| class | PROTOBUF_FINAL |
Enumerations | |
| enum | Variant_Type : int { Variant_Type_INT = 0, Variant_Type_FLOAT64 = 1, Variant_Type_IDTYPE = 2, Variant_Type_STRING = 3, Variant_Type_PROXY = 4, Variant_Type_INPUT = 5, Variant_Type_BYTES = 6, Variant_Type_MAP = 7 } |
| enum | LinkState_LinkDescription_Direction : int { LinkState_LinkDescription_Direction_NONE = 0, LinkState_LinkDescription_Direction_INPUT = 1, LinkState_LinkDescription_Direction_OUTPUT = 2 } |
| enum | MousePointer_Ratio : int { MousePointer_Ratio_BOTH = 0, MousePointer_Ratio_HEIGHT = 1, MousePointer_Ratio_WIDTH = 2 } |
| enum | QtEvent_QtEventType : int { QtEvent_QtEventType_CHAT = 1, QtEvent_QtEventType_OTHER = 3 } |
| Enumerator | |
| Variant_Type_INT | |
| Variant_Type_FLOAT64 | |
| Variant_Type_IDTYPE | |
| Variant_Type_STRING | |
| Variant_Type_PROXY | |
| Variant_Type_INPUT | |
| Variant_Type_BYTES | |
| Variant_Type_MAP | |
Definition at line 160 of file vtkPVMessage.pb.h.
| Enumerator | |
| LinkState_LinkDescription_Direction_NONE | |
| LinkState_LinkDescription_Direction_INPUT | |
| LinkState_LinkDescription_Direction_OUTPUT | |
Definition at line 189 of file vtkPVMessage.pb.h.
| Enumerator | |
| MousePointer_Ratio_BOTH | |
| MousePointer_Ratio_HEIGHT | |
| MousePointer_Ratio_WIDTH | |
Definition at line 213 of file vtkPVMessage.pb.h.
| Enumerator | |
| QtEvent_QtEventType_CHAT | |
| QtEvent_QtEventType_OTHER | |
Definition at line 237 of file vtkPVMessage.pb.h.
| VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::Variant_Type_IsValid | ( | int | value | ) |
| VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::Variant_Type_descriptor | ( | ) |
Definition at line 177 of file vtkPVMessage.pb.h.
Definition at line 184 of file vtkPVMessage.pb.h.
| VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::LinkState_LinkDescription_Direction_IsValid | ( | int | value | ) |
| VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::LinkState_LinkDescription_Direction_descriptor | ( | ) |
Definition at line 201 of file vtkPVMessage.pb.h.
Definition at line 208 of file vtkPVMessage.pb.h.
| VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::MousePointer_Ratio_IsValid | ( | int | value | ) |
| VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::MousePointer_Ratio_descriptor | ( | ) |
Definition at line 225 of file vtkPVMessage.pb.h.
Definition at line 232 of file vtkPVMessage.pb.h.
| VTKREMOTINGSERVERMANAGER_EXPORT bool paraview_protobuf::QtEvent_QtEventType_IsValid | ( | int | value | ) |
| VTKREMOTINGSERVERMANAGER_EXPORTconst ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::QtEvent_QtEventType_descriptor | ( | ) |
Definition at line 248 of file vtkPVMessage.pb.h.
Definition at line 255 of file vtkPVMessage.pb.h.
