vtkSMUtilities.h
10 #ifndef vtkSMUtilities_h
11 #define vtkSMUtilities_h
12
13 #include "vtkRemotingViewsModule.h" //needed for exports
14 #include "vtkSMObject.h"
15 #include "vtkSmartPointer.h" // needed for vtkSmartPointer
16 #include <vector> // needed for std::vector
17
18 class vtkImageData;
19 class vtkPoints;
20 class VTKREMOTINGVIEWS_EXPORT vtkSMUtilities : public vtkSMObject
21 {
22 public:
23  static vtkSMUtilities* New();
24  vtkTypeMacro(vtkSMUtilities, vtkSMObject);
25  void PrintSelf(ostream& os, vtkIndent indent) override;
26
34  static int SaveImage(vtkImageData* image, const char* filename, int quality);
35  static int SaveImage(vtkImageData* image, const char* filename)
36  {
37  return vtkSMUtilities::SaveImage(image, filename, -1);
38  }
44  static int SaveImage(vtkImageData* image, const char* filename, const char* writerName);
45
50  static int SaveImageOnProcessZero(
51  vtkImageData* image, const char* filename, const char* writerName);
52
60  static vtkPoints* CreateOrbit(
61  const double center[3], const double normal[3], int resolution, const double startPoint[3]);
62
63  // Will pick an arbitrary starting point
64  static vtkPoints* CreateOrbit(
65  const double center[3], const double normal[3], double radius, int resolution);
66
72  static void Merge(vtkImageData* dest, vtkImageData* src, int borderWidth = 0,
73  const unsigned char* borderColorRGB = nullptr);
74
78  static vtkSmartPointer<vtkImageData> MergeImages(
79  const std::vector<vtkSmartPointer<vtkImageData>>& images, int borderWidth = 0,
80  const unsigned char* borderColorRGB = nullptr);
81
87  static void FillImage(vtkImageData* image, const int extent[6], const unsigned char rgb[3]);
88
89 protected:
90  vtkSMUtilities() = default;
91  ~vtkSMUtilities() override = default;
92
93 private:
94  vtkSMUtilities(const vtkSMUtilities&) = delete;
95  void operator=(const vtkSMUtilities&) = delete;
96 };
97
98 #endif
vtkPoints
vtkSMObject
superclass for most server manager classes
Definition: vtkSMObject.h:17
vtkSMObject::PrintSelf
vtkSMUtilities
collection of utility methods.
Definition: vtkSMUtilities.h:20
vtkSMObject.h
vtkSmartPointer< vtkImageData >
static int SaveImage(vtkImageData *image, const char *filename, int quality)
Save the image to a file.
vtkImageData
vtkIndent
vtkSmartPointer.h
vtkSMObject::New
static vtkSMObject * New()
static int SaveImage(vtkImageData *image, const char *filename)
Definition: vtkSMUtilities.h:35
