| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetMeshVisibility (bool visible) |
| | Toggle the visibility of the original mesh. More...
| void | SetVisibility (bool) override |
| | Get/Set the visibility for this representation. More...
| void | SetMaskArray (const char *val) |
| void | SetScaleArray (const char *val) |
| void | SetOrientationArray (const char *val) |
| void | SetSourceIndexArray (const char *val) |
| void | SetScaling (bool val) |
| void | SetScaleMode (int val) |
| void | SetScaleFactor (double val) |
| void | SetOrient (bool val) |
| void | SetOrientationMode (int val) |
| void | SetMasking (bool val) |
| void | SetSourceIndexing (bool val) |
| void | SetUseSourceTableTree (bool val) |
| void | SetUseCullingAndLOD (bool val) |
| void | SetNumberOfLOD (int val) |
| void | SetLODDistanceAndTargetReduction (int index, float dist, float reduc) |
| void | SetColorByLODIndex (bool val) |
| void | SetInterpolateScalarsBeforeMapping (int val) override |
| void | SetLookupTable (vtkScalarsToColors *val) override |
| void | SetMapScalars (int val) override |
| | Sets if scalars are mapped through a color-map or are used directly as colors. More...
| void | SetStatic (int val) override |
| void | SetOrientation (double, double, double) override |
| void | SetOrigin (double, double, double) override |
| void | SetPickable (int val) override |
| void | SetPosition (double, double, double) override |
| void | SetScale (double, double, double) override |
| void | SetTexture (vtkTexture *) override |
| void | SetUserTransform (const double[16]) override |
| virtual void | SetSuppressLOD (bool suppress) |
| | Enable/Disable LOD;. More...
| virtual void | SetRepresentation (const char *) |
| | Overload to set representation type using string. More...
| vtkDataObject * | GetRenderedDataObject (int port) override |
| virtual void | SetNormalArray (const char *val) |
| | Set the normal array used for smooth shading. More...
| virtual void | SetTCoordArray (const char *val) |
| | Set the texture coordinates array used for texture mapping. More...
| virtual void | SetTangentArray (const char *val) |
| | Set the tangent coordinates array used for normal mapping. More...
| virtual void | SetUseOutline (int) |
| void | SetTriangulate (int) |
| void | SetNonlinearSubdivisionLevel (int) |
| void | SetMatchBoundariesIgnoringCellOrder (int) |
| virtual void | SetGenerateFeatureEdges (bool) |
| void | SetComputePointNormals (bool) |
| void | SetSplitting (bool) |
| void | SetFeatureAngle (double) |
| virtual void | SetAmbientColor (double r, double g, double b) |
| virtual void | SetColor (double r, double g, double b) |
| virtual void | SetDiffuseColor (double r, double g, double b) |
| virtual void | SetLighting (bool lighting) |
| virtual void | SetEdgeColor (double r, double g, double b) |
| virtual void | SetInteractiveSelectionColor (double r, double g, double b) |
| virtual void | SetInterpolation (int val) |
| virtual void | SetLineWidth (double val) |
| virtual void | SetOpacity (double val) |
| virtual void | SetEdgeOpacity (double val) |
| virtual void | SetPointSize (double val) |
| virtual void | SetSpecularColor (double r, double g, double b) |
| virtual void | SetSpecularPower (double val) |
| virtual void | SetLuminosity (double val) |
| virtual void | SetRenderPointsAsSpheres (bool) |
| virtual void | SetRenderLinesAsTubes (bool) |
| virtual void | SetRoughness (double val) |
| virtual void | SetMetallic (double val) |
| virtual void | SetEdgeTint (double r, double g, double b) |
| virtual void | SetAnisotropy (double val) |
| virtual void | SetAnisotropyRotation (double val) |
| virtual void | SetBaseIOR (double val) |
| virtual void | SetCoatIOR (double val) |
| virtual void | SetCoatStrength (double val) |
| virtual void | SetCoatRoughness (double val) |
| virtual void | SetCoatNormalScale (double val) |
| virtual void | SetCoatColor (double r, double g, double b) |
| virtual void | SetBaseColorTexture (vtkTexture *tex) |
| virtual void | SetMaterialTexture (vtkTexture *tex) |
| virtual void | SetAnisotropyTexture (vtkTexture *tex) |
| virtual void | SetNormalTexture (vtkTexture *tex) |
| virtual void | SetCoatNormalTexture (vtkTexture *tex) |
| virtual void | SetEmissiveTexture (vtkTexture *tex) |
| virtual void | SetNormalScale (double val) |
| virtual void | SetOcclusionStrength (double val) |
| virtual void | SetEmissiveFactor (double rval, double gval, double bval) |
| virtual void | SetShowTexturesOnBackface (bool) |
| virtual void | SetFlipTextures (bool) |
| virtual void | SetTextureTransform (vtkTransform *) |
| virtual vtkTransform * | GetTextureTransform () |
| virtual void | SetRepeatTextures (bool) |
| virtual bool | GetRepeatTextures () |
| virtual void | SetInterpolateTextures (bool) |
| virtual bool | GetInterpolateTextures () |
| virtual void | SetUseMipmapTextures (bool) |
| virtual bool | GetUseMipmapTextures () |
| virtual void | SetColorMissingArraysWithNanColor (bool val) |
| virtual void | SetSeamlessU (bool) |
| virtual void | SetSeamlessV (bool) |
| virtual void | SetSelection (vtkSelection *selection) |
| | Sets the selection used by the mapper. More...
