Abstract class for Python completers. More...
#include <pqPythonCompleter.h>
| pqPythonCompleter (QWidget *parent) | |
Public Member Functions inherited from pqWidgetCompleter | |
| pqWidgetCompleter (QWidget *parent) | |
| virtual void | updateCompletionModel (const QString &prompt) |
| This method is called by the client to request an update on the internal completion model, given a text prompt. More... | |
| bool | getCompleteEmptyPrompts () |
| get/set CompleteEmptyPrompts, indicating whether or not the completer should show anything if an empty prompt is given. More... | |
| void | setCompleteEmptyPrompts (bool newValue) |
| QStringList | getCompletions (const QString &prompt) override |
| Return a list of strings that could match the given prompt. More... | |
| QString | getCompletionPrefix (const QString &prompt) override |
| Return the part of the prompt that can be completed. More... | |
| QString | getVariableToComplete (const QString &prompt) |
| From a prompt string that can contain multiple tokens, retrieve the last (possibly incomplete) variable name. More... | |
| void | appendPyObjectAttributes (PyObject *object, QStringList &results) |
| Given a PyObject, append all of its attributes in the results list. More... | |
| PyObject * | derivePyObject (const QString &pythonObjectName, PyObject *locals) |
Given pythonObjectName string in the form "X.Y.Z.T" and script locals, return the most derived PyObject that matches the string. More... | |
| virtual QStringList | getPythonCompletions (const QString &pythonObjectName)=0 |
| Given a text prompt, return a list of possible completions. More... | |
Child classes must implement how Python attributes are retrieved from a given variable name prompt.
Definition at line 15 of file pqPythonCompleter.h.
Definition at line 18 of file pqPythonCompleter.h.
overrideprotectedvirtual |
Implements pqWidgetCompleter.
For example, given "X.Y.Z" string and a locals object containing an object X with attribute Z, returns the object X.Y
protectedpure virtual |
This method must be implemented in concrete classes.
Implemented in pqPythonCalculatorCompleter, and pqPythonShellCompleter.
