vtkTimeToTextConvertor Class Reference
#include <vtkTimeToTextConvertor.h>
Inheritance diagram for vtkTimeToTextConvertor:
Collaboration diagram for vtkTimeToTextConvertor:
typedef vtkTableAlgorithm Superclass
- Public Types inherited from vtkTableAlgorithm
enum  DesiredOutputPrecision
virtual void SetFormat (const char *)
 Get/Set the format in which the to display the input update time. More...
virtual char * GetFormat ()
virtual void SetShift (double)
 Apply a translation to the time. More...
virtual double GetShift ()
virtual void SetScale (double)
 Apply a scale to the time. More...
virtual double GetScale ()
- Public Member Functions inherited from vtkTableAlgorithm
vtkTableAlgorithm * NewInstance () const
vtkTable * GetOutput ()
vtkTable * GetOutput (int index)
void SetInputData (vtkDataObject *obj)
void SetInputData (int index, vtkDataObject *obj)
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkTimeToTextConvertor * New ()
static vtkTimeToTextConvertor * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkTableAlgorithm
static vtkTableAlgorithm * New ()
static vtkTableAlgorithm * SafeDownCast (vtkObjectBase *o)
static vtkAlgorithm * New ()
 vtkTimeToTextConvertor ()
 ~vtkTimeToTextConvertor () override
int RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override
- Protected Member Functions inherited from vtkTableAlgorithm
 vtkTableAlgorithm ()
 ~vtkTableAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
char * Format
double Shift
double Scale
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter can be attached to any filter/source/reader that supports time. vtkTimeToTextConvertor will generate a 1x1 vtkTable with the string for the data time using the format specified. The input to this filter is optional. If no input is specified, it will show produce request time in the output.
Definition at line 19 of file vtkTimeToTextConvertor.h.
Definition at line 23 of file vtkTimeToTextConvertor.h.
◆ vtkTimeToTextConvertor()
vtkTimeToTextConvertor::vtkTimeToTextConvertor ( )
◆ ~vtkTimeToTextConvertor()
vtkTimeToTextConvertor::~vtkTimeToTextConvertor ( )
static vtkTimeToTextConvertor* vtkTimeToTextConvertor::New ( )
virtual const char* vtkTimeToTextConvertor::GetClassName ( )
static int vtkTimeToTextConvertor::IsTypeOf ( const char *  type)
virtual int vtkTimeToTextConvertor::IsA ( const char *  type)
Reimplemented from vtkTableAlgorithm.
static vtkTimeToTextConvertor* vtkTimeToTextConvertor::SafeDownCast ( vtkObject *  o)
void vtkTimeToTextConvertor::PrintSelf ( ostream &  os,
◆ SetFormat()
virtual void vtkTimeToTextConvertor::SetFormat ( const char *  )
Use fmt formatting. Default is "Time: {time:f}".
◆ GetFormat()
virtual char* vtkTimeToTextConvertor::GetFormat ( )
◆ SetShift()
virtual void vtkTimeToTextConvertor::SetShift ( double  )
◆ GetShift()
virtual double vtkTimeToTextConvertor::GetShift ( )
◆ SetScale()
virtual void vtkTimeToTextConvertor::SetScale ( double  )
◆ GetScale()
virtual double vtkTimeToTextConvertor::GetScale ( )
◆ FillInputPortInformation()
int vtkTimeToTextConvertor::FillInputPortInformation ( int  port,
vtkInformation *  info
overrideprotectedvirtual
◆ RequestData()
int vtkTimeToTextConvertor::RequestData ( vtkInformation *  request,
◆ RequestInformation()
int vtkTimeToTextConvertor::RequestInformation ( vtkInformation *  request,
◆ Format
char* vtkTimeToTextConvertor::Format
Definition at line 63 of file vtkTimeToTextConvertor.h.
◆ Shift
double vtkTimeToTextConvertor::Shift
Definition at line 64 of file vtkTimeToTextConvertor.h.
◆ Scale
double vtkTimeToTextConvertor::Scale
Definition at line 65 of file vtkTimeToTextConvertor.h.
