an internal class encapsulating logic for Catalyst Python scripts. More...
#include <vtkCPPythonScriptV2Helper.h>
| bool | PrepareFromScript (const std::string &fname) |
| Prepares the Python package/module for import. More... | |
| const std::string & | GetScriptFileName () const |
| Returns the name of the script passed in to PrepareFromScript. More... | |
| bool | IsImported () const |
| Returns if the package/module has been imported. More... | |
| bool | Import (const std::vector< std::string > &args={}) |
| Imports the module/package. More... | |
| bool | CatalystInitialize () |
Calls catalyst_initialize. More... | |
| bool | CatalystFinalize () |
Calls catalyst_finalize. More... | |
| bool | CatalystExecute (int timestep, double time, const std::vector< std::string > ¶ms={}) |
Calls catalyst_execute. More... | |
| bool | CatalystResults () |
Calls catalyst_results. More... | |
| bool | Import (vtkCPDataDescription *desc) |
| There are overloads intended for vtkCPPythonScriptV2Pipeline i.e. More... | |
| bool | CatalystInitialize (vtkCPDataDescription *desc) |
| bool | RequestDataDescription (vtkCPDataDescription *desc) |
| bool | CatalystExecute (vtkCPDataDescription *desc) |
| static vtkCPPythonScriptV2Helper * | New () |
| static vtkCPPythonScriptV2Helper * | SafeDownCast (vtkObject *o) |
This class is an internal helper to share code between vtkInSituPipelinePython and vtkCPPythonScriptV2Pipeline.
Definition at line 23 of file vtkCPPythonScriptV2Helper.h.
Definition at line 27 of file vtkCPPythonScriptV2Helper.h.
| bool vtkCPPythonScriptV2Helper::PrepareFromScript | ( | const std::string & | fname | ) |
This doesn't actually import it yet. Returns false if the prep failed for some reason.
| const std::string& vtkCPPythonScriptV2Helper::GetScriptFileName | ( | ) | const |
| bool vtkCPPythonScriptV2Helper::IsImported | ( | ) | const |
| bool vtkCPPythonScriptV2Helper::Import | ( | const std::vector< std::string > & | args = {} | ) |
This overload is used by vtkInSituPipelinePython which in turn is used in ParaView-Catalyst, the ParaView-based implementation of the Catalyst In Situ API.
Returns true on success.
| bool vtkCPPythonScriptV2Helper::CatalystInitialize | ( | ) |
| bool vtkCPPythonScriptV2Helper::CatalystFinalize | ( | ) |
| bool vtkCPPythonScriptV2Helper::CatalystExecute | ( | int | timestep, |
| double | time, | ||
| const std::vector< std::string > & | params = {} |
| bool vtkCPPythonScriptV2Helper::CatalystResults | ( | ) |
| bool vtkCPPythonScriptV2Helper::Import | ( | vtkCPDataDescription * | desc | ) |
legacy Catalyst adaptors that don't use Conduit.
| bool vtkCPPythonScriptV2Helper::CatalystInitialize | ( | vtkCPDataDescription * | desc | ) |
| bool vtkCPPythonScriptV2Helper::RequestDataDescription | ( | vtkCPDataDescription * | desc | ) |
| bool vtkCPPythonScriptV2Helper::CatalystExecute | ( | vtkCPDataDescription * | desc | ) |
Internal methods.
These are called by Python modules internal to ParaView and may change without notice. Should not be considered as part of ParaView API.
| void vtkCPPythonScriptV2Helper::RegisterExtractor | ( | vtkSMProxy * | extractor | ) |
Internal methods.
| void vtkCPPythonScriptV2Helper::RegisterView | ( | vtkSMProxy * | view | ) |
Internal methods.
| void vtkCPPythonScriptV2Helper::SetOptions | ( | vtkSMProxy * | catalystOptions | ) |
Internal methods.
Internal methods.
Internal methods.
Definition at line 97 of file vtkCPPythonScriptV2Helper.h.
| vtkSMProxy* vtkCPPythonScriptV2Helper::GetTrivialProducer | ( | const char * | inputname | ) |
Internal methods.
| vtkStringList* vtkCPPythonScriptV2Helper::GetArgumentsAsStringList | ( | ) | const |
Internal methods.
| vtkStringList* vtkCPPythonScriptV2Helper::GetParametersAsStringList | ( | ) | const |
Internal methods.
