vtkSMTransferFunctionManager Class Reference
manages transfer functions i.e. color lookuptables and opacity piecewise functions for ParaView applications. More...
#include <vtkSMTransferFunctionManager.h>
Inheritance diagram for vtkSMTransferFunctionManager:
Collaboration diagram for vtkSMTransferFunctionManager:
enum  UpdateScalarBarsMode { HIDE_UNUSED_SCALAR_BARS = 0x01, SHOW_USED_SCALAR_BARS = 0x02 }
enum  TransferFunctionResetMode {
  NEVER = -1, GROW_ON_APPLY = 0, GROW_ON_APPLY_AND_TIMESTEP = 1, RESET_ON_APPLY = 2,
  RESET_ON_APPLY_AND_TIMESTEP = 3
 Enum for TransferFunctionResetMode. More...
virtual vtkSMProxy * GetColorTransferFunction (const char *arrayName, vtkSMSessionProxyManager *pxm)
 Returns a color transfer function proxy instance for mapping a data array with the given name. More...
virtual vtkSMProxy * GetOpacityTransferFunction (const char *arrayName, vtkSMSessionProxyManager *pxm)
 Returns a opacity transfer function proxy (aka Piecewise Function) instance for mapping a data array with the given name. More...
virtual vtkSMProxy * GetTransferFunction2D (const char *arrayName, vtkSMSessionProxyManager *pxm)
 Returns a 2D transfer function proxy (aka Image Data) instance. More...
virtual vtkSMProxy * GetTransferFunction2D (const char *arrayName, const char *array2Name, vtkSMSessionProxyManager *pxm)
virtual vtkSMProxy * GetScalarBarRepresentation (vtkSMProxy *colorTransferFunctionProxy, vtkSMProxy *view)
 Returns the scalar-bar (color-legend) representation corresponding to the transfer function for the view (currently only render-views are supported). More...
void ResetAllTransferFunctionRangesUsingCurrentData (vtkSMSessionProxyManager *pxm, bool animating=false)
 Iterates over all "known" transfer function proxies and request each one of them to update its range using data information currently available. More...
virtual bool UpdateScalarBars (vtkSMProxy *viewProxy, unsigned int mode)
 Updates the scalar bar visibility in the view. More...
virtual bool UpdateScalarBarsComponentTitle (vtkSMProxy *lutProxy, vtkSMProxy *representation)
 Updates all scalar bars using provided lutProxy, the representation is used to recover the component title. More...
virtual bool HideScalarBarIfNotNeeded (vtkSMProxy *lutProxy, vtkSMProxy *view)
 Hides the scalar bar, if any, for the lutProxy in the view if it's not being used. More...
static vtkSMTransferFunctionManager * New ()
static vtkSMTransferFunctionManager * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMTransferFunctionManager ()
 ~vtkSMTransferFunctionManager () override
 vtkSMObject ()
 ~vtkSMObject () override
vtkSMTransferFunctionManager manages transfer functions i.e. color lookuptables and opacity piecewise functions for ParaView applications. vtkSMTransferFunctionManager implements the ParaView specific mechanism for managing such transfer function proxies where there's one transfer function created and maintained per data array name.
vtkSMTransferFunctionManager has no state. You can create as many instances as per your choosing to call the methods. It uses the session proxy manager to locate proxies registered using specific names under specific groups. Thus, the state is maintained by the proxy manager itself.
Definition at line 29 of file vtkSMTransferFunctionManager.h.
Definition at line 33 of file vtkSMTransferFunctionManager.h.
◆ UpdateScalarBarsMode
Enumerator
Definition at line 78 of file vtkSMTransferFunctionManager.h.
◆ TransferFunctionResetMode
Enumerator
NEVER
GROW_ON_APPLY
RESET_ON_APPLY
Definition at line 87 of file vtkSMTransferFunctionManager.h.
◆ vtkSMTransferFunctionManager()
vtkSMTransferFunctionManager::vtkSMTransferFunctionManager ( )
◆ ~vtkSMTransferFunctionManager()
vtkSMTransferFunctionManager::~vtkSMTransferFunctionManager ( )
static vtkSMTransferFunctionManager* vtkSMTransferFunctionManager::New ( )
virtual const char* vtkSMTransferFunctionManager::GetClassName ( )
static int vtkSMTransferFunctionManager::IsTypeOf ( const char *  type)
virtual int vtkSMTransferFunctionManager::IsA ( const char *  type)
static vtkSMTransferFunctionManager* vtkSMTransferFunctionManager::SafeDownCast ( vtkObject *  o)
void vtkSMTransferFunctionManager::PrintSelf ( ostream &  os,
◆ GetColorTransferFunction()
virtual vtkSMProxy* vtkSMTransferFunctionManager::GetColorTransferFunction ( const char *  arrayName,
vtkSMSessionProxyManager *  pxm
If none exists in the given session, a new instance will be created and returned.
◆ GetOpacityTransferFunction()
virtual vtkSMProxy* vtkSMTransferFunctionManager::GetOpacityTransferFunction ( const char *  arrayName,
◆ GetTransferFunction2D() [1/2]
virtual vtkSMProxy* vtkSMTransferFunctionManager::GetTransferFunction2D ( const char *  arrayName,
◆ GetTransferFunction2D() [2/2]
const char *  array2Name,
◆ GetScalarBarRepresentation()
virtual vtkSMProxy* vtkSMTransferFunctionManager::GetScalarBarRepresentation ( vtkSMProxy *  colorTransferFunctionProxy,
vtkSMProxy *  view
Thus returns an existing proxy, if present, otherwise a new one is created, if possible.
◆ ResetAllTransferFunctionRangesUsingCurrentData()
void vtkSMTransferFunctionManager::ResetAllTransferFunctionRangesUsingCurrentData ( vtkSMSessionProxyManager *  pxm,
bool  animating = false
Set animating to true if this is called in the context of an animation, false otherwise.
◆ UpdateScalarBars()
virtual bool vtkSMTransferFunctionManager::UpdateScalarBars ( vtkSMProxy *  viewProxy,
unsigned int  mode
Based on the specified mode, scalars bars representing non-represented arrays can be automatically hidden; and those corresponding to arrays used for coloring can be automatically shown.
◆ UpdateScalarBarsComponentTitle()
virtual bool vtkSMTransferFunctionManager::UpdateScalarBarsComponentTitle ( vtkSMProxy *  lutProxy,
vtkSMProxy *  representation
◆ HideScalarBarIfNotNeeded()
virtual bool vtkSMTransferFunctionManager::HideScalarBarIfNotNeeded ( vtkSMProxy *  lutProxy,
vtkSMProxy *  view
Returns true if the scalar bar visibility was changed.
