actor for a cube-axes like prop in the 3D view. More...
#include <vtkGridAxes3DActor.h>
| enum | FaceMasks { MIN_YZ = 0x01, MIN_ZX = 0x02, MIN_XY = 0x04, MAX_YZ = 0x08, MAX_ZX = 0x010, MAX_XY = 0x020 } |
| Values for FaceMask. More... | |
| enum | LabelMasks { MIN_X = vtkGridAxesHelper::MIN_X, MIN_Y = vtkGridAxesHelper::MIN_Y, MIN_Z = vtkGridAxesHelper::MIN_Z, MAX_X = vtkGridAxesHelper::MAX_X, MAX_Y = vtkGridAxesHelper::MAX_Y, MAX_Z = vtkGridAxesHelper::MAX_Z } |
| typedef vtkProp3D | Superclass |
Public Types inherited from vtkProp3D | |
| typedef vtkProp | Superclass |
Public Types inherited from vtkProp | |
| void | ShallowCopy (vtkProp *prop) override |
| Shallow copy from another vtkGridAxes3DActor. More... | |
| void | GetActors (vtkPropCollection *) override |
| For some exporters and other other operations we must be able to collect all the actors or volumes. More... | |
| void | UpdateGeometry (vtkViewport *vp) |
| Updates the billboard geometry without performing any rendering, to assist GetActors(). More... | |
| void | SetUseCustomLabels (int axis, bool val) |
| Set whether the specified axis should use custom labels instead of automatically determined ones. More... | |
| void | SetXUseCustomLabels (bool val) |
| void | SetYUseCustomLabels (bool val) |
| void | SetZUseCustomLabels (bool val) |
| void | SetNumberOfLabels (int axis, vtkIdType val) |
| void | SetNumberOfXLabels (vtkIdType val) |
| void | SetNumberOfYLabels (vtkIdType val) |
| void | SetNumberOfZLabels (vtkIdType val) |
| void | SetLabel (int axis, vtkIdType index, double value) |
| void | SetXLabel (vtkIdType index, double value) |
| void | SetYLabel (vtkIdType index, double value) |
| void | SetZLabel (vtkIdType index, double value) |
| virtual void | GetRenderedBounds (double bounds[6]) |
| Get an bounding box that is expected to contain all rendered elements, since GetBounds() returns the bounding box the grid axes describes. More... | |
| int | RenderOpaqueGeometry (vtkViewport *) override |
| int | RenderTranslucentPolygonalGeometry (vtkViewport *viewport) override |
| int | RenderOverlay (vtkViewport *viewport) override |
| int | HasTranslucentPolygonalGeometry () override |
| void | ReleaseGraphicsResources (vtkWindow *) override |
| virtual void | SetGridBounds (double, double, double, double, double, double) |
| Set the bounding box defining the grid space. More... | |
| virtual void | SetGridBounds (double [6]) |
| virtual double * | GetGridBounds () |
| virtual void | GetGridBounds (double &, double &, double &, double &, double &, double &) |
| virtual void | GetGridBounds (double [6]) |
| virtual void | SetFaceMask (unsigned int mask) |
| Set the mask to select faces. More... | |
| virtual unsigned int | GetFaceMask () |
| virtual void | SetLabelMask (unsigned int mask) |
| Set the axis to label. More... | |
| unsigned int | GetLabelMask () |
| virtual void | SetLabelUniqueEdgesOnly (bool) |
| Set to true to only label edges shared with 1 face. More... | |
| virtual bool | GetLabelUniqueEdgesOnly () |
| void | SetGenerateGrid (bool val) |
| Turn off to not generate polydata for the plane's grid. More... | |
| bool | GetGenerateGrid () |
| virtual void | GenerateGridOn () |
| virtual void | GenerateGridOff () |
| void | SetGenerateEdges (bool val) |
| Turn off to not generate the polydata for the plane's edges. More... | |
| bool | GetGenerateEdges () |
| virtual void | GenerateEdgesOn () |
| virtual void | GenerateEdgesOff () |
| void | SetGenerateTicks (bool val) |
| Turn off to not generate the markers for the tick positions. More... | |
| bool | GetGenerateTicks () |
| virtual void | GenerateTicksOn () |
| virtual void | GenerateTicksOff () |
| void | SetProperty (vtkProperty *) |
| Get/Set the property used to control the appearance of the rendered grid. More... | |
| vtkProperty * | GetProperty () |
| void | SetTitleTextProperty (int axis, vtkTextProperty *) |
| Get/Set the vtkTextProperty for the title for each the axes. More... | |
