: A pop-up dialog used to browse and create proxies. More...
#include <pqQuickLaunchDialogExtended.h>
Inherits QDialog.
Signals | |
| void | applyRequested () |
| Emited when a pipeline update is request by the user. More... | |
| pqQuickLaunchDialogExtended (QWidget *parent, const QList< QAction *> &actions) | |
| ~pqQuickLaunchDialogExtended () override | |
Protected Slots | |
| void | requestChanged (const QString &request) |
| Updates the dialog with the given user request. More... | |
| void | currentChanged (const QModelIndex ¤tIndex, QSortFilterProxyModel *proxyModel) |
| Updates the dialog when the current selected item changed. More... | |
| void | handleTextChanged (int key) |
| Handles text changed event. More... | |
| void | move (int key) |
| Move in proxy list. More... | |
| void | toggleFocus () |
| Update focus between both list views. More... | |
| void | cancel () |
| Clear request or quit if request is already empty. More... | |
| void | showProxyHelp () |
| Open the Help panel for current proxy. More... | |
| void | createCurrentProxy (bool autoApply) |
| Creates the current proxy in the pipeline. More... | |
| void | createCurrentProxyWithoutApply () |
: pqQuickLaunchDialogExtended is a Dialog intended for quick navigation through proxies like filters and sources.
The user text input is used to search in proxies name and documentation. Two lists are displayed: the top one contains proxies that are available The second contains the disabled ones.
Help and missing requirements are displayed for the selected proxy.
This dialog is keyboard-oriented:
Note that mouse interaction is still possible to select and create proxies.
Definition at line 44 of file pqQuickLaunchDialogExtended.h.
| pqQuickLaunchDialogExtended::pqQuickLaunchDialogExtended | ( | QWidget * | parent, |
| const QList< QAction *> & | actions | ||
signal |
Typically emited from a Shift+Enter event.
protectedslot |
This filters the proxies lists. Force focus to the first available proxy if any. Fallback to the first disabled proxy otherwise.
protectedslot |
This mainly display its documentation and requirements when relevant.
protectedslot |
That will also close the window.
protectedslot |
protectedslot |
protectedslot |
Move in proxy list.
protectedslot |
protectedslot |
protectedslot |
This will also close the dialog.
