| std::string & | trim (std::string &s) |
| Trims leading & trailing whitespace from a string. More... | |
| MPI_Comm | GetMPICommunicator (vtkMultiProcessController *mpc) |
| Returns the corresponding MPI communicator for the multi-process controller used by this instance. More... | |
| vtkDataArray * | GetVtkDataArray (std::string name, int type, void *rawBuffer, int N) |
| This method parses the data in the rawbuffer and reads it into a vtkDataArray that can be attached as vtkPointData to a vtkDataSet, in this case, a vtkUnstructuredGrid that consists of the particles. More... | |
| vtkIdType | GetIdFromRawBuffer (const int type, void *buffer, vtkIdType buffer_idx) |
| This method accesses the user-supplied buffer at the given index and returns the data as a vtkIdType. More... | |
| double | GetDoubleFromRawBuffer (const int type, void *buffer, vtkIdType buffer_idx) |
| This method accesses the user-supplied buffer at the given index and returns the data as a double. More... | |
| gio::GenericIOReader * | GetReader (MPI_Comm comm, bool posix, int distribution, const std::string &fileName) |
| This method constructs and returns the underlying GenericIO reader. More... | |
| gio::GenericIOWriter * | GetWriter (MPI_Comm comm, const std::string &fileName) |
| This method constructs and returns the underlying GenericIO writer. More... | |
| std::string & | ltrim (std::string &s) |
| Trims leading whitespace from a string. More... | |
| std::string & | rtrim (std::string &s) |
| Trims trailing whitespace from a string. More... | |
| void | SafeDeleteString (char *&str) |
| If the pointer given is non-nullptr this function deletes the string and set the pointer to nullptr. More... | |
Definition at line 40 of file vtkGenericIOUtilities.h.
Definition at line 53 of file vtkGenericIOUtilities.h.
Definition at line 66 of file vtkGenericIOUtilities.h.
| MPI_Comm vtkGenericIOUtilities::GetMPICommunicator | ( | vtkMultiProcessController * | mpc | ) |
| vtkDataArray* vtkGenericIOUtilities::GetVtkDataArray | ( | std::string | name, |
| int | type, | ||
| void * | rawBuffer, | ||
| int | N | ||
| vtkIdType vtkGenericIOUtilities::GetIdFromRawBuffer | ( | const int | type, |
| void * | buffer, | ||
| vtkIdType | buffer_idx | ||
It is intended as a convenience method to allow the user to access the data in an agnostic-type fashion.
| double vtkGenericIOUtilities::GetDoubleFromRawBuffer | ( | const int | type, |
| gio::GenericIOReader* vtkGenericIOUtilities::GetReader | ( | MPI_Comm | comm, |
| bool | posix, | ||
| int | distribution, | ||
| const std::string & | fileName | ||
| gio::GenericIOWriter* vtkGenericIOUtilities::GetWriter | ( | MPI_Comm | comm, |
The returned writer will have its filename set already
This sets the pointer variable in the calling function since the pointer is passed by reference.
Definition at line 123 of file vtkGenericIOUtilities.h.
