Serialize/deserialize vtkSelection to/from xml.
vtkSelectionSerializer is a helper class that can serialize/deserialize vtkSelection to/from xml. Currently, it supports only a subset of properties: CONTENT_TYPE, SOURCE_ID, PROP_ID, PROCESS_ID, ORIGINAL_SOURCE_ID
- See also
- vtkSelection
Definition at line 26 of file vtkSelectionSerializer.h.
| static void vtkSelectionSerializer::Parse |
const char * |
xml, |
vtkSelection * |
root |
Parse an xml string to create a new selection tree.
The string is 0 terminated for the first version of this function, or we specify the length of the string for the second version. Currently, this supports only a subset of properties: CONTENT_TYPE, SOURCE_ID, PROP_ID, PROCESS_ID
const char * |
xml, |
unsigned int |
length, |
vtkSelection * |
root |