| void | SetXTitleTextProperty (vtkTextProperty *prop) |
| void | SetYTitleTextProperty (vtkTextProperty *prop) |
| void | SetZTitleTextProperty (vtkTextProperty *prop) |
| vtkTextProperty * | GetTitleTextProperty (int axis) |
| void | SetTitle (int axis, const std::string &title) |
| Get/Set the text to use for titles for the axis. More... | |
| void | SetXTitle (const std::string &title) |
| void | SetYTitle (const std::string &title) |
| void | SetZTitle (const std::string &title) |
| const std::string & | GetTitle (int axis) |
| void | SetLabelTextProperty (int axis, vtkTextProperty *) |
| Get/Set the vtkTextProperty that governs how the axis labels are displayed. More... | |
| void | SetXLabelTextProperty (vtkTextProperty *prop) |
| void | SetYLabelTextProperty (vtkTextProperty *prop) |
| void | SetZLabelTextProperty (vtkTextProperty *prop) |
| vtkTextProperty * | GetLabelTextProperty (int axis) |
| void | SetNotation (int axis, int notation) |
| Get/set the numerical notation, standard, scientific or mixed (0, 1, 2). More... | |
| void | SetXNotation (int notation) |
| void | SetYNotation (int notation) |
| void | SetZNotation (int notation) |
| int | GetNotation (int axis) |
| void | SetPrecision (int axis, int val) |
| Get/set the numerical precision to use, default is 2. More... | |
| void | SetXPrecision (int val) |
| void | SetYPrecision (int val) |
| void | SetZPrecision (int val) |
| int | GetPrecision (int axis) |
| void | SetTickLabelFunction (int axis, std::function< double(double)> func) |
| Get/Set the function that will be applied to the tick label of each axis. More... | |
| std::function< double(double)> | GetTickLabelFunction (int axis) |
| double * | GetBounds () override |
| Returns the prop bounds. More... | |
| virtual void | SetForceOpaque (bool) |
| If true, the actor will always be rendered during the opaque pass. More... | |
| virtual bool | GetForceOpaque () |
| virtual void | ForceOpaqueOn () |
| virtual void | ForceOpaqueOff () |
Public Member Functions inherited from vtkProp3D | |
| vtkProp3D * | NewInstance () const |
| virtual void | SetPosition (double pos[3]) |
| virtual double * | GetPosition () |
| virtual void | GetPosition (double data[3]) |
| void | AddPosition (double deltaPosition[3]) |
| void | AddPosition (double deltaX, double deltaY, double deltaZ) |
| double * | GetCenter () |
| double * | GetXRange () |
| double * | GetYRange () |
| double * | GetZRange () |
| double | GetLength () |
| void | RotateX (double) |
| void | RotateY (double) |
| void | RotateZ (double) |
| void | RotateWXYZ (double w, double x, double y, double z) |
| void | SetOrientation (double x, double y, double z) |
| void | SetOrientation (double orientation[3]) |
| double * | GetOrientationWXYZ () |
| void | AddOrientation (double x, double y, double z) |
| void | AddOrientation (double orentation[3]) |
| void | PokeMatrix (vtkMatrix4x4 *matrix) |
| void | InitPathTraversal () |
| vtkMTimeType | GetMTime () |
| vtkMTimeType | GetUserTransformMatrixMTime () |
| virtual void | ComputeMatrix () |
| virtual void | SetPosition (double x, double y, double z) |
| virtual void | SetOrigin (double x, double y, double z) |
| virtual void | SetOrigin (const double pos[3]) |
| virtual double * | GetOrigin () |
| virtual void | GetOrigin (double data[3]) |
| virtual void | SetScale (double x, double y, double z) |
| virtual void | SetScale (double scale[3]) |
| virtual double * | GetScale () |
| virtual void | GetScale (double data[3]) |
| void | SetScale (double s) |
| void | SetUserTransform (vtkLinearTransform *transform) |
| virtual vtkLinearTransform * | GetUserTransform () |
| void | SetUserMatrix (vtkMatrix4x4 *matrix) |
| vtkMatrix4x4 * | GetUserMatrix () |
| virtual void | GetMatrix (vtkMatrix4x4 *m) |
| virtual void | GetMatrix (double m[16]) |
| void | GetBounds (double bounds[6]) |
| double * | GetOrientation () |
| void | GetOrientation (double orentation[3]) |
| vtkMatrix4x4 * | GetMatrix () |
| virtual int | GetIsIdentity () |
