| virtual void | SetFileDimensionality (int) |
| | The number of dimensions stored in a file. More...
| virtual int | GetFileDimensionality () |
| virtual void | SetDataExtent (int, int, int, int, int, int) |
| | Get/Set the extent of the data on disk. More...
| virtual void | SetDataExtent (int [6]) |
| virtual int * | GetDataExtent () |
| virtual void | GetDataExtent (int &, int &, int &, int &, int &, int &) |
| virtual void | GetDataExtent (int [6]) |
| virtual void | SetReadAsImageStack (bool) |
| virtual bool | GetReadAsImageStack () |
| virtual void | ReadAsImageStackOn () |
| virtual void | ReadAsImageStackOff () |
| int | ProcessRequest (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| | Overridden to directly call the internal reader after passing it the correct filenames when ReadAsImageStack is true. More...
| virtual int | CanReadFile (const char *filename) |
| | CanReadFile is forwarded to the internal reader if it supports it. More...
| virtual void | AddFileName (const char *fname) |
| | Adds names of files to be read. More...
| virtual void | RemoveAllFileNames () |
| | Remove all file names. More...
| virtual unsigned int | GetNumberOfFileNames () |
| | Returns the number of file names added by AddFileName. More...
| virtual const char * | GetFileName (unsigned int idx) |
| | Returns the name of a file with index idx. More...
| const char * | GetCurrentFileName () |
| virtual int | GetUseMetaFile () |
| | If true, then use the meta file. More...
| virtual void | SetUseMetaFile (int) |
| virtual void | UseMetaFileOn () |
| virtual void | UseMetaFileOff () |
| virtual bool | GetIgnoreReaderTime () |
| | If true, then treat file series like it does not contain any time step values. More...
| virtual void | SetIgnoreReaderTime (bool) |
| virtual void | IgnoreReaderTimeOn () |
| virtual void | IgnoreReaderTimeOff () |
| | vtkMetaReader () |
| | ~vtkMetaReader () override |
| vtkMTimeType | GetMTime () override |
| | Return the MTime when also considering the internal reader. More...
| virtual void | SetReader (vtkAlgorithm *) |
| | Set/get the internal reader. More...
| virtual vtkAlgorithm * | GetReader () |
| void | SetMetaFileName (const char *name) |
| | Get/set the filename for the meta-file. More...
| char * | GetMetaFileName () |
| virtual vtkIdType * | GetFileIndexRange () |
| | Returns the available range of file indexes. More...
| virtual void | GetFileIndexRange (vtkIdType &, vtkIdType &) |
| virtual void | GetFileIndexRange (vtkIdType [2]) |
| vtkIdType | GetFileIndex () |
| | Get/set the index of the file to read. More...
| void | SetFileIndex (vtkIdType i) |
| virtual void | SetFileNameMethod (const char *) |
| | Name of the method used to set the file name of the internal reader. More...
| virtual char * | GetFileNameMethod () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkRawImageFileSeriesReader () |
| | ~vtkRawImageFileSeriesReader () override |
| void | UpdateReaderDataExtent () override |
| | Update the reader extent if the image file format does not know what it is (e.g. More...
| | vtkImageFileSeriesReader () |
| | ~vtkImageFileSeriesReader () override |
| void | UpdateFileNames () |
| | vtkFileSeriesReader () |
| | ~vtkFileSeriesReader () override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | RequestUpdateExtent (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| virtual int | RequestInformationForInput (int index, vtkInformation *request=nullptr, vtkInformationVector *outputVector=nullptr) |
| | Make sure the reader's output is set to the given index and, if it changed, run RequestInformation on the reader. More...
| virtual int | ReadMetaDataFile (const char *metafilename, vtkStringArray *filesToRead, std::vector< double > &timeValues, int maxFilesToRead=VTK_INT_MAX) |
| | Reads a metadata file and returns a list of filenames (in filesToRead). More...
| virtual void | UpdateMetaData () |
| | Re-reads information from the metadata file, if necessary. More...
| void | ResetTimeRanges () |
| | Resets information about TimeRanges. More...
| void | RemoveAllFileNamesInternal () |
| | Add/Remove filenames without changing the MTime. More...
| void | AddFileNameInternal (const char *) |
| virtual void | RemoveAllRealFileNamesInternal () |
| | Remove all real file names. More...
| void | CopyRealFileNamesFromFileNames () |
| | Set the real filenames to those in the internal FileNames. More...
| int | ChooseInput (vtkInformation *) |
| virtual void | Set_MetaFileName (const char *) |
| virtual char * | Get_MetaFileName () |
| virtual void | Set_FileIndex (vtkIdType) |
| virtual vtkIdType | Get_FileIndex () |
| void | ReaderSetFileName (const char *filename) |
| int | ReaderCanReadFile (const char *filename) |
| std::string | FromRelativeToMetaFile (const char *metaFileName, const char *fileName) |
| | 'metaFileName' to either a file path that is relative to the current working directory (CWD) or to an absolute file path. More...
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
