src
paraview-5.12
VTKExtensions
FiltersGeneral
vtkEquivalenceSet.h
1
// SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
// SPDX-FileCopyrightText: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
3
// SPDX-License-Identifier: BSD-3-Clause
12
#ifndef vtkEquivalenceSet_h
13
#define vtkEquivalenceSet_h
14
15
vtkObject.h
16
#include "vtkPVVTKExtensionsFiltersGeneralModule.h"
//needed for exports
17
vtkIntArray
18
VTKPVVTKEXTENSIONSFILTERSGENERAL_EXPORT
vtkEquivalenceSet
public
vtkObject
20
21
public
22
vtkTypeMacro(
vtkEquivalenceSet
vtkObject
23
void
PrintSelf
(ostream& os,
vtkIndent
indent)
override
24
vtkEquivalenceSet
New
25
26
void
Initialize();
27
void
AddEquivalence(
int
id1,
int
id2);
28
// The length of the equivalent array...
30
// The Domain of the equivalance map is [0, numberOfMembers).
31
int
GetNumberOfMembers();
32
33
// Valid only after set is resolved.
// The range of the map is [0 numberOfResolvedSets)
35
int
GetNumberOfResolvedSets
return
this->NumberOfResolvedSets; }
36
37
// Return the id of the equivalent set.
38
int
GetEquivalentSetId(
int
memberId);
40
// Equivalent set ids are reassinged to be sequential.
41
// You cannot add anymore equivalences after this is called.
42
int
ResolveEquivalences();
43
void
DeepCopy
vtkEquivalenceSet
* in);
45
46
// Needed for sending the set over MPI.
47
// Be very careful with the pointer.
48
// I guess this means do not write to the memory.
49
int
* GetPointer();
50
51
// Free unused memory
52
void
Squeeze();
53
54
// Report used memory
55
vtkIdType
Capacity();
56
57
// We should fix the pointer API and hide this ivar.
58
int
Resolved
59
60
int
GetReference(
int
memberId);
61
62
vtkEquivalenceSet
64
vtkEquivalenceSet
override
65
66
int
67
68
// To merge connected framgments that have different ids because they were
69
// traversed by different processes or passes.
70
vtkIntArray
EquivalenceArray
71
72
73
void
EquateInternal(
int
id1,
int
id2);
74
75
private
76
vtkEquivalenceSet
const
vtkEquivalenceSet
delete
77
void
operator=
const
vtkEquivalenceSet
delete
78
79
80
#endif
DeepCopy
void DeepCopy(vtkPistonReference *self, vtkPistonReference *other)
vtkObjectBase::operator=
vtkEquivalenceSet::Resolved
int Resolved
Definition:
vtkEquivalenceSet.h:58
vtkIdType
int vtkIdType
vtkObject::New
static vtkObject * New()
vtkObject
vtkEquivalenceSet::EquivalenceArray
vtkIntArray * EquivalenceArray
Definition:
vtkEquivalenceSet.h:70
vtkIndent
vtkIntArray
vtkEquivalenceSet::GetNumberOfResolvedSets
int GetNumberOfResolvedSets()
Definition:
vtkEquivalenceSet.h:35
vtkObject.h
vtkEquivalenceSet::NumberOfResolvedSets
int NumberOfResolvedSets
Definition:
vtkEquivalenceSet.h:66
vtkEquivalenceSet
records groups of integers that are equivalent.
Definition:
vtkEquivalenceSet.h:19
vtkObject::PrintSelf
