data stored in Enzo format. The\n"
34382 " output of this reader is a hierarchical-box\n"
34383 " dataset.</Documentation>\n"
34384 " <SubProxy>\n"
34385 " <Proxy name=\"Reader\"\n"
34386 " proxygroup=\"internal_sources\"\n"
34387 " proxyname=\"FlashReaderCore\"></Proxy>\n"
34388 " <ExposedProperties>\n"
34389 " <Property name=\"NumLevels\" />\n"
34390 " <Property name=\"NumBlocks\" />\n"
34391 " <Property name=\"EnableCaching\" />\n"
34392 " <Property name=\"Level\" />\n"
34393 " <PropertyGroup label=\"Cell/Point Array Status\"\n"
34394 " name=\"CellPointArrayStatus\"\n"
34395 " panel_visibility=\"default\"\n"
34396 " panel_widget=\"ArrayStatus\">\n"
34397 " <Property name=\"PointArrayStatus\" />\n"
34398 " <Property name=\"CellArrayStatus\" />\n"
34399 " </PropertyGroup>\n"
34400 " </ExposedProperties>\n"
34401 " </SubProxy>\n"
34402 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34403 " information_only=\"1\"\n"
34404 " name=\"FileNameInfo\">\n"
34405 " <SimpleStringInformationHelper />\n"
34406 " </StringVectorProperty>\n"
34407 " <StringVectorProperty animateable=\"0\"\n"
34408 " clean_command=\"RemoveAllFileNames\"\n"
34409 " command=\"AddFileName\"\n"
34410 " name=\"FileNames\"\n"
34411 " number_of_elements=\"0\"\n"
34412 " panel_visibility=\"never\"\n"
34413 " repeat_command=\"1\">\n"
34414 " <FileListDomain name=\"files\" />\n"
34415 " <Documentation>The list of files to be read by the\n"
34416 " reader.</Documentation>\n"
34417 " </StringVectorProperty>\n"
34418 " <DoubleVectorProperty information_only=\"1\"\n"
34419 " name=\"TimestepValues\"\n"
34420 " repeatable=\"1\">\n"
34421 " <TimeStepsInformationHelper />\n"
34422 " <Documentation>Available timestep values.</Documentation>\n"
34423 " </DoubleVectorProperty>\n"
34424 " <Hints>\n"
34425 " <ReaderFactory extensions=\"Flash flash\"\n"
34426 " file_description=\"AMR Flash Files\" />\n"
34427 " </Hints>\n"
34428 " </SourceProxy>\n"
34429 "\n"
34430 " <!-- ================================================================== -->\n"
34431 " <SourceProxy class=\"vtkAMRFileSeriesReader\"\n"
34432 " file_name_method=\"SetFileName\"\n"
34433 " label=\"Enzo Reader\"\n"
34434 " name=\"EnzoReader\"\n"
34435 " si_class=\"vtkSIMetaReaderProxy\">\n"
34436 " <Documentation long_help=\"Read hierarchical box dataset from an Enzo file.\"\n"
34437 " short_help=\"Read hierarchical box dataset from an Enzo file.\">\n"
34438 " This Enzo reader loads data stored in Enzo format. The\n"
34439 " output of this reader is a hierarchical-box\n"
34440 " dataset.</Documentation>\n"
34441 " <SubProxy>\n"
34442 " <Proxy name=\"Reader\"\n"
34443 " proxygroup=\"internal_sources\"\n"
34444 " proxyname=\"EnzoReaderCore\"></Proxy>\n"
34445 " <ExposedProperties>\n"
34446 " <Property name=\"NumLevels\" />\n"
34447 " <Property name=\"NumBlocks\" />\n"
34448 " <Property name=\"EnableCaching\" />\n"
34449 " <Property name=\"ConvertToCGS\" />\n"
34450 " <Property name=\"Level\" />\n"
34451 " <Property name=\"PointArrayStatus\" />\n"
34452 " <Property name=\"CellArrayStatus\" />\n"
34453 " </ExposedProperties>\n"
34454 " </SubProxy>\n"
34455 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34456 " information_only=\"1\"\n"
34457 " name=\"FileNameInfo\">\n"
34458 " <SimpleStringInformationHelper />\n"
34459 " </StringVectorProperty>\n"
34460 " <StringVectorProperty animateable=\"0\"\n"
34461 " clean_command=\"RemoveAllFileNames\"\n"
34462 " command=\"AddFileName\"\n"
34463 " name=\"FileNames\"\n"
34464 " number_of_elements=\"0\"\n"
34465 " panel_visibility=\"never\"\n"
34466 " repeat_command=\"1\">\n"
34467 " <FileListDomain name=\"files\" />\n"
34468 " <Documentation>The list of files to be read by the\n"
34469 " reader.</Documentation>\n"
34470 " </StringVectorProperty>\n"
34471 " <DoubleVectorProperty information_only=\"1\"\n"
34472 " name=\"TimestepValues\"\n"
34473 " repeatable=\"1\">\n"
34474 " <TimeStepsInformationHelper />\n"
34475 " <Documentation>Available timestep values.</Documentation>\n"
34476 " </DoubleVectorProperty>\n"
34477 " <Hints>\n"
34478 " <ReaderFactory extensions=\"boundary hierarchy\"\n"
34479 " file_description=\"AMR Enzo Files\" />\n"
34480 " </Hints>\n"
34481 " </SourceProxy>\n"
34482 "\n"
34483 " <!-- ================================================================== -->\n"
34484 " <SourceProxy class=\"vtkAMRFileSeriesReader\"\n"
34485 " file_name_method=\"SetFileName\"\n"
34486 " label=\"Velodyne AMR Reader\"\n"
34487 " name=\"VelodyneAMRReader\"\n"
34488 " si_class=\"vtkSIMetaReaderProxy\">\n"
34489 " <Documentation long_help=\"Read vtkOverlappingAMR data set from from a Xamr dataset.\"\n"
34490 " short_help=\"Read Velodyne AMR.\">\n"
34491 " This Velodyne AMR reader loads data stored in XAMR format. The\n"
34492 " output of this reader is a vtkOverlappingAMR\n"
34493 " dataset.</Documentation>\n"
34494 " <SubProxy>\n"
34495 " <Proxy name=\"Reader\"\n"
34496 " proxygroup=\"internal_sources\"\n"
34497 " proxyname=\"VelodyneReaderCore\"></Proxy>\n"
34498 " <ExposedProperties>\n"
34499 " <Property name=\"NumLevels\" />\n"
34500 " <Property name=\"NumBlocks\" />\n"
34501 " <Property name=\"EnableCaching\" />\n"
34502 " <Property name=\"Level\" />\n"
34503 " <PropertyGroup label=\"Cell/Point Array Status\"\n"
34504 " name=\"CellPointArrayStatus\"\n"
34505 " panel_visibility=\"default\"\n"
34506 " panel_widget=\"ArrayStatus\">\n"
34507 " <Property name=\"PointArrayStatus\" />\n"
34508 " <Property name=\"CellArrayStatus\" />\n"
34509 " </PropertyGroup>\n"
34510 " </ExposedProperties>\n"
34511 " </SubProxy>\n"
34512 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34513 " information_only=\"1\"\n"
34514 " name=\"FileNameInfo\">\n"
34515 " <SimpleStringInformationHelper />\n"
34516 " </StringVectorProperty>\n"
34517 " <StringVectorProperty animateable=\"0\"\n"
34518 " clean_command=\"RemoveAllFileNames\"\n"
34519 " command=\"AddFileName\"\n"
34520 " name=\"FileNames\"\n"
34521 " number_of_elements=\"0\"\n"
34522 " panel_visibility=\"never\"\n"
34523 " repeat_command=\"1\">\n"
34524 " <FileListDomain name=\"files\" />\n"
34525 " <Documentation>The list of files to be read by the\n"
34526 " reader.</Documentation>\n"
34527 " </StringVectorProperty>\n"
34528 " <DoubleVectorProperty information_only=\"1\"\n"
34529 " name=\"TimestepValues\"\n"
34530 " repeatable=\"1\">\n"
34531 " <TimeStepsInformationHelper />\n"
34532 " <Documentation>Available timestep values.</Documentation>\n"
34533 " </DoubleVectorProperty>\n"
34534 " <Hints>\n"
34535 " <ReaderFactory extensions=\"xamr Xamr XAMR\"\n"
34536 " file_description=\"AMR Velodyne Files\" />\n"
34537 " </Hints>\n"
34538 " </SourceProxy>\n"
34539 "\n"
34540 " <!-- ================================================================== -->\n"
34541 " <SourceProxy class=\"vtkFileSeriesReader\"\n"
34542 " file_name_method=\"SetFileName\"\n"
34543 " label=\"AMReX/BoxLib Grid Reader\"\n"
34544 " name=\"AMReXGridReader\"\n"
34545 " si_class=\"vtkSIMetaReaderProxy\">\n"
34546 " <Documentation\n"
34547 " long_help=\"Reads AMReX plotfiles (grids) data.\"\n"
34548 " short_help=\"Reads AMReX plotfiles (grids) data.\">\n"
34549 " This AMReX reader loads data stored in AMReX plt file format. The\n"
34550 " output of this reader is a hierarchical-box dataset.</Documentation>\n"
34551 " <SubProxy>\n"
34552 " <Proxy name=\"Reader\"\n"
34553 " proxygroup=\"internal_sources\"\n"
34554 " proxyname=\"vtkAMReXGridReaderCore\">\n"
34555 " </Proxy>\n"
34556 " <ExposedProperties>\n"
34557 " <Property name=\"NumLevels\" />\n"
34558 " <Property name=\"NumBlocks\" />\n"
34559 " <Property name=\"EnableCaching\" />\n"
34560 " <Property name=\"Level\" />\n"
34561 " <Property name=\"PointArrayStatus\" />\n"
34562 " <Property name=\"CellArrayStatus\" />\n"
34563 " </ExposedProperties>\n"
34564 " </SubProxy>\n"
34565 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34566 " information_only=\"1\"\n"
34567 " name=\"FileNameInfo\">\n"
34568 " <SimpleStringInformationHelper />\n"
34569 " </StringVectorProperty>\n"
34570 " <StringVectorProperty animateable=\"0\"\n"
34571 " clean_command=\"RemoveAllFileNames\"\n"
34572 " command=\"AddFileName\"\n"
34573 " name=\"FileNames\"\n"
34574 " number_of_elements=\"0\"\n"
34575 " panel_visibility=\"never\"\n"
34576 " repeat_command=\"1\">\n"
34577 " <FileListDomain name=\"files\" />\n"
34578 " <Documentation>The list of files to be read by the\n"
34579 " reader.</Documentation>\n"
34580 " </StringVectorProperty>\n"
34581 " <DoubleVectorProperty information_only=\"1\"\n"
34582 " name=\"TimestepValues\"\n"
34583 " repeatable=\"1\">\n"
34584 " <TimeStepsInformationHelper />\n"
34585 " <Documentation>Available timestep values.</Documentation>\n"
34586 " </DoubleVectorProperty>\n"
34587 " <Hints>\n"
34588 " <ReaderFactory\n"
34589 " filename_patterns=\"plt*\"\n"
34590 " file_description=\"AMReX/BoxLib plotfiles (grids)\"\n"
34591 " is_directory=\"1\"\n"
34592 " />\n"
34593 " </Hints>\n"
34594 " </SourceProxy>\n"
34595 "\n"
34596 " <!-- ================================================================== -->\n"
34597 " <SourceProxy name=\"AMReXParticlesReader\"\n"
34598 " class=\"vtkFileSeriesReader\"\n"
34599 " file_name_method=\"SetPlotFileName\"\n"
34600 " label=\"AMReX/BoxLib Particles Reader\"\n"
34601 " si_class=\"vtkSIMetaReaderProxy\">\n"
34602 " <Documentation short_help=\"Reader for AMReX particle data\">\n"
34603 " Reads particle data from AMReX plotfiles. This is a distributed reader.\n"
34604 ;
34605
34606 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOAMR/Resources/readers_pv_ioamr.xml
34608 " </Documentation>\n"
34609 "\n"
34610 " <SubProxy>\n"
34611 " <Proxy name=\"Reader\" proxygroup=\"internal_sources\" proxyname=\"AMReXParticlesReaderCore\" />\n"
34612 " <ExposedProperties>\n"
34613 " <Property name=\"ParticleType\" />\n"
34614 " <Property name=\"PointArrayInfo\" />\n"
34615 " <Property name=\"PointArrayStatus\" />\n"
34616 " </ExposedProperties>\n"
34617 " </SubProxy>\n"
34618 " <StringVectorProperty command=\"GetCurrentFileName\"\n"
34619 " information_only=\"1\"\n"
34620 " name=\"FileNameInfo\">\n"
34621 " <SimpleStringInformationHelper />\n"
34622 " </StringVectorProperty>\n"
34623 " <StringVectorProperty animateable=\"0\"\n"
34624 " clean_command=\"RemoveAllFileNames\"\n"
34625 " command=\"AddFileName\"\n"
34626 " name=\"FileNames\"\n"
34627 " number_of_elements=\"0\"\n"
34628 " panel_visibility=\"never\"\n"
34629 " repeat_command=\"1\">\n"
34630 " <FileListDomain name=\"files\" />\n"
34631 " <Documentation>The list of plotfiles to be read by the reader.</Documentation>\n"
34632 " </StringVectorProperty>\n"
34633 " <DoubleVectorProperty information_only=\"1\" name=\"TimestepValues\" repeatable=\"1\">\n"
34634 " <TimeStepsInformationHelper />\n"
34635 " <Documentation>Available timestep values.</Documentation>\n"
34636 " </DoubleVectorProperty>\n"
34637 " <Hints>\n"
34638 " <ReaderFactory\n"
34639 " filename_patterns=\"plt*\"\n"
34640 " file_description=\"AMReX/BoxLib plotfiles (particles)\"\n"
34641 " is_directory=\"1\" />\n"
34642 " </Hints>\n"
34643 " <!-- end AMReXParticlesReader -->\n"
34644 " </SourceProxy>\n"
34645 " </ProxyGroup>\n"
34646 "</ServerManagerConfiguration>\n"
34647 "\n";
34648 // Get single string
34650 {
34651
34652  const size_t len0 = strlen(paraview_server_managerreaders_pv_ioamrInterface0);
34653  const size_t len1 = strlen(paraview_server_managerreaders_pv_ioamrInterface1);
34654  const size_t len2 = strlen(paraview_server_managerreaders_pv_ioamrInterface2);
34655  const size_t len3 = strlen(paraview_server_managerreaders_pv_ioamrInterface3);
34656  size_t len = ( 0
34657  + len0
34658  + len1
34659  + len2
34660  + len3 );
34661  char* res = new char[ len + 1];
34662  size_t offset = 0;
34667  assert(offset == len);
34668  res[offset] = 0;
34669  return res;
34670 }
34671
34672
34673 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersStatistics/Resources/statistics_filters.xml
34675 "<ServerManagerConfiguration>\n"
34676 " <ProxyGroup name=\"filters\">\n"
34677 " <!-- ==================================================================== -->\n"
34678 " <SourceProxy class=\"vtkPSciVizContingencyStats\"\n"
34679 " label=\"Contingency Statistics\"\n"
34680 " name=\"ContingencyStatistics\">\n"
34681 " <Documentation long_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\"\n"
34682 " short_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\">\n"
34683 " This filter either computes a statistical model of a dataset or takes\n"
34684 " such a model as its second input. Then, the model (however it is\n"
34685 " obtained) may optionally be used to assess the input dataset. This filter\n"
34686 " computes contingency tables between pairs of attributes. This result is a\n"
34687 " tabular bivariate probability distribution which serves as a\n"
34688 " Bayesian-style prior model. Data is assessed by computing &lt;ul&gt;\n"
34689 " &lt;li&gt; the probability of observing both variables simultaneously;\n"
34690 " &lt;li&gt; the probability of each variable conditioned on the other (the\n"
34691 " two values need not be identical); and &lt;li&gt; the pointwise mutual\n"
34692 " information (PMI). &lt;/ul&gt; Finally, the summary statistics include\n"
34693 " the information entropy of the observations.</Documentation>\n"
34694 " <InputProperty command=\"SetInputConnection\"\n"
34695 " name=\"Input\"\n"
34696 " port_index=\"0\">\n"
34697 " <ProxyGroupDomain name=\"groups\">\n"
34698 " <Group name=\"sources\" />\n"
34699 " <Group name=\"filters\" />\n"
34700 " </ProxyGroupDomain>\n"
34701 " <DataTypeDomain name=\"input_type\">\n"
34702 " <DataType value=\"vtkImageData\" />\n"
34703 " <DataType value=\"vtkStructuredGrid\" />\n"
34704 " <DataType value=\"vtkPolyData\" />\n"
34705 " <DataType value=\"vtkUnstructuredGrid\" />\n"
34706 " <DataType value=\"vtkTable\" />\n"
34707 " <DataType value=\"vtkGraph\" />\n"
34708 " </DataTypeDomain>\n"
34709 " <InputArrayDomain name=\"input_array\" />\n"
34710 " <Documentation>The input to the filter. Arrays from this dataset will\n"
34711 " be used for computing statistics and/or assessed by a statistical\n"
34712 " model.</Documentation>\n"
34713 " </InputProperty>\n"
34714 " <InputProperty command=\"SetInputConnection\"\n"
34715 " name=\"ModelInput\"\n"
34716 " null_on_empty=\"1\"\n"
34717 " port_index=\"1\">\n"
34718 " <Hints>\n"
34719 " <Optional />\n"
34720 " <!-- No input selection dialog at instantiation -->\n"
34721 " </Hints>\n"
34722 " <ProxyGroupDomain name=\"groups\">\n"
34723 " <Group name=\"sources\" />\n"
34724 " <Group name=\"filters\" />\n"
34725 " </ProxyGroupDomain>\n"
34726 " <DataTypeDomain name=\"input_type\">\n"
34727 " <DataType value=\"vtkTable\" />\n"
34728 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
34729 " </DataTypeDomain>\n"
34730 " <Documentation>A previously-calculated model with which to assess a\n"
34731 " separate dataset. This input is optional.</Documentation>\n"
34732 " </InputProperty>\n"
34733 " <IntVectorProperty command=\"SetAttributeMode\"\n"
34734 " default_values=\"0\"\n"
34735 " name=\"AttributeMode\"\n"
34736 " number_of_elements=\"1\">\n"
34737 " <FieldDataDomain enable_field_data=\"1\"\n"
34738 " name=\"enum\">\n"
34739 " <RequiredProperties>\n"
34740 " <Property function=\"Input\"\n"
34741 " name=\"Input\" />\n"
34742 " </RequiredProperties>\n"
34743 " </FieldDataDomain>\n"
34744 " <Documentation>Specify which type of field data the arrays will be\n"
34745 " drawn from.</Documentation>\n"
34746 " </IntVectorProperty>\n"
34747 " <StringVectorProperty clean_command=\"ClearAttributeArrays\"\n"
34748 " command=\"EnableAttributeArray\"\n"
34749 " label=\"Variables of Interest\"\n"
34750 " name=\"SelectArrays\"\n"
34751 " number_of_elements_per_command=\"1\"\n"
34752 " repeat_command=\"1\">\n"
34753 " <ArrayListDomain name=\"array_list\">\n"
34754 " <RequiredProperties>\n"
34755 " <Property function=\"Input\"\n"
34756 " name=\"Input\" />\n"
34757 " <Property function=\"FieldDataSelection\"\n"
34758 " name=\"AttributeMode\" />\n"
34759 " </RequiredProperties>\n"
34760 " </ArrayListDomain>\n"
34761 " <Documentation>Choose arrays whose entries will be used to form\n"
34762 " observations for statistical analysis.</Documentation>\n"
34763 " </StringVectorProperty>\n"
34764 " <IntVectorProperty animateable=\"0\"\n"
34765 " command=\"SetTask\"\n"
34766 " default_values=\"0\"\n"
34767 " name=\"Task\"\n"
34768 " number_of_elements=\"1\">\n"
34769 " <EnumerationDomain name=\"task_list\">\n"
34770 " <Entry text=\"Detailed model of input data\"\n"
34771 " value=\"0\" />\n"
34772 " <Entry text=\"Model a subset of the data\"\n"
34773 " value=\"1\" />\n"
34774 " <Entry text=\"Assess the data with a model\"\n"
34775 " value=\"2\" />\n"
34776 " <Entry text=\"Model and assess the same data\"\n"
34777 " value=\"3\" />\n"
34778 " </EnumerationDomain>\n"
34779 " <Documentation>Specify the task to be performed: modeling and/or\n"
34780 " assessment. &lt;ol&gt; &lt;li&gt; \"Detailed model of input data,\"\n"
34781 " creates a set of output tables containing a calculated statistical\n"
34782 " model of the &lt;b&gt;entire&lt;/b&gt; input dataset;&lt;/li&gt;\n"
34783 " &lt;li&gt; \"Model a subset of the data,\" creates an output table (or\n"
34784 " tables) summarizing a &lt;b&gt;randomly-chosen subset&lt;/b&gt; of the\n"
34785 " input dataset;&lt;/li&gt; &lt;li&gt; \"Assess the data with a model,\"\n"
34786 " adds attributes to the first input dataset using a model provided on\n"
34787 " the second input port; and&lt;/li&gt; &lt;li&gt; \"Model and assess the\n"
34788 " same data,\" is really just operations 2 and 3 above applied to the same\n"
34789 " input dataset. The model is first trained using a fraction of the input\n"
34790 " data and then the entire dataset is assessed using that\n"
34791 " model.&lt;/li&gt; &lt;/ol&gt; When the task includes creating a model\n"
34792 " (i.e., tasks 2, and 4), you may adjust the fraction of the input\n"
34793 " dataset used for training. You should avoid using a large fraction of\n"
34794 " the input data for training as you will then not be able to detect\n"
34795 " overfitting. The &lt;i&gt;Training fraction&lt;/i&gt; setting will be\n"
34796 " ignored for tasks 1 and 3.</Documentation>\n"
34797 " </IntVectorProperty>\n"
34798 " <DoubleVectorProperty animateable=\"1\"\n"
34799 " command=\"SetTrainingFraction\"\n"
34800 " default_values=\"0.1\"\n"
34801 " name=\"TrainingFraction\"\n"
34802 " number_of_elements=\"1\">\n"
34803 " <DoubleRangeDomain max=\"1\"\n"
34804 " min=\"0\"\n"
34805 " name=\"training_range\" />\n"
34806 " <Documentation>Specify the fraction of values from the input dataset to\n"
34807 " be used for model fitting. The exact set of values is chosen at random\n"
34808 " from the dataset.</Documentation>\n"
34809 " </DoubleVectorProperty>\n"
34810 " <OutputPort index=\"0\"\n"
34811 " name=\"Statistical Model\" />\n"
34812 " <OutputPort index=\"1\"\n"
34813 " name=\"Assessed Data\" />\n"
34814 " <Hints>\n"
34815 " <Visibility replace_input=\"1\" />\n"
34816 " <!-- View can be used to specify the preferred view for the proxy -->\n"
34817 " <View type=\"SpreadSheetView\" port=\"0\" />\n"
34818 " <View type=\"None\" port=\"1\" />\n"
34819 " </Hints>\n"
34820 " </SourceProxy>\n"
34821 " <!-- ContingencyStatistics -->\n"
34822 " <!-- ==================================================================== -->\n"
34823 " <SourceProxy class=\"vtkPSciVizDescriptiveStats\"\n"
34824 " label=\"Descriptive Statistics\"\n"
34825 " name=\"DescriptiveStatistics\">\n"
34826 " <Documentation long_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\"\n"
34827 " short_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\">\n"
34828 " This filter either computes a statistical model of a dataset or takes\n"
34829 " such a model as its second input. Then, the model (however it is\n"
34830 " obtained) may optionally be used to assess the input dataset.&lt;p&gt;\n"
34831 " This filter computes the min, max, mean, raw moments M2 through M4,\n"
34832 " standard deviation, skewness, and kurtosis for each array you\n"
34833 " select.&lt;p&gt; The model is simply a univariate Gaussian distribution\n"
34834 " with the mean and standard deviation provided. Data is assessed using\n"
34835 " this model by detrending the data (i.e., subtracting the mean) and then\n"
34836 " dividing by the standard deviation. Thus the assessment is an array whose\n"
34837 " entries are the number of standard deviations from the mean that each\n"
34838 " input point lies.</Documentation>\n"
34839 " <InputProperty command=\"SetInputConnection\"\n"
34840 " name=\"Input\"\n"
34841 " port_index=\"0\">\n"
34842 " <ProxyGroupDomain name=\"groups\">\n"
34843 " <Group name=\"sources\" />\n"
34844 " <Group name=\"filters\" />\n"
34845 " </ProxyGroupDomain>\n"
34846 " <DataTypeDomain name=\"input_type\">\n"
34847 " <DataType value=\"vtkImageData\" />\n"
34848 " <DataType value=\"vtkStructuredGrid\" />\n"
34849 " <DataType value=\"vtkPolyData\" />\n"
34850 " <DataType value=\"vtkUnstructuredGrid\" />\n"
34851 " <DataType value=\"vtkTable\" />\n"
34852 " <DataType value=\"vtkGraph\" />\n"
34853 " </DataTypeDomain>\n"
34854 " <InputArrayDomain name=\"input_array\" />\n"
34855 " <Documentation>The input to the filter. Arrays from this dataset will\n"
34856 " be used for computing statistics and/or assessed by a statistical\n"
34857 " model.</Documentation>\n"
34858 " </InputProperty>\n"
34859 " <InputProperty command=\"SetInputConnection\"\n"
34860 " name=\"ModelInput\"\n"
34861 " null_on_empty=\"1\"\n"
34862 " port_index=\"1\">\n"
34863 " <Hints>\n"
34864 " <Optional />\n"
34865 " <!-- No input selection dialog at instantiation -->\n"
34866 " </Hints>\n"
34867 " <ProxyGroupDomain name=\"groups\">\n"
34868 " <Group name=\"sources\" />\n"
34869 " <Group name=\"filters\" />\n"
34870 " </ProxyGroupDomain>\n"
34871 " <DataTypeDomain name=\"input_type\">\n"
34872 " <DataType value=\"vtkTable\" />\n"
34873 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
34874 " </DataTypeDomain>\n"
34875 " <Documentation>A previously-calculated model with which to assess a\n"
34876 " separate dataset. This input is optional.</Documentation>\n"
34877 " </InputProperty>\n"
34878 " <IntVectorProperty command=\"SetAttributeMode\"\n"
34879 " default_values=\"0\"\n"
34880 " name=\"AttributeMode\"\n"
34881 " number_of_elements=\"1\">\n"
34882 " <FieldDataDomain enable_field_data=\"1\"\n"
34883 " name=\"enum\">\n"
34884 " <RequiredProperties>\n"
34885 " <Property function=\"Input\"\n"
34886 " name=\"Input\" />\n"
34887 " </RequiredProperties>\n"
34888 " </FieldDataDomain>\n"
34889 " <Documentation>Specify which type of field data the arrays will be\n"
34890 " drawn from.</Documentation>\n"
34891 " </IntVectorProperty>\n"
34892 " <StringVectorProperty clean_command=\"ClearAttributeArrays\"\n"
34893 " command=\"EnableAttributeArray\"\n"
34894 " label=\"Variables of Interest\"\n"
34895 " name=\"SelectArrays\"\n"
34896 " number_of_elements_per_command=\"1\"\n"
34897 " repeat_command=\"1\">\n"
34898 " <ArrayListDomain name=\"array_list\">\n"
34899 " <RequiredProperties>\n"
34900 " <Property function=\"Input\"\n"
34901 " name=\"Input\" />\n"
34902 " <Property function=\"FieldDataSelection\"\n"
34903 " name=\"AttributeMode\" />\n"
34904 " </RequiredProperties>\n"
34905 " </ArrayListDomain>\n"
34906 " <Documentation>Choose arrays whose entries will be used to form\n"
34907 " observations for statistical analysis.</Documentation>\n"
34908 " </StringVectorProperty>\n"
34909 " <IntVectorProperty animateable=\"0\"\n"
34910 " command=\"SetTask\"\n"
34911 " default_values=\"0\"\n"
34912 " name=\"Task\"\n"
34913 " number_of_elements=\"1\">\n"
34914 " <EnumerationDomain name=\"task_list\">\n"
34915 " <Entry text=\"Detailed model of input data\"\n"
34916 " value=\"0\" />\n"
34917 " <Entry text=\"Model a subset of the data\"\n"
34918 " value=\"1\" />\n"
34919 " <Entry text=\"Assess the data with a model\"\n"
34920 " value=\"2\" />\n"
34921 " <Entry text=\"Model and assess the same data\"\n"
34922 " value=\"3\" />\n"
34923 " </EnumerationDomain>\n"
34924 " <Documentation>Specify the task to be performed: modeling and/or\n"
34925 " assessment. &lt;ol&gt; &lt;li&gt; \"Detailed model of input data,\"\n"
34926 " creates a set of output tables containing a calculated statistical\n"
34927 " model of the &lt;b&gt;entire&lt;/b&gt; input dataset;&lt;/li&gt;\n"
34928 " &lt;li&gt; \"Model a subset of the data,\" creates an output table (or\n"
34929 " tables) summarizing a &lt;b&gt;randomly-chosen subset&lt;/b&gt; of the\n"
34930 " input dataset;&lt;/li&gt; &lt;li&gt; \"Assess the data with a model,\"\n"
34931 " adds attributes to the first input dataset using a model provided on\n"
34932 " the second input port; and&lt;/li&gt; &lt;li&gt; \"Model and assess the\n"
34933 " same data,\" is really just operations 2 and 3 above applied to the same\n"
34934 " input dataset. The model is first trained using a fraction of the input\n"
34935 " data and then the entire dataset is assessed using that\n"
34936 " model.&lt;/li&gt; &lt;/ol&gt; When the task includes creating a model\n"
34937 " (i.e., tasks 2, and 4), you may adjust the fraction of the input\n"
34938 " dataset used for training. You should avoid using a large fraction of\n"
34939 " the input data for training as you will then not be able to detect\n"
34940 " overfitting. The &lt;i&gt;Training fraction&lt;/i&gt; setting will be\n"
34941 " ignored for tasks 1 and 3.</Documentation>\n"
34942 " </IntVectorProperty>\n"
34943 " <DoubleVectorProperty animateable=\"1\"\n"
34944 " command=\"SetTrainingFraction\"\n"
34945 " default_values=\"0.1\"\n"
34946 " name=\"TrainingFraction\"\n"
34947 " number_of_elements=\"1\">\n"
34948 " <DoubleRangeDomain max=\"1\"\n"
34949 " min=\"0\"\n"
34950 " name=\"training_range\" />\n"
34951 " <Documentation>Specify the fraction of values from the input dataset to\n"
34952 " be used for model fitting. The exact set of values is chosen at random\n"
34953 " from the dataset.</Documentation>\n"
34954 " </DoubleVectorProperty>\n"
34955 " <IntVectorProperty animateable=\"1\"\n"
34956 " command=\"SetSignedDeviations\"\n"
34957 " default_values=\"0\"\n"
34958 " label=\"Deviations should be\"\n"
34959 " name=\"SignedDeviations\"\n"
34960 " number_of_elements=\"1\">\n"
34961 ;
34962
34963 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersStatistics/Resources/statistics_filters.xml
34965 " <EnumerationDomain name=\"signed_distance\">\n"
34966 " <Entry text=\"Unsigned\"\n"
34967 " value=\"0\" />\n"
34968 " <Entry text=\"Signed\"\n"
34969 " value=\"1\" />\n"
34970 " </EnumerationDomain>\n"
34971 " <Documentation>Should the assessed values be signed deviations or\n"
34972 " unsigned?</Documentation>\n"
34973 " </IntVectorProperty>\n"
34974 " <OutputPort index=\"0\"\n"
34975 " name=\"Statistical Model\" />\n"
34976 " <OutputPort index=\"1\"\n"
34977 " name=\"Assessed Data\" />\n"
34978 " <Hints>\n"
34979 " <Visibility replace_input=\"1\" />\n"
34980 " <!-- View can be used to specify the preferred view for the proxy -->\n"
34981 " <View type=\"SpreadSheetView\" port=\"0\" />\n"
34982 " <View type=\"None\" port=\"1\" />\n"
34983 " </Hints>\n"
34984 " </SourceProxy>\n"
34985 " <!-- DescriptiveStatistics -->\n"
34986 " <!-- ==================================================================== -->\n"
34987 " <SourceProxy class=\"vtkPSciVizKMeans\"\n"
34988 " label=\"K Means\"\n"
34989 " name=\"KMeans\">\n"
34990 " <Documentation long_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\"\n"
34991 " short_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\">\n"
34992 " This filter either computes a statistical model of a dataset or takes\n"
34993 " such a model as its second input. Then, the model (however it is\n"
34994 " obtained) may optionally be used to assess the input dataset.&lt;p&gt;\n"
34995 " This filter iteratively computes the center of k clusters in a space\n"
34996 " whose coordinates are specified by the arrays you select. The clusters\n"
34997 " are chosen as local minima of the sum of square Euclidean distances from\n"
34998 " each point to its nearest cluster center. The model is then a set of\n"
34999 " cluster centers. Data is assessed by assigning a cluster center and\n"
35000 " distance to the cluster to each point in the input data\n"
35001 " set.</Documentation>\n"
35002 " <InputProperty command=\"SetInputConnection\"\n"
35003 " name=\"Input\"\n"
35004 " port_index=\"0\">\n"
35005 " <ProxyGroupDomain name=\"groups\">\n"
35006 " <Group name=\"sources\" />\n"
35007 " <Group name=\"filters\" />\n"
35008 " </ProxyGroupDomain>\n"
35009 " <DataTypeDomain name=\"input_type\">\n"
35010 " <DataType value=\"vtkImageData\" />\n"
35011 " <DataType value=\"vtkStructuredGrid\" />\n"
35012 " <DataType value=\"vtkPolyData\" />\n"
35013 " <DataType value=\"vtkUnstructuredGrid\" />\n"
35014 " <DataType value=\"vtkTable\" />\n"
35015 " <DataType value=\"vtkGraph\" />\n"
35016 " </DataTypeDomain>\n"
35017 " <InputArrayDomain name=\"input_array\" />\n"
35018 " <Documentation>The input to the filter. Arrays from this dataset will\n"
35019 " be used for computing statistics and/or assessed by a statistical\n"
35020 " model.</Documentation>\n"
35021 " </InputProperty>\n"
35022 " <InputProperty command=\"SetInputConnection\"\n"
35023 " name=\"ModelInput\"\n"
35024 " null_on_empty=\"1\"\n"
35025 " port_index=\"1\">\n"
35026 " <Hints>\n"
35027 " <Optional />\n"
35028 " <!-- No input selection dialog at instantiation -->\n"
35029 " </Hints>\n"
35030 " <ProxyGroupDomain name=\"groups\">\n"
35031 " <Group name=\"sources\" />\n"
35032 " <Group name=\"filters\" />\n"
35033 " </ProxyGroupDomain>\n"
35034 " <DataTypeDomain name=\"input_type\">\n"
35035 " <DataType value=\"vtkTable\" />\n"
35036 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
35037 " </DataTypeDomain>\n"
35038 " <Documentation>A previously-calculated model with which to assess a\n"
35039 " separate dataset. This input is optional.</Documentation>\n"
35040 " </InputProperty>\n"
35041 " <IntVectorProperty command=\"SetAttributeMode\"\n"
35042 " default_values=\"0\"\n"
35043 " name=\"AttributeMode\"\n"
35044 " number_of_elements=\"1\">\n"
35045 " <FieldDataDomain enable_field_data=\"1\"\n"
35046 " name=\"enum\">\n"
35047 " <RequiredProperties>\n"
35048 " <Property function=\"Input\"\n"
35049 " name=\"Input\" />\n"
35050 " </RequiredProperties>\n"
35051 " </FieldDataDomain>\n"
35052 " <Documentation>Specify which type of field data the arrays will be\n"
35053 " drawn from.</Documentation>\n"
35054 " </IntVectorProperty>\n"
35055 " <StringVectorProperty clean_command=\"ClearAttributeArrays\"\n"
35056 " command=\"EnableAttributeArray\"\n"
35057 " label=\"Variables of Interest\"\n"
35058 " name=\"SelectArrays\"\n"
35059 " number_of_elements_per_command=\"1\"\n"
35060 " repeat_command=\"1\">\n"
35061 " <ArrayListDomain name=\"array_list\">\n"
35062 " <RequiredProperties>\n"
35063 " <Property function=\"Input\"\n"
35064 " name=\"Input\" />\n"
35065 " <Property function=\"FieldDataSelection\"\n"
35066 " name=\"AttributeMode\" />\n"
35067 " </RequiredProperties>\n"
35068 " </ArrayListDomain>\n"
35069 " <Documentation>Choose arrays whose entries will be used to form\n"
35070 " observations for statistical analysis.</Documentation>\n"
35071 " </StringVectorProperty>\n"
35072 " <IntVectorProperty animateable=\"0\"\n"
35073 " command=\"SetTask\"\n"
35074 " default_values=\"3\"\n"
35075 " name=\"Task\"\n"
35076 " number_of_elements=\"1\">\n"
35077 " <EnumerationDomain name=\"task_list\">\n"
35078 " <Entry text=\"Detailed model of input data\"\n"
35079 " value=\"0\" />\n"
35080 " <Entry text=\"Model a subset of the data\"\n"
35081 " value=\"1\" />\n"
35082 " <Entry text=\"Assess the data with a model\"\n"
35083 " value=\"2\" />\n"
35084 " <Entry text=\"Model and assess the same data\"\n"
35085 " value=\"3\" />\n"
35086 " </EnumerationDomain>\n"
35087 " <Documentation>Specify the task to be performed: modeling and/or\n"
35088 " assessment. &lt;ol&gt; &lt;li&gt; \"Detailed model of input data,\"\n"
35089 " creates a set of output tables containing a calculated statistical\n"
35090 " model of the &lt;b&gt;entire&lt;/b&gt; input dataset;&lt;/li&gt;\n"
35091 " &lt;li&gt; \"Model a subset of the data,\" creates an output table (or\n"
35092 " tables) summarizing a &lt;b&gt;randomly-chosen subset&lt;/b&gt; of the\n"
35093 " input dataset;&lt;/li&gt; &lt;li&gt; \"Assess the data with a model,\"\n"
35094 " adds attributes to the first input dataset using a model provided on\n"
35095 " the second input port; and&lt;/li&gt; &lt;li&gt; \"Model and assess the\n"
35096 " same data,\" is really just operations 2 and 3 above applied to the same\n"
35097 " input dataset. The model is first trained using a fraction of the input\n"
35098 " data and then the entire dataset is assessed using that\n"
35099 " model.&lt;/li&gt; &lt;/ol&gt; When the task includes creating a model\n"
35100 " (i.e., tasks 2, and 4), you may adjust the fraction of the input\n"
35101 " dataset used for training. You should avoid using a large fraction of\n"
35102 " the input data for training as you will then not be able to detect\n"
35103 " overfitting. The &lt;i&gt;Training fraction&lt;/i&gt; setting will be\n"
35104 " ignored for tasks 1 and 3.</Documentation>\n"
35105 " </IntVectorProperty>\n"
35106 " <DoubleVectorProperty animateable=\"1\"\n"
35107 " command=\"SetTrainingFraction\"\n"
35108 " default_values=\"0.1\"\n"
35109 " name=\"TrainingFraction\"\n"
35110 " number_of_elements=\"1\">\n"
35111 " <DoubleRangeDomain max=\"1\"\n"
35112 " min=\"0\"\n"
35113 " name=\"training_range\" />\n"
35114 " <Documentation>Specify the fraction of values from the input dataset to\n"
35115 " be used for model fitting. The exact set of values is chosen at random\n"
35116 " from the dataset.</Documentation>\n"
35117 " </DoubleVectorProperty>\n"
35118 " <IntVectorProperty animateable=\"1\"\n"
35119 " command=\"SetK\"\n"
35120 " default_values=\"5\"\n"
35121 " label=\"k\"\n"
35122 " name=\"K\"\n"
35123 " number_of_elements=\"1\">\n"
35124 " <IntRangeDomain min=\"1\"\n"
35125 " name=\"num_cluster_centers\" />\n"
35126 " <Documentation>Specify the number of clusters.</Documentation>\n"
35127 " </IntVectorProperty>\n"
35128 " <IntVectorProperty animateable=\"1\"\n"
35129 " command=\"SetMaxNumIterations\"\n"
35130 " default_values=\"50\"\n"
35131 " label=\"Max Iterations\"\n"
35132 " name=\"MaxNumIterations\"\n"
35133 " number_of_elements=\"1\">\n"
35134 " <IntRangeDomain min=\"1\"\n"
35135 " name=\"max_num_iter\" />\n"
35136 " <Documentation>Specify the maximum number of iterations in which\n"
35137 " cluster centers are moved before the algorithm\n"
35138 " terminates.</Documentation>\n"
35139 " </IntVectorProperty>\n"
35140 " <DoubleVectorProperty animateable=\"1\"\n"
35141 " command=\"SetTolerance\"\n"
35142 " default_values=\"0.01\"\n"
35143 " name=\"Tolerance\"\n"
35144 " number_of_elements=\"1\">\n"
35145 " <DoubleRangeDomain max=\"1\"\n"
35146 " min=\"0\"\n"
35147 " name=\"cluster_center_tolerance\" />\n"
35148 " <Documentation>Specify the relative tolerance that will cause early\n"
35149 " termination.</Documentation>\n"
35150 " </DoubleVectorProperty>\n"
35151 " <OutputPort index=\"0\"\n"
35152 " name=\"Statistical Model\" />\n"
35153 " <OutputPort index=\"1\"\n"
35154 " name=\"Assessed Data\" />\n"
35155 " <Hints>\n"
35156 " <Visibility replace_input=\"1\" />\n"
35157 " <!-- View can be used to specify the preferred view for the proxy -->\n"
35158 " <View type=\"SpreadSheetView\" port=\"0\" />\n"
35159 " <View type=\"None\" port=\"1\" />\n"
35160 " </Hints>\n"
35161 " </SourceProxy>\n"
35162 " <!-- K Means -->\n"
35163 " <!-- ==================================================================== -->\n"
35164 " <SourceProxy class=\"vtkPSciVizMultiCorrelativeStats\"\n"
35165 " label=\"Multicorrelative Statistics\"\n"
35166 " name=\"MulticorrelativeStatistics\">\n"
35167 " <Documentation long_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\"\n"
35168 " short_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\">\n"
35169 " This filter either computes a statistical model of a dataset or takes\n"
35170 " such a model as its second input. Then, the model (however it is\n"
35171 " obtained) may optionally be used to assess the input dataset.&lt;p&gt;\n"
35172 " This filter computes the covariance matrix for all the arrays you select\n"
35173 " plus the mean of each array. The model is thus a multivariate Gaussian\n"
35174 " distribution with the mean vector and variances provided. Data is\n"
35175 " assessed using this model by computing the Mahalanobis distance for each\n"
35176 " input point. This distance will always be positive.&lt;p&gt; The learned\n"
35177 " model output format is rather dense and can be confusing, so it is\n"
35178 " discussed here. The first filter output is a multiblock dataset\n"
35179 " consisting of 2 tables: &lt;ol&gt; &lt;li&gt; Raw covariance data.\n"
35180 " &lt;li&gt; Covariance matrix and its Cholesky decomposition. &lt;/ol&gt;\n"
35181 " The raw covariance table has 3 meaningful columns: 2 titled \"Column1\" and\n"
35182 " \"Column2\" whose entries generally refer to the N arrays you selected when\n"
35183 " preparing the filter and 1 column titled \"Entries\" that contains numeric\n"
35184 " values. The first row will always contain the number of observations in\n"
35185 " the statistical analysis. The next N rows contain the mean for each of\n"
35186 " the N arrays you selected. The remaining rows contain covariances of\n"
35187 " pairs of arrays.&lt;p&gt; The second table (covariance matrix and\n"
35188 " Cholesky decomposition) contains information derived from the raw\n"
35189 " covariance data of the first table. The first N rows of the first column\n"
35190 " contain the name of one array you selected for analysis. These rows are\n"
35191 " followed by a single entry labeled \"Cholesky\" for a total of N+1 rows.\n"
35192 " The second column, Mean contains the mean of each variable in the first N\n"
35193 " entries and the number of observations processed in the final (N+1)\n"
35194 " row.&lt;p&gt; The remaining columns (there are N, one for each array)\n"
35195 " contain 2 matrices in triangular format. The upper right triangle\n"
35196 " contains the covariance matrix (which is symmetric, so its lower triangle\n"
35197 " may be inferred). The lower left triangle contains the Cholesky\n"
35198 " decomposition of the covariance matrix (which is triangular, so its upper\n"
35199 " triangle is zero). Because the diagonal must be stored for both matrices,\n"
35200 " an additional row is required &#226;&#8364;&#8221; hence the N+1 rows and\n"
35201 " the final entry of the column named \"Column\".</Documentation>\n"
35202 " <InputProperty command=\"SetInputConnection\"\n"
35203 " name=\"Input\"\n"
35204 " port_index=\"0\">\n"
35205 " <ProxyGroupDomain name=\"groups\">\n"
35206 " <Group name=\"sources\" />\n"
35207 " <Group name=\"filters\" />\n"
35208 " </ProxyGroupDomain>\n"
35209 " <DataTypeDomain name=\"input_type\">\n"
35210 " <DataType value=\"vtkImageData\" />\n"
35211 " <DataType value=\"vtkStructuredGrid\" />\n"
35212 " <DataType value=\"vtkPolyData\" />\n"
35213 " <DataType value=\"vtkUnstructuredGrid\" />\n"
35214 " <DataType value=\"vtkTable\" />\n"
35215 " <DataType value=\"vtkGraph\" />\n"
35216 " </DataTypeDomain>\n"
35217 " <InputArrayDomain name=\"input_array\" />\n"
35218 " <Documentation>The input to the filter. Arrays from this dataset will\n"
35219 " be used for computing statistics and/or assessed by a statistical\n"
35220 " model.</Documentation>\n"
35221 " </InputProperty>\n"
35222 " <InputProperty command=\"SetInputConnection\"\n"
35223 " name=\"ModelInput\"\n"
35224 " null_on_empty=\"1\"\n"
35225 " port_index=\"1\">\n"
35226 " <Hints>\n"
35227 " <Optional />\n"
35228 " <!-- No input selection dialog at instantiation -->\n"
35229 " </Hints>\n"
35230 " <ProxyGroupDomain name=\"groups\">\n"
35231 " <Group name=\"sources\" />\n"
35232 " <Group name=\"filters\" />\n"
35233 " </ProxyGroupDomain>\n"
35234 " <DataTypeDomain name=\"input_type\">\n"
35235 " <DataType value=\"vtkTable\" />\n"
35236 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
35237 " </DataTypeDomain>\n"
35238 " <Documentation>A previously-calculated model with which to assess a\n"
35239 " separate dataset. This input is optional.</Documentation>\n"
35240 " </InputProperty>\n"
35241 " <IntVectorProperty command=\"SetAttributeMode\"\n"
35242 " default_values=\"0\"\n"
35243 " name=\"AttributeMode\"\n"
35244 " number_of_elements=\"1\">\n"
35245 " <FieldDataDomain enable_field_data=\"1\"\n"
35246 " name=\"enum\">\n"
35247 " <RequiredProperties>\n"
35248 " <Property function=\"Input\"\n"
35249 " name=\"Input\" />\n"
35250 " </RequiredProperties>\n"
35251 " </FieldDataDomain>\n"
35252 " <Documentation>Specify which type of field data the arrays will be\n"
35253 ;
35254
35255 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersStatistics/Resources/statistics_filters.xml
35257 " drawn from.</Documentation>\n"
35258 " </IntVectorProperty>\n"
35259 " <StringVectorProperty clean_command=\"ClearAttributeArrays\"\n"
35260 " command=\"EnableAttributeArray\"\n"
35261 " label=\"Variables of Interest\"\n"
35262 " name=\"SelectArrays\"\n"
35263 " number_of_elements_per_command=\"1\"\n"
35264 " repeat_command=\"1\">\n"
35265 " <ArrayListDomain name=\"array_list\">\n"
35266 " <RequiredProperties>\n"
35267 " <Property function=\"Input\"\n"
35268 " name=\"Input\" />\n"
35269 " <Property function=\"FieldDataSelection\"\n"
35270 " name=\"AttributeMode\" />\n"
35271 " </RequiredProperties>\n"
35272 " </ArrayListDomain>\n"
35273 " <Documentation>Choose arrays whose entries will be used to form\n"
35274 " observations for statistical analysis.</Documentation>\n"
35275 " </StringVectorProperty>\n"
35276 " <IntVectorProperty animateable=\"0\"\n"
35277 " command=\"SetTask\"\n"
35278 " default_values=\"3\"\n"
35279 " name=\"Task\"\n"
35280 " number_of_elements=\"1\">\n"
35281 " <EnumerationDomain name=\"task_list\">\n"
35282 " <Entry text=\"Detailed model of input data\"\n"
35283 " value=\"0\" />\n"
35284 " <Entry text=\"Model a subset of the data\"\n"
35285 " value=\"1\" />\n"
35286 " <Entry text=\"Assess the data with a model\"\n"
35287 " value=\"2\" />\n"
35288 " <Entry text=\"Model and assess the same data\"\n"
35289 " value=\"3\" />\n"
35290 " </EnumerationDomain>\n"
35291 " <Documentation>Specify the task to be performed: modeling and/or\n"
35292 " assessment. &lt;ol&gt; &lt;li&gt; \"Detailed model of input data,\"\n"
35293 " creates a set of output tables containing a calculated statistical\n"
35294 " model of the &lt;b&gt;entire&lt;/b&gt; input dataset;&lt;/li&gt;\n"
35295 " &lt;li&gt; \"Model a subset of the data,\" creates an output table (or\n"
35296 " tables) summarizing a &lt;b&gt;randomly-chosen subset&lt;/b&gt; of the\n"
35297 " input dataset;&lt;/li&gt; &lt;li&gt; \"Assess the data with a model,\"\n"
35298 " adds attributes to the first input dataset using a model provided on\n"
35299 " the second input port; and&lt;/li&gt; &lt;li&gt; \"Model and assess the\n"
35300 " same data,\" is really just operations 2 and 3 above applied to the same\n"
35301 " input dataset. The model is first trained using a fraction of the input\n"
35302 " data and then the entire dataset is assessed using that\n"
35303 " model.&lt;/li&gt; &lt;/ol&gt; When the task includes creating a model\n"
35304 " (i.e., tasks 2, and 4), you may adjust the fraction of the input\n"
35305 " dataset used for training. You should avoid using a large fraction of\n"
35306 " the input data for training as you will then not be able to detect\n"
35307 " overfitting. The &lt;i&gt;Training fraction&lt;/i&gt; setting will be\n"
35308 " ignored for tasks 1 and 3.</Documentation>\n"
35309 " </IntVectorProperty>\n"
35310 " <DoubleVectorProperty animateable=\"1\"\n"
35311 " command=\"SetTrainingFraction\"\n"
35312 " default_values=\"0.1\"\n"
35313 " name=\"TrainingFraction\"\n"
35314 " number_of_elements=\"1\">\n"
35315 " <DoubleRangeDomain max=\"1\"\n"
35316 " min=\"0\"\n"
35317 " name=\"training_range\" />\n"
35318 " <Documentation>Specify the fraction of values from the input dataset to\n"
35319 " be used for model fitting. The exact set of values is chosen at random\n"
35320 " from the dataset.</Documentation>\n"
35321 " </DoubleVectorProperty>\n"
35322 " <OutputPort index=\"0\"\n"
35323 " name=\"Statistical Model\" />\n"
35324 " <OutputPort index=\"1\"\n"
35325 " name=\"Assessed Data\" />\n"
35326 " <Hints>\n"
35327 " <Visibility replace_input=\"1\" />\n"
35328 " <!-- View can be used to specify the preferred view for the proxy -->\n"
35329 " <View type=\"SpreadSheetView\" port=\"0\" />\n"
35330 " <View type=\"None\" port=\"1\" />\n"
35331 " </Hints>\n"
35332 " </SourceProxy>\n"
35333 " <!-- MulticorrelativeStatistics -->\n"
35334 " <!-- ==================================================================== -->\n"
35335 " <SourceProxy class=\"vtkPSciVizPCAStats\"\n"
35336 " label=\"Principal Component Analysis\"\n"
35337 " name=\"PCAStatistics\">\n"
35338 " <Documentation long_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\"\n"
35339 " short_help=\"Compute a statistical model of a dataset and/or assess the dataset with a statistical model.\">\n"
35340 " This filter either computes a statistical model of a dataset or takes\n"
35341 " such a model as its second input. Then, the model (however it is\n"
35342 " obtained) may optionally be used to assess the input dataset. &lt;p&gt;\n"
35343 " This filter performs additional analysis above and beyond the\n"
35344 " multicorrelative filter. It computes the eigenvalues and eigenvectors of\n"
35345 " the covariance matrix from the multicorrelative filter. Data is then\n"
35346 " assessed by projecting the original tuples into a possibly\n"
35347 " lower-dimensional space. &lt;p&gt; Since the PCA filter uses the\n"
35348 " multicorrelative filter's analysis, it shares the same raw covariance\n"
35349 " table specified in the multicorrelative documentation. The second table\n"
35350 " in the multiblock dataset comprising the model output is an expanded\n"
35351 " version of the multicorrelative version. &lt;p&gt; As with the\n"
35352 " multicorrelative filter, the second model table contains the mean values,\n"
35353 " the upper-triangular portion of the symmetric covariance matrix, and the\n"
35354 " non-zero lower-triangular portion of the Cholesky decomposition of the\n"
35355 " covariance matrix. Below these entries are the eigenvalues of the\n"
35356 " covariance matrix (in the column labeled \"Mean\") and the eigenvectors (as\n"
35357 " row vectors) in an additional NxN matrix.</Documentation>\n"
35358 " <InputProperty command=\"SetInputConnection\"\n"
35359 " name=\"Input\"\n"
35360 " port_index=\"0\">\n"
35361 " <ProxyGroupDomain name=\"groups\">\n"
35362 " <Group name=\"sources\" />\n"
35363 " <Group name=\"filters\" />\n"
35364 " </ProxyGroupDomain>\n"
35365 " <DataTypeDomain name=\"input_type\">\n"
35366 " <DataType value=\"vtkImageData\" />\n"
35367 " <DataType value=\"vtkRectilinearGrid\" />\n"
35368 " <DataType value=\"vtkStructuredGrid\" />\n"
35369 " <DataType value=\"vtkPolyData\" />\n"
35370 " <DataType value=\"vtkUnstructuredGrid\" />\n"
35371 " <DataType value=\"vtkTable\" />\n"
35372 " <DataType value=\"vtkGraph\" />\n"
35373 " </DataTypeDomain>\n"
35374 " <InputArrayDomain name=\"input_array\" />\n"
35375 " <Documentation>The input to the filter. Arrays from this dataset will\n"
35376 " be used for computing statistics and/or assessed by a statistical\n"
35377 " model.</Documentation>\n"
35378 " </InputProperty>\n"
35379 " <InputProperty command=\"SetInputConnection\"\n"
35380 " name=\"ModelInput\"\n"
35381 " null_on_empty=\"1\"\n"
35382 " port_index=\"1\">\n"
35383 " <Hints>\n"
35384 " <Optional />\n"
35385 " <!-- No input selection dialog at instantiation -->\n"
35386 " </Hints>\n"
35387 " <ProxyGroupDomain name=\"groups\">\n"
35388 " <Group name=\"sources\" />\n"
35389 " <Group name=\"filters\" />\n"
35390 " </ProxyGroupDomain>\n"
35391 " <DataTypeDomain name=\"input_type\">\n"
35392 " <DataType value=\"vtkTable\" />\n"
35393 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
35394 " </DataTypeDomain>\n"
35395 " <Documentation>A previously-calculated model with which to assess a\n"
35396 " separate dataset. This input is optional.</Documentation>\n"
35397 " </InputProperty>\n"
35398 " <IntVectorProperty command=\"SetAttributeMode\"\n"
35399 " default_values=\"0\"\n"
35400 " name=\"AttributeMode\"\n"
35401 " number_of_elements=\"1\">\n"
35402 " <FieldDataDomain enable_field_data=\"1\"\n"
35403 " name=\"enum\">\n"
35404 " <RequiredProperties>\n"
35405 " <Property function=\"Input\"\n"
35406 " name=\"Input\" />\n"
35407 " </RequiredProperties>\n"
35408 " </FieldDataDomain>\n"
35409 " <Documentation>Specify which type of field data the arrays will be\n"
35410 " drawn from.</Documentation>\n"
35411 " </IntVectorProperty>\n"
35412 " <StringVectorProperty clean_command=\"ClearAttributeArrays\"\n"
35413 " command=\"EnableAttributeArray\"\n"
35414 " label=\"Variables of Interest\"\n"
35415 " name=\"SelectArrays\"\n"
35416 " number_of_elements_per_command=\"1\"\n"
35417 " repeat_command=\"1\">\n"
35418 " <ArrayListDomain name=\"array_list\">\n"
35419 " <RequiredProperties>\n"
35420 " <Property function=\"Input\"\n"
35421 " name=\"Input\" />\n"
35422 " <Property function=\"FieldDataSelection\"\n"
35423 " name=\"AttributeMode\" />\n"
35424 " </RequiredProperties>\n"
35425 " </ArrayListDomain>\n"
35426 " <Documentation>Choose arrays whose entries will be used to form\n"
35427 " observations for statistical analysis.</Documentation>\n"
35428 " </StringVectorProperty>\n"
35429 " <IntVectorProperty animateable=\"0\"\n"
35430 " command=\"SetTask\"\n"
35431 " default_values=\"3\"\n"
35432 " name=\"Task\"\n"
35433 " number_of_elements=\"1\">\n"
35434 " <EnumerationDomain name=\"task_list\">\n"
35435 " <Entry text=\"Detailed model of input data\"\n"
35436 " value=\"0\" />\n"
35437 " <Entry text=\"Model a subset of the data\"\n"
35438 " value=\"1\" />\n"
35439 " <Entry text=\"Assess the data with a model\"\n"
35440 " value=\"2\" />\n"
35441 " <Entry text=\"Model and assess the same data\"\n"
35442 " value=\"3\" />\n"
35443 " </EnumerationDomain>\n"
35444 " <Documentation>Specify the task to be performed: modeling and/or\n"
35445 " assessment. &lt;ol&gt; &lt;li&gt; \"Detailed model of input data,\"\n"
35446 " creates a set of output tables containing a calculated statistical\n"
35447 " model of the &lt;b&gt;entire&lt;/b&gt; input dataset;&lt;/li&gt;\n"
35448 " &lt;li&gt; \"Model a subset of the data,\" creates an output table (or\n"
35449 " tables) summarizing a &lt;b&gt;randomly-chosen subset&lt;/b&gt; of the\n"
35450 " input dataset;&lt;/li&gt; &lt;li&gt; \"Assess the data with a model,\"\n"
35451 " adds attributes to the first input dataset using a model provided on\n"
35452 " the second input port; and&lt;/li&gt; &lt;li&gt; \"Model and assess the\n"
35453 " same data,\" is really just operations 2 and 3 above applied to the same\n"
35454 " input dataset. The model is first trained using a fraction of the input\n"
35455 " data and then the entire dataset is assessed using that\n"
35456 " model.&lt;/li&gt; &lt;/ol&gt; When the task includes creating a model\n"
35457 " (i.e., tasks 2, and 4), you may adjust the fraction of the input\n"
35458 " dataset used for training. You should avoid using a large fraction of\n"
35459 " the input data for training as you will then not be able to detect\n"
35460 " overfitting. The &lt;i&gt;Training fraction&lt;/i&gt; setting will be\n"
35461 " ignored for tasks 1 and 3.</Documentation>\n"
35462 " </IntVectorProperty>\n"
35463 " <DoubleVectorProperty animateable=\"1\"\n"
35464 " command=\"SetTrainingFraction\"\n"
35465 " default_values=\"0.1\"\n"
35466 " name=\"TrainingFraction\"\n"
35467 " number_of_elements=\"1\">\n"
35468 " <DoubleRangeDomain max=\"1\"\n"
35469 " min=\"0\"\n"
35470 " name=\"training_range\" />\n"
35471 " <Documentation>Specify the fraction of values from the input dataset to\n"
35472 " be used for model fitting. The exact set of values is chosen at random\n"
35473 " from the dataset.</Documentation>\n"
35474 " </DoubleVectorProperty>\n"
35475 " <IntVectorProperty animateable=\"1\"\n"
35476 " command=\"SetNormalizationScheme\"\n"
35477 " default_values=\"2\"\n"
35478 " label=\"Normalization Scheme\"\n"
35479 " name=\"NormalizationScheme\"\n"
35480 " number_of_elements=\"1\">\n"
35481 " <EnumerationDomain name=\"norm_scheme\">\n"
35482 " <Entry text=\"No normalization\"\n"
35483 " value=\"0\" />\n"
35484 " <Entry text=\"Normalize using covariances\"\n"
35485 " value=\"3\" />\n"
35486 " </EnumerationDomain>\n"
35487 " <Documentation>Before the eigenvector decomposition of the covariance\n"
35488 " matrix takes place, you may normalize each (i,j) entry by sqrt(\n"
35489 " cov(i,i) * cov(j,j) ). This implies that the variance of each variable\n"
35490 " of interest should be of equal importance.</Documentation>\n"
35491 " </IntVectorProperty>\n"
35492 " <IntVectorProperty animateable=\"1\"\n"
35493 " command=\"SetBasisScheme\"\n"
35494 " default_values=\"0\"\n"
35495 " label=\"Basis Scheme\"\n"
35496 " name=\"BasisScheme\"\n"
35497 " number_of_elements=\"1\">\n"
35498 " <EnumerationDomain name=\"basis_scheme\">\n"
35499 " <Entry text=\"Full basis\"\n"
35500 " value=\"0\" />\n"
35501 " <Entry text=\"Fixed-size basis\"\n"
35502 " value=\"1\" />\n"
35503 " <Entry text=\"Fixed-energy basis\"\n"
35504 " value=\"2\" />\n"
35505 " </EnumerationDomain>\n"
35506 " <Documentation>When reporting assessments, should the full eigenvector\n"
35507 " decomposition be used to project the original vector into the new space\n"
35508 " (Full basis), or should a fixed subset of the decomposition be used\n"
35509 " (Fixed-size basis), or should the projection be clipped to preserve at\n"
35510 " least some fixed \"energy\" (Fixed-energy basis)?&lt;p&gt; As an example,\n"
35511 " suppose the variables of interest were {A,B,C,D,E} and that the\n"
35512 " eigenvalues of the covariance matrix for these were {5,2,1.5,1,.5}. If\n"
35513 " the \"Full basis\" scheme is used, then all 5 components of the\n"
35514 " eigenvectors will be used to project each {A,B,C,D,E}-tuple in the\n"
35515 " original data into a new 5-components space.&lt;p&gt; If the\n"
35516 " \"Fixed-size\" scheme is used and the \"Basis Size\" property is set to 4,\n"
35517 " then only the first 4 eigenvector components will be used to project\n"
35518 " each {A,B,C,D,E}-tuple into the new space and that space will be of\n"
35519 " dimension 4, not 5.&lt;p&gt; If the \"Fixed-energy basis\" scheme is used\n"
35520 " and the \"Basis Energy\" property is set to 0.8, then only the first 3\n"
35521 " eigenvector components will be used to project each {A,B,C,D,E}-tuple\n"
35522 " into the new space, which will be of dimension 3. The number 3 is\n"
35523 " chosen because 3 is the lowest N for which the sum of the first N\n"
35524 " eigenvalues divided by the sum of all eigenvalues is larger than the\n"
35525 " specified \"Basis Energy\" (i.e., (5+2+1.5)/10 = 0.85 &gt;\n"
35526 " 0.8).</Documentation>\n"
35527 " </IntVectorProperty>\n"
35528 " <IntVectorProperty animateable=\"1\"\n"
35529 " command=\"SetFixedBasisSize\"\n"
35530 " default_values=\"2\"\n"
35531 " label=\"Basis Size\"\n"
35532 " name=\"BasisSize\"\n"
35533 " number_of_elements=\"1\">\n"
35534 ;
35535
35536 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersStatistics/Resources/statistics_filters.xml
35538 " <IntRangeDomain min=\"1\"\n"
35539 " name=\"basis_size_range\" />\n"
35540 " <Documentation>The maximum number of eigenvector components to use when\n"
35541 " projecting into the new space.</Documentation>\n"
35542 " </IntVectorProperty>\n"
35543 " <DoubleVectorProperty animateable=\"1\"\n"
35544 " command=\"SetFixedBasisEnergy\"\n"
35545 " default_values=\"0.1\"\n"
35546 " label=\"Basis Energy\"\n"
35547 " name=\"BasisEnergy\"\n"
35548 " number_of_elements=\"1\">\n"
35549 " <DoubleRangeDomain max=\"1\"\n"
35550 " min=\"0\"\n"
35551 " name=\"basis_energy_range\" />\n"
35552 " <Documentation>The minimum energy to use when determining the\n"
35553 " dimensionality of the new space into which the assessment will project\n"
35554 " tuples.</Documentation>\n"
35555 " </DoubleVectorProperty>\n"
35556 " <IntVectorProperty command=\"SetRobustPCA\"\n"
35557 " default_values=\"0\"\n"
35558 " name=\"RobustPCA\"\n"
35559 " number_of_elements=\"1\">\n"
35560 " <BooleanDomain name=\"bool\" />\n"
35561 " <Documentation>Compute robust PCA with medians instead of means.</Documentation>\n"
35562 " </IntVectorProperty>\n"
35563 " <OutputPort index=\"0\"\n"
35564 " name=\"Statistical Model\" />\n"
35565 " <OutputPort index=\"1\"\n"
35566 " name=\"Assessed Data\" />\n"
35567 " <Hints>\n"
35568 " <Visibility replace_input=\"1\" />\n"
35569 " <!-- View can be used to specify the preferred view for the proxy -->\n"
35570 " <View type=\"SpreadSheetView\" port=\"0\" />\n"
35571 " <View type=\"None\" port=\"1\" />\n"
35572 " </Hints>\n"
35573 " </SourceProxy>\n"
35574 " <!-- PCAStatistics -->\n"
35575 " </ProxyGroup>\n"
35576 "</ServerManagerConfiguration>\n"
35577 "\n";
35578 // Get single string
35580 {
35581
35582  const size_t len0 = strlen(paraview_server_managerstatistics_filtersInterface0);
35583  const size_t len1 = strlen(paraview_server_managerstatistics_filtersInterface1);
35584  const size_t len2 = strlen(paraview_server_managerstatistics_filtersInterface2);
35585  const size_t len3 = strlen(paraview_server_managerstatistics_filtersInterface3);
35586  size_t len = ( 0
35587  + len0
35588  + len1
35589  + len2
35590  + len3 );
35591  char* res = new char[ len + 1];
35592  size_t offset = 0;
35597  assert(offset == len);
35598  res[offset] = 0;
35599  return res;
35600 }
35601
35602
35603 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersPython/Resources/python_filters.xml
35605 "<ServerManagerConfiguration>\n"
35606 " <ProxyGroup name=\"filters\">\n"
35607 " <SourceProxy class=\"vtkPythonCalculator\"\n"
35608 " label=\"Python Calculator\"\n"
35609 " name=\"PythonCalculator\">\n"
35610 " <Documentation long_help=\"This filter evaluates a Python expression\"\n"
35611 " short_help=\"Evaluates a Python expression\">This filter\n"
35612 " uses Python to calculate an expression. It depends heavily\n"
35613 " on the numpy and paraview.vtk modules. To use the parallel\n"
35614 " functions, mpi4py is also necessary. The expression is\n"
35615 " evaluated and the resulting scalar value or numpy array is\n"
35616 " added to the output as an array. See numpy integration and\n"
35617 " python calculator documentation for the list of available\n"
35618 " functions. This filter tries to make it easy for the user\n"
35619 " to write expressions by defining certain variables. The\n"
35620 " filter tries to assign each array to a variable of the\n"
35621 " same name. If the name of the array is not a valid Python\n"
35622 " variable, it may be accessed through a variable with a\n"
35623 " sanitized version of that array name consisting of only\n"
35624 " '_' and the alphanumeric characters in the name joined\n"
35625 " together with no spaces. Point coordinates from datasets\n"
35626 " that explicitly define them can be accessed using the variable\n"
35627 " named 'points'.</Documentation>\n"
35628 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
35629 " command=\"AddInputConnection\"\n"
35630 " multiple_input=\"1\"\n"
35631 " name=\"Input\">\n"
35632 " <ProxyGroupDomain name=\"groups\">\n"
35633 " <Group name=\"sources\" />\n"
35634 " <Group name=\"filters\" />\n"
35635 " </ProxyGroupDomain>\n"
35636 " <DataTypeDomain name=\"input_type\">\n"
35637 " <DataType value=\"vtkDataSet\" />\n"
35638 " <DataType value=\"vtkHyperTreeGrid\" />\n"
35639 " <DataType value=\"vtkTable\" />\n"
35640 " </DataTypeDomain>\n"
35641 " <Documentation>Set the input of the filter.</Documentation>\n"
35642 " </InputProperty>\n"
35643 "\n"
35644 " <IntVectorProperty animateable=\"0\"\n"
35645 " command=\"SetUseMultilineExpression\"\n"
35646 " default_values=\"0\"\n"
35647 " name=\"UseMultilineExpression\"\n"
35648 " number_of_elements=\"1\">\n"
35649 " <BooleanDomain name=\"bool\" />\n"
35650 " <Documentation>If this property is set to true, the expression is a multiline script that\n"
35651 " returns the output array.</Documentation>\n"
35652 " </IntVectorProperty>\n"
35653 " <StringVectorProperty command=\"SetExpression\"\n"
35654 " name=\"Expression\"\n"
35655 " number_of_elements=\"1\">\n"
35656 " <Hints>\n"
35657 " <Widget type=\"one_liner_wrapped\" syntax=\"python\" autocomplete=\"python_calc\"/>\n"
35658 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
35659 " mode=\"visibility\"\n"
35660 " property=\"UseMultilineExpression\"\n"
35661 " value=\"0\" />\n"
35662 " </Hints>\n"
35663 " <Documentation>The Python expression evaluated during\n"
35664 " execution. Set of potentially available variables [inputs, points, t_value,\n"
35665 " t_index, FieldData, PointData, CellData] (i.e.: \"Momentum: (%f, %f, %f)\" %\n"
35666 " (XMOM[t_index,0], YMOM[t_index,0], ZMOM[t_index,0]) ). Additional variables,\n"
35667 " using the fmt library's syntax, are {timevalue}, and {timeindex}. These variables\n"
35668 " are always available, and their default values are 0, and 0 respectively.\n"
35669 " </Documentation>\n"
35670 " </StringVectorProperty>\n"
35671 " <StringVectorProperty command=\"SetMultilineExpression\"\n"
35672 " name=\"MultilineExpression\"\n"
35673 " number_of_elements=\"1\"\n"
35674 " default_values=\"outputArray=numpy.ones(1)&#xA;return outputArray\">\n"
35675 " <Hints>\n"
35676 " <Widget type=\"multi_line\" syntax=\"python\" autocomplete=\"python_calc\"/>\n"
35677 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
35678 " mode=\"visibility\"\n"
35679 " property=\"UseMultilineExpression\"\n"
35680 " value=\"1\" />\n"
35681 " </Hints>\n"
35682 " <Documentation>The multiline Python expression executed, that should return the output array\n"
35683 " using the Python \"return\" keyword. The variables that can be used here are the exact same as the ones available in the\n"
35684 " single-line expression editor.\n"
35685 " </Documentation>\n"
35686 " </StringVectorProperty>\n"
35687 "\n"
35688 " <IntVectorProperty command=\"SetArrayAssociation\"\n"
35689 " default_values=\"0\"\n"
35690 " name=\"ArrayAssociation\"\n"
35691 " number_of_elements=\"1\">\n"
