#include "vtk_cgns_mangle.h"
| #define | CG_BUILD_HDF5 1 |
| #define | CG_BUILD_LEGACY 0 |
| #define | CG_BUILD_64BIT 1 |
| #define | CG_BUILD_SCOPE 1 |
| #define | CG_BUILD_BASESCOPE 0 |
| #define | CG_BUILD_PARALLEL 0 |
| #define | CG_BUILD_COMPLEX_C99_EXT 0 |
| #define | CG_MAX_INT32 0x7FFFFFFF |
| #define | CG_LONG_T long |
| #define | to_ADF_ID(ID, ADF_ID) memcpy(&(ADF_ID),&(ID),sizeof(hid_t)) |
| #define | to_HDF_ID(ADF_ID, ID) memcpy(&(ID),&(ADF_ID),sizeof(hid_t)) |
| #define | HDF5_HAVE_MULTI_DATASETS 0 |
| #define | HDF5_HAVE_COLL_METADATA 0 |
| #define | HDF5_HAVE_FILE_SPACE_STRATEGY 0 |
| #define | CG_HAVE_STAT64_STRUCT 0 |
| #define | CG_SIZEOF_SIZE 64 |
| #define | CG_SIZE_DATATYPE "I8" |
| #define | FORTRAN_DEFAULT_INTEGER_C_INT64_T 0 |
Typedefs | |
| typedef CG_LONG_T | cgsize_t |
| typedef int | cgerr_t |
| typedef int | cgint_t |
| typedef double | cgid_t |
| typedef int | cgint_f |
| typedef CG_LONG_T | cglong_t |
| typedef unsigned CG_LONG_T | cgulong_t |
| #define CG_BUILD_HDF5 1 |
Definition at line 34 of file cgnstypes.h.
| #define CG_BUILD_LEGACY 0 |
Definition at line 35 of file cgnstypes.h.
| #define CG_BUILD_64BIT 1 |
Definition at line 36 of file cgnstypes.h.
| #define CG_BUILD_SCOPE 1 |
Definition at line 37 of file cgnstypes.h.
| #define CG_BUILD_BASESCOPE 0 |
Definition at line 38 of file cgnstypes.h.
| #define CG_BUILD_PARALLEL 0 |
Definition at line 39 of file cgnstypes.h.
| #define CG_BUILD_COMPLEX_C99_EXT 0 |
Definition at line 40 of file cgnstypes.h.
| #define CG_MAX_INT32 0x7FFFFFFF |
Definition at line 42 of file cgnstypes.h.
| #define CG_LONG_T long |
Definition at line 46 of file cgnstypes.h.
| #define to_ADF_ID | ( | ID, | |
| ADF_ID | |||
| ) | memcpy(&(ADF_ID),&(ID),sizeof(hid_t)) |
Definition at line 55 of file cgnstypes.h.
| #define to_HDF_ID | ( | ADF_ID, | |
| ID | |||
| ) | memcpy(&(ID),&(ADF_ID),sizeof(hid_t)) |
Definition at line 56 of file cgnstypes.h.
| #define HDF5_HAVE_MULTI_DATASETS 0 |
Definition at line 60 of file cgnstypes.h.
| #define HDF5_HAVE_COLL_METADATA 0 |
Definition at line 64 of file cgnstypes.h.
| #define HDF5_HAVE_FILE_SPACE_STRATEGY 0 |
Definition at line 68 of file cgnstypes.h.
| #define CG_HAVE_STAT64_STRUCT 0 |
Definition at line 72 of file cgnstypes.h.
| #define CG_SIZEOF_SIZE 64 |
Definition at line 83 of file cgnstypes.h.
| #define CG_SIZE_DATATYPE "I8" |
Definition at line 84 of file cgnstypes.h.
| #define FORTRAN_DEFAULT_INTEGER_C_INT64_T 0 |
Definition at line 97 of file cgnstypes.h.
Definition at line 85 of file cgnstypes.h.
Definition at line 91 of file cgnstypes.h.
Definition at line 92 of file cgnstypes.h.
Definition at line 93 of file cgnstypes.h.
Definition at line 101 of file cgnstypes.h.
Definition at line 105 of file cgnstypes.h.
Definition at line 106 of file cgnstypes.h.
