selects proxies. More...
#include <vtkSMProxySelectionModel.h>
| enum | ProxySelectionFlag { NO_UPDATE = 0, CLEAR = 1, SELECT = 2, DESELECT = 4, CLEAR_AND_SELECT = CLEAR | SELECT } |
| typedef std::list< vtkSmartPointer< vtkSMProxy > > | SelectionType |
| Type for selection. More... | |
| Override the set session, so we can attach an observer to the Collaboration manager in order to monitor master/slave changes. More... | |
| vtkSMProxy * | GetCurrentProxy () |
| Returns the proxy that is current, nullptr if there is no current. More... | |
| void | SetCurrentProxy (vtkSMProxy *proxy, int command) |
| Sets the current proxy. More... | |
| bool | IsSelected (vtkSMProxy *proxy) |
| Returns true if the proxy is selected. More... | |
| unsigned int | GetNumberOfSelectedProxies () |
| vtkSMProxy * | GetSelectedProxy (unsigned int index) |
| Returns the selected proxy at the given index. More... | |
| const SelectionType & | GetSelection () |
| Returns the selection set. More... | |
| void | Select (const SelectionType &proxies, int command) |
| Update the selected set of proxies. More... | |
| void | Select (vtkSMProxy *proxy, int command) |
| void | Clear () |
| Wrapper friendly methods to doing what Select() can do. More... | |
| void | Select (vtkSMProxy *proxy) |
| void | Deselect (vtkSMProxy *proxy) |
| void | ClearAndSelect (vtkSMProxy *proxy) |
| bool | GetSelectionDataBounds (double bounds[6]) |
| Utility method to get the data bounds for the currently selected items. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| void | SetFollowingMaster (bool following) |
| Allow to synchronize the active object with master or just keep remote object out-of-synch. More... | |
| bool | IsFollowingMaster () |
| bool | HasGlobalID () |
| virtual void | EnableLocalPushOnly () |
| virtual void | DisableLocalPushOnly () |
| virtual void | SetLocation (vtkTypeUInt32) |
| virtual void | PrototypeOn () |
| virtual void | PrototypeOff () |
| bool | IsPrototype () |
| virtual void | SetPrototype (bool) |
| static vtkSMProxySelectionModel * | New () |
| static vtkSMProxySelectionModel * | SafeDownCast (vtkObject *o) |
| vtkSMProxySelectionModel () | |
| ~vtkSMProxySelectionModel () override | |
| void | InvokeCurrentChanged (vtkSMProxy *proxy) |
| void | InvokeSelectionChanged () |
| void | PushStateToSession () |
| When the state has changed we call that method so the state can be shared is any collaboration is involved. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes | |
| vtkSmartPointer< vtkSMProxy > | Current |
| SelectionType | Selection |
| vtkSMMessage * | State |
Protected Attributes inherited from vtkSMRemoteObject | |
| vtkTypeUInt32 | GlobalID |
| vtkTypeUInt32 | Location |
| bool | Prototype |
| bool | ClientOnlyLocationFlag |
Friends | |
| class | vtkInternal |
selects proxies.
vtkSMProxySelectionModel is used to select proxies. vtkSMProxyManager uses two instances of vtkSMProxySelectionModel for keeping track of the selected/active sources/filters and the active view.
Definition at line 28 of file vtkSMProxySelectionModel.h.
Definition at line 32 of file vtkSMProxySelectionModel.h.
| typedef std::list<vtkSmartPointer<vtkSMProxy> > vtkSMProxySelectionModel::SelectionType |
Type for selection.
Definition at line 53 of file vtkSMProxySelectionModel.h.
| Enumerator | |
| NO_UPDATE | |
| CLEAR | |
| SELECT | |
| DESELECT | |
| CLEAR_AND_SELECT | |
Definition at line 56 of file vtkSMProxySelectionModel.h.
Reimplemented from vtkSMRemoteObject.
Reimplemented from vtkSMSessionObject.
| void vtkSMProxySelectionModel::SetFollowingMaster | ( | bool | following | ) |
Only the state from the master will be loaded.
| bool vtkSMProxySelectionModel::IsFollowingMaster | ( | ) |
| vtkSMProxy* vtkSMProxySelectionModel::GetCurrentProxy | ( | ) |
| void vtkSMProxySelectionModel::SetCurrentProxy | ( | vtkSMProxy * | proxy, |
| int | command | ||
command is used to control how the current selection is affected.
| bool vtkSMProxySelectionModel::IsSelected | ( | vtkSMProxy * | proxy | ) |
| unsigned int vtkSMProxySelectionModel::GetNumberOfSelectedProxies | ( | ) |
| vtkSMProxy* vtkSMProxySelectionModel::GetSelectedProxy | ( | unsigned int | index | ) |
Definition at line 97 of file vtkSMProxySelectionModel.h.
| void vtkSMProxySelectionModel::Select | ( | const SelectionType & | proxies, |
| int | command | ||
command affects how the selection is updated.
| void vtkSMProxySelectionModel::Select | ( | vtkSMProxy * | proxy, |
| int | command | ||
Definition at line 117 of file vtkSMProxySelectionModel.h.
Definition at line 118 of file vtkSMProxySelectionModel.h.
Definition at line 119 of file vtkSMProxySelectionModel.h.
Definition at line 120 of file vtkSMProxySelectionModel.h.
| bool vtkSMProxySelectionModel::GetSelectionDataBounds | ( | double | bounds[6] | ) |
This only makes sense for selections comprising of source-proxies or output-port proxies. Returns true is the bounds are valid.
This method will be used to fill the undo stack. If not overridden this will return nullptr.
This allow to split the load process in 2 step to prevent invalid state when property refere to a sub-proxy that does not exist yet.
friend |
Definition at line 170 of file vtkSMProxySelectionModel.h.
Definition at line 154 of file vtkSMProxySelectionModel.h.
Definition at line 155 of file vtkSMProxySelectionModel.h.
Definition at line 164 of file vtkSMProxySelectionModel.h.
