Functions
vtkGenericIOUtilities Namespace Reference
Functions
std::string & ltrim (std::string &s)
 Trims leading whitespace from a string. More...
std::string & rtrim (std::string &s)
 Trims trailing whitespace from a string. More...
std::string & trim (std::string &s)
 Trims leading & trailing whitespace from a string. More...
MPI_Comm GetMPICommunicator (vtkMultiProcessController *mpc)
 Returns the corresponding MPI communicator for the multi-process controller used by this instance. More...
vtkDataArray * GetVtkDataArray (std::string name, int type, void *rawBuffer, int N)
 This method parses the data in the rawbuffer and reads it into a vtkDataArray that can be attached as vtkPointData to a vtkDataSet, in this case, a vtkUnstructuredGrid that consists of the particles. More...
vtkIdType GetIdFromRawBuffer (const int type, void *buffer, vtkIdType buffer_idx)
 This method accesses the user-supplied buffer at the given index and returns the data as a vtkIdType. More...
double GetDoubleFromRawBuffer (const int type, void *buffer, vtkIdType buffer_idx)
 This method accesses the user-supplied buffer at the given index and returns the data as a double. More...
gio::GenericIOReader * GetReader (MPI_Comm comm, bool posix, int distribution, const std::string &fileName)
 This method constructs and returns the underlying GenericIO reader. More...
gio::GenericIOWriter * GetWriter (MPI_Comm comm, const std::string &fileName)
 This method constructs and returns the underlying GenericIO writer. More...
void SafeDeleteString (char *&str)
 If the pointer given is non-nullptr this function deletes the string and set the pointer to nullptr. More...
Function Documentation
◆ ltrim()
std::string& vtkGenericIOUtilities::ltrim ( std::string &  s)
inline
Definition at line 40 of file vtkGenericIOUtilities.h.
◆ rtrim()
std::string& vtkGenericIOUtilities::rtrim ( std::string &  s)
inline
Definition at line 53 of file vtkGenericIOUtilities.h.
◆ trim()
std::string& vtkGenericIOUtilities::trim ( std::string &  s)
inline
Definition at line 66 of file vtkGenericIOUtilities.h.
◆ GetMPICommunicator()
MPI_Comm vtkGenericIOUtilities::GetMPICommunicator ( vtkMultiProcessController *  mpc)
◆ GetVtkDataArray()
vtkDataArray* vtkGenericIOUtilities::GetVtkDataArray ( std::string  name,
int  type,
void *  rawBuffer,
int  N
◆ GetIdFromRawBuffer()
vtkIdType vtkGenericIOUtilities::GetIdFromRawBuffer ( const int  type,
void *  buffer,
It is intended as a convenience method to allow the user to access the data in an agnostic-type fashion.
◆ GetDoubleFromRawBuffer()
double vtkGenericIOUtilities::GetDoubleFromRawBuffer ( const int  type,
void *  buffer,
◆ GetReader()
gio::GenericIOReader* vtkGenericIOUtilities::GetReader ( MPI_Comm  comm,
bool  posix,
int  distribution,
const std::string &  fileName
◆ GetWriter()
gio::GenericIOWriter* vtkGenericIOUtilities::GetWriter ( MPI_Comm  comm,
The returned writer will have its filename set already
◆ SafeDeleteString()
void vtkGenericIOUtilities::SafeDeleteString ( char *&  str)
inline
This sets the pointer variable in the calling function since the pointer is passed by reference.
Definition at line 123 of file vtkGenericIOUtilities.h.