35692 " <FieldDataDomain name=\"enum\" enable_field_data=\"1\">\n"
35693 " <RequiredProperties>\n"
35694 " <Property function=\"Input\"\n"
35695 " name=\"Input\" />\n"
35696 " </RequiredProperties>\n"
35697 " </FieldDataDomain>\n"
35698 " <Documentation>\n"
35699 " This property controls which input arrays are defined as variables.\n"
35700 " This is also the default for output association.\n"
35701 " Depending on the operation, output association may vary.\n"
35702 " </Documentation>\n"
35703 " </IntVectorProperty>\n"
35704 " <StringVectorProperty command=\"SetArrayName\"\n"
35705 " default_values=\"result\"\n"
35706 " name=\"ArrayName\"\n"
35707 " number_of_elements=\"1\">\n"
35708 " <Documentation>The name of the output array.</Documentation>\n"
35709 " </StringVectorProperty>\n"
35710 " <IntVectorProperty animateable=\"0\"\n"
35711 " command=\"SetCopyArrays\"\n"
35712 " default_values=\"1\"\n"
35713 " name=\"CopyArrays\"\n"
35714 " number_of_elements=\"1\">\n"
35715 " <BooleanDomain name=\"bool\" />\n"
35716 " <Documentation>If this property is set to true, all the cell and point\n"
35717 " arrays from first input are copied to the output.</Documentation>\n"
35718 " </IntVectorProperty>\n"
35719 " <IntVectorProperty command=\"SetResultArrayType\"\n"
35720 " default_values=\"11\"\n"
35721 " label=\"Result Array Type\"\n"
35722 " name=\"ResultArrayType\"\n"
35723 " number_of_elements=\"1\"\n"
35724 " panel_visibility=\"advanced\">\n"
35725 " <EnumerationDomain name=\"enum\">\n"
35726 " <Entry text=\"Same as Input\"\n"
35727 " value=\"-1\" />\n"
35728 " <Entry text=\"Char\"\n"
35729 " value=\"2\" />\n"
35730 " <Entry text=\"Signed Char\"\n"
35731 " value=\"15\" />\n"
35732 " <Entry text=\"Unsigned Char\"\n"
35733 " value=\"3\" />\n"
35734 " <Entry text=\"Short\"\n"
35735 " value=\"4\" />\n"
35736 " <Entry text=\"Unsigned Short\"\n"
35737 " value=\"5\" />\n"
35738 " <Entry text=\"Int\"\n"
35739 " value=\"6\" />\n"
35740 " <Entry text=\"Unsigned Int\"\n"
35741 " value=\"7\" />\n"
35742 " <Entry text=\"Long\"\n"
35743 " value=\"8\" />\n"
35744 " <Entry text=\"Unsigned Long\"\n"
35745 " value=\"9\" />\n"
35746 " <Entry text=\"Float\"\n"
35747 " value=\"10\" />\n"
35748 " <Entry text=\"Double\"\n"
35749 " value=\"11\" />\n"
35750 " <Entry text=\"Id Type\"\n"
35751 " value=\"12\" />\n"
35752 " </EnumerationDomain>\n"
35753 " <Documentation>This property determines what array type to output.\n"
35754 " The default is a vtkDoubleArray.</Documentation>\n"
35755 " </IntVectorProperty>\n"
35756 " <!-- End PythonCalculator -->\n"
35757 " </SourceProxy>\n"
35758 "\n"
35759 " <SourceProxy class=\"vtkAnnotateAttributeDataFilter\"\n"
35760 " label=\"Annotate Attribute Data\"\n"
35761 " name=\"AnnotateAttributeData\">\n"
35762 " <Documentation short_help=\"Adds a text annotation to a Render View\">\n"
35763 "This filter can be used to add a text annotation to a Render View (or\n"
35764 "similar) using a tuple from any attribute array (point/cell/field/row\n"
35765 "etc.) from a specific rank (when running in parallel). Use **ArrayName**\n"
35766 "property to select the array association and array name. Use\n"
35767 "**ElementId* property to set the element number to extract the value to\n"
35768 "label with. When running on multiple ranks, use **ProcessId** property\n"
35769 "to select the rank of interest. The **Prefix** property can be used to\n"
35770 "specify a string that will be used as the prefix to the generated\n"
35771 "annotation text.\n"
35772 " </Documentation>\n"
35773 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
35774 " command=\"AddInputConnection\"\n"
35775 " name=\"Input\">\n"
35776 " <ProxyGroupDomain name=\"groups\" >\n"
35777 " <Group name=\"sources\" />\n"
35778 " <Group name=\"filters\" />\n"
35779 " </ProxyGroupDomain>\n"
35780 " <DataTypeDomain name=\"input_type\" composite_data_supported=\"0\">\n"
35781 " <DataType value=\"vtkDataSet\" />\n"
35782 " <DataType value=\"vtkTable\" />\n"
35783 " </DataTypeDomain>\n"
35784 " <InputArrayDomain attribute_type=\"any\"\n"
35785 " name=\"input_array\" />\n"
35786 " <Documentation>\n"
35787 " Set the input of the filter. To avoid the complications/confusion when identifying\n"
35788 " elements in a composite dataset, this filter doesn't support composite datasets\n"
35789 " currently.\n"
35790 " </Documentation>\n"
35791 " </InputProperty>\n"
35792 " <StringVectorProperty animateable=\"0\"\n"
35793 " command=\"SetInputArrayToProcess\"\n"
35794 " element_types=\"0 0 0 0 2\"\n"
35795 " name=\"SelectInputArray\"\n"
35796 " number_of_elements=\"5\">\n"
35797 " <ArrayListDomain attribute_type=\"Scalars\"\n"
35798 " name=\"array_list\">\n"
35799 " <RequiredProperties>\n"
35800 " <Property function=\"Input\"\n"
35801 " name=\"Input\" />\n"
35802 " </RequiredProperties>\n"
35803 " </ArrayListDomain>\n"
35804 " <Documentation>This property indicates the name of the array from which\n"
35805 " to obtain the annotation value.</Documentation>\n"
35806 " </StringVectorProperty>\n"
35807 " <IntVectorProperty name=\"ElementId\"\n"
35808 " command=\"SetElementId\"\n"
35809 " number_of_elements=\"1\"\n"
35810 " default_values=\"0\">\n"
35811 " <!-- this should really be an IdTypeVectorProperty, but the UI doesn't\n"
35812 " support those yet -->\n"
35813 " <IntRangeDomain name=\"range\"/>\n"
35814 " <Documentation>\n"
35815 " Set the element index to annotate with.\n"
35816 " </Documentation>\n"
35817 " </IntVectorProperty>\n"
35818 " <IntVectorProperty name=\"ProcessId\"\n"
35819 " command=\"SetProcessId\"\n"
35820 " number_of_elements=\"1\"\n"
35821 " default_values=\"0\">\n"
35822 " <IntRangeDomain name=\"range\" min=\"0\" />\n"
35823 " <Documentation>\n"
35824 " Set the process rank to extract element from.\n"
35825 " </Documentation>\n"
35826 " </IntVectorProperty>\n"
35827 " <StringVectorProperty command=\"SetPrefix\"\n"
35828 " default_values=\"Value is: \"\n"
35829 " name=\"Prefix\"\n"
35830 " number_of_elements=\"1\">\n"
35831 " <Documentation>Text that is used as a prefix to the field value</Documentation>\n"
35832 " </StringVectorProperty>\n"
35833 " <Hints>\n"
35834 " <Visibility replace_input=\"0\" />\n"
35835 " <OutputPort index=\"0\" name=\"Output-0\" type=\"text\" />\n"
35836 " </Hints>\n"
35837 " </SourceProxy>\n"
35838 " <SourceProxy class=\"vtkPythonAnnotationFilter\"\n"
35839 " label=\"Python Annotation\"\n"
35840 " name=\"PythonAnnotation\">\n"
35841 " <Documentation long_help=\"This filter evaluates a Python expression for a text annotation\"\n"
35842 " short_help=\"Evaluates a Python expression for a text annotation\">\n"
35843 " This filter uses Python to calculate an expression and display\n"
35844 " the result as an annotation in the render view. It\n"
35845 " depends heavily on the numpy and paraview.vtk modules. To\n"
35846 " use the parallel functions, mpi4py is also necessary. The\n"
35847 " expression is evaluated and the resulting scalar value or\n"
35848 " numpy array is added to the output as an array. See numpy\n"
35849 " integration, python annotation and python calculator\n"
35850 " documentation for the list of available functions.\n"
35851 " This filter tries to make it easy for the user\n"
35852 " to write expressions by defining certain variables. The\n"
35853 " filter tries to assign each array to a variable of the\n"
35854 " same name. If the name of the array is not a valid Python\n"
35855 " variable, it may be accessed through a variable with a\n"
35856 " sanitized version of that array name consisting of only\n"
35857 " '_' and the alphanumeric characters in the name joined\n"
35858 " together with no spaces. Point coordinates from datasets\n"
35859 " that explicitly define them can be accessed using the variable\n"
35860 " named 'points'.</Documentation>\n"
35861 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
35862 " command=\"AddInputConnection\"\n"
35863 " multiple_input=\"0\"\n"
35864 " name=\"Input\">\n"
35865 " <ProxyGroupDomain name=\"groups\">\n"
35866 " <Group name=\"sources\" />\n"
35867 " <Group name=\"filters\" />\n"
35868 " </ProxyGroupDomain>\n"
35869 " <DataTypeDomain name=\"input_type\">\n"
35870 " <DataType value=\"vtkDataObject\" />\n"
35871 " </DataTypeDomain>\n"
35872 " <Documentation>Set the input of the filter.</Documentation>\n"
35873 " </InputProperty>\n"
35874 " <IntVectorProperty command=\"SetArrayAssociation\"\n"
35875 " default_values=\"2\"\n"
35876 " name=\"ArrayAssociation\"\n"
35877 " number_of_elements=\"1\">\n"
35878 " <Documentation>Select the attribute to use to populate array names.</Documentation>\n"
35879 " <FieldDataDomain enable_field_data=\"1\"\n"
35880 " name=\"enum\">\n"
35881 " <RequiredProperties>\n"
35882 " <Property function=\"Input\"\n"
35883 " name=\"Input\" />\n"
35884 " </RequiredProperties>\n"
35885 " </FieldDataDomain>\n"
35886 " </IntVectorProperty>\n"
35887 " <StringVectorProperty command=\"SetExpression\"\n"
35888 " name=\"Expression\"\n"
35889 " number_of_elements=\"1\">\n"
35890 " <Hints>\n"
35891 " <Widget type=\"one_liner_wrapped\" syntax=\"python\" />\n"
35892 " </Hints>\n"
35893 " <Documentation>The Python expression evaluated during execution.\n"
35894 " FieldData arrays are directly available through their name. Set of\n"
35895 " potentially available variables [inputs, points, t_value, t_steps,\n"
35896 " t_range, t_index, FieldData, PointData, CellData]\n"
35897 " (i.e.: \"Momentum: (%f, %f, %f)\" % (XMOM[t_index,0], YMOM[t_index,0], ZMOM[t_index,0]) )\n"
35898 ;
35899
35900 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersPython/Resources/python_filters.xml
35902 " Additional variables, using the fmt library's syntax, are {timevalue}, {timerange},\n"
35903 " {timesteps} and {timeindex}. These variables are always available, and their default\n"
35904 " values are 0, [], [] and 0 respectively.\n"
35905 " </Documentation>\n"
35906 " </StringVectorProperty>\n"
35907 " <StringVectorProperty command=\"GetComputedAnnotationValue\"\n"
35908 " information_only=\"1\"\n"
35909 " name=\"AnnotationValue\">\n"
35910 " <Documentation>Text that is used as annotation</Documentation>\n"
35911 " </StringVectorProperty>\n"
35912 " <Hints>\n"
35913 " <Visibility replace_input=\"0\" />\n"
35914 " <OutputPort index=\"0\"\n"
35915 " name=\"Output-0\"\n"
35916 " type=\"text\" />\n"
35917 " </Hints>\n"
35918 " <!-- End PythonAnnotation -->\n"
35919 " </SourceProxy>\n"
35920 " <SourceProxy class=\"vtkPythonProgrammableFilter\"\n"
35921 " label=\"Programmable Filter\"\n"
35922 " name=\"ProgrammableFilter\">\n"
35923 " <Documentation long_help=\"Executes a user supplied python script on its input dataset to produce an output dataset.\"\n"
35924 " short_help=\"Executes a python script to produce data.\">\n"
35925 " This filter will execute a python script to produce an\n"
35926 " output dataset. The filter keeps a copy of the python\n"
35927 " script in Script and creates a python\n"
35928 " Interpreter to run the script upon the first\n"
35929 " execution. To execute external python scripts on the ParaView server, use:\n"
35930 " execfile('full_path/script_name.py'). Documentation is found in the Programmable Filter\n"
35931 " and numpy integration section of the paraview documentation.\n"
35932 " </Documentation>\n"
35933 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
35934 " command=\"AddInputConnection\"\n"
35935 " multiple_input=\"1\"\n"
35936 " name=\"Input\">\n"
35937 " <ProxyGroupDomain name=\"groups\">\n"
35938 " <Group name=\"sources\" />\n"
35939 " <Group name=\"filters\" />\n"
35940 " </ProxyGroupDomain>\n"
35941 " <DataTypeDomain name=\"input_type\">\n"
35942 " <DataType value=\"vtkDataObject\" />\n"
35943 " <DataType value=\"vtkHyperTreeGrid\" />\n"
35944 " </DataTypeDomain>\n"
35945 " <Documentation>This property specifies the input(s) to the programmable\n"
35946 " filter.</Documentation>\n"
35947 " </InputProperty>\n"
35948 " <IntVectorProperty command=\"SetOutputDataSetType\"\n"
35949 " default_values=\"8\"\n"
35950 " name=\"OutputDataSetType\"\n"
35951 " number_of_elements=\"1\"\n"
35952 " panel_visibility=\"default\">\n"
35953 " <EnumerationDomain name=\"enum\">\n"
35954 " <!-- Values come from vtkType.h-->\n"
35955 " <Entry text=\"Same as Input\"\n"
35956 " value=\"8\" />\n"
35957 " <!-- text=\"vtkDataSet\" -->\n"
35958 " <Entry text=\"vtkPolyData\"\n"
35959 " value=\"0\" />\n"
35960 " <!-- <Entry value=\"1\" text=\"vtkStructuredPoints\"/> -->\n"
35961 " <Entry text=\"vtkStructuredGrid\"\n"
35962 " value=\"2\" />\n"
35963 " <Entry text=\"vtkRectilinearGrid\"\n"
35964 " value=\"3\" />\n"
35965 " <Entry text=\"vtkUnstructuredGrid\"\n"
35966 " value=\"4\" />\n"
35967 " <!-- <Entry value=\"5\" text=\"vtkPiecewiseFunction\"/> -->\n"
35968 " <Entry text=\"vtkImageData\"\n"
35969 " value=\"6\" />\n"
35970 " <!-- <Entry value=\"7\" text=\"vtkDataObject\"/> -->\n"
35971 " <!-- <Entry value=\"9\" text=\"vtkPointSet\"/> -->\n"
35972 " <Entry text=\"vtkUniformGrid\"\n"
35973 " value=\"10\" />\n"
35974 " <!-- <Entry value=\"11\" text=\"vtkCompositeDataSet\"/> -->\n"
35975 " <Entry text=\"vtkMultiblockDataSet\"\n"
35976 " value=\"13\" />\n"
35977 " <Entry text=\"vtkHierarchicalBoxDataSet\"\n"
35978 " value=\"15\" />\n"
35979 " <!-- <Entry value=\"16\" text=\"vtkGenericDataSet\"/> -->\n"
35980 " <!-- <Entry value=\"17\" text=\"vtkHyperOctree\"/> -->\n"
35981 " <Entry text=\"vtkHyperTreeGrid\"\n"
35982 " value=\"32\" />\n"
35983 " <!-- <Entry value=\"18\" text=\"vtkTemporalDataSet\"/> -->\n"
35984 " <Entry text=\"vtkTable\"\n"
35985 " value=\"19\" />\n"
35986 " <!-- <Entry value=\"20\" text=\"vtkGraph\"/> -->\n"
35987 " <!-- <Entry value=\"21\" text=\"vtkTree\"/> -->\n"
35988 " <Entry text=\"vtkMolecule\"\n"
35989 " value=\"33\" />\n"
35990 " <Entry text=\"vtkPartitionedDataSet\" value=\"37\" />\n"
35991 " <Entry text=\"vtkPartitionedDataSetCollection\" value=\"38\" />\n"
35992 " </EnumerationDomain>\n"
35993 " <Documentation>The value of this property determines the dataset type\n"
35994 " for the output of the programmable filter.</Documentation>\n"
35995 " </IntVectorProperty>\n"
35996 " <StringVectorProperty command=\"SetScript\"\n"
35997 " name=\"Script\"\n"
35998 " number_of_elements=\"1\"\n"
35999 " panel_visibility=\"default\">\n"
36000 " <Hints>\n"
36001 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36002 " </Hints>\n"
36003 " <Documentation>This property contains the text of a python program that\n"
36004 " the programmable filter runs. To execute external python scripts on the ParaView server, use:\n"
36005 " execfile('full_path/script_name.py'). Documentation is found in the Programmable Filter\n"
36006 " chapter of the ParaView Guide.</Documentation>\n"
36007 " </StringVectorProperty>\n"
36008 " <StringVectorProperty command=\"SetInformationScript\"\n"
36009 " label=\"RequestInformation Script\"\n"
36010 " name=\"InformationScript\"\n"
36011 " number_of_elements=\"1\"\n"
36012 " panel_visibility=\"advanced\">\n"
36013 " <Hints>\n"
36014 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36015 " </Hints>\n"
36016 " <Documentation>This property is a python script that is executed during\n"
36017 " the RequestInformation pipeline pass. Use this to provide information\n"
36018 " such as WHOLE_EXTENT to the pipeline downstream.</Documentation>\n"
36019 " </StringVectorProperty>\n"
36020 " <StringVectorProperty command=\"SetUpdateExtentScript\"\n"
36021 " label=\"RequestUpdateExtent Script\"\n"
36022 " name=\"UpdateExtentScript\"\n"
36023 " number_of_elements=\"1\"\n"
36024 " panel_visibility=\"advanced\">\n"
36025 " <Hints>\n"
36026 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36027 " </Hints>\n"
36028 " <Documentation>This property is a python script that is executed during\n"
36029 " the RequestUpdateExtent pipeline pass. Use this to modify the update\n"
36030 " extent that your filter ask up stream for.</Documentation>\n"
36031 " </StringVectorProperty>\n"
36032 " <IntVectorProperty animateable=\"0\"\n"
36033 " command=\"SetCopyArrays\"\n"
36034 " default_values=\"0\"\n"
36035 " name=\"CopyArrays\"\n"
36036 " number_of_elements=\"1\">\n"
36037 " <BooleanDomain name=\"bool\" />\n"
36038 " <Documentation>If this property is set to true, all the cell and point\n"
36039 " arrays from first input are copied to the output.</Documentation>\n"
36040 " </IntVectorProperty>\n"
36041 " <StringVectorProperty animateable=\"0\"\n"
36042 " clean_command=\"ClearParameters\"\n"
36043 " command=\"SetParameterInternal\"\n"
36044 " is_internal=\"1\"\n"
36045 " name=\"Parameters\"\n"
36046 " number_of_elements_per_command=\"2\"\n"
36047 " repeat_command=\"1\"></StringVectorProperty>\n"
36048 " <StringVectorProperty command=\"SetPythonPath\"\n"
36049 " name=\"PythonPath\"\n"
36050 " number_of_elements=\"1\"\n"
36051 " panel_visibility=\"advanced\">\n"
36052 " <Documentation>A semi-colon (;) separated list of directories to add to\n"
36053 " the python library search path.</Documentation>\n"
36054 " </StringVectorProperty>\n"
36055 " <DoubleVectorProperty information_only=\"1\"\n"
36056 " name=\"TimestepValues\"\n"
36057 " repeatable=\"1\">\n"
36058 " <TimeStepsInformationHelper />\n"
36059 " <Documentation>Available timestep values.</Documentation>\n"
36060 " </DoubleVectorProperty>\n"
36061 "\n"
36062 " <!-- End ProgrammableFilter -->\n"
36063 " </SourceProxy>\n"
36064 "\n"
36065 " <SourceProxy class=\"vtkPythonProgrammableFilter\"\n"
36066 " label=\"Programmable Annotation\"\n"
36067 " name=\"ProgrammableAnnotation\">\n"
36068 " <Documentation long_help=\"Executes a user supplied python script on its input dataset to produce an output vtkTable containing a single tuple vtkStringArray to be displayed as a text.\"\n"
36069 " short_help=\"Executes a python script to produce a text.\">\n"
36070 " This filter will execute a python script to produce a\n"
36071 " text. The text should be contained in a vtkTable containing a single vtkStringArray, itself\n"
36072 " containing a single tuple. The filter keeps a copy of the python\n"
36073 " script in Script and creates a python\n"
36074 " Interpreter to run the script upon the first\n"
36075 " execution. To execute external python scripts on the ParaView server, use:\n"
36076 " execfile('full_path/script_name.py'). Documentation is found in the Programmable Filter and\n"
36077 " numpy integration section of the paraview documentation.</Documentation>\n"
36078 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
36079 " command=\"AddInputConnection\"\n"
36080 " multiple_input=\"1\"\n"
36081 " name=\"Input\">\n"
36082 " <ProxyGroupDomain name=\"groups\">\n"
36083 " <Group name=\"sources\" />\n"
36084 " <Group name=\"filters\" />\n"
36085 " </ProxyGroupDomain>\n"
36086 " <DataTypeDomain name=\"input_type\">\n"
36087 " <DataType value=\"vtkDataObject\" />\n"
36088 " <DataType value=\"vtkHyperTreeGrid\" />\n"
36089 " </DataTypeDomain>\n"
36090 " <Documentation>This property specifies the input(s) to the programmable\n"
36091 " filter.</Documentation>\n"
36092 " </InputProperty>\n"
36093 " <IntVectorProperty command=\"SetOutputDataSetType\"\n"
36094 " default_values=\"19\"\n"
36095 " name=\"OutputDataSetType\"\n"
36096 " number_of_elements=\"1\"\n"
36097 " panel_visibility=\"never\">\n"
36098 " </IntVectorProperty>\n"
36099 " <StringVectorProperty command=\"SetScript\"\n"
36100 " name=\"Script\"\n"
36101 " number_of_elements=\"1\"\n"
36102 " default_values=\"to = self.GetTableOutput()&#xA;arr = vtk.vtkStringArray()&#xA;arr.SetName(&#x22;Text&#x22;)&#xA;arr.SetNumberOfComponents(1)&#xA;arr.InsertNextValue(&#x22;YourString&#x22;)&#xA;to.AddColumn(arr)\"\n"
36103 " panel_visibility=\"default\">\n"
36104 " <Hints>\n"
36105 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36106 " </Hints>\n"
36107 " <Documentation>This property contains the text of a python program that\n"
36108 " the programmable filter runs. To execute external python scripts on the ParaView server, use:\n"
36109 " execfile('full_path/script_name.py'). Make sure to output a vtkTable containing a single vtkStringArray,\n"
36110 " itself containing a single tuple.</Documentation>\n"
36111 " </StringVectorProperty>\n"
36112 " <StringVectorProperty animateable=\"0\"\n"
36113 " clean_command=\"ClearParameters\"\n"
36114 " command=\"SetParameterInternal\"\n"
36115 " is_internal=\"1\"\n"
36116 " name=\"Parameters\"\n"
36117 " number_of_elements_per_command=\"2\"\n"
36118 " repeat_command=\"1\">\n"
36119 " </StringVectorProperty>\n"
36120 " <StringVectorProperty command=\"SetPythonPath\"\n"
36121 " name=\"PythonPath\"\n"
36122 " number_of_elements=\"1\"\n"
36123 " panel_visibility=\"advanced\">\n"
36124 " <Documentation>A semi-colon (;) separated list of directories to add to\n"
36125 " the python library search path.</Documentation>\n"
36126 " </StringVectorProperty>\n"
36127 " <Hints>\n"
36128 " <OutputPort index=\"0\"\n"
36129 " name=\"Output-0\"\n"
36130 " type=\"text\" />\n"
36131 " <Visibility replace_input=\"0\" />\n"
36132 " </Hints>\n"
36133 " <!-- End ProgrammableAnnotation -->\n"
36134 " </SourceProxy>\n"
36135 " </ProxyGroup>\n"
36136 "</ServerManagerConfiguration>\n"
36137 "\n";
36138 // Get single string
36140 {
36141
36142  const size_t len0 = strlen(paraview_server_managerpython_filtersInterface0);
36143  const size_t len1 = strlen(paraview_server_managerpython_filtersInterface1);
36144  size_t len = ( 0
36145  + len0
36146  + len1 );
36147  char* res = new char[ len + 1];
36148  size_t offset = 0;
36151  assert(offset == len);
36152  res[offset] = 0;
36153  return res;
36154 }
36155
36156
36157 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersPython/Resources/python_misc.xml
36159 "<ServerManagerConfiguration>\n"
36160 " <ProxyGroup name=\"misc_internals\">\n"
36161 " <Proxy name=\"CDBWriter\" class=\"vtkCDBWriter\">\n"
36162 " <Documentation>\n"
36163 " This is used by vtkSMExtractsController to write summary table.\n"
36164 " </Documentation>\n"
36165 " <StringVectorProperty name=\"FileName\" command=\"SetPath\" />\n"
36166 " </Proxy>\n"
36167 " </ProxyGroup>\n"
36168 "</ServerManagerConfiguration>\n"
36169 "\n";
36170 // Get single string
36172 {
36173
36174  const size_t len0 = strlen(paraview_server_managerpython_miscInterface0);
36175  size_t len = ( 0
36176  + len0 );
36177  char* res = new char[ len + 1];
36178  size_t offset = 0;
36179  std::copy(paraview_server_managerpython_miscInterface0, paraview_server_managerpython_miscInterface0 + len0, res + offset); offset += len0;
36180  assert(offset == len);
36181  res[offset] = 0;
36182  return res;
36183 }
36184
36185
36186 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersPython/Resources/python_sources.xml
36188 "<ServerManagerConfiguration>\n"
36189 " <!-- =================================================================== -->\n"
36190 " <ProxyGroup name=\"sources\">\n"
36191 " <SourceProxy class=\"vtkPythonProgrammableFilter\"\n"
36192 " label=\"Programmable Source\"\n"
36193 " name=\"ProgrammableSource\">\n"
36194 " <Documentation long_help=\"Executes a user supplied python script to produce an output dataset.\"\n"
36195 " short_help=\"Executes a python script to produce data.\">\n"
36196 " This source will execute a python script to produce an\n"
36197 " output dataset. The source keeps a copy of the python\n"
36198 " script in Script and creates a python\n"
36199 " Interpreter to run the script upon the first\n"
36200 " execution. To execute external python scripts on the ParaView server, use:\n"
36201 " execfile('full_path/script_name.py'). Documentation is found in the Programmable Filter\n"
36202 " chapter of the ParaView Guide.</Documentation>\n"
36203 " <IntVectorProperty command=\"SetOutputDataSetType\"\n"
36204 " default_values=\"0\"\n"
36205 " name=\"OutputDataSetType\"\n"
36206 " number_of_elements=\"1\"\n"
36207 " panel_visibility=\"default\">\n"
36208 " <EnumerationDomain name=\"enum\">\n"
36209 " <!-- Values come from vtkType.h-->\n"
36210 " <!-- <Entry value=\"8\" text=\"Same as Input\"/> -->\n"
36211 " <!-- text=\"vtkDataSet\" -->\n"
36212 " <Entry text=\"vtkPolyData\"\n"
36213 " value=\"0\" />\n"
36214 " <!-- <Entry value=\"1\" text=\"vtkStructuredPoints\"/> -->\n"
36215 " <Entry text=\"vtkStructuredGrid\"\n"
36216 " value=\"2\" />\n"
36217 " <Entry text=\"vtkRectilinearGrid\"\n"
36218 " value=\"3\" />\n"
36219 " <Entry text=\"vtkUnstructuredGrid\"\n"
36220 " value=\"4\" />\n"
36221 " <!-- <Entry value=\"5\" text=\"vtkPiecewiseFunction\"/> -->\n"
36222 " <Entry text=\"vtkImageData\"\n"
36223 " value=\"6\" />\n"
36224 " <!-- <Entry value=\"7\" text=\"vtkDataObject\"/> -->\n"
36225 " <!-- <Entry value=\"9\" text=\"vtkPointSet\"/> -->\n"
36226 " <!-- <Entry value=\"10\" text=\"vtkUniformGrid\"/> -->\n"
36227 " <!-- <Entry value=\"11\" text=\"vtkCompositeDataSet\"/> -->\n"
36228 " <!-- <Entry value=\"12\" text=\"vtkMultigroupDataSet\"/> -->\n"
36229 " <Entry text=\"vtkMultiblockDataSet\"\n"
36230 " value=\"13\" />\n"
36231 " <!-- <Entry value=\"14\" text=\"vtkHierarchicalDataSet\"/> -->\n"
36232 " <Entry text=\"vtkHierarchicalBoxDataSet\"\n"
36233 " value=\"15\" />\n"
36234 " <!-- <Entry value=\"16\" text=\"vtkGenericDataSet\"/> -->\n"
36235 " <!-- <Entry value=\"17\" text=\"vtkHyperOctree\"/> -->\n"
36236 " <!-- <Entry value=\"18\" text=\"vtkTemporalDataSet\"/> -->\n"
36237 " <Entry text=\"vtkTable\"\n"
36238 " value=\"19\" />\n"
36239 " <!-- <Entry value=\"20\" text=\"vtkGraph\"/> -->\n"
36240 " <!-- <Entry value=\"21\" text=\"vtkTree\"/> -->\n"
36241 " <Entry text=\"vtkMolecule\"\n"
36242 " value=\"33\" />\n"
36243 " <Entry text=\"vtkPartitionedDataSet\" value=\"37\" />\n"
36244 " <Entry text=\"vtkPartitionedDataSetCollection\" value=\"38\" />\n"
36245 " </EnumerationDomain>\n"
36246 " <Documentation>The value of this property determines the dataset type\n"
36247 " for the output of the programmable source.</Documentation>\n"
36248 " </IntVectorProperty>\n"
36249 " <StringVectorProperty command=\"SetScript\"\n"
36250 " name=\"Script\"\n"
36251 " number_of_elements=\"1\"\n"
36252 " panel_visibility=\"default\">\n"
36253 " <Hints>\n"
36254 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36255 " </Hints>\n"
36256 " <Documentation>This property contains the text of a python program that\n"
36257 " the programmable source runs. To execute external python scripts on the ParaView server, use:\n"
36258 " execfile('full_path/script_name.py'). Documentation is found in the Programmable Filter\n"
36259 " chapter of the ParaView Guide.</Documentation>\n"
36260 " </StringVectorProperty>\n"
36261 " <StringVectorProperty command=\"SetInformationScript\"\n"
36262 " label=\"Script (RequestInformation)\"\n"
36263 " name=\"InformationScript\"\n"
36264 " number_of_elements=\"1\"\n"
36265 " panel_visibility=\"advanced\">\n"
36266 " <Hints>\n"
36267 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36268 " </Hints>\n"
36269 " <Documentation>This property is a python script that is executed during\n"
36270 " the RequestInformation pipeline pass. Use this to provide information\n"
36271 " such as WHOLE_EXTENT to the pipeline downstream.</Documentation>\n"
36272 " </StringVectorProperty>\n"
36273 " <StringVectorProperty animateable=\"0\"\n"
36274 " clean_command=\"ClearParameters\"\n"
36275 " command=\"SetParameterInternal\"\n"
36276 " is_internal=\"1\"\n"
36277 " name=\"Parameters\"\n"
36278 " number_of_elements_per_command=\"2\"\n"
36279 " repeat_command=\"1\"></StringVectorProperty>\n"
36280 " <StringVectorProperty command=\"SetPythonPath\"\n"
36281 " name=\"PythonPath\"\n"
36282 " number_of_elements=\"1\"\n"
36283 " panel_visibility=\"advanced\">\n"
36284 " <Documentation>A semi-colon (;) separated list of directories to add to\n"
36285 " the python library search path.</Documentation>\n"
36286 " </StringVectorProperty>\n"
36287 " <DoubleVectorProperty information_only=\"1\"\n"
36288 " name=\"TimestepValues\"\n"
36289 " repeatable=\"1\">\n"
36290 " <TimeStepsInformationHelper />\n"
36291 " <Documentation>Available timestep values.</Documentation>\n"
36292 " </DoubleVectorProperty>\n"
36293 " <!-- End ProgrammableSource -->\n"
36294 " </SourceProxy>\n"
36295 "\n"
36296 " <SourceProxy class=\"vtkPythonProgrammableFilter\"\n"
36297 " label=\"Live Programmable Source\"\n"
36298 " name=\"LiveProgrammableSource\"\n"
36299 " base_proxygroup=\"sources\"\n"
36300 " base_proxyname=\"ProgrammableSource\">\n"
36301 " <Documentation>\n"
36302 " A programmable source that can produce new data autonomously.\n"
36303 " </Documentation>\n"
36304 " <StringVectorProperty command=\"SetCheckNeedsUpdateScript\"\n"
36305 " label=\"Script (CheckNeedsUpdate)\"\n"
36306 " name=\"CheckNeedsUpdateScript\"\n"
36307 " number_of_elements=\"1\">\n"
36308 " <Hints>\n"
36309 " <Widget type=\"multi_line\" syntax=\"python\" />\n"
36310 " </Hints>\n"
36311 " <Documentation>\n"
36312 " Specify the script to use to check if the filter/source has new data.\n"
36313 " This is only needed for \"live\" sources, that can cause data to be available\n"
36314 " outside of ParaView.\n"
36315 " </Documentation>\n"
36316 " </StringVectorProperty>\n"
36317 "\n"
36318 " <Property name=\"PauseLiveSource\" panel_widget=\"pause_livesource\">\n"
36319 " <Documentation>\n"
36320 " Pause live source.\n"
36321 " </Documentation>\n"
36322 " </Property>\n"
36323 " <Hints>\n"
36324 " <LiveSource />\n"
36325 " </Hints>\n"
36326 " </SourceProxy>\n"
36327 " </ProxyGroup>\n"
36328 "</ServerManagerConfiguration>\n"
36329 "\n";
36330 // Get single string
36332 {
36333
36334  const size_t len0 = strlen(paraview_server_managerpython_sourcesInterface0);
36335  size_t len = ( 0
36336  + len0 );
36337  char* res = new char[ len + 1];
36338  size_t offset = 0;
36340  assert(offset == len);
36341  res[offset] = 0;
36342  return res;
36343 }
36344
36345
36346 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/Resources/amr_filters.xml
36348 "<ServerManagerConfiguration>\n"
36349 " <ProxyGroup name=\"filters\">\n"
36350 " <!-- ==================================================================== -->\n"
36351 " <SourceProxy class=\"vtkPVAMRDualClip\"\n"
36352 " label=\"AMR Dual Clip\"\n"
36353 " name=\"AMRDualClip\">\n"
36354 " <Documentation long_help=\"Clip with scalars. Tetrahedra.\"\n"
36355 " short_help=\"Clip with decimation.\"></Documentation>\n"
36356 " <InputProperty command=\"SetInputConnection\"\n"
36357 " name=\"Input\">\n"
36358 " <ProxyGroupDomain name=\"groups\">\n"
36359 " <Group name=\"sources\" />\n"
36360 " <Group name=\"filters\" />\n"
36361 " </ProxyGroupDomain>\n"
36362 " <DataTypeDomain name=\"input_type\">\n"
36363 " <DataType value=\"vtkNonOverlappingAMR\" />\n"
36364 " </DataTypeDomain>\n"
36365 " <Documentation>This property specifies the input of the\n"
36366 " filter.</Documentation>\n"
36367 " <InputArrayDomain attribute_type=\"cell\"\n"
36368 " name=\"input_array\"\n"
36369 " number_of_components=\"1\" />\n"
36370 " </InputProperty>\n"
36371 " <StringVectorProperty clean_command=\"ClearInputCellArrayToProcess\"\n"
36372 " command=\"AddInputCellArrayToProcess\"\n"
36373 " name=\"SelectMaterialArrays\"\n"
36374 " number_of_elements=\"1\"\n"
36375 " repeat_command=\"1\">\n"
36376 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36377 " data_type=\"VTK_UNSIGNED_CHAR\"\n"
36378 " name=\"array_list\">\n"
36379 " <RequiredProperties>\n"
36380 " <Property function=\"Input\"\n"
36381 " name=\"Input\" />\n"
36382 " </RequiredProperties>\n"
36383 " </ArrayListDomain>\n"
36384 " <Hints>\n"
36385 " <NoDefault />\n"
36386 " </Hints>\n"
36387 " <Documentation>This property specifies the cell arrays from which the\n"
36388 " clip filter will compute clipped cells.</Documentation>\n"
36389 " </StringVectorProperty>\n"
36390 " <DoubleVectorProperty command=\"SetVolumeFractionSurfaceValue\"\n"
36391 " default_values=\"0.1\"\n"
36392 " label=\"Volume Fraction Value\"\n"
36393 " name=\"VolumeFractionSurfaceValue\"\n"
36394 " number_of_elements=\"1\">\n"
36395 " <DoubleRangeDomain max=\"1.0\"\n"
36396 " min=\"0.0\"\n"
36397 " name=\"scalar_range\" />\n"
36398 " <!--<RequiredProperties>\n"
36399 " <Property name=\"Input\" function=\"Input\"/>\n"
36400 " <Property name=\"AddInputCellArrayToProcess\" function=\"ArraySelection\"/>\n"
36401 " </RequiredProperties>\n"
36402 " </ArrayRangeDomain>-->\n"
36403 " <Documentation>This property specifies the values at which to compute\n"
36404 " the isosurface.</Documentation>\n"
36405 " </DoubleVectorProperty>\n"
36406 " <IntVectorProperty animateable=\"1\"\n"
36407 " command=\"SetEnableInternalDecimation\"\n"
36408 " default_values=\"1\"\n"
36409 " name=\"InternalDecimation\"\n"
36410 " number_of_elements=\"1\">\n"
36411 " <BooleanDomain name=\"bool\" />\n"
36412 " <Documentation>If this property is on, internal tetrahedra are\n"
36413 " decimation</Documentation>\n"
36414 " </IntVectorProperty>\n"
36415 " <IntVectorProperty animateable=\"1\"\n"
36416 " command=\"SetEnableMultiProcessCommunication\"\n"
36417 " default_values=\"1\"\n"
36418 " name=\"MultiprocessCommunication\"\n"
36419 " number_of_elements=\"1\">\n"
36420 " <BooleanDomain name=\"bool\" />\n"
36421 " <Documentation>If this property is off, each process executes\n"
36422 " independently.</Documentation>\n"
36423 " </IntVectorProperty>\n"
36424 " <IntVectorProperty animateable=\"1\"\n"
36425 " command=\"SetEnableMergePoints\"\n"
36426 " default_values=\"1\"\n"
36427 " name=\"MergePoints\"\n"
36428 " number_of_elements=\"1\">\n"
36429 " <BooleanDomain name=\"bool\" />\n"
36430 " <Documentation>Use more memory to merge points on the boundaries of\n"
36431 " blocks.</Documentation>\n"
36432 " </IntVectorProperty>\n"
36433 " <!-- End PV AMR Dual Clip -->\n"
36434 " </SourceProxy>\n"
36435 " <!-- ==================================================================== -->\n"
36436 " <SourceProxy class=\"vtkPVAMRDualContour\"\n"
36437 " label=\"AMR Contour\"\n"
36438 " name=\"AMRDualContour\">\n"
36439 " <Documentation short_help=\"Iso surface cell array.\"></Documentation>\n"
36440 " <InputProperty command=\"SetInputConnection\"\n"
36441 " name=\"Input\">\n"
36442 " <ProxyGroupDomain name=\"groups\">\n"
36443 " <Group name=\"sources\" />\n"
36444 " <Group name=\"filters\" />\n"
36445 " </ProxyGroupDomain>\n"
36446 " <Documentation>This property specifies the input of the\n"
36447 " filter.</Documentation>\n"
36448 " <DataTypeDomain name=\"input_type\">\n"
36449 " <DataType value=\"vtkNonOverlappingAMR\" />\n"
36450 " </DataTypeDomain>\n"
36451 " <InputArrayDomain attribute_type=\"cell\"\n"
36452 " name=\"input_array\"\n"
36453 " number_of_components=\"1\" />\n"
36454 " </InputProperty>\n"
36455 " <StringVectorProperty clean_command=\"ClearInputCellArrayToProcess\"\n"
36456 " command=\"AddInputCellArrayToProcess\"\n"
36457 " name=\"SelectMaterialArrays\"\n"
36458 " number_of_elements=\"1\"\n"
36459 " repeat_command=\"1\">\n"
36460 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36461 " data_type=\"VTK_UNSIGNED_CHAR VTK_INT\"\n"
36462 " name=\"array_list\">\n"
36463 " <RequiredProperties>\n"
36464 " <Property function=\"Input\"\n"
36465 " name=\"Input\" />\n"
36466 " </RequiredProperties>\n"
36467 " </ArrayListDomain>\n"
36468 " <Hints>\n"
36469 " <NoDefault />\n"
36470 " </Hints>\n"
36471 " <Documentation>This property specifies the cell arrays from which the\n"
36472 " contour filter will compute contour cells.</Documentation>\n"
36473 " </StringVectorProperty>\n"
36474 " <DoubleVectorProperty command=\"SetVolumeFractionSurfaceValue\"\n"
36475 " default_values=\"0.1\"\n"
36476 " label=\"Volume Fraction Value\"\n"
36477 " name=\"VolumeFractionSurfaceValue\"\n"
36478 " number_of_elements=\"1\">\n"
36479 " <DoubleRangeDomain max=\"1.0\"\n"
36480 " min=\"0.0\"\n"
36481 " name=\"scalar_range\" />\n"
36482 " <!--<RequiredProperties>\n"
36483 " <Property name=\"Input\" function=\"Input\"/>\n"
36484 " <Property name=\"AddInputCellArrayToProcess\" function=\"ArraySelection\"/>\n"
36485 " </RequiredProperties>\n"
36486 " </ArrayRangeDomain>-->\n"
36487 " <Documentation>This property specifies the values at which to compute\n"
36488 " the isosurface.</Documentation>\n"
36489 " </DoubleVectorProperty>\n"
36490 " <IntVectorProperty animateable=\"1\"\n"
36491 " command=\"SetEnableCapping\"\n"
36492 " default_values=\"1\"\n"
36493 " name=\"Capping\"\n"
36494 " number_of_elements=\"1\">\n"
36495 " <BooleanDomain name=\"bool\" />\n"
36496 " <Documentation>If this property is on, the the boundary of the data set\n"
36497 " is capped.</Documentation>\n"
36498 " </IntVectorProperty>\n"
36499 " <IntVectorProperty animateable=\"1\"\n"
36500 " command=\"SetEnableDegenerateCells\"\n"
36501 " default_values=\"1\"\n"
36502 " name=\"DegenerateCells\"\n"
36503 " number_of_elements=\"1\">\n"
36504 " <BooleanDomain name=\"bool\" />\n"
36505 " <Documentation>If this property is on, a transition mesh between levels\n"
36506 " is created.</Documentation>\n"
36507 " </IntVectorProperty>\n"
36508 " <IntVectorProperty animateable=\"1\"\n"
36509 " command=\"SetEnableMultiProcessCommunication\"\n"
36510 " default_values=\"1\"\n"
36511 " name=\"MultiprocessCommunication\"\n"
36512 " number_of_elements=\"1\">\n"
36513 " <BooleanDomain name=\"bool\" />\n"
36514 " <Documentation>If this property is off, each process executes\n"
36515 " independently.</Documentation>\n"
36516 " </IntVectorProperty>\n"
36517 " <IntVectorProperty animateable=\"1\"\n"
36518 " command=\"SetSkipGhostCopy\"\n"
36519 " default_values=\"1\"\n"
36520 " name=\"SkipGhostCopy\"\n"
36521 " number_of_elements=\"1\">\n"
36522 " <BooleanDomain name=\"bool\" />\n"
36523 " <Documentation>A simple test to see if ghost values are already set\n"
36524 " properly.</Documentation>\n"
36525 " </IntVectorProperty>\n"
36526 " <IntVectorProperty animateable=\"1\"\n"
36527 " command=\"SetTriangulateCap\"\n"
36528 " default_values=\"1\"\n"
36529 " name=\"Triangulate\"\n"
36530 " number_of_elements=\"1\">\n"
36531 " <BooleanDomain name=\"bool\" />\n"
36532 " <Documentation>Use triangles instead of quads on capping\n"
36533 " surfaces.</Documentation>\n"
36534 " </IntVectorProperty>\n"
36535 " <IntVectorProperty animateable=\"1\"\n"
36536 " command=\"SetEnableMergePoints\"\n"
36537 " default_values=\"1\"\n"
36538 " name=\"MergePoints\"\n"
36539 " number_of_elements=\"1\">\n"
36540 " <BooleanDomain name=\"bool\" />\n"
36541 " <Documentation>Use more memory to merge points on the boundaries of\n"
36542 " blocks.</Documentation>\n"
36543 " </IntVectorProperty>\n"
36544 " <!-- End AMR Dual Contour -->\n"
36545 " </SourceProxy>\n"
36546 " <!-- ==================================================================== -->\n"
36547 " <SourceProxy class=\"vtkPVAMRFragmentIntegration\"\n"
36548 " label=\"AMR Fragment Integration\"\n"
36549 " name=\"AMRFragmentIntegration\">\n"
36550 " <Documentation short_help=\"Fragment Integration\"></Documentation>\n"
36551 " <InputProperty command=\"SetInputConnection\"\n"
36552 " name=\"Input\">\n"
36553 " <ProxyGroupDomain name=\"groups\">\n"
36554 " <Group name=\"sources\" />\n"
36555 " <Group name=\"filters\" />\n"
36556 " </ProxyGroupDomain>\n"
36557 " <Documentation>This property specifies the volume input of the\n"
36558 " filter.</Documentation>\n"
36559 " <DataTypeDomain name=\"input_type\">\n"
36560 " <DataType value=\"vtkNonOverlappingAMR\" />\n"
36561 " </DataTypeDomain>\n"
36562 " <InputArrayDomain attribute_type=\"cell\"\n"
36563 " name=\"input_array\"\n"
36564 " number_of_components=\"1\" />\n"
36565 " </InputProperty>\n"
36566 " <StringVectorProperty clean_command=\"ClearInputVolumeArrayToProcess\"\n"
36567 " command=\"AddInputVolumeArrayToProcess\"\n"
36568 " name=\"SelectMaterialArrays\"\n"
36569 " number_of_elements=\"1\"\n"
36570 " repeat_command=\"1\">\n"
36571 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36572 " data_type=\"VTK_UNSIGNED_CHAR VTK_INT\"\n"
36573 " name=\"array_list\">\n"
36574 " <RequiredProperties>\n"
36575 " <Property function=\"Input\" name=\"Input\" />\n"
36576 " </RequiredProperties>\n"
36577 " </ArrayListDomain>\n"
36578 " <Hints>\n"
36579 " <NoDefault />\n"
36580 " </Hints>\n"
36581 " <Documentation>This property specifies the cell arrays from which the\n"
36582 " analysis will determine fragments</Documentation>\n"
36583 " </StringVectorProperty>\n"
36584 " <StringVectorProperty clean_command=\"ClearInputMassArrayToProcess\"\n"
36585 " command=\"AddInputMassArrayToProcess\"\n"
36586 " name=\"SelectMassArrays\"\n"
36587 " number_of_elements=\"1\"\n"
36588 " repeat_command=\"1\">\n"
36589 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36590 " data_type=\"VTK_DOUBLE VTK_FLOAT\"\n"
36591 " name=\"array_list\">\n"
36592 " <RequiredProperties>\n"
36593 " <Property function=\"Input\" name=\"Input\" />\n"
36594 " </RequiredProperties>\n"
36595 " </ArrayListDomain>\n"
36596 " <Hints>\n"
36597 " <NoDefault />\n"
36598 " </Hints>\n"
36599 " <Documentation>This property specifies the cell arrays from which the\n"
36600 " analysis will determine fragment mass</Documentation>\n"
36601 " </StringVectorProperty>\n"
36602 " <StringVectorProperty clean_command=\"ClearInputVolumeWeightedArrayToProcess\"\n"
36603 " command=\"AddInputVolumeWeightedArrayToProcess\"\n"
36604 " name=\"SelectVolumeWeightedArrays\"\n"
36605 " number_of_elements=\"1\"\n"
36606 " repeat_command=\"1\">\n"
36607 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36608 " data_type=\"VTK_DOUBLE VTK_FLOAT\"\n"
36609 " name=\"array_list\">\n"
36610 " <RequiredProperties>\n"
36611 " <Property function=\"Input\" name=\"Input\" />\n"
36612 " </RequiredProperties>\n"
36613 " </ArrayListDomain>\n"
36614 " <Hints>\n"
36615 " <NoDefault />\n"
36616 " </Hints>\n"
36617 " <Documentation>This property specifies the cell arrays from which the\n"
36618 " analysis will determine volume weighted average values</Documentation>\n"
36619 " </StringVectorProperty>\n"
36620 " <StringVectorProperty clean_command=\"ClearInputMassWeightedArrayToProcess\"\n"
36621 " command=\"AddInputMassWeightedArrayToProcess\"\n"
36622 " name=\"SelectMassWeightedArrays\"\n"
36623 " number_of_elements=\"1\"\n"
36624 " repeat_command=\"1\">\n"
36625 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36626 " data_type=\"VTK_DOUBLE VTK_FLOAT\"\n"
36627 " name=\"array_list\">\n"
36628 " <RequiredProperties>\n"
36629 " <Property function=\"Input\" name=\"Input\" />\n"
36630 " </RequiredProperties>\n"
36631 " </ArrayListDomain>\n"
36632 " <Hints>\n"
36633 " <NoDefault />\n"
36634 " </Hints>\n"
36635 " <Documentation>This property specifies the cell arrays from which the\n"
36636 " analysis will determine mass weighted average values</Documentation>\n"
36637 " </StringVectorProperty>\n"
36638 " <!-- End AMR Fragment Integration -->\n"
36639 " </SourceProxy>\n"
36640 " <!-- ==================================================================== -->\n"
36641 " <SourceProxy class=\"vtkAMRConnectivity\"\n"
36642 " label=\"AMR Connectivity\"\n"
36643 " name=\"AMRConnectivity\">\n"
36644 " <Documentation short_help=\"Fragment Identification\"></Documentation>\n"
36645 " <InputProperty command=\"SetInputConnection\"\n"
36646 " name=\"Input\">\n"
36647 " <ProxyGroupDomain name=\"groups\">\n"
36648 " <Group name=\"sources\" />\n"
36649 " <Group name=\"filters\" />\n"
36650 " </ProxyGroupDomain>\n"
36651 " <Documentation>This property specifies the volume input of the\n"
36652 " filter.</Documentation>\n"
36653 " <DataTypeDomain name=\"input_type\">\n"
36654 " <DataType value=\"vtkNonOverlappingAMR\" />\n"
36655 " </DataTypeDomain>\n"
36656 " <InputArrayDomain attribute_type=\"cell\"\n"
36657 " name=\"input_array\"\n"
36658 " number_of_components=\"1\" />\n"
36659 " </InputProperty>\n"
36660 " <StringVectorProperty clean_command=\"ClearInputVolumeArrayToProcess\"\n"
36661 " command=\"AddInputVolumeArrayToProcess\"\n"
36662 ;
36663
36664 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/AMR/Resources/amr_filters.xml
36666 " name=\"SelectMaterialArrays\"\n"
36667 " number_of_elements=\"1\"\n"
36668 " repeat_command=\"1\">\n"
36669 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36670 " data_type=\"VTK_UNSIGNED_CHAR VTK_INT\"\n"
36671 " name=\"array_list\">\n"
36672 " <RequiredProperties>\n"
36673 " <Property function=\"Input\" name=\"Input\" />\n"
36674 " </RequiredProperties>\n"
36675 " </ArrayListDomain>\n"
36676 " <Hints>\n"
36677 " <NoDefault />\n"
36678 " </Hints>\n"
36679 " <Documentation>This property specifies the cell arrays from which the\n"
36680 " analysis will determine fragments</Documentation>\n"
36681 " </StringVectorProperty>\n"
36682 " <DoubleVectorProperty command=\"SetVolumeFractionSurfaceValue\"\n"
36683 " default_values=\"0.1\"\n"
36684 " label=\"Volume Fraction Value\"\n"
36685 " name=\"VolumeFractionSurfaceValue\"\n"
36686 " number_of_elements=\"1\">\n"
36687 " <DoubleRangeDomain max=\"1.0\"\n"
36688 " min=\"0.0\"\n"
36689 " name=\"scalar_range\" />\n"
36690 " <!--<RequiredProperties>\n"
36691 " <Property name=\"Input\" function=\"Input\"/>\n"
36692 " <Property name=\"AddInputCellArrayToProcess\" function=\"ArraySelection\"/>\n"
36693 " </RequiredProperties>\n"
36694 " </ArrayRangeDomain>-->\n"
36695 " <Documentation>This property specifies the values at which to compute\n"
36696 " the isosurface.</Documentation>\n"
36697 " </DoubleVectorProperty>\n"
36698 " <IntVectorProperty command=\"SetResolveBlocks\"\n"
36699 " default_values=\"1\"\n"
36700 " name=\"Resolve Blocks\"\n"
36701 " number_of_elements=\"1\">\n"
36702 " <BooleanDomain name=\"bool\" />\n"
36703 " <Documentation>Resolve the fragments between blocks.</Documentation>\n"
36704 " </IntVectorProperty>\n"
36705 " <IntVectorProperty command=\"SetPropagateGhosts\"\n"
36706 " default_values=\"0\"\n"
36707 " name=\"Propagate Ghosts\"\n"
36708 " number_of_elements=\"1\">\n"
36709 " <BooleanDomain name=\"bool\" />\n"
36710 " <Documentation>Propagate regionIds into the ghosts.</Documentation>\n"
36711 " </IntVectorProperty>\n"
36712 " <!-- End AMR Fragment Integration -->\n"
36713 " </SourceProxy>\n"
36714 " <!-- ==================================================================== -->\n"
36715 " <SourceProxy class=\"vtkAMRToMultiBlockFilter\"\n"
36716 " label=\"Convert AMR dataset to Multi-block\"\n"
36717 " name=\"AMRToMultiBlock\">\n"
36718 " <Documentation long_help=\"Convert AMR to Multiblock\"\n"
36719 " short_help=\"Convert AMR to Multiblock\"></Documentation>\n"
36720 " <InputProperty command=\"SetInputConnection\"\n"
36721 " name=\"Input\">\n"
36722 " <ProxyGroupDomain name=\"groups\">\n"
36723 " <Group name=\"sources\" />\n"
36724 " <Group name=\"filters\" />\n"
36725 " </ProxyGroupDomain>\n"
36726 " <DataTypeDomain name=\"input_type\">\n"
36727 " <DataType value=\"vtkOverlappingAMR\" />\n"
36728 " </DataTypeDomain>\n"
36729 " <Documentation>This property specifies the input for this\n"
36730 " filter.</Documentation>\n"
36731 " </InputProperty>\n"
36732 " </SourceProxy>\n"
36733 " <!-- ==================================================================== -->\n"
36734 " <SourceProxy class=\"vtkAMRResampleFilter\"\n"
36735 " label=\"Resample AMR\"\n"
36736 " name=\"AMRResampleFilter\">\n"
36737 " <Documentation long_help=\"Converts AMR data to a uniform grid\"\n"
36738 " short_help=\"Converts AMR data to a uniform grid\">This\n"
36739 " filter allows the user to specify a Region of Interest(ROI)\n"
36740 " within the AMR data-set and extract it as a uniform\n"
36741 " grid.</Documentation>\n"
36742 " <InputProperty command=\"SetInputConnection\"\n"
36743 " name=\"Input\">\n"
36744 " <ProxyGroupDomain name=\"groups\">\n"
36745 " <Group name=\"sources\" />\n"
36746 " <Group name=\"filters\" />\n"
36747 " </ProxyGroupDomain>\n"
36748 " <DataTypeDomain name=\"input_type\">\n"
36749 " <DataType value=\"vtkOverlappingAMR\" />\n"
36750 " </DataTypeDomain>\n"
36751 " <Documentation>This property specifies the input for this\n"
36752 " filter.</Documentation>\n"
36753 " </InputProperty>\n"
36754 " <IntVectorProperty command=\"SetDemandDrivenMode\"\n"
36755 " default_values=\"1\"\n"
36756 " name=\"Demand-Driven Mode\"\n"
36757 " number_of_elements=\"1\">\n"
36758 " <BooleanDomain name=\"bool\" />\n"
36759 " <Documentation>This property specifies whether the resampling filter\n"
36760 " will operate in demand-driven mode or not.</Documentation>\n"
36761 " </IntVectorProperty>\n"
36762 " <IntVectorProperty command=\"SetTransferToNodes\"\n"
36763 " default_values=\"1\"\n"
36764 " name=\"TransferToNodes\"\n"
36765 " number_of_elements=\"1\">\n"
36766 " <BooleanDomain name=\"bool\" />\n"
36767 " <Documentation>This property specifies whether the solution will be\n"
36768 " transferred to the nodes of the extracted region or the\n"
36769 " cells.</Documentation>\n"
36770 " </IntVectorProperty>\n"
36771 " <IntVectorProperty command=\"SetNumberOfPartitions\"\n"
36772 " default_values=\"1\"\n"
36773 " name=\"NumberOfPartitions\"\n"
36774 " number_of_elements=\"1\">\n"
36775 " <IntRangeDomain name=\"range\" />\n"
36776 " <Documentation>Set the number of subdivisions for recursive coordinate\n"
36777 " bisection.</Documentation>\n"
36778 " </IntVectorProperty>\n"
36779 " <!--\n"
36780 " <IntVectorProperty\n"
36781 " name=\"LevelOfResolution\"\n"
36782 " command=\"SetLevelOfResolution\"\n"
36783 " number_of_elements=\"1\"\n"
36784 " default_values=\"0\" >\n"
36785 " <IntRangeDomain name=\"range\" min=\"0\" max=\"100\" />\n"
36786 " <Documentation>\n"
36787 " Set maximum slice resolution.\n"
36788 " </Documentation>\n"
36789 " </IntVectorProperty>\n"
36790 "\n"
36791 " -->\n"
36792 " <IntVectorProperty animateable=\"1\"\n"
36793 " command=\"SetNumberOfSamples\"\n"
36794 " default_values=\"10 10 10\"\n"
36795 " name=\"Number of Samples\"\n"
36796 " number_of_elements=\"3\">\n"
36797 " <IntRangeDomain name=\"range\" />\n"
36798 " <Documentation>Sets the number of samples in each\n"
36799 " dimension</Documentation>\n"
36800 " </IntVectorProperty>\n"
36801 " <DoubleVectorProperty animateable=\"1\"\n"
36802 " command=\"SetMin\"\n"
36803 " default_values=\"0.0 0.0 0.0\"\n"
36804 " name=\"Min\"\n"
36805 " number_of_elements=\"3\">\n"
36806 " <DoubleRangeDomain name=\"range\" />\n"
36807 " <Documentation>This property sets the minimum 3-D coordinate location\n"
36808 " by which the particles will be filtered out.</Documentation>\n"
36809 " </DoubleVectorProperty>\n"
36810 " <DoubleVectorProperty animateable=\"1\"\n"
36811 " command=\"SetMax\"\n"
36812 " default_values=\"0.0 0.0 0.0\"\n"
36813 " name=\"Max\"\n"
36814 " number_of_elements=\"3\">\n"
36815 " <DoubleRangeDomain name=\"range\" />\n"
36816 " <Documentation>This property sets the minimum 3-D coordinate location\n"
36817 " by which the particles will be filtered out.</Documentation>\n"
36818 " </DoubleVectorProperty>\n"
36819 " </SourceProxy>\n"
36820 " <!-- ==================================================================== -->\n"
36821 " <SourceProxy class=\"vtkAMRFragmentsFilter\"\n"
36822 " label=\"AMR Fragments Filter\"\n"
36823 " name=\"AMRFragmentsFilter\">\n"
36824 " <Documentation short_help=\"Meta Fragment filter\">Combines the running of\n"
36825 " AMRContour, AMRFragmentIntegration, AMRDualContour and ExtractCTHParts</Documentation>\n"
36826 " <InputProperty command=\"SetInputConnection\"\n"
36827 " name=\"Input\">\n"
36828 " <ProxyGroupDomain name=\"groups\">\n"
36829 " <Group name=\"sources\" />\n"
36830 " <Group name=\"filters\" />\n"
36831 " </ProxyGroupDomain>\n"
36832 " <Documentation>This property specifies the volume input of the\n"
36833 " filter.</Documentation>\n"
36834 " <DataTypeDomain name=\"input_type\">\n"
36835 " <DataType value=\"vtkNonOverlappingAMR\" />\n"
36836 " </DataTypeDomain>\n"
36837 " <InputArrayDomain attribute_type=\"cell\"\n"
36838 " name=\"input_array\"\n"
36839 " number_of_components=\"1\" />\n"
36840 " </InputProperty>\n"
36841 " <StringVectorProperty clean_command=\"ClearInputVolumeArrayToProcess\"\n"
36842 " command=\"AddInputVolumeArrayToProcess\"\n"
36843 " name=\"SelectMaterialArrays\"\n"
36844 " number_of_elements=\"1\"\n"
36845 " repeat_command=\"1\">\n"
36846 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36847 " data_type=\"VTK_UNSIGNED_CHAR VTK_INT\"\n"
36848 " name=\"array_list\">\n"
36849 " <RequiredProperties>\n"
36850 " <Property function=\"Input\" name=\"Input\" />\n"
36851 " </RequiredProperties>\n"
36852 " </ArrayListDomain>\n"
36853 " <Hints>\n"
36854 " <NoDefault />\n"
36855 " </Hints>\n"
36856 " <Documentation>This property specifies the cell arrays from which the\n"
36857 " analysis will determine fragments</Documentation>\n"
36858 " </StringVectorProperty>\n"
36859 " <StringVectorProperty clean_command=\"ClearInputMassArrayToProcess\"\n"
36860 " command=\"AddInputMassArrayToProcess\"\n"
36861 " name=\"SelectMassArrays\"\n"
36862 " number_of_elements=\"1\"\n"
36863 " repeat_command=\"1\">\n"
36864 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36865 " data_type=\"VTK_DOUBLE VTK_FLOAT\"\n"
36866 " name=\"array_list\">\n"
36867 " <RequiredProperties>\n"
36868 " <Property function=\"Input\" name=\"Input\" />\n"
36869 " </RequiredProperties>\n"
36870 " </ArrayListDomain>\n"
36871 " <Hints>\n"
36872 " <NoDefault />\n"
36873 " </Hints>\n"
36874 " <Documentation>This property specifies the cell arrays from which the\n"
36875 " analysis will determine fragment mass</Documentation>\n"
36876 " </StringVectorProperty>\n"
36877 " <StringVectorProperty clean_command=\"ClearInputVolumeWeightedArrayToProcess\"\n"
36878 " command=\"AddInputVolumeWeightedArrayToProcess\"\n"
36879 " name=\"SelectVolumeWeightedArrays\"\n"
36880 " number_of_elements=\"1\"\n"
36881 " repeat_command=\"1\">\n"
36882 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36883 " data_type=\"VTK_DOUBLE VTK_FLOAT\"\n"
36884 " name=\"array_list\">\n"
36885 " <RequiredProperties>\n"
36886 " <Property function=\"Input\" name=\"Input\" />\n"
36887 " </RequiredProperties>\n"
36888 " </ArrayListDomain>\n"
36889 " <Hints>\n"
36890 " <NoDefault />\n"
36891 " </Hints>\n"
36892 " <Documentation>This property specifies the cell arrays from which the\n"
36893 " analysis will determine volume weighted average values</Documentation>\n"
36894 " </StringVectorProperty>\n"
36895 " <StringVectorProperty clean_command=\"ClearInputMassWeightedArrayToProcess\"\n"
36896 " command=\"AddInputMassWeightedArrayToProcess\"\n"
36897 " name=\"SelectMassWeightedArrays\"\n"
36898 " number_of_elements=\"1\"\n"
36899 " repeat_command=\"1\">\n"
36900 " <ArrayListDomain attribute_type=\"Scalars\"\n"
36901 " data_type=\"VTK_DOUBLE VTK_FLOAT\"\n"
36902 " name=\"array_list\">\n"
36903 " <RequiredProperties>\n"
36904 " <Property function=\"Input\" name=\"Input\" />\n"
36905 " </RequiredProperties>\n"
36906 " </ArrayListDomain>\n"
36907 " <Hints>\n"
36908 " <NoDefault />\n"
36909 " </Hints>\n"
36910 " <Documentation>This property specifies the cell arrays from which the\n"
36911 " analysis will determine mass weighted average values</Documentation>\n"
36912 " </StringVectorProperty>\n"
36913 " <DoubleVectorProperty command=\"SetVolumeFractionSurfaceValue\"\n"
36914 " default_values=\"0.1\"\n"
36915 " label=\"Volume Fraction Value\"\n"
36916 " name=\"VolumeFractionSurfaceValue\"\n"
36917 " number_of_elements=\"1\">\n"
36918 " <DoubleRangeDomain max=\"1.0\"\n"
36919 " min=\"0.0\"\n"
36920 " name=\"scalar_range\" />\n"
36921 " <Documentation>This property specifies the values at which to compute\n"
36922 " the isosurface.</Documentation>\n"
36923 " </DoubleVectorProperty>\n"
36924 " <IntVectorProperty command=\"SetExtractSurface\"\n"
36925 " default_values=\"0\"\n"
36926 " name=\"Extract Surface\"\n"
36927 " number_of_elements=\"1\">\n"
36928 " <BooleanDomain name=\"bool\" />\n"
36929 " <Documentation>Whether or not to extract a surface from this data</Documentation>\n"
36930 " </IntVectorProperty>\n"
36931 " <IntVectorProperty command=\"SetUseWatertightSurface\"\n"
36932 " default_values=\"0\"\n"
36933 " name=\"Use Watertight Surface\"\n"
36934 " number_of_elements=\"1\">\n"
36935 " <BooleanDomain name=\"bool\" />\n"
36936 " <Documentation>Whether the extracted surface should be watertight or not</Documentation>\n"
36937 " </IntVectorProperty>\n"
36938 " <IntVectorProperty command=\"SetIntegrateFragments\"\n"
36939 " default_values=\"1\"\n"
36940 " name=\"Integrate Fragments\"\n"
36941 " number_of_elements=\"1\">\n"
36942 " <BooleanDomain name=\"bool\" />\n"
36943 " <Documentation>Whether or not to integrate fragments in this data</Documentation>\n"
36944 " </IntVectorProperty>\n"
36945 " <!-- End AMR Fragments Filter -->\n"
36946 " </SourceProxy>\n"
36947 " </ProxyGroup>\n"
36948 "</ServerManagerConfiguration>\n"
36949 "\n";
36950 // Get single string
36952 {
36953
36954  const size_t len0 = strlen(paraview_server_manageramr_filtersInterface0);
36955  const size_t len1 = strlen(paraview_server_manageramr_filtersInterface1);
36956  size_t len = ( 0
36957  + len0
36958  + len1 );
36959  char* res = new char[ len + 1];
36960  size_t offset = 0;
36961  std::copy(paraview_server_manageramr_filtersInterface0, paraview_server_manageramr_filtersInterface0 + len0, res + offset); offset += len0;
36962  std::copy(paraview_server_manageramr_filtersInterface1, paraview_server_manageramr_filtersInterface1 + len1, res + offset); offset += len1;
36963  assert(offset == len);
36964  res[offset] = 0;
36965  return res;
36966 }
36967
36968
36969 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
36971 "<ServerManagerConfiguration>\n"
36972 " <ProxyGroup name=\"filters\">\n"
36973 " <!-- ==================================================================== -->\n"
36974 " <SourceProxy class=\"vtkStreaklineFilter\"\n"
36975 " name=\"LegacyStreakLine\">\n"
36976 " <Documentation long_help=\"Trace Streak lines through time in a vector field.\"\n"
36977 " short_help=\"Trace Streak lines through time in a vector field.\">\n"
36978 " The Particle Trace filter generates pathlines in a vector\n"
36979 " field from a collection of seed points. The vector field\n"
36980 " used is selected from the Vectors menu, so the input data\n"
36981 " set is required to have point-centered vectors. The Seed\n"
36982 " portion of the interface allows you to select whether the\n"
36983 " seed points for this integration lie in a point cloud or\n"
36984 " along a line. Depending on which is selected, the\n"
36985 " appropriate 3D widget (point or line widget) is displayed\n"
36986 " along with traditional user interface controls for\n"
36987 " positioning the point cloud or line within the data set.\n"
36988 " Instructions for using the 3D widgets and the\n"
36989 " corresponding manual controls can be found in section 7.4.\n"
36990 " This filter operates on any type of data set, provided it\n"
36991 " has point-centered vectors. The output is polygonal data\n"
36992 " containing polylines. This filter is available on the\n"
36993 " Toolbar.\n"
36994 " </Documentation>\n"
36995 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
36996 " command=\"AddInputConnection\"\n"
36997 " multiple_input=\"1\"\n"
36998 " name=\"Input\">\n"
36999 " <ProxyGroupDomain name=\"groups\">\n"
37000 " <Group name=\"sources\"/>\n"
37001 " <Group name=\"filters\"/>\n"
37002 " </ProxyGroupDomain>\n"
37003 " <DataTypeDomain composite_data_supported=\"1\"\n"
37004 " name=\"input_type\">\n"
37005 " <DataType value=\"vtkDataObject\"/>\n"
37006 " </DataTypeDomain>\n"
37007 " <InputArrayDomain attribute_type=\"point\"\n"
37008 " name=\"input_array\"\n"
37009 " number_of_components=\"3\"/>\n"
37010 " <Documentation>\n"
37011 " Specify which is the Input of the StreamTracer filter.\n"
37012 " </Documentation>\n"
37013 " </InputProperty>\n"
37014 " <IntVectorProperty command=\"SetStaticSeeds\"\n"
37015 " default_values=\"0\"\n"
37016 " name=\"StaticSeeds\"\n"
37017 " number_of_elements=\"1\">\n"
37018 " <BooleanDomain name=\"bool\"/>\n"
37019 " <Documentation>\n"
37020 " If the input seeds are not changing, then this can be set to 1 to avoid having to do a repeated grid search\n"
37021 " that would return the exact same result.\n"
37022 " </Documentation>\n"
37023 " </IntVectorProperty>\n"
37024 " <IntVectorProperty command=\"SetMeshOverTime\"\n"
37025 " default_values=\"0\"\n"
37026 " name=\"MeshOverTime\"\n"
37027 " number_of_elements=\"1\">\n"
37028 " <EnumerationDomain name=\"enum\">\n"
37029 " <Entry text=\"Different\" value=\"0\"/>\n"
37030 " <Entry text=\"Static\" value=\"1\"/>\n"
37031 " <Entry text=\"Linear Transformation\" value=\"2\"/>\n"
37032 " <Entry text=\"Same Topology\" value=\"3\"/>\n"
37033 " </EnumerationDomain>\n"
37034 " <Documentation>\n"
37035 " The input mesh can either be 1) different over time, or 2) static over time,\n"
37036 " or 3) a linear transformation of the first time step over time, or 4) have the same topology over time.\n"
37037 " If a value other than Different are used, then performance can be improved significantly because certain\n"
37038 " data structures, such as locators or cell links are not rebuilt for each timestep.\n"
37039 " </Documentation>\n"
37040 " </IntVectorProperty>\n"
37041 " <IntVectorProperty command=\"SetInterpolatorType\"\n"
37042 " default_values=\"1\"\n"
37043 " name=\"InterpolatorType\"\n"
37044 " number_of_elements=\"1\"\n"
37045 " panel_visibility=\"advanced\">\n"
37046 " <EnumerationDomain name=\"enum\">\n"
37047 " <Entry text=\"Interpolator with Point Locator\"\n"
37048 " value=\"0\"/>\n"
37049 " <Entry text=\"Interpolator with Cell Locator\"\n"
37050 " value=\"1\"/>\n"
37051 " </EnumerationDomain>\n"
37052 " <Documentation>\n"
37053 " This property determines which interpolator to use for evaluating the velocity vector field. The first is\n"
37054 " faster though the second is more robust in locating cells during streamline integration.\n"
37055 " </Documentation>\n"
37056 " </IntVectorProperty>\n"
37057 " <InputProperty clean_command=\"RemoveAllSources\"\n"
37058 " command=\"AddSourceConnection\"\n"
37059 " label=\"Seed Source\"\n"
37060 " multiple_input=\"1\"\n"
37061 " name=\"Source\">\n"
37062 " <ProxyGroupDomain name=\"groups\">\n"
37063 " <Group name=\"sources\"/>\n"
37064 " <Group name=\"filters\"/>\n"
37065 " </ProxyGroupDomain>\n"
37066 " <DataTypeDomain name=\"input_type\">\n"
37067 " <DataType value=\"vtkDataSet\"/>\n"
37068 " </DataTypeDomain>\n"
37069 " <Documentation>\n"
37070 " Specify the seed dataset. Typically, from where the vector field integration should begin. Usually a\n"
37071 " point/radius or a line with a given resolution.\n"
37072 " </Documentation>\n"
37073 " </InputProperty>\n"
37074 " <DoubleVectorProperty command=\"SetTerminationTime\"\n"
37075 " default_values=\"3.0\"\n"
37076 " name=\"TerminationTime\"\n"
37077 " number_of_elements=\"1\"\n"
