Classes | Public Types | Public Member Functions | Static Public Member Functions | Public Attributes | Protected Member Functions | Protected Attributes | List of all members
vtkSpyPlotUniReader Class Reference
Read SPCTH Spy Plot file format. More...
#include <vtkSpyPlotUniReader.h>
Inheritance diagram for vtkSpyPlotUniReader:
Collaboration diagram for vtkSpyPlotUniReader:
struct  CellMaterialField
struct  DataDump
struct  MarkerDump
struct  MarkerMaterialField
struct  MaterialMarker
struct  Variable
virtual int ReadInformation ()
 Reads the basic information from the file such as the header, number of fields, etc. More...
int MakeCurrent ()
 Make sure that actual data (including grid blocks) is current else it will read in the required data from file. More...
void PrintInformation ()
void PrintMemoryUsage ()
virtual int GetNumberOfCellFields ()
double * GetTimeArray ()
int IsAMR ()
 Returns 1 if the grid information contained in the file has Adaptive Mesh Refinement (AMR) else it returns 0. More...
int GetNumberOfDataBlocks ()
 Return the number of grids in the reader. More...
const char * GetCellFieldName (int field)
 Return the name of the ith field. More...
vtkDataArray * GetCellFieldData (int block, int field, int *fixed)
 Return the data array of the block's field. More...
vtkDataArray * GetMaterialMassField (const int &block, const int &materialIndex)
 Return the mass data array for the material index passed in for the passed in block. More...
vtkDataArray * GetMaterialVolumeFractionField (const int &block, const int &materialIndex)
 Return the volume fraction data array for the material index passed in for the passed in block. More...
int MarkCellFieldDataFixed (int block, int field)
 Mark the block's field to have been fixed w/r bad ghost cells. More...
vtkFloatArray * GetTracers ()
 Return the data array for the tracer positions. More...
vtkSpyPlotBlock * GetBlock (int i)
int GetNumberOfMaterials () const
int GetNumberOfDimensions () const
int GetCoordinateSystem () const
virtual void SetGenerateMarkers (int)
virtual int GetGenerateMarkers ()
virtual int GetMarkersOn ()
vtkSpyPlotBlock * GetDataBlock (int block)
virtual void SetDataTypeChanged (int)
void SetDownConvertVolumeFraction (int vf)
 Set and get the Binary SpyPlot File name the reader will process. More...
virtual char * GetFileName ()
virtual void SetCellArraySelection (vtkDataArraySelection *da)
int SetCurrentTime (double time)
 Set and get the current time step to process. More...
virtual double GetCurrentTime ()
int SetCurrentTimeStep (int timeStep)
virtual int GetCurrentTimeStep ()
virtual int * GetTimeStepRange ()
 Set and Get the time range for the simulation run. More...
virtual void GetTimeStepRange (int &, int &)
virtual void GetTimeStepRange (int[2])
virtual double * GetTimeRange ()
virtual void GetTimeRange (double &, double &)
virtual void GetTimeRange (double[2])
virtual void SetNeedToCheck (int)
int GetTimeStepFromTime (double time)
 Functions that map from time to time step and vice versa. More...
double GetTimeFromTimeStep (int timeStep)
static vtkSpyPlotUniReader * SafeDownCast (vtkObject *o)
static vtkSpyPlotUniReader * New ()
Public Attributes
MaterialMarker * Markers
MarkerDump * MarkersDumps
 vtkSpyPlotUniReader ()
 ~vtkSpyPlotUniReader () override
vtkSpyPlotBlock * Blocks
vtkSpyPlotUniReader is a reader that reads SPCTH Spy Plot file binary format that describes part of a dataset (in the case that the simulation consists of more than 1 file) or the entire simulation. The reader supports both Spy dataset types: flat mesh and AMR (Adaptive Mesh Refinement).
Implementation Details:
Class was extracted from vtkSpyPlotReader.cxx and is a helper to that class. Note the grids in the reader may have bad ghost cells that will need to be taken into consideration in terms of both geometry and
cell data
Definition at line 36 of file vtkSpyPlotUniReader.h.
Definition at line 39 of file vtkSpyPlotUniReader.h.
