vtkPEnSightGoldBinaryReader.h
2 // SPDX-FileCopyrightText: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
3 // SPDX-FileCopyrightText: Copyright (c) CEA
4 // SPDX-License-Identifier: BSD-3-Clause
21 #ifndef vtkPEnSightGoldBinaryReader_h
22 #define vtkPEnSightGoldBinaryReader_h
23
24 #include "vtkPEnSightReader.h"
25 #include "vtkPVVTKExtensionsIOEnSightModule.h" //needed for exports
26
29 class vtkPoints;
30
31 class VTKPVVTKEXTENSIONSIOENSIGHT_EXPORT vtkPEnSightGoldBinaryReader : public vtkPEnSightReader
32 {
33 public:
36  void PrintSelf(ostream& os, vtkIndent indent) override;
37
38 protected:
40  ~vtkPEnSightGoldBinaryReader() override;
41
42  // Returns 1 if successful. Sets file size as a side action.
43  int OpenFile(const char* filename);
45  // Returns 1 if successful. Handles constructing the filename, opening the file and checking
46  // if it's binary
47  int InitializeFile(const char* filename);
48
52  int ReadGeometryFile(const char* fileName, int timeStep, vtkMultiBlockDataSet* output) override;
53
59  const char* fileName, int timeStep, vtkMultiBlockDataSet* output) override;
60
66  int ReadScalarsPerNode(const char* fileName, const char* description, int timeStep,
67  vtkMultiBlockDataSet* output, int measured = 0, int numberOfComponents = 1,
68  int component = 0) override;
69
74  int ReadVectorsPerNode(const char* fileName, const char* description, int timeStep,
75  vtkMultiBlockDataSet* output, int measured = 0) override;
76
81  int ReadTensorsPerNode(const char* fileName, const char* description, int timeStep,
82  vtkMultiBlockDataSet* output) override;
83
89  int ReadScalarsPerElement(const char* fileName, const char* description, int timeStep,
90  vtkMultiBlockDataSet* output, int numberOfComponents = 1, int component = 0) override;
91
96  int ReadVectorsPerElement(const char* fileName, const char* description, int timeStep,
97  vtkMultiBlockDataSet* output) override;
98
103  int ReadTensorsPerElement(const char* fileName, const char* description, int timeStep,
104  vtkMultiBlockDataSet* output) override;
105
112  int partId, char line[80], const char* name, vtkMultiBlockDataSet* output) override;
113
119  int partId, char line[256], const char* name, vtkMultiBlockDataSet* output) override;
120
125  int CreateRectilinearGridOutput(
126  int partId, char line[256], const char* name, vtkMultiBlockDataSet* output);
127
132  int CreateImageDataOutput(
133  int partId, char line[80], const char* name, vtkMultiBlockDataSet* output);
134
139  int ReadLine(char result[80]);
140
142
146  int ReadInt(int* result);
147  int ReadPartId(int* result);
149
154  int ReadIntArray(int* result, int numInts);
155
160  int ReadFloatArray(float* result, int numFloats);
161
165  int ReadOrSkipCoordinates(vtkPoints* points, long offset, int partId, bool skip);
166
171  int InjectCoordinatesAtEnd(vtkUnstructuredGrid* output, long coordinatesOffset, int partId);
172
179  int CountTimeSteps();
180
182
185  int SkipTimeStep();
186  int SkipStructuredGrid(char line[256]);
187  int SkipUnstructuredGrid(char line[256]);
188  int SkipRectilinearGrid(char line[256]);
189  int SkipImageData(char line[256]);
191
194  int Fortran;
195
196  istream* IFile;
197  // The size of the file could be used to choose byte order.
