vtkACosmoReader.h
2 // SPDX-FileCopyrightText: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
3 // SPDX-FileCopyrightText: Copyright (c) 2007, 2009 Los Alamos National Security, LLC
4 // SPDX-License-Identifier: LicenseRef-BSD-3-Clause-LANL-USGov
11 #ifndef vtkACosmoReader_h
12 #define vtkACosmoReader_h
13
14 #include "vtkMultiBlockDataSetAlgorithm.h" // Base class
16 #include "vtkPVVTKExtensionsCosmoToolsModule.h" // For export macro
17
18 // C/C++ includes
19 #include <set> // For STL set
20 #include <string> // For C++ string
21 #include <vector> // For STL vector
22
23 // Forward declarations
24
25 class vtkInformation;
30 class VTKPVVTKEXTENSIONSCOSMOTOOLS_EXPORT vtkACosmoReader : public vtkMultiBlockDataSetAlgorithm
31 {
32 public:
33  static vtkACosmoReader* New();
35  virtual void PrintSelf(ostream& os, vtkIndent indent);
36
38
42  void AddFileName(const char*);
43  void RemoveAllFileNames();
45
46  // Set/Get the box size for the simulation (range along x,y,z)
47  // Negative x,y,z values are subtracted from this for wraparound
48  vtkSetMacro(BoxSize, double);
49  vtkGetMacro(BoxSize, double);
50
52
55  vtkSetMacro(ByteSwap, int);
56  vtkGetMacro(ByteSwap, int);
58
60
64  vtkSetMacro(TagSize, int);
65  vtkGetMacro(TagSize, int);
67
69
72  vtkSetMacro(Level, int);
73  vtkGetMacro(Level, int);
75
76 protected:
78  ~vtkACosmoReader();
79
80  // Standard pipeline methods
83
87  void LoadMetaData();
88
93  void ExtractInfoFromFileNames();
94
98  void ReadMetaDataFile(const int levelIdx, std::string file);
99
104  int GetBlockIndex(const int level, const int idx);
105
110  void SetupBlockRequest(vtkInformation* outInfo);
111
115  void ReadBlock(const int blockIdx, vtkMultiBlockDataSet* mbds);
116
121  int GetBlockStartOffSetInFile(const int level, const int index);
122
127  void ReadBlockFromFile(
128  std::string file, const int start, const int end, vtkUnstructuredGrid* particles);
129
130  std::string BaseFileName; // Base path and file name
131  char* FileName; // Name of binary particle file
132  bool MetadataIsLoaded; // Indicates if the meta data has been loaded
133
134  double BoxSize; // Maximum of x,y,z locations from simulation
135  int ByteSwap; // indicates whether to swap data or not
136  int TagSize; // Size of the tag, 0 = 32-bit or 1 = 64-bit
137  int Level; // level of resolution to load (staring from 1)
138  int TotalNumberOfLevels; // The total number of levels
139
141
142  struct block_t; // defined in the implementation
143
144  std::vector<int> NBlocks; // Number of blocks at level "i"
145  std::vector<block_t> ParticleBlocks; // stores block info for each block
146  std::vector<int> RequestedBlocks; // list of blocks to load
147  std::set<std::string> FileNames;
148
149 private:
150  vtkACosmoReader(const vtkACosmoReader&) = delete;
151  void operator=(const vtkACosmoReader&) = delete;
152 };
153
154 #endif
vtkObjectBase::operator=
vtkACosmoReader::MetadataIsLoaded
Definition: vtkACosmoReader.h:132
vtkACosmoReader::MetaData
vtkMultiBlockDataSet * MetaData
Definition: vtkACosmoReader.h:140
vtkInformationVector
vtkACosmoReader::Level
int Level
Definition: vtkACosmoReader.h:137
vtkACosmoReader::TotalNumberOfLevels
Definition: vtkACosmoReader.h:138
vtkMultiBlockDataSetAlgorithm::New
static vtkMultiBlockDataSetAlgorithm * New()
vtkACosmoReader::BoxSize
double BoxSize
Definition: vtkACosmoReader.h:134
vtkACosmoReader
Adaptively read a binary cosmology data file.
Definition: vtkACosmoReader.h:30
vtkMultiBlockDataSetAlgorithm::RequestData
virtual int RequestData(vtkInformation *, vtkInformationVector **, vtkInformationVector *)
vtkACosmoReader::ParticleBlocks
std::vector< block_t > ParticleBlocks
Definition: vtkACosmoReader.h:145
vtkACosmoReader::NBlocks
std::vector< int > NBlocks
Definition: vtkACosmoReader.h:142
vtkIndent
vtkACosmoReader::BaseFileName
Definition: vtkACosmoReader.h:130
vtkACosmoReader::FileNames
std::set< std::string > FileNames
Definition: vtkACosmoReader.h:147
vtkInformation
char * FileName
Definition: vtkACosmoReader.h:131
vtkACosmoReader::RequestedBlocks
std::vector< int > RequestedBlocks
Definition: vtkACosmoReader.h:146
vtkACosmoReader::ByteSwap
int ByteSwap
Definition: vtkACosmoReader.h:135
vtkUnstructuredGrid
vtkMultiBlockDataSetAlgorithm::PrintSelf
vtkMultiBlockDataSetAlgorithm::RequestInformation
virtual int RequestInformation(vtkInformation *, vtkInformationVector **, vtkInformationVector *)
vtkACosmoReader::TagSize
int TagSize
Definition: vtkACosmoReader.h:136
