Classes | Functions
SpyPlotHistoryReaderPrivate Namespace Reference
class  TimeStep
Functions
template<class T >
bool convert (const std::string &num, T &t)
void trim (std::string &string, const std::string &whitespace=" \t\"")
int rowFromHeaderCol (const std::string &str)
std::string nameFromHeaderCol (const std::string &str)
void split (const std::string &s, const char &delim, std::vector< std::string > &elems)
void getMetaHeaderInfo (const std::string &s, const char &delim, std::map< std::string, int > &fields, std::map< int, std::string > &lookup)
void getTimeStepInfo (const std::string &s, const char &delim, std::map< int, std::string > &lookup, std::map< std::string, std::string > &info)
std::vector< std::string > createTableLayoutFromHeader (std::string &header, const char &delim, std::map< int, int > &columnIndexToRowId, std::map< int, std::string > &fieldCols)
Function Documentation
◆ convert()
template<class T >
bool SpyPlotHistoryReaderPrivate::convert ( const std::string &  num,
T &  t
Definition at line 39 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ trim()
void SpyPlotHistoryReaderPrivate::trim ( std::string &  string,
const std::string &  whitespace = " \t\""
Definition at line 47 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ rowFromHeaderCol()
int SpyPlotHistoryReaderPrivate::rowFromHeaderCol ( const std::string &  str)
Definition at line 62 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ nameFromHeaderCol()
std::string SpyPlotHistoryReaderPrivate::nameFromHeaderCol ( const std::string &  str)
Definition at line 76 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ split()
void SpyPlotHistoryReaderPrivate::split ( const std::string &  s,
const char &  delim,
std::vector< std::string > &  elems
Definition at line 90 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ getMetaHeaderInfo()
void SpyPlotHistoryReaderPrivate::getMetaHeaderInfo ( const std::string &  s,
const char &  delim,
std::map< std::string, int > &  fields,
std::map< int, std::string > &  lookup
Definition at line 103 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ getTimeStepInfo()
void SpyPlotHistoryReaderPrivate::getTimeStepInfo ( const std::string &  s,
const char &  delim,
std::map< int, std::string > &  lookup,
std::map< std::string, std::string > &  info
Definition at line 136 of file vtkSpyPlotHistoryReaderPrivate.h.
◆ createTableLayoutFromHeader()
std::vector<std::string> SpyPlotHistoryReaderPrivate::createTableLayoutFromHeader ( std::string &  header,
const char &  delim,
std::map< int, int > &  columnIndexToRowId,
std::map< int, std::string > &  fieldCols
Definition at line 163 of file vtkSpyPlotHistoryReaderPrivate.h.