37078 " panel_visibility=\"never\">\n"
37079 " <DoubleRangeDomain name=\"range\"/>\n"
37080 " <Documentation>\n"
37081 " Setting TerminationTime to a positive value will cause particles to terminate when the time is reached.\n"
37082 " The units of time should be consistent with the primary time variable.\n"
37083 " </Documentation>\n"
37084 " </DoubleVectorProperty>\n"
37085 " <DoubleVectorProperty information_only=\"1\"\n"
37086 " name=\"TimestepValues\">\n"
37087 " <TimeStepsInformationHelper/>\n"
37088 " </DoubleVectorProperty>\n"
37089 " <IntVectorProperty command=\"SetForceReinjectionEveryNSteps\"\n"
37090 " default_values=\"1\"\n"
37091 " name=\"ForceReinjectionEveryNSteps\"\n"
37092 " number_of_elements=\"1\">\n"
37093 " <IntRangeDomain name=\"range\"/>\n"
37094 " <Documentation>\n"
37095 " When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow.\n"
37096 " Setting ForceReinjectionEveryNSteps to a non zero value will cause the particle source to reinject particles\n"
37097 " every Nth step even if it is otherwise unchanged. Note that if the particle source is also animated, this flag\n"
37098 " will be redundant as the particles will be reinjected whenever the source changes anyway.\n"
37099 " </Documentation>\n"
37100 " </IntVectorProperty>\n"
37101 " <StringVectorProperty animateable=\"0\"\n"
37102 " command=\"SetInputArrayToProcess\"\n"
37103 " element_types=\"0 0 0 0 2\"\n"
37104 " name=\"SelectInputVectors\"\n"
37105 " number_of_elements=\"5\"\n"
37106 " panel_visibility=\"default\">\n"
37107 " <ArrayListDomain attribute_type=\"Vectors\"\n"
37108 " name=\"array_list\">\n"
37109 " <RequiredProperties>\n"
37110 " <Property function=\"Input\"\n"
37111 " name=\"Input\"/>\n"
37112 " </RequiredProperties>\n"
37113 " </ArrayListDomain>\n"
37114 " <Documentation>\n"
37115 " Specify which vector array should be used for the integration through that filter.\n"
37116 " </Documentation>\n"
37117 " </StringVectorProperty>\n"
37118 " <IntVectorProperty command=\"SetComputeVorticity\"\n"
37119 " default_values=\"1\"\n"
37120 " name=\"ComputeVorticity\"\n"
37121 " number_of_elements=\"1\">\n"
37122 " <BooleanDomain name=\"bool\"/>\n"
37123 " <Documentation>\n"
37124 " Compute vorticity and angular rotation of particles as they progress\n"
37125 " </Documentation>\n"
37126 " </IntVectorProperty>\n"
37127 " <IntVectorProperty command=\"SetDisableResetCache\"\n"
37128 " default_values=\"0\"\n"
37129 " name=\"DisableResetCache\"\n"
37130 " number_of_elements=\"1\"\n"
37131 " panel_visibility=\"never\">\n"
37132 " <BooleanDomain name=\"bool\"/>\n"
37133 " <Documentation>\n"
37134 " Prevents cache from getting reset so that new computation always start from previous results.\n"
37135 " </Documentation>\n"
37136 " </IntVectorProperty>\n"
37137 " </SourceProxy>\n"
37138 "\n"
37139 " <!-- ==================================================================== -->\n"
37140 " <SourceProxy class=\"vtkCleanUnstructuredGrid\"\n"
37141 " label=\"Clean to Grid\"\n"
37142 " name=\"CleanUnstructuredGrid\">\n"
37143 " <Documentation long_help=\"This filter merges points and converts the data set to unstructured grid.\"\n"
37144 " short_help=\"Merge points.\">The Clean to Grid filter merges\n"
37145 " points that are exactly coincident. It also converts the\n"
37146 " data set to an unstructured grid. You may wish to do this\n"
37147 " if you want to apply a filter to your data set that is\n"
37148 " available for unstructured grids but not for the initial\n"
37149 " type of your data set (e.g., applying warp vector to\n"
37150 " volumetric data). The Clean to Grid filter operates on any\n"
37151 " type of data set.</Documentation>\n"
37152 " <InputProperty command=\"SetInputConnection\"\n"
37153 " name=\"Input\">\n"
37154 " <ProxyGroupDomain name=\"groups\">\n"
37155 " <Group name=\"sources\" />\n"
37156 " <Group name=\"filters\" />\n"
37157 " </ProxyGroupDomain>\n"
37158 " <DataTypeDomain name=\"input_type\">\n"
37159 " <DataType value=\"vtkDataSet\" />\n"
37160 " </DataTypeDomain>\n"
37161 " <Documentation>This property specifies the input to the Clean to Grid\n"
37162 " filter.</Documentation>\n"
37163 " </InputProperty>\n"
37164 " <DoubleVectorProperty animateable=\"1\"\n"
37165 " command=\"SetTolerance\"\n"
37166 " default_values=\"0.0\"\n"
37167 " name=\"Tolerance\"\n"
37168 " number_of_elements=\"1\">\n"
37169 " <DoubleRangeDomain max=\"1\"\n"
37170 " min=\"0\"\n"
37171 " name=\"range\" />\n"
37172 " <Documentation>When merging nearby points and\n"
37173 " not using absolute tolerance (see ToleranceIsAbsolute property), this\n"
37174 " property specifies the tolerance for performing merging as a fraction\n"
37175 " of the length of the diagonal of the bounding box of the input data\n"
37176 " set.</Documentation>\n"
37177 " </DoubleVectorProperty>\n"
37178 " <DoubleVectorProperty command=\"SetAbsoluteTolerance\"\n"
37179 " default_values=\"1.0\"\n"
37180 " name=\"AbsoluteTolerance\"\n"
37181 " number_of_elements=\"1\">\n"
37182 " <DoubleRangeDomain min=\"0\"\n"
37183 " name=\"range\" />\n"
37184 " <Documentation>When merging nearby points and\n"
37185 " using absolute tolerance (see ToleranceIsAbsolute property), this\n"
37186 " property specifies the tolerance for performing merging in the spatial\n"
37187 " units of the input data set.</Documentation>\n"
37188 " </DoubleVectorProperty>\n"
37189 " <IntVectorProperty command=\"SetToleranceIsAbsolute\"\n"
37190 " default_values=\"0\"\n"
37191 " name=\"ToleranceIsAbsolute\"\n"
37192 " number_of_elements=\"1\">\n"
37193 " <BooleanDomain name=\"bool\" />\n"
37194 " <Documentation>This property determines whether to use absolute or\n"
37195 " relative (a percentage of the bounding box) tolerance when performing\n"
37196 " point merging.</Documentation>\n"
37197 " </IntVectorProperty>\n"
37198 " <IntVectorProperty command=\"SetRemovePointsWithoutCells\"\n"
37199 " default_values=\"0\"\n"
37200 " name=\"RemovePointsWithoutCells\"\n"
37201 " number_of_elements=\"1\">\n"
37202 " <BooleanDomain name=\"bool\" />\n"
37203 " </IntVectorProperty>\n"
37204 " <IntVectorProperty name=\"PointDataWeightingStrategy\"\n"
37205 " command=\"SetPointDataWeighingStrategy\"\n"
37206 " number_of_elements=\"1\"\n"
37207 " default_values=\"0\"\n"
37208 " panel_visibility=\"advanced\">\n"
37209 " <EnumerationDomain name=\"enum\">\n"
37210 " <Entry text=\"Take First Point\" value=\"0\" />\n"
37211 " <Entry text=\"Average by Number\" value=\"1\" />\n"
37212 " <Entry text=\"Average by Spatial Density\" value=\"2\" />\n"
37213 " </EnumerationDomain>\n"
37214 " <Documentation>\n"
37215 " Select how to merge data located on merged points:\n"
37216 " - Take First Point (default): the point with the lowest index imposes its data on to the merged point\n"
37217 " - Average by Number: a number average is performed on all the duplicate points\n"
37218 " - Average by Spatial Density: an average by attached cell volume (i.e. for every cell the point is\n"
37219 " connected to sum cell_volume/number_cell_points) is performed on the point data\n"
37220 " </Documentation>\n"
37221 " </IntVectorProperty>\n"
37222 " <Hints>\n"
37223 " <WarnOnCreate>\n"
37224 " <DataTypeDomain name=\"input_type\">\n"
37225 " <DataType value=\"vtkImageData\" />\n"
37226 " <DataType value=\"vtkRectilinearGrid\" />\n"
37227 " <DataType value=\"vtkStructuredGrid\" />\n"
37228 " </DataTypeDomain>\n"
37229 " <MemoryUsage relative=\"20\" />\n"
37230 " <Text title=\"Potentially running out of memory\">\n"
37231 " **Clean to Grid** filter will create an unstructured grid output and\n"
37232 " you may not have enough memory to create it.\n"
37233 " Do you want to continue?\n"
37234 " </Text>\n"
37235 " </WarnOnCreate>\n"
37236 " </Hints>\n"
37237 "\n"
37238 " <!-- End CleanUnstructuredGrid -->\n"
37239 " </SourceProxy>\n"
37240 "\n"
37241 " <!-- ==================================================================== -->\n"
37242 " <SourceProxy class=\"vtkCleanUnstructuredGridCells\"\n"
37243 " label=\"Clean Cells to Grid\"\n"
37244 " name=\"CleanUnstructuredGridCells\">\n"
37245 " <Documentation long_help=\"This filter merges cells and converts the data set to unstructured grid.\"\n"
37246 " short_help=\"Merge cells.\">Merges degenerate cells. Assumes\n"
37247 " the input grid does not contain duplicate points. You may\n"
37248 " want to run vtkCleanUnstructuredGrid first to assert it.\n"
37249 " If duplicated cells are found they are removed in the\n"
37250 " output. The filter also handles the case, where a cell may\n"
37251 " contain degenerate nodes (i.e. one and the same node is\n"
37252 " referenced by a cell more than once).</Documentation>\n"
37253 " <InputProperty command=\"SetInputConnection\"\n"
37254 " name=\"Input\">\n"
37255 " <ProxyGroupDomain name=\"groups\">\n"
37256 " <Group name=\"sources\" />\n"
37257 " <Group name=\"filters\" />\n"
37258 " </ProxyGroupDomain>\n"
37259 " <DataTypeDomain name=\"input_type\">\n"
37260 " <DataType value=\"vtkUnstructuredGrid\" />\n"
37261 ;
37262
37263 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
37265 " </DataTypeDomain>\n"
37266 " <Documentation>This property specifies the input to the Clean Cells to\n"
37267 " Grid filter.</Documentation>\n"
37268 " </InputProperty>\n"
37269 " <!-- End CleanUnstructuredGridCells -->\n"
37270 " </SourceProxy>\n"
37271 "\n"
37272 " <!-- ==================================================================== -->\n"
37273 " <SourceProxy class=\"vtkHybridProbeFilter\"\n"
37274 " label=\"Extract Location\"\n"
37275 " name=\"ExtractLocation\">\n"
37276 " <Documentation long_help=\"Sample or extract cells at a point.\"\n"
37277 " short_help=\"Sample or extracy cells at a point.\">\n"
37278 " This filter allows you to specify a location and then either interpolate\n"
37279 " the data attributes from the input dataset at that location or extract the\n"
37280 " cell(s) at the location.\n"
37281 " </Documentation>\n"
37282 " <InputProperty command=\"SetInputConnection\" name=\"Input\">\n"
37283 " <ProxyGroupDomain name=\"groups\">\n"
37284 " <Group name=\"sources\" />\n"
37285 " <Group name=\"filters\" />\n"
37286 " </ProxyGroupDomain>\n"
37287 " <DataTypeDomain name=\"input_type\">\n"
37288 " <DataType value=\"vtkDataSet\" />\n"
37289 " <DataType value=\"vtkCompositeDataSet\" />\n"
37290 " </DataTypeDomain>\n"
37291 " <InputArrayDomain name=\"input_array\" />\n"
37292 " <Documentation>Set the input dataset producer</Documentation>\n"
37293 " </InputProperty>\n"
37294 "\n"
37295 " <IntVectorProperty name=\"Mode\"\n"
37296 " command=\"SetMode\"\n"
37297 " number_of_elements=\"1\"\n"
37298 " default_values=\"1\">\n"
37299 " <EnumerationDomain name=\"enum\">\n"
37300 " <Entry text=\"Interpolate At Location\" value=\"0\" />\n"
37301 " <Entry text=\"Extract Cell At Location\" value=\"1\" />\n"
37302 " </EnumerationDomain>\n"
37303 " <Documentation>\n"
37304 " Select whether to interpolate (probe) data attributes at the specified\n"
37305 " location, or to extract cell(s) containing the specified location.\n"
37306 " </Documentation>\n"
37307 " </IntVectorProperty>\n"
37308 "\n"
37309 " <DoubleVectorProperty command=\"SetLocation\"\n"
37310 " default_values=\"0.0 0.0 0.0\"\n"
37311 " name=\"Location\"\n"
37312 " number_of_elements=\"3\">\n"
37313 " <Documentation>Select the location of interest in 3D space.</Documentation>\n"
37314 " <BoundsDomain default_mode=\"mid\"\n"
37315 " mode=\"normal\"\n"
37316 " name=\"range\">\n"
37317 " <RequiredProperties>\n"
37318 " <Property function=\"Input\"\n"
37319 " name=\"Input\" />\n"
37320 " </RequiredProperties>\n"
37321 " </BoundsDomain>\n"
37322 " </DoubleVectorProperty>\n"
37323 " <PropertyGroup label=\"Location Parameters\" panel_widget=\"InteractiveHandle\">\n"
37324 " <Property function=\"WorldPosition\" name=\"Location\" />\n"
37325 " <Property function=\"Input\" name=\"Input\" />\n"
37326 " </PropertyGroup>\n"
37327 " <Hints>\n"
37328 " <Visibility replace_input=\"2\" />\n"
37329 " </Hints>\n"
37330 " <!-- End ProbePoint -->\n"
37331 " </SourceProxy>\n"
37332 "\n"
37333 " <!-- ==================================================================== -->\n"
37334 " <SourceProxy class=\"vtkIntegrateFlowThroughSurface\"\n"
37335 " label=\"Surface Flow\"\n"
37336 " name=\"IntegrateFlowThroughSurface\">\n"
37337 " <Documentation long_help=\"This filter integrates flow through a surface.\"\n"
37338 " short_help=\"This filter integrates flow through a surface.\">\n"
37339 " The flow integration filter integrates the dot product of\n"
37340 " a point flow vector field and surface normal. It computes\n"
37341 " the net flow across the 2D surface. It operates on any\n"
37342 " type of dataset and produces an unstructured grid\n"
37343 " output.</Documentation>\n"
37344 " <InputProperty command=\"SetInputConnection\"\n"
37345 " name=\"Input\">\n"
37346 " <ProxyGroupDomain name=\"groups\">\n"
37347 " <Group name=\"sources\" />\n"
37348 " <Group name=\"filters\" />\n"
37349 " </ProxyGroupDomain>\n"
37350 " <DataTypeDomain name=\"input_type\">\n"
37351 " <DataType value=\"vtkDataSet\" />\n"
37352 " </DataTypeDomain>\n"
37353 " <InputArrayDomain attribute_type=\"point\"\n"
37354 " name=\"input_array\"\n"
37355 " number_of_components=\"3\" />\n"
37356 " <Documentation>This property specifies the input to the Surface Flow\n"
37357 " filter.</Documentation>\n"
37358 " </InputProperty>\n"
37359 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
37360 " element_types=\"0 0 0 0 2\"\n"
37361 " name=\"SelectInputVectors\"\n"
37362 " number_of_elements=\"5\">\n"
37363 " <ArrayListDomain attribute_type=\"Vectors\"\n"
37364 " name=\"array_list\">\n"
37365 " <RequiredProperties>\n"
37366 " <Property function=\"Input\"\n"
37367 " name=\"Input\" />\n"
37368 " </RequiredProperties>\n"
37369 " </ArrayListDomain>\n"
37370 " <Documentation>The value of this property specifies the name of the\n"
37371 " input vector array containing the flow vector field.</Documentation>\n"
37372 " </StringVectorProperty>\n"
37373 " <!-- End IntegrateFlowThroughSurface -->\n"
37374 " </SourceProxy>\n"
37375 "\n"
37376 " <!-- ==================================================================== -->\n"
37377 " <SourceProxy class=\"vtkIsoVolume\"\n"
37378 " label=\"Iso Volume\"\n"
37379 " name=\"IsoVolume\">\n"
37380 " <Documentation long_help=\"This filter extracts cells by clipping cells that have point\n"
37381 " scalars not in the specified range.\"\n"
37382 " short_help=\"Extract cells that satisfy a threshold criterion.\">\n"
37383 " This filter clip away the cells using lower and upper\n"
37384 " thresholds.</Documentation>\n"
37385 " <InputProperty command=\"SetInputConnection\"\n"
37386 " name=\"Input\">\n"
37387 " <ProxyGroupDomain name=\"groups\">\n"
37388 " <Group name=\"sources\" />\n"
37389 " <Group name=\"filters\" />\n"
37390 " </ProxyGroupDomain>\n"
37391 " <DataTypeDomain name=\"input_type\">\n"
37392 " <DataType value=\"vtkDataSet\" />\n"
37393 " </DataTypeDomain>\n"
37394 " <InputArrayDomain name=\"input_array\"\n"
37395 " number_of_components=\"1\">\n"
37396 " </InputArrayDomain>\n"
37397 " <Documentation>This property specifies the input to the Threshold\n"
37398 " filter.</Documentation>\n"
37399 " </InputProperty>\n"
37400 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
37401 " element_types=\"0 0 0 0 2\"\n"
37402 " label=\"Input Scalars\"\n"
37403 " name=\"SelectInputScalars\"\n"
37404 " number_of_elements=\"5\">\n"
37405 " <ArrayListDomain attribute_type=\"Scalars\"\n"
37406 " name=\"array_list\">\n"
37407 " <RequiredProperties>\n"
37408 " <Property function=\"Input\"\n"
37409 " name=\"Input\" />\n"
37410 " </RequiredProperties>\n"
37411 " </ArrayListDomain>\n"
37412 " <Documentation>The value of this property contains the name of the\n"
37413 " scalar array from which to perform thresholding.</Documentation>\n"
37414 " </StringVectorProperty>\n"
37415 " <DoubleVectorProperty command=\"ThresholdBetween\"\n"
37416 " default_values=\"0 0\"\n"
37417 " label=\"Threshold Range\"\n"
37418 " name=\"ThresholdBetween\"\n"
37419 " number_of_elements=\"2\"\n"
37420 " panel_widget=\"double_range\">\n"
37421 " <ArrayRangeDomain name=\"range\">\n"
37422 " <RequiredProperties>\n"
37423 " <Property function=\"Input\"\n"
37424 " name=\"Input\" />\n"
37425 " <Property function=\"ArraySelection\"\n"
37426 " name=\"SelectInputScalars\" />\n"
37427 " </RequiredProperties>\n"
37428 " </ArrayRangeDomain>\n"
37429 " <Documentation>The values of this property specify the upper and lower\n"
37430 " bounds of the thresholding operation.</Documentation>\n"
37431 " </DoubleVectorProperty>\n"
37432 " <Hints>\n"
37433 " <Visibility replace_input=\"2\" />\n"
37434 " <WarnOnCreate>\n"
37435 " <DataTypeDomain name=\"input_type\">\n"
37436 " <DataType value=\"vtkImageData\" />\n"
37437 " <DataType value=\"vtkRectilinearGrid\" />\n"
37438 " <DataType value=\"vtkStructuredGrid\" />\n"
37439 " </DataTypeDomain>\n"
37440 " <MemoryUsage relative=\"10\" />\n"
37441 " <Text title=\"Potentially running out of memory\">\n"
37442 " **Isovolume** filter will create an unstructured grid output and\n"
37443 " you may not have enough memory to create it.\n"
37444 " Do you want to continue?\n"
37445 " </Text>\n"
37446 " </WarnOnCreate>\n"
37447 " </Hints>\n"
37448 " <!-- End Iso Volume -->\n"
37449 " </SourceProxy>\n"
37450 "\n"
37451 " <!-- ==================================================================== -->\n"
37452 " <SourceProxy class=\"vtkPlotEdges\"\n"
37453 " label=\"Plot On Sorted Lines\"\n"
37454 " name=\"PlotOnSortedLines\">\n"
37455 " <Documentation long_help=\"The Plot on Sorted Lines filter sorts and orders polylines for graph visualization.\"\n"
37456 " short_help=\"\">The Plot on Sorted Lines filter sorts and orders\n"
37457 " polylines for graph visualization. See http://www.paraview.org/ParaView3/index.php/Plotting_Over_Curves for more information.</Documentation>\n"
37458 " <InputProperty command=\"SetInputConnection\"\n"
37459 " name=\"Input\">\n"
37460 " <ProxyGroupDomain name=\"groups\">\n"
37461 " <Group name=\"sources\" />\n"
37462 " <Group name=\"filters\" />\n"
37463 " </ProxyGroupDomain>\n"
37464 " <DataTypeDomain name=\"input_type\">\n"
37465 " <DataType value=\"vtkPolyData\" />\n"
37466 " </DataTypeDomain>\n"
37467 " <Documentation>This property specifies the input to the Plot Edges\n"
37468 " filter.</Documentation>\n"
37469 " </InputProperty>\n"
37470 " <Hints>\n"
37471 " <!-- View can be used to specify the preferred view for the proxy -->\n"
37472 " <View type=\"XYChartView\" />\n"
37473 " <!-- Temporary hint to allow the output of this filter to be plotted -->\n"
37474 " <Plotable />\n"
37475 " </Hints>\n"
37476 " <!-- End PlotEdges -->\n"
37477 " </SourceProxy>\n"
37478 "\n"
37479 " <SourceProxy class=\"vtkConvertPolyhedraFilter\"\n"
37480 " label=\"Convert Polyhedral Cells\"\n"
37481 " name=\"ConvertPolyhedra\">\n"
37482 " <Documentation long_help=\"Attempt to convert polyhedral cells tp simple cells.\">\n"
37483 "Attempt to convert polyhedral cells to simple cells (tetrahedron, pyramid, wedge\n"
37484 "or hexahedron). It will speed up downstream processing if polyhedral cells can\n"
37485 "be treated as simple cells.\n"
37486 " </Documentation>\n"
37487 " <InputProperty command=\"SetInputConnection\"\n"
37488 " name=\"Input\">\n"
37489 " <ProxyGroupDomain name=\"groups\">\n"
37490 " <Group name=\"sources\" />\n"
37491 " <Group name=\"filters\" />\n"
37492 " </ProxyGroupDomain>\n"
37493 " <DataTypeDomain name=\"input_type\">\n"
37494 " <DataType value=\"vtkUnstructuredGridBase\" />\n"
37495 " </DataTypeDomain>\n"
37496 " <Documentation>This property specifies the input to the Convert Polyhedral Cells\n"
37497 " filter.</Documentation>\n"
37498 " </InputProperty>\n"
37499 " </SourceProxy>\n"
37500 "\n"
37501 "\n"
37502 " <!-- ==================================================================== -->\n"
37503 " <SourceProxy class=\"vtkPVArrayCalculator\"\n"
37504 " name=\"Calculator\">\n"
37505 " <Documentation long_help=\"Compute new attribute arrays as function of existing arrays.\"\n"
37506 " short_help=\"Compute new attribute arrays.\">\n"
37507 "The Calculator filter computes a new data array or new point\n"
37508 "coordinates as a function of existing scalar or vector arrays. If\n"
37509 "point-centered arrays are used in the computation of a new data array,\n"
37510 "the resulting array will also be point-centered. Similarly,\n"
37511 "computations using cell-centered arrays will produce a new\n"
37512 "cell-centered array. If the function is computing point coordinates,\n"
37513 "the result of the function must be a three-component vector.\n"
37514 "\n"
37515 "The Calculator interface operates similarly to a scientific\n"
37516 "calculator. In creating the function to evaluate, the standard order\n"
37517 "of operations applies. Each of the calculator functions is described\n"
37518 "below. Unless otherwise noted, enclose the operand in parentheses\n"
37519 "using the ( and ) buttons.\n"
37520 "\n"
37521 "- Clear: Erase the current function (displayed in the read-only text\n"
37522 " box above the calculator buttons).\n"
37523 "- /: Divide one scalar by another. The operands for this function are\n"
37524 " not required to be enclosed in parentheses.\n"
37525 "- *: Multiply two scalars, or multiply a vector by a scalar (scalar multiple).\n"
37526 " The operands for this function are not required to be enclosed in parentheses.\n"
37527 "- -: Negate a scalar or vector (unary minus), or subtract one scalar or vector\n"
37528 " from another. The operands for this function are not required to be enclosed\n"
37529 " in parentheses.\n"
37530 "- +: Add two scalars or two vectors. The operands for this function are not\n"
37531 " required to be enclosed in parentheses.\n"
37532 "- sin: Compute the sine of a scalar.\n"
37533 "- cos: Compute the cosine of a scalar.\n"
37534 "- tan: Compute the tangent of a scalar.\n"
37535 "- asin: Compute the arcsine of a scalar.\n"
37536 "- acos: Compute the arccosine of a scalar.\n"
37537 "- atan: Compute the arctangent of a scalar.\n"
37538 "- sinh: Compute the hyperbolic sine of a scalar.\n"
37539 "- cosh: Compute the hyperbolic cosine of a scalar.\n"
37540 "- tanh: Compute the hyperbolic tangent of a scalar.\n"
37541 "- min: Compute minimum of two scalars.\n"
37542 "- max: Compute maximum of two scalars.\n"
37543 "- x^y: Raise one scalar to the power of another scalar. The operands for\n"
37544 " this function are not required to be enclosed in parentheses.\n"
37545 "- sqrt: Compute the square root of a scalar.\n"
37546 "- exp: Raise e to the power of a scalar.\n"
37547 "- ln: Compute the logarithm of a scalar to the base 'e'.\n"
37548 "- log10: Compute the logarithm of a scalar to the base 10.\n"
37549 "- ceil: Compute the ceiling of a scalar. floor: Compute the floor of a scalar.\n"
37550 "- abs: Compute the absolute value of a scalar.\n"
37551 "- dot: Compute the dot product of two vectors.\n"
37552 "- cross: Compute cross product of two vectors.\n"
37553 "- mag: Compute the magnitude of a vector.\n"
37554 "- norm: Normalize a vector.\n"
37555 "\n"
37556 "The operands are described below. The digits 0 - 9 and the decimal\n"
37557 "point are used to enter constant scalar values. **iHat**, **jHat**,\n"
37558 "and **kHat** are vector constants representing unit vectors in the X,\n"
37559 "Y, and Z directions, respectively. The scalars menu lists the names of\n"
37560 "the scalar arrays and the components of the vector arrays of either\n"
37561 "the point-centered or cell-centered data. The vectors menu lists the\n"
37562 "names of the point-centered or cell-centered vector arrays. The\n"
37563 "function will be computed for each point (or cell) using the scalar or\n"
37564 "vector value of the array at that point (or cell). The filter operates\n"
37565 "on any type of data set, but the input data set must have at least one\n"
37566 "scalar or vector array. The arrays can be either point-centered or\n"
37567 "cell-centered. The Calculator filter's output is of the same data set\n"
37568 "type as the input.\n"
37569 "\n"
37570 "The output array type can be specified as an advanced option with the default\n"
37571 "being of a vtkDoubleArray.</Documentation>\n"
37572 " <InputProperty command=\"SetInputConnection\"\n"
37573 " name=\"Input\">\n"
37574 " <ProxyGroupDomain name=\"groups\">\n"
37575 " <Group name=\"sources\" />\n"
37576 " <Group name=\"filters\" />\n"
37577 " </ProxyGroupDomain>\n"
37578 " <DataTypeDomain name=\"input_type\">\n"
37579 ;
37580
37581 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
37583 " <DataType value=\"vtkDataSet\" />\n"
37584 " <DataType value=\"vtkGraph\"/>\n"
37585 " <DataType value=\"vtkTable\"/>\n"
37586 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
37587 " </DataTypeDomain>\n"
37588 " <InputArrayDomain name=\"input_array\" optional=\"1\"/>\n"
37589 " <Documentation>This property specifies the input dataset (vtkDataSet, vtkTable or vtkGraph) to the\n"
37590 " Calculator filter. The scalar and vector variables may be chosen from\n"
37591 " this dataset's arrays.</Documentation>\n"
37592 " </InputProperty>\n"
37593 " <IntVectorProperty command=\"SetAttributeType\"\n"
37594 " default_values=\"0\"\n"
37595 " name=\"AttributeType\"\n"
37596 " number_of_elements=\"1\">\n"
37597 " <FieldDataDomain name=\"enum\">\n"
37598 " <RequiredProperties>\n"
37599 " <Property function=\"Input\"\n"
37600 " name=\"Input\" />\n"
37601 " </RequiredProperties>\n"
37602 " </FieldDataDomain>\n"
37603 " <Documentation>This property determines on which types of field data the computation is to\n"
37604 " be performed on.</Documentation>\n"
37605 " </IntVectorProperty>\n"
37606 " <IntVectorProperty command=\"SetCoordinateResults\"\n"
37607 " default_values=\"0\"\n"
37608 " name=\"CoordinateResults\"\n"
37609 " number_of_elements=\"1\">\n"
37610 " <BooleanDomain name=\"bool\" />\n"
37611 " <Hints>\n"
37612 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"AttributeType\" value=\"0\" inverse=\"0\" />\n"
37613 " </Hints>\n"
37614 " <Documentation>The value of this property determines whether the\n"
37615 " results of this computation should be used as point coordinates or as a\n"
37616 " new array.</Documentation>\n"
37617 " </IntVectorProperty>\n"
37618 " <IntVectorProperty command=\"SetResultNormals\"\n"
37619 " default_values=\"0\"\n"
37620 " name=\"ResultNormals\"\n"
37621 " number_of_elements=\"1\"\n"
37622 " panel_visibility=\"advanced\">\n"
37623 " <BooleanDomain name=\"bool\" />\n"
37624 " <Documentation>Set whether to output results as point/cell\n"
37625 " normals. Outputting as normals is only valid with vector\n"
37626 " results. Point or cell normals are selected using\n"
37627 " AttributeMode.</Documentation>\n"
37628 " </IntVectorProperty>\n"
37629 " <IntVectorProperty command=\"SetResultTCoords\"\n"
37630 " default_values=\"0\"\n"
37631 " name=\"ResultTCoords\"\n"
37632 " number_of_elements=\"1\"\n"
37633 " panel_visibility=\"advanced\">\n"
37634 " <BooleanDomain name=\"bool\" />\n"
37635 " <Documentation>Set whether to output results as point/cell\n"
37636 " texture coordinates. Point or cell texture coordinates are\n"
37637 " selected using AttributeMode. 2-component texture coordinates\n"
37638 " cannot be generated at this time.</Documentation>\n"
37639 " </IntVectorProperty>\n"
37640 " <StringVectorProperty command=\"SetResultArrayName\"\n"
37641 " default_values=\"Result\"\n"
37642 " name=\"ResultArrayName\"\n"
37643 " number_of_elements=\"1\">\n"
37644 " <Documentation>This property contains the name for the output array\n"
37645 " containing the result of this computation.</Documentation>\n"
37646 " </StringVectorProperty>\n"
37647 " <StringVectorProperty command=\"SetFunction\"\n"
37648 " name=\"Function\"\n"
37649 " number_of_elements=\"1\"\n"
37650 " panel_widget=\"calculator\" >\n"
37651 " <Documentation>\n"
37652 "This property contains the equation for computing the new\n"
37653 "array.\n"
37654 " </Documentation>\n"
37655 " </StringVectorProperty>\n"
37656 " <IntVectorProperty command=\"SetReplaceInvalidValues\"\n"
37657 " default_values=\"1\"\n"
37658 " label=\"Replace Invalid Results\"\n"
37659 " name=\"ReplaceInvalidValues\"\n"
37660 " number_of_elements=\"1\"\n"
37661 " panel_visibility=\"advanced\">\n"
37662 " <BooleanDomain name=\"bool\" />\n"
37663 " <Documentation>This property determines whether invalid values in the\n"
37664 " computation will be replaced with a specific value. (See the\n"
37665 " ReplacementValue property.)</Documentation>\n"
37666 " </IntVectorProperty>\n"
37667 " <DoubleVectorProperty command=\"SetReplacementValue\"\n"
37668 " default_values=\"0.0\"\n"
37669 " name=\"ReplacementValue\"\n"
37670 " number_of_elements=\"1\"\n"
37671 " panel_visibility=\"advanced\">\n"
37672 " <DoubleRangeDomain name=\"range\" />\n"
37673 " <Documentation>If invalid values in the computation are to be replaced\n"
37674 " with another value, this property contains that value.</Documentation>\n"
37675 " </DoubleVectorProperty>\n"
37676 " <IntVectorProperty command=\"SetResultArrayType\"\n"
37677 " default_values=\"11\"\n"
37678 " label=\"Result Array Type\"\n"
37679 " name=\"ResultArrayType\"\n"
37680 " number_of_elements=\"1\"\n"
37681 " panel_visibility=\"advanced\">\n"
37682 " <EnumerationDomain name=\"enum\">\n"
37683 " <Entry text=\"Char\"\n"
37684 " value=\"2\" />\n"
37685 " <Entry text=\"Signed Char\"\n"
37686 " value=\"15\" />\n"
37687 " <Entry text=\"Unsigned Char\"\n"
37688 " value=\"3\" />\n"
37689 " <Entry text=\"Short\"\n"
37690 " value=\"4\" />\n"
37691 " <Entry text=\"Unsigned Short\"\n"
37692 " value=\"5\" />\n"
37693 " <Entry text=\"Int\"\n"
37694 " value=\"6\" />\n"
37695 " <Entry text=\"Unsigned Int\"\n"
37696 " value=\"7\" />\n"
37697 " <Entry text=\"Long\"\n"
37698 " value=\"8\" />\n"
37699 " <Entry text=\"Unsigned Long\"\n"
37700 " value=\"9\" />\n"
37701 " <Entry text=\"Float\"\n"
37702 " value=\"10\" />\n"
37703 " <Entry text=\"Double\"\n"
37704 " value=\"11\" />\n"
37705 " <Entry text=\"Id Type\"\n"
37706 " value=\"12\" />\n"
37707 " </EnumerationDomain>\n"
37708 " <Documentation>This property determines what array type to output.\n"
37709 " The default is a vtkDoubleArray.</Documentation>\n"
37710 " </IntVectorProperty>\n"
37711 " <IntVectorProperty name=\"FunctionParserType\"\n"
37712 " command=\"SetFunctionParserTypeFromInt\"\n"
37713 " default_values=\"1\"\n"
37714 " number_of_elements=\"1\"\n"
37715 " panel_visibility=\"never\">\n"
37716 " <Documentation>Hidden property that specifies whether the old (ParaView 5.9 and before)\n"
37717 " expression parser or new (ParaView 5.10) vtkPVLinearExtrusionFilter is used.</Documentation>\n"
37718 " </IntVectorProperty>\n"
37719 " <!-- End Calculator -->\n"
37720 " </SourceProxy>\n"
37721 "\n"
37722 " <!-- ==================================================================== -->\n"
37723 " <SourceProxy class=\"vtkPVClipClosedSurface\"\n"
37724 " label=\"Clip Closed Surface\"\n"
37725 " name=\"ClipClosedSurface\">\n"
37726 " <Documentation long_help=\"Clip a polygonal dataset with a plane to produce closed surfaces\"\n"
37727 " short_help=\"Clip a polygonal dataset with a plane to produce closed surfaces\">\n"
37728 " This clip filter cuts away a portion of the input polygonal dataset using\n"
37729 " a plane to generate a new polygonal dataset.</Documentation>\n"
37730 " <InputProperty command=\"SetInputConnection\"\n"
37731 " name=\"Input\">\n"
37732 " <ProxyGroupDomain name=\"groups\">\n"
37733 " <Group name=\"sources\" />\n"
37734 " <Group name=\"filters\" />\n"
37735 " </ProxyGroupDomain>\n"
37736 " <DataTypeDomain name=\"input_type\">\n"
37737 " <DataType value=\"vtkPolyData\" />\n"
37738 " </DataTypeDomain>\n"
37739 " <InputArrayDomain attribute_type=\"point\"\n"
37740 " name=\"input_array\"\n"
37741 " number_of_components=\"1\"\n"
37742 " optional=\"1\" />\n"
37743 " <Documentation>This property specifies the dataset on which the Clip\n"
37744 " filter will operate.</Documentation>\n"
37745 " </InputProperty>\n"
37746 " <ProxyProperty command=\"SetClippingPlane\"\n"
37747 " label=\"Clipping Plane\"\n"
37748 " name=\"ClippingPlane\">\n"
37749 " <ProxyGroupDomain name=\"groups\">\n"
37750 " <Group name=\"implicit_functions\" />\n"
37751 " </ProxyGroupDomain>\n"
37752 " <ProxyListDomain name=\"proxy_list\">\n"
37753 " <Proxy group=\"implicit_functions\"\n"
37754 " name=\"Plane\" />\n"
37755 " </ProxyListDomain>\n"
37756 " <Documentation>This property specifies the parameters of the clipping\n"
37757 " plane used to clip the polygonal data.</Documentation>\n"
37758 " </ProxyProperty>\n"
37759 " <IntVectorProperty command=\"SetGenerateFaces\"\n"
37760 " default_values=\"1\"\n"
37761 " name=\"GenerateFaces\"\n"
37762 " number_of_elements=\"1\">\n"
37763 " <BooleanDomain name=\"bool\" />\n"
37764 " <Documentation>Generate polygonal faces in the output.</Documentation>\n"
37765 " </IntVectorProperty>\n"
37766 " <IntVectorProperty command=\"SetGenerateOutline\"\n"
37767 " default_values=\"0\"\n"
37768 " name=\"GenerateOutline\"\n"
37769 " number_of_elements=\"1\">\n"
37770 " <BooleanDomain name=\"bool\" />\n"
37771 " <Documentation>Generate clipping outlines in the output wherever an\n"
37772 " input face is cut by the clipping plane.</Documentation>\n"
37773 " </IntVectorProperty>\n"
37774 " <IntVectorProperty command=\"SetScalarMode\"\n"
37775 " default_values=\"0\"\n"
37776 " label=\"Generate Cell Origins\"\n"
37777 " name=\"ScalarMode\"\n"
37778 " number_of_elements=\"1\">\n"
37779 " <EnumerationDomain name=\"enum\">\n"
37780 " <Entry text=\"None\"\n"
37781 " value=\"0\" />\n"
37782 " <Entry text=\"Color\"\n"
37783 " value=\"1\" />\n"
37784 " <Entry text=\"Label\"\n"
37785 " value=\"2\" />\n"
37786 " </EnumerationDomain>\n"
37787 " <Documentation>Generate (cell) data for coloring purposes such that the\n"
37788 " newly generated cells (including capping faces and clipping outlines)\n"
37789 " can be distinguished from the input cells.</Documentation>\n"
37790 " </IntVectorProperty>\n"
37791 " <IntVectorProperty command=\"SetInsideOut\"\n"
37792 " default_values=\"0\"\n"
37793 " name=\"InsideOut\"\n"
37794 " number_of_elements=\"1\">\n"
37795 " <BooleanDomain name=\"bool\" />\n"
37796 " <Documentation>If this flag is turned off, the clipper will return the\n"
37797 " portion of the data that lies within the clipping plane. Otherwise, the\n"
37798 " clipper will return the portion of the data that lies outside the\n"
37799 " clipping plane.</Documentation>\n"
37800 " </IntVectorProperty>\n"
37801 " <DoubleVectorProperty command=\"SetTolerance\"\n"
37802 " default_values=\"0.000001\"\n"
37803 " label=\"Clipping Tolerance\"\n"
37804 " name=\"Tolerance\"\n"
37805 " number_of_elements=\"1\">\n"
37806 " <DoubleRangeDomain name=\"range\" />\n"
37807 " <Documentation>Specify the tolerance for creating new points. A small\n"
37808 " value might incur degenerate triangles.</Documentation>\n"
37809 " </DoubleVectorProperty>\n"
37810 " <DoubleVectorProperty command=\"SetBaseColor\"\n"
37811 " default_values=\"0.10 0.10 1.00\"\n"
37812 " label=\"Base Color\"\n"
37813 " name=\"BaseColor\"\n"
37814 " number_of_elements=\"3\">\n"
37815 " <DoubleRangeDomain max=\"1 1 1\"\n"
37816 " min=\"0 0 0\"\n"
37817 " name=\"range\" />\n"
37818 " <Documentation>Specify the color for the faces from the\n"
37819 " input.</Documentation>\n"
37820 " </DoubleVectorProperty>\n"
37821 " <DoubleVectorProperty command=\"SetClipColor\"\n"
37822 " default_values=\"1.00 0.11 0.10\"\n"
37823 " label=\"Clip Color\"\n"
37824 " name=\"ClipColor\"\n"
37825 " number_of_elements=\"3\">\n"
37826 " <DoubleRangeDomain max=\"1 1 1\"\n"
37827 " min=\"0 0 0\"\n"
37828 " name=\"range\" />\n"
37829 " <Documentation>Specify the color for the capping faces (generated on\n"
37830 " the clipping interface).</Documentation>\n"
37831 " </DoubleVectorProperty>\n"
37832 " <!-- End Clip -->\n"
37833 " </SourceProxy>\n"
37834 "\n"
37835 " <!-- ==================================================================== -->\n"
37836 " <SourceProxy class=\"vtkPVContourFilter\"\n"
37837 " name=\"Contour\">\n"
37838 " <Documentation long_help=\"Generate isolines or isosurfaces using point scalars.\"\n"
37839 " short_help=\"Generate isolines or isosurfaces.\">The Contour\n"
37840 " filter computes isolines or isosurfaces using a selected\n"
37841 " point-centered scalar array. The Contour filter operates\n"
37842 " on any type of data set, but the input is required to have\n"
37843 " at least one point-centered scalar (single-component)\n"
37844 " array. The output of this filter is\n"
37845 " polygonal.</Documentation>\n"
37846 " <InputProperty command=\"SetInputConnection\"\n"
37847 " name=\"Input\">\n"
37848 " <ProxyGroupDomain name=\"groups\">\n"
37849 " <Group name=\"sources\" />\n"
37850 " <Group name=\"filters\" />\n"
37851 " </ProxyGroupDomain>\n"
37852 " <DataTypeDomain name=\"input_type\">\n"
37853 " <DataType value=\"vtkDataSet\" />\n"
37854 " <DataType value=\"vtkHyperTreeGrid\" />\n"
37855 " </DataTypeDomain>\n"
37856 " <InputArrayDomain attribute_type=\"point\"\n"
37857 " name=\"input_array\"\n"
37858 " number_of_components=\"1\"\n"
37859 " data_type=\"vtkDataSet\" />\n"
37860 " <InputArrayDomain attribute_type=\"cell\"\n"
37861 " name=\"input_array_htg\"\n"
37862 " number_of_components=\"1\"\n"
37863 " data_type=\"vtkHyperTreeGrid\" />\n"
37864 " <Documentation>This property specifies the input dataset to be used by\n"
37865 " the contour filter.</Documentation>\n"
37866 " </InputProperty>\n"
37867 " <StringVectorProperty animateable=\"0\"\n"
37868 " command=\"SetInputArrayToProcess\"\n"
37869 " element_types=\"int int int int str\"\n"
37870 " label=\"Contour By\"\n"
37871 " name=\"SelectInputScalars\"\n"
37872 " number_of_elements=\"5\">\n"
37873 " <ArrayListDomain attribute_type=\"Scalars\"\n"
37874 " name=\"array_list\">\n"
37875 " <RequiredProperties>\n"
37876 " <Property function=\"Input\"\n"
37877 " name=\"Input\" />\n"
37878 " </RequiredProperties>\n"
37879 " </ArrayListDomain>\n"
37880 " <Documentation>This property specifies the name of the scalar array\n"
37881 " from which the contour filter will compute isolines and/or\n"
37882 " isosurfaces.</Documentation>\n"
37883 " </StringVectorProperty>\n"
37884 " <IntVectorProperty animateable=\"0\"\n"
37885 ;
37886
37887 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
37889 " command=\"SetComputeNormals\"\n"
37890 " default_values=\"1\"\n"
37891 " name=\"ComputeNormals\"\n"
37892 " number_of_elements=\"1\">\n"
37893 " <BooleanDomain name=\"bool\" />\n"
37894 " <Hints>\n"
37895 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
37896 " name=\"vtkPolyData vtkHyperTreeGrid\"\n"
37897 " exclude=\"1\"\n"
37898 " mode=\"enabled_state\" />\n"
37899 " </Hints>\n"
37900 " <Documentation>If this property is set to 1, a scalar array containing\n"
37901 " a normal value at each point in the isosurface or isoline will be\n"
37902 " created by the contour filter; otherwise an array of normals will not\n"
37903 " be computed. This operation is fairly expensive both in terms of\n"
37904 " computation time and memory required, so if the output dataset produced\n"
37905 " by the contour filter will be processed by filters that modify the\n"
37906 " dataset's topology or geometry, it may be wise to set the value of this\n"
37907 " property to 0. Select whether to compute normals.</Documentation>\n"
37908 " </IntVectorProperty>\n"
37909 " <IntVectorProperty animateable=\"0\"\n"
37910 " command=\"SetComputeGradients\"\n"
37911 " default_values=\"0\"\n"
37912 " name=\"ComputeGradients\"\n"
37913 " number_of_elements=\"1\">\n"
37914 " <BooleanDomain name=\"bool\" />\n"
37915 " <Hints>\n"
37916 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
37917 " <Expression type=\"or\">\n"
37918 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
37919 " name=\"Structured\"\n"
37920 " mode=\"enabled_state\"/>\n"
37921 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
37922 " name=\"vtkHyperTreeGrid\"\n"
37923 " mode=\"enabled_state\"\n"
37924 " exclude=\"1\"/>\n"
37925 " </Expression>\n"
37926 " </PropertyWidgetDecorator>\n"
37927 " </Hints>\n"
37928 " <Documentation>If this property is set to 1, a scalar array containing\n"
37929 " a gradient value at each point in the isosurface or isoline will be\n"
37930 " created by this filter; otherwise an array of gradients will not be\n"
37931 " computed. This operation is fairly expensive both in terms of\n"
37932 " computation time and memory required, so if the output dataset produced\n"
37933 " by the contour filter will be processed by filters that modify the\n"
37934 " dataset's topology or geometry, it may be wise to set the value of this\n"
37935 " property to 0. Not that if ComputeNormals is set to 1, then gradients\n"
37936 " will have to be calculated, but they will only be stored in the output\n"
37937 " dataset if ComputeGradients is also set to 1.</Documentation>\n"
37938 " </IntVectorProperty>\n"
37939 " <IntVectorProperty animateable=\"0\"\n"
37940 " command=\"SetComputeScalars\"\n"
37941 " default_values=\"1\"\n"
37942 " name=\"ComputeScalars\"\n"
37943 " number_of_elements=\"1\"\n"
37944 " panel_visibility=\"advanced\">\n"
37945 " <Hints>\n"
37946 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
37947 " name=\"vtkHyperTreeGrid\"\n"
37948 " exclude=\"1\"\n"
37949 " mode=\"enabled_state\"/>\n"
37950 " </Hints>\n"
37951 " <BooleanDomain name=\"bool\" />\n"
37952 " <Documentation>If this property is set to 1, an array of scalars\n"
37953 " (containing the contour value) will be added to the output dataset. If\n"
37954 " set to 0, the output will not contain this array.</Documentation>\n"
37955 " </IntVectorProperty>\n"
37956 " <IntVectorProperty animateable=\"0\"\n"
37957 " command=\"SetOutputPointsPrecision\"\n"
37958 " default_values=\"2\"\n"
37959 " name=\"OutputPointsPrecision\"\n"
37960 " number_of_elements=\"1\"\n"
37961 " panel_visibility=\"advanced\" >\n"
37962 " <Hints>\n"
37963 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
37964 " name=\"vtkHyperTreeGrid\"\n"
37965 " exclude=\"1\"\n"
37966 " mode=\"enabled_state\"/>\n"
37967 " </Hints>\n"
37968 " <EnumerationDomain name=\"enum\">\n"
37969 " <Entry text=\"Single\"\n"
37970 " value=\"0\" />\n"
37971 " <Entry text=\"Double\"\n"
37972 " value=\"1\" />\n"
37973 " <Entry text=\"Same as input\"\n"
37974 " value=\"2\" />\n"
37975 " </EnumerationDomain>\n"
37976 " <Documentation>\n"
37977 "Select the output precision of the coordinates. **Single** sets the\n"
37978 "output to single-precision floating-point (i.e., float), **Double**\n"
37979 "sets it to double-precision floating-point (i.e., double), and\n"
37980 "**Default** sets it to the same precision as the precision of the\n"
37981 "points in the input. Defaults to ***Single***.\n"
37982 " </Documentation>\n"
37983 " </IntVectorProperty>\n"
37984 " <IntVectorProperty animateable=\"0\"\n"
37985 " command=\"SetGenerateTriangles\"\n"
37986 " default_values=\"1\"\n"
37987 " name=\"GenerateTriangles\"\n"
37988 " number_of_elements=\"1\">\n"
37989 " <Hints>\n"
37990 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
37991 " name=\"vtkHyperTreeGrid\"\n"
37992 " exclude=\"1\"\n"
37993 " mode=\"enabled_state\"/>\n"
37994 " </Hints>\n"
37995 " <BooleanDomain name=\"bool\" />\n"
37996 " <Documentation>This parameter controls whether to produce triangles in the output.\n"
37997 " Warning: Many filters do not properly handle non-triangular polygons.\n"
37998 " </Documentation>\n"
37999 " </IntVectorProperty>\n"
38000 " <IntVectorProperty animateable=\"0\"\n"
38001 " command=\"SetFastMode\"\n"
38002 " default_values=\"0\"\n"
38003 " name=\"FastMode\"\n"
38004 " number_of_elements=\"1\">\n"
38005 " <Hints>\n"
38006 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
38007 " <Expression type=\"and\">\n"
38008 "\n"
38009 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
38010 " name=\"vtkImageData\"\n"
38011 " mode=\"visibility\"/>\n"
38012 "\n"
38013 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38014 " property=\"GenerateTriangles\"\n"
38015 " value=\"1\"\n"
38016 " mode=\"enabled_state\"/>\n"
38017 " </Expression>\n"
38018 " </PropertyWidgetDecorator>\n"
38019 " </Hints>\n"
38020 " <BooleanDomain name=\"bool\"/>\n"
38021 " <Documentation>\n"
38022 " This parameter controls whether to use Fast Mode or not.\n"
38023 " Fast Mode is only applicable to vtkImageData input and when GenerateTriangles is on.\n"
38024 " Fast Mode is much faster but it may produce degenerate triangles.\n"
38025 " </Documentation>\n"
38026 " </IntVectorProperty>\n"
38027 " <IntVectorProperty command=\"SetHTGStrategy3D\"\n"
38028 " name=\"HTGStrategy3D\"\n"
38029 " label=\"Contour strategy (3D)\"\n"
38030 " number_of_elements=\"1\"\n"
38031 " default_values=\"0\">\n"
38032 " <EnumerationDomain name=\"enum\">\n"
38033 " <Entry text=\"Use Voxels\" value=\"0\" />\n"
38034 " <Entry text=\"Use Decomposed Polyhedra\" value=\"1\" />\n"
38035 " </EnumerationDomain>\n"
38036 " <Hints>\n"
38037 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
38038 " name=\"vtkHyperTreeGrid\"\n"
38039 " mode=\"visibility\" />\n"
38040 " </Hints>\n"
38041 " <Documentation>\n"
38042 " Choose the contour strategy to apply (3D case only). **IMPORTANT**: the\n"
38043 " **Use Decomposed Polyhedra** strategy generally leads to better results\n"
38044 " but can take significantly more time to complete.\n"
38045 " </Documentation>\n"
38046 " </IntVectorProperty>\n"
38047 " <IntVectorProperty command=\"SetUseImplicitArraysHTG\"\n"
38048 " name=\"UseImplicitArraysHTG\"\n"
38049 " label=\"Reduce Output Memory Usage\"\n"
38050 " number_of_elements=\"1\"\n"
38051 " default_values=\"0\"\n"
38052 " panel_visibility=\"advanced\">\n"
38053 " <BooleanDomain name=\"bool\"/>\n"
38054 " <Hints>\n"
38055 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
38056 " name=\"vtkHyperTreeGrid\"\n"
38057 " mode=\"visibility\" />\n"
38058 " </Hints>\n"
38059 " <Documentation>\n"
38060 " If checked, the filter will optimize the space allocated to store the contour values.\n"
38061 " This option can lower the memory consumption, especially if the output contour\n"
38062 " contains a lot of points and is generated with few contour values, at the cost of some\n"
38063 " extra computation. Note that this option will do nothing if there are more than 256\n"
38064 " contour values.\n"
38065 " </Documentation>\n"
38066 " </IntVectorProperty>\n"
38067 " <DoubleVectorProperty animateable=\"1\"\n"
38068 " command=\"SetValue\"\n"
38069 " label=\"Isosurfaces\"\n"
38070 " name=\"ContourValues\"\n"
38071 " number_of_elements=\"0\"\n"
38072 " number_of_elements_per_command=\"1\"\n"
38073 " repeat_command=\"1\"\n"
38074 " set_number_command=\"SetNumberOfContours\"\n"
38075 " use_index=\"1\">\n"
38076 " <ArrayRangeDomain name=\"scalar_range\">\n"
38077 " <RequiredProperties>\n"
38078 " <Property function=\"Input\"\n"
38079 " name=\"Input\" />\n"
38080 " <Property function=\"ArraySelection\"\n"
38081 " name=\"SelectInputScalars\" />\n"
38082 " </RequiredProperties>\n"
38083 " </ArrayRangeDomain>\n"
38084 " <Documentation>This property specifies the values at which to compute\n"
38085 " isosurfaces/isolines and also the number of such\n"
38086 " values.</Documentation>\n"
38087 " </DoubleVectorProperty>\n"
38088 "\n"
38089 " <Hints>\n"
38090 " <Visibility replace_input=\"2\" />\n"
38091 " <WarnOnCreate>\n"
38092 " <DataTypeDomain name=\"input_type\">\n"
38093 " <DataType value=\"vtkImageData\" />\n"
38094 " <DataType value=\"vtkRectilinearGrid\" />\n"
38095 " <DataType value=\"vtkStructuredGrid\" />\n"
38096 " </DataTypeDomain>\n"
38097 " <MemoryUsage relative=\"10\" />\n"
38098 " <Text title=\"Potentially running out of memory\">\n"
38099 " **Contour** filter will create a polydata output and\n"
38100 " you may not have enough memory to create it.\n"
38101 " Do you want to continue?\n"
38102 " </Text>\n"
38103 " </WarnOnCreate>\n"
38104 " </Hints>\n"
38105 " <!-- incremental point locator begin -->\n"
38106 " <ProxyProperty command=\"SetLocator\"\n"
38107 " label=\"Point Merge Method\"\n"
38108 " name=\"Locator\"\n"
38109 " panel_visibility=\"advanced\" >\n"
38110 " <ProxyGroupDomain name=\"groups\">\n"
38111 " <Group name=\"incremental_point_locators\" />\n"
38112 " </ProxyGroupDomain>\n"
38113 " <ProxyListDomain name=\"proxy_list\">\n"
38114 " <Proxy group=\"incremental_point_locators\"\n"
38115 " name=\"MergePoints\" />\n"
38116 " <Proxy group=\"incremental_point_locators\"\n"
38117 " name=\"IncrementalOctreeMergePoints\" />\n"
38118 " <Proxy group=\"incremental_point_locators\"\n"
38119 " name=\"NonMergingPointLocator\" />\n"
38120 " </ProxyListDomain>\n"
38121 " <Documentation>This property specifies which incremental point locator to\n"
38122 " use for handling duplicate/coincident points.</Documentation>\n"
38123 " </ProxyProperty>\n"
38124 " <!-- incremental point locator end -->\n"
38125 "\n"
38126 " <PropertyGroup label=\"Hyper Tree Grid Contour\">\n"
38127 " <Property name=\"HTGStrategy3D\" />\n"
38128 " <Property name=\"UseImplicitArraysHTG\" />\n"
38129 " </PropertyGroup>\n"
38130 " <PropertyGroup label=\"Isosurfaces\">\n"
38131 " <Property name=\"ContourValues\" />\n"
38132 " </PropertyGroup>\n"
38133 " <PropertyGroup label=\"Point Locator\">\n"
38134 " <Property name=\"Locator\" />\n"
38135 " </PropertyGroup>\n"
38136 " <!-- End Contour -->\n"
38137 " </SourceProxy>\n"
38138 "\n"
38139 " <!-- ==================================================================== -->\n"
38140 " <SourceProxy class=\"vtkPVExtractComponent\"\n"
38141 " name=\"ExtractComponent\"\n"
38142 " label=\"Extract Component\">\n"
38143 " <Documentation long_help=\"This filter extracts a component of a multi-component attribute array.\"\n"
38144 " short_help=\"Extract Component.\"/>\n"
38145 " <InputProperty command=\"SetInputConnection\" name=\"Input\">\n"
38146 " <ProxyGroupDomain name=\"groups\">\n"
38147 " <Group name=\"sources\" />\n"
38148 " <Group name=\"filters\" />\n"
38149 " </ProxyGroupDomain>\n"
38150 " <DataTypeDomain name=\"input_type\">\n"
38151 " <DataType value=\"vtkDataSet\" />\n"
38152 " </DataTypeDomain>\n"
38153 " <InputArrayDomain name=\"input_array\">\n"
38154 " </InputArrayDomain>\n"
38155 " <Documentation>\n"
38156 " This property specifies the input of the Extract Component filter.\n"
38157 " </Documentation>\n"
38158 " </InputProperty>\n"
38159 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
38160 " element_types=\"0 0 0 0 2\"\n"
38161 " name=\"SelectInputArray\"\n"
38162 " label=\"Input Array\"\n"
38163 " number_of_elements=\"5\">\n"
38164 " <ArrayListDomain name=\"array_list\">\n"
38165 " <RequiredProperties>\n"
38166 " <Property function=\"Input\"\n"
38167 " name=\"Input\" />\n"
38168 " </RequiredProperties>\n"
38169 " </ArrayListDomain>\n"
38170 " <Documentation>\n"
38171 " This property indicates the name of the array to be extracted.\n"
38172 " </Documentation>\n"
38173 " </StringVectorProperty>\n"
38174 " <IntVectorProperty animateable=\"0\"\n"
38175 " command=\"SetInputArrayComponent\"\n"
38176 " default_values=\"0\"\n"
38177 " name=\"Component\"\n"
38178 " number_of_elements=\"1\">\n"
38179 " <NumberOfComponentsDomain name=\"comps\">\n"
38180 " <RequiredProperties>\n"
38181 " <Property function=\"Input\"\n"
38182 " name=\"Input\" />\n"
38183 " <Property function=\"ArraySelection\"\n"
38184 " name=\"SelectInputArray\" />\n"
38185 " </RequiredProperties>\n"
38186 " </NumberOfComponentsDomain>\n"
38187 " <Documentation>\n"
38188 " This property indicates the component of the array to be extracted.\n"
38189 " </Documentation>\n"
38190 " </IntVectorProperty>\n"
38191 " <StringVectorProperty command=\"SetOutputArrayName\"\n"
38192 " name=\"OutputArrayName\"\n"
38193 " label=\"Output Array Name\"\n"
38194 " default_values=\"Result\"\n"
38195 " number_of_elements=\"1\">\n"
38196 " <Documentation>\n"
38197 " This property indicates the name of the output scalar array.\n"
38198 " </Documentation>\n"
38199 ;
38200
38201 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
38203 " </StringVectorProperty>\n"
38204 " <!-- End ExtractComponent -->\n"
38205 " </SourceProxy>\n"
38206 "\n"
38207 " <!-- ==================================================================== -->\n"
38208 " <SourceProxy class=\"vtkPVExtractGhostCells\"\n"
38209 " name=\"ExtractGhostCells\"\n"
38210 " label=\"Extract Ghost Cells\">\n"
38211 " <Documentation short_help=\"Extract ghost cells so they can be visualized.\">\n"
38212 " This filter extracts the ghost cells from the input and displays them so\n"
38213 " one can inspect them visually.\n"
38214 " </Documentation>\n"
38215 "\n"
38216 " <InputProperty command=\"SetInputConnection\"\n"
38217 " name=\"Input\">\n"
38218 " <ProxyGroupDomain name=\"groups\">\n"
38219 " <Group name=\"sources\"/>\n"
38220 " <Group name=\"filters\"/>\n"
38221 " </ProxyGroupDomain>\n"
38222 " <DataTypeDomain name=\"input_type\">\n"
38223 " <DataType value=\"vtkDataSet\"/>\n"
38224 " <DataType value=\"vtkCompositeDataSet\"/>\n"
38225 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
38226 " </DataTypeDomain>\n"
38227 " </InputProperty>\n"
38228 " <StringVectorProperty name=\"ArrayName\"\n"
38229 " command=\"SetOutputGhostArrayName\"\n"
38230 " number_of_elements=\"1\"\n"
38231 " default_values=\"GhostType\">\n"
38232 " <Documentation>\n"
38233 " Name of the ghost cell array in the output.\n"
38234 " It must be different to `vtkGhostType` in order for the cells to be displayed.\n"
38235 " </Documentation>\n"
38236 " </StringVectorProperty>\n"
38237 " </SourceProxy>\n"
38238 "\n"
38239 " <!-- ==================================================================== -->\n"
38240 " <SourceProxy class=\"vtkPVExtractVOI\"\n"
38241 " label=\"Extract Subset\"\n"
38242 " name=\"ExtractGrid\">\n"
38243 " <Documentation long_help=\"Extract a subgrid from a structured grid with the option of setting subsample strides.\"\n"
38244 " short_help=\"Extract a subgrid or subsample.\">The Extract\n"
38245 " Grid filter returns a subgrid of a structured input data\n"
38246 " set (uniform rectilinear, curvilinear, or nonuniform\n"
38247 " rectilinear). The output data set type of this filter is\n"
38248 " the same as the input type.</Documentation>\n"
38249 " <InputProperty command=\"SetInputConnection\"\n"
38250 " name=\"Input\">\n"
38251 " <ProxyGroupDomain name=\"groups\">\n"
38252 " <Group name=\"sources\" />\n"
38253 " <Group name=\"filters\" />\n"
38254 " </ProxyGroupDomain>\n"
38255 " <DataTypeDomain name=\"input_type\">\n"
38256 " <DataType value=\"vtkImageData\" />\n"
38257 " <DataType value=\"vtkRectilinearGrid\" />\n"
38258 " <DataType value=\"vtkStructuredPoints\" />\n"
38259 " <DataType value=\"vtkStructuredGrid\" />\n"
38260 " </DataTypeDomain>\n"
38261 " <Documentation>This property specifies the input to the Extract Grid\n"
38262 " filter.</Documentation>\n"
38263 " </InputProperty>\n"
38264 " <IntVectorProperty command=\"SetVOI\"\n"
38265 " default_values=\"0 0 0 0 0 0\"\n"
38266 " name=\"VOI\"\n"
38267 " number_of_elements=\"6\"\n"
38268 " panel_visibility=\"default\">\n"
38269 " <ExtentDomain name=\"extent\">\n"
38270 " <RequiredProperties>\n"
38271 " <Property function=\"Input\"\n"
38272 " name=\"Input\" />\n"
38273 " </RequiredProperties>\n"
38274 " </ExtentDomain>\n"
38275 " <Documentation>This property specifies the minimum and maximum point\n"
38276 " indices along each of the I, J, and K axes; these values indicate the\n"
38277 " volume of interest (VOI). The output will have the (I,J,K) extent\n"
38278 " specified here.</Documentation>\n"
38279 " </IntVectorProperty>\n"
38280 " <IntVectorProperty animateable=\"1\"\n"
38281 " command=\"SetSampleRateI\"\n"
38282 " default_values=\"1\"\n"
38283 " name=\"SampleRateI\"\n"
38284 " number_of_elements=\"1\"\n"
38285 " panel_visibility=\"advanced\">\n"
38286 " <IntRangeDomain min=\"1\"\n"
38287 " name=\"range\" />\n"
38288 " <Documentation>This property indicates the sampling rate in the I\n"
38289 " dimension. A value greater than 1 results in subsampling; every nth\n"
38290 " index will be included in the output.</Documentation>\n"
38291 " </IntVectorProperty>\n"
38292 " <IntVectorProperty animateable=\"1\"\n"
38293 " command=\"SetSampleRateJ\"\n"
38294 " default_values=\"1\"\n"
38295 " name=\"SampleRateJ\"\n"
38296 " number_of_elements=\"1\"\n"
38297 " panel_visibility=\"advanced\">\n"
38298 " <IntRangeDomain min=\"1\"\n"
38299 " name=\"range\" />\n"
38300 " <Documentation>This property indicates the sampling rate in the J\n"
38301 " dimension. A value greater than 1 results in subsampling; every nth\n"
38302 " index will be included in the output.</Documentation>\n"
38303 " </IntVectorProperty>\n"
38304 " <IntVectorProperty animateable=\"1\"\n"
38305 " command=\"SetSampleRateK\"\n"
38306 " default_values=\"1\"\n"
38307 " name=\"SampleRateK\"\n"
38308 " number_of_elements=\"1\"\n"
38309 " panel_visibility=\"advanced\">\n"
38310 " <IntRangeDomain min=\"1\"\n"
38311 " name=\"range\" />\n"
38312 " <Documentation>This property indicates the sampling rate in the K\n"
38313 " dimension. A value greater than 1 results in subsampling; every nth\n"
38314 " index will be included in the output.</Documentation>\n"
38315 " </IntVectorProperty>\n"
38316 " <IntVectorProperty command=\"SetIncludeBoundary\"\n"
38317 " default_values=\"0\"\n"
38318 " name=\"IncludeBoundary\"\n"
38319 " number_of_elements=\"1\"\n"
38320 " panel_visibility=\"advanced\">\n"
38321 " <BooleanDomain name=\"bool\" />\n"
38322 " <Documentation>If the value of this property is 1, then if the sample\n"
38323 " rate in any dimension is greater than 1, the boundary indices of the\n"
38324 " input dataset will be passed to the output even if the boundary extent\n"
38325 " is not an even multiple of the sample rate in a given\n"
38326 " dimension.</Documentation>\n"
38327 " </IntVectorProperty>\n"
38328 " <Hints>\n"
38329 " <Visibility replace_input=\"0\" />\n"
38330 " </Hints>\n"
38331 " <!-- End ExtractGrid -->\n"
38332 " </SourceProxy>\n"
38333 "\n"
38334 " <!-- ==================================================================== -->\n"
38335 " <SourceProxy class=\"vtkPVGlyphFilter\"\n"
38336 " name=\"Glyph\">\n"
38337 " <Documentation long_help=\"This filter produces a glyph at points or cell centers in an input data set. The glyphs can be oriented and scaled by point or cell attributes of the input dataset.\"\n"
38338 " short_help=\"Generate glyphs that represent attributes in the input data set.\">\n"
38339 "The Glyph filter generates a glyph (i.e., an arrow, cone, cube, cylinder, line,\n"
38340 "sphere, or 2D glyph) at each point or cell in the input dataset. The glyphs can be\n"
38341 "oriented and scaled by the input scalar and vector arrays. If the arrays are\n"
38342 "point-centered, glyphs are placed at points in the input dataset. If the arrays\n"
38343 "are cell-centered, glyphs are placed at the center of cells in the input dataset.\n"
38344 "A transform that applies to the glyph source can be modified to change the shape\n"
38345 "of the glyph. This filter operates on any type of data set. Its output is a polygonal\n"
38346 "dataset.\n"
38347 "\n"
38348 "To use this filter, select the **Orientation Array** to orient the glyphs and the\n"
38349 "**Scale Array** to control glyph scaling if desired - each array\n"
38350 "can be set to 'No array' if orientation or scaling is not desired. When scaling\n"
38351 "by a 3-element vector array, the **Vector Scale Mode** can be set to either\n"
38352 "'Scale by Magnitude', which scales glyphs according to the vector magnitude,\n"
38353 "or 'Scale by Components', which treats each component as a separate scaling\n"
38354 "factor in the corresponding dimension, i.e., the first component is the\n"
38355 "scaling factor in the x-dimension, the second component scales the y-dimension,\n"
38356 "and the third component scales the z-dimension. An overall constant **Scale Factor**\n"
38357 "is applied following the scaling controlled by other properties of this filter.\n"
38358 "\n"
38359 "The **Glyph Mode** property controls which points in the input dataset\n"
38360 "are selected for glyphing since in most cases, glyphing all points in\n"
38361 "the input dataset can be both performance impeding as well as visually\n"
38362 "cluttered.\n"
38363 " </Documentation>\n"
38364 " <InputProperty command=\"SetInputConnection\"\n"
38365 " name=\"Input\">\n"
38366 " <ProxyGroupDomain name=\"groups\">\n"
38367 " <Group name=\"sources\" />\n"
38368 " <Group name=\"filters\" />\n"
38369 " </ProxyGroupDomain>\n"
38370 " <DataTypeDomain name=\"input_type\">\n"
38371 " <DataType value=\"vtkDataSet\" />\n"
38372 " </DataTypeDomain>\n"
38373 " <InputArrayDomain name=\"scale_array\"\n"
38374 " number_of_components=\"1,3\"\n"
38375 " optional=\"1\" />\n"
38376 " <InputArrayDomain name=\"vector_array\"\n"
38377 " number_of_components=\"3\"\n"
38378 " optional=\"1\" />\n"
38379 " <Documentation>\n"
38380 "This property specifies the input to this filter. This is the\n"
38381 "dataset from which the locations are selected to be glyphed.\n"
38382 " </Documentation>\n"
38383 " </InputProperty>\n"
38384 " <InputProperty command=\"SetSourceConnection\"\n"
38385 " label=\"Glyph Type\"\n"
38386 " name=\"Source\">\n"
38387 " <ProxyGroupDomain name=\"groups\">\n"
38388 " <Group name=\"sources\" />\n"
38389 " <Group name=\"glyph_sources\" />\n"
38390 " </ProxyGroupDomain>\n"
38391 " <DataTypeDomain name=\"input_type\">\n"
38392 " <DataType value=\"vtkPolyData\" />\n"
38393 " </DataTypeDomain>\n"
38394 " <ProxyListDomain name=\"proxy_list\">\n"
38395 " <Proxy group=\"sources\" name=\"ArrowSource\" />\n"
38396 " <Proxy group=\"sources\" name=\"ConeSource\" />\n"
38397 " <Proxy group=\"sources\" name=\"CubeSource\" />\n"
38398 " <Proxy group=\"sources\" name=\"CylinderSource\" />\n"
38399 " <Proxy group=\"sources\" name=\"LineSource\" />\n"
38400 " <Proxy group=\"sources\" name=\"SphereSource\" />\n"
38401 " <Proxy group=\"sources\" name=\"GlyphSource2D\" />\n"
38402 " </ProxyListDomain>\n"
38403 " <Hints>\n"
38404 " <ProxyPropertyWidget selected_proxy_panel_visibility=\"advanced\" />\n"
38405 " <!-- show the selected proxy's panel, only in advanced mode. -->\n"
38406 " </Hints>\n"
38407 " <Documentation>\n"
38408 "This property determines which type of glyph will be placed at the\n"
38409 "points in the input dataset.\n"
38410 " </Documentation>\n"
38411 " </InputProperty>\n"
38412 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
38413 " default_values=\"1\"\n"
