representation for "Histogram View". More...
#include <vtkPVHistogramChartRepresentation.h>
| typedef vtkXYChartRepresentation | Superclass |
Public Types inherited from vtkXYChartRepresentation | |
| typedef vtkChartRepresentation | Superclass |
Public Types inherited from vtkChartRepresentation | |
| typedef vtkPVDataRepresentation | Superclass |
Public Types inherited from vtkPVDataRepresentation | |
| enum | { SkippedUpdateDataEvent = vtkCommand::UserEvent + 91, UpdateTimeChangedEvent } |
| typedef vtkDataRepresentation | Superclass |
Public Types inherited from vtkDataRepresentation | |
| typedef vtkPassInputTypeAlgorithm | Superclass |
Public Types inherited from vtkPassInputTypeAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| void | SetHistogramColor (double r, double g, double b) |
| Sets the color for the histograms. More... | |
| void | SetUseColorMapping (bool colorMapping) |
| Sets the histogram to be color mapped by the scalar. More... | |
| void | SetLookupTable (vtkScalarsToColors *lut) |
| Sets the lookup table that is used for color mapping by the scalar. More... | |
| void | SetHistogramLineStyle (int style) |
| Set the line style for the histogram. More... | |
| vtkSmartPointer< vtkDataObject > | TransformInputData (vtkDataObject *data) override |
| Method to be overridden to transform input data to a vtkTable. More... | |
| bool | MapSelectionToInput (vtkSelection *) override |
| Overridden to transform id-based selection produced by the histogram view to a threshold-based selection. More... | |
| bool | MapSelectionToView (vtkSelection *sel) override |
| Inverse of MapSelectionToInput(). More... | |
| void | SetComponent (int) |
| Controls which input data component should be binned, for input arrays with more-than-one component. More... | |
| int | GetComponent () |
| void | SetBinCount (int) |
| Controls the number of bins N in the output histogram data. More... | |
| int | GetBinCount () |
| void | SetCenterBinsAroundMinAndMax (bool) |
| Get/Set if first and last bins must be centered around the min and max data. More... | |
| bool | GetCenterBinsAroundMinAndMax () |
| void | SetCustomBinRanges (double min, double max) |
| Get/Set custom bin ranges to use. More... | |
| double * | GetCustomBinRanges () |
| void | SetUseCustomBinRanges (bool) |
| When set to true, CustomBinRanges will be used instead of using the full range for the selected array. More... | |
| bool | GetUseCustomBinRanges () |
| void | SetInputArrayToProcess (int idx, int port, int connection, int fieldAssociation, const char *name) override |
| Overload the vtkAlgorithm method to update after the change. More... | |
Public Member Functions inherited from vtkXYChartRepresentation | |
| void | SetVisibility (bool visible) override |
| Set visibility of the representation. More... | |
| void | SetChartTypeToLine () |
| void | SetChartTypeToPoints () |
| void | SetChartTypeToBar () |
| void | SetChartTypeToStacked () |
| void | SetChartTypeToBag () |
| void | SetChartTypeToFunctionalBag () |
| void | SetChartTypeToArea () |
| vtkChartXY * | GetChart () |
| Returns the vtkChartXY instance from the view to which this representation is added. More... | |
| void | ClearSeriesVisibilities () |
| void | ClearLineThicknesses () |
| void | ClearLineStyles () |
| void | ClearColors () |
| void | ClearOpacities () |
| void | ClearAxisCorners () |
| void | ClearMarkerSizes () |
| void | ClearMarkerStyles () |
| void | ClearLabels () |
| virtual void | SetSelectionColor (double, double, double) |
| virtual void | SetSelectionColor (double [3]) |
| virtual double * | GetSelectionColor () |
| virtual void | GetSelectionColor (double &, double &, double &) |
| virtual void | GetSelectionColor (double [3]) |
| virtual void | SetChartType (int) |
| Get/Set the chart type, defaults to line chart. More... | |
| virtual int | GetChartType () |
| virtual void | SetXAxisSeriesName (const char *) |
| Set the series to use as the X-axis. More... | |
| virtual char * | GetXAxisSeriesName () |
| virtual void | SetUseIndexForXAxis (bool) |
| Set whether the index should be used for the x axis. More... | |
| virtual bool | GetUseIndexForXAxis () |
| void | SetSortDataByXAxis (bool val) |
| Get/set whether the points in the chart should be sorted by their x-axis value. More... | |
| virtual bool | GetSortDataByXAxis () |
| void | SetSeriesVisibility (const char *seriesname, bool visible) |
| Set/Clear the properties for Y series/columns. More... | |
| void | SetLineThickness (const char *name, double value) |
| void | SetLineStyle (const char *name, int value) |
| void | SetColor (const char *name, double r, double g, double b) |
| void | SetOpacity (const char *seriesname, double opacity) |
| void | SetAxisCorner (const char *name, int corner) |
| void | SetMarkerStyle (const char *name, int style) |
| void | SetMarkerSize (const char *name, double value) |
| void | SetLabel (const char *name, const char *label) |
| void | SetUseColorMapping (const char *name, bool useColorMapping) |
| void | SetLookupTable (const char *name, vtkScalarsToColors *lut) |
| const char * | GetLabel (const char *name) const |
| virtual void | SetSeriesLabelPrefix (const char *) |