| vtkPVLODActor * | GetActor () |
| | Provides access to the actor used by this representation. More...
| const char * | GetColorArrayName () |
| | Convenience method to get the array name used to scalar color with. More...
| virtual void | SetMaterial (const char *) |
| | For OSPRay, choose from among available materials. More...
| virtual void | SetShaderReplacements (const char *) |
| | Specify shader replacements using a Json string. More...
| void | SetArrayIdNames (const char *pointArray, const char *cellArray) override |
| | Specify the array names used for the selection. More...
| void | SetBlockColorsDistinctValues (int distinctValues) |
| | Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More...
| int | GetBlockColorsDistinctValues () |
| virtual void | DisableLightingOn () |
| | Disables the lighting on the object. More...
| virtual void | DisableLightingOff () |
| virtual void | SetDisableLighting (bool) |
| virtual bool | GetDisableLighting () |
| virtual void | SetAmbient (double) |
| | Set the lighting properties of the object. More...
| virtual void | SetDiffuse (double) |
| virtual void | SetSpecular (double) |
| virtual double | GetAmbient () |
| virtual double | GetDiffuse () |
| virtual double | GetSpecular () |
| void | SetCoordinateShiftScaleMethod (int val) |
| | Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
| int | GetCoordinateShiftScaleMethod () |
| virtual void | SetRepresentation (int) |
| | Set the representation type. More...
| virtual int | GetRepresentation () |
| virtual void | SetRequestGhostCellsIfNeeded (bool) |
| | Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
| virtual bool | GetRequestGhostCellsIfNeeded () |
| virtual void | RequestGhostCellsIfNeededOn () |
| virtual void | RequestGhostCellsIfNeededOff () |
| virtual void | SetActiveAssembly (const char *) |
| | Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More...
| virtual char * | GetActiveAssembly () |
| void | AddBlockSelector (const char *selector) |
| | Update list of selectors that determine the selected blocks. More...
| void | RemoveAllBlockSelectors () |
| void | SetBlockColor (const char *selector, double r, double g, double b) |
| | Set the color for a single block. More...
| void | RemoveAllBlockColors () |
| void | SetBlockOpacity (const char *selector, double opacity) |
| | Set the opacity for a single block. More...
| void | RemoveAllBlockOpacities () |
| void | SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate) |
| | Set if to interpolate scalars before mapping for a single block. More...
| void | RemoveAllBlockInterpolateScalarsBeforeMappings () |
| void | SetBlockMapScalars (const char *selector, int val) |
| | Set the block to map scalars for a single block. More...
| void | RemoveAllBlockMapScalars () |
| void | SetBlockArrayName (const char *selector, int assoc, const char *arrayName) |
| | Set the color array for a single block. More...
| void | RemoveAllBlockArrayNames () |
| void | SetBlockLookupTable (vtkScalarsToColors *lut) |
| | Set the look up table for a single block. More...
| void | RemoveAllBlockLookupTables () |
| virtual void | SetEnableScaling (int v) |
| | For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
| virtual void | SetScalingArrayName (const char *) |
| virtual void | SetScalingFunction (vtkPiecewiseFunction *pwf) |
| virtual void | SetUseDataPartitions (bool) |
| | Specify whether or not to redistribute the data. More...
| virtual bool | GetUseDataPartitions () |
| virtual void | SetUseShaderReplacements (bool) |
| | Specify whether or not to shader replacements string must be used. More...
| virtual bool | GetUseShaderReplacements () |
| void | SetPlaceHolderDataType (int datatype) |
| | Set/Get the placeholder data type. More...
| virtual int | GetPlaceHolderDataType () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkGlyph3DRepresentation () |
| | ~vtkGlyph3DRepresentation () override |
| void | SetupDefaults () override |
| | This method is called in the constructor. More...
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| | Overridden to request single piece from the Glyph source. More...
| vtkPVLODActor * | GetRenderedProp () override |
| | Used in ConvertSelection to locate the prop used for actual rendering. More...
| void | UpdateColoringParameters () override |
| | Overridden to ensure that the coloring decisions are passed over to the glyph mapper. More...
| void | ComputeGlyphBounds (double bounds[6]) |
| | Determines bounds using the vtkGlyph3DMapper. More...
| | vtkGeometryRepresentation () |
| | ~vtkGeometryRepresentation () override |
| void | HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *) |
| void | PopulateBlockAttributes (vtkCompositeDataDisplayAttributes *attrs, vtkDataObject *outputData) |
| | Block attributes in a mapper are referenced to each block through DataObject pointers. More...
| void | ComputeVisibleDataBounds () |
| | Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
| void | UpdateShaderReplacements () |
| | Update the mapper with the shader replacement strings if feature is enabled. More...
| virtual bool | NeedsOrderedCompositing () |
| | Returns true if this representation has translucent geometry. More...
| virtual void | SetPointArrayToProcess (int p, const char *val) |
| | Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
| void | UpdateGeneralTextureTransform () |
| | This is called whenever the texture transformation matrix changes. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
