#include <pqCustomViewpointButtonDialog.h>
Inherits QDialog.
| pqCustomViewpointButtonDialog (QWidget *parent, Qt::WindowFlags f, QStringList &toolTips, QStringList &configurations, QString ¤tConfig) | |
| Create and initialize the dialog. More... | |
| ~pqCustomViewpointButtonDialog () override | |
| void | setToolTipsAndConfigurations (const QStringList &toolTips, const QStringList &configs) |
| Set the list of tool tips and configurations. More... | |
| void | setToolTips (const QStringList &toolTips) |
| Set/get a list of tool tips, one for each button. More... | |
| QStringList | getToolTips () |
| void | setConfigurations (const QStringList &configs) |
| Set/get a list of camera configurations, one for each button. More... | |
| QStringList | getConfigurations () |
| void | setCurrentConfiguration (const QString &config) |
| Set/get the current camera configuration. More... | |
| QString | getCurrentConfiguration () |
Static Public Attributes | |
| static const QString | DEFAULT_TOOLTIP |
| Constant variable that contains the default name for the tool tips. More... | |
| static const int | MINIMUM_NUMBER_OF_ITEMS |
| Constant variable that defines the minimum number of items. More... | |
| static const int | MAXIMUM_NUMBER_OF_ITEMS |
| Constant variable that defines the maximum number of items. More... | |
Friends | |
| class | pqCustomViewpointButtonDialogUI |
Definition at line 33 of file pqCustomViewpointButtonDialog.h.
| pqCustomViewpointButtonDialog::pqCustomViewpointButtonDialog | ( | QWidget * | parent, |
| Qt::WindowFlags | f, | ||
| QStringList & | toolTips, | ||
| QStringList & | configurations, | ||
| QString & | currentConfig | ||
| void pqCustomViewpointButtonDialog::setToolTipsAndConfigurations | ( | const QStringList & | toolTips, |
| const QStringList & | configs | ||
This is the preferred way of settings these as it supports changing the number of items.
| void pqCustomViewpointButtonDialog::setToolTips | ( | const QStringList & | toolTips | ) |
The number of items in the toolTips list must match the current number of tooltips being shown. Use setToolTipsAndConfigurations to change the number of items.
| QStringList pqCustomViewpointButtonDialog::getToolTips | ( | ) |
| void pqCustomViewpointButtonDialog::setConfigurations | ( | const QStringList & | configs | ) |
The number of items in configs must match the current number of configs. Use setToolTipsAndConfigurations to change the number of items.
| QStringList pqCustomViewpointButtonDialog::getConfigurations | ( | ) |
| void pqCustomViewpointButtonDialog::setCurrentConfiguration | ( | const QString & | config | ) |
| QString pqCustomViewpointButtonDialog::getCurrentConfiguration | ( | ) |
friend |
Definition at line 110 of file pqCustomViewpointButtonDialog.h.
Definition at line 49 of file pqCustomViewpointButtonDialog.h.
Definition at line 54 of file pqCustomViewpointButtonDialog.h.
Definition at line 59 of file pqCustomViewpointButtonDialog.h.
