Macros
XdmfConfig.h File Reference
Macros
#define XDMF_REQUIRE_LARGE_FILE_SUPPORT
#define _LARGEFILE_SOURCE
#define _LARGEFILE64_SOURCE
#define _LARGE_FILES
#define _FILE_OFFSET_BITS   64
#define XDMF_WORDS_LITTLEENDIAN
#define XDMF_BYTE_ORDER_LITTLE
#define XDMF_SYSTEM   Linux-5.4.0-193-generic
#define XDMF_VOID_VALID
#define XDMF_VOID   void
#define XDMF_PTR_VALID
#define XDMF_PTR   void *
#define XDMF_CHAR_VALID
#define XDMF_CHAR   char
#define XDMF_8_INT_VALID
#define XDMF_8_INT   char
#define XDMF_8_U_INT   unsigned char
#define XDMF_16_INT_VALID
#define XDMF_16_INT   short
#define XDMF_16_U_INT   unsigned short
#define XDMF_32_INT_VALID
#define XDMF_32_INT   int
#define XDMF_32_U_INT   unsigned int
#define XDMF_32_S_INT   int
#define XDMF_32_FLOAT_VALID
#define XDMF_32_FLOAT   float
#define XDMF_FLOAT   float
#define XDMF_64_FLOAT_VALID
#define XDMF_64_FLOAT   double
#define XDMF_DOUBLE   double
#define SIZEOF_LONG_LONG   8
#define XDMF_64_INT   long long
#define HAVE_64_INT
#define XDMF_have_64_bit_int
#define XDMF_HAVE_64BIT_STREAMS
#define XDMF_64BIT_CAST
#define XDMF_USE_ANSI_STDLIB
#define XDMF_LONG64   long long
#define BUILD_SHARED_LIBS
#define XDMF_NO_MPI
#define Xdmf_EXPORTS
Macro Definition Documentation
◆ XDMF_REQUIRE_LARGE_FILE_SUPPORT
Definition at line 8 of file XdmfConfig.h.
◆ _LARGEFILE_SOURCE
Definition at line 11 of file XdmfConfig.h.
◆ _LARGEFILE64_SOURCE
Definition at line 14 of file XdmfConfig.h.
◆ _LARGE_FILES
Definition at line 17 of file XdmfConfig.h.
◆ _FILE_OFFSET_BITS
Definition at line 20 of file XdmfConfig.h.
◆ XDMF_WORDS_LITTLEENDIAN
Definition at line 31 of file XdmfConfig.h.
◆ XDMF_BYTE_ORDER_LITTLE
Definition at line 32 of file XdmfConfig.h.
◆ XDMF_SYSTEM
Definition at line 35 of file XdmfConfig.h.
◆ XDMF_VOID_VALID
Definition at line 37 of file XdmfConfig.h.
◆ XDMF_VOID
Definition at line 42 of file XdmfConfig.h.
◆ XDMF_PTR_VALID
Definition at line 44 of file XdmfConfig.h.
◆ XDMF_PTR
Definition at line 49 of file XdmfConfig.h.
◆ XDMF_CHAR_VALID
Definition at line 51 of file XdmfConfig.h.
◆ XDMF_CHAR
Definition at line 56 of file XdmfConfig.h.
◆ XDMF_8_INT_VALID
Definition at line 58 of file XdmfConfig.h.
◆ XDMF_8_INT
Definition at line 63 of file XdmfConfig.h.
◆ XDMF_8_U_INT
Definition at line 64 of file XdmfConfig.h.
◆ XDMF_16_INT_VALID
Definition at line 66 of file XdmfConfig.h.
◆ XDMF_16_INT
Definition at line 71 of file XdmfConfig.h.
◆ XDMF_16_U_INT
Definition at line 72 of file XdmfConfig.h.
◆ XDMF_32_INT_VALID
Definition at line 74 of file XdmfConfig.h.
◆ XDMF_32_INT
Definition at line 79 of file XdmfConfig.h.
◆ XDMF_32_U_INT
Definition at line 80 of file XdmfConfig.h.
◆ XDMF_32_S_INT
Definition at line 81 of file XdmfConfig.h.
◆ XDMF_32_FLOAT_VALID
Definition at line 83 of file XdmfConfig.h.
◆ XDMF_32_FLOAT
Definition at line 88 of file XdmfConfig.h.
◆ XDMF_FLOAT
Definition at line 89 of file XdmfConfig.h.
◆ XDMF_64_FLOAT_VALID
Definition at line 91 of file XdmfConfig.h.
◆ XDMF_64_FLOAT
Definition at line 96 of file XdmfConfig.h.
◆ XDMF_DOUBLE
Definition at line 97 of file XdmfConfig.h.
◆ SIZEOF_LONG_LONG
Definition at line 105 of file XdmfConfig.h.
◆ XDMF_64_INT
Definition at line 109 of file XdmfConfig.h.
◆ HAVE_64_INT
#define HAVE_64_INT
Definition at line 110 of file XdmfConfig.h.
◆ XDMF_have_64_bit_int
Definition at line 111 of file XdmfConfig.h.
◆ XDMF_HAVE_64BIT_STREAMS
Definition at line 119 of file XdmfConfig.h.
◆ XDMF_64BIT_CAST
Definition at line 121 of file XdmfConfig.h.
◆ XDMF_USE_ANSI_STDLIB
Definition at line 127 of file XdmfConfig.h.
◆ XDMF_LONG64
Definition at line 137 of file XdmfConfig.h.
◆ BUILD_SHARED_LIBS
Definition at line 142 of file XdmfConfig.h.
◆ XDMF_NO_MPI
#define XDMF_NO_MPI
Definition at line 152 of file XdmfConfig.h.
◆ Xdmf_EXPORTS
Definition at line 157 of file XdmfConfig.h.
