defines ParaViewWeb application interface. More...
#include <vtkPVWebApplication.h>
| bool | GetHasImagesBeingProcessed (vtkSMViewProxy *) |
| StillRenderToString() need not necessary returns the most recently rendered image. More... | |
| bool | HandleInteractionEvent (vtkSMViewProxy *view, vtkWebInteractionEvent *event) |
| Communicate mouse interaction to a view. More... | |
| void | InvalidateCache (vtkSMViewProxy *view) |
| Invalidate view cache. More... | |
| const char * | GetWebGLSceneMetaData (vtkSMViewProxy *view) |
| Return the Meta data description of the input scene in JSON format. More... | |
| const char * | GetWebGLBinaryData (vtkSMViewProxy *view, const char *id, int partIndex) |
| Return the binary data given the part index and the webGL object piece id in the scene. More... | |
| vtkUnsignedCharArray * | StillRender (vtkSMViewProxy *view, int quality=100) |
| Render a view and obtain the rendered image. More... | |
| vtkUnsignedCharArray * | InteractiveRender (vtkSMViewProxy *view, int quality=50) |
| const char * | StillRenderToString (vtkSMViewProxy *view, unsigned long time=0, int quality=100) |
| vtkUnsignedCharArray * | StillRenderToBuffer (vtkSMViewProxy *view, unsigned long time=0, int quality=100) |
| virtual vtkMTimeType | GetLastStillRenderToMTime () |
| Return the MTime of the last array exported by StillRenderToString, StillRenderToBuffer. More... | |
| virtual int * | GetLastStillRenderImageSize () |
| Return the size of the last image exported. More... | |
| virtual void | GetLastStillRenderImageSize (int &, int &) |
| virtual void | GetLastStillRenderImageSize (int [2]) |
| static vtkPVWebApplication * | New () |
| static vtkPVWebApplication * | SafeDownCast (vtkObject *o) |
| vtkPVWebApplication () | |
| ~vtkPVWebApplication () override | |
Protected Attributes | |
| int | ImageEncoding |
| int | ImageCompression |
| vtkMTimeType | LastStillRenderToMTime |
| int | LastStillRenderImageSize [3] |
| enum | { ENCODING_NONE = 0, ENCODING_BASE64 = 1 } |
| Set the encoding to be used for rendered images. More... | |
| virtual void | SetImageEncoding (int) |
| virtual int | GetImageEncoding () |
| enum | { COMPRESSION_NONE = 0, COMPRESSION_PNG = 1, COMPRESSION_JPEG = 2 } |
| Set the compression to be used for rendered images. More... | |
| virtual void | SetImageCompression (int) |
| virtual int | GetImageCompression () |
vtkPVWebApplication defines the core interface for a ParaViewWeb application. This exposes methods that make it easier to manage views and rendered images from views.
Definition at line 22 of file vtkPVWebApplication.h.
Definition at line 26 of file vtkPVWebApplication.h.
| anonymous enum |
| Enumerator | |
| ENCODING_NONE | |
| ENCODING_BASE64 | |
Definition at line 33 of file vtkPVWebApplication.h.
| anonymous enum |
| Enumerator | |
| COMPRESSION_NONE | |
| COMPRESSION_PNG | |
| COMPRESSION_JPEG | |
Definition at line 46 of file vtkPVWebApplication.h.
| vtkUnsignedCharArray* vtkPVWebApplication::StillRender | ( | vtkSMViewProxy * | view, |
| int | quality = 100 |
| vtkUnsignedCharArray* vtkPVWebApplication::InteractiveRender | ( | vtkSMViewProxy * | view, |
| int | quality = 50 |
| const char* vtkPVWebApplication::StillRenderToString | ( | vtkSMViewProxy * | view, |
| unsigned long | time = 0, |
| vtkUnsignedCharArray* vtkPVWebApplication::StillRenderToBuffer | ( | vtkSMViewProxy * | view, |
| bool vtkPVWebApplication::GetHasImagesBeingProcessed | ( | vtkSMViewProxy * | ) |
Use this method to get whether there are any pending images being processed concurrently.
| bool vtkPVWebApplication::HandleInteractionEvent | ( | vtkSMViewProxy * | view, |
| vtkWebInteractionEvent * | event | ||
Returns true if the interaction changed the view state, otherwise returns false.
| void vtkPVWebApplication::InvalidateCache | ( | vtkSMViewProxy * | view | ) |
| const char* vtkPVWebApplication::GetWebGLSceneMetaData | ( | vtkSMViewProxy * | view | ) |
This is using the vtkWebGLExporter to parse the scene. NOTE: This should be called before getting the webGL binary data.
| const char* vtkPVWebApplication::GetWebGLBinaryData | ( | vtkSMViewProxy * | view, |
| const char * | id, | ||
| int | partIndex | ||
Definition at line 116 of file vtkPVWebApplication.h.
Definition at line 117 of file vtkPVWebApplication.h.
Definition at line 118 of file vtkPVWebApplication.h.
Definition at line 119 of file vtkPVWebApplication.h.
