| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool val) override |
| | Set the visibility for this representation. More...
| virtual void | SetRepresentation (const char *) |
| | Overload to set representation type using string. More...
| vtkDataObject * | GetRenderedDataObject (int port) override |
| void | SetUseOutline (int) |
| | Use Outline representation is NOT SUPPORTED by this representation. More...
| virtual void | SetMapScalars (bool val) |
| | Sets if scalars are mapped through a color-map or are used directly as colors (rgb). More...
| virtual void | SetStatic (int val) |
| | Turn on/off flag to control whether the mapper's data is static. More...
| virtual void | SetSelection (vtkSelection *selection) |
| | Sets the selection used by the mapper. More...
| vtkActor * | GetActor () |
| | Provides access to the actor used by this representation. More...
| const char * | GetColorArrayName () |
| | Convenience method to get the array name used to scalar color with. More...
| virtual void | SetShaderReplacements (const char *) |
| | Specify shader replacements using a Json string. More...
| virtual bool | GetAdaptiveDecimation () |
| | Use adaptive decimation to only render the part inside the camera frustum. More...
| virtual void | SetAdaptiveDecimation (bool) |
| virtual void | AdaptiveDecimationOn () |
| virtual void | AdaptiveDecimationOff () |
| virtual void | SetAmbient (double) |
| | Set/Get the lighting properties of the object. More...
| virtual void | SetDiffuse (double) |
| virtual void | SetSpecular (double) |
| virtual double | GetAmbient () |
| virtual double | GetDiffuse () |
| virtual double | GetSpecular () |
| virtual void | SetRepresentation (int) |
| | Set the representation type: WIREFRAME SURFACE SURFACE_WITH_EDGES. More...
| virtual int | GetRepresentation () |
| virtual void | SetAmbientColor (double r, double g, double b) |
| | Forwarded to vtkProperty. More...
| virtual void | SetBaseIOR (double val) |
| virtual void | SetBaseColorTexture (vtkTexture *tex) |
| virtual void | SetCoatIOR (double val) |
| virtual void | SetCoatStrength (double val) |
| virtual void | SetCoatRoughness (double val) |
| virtual void | SetCoatColor (double a, double b, double c) |
| virtual void | SetCoatNormalScale (double val) |
| virtual void | SetColor (double r, double g, double b) |
| virtual void | SetDiffuseColor (double r, double g, double b) |
| virtual void | SetEdgeColor (double r, double g, double b) |
| virtual void | SetEdgeTint (double r, double g, double b) |
| virtual void | SetEmissiveFactor (double rval, double gval, double bval) |
| virtual void | SetEmissiveTexture (vtkTexture *tex) |
| virtual void | SetInteractiveSelectionColor (double r, double g, double b) |
| virtual void | SetInterpolation (int val) |
| virtual void | SetLineWidth (double val) |
| virtual void | SetMaterial (std::string name) |
| virtual void | SetMaterialTexture (vtkTexture *tex) |
| virtual void | SetMetallic (double val) |
| virtual void | SetNormalScale (double val) |
| virtual void | SetNormalTexture (vtkTexture *tex) |
| virtual void | SetOcclusionStrength (double val) |
| virtual void | SetOpacity (double val) |
| virtual void | SetPointSize (double val) |
| virtual void | SetRenderLinesAsTubes (bool) |
| virtual void | SetRenderPointsAsSpheres (bool) |
| virtual void | SetRoughness (double val) |
| virtual void | SetSpecularColor (double r, double g, double b) |
| virtual void | SetSpecularPower (double val) |
| virtual void | SetFlipTextures (bool) |
| | Forwarded to Actor. More...
| virtual void | SetOrientation (double, double, double) |
| virtual void | SetOrigin (double, double, double) |
| virtual void | SetPickable (int val) |
| virtual void | SetPosition (double, double, double) |
| virtual void | SetScale (double, double, double) |
| virtual void | SetTexture (vtkTexture *) |
| virtual void | SetUserTransform (const double[16]) |
| virtual void | SetEnableScaling (int val) |
| | Forwarded to OSPray (via the Actor) More...
| virtual void | SetScalingArrayName (const char *val) |
| virtual void | SetScalingFunction (vtkPiecewiseFunction *pwf) |
| virtual void | SetMaterial (const char *val) |
| virtual void | SetLuminosity (double val) |
| virtual void | SetRepeatTextures (bool) |
| | Forwarded to all textures (and stored for later re-use) More...
| virtual bool | GetRepeatTextures () |
| virtual void | SetInterpolateTextures (bool) |
| virtual bool | GetInterpolateTextures () |
| virtual void | SetUseMipmapTextures (bool) |
| virtual bool | GetUseMipmapTextures () |
| virtual void | SetInterpolateScalarsBeforeMapping (int val) |
| | Forwarded to Mapper and LODMapper. More...
| virtual void | SetLookupTable (vtkScalarsToColors *val) |
| virtual void | SetUseShaderReplacements (bool) |
| | Specify whether or not to shader replacements string must be used. More...
| virtual bool | GetUseShaderReplacements () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| | Specify the array names used for the selection. More...
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkHyperTreeGridRepresentation () |
| | ~vtkHyperTreeGridRepresentation () override |
| virtual void | SetupDefaults () |
| | This method is called in the constructor. More...
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| virtual void | UpdateColoringParameters () |
| | Passes on parameters to vtkProperty and vtkMapper. More...
| virtual vtkActor * | GetRenderedProp () |
| | Used in ConvertSelection to locate the prop used for actual rendering. More...
| void | UpdateShaderReplacements () |
| | Update the mapper with the shader replacement strings if feature is enabled. More...
| virtual bool | NeedsOrderedCompositing () |
| | Returns true if this representation has translucent geometry. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