◆ vtkSpyPlotUniReader()
vtkSpyPlotUniReader::vtkSpyPlotUniReader ( )
◆ ~vtkSpyPlotUniReader()
vtkSpyPlotUniReader::~vtkSpyPlotUniReader ( )
virtual const char* vtkSpyPlotUniReader::GetClassName ( )
static int vtkSpyPlotUniReader::IsTypeOf ( const char *  type)
virtual int vtkSpyPlotUniReader::IsA ( const char *  type)
static vtkSpyPlotUniReader* vtkSpyPlotUniReader::SafeDownCast ( vtkObject *  o)
static vtkSpyPlotUniReader* vtkSpyPlotUniReader::New ( )
void vtkSpyPlotUniReader::PrintSelf ( ostream &  os,
◆ SetFileName()
virtual void vtkSpyPlotUniReader::SetFileName ( const char *  )
◆ GetFileName()
virtual char* vtkSpyPlotUniReader::GetFileName ( )
◆ SetCellArraySelection()
virtual void vtkSpyPlotUniReader::SetCellArraySelection ( vtkDataArraySelection *  da)
◆ ReadInformation()
virtual int vtkSpyPlotUniReader::ReadInformation ( )
◆ MakeCurrent()
int vtkSpyPlotUniReader::MakeCurrent ( )
◆ PrintInformation()
void vtkSpyPlotUniReader::PrintInformation ( )
◆ PrintMemoryUsage()
void vtkSpyPlotUniReader::PrintMemoryUsage ( )
◆ SetCurrentTime()
int vtkSpyPlotUniReader::SetCurrentTime ( double  time)
◆ GetCurrentTime()
virtual double vtkSpyPlotUniReader::GetCurrentTime ( )
◆ SetCurrentTimeStep()
int vtkSpyPlotUniReader::SetCurrentTimeStep ( int  timeStep)
◆ GetCurrentTimeStep()
virtual int vtkSpyPlotUniReader::GetCurrentTimeStep ( )
◆ GetTimeStepRange() [1/3]
virtual int* vtkSpyPlotUniReader::GetTimeStepRange ( )
◆ GetTimeStepRange() [2/3]
virtual void vtkSpyPlotUniReader::GetTimeStepRange ( int &  ,
int &
◆ GetTimeStepRange() [3/3]
virtual void vtkSpyPlotUniReader::GetTimeStepRange ( int  [2])
◆ GetTimeRange() [1/3]
virtual double* vtkSpyPlotUniReader::GetTimeRange ( )
◆ GetTimeRange() [2/3]
virtual void vtkSpyPlotUniReader::GetTimeRange ( double &  ,
double &
◆ GetTimeRange() [3/3]
virtual void vtkSpyPlotUniReader::GetTimeRange ( double  [2])
◆ SetNeedToCheck()
virtual void vtkSpyPlotUniReader::SetNeedToCheck ( int  )
◆ GetTimeStepFromTime()
int vtkSpyPlotUniReader::GetTimeStepFromTime ( double  time)
◆ GetTimeFromTimeStep()
double vtkSpyPlotUniReader::GetTimeFromTimeStep ( int  timeStep)
◆ GetNumberOfCellFields()
virtual int vtkSpyPlotUniReader::GetNumberOfCellFields ( )
◆ GetTimeArray()
double * vtkSpyPlotUniReader::GetTimeArray ( )
inline
Definition at line 313 of file vtkSpyPlotUniReader.h.
◆ IsAMR()
int vtkSpyPlotUniReader::IsAMR ( )
inline
Definition at line 318 of file vtkSpyPlotUniReader.h.
◆ GetNumberOfDataBlocks()
int vtkSpyPlotUniReader::GetNumberOfDataBlocks ( )
◆ GetCellFieldName()
const char* vtkSpyPlotUniReader::GetCellFieldName ( int  field)
◆ GetCellFieldData()
vtkDataArray* vtkSpyPlotUniReader::GetCellFieldData ( int  block,
int  field,
int *  fixed
The "fixed" argument is set to 1 if the array has been corrected for bad ghost cells else it is set to 0
◆ GetMaterialMassField()
vtkDataArray* vtkSpyPlotUniReader::GetMaterialMassField ( const int &  block,
const int &  materialIndex
◆ GetMaterialVolumeFractionField()
vtkDataArray* vtkSpyPlotUniReader::GetMaterialVolumeFractionField ( const int &  block,
◆ MarkCellFieldDataFixed()
int vtkSpyPlotUniReader::MarkCellFieldDataFixed ( int  block,
int  field
◆ GetTracers()
vtkFloatArray* vtkSpyPlotUniReader::GetTracers ( )
◆ GetBlock()
vtkSpyPlotBlock* vtkSpyPlotUniReader::GetBlock ( int  i)
◆ GetNumberOfMaterials()
int vtkSpyPlotUniReader::GetNumberOfMaterials ( ) const
inline
Definition at line 153 of file vtkSpyPlotUniReader.h.
◆ GetNumberOfDimensions()
int vtkSpyPlotUniReader::GetNumberOfDimensions ( ) const
inline
Definition at line 156 of file vtkSpyPlotUniReader.h.
◆ GetCoordinateSystem()
int vtkSpyPlotUniReader::GetCoordinateSystem ( ) const
inline
Definition at line 159 of file vtkSpyPlotUniReader.h.
◆ SetGenerateMarkers()
virtual void vtkSpyPlotUniReader::SetGenerateMarkers ( int  )
◆ GetGenerateMarkers()
virtual int vtkSpyPlotUniReader::GetGenerateMarkers ( )
◆ GetMarkersOn()
virtual int vtkSpyPlotUniReader::GetMarkersOn ( )
◆ GetDataBlock()
vtkSpyPlotBlock* vtkSpyPlotUniReader::GetDataBlock ( int  block)
◆ SetDataTypeChanged()
virtual void vtkSpyPlotUniReader::SetDataTypeChanged ( int  )
◆ SetDownConvertVolumeFraction()
void vtkSpyPlotUniReader::SetDownConvertVolumeFraction ( int  vf)
◆ Markers
MaterialMarker* vtkSpyPlotUniReader::Markers
Definition at line 214 of file vtkSpyPlotUniReader.h.
◆ MarkersDumps
MarkerDump* vtkSpyPlotUniReader::MarkersDumps
Definition at line 215 of file vtkSpyPlotUniReader.h.
◆ Blocks
vtkSpyPlotBlock* vtkSpyPlotUniReader::Blocks
Definition at line 229 of file vtkSpyPlotUniReader.h.
