src
paraview-5.12
Remoting
ServerManager
vtkSMUndoStack.h
1
// SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
// SPDX-License-Identifier: BSD-3-Clause
24
#ifndef vtkSMUndoStack_h
25
#define vtkSMUndoStack_h
26
27
//needed for exports
28
vtkUndoStack.h
30
vtkSMUndoRedoStateLoader;
31
vtkSMUndoStackObserver;
32
vtkUndoSet
33
vtkCollection
35
VTKREMOTINGSERVERMANAGER_EXPORT
vtkSMUndoStack
public
vtkUndoStack
36
37
public
38
vtkSMUndoStack
New
vtkTypeMacro(
vtkSMUndoStack
vtkUndoStack
40
void
PrintSelf
(ostream& os,
vtkIndent
indent)
override
41
46
void
Push
const
char
* label,
vtkUndoSet
* changeSet)
override
47
55
int
Undo
override
56
64
int
Redo
override
65
66
enum
EventIds
67
68
PushUndoSetEvent = 1987,
69
ObjectCreationEvent = 1988
70
71
72
73
vtkSMUndoStack
75
vtkSMUndoStack
override
76
77
// Helper method used to push all vtkSMRemoteObject to the collection of
78
// all the sessions that have been used across that undoset.
79
// (It is more than likely that only one session will be find but in case of
80
// collaboration, we might want to support a set of sessions.)
81
// This is useful when we execute the undoset to prevent automatic
82
// object deletion between 2 undo element calls when a proxy registration
83
// is supposed to happen.
84
void
FillWithRemoteObjects(
vtkUndoSet
* undoSet,
vtkCollection
* collection);
85
86
private
87
vtkSMUndoStack
const
vtkSMUndoStack
delete
88
void
operator=(
const
vtkSMUndoStack
delete
89
90
vtkInternal;
91
vtkInternal*
Internal
92
93
94
#endif
vtkUndoSet
Maintains a collection of vtkUndoElement that can be undone/redone in a single step.
Definition:
vtkUndoSet.h:30
vtkUndoStack::Undo
virtual int Undo()
Performs an Undo using the set on the top of the undo stack.
vtkUndoStack
undo/redo stack.
Definition:
vtkUndoStack.h:35
vtkUndoStack::Internal
vtkUndoStackInternal * Internal
Definition:
vtkUndoStack.h:167
vtkCollection
vtkUndoStack::Push
virtual void Push(const char *label, vtkUndoSet *changeSet)
Push an undo set on the Undo stack.
vtkIndent
vtkSMUndoStack::EventIds
EventIds
Definition:
vtkSMUndoStack.h:66
vtkUndoStack.h
vtkUndoStack::New
static vtkUndoStack * New()
vtkUndoStack::PrintSelf
vtkSMUndoStack
Definition:
vtkSMUndoStack.h:35
vtkUndoStack::Redo
virtual int Redo()
Performs a Redo using the set on the top of the redo stack.