38414 " element_types=\"0 0 0 0 2\"\n"
38415 " name=\"OrientationArray\"\n"
38416 " number_of_elements=\"5\">\n"
38417 " <!-- default value=1 so normals go to the right place -->\n"
38418 " <ArrayListDomain attribute_type=\"Vectors\"\n"
38419 " input_domain_name=\"vector_array\"\n"
38420 " name=\"array_list\"\n"
38421 " none_string=\"No orientation array\">\n"
38422 " <RequiredProperties>\n"
38423 " <Property function=\"Input\"\n"
38424 " name=\"Input\" />\n"
38425 " </RequiredProperties>\n"
38426 " </ArrayListDomain>\n"
38427 " <Documentation>\n"
38428 "Select the input array to use for orienting the glyphs.\n"
38429 " </Documentation>\n"
38430 " </StringVectorProperty>\n"
38431 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
38432 " default_values=\"0\"\n"
38433 " element_types=\"0 0 0 0 2\"\n"
38434 " name=\"ScaleArray\"\n"
38435 " number_of_elements=\"5\">\n"
38436 " <ArrayListDomain attribute_type=\"Scalars\"\n"
38437 " input_domain_name=\"scale_array\"\n"
38438 " name=\"array_list\"\n"
38439 " none_string=\"No scale array\">\n"
38440 " <RequiredProperties>\n"
38441 " <Property function=\"Input\"\n"
38442 " name=\"Input\" />\n"
38443 " </RequiredProperties>\n"
38444 " </ArrayListDomain>\n"
38445 " <Documentation>\n"
38446 "Select the input array to be used for scaling the glyphs. If the scale\n"
38447 "array is a vector array, you can control how the glyphs are scaled with\n"
38448 "the **Vector Scale Mode** property.\n"
38449 " </Documentation>\n"
38450 " </StringVectorProperty>\n"
38451 " <IntVectorProperty command=\"SetVectorScaleMode\"\n"
38452 " default_values=\"0\"\n"
38453 " name=\"VectorScaleMode\"\n"
38454 " number_of_elements=\"1\">\n"
38455 " <EnumerationDomain name=\"enum\">\n"
38456 " <Entry text=\"Scale by Magnitude\"\n"
38457 " value=\"0\" />\n"
38458 " <Entry text=\"Scale by Components\"\n"
38459 " value=\"1\" />\n"
38460 " </EnumerationDomain>\n"
38461 " <Documentation>\n"
38462 "Select the mode when the scaling array is a vector. **Scale by Magnitude** scales the glyph by\n"
38463 "the vector magnitude. **Scale by Components** scales glyphs by each vector component in the dimension\n"
38464 "that component represents, e.g., the x-direction is scaled by component 0, the y-direction is\n"
38465 "scaled by component 1, and so on.\n"
38466 " </Documentation>\n"
38467 " <Hints>\n"
38468 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38469 " mode=\"visibility\"\n"
38470 " property=\"ScaleArray\"\n"
38471 " number_of_components=\"3\"\n"
38472 " index=\"4\" />\n"
38473 " </Hints>\n"
38474 " </IntVectorProperty>\n"
38475 "\n"
38476 " <IntVectorProperty information_only=\"1\"\n"
38477 " name=\"ComponentSelection\"\n"
38478 " default_values=\"4\"\n"
38479 " number_of_elements=\"1\"\n"
38480 " panel_visibility=\"never\">\n"
38481 " <Documentation>\n"
38482 "Specifies array component to use. Fixed at 4 to ensure the\n"
38483 "ArrayRangeDomain is set to the vector magnitude for up to 3-component\n"
38484 "arrays.\n"
38485 " </Documentation>\n"
38486 " </IntVectorProperty>\n"
38487 " <DoubleVectorProperty command=\"SetScaleFactor\"\n"
38488 " default_values=\"1.0\"\n"
38489 " name=\"ScaleFactor\"\n"
38490 " number_of_elements=\"1\"\n"
38491 " panel_widget=\"glyph_scale_factor\">\n"
38492 " <BoundsDomain mode=\"scaled_extent\" name=\"bounds\" scale_factor=\"0.1\">\n"
38493 " <RequiredProperties>\n"
38494 " <Property function=\"Input\" name=\"Input\" />\n"
38495 " </RequiredProperties>\n"
38496 " </BoundsDomain>\n"
38497 " <ArrayRangeDomain name=\"scalar_range\">\n"
38498 " <RequiredProperties>\n"
38499 " <Property function=\"Input\" name=\"Input\" />\n"
38500 " <Property function=\"ArraySelection\" name=\"ScaleArray\" />\n"
38501 " </RequiredProperties>\n"
38502 " </ArrayRangeDomain>\n"
38503 " <ArrayRangeDomain name=\"vector_range\">\n"
38504 " <RequiredProperties>\n"
38505 " <Property function=\"Input\" name=\"Input\" />\n"
38506 " <Property function=\"ArraySelection\" name=\"OrientationArray\" />\n"
38507 " </RequiredProperties>\n"
38508 " </ArrayRangeDomain>\n"
38509 " <Documentation>Specify the constant multiplier to use to scale the glyphs.\n"
38510 ;
38511
38512 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
38514 " </Documentation>\n"
38515 " </DoubleVectorProperty>\n"
38516 " <ProxyProperty command=\"SetSourceTransform\"\n"
38517 " name=\"GlyphTransform\"\n"
38518 " panel_visibility=\"advanced\">\n"
38519 " <ProxyListDomain name=\"proxy_list\">\n"
38520 " <Proxy group=\"extended_sources\"\n"
38521 " name=\"Transform2\" />\n"
38522 " </ProxyListDomain>\n"
38523 " <Documentation>\n"
38524 "The values in this property allow you to specify the transform\n"
38525 "(translation, rotation, and scaling) to apply to the glyph\n"
38526 "source.</Documentation>\n"
38527 " </ProxyProperty>\n"
38528 "\n"
38529 " <IntVectorProperty command=\"SetGlyphMode\"\n"
38530 " default_values=\"2\"\n"
38531 " name=\"GlyphMode\"\n"
38532 " number_of_elements=\"1\"\n"
38533 " panel_visibility=\"default\">\n"
38534 " <EnumerationDomain name=\"enum\">\n"
38535 " <Entry text=\"All Points\" value=\"0\"/>\n"
38536 " <Entry text=\"Every Nth Point\" value=\"1\"/>\n"
38537 " <Entry text=\"Uniform Spatial Distribution (Bounds Based)\" value=\"2\"/>\n"
38538 " <Entry text=\"Uniform Spatial Distribution (Surface Sampling)\" value=\"3\"/>\n"
38539 " <Entry text=\"Uniform Spatial Distribution (Volume Sampling)\" value=\"4\"/>\n"
38540 " </EnumerationDomain>\n"
38541 " <Documentation>\n"
38542 "This property indicates the mode that will be used to generate\n"
38543 "glyphs from the dataset.\n"
38544 " </Documentation>\n"
38545 " </IntVectorProperty>\n"
38546 " <IntVectorProperty command=\"SetMaximumNumberOfSamplePoints\"\n"
38547 " number_of_elements=\"1\"\n"
38548 " default_values=\"5000\"\n"
38549 " name=\"MaximumNumberOfSamplePoints\">\n"
38550 " <IntRangeDomain min=\"1\" name=\"range\" />\n"
38551 " <Documentation>\n"
38552 "This property specifies the maximum number of sample points to use\n"
38553 "when sampling the space when Uniform Spatial Distribution is used.\n"
38554 " </Documentation>\n"
38555 " <Hints>\n"
38556 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
38557 " <Expression type=\"or\">\n"
38558 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"GlyphMode\" value=\"2\" inverse=\"0\" />\n"
38559 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"GlyphMode\" value=\"3\" inverse=\"0\" />\n"
38560 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"GlyphMode\" value=\"4\" inverse=\"0\" />\n"
38561 " </Expression>\n"
38562 " </PropertyWidgetDecorator>\n"
38563 " <!-- show this widget when GlyphMode==2||3||4 -->\n"
38564 " </Hints>\n"
38565 " </IntVectorProperty>\n"
38566 " <IntVectorProperty command=\"SetSeed\"\n"
38567 " number_of_elements=\"1\"\n"
38568 " default_values=\"10339\"\n"
38569 " name=\"Seed\">\n"
38570 " <IntRangeDomain min=\"1\" name=\"range\"/>\n"
38571 " <Documentation>\n"
38572 "This property specifies the seed that will be used for generating a\n"
38573 "uniform distribution of glyph points when a Uniform Spatial\n"
38574 "Distribution is used.\n"
38575 " </Documentation>\n"
38576 " <Hints>\n"
38577 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
38578 " <Expression type=\"or\">\n"
38579 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"GlyphMode\" value=\"2\" inverse=\"0\" />\n"
38580 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"GlyphMode\" value=\"3\" inverse=\"0\" />\n"
38581 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"GlyphMode\" value=\"4\" inverse=\"0\" />\n"
38582 " </Expression>\n"
38583 " </PropertyWidgetDecorator>\n"
38584 " <!-- show this widget when GlyphMode==2||3||4 -->\n"
38585 " </Hints>\n"
38586 " </IntVectorProperty>\n"
38587 " <IntVectorProperty command=\"SetStride\"\n"
38588 " number_of_elements=\"1\"\n"
38589 " default_values=\"1\"\n"
38590 " name=\"Stride\">\n"
38591 " <IntRangeDomain min=\"1\" name=\"range\"/>\n"
38592 " <Documentation>\n"
38593 "This property specifies the stride that will be used when glyphing by\n"
38594 "Every Nth Point.\n"
38595 " </Documentation>\n"
38596 " <Hints>\n"
38597 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38598 " mode=\"visibility\"\n"
38599 " property=\"GlyphMode\"\n"
38600 " value=\"1\" />\n"
38601 " <!-- show this widget when GlyphMode==1 -->\n"
38602 " </Hints>\n"
38603 " </IntVectorProperty>\n"
38604 "\n"
38605 " <PropertyGroup label=\"Glyph Source\">\n"
38606 " <Property name=\"Source\" />\n"
38607 " </PropertyGroup>\n"
38608 " <PropertyGroup label=\"Orientation\">\n"
38609 " <Property name=\"OrientationArray\" />\n"
38610 " </PropertyGroup>\n"
38611 " <PropertyGroup label=\"Scale\">\n"
38612 " <Property name=\"ScaleArray\" />\n"
38613 " <Property name=\"VectorScaleMode\" />\n"
38614 " <Property name=\"ScaleFactor\" />\n"
38615 " </PropertyGroup>\n"
38616 " <PropertyGroup label=\"Glyph Transform\">\n"
38617 " <Property name=\"GlyphTransform\" />\n"
38618 " </PropertyGroup>\n"
38619 " <PropertyGroup label=\"Masking\">\n"
38620 " <Property name=\"GlyphMode\" />\n"
38621 " <Property name=\"MaximumNumberOfSamplePoints\" />\n"
38622 " <Property name=\"Seed\" />\n"
38623 " <Property name=\"Stride\" />\n"
38624 " </PropertyGroup>\n"
38625 "\n"
38626 " <Hints>\n"
38627 " <!-- Visibility Element can be used to suggest the GUI about\n"
38628 " visibility of this filter (or its input) on creation.\n"
38629 " replace_input=\"0\" implies that the input visibility is not\n"
38630 " changed on creation of this filter (defaults to \"1\")\n"
38631 " -->\n"
38632 " <Visibility replace_input=\"0\" />\n"
38633 " <WarnOnCreate>\n"
38634 " <DataTypeDomain name=\"input_type\">\n"
38635 " <DataType value=\"vtkDataSet\" />\n"
38636 " </DataTypeDomain>\n"
38637 " <MemoryUsage relative=\"500\" />\n"
38638 " <Text title=\"Potentially running out of memory\">\n"
38639 " **Glyph** filter will create one geometry by point\n"
38640 " if configured as such in the \"Glyph Mode\" property,\n"
38641 " which you may not have enough memory to do.\n"
38642 " Do you want to continue?\n"
38643 " </Text>\n"
38644 " </WarnOnCreate>\n"
38645 " </Hints>\n"
38646 " <!-- End Glyph -->\n"
38647 " </SourceProxy>\n"
38648 "\n"
38649 " <!-- ==================================================================== -->\n"
38650 " <SourceProxy class=\"vtkPVGlyphFilter\"\n"
38651 " name=\"GlyphWithCustomSource\"\n"
38652 " label=\"Glyph With Custom Source\">\n"
38653 " The glyph is provided as the **Source** input to this filter.\n"
38654 " <Documentation long_help=\"This filter produces a glyph at points or cell centers in an input data set. The glyphs can be oriented and scaled by point or cell attributes of the input dataset.\"\n"
38655 " short_help=\"Generate glyphs that represent attributes in the input data set.\">\n"
38656 "The **Glyph With Custom Source** filter generates a glyph specified as the **Source**\n"
38657 "input to this filter at each point in the input dataset. The glyphs can be\n"
38658 "oriented and scaled by the input scalar and vector arrays. If the arrays are\n"
38659 "point-centered, glyphs are placed at points in the input dataset. If the arrays\n"
38660 "are cell-centered, glyphs are placed at the center of cells in the input dataset.\n"
38661 "A transform that applies to the glyph source can be modified to change the shape\n"
38662 "of the glyph. This filter operates on any type of data set. Its output is a polygonal\n"
38663 "dataset.\n"
38664 "\n"
38665 "To use this filter, select the **Orientation Array** to orient the glyphs and the\n"
38666 "**Scale Array** to control glyph scaling if desired - each array\n"
38667 "can be set to 'No array' if orientation or scaling is not desired. When scaling\n"
38668 "by a 3-element vector array, the **Vector Scale Mode** can be set to either\n"
38669 "'Scale by Magnitude', which scales glyphs according to the vector magnitude,\n"
38670 "or 'Scale by Components', which treats each component as a separate scaling\n"
38671 "factor in the corresponding dimension, i.e., the first component is the\n"
38672 "scaling factor in the x-dimension, the second component scales the y-dimension,\n"
38673 "and the third component scales the z-dimension. An overall constant **Scale Factor**\n"
38674 "is applied following the scaling controlled by other properties of this filter.\n"
38675 "\n"
38676 "The **Glyph Mode** property controls which points in the input dataset\n"
38677 "are selected for glyphing since in most cases, glyphing all points in\n"
38678 "the input dataset can be both performance impeding as well as visually\n"
38679 "cluttered.\n"
38680 " </Documentation>\n"
38681 " <InputProperty command=\"SetInputConnection\"\n"
38682 " name=\"Input\">\n"
38683 " <ProxyGroupDomain name=\"groups\">\n"
38684 " <Group name=\"sources\" />\n"
38685 " <Group name=\"filters\" />\n"
38686 " </ProxyGroupDomain>\n"
38687 " <DataTypeDomain name=\"input_type\">\n"
38688 " <DataType value=\"vtkDataSet\" />\n"
38689 " </DataTypeDomain>\n"
38690 " <InputArrayDomain name=\"scale_array\"\n"
38691 " number_of_components=\"1,3\"\n"
38692 " optional=\"1\" />\n"
38693 " <InputArrayDomain name=\"vector_array\"\n"
38694 " number_of_components=\"3\"\n"
38695 " optional=\"1\" />\n"
38696 " <Documentation>\n"
38697 "This property specifies the input to this filter. This is the\n"
38698 "dataset from which the locations are selected to be glyphed.\n"
38699 " </Documentation>\n"
38700 " </InputProperty>\n"
38701 " <InputProperty command=\"SetSourceConnection\"\n"
38702 " label=\"Glyph Source\"\n"
38703 " name=\"Source\">\n"
38704 " <ProxyGroupDomain name=\"groups\">\n"
38705 " <Group name=\"sources\" />\n"
38706 " <Group name=\"glyph_sources\" />\n"
38707 " </ProxyGroupDomain>\n"
38708 " <DataTypeDomain name=\"input_type\">\n"
38709 " <DataType value=\"vtkPolyData\" />\n"
38710 " </DataTypeDomain>\n"
38711 " <Documentation>\n"
38712 "This property determines the glyph geometry source that will be\n"
38713 "placed at the points in the input dataset.\n"
38714 " </Documentation>\n"
38715 " <Hints>\n"
38716 " <ProxyPropertyWidget selected_proxy_panel_visibility=\"advanced\" />\n"
38717 " <!-- show the selected proxy's panel, only in advanced mode. -->\n"
38718 " </Hints>\n"
38719 " <Documentation>\n"
38720 "This property determines which glyph will be placed at the\n"
38721 "points in the input dataset.\n"
38722 " </Documentation>\n"
38723 " </InputProperty>\n"
38724 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
38725 " default_values=\"1\"\n"
38726 " element_types=\"0 0 0 0 2\"\n"
38727 " name=\"OrientationArray\"\n"
38728 " number_of_elements=\"5\">\n"
38729 " <!-- default value=1 so normals go to the right place -->\n"
38730 " <ArrayListDomain attribute_type=\"Vectors\"\n"
38731 " input_domain_name=\"vector_array\"\n"
38732 " name=\"array_list\"\n"
38733 " none_string=\"No orientation array\">\n"
38734 " <RequiredProperties>\n"
38735 " <Property function=\"Input\"\n"
38736 " name=\"Input\" />\n"
38737 " </RequiredProperties>\n"
38738 " </ArrayListDomain>\n"
38739 " <Documentation>\n"
38740 "Select the input array to use for orienting the glyphs.\n"
38741 " </Documentation>\n"
38742 " </StringVectorProperty>\n"
38743 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
38744 " default_values=\"0\"\n"
38745 " element_types=\"0 0 0 0 2\"\n"
38746 " name=\"ScaleArray\"\n"
38747 " number_of_elements=\"5\">\n"
38748 " <ArrayListDomain attribute_type=\"Scalars\"\n"
38749 " input_domain_name=\"scale_array\"\n"
38750 " name=\"array_list\"\n"
38751 " none_string=\"No scale array\">\n"
38752 " <RequiredProperties>\n"
38753 " <Property function=\"Input\"\n"
38754 " name=\"Input\" />\n"
38755 " </RequiredProperties>\n"
38756 " </ArrayListDomain>\n"
38757 " <Documentation>\n"
38758 "Select the input array to be used for scaling the glyphs. If the scale\n"
38759 "array is a vector array, you can control how the glyphs are scaled with\n"
38760 "the **Vector Scale Mode** property.\n"
38761 " </Documentation>\n"
38762 " </StringVectorProperty>\n"
38763 " <IntVectorProperty command=\"SetVectorScaleMode\"\n"
38764 " default_values=\"0\"\n"
38765 " name=\"VectorScaleMode\"\n"
38766 " number_of_elements=\"1\">\n"
38767 " <EnumerationDomain name=\"enum\">\n"
38768 " <Entry text=\"Scale by Magnitude\"\n"
38769 " value=\"0\" />\n"
38770 " <Entry text=\"Scale by Components\"\n"
38771 " value=\"1\" />\n"
38772 " </EnumerationDomain>\n"
38773 " <Documentation>\n"
38774 "Select the mode when the scaling array is a vector. **Scale by Magnitude** scales the glyph by\n"
38775 "the vector magnitude. **Scale by Components** scales glyphs by each vector component in the dimension\n"
38776 "that component represents, e.g., the x-direction is scaled by component 0, the y-direction is\n"
38777 "scaled by component 1, and so on.\n"
38778 " </Documentation>\n"
38779 " <Hints>\n"
38780 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38781 " mode=\"visibility\"\n"
38782 " property=\"ScaleArray\"\n"
38783 " number_of_components=\"3\"\n"
38784 " index=\"4\" />\n"
38785 " </Hints>\n"
38786 " </IntVectorProperty>\n"
38787 "\n"
38788 " <IntVectorProperty information_only=\"1\"\n"
38789 " name=\"ComponentSelection\"\n"
38790 " default_values=\"4\"\n"
38791 " number_of_elements=\"1\"\n"
38792 " panel_visibility=\"never\">\n"
38793 " <Documentation>\n"
38794 "Specifies array component to use. Fixed at 4 to ensure the\n"
38795 "ArrayRangeDomain is set to the vector magnitude for up to 3-component\n"
38796 "arrays.\n"
38797 " </Documentation>\n"
38798 " </IntVectorProperty>\n"
38799 " <DoubleVectorProperty command=\"SetScaleFactor\"\n"
38800 " default_values=\"1.0\"\n"
38801 " name=\"ScaleFactor\"\n"
38802 " number_of_elements=\"1\"\n"
38803 " panel_widget=\"glyph_scale_factor\">\n"
38804 " <BoundsDomain mode=\"scaled_extent\" name=\"bounds\" scale_factor=\"0.1\">\n"
38805 " <RequiredProperties>\n"
38806 " <Property function=\"Input\" name=\"Input\" />\n"
38807 " </RequiredProperties>\n"
38808 " </BoundsDomain>\n"
38809 " <ArrayRangeDomain name=\"scalar_range\">\n"
38810 " <RequiredProperties>\n"
38811 " <Property function=\"Input\" name=\"Input\" />\n"
38812 " <Property function=\"ArraySelection\" name=\"ScaleArray\" />\n"
38813 " </RequiredProperties>\n"
38814 " </ArrayRangeDomain>\n"
38815 " <ArrayRangeDomain name=\"vector_range\">\n"
38816 " <RequiredProperties>\n"
38817 " <Property function=\"Input\" name=\"Input\" />\n"
38818 " <Property function=\"ArraySelection\" name=\"OrientationArray\" />\n"
38819 " </RequiredProperties>\n"
38820 " </ArrayRangeDomain>\n"
38821 " <Documentation>Specify the constant multiplier to use to scale the glyphs.\n"
38822 " </Documentation>\n"
38823 " </DoubleVectorProperty>\n"
38824 " <ProxyProperty command=\"SetSourceTransform\"\n"
38825 " name=\"GlyphTransform\"\n"
38826 " panel_visibility=\"advanced\">\n"
38827 " <ProxyListDomain name=\"proxy_list\">\n"
38828 ;
38829
38830 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
38832 " <Proxy group=\"extended_sources\"\n"
38833 " name=\"Transform2\" />\n"
38834 " </ProxyListDomain>\n"
38835 " <Documentation>\n"
38836 "The values in this property allow you to specify the transform\n"
38837 "(translation, rotation, and scaling) to apply to the glyph\n"
38838 "source.</Documentation>\n"
38839 " </ProxyProperty>\n"
38840 "\n"
38841 " <IntVectorProperty command=\"SetGlyphMode\"\n"
38842 " default_values=\"2\"\n"
38843 " name=\"GlyphMode\"\n"
38844 " number_of_elements=\"1\"\n"
38845 " panel_visibility=\"default\">\n"
38846 " <EnumerationDomain name=\"enum\">\n"
38847 " <Entry text=\"All Points\" value=\"0\"/>\n"
38848 " <Entry text=\"Every Nth Point\" value=\"1\"/>\n"
38849 " <Entry text=\"Uniform Spatial Distribution\" value=\"2\"/>\n"
38850 " </EnumerationDomain>\n"
38851 " <Documentation>\n"
38852 "This property indicates the mode that will be used to generate\n"
38853 "glyphs from the dataset.\n"
38854 " </Documentation>\n"
38855 " </IntVectorProperty>\n"
38856 " <IntVectorProperty command=\"SetMaximumNumberOfSamplePoints\"\n"
38857 " number_of_elements=\"1\"\n"
38858 " default_values=\"5000\"\n"
38859 " name=\"MaximumNumberOfSamplePoints\">\n"
38860 " <IntRangeDomain min=\"1\" name=\"range\" />\n"
38861 " <Documentation>\n"
38862 "This property specifies the maximum number of sample points to use\n"
38863 "when sampling the space when Uniform Spatial Distribution is used.\n"
38864 " </Documentation>\n"
38865 " <Hints>\n"
38866 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38867 " mode=\"visibility\"\n"
38868 " property=\"GlyphMode\"\n"
38869 " value=\"2\" />\n"
38870 " <!-- show this widget when GlyphMode==2 -->\n"
38871 " </Hints>\n"
38872 " </IntVectorProperty>\n"
38873 " <IntVectorProperty command=\"SetSeed\"\n"
38874 " number_of_elements=\"1\"\n"
38875 " default_values=\"10339\"\n"
38876 " name=\"Seed\">\n"
38877 " <IntRangeDomain min=\"1\" name=\"range\"/>\n"
38878 " <Documentation>\n"
38879 "This property specifies the seed that will be used for generating a\n"
38880 "uniform distribution of glyph points when a Uniform Spatial\n"
38881 "Distribution is used.\n"
38882 " </Documentation>\n"
38883 " <Hints>\n"
38884 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38885 " mode=\"visibility\"\n"
38886 " property=\"GlyphMode\"\n"
38887 " value=\"2\" />\n"
38888 " <!-- show this widget when GlyphMode==2 -->\n"
38889 " </Hints>\n"
38890 " </IntVectorProperty>\n"
38891 " <IntVectorProperty command=\"SetStride\"\n"
38892 " number_of_elements=\"1\"\n"
38893 " default_values=\"1\"\n"
38894 " name=\"Stride\">\n"
38895 " <IntRangeDomain min=\"1\" name=\"range\"/>\n"
38896 " <Documentation>\n"
38897 "This property specifies the stride that will be used when glyphing by\n"
38898 "Every Nth Point.\n"
38899 " </Documentation>\n"
38900 " <Hints>\n"
38901 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
38902 " mode=\"visibility\"\n"
38903 " property=\"GlyphMode\"\n"
38904 " value=\"1\" />\n"
38905 " <!-- show this widget when GlyphMode==1 -->\n"
38906 " </Hints>\n"
38907 " </IntVectorProperty>\n"
38908 "\n"
38909 " <PropertyGroup label=\"Glyph Source\">\n"
38910 " <Property name=\"Source\" />\n"
38911 " </PropertyGroup>\n"
38912 " <PropertyGroup label=\"Orientation\">\n"
38913 " <Property name=\"OrientationArray\" />\n"
38914 " </PropertyGroup>\n"
38915 " <PropertyGroup label=\"Scale\">\n"
38916 " <Property name=\"ScaleArray\" />\n"
38917 " <Property name=\"VectorScaleMode\" />\n"
38918 " <Property name=\"ScaleFactor\" />\n"
38919 " </PropertyGroup>\n"
38920 " <PropertyGroup label=\"Glyph Transform\">\n"
38921 " <Property name=\"GlyphTransform\" />\n"
38922 " </PropertyGroup>\n"
38923 " <PropertyGroup label=\"Masking\">\n"
38924 " <Property name=\"GlyphMode\" />\n"
38925 " <Property name=\"MaximumNumberOfSamplePoints\" />\n"
38926 " <Property name=\"Seed\" />\n"
38927 " <Property name=\"Stride\" />\n"
38928 " </PropertyGroup>\n"
38929 "\n"
38930 " <Hints>\n"
38931 " <!-- Visibility Element can be used to suggest the GUI about\n"
38932 " visibility of this filter (or its input) on creation.\n"
38933 " replace_input=\"0\" implies that the input visibility is not\n"
38934 " changed on creation of this filter (defaults to \"1\")\n"
38935 " -->\n"
38936 " <Visibility replace_input=\"0\" />\n"
38937 " </Hints>\n"
38938 " <!-- End Glyph -->\n"
38939 " </SourceProxy>\n"
38940 "\n"
38941 " <!-- ==================================================================== -->\n"
38942 " <SourceProxy class=\"vtkPVGradientFilter\"\n"
38943 " label=\"Gradient\"\n"
38944 " name=\"Gradient\">\n"
38945 " <Documentation long_help=\"Estimate the gradient for each point or cell in any type of dataset.\"\n"
38946 " short_help=\"Compute the gradient for any type of dataset.\">\n"
38947 " The Gradient filter estimates the gradient vector at each\n"
38948 " point or cell. It operates on any type of vtkDataSet, and\n"
38949 " the output is of the same type as the input.\n"
38950 " For unstructured grids, the gradient is computed with the\n"
38951 " cell derivatives. For structured grids, the gradient is computed\n"
38952 " using central differencing, except on the boundary of the\n"
38953 " dataset where forward and backward differencing is used for\n"
38954 " the boundary elements.\n"
38955 " If the dataset is a vtkImageData, the gradient computation\n"
38956 " at the boundaries can also be done with central differencing\n"
38957 " using a duplication of the boundary values, smoothing out\n"
38958 " the result (see 'Boundary Method' property).\n"
38959 " </Documentation>\n"
38960 " <InputProperty command=\"SetInputConnection\"\n"
38961 " name=\"Input\">\n"
38962 " <ProxyGroupDomain name=\"groups\">\n"
38963 " <Group name=\"sources\" />\n"
38964 " <Group name=\"filters\" />\n"
38965 " </ProxyGroupDomain>\n"
38966 " <DataTypeDomain name=\"input_type\">\n"
38967 " <DataType value=\"vtkDataSet\" />\n"
38968 " <DataType value=\"vtkHyperTreeGrid\" />\n"
38969 " </DataTypeDomain>\n"
38970 " <InputArrayDomain name=\"input_array\" />\n"
38971 " <Documentation>\n"
38972 " Specify the input to the Gradient filter.\n"
38973 " </Documentation>\n"
38974 " </InputProperty>\n"
38975 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
38976 " element_types=\"0 0 0 0 2\"\n"
38977 " label=\"Scalar Array\"\n"
38978 " name=\"SelectInputScalars\"\n"
38979 " number_of_elements=\"5\">\n"
38980 " <ArrayListDomain attribute_type=\"Scalars\"\n"
38981 " name=\"array_list\">\n"
38982 " <RequiredProperties>\n"
38983 " <Property function=\"Input\"\n"
38984 " name=\"Input\" />\n"
38985 " </RequiredProperties>\n"
38986 " </ArrayListDomain>\n"
38987 " <Documentation>\n"
38988 " Specify the name of the scalar array from which to compute the gradient.\n"
38989 " </Documentation>\n"
38990 " </StringVectorProperty>\n"
38991 " <IntVectorProperty command=\"SetBoundaryMethod\"\n"
38992 " default_values=\"1\"\n"
38993 " name=\"BoundaryMethod\"\n"
38994 " number_of_elements=\"1\">\n"
38995 " <EnumerationDomain name=\"enum\">\n"
38996 " <Entry text=\"Smoothed\"\n"
38997 " value=\"0\" />\n"
38998 " <Entry text=\"Non-Smoothed\"\n"
38999 " value=\"1\" />\n"
39000 " </EnumerationDomain>\n"
39001 " <Hints>\n"
39002 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39003 " name=\"vtkImageData\"\n"
39004 " mode=\"visibility\" />\n"
39005 " </Hints>\n"
39006 " <Documentation>\n"
39007 " Specify how to compute the gradient on the boundaries.\n"
39008 " 'Smoothed' uses central differencing by duplicating the boundary values\n"
39009 " to compute the gradient on the boundary elements (corresponds to the\n"
39010 " old 'Gradient' filter). 'Non-Smoothed' uses forward/backward differencing\n"
39011 " with the values of a boundary element and its neighbor to compute the\n"
39012 " gradient (corresponds to the old 'Gradient Of Unstructured DataSet' filter).\n"
39013 " </Documentation>\n"
39014 " </IntVectorProperty>\n"
39015 " <IntVectorProperty command=\"SetDimensionality\"\n"
39016 " default_values=\"3\"\n"
39017 " name=\"Dimensionality\"\n"
39018 " number_of_elements=\"1\">\n"
39019 " <EnumerationDomain name=\"enum\">\n"
39020 " <Entry text=\"Two\"\n"
39021 " value=\"2\" />\n"
39022 " <Entry text=\"Three\"\n"
39023 " value=\"3\" />\n"
39024 " </EnumerationDomain>\n"
39025 " <Hints>\n"
39026 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39027 " name=\"vtkImageData\"\n"
39028 " mode=\"visibility\" />\n"
39029 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39030 " property=\"BoundaryMethod\"\n"
39031 " value=\"0\"\n"
39032 " mode=\"enabled_state\" />\n"
39033 " </Hints>\n"
39034 " <Documentation>\n"
39035 " Specify whether to compute the gradient in two or three dimensions.\n"
39036 " In two dimensions, the X and Y dimensions are used.\n"
39037 " </Documentation>\n"
39038 " </IntVectorProperty>\n"
39039 " <IntVectorProperty command=\"SetHTGMode\"\n"
39040 " default_values=\"0\"\n"
39041 " name=\"HTGMode\"\n"
39042 " number_of_elements=\"1\">\n"
39043 " <EnumerationDomain name=\"enum\">\n"
39044 " <Entry text=\"Unlimited\"\n"
39045 " value=\"0\" />\n"
39046 " <Entry text=\"Unstructured\"\n"
39047 " value=\"1\" />\n"
39048 " </EnumerationDomain>\n"
39049 " <Hints>\n"
39050 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39051 " name=\"vtkHyperTreeGrid\"\n"
39052 " mode=\"visibility\" />\n"
39053 " </Hints>\n"
39054 " <Documentation>\n"
39055 " Specify how to compute the gradient on a Hypertree Grid.\n"
39056 " 'Unlimited' handles the resolution change by virtually subdividing\n"
39057 " coarser cells and eventually applyging a ratio.\n"
39058 " 'Unstructured' operate like the AMR like if it was an unstructured\n"
39059 " mesh, which may give a higher weight to coarser cells.\n"
39060 " </Documentation>\n"
39061 " </IntVectorProperty>\n"
39062 " <IntVectorProperty command=\"SetHTGExtensiveComputation\"\n"
39063 " default_values=\"0\"\n"
39064 " name=\"ExtensiveComputation\"\n"
39065 " number_of_elements=\"1\"\n"
39066 " panel_visibility=\"default\">\n"
39067 " <BooleanDomain name=\"bool\" />\n"
39068 " <Hints>\n"
39069 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39070 " <Expression type=\"and\">\n"
39071 "\n"
39072 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39073 " name=\"vtkHyperTreeGrid\"\n"
39074 " mode=\"visibility\" />\n"
39075 "\n"
39076 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39077 " property=\"HTGMode\"\n"
39078 " value=\"0\"\n"
39079 " mode=\"enabled_state\" />\n"
39080 " </Expression>\n"
39081 " </PropertyWidgetDecorator>\n"
39082 " </Hints>\n"
39083 " <Documentation>\n"
39084 " Use the extensive ratio during the Hyper Tree Grid gradient computation.\n"
39085 " This property only work in UNLIMITED mode.\n"
39086 " </Documentation>\n"
39087 " </IntVectorProperty>\n"
39088 " <IntVectorProperty command=\"SetComputeGradient\"\n"
39089 " default_values=\"1\"\n"
39090 " name=\"ComputeGradient\"\n"
39091 " number_of_elements=\"1\"\n"
39092 " panel_visibility=\"advanced\">\n"
39093 " <BooleanDomain name=\"bool\" />\n"
39094 " <Hints>\n"
39095 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39096 " <Expression type=\"or\">\n"
39097 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39098 " name=\"vtkImageData\"\n"
39099 " exclude=\"1\"\n"
39100 " mode=\"enabled_state\" />\n"
39101 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39102 " property=\"BoundaryMethod\"\n"
39103 " value=\"1\"\n"
39104 " mode=\"enabled_state\" />\n"
39105 " </Expression>\n"
39106 " </PropertyWidgetDecorator>\n"
39107 " </Hints>\n"
39108 " <Documentation>\n"
39109 " If on, the gradient of the input array is computed.\n"
39110 " </Documentation>\n"
39111 " </IntVectorProperty>\n"
39112 " <StringVectorProperty command=\"SetResultArrayName\"\n"
39113 " default_values=\"Gradient\"\n"
39114 " name=\"ResultArrayName\"\n"
39115 " number_of_elements=\"1\">\n"
39116 " <Hints>\n"
39117 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39118 " <Expression type=\"or\">\n"
39119 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39120 " name=\"vtkImageData\"\n"
39121 " exclude=\"1\"\n"
39122 " mode=\"enabled_state\" />\n"
39123 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39124 " property=\"BoundaryMethod\"\n"
39125 " value=\"1\"\n"
39126 " mode=\"enabled_state\" />\n"
39127 " </Expression>\n"
39128 " </PropertyWidgetDecorator>\n"
39129 " </Hints>\n"
39130 " <Documentation>\n"
39131 " Provide a name for the output array containing the gradient vectors.\n"
39132 " </Documentation>\n"
39133 " </StringVectorProperty>\n"
39134 " <IntVectorProperty command=\"SetFasterApproximation\"\n"
39135 " default_values=\"0\"\n"
39136 " name=\"FasterApproximation\"\n"
39137 " number_of_elements=\"1\"\n"
39138 " panel_visibility=\"advanced\">\n"
39139 " <BooleanDomain name=\"bool\" />\n"
39140 " <Hints>\n"
39141 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39142 " <Expression type=\"and\">\n"
39143 "\n"
39144 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39145 " name=\"vtkHyperTreeGrid\"\n"
39146 " mode=\"visibility\"\n"
39147 " exclude=\"1\" />\n"
39148 "\n"
39149 " <Expression type=\"or\">\n"
39150 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39151 " name=\"vtkImageData\"\n"
39152 " exclude=\"1\"\n"
39153 " mode=\"enabled_state\" />\n"
39154 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39155 " property=\"BoundaryMethod\"\n"
39156 ;
39157
39158 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
39160 " value=\"1\"\n"
39161 " mode=\"enabled_state\" />\n"
39162 " </Expression>\n"
39163 " </Expression>\n"
39164 " </PropertyWidgetDecorator>\n"
39165 " </Hints>\n"
39166 " <Documentation>\n"
39167 " If on, the Gradient filter will provide a less accurate (but close)\n"
39168 " algorithm that performs fewer derivative calculations (and is therefore\n"
39169 " faster). The error contains some smoothing of the output data and some\n"
39170 " possible errors on the boundary. Has no effect when performing the\n"
39171 " gradient of cell data or when the input grid is not a vtkUnstructuredGrid.\n"
39172 " </Documentation>\n"
39173 " </IntVectorProperty>\n"
39174 " <IntVectorProperty command=\"SetComputeDivergence\"\n"
39175 " default_values=\"0\"\n"
39176 " name=\"ComputeDivergence\"\n"
39177 " number_of_elements=\"1\"\n"
39178 " panel_visibility=\"advanced\">\n"
39179 " <BooleanDomain name=\"bool\" />\n"
39180 " <Hints>\n"
39181 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39182 " <Expression type=\"or\">\n"
39183 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39184 " name=\"vtkImageData\"\n"
39185 " exclude=\"1\"\n"
39186 " mode=\"enabled_state\" />\n"
39187 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39188 " property=\"BoundaryMethod\"\n"
39189 " value=\"1\"\n"
39190 " mode=\"enabled_state\" />\n"
39191 " </Expression>\n"
39192 " </PropertyWidgetDecorator>\n"
39193 " </Hints>\n"
39194 " <Documentation>\n"
39195 " If on, the divergence of a 3-component array is computed.\n"
39196 " </Documentation>\n"
39197 " </IntVectorProperty>\n"
39198 " <StringVectorProperty command=\"SetDivergenceArrayName\"\n"
39199 " default_values=\"Divergence\"\n"
39200 " name=\"DivergenceArrayName\"\n"
39201 " number_of_elements=\"1\"\n"
39202 " panel_visibility=\"advanced\">\n"
39203 " <Hints>\n"
39204 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39205 " <Expression type=\"or\">\n"
39206 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39207 " name=\"vtkImageData\"\n"
39208 " exclude=\"1\"\n"
39209 " mode=\"enabled_state\" />\n"
39210 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39211 " property=\"BoundaryMethod\"\n"
39212 " value=\"1\"\n"
39213 " mode=\"enabled_state\" />\n"
39214 " </Expression>\n"
39215 " </PropertyWidgetDecorator>\n"
39216 " </Hints>\n"
39217 " <Documentation>\n"
39218 " Provide a name for the output array containing the divergence vector.\n"
39219 " </Documentation>\n"
39220 " </StringVectorProperty>\n"
39221 " <IntVectorProperty command=\"SetComputeVorticity\"\n"
39222 " default_values=\"0\"\n"
39223 " name=\"ComputeVorticity\"\n"
39224 " number_of_elements=\"1\"\n"
39225 " panel_visibility=\"advanced\">\n"
39226 " <BooleanDomain name=\"bool\" />\n"
39227 " <Hints>\n"
39228 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39229 " <Expression type=\"or\">\n"
39230 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39231 " name=\"vtkImageData\"\n"
39232 " exclude=\"1\"\n"
39233 " mode=\"enabled_state\" />\n"
39234 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39235 " property=\"BoundaryMethod\"\n"
39236 " value=\"1\"\n"
39237 " mode=\"enabled_state\" />\n"
39238 " </Expression>\n"
39239 " </PropertyWidgetDecorator>\n"
39240 " </Hints>\n"
39241 " <Documentation>\n"
39242 " If on, the vorticity/curl of a 3-component array is computed.\n"
39243 " </Documentation>\n"
39244 " </IntVectorProperty>\n"
39245 " <StringVectorProperty command=\"SetVorticityArrayName\"\n"
39246 " default_values=\"Vorticity\"\n"
39247 " name=\"VorticityArrayName\"\n"
39248 " number_of_elements=\"1\"\n"
39249 " panel_visibility=\"advanced\">\n"
39250 " <Hints>\n"
39251 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39252 " <Expression type=\"or\">\n"
39253 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39254 " name=\"vtkImageData\"\n"
39255 " exclude=\"1\"\n"
39256 " mode=\"enabled_state\" />\n"
39257 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39258 " property=\"BoundaryMethod\"\n"
39259 " value=\"1\"\n"
39260 " mode=\"enabled_state\" />\n"
39261 " </Expression>\n"
39262 " </PropertyWidgetDecorator>\n"
39263 " </Hints>\n"
39264 " <Documentation>\n"
39265 " Provide a name for the output array containing the vorticity vector.\n"
39266 " </Documentation>\n"
39267 " </StringVectorProperty>\n"
39268 " <IntVectorProperty command=\"SetComputeQCriterion\"\n"
39269 " default_values=\"0\"\n"
39270 " name=\"ComputeQCriterion\"\n"
39271 " label=\"Compute Q Criterion\"\n"
39272 " number_of_elements=\"1\"\n"
39273 " panel_visibility=\"advanced\">\n"
39274 " <BooleanDomain name=\"bool\" />\n"
39275 " <Hints>\n"
39276 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39277 " <Expression type=\"or\">\n"
39278 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39279 " name=\"vtkImageData\"\n"
39280 " exclude=\"1\"\n"
39281 " mode=\"enabled_state\" />\n"
39282 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39283 " property=\"BoundaryMethod\"\n"
39284 " value=\"1\"\n"
39285 " mode=\"enabled_state\" />\n"
39286 " </Expression>\n"
39287 " </PropertyWidgetDecorator>\n"
39288 " </Hints>\n"
39289 " <Documentation>\n"
39290 " If on, the Q-criterion of a 3-component array is computed.\n"
39291 " </Documentation>\n"
39292 " </IntVectorProperty>\n"
39293 " <StringVectorProperty command=\"SetQCriterionArrayName\"\n"
39294 " default_values=\"Q Criterion\"\n"
39295 " name=\"QCriterionArrayName\"\n"
39296 " number_of_elements=\"1\"\n"
39297 " panel_visibility=\"advanced\">\n"
39298 " <Hints>\n"
39299 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39300 " <Expression type=\"or\">\n"
39301 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39302 " name=\"vtkImageData\"\n"
39303 " exclude=\"1\"\n"
39304 " mode=\"enabled_state\" />\n"
39305 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39306 " property=\"BoundaryMethod\"\n"
39307 " value=\"1\"\n"
39308 " mode=\"enabled_state\" />\n"
39309 " </Expression>\n"
39310 " </PropertyWidgetDecorator>\n"
39311 " </Hints>\n"
39312 " <Documentation>\n"
39313 " Provide a name for the output array containing the Q criterion.\n"
39314 " </Documentation>\n"
39315 " </StringVectorProperty>\n"
39316 " <IntVectorProperty command=\"SetContributingCellOption\"\n"
39317 " default_values=\"2\"\n"
39318 " name=\"ContributingCellOption\"\n"
39319 " number_of_elements=\"1\"\n"
39320 " panel_visibility=\"advanced\">\n"
39321 " <EnumerationDomain name=\"enum\">\n"
39322 " <Entry text=\"All\"\n"
39323 " value=\"0\" />\n"
39324 " <Entry text=\"Patch\"\n"
39325 " value=\"1\" />\n"
39326 " <Entry text=\"Dataset Max\"\n"
39327 " value=\"2\" />\n"
39328 " </EnumerationDomain>\n"
39329 " <Hints>\n"
39330 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39331 " <Expression type=\"and\">\n"
39332 "\n"
39333 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39334 " name=\"vtkHyperTreeGrid\"\n"
39335 " mode=\"visibility\"\n"
39336 " exclude=\"1\" />\n"
39337 "\n"
39338 " <Expression type=\"or\">\n"
39339 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39340 " name=\"vtkImageData\"\n"
39341 " exclude=\"1\"\n"
39342 " mode=\"enabled_state\" />\n"
39343 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39344 " property=\"BoundaryMethod\"\n"
39345 " value=\"1\"\n"
39346 " mode=\"enabled_state\" />\n"
39347 " </Expression>\n"
39348 " </Expression>\n"
39349 " </PropertyWidgetDecorator>\n"
39350 " </Hints>\n"
39351 " <Documentation>\n"
39352 " Specify which dimensions of cells should be used when computing\n"
39353 " gradient quantities. Default is to use the dataset maximum cell dimension.\n"
39354 " </Documentation>\n"
39355 " </IntVectorProperty>\n"
39356 " <IntVectorProperty command=\"SetReplacementValueOption\"\n"
39357 " default_values=\"1\"\n"
39358 " name=\"ReplacementValueOption\"\n"
39359 " number_of_elements=\"1\"\n"
39360 " panel_visibility=\"advanced\">\n"
39361 " <EnumerationDomain name=\"enum\">\n"
39362 " <Entry text=\"Zero\"\n"
39363 " value=\"0\" />\n"
39364 " <Entry text=\"NaN\"\n"
39365 " value=\"1\" />\n"
39366 " <Entry text=\"Data Type Min\"\n"
39367 " value=\"2\" />\n"
39368 " <Entry text=\"Data Type Max\"\n"
39369 " value=\"3\" />\n"
39370 " </EnumerationDomain>\n"
39371 " <Hints>\n"
39372 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39373 " <Expression type=\"and\">\n"
39374 "\n"
39375 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39376 " name=\"vtkHyperTreeGrid\"\n"
39377 " mode=\"visibility\"\n"
39378 " exclude=\"1\" />\n"
39379 "\n"
39380 " <Expression type=\"or\">\n"
39381 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39382 " name=\"vtkImageData\"\n"
39383 " exclude=\"1\"\n"
39384 " mode=\"enabled_state\" />\n"
39385 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39386 " property=\"BoundaryMethod\"\n"
39387 " value=\"1\"\n"
39388 " mode=\"enabled_state\" />\n"
39389 " </Expression>\n"
39390 " </Expression>\n"
39391 " </PropertyWidgetDecorator>\n"
39392 " </Hints>\n"
39393 " <Documentation>\n"
39394 " Specify what value to use when the gradient quantities at a point cannot\n"
39395 " be computed with the selected **ContributingCellOption**.\n"
39396 " </Documentation>\n"
39397 " </IntVectorProperty>\n"
39398 " <!-- End Gradient -->\n"
39399 " </SourceProxy>\n"
39400 "\n"
39401 " <!-- ==================================================================== -->\n"
39402 " <SourceProxy class=\"vtkPVLinearExtrusionFilter\"\n"
39403 " label=\"Linear Extrusion\"\n"
39404 " name=\"LinearExtrusionFilter\">\n"
39405 " <Documentation long_help=\"This filter creates a swept surface defined by translating the input along a vector.\"\n"
39406 " short_help=\"Generate a linear swept surface.\">The Linear\n"
39407 " Extrusion filter creates a swept surface by translating\n"
39408 " the input dataset along a specified vector. This filter is\n"
39409 " intended to operate on 2D polygonal data. This filter\n"
39410 " operates on polygonal data and produces polygonal data\n"
39411 " output.</Documentation>\n"
39412 " <InputProperty command=\"SetInputConnection\"\n"
39413 " name=\"Input\">\n"
39414 " <ProxyGroupDomain name=\"groups\">\n"
39415 " <Group name=\"sources\" />\n"
39416 " <Group name=\"filters\" />\n"
39417 " </ProxyGroupDomain>\n"
39418 " <DataTypeDomain name=\"input_type\">\n"
39419 " <DataType value=\"vtkPolyData\" />\n"
39420 " </DataTypeDomain>\n"
39421 " <Documentation>This property specifies the input to the Linear\n"
39422 " Extrusion filter.</Documentation>\n"
39423 " </InputProperty>\n"
39424 " <DoubleVectorProperty animateable=\"1\"\n"
39425 " command=\"SetScaleFactor\"\n"
39426 " default_values=\"1.0\"\n"
39427 " name=\"ScaleFactor\"\n"
39428 " number_of_elements=\"1\">\n"
39429 " <DoubleRangeDomain name=\"range\" />\n"
39430 " <Documentation>The value of this property determines the distance along\n"
39431 " the vector the dataset will be translated. (A scale factor of 0.5 will\n"
39432 " move the dataset half the length of the vector, and a scale factor of 2\n"
39433 " will move it twice the vector's length.)</Documentation>\n"
39434 " </DoubleVectorProperty>\n"
39435 " <DoubleVectorProperty command=\"SetVector\"\n"
39436 " default_values=\"0 0 1\"\n"
39437 " name=\"Vector\"\n"
39438 " number_of_elements=\"3\">\n"
39439 " <DoubleRangeDomain name=\"range\" />\n"
39440 " <Documentation>The value of this property indicates the X, Y, and Z\n"
39441 " components of the vector along which to sweep the input\n"
39442 " dataset.</Documentation>\n"
39443 " </DoubleVectorProperty>\n"
39444 " <IntVectorProperty command=\"SetCapping\"\n"
39445 " default_values=\"1\"\n"
39446 " name=\"Capping\"\n"
39447 " number_of_elements=\"1\">\n"
39448 " <BooleanDomain name=\"bool\" />\n"
39449 " <Documentation>The value of this property indicates whether to cap the\n"
39450 " ends of the swept surface. Capping works by placing a copy of the input\n"
39451 " dataset on either end of the swept surface, so it behaves properly if\n"
39452 " the input is a 2D surface composed of filled polygons. If the input\n"
39453 " dataset is a closed solid (e.g., a sphere), then if capping is on\n"
39454 " (i.e., this property is set to 1), two copies of the data set will be\n"
39455 " displayed on output (the second translated from the first one along the\n"
39456 " specified vector). If instead capping is off (i.e., this property is\n"
39457 " set to 0), then an input closed solid will produce no\n"
39458 " output.</Documentation>\n"
39459 " </IntVectorProperty>\n"
39460 " <IntVectorProperty command=\"SetPieceInvariant\"\n"
39461 " default_values=\"0\"\n"
39462 " name=\"PieceInvariant\"\n"
39463 ;
39464
39465 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
39467 " number_of_elements=\"1\">\n"
39468 " <BooleanDomain name=\"bool\" />\n"
39469 " <Documentation>The value of this property determines whether the output\n"
39470 " will be the same regardless of the number of processors used to compute\n"
39471 " the result. The difference is whether there are internal polygonal\n"
39472 " faces on the processor boundaries. A value of 1 will keep the results\n"
39473 " the same; a value of 0 will allow internal faces on processor\n"
39474 " boundaries.</Documentation>\n"
39475 " </IntVectorProperty>\n"
39476 " <!-- End LinearExtrusionFilter -->\n"
39477 " </SourceProxy>\n"
39478 "\n"
39479 " <!-- ==================================================================== -->\n"
39480 " <SourceProxy class=\"vtkLinearCellExtrusionFilter\"\n"
39481 " label=\"Linear Cell Extrusion\"\n"
39482 " name=\"LinearCellExtrusionFilter\">\n"
39483 " <Documentation long_help=\"This filter creates a swept surface defined by translating the input along a vector.\"\n"
39484 " short_help=\"Generate a linear swept surface.\">The Linear\n"
39485 " Extrusion filter creates a swept surface by translating\n"
39486 " the input dataset along the cell normals or a specified vector.\n"
39487 " This filter is intended to operate on polygonal data and produces\n"
39488 " 3D unstructured grid output.</Documentation>\n"
39489 " <InputProperty command=\"SetInputConnection\"\n"
39490 " name=\"Input\">\n"
39491 " <ProxyGroupDomain name=\"groups\">\n"
39492 " <Group name=\"sources\" />\n"
39493 " <Group name=\"filters\" />\n"
39494 " </ProxyGroupDomain>\n"
39495 " <DataTypeDomain name=\"input_type\">\n"
39496 " <DataType value=\"vtkPolyData\" />\n"
39497 " </DataTypeDomain>\n"
39498 " <InputArrayDomain attribute_type=\"cell\"\n"
39499 " name=\"input_array1\"\n"
39500 " number_of_components=\"1\" />\n"
39501 " <Documentation>This property specifies the input to the Linear Cell\n"
39502 " Extrusion filter.</Documentation>\n"
39503 " </InputProperty>\n"
39504 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
39505 " element_types=\"0 0 0 0 2\"\n"
39506 " name=\"SelectInputScalars\"\n"
39507 " number_of_elements=\"5\">\n"
39508 " <ArrayListDomain attribute_type=\"Scalars\"\n"
39509 " name=\"array_list\">\n"
39510 " <RequiredProperties>\n"
39511 " <Property function=\"Input\"\n"
39512 " name=\"Input\" />\n"
39513 " </RequiredProperties>\n"
39514 " </ArrayListDomain>\n"
39515 " <Documentation>The array used to set the extrusion length.</Documentation>\n"
39516 " </StringVectorProperty>\n"
39517 " <DoubleVectorProperty command=\"SetScaleFactor\"\n"
39518 " default_values=\"1\"\n"
39519 " name=\"ScaleFactor\"\n"
39520 " number_of_elements=\"1\">\n"
39521 " <Documentation>Scale factor applied to the extrusion length.</Documentation>\n"
39522 " </DoubleVectorProperty>\n"
39523 " <IntVectorProperty command=\"SetUseUserVector\"\n"
39524 " default_values=\"0\"\n"
39525 " name=\"UseUserVector\"\n"
39526 " number_of_elements=\"1\">\n"
39527 " <BooleanDomain name=\"bool\" />\n"
39528 " <Documentation>Use a custom extrusion direction.</Documentation>\n"
39529 " </IntVectorProperty>\n"
39530 " <DoubleVectorProperty command=\"SetUserVector\"\n"
39531 " default_values=\"0 0 1\"\n"
39532 " name=\"UserVector\"\n"
39533 " number_of_elements=\"3\">\n"
39534 " <Documentation>Set the custom extrusion direction.</Documentation>\n"
39535 " <Hints>\n"
39536 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
39537 " <Property name=\"UseUserVector\" function=\"boolean\" />\n"
39538 " </PropertyWidgetDecorator>\n"
39539 " </Hints>\n"
39540 " </DoubleVectorProperty>\n"
39541 " <IntVectorProperty command=\"SetMergeDuplicatePoints\"\n"
39542 " default_values=\"0\"\n"
39543 " name=\"MergeDuplicatePoints\"\n"
39544 " number_of_elements=\"1\">\n"
39545 " <BooleanDomain name=\"bool\" />\n"
39546 " <Documentation>Remove duplicate points.</Documentation>\n"
39547 " </IntVectorProperty>\n"
39548 " <Hints>\n"
39549 " <WarnOnCreate>\n"
39550 " <DataTypeDomain name=\"input_type\">\n"
39551 " <DataType value=\"vtkPolyData\" />\n"
39552 " </DataTypeDomain>\n"
39553 " <MemoryUsage relative=\"4\" />\n"
39554 " <Text title=\"Potentially running out of memory\">\n"
39555 " **Linear Cell Extrusion** filter will create an unstructured grid output and\n"
39556 " you may not have enough memory to create it.\n"
39557 " Do you want to continue?\n"
39558 " </Text>\n"
39559 " </WarnOnCreate>\n"
39560 " </Hints>\n"
39561 "\n"
39562 " <!-- End LinearCellExtrusionFilter -->\n"
39563 " </SourceProxy>\n"
39564 " <!-- ==================================================================== -->\n"
39565 "\n"
39566 " <SourceProxy class=\"vtkPVMetaClipDataSet\"\n"
39567 " name=\"Clip\">\n"
39568 " <Documentation long_help=\"Clip with an implicit function (an implicit description). Clipping does not reduce the dimensionality of the data set. The output data type of this filter is always an unstructured grid.\"\n"
39569 " short_help=\"Clip with an implicit function.\">The Clip filter\n"
39570 " cuts away a portion of the input data set using an\n"
39571 " implicit function (an implicit description).\n"
39572 " This filter operates on all types of data\n"
39573 " sets, and it returns unstructured grid data on\n"
39574 " output.</Documentation>\n"
39575 " <InputProperty command=\"SetInputConnection\"\n"
39576 " name=\"Input\">\n"
39577 " <ProxyGroupDomain name=\"groups\">\n"
39578 " <Group name=\"sources\" />\n"
39579 " <Group name=\"filters\" />\n"
39580 " </ProxyGroupDomain>\n"
39581 " <DataTypeDomain name=\"input_type\">\n"
39582 " <DataType value=\"vtkDataSet\" />\n"
39583 " <DataType value=\"vtkHyperTreeGrid\" />\n"
39584 " </DataTypeDomain>\n"
39585 " <InputArrayDomain name=\"input_array\"\n"
39586 " number_of_components=\"1\"\n"
39587 " optional=\"1\" />\n"
39588 " <Documentation>This property specifies the dataset on which the Clip\n"
39589 " filter will operate.</Documentation>\n"
39590 " </InputProperty>\n"
39591 " <ProxyProperty command=\"SetDataSetClipFunction\"\n"
39592 " label=\"Clip Type\"\n"
39593 " name=\"ClipFunction\">\n"
39594 " <ProxyGroupDomain name=\"groups\">\n"
39595 " <Group name=\"implicit_functions\" />\n"
39596 " </ProxyGroupDomain>\n"
39597 " <ProxyListDomain name=\"proxy_list\">\n"
39598 " <Group name=\"clip_implicit_functions\" default=\"Plane\" />\n"
39599 " </ProxyListDomain>\n"
39600 " <Hints>\n"
39601 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39602 " name=\"vtkHyperTreeGrid\"\n"
39603 " exclude=\"1\"\n"
39604 " mode=\"visibility\"/>\n"
39605 " </Hints>\n"
39606 " <Documentation>This property specifies the parameters of the clip\n"
39607 " function (an implicit description) used to clip the dataset.</Documentation>\n"
39608 " </ProxyProperty>\n"
39609 " <ProxyProperty command=\"SetHyperTreeGridClipFunction\"\n"
39610 " label=\"Hyper Tree Grid Clipper\"\n"
39611 " name=\"HyperTreeGridClipFunction\">\n"
39612 " <ProxyListDomain name=\"proxy_list\">\n"
39613 " <Group name=\"clip_htg_implicit_functions\" default=\"Plane\" />\n"
39614 " </ProxyListDomain>\n"
39615 " <Documentation>This property specifies the parameters of the clip\n"
39616 " function (an implicit description) used to clip the hyper tree grid.</Documentation>\n"
39617 " <Hints>\n"
39618 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39619 " name=\"vtkHyperTreeGrid\"\n"
39620 " mode=\"visibility\"/>\n"
39621 " </Hints>\n"
39622 " </ProxyProperty>\n"
39623 " <DoubleVectorProperty information_only=\"1\"\n"
39624 " name=\"InputBounds\">\n"
39625 " <BoundsDomain name=\"bounds\">\n"
39626 " <RequiredProperties>\n"
39627 " <Property function=\"Input\"\n"
39628 " name=\"Input\" />\n"
39629 " </RequiredProperties>\n"
39630 " </BoundsDomain>\n"
39631 " </DoubleVectorProperty>\n"
39632 " <StringVectorProperty animateable=\"0\"\n"
39633 " command=\"SetInputArrayToProcess\"\n"
39634 " element_types=\"0 0 0 0 2\"\n"
39635 " label=\"Scalars\"\n"
39636 " name=\"SelectInputScalars\"\n"
39637 " number_of_elements=\"5\">\n"
39638 " <ArrayListDomain attribute_type=\"Scalars\"\n"
39639 " name=\"array_list\">\n"
39640 " <RequiredProperties>\n"
39641 " <Property function=\"Input\"\n"
39642 " name=\"Input\" />\n"
39643 " </RequiredProperties>\n"
39644 " </ArrayListDomain>\n"
39645 " <Documentation>If clipping with scalars, this property specifies the\n"
39646 " name of the scalar array on which to perform the clip\n"
39647 " operation.</Documentation>\n"
39648 " <Hints>\n"
39649 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39650 " <Expression type=\"or\">\n"
39651 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39652 " mode=\"visibility\"\n"
39653 " property=\"ClipFunction\"\n"
39654 " value=\"Scalar\" />\n"
39655 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39656 " mode=\"visibility\"\n"
39657 " property=\"HyperTreeGridClipFunction\"\n"
39658 " value=\"Scalar\" />\n"
39659 " </Expression>\n"
39660 " </PropertyWidgetDecorator>\n"
39661 " </Hints>\n"
39662 " </StringVectorProperty>\n"
39663 " <DoubleVectorProperty command=\"SetValue\"\n"
39664 " default_values=\"0.0\"\n"
39665 " name=\"Value\"\n"
39666 " number_of_elements=\"1\">\n"
39667 " <ArrayRangeDomain name=\"range\">\n"
39668 " <RequiredProperties>\n"
39669 " <Property function=\"Input\"\n"
39670 " name=\"Input\" />\n"
39671 " <Property function=\"ArraySelection\"\n"
39672 " name=\"SelectInputScalars\" />\n"
39673 " </RequiredProperties>\n"
39674 " </ArrayRangeDomain>\n"
39675 " <Documentation>If clipping with scalars, this property sets the scalar\n"
39676 " value about which to clip the dataset based on the scalar array chosen.\n"
39677 " (See SelectInputScalars.) If clipping with a clip function, this\n"
39678 " property specifies an offset from the clip function to use in the\n"
39679 " clipping operation. Neither functionality is currently available in\n"
39680 " ParaView's user interface.</Documentation>\n"
39681 " <Hints>\n"
39682 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39683 " <Expression type=\"or\">\n"
39684 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39685 " mode=\"visibility\"\n"
39686 " property=\"ClipFunction\"\n"
39687 " value=\"Scalar\" />\n"
39688 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39689 " mode=\"visibility\"\n"
39690 " property=\"HyperTreeGridClipFunction\"\n"
39691 " value=\"Scalar\" />\n"
39692 " </Expression>\n"
39693 " </PropertyWidgetDecorator>\n"
39694 " </Hints>\n"
39695 " </DoubleVectorProperty>\n"
39696 " <IntVectorProperty command=\"SetInsideOut\"\n"
39697 " default_values=\"1\"\n"
39698 " name=\"Invert\"\n"
39699 " number_of_elements=\"1\">\n"
39700 " <BooleanDomain name=\"bool\" />\n"
39701 " <Documentation>Invert which part of the geometry is clipped.</Documentation>\n"
39702 " </IntVectorProperty>\n"
39703 " <IntVectorProperty command=\"SetUseValueAsOffset\"\n"
39704 " default_values=\"0\"\n"
39705 " name=\"UseValueAsOffset\"\n"
39706 " number_of_elements=\"1\"\n"
39707 " panel_visibility=\"never\">\n"
39708 " <BooleanDomain name=\"bool\" />\n"
39709 " <Documentation>If UseValueAsOffset is true, Value is used as an offset\n"
39710 " parameter to the implicit function. Otherwise, Value is used only when\n"
39711 " clipping using a scalar array.</Documentation>\n"
39712 " </IntVectorProperty>\n"
39713 " <IntVectorProperty command=\"PreserveInputCells\"\n"
39714 " default_values=\"0\"\n"
39715 " label=\"Crinkle clip\"\n"
39716 " name=\"PreserveInputCells\"\n"
39717 " number_of_elements=\"1\">\n"
39718 " <BooleanDomain name=\"bool\" />\n"
39719 " <Documentation>This parameter controls whether to extract entire cells\n"
39720 " in the given region or clip those cells so all of the output will stay\n"
39721 " only on that side of region.</Documentation>\n"
39722 " <Hints>\n"
39723 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39724 " <Expression type=\"and\">\n"
39725 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39726 " mode=\"visibility\"\n"
39727 " exclude=\"1\"\n"
39728 " name=\"vtkHyperTreeGrid\" />\n"
39729 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39730 " mode=\"visibility\"\n"
39731 " property=\"ClipFunction\"\n"
39732 " value=\"Scalar\"\n"
39733 " inverse=\"1\" />\n"
39734 " </Expression>\n"
39735 " </PropertyWidgetDecorator>\n"
39736 " </Hints>\n"
39737 " </IntVectorProperty>\n"
39738 " <IntVectorProperty command=\"SetExactBoxClip\"\n"
39739 " default_values=\"0\"\n"
39740 " name=\"Exact\"\n"
39741 " number_of_elements=\"1\">\n"
39742 " <BooleanDomain name=\"bool\" />\n"
39743 " <Documentation>If this property is set to 1 it will clip to the exact specifications\n"
39744 " for the **Box** option only, otherwise the clip will only approximate the box geometry. The\n"
39745 " exact clip is very expensive as it requires generating 6 plane clips. Additionally,\n"
39746 " **Invert** must be checked and **Crinkle clip** must be unchecked.</Documentation>\n"
39747 " <Hints>\n"
39748 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39749 " <Expression type=\"and\">\n"
39750 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ClipFunction\" value=\"Box\" inverse=\"0\" />\n"
39751 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"Invert\" value=\"1\" />\n"
39752 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"PreserveInputCells\" value=\"0\" />\n"
39753 " </Expression>\n"
39754 " </PropertyWidgetDecorator>\n"
39755 " </Hints>\n"
39756 " </IntVectorProperty>\n"
39757 " <Hints>\n"
39758 " <Visibility replace_input=\"2\" />\n"
39759 " <WarnOnCreate>\n"
39760 " <DataTypeDomain name=\"input_type\">\n"
39761 " <DataType value=\"vtkImageData\" />\n"
39762 ;
39763
39764 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
39766 " <DataType value=\"vtkRectilinearGrid\" />\n"
39767 " <DataType value=\"vtkStructuredGrid\" />\n"
39768 " </DataTypeDomain>\n"
39769 " <MemoryUsage relative=\"20\" />\n"
39770 " <Text title=\"Potentially running out of memory\">\n"
39771 " **Clip** filter will create an unstructured grid output and\n"
39772 " you may not have enough memory to create it.\n"
39773 " Do you want to continue?\n"
39774 " </Text>\n"
39775 " </WarnOnCreate>\n"
39776 " </Hints>\n"
39777 " <!-- End Clip -->\n"
39778 " </SourceProxy>\n"
39779 "\n"
39780 " <!-- ==================================================================== -->\n"
39781 " <SourceProxy class=\"vtkPVMetaSliceDataSet\"\n"
39782 " label=\"Slice\"\n"
39783 " name=\"Cut\">\n"
39784 " <Documentation long_help=\"This filter slices a data set with a plane. Slicing is similar to a contour. It creates surfaces from volumes and lines from surfaces.\"\n"
39785 " short_help=\"Slice datasets with planes.\">This filter\n"
39786 " extracts the portion of the input dataset that lies along\n"
39787 " the specified plane. The Slice filter takes any type of\n"
39788 " dataset or hyper tree grid as input. The output of this filter is polygonal\n"
39789 " data.</Documentation>\n"
39790 " <InputProperty command=\"SetInputConnection\"\n"
39791 " name=\"Input\">\n"
39792 " <ProxyGroupDomain name=\"groups\">\n"
39793 " <Group name=\"sources\" />\n"
39794 " <Group name=\"filters\" />\n"
39795 " </ProxyGroupDomain>\n"
39796 " <DataTypeDomain name=\"input_type\">\n"
39797 " <DataType value=\"vtkDataSet\" />\n"
39798 " <DataType value=\"vtkHyperTreeGrid\" />\n"
39799 " </DataTypeDomain>\n"
39800 " <Documentation>This property specifies the input to the Slice\n"
39801 " filter.</Documentation>\n"
39802 " </InputProperty>\n"
39803 " <ProxyProperty command=\"SetDataSetCutFunction\"\n"
39804 " label=\"Slice Type\"\n"
39805 " name=\"CutFunction\">\n"
39806 " <Hints>\n"
39807 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39808 " name=\"vtkHyperTreeGrid\"\n"
39809 " exclude=\"1\"\n"
39810 " mode=\"visibility\"/>\n"
39811 " </Hints>\n"
39812 " <ProxyListDomain name=\"proxy_list\">\n"
39813 " <Group name=\"slice_implicit_functions\" default=\"Plane\"/>\n"
39814 " </ProxyListDomain>\n"
39815 " <Documentation>This property sets the parameters of the slice\n"
39816 " function.</Documentation>\n"
39817 " </ProxyProperty>\n"
39818 " <ProxyProperty command=\"SetHyperTreeGridCutFunction\"\n"
39819 " label=\"Hyper Tree Grid Slicer\"\n"
39820 " name=\"HyperTreeGridImplicitFunction\">\n"
39821 " <Hints>\n"
39822 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39823 " name=\"vtkHyperTreeGrid\"\n"
39824 " mode=\"visibility\"/>\n"
39825 " </Hints>\n"
39826 " <ProxyListDomain name=\"proxy_list\">\n"
39827 " <Group name=\"slice_htg_amr_implicit_functions\" default=\"Plane\"/>\n"
39828 " </ProxyListDomain>\n"
39829 " <Documentation>This property sets the parameters of the slice\n"
39830 " function.</Documentation>\n"
39831 " </ProxyProperty>\n"
39832 " <DoubleVectorProperty information_only=\"1\"\n"
39833 " name=\"InputBounds\">\n"
39834 " <BoundsDomain name=\"bounds\">\n"
39835 " <RequiredProperties>\n"
39836 " <Property function=\"Input\"\n"
39837 " name=\"Input\" />\n"
39838 " </RequiredProperties>\n"
39839 " </BoundsDomain>\n"
39840 " </DoubleVectorProperty>\n"
39841 " <IntVectorProperty command=\"SetDual\"\n"
39842 " default_values=\"0\"\n"
39843 " label=\"Use Dual\"\n"
39844 " name=\"SetDual\"\n"
39845 " number_of_elements=\"1\">\n"
39846 " <Hints>\n"
39847 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39848 " <Expression type=\"and\">\n"
39849 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39850 " mode=\"visibility\"\n"
39851 " property=\"HyperTreeGridImplicitFunction\"\n"
39852 " value=\"Plane\"/>\n"
39853 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39854 " mode=\"visibility\"\n"
39855 " name=\"vtkHyperTreeGrid\"/>\n"
39856 " </Expression>\n"
39857 " </PropertyWidgetDecorator>\n"
39858 " </Hints>\n"
