Selects arrays and extracts blocks. More...
#include <vtkSelectArraysExtractBlocks.h>
| typedef vtkCompositeDataSetAlgorithm | Superclass |
Public Types inherited from vtkCompositeDataSetAlgorithm | |
| typedef vtkAlgorithm | Superclass |
Public Types inherited from vtkAlgorithm | |
| enum | DesiredOutputPrecision |
| vtkMTimeType | GetMTime () override |
| Override GetMTime because we rely on internal filters that have their own MTime. More... | |
| virtual void | SetPassArraysEnabled (bool) |
| Enable/disable the internal vtkPassSelectedArrays filter. More... | |
| virtual bool | GetPassArraysEnabled () |
| virtual void | PassArraysEnabledOn () |
| virtual void | PassArraysEnabledOff () |
| virtual void | SetExtractBlocksEnabled (bool) |
| Enable/disable the internal vtkExtractBlockUsingDataAssembly filter. More... | |
| virtual bool | GetExtractBlocksEnabled () |
| virtual void | ExtractBlocksEnabledOn () |
| virtual void | ExtractBlocksEnabledOff () |
| vtkDataArraySelection * | GetPointDataArraySelection () |
Convenience methods that call GetArraySelection with corresponding association type. More... | |
| vtkDataArraySelection * | GetCellDataArraySelection () |
| vtkDataArraySelection * | GetFieldDataArraySelection () |
| vtkDataArraySelection * | GetVertexDataArraySelection () |
| vtkDataArraySelection * | GetEdgeDataArraySelection () |
| vtkDataArraySelection * | GetRowDataArraySelection () |
| bool | AddSelector (const char *selector) |
| API to set selectors. More... | |
| void | ClearSelectors () |
| void | SetAssemblyName (const char *assemblyName) |
| Get/Set the active assembly to use. More... | |
| const char * | GetAssemblyName () const |
Public Member Functions inherited from vtkCompositeDataSetAlgorithm | |
| vtkCompositeDataSetAlgorithm * | NewInstance () const |
| vtkCompositeDataSet * | GetOutput () |
| vtkCompositeDataSet * | GetOutput (int) |
Public Member Functions inherited from vtkAlgorithm | |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
Public Attributes inherited from vtkAlgorithm | |
| SINGLE_PRECISION | |
| DOUBLE_PRECISION | |
| DEFAULT_PRECISION | |
| int | AbortExecute |
Static Protected Member Functions inherited from vtkAlgorithm | |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
Protected Attributes inherited from vtkAlgorithm | |
| vtkInformation * | Information |
| double | Progress |
| char * | ProgressText |
| vtkProgressObserver * | ProgressObserver |
| unsigned long | ErrorCode |
Static Protected Attributes inherited from vtkAlgorithm | |
| static vtkExecutive * | DefaultExecutivePrototype |
vtkSelectArraysExtractBlocks is a meta-filter combining the vtkPassSelectedArrays and vtkExtractBlockUsingDataAssembly filters. It is intended to be used as a pre-processing filter for certain composite writers. It adds the possibility to choose the blocks to write, in addition to the data arrays.
Definition at line 24 of file vtkSelectArraysExtractBlocks.h.
Definition at line 29 of file vtkSelectArraysExtractBlocks.h.
Reimplemented from vtkCompositeDataSetAlgorithm.
When disabled, this filter passes all input arrays irrespective of the array selection. Default is true.
When disabled, this filter passes all input blocks irrespective of the block selection. Default is true.
| vtkDataArraySelection* vtkSelectArraysExtractBlocks::GetPointDataArraySelection | ( | ) |
Forwarded to internal vtkPassSelectedArrays filter.
| vtkDataArraySelection* vtkSelectArraysExtractBlocks::GetCellDataArraySelection | ( | ) |
| vtkDataArraySelection* vtkSelectArraysExtractBlocks::GetFieldDataArraySelection | ( | ) |
| vtkDataArraySelection* vtkSelectArraysExtractBlocks::GetVertexDataArraySelection | ( | ) |
| vtkDataArraySelection* vtkSelectArraysExtractBlocks::GetEdgeDataArraySelection | ( | ) |
| vtkDataArraySelection* vtkSelectArraysExtractBlocks::GetRowDataArraySelection | ( | ) |
| bool vtkSelectArraysExtractBlocks::AddSelector | ( | const char * | selector | ) |
Multiple selectors can be added using AddSelector. The order in which selectors are specified is not preserved and has no impact on the result.
AddSelector returns true if the selector was added, false if the selector was already specified and hence not added.
Forwarded to internal vtkExtractBlockUsingDataAssembly filter.
| void vtkSelectArraysExtractBlocks::ClearSelectors | ( | ) |
| void vtkSelectArraysExtractBlocks::SetAssemblyName | ( | const char * | assemblyName | ) |
The chosen assembly is used in combination with the selectors specified to determine which blocks are to be extracted.
By default, this is set to vtkDataAssemblyUtilities::HierarchyName().
| const char* vtkSelectArraysExtractBlocks::GetAssemblyName | ( | ) | const |
overrideprotectedvirtual |
