Base class for key frames. More...
#include <vtkPVKeyFrame.h>
| virtual void | RemoveAllKeyValues () |
| Removes all key values. More... | |
| virtual void | UpdateValue (double currenttime, vtkPVAnimationCue *cue, vtkPVKeyFrame *next) |
| This method will do the actual interpolation. More... | |
| virtual void | SetKeyTime (double) |
| Key time is the time at which this key frame is associated. More... | |
| virtual double | GetKeyTime () |
| virtual void | SetKeyValue (double val) |
| Get/Set the animated value at this key frame. More... | |
| virtual void | SetKeyValue (unsigned int index, double val) |
| double | GetKeyValue () |
| double | GetKeyValue (unsigned int index) |
| unsigned int | GetNumberOfKeyValues () |
| Set/Get the number of key values this key frame currently stores. More... | |
| virtual void | SetNumberOfKeyValues (unsigned int num) |
| static vtkPVKeyFrame * | SafeDownCast (vtkObject *o) |
| static vtkPVKeyFrame * | New () |
| vtkPVKeyFrame () | |
| ~vtkPVKeyFrame () override | |
Protected Attributes | |
| double | KeyTime |
| vtkPVKeyFrameInternals * | Internals |
A key frame is responsible to interpolate the curve between it self and a consequent key frame. A new subclass is needed for each type of interpolation available between two key frames. This class can be instantiated to create a no-action key frame.
Definition at line 24 of file vtkPVKeyFrame.h.
| typedef vtkObject vtkPVKeyFrame::Superclass |
Definition at line 27 of file vtkPVKeyFrame.h.
Reimplemented in vtkPVCompositeKeyFrame, vtkPVCameraKeyFrame, vtkPVSinusoidKeyFrame, vtkPVRampKeyFrame, vtkPVBooleanKeyFrame, and vtkPVExponentialKeyFrame.
Reimplemented in vtkPVSinusoidKeyFrame, and vtkPVRampKeyFrame.
KeyTime ranges from [0,1], where 0 is the start time of the cue for which this is a key frame and 1 is that cue's end time.
Reimplemented in vtkPVCompositeKeyFrame.
inlinevirtual |
Note that is the number of values is adjusted to fit the index specified in SetKeyValue.
Reimplemented in vtkPVCompositeKeyFrame, and vtkPVCameraKeyFrame.
Definition at line 48 of file vtkPVKeyFrame.h.
Definition at line 50 of file vtkPVKeyFrame.h.
| unsigned int vtkPVKeyFrame::GetNumberOfKeyValues | ( | ) |
currenttime is normalized to the time range between this key frame and the next key frame.
Reimplemented in vtkPVCompositeKeyFrame, vtkPVCameraKeyFrame, vtkPVSinusoidKeyFrame, vtkPVBooleanKeyFrame, vtkPVExponentialKeyFrame, and vtkPVRampKeyFrame.
Definition at line 78 of file vtkPVKeyFrame.h.
Definition at line 79 of file vtkPVKeyFrame.h.