Public Member Functions inherited from vtkProp | |
| vtkProp * | NewInstance () const |
| virtual void | Pick () |
| virtual bool | HasKeys (vtkInformation *requiredKeys) |
| virtual void | BuildPaths (vtkAssemblyPaths *paths, vtkAssemblyPath *path) |
| virtual void | GetActors2D (vtkPropCollection *) |
| virtual void | GetVolumes (vtkPropCollection *) |
| virtual void | SetVisibility (int) |
| virtual int | GetVisibility () |
| virtual void | VisibilityOn () |
| virtual void | VisibilityOff () |
| virtual void | SetPickable (int) |
| virtual int | GetPickable () |
| virtual void | PickableOn () |
| virtual void | PickableOff () |
| virtual void | SetDragable (int) |
| virtual int | GetDragable () |
| virtual void | DragableOn () |
| virtual void | DragableOff () |
| virtual vtkMTimeType | GetRedrawMTime () |
| virtual void | SetUseBounds (bool) |
| virtual bool | GetUseBounds () |
| virtual void | UseBoundsOn () |
| virtual void | UseBoundsOff () |
| virtual vtkAssemblyPath * | GetNextPath () |
| virtual int | GetNumberOfPaths () |
| virtual void | PokeMatrix (vtkMatrix4x4 *vtkNotUsed(matrix)) |
| virtual vtkInformation * | GetPropertyKeys () |
| virtual void | SetPropertyKeys (vtkInformation *keys) |
| virtual int | RenderVolumetricGeometry (vtkViewport *) |
| virtual bool | RenderFilteredOpaqueGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredTranslucentPolygonalGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredVolumetricGeometry (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual bool | RenderFilteredOverlay (vtkViewport *v, vtkInformation *requiredKeys) |
| virtual double | GetEstimatedRenderTime (vtkViewport *) |
| virtual double | GetEstimatedRenderTime () |
| virtual void | SetEstimatedRenderTime (double t) |
| virtual void | RestoreEstimatedRenderTime () |
| virtual void | AddEstimatedRenderTime (double t, vtkViewport *vtkNotUsed(vp)) |
| virtual void | SetAllocatedRenderTime (double t, vtkViewport *vtkNotUsed(v)) |
| virtual double | GetAllocatedRenderTime () |
| void | SetRenderTimeMultiplier (double t) |
| virtual double | GetRenderTimeMultiplier () |
| virtual bool | GetSupportsSelection () |
| virtual int | GetNumberOfConsumers () |
| void | AddConsumer (vtkObject *c) |
| void | RemoveConsumer (vtkObject *c) |
| vtkObject * | GetConsumer (int i) |
| int | IsConsumer (vtkObject *c) |
| vtkGridAxes3DActor () | |
| ~vtkGridAxes3DActor () override | |
| virtual void | Update (vtkViewport *viewport) |
Protected Member Functions inherited from vtkProp3D | |
| vtkProp3D () | |
| ~vtkProp3D () | |
Protected Member Functions inherited from vtkProp | |
| vtkProp () | |
| ~vtkProp () | |
vtkGridAxes3DActor is an alternate implementation for something like the vtkCubeAxesActor which can be used to render a 3D grid in a scene. It uses vtkGridAxes2DActor to render individual axes planes for the box.
Definition at line 30 of file vtkGridAxes3DActor.h.
Definition at line 34 of file vtkGridAxes3DActor.h.
Developer note: these are deliberately in the same order as vtkGridAxesHelper::Faces which is same order as faces in vtkVoxel.
| Enumerator | |
| MIN_YZ | |
| MIN_ZX | |
| MIN_XY | |
| MAX_YZ | |
| MAX_ZX | |
| MAX_XY | |
Definition at line 57 of file vtkGridAxes3DActor.h.
| Enumerator | |
| MIN_X | |
| MIN_Y | |
| MIN_Z | |
| MAX_X | |
| MAX_Y | |
| MAX_Z | |
Definition at line 77 of file vtkGridAxes3DActor.h.
Reimplemented in vtkPVGridAxes3DActor.
Reimplemented from vtkProp3D.
This, together with the Face identify which planar surface this class is interested in. This class is designed to work with a single planar surface.
The faces rendered can be a subset of the faces selected using the FaceMask based on the BackfaceCulling and FrontfaceCulling flags set on the Property.
| unsigned int vtkGridAxes3DActor::GetLabelMask | ( | ) |
These methods are used in that process. In case the viewport is not a consumer of this prop: call UpdateGeometry() first for updated viewport-specific billboard geometry.
