| int | GetNumberOfAttributes () |
| | Get the number of distinct attribute values present in the file. More...
| const char * | GetAttributeName (int attribute) |
| | Get the name of an attribute. More...
| int | GetAttributeIndex (const char *name) |
| | Get the index of the attribute with the given name. More...
| int | GetNumberOfAttributeValues (int attribute) |
| | Get the number of distinct values for the given attribute. More...
| vtkXMLDataElement * | GetOutputXMLDataElement (int index) |
| | Get the vtkXMLDataElement representing the collection element corresponding to the output with the given index. More...
| virtual void | SetRestriction (const char *name, const char *value) |
| | Get/Set the required value for a particular named attribute. More...
| virtual const char * | GetRestriction (const char *name) |
| virtual void | SetRestrictionAsIndex (const char *name, int index) |
| | Get/set the required value for a particular named attribute. More...
| virtual int | GetRestrictionAsIndex (const char *name) |
| const char * | GetAttributeValue (int attribute, int index) |
| | Get one of the possible values for a given attribute. More...
| const char * | GetAttributeValue (const char *name, int index) |
| int | GetAttributeValueIndex (int attribute, const char *value) |
| | Get the index of the attribute value with the given name. More...
| int | GetAttributeValueIndex (const char *name, const char *value) |
| virtual void | SetForceOutputTypeToMultiBlock (int) |
| | If ForceOutputTypeToMultiBlock is set to 1, the output of this reader will always be a multi-block dataset, even if there is 1 simple output. More...
| virtual int | GetForceOutputTypeToMultiBlock () |
| virtual void | ForceOutputTypeToMultiBlockOn () |
| virtual void | ForceOutputTypeToMultiBlockOff () |
| vtkXMLReader * | NewInstance () const |
| virtual int | CanReadFile (const char *name) |
| virtual void | CopyOutputInformation (vtkInformation *vtkNotUsed(outInfo), int vtkNotUsed(port)) |
| virtual int | GetNumberOfTimeSteps () |
| virtual void | SetFileName (const char *) |
| virtual char * | GetFileName () |
| virtual void | SetReadFromInputString (int) |
| virtual int | GetReadFromInputString () |
| virtual void | ReadFromInputStringOn () |
| virtual void | ReadFromInputStringOff () |
| void | SetInputString (std::string s) |
| vtkDataSet * | GetOutputAsDataSet () |
| vtkDataSet * | GetOutputAsDataSet (int index) |
| virtual vtkDataArraySelection * | GetPointDataArraySelection () |
| virtual vtkDataArraySelection * | GetCellDataArraySelection () |
| int | GetNumberOfPointArrays () |
| int | GetNumberOfCellArrays () |
| const char * | GetPointArrayName (int index) |
| const char * | GetCellArrayName (int index) |
| int | GetPointArrayStatus (const char *name) |
| int | GetCellArrayStatus (const char *name) |
| void | SetPointArrayStatus (const char *name, int status) |
| void | SetCellArrayStatus (const char *name, int status) |
| virtual void | SetTimeStep (int) |
| virtual int | GetTimeStep () |
| virtual int * | GetTimeStepRange () |
| virtual void | GetTimeStepRange (int &, int &) |
| virtual void | GetTimeStepRange (int[2]) |
| virtual void | SetTimeStepRange (int, int) |
| void | SetTimeStepRange (int[2]) |
| vtkXMLDataParser * | GetXMLParser () |
| void | SetReaderErrorObserver (vtkCommand *) |
| virtual vtkCommand * | GetReaderErrorObserver () |
| void | SetParserErrorObserver (vtkCommand *) |
| virtual vtkCommand * | GetParserErrorObserver () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkXMLCollectionReader () |
| | ~vtkXMLCollectionReader () override |
| void | BuildRestrictedDataSets () |
| const char * | GetDataSetName () override |
| int | ReadPrimaryElement (vtkXMLDataElement *ePrimary) override |
| int | FillOutputPortInformation (int, vtkInformation *info) override |
| vtkDataObject * | SetupOutput (const std::string &filePath, int index) |
| vtkXMLReader * | SetupReader (const std::string &filePath, int index) |
| | Ensures that an appropriate reader is setup for the specified index. More...