| VTKREMOTINGSERVERMANAGER_EXPORT ChartViewBoundsDefaultTypeInternal paraview_protobuf::_ChartViewBounds_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ChatMessageDefaultTypeInternal paraview_protobuf::_ChatMessage_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ClientsInformationDefaultTypeInternal paraview_protobuf::_ClientsInformation_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ClientsInformation_ClientInfoDefaultTypeInternal paraview_protobuf::_ClientsInformation_ClientInfo_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT DefinitionHeaderDefaultTypeInternal paraview_protobuf::_DefinitionHeader_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT LinkStateDefaultTypeInternal paraview_protobuf::_LinkState_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT LinkState_LinkDescriptionDefaultTypeInternal paraview_protobuf::_LinkState_LinkDescription_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT MessageDefaultTypeInternal paraview_protobuf::_Message_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT MessageCollectionDefaultTypeInternal paraview_protobuf::_MessageCollection_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT MousePointerDefaultTypeInternal paraview_protobuf::_MousePointer_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT PXMRegistrationStateDefaultTypeInternal paraview_protobuf::_PXMRegistrationState_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT PXMRegistrationState_EntryDefaultTypeInternal paraview_protobuf::_PXMRegistrationState_Entry_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyDefinitionStateDefaultTypeInternal paraview_protobuf::_ProxyDefinitionState_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyDefinitionState_ProxyXMLDefinitionDefaultTypeInternal paraview_protobuf::_ProxyDefinitionState_ProxyXMLDefinition_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxySelectionModelStateDefaultTypeInternal paraview_protobuf::_ProxySelectionModelState_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyStateDefaultTypeInternal paraview_protobuf::_ProxyState_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_AnnotationDefaultTypeInternal paraview_protobuf::_ProxyState_Annotation_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_PropertyDefaultTypeInternal paraview_protobuf::_ProxyState_Property_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_SubProxyDefaultTypeInternal paraview_protobuf::_ProxyState_SubProxy_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT ProxyState_UserDataDefaultTypeInternal paraview_protobuf::_ProxyState_UserData_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT PullRequestDefaultTypeInternal paraview_protobuf::_PullRequest_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT QtEventDefaultTypeInternal paraview_protobuf::_QtEvent_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT VariantDefaultTypeInternal paraview_protobuf::_Variant_default_instance_ |
| VTKREMOTINGSERVERMANAGER_EXPORT VariantListDefaultTypeInternal paraview_protobuf::_VariantList_default_instance_ |
| constexpr Variant_Type paraview_protobuf::Variant_Type_Type_MIN = Variant_Type_INT |
Definition at line 171 of file vtkPVMessage.pb.h.
| constexpr Variant_Type paraview_protobuf::Variant_Type_Type_MAX = Variant_Type_MAP |
Definition at line 172 of file vtkPVMessage.pb.h.
| constexpr int paraview_protobuf::Variant_Type_Type_ARRAYSIZE = Variant_Type_Type_MAX + 1 |
Definition at line 173 of file vtkPVMessage.pb.h.
| constexpr LinkState_LinkDescription_Direction paraview_protobuf::LinkState_LinkDescription_Direction_Direction_MIN = LinkState_LinkDescription_Direction_NONE |
Definition at line 195 of file vtkPVMessage.pb.h.
| constexpr LinkState_LinkDescription_Direction paraview_protobuf::LinkState_LinkDescription_Direction_Direction_MAX = LinkState_LinkDescription_Direction_OUTPUT |
Definition at line 196 of file vtkPVMessage.pb.h.
| constexpr int paraview_protobuf::LinkState_LinkDescription_Direction_Direction_ARRAYSIZE = LinkState_LinkDescription_Direction_Direction_MAX + 1 |
Definition at line 197 of file vtkPVMessage.pb.h.
| constexpr MousePointer_Ratio paraview_protobuf::MousePointer_Ratio_Ratio_MIN = MousePointer_Ratio_BOTH |
Definition at line 219 of file vtkPVMessage.pb.h.
| constexpr MousePointer_Ratio paraview_protobuf::MousePointer_Ratio_Ratio_MAX = MousePointer_Ratio_WIDTH |
Definition at line 220 of file vtkPVMessage.pb.h.
| constexpr int paraview_protobuf::MousePointer_Ratio_Ratio_ARRAYSIZE = MousePointer_Ratio_Ratio_MAX + 1 |
Definition at line 221 of file vtkPVMessage.pb.h.
| constexpr QtEvent_QtEventType paraview_protobuf::QtEvent_QtEventType_QtEventType_MIN = QtEvent_QtEventType_CHAT |
Definition at line 242 of file vtkPVMessage.pb.h.
| constexpr QtEvent_QtEventType paraview_protobuf::QtEvent_QtEventType_QtEventType_MAX = QtEvent_QtEventType_OTHER |
Definition at line 243 of file vtkPVMessage.pb.h.
| constexpr int paraview_protobuf::QtEvent_QtEventType_QtEventType_ARRAYSIZE = QtEvent_QtEventType_QtEventType_MAX + 1 |
Definition at line 244 of file vtkPVMessage.pb.h.