198  long FileSize;
199
200  // Float Vector Buffer utils
201  void GetVectorFromFloatBuffer(vtkIdType i, float* vector);
202  void UpdateFloatBuffer();
203  // The buffer
204  float** FloatBuffer;
205  // The buffer size. Default is 1000
207  // The FloatBuffer store the vectors
208  // from FloatBufferIndexBegin to FloatBufferIndexBegin + FloatBufferSize
210  // X variable positions of vector number 0 in file
212  // Total number of vectors;
214
215 private:
217  void operator=(const vtkPEnSightGoldBinaryReader&) = delete;
218 };
219
220 #endif
vtkPoints
vtkGenericEnSightReader::ReadLine
int ReadLine(char result[256])
vtkPEnSightGoldBinaryReader::IFile
istream * IFile
Definition: vtkPEnSightGoldBinaryReader.h:196
vtkPEnSightReader::ReadScalarsPerElement
virtual int ReadScalarsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int numberOfComponents=1, int component=0)=0
Read scalars per element for this dataset.
Definition: vtkPEnSightGoldBinaryReader.h:31
vtkIdType
int vtkIdType
vtkPEnSightGoldBinaryReader::FloatBufferSize
vtkIdType FloatBufferSize
Definition: vtkPEnSightGoldBinaryReader.h:206
vtkPEnSightReader::CreateStructuredGridOutput
virtual int CreateStructuredGridOutput(int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0
Read a structured part from the geometry file and create a vtkStructuredGridOutput.
vtkPEnSightReader::ReadVectorsPerElement
virtual int ReadVectorsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read vectors per element for this dataset.
vtkPEnSightReader::ReadScalarsPerNode
virtual int ReadScalarsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0, int numberOfComponents=1, int component=0)=0
Read scalars per node for this dataset.
vtkPEnSightGoldBinaryReader::FileSize
long FileSize
Definition: vtkPEnSightGoldBinaryReader.h:198
vtkPEnSightGoldBinaryReader::FloatBufferNumberOfVectors
vtkIdType FloatBufferNumberOfVectors
Definition: vtkPEnSightGoldBinaryReader.h:213
vtkPEnSightReader::ReadMeasuredGeometryFile
virtual int ReadMeasuredGeometryFile(const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0
Read the measured geometry file.
vtkPEnSightReader
Definition: vtkPEnSightReader.h:45
vtkPEnSightReader::ReadTensorsPerNode
virtual int ReadTensorsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read tensors per node for this dataset.
vtkPEnSightGoldBinaryReader::NodeIdsListed
int NodeIdsListed
Definition: vtkPEnSightGoldBinaryReader.h:192
vtkIndent
vtkPEnSightGoldBinaryReader::FloatBufferIndexBegin
vtkIdType FloatBufferIndexBegin
Definition: vtkPEnSightGoldBinaryReader.h:209
vtkPEnSightReader::CreateUnstructuredGridOutput
virtual int CreateUnstructuredGridOutput(int partId, char line[80], const char *name, vtkMultiBlockDataSet *output)=0
Read an unstructured part (partId) from the geometry file and create a vtkUnstructuredGrid output.
vtkPEnSightGoldBinaryReader::Fortran
int Fortran
Definition: vtkPEnSightGoldBinaryReader.h:194
vtkPEnSightGoldBinaryReader::ElementIdsListed
int ElementIdsListed
Definition: vtkPEnSightGoldBinaryReader.h:193
vtkPEnSightReader::ReadVectorsPerNode
virtual int ReadVectorsPerNode(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output, int measured=0)=0
Read vectors per node for this dataset.
vtkPGenericEnSightReader::New
static vtkPGenericEnSightReader * New()
vtkPEnSightGoldBinaryReader::FloatBufferFilePosition
vtkIdType FloatBufferFilePosition
Definition: vtkPEnSightGoldBinaryReader.h:211
vtkPEnSightReader::ReadGeometryFile
virtual int ReadGeometryFile(const char *fileName, int timeStep, vtkMultiBlockDataSet *output)=0
Read the geometry file.
vtkUnstructuredGrid
float ** FloatBuffer
Definition: vtkPEnSightGoldBinaryReader.h:204
vtkPEnSightReader::ReadTensorsPerElement
virtual int ReadTensorsPerElement(const char *fileName, const char *description, int timeStep, vtkMultiBlockDataSet *output)=0
Read tensors per element for this dataset.
vtkPEnSightReader::PrintSelf
vtkPEnSightReader.h
