pqTreeWidgetItem.h
4 #ifndef pqTreeWidgetItem_h
5 #define pqTreeWidgetItem_h
6
7 #include "pqWidgetsModule.h"
8 #include <QTreeWidgetItem>
9
16 class PQWIDGETS_EXPORT pqTreeWidgetItem : public QTreeWidgetItem
17 {
18  typedef QTreeWidgetItem Superclass;
20 public:
21  pqTreeWidgetItem(int atype = UserType)
22  : Superclass(atype)
23  , CallbackHandler(nullptr)
24  {
25  }
26  pqTreeWidgetItem(const QStringList& strings, int atype = UserType)
27  : Superclass(strings, atype)
28  , CallbackHandler(nullptr)
29  {
30  }
31  pqTreeWidgetItem(QTreeWidget* aparent, int atype = UserType)
32  : Superclass(aparent, atype)
33  , CallbackHandler(nullptr)
34  {
35  }
36  pqTreeWidgetItem(QTreeWidget* aparent, const QStringList& strings, int atype = UserType)
37  : Superclass(aparent, strings, atype)
38  , CallbackHandler(nullptr)
39  {
40  }
41  pqTreeWidgetItem(QTreeWidget* aparent, QTreeWidgetItem* preceding, int atype = UserType)
42  : Superclass(aparent, preceding, atype)
43  , CallbackHandler(nullptr)
44  {
45  }
46  pqTreeWidgetItem(QTreeWidgetItem* aparent, int atype = UserType)
47  : Superclass(aparent, atype)
48  , CallbackHandler(nullptr)
49  {
50  }
51  pqTreeWidgetItem(QTreeWidgetItem* aparent, const QStringList& strings, int atype = UserType)
52  : Superclass(aparent, strings, atype)
53  , CallbackHandler(nullptr)
54  {
55  }
56  pqTreeWidgetItem(QTreeWidgetItem* aparent, QTreeWidgetItem* preceding, int atype = UserType)
57  : Superclass(aparent, preceding, atype)
58  , CallbackHandler(nullptr)
59  {
60  }
61
65  void setData(int column, int role, const QVariant& v) override;
66
68  {
69  public:
70  virtual ~pqCallbackHandler() = default;
71
75  virtual void dataAboutToChange(pqTreeWidgetItem* /*item*/, int /*column*/, int /*role*/){};
76
80  virtual void checkStateAboutToChange(pqTreeWidgetItem* /*item*/, int /*column*/){};
81
85  virtual void checkStateChanged(pqTreeWidgetItem* /*item*/, int /*column*/){};
86
90  virtual void dataChanged(pqTreeWidgetItem* /*item*/, int /*column*/, int /*role*/){};
91
95  virtual bool acceptChange(pqTreeWidgetItem* /*item*/, const QVariant& /*curValue*/,
96  const QVariant& /*newValue*/, int /*column*/, int /*role*/)
97  {
98  return true;
99  }
100  };
101
105  void setCallbackHandler(pqCallbackHandler* hdlr) { this->CallbackHandler = hdlr; }
106
107 protected:
109 };
110
111 #endif
pqTreeWidgetItem::pqTreeWidgetItem
pqTreeWidgetItem(QTreeWidgetItem *aparent, int atype=UserType)
Definition: pqTreeWidgetItem.h:46
pqTreeWidgetItem
pqTreeWidgetItem is a QTreeWidgetItem with callbacks for whenever the data for the pqTreeWidgetItem c...
Definition: pqTreeWidgetItem.h:16
pqTreeWidgetItem(const QStringList &strings, int atype=UserType)
Definition: pqTreeWidgetItem.h:26
pqTreeWidgetItem::pqCallbackHandler
Definition: pqTreeWidgetItem.h:67
pqTreeWidgetItem::pqCallbackHandler::checkStateAboutToChange
virtual void checkStateAboutToChange(pqTreeWidgetItem *, int)
Called to indicate that the data is about to be changed.
Definition: pqTreeWidgetItem.h:80
pqTreeWidgetItem(QTreeWidgetItem *aparent, QTreeWidgetItem *preceding, int atype=UserType)
Definition: pqTreeWidgetItem.h:56
pqTreeWidgetItem::CallbackHandler
pqCallbackHandler * CallbackHandler
Definition: pqTreeWidgetItem.h:108
pqTreeWidgetItem::pqCallbackHandler::checkStateChanged
virtual void checkStateChanged(pqTreeWidgetItem *, int)
Called to indicate that the check state for the item has been changed.
Definition: pqTreeWidgetItem.h:85
pqTreeWidgetItem::setCallbackHandler
void setCallbackHandler(pqCallbackHandler *hdlr)
Set the name of the callback slot to call.
Definition: pqTreeWidgetItem.h:105
pqTreeWidgetItem(QTreeWidget *aparent, const QStringList &strings, int atype=UserType)
Definition: pqTreeWidgetItem.h:36
pqTreeWidgetItem(QTreeWidgetItem *aparent, const QStringList &strings, int atype=UserType)
Definition: pqTreeWidgetItem.h:51
pqTreeWidgetItem(QTreeWidget *aparent, QTreeWidgetItem *preceding, int atype=UserType)
Definition: pqTreeWidgetItem.h:41
pqTreeWidgetItem(QTreeWidget *aparent, int atype=UserType)
Definition: pqTreeWidgetItem.h:31
pqTreeWidgetItem::pqCallbackHandler::dataAboutToChange
virtual void dataAboutToChange(pqTreeWidgetItem *, int, int)
Definition: pqTreeWidgetItem.h:75
pqTreeWidgetItem::pqCallbackHandler::acceptChange
virtual bool acceptChange(pqTreeWidgetItem *, const QVariant &, const QVariant &, int, int)
Called to check if the change has to be accepted or rejected.
Definition: pqTreeWidgetItem.h:95
pqTreeWidgetItem(int atype=UserType)
Definition: pqTreeWidgetItem.h:21
pqTreeWidgetItem::pqCallbackHandler::dataChanged
virtual void dataChanged(pqTreeWidgetItem *, int, int)
Called to indicate that the data has been changed.
Definition: pqTreeWidgetItem.h:90