39859 " <BooleanDomain name=\"bool\" />\n"
39860 " <Documentation>If checked, uses the dual of the hyper tree grid.</Documentation>\n"
39861 " </IntVectorProperty>\n"
39862 " <IntVectorProperty command=\"PreserveInputCells\"\n"
39863 " default_values=\"0\"\n"
39864 " label=\"Crinkle slice\"\n"
39865 " name=\"PreserveInputCells\"\n"
39866 " number_of_elements=\"1\">\n"
39867 " <Hints>\n"
39868 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39869 " name=\"vtkHyperTreeGrid\"\n"
39870 " exclude=\"1\"\n"
39871 " mode=\"visibility\" />\n"
39872 " </Hints>\n"
39873 " <BooleanDomain name=\"bool\" />\n"
39874 " <Documentation>This parameter controls whether to extract the entire\n"
39875 " cells that are sliced by the region or just extract a triangulated\n"
39876 " surface of that region.</Documentation>\n"
39877 " </IntVectorProperty>\n"
39878 " <IntVectorProperty command=\"SetGenerateTriangles\"\n"
39879 " default_values=\"1\"\n"
39880 " name=\"Triangulate the slice\"\n"
39881 " number_of_elements=\"1\">\n"
39882 " <BooleanDomain name=\"bool\" />\n"
39883 " <Documentation>This parameter controls whether to produce triangles in the output.</Documentation>\n"
39884 " <Hints>\n"
39885 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39886 " <Expression type=\"and\">\n"
39887 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
39888 " name=\"vtkHyperTreeGrid\"\n"
39889 " mode=\"visibility\"\n"
39890 " exclude=\"1\" />\n"
39891 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
39892 " <Property name=\"PreserveInputCells\" function=\"boolean_invert\" />\n"
39893 " </PropertyWidgetDecorator>\n"
39894 " </Expression>\n"
39895 " </PropertyWidgetDecorator>\n"
39896 " </Hints>\n"
39897 " </IntVectorProperty>\n"
39898 " <DoubleVectorProperty animateable=\"1\"\n"
39899 " command=\"SetValue\"\n"
39900 " label=\"Slice Offset Values\"\n"
39901 " name=\"ContourValues\"\n"
39902 " number_of_elements_per_command=\"1\"\n"
39903 " repeat_command=\"1\"\n"
39904 " set_number_command=\"SetNumberOfContours\"\n"
39905 " use_index=\"1\"\n"
39906 " panel_visibility=\"advanced\">\n"
39907 " <Hints>\n"
39908 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
39909 " <Expression type=\"and\">\n"
39910 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
39911 " mode=\"visibility\"\n"
39912 " property=\"HyperTreeGridImplicitFunction\"\n"
39913 " value=\"Axis Aligned Plane\"\n"
39914 " inverse=\"1\" />\n"
39915 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
39916 " <Property name=\"PreserveInputCells\" function=\"boolean_invert\" />\n"
39917 " </PropertyWidgetDecorator>\n"
39918 " </Expression>\n"
39919 " </PropertyWidgetDecorator>\n"
39920 " </Hints>\n"
39921 " <BoundsDomain mode=\"magnitude\"\n"
39922 " name=\"bounds\">\n"
39923 " <RequiredProperties>\n"
39924 " <Property function=\"Input\"\n"
39925 " name=\"Input\" />\n"
39926 " </RequiredProperties>\n"
39927 " </BoundsDomain>\n"
39928 " <Documentation>The values in this property specify a list of current\n"
39929 " offset values. This can be used to create multiple slices with\n"
39930 " different centers. Each entry represents a new slice with its center\n"
39931 " shifted by the offset value. The 'Values Range' information is the\n"
39932 " range based on the global bounding box, not necessarily on the current\n"
39933 " slice geometry configuration.</Documentation>\n"
39934 " </DoubleVectorProperty>\n"
39935 " <!-- incremental point locator begin -->\n"
39936 " <ProxyProperty command=\"SetLocator\"\n"
39937 " label=\"Point Merge Method\"\n"
39938 " name=\"Locator\"\n"
39939 " panel_visibility=\"advanced\" >\n"
39940 " <ProxyGroupDomain name=\"groups\">\n"
39941 " <Group name=\"incremental_point_locators\" />\n"
39942 " </ProxyGroupDomain>\n"
39943 " <ProxyListDomain name=\"proxy_list\">\n"
39944 " <Proxy group=\"incremental_point_locators\"\n"
39945 " name=\"MergePoints\" />\n"
39946 " <Proxy group=\"incremental_point_locators\"\n"
39947 " name=\"IncrementalOctreeMergePoints\" />\n"
39948 " <Proxy group=\"incremental_point_locators\"\n"
39949 " name=\"NonMergingPointLocator\" />\n"
39950 " </ProxyListDomain>\n"
39951 " <Documentation>This property specifies which incremental point locator to\n"
39952 " use for handling duplicate/coincident points.</Documentation>\n"
39953 " </ProxyProperty>\n"
39954 " <!-- incremental point locator end -->\n"
39955 " <Hints>\n"
39956 " <Visibility replace_input=\"2\" />\n"
39957 " </Hints>\n"
39958 " <!-- End Cut -->\n"
39959 " </SourceProxy>\n"
39960 "\n"
39961 " <!-- ==================================================================== -->\n"
39962 " <SourceProxy class=\"vtkPVThreshold\"\n"
39963 " name=\"Threshold\">\n"
39964 " <Documentation long_help=\"This filter extracts cells that have point or cell scalars in the specified range.\"\n"
39965 " short_help=\"Extract cells that satisfy a threshold criterion.\">\n"
39966 " The Threshold filter extracts the portions of the input\n"
39967 " dataset whose scalars lie within the specified range. This\n"
39968 " filter operates on either point-centered or cell-centered\n"
39969 " data. It operates on any type of dataset and produces\n"
39970 " unstructured grid output.\n"
39971 " The scalar array from which to threshold the data can be selected\n"
39972 " in the 'Scalars' menu. For a multi-components array, 'Selected\n"
39973 " Component' menu allows you to select a specific component or\n"
39974 " magnitude if using the 'Selected' component mode. You can also\n"
39975 " choose 'All' or 'Any' that will keep data if either all components\n"
39976 " or at least one satisfies the threshold. Note that multi-components\n"
39977 " arrays are not available with Hyper Tree Grid inputs.\n"
39978 " The 'Lower Threshold' and 'Upper Threshold' sliders determine\n"
39979 " the range of the scalars to retain in the output.\n"
39980 " The threshold method can be selected from the 'Threshold Method' menu.\n"
39981 " The 'All Scalars' option only applies to Point Data. When this\n"
39982 " option is on, a cell will only be passed to the output if the\n"
39983 " scalar values of all of its points lie within the chosen range.\n"
39984 " When off, a cell will be added to the output if the specified\n"
39985 " scalar value for any of its points is within the chosen range.\n"
39986 " </Documentation>\n"
39987 " <InputProperty command=\"SetInputConnection\"\n"
39988 " name=\"Input\">\n"
39989 " <ProxyGroupDomain name=\"groups\">\n"
39990 " <Group name=\"sources\" />\n"
39991 " <Group name=\"filters\" />\n"
39992 " </ProxyGroupDomain>\n"
39993 " <DataTypeDomain name=\"input_type\">\n"
39994 " <DataType value=\"vtkDataSet\" />\n"
39995 " <DataType value=\"vtkHyperTreeGrid\" />\n"
39996 " </DataTypeDomain>\n"
39997 " <InputArrayDomain name=\"input_array\" />\n"
39998 " <Documentation>This property specifies the input to the Threshold\n"
39999 " filter.</Documentation>\n"
40000 " </InputProperty>\n"
40001 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
40002 " element_types=\"0 0 0 0 2\"\n"
40003 " label=\"Scalars\"\n"
40004 " name=\"SelectInputScalars\"\n"
40005 " number_of_elements=\"5\">\n"
40006 " <ArrayListDomain name=\"array_list\" input_domain_name=\"input_array\">\n"
40007 " <RequiredProperties>\n"
40008 " <Property function=\"Input\"\n"
40009 " name=\"Input\" />\n"
40010 " </RequiredProperties>\n"
40011 " </ArrayListDomain>\n"
40012 " <Documentation>The value of this property contains the name of the\n"
40013 " array from which to perform thresholding. Be aware that HTG does not\n"
40014 " support multi-component arrays.</Documentation>\n"
40015 " </StringVectorProperty>\n"
40016 " <IntVectorProperty command=\"SetComponentMode\"\n"
40017 " name=\"ComponentMode\"\n"
40018 " default_values=\"0\"\n"
40019 " number_of_elements=\"1\">\n"
40020 " <EnumerationDomain name=\"enum\">\n"
40021 " <Entry text=\"Selected\"\n"
40022 " value=\"0\" />\n"
40023 " <Entry text=\"All\"\n"
40024 " value=\"1\" />\n"
40025 " <Entry text=\"Any\"\n"
40026 " value=\"2\" />\n"
40027 " </EnumerationDomain>\n"
40028 " <Hints>\n"
40029 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40030 " name=\"vtkHyperTreeGrid\"\n"
40031 " exclude=\"1\"\n"
40032 " mode=\"visibility\"/>\n"
40033 " </Hints>\n"
40034 " <Documentation>This property specifies how multi-component arrays are handled.\n"
40035 " 'Selected' will use the 'Selected Component' property.\n"
40036 " 'All' will pass if all components satisfy the rule.\n"
40037 " 'Any' will pass if any component satisfies the rule.\n"
40038 " </Documentation>\n"
40039 " </IntVectorProperty>\n"
40040 " <IntVectorProperty command=\"SetSelectedComponent\"\n"
40041 " name=\"SelectedComponent\"\n"
40042 " default_values=\"0\"\n"
40043 " number_of_elements=\"1\">\n"
40044 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"1\">\n"
40045 " <RequiredProperties>\n"
40046 " <Property function=\"Input\"\n"
40047 " name=\"Input\" />\n"
40048 " <Property function=\"ArraySelection\"\n"
40049 " name=\"SelectInputScalars\" />\n"
40050 " </RequiredProperties>\n"
40051 " </NumberOfComponentsDomain>\n"
40052 " <Hints>\n"
40053 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40054 " name=\"vtkHyperTreeGrid\"\n"
40055 " exclude=\"1\"\n"
40056 " mode=\"visibility\"/>\n"
40057 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"ComponentMode\" value=\"0\" />\n"
40058 " </Hints>\n"
40059 " <Documentation>This property specifies which component of the array needs to satisfy\n"
40060 " the rule.\n"
40061 ;
40062
40063 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
40065 " </Documentation>\n"
40066 " </IntVectorProperty>\n"
40067 " <DoubleVectorProperty command=\"SetLowerThreshold\"\n"
40068 " default_values=\"0\"\n"
40069 " name=\"LowerThreshold\"\n"
40070 " number_of_elements=\"1\">\n"
40071 " <ArrayRangeDomain name=\"range\"\n"
40072 " default_mode=\"min\">\n"
40073 " <RequiredProperties>\n"
40074 " <Property function=\"Input\"\n"
40075 " name=\"Input\" />\n"
40076 " <Property function=\"ArraySelection\"\n"
40077 " name=\"SelectInputScalars\" />\n"
40078 " <Property function=\"ComponentSelection\"\n"
40079 " name=\"SelectedComponent\" />\n"
40080 " </RequiredProperties>\n"
40081 " </ArrayRangeDomain>\n"
40082 " <Hints>\n"
40083 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40084 " <Expression type=\"or\">\n"
40085 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ThresholdMethod\" value=\"0\" />\n"
40086 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ThresholdMethod\" value=\"1\" />\n"
40087 " </Expression>\n"
40088 " </PropertyWidgetDecorator>\n"
40089 " </Hints>\n"
40090 " <Documentation>\n"
40091 " The value of this property specifies the lower bound of the\n"
40092 " thresholding operation.\n"
40093 " </Documentation>\n"
40094 " </DoubleVectorProperty>\n"
40095 " <DoubleVectorProperty command=\"SetUpperThreshold\"\n"
40096 " default_values=\"0\"\n"
40097 " name=\"UpperThreshold\"\n"
40098 " number_of_elements=\"1\">\n"
40099 " <ArrayRangeDomain name=\"range\"\n"
40100 " default_mode=\"max\">\n"
40101 " <RequiredProperties>\n"
40102 " <Property function=\"Input\"\n"
40103 " name=\"Input\" />\n"
40104 " <Property function=\"ArraySelection\"\n"
40105 " name=\"SelectInputScalars\" />\n"
40106 " <Property function=\"ComponentSelection\"\n"
40107 " name=\"SelectedComponent\" />\n"
40108 " </RequiredProperties>\n"
40109 " </ArrayRangeDomain>\n"
40110 " <Hints>\n"
40111 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40112 " <Expression type=\"or\">\n"
40113 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ThresholdMethod\" value=\"0\" />\n"
40114 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ThresholdMethod\" value=\"2\" />\n"
40115 " </Expression>\n"
40116 " </PropertyWidgetDecorator>\n"
40117 " </Hints>\n"
40118 " <Documentation>\n"
40119 " The value of this property specifies the upper bound of the\n"
40120 " thresholding operation.\n"
40121 " </Documentation>\n"
40122 " </DoubleVectorProperty>\n"
40123 " <IntVectorProperty command=\"SetThresholdFunction\"\n"
40124 " default_values=\"0\"\n"
40125 " name=\"ThresholdMethod\"\n"
40126 " number_of_elements=\"1\"\n"
40127 " panel_visibility=\"default\">\n"
40128 " <EnumerationDomain name=\"enum\">\n"
40129 " <Entry text=\"Between\" value=\"0\"/>\n"
40130 " <Entry text=\"Below Lower Threshold\" value=\"1\"/>\n"
40131 " <Entry text=\"Above Upper Threshold\" value=\"2\"/>\n"
40132 " </EnumerationDomain>\n"
40133 " <Documentation>\n"
40134 " This property indicates the threshold method.\n"
40135 " </Documentation>\n"
40136 " </IntVectorProperty>\n"
40137 " <IntVectorProperty command=\"SetAllScalars\"\n"
40138 " default_values=\"1\"\n"
40139 " name=\"AllScalars\"\n"
40140 " number_of_elements=\"1\">\n"
40141 " <Hints>\n"
40142 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40143 " name=\"vtkHyperTreeGrid\"\n"
40144 " exclude=\"1\"\n"
40145 " mode=\"visibility\" />\n"
40146 " </Hints>\n"
40147 " <BooleanDomain name=\"bool\" />\n"
40148 " <Documentation>If the value of this property is 1, then a cell is only\n"
40149 " included in the output if the value of the selected array for all its\n"
40150 " points is within the threshold. This is only relevant when thresholding\n"
40151 " by a point-centered array.</Documentation>\n"
40152 " </IntVectorProperty>\n"
40153 " <IntVectorProperty command=\"SetUseContinuousCellRange\"\n"
40154 " default_values=\"0\"\n"
40155 " name=\"UseContinuousCellRange\"\n"
40156 " number_of_elements=\"1\">\n"
40157 " <Hints>\n"
40158 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40159 " name=\"vtkHyperTreeGrid\"\n"
40160 " exclude=\"1\"\n"
40161 " mode=\"visibility\" />\n"
40162 " </Hints>\n"
40163 " <BooleanDomain name=\"bool\" />\n"
40164 " <Documentation>\n"
40165 " If off, the vertex scalars are treated as a discrete set. If on, they\n"
40166 " are treated as a continuous interval over the minimum and maximum. One\n"
40167 " important \"on\" use case: When setting lower and upper threshold\n"
40168 " equal to some value and turning AllScalars off, the results are\n"
40169 " cells containing the isosurface for that value. WARNING: Whether on\n"
40170 " or off, for higher order input, the filter will not give accurate\n"
40171 " results.\n"
40172 " </Documentation>\n"
40173 " </IntVectorProperty>\n"
40174 " <IntVectorProperty command=\"SetInvert\"\n"
40175 " default_values=\"0\"\n"
40176 " name=\"Invert\"\n"
40177 " number_of_elements=\"1\">\n"
40178 " <Hints>\n"
40179 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40180 " name=\"vtkHyperTreeGrid\"\n"
40181 " exclude=\"1\"\n"
40182 " mode=\"visibility\"/>\n"
40183 " </Hints>\n"
40184 " <BooleanDomain name=\"bool\" />\n"
40185 " <Documentation>Invert the threshold results. That is, cells that would have been in the\n"
40186 " output with this option off are excluded, while cells that would have been excluded from\n"
40187 " the output are included.\n"
40188 " </Documentation>\n"
40189 " </IntVectorProperty>\n"
40190 " <IntVectorProperty name=\"MemoryStrategy\"\n"
40191 " command=\"SetMemoryStrategy\"\n"
40192 " number_of_elements=\"1\"\n"
40193 " default_values=\"0\"\n"
40194 " panel_visibility=\"advanced\">\n"
40195 " <Hints>\n"
40196 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40197 " name=\"vtkHyperTreeGrid\"\n"
40198 " mode=\"visibility\" />\n"
40199 " </Hints>\n"
40200 " <EnumerationDomain name=\"enum\">\n"
40201 " <Entry text=\"Mask Input\" value=\"0\" />\n"
40202 " <Entry text=\"Regenerate Trees And Index Fields\" value=\"1\" />\n"
40203 " <Entry text=\"New HyperTreeGrid\" value=\"2\" />\n"
40204 " </EnumerationDomain>\n"
40205 " <Documentation>\n"
40206 " Select how to construct the result in memory:\n"
40207 " - MaskInput (default): shallow copy the input and mask all cells being thresholded\n"
40208 " - Regenerate Trees And Index Fields: generate a new tree structure but use indexed arrays on the\n"
40209 " input for cell data\n"
40210 " - New HyperTreeGrid: construct a new HyperTreeGrid from scratch representing the minimal\n"
40211 " threshold of the input\n"
40212 " </Documentation>\n"
40213 " </IntVectorProperty>\n"
40214 " <Hints>\n"
40215 " <Visibility replace_input=\"2\" />\n"
40216 " <WarnOnCreate>\n"
40217 " <DataTypeDomain name=\"input_type\">\n"
40218 " <DataType value=\"vtkImageData\" />\n"
40219 " <DataType value=\"vtkRectilinearGrid\" />\n"
40220 " <DataType value=\"vtkStructuredGrid\" />\n"
40221 " </DataTypeDomain>\n"
40222 " <MemoryUsage relative=\"20\" />\n"
40223 " <Text title=\"Potentially running out of memory\">\n"
40224 " **Threshold** filter will create an unstructured grid output and\n"
40225 " you may not have enough memory to create it.\n"
40226 " Do you want to continue?\n"
40227 " </Text>\n"
40228 " </WarnOnCreate>\n"
40229 " </Hints>\n"
40230 " <!-- End Threshold -->\n"
40231 " </SourceProxy>\n"
40232 "\n"
40233 " <!-- ==================================================================== -->\n"
40234 " <SourceProxy class=\"vtkPVPlaneCutter\"\n"
40235 " name=\"SliceWithPlane\"\n"
40236 " label=\"Slice With Plane\">\n"
40237 " <Documentation\n"
40238 " long_help=\"This filter slices a data set with a plane. Slicing is similar to a contour. It creates surfaces from volumes and lines from surfaces. This filter is faster than the standard Slice filter.\"\n"
40239 " short_help=\"Slice datasets with a plane.\">\n"
40240 " This filter extracts the portion of the input dataset that lies along\n"
40241 " the specified plane. The Slice filter takes any type of\n"
40242 " dataset as input. This is a multithreaded implementation.\n"
40243 " </Documentation>\n"
40244 " <InputProperty command=\"SetInputConnection\"\n"
40245 " name=\"Input\">\n"
40246 " <ProxyGroupDomain name=\"groups\">\n"
40247 " <Group name=\"sources\"/>\n"
40248 " <Group name=\"filters\"/>\n"
40249 " </ProxyGroupDomain>\n"
40250 " <DataTypeDomain name=\"input_type\">\n"
40251 " <DataType value=\"vtkDataSet\"/>\n"
40252 " <DataType value=\"vtkCompositeDataSet\"/>\n"
40253 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
40254 " </DataTypeDomain>\n"
40255 " <Documentation>\n"
40256 " This property specifies the input of the slice filter.\n"
40257 " </Documentation>\n"
40258 " </InputProperty>\n"
40259 " <ProxyProperty command=\"SetPlane\"\n"
40260 " label=\"Plane Type\"\n"
40261 " name=\"Plane\">\n"
40262 " <ProxyListDomain name=\"proxy_list\">\n"
40263 " <Group name=\"slice_htg_amr_implicit_functions\" default=\"Plane\"/>\n"
40264 " </ProxyListDomain>\n"
40265 " <Documentation>\n"
40266 " This property sets the parameters of the plane function.\n"
40267 " </Documentation>\n"
40268 " </ProxyProperty>\n"
40269 " <IntVectorProperty animateable=\"0\"\n"
40270 " command=\"SetBuildTree\"\n"
40271 " default_values=\"1\"\n"
40272 " name=\"BuildTree\"\n"
40273 " panel_visibility=\"advanced\"\n"
40274 " number_of_elements=\"1\">\n"
40275 " <BooleanDomain name=\"bool\"/>\n"
40276 " <Hints>\n"
40277 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40278 " name=\"vtkHyperTreeGrid vtkOverlappingAMR\"\n"
40279 " exclude=\"1\"\n"
40280 " mode=\"visibility\"/>\n"
40281 " </Hints>\n"
40282 " <Documentation>\n"
40283 " If enabled and input is not an Image Data, Sphere Tree will be computed, for a faster slice computation.\n"
40284 " </Documentation>\n"
40285 " </IntVectorProperty>\n"
40286 " <IntVectorProperty animateable=\"0\"\n"
40287 " command=\"SetBuildHierarchy\"\n"
40288 " default_values=\"1\"\n"
40289 " name=\"BuildHierarchy\"\n"
40290 " panel_visibility=\"advanced\"\n"
40291 " number_of_elements=\"1\">\n"
40292 " <BooleanDomain name=\"bool\"/>\n"
40293 " <Documentation>\n"
40294 " If enabled and input is not an Image Data, Tree hierarchy will be computed, for a faster slice computation.\n"
40295 " </Documentation>\n"
40296 " <Hints>\n"
40297 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40298 " <Expression type=\"and\">\n"
40299 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40300 " name=\"vtkHyperTreeGrid vtkOverlappingAMR\"\n"
40301 " exclude=\"1\"\n"
40302 " mode=\"visibility\"/>\n"
40303 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
40304 " <Property name=\"BuildTree\" function=\"boolean\"/>\n"
40305 " </PropertyWidgetDecorator>\n"
40306 " </Expression>\n"
40307 " </PropertyWidgetDecorator>\n"
40308 " </Hints>\n"
40309 " </IntVectorProperty>\n"
40310 " <IntVectorProperty animateable=\"0\"\n"
40311 " command=\"SetComputeNormals\"\n"
40312 " default_values=\"0\"\n"
40313 " name=\"ComputeNormals\"\n"
40314 " panel_visibility=\"advanced\"\n"
40315 " number_of_elements=\"1\">\n"
40316 " <BooleanDomain name=\"bool\"/>\n"
40317 " <Hints>\n"
40318 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40319 " name=\"vtkHyperTreeGrid vtkOverlappingAMR\"\n"
40320 " exclude=\"1\"\n"
40321 " mode=\"visibility\"/>\n"
40322 " </Hints>\n"
40323 " <Documentation>\n"
40324 " If enabled, compute the normal on each cell. Since all output cells are coplanar,\n"
40325 " the normal generated is simply the normal of the plane used to slice with.\n"
40326 " By default, computing of normals is disabled.\n"
40327 " </Documentation>\n"
40328 " </IntVectorProperty>\n"
40329 " <IntVectorProperty animateable=\"0\"\n"
40330 " command=\"SetInterpolateAttributes\"\n"
40331 " default_values=\"1\"\n"
40332 " name=\"InterpolateAttributes\"\n"
40333 " panel_visibility=\"advanced\"\n"
40334 " number_of_elements=\"1\">\n"
40335 " <BooleanDomain name=\"bool\"/>\n"
40336 " <Hints>\n"
40337 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40338 " name=\"vtkHyperTreeGrid vtkOverlappingAMR\"\n"
40339 " exclude=\"1\"\n"
40340 " mode=\"visibility\"/>\n"
40341 " </Hints>\n"
40342 " <Documentation>\n"
40343 " If enabled, interpolate attribute data. By default this is\n"
40344 " enabled. Point data is always interpolated. Cell data is transferred\n"
40345 " unless input is an image data.\n"
40346 " </Documentation>\n"
40347 " </IntVectorProperty>\n"
40348 " <IntVectorProperty animateable=\"0\"\n"
40349 " command=\"SetGeneratePolygons\"\n"
40350 " default_values=\"1\"\n"
40351 " name=\"GeneratePolygons\"\n"
40352 " panel_visibility=\"advanced\"\n"
40353 " number_of_elements=\"1\">\n"
40354 " <BooleanDomain name=\"bool\"/>\n"
40355 " <Hints>\n"
40356 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40357 " name=\"vtkHyperTreeGrid vtkOverlappingAMR\"\n"
40358 " exclude=\"1\"\n"
40359 " mode=\"visibility\"/>\n"
40360 " </Hints>\n"
40361 " <Documentation>\n"
40362 " If enabled and input is a vtkImageData, vtkStructuredGrid or vtkRectilinearGrid,\n"
40363 " output slice will consist of polygons instead of only triangles.\n"
40364 " </Documentation>\n"
40365 " </IntVectorProperty>\n"
40366 " <IntVectorProperty command=\"SetMergePoints\"\n"
40367 " default_values=\"0\"\n"
40368 " name=\"MergePoints\"\n"
40369 " label=\"Merge duplicated points in the slice\"\n"
40370 " number_of_elements=\"1\">\n"
40371 " <BooleanDomain name=\"bool\"/>\n"
40372 " <Documentation>This parameter controls whether to merge duplicated points in the slice.</Documentation>\n"
40373 ;
40374
40375 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
40377 " <Hints>\n"
40378 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40379 " name=\"vtkHyperTreeGrid vtkOverlappingAMR\"\n"
40380 " exclude=\"1\"\n"
40381 " mode=\"visibility\"/>\n"
40382 " </Hints>\n"
40383 " </IntVectorProperty>\n"
40384 " <IntVectorProperty command=\"SetDual\"\n"
40385 " default_values=\"0\"\n"
40386 " label=\"Use Dual\"\n"
40387 " name=\"SetDual\"\n"
40388 " number_of_elements=\"1\">\n"
40389 " <Hints>\n"
40390 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40391 " <Expression type=\"and\">\n"
40392 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40393 " mode=\"visibility\"\n"
40394 " name=\"vtkHyperTreeGrid\"/>\n"
40395 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
40396 " mode=\"visibility\"\n"
40397 " property=\"Plane\"\n"
40398 " value=\"Plane\"/>\n"
40399 " </Expression>\n"
40400 " </PropertyWidgetDecorator>\n"
40401 " </Hints>\n"
40402 " <BooleanDomain name=\"bool\"/>\n"
40403 " <Documentation>\n"
40404 " If checked, uses the dual of the hyper tree grid.\n"
40405 " </Documentation>\n"
40406 " </IntVectorProperty>\n"
40407 "\n"
40408 " <IntVectorProperty command=\"SetLevelOfResolution\"\n"
40409 " default_values=\"0\"\n"
40410 " name=\"Level\"\n"
40411 " number_of_elements=\"1\">\n"
40412 " <Hints>\n"
40413 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40414 " mode=\"visibility\"\n"
40415 " name=\"vtkOverlappingAMR\"/>\n"
40416 " </Hints>\n"
40417 " <AMRLevelsDomain default_mode=\"max\"\n"
40418 " name=\"range\">\n"
40419 " <RequiredProperties>\n"
40420 " <Property function=\"Input\"\n"
40421 " name=\"Input\"/>\n"
40422 " </RequiredProperties>\n"
40423 " </AMRLevelsDomain>\n"
40424 " <Documentation>\n"
40425 " Set maximum slice resolution.\n"
40426 " </Documentation>\n"
40427 " </IntVectorProperty>\n"
40428 "\n"
40429 " <IntVectorProperty command=\"SetUseNativeCutter\"\n"
40430 " default_values=\"0\"\n"
40431 " name=\"UseNativeCutter\"\n"
40432 " number_of_elements=\"1\">\n"
40433 " <BooleanDomain name=\"bool\"/>\n"
40434 " <Hints>\n"
40435 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40436 " <Expression type=\"and\">\n"
40437 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40438 " mode=\"visibility\"\n"
40439 " name=\"vtkOverlappingAMR\"/>\n"
40440 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
40441 " mode=\"visibility\"\n"
40442 " property=\"Plane\"\n"
40443 " value=\"Plane\"/>\n"
40444 " </Expression>\n"
40445 " </PropertyWidgetDecorator>\n"
40446 " </Hints>\n"
40447 " <Documentation>\n"
40448 " This property specifies whether the ParaView's generic\n"
40449 " dataset cutter is used instead of the specialized AMR cutter.\n"
40450 " </Documentation>\n"
40451 " </IntVectorProperty>\n"
40452 " <!-- End SliceWithPlane -->\n"
40453 " </SourceProxy>\n"
40454 "\n"
40455 " <!-- ==================================================================== -->\n"
40456 " <SourceProxy class=\"vtkAxisAlignedCutter\"\n"
40457 " name=\"AxisAlignedSlice\"\n"
40458 " label=\"Axis-Aligned Slice\">\n"
40459 " <Documentation long_help=\"Slice input data with an Axis-Aligned cut function, preserving the input type.\"\n"
40460 " short_help=\"Slice input data with an Axis-Aligned cut function.\">\n"
40461 " This filter produces axis-aligned slices of the input HyperTree Grids and Overlapping AMRs.\n"
40462 " The output data type is the same as the input, effectively reducing the dimensionality of the input by one.\n"
40463 " In the case of HyperTree Grids, multiple slices can be produced at once. All output slices are stored in a\n"
40464 " Partitioned Dataset Collection of HyperTree Grids.\n"
40465 " </Documentation>\n"
40466 "\n"
40467 " <InputProperty command=\"SetInputConnection\"\n"
40468 " name=\"Input\">\n"
40469 " <ProxyGroupDomain name=\"groups\">\n"
40470 " <Group name=\"sources\"/>\n"
40471 " <Group name=\"filters\"/>\n"
40472 " </ProxyGroupDomain>\n"
40473 " <DataTypeDomain name=\"input_type\">\n"
40474 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
40475 " <DataType value=\"vtkOverlappingAMR\"/>\n"
40476 " </DataTypeDomain>\n"
40477 " <Documentation>\n"
40478 " This property specifies the input of the slice filter.\n"
40479 " </Documentation>\n"
40480 " </InputProperty>\n"
40481 "\n"
40482 " <ProxyProperty command=\"SetCutFunction\"\n"
40483 " name=\"CutFunction\">\n"
40484 " <ProxyListDomain name=\"proxy_list\">\n"
40485 " <Proxy group=\"implicit_functions\"\n"
40486 " name=\"Axis Aligned Plane\"/>\n"
40487 " </ProxyListDomain>\n"
40488 " <Documentation>\n"
40489 " This property sets the parameters of the cut function.\n"
40490 " </Documentation>\n"
40491 " </ProxyProperty>\n"
40492 "\n"
40493 " <DoubleVectorProperty information_only=\"1\"\n"
40494 " name=\"InputBounds\">\n"
40495 " <BoundsDomain name=\"bounds\">\n"
40496 " <RequiredProperties>\n"
40497 " <Property function=\"Input\"\n"
40498 " name=\"Input\" />\n"
40499 " </RequiredProperties>\n"
40500 " </BoundsDomain>\n"
40501 " </DoubleVectorProperty>\n"
40502 "\n"
40503 " <IntVectorProperty command=\"SetLevelOfResolution\"\n"
40504 " default_values=\"0\"\n"
40505 " name=\"Level\"\n"
40506 " number_of_elements=\"1\">\n"
40507 " <Hints>\n"
40508 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40509 " mode=\"visibility\"\n"
40510 " name=\"vtkOverlappingAMR\"/>\n"
40511 " </Hints>\n"
40512 " <AMRLevelsDomain default_mode=\"max\"\n"
40513 " name=\"range\">\n"
40514 " <RequiredProperties>\n"
40515 " <Property function=\"Input\"\n"
40516 " name=\"Input\"/>\n"
40517 " </RequiredProperties>\n"
40518 " </AMRLevelsDomain>\n"
40519 " <Documentation>\n"
40520 " Set maximum slice resolution.\n"
40521 " </Documentation>\n"
40522 " </IntVectorProperty>\n"
40523 "\n"
40524 " <DoubleVectorProperty animateable=\"1\"\n"
40525 " command=\"SetOffsetValue\"\n"
40526 " name=\"OffsetValues\"\n"
40527 " number_of_elements_per_command=\"1\"\n"
40528 " repeat_command=\"1\"\n"
40529 " set_number_command=\"SetNumberOfOffsetValues\"\n"
40530 " use_index=\"1\"\n"
40531 " panel_visibility=\"advanced\">\n"
40532 " <Hints>\n"
40533 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
40534 " mode=\"visibility\"\n"
40535 " name=\"vtkOverlappingAMR\"\n"
40536 " exclude=\"1\"/>\n"
40537 " </Hints>\n"
40538 " <BoundsDomain mode=\"magnitude\"\n"
40539 " name=\"bounds\">\n"
40540 " <RequiredProperties>\n"
40541 " <Property function=\"Input\"\n"
40542 " name=\"Input\" />\n"
40543 " </RequiredProperties>\n"
40544 " </BoundsDomain>\n"
40545 " <Documentation>\n"
40546 " The values in this property specify a list of current slice\n"
40547 " offset values. This can be used to create multiple slices with\n"
40548 " different centers. Each entry represents a new slice with its center\n"
40549 " shifted by the offset value. The 'Values Range' information is the\n"
40550 " range based on the global bounding box, not necessarily on the current\n"
40551 " slice geometry configuration. **These offset values are added\n"
40552 " to the global offset value set through the \"Offset\" property.**\n"
40553 " </Documentation>\n"
40554 " </DoubleVectorProperty>\n"
40555 " <PropertyGroup label=\"Multiple Slices\">\n"
40556 " <Property name=\"OffsetValues\"/>\n"
40557 " </PropertyGroup>\n"
40558 " <PropertyGroup label=\"Overlapping AMR parameters\">\n"
40559 " <Property name=\"Level\"/>\n"
40560 " </PropertyGroup>\n"
40561 " <!-- End SliceWithAxisAlignedPlane -->\n"
40562 " </SourceProxy>\n"
40563 "\n"
40564 " <!-- ==================================================================== -->\n"
40565 " <SourceProxy class=\"vtkPVTransposeTable\"\n"
40566 " label=\"Transpose Table\"\n"
40567 " name=\"TransposeTable\">\n"
40568 " <Documentation long_help=\"Transpose a table.\"\n"
40569 " short_help=\"Transpose a table.\">\n"
40570 " </Documentation>\n"
40571 " <InputProperty command=\"SetInputConnection\"\n"
40572 " name=\"Input\">\n"
40573 " <ProxyGroupDomain name=\"groups\">\n"
40574 " <Group name=\"sources\" />\n"
40575 " <Group name=\"filters\" />\n"
40576 " </ProxyGroupDomain>\n"
40577 " <DataTypeDomain name=\"input_type\">\n"
40578 " <DataType value=\"vtkTable\" />\n"
40579 " </DataTypeDomain>\n"
40580 " <InputArrayDomain attribute_type=\"row\"\n"
40581 " name=\"input_aray\"\n"
40582 " number_of_components=\"1\"/>\n"
40583 " <Documentation>This property specifies the input to the\n"
40584 " filter.</Documentation>\n"
40585 " </InputProperty>\n"
40586 " <StringVectorProperty clean_command=\"ClearAttributeArrays\"\n"
40587 " command=\"EnableAttributeArray\"\n"
40588 " label=\"Variables of Interest\"\n"
40589 " name=\"SelectArrays\"\n"
40590 " number_of_elements_per_command=\"1\"\n"
40591 " repeat_command=\"1\">\n"
40592 " <ArrayListDomain name=\"array_list\">\n"
40593 " <RequiredProperties>\n"
40594 " <Property function=\"Input\"\n"
40595 " name=\"Input\" />\n"
40596 " </RequiredProperties>\n"
40597 " </ArrayListDomain>\n"
40598 " <Documentation>Choose arrays whose entries will be used to form\n"
40599 " observations for statistical analysis.</Documentation>\n"
40600 " </StringVectorProperty>\n"
40601 " <IntVectorProperty command=\"SetAddIdColumn\"\n"
40602 " default_values=\"1\"\n"
40603 " name=\"AddIdColumn\"\n"
40604 " label=\"Add a column with original columns name\"\n"
40605 " number_of_elements=\"1\">\n"
40606 " <BooleanDomain name=\"bool\" />\n"
40607 " <Documentation>This flag indicates if a column must be inserted\n"
40608 " at index 0 with the names (ids) of the input columns.</Documentation>\n"
40609 " </IntVectorProperty>\n"
40610 " <IntVectorProperty command=\"SetUseIdColumn\"\n"
40611 " default_values=\"0\"\n"
40612 " name=\"UseIdColumn\"\n"
40613 " label=\"Use the column with original columns name\"\n"
40614 " number_of_elements=\"1\">\n"
40615 " <BooleanDomain name=\"bool\" />\n"
40616 " <Documentation>This flag indicates if the output column must be\n"
40617 " named using the names listed in the index 0 column.</Documentation>\n"
40618 " </IntVectorProperty>\n"
40619 " <IntVectorProperty command=\"SetDoNotTranspose\"\n"
40620 " default_values=\"0\"\n"
40621 " name=\"DoNotTranspose\"\n"
40622 " label=\"Only extract selected columns\"\n"
40623 " number_of_elements=\"1\">\n"
40624 " <BooleanDomain name=\"bool\" />\n"
40625 " <Documentation>This flag indicates if the sub-table must be\n"
40626 " effectively transposed or not.</Documentation>\n"
40627 " </IntVectorProperty>\n"
40628 " <!-- End TransposeTable -->\n"
40629 " </SourceProxy>\n"
40630 "\n"
40631 " <!-- ==================================================================== -->\n"
40632 " <SourceProxy class=\"vtkRectilinearGridConnectivity\"\n"
40633 " label=\"Rectilinear Grid Connectivity\"\n"
40634 " name=\"RectilinearGridConnectivity\">\n"
40635 " <Documentation long_help=\"Parallel fragments extraction and attributes integration on rectilinear grids.\"\n"
40636 " short_help=\"Parallel fragments extraction and attributes integration on rectilinear grids.\">\n"
40637 " Extracts material fragments from multiblock vtkRectilinearGrid datasets\n"
40638 " based on the selected volume fraction array(s) and a fraction isovalue\n"
40639 " and integrates the associated attributes.</Documentation>\n"
40640 " <InputProperty command=\"SetInputConnection\"\n"
40641 " name=\"Input\">\n"
40642 " <ProxyGroupDomain name=\"groups\">\n"
40643 " <Group name=\"sources\" />\n"
40644 " <Group name=\"filters\" />\n"
40645 " </ProxyGroupDomain>\n"
40646 " <DataTypeDomain name=\"input_type\">\n"
40647 " <DataType value=\"vtkRectilinearGrid\" />\n"
40648 " <DataType value=\"vtkCompositeDataSet\" />\n"
40649 " </DataTypeDomain>\n"
40650 " <InputArrayDomain attribute_type=\"cell\"\n"
40651 " name=\"input_array\"\n"
40652 " number_of_components=\"1\" />\n"
40653 " <Documentation>This property specifies the input of the\n"
40654 " filter.</Documentation>\n"
40655 " </InputProperty>\n"
40656 " <StringVectorProperty clean_command=\"RemoveDoubleVolumeArrayNames\"\n"
40657 " command=\"AddDoubleVolumeArrayName\"\n"
40658 " label=\"Double Volume Arrays\"\n"
40659 " name=\"AddDoubleVolumeArrayName\"\n"
40660 " number_of_elements_per_command=\"1\"\n"
40661 " repeat_command=\"1\">\n"
40662 " <Documentation>This property specifies the name(s) of the volume\n"
40663 " fraction array(s) for generating parts.</Documentation>\n"
40664 " <ArrayListDomain attribute_type=\"Scalars\"\n"
40665 " data_type=\"VTK_DOUBLE\"\n"
40666 " name=\"array_list\">\n"
40667 " <RequiredProperties>\n"
40668 " <Property function=\"Input\"\n"
40669 " name=\"Input\" />\n"
40670 " </RequiredProperties>\n"
40671 " </ArrayListDomain>\n"
40672 " <Hints>\n"
40673 " <!-- This overrides the GUI's default mechanism to\n"
40674 " not set the default value for this property\n"
40675 " using the domain when the proxy is created -->\n"
40676 " <NoDefault />\n"
40677 " <PropertyWidgetDecorator type=\"CTHArraySelectionDecorator\">\n"
40678 " <Property name=\"AddFloatVolumeArrayName\" />\n"
40679 " <Property name=\"AddUnsignedCharVolumeArrayName\" />\n"
40680 " </PropertyWidgetDecorator>\n"
40681 " </Hints>\n"
40682 " </StringVectorProperty>\n"
40683 " <StringVectorProperty clean_command=\"RemoveFloatVolumeArrayNames\"\n"
40684 " command=\"AddFloatVolumeArrayName\"\n"
40685 " label=\"Float Volume Arrays\"\n"
40686 " name=\"AddFloatVolumeArrayName\"\n"
40687 " number_of_elements_per_command=\"1\"\n"
40688 " repeat_command=\"1\">\n"
40689 " <Documentation>This property specifies the name(s) of the volume\n"
40690 " fraction array(s) for generating parts.</Documentation>\n"
40691 " <ArrayListDomain attribute_type=\"Scalars\"\n"
40692 " data_type=\"VTK_FLOAT\"\n"
40693 " name=\"array_list\">\n"
40694 " <RequiredProperties>\n"
40695 " <Property function=\"Input\"\n"
40696 " name=\"Input\" />\n"
40697 " </RequiredProperties>\n"
40698 ;
40699
40700 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
40702 " </ArrayListDomain>\n"
40703 " <Hints>\n"
40704 " <!-- This overrides the GUI's default mechanism to\n"
40705 " not set the default value for this property\n"
40706 " using the domain when the proxy is created -->\n"
40707 " <NoDefault />\n"
40708 " <PropertyWidgetDecorator type=\"CTHArraySelectionDecorator\">\n"
40709 " <Property name=\"AddDoubleVolumeArrayName\" />\n"
40710 " <Property name=\"AddUnsignedCharVolumeArrayName\" />\n"
40711 " </PropertyWidgetDecorator>\n"
40712 " </Hints>\n"
40713 " </StringVectorProperty>\n"
40714 " <StringVectorProperty clean_command=\"RemoveUnsignedCharVolumeArrayNames\"\n"
40715 " command=\"AddUnsignedCharVolumeArrayName\"\n"
40716 " label=\"Unsigned Character Volume Arrays\"\n"
40717 " name=\"AddUnsignedCharVolumeArrayName\"\n"
40718 " number_of_elements_per_command=\"1\"\n"
40719 " repeat_command=\"1\">\n"
40720 " <Documentation>This property specifies the name(s) of the volume\n"
40721 " fraction array(s) for generating parts.</Documentation>\n"
40722 " <ArrayListDomain attribute_type=\"Scalars\"\n"
40723 " data_type=\"VTK_UNSIGNED_CHAR\"\n"
40724 " name=\"array_list\">\n"
40725 " <RequiredProperties>\n"
40726 " <Property function=\"Input\"\n"
40727 " name=\"Input\" />\n"
40728 " </RequiredProperties>\n"
40729 " </ArrayListDomain>\n"
40730 " <Hints>\n"
40731 " <!-- This overrides the GUI's default mechanism to\n"
40732 " not set the default value for this property\n"
40733 " using the domain when the proxy is created -->\n"
40734 " <NoDefault />\n"
40735 " <PropertyWidgetDecorator type=\"CTHArraySelectionDecorator\">\n"
40736 " <Property name=\"AddDoubleVolumeArrayName\" />\n"
40737 " <Property name=\"AddFloatVolumeArrayName\" />\n"
40738 " </PropertyWidgetDecorator>\n"
40739 " </Hints>\n"
40740 " </StringVectorProperty>\n"
40741 " <DoubleVectorProperty command=\"SetVolumeFractionSurfaceValue\"\n"
40742 " default_values=\"0.1\"\n"
40743 " label=\"Volume Fraction Value\"\n"
40744 " name=\"VolumeFractionSurfaceValue\"\n"
40745 " number_of_elements=\"1\">\n"
40746 " <DoubleRangeDomain max=\"1\"\n"
40747 " min=\"0\"\n"
40748 " name=\"range\" />\n"
40749 " <Documentation>The value of this property is the volume fraction value\n"
40750 " for the surface.</Documentation>\n"
40751 " </DoubleVectorProperty>\n"
40752 " <!-- End Rectilinear Grid Connectivity -->\n"
40753 " </SourceProxy>\n"
40754 "\n"
40755 " <!-- ==================================================================== -->\n"
40756 " <SourceProxy class=\"vtkRulerLineForInput\"\n"
40757 " name=\"RulerFilter\"\n"
40758 " label=\"Bounding Ruler\">\n"
40759 " <Documentation short_help=\"Create a line along the input to use as a ruler\">\n"
40760 " This filter creates a line along the object and defaults its\n"
40761 " representation to showing a ruler along that line.\n"
40762 " </Documentation>\n"
40763 " <InputProperty command=\"SetInputConnection\"\n"
40764 " name=\"Input\">\n"
40765 " <ProxyGroupDomain name=\"groups\">\n"
40766 " <Group name=\"sources\" />\n"
40767 " <Group name=\"filters\" />\n"
40768 " </ProxyGroupDomain>\n"
40769 " <DataTypeDomain name=\"input_type\">\n"
40770 " <DataType value=\"vtkDataObject\" />\n"
40771 " </DataTypeDomain>\n"
40772 " </InputProperty>\n"
40773 " <IntVectorProperty command=\"SetAxis\"\n"
40774 " default_values=\"0\"\n"
40775 " name=\"Axis\"\n"
40776 " number_of_elements=\"1\">\n"
40777 " <EnumerationDomain name=\"enum\">\n"
40778 " <Entry text=\"X Axis\"\n"
40779 " value=\"0\" />\n"
40780 " <Entry text=\"Y Axis\"\n"
40781 " value=\"1\" />\n"
40782 " <Entry text=\"Z Axis\"\n"
40783 " value=\"2\" />\n"
40784 " <Entry text=\"Oriented Bounding Box Major Axis\"\n"
40785 " value=\"3\" />\n"
40786 " <Entry text=\"Oriented Bounding Box Medium Axis\"\n"
40787 " value=\"4\" />\n"
40788 " <Entry text=\"Oriented Bounding Box Minor Axis\"\n"
40789 " value=\"5\" />\n"
40790 " </EnumerationDomain>\n"
40791 " <Documentation>Select along which axis the ruler should be aligned. Note:\n"
40792 " this filter requires that all points in the dataset to which it is applied\n"
40793 " be copied to a single rank when this option is set to any of the\n"
40794 " Oriented Bound Box options, so make sure the dataset can fit on one rank\n"
40795 " before applying this filter.</Documentation>\n"
40796 " </IntVectorProperty>\n"
40797 " <Hints>\n"
40798 " <Representation view=\"RenderView\" type=\"RulerSourceRepresentation\" />\n"
40799 " <Visibility replace_input=\"0\" />\n"
40800 " </Hints>\n"
40801 " <!-- End vtkRulerLineForInput -->\n"
40802 " </SourceProxy>\n"
40803 "\n"
40804 " <!-- ==================================================================== -->\n"
40805 " <SourceProxy class=\"vtkSliceAlongPolyPlane\"\n"
40806 " label=\"Slice Along PolyLine\"\n"
40807 " name=\"SliceAlongPolyLine\">\n"
40808 " <Documentation\n"
40809 " long_help=\"Slice along the surface defined by sweeping a polyline parallel to the z-axis.\"\n"
40810 " short_help=\"Slice along the surface defined by sweeping a polyline parallel to the z-axis.\">\n"
40811 " The Slice Along PolyLine filter is similar to the Slice Filter except that it slices along a surface that\n"
40812 " is defined by sweeping the input polyline parallel to the z-axis. Explained another way: take a laser\n"
40813 " cutter and move it so that it hits every point on the input polyline while keeping it parallel\n"
40814 " to the z-axis. The surface cut from the input dataset is the result.\n"
40815 " </Documentation>\n"
40816 " <InputProperty command=\"SetInputConnection\" name=\"Dataset\" port_index=\"0\">\n"
40817 " <ProxyGroupDomain name=\"groups\">\n"
40818 " <Group name=\"sources\" />\n"
40819 " <Group name=\"filters\" />\n"
40820 " </ProxyGroupDomain>\n"
40821 " <DataTypeDomain name=\"input_type\">\n"
40822 " <DataType value=\"vtkDataSet\" />\n"
40823 " </DataTypeDomain>\n"
40824 " <Documentation>\n"
40825 " Set the vtkDataObject to slice.\n"
40826 " </Documentation>\n"
40827 " </InputProperty>\n"
40828 " <InputProperty command=\"SetInputConnection\" name=\"PolyLine\" port_index=\"1\">\n"
40829 " <ProxyGroupDomain name=\"groups\">\n"
40830 " <Group name=\"sources\" />\n"
40831 " <Group name=\"filters\" />\n"
40832 " </ProxyGroupDomain>\n"
40833 " <DataTypeDomain name=\"input_type\">\n"
40834 " <DataType value=\"vtkPolyData\" />\n"
40835 " </DataTypeDomain>\n"
40836 " <Documentation>\n"
40837 " Set the polyline to slice along.\n"
40838 " </Documentation>\n"
40839 " </InputProperty>\n"
40840 " <DoubleVectorProperty animatable=\"0\"\n"
40841 " command=\"SetTolerance\"\n"
40842 " default_values=\"10\"\n"
40843 " label=\"Tolerance\"\n"
40844 " name=\"Tolerance\"\n"
40845 " number_of_elements=\"1\">\n"
40846 " <BoundsDomain mode=\"approximate_cell_length\"\n"
40847 " name=\"bounds\">\n"
40848 " <RequiredProperties>\n"
40849 " <Property function=\"Input\" name=\"Dataset\" />\n"
40850 " </RequiredProperties>\n"
40851 " </BoundsDomain>\n"
40852 " <Documentation>\n"
40853 " The threshold used internally to determine correspondence between the polyline\n"
40854 " and the output slice. If the output has sections missing, increasing this\n"
40855 " value may help.\n"
40856 " </Documentation>\n"
40857 " </DoubleVectorProperty>\n"
40858 " <!-- End Slice Along PolyLine -->\n"
40859 " </SourceProxy>\n"
40860 "\n"
40861 " <!-- ==================================================================== -->\n"
40862 " <SourceProxy class=\"vtkThresholdTable\"\n"
40863 " label=\"Threshold Table\"\n"
40864 " name=\"ThresholdTable\">\n"
40865 " <Documentation long_help=\"This filter extracts table rows that satisfy a threshold criterion for a given column.\"\n"
40866 " short_help=\"Threshold table rows.\">\n"
40867 " The Threshold Table Filter uses minimum and/or maximum values to threshold\n"
40868 " table rows based on the values in a particular column of a vtkTable object.\n"
40869 " It operates on scalar fields, and accepts two thresholding parameters:\n"
40870 " MinValue and MaxValue. This filter offers four different thresholding\n"
40871 " methods : \"Below Max Threshold\", \"Above Min Threshold\", \"Between\", and \"Outside\".\n"
40872 " The output of this filter is a vtkTable object with less or as many rows as the input vtkTable.\n"
40873 " </Documentation>\n"
40874 " <InputProperty command=\"SetInputConnection\"\n"
40875 " name=\"Input\">\n"
40876 " <ProxyGroupDomain name=\"groups\">\n"
40877 " <Group name=\"sources\" />\n"
40878 " <Group name=\"filters\" />\n"
40879 " </ProxyGroupDomain>\n"
40880 " <DataTypeDomain name=\"input_type\">\n"
40881 " <DataType value=\"vtkTable\" />\n"
40882 " </DataTypeDomain>\n"
40883 " <InputArrayDomain name=\"input_array\"\n"
40884 " number_of_components=\"1\"/>\n"
40885 " <Documentation>This property specifies the input to the Threshold Table\n"
40886 " filter.</Documentation>\n"
40887 " </InputProperty>\n"
40888 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
40889 " element_types=\"0 0 0 0 2\"\n"
40890 " label=\"Column\"\n"
40891 " name=\"SelectInputScalars\"\n"
40892 " number_of_elements=\"5\">\n"
40893 " <ArrayListDomain attribute_type=\"Scalars\"\n"
40894 " name=\"array_list\">\n"
40895 " <RequiredProperties>\n"
40896 " <Property function=\"Input\"\n"
40897 " name=\"Input\" />\n"
40898 " </RequiredProperties>\n"
40899 " </ArrayListDomain>\n"
40900 " <Documentation>This property specifies which column to use for\n"
40901 " thresholding.</Documentation>\n"
40902 " </StringVectorProperty>\n"
40903 " <DoubleVectorProperty command=\"SetMinValue\"\n"
40904 " default_values=\"0\"\n"
40905 " name=\"MinValue\"\n"
40906 " number_of_elements=\"1\">\n"
40907 " <ArrayRangeDomain name=\"range\"\n"
40908 " default_mode=\"min\">\n"
40909 " <RequiredProperties>\n"
40910 " <Property function=\"Input\"\n"
40911 " name=\"Input\" />\n"
40912 " <Property function=\"ArraySelection\"\n"
40913 " name=\"SelectInputScalars\" />\n"
40914 " </RequiredProperties>\n"
40915 " </ArrayRangeDomain>\n"
40916 " <Hints>\n"
40917 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40918 " <Expression type=\"or\">\n"
40919 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"Mode\" value=\"1\" />\n"
40920 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"Mode\" value=\"2\" />\n"
40921 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"Mode\" value=\"3\" />\n"
40922 " </Expression>\n"
40923 " </PropertyWidgetDecorator>\n"
40924 " </Hints>\n"
40925 " <Documentation>\n"
40926 " The value of this property specifies the lower bound of the\n"
40927 " thresholding operation.\n"
40928 " </Documentation>\n"
40929 " </DoubleVectorProperty>\n"
40930 " <DoubleVectorProperty command=\"SetMaxValue\"\n"
40931 " default_values=\"0\"\n"
40932 " name=\"MaxValue\"\n"
40933 " number_of_elements=\"1\">\n"
40934 " <ArrayRangeDomain name=\"range\"\n"
40935 " default_mode=\"max\">\n"
40936 " <RequiredProperties>\n"
40937 " <Property function=\"Input\"\n"
40938 " name=\"Input\" />\n"
40939 " <Property function=\"ArraySelection\"\n"
40940 " name=\"SelectInputScalars\" />\n"
40941 " </RequiredProperties>\n"
40942 " </ArrayRangeDomain>\n"
40943 " <Hints>\n"
40944 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
40945 " <Expression type=\"or\">\n"
40946 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"Mode\" value=\"0\" />\n"
40947 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"Mode\" value=\"2\" />\n"
40948 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"Mode\" value=\"3\" />\n"
40949 " </Expression>\n"
40950 " </PropertyWidgetDecorator>\n"
40951 " </Hints>\n"
40952 " <Documentation>\n"
40953 " The value of this property specifies the upper bound of the\n"
40954 " thresholding operation.\n"
40955 " </Documentation>\n"
40956 " </DoubleVectorProperty>\n"
40957 " <IntVectorProperty command=\"SetMode\"\n"
40958 " default_values=\"2\"\n"
40959 " name=\"Mode\"\n"
40960 " number_of_elements=\"1\"\n"
40961 " panel_visibility=\"default\">\n"
40962 " <EnumerationDomain name=\"enum\">\n"
40963 " <Entry text=\"Below Max Threshold\" value=\"0\"/>\n"
40964 " <Entry text=\"Above Min Threshold\" value=\"1\"/>\n"
40965 " <Entry text=\"Between\" value=\"2\"/>\n"
40966 " <Entry text=\"Outside\" value=\"3\"/>\n"
40967 " </EnumerationDomain>\n"
40968 " <Documentation>\n"
40969 " This property indicates the threshold method.\n"
40970 " </Documentation>\n"
40971 " </IntVectorProperty>\n"
40972 " <!-- End ThresholdTable -->\n"
40973 " </SourceProxy>\n"
40974 "\n"
40975 " <!-- ==================================================================== -->\n"
40976 " <SourceProxy class=\"vtkSurfaceVectors\"\n"
40977 " label=\"Surface Vectors\"\n"
40978 " name=\"SurfaceVectors\">\n"
40979 " <Documentation long_help=\"This filter constrains vectors to lie on a surface.\"\n"
40980 " short_help=\"This filter constrains vectors to lie on a surface.\">\n"
40981 " The Surface Vectors filter is used for 2D data sets. It\n"
40982 " constrains vectors to lie in a surface by removing\n"
40983 " components of the vectors normal to the local\n"
40984 " surface.</Documentation>\n"
40985 " <InputProperty command=\"SetInputConnection\"\n"
40986 " name=\"Input\">\n"
40987 " <ProxyGroupDomain name=\"groups\">\n"
40988 " <Group name=\"sources\" />\n"
40989 " <Group name=\"filters\" />\n"
40990 " </ProxyGroupDomain>\n"
40991 " <DataTypeDomain name=\"input_type\">\n"
40992 " <DataType value=\"vtkDataSet\" />\n"
40993 " </DataTypeDomain>\n"
40994 " <InputArrayDomain attribute_type=\"point\"\n"
40995 " name=\"input_array\"\n"
40996 " number_of_components=\"3\" />\n"
40997 " <Documentation>This property specifies the input to the Surface Vectors\n"
40998 " filter.</Documentation>\n"
40999 " </InputProperty>\n"
41000 " <StringVectorProperty animateable=\"0\"\n"
41001 " command=\"SetInputArrayToProcess\"\n"
41002 " element_types=\"0 0 0 0 2\"\n"
41003 " name=\"SelectInputVectors\"\n"
41004 " number_of_elements=\"5\">\n"
41005 " <ArrayListDomain attribute_type=\"Vectors\"\n"
41006 " name=\"array_list\">\n"
41007 " <RequiredProperties>\n"
41008 " <Property function=\"Input\"\n"
41009 " name=\"Input\" />\n"
41010 " </RequiredProperties>\n"
41011 " </ArrayListDomain>\n"
41012 ;
41013
41014 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
41016 " <Documentation>This property specifies the name of the input vector\n"
41017 " array to process.</Documentation>\n"
41018 " </StringVectorProperty>\n"
41019 " <IntVectorProperty command=\"SetConstraintMode\"\n"
41020 " default_values=\"0\"\n"
41021 " name=\"ConstraintMode\"\n"
41022 " number_of_elements=\"1\">\n"
41023 " <EnumerationDomain name=\"enum\">\n"
41024 " <Entry text=\"Parallel\"\n"
41025 " value=\"0\" />\n"
41026 " <Entry text=\"Perpendicular\"\n"
41027 " value=\"1\" />\n"
41028 " <Entry text=\"PerpendicularScale\"\n"
41029 " value=\"2\" />\n"
41030 " </EnumerationDomain>\n"
41031 " <Documentation>This property specifies whether the vectors will be\n"
41032 " parallel or perpendicular to the surface. If the value is set to\n"
41033 " PerpendicularScale (2), then the output will contain a scalar array\n"
41034 " with the dot product of the surface normal and the vector at each\n"
41035 " point.</Documentation>\n"
41036 " </IntVectorProperty>\n"
41037 " <!-- End SurfaceVectors -->\n"
41038 " </SourceProxy>\n"
41039 "\n"
41040 " <!-- ==================================================================== -->\n"
41041 " <SourceProxy class=\"vtkTimeStepProgressFilter\"\n"
41042 " label=\"Time Step Progress Bar\"\n"
41043 " name=\"TimeStepProgressFilter\">\n"
41044 " <Documentation long_help=\"Shows input data time as progress bar in the view.\"\n"
41045 " short_help=\"Show data time step as progress bar.\">The Time Step Progress Bar\n"
41046 " filter can be used to show the relative position of the actual time step/value\n"
41047 " relatively to the number of timesteps/data time range in a progress bar.\n"
41048 " </Documentation>\n"
41049 " <InputProperty command=\"SetInputConnection\"\n"
41050 " name=\"Input\">\n"
41051 " <ProxyGroupDomain name=\"groups\">\n"
41052 " <Group name=\"sources\" />\n"
41053 " <Group name=\"filters\" />\n"
41054 " </ProxyGroupDomain>\n"
41055 " <Documentation>This property specifies the input dataset for which to\n"
41056 " display the time step.</Documentation>\n"
41057 " </InputProperty>\n"
41058 " <Hints>\n"
41059 " <Visibility replace_input=\"0\" />\n"
41060 " <OutputPort index=\"0\"\n"
41061 " name=\"Output-0\"\n"
41062 " type=\"progress\" />\n"
41063 " </Hints>\n"
41064 " <!-- End of TimeToTextConvertor -->\n"
41065 " </SourceProxy>\n"
41066 "\n"
41067 " <!-- ==================================================================== -->\n"
41068 " <SourceProxy class=\"vtkTimeToTextConvertor\"\n"
41069 " label=\"Annotate Time Filter\"\n"
41070 " name=\"TimeToTextConvertor\">\n"
41071 " <Documentation long_help=\"Shows input data time as text annnotation in the view.\"\n"
41072 " short_help=\"Show data time as text.\">The Annotate Time\n"
41073 " filter can be used to show the data time in a text\n"
41074 " annotation.</Documentation>\n"
41075 " <InputProperty command=\"SetInputConnection\"\n"
41076 " name=\"Input\">\n"
41077 " <ProxyGroupDomain name=\"groups\">\n"
41078 " <Group name=\"sources\" />\n"
41079 " <Group name=\"filters\" />\n"
41080 " </ProxyGroupDomain>\n"
41081 " <Documentation>This property specifies the input dataset for which to\n"
41082 " display the time.</Documentation>\n"
41083 " </InputProperty>\n"
41084 " <StringVectorProperty command=\"SetFormat\"\n"
41085 " default_values=\"Time: {time:f}\"\n"
41086 " name=\"Format\"\n"
41087 " number_of_elements=\"1\"\n"
41088 " panel_visibility=\"default\">\n"
41089 " <Documentation>The value of this property is a format string used to\n"
41090 " display the input time. The format string is specified using fmt style\n"
41091 " </Documentation>\n"
41092 " </StringVectorProperty>\n"
41093 " <DoubleVectorProperty command=\"SetShift\"\n"
41094 " default_values=\"0.0\"\n"
41095 " name=\"Shift\"\n"
41096 " number_of_elements=\"1\">\n"
41097 " <DoubleRangeDomain name=\"range\" />\n"
41098 " <Documentation>The amount of time the input is shifted (after\n"
41099 " scaling).</Documentation>\n"
41100 " </DoubleVectorProperty>\n"
41101 " <DoubleVectorProperty command=\"SetScale\"\n"
41102 " default_values=\"1.0\"\n"
41103 " name=\"Scale\"\n"
41104 " number_of_elements=\"1\">\n"
41105 " <DoubleRangeDomain name=\"range\" />\n"
41106 " <Documentation>The factor by which the input time is\n"
41107 " scaled.</Documentation>\n"
41108 " </DoubleVectorProperty>\n"
41109 " <Hints>\n"
41110 " <Visibility replace_input=\"0\" />\n"
41111 " <OutputPort index=\"0\"\n"
41112 " name=\"Output-0\"\n"
41113 " type=\"text\" />\n"
41114 " </Hints>\n"
41115 " <!-- End of TimeToTextConvertor -->\n"
41116 " </SourceProxy>\n"
41117 "\n"
41118 " <!-- ==================================================================== -->\n"
41119 " <SourceProxy class=\"vtkOMETIFFChannelCalculator\" name=\"OMETIFFChannelCalculator\"\n"
41120 " label=\"OME TIFF Channel Calculator\">\n"
41121 " <InputProperty command=\"SetInputConnection\" name=\"Input\">\n"
41122 " <ProxyGroupDomain name=\"groups\">\n"
41123 " <Group name=\"sources\" />\n"
41124 " <Group name=\"filters\" />\n"
41125 " </ProxyGroupDomain>\n"
41126 " <DataTypeDomain name=\"input_type\">\n"
41127 " <DataType value=\"vtkImageData\" />\n"
41128 " </DataTypeDomain>\n"
41129 " <InputArrayDomain name=\"point_arrays\" attribute_type=\"point\" optional=\"1\" />\n"
41130 " </InputProperty>\n"
41131 "\n"
41132 " <StringVectorProperty\n"
41133 " name=\"ChannelVisibilities\"\n"
41134 " command=\"GetChannelSelection\"\n"
41135 " number_of_elements_per_command=\"1\"\n"
41136 " repeat_command=\"1\"\n"
41137 " si_class=\"vtkSIDataArraySelectionProperty\">\n"
41138 " <ArrayListDomain name=\"array_list\" input_domain_name=\"point_arrays\">\n"
41139 " <RequiredProperties>\n"
41140 " <Property name=\"Input\" function=\"Input\" />\n"
41141 " </RequiredProperties>\n"
41142 " </ArrayListDomain>\n"
41143 " <Documentation>\n"
41144 " Select the point data arrays to pass through\n"
41145 " </Documentation>\n"
41146 " <Hints>\n"
41147 " <ArraySelectionWidget icon_type=\"point\"/>\n"
41148 " </Hints>\n"
41149 " </StringVectorProperty>\n"
41150 "\n"
41151 " <ProxyProperty command=\"SetChannel1LUT\" name=\"Channel1LUT\" >\n"
41152 " <ProxyGroupDomain name=\"groups\">\n"
41153 " <Group name=\"lookup_tables\" />\n"
41154 " </ProxyGroupDomain>\n"
41155 " </ProxyProperty>\n"
41156 " <ProxyProperty command=\"SetChannel2LUT\" name=\"Channel2LUT\" >\n"
41157 " <ProxyGroupDomain name=\"groups\">\n"
41158 " <Group name=\"lookup_tables\" />\n"
41159 " </ProxyGroupDomain>\n"
41160 " </ProxyProperty>\n"
41161 " <ProxyProperty command=\"SetChannel3LUT\" name=\"Channel3LUT\" >\n"
41162 " <ProxyGroupDomain name=\"groups\">\n"
41163 " <Group name=\"lookup_tables\" />\n"
41164 " </ProxyGroupDomain>\n"
41165 " </ProxyProperty>\n"
41166 " <ProxyProperty command=\"SetChannel4LUT\" name=\"Channel4LUT\" >\n"
41167 " <ProxyGroupDomain name=\"groups\">\n"
41168 " <Group name=\"lookup_tables\" />\n"
41169 " </ProxyGroupDomain>\n"
41170 " </ProxyProperty>\n"
41171 " <ProxyProperty command=\"SetChannel5LUT\" name=\"Channel5LUT\" >\n"
41172 " <ProxyGroupDomain name=\"groups\">\n"
41173 " <Group name=\"lookup_tables\" />\n"
41174 " </ProxyGroupDomain>\n"
41175 " </ProxyProperty>\n"
41176 " <ProxyProperty command=\"SetChannel6LUT\" name=\"Channel6LUT\" >\n"
41177 " <ProxyGroupDomain name=\"groups\">\n"
41178 " <Group name=\"lookup_tables\" />\n"
41179 " </ProxyGroupDomain>\n"
41180 " </ProxyProperty>\n"
41181 " <ProxyProperty command=\"SetChannel7LUT\" name=\"Channel7LUT\" >\n"
41182 " <ProxyGroupDomain name=\"groups\">\n"
41183 " <Group name=\"lookup_tables\" />\n"
41184 " </ProxyGroupDomain>\n"
41185 " </ProxyProperty>\n"
41186 " <ProxyProperty command=\"SetChannel8LUT\" name=\"Channel8LUT\" >\n"
41187 " <ProxyGroupDomain name=\"groups\">\n"
41188 " <Group name=\"lookup_tables\" />\n"
41189 " </ProxyGroupDomain>\n"
41190 " </ProxyProperty>\n"
41191 " <ProxyProperty command=\"SetChannel9LUT\" name=\"Channel9LUT\" >\n"
41192 " <ProxyGroupDomain name=\"groups\">\n"
41193 " <Group name=\"lookup_tables\" />\n"
41194 " </ProxyGroupDomain>\n"
41195 " </ProxyProperty>\n"
41196 " <ProxyProperty command=\"SetChannel10LUT\" name=\"Channel10LUT\" >\n"
41197 " <ProxyGroupDomain name=\"groups\">\n"
41198 " <Group name=\"lookup_tables\" />\n"
41199 " </ProxyGroupDomain>\n"
41200 " </ProxyProperty>\n"
41201 " <DoubleVectorProperty name=\"Channel1Weight\"\n"
41202 " command=\"SetChannel1Weight\"\n"
41203 " number_of_elements=\"1\"\n"
41204 " default_values=\"1.0\" />\n"
41205 " <DoubleVectorProperty name=\"Channel2Weight\"\n"
41206 " command=\"SetChannel2Weight\"\n"
41207 " number_of_elements=\"1\"\n"
41208 " default_values=\"1.0\" />\n"
41209 " <DoubleVectorProperty name=\"Channel3Weight\"\n"
41210 " command=\"SetChannel3Weight\"\n"
41211 " number_of_elements=\"1\"\n"
41212 " default_values=\"1.0\" />\n"
41213 " <DoubleVectorProperty name=\"Channel4Weight\"\n"
41214 " command=\"SetChannel4Weight\"\n"
41215 " number_of_elements=\"1\"\n"
41216 " default_values=\"1.0\" />\n"
41217 " <DoubleVectorProperty name=\"Channel5Weight\"\n"
41218 " command=\"SetChannel5Weight\"\n"
41219 " number_of_elements=\"1\"\n"
41220 " default_values=\"1.0\" />\n"
41221 " <DoubleVectorProperty name=\"Channel6Weight\"\n"
41222 " command=\"SetChannel6Weight\"\n"
41223 " number_of_elements=\"1\"\n"
41224 " default_values=\"1.0\" />\n"
41225 " <DoubleVectorProperty name=\"Channel7Weight\"\n"
41226 " command=\"SetChannel7Weight\"\n"
41227 " number_of_elements=\"1\"\n"
41228 " default_values=\"1.0\" />\n"
41229 " <DoubleVectorProperty name=\"Channel8Weight\"\n"
41230 " command=\"SetChannel8Weight\"\n"
41231 " number_of_elements=\"1\"\n"
41232 " default_values=\"1.0\" />\n"
41233 " <DoubleVectorProperty name=\"Channel9Weight\"\n"
41234 " command=\"SetChannel9Weight\"\n"
41235 " number_of_elements=\"1\"\n"
41236 " default_values=\"1.0\" />\n"
41237 " <DoubleVectorProperty name=\"Channel10Weight\"\n"
41238 " command=\"SetChannel10Weight\"\n"
41239 " number_of_elements=\"1\"\n"
41240 " default_values=\"1.0\" />\n"
41241 "\n"
41242 " <PropertyGroup label=\"Color + Opacity Settings\" panel_widget=\"OMETransferFunctions\">\n"
41243 " <Property name=\"Channel1LUT\" function=\"Channel_1\" />\n"
41244 " <Property name=\"Channel2LUT\" function=\"Channel_2\" />\n"
41245 " <Property name=\"Channel3LUT\" function=\"Channel_3\" />\n"
41246 " <Property name=\"Channel4LUT\" function=\"Channel_4\" />\n"
41247 " <Property name=\"Channel5LUT\" function=\"Channel_5\" />\n"
41248 " <Property name=\"Channel6LUT\" function=\"Channel_6\" />\n"
41249 " <Property name=\"Channel7LUT\" function=\"Channel_7\" />\n"
41250 " <Property name=\"Channel8LUT\" function=\"Channel_8\" />\n"
41251 " <Property name=\"Channel9LUT\" function=\"Channel_9\" />\n"
41252 " <Property name=\"Channel10LUT\" function=\"Channel_10\" />\n"
41253 " <Property name=\"Channel1Weight\" function=\"Channel_1Weight\" />\n"
41254 " <Property name=\"Channel2Weight\" function=\"Channel_2Weight\" />\n"
41255 " <Property name=\"Channel3Weight\" function=\"Channel_3Weight\" />\n"
41256 " <Property name=\"Channel4Weight\" function=\"Channel_4Weight\" />\n"
41257 " <Property name=\"Channel5Weight\" function=\"Channel_5Weight\" />\n"
41258 " <Property name=\"Channel6Weight\" function=\"Channel_6Weight\" />\n"
41259 " <Property name=\"Channel7Weight\" function=\"Channel_7Weight\" />\n"
41260 " <Property name=\"Channel8Weight\" function=\"Channel_8Weight\" />\n"
41261 " <Property name=\"Channel9Weight\" function=\"Channel_9Weight\" />\n"
41262 " <Property name=\"Channel10Weight\" function=\"Channel_10Weight\" />\n"
41263 " </PropertyGroup>\n"
41264 " <Hints>\n"
