pqLiveSourceBehavior adds support for generated "live" sources algorithms. More...
#include <pqLiveSourceBehavior.h>
Inherits QObject.
| pqLiveSourceBehavior (QObject *parent=nullptr) | |
| ~pqLiveSourceBehavior () override | |
| static void | pause () |
| Pause live updates. More... | |
| static void | resume () |
| Resume live updates. More... | |
| static bool | isPaused () |
| Returns true if live updates are paused. More... | |
These are vtkAlgorithm subclasses that have a method GetNeedsUpdate which returns true (bool) when source may have new data and should be refreshed. This must be not confused with ParaView Catalyst.
To indicate a source is a "live source", one needs to simply add <LiveSource> XML hint for the source proxy.
This tag can have multiple attributes:
interval: Call GetNeedsUpdate at interval value in milliseconds (default to 100).emulated_time: Boolean to mark the live source as an algorithm inheriting from vtkEmulatedTimeAlgorithm, which will play all timesteps available in an emulated real time.Definition at line 38 of file pqLiveSourceBehavior.h.
| pqLiveSourceBehavior::pqLiveSourceBehavior | ( | QObject * | parent = nullptr | ) |
Pause live updates.