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| void | SetupEmptyOutput () override |
| void | ReadXMLData () override |
| void | ReadXMLDataImpl () |
| virtual void | InternalProgressCallback () |
| void | AddAttributeNameValue (const char *name, const char *value) |
| virtual void | SetRestrictionImpl (const char *name, const char *value, bool doModify) |
| void | ReadAFile (int index, int updatePiece, int updateNumPieces, int updateGhostLevels, vtkDataObject *actualOutput) |
| void | FillArraySelectionUsingReaders (const std::string &filePath) |
| | iterating over all readers (which corresponds to number of distinct datasets in the file, and not distinct timesteps), populate this->*ArraySelection objects. More...
| | vtkXMLReader () |
| | ~vtkXMLReader () |
| virtual int | ReadXMLInformation () |
| virtual int | CanReadFileVersion (int major, int minor) |
| virtual void | SetupOutputInformation (vtkInformation *vtkNotUsed(outInfo)) |
| virtual void | SetupOutputData () |
| virtual int | ReadVTKFile (vtkXMLDataElement *eVTKFile) |
| vtkAbstractArray * | CreateArray (vtkXMLDataElement *da) |
| int | CreateInformationKey (vtkXMLDataElement *eInfoKey, vtkInformation *info) |
| bool | ReadInformation (vtkXMLDataElement *infoRoot, vtkInformation *info) |
| virtual int | OpenStream () |
| virtual void | CloseStream () |
| virtual int | OpenVTKFile () |
| virtual void | CloseVTKFile () |
| virtual int | OpenVTKString () |
| virtual void | CloseVTKString () |
| virtual void | CreateXMLParser () |
| virtual void | DestroyXMLParser () |
| void | SetupCompressor (const char *type) |
| int | CanReadFileVersionString (const char *version) |
| virtual int | CanReadFileWithDataType (const char *dsname) |
| virtual int | GetFileMajorVersion () |
| virtual int | GetFileMinorVersion () |
| int | IntersectExtents (int *extent1, int *extent2, int *result) |
| int | Min (int a, int b) |
| int | Max (int a, int b) |
| void | ComputePointDimensions (int *extent, int *dimensions) |
| void | ComputePointIncrements (int *extent, vtkIdType *increments) |
| void | ComputeCellDimensions (int *extent, int *dimensions) |
| void | ComputeCellIncrements (int *extent, vtkIdType *increments) |
| vtkIdType | GetStartTuple (int *extent, vtkIdType *increments, int i, int j, int k) |
| void | ReadAttributeIndices (vtkXMLDataElement *eDSA, vtkDataSetAttributes *dsa) |
| char ** | CreateStringArray (int numStrings) |
| void | DestroyStringArray (int numStrings, char **strings) |
| void | SetDataArraySelections (vtkXMLDataElement *eDSA, vtkDataArraySelection *sel) |
| int | SetFieldDataInfo (vtkXMLDataElement *eDSA, int association, int numTuples, vtkInformationVector *(&infoVector)) |
| int | PointDataArrayIsEnabled (vtkXMLDataElement *ePDA) |
| int | CellDataArrayIsEnabled (vtkXMLDataElement *eCDA) |
| virtual void | SqueezeOutputArrays (vtkDataObject *) |
| virtual void | GetProgressRange (float *range) |
| virtual void | SetProgressRange (const float range[2], int curStep, int numSteps) |
| virtual void | SetProgressRange (const float range[2], int curStep, const float *fractions) |
| virtual void | UpdateProgressDiscrete (float progress) |
| virtual int | RequestData (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) |
| virtual int | RequestDataObject (vtkInformation *vtkNotUsed(request), vtkInformationVector **vtkNotUsed(inputVector), vtkInformationVector *vtkNotUsed(outputVector)) |
| void | SetNumberOfTimeSteps (int num) |
| vtkDataObject * | GetCurrentOutput () |
| vtkInformation * | GetCurrentOutputInformation () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkObject () |
| | vtkObjectBase () |
