server side object used to gather information from, by vtkPVFileInformation. More...
#include <vtkPVFileInformationHelper.h>
| bool | GetActiveFileIsReadable () |
| Returns if this->Path is a readable file. More... | |
| bool | GetActiveFileIsDirectory () |
| Returns if this->Path is a directory. More... | |
| virtual void | SetPath (const char *) |
| Get/Set the path to the directory/file whose information we are interested in. More... | |
| virtual char * | GetPath () |
| virtual void | SetWorkingDirectory (const char *) |
| Get/Set the current working directory. More... | |
| virtual char * | GetWorkingDirectory () |
| virtual int | GetDirectoryListing () |
| Get/Set if the we should attempt to get the information of contents if Path is a directory. More... | |
| virtual void | SetDirectoryListing (int) |
| virtual void | DirectoryListingOn () |
| virtual void | DirectoryListingOff () |
| virtual int | GetSpecialDirectories () |
| Get/Set if the query is for special directories. More... | |
| virtual void | SetSpecialDirectories (int) |
| virtual void | SpecialDirectoriesOn () |
| virtual void | SpecialDirectoriesOff () |
| virtual bool | GetExamplesInSpecialDirectories () |
| Get/Set if special directories includes the Examples placeholder. More... | |
| virtual void | SetExamplesInSpecialDirectories (bool) |
| virtual void | ExamplesInSpecialDirectoriesOn () |
| virtual void | ExamplesInSpecialDirectoriesOff () |
| virtual int | GetFastFileTypeDetection () |
| When on, while listing a directory, whenever a group of files is encountered, we verify the type/accessibility of only the first file in the group and assume that all other have similar permissions. More... | |
| virtual void | SetFastFileTypeDetection (int) |
| virtual bool | GetGroupFileSequences () |
| Groups file sequences when found. More... | |
| virtual void | SetGroupFileSequences (bool) |
| virtual void | GroupFileSequencesOn () |
| virtual void | GroupFileSequencesOff () |
| virtual char * | GetPathSeparator () |
| Returns the platform specific path separator. More... | |
| virtual bool | GetReadDetailedFileInformation () |
| When off, while listing a directory we skip the expensive fstat call on every file and instead return only their names and basic information about them. More... | |
| virtual void | SetReadDetailedFileInformation (bool) |
| static vtkPVFileInformationHelper * | New () |
| static vtkPVFileInformationHelper * | SafeDownCast (vtkObject *o) |
| vtkPVFileInformationHelper () | |
| ~vtkPVFileInformationHelper () override | |
| virtual void | SetPathSeparator (const char *) |
Protected Attributes | |
| char * | Path |
| char * | WorkingDirectory |
| int | DirectoryListing |
| int | SpecialDirectories |
| int | FastFileTypeDetection |
| bool | GroupFileSequences |
| bool | ExamplesInSpecialDirectories |
| bool | ReadDetailedFileInformation |
| char * | PathSeparator |
When collection information, ProcessModule cannot pass parameters to the information object. In case of vtkPVFileInformation, we need data on the server side such as which directory/file are we concerned with. To make such information available, we use vtkPVFileInformationHelper. One creates a server side representation of vtkPVFileInformationHelper and sets attributes on it, then requests a gather information on the helper object.
Definition at line 24 of file vtkPVFileInformationHelper.h.
Definition at line 28 of file vtkPVFileInformationHelper.h.
This is ignored when SpecialDirectories is set to True.
This is needed if Path is relative. The relative path will be converted to absolute path using the working directory specified before obtaining information about it. If 0 (default), then the application's current working directory will be used to flatten relative paths.
Default value is 0. This is ignored when SpecialDirectories is set to True.
Off by default. If set to true, Path and DirectoryListing are ignored and the vtkPVFileInformation object is populated with information about special directories such as "My Documents", "Desktop" etc on Windows systems and "Home" on Unix based systems.
On by default.
On by default.
On by default.
On by default.
On by default.
On by default.
A file sequence could be [foo1.png, foo2.png, foo6.png]. When turned on, the series of files is grouped and our sequence example is named foo..png and original files are discarded from the listing. By default, this flag is set to true.
| bool vtkPVFileInformationHelper::GetActiveFileIsReadable | ( | ) |
| bool vtkPVFileInformationHelper::GetActiveFileIsDirectory | ( | ) |
Defaults to off. To enable the detailed information like file size and modified time turn this on.
protectedvirtual |
Definition at line 144 of file vtkPVFileInformationHelper.h.
Definition at line 145 of file vtkPVFileInformationHelper.h.
Definition at line 146 of file vtkPVFileInformationHelper.h.
Definition at line 147 of file vtkPVFileInformationHelper.h.
Definition at line 148 of file vtkPVFileInformationHelper.h.
Definition at line 149 of file vtkPVFileInformationHelper.h.
Definition at line 150 of file vtkPVFileInformationHelper.h.
Definition at line 152 of file vtkPVFileInformationHelper.h.
Definition at line 153 of file vtkPVFileInformationHelper.h.
