vtkSMDoubleRangeDomain.h
12 #ifndef vtkSMDoubleRangeDomain_h
13 #define vtkSMDoubleRangeDomain_h
14
15 // Tell the template header how to give our superclass a DLL interface.
16 #if !defined(vtkSMDoubleRangeDomain_cxx)
17 #define VTK_DATA_ARRAY_TEMPLATE_TYPE double
18 #endif
20 #include "vtkRemotingServerManagerModule.h" //needed for exports
21 #include "vtkSMDomain.h"
22 #include "vtkSMRangeDomainTemplate.h" // Read superclass
23
24 // Fake the superclass for the wrappers.
25 #ifndef __WRAP__
26 #define vtkSMDomain vtkSMRangeDomainTemplate<double>
27 #endif
28 class VTKREMOTINGSERVERMANAGER_EXPORT vtkSMDoubleRangeDomain : public vtkSMDomain
29 #ifndef __WRAP__
30 #undef vtkSMDomain
31 #endif
32 {
33 public:
34  static vtkSMDoubleRangeDomain* New();
36  void PrintSelf(ostream& os, vtkIndent indent) override;
37
43  virtual double GetMinimum(unsigned int idx, int& exists)
44  {
45  return this->RealSuperclass::GetMinimum(idx, exists);
46  }
47
53  virtual double GetMaximum(unsigned int idx, int& exists)
54  {
55  return this->RealSuperclass::GetMaximum(idx, exists);
56  }
57
61  virtual int GetMinimumExists(unsigned int idx)
62  {
63  return this->RealSuperclass::GetMinimumExists(idx) ? 1 : 0;
64  }
65  virtual int GetMaximumExists(unsigned int idx)
66  {
67  return this->RealSuperclass::GetMaximumExists(idx) ? 1 : 0;
68  }
69
75  virtual double GetMinimum(unsigned int idx) { return this->RealSuperclass::GetMinimum(idx); }
76  virtual double GetMaximum(unsigned int idx) { return this->RealSuperclass::GetMaximum(idx); }
77
81  virtual int GetResolution() { return this->RealSuperclass::GetResolution(); }
82
83 protected:
85  ~vtkSMDoubleRangeDomain() override;
86
87 private:
89  void operator=(const vtkSMDoubleRangeDomain&) = delete;
90
91  typedef vtkSMRangeDomainTemplate<double> RealSuperclass;
92 };
93
94 #if !defined(vtkSMDoubleRangeDomain_cxx)
95 #undef VTK_DATA_ARRAY_TEMPLATE_TYPE
96 #endif
97
98 #endif
type specific extension to vtkSMRangeDomainTemplate for doubles.
Definition: vtkSMDoubleRangeDomain.h:28
vtkSMDoubleRangeDomain::GetMaximum
Definition: vtkSMDoubleRangeDomain.h:76
virtual double GetMaximum(unsigned int idx, int &exists)
Return a max.
Definition: vtkSMDoubleRangeDomain.h:53
vtkSMDoubleRangeDomain::GetMinimum
virtual double GetMinimum(unsigned int idx, int &exists)
Return a min.
Definition: vtkSMDoubleRangeDomain.h:43
vtkSMDomain::PrintSelf
superclass for type-specific range domains i.e. domains that constrain a value within a min and max.
Definition: vtkSMRangeDomainTemplate.h:52
vtkIndent
vtkSMDomain
represents the possible values a property can have
Definition: vtkSMDomain.h:37
vtkSMDomain::New
static vtkSMDomain * New()
vtkSMDoubleRangeDomain::GetResolution
Returns the resolution.
Definition: vtkSMDoubleRangeDomain.h:81
vtkSMDoubleRangeDomain::GetMaximumExists
Definition: vtkSMDoubleRangeDomain.h:65
vtkSMDomain.h
Returns the minimum/maximum value, is exists, otherwise 0 is returned.
Definition: vtkSMDoubleRangeDomain.h:75
vtkSMDoubleRangeDomain::GetMinimumExists
Returns if minimum/maximum bound is set for the domain.
Definition: vtkSMDoubleRangeDomain.h:61
