Prominent values a data array takes on. More...
#include <vtkPVProminentValuesInformation.h>
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | InitializeParameters () |
| Remove all parameter information. More... | |
| void | Initialize () |
| Remove all gathered information (but not parameters). More... | |
| void | AddDistinctValues (vtkPVProminentValuesInformation *) |
| Merge another list of prominent values. More... | |
| vtkAbstractArray * | GetProminentComponentValues (int component) |
| Returns either nullptr (array component appears to be continuous) or a pointer to a vtkAbstractArray (array component appears to be discrete) containing a sorted list of all distinct prominent values encountered in the array component. More... | |
| virtual void | SetPortNumber (int) |
| Set/get the output port whose dataset should be queried. More... | |
| virtual int | GetPortNumber () |
| virtual void | SetSubsetAssemblyName (const char *) |
| Set/get subset assembly's name. More... | |
| virtual char * | GetSubsetAssemblyName () |
| virtual void | SetSubsetSelector (const char *) |
| Set/get subset selector's name. More... | |
| virtual char * | GetSubsetSelector () |
| virtual void | SetFieldAssociation (const char *) |
| Set/get array's association. More... | |
| virtual char * | GetFieldAssociation () |
| virtual void | SetFieldName (const char *) |
| Set/get array's name. More... | |
| virtual char * | GetFieldName () |
| void | SetNumberOfComponents (int numComps) |
| Changing the number of components clears the ranges back to the default. More... | |
| virtual int | GetNumberOfComponents () |
| virtual void | SetFraction (double) |
| Set/get the minimum fraction of the array that should be composed of a value (between 0 and 1) in order for it to be considered prominent. More... | |
| virtual double | GetFraction () |
| virtual void | SetUncertainty (double) |
| Set/get the maximum uncertainty allowed in the detection of prominent values. More... | |
| virtual double | GetUncertainty () |
| virtual void | SetForce (bool) |
| Set/get the force flag that will be used when recovering the prominents values. More... | |
| virtual bool | GetForce () |
| virtual bool | GetValid () |
| Get the validity of the information. More... | |
| int | Compare (vtkPVProminentValuesInformation *info) |
| Returns 1 if the array can be combined. More... | |
| void | DeepCopy (vtkPVProminentValuesInformation *other) |
| Copy information from an other object. More... | |
| void | CopyFromObject (vtkObject *) override |
| Transfer information about a single object into this object. More... | |
| virtual void | CopyDistinctValuesFromObject (vtkAbstractArray *) |
| Transfer information about a single vtkAbstractArray's prominent values into this object. More... | |
| void | AddInformation (vtkPVInformation *other) override |
| Merge another information object. More... | |
| void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) override |
| void | CopyParametersToStream (vtkMultiProcessStream &) override |
| Push/pop parameters controlling which array to sample onto/off of the stream. More... | |
| void | CopyParametersFromStream (vtkMultiProcessStream &) override |
Public Member Functions inherited from vtkPVInformation | |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVProminentValuesInformation * | New () |
| static vtkPVProminentValuesInformation * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
Protected Attributes | |
| int | PortNumber |
| Information parameters. More... | |
| char * | SubsetAssemblyName |
| char * | SubsetSelector |
| int | NumberOfComponents |
| char * | FieldName |
| char * | FieldAssociation |
| double | Fraction |
| double | Uncertainty |
| bool | Force |
| bool | Valid |
| vtkInternalDistinctValues * | DistinctValues |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
This vtkPVInformation subclass provides a way for clients to discover whether a specific remote vtkAbstractArray instance behaves like a discrete set or a continuum (for each component of its tuples as well as for its tuples as a whole).
If the array behaves discretely (which we define to be: takes on fewer than 33 distinct values over more than 99.9% of its entries to within a given confidence that dictates the number of samples required), then the prominent values are also made available.
This class uses vtkAbstractArray::GetProminentComponentValues().
Definition at line 32 of file vtkPVProminentValuesInformation.h.
Definition at line 36 of file vtkPVProminentValuesInformation.h.
protecteddelete |
Reimplemented from vtkPVInformation.
| void vtkPVProminentValuesInformation::SetNumberOfComponents | ( | int | numComps | ) |
Setting this to one indicates that an array must have every value be identical in order to have any considered prominent.
The uncertainty is the probability of prominent values going undetected. Setting this to zero forces the entire array to be inspected.
If not set, a maximum of vtkAbstractArray::MAX_DISCRETE_VALUES (32) values will be recovered, if there is more, none will be recovered and the information will be considered invalid. If the force flag is set, there is no maximum number of prominent values recovered and the information should be valid even with a high number of prominent values.
The flag has a meaning after trying to recover prominent values, if true, the data can be used, if false, this information should be considered invalid.
| int vtkPVProminentValuesInformation::Compare | ( | vtkPVProminentValuesInformation * | info | ) |
It must have the same name and number of components.
| void vtkPVProminentValuesInformation::DeepCopy | ( | vtkPVProminentValuesInformation * | other | ) |
This is called after CopyFromObject has determined the number of components available; this method relies on this->NumberOfComponents being valid.
Implements vtkPVInformation.
| void vtkPVProminentValuesInformation::InitializeParameters | ( | ) |
You must copy/set parameter values before adding data or copying data from an object.
| void vtkPVProminentValuesInformation::Initialize | ( | ) |
Next add will behave like a copy.
| void vtkPVProminentValuesInformation::AddDistinctValues | ( | vtkPVProminentValuesInformation * | ) |
| vtkAbstractArray* vtkPVProminentValuesInformation::GetProminentComponentValues | ( | int | component | ) |
Passing -1 as the component will return information about distinct tuple values as opposed to distinct component values.
protecteddelete |
Definition at line 212 of file vtkPVProminentValuesInformation.h.
Definition at line 213 of file vtkPVProminentValuesInformation.h.
Definition at line 214 of file vtkPVProminentValuesInformation.h.
Definition at line 215 of file vtkPVProminentValuesInformation.h.
Definition at line 216 of file vtkPVProminentValuesInformation.h.
Definition at line 217 of file vtkPVProminentValuesInformation.h.
Definition at line 218 of file vtkPVProminentValuesInformation.h.
Definition at line 219 of file vtkPVProminentValuesInformation.h.
Definition at line 220 of file vtkPVProminentValuesInformation.h.
Definition at line 221 of file vtkPVProminentValuesInformation.h.
Definition at line 227 of file vtkPVProminentValuesInformation.h.
