Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Static Protected Member Functions | Protected Attributes | List of all members
vtkUnstructuredPOPReader Class Reference
read NetCDF files More...
#include <vtkUnstructuredPOPReader.h>
Inheritance diagram for vtkUnstructuredPOPReader:
Collaboration diagram for vtkUnstructuredPOPReader:
typedef vtkUnstructuredGridAlgorithm Superclass
- Public Types inherited from vtkUnstructuredGridAlgorithm
enum  DesiredOutputPrecision
 The NetCDF file to open. More...
virtual char * GetFileName ()
virtual void SetStride (int, int, int)
 Enable subsampling in i,j and k dimensions for the topologically structured input data. More...
virtual void SetStride (int[3])
virtual int * GetStride ()
virtual void GetStride (int &, int &, int &)
virtual void GetStride (int[3])
virtual void SetVOI (int, int, int, int, int, int)
 Set the VOI of for the topologically structured input data. More...
virtual void SetVOI (int[6])
virtual int * GetVOI ()
virtual void GetVOI (int &, int &, int &, int &, int &, int &)
virtual void GetVOI (int[6])
virtual int GetNumberOfVariableArrays ()
 Variable array selection. More...
virtual const char * GetVariableArrayName (int idx)
virtual int GetVariableArrayStatus (const char *name)
virtual void SetVariableArrayStatus (const char *name, int status)
virtual void SetRadius (double)
 Set the outer radius of the Earth. More...
virtual double GetRadius ()
virtual int GetVectorGrid ()
 Determine whether or not the input data is being interpolated at the U/vector points or T/scalar points. More...
virtual void SetVerticalVelocity (bool)
 Specify whether or not to compute the vertical velocity component from the horizontal velocity components. More...
virtual bool GetVerticalVelocity ()
- Public Member Functions inherited from vtkUnstructuredGridAlgorithm
vtkUnstructuredGridAlgorithm * NewInstance () const
vtkDataObject * GetInput ()
vtkUnstructuredGrid * GetUnstructuredGridInput (int port)
vtkUnstructuredGrid * GetOutput ()
vtkUnstructuredGrid * GetOutput (int)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkUnstructuredPOPReader * SafeDownCast (vtkObject *o)
static vtkUnstructuredPOPReader * New ()
- Static Public Member Functions inherited from vtkUnstructuredGridAlgorithm
static vtkUnstructuredGridAlgorithm * New ()
static vtkUnstructuredGridAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkUnstructuredPOPReader ()
 ~vtkUnstructuredPOPReader () override
bool Transform (vtkUnstructuredGrid *grid, size_t *start, size_t *count, int *wholeExtent, int *subExtent, int numberOfGhostLevels, int wrapped, int piece, int numberOfPieces)
 Transform the grid from a topologically structured grid to a sphere shaped grid and do any vector transformations on field data that is needed. More...
int ProcessGrid (vtkUnstructuredGrid *grid, int piece, int numberOfPieces, int numberOfGhostLevels)
 Given the meta data about the grid partitioning, read in the data from the file and create the unstructured grid. More...
bool ReadMetaData (int wholeExtent[6])
 Reads the meta data from the NetCDF file for information like what variables exist and the dimensions of the grids and variables. More...
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
void LoadPointData (vtkUnstructuredGrid *grid, int netCDFFD, int varidp, size_t *start, size_t *count, ptrdiff_t *rStride, const char *arrayName)
 Adds a point data field given by varidp in the NetCDF file to the grid's point data. More...
void ComputeVerticalVelocity (vtkUnstructuredGrid *grid, int *wholeExtent, int *subExtent, int numberOfGhostLevels, int latlonFileId)
 Compute the vertical velocity component and add it into the velocity field. More...
void CommunicateParallelVerticalVelocity (int *wholeExtent, int *subExtent, int numberOfGhostLevels, VTKPointIterator &pointIterator, double *w)
 If the reader is being run in parallel, do the necessary communication to finish the vertical velocity integration on each process. More...
int GetPointOwnerPiece (int iIndex, int jIndex, int kKindex, int numberOfPieces, int numberOfGhostLevels, int *wholeExtent)
 Given ijk indices with respect to WholeExtent, return the process that is considered owning this point. More...