41265 " <InitializationHelper class=\"vtkSMOMETIFFChannelCalculatorInitializationHelper\" />\n"
41266 " </Hints>\n"
41267 " </SourceProxy>\n"
41268 "\n"
41269 " <!-- ==================================================================== -->\n"
41270 " <SourceProxy class=\"vtkAnnotateGlobalDataFilter\"\n"
41271 " label=\"Annotate Global Data\"\n"
41272 " name=\"AnnotateGlobalData\">\n"
41273 " <Documentation short_help=\"Filter for annotating with global/field data\">\n"
41274 " Generates annotation text from global / field data presumed to be associated\n"
41275 " with time steps in the source dataset for this filter.\n"
41276 " If the field array chosen has as many elements as number of timesteps,\n"
41277 " the array is assumed to be \"temporal\" and indexed using the current\n"
41278 " timestep.\n"
41279 " </Documentation>\n"
41280 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
41281 " command=\"AddInputConnection\"\n"
41282 " multiple_input=\"1\"\n"
41283 " name=\"Input\">\n"
41284 " <ProxyGroupDomain name=\"groups\">\n"
41285 " <Group name=\"sources\" />\n"
41286 " <Group name=\"filters\" />\n"
41287 " </ProxyGroupDomain>\n"
41288 " <DataTypeDomain name=\"input_type\">\n"
41289 " <DataType value=\"vtkDataObject\" />\n"
41290 " <DataType value=\"vtkHyperTreeGrid\" />\n"
41291 " </DataTypeDomain>\n"
41292 " <InputArrayDomain attribute_type=\"field\"\n"
41293 " name=\"input_array\"\n"
41294 " number_of_components=\"1\" />\n"
41295 " <Documentation>Set the input of the filter.</Documentation>\n"
41296 " </InputProperty>\n"
41297 " <StringVectorProperty command=\"SetFieldArrayName\"\n"
41298 " name=\"SelectArrays\"\n"
41299 " number_of_elements=\"1\">\n"
41300 " <ArrayListDomain name=\"array_list\">\n"
41301 " <RequiredProperties>\n"
41302 " <Property function=\"Input\"\n"
41303 " name=\"Input\" />\n"
41304 " </RequiredProperties>\n"
41305 " </ArrayListDomain>\n"
41306 " <Documentation>Choose array that is going to be\n"
41307 " displayed.</Documentation>\n"
41308 " </StringVectorProperty>\n"
41309 " <StringVectorProperty command=\"SetPrefix\"\n"
41310 " default_values=\"Value is: \"\n"
41311 " name=\"Prefix\"\n"
41312 " number_of_elements=\"1\">\n"
41313 " <Documentation>Text that is used as a prefix to the field\n"
41314 " value.</Documentation>\n"
41315 " </StringVectorProperty>\n"
41316 " <StringVectorProperty command=\"SetFormat\"\n"
41317 " default_values=\"%7.5g\"\n"
41318 " name=\"Format\"\n"
41319 " number_of_elements=\"1\">\n"
41320 " <Documentation>Text that is used as the C format string used by the\n"
41321 " snprintf string formatter used to convert a global data value to a string.\n"
41322 " </Documentation>\n"
41323 " </StringVectorProperty>\n"
41324 " <StringVectorProperty command=\"SetPostfix\"\n"
41325 " default_values=\"\"\n"
41326 " name=\"Suffix\"\n"
41327 " number_of_elements=\"1\">\n"
41328 " <Documentation>Text that is used as a suffix to the field\n"
41329 " value.</Documentation>\n"
41330 " </StringVectorProperty>\n"
41331 " <Hints>\n"
41332 " <Visibility replace_input=\"0\" />\n"
41333 " <OutputPort index=\"0\" name=\"Output-0\" type=\"text\" />\n"
41334 " </Hints>\n"
41335 " <!-- End AnnotateGlobalData -->\n"
41336 " </SourceProxy>\n"
41337 "\n"
41338 " <!-- ==================================================================== -->\n"
41339 " <SourceProxy class=\"vtkAnnotateSelectionFilter\"\n"
41340 ;
41341
41342 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
41344 " label=\"Annotate Selection\"\n"
41345 " name=\"AnnotateSelection\">\n"
41346 " <Documentation short_help=\"Filter for annotating selection\">\n"
41347 " Generates annotation text for each selectionNode from a selection.\n"
41348 " </Documentation>\n"
41349 " <InputProperty command=\"SetInputConnection\"\n"
41350 " name=\"Input\">\n"
41351 " <ProxyGroupDomain name=\"groups\">\n"
41352 " <Group name=\"sources\"/>\n"
41353 " <Group name=\"filters\"/>\n"
41354 " </ProxyGroupDomain>\n"
41355 " <DataTypeDomain name=\"input_type\">\n"
41356 " <DataType value=\"vtkDataSet\"/>\n"
41357 " </DataTypeDomain>\n"
41358 " <Documentation>\n"
41359 " This property specifies the input from which the selection is extracted.\n"
41360 " </Documentation>\n"
41361 " </InputProperty>\n"
41362 " <InputProperty command=\"SetSelectionConnection\"\n"
41363 " name=\"Selection\">\n"
41364 " <ProxyGroupDomain name=\"groups\">\n"
41365 " <Group name=\"sources\"/>\n"
41366 " <Group name=\"filters\"/>\n"
41367 " </ProxyGroupDomain>\n"
41368 " <DataTypeDomain name=\"input_type\">\n"
41369 " <DataType value=\"vtkSelection\"/>\n"
41370 " </DataTypeDomain>\n"
41371 " <Documentation>\n"
41372 " The input that provides the selection object.\n"
41373 " </Documentation>\n"
41374 " <Hints>\n"
41375 " <!-- This tag alerts the auto-generated panels and input selection\n"
41376 " that this input is a selection. It should use the special\n"
41377 " selection GUI. -->\n"
41378 " <SelectionInput/>\n"
41379 " </Hints>\n"
41380 " </InputProperty>\n"
41381 " <StringVectorProperty name=\"Labels\"\n"
41382 " command=\"SetLabels\"\n"
41383 " clean_command=\"ResetLabels\"\n"
41384 " number_of_elements_per_command=\"1\"\n"
41385 " repeat_command=\"1\"\n"
41386 " use_index=\"1\"\n"
41387 " panel_visibility=\"default\">\n"
41388 " <Documentation>\n"
41389 " Associated for each selection node an label.\n"
41390 " </Documentation>\n"
41391 " </StringVectorProperty>\n"
41392 " <StringVectorProperty name=\"DefaultLabel\"\n"
41393 " command=\"SetDefaultLabel\"\n"
41394 " default_values=\"none\"\n"
41395 " number_of_elements=\"1\"\n"
41396 " panel_visibility=\"default\">\n"
41397 " <Documentation>\n"
41398 " Specify the default label used for unlabelized data.\n"
41399 " </Documentation>\n"
41400 " </StringVectorProperty>\n"
41401 " <PropertyGroup name = \"LabelsOnSelection\" panel_widget=\"SelectionList\" >\n"
41402 " <Property name=\"Labels\" />\n"
41403 " <Property name=\"Selection\"/>\n"
41404 " </PropertyGroup>\n"
41405 " <Hints>\n"
41406 " <InitializationHelper class=\"vtkSMExtractSelectionProxyInitializationHelper\"/>\n"
41407 " <WarnOnCreate>\n"
41408 " <DataTypeDomain name=\"input_type\">\n"
41409 " <DataType value=\"vtkImageData\" />\n"
41410 " <DataType value=\"vtkRectilinearGrid\" />\n"
41411 " <DataType value=\"vtkStructuredGrid\" />\n"
41412 " </DataTypeDomain>\n"
41413 " <MemoryUsage relative=\"20\" />\n"
41414 " <Text title=\"Potentially running out of memory\">\n"
41415 " **Extract Selection** filter will create an unstructured grid output\n"
41416 " and you may not have enough memory to create it.\n"
41417 " Do you want to continue?\n"
41418 " </Text>\n"
41419 " </WarnOnCreate>\n"
41420 " </Hints>\n"
41421 " <!-- End AnnotateSelection -->\n"
41422 " </SourceProxy>\n"
41423 "\n"
41424 " <!-- ==================================================================== -->\n"
41425 " <SourceProxy class=\"vtkMergeVectorComponents\"\n"
41426 " label=\"Merge Vector Components\"\n"
41427 " name=\"MergeVectorComponents\">\n"
41428 " <Documentation\n"
41429 " long_help=\"Merge three 1-component arrays of the same attribute type (point-data or cell-data)\n"
41430 " into one 3-component vector.\"\n"
41431 " short_help=\"Merge three 1-component arrays into one 3-component vector.\">\n"
41432 " The MergeVectorComponents filter can be used to merge 1-component arrays of\n"
41433 " the same attribute type (point-data or cell-data) into one 3-component vector.\n"
41434 " </Documentation>\n"
41435 " <InputProperty command=\"SetInputConnection\"\n"
41436 " name=\"Input\">\n"
41437 " <ProxyGroupDomain name=\"groups\">\n"
41438 " <Group name=\"sources\"/>\n"
41439 " <Group name=\"filters\"/>\n"
41440 " </ProxyGroupDomain>\n"
41441 " <DataTypeDomain name=\"input_type\">\n"
41442 " <DataType value=\"vtkDataSet\"/>\n"
41443 " </DataTypeDomain>\n"
41444 " <InputArrayDomain name=\"scale_array\"\n"
41445 " number_of_components=\"1\"\n"
41446 " optional=\"1\" />\n"
41447 " </InputProperty>\n"
41448 " <IntVectorProperty command=\"SetAttributeType\"\n"
41449 " default_values=\"0\"\n"
41450 " name=\"AttributeType\"\n"
41451 " number_of_elements=\"1\">\n"
41452 " <FieldDataDomain name=\"enum\">\n"
41453 " <RequiredProperties>\n"
41454 " <Property function=\"Input\"\n"
41455 " name=\"Input\" />\n"
41456 " </RequiredProperties>\n"
41457 " </FieldDataDomain>\n"
41458 " <Documentation>This property determines on which types of field data the computation is to\n"
41459 " be performed on.</Documentation>\n"
41460 " </IntVectorProperty>\n"
41461 " <StringVectorProperty command=\"SetXArrayName\"\n"
41462 " name=\"XArrayName\"\n"
41463 " label=\"X Array\"\n"
41464 " number_of_elements=\"1\">\n"
41465 " <ArrayListDomain name=\"array_list\"\n"
41466 " input_domain_name=\"scale_array\">\n"
41467 " <RequiredProperties>\n"
41468 " <Property function=\"Input\"\n"
41469 " name=\"Input\" />\n"
41470 " <Property function=\"FieldDataSelection\"\n"
41471 " name=\"AttributeType\" />\n"
41472 " </RequiredProperties>\n"
41473 " </ArrayListDomain>\n"
41474 " <Documentation>\n"
41475 " This property indicates the name of the array with the X component.\n"
41476 " </Documentation>\n"
41477 " </StringVectorProperty>\n"
41478 " <StringVectorProperty command=\"SetYArrayName\"\n"
41479 " name=\"YArrayName\"\n"
41480 " label=\"Y Array\"\n"
41481 " number_of_elements=\"1\">\n"
41482 " <ArrayListDomain name=\"array_list\"\n"
41483 " input_domain_name=\"scale_array\">\n"
41484 " <RequiredProperties>\n"
41485 " <Property function=\"Input\"\n"
41486 " name=\"Input\" />\n"
41487 " <Property function=\"FieldDataSelection\"\n"
41488 " name=\"AttributeType\" />\n"
41489 " </RequiredProperties>\n"
41490 " </ArrayListDomain>\n"
41491 " <Documentation>\n"
41492 " This property indicates the name of the array with the Y component.\n"
41493 " </Documentation>\n"
41494 " </StringVectorProperty>\n"
41495 " <StringVectorProperty command=\"SetZArrayName\"\n"
41496 " name=\"ZArrayName\"\n"
41497 " label=\"Z Array\"\n"
41498 " number_of_elements=\"1\">\n"
41499 " <ArrayListDomain name=\"array_list\"\n"
41500 " input_domain_name=\"scale_array\">\n"
41501 " <RequiredProperties>\n"
41502 " <Property function=\"Input\"\n"
41503 " name=\"Input\" />\n"
41504 " <Property function=\"FieldDataSelection\"\n"
41505 " name=\"AttributeType\" />\n"
41506 " </RequiredProperties>\n"
41507 " </ArrayListDomain>\n"
41508 " <Documentation>\n"
41509 " This property indicates the name of the array with the Z component.\n"
41510 " </Documentation>\n"
41511 " </StringVectorProperty>\n"
41512 " <StringVectorProperty command=\"SetOutputVectorName\"\n"
41513 " default_values=\"Vector\"\n"
41514 " name=\"OutputVectorName\"\n"
41515 " number_of_elements=\"1\">\n"
41516 " <Documentation>This property contains the name for the output vector\n"
41517 " containing the result of the merging.</Documentation>\n"
41518 " </StringVectorProperty>\n"
41519 " <!-- End MergeVectorComponents -->\n"
41520 " </SourceProxy>\n"
41521 "\n"
41522 " <!-- ==================================================================== -->\n"
41523 " <SourceProxy class=\"vtkPointSetToOctreeImageFilter\"\n"
41524 " name=\"PointSetToOctreeImage\"\n"
41525 " label=\"PointSet To Octree Image\">\n"
41526 " <Documentation\n"
41527 " long_help=\"Convert a point set to an octree image.\"\n"
41528 " short_help=\"Convert a point set to an octree image.\">\n"
41529 " PointSetToOctreeImage can be used to convert a point set to an image with a number of points per cell\n"
41530 " target and an unsigned char octree cell array. Each bit of the unsigned char indicates if the point-set had a\n"
41531 " point close to one of the 8 corners of the cell. It can optionally also output a cell array based on an input\n"
41532 " point array. This array will have 1 or many components that represent different functions i.e. last value, min,\n"
41533 " max, count, sum, mean.\n"
41534 " </Documentation>\n"
41535 " <InputProperty command=\"SetInputConnection\"\n"
41536 " name=\"Input\">\n"
41537 " <ProxyGroupDomain name=\"groups\">\n"
41538 " <Group name=\"sources\"/>\n"
41539 " <Group name=\"filters\"/>\n"
41540 " </ProxyGroupDomain>\n"
41541 " <DataTypeDomain name=\"input_type\">\n"
41542 " <DataType value=\"vtkPointSet\"/>\n"
41543 " </DataTypeDomain>\n"
41544 " <InputArrayDomain name=\"point_scalar_arrays\"\n"
41545 " attribute_type=\"point\"\n"
41546 " number_of_components=\"1\"\n"
41547 " optional=\"1\"/>\n"
41548 " </InputProperty>\n"
41549 " <IntVectorProperty command=\"SetNumberOfPointsPerCell\"\n"
41550 " name=\"NumberOfPointsPerCell\"\n"
41551 " default_values=\"1\"\n"
41552 " number_of_elements=\"1\">\n"
41553 " <Documentation>\n"
41554 " Set the average number of points in each cell of the output image.\n"
41555 " </Documentation>\n"
41556 " </IntVectorProperty>\n"
41557 " <IntVectorProperty command=\"SetProcessInputPointArray\"\n"
41558 " name=\"ProcessInputPointArray\"\n"
41559 " default_values=\"0\"\n"
41560 " number_of_elements=\"1\">\n"
41561 " <BooleanDomain name=\"bool\"/>\n"
41562 " <Documentation>\n"
41563 " Set if input point array should be processed.\n"
41564 " </Documentation>\n"
41565 " </IntVectorProperty>\n"
41566 " <IntVectorProperty command=\"SetComputeLastValue\"\n"
41567 " name=\"ComputeLastValue\"\n"
41568 " default_values=\"1\"\n"
41569 " number_of_elements=\"1\">\n"
41570 " <BooleanDomain name=\"bool\"/>\n"
41571 " <Documentation>\n"
41572 " Set if the last value for each cell id of the point array will be computed.\n"
41573 " </Documentation>\n"
41574 " <Hints>\n"
41575 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41576 " value=\"1\"/>\n"
41577 " </Hints>\n"
41578 " </IntVectorProperty>\n"
41579 " <IntVectorProperty command=\"SetComputeMin\"\n"
41580 " name=\"ComputeMin\"\n"
41581 " default_values=\"0\"\n"
41582 " number_of_elements=\"1\">\n"
41583 " <BooleanDomain name=\"bool\"/>\n"
41584 " <Documentation>\n"
41585 " Set if the min value for each cell id of the point array will be computed.\n"
41586 " </Documentation>\n"
41587 " <Hints>\n"
41588 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41589 " value=\"1\"/>\n"
41590 " </Hints>\n"
41591 " </IntVectorProperty>\n"
41592 " <IntVectorProperty command=\"SetComputeMax\"\n"
41593 " name=\"ComputeMax\"\n"
41594 " default_values=\"0\"\n"
41595 " number_of_elements=\"1\">\n"
41596 " <BooleanDomain name=\"bool\"/>\n"
41597 " <Documentation>\n"
41598 " Set if the max value for each cell id of the point array will be computed.\n"
41599 " </Documentation>\n"
41600 " <Hints>\n"
41601 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41602 " value=\"1\"/>\n"
41603 " </Hints>\n"
41604 " </IntVectorProperty>\n"
41605 " <IntVectorProperty command=\"SetComputeCount\"\n"
41606 " name=\"ComputeCount\"\n"
41607 " default_values=\"0\"\n"
41608 " number_of_elements=\"1\">\n"
41609 " <BooleanDomain name=\"bool\"/>\n"
41610 " <Documentation>\n"
41611 " Set if the count of the values for each cell id of the point array will be computed.\n"
41612 " </Documentation>\n"
41613 " <Hints>\n"
41614 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41615 " value=\"1\"/>\n"
41616 " </Hints>\n"
41617 " </IntVectorProperty>\n"
41618 " <IntVectorProperty command=\"SetComputeSum\"\n"
41619 " name=\"ComputeSum\"\n"
41620 " default_values=\"0\"\n"
41621 " number_of_elements=\"1\">\n"
41622 " <BooleanDomain name=\"bool\"/>\n"
41623 " <Documentation>\n"
41624 " Set if the sum of the values for each cell id of the point array will be computed.\n"
41625 " </Documentation>\n"
41626 " <Hints>\n"
41627 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41628 " value=\"1\"/>\n"
41629 " </Hints>\n"
41630 " </IntVectorProperty>\n"
41631 " <IntVectorProperty command=\"SetComputeMean\"\n"
41632 " name=\"ComputeMean\"\n"
41633 " default_values=\"0\"\n"
41634 " number_of_elements=\"1\">\n"
41635 " <BooleanDomain name=\"bool\"/>\n"
41636 " <Documentation>\n"
41637 " Set if the mean value for each cell id of the point array will be computed.\n"
41638 " </Documentation>\n"
41639 " <Hints>\n"
41640 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41641 " value=\"1\"/>\n"
41642 " </Hints>\n"
41643 " </IntVectorProperty>\n"
41644 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
41645 " element_types=\"0 0 0 0 2\"\n"
41646 " label=\"Point Array\"\n"
41647 " name=\"SelectInputPointArray\"\n"
41648 " number_of_elements=\"5\">\n"
41649 " <ArrayListDomain name=\"array_list\" input_domain_name=\"point_scalar_arrays\">\n"
41650 " <RequiredProperties>\n"
41651 " <Property function=\"Input\"\n"
41652 " name=\"Input\"/>\n"
41653 " </RequiredProperties>\n"
41654 " </ArrayListDomain>\n"
41655 " <Documentation>\n"
41656 " The value of this property contains the name of the scalar point array to be processed.\n"
41657 " </Documentation>\n"
41658 " <Hints>\n"
41659 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputPointArray\"\n"
41660 " value=\"1\"/>\n"
41661 " </Hints>\n"
41662 " </StringVectorProperty>\n"
41663 " </SourceProxy>\n"
41664 "\n"
41665 " <!-- ==================================================================== -->\n"
41666 " <SourceProxy class=\"vtkOctreeImageToPointSetFilter\"\n"
41667 " name=\"OctreeImageToPointSet\"\n"
41668 ;
41669
41670 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_filters.xml
41672 " label=\"Octree Image to PointSet\">\n"
41673 " <Documentation\n"
41674 " long_help=\"Convert an octree image to point set.\"\n"
41675 " short_help=\"Convert an octree image to point set.\">\n"
41676 " OctreeImageToPointSet can be used to convert an image with an unsigned char octree cell array to a point\n"
41677 " set. Each bit of the unsigned char indicates if the cell had a point close to one of its 8 corners.\n"
41678 " It can optionally also output a point array based on an input cell array. This array will have 1 of the\n"
41679 " components of the input array.\n"
41680 " </Documentation>\n"
41681 " <InputProperty command=\"SetInputConnection\"\n"
41682 " name=\"Input\">\n"
41683 " <ProxyGroupDomain name=\"groups\">\n"
41684 " <Group name=\"sources\"/>\n"
41685 " <Group name=\"filters\"/>\n"
41686 " </ProxyGroupDomain>\n"
41687 " <DataTypeDomain name=\"input_type\">\n"
41688 " <DataType value=\"vtkImageData\"/>\n"
41689 " </DataTypeDomain>\n"
41690 " <InputArrayDomain name=\"cell_arrays\"\n"
41691 " attribute_type=\"cell\"\n"
41692 " optional=\"1\"/>\n"
41693 " </InputProperty>\n"
41694 " <IntVectorProperty command=\"SetCreateVerticesCellArray\"\n"
41695 " default_values=\"1\"\n"
41696 " name=\"CreateVerticesCellArray\"\n"
41697 " number_of_elements=\"1\"\n"
41698 " panel_visibility=\"advanced\">\n"
41699 " <BooleanDomain name=\"bool\"/>\n"
41700 " <Documentation>\n"
41701 " Set whether a cell array of vertices will be created.\n"
41702 " </Documentation>\n"
41703 " </IntVectorProperty>\n"
41704 " <IntVectorProperty command=\"SetProcessInputCellArray\"\n"
41705 " name=\"ProcessInputCellArray\"\n"
41706 " default_values=\"0\"\n"
41707 " number_of_elements=\"1\">\n"
41708 " <BooleanDomain name=\"bool\"/>\n"
41709 " <Documentation>\n"
41710 " Set if input cell array should be processed.\n"
41711 " </Documentation>\n"
41712 " </IntVectorProperty>\n"
41713 " <StringVectorProperty command=\"SetInputArrayToProcess\"\n"
41714 " element_types=\"0 0 0 0 2\"\n"
41715 " label=\"Cell Array\"\n"
41716 " name=\"SelectInputCellArray\"\n"
41717 " number_of_elements=\"5\">\n"
41718 " <ArrayListDomain name=\"array_list\" input_domain_name=\"cell_arrays\">\n"
41719 " <RequiredProperties>\n"
41720 " <Property function=\"Input\"\n"
41721 " name=\"Input\"/>\n"
41722 " </RequiredProperties>\n"
41723 " </ArrayListDomain>\n"
41724 " <Documentation>\n"
41725 " The value of this property contains the name of the cell array to be processed.\n"
41726 " </Documentation>\n"
41727 " <Hints>\n"
41728 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"visibility\" property=\"ProcessInputCellArray\"\n"
41729 " value=\"1\"/>\n"
41730 " </Hints>\n"
41731 " </StringVectorProperty>\n"
41732 " <IntVectorProperty animateable=\"0\"\n"
41733 " command=\"SetCellArrayComponent\"\n"
41734 " default_values=\"0\"\n"
41735 " name=\"Component\"\n"
41736 " number_of_elements=\"1\">\n"
41737 " <NumberOfComponentsDomain name=\"comps\" enable_magnitude=\"0\">\n"
41738 " <RequiredProperties>\n"
41739 " <Property function=\"Input\"\n"
41740 " name=\"Input\"/>\n"
41741 " <Property function=\"ArraySelection\"\n"
41742 " name=\"SelectInputCellArray\"/>\n"
41743 " </RequiredProperties>\n"
41744 " </NumberOfComponentsDomain>\n"
41745 " <Documentation>\n"
41746 " The value of this property specifies the array component\n"
41747 " that will be extracted from the cell array.\n"
41748 " </Documentation>\n"
41749 " </IntVectorProperty>\n"
41750 " </SourceProxy>\n"
41751 "\n"
41752 " <!-- ==================================================================== -->\n"
41753 " <SourceProxy class=\"vtkMultiObjectMassProperties\"\n"
41754 " label=\"Connected Surface Properties\"\n"
41755 " name=\"ConnectedSurfaceProperties\">\n"
41756 " <Documentation\n"
41757 " long_help=\"Compute volume, area, and centroid of multiple connected polygonal\n"
41758 " objects in a single polygonal input\"\n"
41759 " short_help=\"Compute volume, area, and centroid of multiple polygonal objects\">\n"
41760 " Given a PolyData, computed the volume, area and centroid of one or more polygonal objects.\n"
41761 " An optional object IDs cell data array that maps a polygon to a specific object may be provided,\n"
41762 " or the objects will be identified as connected components in the input data.\n"
41763 " </Documentation>\n"
41764 " <InputProperty command=\"SetInputConnection\"\n"
41765 " name=\"Input\">\n"
41766 " <ProxyGroupDomain name=\"groups\">\n"
41767 " <Group name=\"sources\"/>\n"
41768 " <Group name=\"filters\"/>\n"
41769 " </ProxyGroupDomain>\n"
41770 " <DataTypeDomain name=\"input_type\">\n"
41771 " <DataType value=\"vtkPolyData\"/>\n"
41772 " </DataTypeDomain>\n"
41773 " <InputArrayDomain attribute_type=\"cell\"\n"
41774 " name=\"scale_array\"\n"
41775 " number_of_components=\"1\"\n"
41776 " optional=\"1\" />\n"
41777 " </InputProperty>\n"
41778 " <IntVectorProperty command=\"SetSkipValidityCheck\"\n"
41779 " name=\"SkipObjectIdentification\"\n"
41780 " default_values=\"0\"\n"
41781 " number_of_elements=\"1\">\n"
41782 " <BooleanDomain name=\"bool\" />\n"
41783 " <Documentation>This property determines whether to skip the object identification\n"
41784 " which detects the multiple objects in the PolyData. This check can be skipped\n"
41785 " only if the PolyData has a CellData array with the object Ids, and the ids start with 0 index.\n"
41786 " The name of that array is configurable.\n"
41787 " </Documentation>\n"
41788 " </IntVectorProperty>\n"
41789 " <StringVectorProperty command=\"SetObjectIdsArrayName\"\n"
41790 " name=\"ObjectIdsArrayName\"\n"
41791 " default_values=\"ObjectIds\"\n"
41792 " number_of_elements=\"1\">\n"
41793 " <ArrayListDomain attribute_type=\"Scalars\"\n"
41794 " name=\"array_list\">\n"
41795 " <RequiredProperties>\n"
41796 " <Property function=\"Input\"\n"
41797 " name=\"Input\" />\n"
41798 " </RequiredProperties>\n"
41799 " </ArrayListDomain>\n"
41800 " <Hints>\n"
41801 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
41802 " <Property name=\"SkipObjectIdentification\" function=\"boolean\"/>\n"
41803 " </PropertyWidgetDecorator>\n"
41804 " <NoDefault />\n"
41805 " </Hints>\n"
41806 " <Documentation>\n"
41807 " This property indicates the name of the array with the object IDs. The default name is \"ObjectIds\".\n"
41808 " </Documentation>\n"
41809 " </StringVectorProperty>\n"
41810 " </SourceProxy>\n"
41811 " <SourceProxy class=\"vtkMultiObjectMassProperties\"\n"
41812 " base_proxyname=\"ConnectedSurfaceProperties\"\n"
41813 " base_proxygroup=\"filters\"\n"
41814 " name=\"ComputeConnectedSurfaceProperties\">\n"
41815 " <Deprecated deprecated_in=\"5.13\" to_remove_in=\"5.14\">\n"
41816 " This has been renamed into 'ConnectedSurfaceProperties'. Please consider using that instead.\n"
41817 " </Deprecated>\n"
41818 " <!-- End ComputeConnectedSurfaceProperties -->\n"
41819 " </SourceProxy>\n"
41820 "\n"
41821 " <!-- ==================================================================== -->\n"
41822 " <SourceProxy class=\"vtkEqualizerFilter\"\n"
41823 " name=\"EqualizerFilter\"\n"
41824 " label=\"Equalizer Filter\">\n"
41825 " <Documentation long_help=\"Filter for signal modification.\">\n"
41826 " The Equalizer Filter implements an algorithm that selectively corrects\n"
41827 " the signal amplitude depending on the frequency characteristics.\n"
41828 " </Documentation>\n"
41829 " <InputProperty name=\"Input\"\n"
41830 " command=\"SetInputConnection\">\n"
41831 " <ProxyGroupDomain name=\"groups\">\n"
41832 " <Group name=\"sources\"/>\n"
41833 " <Group name=\"filters\"/>\n"
41834 " </ProxyGroupDomain>\n"
41835 " <DataTypeDomain composite_data_supported=\"1\"\n"
41836 " name=\"input_type\">\n"
41837 " <DataType value=\"vtkTable\"/>\n"
41838 " </DataTypeDomain>\n"
41839 " </InputProperty>\n"
41840 "\n"
41841 " <IntVectorProperty command=\"SetSamplingFrequency\"\n"
41842 " default_values=\"1000\"\n"
41843 " name=\"SamplingFrequency\"\n"
41844 " label=\"Sampling Frequency, Hz\"\n"
41845 " number_of_elements=\"1\">\n"
41846 " <Documentation>\n"
41847 " Set sampling frequency of signal.\n"
41848 " </Documentation>\n"
41849 " </IntVectorProperty>\n"
41850 "\n"
41851 " <StringVectorProperty name=\"Array\"\n"
41852 " command=\"SetArray\"\n"
41853 " number_of_elements=\"1\"\n"
41854 " animateable=\"0\">\n"
41855 " <ArrayListDomain\n"
41856 " name=\"array_list\" attribute_type=\"Scalars\"\n"
41857 " input_domain_name=\"inputs_array\">\n"
41858 " <RequiredProperties>\n"
41859 " <Property name=\"Input\" function=\"Input\"/>\n"
41860 " </RequiredProperties>\n"
41861 " </ArrayListDomain>\n"
41862 " <Documentation>\n"
41863 " Specify the name of a scalar array which will be used to FFT.\n"
41864 " </Documentation>\n"
41865 " <Hints>\n"
41866 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
41867 " <Property name=\"AllColumns\" function=\"boolean_invert\" />\n"
41868 " </PropertyWidgetDecorator>\n"
41869 " </Hints>\n"
41870 " </StringVectorProperty>\n"
41871 "\n"
41872 " <IntVectorProperty command=\"SetAllColumns\"\n"
41873 " default_values=\"0\"\n"
41874 " name=\"AllColumns\"\n"
41875 " number_of_elements=\"1\">\n"
41876 " <BooleanDomain name=\"bool\" />\n"
41877 " <Documentation>Use for all columns of table.\n"
41878 " </Documentation>\n"
41879 " </IntVectorProperty>\n"
41880 "\n"
41881 " <IntVectorProperty animateable=\"1\"\n"
41882 " command=\"SetSpectrumGain\"\n"
41883 " default_values=\"0\"\n"
41884 " name=\"SpectrumGain\"\n"
41885 " label=\"Spectrum Gain, dB\"\n"
41886 " number_of_elements=\"1\">\n"
41887 " <IntRangeDomain max=\"50\"\n"
41888 " min=\"-50\"\n"
41889 " name=\"range\" />\n"
41890 " <Documentation>\n"
41891 " Specify a gain coefficient (in dB) to apply to the spectrum of the input signal.\n"
41892 " Used only for convenient viewing.\n"
41893 " </Documentation>\n"
41894 " </IntVectorProperty>\n"
41895 "\n"
41896 " <StringVectorProperty animateable=\"1\"\n"
41897 " command=\"SetPoints\"\n"
41898 " label=\"Equalizer Points\"\n"
41899 " name=\"EqualizerPoints\"\n"
41900 " number_of_elements=\"1\" >\n"
41901 " <Documentation>This property defines the interactive points of the equalizer.</Documentation>\n"
41902 " </StringVectorProperty>\n"
41903 "\n"
41904 " <PropertyGroup name=\"Equalizer Filtering Points\" panel_widget=\"EqualizerPropertyWidget\">\n"
41905 " <Property name=\"EqualizerPoints\" />\n"
41906 " <Property name=\"SamplingFrequency\" />\n"
41907 " <Hints>\n"
41908 " <WidgetVisibilityLink port=\"2\" />\n"
41909 " </Hints>\n"
41910 " </PropertyGroup>\n"
41911 "\n"
41912 " <OutputPort index=\"0\" name=\"Spectrum\" />\n"
41913 " <OutputPort index=\"1\" name=\"Result\" />\n"
41914 " <OutputPort index=\"2\" name=\"Normalized Spectrum\" />\n"
41915 "\n"
41916 " <Hints>\n"
41917 " <PipelineIcon port=\"0\" name=\"XYChartView\" />\n"
41918 " <View port=\"0\" type=\"None\" />\n"
41919 "\n"
41920 " <PipelineIcon port=\"1\" name=\"XYChartView\" />\n"
41921 " <View port=\"1\" type=\"None\" />\n"
41922 "\n"
41923 " <PipelineIcon port=\"2\" name=\"XYChartView\" />\n"
41924 " <View port=\"2\" type=\"XYChartView\" />\n"
41925 "\n"
41926 " <RepresentationType view=\"XYChartView\" type=\"XYChartRepresentation\" />\n"
41927 " </Hints>\n"
41928 "\n"
41929 " </SourceProxy>\n"
41930 " <!-- End vtkEqualizerFilter -->\n"
41931 "\n"
41932 " </ProxyGroup>\n"
41933 "</ServerManagerConfiguration>\n"
41934 "\n";
41935 // Get single string
41937 {
41938
41939  const size_t len0 = strlen(paraview_server_managergeneral_filtersInterface0);
41940  const size_t len1 = strlen(paraview_server_managergeneral_filtersInterface1);
41941  const size_t len2 = strlen(paraview_server_managergeneral_filtersInterface2);
41942  const size_t len3 = strlen(paraview_server_managergeneral_filtersInterface3);
41943  const size_t len4 = strlen(paraview_server_managergeneral_filtersInterface4);
41944  const size_t len5 = strlen(paraview_server_managergeneral_filtersInterface5);
41945  const size_t len6 = strlen(paraview_server_managergeneral_filtersInterface6);
41946  const size_t len7 = strlen(paraview_server_managergeneral_filtersInterface7);
41947  const size_t len8 = strlen(paraview_server_managergeneral_filtersInterface8);
41948  const size_t len9 = strlen(paraview_server_managergeneral_filtersInterface9);
41949  const size_t len10 = strlen(paraview_server_managergeneral_filtersInterface10);
41950  const size_t len11 = strlen(paraview_server_managergeneral_filtersInterface11);
41951  const size_t len12 = strlen(paraview_server_managergeneral_filtersInterface12);
41952  const size_t len13 = strlen(paraview_server_managergeneral_filtersInterface13);
41953  const size_t len14 = strlen(paraview_server_managergeneral_filtersInterface14);
41954  const size_t len15 = strlen(paraview_server_managergeneral_filtersInterface15);
41955  size_t len = ( 0
41956  + len0
41957  + len1
41958  + len2
41959  + len3
41960  + len4
41961  + len5
41962  + len6
41963  + len7
41964  + len8
41965  + len9
41966  + len10
41967  + len11
41968  + len12
41969  + len13
41970  + len14
41971  + len15 );
41972  char* res = new char[ len + 1];
41973  size_t offset = 0;
41990  assert(offset == len);
41991  res[offset] = 0;
41992  return res;
41993 }
41994
41995
41996 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneral/Resources/general_sources.xml
41998 "<ServerManagerConfiguration>\n"
41999 " <ProxyGroup name=\"sources\">\n"
42000 " <!-- ==================================================================== -->\n"
42001 " <SourceProxy class=\"vtkHierarchicalFractal\"\n"
42002 " label=\"Hierarchical Fractal\"\n"
42003 " name=\"HierarchicalFractal\">\n"
42004 " <Documentation long_help=\"Test source for AMR with HierarchicalDataSet\"\n"
42005 " short_help=\"Hierarchical fractal\">The Hierarchical Fractal\n"
42006 " source is a collection of uniform grids. All have the same\n"
42007 " dimensions. Each block has a different origin and spacing.\n"
42008 " This source uses the Mandelbrot source to create cell\n"
42009 " data. The fractal array is scaled to look like a volume\n"
42010 " fraction.</Documentation>\n"
42011 " <IntVectorProperty command=\"SetDimensions\"\n"
42012 " default_values=\"10\"\n"
42013 " name=\"Dimensions\"\n"
42014 " number_of_elements=\"1\">\n"
42015 " <IntRangeDomain max=\"64\"\n"
42016 " min=\"2\"\n"
42017 " name=\"range\" />\n"
42018 " <Documentation>This property specifies the X, Y, Z cell dimensions of a\n"
42019 " block.</Documentation>\n"
42020 " </IntVectorProperty>\n"
42021 " <DoubleVectorProperty command=\"SetFractalValue\"\n"
42022 " default_values=\"9.5\"\n"
42023 " name=\"FractalValue\"\n"
42024 " number_of_elements=\"1\">\n"
42025 " <DoubleRangeDomain min=\"0\"\n"
42026 " name=\"range\" />\n"
42027 " <Documentation>The value of this property will be mapped to 0.5 for use\n"
42028 " as a volume fraction.</Documentation>\n"
42029 " </DoubleVectorProperty>\n"
42030 " <IntVectorProperty command=\"SetMaximumLevel\"\n"
42031 " default_values=\"5\"\n"
42032 " name=\"MaximumLevel\"\n"
42033 " number_of_elements=\"1\">\n"
42034 " <IntRangeDomain max=\"10\"\n"
42035 " min=\"1\"\n"
42036 " name=\"range\" />\n"
42037 " <Documentation>This property specifies how many levels of refinement\n"
42038 " should be included in this hierarchical dataset.</Documentation>\n"
42039 " </IntVectorProperty>\n"
42040 " <IntVectorProperty command=\"SetGhostLevels\"\n"
42041 " default_values=\"1\"\n"
42042 " name=\"GhostLevels\"\n"
42043 " number_of_elements=\"1\">\n"
42044 " <BooleanDomain name=\"bool\" />\n"
42045 " <Documentation>This property specifies whether ghost levels should be\n"
42046 " generated at processor boundaries.</Documentation>\n"
42047 " </IntVectorProperty>\n"
42048 " <IntVectorProperty command=\"SetTwoDimensional\"\n"
42049 " default_values=\"1\"\n"
42050 " name=\"TwoDimensional\"\n"
42051 " number_of_elements=\"1\">\n"
42052 " <BooleanDomain name=\"bool\" />\n"
42053 " <Documentation>If this property is set to 1, the generated dataset will\n"
42054 " be 2D; otherwise it will be 3D.</Documentation>\n"
42055 " </IntVectorProperty>\n"
42056 " <IntVectorProperty command=\"SetAsymetric\"\n"
42057 " default_values=\"0\"\n"
42058 " name=\"Asymetric\"\n"
42059 " number_of_elements=\"1\">\n"
42060 " <BooleanDomain name=\"bool\" />\n"
42061 " <Documentation>If this property is set to 0, all the blocks will be the\n"
42062 " same size. If it is set to 1, an asymmetric dataset will be created:\n"
42063 " some blocks will have an X dimension that is larger by 2\n"
42064 " units.</Documentation>\n"
42065 " </IntVectorProperty>\n"
42066 " <IntVectorProperty command=\"SetGenerateRectilinearGrids\"\n"
42067 " default_values=\"0\"\n"
42068 " name=\"RectilinearGrids\"\n"
42069 " number_of_elements=\"1\">\n"
42070 " <BooleanDomain name=\"bool\" />\n"
42071 " <Documentation>If this property is set to 1, the hierarchical dataset\n"
42072 " will contain rectilinear grids; otherwise it will contain uniform\n"
42073 " grids.</Documentation>\n"
42074 " </IntVectorProperty>\n"
42075 " <IntVectorProperty command=\"GetTimeStepRange\"\n"
42076 " information_only=\"1\"\n"
42077 " name=\"TimeStepRangeInfo\">\n"
42078 " <SimpleIntInformationHelper />\n"
42079 " </IntVectorProperty>\n"
42080 " <IntVectorProperty animateable=\"1\"\n"
42081 " command=\"SetTimeStep\"\n"
42082 " default_values=\"0\"\n"
42083 " name=\"TimeStep\"\n"
42084 " number_of_elements=\"1\" >\n"
42085 " <IntRangeDomain name=\"range\"\n"
42086 " default_mode=\"min\" >\n"
42087 " <RequiredProperties>\n"
42088 " <Property function=\"Range\"\n"
42089 " name=\"TimeStepRangeInfo\" />\n"
42090 " </RequiredProperties>\n"
42091 " </IntRangeDomain>\n"
42092 " <Documentation>This property specifies the timestep to use for this\n"
42093 " dataset.</Documentation>\n"
42094 " </IntVectorProperty>\n"
42095 " <!-- End HierarchicalFractal -->\n"
42096 " </SourceProxy>\n"
42097 " <!-- ==================================================================== -->\n"
42098 " <SourceProxy class=\"vtkImageSimpleSource\"\n"
42099 " label=\"Fast Uniform Grid\"\n"
42100 " name=\"FastUniformGrid\">\n"
42101 " <Documentation long_help=\"Create a uniform grid in 3 dimensions with scalar and vector data arrays, consuming minimal computational resources.\"\n"
42102 " short_help=\"Create a 3D uniform grid with scalar and vector arrays.\">The\n"
42103 " Fast Uniform Grid source can be used to create a uniform\n"
42104 " grid with scalar values derived from relatively light\n"
42105 " computations. The active scalar array is named \"X\", and\n"
42106 " is set to the X coordinate for each pixel. There are two\n"
42107 " additional point data sets. The data array named\n"
42108 " \"DistanceSquared\" is computed as the squared distance from\n"
42109 " each pixel to the origin. The data array named \"Swirl\"\n"
42110 " is a vector field computed as (Y,Z,X) at each pixel.\n"
42111 " </Documentation>\n"
42112 " <IntVectorProperty command=\"SetWholeExtent\"\n"
42113 " default_values=\"-10 10 -10 10 -10 10\"\n"
42114 " name=\"WholeExtent\"\n"
42115 " number_of_elements=\"6\">\n"
42116 " <IntRangeDomain name=\"range\" />\n"
42117 " <Documentation>The six values in the property indicate the X, Y, and Z\n"
42118 " extent of the output data. The first two numbers are the minimum and\n"
42119 " maximum X extent; the next two are the minimum and maximum Y extent;\n"
42120 " and the final two are the minimum and maximum Z extent. The numbers are\n"
42121 " inclusive, so values of -10, 10, -10, 10, =10, 10 indicate that the\n"
42122 " dimensions of the output will be 21 x 21 x 21.</Documentation>\n"
42123 " </IntVectorProperty>\n"
42124 " <IntVectorProperty command=\"SetEnableDistanceSquaredData\"\n"
42125 " default_values=\"1\"\n"
42126 " name=\"Generate DistanceSquared Scalars\"\n"
42127 " number_of_elements=\"1\"\n"
42128 " panel_visibility=\"advanced\">\n"
42129 " <Documentation>\n"
42130 " Enable/disable DistanceSquared point data scalar array.\n"
42131 " </Documentation>\n"
42132 " <BooleanDomain name=\"bool\" />\n"
42133 " </IntVectorProperty>\n"
42134 " <IntVectorProperty command=\"SetEnableSwirlData\"\n"
42135 " default_values=\"1\"\n"
42136 " name=\"Generate Swirl Vectors\"\n"
42137 " number_of_elements=\"1\"\n"
42138 " panel_visibility=\"advanced\">\n"
42139 " <Documentation>\n"
42140 " Enable/disable Swirl point data vector array.\n"
42141 " </Documentation>\n"
42142 " <BooleanDomain name=\"bool\" />\n"
42143 " </IntVectorProperty>\n"
42144 "\n"
42145 " <IntVectorProperty command=\"SetEnableSMP\"\n"
42146 " default_values=\"0\"\n"
42147 " name=\"EnableSMP\"\n"
42148 " number_of_elements=\"1\"\n"
42149 " panel_visibility=\"advanced\">\n"
42150 " <Documentation>\n"
42151 " Enable/disable SMP for threading.\n"
42152 " </Documentation>\n"
42153 " <BooleanDomain name=\"bool\" />\n"
42154 " </IntVectorProperty>\n"
42155 " <IntVectorProperty command=\"SetDesiredBytesPerPiece\"\n"
42156 " default_values=\"65536\"\n"
42157 " name=\"DesiredBytesPerPiece\"\n"
42158 " number_of_elements=\"1\"\n"
42159 " panel_visibility=\"advanced\">\n"
42160 " <Documentation>\n"
42161 " The desired bytes per piece when the volume is split for SMP execution.\n"
42162 " When SMP is enabled, this is used to subdivide the volume into pieces.\n"
42163 " Smaller pieces allow for better dynamic load balancing, but increase\n"
42164 " the total overhead.\n"
42165 " </Documentation>\n"
42166 " </IntVectorProperty>\n"
42167 " </SourceProxy>\n"
42168 " <!-- ==================================================================== -->\n"
42169 " <SourceProxy class=\"vtkPVTextSource\"\n"
42170 " label=\"Text\"\n"
42171 " name=\"TextSource\">\n"
42172 " <Documentation long_help=\"The Text source generates a table containing text.\"\n"
42173 " short_help=\"Display text\">\n"
42174 " The Text source is used to generate a vtkTable with a single text string.\n"
42175 " To create a table with several columns, use the '|' (pipe) character.\n"
42176 " To create several rows, simply add newlines.\n"
42177 " </Documentation>\n"
42178 " <StringVectorProperty command=\"SetText\"\n"
42179 " default_values=\"Text\"\n"
42180 " name=\"Text\"\n"
42181 " number_of_elements=\"1\"\n"
42182 " panel_visibility=\"default\">\n"
42183 " <Hints>\n"
42184 " <Widget type=\"multi_line\" />\n"
42185 " </Hints>\n"
42186 " <Documentation>\n"
42187 " This property specifies the text to display. To display text separated into cells,\n"
42188 " use newlines to separate text into rows and the '|' (pipe) character to create columns.\n"
42189 " </Documentation>\n"
42190 " </StringVectorProperty>\n"
42191 " <Hints>\n"
42192 " <OutputPort index=\"0\"\n"
42193 " name=\"Output-0\"\n"
42194 " type=\"text\" />\n"
42195 " </Hints>\n"
42196 " <!-- End of TextSource -->\n"
42197 " </SourceProxy>\n"
42198 "\n"
42199 " <!-- ==================================================================== -->\n"
42200 " <SourceProxy class=\"vtkTimeToTextConvertor\"\n"
42201 " label=\"Annotate Time\"\n"
42202 " name=\"TimeToTextConvertorSource\">\n"
42203 " <Documentation long_help=\"Shows the animation time as text annotation in the view.\"\n"
42204 " short_help=\"Show animation time as text\">The Annotate Time\n"
42205 " source can be used to show the animation time in text\n"
42206 " annotation.</Documentation>\n"
42207 " <StringVectorProperty command=\"SetFormat\"\n"
42208 " default_values=\"Time: {time:f}\"\n"
42209 " name=\"Format\"\n"
42210 " number_of_elements=\"1\"\n"
42211 " panel_visibility=\"default\">\n"
42212 " <Documentation>The value of this property is a format string used to\n"
42213 " display the input time. The format string is specified using fmt style.\n"
42214 " </Documentation>\n"
42215 " </StringVectorProperty>\n"
42216 " <Hints>\n"
42217 " <OutputPort index=\"0\"\n"
42218 " name=\"Output-0\"\n"
42219 " type=\"text\" />\n"
42220 " </Hints>\n"
42221 " <!-- End of TimeToTextConvertorSource -->\n"
42222 " </SourceProxy>\n"
42223 " </ProxyGroup>\n"
42224 "</ServerManagerConfiguration>\n"
42225 "\n";
42226 // Get single string
42228 {
42229
42230  const size_t len0 = strlen(paraview_server_managergeneral_sourcesInterface0);
42231  size_t len = ( 0
42232  + len0 );
42233  char* res = new char[ len + 1];
42234  size_t offset = 0;
42236  assert(offset == len);
42237  res[offset] = 0;
42238  return res;
42239 }
42240
42241
42242 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersParallelDIY2/Resources/parallel_diy_filters.xml
42244 "<ServerManagerConfiguration>\n"
42245 " <!-- ******************************************************************** -->\n"
42246 " <ProxyGroup name=\"filters\">\n"
42247 " <!-- ==================================================================== -->\n"
42248 " <SourceProxy class=\"vtkPVGhostCellsGenerator\"\n"
42249 " name=\"GhostCells\">\n"
42250 " <Documentation short_help=\"Generate ghosts.\">\n"
42251 " Generate ghost cells and ghost points in a composite data set. Ghosts are exchanged\n"
42252 " between blocks / partitions of same type. Currently, vtkImageData, vtkRectilinearGrid,\n"
42253 " vtkStructuredGrid, vtkPolyData, vtkUnstructuredGrid and vtkHyperTreeGrid are supported.\n"
42254 " Those input types (exception for vtkHyperTreeGrid) can be dispatched in vtkPartitionedDataSet\n"
42255 " or vtkPartitionedDataSetCollection. Inside a collection, 2 partitioned data sets do not\n"
42256 " exchange ghosts, but partitions inside a partitioned data set do.\n"
42257 " </Documentation>\n"
42258 " <InputProperty command=\"SetInputConnection\"\n"
42259 " name=\"Input\">\n"
42260 " <ProxyGroupDomain name=\"groups\">\n"
42261 " <Group name=\"sources\" />\n"
42262 " <Group name=\"filters\" />\n"
42263 " </ProxyGroupDomain>\n"
42264 " <DataTypeDomain name=\"input_type\">\n"
42265 " <DataType value=\"vtkCompositeDataSet\" />\n"
42266 " <DataType value=\"vtkDataSet\" />\n"
42267 " <DataType value=\"vtkHyperTreeGrid\" />\n"
42268 " </DataTypeDomain>\n"
42269 " <Documentation>This property specifies the input.</Documentation>\n"
42270 " </InputProperty>\n"
42271 " <IntVectorProperty command=\"SetSynchronizeOnly\"\n"
42272 " default_values=\"0\"\n"
42273 " name=\"SynchronizeOnly\"\n"
42274 " number_of_elements=\"1\">\n"
42275 " <Documentation>\n"
42276 " Specify if the filter should only try to synchronize ghost data.\n"
42277 " If On, it assumes the number of ghost layer should not change.\n"
42278 " If On, but conditions are not met (ghosts, gids and pids), it\n"
42279 " will fallback on the default behavior: generating ghosts.\n"
42280 " </Documentation>\n"
42281 " <BooleanDomain name=\"bool\" />\n"
42282 " <Hints>\n"
42283 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
42284 " name=\"vtkHyperTreeGrid\"\n"
42285 " exclude=\"1\"\n"
42286 " mode=\"visibility\"/>\n"
42287 " </Hints>\n"
42288 " </IntVectorProperty>\n"
42289 "\n"
42290 " <IntVectorProperty command=\"SetGenerateGlobalIds\"\n"
42291 " default_values=\"0\"\n"
42292 " name=\"GenerateGlobalIds\"\n"
42293 " number_of_elements=\"1\">\n"
42294 " <Documentation>\n"
42295 " Specify if the filter should generate global ids when generating ghost cells.\n"
42296 " </Documentation>\n"
42297 " <BooleanDomain name=\"bool\" />\n"
42298 " <Hints>\n"
42299 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
42300 " property=\"SynchronizeOnly\"\n"
42301 " value=\"0\"\n"
42302 " mode=\"enabled_state\" />\n"
42303 " </Hints>\n"
42304 " </IntVectorProperty>\n"
42305 "\n"
42306 " <IntVectorProperty command=\"SetGenerateProcessIds\"\n"
42307 " default_values=\"0\"\n"
42308 " name=\"GenerateProcessIds\"\n"
42309 " number_of_elements=\"1\">\n"
42310 " <Documentation>\n"
42311 " Specify if the filter should generate process ids when generating ghost cells.\n"
42312 " </Documentation>\n"
42313 " <BooleanDomain name=\"bool\" />\n"
42314 " <Hints>\n"
42315 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
42316 " property=\"SynchronizeOnly\"\n"
42317 " value=\"0\"\n"
42318 " mode=\"enabled_state\" />\n"
42319 " </Hints>\n"
42320 " </IntVectorProperty>\n"
42321 "\n"
42322 " <IntVectorProperty command=\"SetBuildIfRequired\"\n"
42323 " default_values=\"0\"\n"
42324 " name=\"BuildIfRequired\"\n"
42325 " number_of_elements=\"1\">\n"
42326 " <Documentation>\n"
42327 " Specify if the filter must generate the ghost cells only\n"
42328 " if required by the pipeline downstream. To force at least a fixed level\n"
42329 " of ghosts, this must be set to 0 (unchecked).\n"
42330 " </Documentation>\n"
42331 " <BooleanDomain name=\"bool\" />\n"
42332 " <Hints>\n"
42333 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
42334 " name=\"vtkHyperTreeGrid\"\n"
42335 " exclude=\"1\"\n"
42336 " mode=\"visibility\"/>\n"
42337 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
42338 " mode=\"enabled_state\"\n"
42339 " property=\"SynchronizeOnly\"\n"
42340 " value=\"0\"/>\n"
42341 " </Hints>\n"
42342 " </IntVectorProperty>\n"
42343 " <IntVectorProperty command=\"SetNumberOfGhostLayers\"\n"
42344 " default_values=\"1\"\n"
42345 " name=\"MinimumNumberOfGhosts\"\n"
42346 " number_of_elements=\"1\"\n"
42347 " panel_visibility=\"default\">\n"
42348 " <Documentation>\n"
42349 " When **BuildIfRequired** if off, use this to specify the minimum number of\n"
42350 " ghost cells to request. The filter may request more ghost levels than indicated if a\n"
42351 " downstream filter asked for more ghost levels.\n"
42352 " </Documentation>\n"
42353 " <IntRangeDomain name=\"range\" min=\"0\" max=\"100\"/>\n"
42354 " <Hints>\n"
42355 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
42356 " name=\"vtkHyperTreeGrid\"\n"
42357 " exclude=\"1\"\n"
42358 " mode=\"visibility\"/>\n"
42359 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
42360 " <Expression type=\"and\">\n"
42361 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"BuildIfRequired\" value=\"0\" />\n"
42362 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"SynchronizeOnly\" value=\"0\" />\n"
42363 " </Expression>\n"
42364 " </PropertyWidgetDecorator>\n"
42365 " </Hints>\n"
42366 " </IntVectorProperty>\n"
42367 " </SourceProxy>\n"
42368 "\n"
42369 " <SourceProxy name=\"GhostCellsGenerator\"\n"
42370 " class=\"vtkPVGhostCellsGenerator\"\n"
42371 " base_proxyname=\"GhostCells\"\n"
42372 " base_proxygroup=\"filters\">\n"
42373 " <Deprecated deprecated_in=\"5.13\" to_remove_in=\"5.15\">\n"
42374 " This has been renamed into 'GhostCells'. Please consider using that instead.\n"
42375 " </Deprecated>\n"
42376 " </SourceProxy>\n"
42377 "\n"
42378 " <!-- ==================================================================== -->\n"
42379 " <SourceProxy class=\"vtkStitchImageDataWithGhosts\"\n"
42380 " name=\"StitchImageDataWithGhosts\">\n"
42381 " <Documentation short_help=\"Stitch Image Data With Ghosts.\">\n"
42382 " Stitches images that are separated by one voxel, effectively generating ghost\n"
42383 " points at the new interfaces between the input images. Setting NumberOfGhosts to n\n"
42384 " stitches the images and generates n-1 layers of ghost cells.\n"
42385 " The inputs CANNOT have any cell data, or the filter will not run.\n"
42386 " </Documentation>\n"
42387 " <InputProperty command=\"SetInputConnection\"\n"
42388 " name=\"Input\">\n"
42389 " <ProxyGroupDomain name=\"groups\">\n"
42390 " <Group name=\"sources\" />\n"
42391 " <Group name=\"filters\" />\n"
42392 " </ProxyGroupDomain>\n"
42393 " <DataTypeDomain name=\"input_type\">\n"
42394 " <DataType value=\"vtkCompositeDataSet\" />\n"
42395 " <DataType value=\"vtkImageData\" />\n"
42396 " </DataTypeDomain>\n"
42397 " <Documentation>This property specifies the input.</Documentation>\n"
42398 " </InputProperty>\n"
42399 "\n"
42400 " <IntVectorProperty command=\"SetNumberOfGhostLayers\"\n"
42401 " default_values=\"1\"\n"
42402 " name=\"NumberOfGhosts\"\n"
42403 " number_of_elements=\"1\"\n"
42404 " panel_visibility=\"default\">\n"
42405 " <Documentation>\n"
42406 " </Documentation>\n"
42407 " <IntRangeDomain name=\"range\" min=\"1\" max=\"10\"/>\n"
42408 " </IntVectorProperty>\n"
42409 " <!-- End StitchImageDataWithGhosts -->\n"
42410 " </SourceProxy>\n"
42411 "\n"
42412 " <!-- ================================================================== -->\n"
42413 " <SourceProxy class=\"vtkPVProbeLineFilter\"\n"
42414 " base_proxygroup=\"internal_filters\"\n"
42415 " base_proxyname=\"ProbeLineGenericProxy\"\n"
42416 " label=\"Plot Over Line\"\n"
42417 " name=\"ProbeLine\">\n"
42418 " <Documentation>The Plot Over Line filter samples the dataset attributes of the\n"
42419 " input dataset at the points of a given line. The values of the point-centered\n"
42420 " variables along that line will be displayed in an XY Plot. This filter uses\n"
42421 " interpolation to determine the values at the selected point, whether or not it\n"
42422 " lies at an input point. This filter operates on any type of data and produces a\n"
42423 " polygonal output (a polyline). One can use different sampling patterns with this\n"
42424 " filter. \"Sample At Cell Boundaries\" gives the most accurate plots, \"Sample At\n"
42425 " Segment Centers\" provides one sample per probed cell, and \"Sample Uniformally\"\n"
42426 " samples uniformally along the input line.</Documentation>\n"
42427 " <DoubleVectorProperty animateable=\"1\"\n"
42428 " command=\"SetPoint1\"\n"
42429 " default_values=\"0.0 0.0 0.0\"\n"
42430 " name=\"Point1\"\n"
42431 " number_of_elements=\"3\">\n"
42432 " <BoundsDomain default_mode=\"min\"\n"
42433 " mode=\"normal\"\n"
42434 " name=\"range\">\n"
42435 " <RequiredProperties>\n"
42436 " <Property function=\"Input\"\n"
42437 " name=\"Input\" />\n"
42438 " </RequiredProperties>\n"
42439 " </BoundsDomain>\n"
42440 " <Documentation>This property controls the coordinates of the first\n"
42441 " endpoint of the line.</Documentation>\n"
42442 " </DoubleVectorProperty>\n"
42443 " <DoubleVectorProperty animateable=\"1\"\n"
42444 " command=\"SetPoint2\"\n"
42445 " default_values=\"0.0 0.0 0.0\"\n"
42446 " name=\"Point2\"\n"
42447 " number_of_elements=\"3\">\n"
42448 " <BoundsDomain default_mode=\"max\"\n"
42449 " mode=\"normal\"\n"
42450 " name=\"range\">\n"
42451 " <RequiredProperties>\n"
42452 " <Property function=\"Input\"\n"
42453 " name=\"Input\" />\n"
42454 " </RequiredProperties>\n"
42455 " </BoundsDomain>\n"
42456 " <Documentation>This property controls the coordinates of the second\n"
42457 " endpoint of the line.</Documentation>\n"
42458 " </DoubleVectorProperty>\n"
42459 " <PropertyGroup label=\"Line Parameters\" panel_widget=\"InteractiveLine\">\n"
42460 " <Property function=\"Point1WorldPosition\" name=\"Point1\" />\n"
42461 " <Property function=\"Point2WorldPosition\" name=\"Point2\" />\n"
42462 " </PropertyGroup>\n"
42463 " <!-- end of ProbeLine -->\n"
42464 " </SourceProxy>\n"
42465 "\n"
42466 " <!-- ================================================================== -->\n"
42467 " <SourceProxy class=\"vtkPVProbeLineFilter\"\n"
42468 " label=\"Resample To Line\"\n"
42469 " name=\"ResampleToLine\">\n"
42470 " <Documentation>Resamples the input data set to a line.</Documentation>\n"
42471 " <InputProperty command=\"SetInputConnection\"\n"
42472 " name=\"Input\">\n"
42473 " <ProxyGroupDomain name=\"groups\">\n"
42474 " <Group name=\"sources\" />\n"
42475 " <Group name=\"filters\" />\n"
42476 " </ProxyGroupDomain>\n"
42477 " <DataTypeDomain name=\"input_type\">\n"
42478 " <DataType value=\"vtkDataSet\" />\n"
42479 " <DataType value=\"vtkCompositeDataSet\" />\n"
42480 " <DataType value=\"vtkHyperTreeGrid\" />\n"
42481 " </DataTypeDomain>\n"
42482 " <InputArrayDomain name=\"input_array\" />\n"
42483 " <Documentation>This property specifies which data set to resample.</Documentation>\n"
42484 " </InputProperty>\n"
42485 " <IntVectorProperty command=\"SetSamplingPattern\"\n"
42486 " name=\"SamplingPattern\"\n"
42487 " default_values=\"2\"\n"
42488 " number_of_elements=\"1\"\n"
42489 " panel_visibility=\"never\">\n"
42490 " <EnumerationDomain name=\"enum\">\n"
42491 " <Entry text=\"Sample At Cell Boundaries\"\n"
42492 " value=\"0\" />\n"
42493 " <Entry text=\"Sample At Segment Centers\"\n"
42494 " value=\"1\" />\n"
42495 " <Entry text=\"Sample Uniformly\"\n"
42496 " value=\"2\" />\n"
42497 " </EnumerationDomain>\n"
42498 " </IntVectorProperty>\n"
42499 " <IntVectorProperty command=\"SetLineResolution\"\n"
42500 " name=\"Resolution\"\n"
42501 " default_values=\"40\"\n"
42502 " number_of_elements=\"1\">\n"
42503 " <Hints>\n"
42504 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
42505 " mode=\"visibility\"\n"
42506 " property=\"SamplingPattern\"\n"
42507 " value=\"2\" />\n"
42508 " <!-- show this widget when SamplingPattern==2 -->\n"
42509 " </Hints>\n"
42510 " <Documentation>This property sets the line resolution.</Documentation>\n"
42511 " </IntVectorProperty>\n"
42512 " <IntVectorProperty command=\"SetPassPartialArrays\"\n"
42513 " default_values=\"1\"\n"
42514 " name=\"PassPartialArrays\"\n"
42515 " number_of_elements=\"1\"\n"
42516 " panel_visibility=\"advanced\">\n"
42517 " <Documentation>When dealing with composite datasets, partial arrays are\n"
42518 " common i.e. data-arrays that are not available in all of the blocks. By\n"
42519 " default, this filter only passes those point and cell data-arrays that\n"
42520 " are available in all the blocks i.e. partial arrays are removed. When\n"
42521 " PassPartialArrays is turned on, this behavior is changed to take a\n"
42522 " union of all arrays present thus partial arrays are passed as well.\n"
42523 " However, for composite dataset input, this filter still produces a\n"
42524 " non-composite output. For all those locations in a block of where a\n"
42525 " particular data array is missing, this filter uses vtkMath::Nan() for\n"
42526 " double and float arrays, and 0 for all other types of arrays i.e int,\n"
42527 " char etc.</Documentation>\n"
42528 " <BooleanDomain name=\"bool\" />\n"
42529 " </IntVectorProperty>\n"
42530 " <IntVectorProperty command=\"SetPassCellArrays\"\n"
42531 " default_values=\"0\"\n"
42532 " name=\"PassCellArrays\"\n"
42533 " number_of_elements=\"1\"\n"
42534 " panel_visibility=\"advanced\">\n"
42535 " <Documentation>\n"
42536 " When set the input cell data arrays are shallow copied to the output.\n"
42537 " </Documentation>\n"
42538 " <BooleanDomain name=\"bool\" />\n"
42539 " </IntVectorProperty>\n"
42540 " <IntVectorProperty command=\"SetPassPointArrays\"\n"
42541 " default_values=\"0\"\n"
42542 " name=\"PassPointArrays\"\n"
42543 " number_of_elements=\"1\"\n"
42544 " panel_visibility=\"advanced\">\n"
42545 " <Documentation>\n"
42546 ;
42547
42548 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersParallelDIY2/Resources/parallel_diy_filters.xml
42550 " When set the input point data arrays are shallow copied to the output.\n"
42551 " </Documentation>\n"
42552 " <BooleanDomain name=\"bool\" />\n"
42553 " </IntVectorProperty>\n"
42554 " <IntVectorProperty command=\"SetPassFieldArrays\"\n"
42555 " default_values=\"1\"\n"
42556 " name=\"PassFieldArrays\"\n"
42557 " number_of_elements=\"1\"\n"
42558 " panel_visibility=\"advanced\">\n"
42559 " <Documentation>\n"
42560 " Set whether to pass the field-data arrays from the Input i.e. the input\n"
42561 " providing the geometry to the output.\n"
42562 " </Documentation>\n"
42563 " <BooleanDomain name=\"bool\" />\n"
42564 " </IntVectorProperty>\n"
42565 " <IntVectorProperty command=\"SetComputeTolerance\"\n"
42566 " default_values=\"1\"\n"
42567 " name=\"ComputeTolerance\"\n"
42568 " number_of_elements=\"1\"\n"
42569 " panel_visibility=\"advanced\">\n"
42570 " <Documentation>\n"
42571 " Set whether to compute the tolerance or to use a user provided\n"
42572 " value.\n"
42573 " </Documentation>\n"
42574 " <BooleanDomain name=\"bool\" />\n"
42575 " </IntVectorProperty>\n"
42576 " <DoubleVectorProperty command=\"SetTolerance\"\n"
42577 " default_values=\"2.2204460492503131e-16\"\n"
42578 " name=\"Tolerance\"\n"
42579 " number_of_elements=\"1\"\n"
42580 " panel_visibility=\"advanced\">\n"
42581 " <DoubleRangeDomain min=\"2.2204460492503131e-16\"\n"
42582 " name=\"range\" />\n"
42583 " <Hints>\n"
42584 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
42585 " <Property name=\"ComputeTolerance\" function=\"boolean_invert\" />\n"
42586 " </PropertyWidgetDecorator>\n"
42587 " </Hints>\n"
42588 " <Documentation>Set the tolerance to use for\n"
42589 " vtkDataSet::FindCell</Documentation>\n"
42590 " </DoubleVectorProperty>\n"
42591 "\n"
42592 " <DoubleVectorProperty animateable=\"1\"\n"
42593 " command=\"SetPoint1\"\n"
42594 " default_values=\"0.0 0.0 0.0\"\n"
42595 " name=\"Point1\"\n"
42596 " number_of_elements=\"3\">\n"
42597 " <BoundsDomain default_mode=\"min\"\n"
42598 " mode=\"normal\"\n"
42599 " name=\"range\">\n"
42600 " <RequiredProperties>\n"
42601 " <Property function=\"Input\"\n"
42602 " name=\"Input\" />\n"
42603 " </RequiredProperties>\n"
42604 " </BoundsDomain>\n"
42605 " <Documentation>This property controls the coordinates of the first\n"
42606 " endpoint of the line.</Documentation>\n"
42607 " </DoubleVectorProperty>\n"
42608 " <DoubleVectorProperty animateable=\"1\"\n"
42609 " command=\"SetPoint2\"\n"
42610 " default_values=\"0.0 0.0 0.0\"\n"
42611 " name=\"Point2\"\n"
42612 " number_of_elements=\"3\">\n"
42613 " <BoundsDomain default_mode=\"max\"\n"
42614 " mode=\"normal\"\n"
42615 " name=\"range\">\n"
42616 " <RequiredProperties>\n"
42617 " <Property function=\"Input\"\n"
42618 " name=\"Input\" />\n"
42619 " </RequiredProperties>\n"
42620 " </BoundsDomain>\n"
42621 " <Documentation>This property controls the coordinates of the second\n"
42622 " endpoint of the line.</Documentation>\n"
42623 " </DoubleVectorProperty>\n"
42624 " <PropertyGroup label=\"Line Parameters\" panel_widget=\"InteractiveLine\">\n"
42625 " <Property function=\"Point1WorldPosition\" name=\"Point1\" />\n"
42626 " <Property function=\"Point2WorldPosition\" name=\"Point2\" />\n"
42627 " </PropertyGroup>\n"
42628 " <!-- end of ResampleToLineLine -->\n"
42629 " </SourceProxy>\n"
42630 "\n"
42631 " <!-- ==================================================================== -->\n"
42632 " <SourceProxy class=\"vtkPVGenerateGlobalIds\"\n"
42633 " label=\"Global Point And Cell Ids\"\n"
42634 " name=\"GlobalPointAndCellIds\">\n"
42635 " <Documentation short_help=\"Generate global point and cell ids.\">\n"
42636 " Generate global point and cell ids. Global ids are unique ids where the same point\n"
42637 " (or cell) will be assigned the same id even if the point (or cell) is duplicated among\n"
42638 " multiple blocks or ranks. This filter also flags duplicated points as ghost points.\n"
42639 " Note that if the input is an HyperTree Grid, this filter only generates global cell ids.\n"
42640 " </Documentation>\n"
42641 " <InputProperty command=\"SetInputConnection\"\n"
42642 " name=\"Input\">\n"
42643 " <ProxyGroupDomain name=\"groups\">\n"
42644 " <Group name=\"sources\" />\n"
42645 " <Group name=\"filters\" />\n"
42646 " </ProxyGroupDomain>\n"
42647 " <DataTypeDomain name=\"input_type\">\n"
42648 " <DataType value=\"vtkDataSet\" />\n"
42649 " <DataType value=\"vtkHyperTreeGrid\" />\n"
42650 " </DataTypeDomain>\n"
42651 " <Documentation>This property specifies the input.</Documentation>\n"
42652 " </InputProperty>\n"
42653 " <DoubleVectorProperty name=\"Tolerance\"\n"
42654 " command=\"SetTolerance\"\n"
42655 " number_of_elements=\"1\"\n"
42656 " default_values=\"0\">\n"
42657 " <Documentation>\n"
42658 " Set the tolerance to use to identify coincident points. 0 means the\n"
42659 " points should be exactly identical.\n"
42660 " </Documentation>\n"
42661 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
42662 " <Hints>\n"
42663 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
42664 " name=\"vtkHyperTreeGrid\"\n"
42665 " exclude=\"1\"\n"
42666 " mode=\"visibility\"/>\n"
42667 " </Hints>\n"
42668 " </DoubleVectorProperty>\n"
42669 " </SourceProxy>\n"
42670 "\n"
42671 " <SourceProxy class=\"vtkPVGenerateGlobalIds\"\n"
42672 " label=\"Generate Global Ids\"\n"
42673 " base_proxyname=\"GlobalPointAndCellIds\"\n"
42674 " base_proxygroup=\"filters\"\n"
42675 " name=\"GenerateGlobalIds\">\n"
42676 " <Deprecated deprecated_in=\"5.13\" to_remove_in=\"5.14\">\n"
42677 " This has been renamed into 'GlobalPointAndCellIds'. Please consider using that instead.\n"
42678 " </Deprecated>\n"
42679 " <!-- End GenerateGlobalIds -->\n"
42680 " </SourceProxy>\n"
42681 " </ProxyGroup>\n"
42682 "</ServerManagerConfiguration>\n"
42683 "\n";
42684 // Get single string
42686 {
42687
42688  const size_t len0 = strlen(paraview_server_managerparallel_diy_filtersInterface0);
42689  const size_t len1 = strlen(paraview_server_managerparallel_diy_filtersInterface1);
42690  size_t len = ( 0
42691  + len0
42692  + len1 );
42693  char* res = new char[ len + 1];
42694  size_t offset = 0;
42697  assert(offset == len);
42698  res[offset] = 0;
42699  return res;
42700 }
42701
42702
42703 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersParallel/Resources/parallel_filters.xml
42705 "<ServerManagerConfiguration>\n"
42706 " <!-- ******************************************************************** -->\n"
42707 " <ProxyGroup name=\"filters\">\n"
42708 " <!-- ==================================================================== -->\n"
42709 " <SourceProxy class=\"vtkPVGenerateProcessIds\"\n"
42710 " name=\"ProcessIds\"\n"
42711 " label=\"Process Ids\">\n"
42712 " <Documentation\n"
42713 " long_help=\"This filter generate point and cell data containing the current process id of each point and cell.\"\n"
42714 " short_help=\"Generate process id scalars\">\n"
