pqVectorWidget.h
4 #ifndef pqVectorWidget_h
5 #define pqVectorWidget_h
6
7 #include "pqWidgetsModule.h"
9 #include <QVariant>
10 #include <QVector2D>
11 #include <QVector3D>
12 #include <QWidget>
13
17 class PQWIDGETS_EXPORT pqVectorWidget : public QWidget
18 {
19  Q_OBJECT
20  Q_PROPERTY(QVariant value READ value USER true);
21
22 public:
23  pqVectorWidget(const QVariant& value, QWidget* parent = nullptr);
24  ~pqVectorWidget() override = default;
25
29  const QVariant& value() const { return this->Vector; }
30
31 Q_SIGNALS:
35  void valueChanged(const QVariant&);
36
37 public Q_SLOTS:
38
43  virtual void setValue(int index, float value) = 0;
45 protected:
46  QVariant Vector;
47
52  void CreateUI(unsigned int nbElem);
53  virtual float getValue(int index) = 0;
54
55 private:
56  Q_DISABLE_COPY(pqVectorWidget);
57 };
58
63 template <class T, unsigned int S>
65 {
66 public:
67  pqVectorWidgetImpl(const T& value, QWidget* parent = nullptr)
68  : pqVectorWidget(value, parent)
69  {
70  // Create the UI with the specified templated number of elements
71  this->CreateUI(S);
72  }
73
74  T value() const { return this->Vector.template value<T>(); }
75
76  void setValue(int index, float value) override
77  {
78  T vec = this->Vector.template value<T>();
79  vec[index] = value;
80  this->Vector = QVariant::fromValue(vec);
81  Q_EMIT this->valueChanged(this->Vector);
82  }
83
84 protected:
85  float getValue(int index) override { return this->Vector.template value<T>()[index]; }
86 };
87
88 #endif
pqVectorWidgetImpl::value
T value() const
Definition: pqVectorWidget.h:74
pqVectorWidgetImpl::setValue
Set the value at index index of the QVariant with value.
Definition: pqVectorWidget.h:76
pqVectorWidget
pqVectorWidget is an abstract widget that can be used to edit a vector.
Definition: pqVectorWidget.h:17
pqVectorWidgetImpl::getValue
Definition: pqVectorWidget.h:85
pqVectorWidget::CreateUI
This function creates an horizontal layout with nbElem spinboxes.
pqVectorWidget::Vector
QVariant Vector
Definition: pqVectorWidget.h:46
pqVectorWidgetImpl::pqVectorWidgetImpl
pqVectorWidgetImpl(const T &value, QWidget *parent=nullptr)
Definition: pqVectorWidget.h:67
pqVectorWidget::valueChanged
void valueChanged(const QVariant &)
Signal emitted when any component value changed.
pqVectorWidgetImpl
pqVectorWidgetImpl is a templated class inherited from pqVectorWidget to be used with QVector classes...
Definition: pqVectorWidget.h:64
index
index
const QVariant & value() const
Get the value directly in vector form.
Definition: pqVectorWidget.h:29