void GetPiecesNeedingPoint (int iIndex, int jIndex, int kKindex, int numberOfPieces, int numberOfGhostLevels, int *wholeExtent, vtkIdList *pieceIds)
 Given ijk indices, fill pieceIds with the pieces which contain need this point for computing the vertical velocity. More...
bool GetExtentInformation (int piece, int numberOfPieces, int numberOfGhostLevels, int *wholeExtent, int *subExtent)
 Given piece, numberOfPieces, numberOfGhostLevels, and wholeExtent, this method fills in subExtent. More...
bool BuildGhostInformation (vtkUnstructuredGrid *grid, int numberOfGhostLevels, int *wholeExtent, int *subExtent, int wrapped, int piece, int numberOfPieces)
 Build up the requested ghost information. More...
- Protected Member Functions inherited from vtkUnstructuredGridAlgorithm
 vtkUnstructuredGridAlgorithm ()
 ~vtkUnstructuredGridAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
static void SelectionModifiedCallback (vtkObject *caller, unsigned long eid, void *clientdata, void *calldata)
static void EventCallback (vtkObject *caller, unsigned long eid, void *clientdata, void *calldata)
vtkCallbackCommand * SelectionObserver
char * FileName
 The name of the file to be opened. More...
int Stride [3]
int NCDFFD
 The NetCDF file descriptor. More...
double Radius
 The radius of the sphere to be outputted in meters. More...
int VOI [6]
int VectorGrid
 Specify whether the grid points are at the vector field (U_LAT and U_LON) locations or the scalar field (T_LAT and T_LON) locations or unset. More...
bool VerticalVelocity
 If it is a vector grid (i.e. More...
bool SubsettingXMin
 State variables so that we know whether or not we are only reading in part of the grid. More...
bool SubsettingXMax
bool ReducedHeightResolution
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
char * OpenedFileName
 If a file is opened, the file name of the opened file. More...
virtual void SetOpenedFileName (const char *)
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
read NetCDF files
vtkUnstructuredPOPReader reads NetCDF POP files into a spherical shaped grid. The input file has topologically structured data. The striding and VOI are done with respect to the topologically structured ordering. Additionally, the z coordinates of the output grid are negated so that the first slice/plane has the highest z-value and the last slice/plane has the lowest z-value. Note that depth_t is used for the z location of the points. For VOI and striding, striding is done first and then the VOI is done. For example, if stride was [1, 2, 3] for a [3600, 2400, 42] grid then the wholeExtent would be [0, 3600, 0, 1200, 0, 14] and then a VOI of [10, 300, 0, 1400, 2 8] would result in a whole extent of [10, 300, 0, 1200, 2, 8] with the first point being [10, 0, 6] in the [3600, 2400, 42] original grid. The reader also requires a GRID.nc file in the same directory as the main file. This is used to map from tripolar logical coordinates to lat-lon coordinates.
Definition at line 38 of file vtkUnstructuredPOPReader.h.
Definition at line 42 of file vtkUnstructuredPOPReader.h.
◆ vtkUnstructuredPOPReader()
vtkUnstructuredPOPReader::vtkUnstructuredPOPReader ( )
◆ ~vtkUnstructuredPOPReader()
vtkUnstructuredPOPReader::~vtkUnstructuredPOPReader ( )
virtual const char* vtkUnstructuredPOPReader::GetClassName ( )
static int vtkUnstructuredPOPReader::IsTypeOf ( const char *  type)
virtual int vtkUnstructuredPOPReader::IsA ( const char *  type)
Reimplemented from vtkUnstructuredGridAlgorithm.
static vtkUnstructuredPOPReader* vtkUnstructuredPOPReader::SafeDownCast ( vtkObject *  o)
static vtkUnstructuredPOPReader* vtkUnstructuredPOPReader::New ( )
void vtkUnstructuredPOPReader::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkUnstructuredPOPReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkUnstructuredPOPReader::GetFileName ( )
◆ SetStride() [1/2]
virtual void vtkUnstructuredPOPReader::SetStride ( int  ,
int  ,
int
Note that if number of points in the z-direction are reduced that the vertical velocity will not be computed.