42715 " GenerateProcessIds is meant to fill in the ProcessIds attribute array,\n"
42716 " to know which processor owns which cells and points. It can generate it\n"
42717 " for both PointData and CellData. The ProcessIds array's name will be\n"
42718 " \"PointProcessIds\" for PointData, and \"CellProcessIds\" for CellData.\n"
42719 " Note that if the input is an HyperTree Grid instance, only cell process\n"
42720 " IDs are available.\n"
42721 " </Documentation>\n"
42722 " <InputProperty command=\"SetInputConnection\"\n"
42723 " name=\"Input\">\n"
42724 " <ProxyGroupDomain name=\"groups\">\n"
42725 " <Group name=\"sources\"/>\n"
42726 " <Group name=\"filters\"/>\n"
42727 " </ProxyGroupDomain>\n"
42728 " <DataTypeDomain composite_data_supported=\"1\"\n"
42729 " name=\"input_type\">\n"
42730 " <DataType value=\"vtkDataSet\"/>\n"
42731 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
42732 " </DataTypeDomain>\n"
42733 " </InputProperty>\n"
42734 " <IntVectorProperty command=\"SetGeneratePointData\"\n"
42735 " default_values=\"1\"\n"
42736 " name=\"GeneratePointData\"\n"
42737 " number_of_elements=\"1\">\n"
42738 " <BooleanDomain name=\"bool\"/>\n"
42739 " <Documentation>\n"
42740 " The value of this property determines whether to generate process id for points.\n"
42741 " </Documentation>\n"
42742 " <Hints>\n"
42743 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
42744 " name=\"vtkHyperTreeGrid\"\n"
42745 " mode=\"visibility\"\n"
42746 " exclude=\"1\"/>\n"
42747 " </Hints>\n"
42748 " </IntVectorProperty>\n"
42749 " <IntVectorProperty command=\"SetGenerateCellData\"\n"
42750 " default_values=\"0\"\n"
42751 " name=\"GenerateCellData\"\n"
42752 " number_of_elements=\"1\">\n"
42753 " <BooleanDomain name=\"bool\"/>\n"
42754 " <Documentation>\n"
42755 " The value of this property determines whether to generate process id for cells.\n"
42756 " </Documentation>\n"
42757 " <Hints>\n"
42758 " <PropertyWidgetDecorator type=\"InputDataTypeDecorator\"\n"
42759 " name=\"vtkHyperTreeGrid\"\n"
42760 " mode=\"visibility\"\n"
42761 " exclude=\"1\"/>\n"
42762 " </Hints>\n"
42763 " </IntVectorProperty>\n"
42764 " </SourceProxy>\n"
42765 "\n"
42766 " <SourceProxy class=\"vtkPVGenerateProcessIds\"\n"
42767 " base_proxyname=\"ProcessIds\"\n"
42768 " base_proxygroup=\"filters\"\n"
42769 " name=\"GenerateProcessIds\">\n"
42770 " <Deprecated deprecated_in=\"5.13\" to_remove_in=\"5.14\">\n"
42771 " This has been replaced by 'ProcessIds'. Please consider using that instead.\n"
42772 " </Deprecated>\n"
42773 " <!-- End of GenerateProcessIds -->\n"
42774 " </SourceProxy>\n"
42775 " <!-- ==================================================================== -->\n"
42776 " <SourceProxy class=\"vtkPVRemoveGhosts\"\n"
42777 " label=\"Remove Ghost Information\"\n"
42778 " name=\"RemoveGhostInformation\">\n"
42779 " <Documentation long_help=\"Removes ghost information.\"\n"
42780 " short_help=\"Removes ghost information.\">\n"
42781 " Removes ghost cells, point data and cell data ghost arrays.\n"
42782 " In the case of HyperTree Grid input, this filter removes the cell\n"
42783 " data ghost array and masks the ghost cells.\n"
42784 " </Documentation>\n"
42785 " <InputProperty command=\"SetInputConnection\"\n"
42786 " name=\"Input\">\n"
42787 " <ProxyGroupDomain name=\"groups\">\n"
42788 " <Group name=\"sources\"/>\n"
42789 " <Group name=\"filters\"/>\n"
42790 " </ProxyGroupDomain>\n"
42791 " <DataTypeDomain name=\"input_type\">\n"
42792 " <DataType value=\"vtkPolyData\"/>\n"
42793 " <DataType value=\"vtkUnstructuredGrid\"/>\n"
42794 " <DataType value=\"vtkHyperTreeGrid\"/>\n"
42795 " </DataTypeDomain>\n"
42796 " <Documentation>\n"
42797 " This property specifies the input to the remove ghost information filter.\n"
42798 " This filter operates on unstructured grids and polydata since it removes the ghost cells.\n"
42799 " It also supports HTGs, in which case it simply masks ghost cells.\n"
42800 " </Documentation>\n"
42801 " </InputProperty>\n"
42802 " <!-- End of RemoveGhostInformation -->\n"
42803 " </SourceProxy>\n"
42804 " </ProxyGroup>\n"
42805 "</ServerManagerConfiguration>\n"
42806 "\n";
42807 // Get single string
42809 {
42810
42811  const size_t len0 = strlen(paraview_server_managerparallel_filtersInterface0);
42812  size_t len = ( 0
42813  + len0 );
42814  char* res = new char[ len + 1];
42815  size_t offset = 0;
42817  assert(offset == len);
42818  res[offset] = 0;
42819  return res;
42820 }
42821
42822
42823 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersMaterialInterface/Resources/material_interface_filters.xml
42825 "<ServerManagerConfiguration>\n"
42826 " <ProxyGroup name=\"filters\">\n"
42827 " <!-- ==================================================================== -->\n"
42828 " <SourceProxy class=\"vtkIntersectFragments\"\n"
42829 " label=\"Intersect Fragments\"\n"
42830 " name=\"IntersectFragments\">\n"
42831 " <Documentation long_help=\"The Intersect Fragments filter perform geometric intersections on sets of fragments.\"\n"
42832 " short_help=\"The Intersect Fragments filter perform geometric intersections on sets of fragments.\">\n"
42833 " The Intersect Fragments filter perform geometric intersections on sets of\n"
42834 " fragments. The filter takes two inputs, the first containing fragment\n"
42835 " geometry and the second containing fragment centers. The filter has two\n"
42836 " outputs. The first is geometry that results from the intersection. The\n"
42837 " second is a set of points that is an approximation of the center of where\n"
42838 " each fragment has been intersected.</Documentation>\n"
42839 " <!-- Out -->\n"
42840 " <OutputPort index=\"0\"\n"
42841 " name=\"geometry\" />\n"
42842 " <OutputPort index=\"1\"\n"
42843 " name=\"statistics\" />\n"
42844 " <!-- In -->\n"
42845 " <InputProperty command=\"SetGeometryInputConnection\"\n"
42846 " name=\"Input\">\n"
42847 " <ProxyGroupDomain name=\"groups\">\n"
42848 " <Group name=\"sources\" />\n"
42849 " <Group name=\"filters\" />\n"
42850 " </ProxyGroupDomain>\n"
42851 " <DataTypeDomain name=\"input_type\">\n"
42852 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
42853 " </DataTypeDomain>\n"
42854 " <Documentation>This input must contain fragment\n"
42855 " geometry.</Documentation>\n"
42856 " </InputProperty>\n"
42857 " <InputProperty command=\"SetStatisticsInputConnection\"\n"
42858 " name=\"Source\">\n"
42859 " <ProxyGroupDomain name=\"groups\">\n"
42860 " <Group name=\"sources\" />\n"
42861 " <Group name=\"filters\" />\n"
42862 " </ProxyGroupDomain>\n"
42863 " <DataTypeDomain name=\"input_type\">\n"
42864 " <DataType value=\"vtkMultiBlockDataSet\" />\n"
42865 " </DataTypeDomain>\n"
42866 " <Documentation>This input must contain fragment\n"
42867 " centers.</Documentation>\n"
42868 " </InputProperty>\n"
42869 " <!-- Cut functuion -->\n"
42870 " <ProxyProperty command=\"SetCutFunction\"\n"
42871 " label=\"Slice Type\"\n"
42872 " name=\"CutFunction\">\n"
42873 " <ProxyListDomain name=\"proxy_list\">\n"
42874 " <Group name=\"extract_implicit_functions\" default=\"Plane\" />\n"
42875 " </ProxyListDomain>\n"
42876 " <Documentation>This property sets the type of intersecting geometry,\n"
42877 " and associated parameters.</Documentation>\n"
42878 " </ProxyProperty>\n"
42879 " <!-- End IntersectFragments -->\n"
42880 " </SourceProxy>\n"
42881 "\n"
42882 " <!-- ==================================================================== -->\n"
42883 " <SourceProxy class=\"vtkMaterialInterfaceFilter\"\n"
42884 " label=\"Material Interface Filter\"\n"
42885 " name=\"MaterialInterfaceFilter\">\n"
42886 " <Documentation long_help=\"The Material Interface filter finds volumes in the input data containing material above a certain material fraction.\"\n"
42887 " short_help=\"The Material Interface filter finds volumes in the input data containing material above a certain material fraction.\">\n"
42888 " The Material Interface filter finds voxels inside of which a material\n"
42889 " fraction (or normalized amount of material) is higher than a given\n"
42890 " threshold. As these voxels are identified surfaces enclosing adjacent\n"
42891 " voxels above the threshold are generated. The resulting volume and its\n"
42892 " surface are what we call a fragment. The filter has the ability to\n"
42893 " compute various volumetric attributes such as fragment volume, mass,\n"
42894 " center of mass as well as volume and mass weighted averages for any of\n"
42895 " the fields present. Any field selected for such computation will be also\n"
42896 " be copied into the fragment surface's point data for visualization. The\n"
42897 " filter also has the ability to generate Oriented Bounding Boxes (OBB) for\n"
42898 " each fragment. The data generated by the filter is organized in three\n"
42899 " outputs. The \"geometry\" output, containing the fragment surfaces. The\n"
42900 " \"statistics\" output, containing a point set of the centers of mass. The\n"
42901 " \"obb representation\" output, containing OBB representations (poly data).\n"
42902 " All computed attributes are copied into the statistics and geometry\n"
42903 " output. The obb representation output is used for validation and\n"
42904 " debugging purposes and is turned off by default. To measure the size of\n"
42905 " craters, the filter can invert a volume fraction and clip the volume\n"
42906 " fraction with a sphere and/or a plane.</Documentation>\n"
42907 " <OutputPort index=\"0\"\n"
42908 " name=\"geometry\" />\n"
42909 " <OutputPort index=\"1\"\n"
42910 " name=\"statistics\" />\n"
42911 " <InputProperty command=\"SetInputConnection\"\n"
42912 " name=\"Input\">\n"
42913 " <ProxyGroupDomain name=\"groups\">\n"
42914 " <Group name=\"sources\" />\n"
42915 " <Group name=\"filters\" />\n"
42916 " </ProxyGroupDomain>\n"
42917 " <DataTypeDomain name=\"input_type\">\n"
42918 " <DataType value=\"vtkNonOverlappingAMR\" />\n"
42919 " </DataTypeDomain>\n"
42920 " <InputArrayDomain attribute_type=\"cell\"\n"
42921 " name=\"input_array\" />\n"
42922 " <Documentation>Input to the filter can be a hierarchical box data set\n"
42923 " containing image data or a multiblock of rectilinear\n"
42924 " grids.</Documentation>\n"
42925 " </InputProperty>\n"
42926 " <!-- Material Fraction Array-->\n"
42927 " <StringVectorProperty clean_command=\"UnselectAllMaterialArrays\"\n"
42928 " command=\"SelectMaterialArray\"\n"
42929 " label=\"Select Material Fraction Arrays\"\n"
42930 " name=\"SelectMaterialArray\"\n"
42931 " number_of_elements_per_command=\"1\"\n"
42932 " repeat_command=\"1\">\n"
42933 " <ArrayListDomain attribute_type=\"Scalars\"\n"
42934 " data_type=\"VTK_UNSIGNED_CHAR\"\n"
42935 " name=\"array_list\">\n"
42936 " <RequiredProperties>\n"
42937 " <Property function=\"Input\"\n"
42938 " name=\"Input\" />\n"
42939 " </RequiredProperties>\n"
42940 " </ArrayListDomain>\n"
42941 " <Hints>\n"
42942 " <!-- override gui no to set default -->\n"
42943 " <!-- <NoDefault /> -->\n"
42944 " </Hints>\n"
42945 " <Documentation>Material fraction is defined as normalized amount of\n"
42946 " material per voxel. It is expected that arrays containing material\n"
42947 " fraction data has been down converted to a unsigned\n"
42948 " char.</Documentation>\n"
42949 " </StringVectorProperty>\n"
42950 " <!-- Material fraction -->\n"
42951 " <DoubleVectorProperty command=\"SetMaterialFractionThreshold\"\n"
42952 " default_values=\"0.5\"\n"
42953 " label=\"Material Fraction Threshold\"\n"
42954 " name=\"MaterialFractionThreshold\"\n"
42955 " number_of_elements=\"1\">\n"
42956 " <DoubleRangeDomain max=\"1\"\n"
42957 " min=\"0.08\"\n"
42958 " name=\"range\" />\n"
42959 " <Documentation>Material fraction is defined as normalized amount of\n"
42960 " material per voxel. Any voxel in the input data set with a material\n"
42961 " fraction greater than this value is included in the output data\n"
42962 " set.</Documentation>\n"
42963 " </DoubleVectorProperty>\n"
42964 " <!-- Invert the volume fraction -->\n"
42965 " <IntVectorProperty command=\"SetInvertVolumeFraction\"\n"
42966 " default_values=\"0\"\n"
42967 " name=\"InvertVolumeFraction\"\n"
42968 " number_of_elements=\"1\">\n"
42969 " <BooleanDomain name=\"bool\" />\n"
42970 " <Documentation>Inverting the volume fraction generates the negative of\n"
42971 " the material. It is useful for analyzing craters.</Documentation>\n"
42972 " </IntVectorProperty>\n"
42973 " <ProxyProperty command=\"SetClipFunction\"\n"
42974 " label=\"Clip Type\"\n"
42975 " name=\"ClipFunction\">\n"
42976 " <ProxyGroupDomain name=\"groups\">\n"
42977 " <Group name=\"implicit_functions\" />\n"
42978 " </ProxyGroupDomain>\n"
42979 " <ProxyListDomain name=\"proxy_list\">\n"
42980 " <Proxy group=\"implicit_functions\"\n"
42981 " name=\"None\" />\n"
42982 " <Proxy group=\"implicit_functions\"\n"
42983 " name=\"Plane\" />\n"
42984 " <Proxy group=\"implicit_functions\"\n"
42985 " name=\"Sphere\" />\n"
42986 " </ProxyListDomain>\n"
42987 " <Documentation>This property sets the type of clip geometry, and\n"
42988 " associated parameters.</Documentation>\n"
42989 " </ProxyProperty>\n"
42990 " <!-- Mass Array-->\n"
42991 " <StringVectorProperty clean_command=\"UnselectAllMassArrays\"\n"
42992 " command=\"SelectMassArray\"\n"
42993 " label=\"Select Mass Arrays\"\n"
42994 " name=\"SelectMassArray\"\n"
42995 " number_of_elements_per_command=\"1\"\n"
42996 " repeat_command=\"1\">\n"
42997 " <ArrayListDomain attribute_type=\"Scalars\"\n"
42998 " data_type=\"VTK_FLOAT VTK_DOUBLE\"\n"
42999 " name=\"array_list\">\n"
43000 " <RequiredProperties>\n"
43001 " <Property function=\"Input\"\n"
43002 " name=\"Input\" />\n"
43003 " </RequiredProperties>\n"
43004 " </ArrayListDomain>\n"
43005 " <Hints>\n"
43006 " <!-- override gui no to set default -->\n"
43007 " <NoDefault />\n"
43008 " </Hints>\n"
43009 " <Documentation>Mass arrays are paired with material fraction arrays.\n"
43010 " This means that the first selected material fraction array is paired\n"
43011 " with the first selected mass array, and so on sequentially. As the\n"
43012 " filter identifies voxels meeting the minimum material fraction\n"
43013 " threshold, these voxel's mass will be used in fragment center of mass\n"
43014 " and mass calculation. A warning is generated if no mass array is\n"
43015 " selected for an individual material fraction array. However, in that\n"
43016 " case the filter will run without issue because the statistics output\n"
43017 " can be generated using fragments' centers computed from axis aligned\n"
43018 " bounding boxes.</Documentation>\n"
43019 " </StringVectorProperty>\n"
43020 " <!-- Volume weighted average Array -->\n"
43021 " <StringVectorProperty clean_command=\"UnselectAllVolumeWtdAvgArrays\"\n"
43022 " command=\"SelectVolumeWtdAvgArray\"\n"
43023 " label=\"Compute volume weighted average over:\"\n"
43024 " name=\"SelectVolumeWtdAvgArray\"\n"
43025 " number_of_elements_per_command=\"1\"\n"
43026 " repeat_command=\"1\">\n"
43027 " <Documentation>Specifies the arrays from which to volume weighted\n"
43028 " average.</Documentation>\n"
43029 " <ArrayListDomain data_type=\"VTK_FLOAT VTK_DOUBLE\"\n"
43030 " name=\"array_list\">\n"
43031 " <RequiredProperties>\n"
43032 " <Property function=\"Input\"\n"
43033 " name=\"Input\" />\n"
43034 " </RequiredProperties>\n"
43035 " </ArrayListDomain>\n"
43036 " <Hints>\n"
43037 " <!-- override gui no to set default -->\n"
43038 " <NoDefault />\n"
43039 " </Hints>\n"
43040 " <Documentation>For arrays selected a volume weighted average is\n"
43041 " computed. The values of these arrays are also copied into fragment\n"
43042 " geometry cell data as the fragment surfaces are\n"
43043 " generated.</Documentation>\n"
43044 " </StringVectorProperty>\n"
43045 " <!-- Mass weighted average Array -->\n"
43046 " <StringVectorProperty clean_command=\"UnselectAllMassWtdAvgArrays\"\n"
43047 " command=\"SelectMassWtdAvgArray\"\n"
43048 " label=\"Compute mass weighted average over:\"\n"
43049 " name=\"SelectMassWtdAvgArray\"\n"
43050 " number_of_elements_per_command=\"1\"\n"
43051 " repeat_command=\"1\">\n"
43052 " <ArrayListDomain data_type=\"VTK_FLOAT VTK_DOUBLE\"\n"
43053 " name=\"array_list\">\n"
43054 " <RequiredProperties>\n"
43055 " <Property function=\"Input\"\n"
43056 " name=\"Input\" />\n"
43057 " </RequiredProperties>\n"
43058 " </ArrayListDomain>\n"
43059 " <Hints>\n"
43060 " <!-- override gui no to set default -->\n"
43061 " <NoDefault />\n"
43062 " </Hints>\n"
43063 " <Documentation>For arrays selected a mass weighted average is computed.\n"
43064 " These arrays are also copied into fragment geometry cell data as the\n"
43065 " fragment surfaces are generated.</Documentation>\n"
43066 " </StringVectorProperty>\n"
43067 " <!-- do not remove -->\n"
43068 " <!-- Summation Array\n"
43069 " <StringVectorProperty\n"
43070 " name=\"SelectSummationArray\"\n"
43071 " command=\"SelectSummationArray\"\n"
43072 " clean_command=\"UnselectAllSummationArrays\"\n"
43073 " repeat_command=\"1\"\n"
43074 " number_of_elements_per_command=\"1\"\n"
43075 " label=\"Compute summation over:\">\n"
43076 " <Documentation>\n"
43077 " Specifies the arrays from which to sum over fragments.\n"
43078 " </Documentation>\n"
43079 "\n"
43080 " <ArrayListDomain\n"
43081 " name=\"array_list\"\n"
43082 " data_type=\"VTK_FLOAT VTK_DOUBLE\">\n"
43083 " <RequiredProperties>\n"
43084 " <Property name=\"Input\" function=\"Input\"/>\n"
43085 " </RequiredProperties>\n"
43086 " </ArrayListDomain>\n"
43087 " <Hints>\n"
43088 " <NoDefault />\n"
43089 " </Hints>\n"
43090 " </StringVectorProperty>-->\n"
43091 " <!-- Compute OBB -->\n"
43092 " <IntVectorProperty command=\"SetComputeOBB\"\n"
43093 " default_values=\"0\"\n"
43094 " name=\"ComputeOBB\"\n"
43095 " number_of_elements=\"1\">\n"
43096 " <BooleanDomain name=\"bool\" />\n"
43097 " <Documentation>Compute Object Oriented Bounding boxes (OBB). When\n"
43098 " active the result of this computation is copied into the statistics\n"
43099 " output. In the case that the filter is built in its validation mode,\n"
43100 " the OBB's are rendered.</Documentation>\n"
43101 " </IntVectorProperty>\n"
43102 " <!-- Write a csv file:\n"
43103 " This is not an excel compatible file, it has more\n"
43104 " information that is stored in headers. Also commas\n"
43105 " are used on tuple boundaries while spaces are used\n"
43106 " on component boundaries.-->\n"
43107 " <IntVectorProperty command=\"SetWriteGeometryOutput\"\n"
43108 " default_values=\"0\"\n"
43109 " name=\"WriteGeometryOutput\"\n"
43110 " number_of_elements=\"1\">\n"
43111 " <BooleanDomain name=\"bool\" />\n"
43112 " <Documentation>If this property is set, then the geometry output is\n"
43113 " written to a text file. The file name will be constructed using the\n"
43114 " path in the \"Output Base Name\" widget.</Documentation>\n"
43115 " </IntVectorProperty>\n"
43116 " <IntVectorProperty command=\"SetWriteStatisticsOutput\"\n"
43117 " default_values=\"0\"\n"
43118 " name=\"WriteStatisticsOutput\"\n"
43119 " number_of_elements=\"1\">\n"
43120 " <BooleanDomain name=\"bool\" />\n"
43121 " <Documentation>If this property is set, then the statistics output is\n"
43122 " written to a text file. The file name will be constructed using the\n"
43123 " path in the \"Output Base Name\" widget.</Documentation>\n"
43124 ;
43125
43126 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersMaterialInterface/Resources/material_interface_filters.xml
43128 " </IntVectorProperty>\n"
43129 " <StringVectorProperty animateable=\"0\"\n"
43130 " command=\"SetOutputBaseName\"\n"
43131 " name=\"OutputBaseName\"\n"
43132 " number_of_elements=\"1\">\n"
43133 " <Documentation>This property specifies the base including path of where\n"
43134 " to write the statistics and geometry output text files. It follows the\n"
43135 " pattern \"/path/to/folder/and/file\" here file has no extension, as the\n"
43136 " filter will generate a unique extension.</Documentation>\n"
43137 " </StringVectorProperty>\n"
43138 " <!-- do not remove\n"
43139 " this is a feature that most users should not\n"
43140 " need. If memory usage becomes a problem then\n"
43141 " this gives the user more control over excluding\n"
43142 " highly loaded processes from memory intesive operations. -->\n"
43143 " <!-- loading bounds\n"
43144 " <IntVectorProperty\n"
43145 " name=\"UpperLoadingBound\"\n"
43146 " command=\"SetUpperLoadingBound\"\n"
43147 " number_of_elements=\"1\"\n"
43148 " default_values=\"-1\"\n"
43149 " label=\"Loading Bound\">\n"
43150 " <DoubleRangeDomain name=\"range\" min=\"-1\" max=\"2000000000\" />\n"
43151 " <Documentation>\n"
43152 " Bound in polygons above which process are excluded from work sharing.\n"
43153 " </Documentation>\n"
43154 " </IntVectorProperty>-->\n"
43155 " <!-- End MaterialInterfaceFilter -->\n"
43156 " </SourceProxy>\n"
43157 " </ProxyGroup>\n"
43158 "</ServerManagerConfiguration>\n"
43159 "\n";
43160 // Get single string
43162 {
43163
43166  size_t len = ( 0
43167  + len0
43168  + len1 );
43169  char* res = new char[ len + 1];
43170  size_t offset = 0;
43173  assert(offset == len);
43174  res[offset] = 0;
43175  return res;
43176 }
43177
43178
43179 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersGeneralMPI/Resources/general_mpi_filters.xml
43181 "<ServerManagerConfiguration>\n"
43182 " <ProxyGroup name=\"filters\">\n"
43183 " <!-- ==================================================================== -->\n"
43184 " <SourceProxy base_proxygroup=\"filters\"\n"
43185 " base_proxyname=\"ParticlePath\"\n"
43186 " class=\"vtkInSituPParticlePathFilter\"\n"
43187 " name=\"InSituParticlePath\">\n"
43188 " <Documentation long_help=\"Trace Particle Paths through time in a vector field.\"\n"
43189 " short_help=\"Trace Particle Paths through time in a vector field.\">\n"
43190 " The Particle Trace filter generates pathlines in a vector\n"
43191 " field from a collection of seed points. The vector field\n"
43192 " used is selected from the Vectors menu, so the input data\n"
43193 " set is required to have point-centered vectors. The Seed\n"
43194 " portion of the interface allows you to select whether the\n"
43195 " seed points for this integration lie in a point cloud or\n"
43196 " along a line. Depending on which is selected, the\n"
43197 " appropriate 3D widget (point or line widget) is displayed\n"
43198 " along with traditional user interface controls for\n"
43199 " positioning the point cloud or line within the data set.\n"
43200 " Instructions for using the 3D widgets and the\n"
43201 " corresponding manual controls can be found in section 7.4.\n"
43202 " This filter operates on any type of data set, provided it\n"
43203 " has point-centered vectors. The output is polygonal data\n"
43204 " containing polylines. This filter is available on the\n"
43205 " Toolbar.</Documentation>\n"
43206 " <InputProperty clean_command=\"RemoveAllRestarts\"\n"
43207 " command=\"AddRestartConnection\"\n"
43208 " label=\"Restart Source\"\n"
43209 " multiple_input=\"0\"\n"
43210 " name=\"RestartSource\"\n"
43211 " panel_visibility=\"never\">\n"
43212 " <ProxyGroupDomain name=\"groups\">\n"
43213 " <Group name=\"sources\" />\n"
43214 " <Group name=\"filters\" />\n"
43215 " </ProxyGroupDomain>\n"
43216 " <DataTypeDomain name=\"input_type\">\n"
43217 " <DataType value=\"vtkDataSet\" />\n"
43218 " </DataTypeDomain>\n"
43219 " <Documentation>Specify the restart dataset. This is optional and\n"
43220 " can be used to have particle histories that were computed\n"
43221 " previously be included in this filter's computation.</Documentation>\n"
43222 " <Hints>\n"
43223 " <Optional />\n"
43224 " </Hints>\n"
43225 " </InputProperty>\n"
43226 " <IntVectorProperty command=\"SetClearCache\"\n"
43227 " default_values=\"0\"\n"
43228 " name=\"ClearCache\"\n"
43229 " number_of_elements=\"1\"\n"
43230 " panel_visibility=\"never\">\n"
43231 " <BooleanDomain name=\"bool\" />\n"
43232 " <Documentation>Clear the particle cache from previous time steps.\n"
43233 " </Documentation>\n"
43234 " </IntVectorProperty>\n"
43235 " <IntVectorProperty command=\"SetFirstTimeStep\"\n"
43236 " default_values=\"0\"\n"
43237 " name=\"FirstTimeStep\"\n"
43238 " number_of_elements=\"1\"\n"
43239 " panel_visibility=\"never\">\n"
43240 " <Documentation>Set the first time step. Default is 0.\n"
43241 " </Documentation>\n"
43242 " </IntVectorProperty>\n"
43243 " <IntVectorProperty command=\"SetRestartedSimulation\"\n"
43244 " default_values=\"0\"\n"
43245 " name=\"RestartedSimulation\"\n"
43246 " number_of_elements=\"1\"\n"
43247 " panel_visibility=\"never\">\n"
43248 " <BooleanDomain name=\"bool\" />\n"
43249 " <Documentation>Specify whether or not this is a restarted simulation.</Documentation>\n"
43250 " </IntVectorProperty>\n"
43251 " <IntVectorProperty command=\"SetDisableResetCache\"\n"
43252 " default_values=\"0\"\n"
43253 " name=\"DisableResetCache\"\n"
43254 " number_of_elements=\"1\"\n"
43255 " panel_visibility=\"never\">\n"
43256 " <BooleanDomain name=\"bool\" />\n"
43257 " <Documentation>Prevents cache from getting reset so that new computation\n"
43258 " always start from previous results.</Documentation>\n"
43259 " </IntVectorProperty>\n"
43260 " <!-- End vtkInSituPParticlePathFilter -->\n"
43261 " </SourceProxy>\n"
43262 " </ProxyGroup>\n"
43263 "</ServerManagerConfiguration>\n"
43264 "\n";
43265 // Get single string
43267 {
43268
43269  const size_t len0 = strlen(paraview_server_managergeneral_mpi_filtersInterface0);
43270  size_t len = ( 0
43271  + len0 );
43272  char* res = new char[ len + 1];
43273  size_t offset = 0;
43275  assert(offset == len);
43276  res[offset] = 0;
43277  return res;
43278 }
43279
43280
43281 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersFlowPaths/Resources/flowpaths_filters.xml
43283 "<ServerManagerConfiguration>\n"
43284 " <ProxyGroup name=\"filters\">\n"
43285 " <!-- ==================================================================== -->\n"
43286 " <SourceProxy class=\"vtkLegacyParticlePathFilter\"\n"
43287 " name=\"LegacyParticlePath\">\n"
43288 " <Documentation long_help=\"Trace Particle Paths through time in a vector field.\"\n"
43289 " short_help=\"Trace Particle Paths through time in a vector field.\">\n"
43290 " The Particle Trace filter generates pathlines in a vector\n"
43291 " field from a collection of seed points. The vector field\n"
43292 " used is selected from the Vectors menu, so the input data\n"
43293 " set is required to have point-centered vectors. The Seed\n"
43294 " portion of the interface allows you to select whether the\n"
43295 " seed points for this integration lie in a point cloud or\n"
43296 " along a line. Depending on which is selected, the\n"
43297 " appropriate 3D widget (point or line widget) is displayed\n"
43298 " along with traditional user interface controls for\n"
43299 " positioning the point cloud or line within the data set.\n"
43300 " Instructions for using the 3D widgets and the\n"
43301 " corresponding manual controls can be found in section 7.4.\n"
43302 " This filter operates on any type of data set, provided it\n"
43303 " has point-centered vectors. The output is polygonal data\n"
43304 " containing polylines.\n"
43305 " </Documentation>\n"
43306 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
43307 " command=\"AddInputConnection\"\n"
43308 " multiple_input=\"1\"\n"
43309 " name=\"Input\">\n"
43310 " <ProxyGroupDomain name=\"groups\">\n"
43311 " <Group name=\"sources\"/>\n"
43312 " <Group name=\"filters\"/>\n"
43313 " </ProxyGroupDomain>\n"
43314 " <DataTypeDomain composite_data_supported=\"1\"\n"
43315 " name=\"input_type\">\n"
43316 " <DataType value=\"vtkDataObject\"/>\n"
43317 " </DataTypeDomain>\n"
43318 " <InputArrayDomain attribute_type=\"point\"\n"
43319 " name=\"input_array\"\n"
43320 " number_of_components=\"3\"/>\n"
43321 " <Documentation>\n"
43322 " Specify which is the Input of the StreamTracer filter.\n"
43323 " </Documentation>\n"
43324 " </InputProperty>\n"
43325 " <InputProperty clean_command=\"RemoveAllSources\"\n"
43326 " command=\"AddSourceConnection\"\n"
43327 " label=\"Seed Source\"\n"
43328 " multiple_input=\"1\"\n"
43329 " name=\"Source\">\n"
43330 " <ProxyGroupDomain name=\"groups\">\n"
43331 " <Group name=\"sources\"/>\n"
43332 " <Group name=\"filters\"/>\n"
43333 " </ProxyGroupDomain>\n"
43334 " <DataTypeDomain name=\"input_type\">\n"
43335 " <DataType value=\"vtkDataSet\"/>\n"
43336 " </DataTypeDomain>\n"
43337 " <Documentation>\n"
43338 " Specify the seed dataset. Typically, from where the vector field integration should begin.\n"
43339 " Usually a point/radius or a line with a given resolution.\n"
43340 " </Documentation>\n"
43341 " </InputProperty>\n"
43342 " <DoubleVectorProperty command=\"SetTerminationTime\"\n"
43343 " default_values=\"0.0\"\n"
43344 " name=\"TerminationTime\"\n"
43345 " number_of_elements=\"1\"\n"
43346 " panel_visibility=\"never\">\n"
43347 " <DoubleRangeDomain name=\"range\"/>\n"
43348 " <Documentation>\n"
43349 " Setting TerminationTime to a positive value will cause particles to terminate when the time is reached.\n"
43350 " The units of time should be consistent with the primary time variable.\n"
43351 " </Documentation>\n"
43352 " </DoubleVectorProperty>\n"
43353 " <DoubleVectorProperty information_only=\"1\"\n"
43354 " name=\"TimestepValues\">\n"
43355 " <TimeStepsInformationHelper/>\n"
43356 " </DoubleVectorProperty>\n"
43357 " <IntVectorProperty command=\"SetForceReinjectionEveryNSteps\"\n"
43358 " default_values=\"0\"\n"
43359 " name=\"ForceReinjectionEveryNSteps\"\n"
43360 " number_of_elements=\"1\">\n"
43361 " <IntRangeDomain name=\"range\"/>\n"
43362 " <Documentation>\n"
43363 " When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow.\n"
43364 " Setting ForceReinjectionEveryNSteps to a non zero value will cause the particle source to reinject\n"
43365 " particles every Nth step even if it is otherwise unchanged. Note that if the particle source is also animated,\n"
43366 " this flag will be redundant as the particles will be reinjected whenever the source changes anyway.\n"
43367 " </Documentation>\n"
43368 " </IntVectorProperty>\n"
43369 " <IntVectorProperty command=\"SetStaticSeeds\"\n"
43370 " default_values=\"0\"\n"
43371 " name=\"StaticSeeds\"\n"
43372 " number_of_elements=\"1\">\n"
43373 " <BooleanDomain name=\"bool\"/>\n"
43374 " <Documentation>\n"
43375 " If the input seeds are not changing, then this can be set to 1 to avoid having to do a repeated grid search\n"
43376 " that would return the exact same result.\n"
43377 " </Documentation>\n"
43378 " </IntVectorProperty>\n"
43379 " <IntVectorProperty command=\"SetMeshOverTime\"\n"
43380 " default_values=\"0\"\n"
43381 " name=\"MeshOverTime\"\n"
43382 " number_of_elements=\"1\">\n"
43383 " <EnumerationDomain name=\"enum\">\n"
43384 " <Entry text=\"Different\" value=\"0\"/>\n"
43385 " <Entry text=\"Static\" value=\"1\"/>\n"
43386 " <Entry text=\"Linear Transformation\" value=\"2\"/>\n"
43387 " <Entry text=\"Same Topology\" value=\"3\"/>\n"
43388 " </EnumerationDomain>\n"
43389 " <Documentation>\n"
43390 " The input mesh can either be 1) different over time, or 2) static over time,\n"
43391 " or 3) a linear transformation of the first time step over time, or 4) have the same topology over time.\n"
43392 " If a value other than Different are used, then performance can be improved significantly because certain\n"
43393 " data structures, such as locators or cell links are not rebuilt for each timestep.\n"
43394 " </Documentation>\n"
43395 " </IntVectorProperty>\n"
43396 " <IntVectorProperty command=\"SetInterpolatorType\"\n"
43397 " default_values=\"1\"\n"
43398 " name=\"InterpolatorType\"\n"
43399 " number_of_elements=\"1\"\n"
43400 " panel_visibility=\"advanced\">\n"
43401 " <EnumerationDomain name=\"enum\">\n"
43402 " <Entry text=\"Interpolator with Point Locator\"\n"
43403 " value=\"0\"/>\n"
43404 " <Entry text=\"Interpolator with Cell Locator\"\n"
43405 " value=\"1\"/>\n"
43406 " </EnumerationDomain>\n"
43407 " <Documentation>\n"
43408 " This property determines which interpolator to use for evaluating the velocity vector field. The first is\n"
43409 " faster though the second is more robust in locating cells during streamline integration.\n"
43410 " </Documentation>\n"
43411 " </IntVectorProperty>\n"
43412 " <StringVectorProperty animateable=\"0\"\n"
43413 " command=\"SetInputArrayToProcess\"\n"
43414 " element_types=\"0 0 0 0 2\"\n"
43415 " name=\"SelectInputVectors\"\n"
43416 " number_of_elements=\"5\"\n"
43417 " panel_visibility=\"default\">\n"
43418 " <ArrayListDomain attribute_type=\"Vectors\"\n"
43419 " name=\"array_list\">\n"
43420 " <RequiredProperties>\n"
43421 " <Property function=\"Input\"\n"
43422 " name=\"Input\"/>\n"
43423 " </RequiredProperties>\n"
43424 " </ArrayListDomain>\n"
43425 " <Documentation>\n"
43426 " Specify which vector array should be used for the integration through that filter.\n"
43427 " </Documentation>\n"
43428 " </StringVectorProperty>\n"
43429 " <IntVectorProperty command=\"SetComputeVorticity\"\n"
43430 " default_values=\"1\"\n"
43431 " name=\"ComputeVorticity\"\n"
43432 " number_of_elements=\"1\">\n"
43433 " <BooleanDomain name=\"bool\"/>\n"
43434 " <Documentation>\n"
43435 " Compute vorticity and angular rotation of particles as they progress\n"
43436 " </Documentation>\n"
43437 " </IntVectorProperty>\n"
43438 " <DoubleVectorProperty command=\"SetTerminalSpeed\"\n"
43439 " default_values=\"0.000000000001\"\n"
43440 " label=\"Terminal Speed\"\n"
43441 " name=\"TerminalSpeed\"\n"
43442 " number_of_elements=\"1\"\n"
43443 " panel_visibility=\"advanced\">\n"
43444 " <DoubleRangeDomain name=\"range\"/>\n"
43445 " <Documentation>\n"
43446 " This property specifies the terminal speed, below which particle advection/integration is terminated.\n"
43447 " </Documentation>\n"
43448 " </DoubleVectorProperty>\n"
43449 " </SourceProxy>\n"
43450 "\n"
43451 " <!-- ==================================================================== -->\n"
43452 " <SourceProxy class=\"vtkLegacyStreaklineFilter\"\n"
43453 " name=\"LegacyStreakLine\">\n"
43454 " <Documentation long_help=\"Trace Streak lines through time in a vector field.\"\n"
43455 " short_help=\"Trace Streak lines through time in a vector field.\">\n"
43456 " The Particle Trace filter generates pathlines in a vector\n"
43457 " field from a collection of seed points. The vector field\n"
43458 " used is selected from the Vectors menu, so the input data\n"
43459 " set is required to have point-centered vectors. The Seed\n"
43460 " portion of the interface allows you to select whether the\n"
43461 " seed points for this integration lie in a point cloud or\n"
43462 " along a line. Depending on which is selected, the\n"
43463 " appropriate 3D widget (point or line widget) is displayed\n"
43464 " along with traditional user interface controls for\n"
43465 " positioning the point cloud or line within the data set.\n"
43466 " Instructions for using the 3D widgets and the\n"
43467 " corresponding manual controls can be found in section 7.4.\n"
43468 " This filter operates on any type of data set, provided it\n"
43469 " has point-centered vectors. The output is polygonal data\n"
43470 " containing polylines.\n"
43471 " </Documentation>\n"
43472 " <InputProperty clean_command=\"RemoveAllInputs\"\n"
43473 " command=\"AddInputConnection\"\n"
43474 " multiple_input=\"1\"\n"
43475 " name=\"Input\">\n"
43476 " <ProxyGroupDomain name=\"groups\">\n"
43477 " <Group name=\"sources\"/>\n"
43478 " <Group name=\"filters\"/>\n"
43479 " </ProxyGroupDomain>\n"
43480 " <DataTypeDomain composite_data_supported=\"1\"\n"
43481 " name=\"input_type\">\n"
43482 " <DataType value=\"vtkDataObject\"/>\n"
43483 " </DataTypeDomain>\n"
43484 " <InputArrayDomain attribute_type=\"point\"\n"
43485 " name=\"input_array\"\n"
43486 " number_of_components=\"3\"/>\n"
43487 " <Documentation>\n"
43488 " Specify which is the Input of the StreamTracer filter.\n"
43489 " </Documentation>\n"
43490 " </InputProperty>\n"
43491 " <IntVectorProperty command=\"SetStaticSeeds\"\n"
43492 " default_values=\"0\"\n"
43493 " name=\"StaticSeeds\"\n"
43494 " number_of_elements=\"1\">\n"
43495 " <BooleanDomain name=\"bool\"/>\n"
43496 " <Documentation>\n"
43497 " If the input seeds are not changing, then this can be set to 1 to avoid having to do a repeated grid search\n"
43498 " that would return the exact same result.\n"
43499 " </Documentation>\n"
43500 " </IntVectorProperty>\n"
43501 " <IntVectorProperty command=\"SetMeshOverTime\"\n"
43502 " default_values=\"0\"\n"
43503 " name=\"MeshOverTime\"\n"
43504 " number_of_elements=\"1\">\n"
43505 " <EnumerationDomain name=\"enum\">\n"
43506 " <Entry text=\"Different\" value=\"0\"/>\n"
43507 " <Entry text=\"Static\" value=\"1\"/>\n"
43508 " <Entry text=\"Linear Transformation\" value=\"2\"/>\n"
43509 " <Entry text=\"Same Topology\" value=\"3\"/>\n"
43510 " </EnumerationDomain>\n"
43511 " <Documentation>\n"
43512 " The input mesh can either be 1) different over time, or 2) static over time,\n"
43513 " or 3) a linear transformation of the first time step over time, or 4) have the same topology over time.\n"
43514 " If a value other than Different are used, then performance can be improved significantly because certain\n"
43515 " data structures, such as locators or cell links are not rebuilt for each timestep.\n"
43516 " </Documentation>\n"
43517 " </IntVectorProperty>\n"
43518 " <IntVectorProperty command=\"SetInterpolatorType\"\n"
43519 " default_values=\"1\"\n"
43520 " name=\"InterpolatorType\"\n"
43521 " number_of_elements=\"1\"\n"
43522 " panel_visibility=\"advanced\">\n"
43523 " <EnumerationDomain name=\"enum\">\n"
43524 " <Entry text=\"Interpolator with Point Locator\"\n"
43525 " value=\"0\"/>\n"
43526 " <Entry text=\"Interpolator with Cell Locator\"\n"
43527 " value=\"1\"/>\n"
43528 " </EnumerationDomain>\n"
43529 " <Documentation>\n"
43530 " This property determines which interpolator to use for evaluating the velocity vector field. The first is\n"
43531 " faster though the second is more robust in locating cells during streamline integration.\n"
43532 " </Documentation>\n"
43533 " </IntVectorProperty>\n"
43534 " <InputProperty clean_command=\"RemoveAllSources\"\n"
43535 " command=\"AddSourceConnection\"\n"
43536 " label=\"Seed Source\"\n"
43537 " multiple_input=\"1\"\n"
43538 " name=\"Source\">\n"
43539 " <ProxyGroupDomain name=\"groups\">\n"
43540 " <Group name=\"sources\"/>\n"
43541 " <Group name=\"filters\"/>\n"
43542 " </ProxyGroupDomain>\n"
43543 " <DataTypeDomain name=\"input_type\">\n"
43544 " <DataType value=\"vtkDataSet\"/>\n"
43545 " </DataTypeDomain>\n"
43546 " <Documentation>\n"
43547 " Specify the seed dataset. Typically, from where the vector field integration should begin. Usually a\n"
43548 " point/radius or a line with a given resolution.\n"
43549 " </Documentation>\n"
43550 " </InputProperty>\n"
43551 " <DoubleVectorProperty command=\"SetTerminationTime\"\n"
43552 " default_values=\"0.0\"\n"
43553 " name=\"TerminationTime\"\n"
43554 " number_of_elements=\"1\"\n"
43555 " panel_visibility=\"never\">\n"
43556 " <DoubleRangeDomain name=\"range\"/>\n"
43557 " <Documentation>\n"
43558 " Setting TerminationTime to a positive value will cause particles to terminate when the time is reached.\n"
43559 " The units of time should be consistent with the primary time variable.\n"
43560 " </Documentation>\n"
43561 " </DoubleVectorProperty>\n"
43562 " <DoubleVectorProperty information_only=\"1\"\n"
43563 " name=\"TimestepValues\">\n"
43564 " <TimeStepsInformationHelper/>\n"
43565 " </DoubleVectorProperty>\n"
43566 " <IntVectorProperty command=\"SetForceReinjectionEveryNSteps\"\n"
43567 " default_values=\"1\"\n"
43568 " name=\"ForceReinjectionEveryNSteps\"\n"
43569 " number_of_elements=\"1\">\n"
43570 " <IntRangeDomain name=\"range\"/>\n"
43571 " <Documentation>\n"
43572 " When animating particles, it is nice to inject new ones every Nth step to produce a continuous flow.\n"
43573 " Setting ForceReinjectionEveryNSteps to a non zero value will cause the particle source to reinject particles\n"
43574 " every Nth step even if it is otherwise unchanged. Note that if the particle source is also animated, this flag\n"
43575 ;
43576
43577 // From file /builds/gitlab-kitware-sciviz-ci/VTKExtensions/FiltersFlowPaths/Resources/flowpaths_filters.xml
43579 " will be redundant as the particles will be reinjected whenever the source changes anyway.\n"
43580 " </Documentation>\n"
43581 " </IntVectorProperty>\n"
43582 " <StringVectorProperty animateable=\"0\"\n"
43583 " command=\"SetInputArrayToProcess\"\n"
43584 " element_types=\"0 0 0 0 2\"\n"
43585 " name=\"SelectInputVectors\"\n"
43586 " number_of_elements=\"5\"\n"
43587 " panel_visibility=\"default\">\n"
43588 " <ArrayListDomain attribute_type=\"Vectors\"\n"
43589 " name=\"array_list\">\n"
43590 " <RequiredProperties>\n"
43591 " <Property function=\"Input\"\n"
43592 " name=\"Input\"/>\n"
43593 " </RequiredProperties>\n"
43594 " </ArrayListDomain>\n"
43595 " <Documentation>\n"
43596 " Specify which vector array should be used for the integration through that filter.\n"
43597 " </Documentation>\n"
43598 " </StringVectorProperty>\n"
43599 " <IntVectorProperty command=\"SetComputeVorticity\"\n"
43600 " default_values=\"1\"\n"
43601 " name=\"ComputeVorticity\"\n"
43602 " number_of_elements=\"1\">\n"
43603 " <BooleanDomain name=\"bool\"/>\n"
43604 " <Documentation>\n"
43605 " Compute vorticity and angular rotation of particles as they progress\n"
43606 " </Documentation>\n"
43607 " </IntVectorProperty>\n"
43608 " <IntVectorProperty command=\"SetDisableResetCache\"\n"
43609 " default_values=\"0\"\n"
43610 " name=\"DisableResetCache\"\n"
43611 " number_of_elements=\"1\"\n"
43612 " panel_visibility=\"never\">\n"
43613 " <BooleanDomain name=\"bool\"/>\n"
43614 " <Documentation>\n"
43615 " Prevents cache from getting reset so that new computation always start from previous results.\n"
43616 " </Documentation>\n"
43617 " </IntVectorProperty>\n"
43618 " </SourceProxy>\n"
43619 "\n"
43620 " </ProxyGroup>\n"
43621 "</ServerManagerConfiguration>\n"
43622 "\n";
43623 // Get single string
43625 {
43626
43627  const size_t len0 = strlen(paraview_server_managerflowpaths_filtersInterface0);
43628  const size_t len1 = strlen(paraview_server_managerflowpaths_filtersInterface1);
43629  size_t len = ( 0
43630  + len0
43631  + len1 );
43632  char* res = new char[ len + 1];
43633  size_t offset = 0;
43636  assert(offset == len);
43637  res[offset] = 0;
43638  return res;
43639 }
43640
43641
43642 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Animation/Resources/animation.xml
43644 "<!-- Proxy definitions for Animation related proxies -->\n"
43645 "<ServerManagerConfiguration>\n"
43646 " <!-- ==================================================================== -->\n"
43647 " <ProxyGroup name=\"animation\">\n"
43648 " <Proxy name=\"AnimationCueBase\">\n"
43649 " <Documentation>Internal base interface for all animation\n"
43650 " cues.</Documentation>\n"
43651 " <IntVectorProperty command=\"SetTimeMode\"\n"
43652 " default_values=\"0\"\n"
43653 " name=\"TimeMode\"\n"
43654 " number_of_elements=\"1\">\n"
43655 " <EnumerationDomain name=\"enum\">\n"
43656 " <Entry text=\"Normalized\"\n"
43657 " value=\"0\" />\n"
43658 " <Entry text=\"Relative\"\n"
43659 " value=\"1\" />\n"
43660 " </EnumerationDomain>\n"
43661 " </IntVectorProperty>\n"
43662 " <DoubleVectorProperty command=\"SetStartTime\"\n"
43663 " default_values=\"0\"\n"
43664 " name=\"StartTime\"\n"
43665 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
43666 " <DoubleVectorProperty command=\"SetEndTime\"\n"
43667 " default_values=\"1\"\n"
43668 " name=\"EndTime\"\n"
43669 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
43670 " <IntVectorProperty command=\"SetAnimatedElement\"\n"
43671 " default_values=\"0\"\n"
43672 " name=\"AnimatedElement\"\n"
43673 " number_of_elements=\"1\"></IntVectorProperty>\n"
43674 " <IntVectorProperty command=\"SetEnabled\"\n"
43675 " default_values=\"1\"\n"
43676 " name=\"Enabled\"\n"
43677 " number_of_elements=\"1\">\n"
43678 " <BooleanDomain name=\"bool\" />\n"
43679 " <Documentation>Enables this animation cue.</Documentation>\n"
43680 " </IntVectorProperty>\n"
43681 " <!-- End of AnimationCueBase -->\n"
43682 " </Proxy>\n"
43683 " <ComparativeAnimationCueProxy class=\"vtkPVComparativeAnimationCue\"\n"
43684 " name=\"ComparativeAnimationCue\"\n"
43685 " processes=\"client\">\n"
43686 " <Documentation>Animation cue used by comparative views.</Documentation>\n"
43687 " <IntVectorProperty command=\"SetAnimatedElement\"\n"
43688 " default_values=\"0\"\n"
43689 " name=\"AnimatedElement\"\n"
43690 " number_of_elements=\"1\"></IntVectorProperty>\n"
43691 " <IntVectorProperty command=\"SetEnabled\"\n"
43692 " default_values=\"1\"\n"
43693 " name=\"Enabled\"\n"
43694 " number_of_elements=\"1\">\n"
43695 " <BooleanDomain name=\"bool\" />\n"
43696 " <Documentation>Enables this animation cue.</Documentation>\n"
43697 " </IntVectorProperty>\n"
43698 " <ProxyProperty argument_type=\"SMProxy\"\n"
43699 " clean_command=\"RemoveAnimatedProxy\"\n"
43700 " command=\"SetAnimatedProxy\"\n"
43701 " name=\"AnimatedProxy\">\n"
43702 " <ProxyGroupDomain name=\"groups\">\n"
43703 " <Group name=\"sources\" />\n"
43704 " <Group name=\"filters\" />\n"
43705 " </ProxyGroupDomain>\n"
43706 " </ProxyProperty>\n"
43707 " <StringVectorProperty command=\"SetAnimatedPropertyName\"\n"
43708 " name=\"AnimatedPropertyName\"\n"
43709 " number_of_elements=\"1\"></StringVectorProperty>\n"
43710 " <StringVectorProperty command=\"SetAnimatedDomainName\"\n"
43711 " name=\"AnimatedDomainName\"\n"
43712 " number_of_elements=\"1\"></StringVectorProperty>\n"
43713 " <!-- end of ComparativeAnimationCue -->\n"
43714 " </ComparativeAnimationCueProxy>\n"
43715 " <Proxy base_proxygroup=\"animation\"\n"
43716 " base_proxyname=\"AnimationCueBase\"\n"
43717 " class=\"vtkPVKeyFrameAnimationCueForProxies\"\n"
43718 " name=\"KeyFrameAnimationCue\"\n"
43719 " processes=\"client\">\n"
43720 " <Documentation>Animation cue with keyframes.</Documentation>\n"
43721 " <ProxyProperty argument_type=\"SMProxy\"\n"
43722 " clean_command=\"RemoveAnimatedProxy\"\n"
43723 " command=\"SetAnimatedProxy\"\n"
43724 " name=\"AnimatedProxy\">\n"
43725 " <ProxyGroupDomain name=\"groups\">\n"
43726 " <Group name=\"sources\" />\n"
43727 " <Group name=\"filters\" />\n"
43728 " </ProxyGroupDomain>\n"
43729 " </ProxyProperty>\n"
43730 " <StringVectorProperty command=\"SetAnimatedPropertyName\"\n"
43731 " name=\"AnimatedPropertyName\"\n"
43732 " number_of_elements=\"1\"></StringVectorProperty>\n"
43733 " <StringVectorProperty command=\"SetAnimatedDomainName\"\n"
43734 " name=\"AnimatedDomainName\"\n"
43735 " number_of_elements=\"1\"></StringVectorProperty>\n"
43736 " <ProxyProperty command=\"AddKeyFrame\"\n"
43737 " name=\"KeyFrames\"\n"
43738 " remove_command=\"RemoveKeyFrame\"\n"
43739 " repeat_command=\"1\">\n"
43740 " <ProxyGroupDomain name=\"groups\">\n"
43741 " <Group name=\"animation_keyframes\" />\n"
43742 " </ProxyGroupDomain>\n"
43743 " </ProxyProperty>\n"
43744 " <IntVectorProperty command=\"GetLastAddedKeyFrameIndex\"\n"
43745 " information_only=\"1\"\n"
43746 " name=\"LastAddedKeyFrameIndex\"></IntVectorProperty>\n"
43747 " <!-- End of KeyFrameAnimationCue -->\n"
43748 " </Proxy>\n"
43749 " <Proxy base_proxygroup=\"animation\"\n"
43750 " base_proxyname=\"AnimationCueBase\"\n"
43751 " class=\"vtkPVCameraAnimationCue\"\n"
43752 " name=\"CameraAnimationCue\"\n"
43753 " processes=\"client\">\n"
43754 " <Documentation>Animation cue which can be used for animating Camera using\n"
43755 " keyframes.</Documentation>\n"
43756 " <ProxyProperty command=\"SetView\"\n"
43757 " name=\"AnimatedProxy\"></ProxyProperty>\n"
43758 " <IntVectorProperty command=\"SetMode\"\n"
43759 " default_values=\"0\"\n"
43760 " name=\"Mode\"\n"
43761 " number_of_elements=\"1\">\n"
43762 " <EnumerationDomain name=\"enum\">\n"
43763 " <Entry text=\"Interpolate Camera\" value=\"0\" />\n"
43764 " <Entry text=\"Path-based\" value=\"1\" />\n"
43765 " <Entry text=\"Follow-data\" value=\"2\" />\n"
43766 " </EnumerationDomain>\n"
43767 " </IntVectorProperty>\n"
43768 " <IntVectorProperty command=\"SetInterpolationMode\"\n"
43769 " default_values=\"1\"\n"
43770 " name=\"Interpolation\"\n"
43771 " number_of_elements=\"1\">\n"
43772 " <EnumerationDomain name=\"enum\">\n"
43773 " <Entry text=\"Linear\" value=\"0\" />\n"
43774 " <Entry text=\"Spline\" value=\"1\" />\n"
43775 " </EnumerationDomain>\n"
43776 " </IntVectorProperty>\n"
43777 " <ProxyProperty command=\"AddKeyFrame\"\n"
43778 " name=\"KeyFrames\"\n"
43779 " remove_command=\"RemoveKeyFrame\"\n"
43780 " repeat_command=\"1\">\n"
43781 " <ProxyGroupDomain name=\"groups\">\n"
43782 " <Group name=\"animation_keyframes\" />\n"
43783 " </ProxyGroupDomain>\n"
43784 " </ProxyProperty>\n"
43785 " <IntVectorProperty command=\"GetLastAddedKeyFrameIndex\"\n"
43786 " information_only=\"1\"\n"
43787 " name=\"LastAddedKeyFrameIndex\">\n"
43788 " </IntVectorProperty>\n"
43789 " <ProxyProperty name=\"DataSource\"\n"
43790 " argument_type=\"SMProxy\"\n"
43791 " command=\"SetDataSourceProxy\">\n"
43792 " </ProxyProperty>\n"
43793 " <!-- End of CameraAnimationCue -->\n"
43794 " </Proxy>\n"
43795 " <Proxy base_proxygroup=\"animation\"\n"
43796 " base_proxyname=\"KeyFrameAnimationCue\"\n"
43797 " class=\"vtkPVKeyFrameAnimationCueForProxies\"\n"
43798 " name=\"TimeAnimationCue\"\n"
43799 " processes=\"client\">\n"
43800 " <Documentation>This is same as KeyFrameAnimationCue except that it has a\n"
43801 " new property \"UseAnimationTime\" which when set overrides the keyframes\n"
43802 " all together and directly uses the animation clock time to update the\n"
43803 " animated property.</Documentation>\n"
43804 " <IntVectorProperty command=\"SetUseAnimationTime\"\n"
43805 " default_values=\"1\"\n"
43806 " name=\"UseAnimationTime\"\n"
43807 " number_of_elements=\"1\">\n"
43808 " <BooleanDomain name=\"bool\" />\n"
43809 " <Documentation>When enabled, the animated property is directly updated\n"
43810 " with the value of the Animation clock. Default value is\n"
43811 " true.</Documentation>\n"
43812 " </IntVectorProperty>\n"
43813 " <!-- end of TimeAnimationCue -->\n"
43814 " </Proxy>\n"
43815 " <!--Scene -->\n"
43816 " <AnimationSceneProxy class=\"vtkSMAnimationScene\"\n"
43817 " name=\"AnimationScene\"\n"
43818 " processes=\"client\">\n"
43819 " <Documentation>Proxy for animation scene.</Documentation>\n"
43820 " <ProxyProperty argument_type=\"SMProxy\"\n"
43821 " clean_command=\"RemoveAllViewProxies\"\n"
43822 " command=\"AddViewProxy\"\n"
43823 " name=\"ViewModules\"\n"
43824 " repeat_command=\"1\">\n"
43825 " <ProxyGroupDomain name=\"groups\">\n"
43826 " <Group name=\"views\" />\n"
43827 " </ProxyGroupDomain>\n"
43828 " <Documentation>Add views to this scene. These are all the views that\n"
43829 " need to be updated when playing the animation.</Documentation>\n"
43830 " </ProxyProperty>\n"
43831 " <ProxyProperty command=\"AddCue\"\n"
43832 " name=\"Cues\"\n"
43833 " remove_command=\"RemoveCue\"\n"
43834 " repeat_command=\"1\">\n"
43835 " <ProxyGroupDomain name=\"groups\">\n"
43836 " <Group name=\"animation\" />\n"
43837 " </ProxyGroupDomain>\n"
43838 " <Documentation>Add cues to this scene.</Documentation>\n"
43839 " </ProxyProperty>\n"
43840 " <DoubleVectorProperty command=\"SetSceneTime\"\n"
43841 " default_values=\"none\"\n"
43842 " name=\"AnimationTime\"\n"
43843 " number_of_elements=\"1\" >\n"
43844 " <Documentation>Set the current animation time.</Documentation>\n"
43845 " </DoubleVectorProperty>\n"
43846 " <DoubleVectorProperty command=\"SetStartTime\"\n"
43847 " default_values=\"0.0\"\n"
43848 " label=\"Start Time\"\n"
43849 " name=\"StartTime\"\n"
43850 " number_of_elements=\"1\" >\n"
43851 " <Documentation>Set the start time for the animation\n"
43852 " scene.</Documentation>\n"
43853 " </DoubleVectorProperty>\n"
43854 " <DoubleVectorProperty command=\"SetEndTime\"\n"
43855 " default_values=\"1.0\"\n"
43856 " label=\"End Time\"\n"
43857 " name=\"EndTime\"\n"
43858 " number_of_elements=\"1\" >\n"
43859 " <Documentation>Set the end time for the animation\n"
43860 " scene.</Documentation>\n"
43861 " </DoubleVectorProperty>\n"
43862 " <IntVectorProperty command=\"SetLockStartTime\"\n"
43863 " default_values=\"0\"\n"
43864 " name=\"LockStartTime\"\n"
43865 " number_of_elements=\"1\">\n"
43866 " <BooleanDomain name=\"bool\" />\n"
43867 " <Documentation>When set the StartTime will not be changed when the data\n"
43868 " time steps change.</Documentation>\n"
43869 " </IntVectorProperty>\n"
43870 " <IntVectorProperty command=\"SetLockEndTime\"\n"
43871 " default_values=\"0\"\n"
43872 " name=\"LockEndTime\"\n"
43873 " number_of_elements=\"1\">\n"
43874 " <BooleanDomain name=\"bool\" />\n"
43875 " <Documentation>When set the EndTime will not be changed when the data\n"
43876 " time steps change.</Documentation>\n"
43877 " </IntVectorProperty>\n"
43878 " <IntVectorProperty command=\"SetForceDisableCaching\"\n"
43879 " default_values=\"0\"\n"
43880 " name=\"ForceDisableCaching\"\n"
43881 " number_of_elements=\"1\">\n"
43882 " <BooleanDomain name=\"bool\" />\n"
43883 " <Documentation>Force disabling animation cache.</Documentation>\n"
43884 " </IntVectorProperty>\n"
43885 " <ProxyProperty argument_type=\"SMProxy\"\n"
43886 " command=\"SetTimeKeeper\"\n"
43887 " name=\"TimeKeeper\">\n"
43888 " <Documentation>Set the time keeper. Time keeper is used to obtain the\n"
43889 " information about timesteps. This is required to play animation in\n"
43890 " \"Snap To Timesteps\" mode.</Documentation>\n"
43891 " </ProxyProperty>\n"
43892 " <IntVectorProperty command=\"SetLoop\"\n"
43893 " default_values=\"0\"\n"
43894 " name=\"Loop\"\n"
43895 " number_of_elements=\"1\">\n"
43896 " <BooleanDomain name=\"bool\" />\n"
43897 " <Documentation>Set to true to play the animation in a\n"
43898 " loop.</Documentation>\n"
43899 " </IntVectorProperty>\n"
43900 " <Property command=\"Play\"\n"
43901 " name=\"Play\" />\n"
43902 " <Property command=\"Reverse\"\n"
43903 " name=\"Reverse\" />\n"
43904 " <Property command=\"Stop\"\n"
43905 " name=\"Stop\" />\n"
43906 " <Property command=\"GoToNext\"\n"
43907 " name=\"GoToNext\" />\n"
43908 " <Property command=\"GoToPrevious\"\n"
43909 " name=\"GoToPrevious\" />\n"
43910 " <Property command=\"GoToFirst\"\n"
43911 " name=\"GoToFirst\" />\n"
43912 " <Property command=\"GoToLast\"\n"
43913 " name=\"GoToLast\" />\n"
43914 " <IntVectorProperty command=\"SetPlayMode\"\n"
43915 " default_values=\"0\"\n"
43916 " name=\"PlayMode\"\n"
43917 " number_of_elements=\"1\">\n"
43918 " <EnumerationDomain name=\"enum\">\n"
43919 " <Entry text=\"Sequence\"\n"
43920 " value=\"0\" />\n"
43921 " <Entry text=\"Snap To TimeSteps\"\n"
43922 " value=\"2\" />\n"
43923 " </EnumerationDomain>\n"
43924 " </IntVectorProperty>\n"
43925 " <IntVectorProperty command=\"SetNumberOfFrames\"\n"
43926 " default_values=\"10\"\n"
43927 " name=\"NumberOfFrames\"\n"
43928 " number_of_elements=\"1\">\n"
43929 " <IntRangeDomain min=\"1\"\n"
43930 " name=\"range\" />\n"
43931 " <Documentation>Set the number of frames in which to play the\n"
43932 " animation.</Documentation>\n"
43933 " </IntVectorProperty>\n"
43934 " <IntVectorProperty command=\"SetFramesPerTimestep\"\n"
43935 " default_values=\"1\"\n"
43936 " name=\"FramesPerTimestep\"\n"
43937 " number_of_elements=\"1\">\n"
43938 " <IntRangeDomain min=\"1\"\n"
43939 " name=\"range\" />\n"
43940 " <Documentation>The number of frames per timestep.</Documentation>\n"
43941 " </IntVectorProperty>\n"
43942 " <IntVectorProperty command=\"SetStride\"\n"
43943 " default_values=\"1\"\n"
43944 " name=\"Stride\"\n"
43945 " number_of_elements=\"1\">\n"
43946 " <IntRangeDomain min=\"1\"\n"
43947 " name=\"range\" />\n"
43948 " <Documentation>Set the frame stride when playing the animation\n"
43949 " and going to the next/previous step.</Documentation>\n"
43950 " </IntVectorProperty>\n"
43951 " <!-- End of AnimationScene -->\n"
43952 " </AnimationSceneProxy>\n"
43953 " <!-- End of animation -->\n"
43954 " </ProxyGroup>\n"
43955 " <!-- ==================================================================== -->\n"
43956 " <ProxyGroup name=\"animation_keyframes\">\n"
43957 " <!-- .................................................................. -->\n"
43958 " <Proxy class=\"vtkPVKeyFrame\"\n"
43959 " name=\"KeyFrame\"\n"
43960 " processes=\"client\">\n"
43961 " <DoubleVectorProperty command=\"SetKeyTime\"\n"
43962 " default_values=\"0.0\"\n"
43963 ;
43964
43965 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Animation/Resources/animation.xml
43967 " name=\"KeyTime\"\n"
43968 " number_of_elements=\"1\">\n"
43969 " <DoubleRangeDomain max=\"1.0\"\n"
43970 " min=\"0.0\"\n"
43971 " name=\"range\" />\n"
43972 " </DoubleVectorProperty>\n"
43973 " <DoubleVectorProperty clean_command=\"RemoveAllKeyValues\"\n"
43974 " command=\"SetKeyValue\"\n"
43975 " default_values=\"0.0\"\n"
43976 " name=\"KeyValues\"\n"
43977 " number_of_elements=\"1\"\n"
43978 " number_of_elements_per_command=\"1\"\n"
43979 " repeat_command=\"1\"\n"
43980 " use_index=\"1\"></DoubleVectorProperty>\n"
43981 " </Proxy>\n"
43982 " <!-- .................................................................. -->\n"
43983 " <Proxy base_proxygroup=\"animation_keyframes\"\n"
43984 " base_proxyname=\"KeyFrame\"\n"
43985 " class=\"vtkPVCompositeKeyFrame\"\n"
43986 " name=\"CompositeKeyFrame\"\n"
43987 " processes=\"client\">\n"
43988 " <IntVectorProperty command=\"SetType\"\n"
43989 " default_values=\"2\"\n"
43990 " label=\"Interpolation\"\n"
43991 " name=\"Type\"\n"
43992 " number_of_elements=\"1\">\n"
43993 " <EnumerationDomain name=\"enum\">\n"
43994 " <Entry text=\"Boolean\"\n"
43995 " value=\"1\" />\n"
43996 " <Entry text=\"Ramp\"\n"
43997 " value=\"2\" />\n"
43998 " <Entry text=\"Exponential\"\n"
43999 " value=\"3\" />\n"
44000 " <Entry text=\"Sinusoid\"\n"
44001 " value=\"4\" />\n"
44002 " </EnumerationDomain>\n"
44003 " </IntVectorProperty>\n"
44004 " <DoubleVectorProperty command=\"SetBase\"\n"
44005 " default_values=\"2.0\"\n"
44006 " name=\"Base\"\n"
44007 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44008 " <DoubleVectorProperty command=\"SetStartPower\"\n"
44009 " default_values=\"0.0\"\n"
44010 " name=\"StartPower\"\n"
44011 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44012 " <DoubleVectorProperty command=\"SetEndPower\"\n"
44013 " default_values=\"1.0\"\n"
44014 " name=\"EndPower\"\n"
44015 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44016 " <DoubleVectorProperty command=\"SetPhase\"\n"
44017 " default_values=\"0.0\"\n"
44018 " name=\"Phase\"\n"
44019 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44020 " <DoubleVectorProperty command=\"SetFrequency\"\n"
44021 " default_values=\"1.0\"\n"
44022 " name=\"Frequency\"\n"
44023 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44024 " <DoubleVectorProperty command=\"SetOffset\"\n"
44025 " default_values=\"0.0\"\n"
44026 " name=\"Offset\"\n"
44027 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44028 " <!-- End of CompositeKeyFrame -->\n"
44029 " </Proxy>\n"
44030 " <!-- .................................................................. -->\n"
44031 " <Proxy base_proxygroup=\"animation_keyframes\"\n"
44032 " base_proxyname=\"KeyFrame\"\n"
44033 " class=\"vtkPVBooleanKeyFrame\"\n"
44034 " name=\"BooleanKeyFrame\"\n"
44035 " processes=\"client\"></Proxy>\n"
44036 " <!-- .................................................................. -->\n"
44037 " <Proxy base_proxygroup=\"animation_keyframes\"\n"
44038 " base_proxyname=\"KeyFrame\"\n"
44039 " class=\"vtkPVRampKeyFrame\"\n"
44040 " name=\"RampKeyFrame\"\n"
44041 " processes=\"client\"></Proxy>\n"
44042 " <!-- .................................................................. -->\n"
44043 " <Proxy base_proxygroup=\"animation_keyframes\"\n"
44044 " base_proxyname=\"KeyFrame\"\n"
44045 " class=\"vtkPVExponentialKeyFrame\"\n"
44046 " name=\"ExponentialKeyFrame\"\n"
44047 " processes=\"client\">\n"
44048 " <DoubleVectorProperty command=\"SetBase\"\n"
44049 " default_values=\"2.0\"\n"
44050 " name=\"Base\"\n"
44051 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44052 " <DoubleVectorProperty command=\"SetStartPower\"\n"
44053 " default_values=\"0.0\"\n"
44054 " name=\"StartPower\"\n"
44055 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44056 " <DoubleVectorProperty command=\"SetEndPower\"\n"
44057 " default_values=\"1.0\"\n"
44058 " name=\"EndPower\"\n"
44059 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44060 " </Proxy>\n"
44061 " <!-- .................................................................. -->\n"
44062 " <Proxy base_proxygroup=\"animation_keyframes\"\n"
44063 " base_proxyname=\"KeyFrame\"\n"
44064 " class=\"vtkPVSinusoidKeyFrame\"\n"
44065 " name=\"SinusoidKeyFrame\"\n"
44066 " processes=\"client\">\n"
44067 " <DoubleVectorProperty command=\"SetPhase\"\n"
44068 " default_values=\"0.0\"\n"
44069 " name=\"Phase\"\n"
44070 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44071 " <DoubleVectorProperty command=\"SetFrequency\"\n"
44072 " default_values=\"1.0\"\n"
44073 " name=\"Frequency\"\n"
44074 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44075 " <DoubleVectorProperty command=\"SetOffset\"\n"
44076 " default_values=\"0.0\"\n"
44077 " name=\"Offset\"\n"
44078 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44079 " </Proxy>\n"
44080 " <!-- .................................................................. -->\n"
44081 " <Proxy base_proxygroup=\"animation_keyframes\"\n"
44082 " base_proxyname=\"KeyFrame\"\n"
44083 " class=\"vtkPVCameraKeyFrame\"\n"
44084 " name=\"CameraKeyFrame\"\n"
44085 " processes=\"client\">\n"
44086 " <DoubleVectorProperty command=\"SetPosition\"\n"
44087 " default_values=\"0.0 0.0 0.0\"\n"
44088 " name=\"Position\"\n"
44089 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
44090 " <DoubleVectorProperty command=\"SetFocalPoint\"\n"
44091 " default_values=\"0.0 0.0 0.0\"\n"
44092 " name=\"FocalPoint\"\n"
44093 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
44094 " <DoubleVectorProperty command=\"SetViewUp\"\n"
44095 " default_values=\"0.0 1.0 0.0\"\n"
44096 " name=\"ViewUp\"\n"
44097 " number_of_elements=\"3\"></DoubleVectorProperty>\n"
44098 " <DoubleVectorProperty command=\"SetViewAngle\"\n"
44099 " default_values=\"30\"\n"
44100 " name=\"ViewAngle\"\n"
44101 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44102 " <DoubleVectorProperty command=\"SetParallelScale\"\n"
44103 " default_values=\"1.0\"\n"
44104 " name=\"ParallelScale\"\n"
44105 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44106 " <!-- These are properties for the new style camera interpolation\n"
