#include <vtkPVDataDeliveryManagerInternals.h>
| class | vtkItem |
| struct | vtkRepresentedData |
| typedef std::pair< unsigned int, int > | ReprPortType |
| typedef std::map< ReprPortType, std::pair< vtkItem, vtkItem > > | ItemsMapType |
| typedef std::map< unsigned int, vtkWeakPointer< vtkPVDataRepresentation > > | RepresentationsMapType |
| vtkItem * | GetItem (unsigned int index, bool use_second, int port, bool create_if_needed=false) |
| vtkItem * | GetItem (vtkPVDataRepresentation *repr, bool use_second, int port, bool create_if_needed=false) |
| int | GetNumberOfPorts (vtkPVDataRepresentation *repr) |
| unsigned long | GetVisibleDataSize (bool use_second_if_available, vtkPVDataDeliveryManager *dmgr) |
| bool | IsRepresentationVisible (unsigned int id) const |
| void | ClearCache (vtkPVDataRepresentation *repr) |
| void | ClearCache (unsigned int id) |
Public Attributes | |
| ItemsMapType | ItemsMap |
| RepresentationsMapType | RepresentationsMap |
Friends | |
| class | vtkItem |
Definition at line 21 of file vtkPVDataDeliveryManagerInternals.h.
| typedef std::pair<unsigned int, int> vtkPVDataDeliveryManager::vtkInternals::ReprPortType |
Definition at line 193 of file vtkPVDataDeliveryManagerInternals.h.
| typedef std::map<ReprPortType, std::pair<vtkItem, vtkItem> > vtkPVDataDeliveryManager::vtkInternals::ItemsMapType |
Definition at line 194 of file vtkPVDataDeliveryManagerInternals.h.
| typedef std::map<unsigned int, vtkWeakPointer<vtkPVDataRepresentation> > vtkPVDataDeliveryManager::vtkInternals::RepresentationsMapType |
Definition at line 197 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 199 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 215 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 221 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 230 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 259 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 266 of file vtkPVDataDeliveryManagerInternals.h.
Definition at line 267 of file vtkPVDataDeliveryManagerInternals.h.
friend |
Definition at line 23 of file vtkPVDataDeliveryManagerInternals.h.
| ItemsMapType vtkPVDataDeliveryManager::vtkInternals::ItemsMap |
Definition at line 279 of file vtkPVDataDeliveryManagerInternals.h.
| RepresentationsMapType vtkPVDataDeliveryManager::vtkInternals::RepresentationsMap |
Definition at line 280 of file vtkPVDataDeliveryManagerInternals.h.
