: A class to handle QKeyEvent in an eventFilter and send high level signals. More...
#include <pqKeyEventFilter.h>
Inherits QObject.
| enum | KeyCategory { Accept, Reject, TextInput, Motion, Focus } |
| An enum for the key events categories. More... | |
Signals | |
| void | textChanged (int key) |
| Emited on text key pressed, without modifier. More... | |
| void | accepted (bool modified) |
| Emited on enter or return pressed modified is true if Shift is pressed. More... | |
| void | rejected () |
| Emited on Escape. More... | |
| void | motion (int key) |
| Emited on a motion key was pressed. More... | |
| void | focusChanged () |
| Emited on Tab press. More... | |
| pqKeyEventFilter (QObject *parent) | |
| ~pqKeyEventFilter () override | |
| void | filter (QObject *monitored) |
| install event filter on monitored object. More... | |
| void | forwardTypes (QObject *monitored, QList< int > types) |
| Filter monitored object but still forward event that fall under the given type. More... | |
| void | forwardType (QObject *monitored, int type) |
| bool | eventFilter (QObject *obj, QEvent *event) override |
| Reimplemented to handled QKeyEvent. More... | |
: pqKeyEventFilter is a configurable class that reimplements eventFilter() and emit high level signals to communicate about key events.
This is specially useful when a container widget wants to know about key events regardless of which of its child receive the event.
Definition at line 26 of file pqKeyEventFilter.h.
| Enumerator | |
| Accept | |
| Reject | |
| TextInput | |
| Motion | |
| Focus | |
Definition at line 38 of file pqKeyEventFilter.h.
| pqKeyEventFilter::pqKeyEventFilter | ( | QObject * | parent | ) |
| void pqKeyEventFilter::filter | ( | QObject * | monitored | ) |
| void pqKeyEventFilter::forwardTypes | ( | QObject * | monitored, |
| QList< int > | types | ||
| void pqKeyEventFilter::forwardType | ( | QObject * | monitored, |
| int | type | ||
signal |
Text keys:
As defined by QChar::isLetterOrNumber and QChar::isSpace
signal |
signal |
Emited on Escape.
signal |
Motion keys: the four arrows, home, end, page down and page up.
signal |
reverse is true on Shift + Tab.