◆ SetStride() [2/2]
virtual void vtkUnstructuredPOPReader::SetStride ( int  [3])
◆ GetStride() [1/3]
virtual int* vtkUnstructuredPOPReader::GetStride ( )
◆ GetStride() [2/3]
virtual void vtkUnstructuredPOPReader::GetStride ( int &  ,
int &  ,
int &
◆ GetStride() [3/3]
virtual void vtkUnstructuredPOPReader::GetStride ( int  [3])
◆ SetVOI() [1/2]
virtual void vtkUnstructuredPOPReader::SetVOI ( int  ,
int  ,
int  ,
int  ,
int  ,
int
◆ SetVOI() [2/2]
virtual void vtkUnstructuredPOPReader::SetVOI ( int  [6])
◆ GetVOI() [1/3]
virtual int* vtkUnstructuredPOPReader::GetVOI ( )
◆ GetVOI() [2/3]
virtual void vtkUnstructuredPOPReader::GetVOI ( int &  ,
int &  ,
int &  ,
int &  ,
int &  ,
int &
◆ GetVOI() [3/3]
virtual void vtkUnstructuredPOPReader::GetVOI ( int  [6])
◆ GetNumberOfVariableArrays()
virtual int vtkUnstructuredPOPReader::GetNumberOfVariableArrays ( )
◆ GetVariableArrayName()
virtual const char* vtkUnstructuredPOPReader::GetVariableArrayName ( int  idx)
◆ GetVariableArrayStatus()
virtual int vtkUnstructuredPOPReader::GetVariableArrayStatus ( const char *  name)
◆ SetVariableArrayStatus()
virtual void vtkUnstructuredPOPReader::SetVariableArrayStatus ( const char *  name,
int  status
◆ SetRadius()
virtual void vtkUnstructuredPOPReader::SetRadius ( double  )
By default it is 6371000 which assumes the length is in meters.
◆ GetRadius()
virtual double vtkUnstructuredPOPReader::GetRadius ( )
◆ GetVectorGrid()
virtual int vtkUnstructuredPOPReader::GetVectorGrid ( )
0 means unset, 2 means vector field, and 1 means scalar field.
◆ SetVerticalVelocity()
virtual void vtkUnstructuredPOPReader::SetVerticalVelocity ( bool  )
Default is false which signifies do not compute.
◆ GetVerticalVelocity()
virtual bool vtkUnstructuredPOPReader::GetVerticalVelocity ( )
◆ RequestData()
int vtkUnstructuredPOPReader::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ SelectionModifiedCallback()
static void vtkUnstructuredPOPReader::SelectionModifiedCallback ( vtkObject *  caller,
unsigned long  eid,
void *  clientdata,
void *  calldata
staticprotected
◆ EventCallback()
static void vtkUnstructuredPOPReader::EventCallback ( vtkObject *  caller,
unsigned long  eid,
void *  clientdata,
void *  calldata
staticprotected
◆ SetOpenedFileName()
virtual void vtkUnstructuredPOPReader::SetOpenedFileName ( const char *  )
protectedvirtual
◆ Transform()
bool vtkUnstructuredPOPReader::Transform ( vtkUnstructuredGrid *  grid,
size_t *  start,
size_t *  count,
int *  wholeExtent,
int *  subExtent,
int  wrapped,
int  piece,
int  numberOfPieces
◆ ProcessGrid()
int vtkUnstructuredPOPReader::ProcessGrid ( vtkUnstructuredGrid *  grid,
int  piece,
int  numberOfPieces,
◆ ReadMetaData()
bool vtkUnstructuredPOPReader::ReadMetaData ( int  wholeExtent[6])
Returns true for success. Also fills out wholeExtent.
◆ RequestInformation()
int vtkUnstructuredPOPReader::RequestInformation ( vtkInformation *  request,
◆ LoadPointData()
void vtkUnstructuredPOPReader::LoadPointData ( vtkUnstructuredGrid *  grid,
int  netCDFFD,
int  varidp,
size_t *  start,
size_t *  count,
ptrdiff_t *  rStride,
const char *  arrayName
If the units is "centimeter/s" it scales the value by 1/100 (i.e. meter/s).