44107 " using path\n"
44108 " -->\n"
44109 " <DoubleVectorProperty clean_command=\"ClearPositionPath\"\n"
44110 " command=\"AddPositionPathPoint\"\n"
44111 " default_values=\"5 0 0 5 5 0 5 0 0\"\n"
44112 " name=\"PositionPathPoints\"\n"
44113 " number_of_elements=\"9\"\n"
44114 " number_of_elements_per_command=\"3\"\n"
44115 " repeat_command=\"1\"></DoubleVectorProperty>\n"
44116 " <DoubleVectorProperty clean_command=\"ClearFocalPath\"\n"
44117 " command=\"AddFocalPathPoint\"\n"
44118 " default_values=\"0 0 0 1 0 0\"\n"
44119 " name=\"FocalPathPoints\"\n"
44120 " number_of_elements=\"6\"\n"
44121 " number_of_elements_per_command=\"3\"\n"
44122 " repeat_command=\"1\"></DoubleVectorProperty>\n"
44123 " <IntVectorProperty command=\"SetPositionMode\"\n"
44124 " default_values=\"0\"\n"
44125 " name=\"PositionMode\"\n"
44126 " number_of_elements=\"1\">\n"
44127 " <EnumerationDomain name=\"enum\">\n"
44128 " <Entry text=\"Path\"\n"
44129 " value=\"0\" />\n"
44130 " <Entry text=\"FixedDirection\"\n"
44131 " value=\"1\" />\n"
44132 " <Entry text=\"LookAhead\"\n"
44133 " value=\"2\" />\n"
44134 " <Entry text=\"Orthogonal\"\n"
44135 " value=\"3\" />\n"
44136 " </EnumerationDomain>\n"
44137 " </IntVectorProperty>\n"
44138 " <IntVectorProperty command=\"SetFocalPointMode\"\n"
44139 " default_values=\"0\"\n"
44140 " name=\"FocalPointMode\"\n"
44141 " number_of_elements=\"1\">\n"
44142 " <EnumerationDomain name=\"enum\">\n"
44143 " <Entry text=\"Path\"\n"
44144 " value=\"0\" />\n"
44145 " <Entry text=\"FixedDirection\"\n"
44146 " value=\"1\" />\n"
44147 " <Entry text=\"LookAhead\"\n"
44148 " value=\"2\" />\n"
44149 " <Entry text=\"Orthogonal\"\n"
44150 " value=\"3\" />\n"
44151 " </EnumerationDomain>\n"
44152 " </IntVectorProperty>\n"
44153 " <IntVectorProperty command=\"SetClosedFocalPath\"\n"
44154 " default_values=\"0\"\n"
44155 " name=\"ClosedFocalPath\"\n"
44156 " number_of_elements=\"1\">\n"
44157 " <BooleanDomain name=\"bool\" />\n"
44158 " </IntVectorProperty>\n"
44159 " <IntVectorProperty command=\"SetClosedPositionPath\"\n"
44160 " default_values=\"0\"\n"
44161 " name=\"ClosedPositionPath\"\n"
44162 " number_of_elements=\"1\">\n"
44163 " <BooleanDomain name=\"bool\" />\n"
44164 " </IntVectorProperty>\n"
44165 " <!-- end of CameraKeyFrame -->\n"
44166 " </Proxy>\n"
44167 " <!-- end of keyframes -->\n"
44168 " </ProxyGroup>\n"
44169 " <!-- ==================================================================== -->\n"
44170 " <ProxyGroup name=\"animation_writers\">\n"
44171 " <Proxy name=\"JPEG\" class=\"vtkJPEGWriter\" process=\"client,dataserver\"\n"
44172 " base_proxygroup=\"screenshot_writers\"\n"
44173 " base_proxyname=\"JPEG\">\n"
44174 " <StringVectorProperty name=\"SuffixFormat\"\n"
44175 " number_of_elements=\"1\"\n"
44176 " default_values=\".%04d\">\n"
44177 " <Documentation>\n"
44178 " Specify the suffix format string to use to add a suffix to the output\n"
44179 " filenames based on the current timestep number.\n"
44180 " </Documentation>\n"
44181 " </StringVectorProperty>\n"
44182 " </Proxy>\n"
44183 " <Proxy name=\"PNG\" class=\"vtkPNGWriter\" process=\"client,dataserver\"\n"
44184 " base_proxygroup=\"screenshot_writers\"\n"
44185 " base_proxyname=\"PNG\">\n"
44186 " <StringVectorProperty name=\"SuffixFormat\"\n"
44187 " number_of_elements=\"1\"\n"
44188 " default_values=\".%04d\">\n"
44189 " <Documentation>\n"
44190 " Specify the suffix format string to use to add a suffix to the output\n"
44191 " filenames based on the current timestep number.\n"
44192 " </Documentation>\n"
44193 " </StringVectorProperty>\n"
44194 " </Proxy>\n"
44195 " <Proxy name=\"TIFF\" class=\"vtkTIFFWriter\" process=\"client,dataserver\"\n"
44196 " base_proxygroup=\"screenshot_writers\"\n"
44197 " base_proxyname=\"TIFF\">\n"
44198 " <StringVectorProperty name=\"SuffixFormat\"\n"
44199 " number_of_elements=\"1\"\n"
44200 " default_values=\".%04d\">\n"
44201 " <Documentation>\n"
44202 " Specify the suffix format string to use to add a suffix to the output\n"
44203 " filenames based on the current timestep number.\n"
44204 " </Documentation>\n"
44205 " </StringVectorProperty>\n"
44206 " </Proxy>\n"
44207 " <Proxy name=\"BMP\" class=\"vtkBMPWriter\" process=\"client,dataserver\"\n"
44208 " base_proxygroup=\"screenshot_writers\"\n"
44209 " base_proxyname=\"BMP\">\n"
44210 " <StringVectorProperty name=\"SuffixFormat\"\n"
44211 " number_of_elements=\"1\"\n"
44212 " default_values=\".%04d\">\n"
44213 " <Documentation>\n"
44214 " Specify the suffix format string to use to add a suffix to the output\n"
44215 " filenames based on the current timestep number.\n"
44216 " </Documentation>\n"
44217 " </StringVectorProperty>\n"
44218 " </Proxy>\n"
44219 " </ProxyGroup>\n"
44220 "\n"
44221 " <!-- ==================================================================== -->\n"
44222 " <ProxyGroup name=\"misc\">\n"
44223 " <!-- .................................................................. -->\n"
44224 " <Proxy class=\"vtkPVRepresentationAnimationHelper\"\n"
44225 " name=\"RepresentationAnimationHelper\"\n"
44226 " processes=\"client\">\n"
44227 " <Documentation>Used to help in animation representation\n"
44228 " properties.</Documentation>\n"
44229 " <ProxyProperty argument_type=\"SMProxy\"\n"
44230 " command=\"SetSourceProxy\"\n"
44231 " name=\"Source\" />\n"
44232 " <IntVectorProperty command=\"SetVisibility\"\n"
44233 " default_values=\"none\"\n"
44234 " is_internal=\"1\"\n"
44235 " name=\"Visibility\"\n"
44236 " number_of_elements=\"1\">\n"
44237 " <BooleanDomain name=\"bool\" />\n"
44238 " </IntVectorProperty>\n"
44239 " <DoubleVectorProperty command=\"SetOpacity\"\n"
44240 " default_values=\"none\"\n"
44241 " is_internal=\"1\"\n"
44242 " name=\"Opacity\"\n"
44243 " number_of_elements=\"1\">\n"
44244 " <DoubleRangeDomain max=\"1.0\"\n"
44245 " min=\"0.0\"\n"
44246 " name=\"range\" />\n"
44247 " </DoubleVectorProperty>\n"
44248 " <!-- End of RepresentationAnimationHelper -->\n"
44249 " </Proxy>\n"
44250 " </ProxyGroup>\n"
44251 "\n"
44252 " <ProxyGroup name=\"misc\">\n"
44253 " <!-- .................................................................. -->\n"
44254 " <SaveAnimationProxy name=\"SaveAnimation\" processes=\"client\"\n"
44255 " label=\"Save Animation\"\n"
44256 " base_proxygroup=\"misc\"\n"
44257 " base_proxyname=\"SaveScreenshotBase\">\n"
44258 "\n"
44259 " <ProxyProperty name=\"Format\">\n"
44260 " <ProxyListDomain name=\"proxy_list\">\n"
44261 " <Group name=\"animation_writers\" />\n"
44262 " </ProxyListDomain>\n"
44263 " <Hints>\n"
44264 " <ProxySelectionWidget enabled=\"0\" />\n"
44265 " </Hints>\n"
44266 " </ProxyProperty>\n"
44267 "\n"
44268 " <ProxyProperty name=\"AnimationScene\" panel_visibility=\"never\" />\n"
44269 "\n"
44270 " <IntVectorProperty name=\"FrameRate\"\n"
44271 " number_of_elements=\"1\"\n"
44272 " default_values=\"1\"\n"
44273 " panel_visibility=\"advanced\">\n"
44274 " <IntRangeDomain name=\"range\" min=\"1\" />\n"
44275 " <Documentation>\n"
44276 " Frame rate in frames-per-second (FPS).\n"
44277 " </Documentation>\n"
44278 " </IntVectorProperty>\n"
44279 "\n"
44280 " <IntVectorProperty name=\"FrameStride\"\n"
44281 " number_of_elements=\"1\"\n"
44282 " default_values=\"1\"\n"
44283 " panel_visibility=\"advanced\">\n"
44284 " <IntRangeDomain name=\"range\" min=\"1\"/>\n"
44285 " <Documentation>\n"
44286 " The stride which is used to extract the next frame.\n"
44287 " E.g. 1, 2, 3, would have frame stride = 1, while 1, 3, 5 would have frame stride = 2.\n"
44288 " </Documentation>\n"
44289 " </IntVectorProperty>\n"
44290 "\n"
44291 " <IntVectorProperty name=\"FrameWindow\"\n"
44292 " number_of_elements=\"2\"\n"
44293 " default_values=\"none\"\n"
44294 ;
44295
44296 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Animation/Resources/animation.xml
44298 " panel_visibility=\"advanced\">\n"
44299 " <AnimationFrameWindowDomain name=\"range\" default_mode=\"min,max\">\n"
44300 " <RequiredProperties>\n"
44301 " <Property name=\"AnimationScene\" function=\"AnimationScene\" />\n"
44302 " <Property name=\"FrameRate\" function=\"FrameRate\" />\n"
44303 " </RequiredProperties>\n"
44304 " </AnimationFrameWindowDomain>\n"
44305 " <Documentation>\n"
44306 " Specify a window to save only a part of the animation.\n"
44307 " </Documentation>\n"
44308 " </IntVectorProperty>\n"
44309 "\n"
44310 " <PropertyGroup label=\"Size and Scaling\">\n"
44311 " <Property name=\"SaveAllViews\" />\n"
44312 " <Property name=\"ImageResolution\" />\n"
44313 " <Property name=\"FontScaling\" />\n"
44314 " </PropertyGroup>\n"
44315 "\n"
44316 " <PropertyGroup label=\"Separator Options\" >\n"
44317 " <Property name=\"SeparatorWidth\" />\n"
44318 " <Property name=\"SeparatorColor\" />\n"
44319 " </PropertyGroup>\n"
44320 "\n"
44321 " <PropertyGroup label=\"Coloring\">\n"
44322 " <Property name=\"OverrideColorPalette\" />\n"
44323 " <Property name=\"StereoMode\" />\n"
44324 " <Property name=\"TransparentBackground\" />\n"
44325 " </PropertyGroup>\n"
44326 "\n"
44327 " <PropertyGroup label=\"File Options\">\n"
44328 " <Property name=\"Format\" />\n"
44329 " </PropertyGroup>\n"
44330 " <!--\n"
44331 " FIXME:\n"
44332 " <PropertyGroup label=\"Compression Options\">\n"
44333 " <Property name=\"ImageQuality\" />\n"
44334 " </PropertyGroup>\n"
44335 " -->\n"
44336 "\n"
44337 " <PropertyGroup label=\"Animation Options\">\n"
44338 " <Property name=\"FrameRate\" />\n"
44339 " <Property name=\"FrameStride\" />\n"
44340 " <Property name=\"FrameWindow\" />\n"
44341 " </PropertyGroup>\n"
44342 "\n"
44343 " </SaveAnimationProxy>\n"
44344 "\n"
44345 " <SaveAnimationExtractsProxy name=\"SaveAnimationExtracts\" processes=\"client\">\n"
44346 "\n"
44347 " <StringVectorProperty name=\"ExtractsOutputDirectory\"\n"
44348 " number_of_elements=\"1\"\n"
44349 " default_values=\"extracts\">\n"
44350 " <Documentation>\n"
44351 " Choose directory under which to save all extracts.\n"
44352 " </Documentation>\n"
44353 " <FileListDomain name=\"directory\" />\n"
44354 " <Hints>\n"
44355 " <UseDirectoryName />\n"
44356 " <AcceptAnyFile />\n"
44357 " </Hints>\n"
44358 " </StringVectorProperty>\n"
44359 "\n"
44360 " <IntVectorProperty name=\"GenerateCinemaSpecification\"\n"
44361 " number_of_elements=\"1\"\n"
44362 " default_values=\"0\">\n"
44363 " <Documentation>\n"
44364 " Generate Cinema specification to summarize generated extracts in a file named\n"
44365 " **data.csv** under the **Extracts Output Directory**.\n"
44366 " </Documentation>\n"
44367 " <BooleanDomain name=\"bool\" />\n"
44368 " </IntVectorProperty>\n"
44369 "\n"
44370 " <ProxyProperty name=\"AnimationScene\" panel_visibility=\"never\"/>\n"
44371 "\n"
44372 " <IntVectorProperty name=\"FrameRate\"\n"
44373 " number_of_elements=\"1\"\n"
44374 " default_values=\"1\"\n"
44375 " panel_visibility=\"never\">\n"
44376 " <IntRangeDomain name=\"range\" min=\"1\"/>\n"
44377 " <Documentation>\n"
44378 " Frame rate in frames-per-second (FPS).\n"
44379 " </Documentation>\n"
44380 " </IntVectorProperty>\n"
44381 "\n"
44382 " <IntVectorProperty name=\"FrameStride\"\n"
44383 " number_of_elements=\"1\"\n"
44384 " default_values=\"1\"\n"
44385 " panel_visibility=\"advanced\">\n"
44386 " <IntRangeDomain name=\"range\" min=\"1\"/>\n"
44387 " <Documentation>\n"
44388 " The stride which is used to extract the next frame.\n"
44389 " E.g. 1, 2, 3, would have frame stride = 1, while 1, 3, 5 would have frame stride = 2.\n"
44390 " </Documentation>\n"
44391 " </IntVectorProperty>\n"
44392 "\n"
44393 " <IntVectorProperty name=\"FrameWindow\"\n"
44394 " number_of_elements=\"2\"\n"
44395 " default_values=\"none\"\n"
44396 " panel_visibility=\"advanced\">\n"
44397 " <AnimationFrameWindowDomain name=\"range\" default_mode=\"min,max\">\n"
44398 " <RequiredProperties>\n"
44399 " <Property name=\"AnimationScene\" function=\"AnimationScene\"/>\n"
44400 " <Property name=\"FrameRate\" function=\"FrameRate\"/>\n"
44401 " </RequiredProperties>\n"
44402 " </AnimationFrameWindowDomain>\n"
44403 " <Documentation>\n"
44404 " Specify a window to save only a part of the animation.\n"
44405 " </Documentation>\n"
44406 " </IntVectorProperty>\n"
44407 "\n"
44408 " <PropertyGroup label=\"Animation Options\">\n"
44409 " <Property name=\"FrameRate\"/>\n"
44410 " <Property name=\"FrameStride\"/>\n"
44411 " <Property name=\"FrameWindow\"/>\n"
44412 " </PropertyGroup>\n"
44413 " </SaveAnimationExtractsProxy>\n"
44414 " </ProxyGroup>\n"
44415 "</ServerManagerConfiguration>\n"
44416 "\n";
44417 // Get single string
44419 {
44420
44421  const size_t len0 = strlen(paraview_server_manageranimationInterface0);
44422  const size_t len1 = strlen(paraview_server_manageranimationInterface1);
44423  const size_t len2 = strlen(paraview_server_manageranimationInterface2);
44424  size_t len = ( 0
44425  + len0
44426  + len1
44427  + len2 );
44428  char* res = new char[ len + 1];
44429  size_t offset = 0;
44430  std::copy(paraview_server_manageranimationInterface0, paraview_server_manageranimationInterface0 + len0, res + offset); offset += len0;
44431  std::copy(paraview_server_manageranimationInterface1, paraview_server_manageranimationInterface1 + len1, res + offset); offset += len1;
44432  std::copy(paraview_server_manageranimationInterface2, paraview_server_manageranimationInterface2 + len2, res + offset); offset += len2;
44433  assert(offset == len);
44434  res[offset] = 0;
44435  return res;
44436 }
44437
44438
44439 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Animation/Resources/writers_animation.xml
44441 "<ServerManagerConfiguration>\n"
44442 " <ProxyGroup name=\"writers\">\n"
44443 " <!-- ================================================================= -->\n"
44444 " <SourceProxy class=\"vtkXMLPVAnimationWriter\"\n"
44445 " name=\"XMLPVAnimationWriter\">\n"
44446 " <Documentation>Internal writer proxy used when saving animation geometry\n"
44447 " to save all parts of the current source to the file with pieces spread\n"
44448 " across the server processes.</Documentation>\n"
44449 " <InputProperty clean_command=\"RemoveAllRepresentations\"\n"
44450 " command=\"AddRepresentation\"\n"
44451 " name=\"Representations\"\n"
44452 " repeat_command=\"1\"\n"
44453 " si_class=\"vtkSIXMLAnimationWriterRepresentationProperty\">\n"
44454 " <Documentation>The input filter/source whose output dataset is to\n"
44455 " written to the file.</Documentation>\n"
44456 " </InputProperty>\n"
44457 " <StringVectorProperty command=\"SetFileName\"\n"
44458 " name=\"FileName\">\n"
44459 " <Documentation>Name of the file to write.</Documentation>\n"
44460 " </StringVectorProperty>\n"
44461 " <Property command=\"Start\"\n"
44462 " name=\"Start\">\n"
44463 " <Documentation>Used to begin writing of the animation</Documentation>\n"
44464 " </Property>\n"
44465 " <DoubleVectorProperty command=\"WriteTime\"\n"
44466 " default_values=\"0.0\"\n"
44467 " is_internal=\"1\"\n"
44468 " name=\"WriteTime\"\n"
44469 " number_of_elements=\"1\">\n"
44470 " <DoubleRangeDomain min=\"0\"\n"
44471 " name=\"range\" />\n"
44472 " <Documentation>Write each time step in the animation</Documentation>\n"
44473 " </DoubleVectorProperty>\n"
44474 " <Property command=\"Finish\"\n"
44475 " name=\"Finish\">\n"
44476 " <Documentation>Finish writing animation</Documentation>\n"
44477 " </Property>\n"
44478 " <IntVectorProperty command=\"GetErrorCode\"\n"
44479 " information_only=\"1\"\n"
44480 " name=\"ErrorCode\"></IntVectorProperty>\n"
44481 " <Hints>\n"
44482 " <Property name=\"Input\"\n"
44483 " show=\"0\" />\n"
44484 " <Property name=\"FileName\"\n"
44485 " show=\"0\" />\n"
44486 " </Hints>\n"
44487 " <!-- End of XMLPVAnimationWriter -->\n"
44488 " </SourceProxy>\n"
44489 " </ProxyGroup>\n"
44490 "</ServerManagerConfiguration>\n"
44491 "\n";
44492 // Get single string
44494 {
44495
44496  const size_t len0 = strlen(paraview_server_managerwriters_animationInterface0);
44497  size_t len = ( 0
44498  + len0 );
44499  char* res = new char[ len + 1];
44500  size_t offset = 0;
44502  assert(offset == len);
44503  res[offset] = 0;
44504  return res;
44505 }
44506
44507
44508 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Animation/Resources/animation_python.xml
44510 "<ServerManagerConfiguration>\n"
44511 " <!-- =================================================================== -->\n"
44512 " <ProxyGroup name=\"animation\">\n"
44513 " <Proxy class=\"vtkPythonAnimationCue\"\n"
44514 " name=\"PythonAnimationCue\"\n"
44515 " processes=\"client\">\n"
44516 " <Documentation>Animation cue that can use python script for\n"
44517 " animation.</Documentation>\n"
44518 " <IntVectorProperty command=\"SetEnabled\"\n"
44519 " default_values=\"1\"\n"
44520 " name=\"Enabled\"\n"
44521 " number_of_elements=\"1\">\n"
44522 " <BooleanDomain name=\"bool\" />\n"
44523 " <Documentation>Enables this animation cue.</Documentation>\n"
44524 " </IntVectorProperty>\n"
44525 " <IntVectorProperty command=\"SetTimeMode\"\n"
44526 " default_values=\"0\"\n"
44527 " name=\"TimeMode\"\n"
44528 " number_of_elements=\"1\">\n"
44529 " <EnumerationDomain name=\"enum\">\n"
44530 " <Entry text=\"Normalized\"\n"
44531 " value=\"0\" />\n"
44532 " <Entry text=\"Relative\"\n"
44533 " value=\"1\" />\n"
44534 " </EnumerationDomain>\n"
44535 " </IntVectorProperty>\n"
44536 " <DoubleVectorProperty command=\"SetStartTime\"\n"
44537 " default_values=\"0\"\n"
44538 " name=\"StartTime\"\n"
44539 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44540 " <DoubleVectorProperty command=\"SetEndTime\"\n"
44541 " default_values=\"1\"\n"
44542 " name=\"EndTime\"\n"
44543 " number_of_elements=\"1\"></DoubleVectorProperty>\n"
44544 " <StringVectorProperty command=\"SetScript\"\n"
44545 " default_values=\"def start_cue(self): pass&#xa;&#xa;def tick(self): pass&#xa;&#xa;def end_cue(self): pass\"\n"
44546 " name=\"Script\"\n"
44547 " number_of_elements=\"1\">\n"
44548 " <Hints>\n"
44549 " <Widget type=\"multi_line\" />\n"
44550 " </Hints>\n"
44551 " <Documentation>This property contains the text for the script to\n"
44552 " execute.</Documentation>\n"
44553 " </StringVectorProperty>\n"
44554 " <!-- end of PythonAnimationCue -->\n"
44555 " </Proxy>\n"
44556 " </ProxyGroup>\n"
44557 "</ServerManagerConfiguration>\n"
44558 "\n";
44559 // Get single string
44561 {
44562
44563  const size_t len0 = strlen(paraview_server_manageranimation_pythonInterface0);
44564  size_t len = ( 0
44565  + len0 );
44566  char* res = new char[ len + 1];
44567  size_t offset = 0;
44569  assert(offset == len);
44570  res[offset] = 0;
44571  return res;
44572 }
44573
44574
44575 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Animation/Resources/animation_oggtheora.xml
44577 "<!-- Proxy definitions for OggTheora writer -->\n"
44578 "<ServerManagerConfiguration>\n"
44579 " <ProxyGroup name=\"animation_writers\">\n"
44580 " <Proxy name=\"OggTheora\" class=\"vtkOggTheoraWriter\" processes=\"client|dataserver\" label=\"Ogg-Theora\">\n"
44581 " <Documentation>\n"
44582 " Writer for saving ogv files.\n"
44583 " </Documentation>\n"
44584 " <StringVectorProperty command=\"SetFileName\"\n"
44585 " name=\"FileName\"\n"
44586 " number_of_elements=\"1\">\n"
44587 " <Documentation>The name of the file to be written.</Documentation>\n"
44588 " </StringVectorProperty>\n"
44589 "\n"
44590 " <IntVectorProperty name=\"Quality\"\n"
44591 " command=\"SetQuality\"\n"
44592 " number_of_elements=\"1\"\n"
44593 " default_values=\"2\">\n"
44594 " <Documentation>\n"
44595 " Specify the compression quality. **0** is worst quality (smallest file size),\n"
44596 " and **2** is best quality (largest file size).\n"
44597 " </Documentation>\n"
44598 " <EnumerationDomain name=\"enum\">\n"
44599 " <Entry text=\"0\" value=\"0\" info=\"worst quality, smaller file\" />\n"
44600 " <Entry text=\"1\" value=\"1\" />\n"
44601 " <Entry text=\"2\" value=\"2\" info=\"best quality, larger file\" />\n"
44602 " </EnumerationDomain>\n"
44603 " <Hints>\n"
44604 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"Compression\" value=\"1\" />\n"
44605 " </Hints>\n"
44606 " </IntVectorProperty>\n"
44607 "\n"
44608 " <IntVectorProperty name=\"FrameRate\"\n"
44609 " command=\"SetRate\"\n"
44610 " number_of_elements=\"1\"\n"
44611 " default_values=\"15\"\n"
44612 " panel_visibility=\"never\">\n"
44613 " <IntRangeDomain name=\"range\" min=\"1\" />\n"
44614 " <Documentation>\n"
44615 " Specify the frame rate in frames-per-second.\n"
44616 " </Documentation>\n"
44617 " <!-- ideally, this property is not hidden and we remove the \"FrameRate\"\n"
44618 " property on \"SaveAnimation\" proxy. However, the way the frame-window stuff is managed currently\n"
44619 " makes this hard. We need to rework frame-windowing logic too.\n"
44620 " -->\n"
44621 " </IntVectorProperty>\n"
44622 "\n"
44623 " <IntVectorProperty name=\"UseSubsampling\"\n"
44624 " command=\"SetSubsampling\"\n"
44625 " number_of_elements=\"1\"\n"
44626 " default_values=\"0\"\n"
44627 " panel_visibility=\"advanced\">\n"
44628 " <BooleanDomain name=\"bool\" />\n"
44629 " <Documentation>\n"
44630 " When checked, the video will be encoded using 4:2:0 subsampling for the color channels.\n"
44631 " </Documentation>\n"
44632 " </IntVectorProperty>\n"
44633 "\n"
44634 " <Property command=\"Start\"\n"
44635 " label=\"Start\"\n"
44636 " name=\"Start\"\n"
44637 " panel_widget=\"command_button\"\n"
44638 " panel_visibility=\"default\">\n"
44639 " <Documentation>Press this to start writing the movie</Documentation>\n"
44640 " </Property>\n"
44641 " <Property command=\"Write\"\n"
44642 " label=\"Write\"\n"
44643 " name=\"Write\"\n"
44644 " panel_widget=\"command_button\"\n"
44645 " panel_visibility=\"default\">\n"
44646 " <Documentation>Press this to write the movie</Documentation>\n"
44647 " </Property>\n"
44648 " <Property command=\"End\"\n"
44649 " label=\"End\"\n"
44650 " name=\"End\"\n"
44651 " panel_widget=\"command_button\"\n"
44652 " panel_visibility=\"default\">\n"
44653 " <Documentation>Press this to end writing the movie</Documentation>\n"
44654 " </Property>\n"
44655 "\n"
44656 " <Hints>\n"
44657 " <FormatOptions extensions=\"ogv\"\n"
44658 " file_description=\"Ogg-Theora video files\" />\n"
44659 " </Hints>\n"
44660 " </Proxy>\n"
44661 " </ProxyGroup>\n"
44662 "</ServerManagerConfiguration>\n"
44663 "\n";
44664 // Get single string
44666 {
44667
44668  const size_t len0 = strlen(paraview_server_manageranimation_oggtheoraInterface0);
44669  size_t len = ( 0
44670  + len0 );
44671  char* res = new char[ len + 1];
44672  size_t offset = 0;
44674  assert(offset == len);
44675  res[offset] = 0;
44676  return res;
44677 }
44678
44679
44680 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Settings/Resources/utilities_settings.xml
44682 "<ServerManagerConfiguration>\n"
44683 " <ProxyGroup name=\"settings\">\n"
44684 " <!-- ================================================================== -->\n"
44685 " <SettingsProxy name=\"GeneralSettings\" label=\"General\"\n"
44686 " processes=\"client|dataserver|renderserver\"\n"
44687 " class=\"vtkPVGeneralSettings\">\n"
44688 " <Documentation>\n"
44689 " Collection of general setting for ParaView.\n"
44690 " </Documentation>\n"
44691 "\n"
44692 " <IntVectorProperty name=\"ShowWelcomeDialog\"\n"
44693 " number_of_elements=\"1\"\n"
44694 " default_values=\"1\"\n"
44695 " panel_visibility=\"advanced\">\n"
44696 " <Documentation>\n"
44697 " Show welcome screen at startup.\n"
44698 " </Documentation>\n"
44699 " <BooleanDomain name=\"bool\" />\n"
44700 " <Hints>\n"
44701 " <SaveInQSettings />\n"
44702 " </Hints>\n"
44703 " </IntVectorProperty>\n"
44704 "\n"
44705 " <IntVectorProperty name=\"ShowSaveStateOnExit\"\n"
44706 " number_of_elements=\"1\"\n"
44707 " default_values=\"0\"\n"
44708 " panel_visibility=\"advanced\">\n"
44709 " <Documentation>\n"
44710 " Prompt to save state when exiting ParaView.\n"
44711 " </Documentation>\n"
44712 " <BooleanDomain name=\"bool\" />\n"
44713 " <Hints>\n"
44714 " <SaveInQSettings />\n"
44715 " </Hints>\n"
44716 " </IntVectorProperty>\n"
44717 "\n"
44718 " <IntVectorProperty name=\"CrashRecovery\"\n"
44719 " number_of_elements=\"1\"\n"
44720 " default_values=\"0\"\n"
44721 " panel_visibility=\"advanced\">\n"
44722 " <Documentation>\n"
44723 " On a crash, attempt to save a state file to potentially restore\n"
44724 " the application state to that before the crash.\n"
44725 " </Documentation>\n"
44726 " <BooleanDomain name=\"bool\" />\n"
44727 " <Hints>\n"
44728 " <SaveInQSettings />\n"
44729 " </Hints>\n"
44730 " </IntVectorProperty>\n"
44731 "\n"
44732 " <IntVectorProperty name=\"ForceSingleColumnMenus\"\n"
44733 " number_of_elements=\"1\"\n"
44734 " default_values=\"0\"\n"
44735 " panel_visibility=\"advanced\">\n"
44736 " <Documentation>\n"
44737 " Force the sources/filters menus to be presented as a single\n"
44738 " scrollable column to ensure that all the filters are selectable\n"
44739 " on low resolution screens.\n"
44740 " </Documentation>\n"
44741 " <BooleanDomain name=\"bool\" />\n"
44742 " <Hints>\n"
44743 " <SaveInQSettings />\n"
44744 " </Hints>\n"
44745 " </IntVectorProperty>\n"
44746 "\n"
44747 " <IntVectorProperty name=\"GUIOverrideFont\"\n"
44748 " label=\"Override Font\"\n"
44749 " command=\"SetGUIOverrideFont\"\n"
44750 " default_values=\"0\"\n"
44751 " number_of_elements=\"1\">\n"
44752 " <BooleanDomain name=\"bool\" />\n"
44753 " <Documentation>\n"
44754 " Override the GUI font size. Uncheck to use system default.\n"
44755 " </Documentation>\n"
44756 " </IntVectorProperty>\n"
44757 "\n"
44758 " <IntVectorProperty name=\"GUIFontSize\"\n"
44759 " label=\"Font Size\"\n"
44760 " command=\"SetGUIFontSize\"\n"
44761 " number_of_elements=\"1\"\n"
44762 " default_values=\"8\">\n"
44763 " <Documentation>\n"
44764 " Specify the font size in points.\n"
44765 " </Documentation>\n"
44766 " <IntRangeDomain name=\"range\" min=\"8\" max=\"32\" />\n"
44767 " <Hints>\n"
44768 " <PropertyWidgetDecorator type=\"ShowWidgetDecorator\">\n"
44769 " <Property name=\"GUIOverrideFont\" />\n"
44770 " </PropertyWidgetDecorator>\n"
44771 " </Hints>\n"
44772 " </IntVectorProperty>\n"
44773 "\n"
44774 " <StringVectorProperty name=\"DefaultViewType\"\n"
44775 " number_of_elements=\"1\"\n"
44776 " default_values=\"RenderView\"\n"
44777 " command=\"SetDefaultViewType\"\n"
44778 " panel_widget=\"viewtype_selector\"\n"
44779 " panel_visibility=\"advanced\">\n"
44780 " <Documentation>\n"
44781 " Set the view to create when ParaView starts up.\n"
44782 " </Documentation>\n"
44783 " </StringVectorProperty>\n"
44784 "\n"
44785 " <StringVectorProperty name=\"InterfaceLanguage\"\n"
44786 " number_of_elements=\"1\"\n"
44787 " default_values=\"en\"\n"
44788 " command=\"SetInterfaceLanguage\"\n"
44789 " panel_widget=\"language_selector\">\n"
44790 " <Documentation>\n"
44791 " Set ParaView language.\n"
44792 " </Documentation>\n"
44793 " <Hints>\n"
44794 " <SaveInQSettings />\n"
44795 " <RestartRequired />\n"
44796 " </Hints>\n"
44797 " </StringVectorProperty>\n"
44798 "\n"
44799 " <IntVectorProperty name=\"ScreenPixelsPerInch\"\n"
44800 " number_of_elements=\"1\"\n"
44801 " default_values=\"72\"\n"
44802 " panel_visibility=\"advanced\">\n"
44803 " <IntRangeDomain name=\"range\" />\n"
44804 " <Documentation>\n"
44805 " Set pixels per inch on the current screen/monitor. This is used for determining\n"
44806 " pixel sizes for fonts and other 2D annotations.\n"
44807 " </Documentation>\n"
44808 " </IntVectorProperty>\n"
44809 "\n"
44810 " <IntVectorProperty name=\"AutoApply\"\n"
44811 " number_of_elements=\"1\"\n"
44812 " default_values=\"0\"\n"
44813 " command=\"SetAutoApply\"\n"
44814 " information_property=\"AutoApplyInfo\">\n"
44815 " <Documentation>\n"
44816 " Automatically apply changes in the 'Properties' panel.\n"
44817 " </Documentation>\n"
44818 " <BooleanDomain name=\"bool\" />\n"
44819 " </IntVectorProperty>\n"
44820 " <IntVectorProperty name=\"AutoApplyInfo\"\n"
44821 " command=\"GetAutoApply\"\n"
44822 " information_only=\"1\">\n"
44823 " <BooleanDomain name=\"bool\" />\n"
44824 " </IntVectorProperty>\n"
44825 "\n"
44826 " <IntVectorProperty name=\"AutoApplyActiveOnly\"\n"
44827 " number_of_elements=\"1\"\n"
44828 " default_values=\"0\"\n"
44829 " command=\"SetAutoApplyActiveOnly\"\n"
44830 " panel_visibility=\"advanced\">\n"
44831 " <Documentation>\n"
44832 " Limit automatic accepting of changes on the 'Properties'\n"
44833 " panel to the active panel alone.\n"
44834 " </Documentation>\n"
44835 " <BooleanDomain name=\"bool\" />\n"
44836 " </IntVectorProperty>\n"
44837 "\n"
44838 " <IntVectorProperty name=\"LoadAllVariables\"\n"
44839 " number_of_elements=\"1\"\n"
44840 " default_values=\"0\"\n"
44841 " command=\"SetLoadAllVariables\">\n"
44842 " <Documentation>\n"
44843 " Load all variables when loading a data set.\n"
44844 " </Documentation>\n"
44845 " <BooleanDomain name=\"bool\" />\n"
44846 " </IntVectorProperty>\n"
44847 "\n"
44848 " <IntVectorProperty name=\"LoadNoChartVariables\"\n"
44849 " number_of_elements=\"1\"\n"
44850 " default_values=\"0\"\n"
44851 " command=\"SetLoadNoChartVariables\">\n"
44852 " <Documentation>\n"
44853 " Do not load any variables when loading a 2D chart.\n"
44854 " </Documentation>\n"
44855 " <BooleanDomain name=\"bool\" />\n"
44856 " </IntVectorProperty>\n"
44857 "\n"
44858 " <IntVectorProperty name=\"PropertiesPanelMode\"\n"
44859 " command=\"SetPropertiesPanelMode\"\n"
44860 " number_of_elements=\"1\"\n"
44861 " default_values=\"0\"\n"
44862 " panel_visibility=\"advanced\">\n"
44863 " <Documentation>\n"
44864 " You can choose to show source, display and view properties in a single\n"
44865 " 'Properties' panel, or place them in separate dock panels.\n"
44866 " </Documentation>\n"
44867 " <EnumerationDomain name=\"enum\">\n"
44868 " <Entry text=\"Combined Properties panel\" value=\"0\" />\n"
44869 " <Entry text=\"Display Properties in a separate panel\" value=\"1\" />\n"
44870 " <Entry text=\"View Properties in a separate panel\" value=\"2\" />\n"
44871 " <Entry text=\"Separate panels for each type of properties\" value=\"3\" />\n"
44872 " </EnumerationDomain>\n"
44873 " <Hints>\n"
44874 " <RestartRequired />\n"
44875 " </Hints>\n"
44876 " </IntVectorProperty>\n"
44877 "\n"
44878 " <IntVectorProperty name=\"LockPanels\"\n"
44879 " command=\"SetLockPanels\"\n"
44880 " number_of_elements=\"1\"\n"
44881 " default_values=\"0\"\n"
44882 " panel_visibility=\"advanced\">\n"
44883 " <Documentation>\n"
44884 " Prevent movement of dockable control panels to other positions.\n"
44885 " </Documentation>\n"
44886 " <BooleanDomain name=\"bool\" />\n"
44887 " <Hints>\n"
44888 " <SaveInQSettings/>\n"
44889 " </Hints>\n"
44890 " </IntVectorProperty>\n"
44891 "\n"
44892 " <IntVectorProperty name=\"AutoConvertProperties\"\n"
44893 " number_of_elements=\"1\"\n"
44894 " default_values=\"0\"\n"
44895 " command=\"SetAutoConvertProperties\">\n"
44896 " <Documentation>\n"
44897 " Automatically convert data arrays as needed by filters including converting\n"
44898 " cell arrays to point arrays, or vice versa, and extracting single components\n"
44899 " from multi-component arrays.\n"
44900 " </Documentation>\n"
44901 " <BooleanDomain name=\"bool\"/>\n"
44902 " </IntVectorProperty>\n"
44903 "\n"
44904 " <IntVectorProperty name=\"BlockColorsDistinctValues\"\n"
44905 " number_of_elements=\"1\"\n"
44906 " default_values=\"12\"\n"
44907 " command=\"SetBlockColorsDistinctValues\"\n"
44908 " panel_visibility=\"advanced\">\n"
44909 " <Documentation>\n"
44910 " Determines the number of distinct values in\n"
44911 " vtkBlockColors. This array is added to each block if\n"
44912 " the dataset is a composite dataset. The array has one value\n"
44913 " set to the reminder of blockIndex divided by\n"
44914 " BlockColorsDistinctValues (blockIndex mod\n"
44915 " BlockColorsDistinctValues).\n"
44916 " </Documentation>\n"
44917 " <IntRangeDomain min=\"2\" name=\"range\" />\n"
44918 " </IntVectorProperty>\n"
44919 "\n"
44920 " <IntVectorProperty name=\"ScalarBarMode\"\n"
44921 " command=\"SetScalarBarMode\"\n"
44922 " number_of_elements=\"1\"\n"
44923 " default_values=\"0\">\n"
44924 " <Documentation>\n"
44925 " Set how ParaView manages showing of color legend bars (or scalar bars) in render views.\n"
44926 " </Documentation>\n"
44927 " <EnumerationDomain name=\"enum\">\n"
44928 " <Entry text=\"Automatically show and/or hide color bars\" value=\"0\" />\n"
44929 " <Entry text=\"Automatically hide unused color bars\" value=\"1\" />\n"
44930 " <Entry text=\"Manual (not recommended)\" value=\"2\" />\n"
44931 " </EnumerationDomain>\n"
44932 " </IntVectorProperty>\n"
44933 "\n"
44934 " <IntVectorProperty name=\"CacheGeometryForAnimation\"\n"
44935 " command=\"SetCacheGeometryForAnimation\"\n"
44936 " number_of_elements=\"1\"\n"
44937 " default_values=\"0\"\n"
44938 " panel_visibility=\"advanced\">\n"
44939 " <BooleanDomain name=\"bool\" />\n"
44940 " <Documentation>\n"
44941 " <!--\n"
44942 " When playing an animation, ParaView can attempt to cache processed geometries\n"
44943 " to attempt to speed up animation play back in a loop by avoiding I/O and data\n"
44944 " processing. Set whether caching should be use, when possible.\n"
44945 " -->\n"
44946 " Enable caching of geometry in an attempt to speed up animation playback in a loop.\n"
44947 " </Documentation>\n"
44948 " </IntVectorProperty>\n"
44949 "\n"
44950 " <!--\n"
44951 " Disabling for now. We need a more complex implementation if we need to truly support\n"
44952 " cache limits correctly. For now, we'll disable cache-limits.\n"
44953 " <IntVectorProperty name=\"AnimationGeometryCacheLimit\"\n"
44954 " command=\"SetAnimationGeometryCacheLimit\"\n"
44955 " number_of_elements=\"1\"\n"
44956 " default_values=\"102400\"\n"
44957 " panel_visibility=\"advanced\">\n"
44958 " <IntRangeDomain name=\"range\" min=\"0\" />\n"
44959 " <Documentation>\n"
44960 " When caching of geometry for animations is enabled, limit the maximum cache size\n"
44961 " for the geometry on any rank. Caching will automatically be disabled if the cache\n"
44962 " exceed this limit on any rank, specified in kilobytes (KB).\n"
44963 " </Documentation>\n"
44964 " <Hints>\n"
44965 " <PropertyWidgetDecorator type=\"EnableWidgetDecorator\">\n"
44966 " <Property name=\"CacheGeometryForAnimation\" />\n"
44967 " </PropertyWidgetDecorator>\n"
44968 " </Hints>\n"
44969 " </IntVectorProperty>\n"
44970 " -->\n"
44971 "\n"
44972 " <IntVectorProperty name=\"AnimationTimeNotation\"\n"
44973 " number_of_elements=\"1\"\n"
44974 " default_values=\"0\"\n"
44975 " command=\"SetAnimationTimeNotation\"\n"
44976 " panel_visibility=\"advanced\">\n"
44977 " <Documentation>\n"
44978 " Set the display notation for the time in the animation toolbar. 'Mixed' will automatically\n"
44979 " choose the shortest display.\n"
44980 " </Documentation>\n"
44981 " <EnumerationDomain name=\"enum\">\n"
44982 " <Entry text=\"Mixed\" value=\"0\" />\n"
44983 " <Entry text=\"Scientific\" value=\"1\" />\n"
44984 " <Entry text=\"Fixed\" value=\"2\" />\n"
44985 " <Entry text=\"Full\" value=\"3\" />\n"
44986 " </EnumerationDomain>\n"
44987 " </IntVectorProperty>\n"
44988 "\n"
44989 " <IntVectorProperty name=\"AnimationTimeShortestAccuratePrecision\"\n"
44990 " number_of_elements=\"1\"\n"
44991 " default_values=\"0\"\n"
44992 " command=\"SetAnimationTimeShortestAccuratePrecision\"\n"
44993 " panel_visibility=\"advanced\">\n"
44994 " <BooleanDomain name=\"bool\" />\n"
44995 " <Documentation>\n"
44996 " Set to use shortest accurate precision instead of actual precision to display animation time.\n"
44997 " </Documentation>\n"
44998 " <Hints>\n"
44999 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
45000 " mode=\"enabled_state\"\n"
45001 " property=\"AnimationTimeNotation\"\n"
45002 " value=\"3\"\n"
45003 " inverse=\"1\" />\n"
45004 " </Hints>\n"
45005 " </IntVectorProperty>\n"
45006 "\n"
45007 " <IntVectorProperty name=\"AnimationTimePrecision\"\n"
45008 " number_of_elements=\"1\"\n"
45009 " default_values=\"6\"\n"
45010 " command=\"SetAnimationTimePrecision\"\n"
45011 " panel_visibility=\"advanced\">\n"
45012 " <Documentation>\n"
45013 " Set the number of significant digits displayed for the time in the animation\n"
45014 " toolbar. Should be in the range [1,17].\n"
45015 " </Documentation>\n"
45016 " <IntRangeDomain name=\"range\" min=\"1\" max=\"17\" />\n"
45017 " <Hints>\n"
45018 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
45019 " <Expression type=\"and\">\n"
45020 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"AnimationTimeShortestAccuratePrecision\" value=\"0\" />\n"
45021 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"AnimationTimeNotation\" value=\"3\" inverse=\"1\" />\n"
45022 " </Expression>\n"
45023 " </PropertyWidgetDecorator>\n"
45024 " </Hints>\n"
45025 " </IntVectorProperty>\n"
45026 "\n"
45027 " <IntVectorProperty name=\"ShowAnimationShortcuts\"\n"
45028 " number_of_elements=\"1\"\n"
45029 " default_values=\"0\"\n"
45030 " command=\"SetShowAnimationShortcuts\"\n"
45031 " panel_visibility=\"advanced\">\n"
45032 " <Documentation>\n"
45033 " Set whether to show or not an animation shortcut button\n"
45034 " on ranged scalar property.\n"
45035 " </Documentation>\n"
45036 " <BooleanDomain name=\"bool\" />\n"
45037 " </IntVectorProperty>\n"
45038 "\n"
45039 " <IntVectorProperty name=\"ResetDisplayEmptyViews\"\n"
45040 " number_of_elements=\"1\"\n"
45041 " default_values=\"1\"\n"
45042 " command=\"SetResetDisplayEmptyViews\"\n"
45043 " panel_visibility=\"advanced\">\n"
45044 " <Documentation>\n"
45045 " When showing a representation in an empty view, set whether or not to reset\n"
45046 " the view display.\n"
45047 " </Documentation>\n"
45048 " <BooleanDomain name=\"bool\" />\n"
45049 " </IntVectorProperty>\n"
45050 "\n"
45051 " <IntVectorProperty name=\"RealNumberDisplayedNotation\"\n"
45052 " number_of_elements=\"1\"\n"
45053 " default_values=\"0\"\n"
45054 " command=\"SetRealNumberDisplayedNotation\"\n"
45055 " panel_visibility=\"advanced\">\n"
45056 " <Documentation>\n"
45057 " Set the notation used to display real numbers.\n"
45058 " </Documentation>\n"
45059 " <EnumerationDomain name=\"enum\">\n"
45060 " <Entry text=\"Mixed\" value=\"0\" />\n"
45061 " <Entry text=\"Scientific\" value=\"1\" />\n"
45062 " <Entry text=\"Fixed\" value=\"2\" />\n"
45063 ;
45064
45065 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Settings/Resources/utilities_settings.xml
45067 " <Entry text=\"Full\" value=\"3\" />\n"
45068 " </EnumerationDomain>\n"
45069 " </IntVectorProperty>\n"
45070 "\n"
45071 " <IntVectorProperty name=\"RealNumberDisplayedShortestAccuratePrecision\"\n"
45072 " number_of_elements=\"1\"\n"
45073 " default_values=\"0\"\n"
45074 " command=\"SetRealNumberDisplayedShortestAccuratePrecision\"\n"
45075 " panel_visibility=\"advanced\">\n"
45076 " <BooleanDomain name=\"bool\" />\n"
45077 " <Documentation>\n"
45078 " Set to use shortest accurate precision instead of actual precision to display real numbers.\n"
45079 " </Documentation>\n"
45080 " <Hints>\n"
45081 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
45082 " mode=\"enabled_state\"\n"
45083 " property=\"RealNumberDisplayedNotation\"\n"
45084 " value=\"3\"\n"
45085 " inverse=\"1\" />\n"
45086 " </Hints>\n"
45087 " </IntVectorProperty>\n"
45088 "\n"
45089 " <IntVectorProperty name=\"RealNumberDisplayedPrecision\"\n"
45090 " number_of_elements=\"1\"\n"
45091 " default_values=\"6\"\n"
45092 " command=\"SetRealNumberDisplayedPrecision\"\n"
45093 " panel_visibility=\"advanced\">\n"
45094 " <Documentation>\n"
45095 " Set the number of significant digits to display in real numbers.\n"
45096 " This does NOT affect the values used in computation.\n"
45097 " </Documentation>\n"
45098 " <IntRangeDomain name=\"range\" min=\"1\" max=\"17\" />\n"
45099 " <Hints>\n"
45100 " <PropertyWidgetDecorator type=\"CompositeDecorator\">\n"
45101 " <Expression type=\"and\">\n"
45102 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"RealNumberDisplayedShortestAccuratePrecision\" value=\"0\" />\n"
45103 " <PropertyWidgetDecorator type=\"GenericDecorator\" mode=\"enabled_state\" property=\"RealNumberDisplayedNotation\" value=\"3\" inverse=\"1\" />\n"
45104 " </Expression>\n"
45105 " </PropertyWidgetDecorator>\n"
45106 " </Hints>\n"
45107 " </IntVectorProperty>\n"
45108 "\n"
45109 " <IntVectorProperty name=\"FullNotationLowExponent\"\n"
45110 " number_of_elements=\"1\"\n"
45111 " default_values=\"-6\"\n"
45112 " command=\"SetFullNotationLowExponent\"\n"
45113 " panel_visibility=\"advanced\">\n"
45114 " <IntRangeDomain name=\"range\" min=\"-30\" max=\"0\" />\n"
45115 " <Documentation>\n"
45116 " When showing an accurate, full precision, real number, scientific or fixed notation can be used. This setting is the lowest exponent value\n"
45117 " that will be represented with a fixed notation instead of a scientific notation.\n"
45118 " </Documentation>\n"
45119 " </IntVectorProperty>\n"
45120 "\n"
45121 " <IntVectorProperty name=\"FullNotationHighExponent\"\n"
45122 " number_of_elements=\"1\"\n"
45123 " default_values=\"20\"\n"
45124 " command=\"SetFullNotationHighExponent\"\n"
45125 " panel_visibility=\"advanced\">\n"
45126 " <IntRangeDomain name=\"range\" min=\"0\" max=\"30\" />\n"
45127 " <Documentation>\n"
45128 " When showing an accurate, full precision, real number, scientific or fixed notation can be used. This setting is the highest exponent value\n"
45129 " that will be represented with a fixed notation instead of a scientific notation.\n"
45130 " </Documentation>\n"
45131 " </IntVectorProperty>\n"
45132 "\n"
45133 " <IntVectorProperty name=\"InheritRepresentationProperties\"\n"
45134 " command=\"SetInheritRepresentationProperties\"\n"
45135 " number_of_elements=\"1\"\n"
45136 " default_values=\"0\"\n"
45137 " panel_visibility=\"advanced\">\n"
45138 " <BooleanDomain name=\"bool\" />\n"
45139 " <Documentation>\n"
45140 " Set whether representations try to maintain properties from an input\n"
45141 " representation, if present. e.g. if you \"Transform\" the representation for\n"
45142 " a source, then any filter that you connect to it and show in the same view\n"
45143 " should be transformed using the same transformation as well.\n"
45144 " </Documentation>\n"
45145 " </IntVectorProperty>\n"
45146 "\n"
45147 " <IntVectorProperty name=\"NumberOfCallbackThreads\"\n"
45148 " command=\"SetNumberOfCallbackThreads\"\n"
45149 " number_of_elements=\"1\"\n"
45150 " default_values=\"1\"\n"
45151 " panel_visibility=\"advanced\">\n"
45152 " <Documentation>\n"
45153 " Set the number of threads that are spawned to run certain jobs asynchronously\n"
45154 " on the root data server rank, or in the client in built-in mode.\n"
45155 " Saving screenshot is typically delegated to those threads.\n"
45156 " </Documentation>\n"
45157 " <IntRangeDomain min=\"1\" />\n"
45158 " </IntVectorProperty>\n"
45159 "\n"
45160 " <IntVectorProperty name=\"NumberOfSMPThreads\"\n"
45161 " command=\"SetNumberOfSMPThreads\"\n"
45162 " number_of_elements=\"1\"\n"
45163 " default_values=\"-1\"\n"
45164 " panel_visibility=\"advanced\">\n"
45165 " <Documentation>\n"
45166 " Set the number of threads that are used in various filters using vtkSMPTools.\n"
45167 " If the value is negative, the default number of threads usually used by vtkSMPTools will be used.\n"
45168 " </Documentation>\n"
45169 " </IntVectorProperty>\n"
45170 "\n"
45171 " <IntVectorProperty name=\"DefaultTimeStep\"\n"
45172 " number_of_elements=\"1\"\n"
45173 " default_values=\"1\">\n"
45174 " <Documentation>\n"
45175 " Any time a new dataset with timesteps is opened,\n"
45176 " set the timestep the application should go to\n"
45177 " by default.\n"
45178 " </Documentation>\n"
45179 " <EnumerationDomain name=\"enum\">\n"
45180 " <Entry text=\"Leave current time unchanged, if possible\" value=\"0\" />\n"
45181 " <Entry text=\"Go to first timestep\" value=\"1\" />\n"
45182 " <Entry text=\"Go to last timestep\" value=\"2\" />\n"
45183 " </EnumerationDomain>\n"
45184 " </IntVectorProperty>\n"
45185 "\n"
45186 " <IntVectorProperty name=\"MaximumNumberOfDataRepresentationLabels\"\n"
45187 " number_of_elements=\"1\"\n"
45188 " default_values=\"100\"\n"
45189 " panel_visibility=\"advanced\">\n"
45190 " <IntRangeDomain min=\"1\"\n"
45191 " name=\"range\" />\n"
45192 " <Documentation>\n"
45193 " Set how many points should be labeled when labeling points with data. If there\n"
45194 " are more point than this then only a subset will be labeled. This helps when many\n"
45195 " points are selected and the number of labels would make then unreadable.\n"
45196 " </Documentation>\n"
45197 " </IntVectorProperty>\n"
45198 "\n"
45199 " <IntVectorProperty name=\"ColorByBlockColorsOnApply\"\n"
45200 " command=\"SetColorByBlockColorsOnApply\"\n"
45201 " number_of_elements=\"1\"\n"
45202 " default_values=\"1\"\n"
45203 " panel_visibility=\"never\">\n"
45204 " <BooleanDomain name=\"bool\" />\n"
45205 " <Documentation>\n"
45206 " Internal setting: automatically color by **vtkBlockColors** if array is present.\n"
45207 " </Documentation>\n"
45208 " </IntVectorProperty>\n"
45209 " <IntVectorProperty name=\"IgnoreNegativeLogAxisWarning\"\n"
45210 " command=\"SetIgnoreNegativeLogAxisWarning\"\n"
45211 " number_of_elements=\"1\"\n"
45212 " default_values=\"0\"\n"
45213 " panel_visibility=\"advanced\">\n"
45214 " <BooleanDomain name=\"bool\" />\n"
45215 " <Documentation>\n"
45216 " When plotting data with nonpositive values using logarithmic axes, ignore the\n"
45217 " standard warning and draw only the data with positive values. Changes will take\n"
45218 " effect for all charts created after this option is changed.\n"
45219 " </Documentation>\n"
45220 " </IntVectorProperty>\n"
45221 "\n"
45222 " <IntVectorProperty name=\"EnableStreaming\"\n"
45223 " command=\"SetEnableStreaming\"\n"
45224 " number_of_elements=\"1\"\n"
45225 " default_values=\"0\"\n"
45226 " panel_visibility=\"default\">\n"
45227 " <BooleanDomain name=\"bool\" />\n"
45228 " <Documentation>\n"
45229 " Enable streamed multipass rendering (Experimental).\n"
45230 " </Documentation>\n"
45231 " <Hints>\n"
45232 " <RestartRequired />\n"
45233 " </Hints>\n"
45234 " </IntVectorProperty>\n"
45235 "\n"
45236 " <IntVectorProperty name=\"UseAcceleratedFilters\"\n"
45237 " command=\"SetUseAcceleratedFilters\"\n"
45238 " number_of_elements=\"1\"\n"
45239 " default_values=\"1\"\n"
45240 " panel_visibility=\"default\">\n"
45241 " <BooleanDomain name=\"bool\" />\n"
45242 " <Documentation>\n"
45243 " Use VTK-m accelerated filters where available.\n"
45244 " </Documentation>\n"
45245 " </IntVectorProperty>\n"
45246 "\n"
45247 " <IntVectorProperty name=\"SelectOnClickInMultiBlockInspector\"\n"
45248 " command=\"SetSelectOnClickMultiBlockInspector\"\n"
45249 " number_of_elements=\"1\"\n"
45250 " default_values=\"1\"\n"
45251 " panel_visibility=\"advanced\">\n"
45252 " <BooleanDomain name=\"bool\" />\n"
45253 " <Documentation>\n"
45254 " Create block selections when clicking on blocks in the MultiBlock Inspector (and other data assembly representation widgets).\n"
45255 " </Documentation>\n"
45256 " <Hints>\n"
45257 " <RestartRequired />\n"
45258 " </Hints>\n"
45259 " </IntVectorProperty>\n"
45260 "\n"
45261 " <PropertyGroup label=\"General Options\">\n"
45262 " <Property name=\"ShowWelcomeDialog\" />\n"
45263 " <Property name=\"ShowSaveStateOnExit\" />\n"
45264 " <Property name=\"CrashRecovery\" />\n"
45265 " <Property name=\"ForceSingleColumnMenus\" />\n"
45266 " </PropertyGroup>\n"
45267 "\n"
45268 " <PropertyGroup label=\"GUI Font\">\n"
45269 " <Property name=\"GUIOverrideFont\"/>\n"
45270 " <Property name=\"GUIFontSize\" />\n"
45271 " </PropertyGroup>\n"
45272 "\n"
45273 " <PropertyGroup label=\"View Options\">\n"
45274 " <Property name=\"DefaultViewType\" />\n"
45275 " <Property name=\"ScreenPixelsPerInch\" />\n"
45276 " </PropertyGroup>\n"
45277 "\n"
45278 " <PropertyGroup label=\"Properties Panel Options\">\n"
45279 " <Property name=\"AutoApply\" />\n"
45280 " <Property name=\"AutoApplyActiveOnly\" />\n"
45281 " <Property name=\"LoadAllVariables\" />\n"
45282 " <Property name=\"LoadNoChartVariables\" />\n"
45283 " </PropertyGroup>\n"
45284 "\n"
45285 " <PropertyGroup label=\"Color/Opacity Map Range Options\">\n"
45286 " <Property name=\"ScalarBarMode\" />\n"
45287 " </PropertyGroup>\n"
45288 "\n"
45289 " <PropertyGroup label=\"Data Processing Options\">\n"
45290 " <Property name=\"AutoConvertProperties\" />\n"
45291 " <Property name=\"BlockColorsDistinctValues\" />\n"
45292 " </PropertyGroup>\n"
45293 "\n"
45294 " <PropertyGroup label=\"Animation\">\n"
45295 " <Property name=\"CacheGeometryForAnimation\" />\n"
45296 " <!--\n"
45297 " <Property name=\"AnimationGeometryCacheLimit\" />\n"
45298 " -->\n"
45299 " <Property name=\"AnimationTimeNotation\" />\n"
45300 " <Property name=\"AnimationTimeShortestAccuratePrecision\" />\n"
45301 " <Property name=\"AnimationTimePrecision\" />\n"
45302 " <Property name=\"ShowAnimationShortcuts\" />\n"
45303 " <Property name=\"DefaultTimeStep\" />\n"
45304 " </PropertyGroup>\n"
45305 "\n"
45306 " <PropertyGroup label=\"Real Number Display\">\n"
45307 " <Property name=\"RealNumberDisplayedNotation\" />\n"
45308 " <Property name=\"RealNumberDisplayedShortestAccuratePrecision\" />\n"
45309 " <Property name=\"RealNumberDisplayedPrecision\" />\n"
45310 " </PropertyGroup>\n"
45311 "\n"
45312 " <PropertyGroup label=\"Full Notation\">\n"
45313 " <Property name=\"FullNotationLowExponent\" />\n"
45314 " <Property name=\"FullNotationHighExponent\" />\n"
45315 " </PropertyGroup>\n"
45316 "\n"
45317 " <PropertyGroup label=\"Interface language\">\n"
45318 " <Property name=\"InterfaceLanguage\" />\n"
45319 " </PropertyGroup>\n"
45320 "\n"
45321 " <PropertyGroup label=\"Miscellaneous\">\n"
45322 " <Property name=\"ResetDisplayEmptyViews\" />\n"
45323 " <Property name=\"InheritRepresentationProperties\" />\n"
45324 " <Property name=\"MaximumNumberOfDataRepresentationLabels\" />\n"
45325 " <Property name=\"IgnoreNegativeLogAxisWarning\" />\n"
45326 " <Property name=\"SelectOnClickInMultiBlockInspector\" />\n"
45327 " </PropertyGroup>\n"
45328 " <Hints>\n"
45329 " <UseDocumentationForLabels />\n"
45330 " </Hints>\n"
45331 " </SettingsProxy>\n"
45332 " </ProxyGroup>\n"
45333 "</ServerManagerConfiguration>\n"
45334 "\n";
45335 // Get single string
45337 {
45338
45339  const size_t len0 = strlen(paraview_server_managerutilities_settingsInterface0);
45340  const size_t len1 = strlen(paraview_server_managerutilities_settingsInterface1);
45341  size_t len = ( 0
45342  + len0
45343  + len1 );
45344  char* res = new char[ len + 1];
45345  size_t offset = 0;
45348  assert(offset == len);
45349  res[offset] = 0;
45350  return res;
45351 }
45352
45353
45354 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Application/Resources/extractors.xml
45356 "<ServerManagerConfiguration>\n"
45357 " <ProxyGroup name=\"extractors\">\n"
45358 " <Proxy name=\"Extractor\">\n"
45359 " <IntVectorProperty name=\"Enable\"\n"
45360 " number_of_elements=\"1\"\n"
45361 " default_values=\"1\">\n"
45362 " <BooleanDomain name=\"bool\" />\n"
45363 " <Documentation>\n"
45364 " Enable the extractor.\n"
45365 " </Documentation>\n"
45366 " </IntVectorProperty>\n"
45367 "\n"
45368 " <ProxyProperty name=\"Trigger\"\n"
45369 " label=\"Trigger\">\n"
45370 " <ProxyListDomain name=\"proxy_list\">\n"
45371 " <Group name=\"extract_triggers\" default=\"TimeStep\" />\n"
45372 " </ProxyListDomain>\n"
45373 " <Documentation>This property sets the parameters of the trigger.</Documentation>\n"
45374 " </ProxyProperty>\n"
45375 " <ProxyProperty name=\"Writer\">\n"
45376 " <ProxyListDomain name=\"proxy_list\" />\n"
45377 " </ProxyProperty>\n"
45378 " <ProxyProperty name=\"Producer\" panel_visibility=\"never\" />\n"
45379 " </Proxy>\n"
45380 "\n"
45381 " <Proxy name=\"SteeringExtractor\">\n"
45382 " <ProxyProperty name=\"Producer\" panel_visibility=\"never\">\n"
45383 " <ProxyGroupDomain name=\"groups\">\n"
45384 " <Group name=\"sources\" />\n"
45385 " <Group name=\"filters\" />\n"
45386 " </ProxyGroupDomain>\n"
45387 " <Documentation>\n"
45388 " This property sets the input of the extractor.\n"
45389 " </Documentation>\n"
45390 " </ProxyProperty>\n"
45391 " </Proxy>\n"
45392 " </ProxyGroup>\n"
45393 "\n"
45394 " <ProxyGroup name=\"extract_triggers\">\n"
45395 " <ExtractTriggerProxy name=\"TimeStep\">\n"
45396 "\n"
45397 " <IntVectorProperty name=\"UseStartTimeStep\"\n"
45398 " number_of_elements=\"1\"\n"
45399 " default_values=\"0\">\n"
45400 " <BooleanDomain name=\"bool\" />\n"
45401 " <Documentation>\n"
45402 " When enabled, **StartTimeStep** will be used to delay the activation of this\n"
45403 " trigger.\n"
45404 " </Documentation>\n"
45405 " </IntVectorProperty>\n"
45406 "\n"
45407 " <IntVectorProperty name=\"StartTimeStep\"\n"
45408 " number_of_elements=\"1\"\n"
45409 " default_values=\"0\">\n"
45410 " <IntRangeDomain name=\"range\" min=\"0\" />\n"
45411 " <Documentation>\n"
45412 " Specify the timestep to at which this trigger is evaluated. This used only\n"
45413 " if **UseStartTimeStep** is enabled.\n"
45414 " </Documentation>\n"
45415 " </IntVectorProperty>\n"
45416 "\n"
45417 " <IntVectorProperty name=\"UseEndTimeStep\"\n"
45418 " number_of_elements=\"1\"\n"
45419 " default_values=\"0\">\n"
45420 " <BooleanDomain name=\"bool\" />\n"
45421 " <Documentation>\n"
45422 " When enabled, **EndTimeStep** will be used to delay the activation of this\n"
45423 " trigger.\n"
45424 " </Documentation>\n"
45425 " </IntVectorProperty>\n"
45426 "\n"
45427 " <IntVectorProperty name=\"EndTimeStep\"\n"
45428 " number_of_elements=\"1\"\n"
45429 " default_values=\"0\">\n"
45430 " <IntRangeDomain name=\"range\" min=\"0\" />\n"
45431 " <Documentation>\n"
45432 " Specify the timestep to at which this trigger is evaluated. This used only\n"
45433 " if **UseEndTimeStep** is enabled.\n"
45434 " </Documentation>\n"
45435 " </IntVectorProperty>\n"
45436 "\n"
45437 " <IntVectorProperty name=\"Frequency\"\n"
45438 " number_of_elements=\"1\"\n"
45439 " default_values=\"1\">\n"
45440 " <IntRangeDomain name=\"range\" min=\"1\" />\n"
45441 " <Documentation>\n"
45442 " Specify the frequency.\n"
45443 " </Documentation>\n"
45444 " </IntVectorProperty>\n"
45445 "\n"
45446 " <PropertyGroup label=\"Start Time Step\" panel_widget=\"CheckableProperty\">\n"
45447 " <Property name=\"StartTimeStep\" function=\"Property\" />\n"
45448 " <Property name=\"UseStartTimeStep\" function=\"PropertyCheckBox\" />\n"
45449 " </PropertyGroup>\n"
45450 "\n"
45451 " <PropertyGroup label=\"End Time Step\" panel_widget=\"CheckableProperty\">\n"
45452 " <Property name=\"EndTimeStep\" function=\"Property\" />\n"
45453 " <Property name=\"UseEndTimeStep\" function=\"PropertyCheckBox\" />\n"
45454 " </PropertyGroup>\n"
45455 " </ExtractTriggerProxy>\n"
45456 "\n"
45457 "\n"
45458 "\n"
45459 " <ExtractTriggerProxy name=\"TimeValue\">\n"
45460 "\n"
45461 " <IntVectorProperty name=\"UseStartTimeValue\"\n"
45462 " number_of_elements=\"1\"\n"
45463 " default_values=\"0\">\n"
45464 " <BooleanDomain name=\"bool\" />\n"
45465 " <Documentation>\n"
45466 " When enabled, **StartTimeValue** will be used to delay the activation of this\n"
45467 " trigger.\n"
45468 " </Documentation>\n"
45469 " </IntVectorProperty>\n"
45470 "\n"
45471 " <DoubleVectorProperty name=\"StartTimeValue\"\n"
45472 " number_of_elements=\"1\"\n"
45473 " default_values=\"0\">\n"
45474 " <Documentation>\n"
45475 " Specify the time value to at which this trigger is evaluated. This used only\n"
45476 " if **UseStartTimeValue** is enabled.\n"
45477 " </Documentation>\n"
45478 " </DoubleVectorProperty>\n"
45479 "\n"
45480 " <IntVectorProperty name=\"UseEndTimeValue\"\n"
45481 " number_of_elements=\"1\"\n"
45482 " default_values=\"0\">\n"
45483 " <BooleanDomain name=\"bool\" />\n"
45484 " <Documentation>\n"
45485 " When enabled, **EndTimeValue** will be used to delay the activation of this\n"
45486 " trigger.\n"
45487 " </Documentation>\n"
45488 " </IntVectorProperty>\n"
45489 "\n"
45490 " <DoubleVectorProperty name=\"EndTimeValue\"\n"
45491 " number_of_elements=\"1\"\n"
45492 " default_values=\"0\">\n"
45493 " <Documentation>\n"
45494 " Specify the time value to at which this trigger is evaluated. This used only\n"
45495 " if **UseEndTimeValue** is enabled.\n"
45496 " </Documentation>\n"
45497 " </DoubleVectorProperty>\n"
45498 "\n"
45499 " <DoubleVectorProperty name=\"Length\"\n"
45500 " number_of_elements=\"1\"\n"
45501 " default_values=\"1\">\n"
45502 " <DoubleRangeDomain name=\"range\" min=\"0\" />\n"
45503 " <Documentation>\n"
45504 " Specify the time value length.\n"
45505 " </Documentation>\n"
45506 " </DoubleVectorProperty>\n"
45507 "\n"
45508 " <PropertyGroup label=\"Start Time Value\" panel_widget=\"CheckableProperty\">\n"
45509 " <Property name=\"StartTimeValue\" function=\"Property\" />\n"
45510 " <Property name=\"UseStartTimeValue\" function=\"PropertyCheckBox\" />\n"
45511 " </PropertyGroup>\n"
45512 "\n"
45513 " <PropertyGroup label=\"End Time Value\" panel_widget=\"CheckableProperty\">\n"
45514 " <Property name=\"EndTimeValue\" function=\"Property\" />\n"
45515 " <Property name=\"UseEndTimeValue\" function=\"PropertyCheckBox\" />\n"
45516 " </PropertyGroup>\n"
45517 " </ExtractTriggerProxy>\n"
45518 "\n"
45519 " </ProxyGroup>\n"
45520 "</ServerManagerConfiguration>\n"
45521 "\n";
45522 // Get single string
45524 {
45525
45526  const size_t len0 = strlen(paraview_server_managerextractorsInterface0);
45527  size_t len = ( 0
45528  + len0 );
45529  char* res = new char[ len + 1];
45530  size_t offset = 0;
45531  std::copy(paraview_server_managerextractorsInterface0, paraview_server_managerextractorsInterface0 + len0, res + offset); offset += len0;
45532  assert(offset == len);
45533  res[offset] = 0;
45534  return res;
45535 }
45536
45537
45538 // From file /builds/gitlab-kitware-sciviz-ci/Remoting/Application/Resources/internal_writers.xml
45540 "<ServerManagerConfiguration>\n"
45541 " <ProxyGroup name=\"internal_writers\">\n"
45542 " <!--\n"
45543 " *****************************************************************\n"
45544 " These are proxies used by meta-writers defined in writers.xml\n"
45545 " *****************************************************************\n"
45546 " -->\n"
45547 " <SourceProxy class=\"vtkPassSelectedArrays\" name=\"PassArrays\"\n"
45548 " base_proxygroup=\"filters\" base_proxyname=\"PassArrays\">\n"
45549 " <!-- extends `PassArrays` to add the ChooseArraysToWrite property -->\n"
45550 " <IntVectorProperty name=\"ChooseArraysToWrite\"\n"
45551 " command=\"SetEnabled\"\n"
45552 " default_values=\"0\"\n"
45553 " number_of_elements=\"1\">\n"
45554 " <BooleanDomain name=\"bool\" />\n"
45555 " <Documentation>\n"
45556 " Explicitly choose which arrays to write.\n"
45557 " </Documentation>\n"
45558 " </IntVectorProperty>\n"
45559 " </SourceProxy>\n"
45560 "\n"
45561 " <!-- ================================================================= -->\n"
45562 " <Proxy name=\"DataWriterBase\">\n"
45563 " <!-- Base for non-xml data writers -->\n"
45564 " <Documentation>This defines the interface for legacy vtk data files\n"
45565 " writer.</Documentation>\n"
45566 " <IntVectorProperty command=\"SetFileType\"\n"
45567 " default_values=\"2\"\n"
45568 " name=\"FileType\"\n"
45569 " number_of_elements=\"1\">\n"
45570 " <EnumerationDomain name=\"enum\">\n"
45571 " <Entry text=\"Ascii\"\n"
45572 " value=\"1\" />\n"
45573 " <Entry text=\"Binary\"\n"
45574 " value=\"2\" />\n"
45575 " </EnumerationDomain>\n"
45576 " <Documentation>The type for the data file (i.e. ascii or\n"
45577 " binary).</Documentation>\n"
45578 " </IntVectorProperty>\n"
45579 " <!-- End of DataWriterBase -->\n"
45580 " </Proxy>\n"
45581 " <!-- ================================================================= -->\n"
45582 " <Proxy name=\"ParallelWriterBase\">\n"
45583 " <Documentation>This defines the interface for the parallel writers.</Documentation>\n"
45584 " <!-- Base for parallel writers -->\n"
45585 "\n"
45586 " <SubProxy>\n"
45587 " <Proxy name=\"PassArrays\" proxygroup=\"internal_writers\" proxyname=\"PassArrays\" />\n"
45588 " <ExposedProperties>\n"
45589 " <PropertyGroup label=\"Data Selection\">\n"
45590 " <Property name=\"ChooseArraysToWrite\" />\n"
45591 " </PropertyGroup>\n"
45592 " <PropertyGroup label=\"Array Selection\" panel_widget=\"ArrayStatus\">\n"
45593 " <Property name=\"PointDataArrays\" />\n"
45594 " <Property name=\"CellDataArrays\" />\n"
45595 " <Property name=\"FieldDataArrays\" />\n"
45596 " <Property name=\"VertexDataArrays\" />\n"
45597 " <Property name=\"EdgeDataArrays\" />\n"
45598 " <Property name=\"RowDataArrays\" />\n"
45599 " <Hints>\n"
45600 " <PropertyWidgetDecorator type=\"GenericDecorator\"\n"
45601 " mode=\"visibility\"\n"
45602 " property=\"ChooseArraysToWrite\"\n"
45603 " value=\"1\" />\n"
45604 " <!-- show this widget when ChooseArraysToWrite==1 -->\n"
45605 " </Hints>\n"
45606 " </PropertyGroup>\n"
45607 " </ExposedProperties>\n"
45608 " <LinkProperties>\n"
45609 " <Property name=\"Input\" with_property=\"Input\" />\n"
45610 " </LinkProperties>\n"
45611 " </SubProxy>\n"
45612 "\n"
45613 " <StringVectorProperty command=\"SetFileName\"\n"
45614 " name=\"FileName\"\n"
45615 " number_of_elements=\"1\">\n"
45616 " <Documentation>The name of the file to be written.</Documentation>\n"
45617 " </StringVectorProperty>\n"
45618 " <IntVectorProperty command=\"SetGhostLevel\"\n"
45619 " default_values=\"0\"\n"
45620 " name=\"GhostLevel\"\n"
45621 " number_of_elements=\"1\">\n"
45622 " <IntRangeDomain min=\"0\"\n"
45623 " name=\"range\" />\n"
45624 " <Documentation>The number of ghost levels to include in the output\n"
45625 " file(s). Note that some writers (such as ExodusIIWriter and CGNSWriter)\n"
45626 " may not support writing ghost levels.</Documentation>\n"
45627 " </IntVectorProperty>\n"
45628 " <SubProxy>\n"
45629 " <SourceProxy class=\"vtkCompleteArrays\"\n"
45630 " name=\"CompleteArrays\"></SourceProxy>\n"
45631 " </SubProxy>\n"
45632 " <!-- End of ParallelWriterBase -->\n"
45633 " </Proxy>\n"
45634 " <!-- ================================================================= -->\n"
45635 " <Proxy name=\"FileSeriesWriter\">\n"
45636 " <StringVectorProperty command=\"SetFileName\"\n"
45637 " name=\"FileName\"\n"
45638 " number_of_elements=\"1\"\n"
45639 " panel_visibility=\"never\">\n"
45640 " <Documentation>The name of the file to be written.</Documentation>\n"
45641 " </StringVectorProperty>\n"
45642 "\n"
45643 " <SubProxy>\n"
45644 " <Proxy name=\"PassArrays\" proxygroup=\"internal_writers\" proxyname=\"PassArrays\" />\n"
45645 " <ExposedProperties>\n"
45646 " <PropertyGroup label=\"Data Selection\">\n"
45647 " <Property name=\"ChooseArraysToWrite\" />\n"
45648 " </PropertyGroup>\n"
45649 "