Reimplemented from vtkProp.
| void vtkGridAxes3DActor::UpdateGeometry | ( | vtkViewport * | vp | ) |
Note that if all faces are being rendered, this will generate no labels.
| void vtkGridAxes3DActor::SetGenerateGrid | ( | bool | val | ) |
| bool vtkGridAxes3DActor::GetGenerateGrid | ( | ) |
| void vtkGridAxes3DActor::SetGenerateEdges | ( | bool | val | ) |
Which edges are rendered is defined by the EdgeMask.
| bool vtkGridAxes3DActor::GetGenerateEdges | ( | ) |
| void vtkGridAxes3DActor::SetGenerateTicks | ( | bool | val | ) |
Which edges are rendered is defined by the TickMask.
| bool vtkGridAxes3DActor::GetGenerateTicks | ( | ) |
| void vtkGridAxes3DActor::SetProperty | ( | vtkProperty * | ) |
| vtkProperty* vtkGridAxes3DActor::GetProperty | ( | ) |
| void vtkGridAxes3DActor::SetTitleTextProperty | ( | int | axis, |
| vtkTextProperty * | |||
Note that the alignment properties are not used.
Definition at line 166 of file vtkGridAxes3DActor.h.
Definition at line 167 of file vtkGridAxes3DActor.h.
Definition at line 168 of file vtkGridAxes3DActor.h.
| vtkTextProperty* vtkGridAxes3DActor::GetTitleTextProperty | ( | int | axis | ) |
| void vtkGridAxes3DActor::SetTitle | ( | int | axis, |
| const std::string & | title | ||
Setting the title to an empty string will hide the title label for that axis.
Definition at line 178 of file vtkGridAxes3DActor.h.
Definition at line 179 of file vtkGridAxes3DActor.h.
Definition at line 180 of file vtkGridAxes3DActor.h.
| const std::string& vtkGridAxes3DActor::GetTitle | ( | int | axis | ) |
| void vtkGridAxes3DActor::SetUseCustomLabels | ( | int | axis, |
| bool | val | ||
Definition at line 189 of file vtkGridAxes3DActor.h.
Definition at line 190 of file vtkGridAxes3DActor.h.
Definition at line 191 of file vtkGridAxes3DActor.h.
Definition at line 194 of file vtkGridAxes3DActor.h.
Definition at line 195 of file vtkGridAxes3DActor.h.
Definition at line 196 of file vtkGridAxes3DActor.h.
Definition at line 199 of file vtkGridAxes3DActor.h.
Definition at line 200 of file vtkGridAxes3DActor.h.
Definition at line 201 of file vtkGridAxes3DActor.h.
| void vtkGridAxes3DActor::SetLabelTextProperty | ( | int | axis, |
Definition at line 212 of file vtkGridAxes3DActor.h.
Definition at line 213 of file vtkGridAxes3DActor.h.
Definition at line 214 of file vtkGridAxes3DActor.h.
| vtkTextProperty* vtkGridAxes3DActor::GetLabelTextProperty | ( | int | axis | ) |
Accepted values are vtkAxis::AUTO, vtkAxis::FIXED, vtkAxis::CUSTOM.
Definition at line 224 of file vtkGridAxes3DActor.h.
Definition at line 225 of file vtkGridAxes3DActor.h.
Definition at line 226 of file vtkGridAxes3DActor.h.
Definition at line 235 of file vtkGridAxes3DActor.h.
Definition at line 236 of file vtkGridAxes3DActor.h.
Definition at line 237 of file vtkGridAxes3DActor.h.
| void vtkGridAxes3DActor::SetTickLabelFunction | ( | int | axis, |
| std::function< double(double)> | func | ||
| std::function<double(double)> vtkGridAxes3DActor::GetTickLabelFunction | ( | int | axis | ) |
protectedvirtual |
Definition at line 291 of file vtkGridAxes3DActor.h.
Definition at line 292 of file vtkGridAxes3DActor.h.
Definition at line 293 of file vtkGridAxes3DActor.h.
Definition at line 294 of file vtkGridAxes3DActor.h.
Definition at line 295 of file vtkGridAxes3DActor.h.
Definition at line 296 of file vtkGridAxes3DActor.h.
Definition at line 297 of file vtkGridAxes3DActor.h.
Definition at line 299 of file vtkGridAxes3DActor.h.
Definition at line 301 of file vtkGridAxes3DActor.h.