| Get/Set the series label prefix. More... | |
| virtual char * | GetSeriesLabelPrefix () |
| bool | Export (vtkAbstractChartExporter *exporter) override |
| Called by vtkPVContextView::Export() to export the representation's data to a CSV file. More... | |
Public Member Functions inherited from vtkChartRepresentation | |
| void | SetSelectionRepresentation (vtkChartSelectionRepresentation *) |
| These must only be set during initialization before adding the representation to any views or calling Update(). More... | |
| This needs to be called on all instances of vtkGeometryRepresentation when the input is modified. More... | |
| void | SetCompositeDataSetIndex (unsigned int) |
| void | AddCompositeDataSetIndex (unsigned int) |
| void | ResetCompositeDataSetIndices () |
| unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) override |
| Override because of internal selection representations that need to be initialized as well. More... | |
| virtual std::string | GetDefaultSeriesLabel (const std::string &tableName, const std::string &columnName) |
| Method to provide the default name given the name of a table and a column in that table. More... | |
| void | SetFieldAssociation (int) |
| Set the field association for arrays to use. More... | |
| virtual int | GetFieldAssociation () |
| virtual void | SetFlattenTable (int) |
| Flatten the table, i.e. More... | |
| virtual int | GetFlattenTable () |
| virtual bool | Export (vtkAbstractChartExporter *vtkNotUsed(exporter)) |
Public Member Functions inherited from vtkPVDataRepresentation | |
| Return 0 if the Initialize() method was not called otherwise a unique ID that will be shared across the processes for that same object. More... | |
| Returns the data object that is rendered from the given input port. More... | |
| Returns the cache-key the representation is currently using. More... | |
| Retrieves an output port for the input data object at the specified port and connection index. More... | |
| Provides access to the view. More... | |
Returns the timestamp when RequestData was executed on the representation. More... | |
| bool | GetNeedsUpdate () |
| Returns true if the representation needs an update. More... | |
| Specify the array names used for the selection. More... | |
| Set the update time. More... | |
| Get whether the UpdateTime is valid. More... | |
| void | ResetUpdateTime () |
| Generally, caching is within the purview of the vtkPVView (and subclasses). More... | |
| Making these methods public. More... | |
| This is solely intended to simplify debugging and use for any other purpose is vehemently discouraged. More... | |
| This flag indicates if the representation is for a temporal pipeline. More... | |
Overridden to ensure that MarkModified is called. More... | |
Public Member Functions inherited from vtkDataRepresentation | |
Public Member Functions inherited from vtkPassInputTypeAlgorithm | |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Protected Types inherited from vtkChartRepresentation | |
| typedef std::map< std::string, std::pair< vtkSmartPointer< vtkTable >, unsigned int > > | MapOfTables |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
vtkPVHistogramChartRepresentation is the vtkPVDataRepresentation subclass for showing an data in the "Histogram View". The representation pipeline extracts histogram from the input dataset and then shows that in the view.
Definition at line 23 of file vtkPVHistogramChartRepresentation.h.
Definition at line 27 of file vtkPVHistogramChartRepresentation.h.
Reimplemented from vtkXYChartRepresentation.
Reimplemented from vtkChartRepresentation.
| void vtkPVHistogramChartRepresentation::SetComponent | ( | int | ) |
| int vtkPVHistogramChartRepresentation::GetComponent | ( | ) |
| void vtkPVHistogramChartRepresentation::SetBinCount | ( | int | ) |
| int vtkPVHistogramChartRepresentation::GetBinCount | ( | ) |
| void vtkPVHistogramChartRepresentation::SetCenterBinsAroundMinAndMax | ( | bool | ) |
This is only used when UseCustomBinRanges is set to false. Default is false.
| bool vtkPVHistogramChartRepresentation::GetCenterBinsAroundMinAndMax | ( | ) |
These are used only when UseCustomBinRanges is set to true.
| double* vtkPVHistogramChartRepresentation::GetCustomBinRanges | ( | ) |
| void vtkPVHistogramChartRepresentation::SetUseCustomBinRanges | ( | bool | ) |
By default, set to false.
| bool vtkPVHistogramChartRepresentation::GetUseCustomBinRanges | ( | ) |
| void vtkPVHistogramChartRepresentation::SetUseColorMapping | ( | bool | colorMapping | ) |
| void vtkPVHistogramChartRepresentation::SetLookupTable | ( | vtkScalarsToColors * | lut | ) |
| void vtkPVHistogramChartRepresentation::SetHistogramLineStyle | ( | int | style | ) |
overrideprotectedvirtual |
This method is called before actual render if this->MTime was modified since the last time this method was called.
Subclasses should override to update "appearance" related changes that don't affect data. When this method is called, you're assured that this->ContextView is valid. Note that this method will not be called if this->GetVisibility() returns false, this subclasses should also override SetVisibility() to hide "actors" and such.
Definition at line 126 of file vtkPVHistogramChartRepresentation.h.
