vtkChartRepresentation subclass for scatter-plot-matrix representation. More...
#include <vtkPVPlotMatrixRepresentation.h>
| typedef vtkChartRepresentation | Superclass |
Public Types inherited from vtkChartRepresentation | |
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| void | SetVisibility (bool visible) override |
| Sets the visibility for the plot matrix representation. More... | |
| void | SetColor (double r, double g, double b) |
| Sets the color for the scatter plots in the plot matrix. More... | |
| void | SetActivePlotColor (double r, double g, double b) |
| Sets the color for the active plot. More... | |
| void | SetHistogramColor (double r, double g, double b) |
| Sets the color for the histograms. More... | |
| void | SetMarkerStyle (int style) |
| Sets the marker style for the scatter plots. More... | |
| void | SetActivePlotMarkerStyle (int style) |
| Sets the marker style for the active plot. More... | |
| void | SetMarkerSize (double size) |
| Sets the marker size for the scatter plots. More... | |
| void | SetActivePlotMarkerSize (double size) |
| Sets the marker size for the active plots. More... | |
| void | SetDensityMapVisibility (bool visible) |
| Set the scatter plot density map visibility. More... | |
| void | SetActivePlotDensityMapVisibility (bool visible) |
| Set the active plot density map visibility. More... | |
| void | SetDensityLineSize (double size) |
| Sets the line size for the density map in the plot matrix. More... | |
| void | SetActivePlotDensityLineSize (double size) |
| Sets the line size for the density map in the active plot. More... | |
| void | SetDensityMapFirstDecileColor (double r, double g, double b) |
| Sets the color for the density map first DecileColor in the scatter plots. More... | |
| void | SetActivePlotDensityMapFirstDecileColor (double r, double g, double b) |
| void | SetDensityMapMedianColor (double r, double g, double b) |
| Sets the color for the density map MeanColor in the scatter plots. More... | |
| void | SetActivePlotDensityMapMedianColor (double r, double g, double b) |
| void | SetDensityMapLastDecileColor (double r, double g, double b) |
| Sets the color for the density map last DecileColor in the scatter plots. More... | |
| void | SetActivePlotDensityMapLastDecileColor (double r, double g, double b) |
| vtkScatterPlotMatrix * | GetPlotMatrix () const |
| Returns the scatter plot matrix. More... | |
| void | SetSeriesVisibility (const char *series, bool visibility) |
| Set series visibility given its name. More... | |
| void | ClearSeriesVisibilities () |
Public Member Functions inherited from vtkChartRepresentation | |
| void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
| These must only be set during initialization before adding the representation to any views or calling Update(). More... | |
| This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More... | |
| void | SetCompositeDataSetIndex (unsigned int) |
| void | AddCompositeDataSetIndex (unsigned int) |
| void | ResetCompositeDataSetIndices () |
| unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| Override because of internal selection representations that need to be initialized as well. More... | |
| vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More... | |
| virtual std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) |
| Method to provide the default name given the name of a table and a column in that table. More... | |
| virtual bool | MapSelectionToInput (vtkSelection *sel) |
| This method is called on the client-side by the vtkPVContextView whenever a new selection is made on all the visible representations in that view. More... | |
| virtual bool | MapSelectionToView (vtkSelection *sel) |
| This is the inverse of MapSelectionToInput(). More... | |
| void | SetFieldAssociation (int) |
| Set the field association for arrays to use. More... | |
| virtual int | GetFieldAssociation () |
| virtual void | SetFlattenTable (int) |
| Flatten the table, i.e. More... | |
| virtual int | GetFlattenTable () |
| virtual bool | Export (vtkAbstractChartExporter *vtkNotUsed(exporter)) |
| Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More... | |
Public Member Functions inherited from vtkPVDataRepresentation | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the data object that is rendered from the given input port. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Specify the array names used for the selection. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
vtkPVPlotMatrixRepresentation manages representations in a vtkScatterPlotMatrix view. It exposes API that affects how the matrix is rendered as well as API to control which of the columns in the input vtkTable are to be plotted in the matrix.
vtkPVPlotMatrixRepresentation currently does not support multiblock of tables and only the first table is rendered.
Definition at line 28 of file vtkPVPlotMatrixRepresentation.h.
Definition at line 32 of file vtkPVPlotMatrixRepresentation.h.
Reimplemented from vtkChartRepresentation.
| void vtkPVPlotMatrixRepresentation::SetSeriesVisibility | ( | const char * | series, |
| bool | visibility | ||
The order in which SetSeriesVisibility is called is used to determine the order for each of the plots in the grid.
| void vtkPVPlotMatrixRepresentation::ClearSeriesVisibilities | ( | ) |
| void vtkPVPlotMatrixRepresentation::SetMarkerStyle | ( | int | style | ) |
| void vtkPVPlotMatrixRepresentation::SetActivePlotMarkerStyle | ( | int | style | ) |
| void vtkPVPlotMatrixRepresentation::SetMarkerSize | ( | double | size | ) |
| void vtkPVPlotMatrixRepresentation::SetActivePlotMarkerSize | ( | double | size | ) |
| void vtkPVPlotMatrixRepresentation::SetDensityMapVisibility | ( | bool | visible | ) |
| void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapVisibility | ( | bool | visible | ) |
| void vtkPVPlotMatrixRepresentation::SetDensityLineSize | ( | double | size | ) |
| void vtkPVPlotMatrixRepresentation::SetActivePlotDensityLineSize | ( | double | size | ) |
| void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapFirstDecileColor | ( | double | r, |
| double | g, | ||
| double | b | ||
| void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapMedianColor | ( | double | r, |
| double | g, | ||
| double | b | ||
| void vtkPVPlotMatrixRepresentation::SetActivePlotDensityMapLastDecileColor | ( | double | r, |
| double | g, | ||
| double | b | ||
| vtkScatterPlotMatrix* vtkPVPlotMatrixRepresentation::GetPlotMatrix | ( | ) | const |
overrideprotectedvirtual |
Overridden to pass information about changes to series visibility etc.
to the plot-matrix.
Add the plot matrix representation to the view.
Remove the plot matrix representation from the view.
