vtkSynchronizedRenderers subclass that handles adjusting of camera for cave configurations. More...
#include <vtkCaveSynchronizedRenderers.h>
| typedef vtkSynchronizedRenderers | Superclass |
Public Types inherited from vtkSynchronizedRenderers | |
Public Member Functions inherited from vtkSynchronizedRenderers | |
| vtkSynchronizedRenderers * | NewInstance () const |
| void | CollectiveExpandForVisiblePropBounds (double bounds[6]) |
| virtual vtkRenderer * | GetRenderer () |
| virtual void | SetParallelController (vtkMultiProcessController *) |
| virtual vtkMultiProcessController * | GetParallelController () |
| virtual void | SetParallelRendering (bool) |
| virtual bool | GetParallelRendering () |
| virtual void | ParallelRenderingOn () |
| virtual void | ParallelRenderingOff () |
| virtual void | SetImageReductionFactor (int) |
| virtual int | GetImageReductionFactor () |
| virtual void | SetWriteBackImages (bool) |
| virtual bool | GetWriteBackImages () |
| virtual void | WriteBackImagesOn () |
| virtual void | WriteBackImagesOff () |
| virtual void | SetRootProcessId (int) |
| virtual int | GetRootProcessId () |
| virtual void | SetCaptureDelegate (vtkSynchronizedRenderers *) |
| virtual vtkSynchronizedRenderers * | GetCaptureDelegate () |
| virtual void | SetAutomaticEventHandling (bool) |
| virtual bool | GetAutomaticEventHandling () |
| virtual void | AutomaticEventHandlingOn () |
| virtual void | AutomaticEventHandlingOff () |
| static vtkCaveSynchronizedRenderers * | New () |
| static vtkCaveSynchronizedRenderers * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSynchronizedRenderers | |
| static vtkSynchronizedRenderers * | New () |
| static vtkSynchronizedRenderers * | SafeDownCast (vtkObjectBase *o) |
| vtkCaveSynchronizedRenderers () | |
| ~vtkCaveSynchronizedRenderers () override | |
| void | HandleStartRender () override |
| Called at the start of each render. More... | |
| void | ProcessCaveConfiguration () |
| During constructor, processes the configuration file to setup the display information. More... | |
| void | SetNumberOfDisplays (int numberOfDisplays) |
| These are to initialize the displays. More... | |
| void | SetEyeSeparation (double eyeSeparation) |
| Set the eye separation for all the displays. More... | |
| void | DefineDisplay (int idx, double origin[3], double x[3], double y[3]) |
| void | ComputeCamera (vtkCamera *cam) |
| Method to update the camera. More... | |
| void | SetRenderer (vtkRenderer *renderer) override |
| Override Superclass to compute Displays parameters in case of a single screen cave (e.g. More... | |
Protected Member Functions inherited from vtkSynchronizedRenderers | |
| vtkSynchronizedRenderers () | |
| ~vtkSynchronizedRenderers () | |
| virtual void | HandleEndRender () |
| virtual void | HandleAbortRender () |
| virtual void | MasterStartRender () |
| virtual void | SlaveStartRender () |
| virtual void | MasterEndRender () |
| virtual void | SlaveEndRender () |
| virtual vtkRawImage & | CaptureRenderedImage () |
| virtual void | PushImageToScreen () |
Protected Attributes | |
| double | EyeSeparation |
| int | NumberOfDisplays |
| double ** | Displays |
| double | DisplayOrigin [3] |
| double | DisplayX [3] |
| double | DisplayY [3] |
| int | once |
Protected Attributes inherited from vtkSynchronizedRenderers | |
| vtkMultiProcessController * | ParallelController |
| vtkOpenGLRenderer * | Renderer |
| vtkSynchronizedRenderers * | CaptureDelegate |
| vtkRawImage | ReducedImage |
| vtkRawImage | FullImage |
| bool | ParallelRendering |
| int | ImageReductionFactor |
| bool | WriteBackImages |
| int | RootProcessId |
| bool | AutomaticEventHandling |
Public Attributes inherited from vtkSynchronizedRenderers | |
| SYNC_RENDERER_TAG | |
| RESET_CAMERA_TAG | |
| COMPUTE_BOUNDS_TAG | |
vtkCaveSynchronizedRenderers is vtkSynchronizedRenderers used for in CAVE configuration. It is used on the render-server side. It ensures that the camera is transformed based on the orientations specified in the pvx configuration file. This code was previously in class vtkCaveRenderManager.
In case of a single display, if the cave bounds are not set, we compute these values from vtkDisplayConfiguration::Geometry and the client camera view angle.
Definition at line 27 of file vtkCaveSynchronizedRenderers.h.
Definition at line 31 of file vtkCaveSynchronizedRenderers.h.
Reimplemented from vtkSynchronizedRenderers.
overrideprotectedvirtual |
Overridden to ensure that the camera is updated based on the configuration.
(This is directly copied from vtkCaveRenderManager).
zSpace)
Definition at line 74 of file vtkCaveSynchronizedRenderers.h.
Definition at line 75 of file vtkCaveSynchronizedRenderers.h.
Definition at line 76 of file vtkCaveSynchronizedRenderers.h.
Definition at line 77 of file vtkCaveSynchronizedRenderers.h.
Definition at line 78 of file vtkCaveSynchronizedRenderers.h.
Definition at line 79 of file vtkCaveSynchronizedRenderers.h.
Definition at line 80 of file vtkCaveSynchronizedRenderers.h.