◆ ComputeVerticalVelocity()
void vtkUnstructuredPOPReader::ComputeVerticalVelocity ( vtkUnstructuredGrid *  grid,
int *  wholeExtent,
int *  subExtent,
int  latlonFileId
◆ CommunicateParallelVerticalVelocity()
void vtkUnstructuredPOPReader::CommunicateParallelVerticalVelocity ( int *  wholeExtent,
int *  subExtent,
VTKPointIterator &  pointIterator,
double *  w
◆ GetPointOwnerPiece()
int vtkUnstructuredPOPReader::GetPointOwnerPiece ( int  iIndex,
int  jIndex,
int  kKindex,
int  numberOfPieces,
int *  wholeExtent
Here the process that owns the piece will have compuated a valid vertical velocity value to share with other processes that need the integrated vertical velocity value. This method returns -1 if no appropriate piece is found.
◆ GetPiecesNeedingPoint()
void vtkUnstructuredPOPReader::GetPiecesNeedingPoint ( int  iIndex,
int  jIndex,
int  kKindex,
int  numberOfPieces,
int *  wholeExtent,
vtkIdList *  pieceIds
Note that the pieces with ghost points only used the reader are not included in the returned Id list. The indices are with respect to WholeExtent.
◆ GetExtentInformation()
bool vtkUnstructuredPOPReader::GetExtentInformation ( int  piece,
int  numberOfPieces,
int *  wholeExtent,
int *  subExtent
This method returns true for success.
◆ BuildGhostInformation()
bool vtkUnstructuredPOPReader::BuildGhostInformation ( vtkUnstructuredGrid *  grid,
int *  wholeExtent,
int *  subExtent,
int  wrapped,
int  piece,
int  numberOfPieces
Note that if the vertical velocity is computed that the reader needs an extra layer of ghost cells. This extra layer is removed before RequestData() is exited. The method returns true for success.
◆ SelectionObserver
vtkCallbackCommand* vtkUnstructuredPOPReader::SelectionObserver
Definition at line 123 of file vtkUnstructuredPOPReader.h.
◆ FileName
char* vtkUnstructuredPOPReader::FileName
Definition at line 128 of file vtkUnstructuredPOPReader.h.
◆ OpenedFileName
char* vtkUnstructuredPOPReader::OpenedFileName
Definition at line 134 of file vtkUnstructuredPOPReader.h.
◆ Stride
int vtkUnstructuredPOPReader::Stride[3]
Definition at line 135 of file vtkUnstructuredPOPReader.h.
◆ NCDFFD
int vtkUnstructuredPOPReader::NCDFFD
Definition at line 143 of file vtkUnstructuredPOPReader.h.
◆ Radius
double vtkUnstructuredPOPReader::Radius
The default value is 6371000.
Definition at line 149 of file vtkUnstructuredPOPReader.h.
◆ VOI
int vtkUnstructuredPOPReader::VOI[6]
Definition at line 151 of file vtkUnstructuredPOPReader.h.
◆ SubsettingXMin
bool vtkUnstructuredPOPReader::SubsettingXMin
SubsettingXMin and SubsettingXMax are used so that we can properly connect the grid in the longitudinal direction. We only compute the vertical velocity if we have the full height resolution of the grid.
Definition at line 161 of file vtkUnstructuredPOPReader.h.
◆ SubsettingXMax
bool vtkUnstructuredPOPReader::SubsettingXMax
Definition at line 162 of file vtkUnstructuredPOPReader.h.
◆ ReducedHeightResolution
bool vtkUnstructuredPOPReader::ReducedHeightResolution
Definition at line 163 of file vtkUnstructuredPOPReader.h.
◆ VectorGrid
int vtkUnstructuredPOPReader::VectorGrid
Definition at line 171 of file vtkUnstructuredPOPReader.h.
◆ VerticalVelocity
bool vtkUnstructuredPOPReader::VerticalVelocity
VectorGrid=2) then specify whether or not to compute the vertical velocity. This can be a costly computation so if the vertical velocity is not needed then keep this off (the default).
Definition at line 179 of file vtkUnstructuredPOPReader.h.
